[Mapbender-commits] r6698 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 5 08:40:36 EDT 2010
Author: christoph
Date: 2010-08-05 12:40:36 +0000 (Thu, 05 Aug 2010)
New Revision: 6698
   trunk/mapbender/http/classes/class_map.php
bugfix: when loadFromSession is used, CRS is always EPSG:4326. Now, the application CRS is used.
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php	2010-08-05 12:18:37 UTC (rev 6697)
+++ trunk/mapbender/http/classes/class_map.php	2010-08-05 12:40:36 UTC (rev 6698)
@@ -279,7 +279,7 @@
 				for ($i = 0; $i < count($currentWms->objLayer[0]->layer_epsg); $i++) {
 					$currentLayerEpsg = $currentWms->objLayer[0]->layer_epsg[$i];
 					if ($currentLayerEpsg["epsg"] !== $srs) {
-						if ($currentLayerEpsg["epsg"] = "EPSG:4326") {
+						if ($currentLayerEpsg["epsg"] === "EPSG:4326") {
 							$wgs84Index = $i;
 						continue;
More information about the Mapbender_commits mailing list
