[Mapbender-commits] r6702 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 5 11:45:58 EDT 2010
Author: christoph
Date: 2010-08-05 15:45:58 +0000 (Thu, 05 Aug 2010)
New Revision: 6702
Added:
   trunk/mapbender/http/classes/class_universal_wms_factory.php
   trunk/mapbender/http/classes/class_wms_1_1_1_factory.php
   trunk/mapbender/http/classes/class_wms_factory.php
new WMS classes, similar to WFS. Will become more interesting once WMS 1.3 is being added
Added: trunk/mapbender/http/classes/class_universal_wms_factory.php
--- trunk/mapbender/http/classes/class_universal_wms_factory.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_universal_wms_factory.php	2010-08-05 15:45:58 UTC (rev 6702)
@@ -0,0 +1,147 @@
+<?php
+# License:
+# Copyright (c) 2009, Open Source Geospatial Foundation
+# This program is dual licensed under the GNU General Public License
+# and Simplified BSD license.
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/class_administration.php";
+require_once dirname(__FILE__) . "/class_ows_factory.php";
+require_once dirname(__FILE__) . "/class_wms_factory.php";
+require_once dirname(__FILE__) . "/class_wms_1_1_1_factory.php";
+ * @return
+ * @param $xml String
+class UniversalWmsFactory extends WmsFactory {
+	 * Parses the capabilities document for the WMS
+	 * version number and returns it.
+	 * @return String
+	private function getVersionFromXml ($xml) {
+		// of course to be refactored. Up to now, the same factory
+		// handles just 1.1.1 and below
+		return "1.1.1 or older";
+		$admin = new administration();
+		$values = $admin->parseXml($xml);
+		foreach ($values as $element) {
+			if($this->sepNameSpace(strtoupper($element[tag])) == "WFS_CAPABILITIES" && $element[type] == "open"){
+				return $element[attributes][version];
+		throw new Exception("WFS version could not be determined from XML.");
+	 * Creates a WMS object by parsing its capabilities document.
+	 * The WMS version is determined by parsing
+	 * the capabilities document up-front.
+	 * @return Wms
+	public function createFromXml ($xml) {
+		try {
+			$version = $this->getVersionFromXml($xml);
+			switch ($version) {
+				case "1.1.1 or older":
+					$factory = new Wms_1_1_1_Factory();
+					break;
+				default:
+					throw new Exception("Unknown WMS version " . $version);
+					break;
+			return $factory->createFromXml($xml);
+		catch (Exception $e) {
+			new mb_exception($e);
+			return null;
+	private function getVersionByWmsId ($id) {
+		$sql = "SELECT wms_version FROM wms WHERE wms_id = $1";
+		$v = array($id);
+		$t = array("i");
+		$res = db_prep_query($sql, $v, $t);
+		$row = db_fetch_array($res);
+		if ($row) {
+			return $row["wms_version"];
+		return null;
+	private function getFactory ($version) {
+			case "1.0.0":
+				return new Wms_1_1_1_Factory();
+				break;
+			case "1.1.0":
+				return Wms_1_1_1_Factory();
+				break;
+			case "1.1.1":
+				break;
+			default:
+				break;
+		return null;
+	public function createFromDb ($id, $appId = null) {
+		try {
+			$version = $this->getVersionByWmsId();
+			if (!is_null($version)) {
+				$factory = $this->getFactory($version);
+				if (!is_null($factory)) {
+					if (!is_null($appId)) {
+						return $factory->createFromDb($id, $appId);
+					return $factory->createFromDb($id);
+				return null;
+			return null;
+	public function createLayerFromDb ($id, $appId = null) {
+		try {
+			$wmsId = intval(wms::getWmsIdByLayerId($id));
+			$version = $this->getVersionByWmsId($wmsId);
+						return $factory->createLayerFromDb($id, $wmsId, $appId);
+					return $factory->createLayerFromDb($id, $wmsId);
+				return null;
+			return null;
\ No newline at end of file
Added: trunk/mapbender/http/classes/class_wms_1_1_1_factory.php
--- trunk/mapbender/http/classes/class_wms_1_1_1_factory.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_wms_1_1_1_factory.php	2010-08-05 15:45:58 UTC (rev 6702)
@@ -0,0 +1,91 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../classes/class_wms_factory.php";
+require_once dirname(__FILE__) . "/../classes/class_wms.php";
+require_once dirname(__FILE__) . "/../classes/class_connector.php";
+require_once dirname(__FILE__) . "/../classes/class_administration.php";
+ * Creates WMS < 1.2 objects from a capabilities documents.
+ * @return Wms
+class Wms_1_1_1_Factory extends WmsFactory {
+	 * @return Wms
+	public function createFromDb ($id) {
+		$appId = func_num_args() >= 2 ?
+			func_get_arg(1) : null;
+		$myWms = new wms();
+			return parent::createFromDb($id, $myWms, $appId);
+		return parent::createFromDb($id, $myWms);
+	public function createLayerFromDb ($id) {
+		$wmsId = func_num_args() >= 2 ?
+		$appId = func_num_args() >= 3 ?
+			func_get_arg(2) : null;
+		// get WMS of this layer
+			$myWms = $this->createFromDb($wmsId, $appId);
+		else {
+			$myWms = $this->createFromDb($wmsId);
+		if (is_null($myWms)) {
+			return null;
+		// delete all layers apart from the one mentioned (but keep parents)
+		// 1. find all layers to keep
+		$keep = array();
+		$currentLayer = $myWms->getLayerById($id);
+		do {
+			$keep[]= $currentLayer->layer_pos;
+			$pos = $currentLayer->layer_parent;
+			$currentLayer = $myWms->getLayerByPos($pos);
+		} while (!is_null($currentLayer));
+		// 2. delete layers not for keeping
+		$i = 0;
+		while ($i < count($myWms->objLayer)) {
+			$l = $myWms->objLayer[$i];
+			if (in_array($l->layer_pos, $keep)) {
+				$i++;
+				continue;
+			// delete layer
+			array_splice($myWms->objLayer, $i, 1);
+		return $myWms;
Added: trunk/mapbender/http/classes/class_wms_factory.php
--- trunk/mapbender/http/classes/class_wms_factory.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_wms_factory.php	2010-08-05 15:45:58 UTC (rev 6702)
@@ -0,0 +1,37 @@
+<?php
+# License:
+abstract class WmsFactory extends OwsFactory {
+	 * Retrieves the data of a WMS from the database and initiates the object.
+	 * @return
+	 * @param $id Integer
+	 * @param $aWms Wms is being created by the subclass
+	 * @param $appId id of the application where this WMS is configured
+		$myWms = func_num_args() >= 2 ?
+			$myWms->createObjFromDB($id, $appId);
+		else {
+			$myWms->createObjFromDBNoGui($id);
+		return $myWms;
More information about the Mapbender_commits mailing list
