[Mapbender-commits] r6725 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Aug 10 03:56:11 EDT 2010
Author: verenadiewald
Date: 2010-08-10 07:56:11 +0000 (Tue, 10 Aug 2010)
New Revision: 6725
trunk/mapbender/http/javascripts/initWmcObj.php
zoom and visible
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2010-08-10 07:55:51 UTC (rev 6724)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2010-08-10 07:56:11 UTC (rev 6725)
@@ -28,6 +28,14 @@
return $_GET[$key];
+$options = array();
+if (Mapbender::session()->exists("addwms_showWMS")) {
+ $options["show"] = intval(Mapbender::session()->get("addwms_showWMS"));
+if (Mapbender::session()->exists("addwms_zoomToExtent")) {
+ $options["zoom"] = !!Mapbender::session()->get("addwms_zoomToExtent");
$getParams["WMS"] = getConfiguration("WMS");
if ($getParams['WMS']) {
@@ -64,6 +72,17 @@
continue;
array_push($wmsArray, $currentWms);
+ if($multipleAssocArray['visible'] && $multipleAssocArray['visible'] != "") {
+ $options['visible'] = $multipleAssocArray['visible'] === "true" ? true : false;
+ if($multipleAssocArray['zoom'] && $multipleAssocArray['zoom'] != "") {
+ $options['zoom'] = $multipleAssocArray['zoom'] === "true" ? true : false;
+ $wmc->mergeWmsArray($wmsArray, $options);
+ $wmsArray = array();
+ $multipleAssocArray = array();
else {
$currentWms = new wms();
@@ -77,6 +96,8 @@
$currentWms->createObjFromDBNoGui($val);
+ $wmc->mergeWmsArray($wmsArray);
else {
$singleAssocArray[$key] = $val;
@@ -90,15 +111,32 @@
$currentWms->createObjFromDB($singleAssocArray['application'], $singleAssocArray['id']);
+ if($singleAssocArray['visible'] && $singleAssocArray['visible'] != "") {
+ $options['visible'] = $singleAssocArray['visible'] === "true" ? true : false;
+ if($singleAssocArray['zoom'] && $singleAssocArray['zoom'] != "") {
+ $options['zoom'] = $singleAssocArray['zoom'] === "true" ? true : false;
+ $singleAssocArray = array();
//get WMS by URL
elseif (array_key_exists('url', $singleAssocArray)) {
$currentWms->createObjFromXML($singleAssocArray['url']);
- $wmc->mergeWmsArray($wmsArray);
$getParams["LAYER"] = getConfiguration("LAYER");
@@ -177,12 +215,25 @@
+//workaround to have a fully merged WMS for loading
+$xml = $wmc->toXml();
+$wmc = new wmc();
+$wmc->createFromXml($xml);
$output = $wmc->wmsToJavaScript();
+//workaround for zoom to WMS
+$extent = $wmc->mainMap->getExtent();
+if (!Mapbender::session()->exists("mb_myBBOX")) {
+ Mapbender::session()->set("mb_myBBOX", $extent->min->x . "," . $extent->min->y . "," . $extent->max->x . "," . $extent->max->y);
for ($i = 0; $i < count($output); $i++) {
echo administration::convertOutgoingString($output[$i]);
+Mapbender::session()->delete("addwms_showWMS");
+Mapbender::session()->delete("addwms_zoomToExtent");
unset($output);
unset($wmc);
More information about the Mapbender_commits
