[Mapbender-commits] r6727 - in trunk/documents/logos: . logo_contest
svn_mapbender at osgeo.org
Tue Aug 10 04:01:17 EDT 2010
Author: astrid_emde
Date: 2010-08-10 08:01:11 +0000 (Tue, 10 Aug 2010)
New Revision: 6727
Added:
trunk/documents/logos/Mapbender_logo_and_text.png
trunk/documents/logos/Mapbender_logo_and_text.svg
trunk/documents/logos/Mapbender_logo_and_text_block.png
trunk/documents/logos/Mapbender_logo_and_text_block.svg
trunk/documents/logos/logo_contest/bender_head.svg
trunk/documents/logos/logo_contest/bender_head2.svg
trunk/documents/logos/logo_contest/bender_head_red.svg
trunk/documents/logos/logo_contest/mapbender_db_toennchen.svg
trunk/documents/logos/logo_contest/mapbender_diagonal.svg
trunk/documents/logos/logo_contest/mapbender_dragon.svg
trunk/documents/logos/logo_contest/mapbender_dragon2.svg
trunk/documents/logos/logo_contest/mapbender_earth.svg
trunk/documents/logos/logo_contest/mapbender_grounded.svg
trunk/documents/logos/logo_contest/mapbender_grounded_holy.svg
trunk/documents/logos/logo_contest/mapbender_hueben.svg
trunk/documents/logos/logo_contest/mb_db2.svg
trunk/documents/logos/mapbender.png
trunk/documents/logos/mapbender.svg
Removed:
trunk/documents/logos/bender_head.svg
trunk/documents/logos/bender_head2.svg
trunk/documents/logos/bender_head_red.svg
trunk/documents/logos/mapbender_db_toennchen.svg
trunk/documents/logos/mapbender_diagonal.svg
trunk/documents/logos/mapbender_dragon.svg
trunk/documents/logos/mapbender_dragon2.svg
trunk/documents/logos/mapbender_earth.svg
trunk/documents/logos/mapbender_grounded.svg
trunk/documents/logos/mapbender_grounded_holy.svg
trunk/documents/logos/mapbender_hueben.svg
trunk/documents/logos/mb_db2.svg
new logos, folder logo_contest for logos which are not in use
Added: trunk/documents/logos/Mapbender_logo_and_text.png
(Binary files differ)
Property changes on: trunk/documents/logos/Mapbender_logo_and_text.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/documents/logos/Mapbender_logo_and_text.svg
--- trunk/documents/logos/Mapbender_logo_and_text.svg (rev 0)
+++ trunk/documents/logos/Mapbender_logo_and_text.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,167 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ version="1.1"
+ width="1052.3622"
+ height="744.09448"
+ id="svg4291"
+ inkscape:version="0.47pre4 r22446"
+ sodipodi:docname="Mapbender_logo_and_text.svg">
+ <metadata
+ id="metadata32">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <sodipodi:namedview
+ pagecolor="#ffffff"
+ bordercolor="#666666"
+ borderopacity="1"
+ objecttolerance="10"
+ gridtolerance="10"
+ guidetolerance="10"
+ inkscape:pageopacity="0"
+ inkscape:pageshadow="2"
+ inkscape:window-width="1280"
+ inkscape:window-height="950"
+ id="namedview30"
+ showgrid="false"
+ inkscape:zoom="0.51"
+ inkscape:cx="491.86737"
+ inkscape:cy="372.04724"
+ inkscape:window-x="0"
+ inkscape:window-y="25"
+ inkscape:window-maximized="1"
+ inkscape:current-layer="svg4291" />
+ <defs
+ id="defs4293">
+ <inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 372.04724 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="1052.3622 : 372.04724 : 1"
+ inkscape:persp3d-origin="526.18109 : 248.03149 : 1"
+ id="perspective34" />
+ </defs>
+ <g
+ style="fill:#cccccc"
+ id="g3663"
+ transform="matrix(0.99607639,0,0,0.99607174,-519.72213,-20.20711)">
+ <g
+ id="g3665">
+ <path
+ id="path3667"
+ d="m 680.875,409.197 -85.187,85.187 C 548.641,447.337 548.639,371.058 595.687,324.011 l 0,0 85.188,85.186 z" />
+ </g>
+ </g>
+ <g
+ style="fill:#87aade"
+ id="g3675"
+ <g
+ id="g3677">
+ <path
+ id="path3679"
+ d="m 680.875,409.197 85.187,-85.187 c 47.047,47.047 47.047,123.327 0,170.374 l 0,0 -85.187,-85.187 z" />
+ </g>
+ </g>
+ <g
+ style="fill:#ff8080"
+ id="g3681"
+ <g
+ id="g3683">
+ <path
+ id="path3685"
+ d="M 680.875,409.197 595.687,324.01 c 47.048,-47.048 123.328,-47.048 170.374,0 l 0,0 -85.186,85.187 z" />
+ </g>
+ </g>
+ <polygon
+ id="polygon3687"
+ points="680.865,409.199 629.846,460.217 611.441,455.78 588.774,428.613 599.945,384.641 642.625,370.959 " />
+ <polygon
+ style="fill:#2a368f;fill-opacity:1"
+ id="polygon3689"
+ points="756.107,446.145 732.626,460.96 693.622,421.955 680.867,409.199 713.513,376.551 753.107,378.478 768.774,400.145 770.774,424.478 " />
+ <polygon
+ style="fill:#ee0000;fill-opacity:1"
+ id="polygon3691"
+ points="718.598,350.745 716.855,366.815 711.046,379.018 680.866,409.199 652.5,380.832 647.566,375.898 640.184,355.004 656.941,324.478 680.866,321.477 707.369,329.641 " />
+ <g
+ id="g3697"
+ <image
+ style="opacity:0.75;overflow:visible"
+ id="image3699"
+ transform="translate(565.7866,294.3364)"
+ height="190"
+ width="230"
+ xlink:href="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAOYAAAC+CAYAAAAht3MhAAAACXBIWXMAAAsSAAALEgHS3X78AAAA GXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAKX9JREFUeNrsnYly20AOREGKOpzE 2f//zE0cWze3UuXZQFA3AEqUrGNYxZLjOI6o4WMDGBwi9ahHPepRj3rUox71qMddHk39CO7j6Obz 0dZqu1r19ROtYNbjMhBm166voFYw6zEeiOd8zwOyj36uglrBrDDitUBfN2esWx98zf6+QlrBrDAC CNn30No1gSJ6r9HPVEgrmA8PpAejdwr5c0Ype/A1OyNYK6AVzIcE0gOxJV+jP0sAaATinnxd/iwO tBXQCuZDAenB2IKvW/L3kXIyKPfgVZ89+LqvgFYwHwnKSBnZOTGv9mumnkgx+wDEv+fOvOrvR6BW QCuYd6eSnjJOwKs9O/N3CFAGJ1JKC93OfL1VX+8caF1AK5wVzFtVyfK1VTcGYade9Wn/zoKsf7de Sw2KVUoN2la92q+3BNYdMH2RmVsBrWDepNlq/UILoj2n6nVqvq8BnRjVzIJp1dFCuAlet0RRkYpW 9axg3pRKWrNVqxsCsZwz82pPq6IIzCbwL5lSbsi5Nq8WVKaiR+pZ4axgfjWUyGRFMM7IOXcg7RzV 9MBEfiWDcg3OlfmzhbT8Lg2/9UGraVvB/BLT1QZ1yjkFQM7VKzotoPqcANVEAaACAPIvd8Z8RVCu nJNBuiXqua+mbQXzq0zX1lFIrYgLBeBCnXPzd1Y5tQ96qim7d3xLBuVSnSvz9SoJaDVtT73f6kdw lumKoJwa81SD+GJey9caTg0zMmVbopgRmHsC5saAaUH8UK+zz6+nn6+eemv1/P/7+vtZVjgrmJeG UkdaGZAaxm+fr/pcGMXUYGbV
MruPiVRTB3pWAMq/7/Fdvb8P8MAo72dN3k+Fs4J5VSitSloz9ZsC En1tFTOCciI4+wcdfRAEQnAWE1WD+fH53t6B/6vBnID3VJSzwlnBvDiUdj9yZqB8MQB+B19bxZw7 N30GykyuLNrTjEzal08w34kPPDXvz5qzm6qcFcxrQzk1gZ2FArBAaM9vBswslDZPVohaNsILoW0m EEo20Mq5+IRzAXzg6QkBqQpnBXOUIwPl3PiPBcgf4LX8nfUtZwNv9mwtJoJTBOfOlmjq7BPM+Sec aDsneoBEyfVHcNZbrYI5RC2F+JQaSm22FgDR+R34lhZKG3ltB9zo0QPGgjoxgHafYE6VaTsDMKLE h0zCA3pQ/D+Fr6pmBXOICYsSByyUBTYN4evnqb+nTdwFuOGHqk6fVBukrq36t60cp+7ZTKVO4hTB LJi2GqUtgFY4K5in+JX65kRQvpJTm7HWp7TBE3Rje10I7I3uQRm1Kumd4FYHgBxqwvbgvZaHQVP9 zQpm1q9k+5TWpyxQ/jSvr0Yti8mLIpoMSK/QGeajKsDstXivjQEUVcTYErVTMpBoiZiY1L16VDCZ X4nUUicNFJ9Sq+N/FJzat0RQdoL3/VhVCCpaZnAi1UedELxoL2txgv4tU0uvx5A9m+pvVjCHmrAd 8Ct1oOenOV8TUNpaSpahY7c0olIrFLRiNaGThPr1ErdDaYKHi9dTyMJZTdoKZtqEnTlgvgYmrI6+ 2vQ162tFRcyoYHkPVFODgkrQJo7faDskZNtreipp1d5T/GrSVjBdE7aVw60RndGThZIpZWOAZFk4 tmgZFStrNRKgcBPgJ9tSNBRx7QNljHJ0PeVnKlpN2gqm64+xHNgCpTZjX83rdxOBnZkgj4ZS36wW RFv76JVYZcBEXRNQkXZ5v3uloPahZaO+GSi3wBpgqt9U1XxiMIOAD9qz1JHYH0Yhvw+Acg+AZPWQ qEgZ1T5aH7MF
19IBGHVAS/95p8zvXnCergclS5bP9A7qq2pWxWRVI1NjxupIrFVNq5RzAmVvzFaU NK7PDzmsjSw/tyHmbO9ElVFZ2kI9dFbKXNfwzAHwjbl3mE+5dcxzr/NBU1XzScEM0u4mJhKrk9M1 lEgl50ppGJTlxkS1j+/yr9RKFygz1TwFTFu8vVTWgIbGKhnykyeOGWu7JCAwN0Y9J1U1q2I24mf5 eEnqFkov0GOh1Ar5oYC0pwZUm7QbOW6ExUzZliimrRnV0DPg9T1j9z6nBswtAXMdmOV7+Zem99Sq +XRgJtRySqKxrKZykTRftUpqIP+Y08Kpe+2wm7kniqnBZLWjSwM9+929A+dEBY2sYqKeQiiotf38 PTs5zOF9StV8VsVsJJdQgMB8EVwlovNebfTVQqmBfFOnhfMDgLMBgZ89uL6o08JcQa/VcuNAaZPi GZwITC+opR8Ik+prVlM2U2uJWoQsgFJ2Bkp9g64VlBbI35/nm1FOTy13xNzsZVjHBQT8VvzEBQuo NmlZgEtD+U3+FWDba+uUYu7lifc1nwrMZA8fqyovRjlt60kEZa98rXJzLpVSFiB/KTB/G8X8MGq2 Frx/mcmVRQ+eFQjKROYxmtWpldPz0VcKymJCz9UDAtWiPu2+5jMqZuOYeyxyiTrasYR0AX7l0piw BcpfCs6ioO8m6LM2AZ9d4P9Zc1an5nXCty68DX/0IGMVKp7lgc7l58+Vh0/xM88pDq9gPoCPme14 Z9tMTgVvIVhTbgWgZGBqtbRQIqX0cksRTMWH8zb7rVKiAUmoK57+ueghh3odoQ4OT2vOPg2Yyf6w XrNmdDPpm0jE3xp5B36lBpOZsMh8tQD1jlWgr3WnFCkDJdvjnRBA7TaNLi7XSQ0LB87M+IcK5gOb scyU1TcSmy/CTNgeBHyWKsr6x4D5G0Rjl3K8XzkESnateo8QnSiAxDoa2FP7hJJ0D1h3QNQVoZqy
T2rGet3Uo/aSTC2tf/kHRGT/gIDPKhHoQX6lrcdEWxwWTva7WAeHqCEXKsxmyfNoHIQF/cicrWA+ jxkb5ZTaSgyvrnIneIvEKuYfEoFF2yIMIu9GRe1GbISzdyK6LCg2FT5bZUJUE9W1elB681Cepoj6 mRSzITdgtjQK3Ty60p/5lkuJ0+5YZo9rumZu0M+Hku2v0zifETPvmSWxluMto9YJrDG4pyD4Y03Z p1HOZzZlbRSxc+CckihsA8xYu7Guc14RlKsklCcNgS0/SwD1PhsvSm33IW2ua5948E0dk3hIn9oK 5oMGfyYn+FI2HxaBaUu5bNUIylF1+/mcY8L9/bcGTmTCbgWnJ37Iv0lfL+pV57rqzwhZJZ0DJ2pv wrr4PcXR1uAPTPaekq9ZtNCrs1wBIL2k9N3YUAKlReMSUKnWWniNaOQPI9PYA7RGZJ8JzMQkaG9L IBrwI45i6hvbJnBnuhFcZAqzgbNPwsk6K6CsJK9jH/ucWbc+uJ9pKoQqmA8W+GHm7ITcMBkokY/J yp1s9g3sHHeJCOQIcLKHi1e03Tqf8RD/8ilU9NlMWU81W3OTZG8WVCBsm2uhhlpRtzu55LYAgbOX XGsQ1BzMmuGSgHMSPPy8jnwVzHs1YUFRtCTMWZsPipohiwHT7mHaYbCb4Ea+iE85AE4RPj8TPWg2 wvvcZhpQT5zPPDV6EKxvjcreuC8pAYxeV/FWch3KWQd1ZApugxs5m2J3yUMnIaBOdztwHewBwxQz A2em2/uBtWLX/VGSD7oHA9H6IKjSfiiM0ZxK5GdmWjfSNLtr3lxmG6UhZi0b18DUUsMuiYdi5vMv +6Ot4D3YHt0X9wpqd+cgNsHXGkxWtoRMKS8trCFQemrjdSH3aiq/QjlF8NwRO+LAvmYLt1HQLbM2 BcY9eb+oAuVuFbW7QyCbAa9ewroN2+vvp30d4p9FZ3+DUAq6sck1aSjZoKCsb98m1
mSv/PhGDpt1 ob1Za55DUG8Z0u6OYfSG3bAbASVlT4WH7hmgQ29ktBUSVYh8lZ8pgofj7oNXL8neAxJBqbOv9FwT rzImGux79FmX++wWAe1uGMhIAZl5xL7HKh0yVQ4oGpsZ0ioST4G+ZdOqd65RTghYRZlAtixsp6Cc yHFnQPSZe3M4+3sBtLszIFvhvWe8yclel3XdgjJTtHvOntq9Rgz7wB9lEHqzR1n1ykL+ZRL16udZ 4Mx73SdgvUlAuxuCsgkCBUMmHLeB2WTHH9jmzawHjaeckUktcr+b5U3ierNKiZLadTc9C2X5ma0T RPPOXRLW/0ekbwHQ7gaAHAKj3fvy/sz+TWeezrqRs2154VU7DDW32wSkt1ZBMcRlaILPB/n6tuVI SVUsoJSfWQMwdyQYtQeRcBZBtpDejInb3TiQCLwueEXAZudesoGzCM5+QNSxFd72UW5EQZsEjFHr yiFQ2jUoSilKKUshNhrdsCMgonmcuwBsb7vnS7omdF8EJVo0L58SNYCaku97kNo5HtqE0nDayV26 Or9xbjpv4zzKZLkFtcykLXpZO5GKsjEUWwKl7X+0TcCIkjos2PqVbf8cBLmuDWf3RVBGC19AmMrx iHJbwDwVXKKFqkM81bTzSXTvWOZneq0w2f/PAkr/h/OaNwHZmmqcBwza843gZA265nI4saxV0C6E l8ZFGVY6FZKN/9sCWEvDskaOe/f+/azkWqZtd+WFb5ILjzoJoB48KJLK6vzsjTUVPm4PBYJsJzgd NGDX4r2nlpjHX6GcTfCQmQTWSiYpw5qxczmsqGnUZ6ZN2I3gPrgITA3e2nlFVT4Twb125SvUs7ui SkpgsnZAFedyuN84B9/TkHYGJGTSdpIb6Br5mSJ+wfVUjiv1vSyjq3cdd8bdt8T89ywUppqt2Vrp gE9Xfm7q+JVbifORURWMrYtdC57TWcYzbNQ17JR67q/pd3ZXgtIrT
EYNsGwntoV5tf1emWp6wSCr nKxtJbrx0DZA1A3Ovk/93vRMyObKfk221cpUcD+kjHJqxUSj/awJi4bzsmCPByYr8l6C73UGzvK+ tnLYNPsqpm13RSgzGR9oLAE7rXJOyVMcmY6TQBGQD4tS8lrJt3xEcGoz6qrlX4FadsI7qaMHYqSa utn0BICpx1OwQI9XIOCBiaC0fYxmn193nz9TrqEAurVbKZc2bbsrLXZDVBIBacfeofF3C+cGYebV JIgydk4EmKXmRROp0Q1tHyQ2jH/xQNAZc1yycLJRfUit7b6mB2QP9i+1/4k6LViV/JDDroUFSvtg X4GHzNVM20sopud/dcRktSDayc0W0MiM9ZLQ0dfMzEVZRZI0ZWfAHNfv3Wtktb+CSRsl+U8lP1wp Uky2V6v/T1Ye15OvM3CiadYayvfP63kXPv7CXstOvf+LwdldUC1ZQGQm/ih1dLL5lHZsgRf1REGJ qHgX/Xu2teAN0Snv/+PzzzrwYBXzogNbB66TBZKtwVTiLCkB39+bzw9t9NvUuaj2FbV20aZs6Yn7 HlhdUfeKi8LZjbzYTcK8m5O9w+9mk/87UMyFo5SsoZO3oZ9Jjm/E79iWHRdfrsG2f0Sd8o5yOEdW TRaQY6PzPKsFDQOK8mhb8z4iGEV4FQlTzy1QTj1ifi7x1LEMmEdw3oRiDoByDvYLNZA/DJzf1c95 JlS0NzhWbqs4PpKNZE5VhPFFmVDfBPdktftnrVygPCwI+GQeKtZy0Q/IqExOhLd9ETlsa9JKXASN Wm8iQDWccwNmNqofgSk2WnvuQ7S7IpRlMRGQ+vwO1HIRBBsmxORkrUcQnOL8bMaXtkGT4kdaOJfC myZ3xsc6SDYYSTWjzg4ZtUSKOZF8f6Q++Xk3gVlv4UWAFvUsYK4ET3GbJX1M79iPtQ89hinLFtpC WRbWwvgKwLSpcWi8OlNIu9C9s6h64e3IA3tNmc8gu
sFXBMxBU75GNGeZWjLFtPWrbHyEgM8aKZ1X K5m5ZuTDWhUtD7uyPeWNFOySSRPsGG0fuhtBLSV48mrT9bsBUp9WLVEGzlRyDZiz7SUkYcra6VUo 6TxjEhbV1Oq5AMrZKXN2LyOl6iVSI6MJ0KyonG0n9WRNsu1JspOyrVncm68nClCbUjhNbo+15v/x HjTarL2uYhoTtg0ikwujlH8h/KmA/GnUEpmvmdmJ3pN4L/6Uq0b8zgitAZSZv6duOcxMIsMQ8+lU C4c9UL2kAhbBZH7l3piZUT+kfQDm0NpQC+gk2LOORmIwGFHA7ix/szsTyibwsRZGKQuIPw2cWi2t UnqTtrwo3c5ZdHESIbxCaxZc6pOA2rzfbJ+hsRLbPdX0UiS95mVMKVlwxit0thUdXuPoJrG1FbXN RCBGwZ6MKX62v9md+dSNtgqKCVsU8Sc4f5go7EJ4yRUD0iuaRU9nCaKTUflW1GrEUyJmQk0S/vKY ye3ZipLJQDURB8joROvUS76bezQDZSJxWxoPTKb8vfgNrwf7m92Japnxq16AWiLF/KGCPQvByeMN iHx5VQaoTMgO7mFbHlF6HosGi+RG0E2SSRDZ6PA5ypnZLvK60tsb1qpK+dy9IuZz1glNDfPWKOqm 2JKovqf8+s+9Y45fXDG9wMHMCfi8GjhfTRR2QcLvDQiHe1UF0ayQ3jE9M8NVUfRO36iRr8R6/txD gy7PdbDjFbxaSbteY6xTR9ZqYvxgr/dSE8Quhnbab081absT1LI5Uy1fwdbIC4FSzM2OZjfa4tc1 WXg28ZiZ450TVke+oX6AeIt1SiTyEoBFgQxvNIKGrjVbTL2zwR8VK19qnXZqrfqEL4oeRiz1D/UT 2ptA0OD0yu4CUHrbI95e5Qzc5EI2ijeCh8La4bBsDmVv9r6iekpboI22cFo5nJi1cc6tcyPurwQq 8wczxcflnJAkAG/w7aXXaeZEkffAR
dL1oOgz2gcWQAbQwQXwQ0zZKL+SqaWX2bNwoGTj020ZD8qm 8VLe0JNYV5UwKFmxtoazvPfyntkU5pXgAba7KLHgzMBPT/x1lmfKRr1PDZRbtS2xVw9Qtl7XWqdy buWwlcnUwI7gzObheuu4B1so45iyA/IrkVqyPFjWU8dCqT8AvcC2pu6DwLkRfxS5yPCSJ11lsQZ7 kKLe+8q8R/RebfnXpbN+eieqzR6AuqAYQdkZM1b/DluUfK11elEPhxcDTbn2Tv1uCyebso2AXDuA ntQ2phtZLVGCOtoOWYDEAQalBbLU0ZXXd+eGX59hInn1oiuSmdSqaygL9vd9/VGnfr+2/CsKgJx8 qDmY4piw9iH4QbJ8NJQz9T39e1D946XXSRfZl2v4Bj5b5CpYOBGUXvuSteMvDy7lGxqVzQR9rGKi mspZYL5qU8gCqW/wPwZOpkRDggo6sqcX/ENd21JdT/mZztygWwPm2+dZ3r++SXUJ2O4K/qbnV64/ r30JopwTYBUUBdX+5RpYC+8Ji+GcdVrIv3rXb0SNd8FniuD0qlWYq3K2anZnZPmgxr26egQVOyOf siVQapV8N6rzpl4RmCgxPBuG19dVrq1Aqcu3dL7rnJh45RrKe/2t3rt+z5kk9ksGffRNx/ZvW7Ml VFRRg6nXj1k4ywuuk1XLlRx3iWCJJgxODaYHJYKzvNfBqtklVVIkV1Rr24PoxAEPSjHmq17YP0Zx fifVZ01MmD3JKNGBBVtpsZDjsq1vBMxWLWa5jnfz/vX7Rn7mDt0852b8GHPWgtka98HrfauvzYK5 ccDUJrwGZ4x1mpPA0jb6XJ0Ei17Bv5N/HfzWxIdG5XzlulgK5zAwzyyq9dqBoL2/vQkaWCh/g/PN mLKsM8BWhqfk2UVnT8cPc20TcPOu1HvUSv8BFHMnvJPBtVSzEd6Csjc+5Nz41juimB+Jh+c56zRT 72ctcSmdBMkFqDCjN
ApbqOvXrs2HeoCXBzqK1Jb/103T6xJq6bWfRIGfFwfKKTGLtCllzde/EP4y r8gkZE+qneSS2JmptHa2DV7kuGC4ATfwh3rQvKsT3aAwc2istiJANfcKqvI5rIX3t9HXpYNevVFM G7CLAj7nrFOJjq8D85iB6XWRR3Cu5bC+Vvd0KvfDSnDd8NHe5hhRWdRCI+oFOxfcfoJFYDWYbwrE /yow34x/uVRm0TpYbJYi15K0r6nw7t4rcH2tAtNTD+1nub7l2B3yPuFEG+k7JxOmByb6zKznDqxl VBg+xjp1AxI4WJWJ15bG64fE7nfUaYO1jcmBmTBjJ4JHc6M2jah2D6mlfspan+yXOrVafgA/bRtE NzOWwU5dK8r20Ao6A/t76CZFN+o6SDC4dIqeLewV4R0IrCKia96TvdAVSKxA13zqOpW9VC/7JrIA J+J3xsgUks/luDqKjcJwzdluwN5lI3FB7UJwY2OUlL4navme8C3fgAmbeQJnq+JbtfBoxuLG3KCR 37wh6WjWB+ovZcI6Jm0PFNEC2oM4wEwOk8N7cM1oj8+OPhhznbzyMRHeAiZqwKWLrTOjPFAx+UZw Av1JPmYm8JPpNm7B7IG5h8zYNwCkVsul8P6srAVitOD6RmzF7762dqyBnmSLrIG5BQenXnpuCfA3 rXoiMFHk1j6MdpLPD77EOjEokSuGKohQYX7j3P9Rv2NUIniWj+kNm/FGAcwCtexJCpjds3wDQL6T jfntiYstctyYayeHCekIzs7s/bFr1DfqNnmDXm28OPA3944Zu1Nmo20pwjJl2MQuppKnrlOkuFFn iVkgJt5WISp2yPaoheZsl0wqiHrDRBdnAz5R0McmFPwBmSMrss0wOAkcmHTaT0Sd1/TNh0wfkeO6 xEzF/lWhJP6mhZPl1KKxEb0Bzxuv3o+4TlHQqElaezMQM2glN0oiy4CNdkPl7AKTQRJvauq8Ia/g GSmm3
Sp5J5vT1kfTFeT90Kim/nu1+GXhURHw3gSIWJsR1IPIK/P6EiiBv4ludn0ddnAQgphV+tvk gbHWSb+PLRCXbPL72rgonmoiOJFZ3Enc1f8sUzaaazkNnhTWjLU5sUuQwuVtTO/kuK2DnHOTl39D ns698Wt0ZDAqsu0lqLv8IqX04ESANmBbhf18VBguI6+T9it35v5dCa6GKjm2JeWy+IpbweVnzHJk s0MnjmKeFPzxmjVFMyW9JsAskOCVCDEod2NCOeBG1f5npvo9Or8UyiBS25jr1SF/FL0V4V3kZOxr dtSeBX1stdKLs4VVkvStMjPl7EikNzsD5awEA6aYURdrZNptBNfuWSjXwZ7fqFAm1ZP17mF7gML8 qluAMvFAsoEXb8+TXetFkibAe9apbzoWwOpEWVaSncKWGcLcSW763ME9YwNAXSKxAKUsoYZIEZQC tkm24o/kzmaKXPQmJzcrulGjwMpRoOOWoAweSJKAEgWSrvIQcvZlUZGzTULPjqtAKjwhPEStNEcL /rAuZdk3wz4s1MbC6wdDI3uXvMkTvqeAPTZ6w94ikAPUM9rWkGyk9cL7shk42T3nFa03ErcmRU2k RzNls6o5SUApEheesorw3VdC6QAqxORLRRbv4Uhcb/p3fMHWD+vbE7UH8WpD2cT0NuAgO2U7FfxB cLJu2KwxsJCAAGrUzNoZbsWpPviqLQbHDbhrGLPXgK75q681UE2vqdZWcG2op5iNc+9HTbJdc7ZL mLFs6yT7RpBi7h04WQPga4ymG/XGffTjxq/Za8/JRGErp5WhNQNYSA2KahMXOLSNvtfR2vug7FMq lff6jEDUY/ADI+qk7t17UdXL0OljqSHJbSL4I45qNgOfCN5o7r34g4BuUinrcfPHkOlj3r2Xdfc8 GNNjMNrkzzHihzwZmGPOskROSXKuRz3YvSaSG6DriUFPoESMRBw054DZJEAd8iTIzMxwM2
TA76pH Pc6596JZMpmC9Wbg16Mp5qlHkwBpyLiyCmM9Lgntzdxj7YA3fApMvfPEYOZvE/x8PepxSQFpRgT7 ZODbE/7zHgCa9QUZiDaI5EV3z/kA61Hh83YWoiBOxn+VZEykPwXMfgTfMPqQvInFZ+0B1aMeQYCG QeklBCAxyHAhckLgMqOYXrh5qNPsZQ+xVoLR/mg96jFUKVHmWube89y6PsGDJ3ohmP2AJwJrgITe iFfbOaRS5QBOLxWuHs95gHuiCcSgE57z7XVq8CK8XgfAUDnbE5XS25CN0pi8bghRO8FWkknA9ahK Kbk+sqiWMlOuFSXLRDy4gaFMVDZSyZ3ksiaiwTC6LcMs+UFJVc16OGrpKaW99xicExne24j1OUon y2Sjsl6eYab7G1JM1i9lRgBFfVOqv1mPSC1b8RvJsV49rLcsYiLLQrrLfjtAKVniuVcR0hPVRIOJ dDtB/Rr156yqWQ9PLVl/nqh1ZSe8PU5UrYIS4xmUcfCHVGpky2YQnDvBI7XZKD82aoE9ydoaCKqH WXuvF7I33oCNNkCmbKZ0cZBqWvayPqa2k6MC5+zIbvRBoclJtrs1i5hVKOvhRf6njgiwSV3lXmuI YmaK/Vmx9WhR2agC3JtRod+QfYrNHDDR1DDWiLeatFUtRfKzXMs8V3u/oel0rNs8YyAaBRj6mW0S ymyvHjQ0x2uai2Zs6lHxegDuPBkMqnBWE1aDOXWg1PfZglhnbIqANzAKKWbUEcEHU9m63v7l9gQ4 bXTWPsnQqPhvwidTW7O2+psVSjb8akYe/Prh/wIUMxrv4THguXVh8CfT8NlTTNYT1na4K2+qJX6m /eCWnx8a+n3ehR5csDfjvh4PqZTeRK6FAdKeCxNs1GBGask6PEY7FbQ9TpeEMurP6TVp3hizYOKY swvz+6L+suhi9xXOGoFV8QsE5Xd1WqssY8aiXsjs3ndnoNJrDKBsTFTWBn
7sm1qaV/3k6EA0tVUf 4FZ9iN+E95gNn0Dq+02F86EjsEJMWM98tVB+S5ixdoKAJ0psekAaSgqm6cDdOIq5duAsZ/ELy1NM t9lvTXR2AX73JjANmEmrh99UKB8zAtsKTyAoZikC8gdRTGvGoiHEWwLlErhe9n5NJ7MP9TFRN2tv SIudN7gFiomCQJnws9faUuTfeLx9WdCqmg8fgdXm6xyYrz8SUE6BWu4dKJeC559khirT9qsTGq7t Oq8bXpSl7yUGe1UiXimNlxi8B/8eXtN+t6t3+GNFYNk+pYbxJzhfFaQFUG3K6qBPEYQCYhms/PZ5 /lZnmYD+oWClA4rY/UjB/PsPPuH0QtJsDNmQ8XyZmZJ78VsO5jMqKpyPBuXEQPlioHwlUGowX4zL pdVyp+IperAygvJN/k1Ct3EWZM4OB1OppteFPYKzMzZ7J4dV41FPFZZEf1Z7kwrnQ0Bp0zqRP6mh /M/n+RNAuTBxEG3C6uHKywSUGkwUAErN3MmAiaJgmeJTb4gnqw6PAPXamVhzVqpZ+/BQdsB8/aaU 8pVA+apM2IVjwu6UT1nUssBXgPxlzNh3ORy4bPfyJVLLEEzHnM1WhZ80XVfyk4p7x5wNC1IrnA8B 5QxA+cNA+ZNAaU3YibpfrFq+K7X8Dc435Vt+qAAQLOiIApGTjE+WVM0MoKzhUXbuiSTN13SHsgrn Q0D5AszX/5wAZfl/SxR2DQI+HpTvKujDfEuJ1DIFZlI1G8HNjJgZGzXZ0v8XA2wIjBXOx4ISpdn9 CCKwrwpe5ldqKDck4BOBWSKxyLcMgz5pME9QTRsQYp3IrGIObbTFuvmJY9JWOB8Tyu+OT+kFe2Zy nA8bRWF/Gd+yfN/6llumlpn99BSYjmoiQCfC21Oi2fReN2w5E9Qhf1/hfAwofzpQ6mT1GQn2IBNW R2EtmHrfcjmGWqbBTKqmBWzinNmu6x6QQ0CtcD4WlAs5TK
8rAP7HgPmqTFwEpb7/tQm7Ukr5B0DJ 9i2XghPXexk4aDkNJlHNCE7U7boNIB06jddrWy8Dvq5w3ieUKPrqBXvKvmc70K/8FURivX3LwdPP J0M+RKOaFhQPzkwb+nagWesNGxqilhXO+4BybqKvPwaYr1EE1ubA2pS7X+Zk2yNWLQebsCeBqVRT kv4mGxpk/dDMtCW2pTKkv2yfUNQK53NBqYM9ngn7S3gyQbg9MrSAYjL0AzVwZnxONklpiFoOBbap cD4dlOV7NtCzkMOqEWa+2mDPbxLs+a2isF7AZ3+qWp4EZhAIkgCaCMr2BPiiAbgVzueAEqXa2cZa SCltHuwfJwLrRWE3cpwPO9i3PAtMEAiSwMSMhtO2ctog0YyJ60VsK5xfC2W2yPnHAChfiPnaEvN1 OcB8fQNQrj2/8tQa4O7Mz7o34Wb2JMwEgTK+ooa2c97LGNfUm/dSW5SMc0Sd0q8J5UoOk9NR1QhK ubPm6+CePhdRTMfXFOLjRSqXGfU+xMQ9RTlTU3+rao6ilpncV5Y8UMAcA8oPEoH9TdQSgUlnk5zz EJ+c82EDOL1oacYEPSfoE8E5FEz4Wk3a0fxKXeQ8BVDq3FebPHAJKH8TKN+E71duBI8CkXMtq8m5 H7rjb2bMmSGKempktkkGf2pFyoUOU3Dv9XryEtLRlsiPM6D8MFAiv/LNUUqqlmO4O92Inz/yN8Xx O89VO5HjuRKS8Du9QbzemO7mAv7sM6mlOAEfVuysfUutkj/OVMoPOc5/9aBk+5Wj+pWjKmbgb3om pJdmJ8DEPVdNGZwWyFSTr6qaF1FL1BIElXB5yQPnKOVv4FO+kwjs6H7lRRTT9KIVOe6K7m11iPhJ ApFpHCmnCB714M361GZK7VE7XjTWa6Slu9vpdpO67aRtOXkKlBrA/wpPt0NKub2UX3kpU1bDycCU E03W1MOZwBkN3kUDYTSgeotGK30FdFjQB8
HJyrnQOINv4jdnPgXKXwGUXnL66H7lxcBUcArwN3cB gENMYQ/ORo57t7C5nmzuykoO60h3SjHrMVwpM4rJRhrYaVx2HCMbY5CB8r9BsAcNyPLGtt8umMlg 0FgqGZlMZeFZJ202HDdqTl3Vclxzlk0XR6PYUbd0uRCUUQ7sqH7lxcEE/qYYxbmk8rTCR7LNnFMv OJtY3VhTrWYCDQLSxhK83sT2ZN38RQFzDpR/HCi314TyoorpwCmfFxqZPqeqdCfHvWrZmDbUvQ/1 vG2kmrGn+pcZ9bTr05I/N3I8Fk/7lV73gQjKPwko99eA8tKmLIJTm7Tbkcxl1DVvooI1PbkhMnWe 9fjag7UstZDY7gN3DeXFwbwSnCj6OgVRuj052ViFaqKOs+6Z9fK2sdC2lt2WsybsXUN5FTAvBGcf LPRO/tXf9XI4bNRuh2zB4rNRDPUY17LxIuZojLqeK6IfvOXnUKtJb0vkJqG8GpgXVE62yDOziDvx J/+i/cujZkoWzhr4OcuqsUBulI+oZ0/q/cpGBXkKmMWMXQK1vEsorwrmFeDUWyJzFQQqYNqi2BK1 s0NHLZgunPVIrU8j/gBkPZl8qfxE2xKkrKW3tl751l1AKTJSruyQI6jj7B3HPzJnUcrdRo7LfN7V Ar3JYVkPCpfT0p6aKztoraPRGqjNqY3E6rX1Cp1Zn567gPLqijmCcjJAbRrWXD1pxTxVdbMlBuQa mLPV37yMGbtR/iPawmpM5NVaQ1viX2ogo+SBm4Lyy8AcwaxlvuXGgIn8ED21KcqL3MqFynqeEErm dqCu/TrvWY/EW8vhaAMEprWEhiQP3ASUX2LKjmDWeoDayN5K+HjutwBOpJo18HP6GmfK/BjMSGGX BEa7tu/3BuWXKuZIZi0yY1fK3JkYxbRtCu1obtS419vrrMdw1dRN2/S+JEr0sGq5lMMJXXaOpY4j vJsg391AeRNgngGnB+YMgL
k1CvphFs/rfNbf2sLd0xHU6rIywF6OU+3mJEq7AWv7oSK8nouyv8W1 7W548Tw4ewfMpRxWiGgw7QIuSRSW+pYVyrPX14KJygF7wePWZw6YuoRvKcfbYHcD5U2BeQacNvCj F8+m5bEaTLSHeZW6uyc2ae36CnAZdMxgLbgGEw0F0q9r9fe7e4Dy5sBMwtkHiomGx9haPdS1wBs2 Wk3Yy6ytVU/7Pf1ARXWY9sFsU/k2ghNG9re+rjdbQUF6keoNab3npWv29OJpxdQLuBWcN6snNe0r lF+2tmh97d6m7Vqg3RWWB30369rc2QJ6xbV2rHwLont6AXfEdK3BnttZ24kcF67b3k578+BlRQl3 ta7NnS8gmk6NOg9Ys3dPFq5CeVtr2wqfOo7M3r3wMr+7WtfmjheQDS5Ci8cW0K3LrFB++dp6TcJR wAg1777LdW3udAFFcuP7UMQPLdooMw3rMeraesOlRI6LpVFQsL/XdW3udAFFhnVeF2cBj7ZDKpQ3 tbYivPVLT9ZW7n1dmztfRDZJTMTPvZR7fpo+oXqK8H5MfbDGd7muzQMsYGbxogWsUN7u2qK19AY8 PUSxQfMEiyiPuHBPCmj6uPd1bZ5xISuMj7e+dU3vbCHPeerWox71qEc96lGPetSjHvWoRz0GHf8T YAAYUnbp8aFV9AAAAABJRU5ErkJggg==" />
+ <g
+ id="g3701">
+ <path
+ style="fill:none;stroke:#ffffff;stroke-width:18"
+ id="path3703"
+ d="m 734.167,462.586 c 16.295,-16.295 37.069,-32.934 37.069,-53.551 0,-20.617 -16.714,-37.334 -37.332,-37.334 -10.813,0 -20.552,4.598 -27.37,11.943 l -1.152,1.086 c 7.854,-6.844 12.816,-16.92 12.816,-28.154 0,-20.617 -16.715,-37.334 -37.332,-37.334 -20.619,0 -37.334,16.717 -37.334,37.334 0,11.322 5.041,21.467 13,28.313 l -1.291,-1.244 c -6.818,-7.346 -16.558,-11.943 -27.37,-11.943 -20.618,0 -37.333,16.717 -37.333,37.334 0,20.617 20.775,37.256 37.07,53.551" />
+ </g>
+ </g>
+ <path
+ style="font-size:120.27506256px;font-style:normal;font-weight:normal;line-height:125%;fill:#000000;fill-opacity:1;stroke:none;font-family:Bitstream Vera Sans"
+ id="path2416"
+ d="m 310.87148,334.09935 26.88332,0 18.65374,47.95994 18.76347,-47.95994 26.82846,0 0,89.61726 -19.97046,0 0,-65.54724 -18.87321,48.32008 -13.3868,0 -18.87319,-48.32008 0,65.54724 -20.02533,0 0,-89.61726" />
+ <path
+ id="path2414"
+ d="m 448.08866,354.87453 c -4.24284,7e-5 -8.47709,0.28611 -12.71986,0.88628 -4.24284,0.56031 -8.48209,1.42028 -12.68831,2.54068 l 0,16.36664 c 3.10894,-1.84071 6.4791,-3.21554 10.10014,-4.13597 3.62099,-0.92032 7.53517,-1.38845 11.74142,-1.3885 5.19376,5e-5 9.00671,0.82188 11.45735,2.42249 2.45054,1.56071 3.69283,4.0434 3.69287,7.44476 l 0,1.65439 -11.58361,0 c -10.60706,5e-5 -18.41384,1.84299 -23.38815,5.52448 -4.93775,3.68157 -7.38574,9.48785 -7.38572,17.3711 -2e-5,6.48271 1.95206,11.7532 5.90227,15.83487 3.98676,4.0417 9.16474,6.05627 15.52897,6.05627 4.71827,0 8.73361,-0.90671 12.02548,-2.74747 3.2918,-1.88079 6.26725,-4.86973 8.90076,-8.95144 l 0,9.95588 19.78998,0 0,-38.34641 c -8e-5,-10.76442 -2.44806,-18.51759 -7.38574,-23.27962 -4.90123,-4.80193 -12.90538,-7.20836 -23.98785,-7.20843 z m 1.35721,38.58275 10.2264,0 0,2.48159 c -4e-5,4.36184 -1.26385,7.98007 -3.78755,10.90125 -2.52379,2.88122 -5.6485,4.34278 -9.34264,4.34278 -2.96269,0 -5.29296,-0.78369 -6.97541,-
2.30432 -1.64595,-1.56064 -2.46192,-3.68963 -2.46191,-6.41077 -2e-5,-2.96122 1.04488,-5.21508 3.09316,-6.73574 2.0848,-1.52061 5.1514,-2.27476 9.24795,-2.27479 z" />
+ <path
+ style="font-size:120.27506255999999496px;font-style:normal;font-weight:normal;line-height:125%;fill:#2a368f;fill-opacity:1;stroke:none;font-family:Bitstream Vera Sans"
+ id="path2410"
+ d="m 537.85367,354.87453 c -4.2794,7e-5 -8.0708,0.92586 -11.3626,2.80656 -3.2919,1.84083 -6.2889,4.73445 -8.9955,8.65601 l 0,-9.83772 -19.6321,0 0,92.79358 19.6321,0 0,-35.30352 c 2.7066,3.92164 5.7036,6.83432 8.9955,8.71511 3.2918,1.84076 7.0832,2.74747 11.3626,2.74747 7.5712,0 13.7891,-3.27499 18.6537,-9.83772 4.8646,-6.60272 7.291,-15.10147 7.2911,-25.4658 -10e-5,-10.36426 -2.4265,-18.81437 -7.2911,-25.37716 -4.8646,-6.60268 -11.0825,-9.89674 -18.6537,-9.89681 z m -7.3226,15.59854 c 4.2062,7e-5 7.4321,1.69046 9.6267,5.0518 2.2311,3.36145 3.3456,8.22101 3.3457,14.62363 -10e-5,6.4027 -1.1146,11.2918 -3.3457,14.65318 -2.1946,3.36141 -5.4205,5.05181 -9.6267,5.05179 -4.2063,2e-5 -7.4221,-1.69038 -9.6898,-5.05179 -2.2312,-3.40139 -3.3457,-8.29051 -3.3457,-14.65318 0,-6.3626 1.1145,-11.20309 3.3457,-14.56454 2.2677,-3.40136 5.4835,-5.11082 9.6898,-5.11089 z" />
+ <path
+ style="font-size:120.27506255999999496px;font-style:normal;font-weight:normal;line-height:125%;fill:#ee0000;fill-opacity:1;stroke:none;font-family:Bitstream Vera Sans"
+ id="path2406"
+ d="m 578.38057,330.32457 0,93.38442 19.6637,0 0,-9.71955 c 2.7066,3.92164 5.7036,6.83432 8.9954,8.71511 3.2918,1.84076 7.0517,2.74747 11.3311,2.74747 7.5712,0 13.7891,-3.27499 18.6537,-9.83772 4.8646,-6.60272 7.3226,-15.10147 7.3226,-25.4658 0,-10.36426 -2.458,-18.81437 -7.3226,-25.37716 -4.8646,-6.60268 -11.0825,-9.89674 -18.6537,-9.89681 -4.2794,7e-5 -8.0393,0.92586 -11.3311,2.80656 -3.2918,1.84083 -6.2888,4.73445 -8.9954,8.65601 l 0,-36.01253 -19.6637,0 z m 32.6992,40.1485 c 4.2062,7e-5 7.4005,1.69046 9.5951,5.0518 2.2311,3.36145 3.3456,8.22101 3.3457,14.62363 -10e-5,6.4027 -1.1146,11.2918 -3.3457,14.65318 -2.1946,3.36141 -5.3889,5.05181 -9.5951,5.05179 -4.2063,2e-5 -7.4222,-1.69038 -9.6898,-5.05179 -2.2312,-3.40139 -3.3458,-8.29051 -3.3457,-14.65318 -10e-5,-6.3626 1.1145,-11.20309 3.3457,-14.56454 2.2676,-3.40136 5.4835,-5.11082 9.6898,-5.11089 z" />
+ <path
+ id="path2402"
+ d="m 688.37747,354.87453 c -10.6071,7e-5 -18.9263,3.14158 -24.9979,9.42412 -6.035,6.28267 -9.0586,14.88533 -9.0586,25.84985 0,11.16467 3.0716,19.85408 9.2164,26.05665 6.1813,6.16255 14.8256,9.24687 25.9448,9.24687 4.6451,0 9.3056,-0.50625 13.9508,-1.50669 4.6451,-0.96039 9.2741,-2.39242 13.9193,-4.31322 l 0,-16.57346 c -4.5721,2.72115 -9.0303,4.78435 -13.3827,6.14488 -4.3161,1.32057 -8.5237,1.97937 -12.6568,1.97937 -5.1207,0 -9.1095,-1.26041 -11.9624,-3.78147 -2.8529,-2.52104 -4.543,-6.30227 -5.0185,-11.3444 l 45.9241,0 0,-6.14487 c 0,-10.64438 -2.8958,-19.13264 -8.7113,-25.49534 -5.7791,-6.36257 -13.5112,-9.54222 -23.1672,-9.54229 z m -0.0947,14.26913 c 3.5112,5e-5 6.3324,1.26047 8.4904,3.78145 2.1945,2.48108 3.314,5.78561 3.3141,9.86727 l -25.5344,0 c 0.5852,-4.40179 2.0729,-7.78259 4.4504,-10.10361 2.3774,-2.36092 5.4755,-3.54506 9.2795,-3.54511 z" />
+ <path
+ id="path2398"
+ d="m 796.85617,382.7796 0,40.93701 -19.751,0 0,-6.66277 0,-24.67024 c 0,-5.80239 -0.128,-9.80405 -0.384,-12.00499 -0.2195,-2.20088 -0.6219,-3.82154 -1.207,-4.86203 -0.7682,-1.40055 -1.8106,-2.48097 -3.1273,-3.24135 -1.3168,-0.80028 -2.8164,-1.20045 -4.4988,-1.20049 -4.0966,4e-5 -7.3152,1.74076 -9.6561,5.22217 -2.3409,3.44148 -3.5113,8.22345 -3.5113,14.34595 l 0,33.07375 -19.6412,0 0,-67.22794 19.6412,0 0,9.84408 c 2.9627,-3.92156 6.1082,-6.80276 9.4366,-8.64359 3.3284,-1.88072 7.0043,-2.8211 11.0277,-2.82117 7.0957,7e-5 12.4723,2.38107 16.13,7.14297 3.6941,4.76203 5.5412,11.68491 5.5412,20.76864" />
+ <path
+ id="path2396"
+ d="m 856.98677,330.32457 0,36.01253 c -2.7067,-3.92156 -5.7037,-6.81518 -8.9955,-8.65601 -3.2553,-1.8807 -6.9936,-2.80649 -11.2364,-2.80656 -7.5712,7e-5 -13.7891,3.29414 -18.6537,9.89681 -4.8646,6.56279 -7.3226,15.0129 -7.3226,25.37716 0,10.36433 2.458,18.86308 7.3226,25.4658 4.8646,6.56273 11.0824,9.83772 18.6537,9.83772 4.2794,0 8.0443,-0.90671 11.2995,-2.74747 3.2553,-1.84077 6.2257,-4.75345 8.9324,-8.71511 l 0,9.71955 19.7584,0 0,-93.38442 -19.7584,0 z m -12.9409,40.1485 c 4.2062,7e-5 7.4006,1.69046 9.5952,5.0518 2.2311,3.36145 3.3456,8.22101 3.3457,14.62363 -10e-5,6.4027 -1.1146,11.2918 -3.3457,14.65318 -2.1946,3.36141 -5.389,5.05181 -9.5952,5.05179 -4.1696,2e-5 -7.364,-1.69038 -9.5951,-5.05179 -2.1946,-3.36138 -3.3141,-8.25048 -3.3141,-14.65318 0,-6.40262 1.1195,-11.26219 3.3141,-14.62363 2.2311,-3.36134 5.4254,-5.05173 9.5951,-5.0518 z" />
+ <path
+ id="path2392"
+ d="m 925.19427,354.87453 c -10.6071,7e-5 -18.9578,3.14158 -25.0294,9.42412 -6.0351,6.28267 -9.0586,14.88533 -9.0586,25.84985 0,11.16467 3.0716,19.85408 9.2164,26.05665 6.1813,6.16255 14.8256,9.24687 25.9447,9.24687 4.6451,0 9.3057,-0.50625 13.9509,-1.50669 4.6451,-0.96039 9.274,-2.39242 13.9192,-4.31322 l 0,-16.57346 c -4.572,2.72115 -9.0302,4.78435 -13.3827,6.14488 -4.316,1.32057 -8.5237,1.97937 -12.6567,1.97937 -5.1207,0 -9.1095,-1.26041 -11.9624,-3.78147 -2.8529,-2.52104 -4.5115,-6.30227 -4.9869,-11.3444 l 45.9241,0 0,-6.14487 c -10e-5,-10.64438 -2.9275,-19.13264 -8.743,-25.49534 -5.779,-6.36257 -13.4796,-9.54222 -23.1356,-9.54229 z m -0.1263,14.26913 c 3.5113,5e-5 6.364,1.26047 8.522,3.78145 2.1945,2.48108 3.2826,5.78561 3.2826,9.86727 l -25.5029,0 c 0.5852,-4.40179 2.0414,-7.78259 4.4188,-10.10361 2.3775,-2.36092 5.4756,-3.54506 9.2795,-3.54511 z" />
+ <path
+ id="text2383"
+ d="m 1017.519,374.79628 c -1.7191,-0.88032 -3.4382,-1.52058 -5.1572,-1.9208 -1.6825,-0.44013 -3.3833,-0.66022 -5.1024,-0.66027 -5.0475,5e-5 -8.94283,1.78079 -11.68603,5.34222 -2.7066,3.52151 -4.0599,8.5836 -4.0599,15.18631 l 0,30.97287 -19.6413,0 0,-67.22794 19.6413,0 0,11.04458 c 2.5237,-4.40176 5.4132,-7.60308 8.66853,-9.60399 3.2918,-2.04078 7.2237,-3.0612 11.7958,-3.06127 0.6583,7e-5 1.3715,0.0401 2.1397,0.12005 0.768,0.0401 1.8836,0.16014 3.3466,0.36015 l 0.055,19.44809" />
+</svg>
Added: trunk/documents/logos/Mapbender_logo_and_text_block.png
Property changes on: trunk/documents/logos/Mapbender_logo_and_text_block.png
Added: trunk/documents/logos/Mapbender_logo_and_text_block.svg
--- trunk/documents/logos/Mapbender_logo_and_text_block.svg (rev 0)
+++ trunk/documents/logos/Mapbender_logo_and_text_block.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,167 @@
+<svg
+ version="1.1"
+ width="1052.3622"
+ id="svg4291"
+ sodipodi:docname="Mapbender_logo_and_text_block.svg">
+ <metadata
+ id="metadata32">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:type
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ borderopacity="1"
+ id="namedview30"
+ showgrid="false"
+ inkscape:zoom="0.55"
+ inkscape:cx="494.36291"
+ <defs
+ id="defs4293">
+ </defs>
+ <g
+ id="g3663"
+ transform="matrix(0.99607639,0,0,0.99607174,-156.00779,-20.20711)">
+ <g
+ id="g3665">
+ <path
+ id="path3667"
+ </g>
+ </g>
+ <g
+ id="g3675"
+ <g
+ id="g3677">
+ <path
+ id="path3679"
+ </g>
+ </g>
+ <g
+ id="g3681"
+ <g
+ id="g3683">
+ <path
+ id="path3685"
+ </g>
+ </g>
+ <polygon
+ id="polygon3687"
+ points="629.846,460.217 611.441,455.78 588.774,428.613 599.945,384.641 642.625,370.959 680.865,409.199 " />
+ <polygon
+ id="polygon3689"
+ points="680.867,409.199 713.513,376.551 753.107,378.478 768.774,400.145 770.774,424.478 756.107,446.145 732.626,460.96 693.622,421.955 " />
+ <polygon
+ id="polygon3691"
+ points="680.866,409.199 652.5,380.832 647.566,375.898 640.184,355.004 656.941,324.478 680.866,321.477 707.369,329.641 718.598,350.745 716.855,366.815 711.046,379.018 " />
+ <g
+ id="g3697"
+ <image
+ id="image3699"
+ height="190"
+ width="230"
+ <g
+ id="g3701">
+ <path
+ id="path3703"
+ </g>
+ </g>
+ <path
+ id="path2416"
+ d="m 168.87148,500.38509 26.88332,0 18.65374,47.95994 18.76347,-47.95994 26.82846,0 0,89.61726 -19.97046,0 0,-65.54724 -18.87321,48.32008 -13.3868,0 -18.87319,-48.32008 0,65.54724 -20.02533,0 0,-89.61726" />
+ <path
+ id="path2414"
+ d="m 306.08866,521.16027 c -4.24284,7e-5 -8.47709,0.28611 -12.71986,0.88628 -4.24284,0.56031 -8.48209,1.42028 -12.68831,2.54068 l 0,16.36664 c 3.10894,-1.84071 6.4791,-3.21554 10.10014,-4.13597 3.62099,-0.92032 7.53517,-1.38845 11.74142,-1.3885 5.19376,5e-5 9.00671,0.82188 11.45735,2.42249 2.45054,1.56071 3.69283,4.0434 3.69287,7.44476 l 0,1.65439 -11.58361,0 c -10.60706,5e-5 -18.41384,1.84299 -23.38815,5.52448 -4.93775,3.68157 -7.38574,9.48785 -7.38572,17.3711 -2e-5,6.48271 1.95206,11.7532 5.90227,15.83487 3.98676,4.0417 9.16474,6.05627 15.52897,6.05627 4.71827,0 8.73361,-0.90671 12.02548,-2.74747 3.2918,-1.88079 6.26725,-4.86973 8.90076,-8.95144 l 0,9.95588 19.78998,0 0,-38.34641 c -8e-5,-10.76442 -2.44806,-18.51759 -7.38574,-23.27962 -4.90123,-4.80193 -12.90538,-7.20836 -23.98785,-7.20843 z m 1.35721,38.58275 10.2264,0 0,2.48159 c -4e-5,4.36184 -1.26385,7.98007 -3.78755,10.90125 -2.52379,2.88122 -5.6485,4.34278 -9.34264,4.34278 -2.96269,0 -5.29296,-0.78369 -6.97541,-
+ <path
+ id="path2410"
+ d="m 395.85367,521.16027 c -4.2794,7e-5 -8.0708,0.92586 -11.3626,2.80656 -3.2919,1.84083 -6.2889,4.73445 -8.9955,8.65601 l 0,-9.83772 -19.6321,0 0,92.79358 19.6321,0 0,-35.30352 c 2.7066,3.92164 5.7036,6.83432 8.9955,8.71511 3.2918,1.84076 7.0832,2.74747 11.3626,2.74747 7.5712,0 13.7891,-3.27499 18.6537,-9.83772 4.8646,-6.60272 7.291,-15.10147 7.2911,-25.4658 -1e-4,-10.36426 -2.4265,-18.81437 -7.2911,-25.37716 -4.8646,-6.60268 -11.0825,-9.89674 -18.6537,-9.89681 z m -7.3226,15.59854 c 4.2062,7e-5 7.4321,1.69046 9.6267,5.0518 2.2311,3.36145 3.3456,8.22101 3.3457,14.62363 -10e-5,6.4027 -1.1146,11.2918 -3.3457,14.65318 -2.1946,3.36141 -5.4205,5.05181 -9.6267,5.05179 -4.2063,2e-5 -7.4221,-1.69038 -9.6898,-5.05179 -2.2312,-3.40139 -3.3457,-8.29051 -3.3457,-14.65318 0,-6.3626 1.1145,-11.20309 3.3457,-14.56454 2.2677,-3.40136 5.4835,-5.11082 9.6898,-5.11089 z" />
+ <path
+ id="path2406"
+ d="m 436.38057,496.61031 0,93.38442 19.6637,0 0,-9.71955 c 2.7066,3.92164 5.7036,6.83432 8.9954,8.71511 3.2918,1.84076 7.0517,2.74747 11.3311,2.74747 7.5712,0 13.7891,-3.27499 18.6537,-9.83772 4.8646,-6.60272 7.3226,-15.10147 7.3226,-25.4658 0,-10.36426 -2.458,-18.81437 -7.3226,-25.37716 -4.8646,-6.60268 -11.0825,-9.89674 -18.6537,-9.89681 -4.2794,7e-5 -8.0393,0.92586 -11.3311,2.80656 -3.2918,1.84083 -6.2888,4.73445 -8.9954,8.65601 l 0,-36.01253 -19.6637,0 z m 32.6992,40.1485 c 4.2062,7e-5 7.4005,1.69046 9.5951,5.0518 2.2311,3.36145 3.3456,8.22101 3.3457,14.62363 -1e-4,6.4027 -1.1146,11.2918 -3.3457,14.65318 -2.1946,3.36141 -5.3889,5.05181 -9.5951,5.05179 -4.2063,2e-5 -7.4222,-1.69038 -9.6898,-5.05179 -2.2312,-3.40139 -3.3458,-8.29051 -3.3457,-14.65318 -10e-5,-6.3626 1.1145,-11.20309 3.3457,-14.56454 2.2676,-3.40136 5.4835,-5.11082 9.6898,-5.11089 z" />
+ <path
+ id="path2402"
+ d="m 546.37747,521.16027 c -10.6071,7e-5 -18.9263,3.14158 -24.9979,9.42412 -6.035,6.28267 -9.0586,14.88533 -9.0586,25.84985 0,11.16467 3.0716,19.85408 9.2164,26.05665 6.1813,6.16255 14.8256,9.24687 25.9448,9.24687 4.6451,0 9.3056,-0.50625 13.9508,-1.50669 4.6451,-0.96039 9.2741,-2.39242 13.9193,-4.31322 l 0,-16.57346 c -4.5721,2.72115 -9.0303,4.78435 -13.3827,6.14488 -4.3161,1.32057 -8.5237,1.97937 -12.6568,1.97937 -5.1207,0 -9.1095,-1.26041 -11.9624,-3.78147 -2.8529,-2.52104 -4.543,-6.30227 -5.0185,-11.3444 l 45.9241,0 0,-6.14487 c 0,-10.64438 -2.8958,-19.13264 -8.7113,-25.49534 -5.7791,-6.36257 -13.5112,-9.54222 -23.1672,-9.54229 z m -0.0947,14.26913 c 3.5112,5e-5 6.3324,1.26047 8.4904,3.78145 2.1945,2.48108 3.314,5.78561 3.3141,9.86727 l -25.5344,0 c 0.5852,-4.40179 2.0729,-7.78259 4.4504,-10.10361 2.3774,-2.36092 5.4755,-3.54506 9.2795,-3.54511 z" />
+ <path
+ id="path2398"
+ d="m 654.85617,549.06534 0,40.93701 -19.751,0 0,-6.66277 0,-24.67024 c 0,-5.80239 -0.128,-9.80405 -0.384,-12.00499 -0.2195,-2.20088 -0.6219,-3.82154 -1.207,-4.86203 -0.7682,-1.40055 -1.8106,-2.48097 -3.1273,-3.24135 -1.3168,-0.80028 -2.8164,-1.20045 -4.4988,-1.20049 -4.0966,4e-5 -7.3152,1.74076 -9.6561,5.22217 -2.3409,3.44148 -3.5113,8.22345 -3.5113,14.34595 l 0,33.07375 -19.6412,0 0,-67.22794 19.6412,0 0,9.84408 c 2.9627,-3.92156 6.1082,-6.80276 9.4366,-8.64359 3.3284,-1.88072 7.0043,-2.8211 11.0277,-2.82117 7.0957,7e-5 12.4723,2.38107 16.13,7.14297 3.6941,4.76203 5.5412,11.68491 5.5412,20.76864" />
+ <path
+ id="path2396"
+ d="m 714.98677,496.61031 0,36.01253 c -2.7067,-3.92156 -5.7037,-6.81518 -8.9955,-8.65601 -3.2553,-1.8807 -6.9936,-2.80649 -11.2364,-2.80656 -7.5712,7e-5 -13.7891,3.29414 -18.6537,9.89681 -4.8646,6.56279 -7.3226,15.0129 -7.3226,25.37716 0,10.36433 2.458,18.86308 7.3226,25.4658 4.8646,6.56273 11.0824,9.83772 18.6537,9.83772 4.2794,0 8.0443,-0.90671 11.2995,-2.74747 3.2553,-1.84077 6.2257,-4.75345 8.9324,-8.71511 l 0,9.71955 19.7584,0 0,-93.38442 -19.7584,0 z m -12.9409,40.1485 c 4.2062,7e-5 7.4006,1.69046 9.5952,5.0518 2.2311,3.36145 3.3456,8.22101 3.3457,14.62363 -10e-5,6.4027 -1.1146,11.2918 -3.3457,14.65318 -2.1946,3.36141 -5.389,5.05181 -9.5952,5.05179 -4.1696,2e-5 -7.364,-1.69038 -9.5951,-5.05179 -2.1946,-3.36138 -3.3141,-8.25048 -3.3141,-14.65318 0,-6.40262 1.1195,-11.26219 3.3141,-14.62363 2.2311,-3.36134 5.4254,-5.05173 9.5951,-5.0518 z" />
+ <path
+ id="path2392"
+ d="m 783.19427,521.16027 c -10.6071,7e-5 -18.9578,3.14158 -25.0294,9.42412 -6.0351,6.28267 -9.0586,14.88533 -9.0586,25.84985 0,11.16467 3.0716,19.85408 9.2164,26.05665 6.1813,6.16255 14.8256,9.24687 25.9447,9.24687 4.6451,0 9.3057,-0.50625 13.9509,-1.50669 4.6451,-0.96039 9.274,-2.39242 13.9192,-4.31322 l 0,-16.57346 c -4.572,2.72115 -9.0302,4.78435 -13.3827,6.14488 -4.316,1.32057 -8.5237,1.97937 -12.6567,1.97937 -5.1207,0 -9.1095,-1.26041 -11.9624,-3.78147 -2.8529,-2.52104 -4.5115,-6.30227 -4.9869,-11.3444 l 45.9241,0 0,-6.14487 c -10e-5,-10.64438 -2.9275,-19.13264 -8.743,-25.49534 -5.779,-6.36257 -13.4796,-9.54222 -23.1356,-9.54229 z m -0.1263,14.26913 c 3.5113,5e-5 6.364,1.26047 8.522,3.78145 2.1945,2.48108 3.2826,5.78561 3.2826,9.86727 l -25.5029,0 c 0.5852,-4.40179 2.0414,-7.78259 4.4188,-10.10361 2.3775,-2.36092 5.4756,-3.54506 9.2795,-3.54511 z" />
+ <path
+ id="text2383"
+ d="m 875.519,541.08202 c -1.7191,-0.88032 -3.4382,-1.52058 -5.1572,-1.9208 -1.6825,-0.44013 -3.3833,-0.66022 -5.1024,-0.66027 -5.0475,5e-5 -8.94283,1.78079 -11.68603,5.34222 -2.7066,3.52151 -4.0599,8.5836 -4.0599,15.18631 l 0,30.97287 -19.6413,0 0,-67.22794 19.6413,0 0,11.04458 c 2.5237,-4.40176 5.4132,-7.60308 8.66853,-9.60399 3.2918,-2.04078 7.2237,-3.0612 11.7958,-3.06127 0.6583,7e-5 1.3715,0.0401 2.1397,0.12005 0.768,0.0401 1.8836,0.16014 3.3466,0.36015 l 0.055,19.44809" />
+</svg>
Deleted: trunk/documents/logos/bender_head.svg
--- trunk/documents/logos/bender_head.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/bender_head.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,306 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Created with Inkscape (http://www.inkscape.org/) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:xlink="http://www.w3.org/1999/xlink"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- width="1000"
- height="1000"
- id="svg2"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- version="1.0"
- sodipodi:docname="bender_head.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape">
- <defs
- id="defs4">
- <inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 526.18109 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="744.09448 : 526.18109 : 1"
- inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
- id="perspective10" />
- id="perspective2447"
- sodipodi:type="inkscape:persp3d" />
- <radialGradient
- xlink:href="#linearGradient583"
- r="0.40413386"
- id="radialGradient582"
- fy="0.22549020"
- fx="0.68367344"
- cy="0.22549020"
- cx="0.68367344" />
- <radialGradient
- r="123.08747"
- id="radialGradient579"
- fy="183.44996"
- fx="201.95493"
- cy="183.44996"
- cx="201.95493"
- gradientTransform="scale(1.0032556,0.996755)"
- gradientUnits="userSpaceOnUse" />
- <linearGradient
- id="linearGradient576">
- <stop
- style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
- offset="0.00000000"
- id="stop577" />
- <stop
- style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
- offset="1.00000000"
- id="stop578" />
- </linearGradient>
- <linearGradient
- id="linearGradient583">
- <stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
- id="stop584" />
- <stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
- id="stop585" />
- </linearGradient>
- id="perspective3349"
- inkscape:persp3d-origin="250 : 166.66667 : 1"
- inkscape:vp_z="500 : 250 : 1"
- inkscape:vp_x="0 : 250 : 1"
- </defs>
- <sodipodi:namedview
- id="base"
- pagecolor="#ffffff"
- bordercolor="#666666"
- borderopacity="1.0"
- gridtolerance="10000"
- guidetolerance="10"
- objecttolerance="10"
- inkscape:pageopacity="0.0"
- inkscape:pageshadow="2"
- inkscape:zoom="0.35"
- inkscape:cx="942.17942"
- inkscape:cy="264.62643"
- inkscape:document-units="px"
- inkscape:current-layer="layer1"
- showgrid="false"
- inkscape:window-width="1400"
- inkscape:window-height="975"
- inkscape:window-x="0"
- inkscape:window-y="25" />
- <metadata
- id="metadata7">
- <rdf:RDF>
- <cc:Work
- rdf:about="">
- <dc:format>image/svg+xml</dc:format>
- <dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
- </cc:Work>
- </rdf:RDF>
- </metadata>
- <g
- inkscape:label="Layer 1"
- inkscape:groupmode="layer"
- id="layer1">
- <rect
- style="opacity:1;fill:#0000ff;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
- id="rect3371"
- width="1000"
- height="1008.5714"
- x="2.8571429"
- y="-2.0463631e-12" />
- <image
- y="19.190197"
- x="1033.7516"
- id="image2449"
- height="1683.3893"
- width="1433.6854"
- sodipodi:absref="/home/seven/data/work/mapbender/logo/bender_angry.jpg"
- xlink:href="bender_angry.jpg" />
- <path
- style="fill:#ffffff;fill-opacity:1;stroke:#828786;stroke-width:11.11559199999999947;stroke-opacity:1"
- d="M 587.41108,230.71741 C 587.41108,290.93793 727.52515,785.42175 734.98383,815.50102 C 549.17152,803.68624 321.43568,879.43073 177.38908,958.50641 C 176.31131,958.50641 95.384695,351.15844 95.384695,230.71741 C 95.384695,110.2764 205.5986,12.527151 341.39788,12.527151 C 477.19717,12.527151 587.41108,110.2764 587.41108,230.71741 z"
- id="path2453"
- sodipodi:nodetypes="cccssc" />
- <path
- style="opacity:1;fill:#cccccc;fill-opacity:1;stroke:#7c7c79;stroke-width:9.88463497000000046;stroke-opacity:1"
- d="M 720.01021,249.52291 C 718.24824,307.2057 709.64515,435.52001 666.10778,501.33466 C 589.76885,510.58006 509.54058,519.91095 392.64443,548.64855 C 213.41409,592.71033 186.88083,638.23725 141.92509,605.53532 C 96.969323,572.83339 33.591095,461.9026 14.968994,415.63231 C -10.709046,351.83012 20.512064,281.929 340.3433,217.07938 C 549.51484,174.66729 675.97127,124.37515 720.01021,249.52291 z"
- id="path3229"
- sodipodi:nodetypes="ccscssc" />
- <path
- style="fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:8.69787883999999956;stroke-opacity:1"
- d="M 674.34466,287.35225 C 671.30678,390.97207 720.24856,402.50711 399.70895,474.47597 C 83.235675,545.53185 107.4477,510.88197 75.340843,427.76326 C 53.204754,370.457 71.333136,316.45897 347.04783,258.21192 C 527.36691,220.11797 636.38037,174.94626 674.34466,287.35225 z"
- id="path3226"
- sodipodi:nodetypes="csssc" />
- <path
- sodipodi:type="arc"
- style="fill:#ff0000;fill-opacity:1;stroke:#000000;stroke-width:0;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
- id="path3231"
- sodipodi:cx="415.1727"
- sodipodi:cy="439.36533"
- sodipodi:rx="65.659912"
- sodipodi:ry="61.619305"
- d="M 480.83261,439.36533 A 65.659912,61.619305 0 1 1 349.51279,439.36533 A 65.659912,61.619305 0 1 1 480.83261,439.36533 z"
- transform="matrix(1.6694906,0,0,1.6694906,-420.85919,-329.37473)" />
- <path
- id="path3233"
- transform="matrix(1.6372348,0,0,1.6372348,-164.613,-373.237)" />
- <path
- style="fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
- id="path3235"
- sodipodi:cx="386.88843"
- sodipodi:cy="466.63947"
- sodipodi:rx="25.253813"
- sodipodi:ry="24.243662"
- d="M 412.14224,466.63947 A 25.253813,24.243662 0 1 1 361.63461,466.63947 A 25.253813,24.243662 0 1 1 412.14224,466.63947 z"
- transform="matrix(1.4496465,0,0,1.4496465,-1085.9012,-288.10519)" />
- <path
- id="path3237"
- transform="matrix(1.4496465,0,0,1.4496465,-892.43581,-378.0622)" />
- <path
- style="fill:#0000ff;fill-opacity:1;stroke:#000000;stroke-width:8.69787883999999956;stroke-opacity:1"
- d="M 648.126,630.73462 C 653.80739,657.21094 687.19916,734.83462 638.31741,763.48641 C 589.43567,792.13825 586.72198,782.30677 474.70917,797.81815 C 352.72151,814.71084 304.14617,870.40061 250.00929,873.8446 C 195.87243,877.28862 163.86111,747.11099 181.0472,726.18465 C 249.16702,643.23977 329.46623,615.6431 404.25244,588.3884 C 576.14643,556.14803 636.76323,577.78199 648.126,630.73462 z"
- id="path3239"
- sodipodi:nodetypes="csscscc" />
- <path
- style="fill:#ffffff;fill-rule:evenodd;stroke:#000000;stroke-width:1.44964647000000002px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
- d="M 162.16362,1003.4118 C 162.16362,1003.4118 156.2315,994.12629 182.33813,979.00746 C 294.97789,913.77572 545.1953,822.94957 745.56238,835.49979 C 846.82693,860.32138 937.35394,1001.5432 937.35394,1001.5432 C 937.35394,1001.5432 162.16362,1003.4118 162.16362,1003.4118 z"
- id="path3242"
- sodipodi:nodetypes="csccc" />
- <path
- d="M 276.13146,653.57693 C 226.46511,698.77358 208.55775,684.63958 225.59757,699.38662 C 242.63738,714.13365 207.60587,736.69258 255.64106,710.65366 C 303.67625,684.61475 292.74446,721.92181 337.26265,726.91279 C 381.78084,731.90377 367.55505,686.66252 398.95738,726.11846 C 448.93114,749.86012 450.77616,725.20438 444.65194,685.99981 C 468.52773,637.50954 399.40762,676.69131 424.26422,639.80411 C 449.12083,602.91691 493.74252,585.43818 438.73851,593.12668 C 367.62865,626.24898 340.05615,652.75918 308.53226,650.00376 C 277.00837,647.24835 278.06457,653.52836 276.13146,653.57693 z"
- id="path580"
- sodipodi:nodetypes="cccccccccc"
- style="fill:#00bd00;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1" />
- <path
- d="M 565.52271,631.32808 C 559.87456,661.22904 567.06016,669.32587 533.12232,675.30261 C 499.18449,681.27936 470.31986,682.79288 497.95878,697.07654 C 525.5977,711.3602 581.57275,680.58896 553.26474,708.4972 C 524.95672,736.40545 549.82311,734.20405 483.39036,760.50812 C 416.95761,786.81219 509.71641,780.24187 516.31727,779.09063 C 561.92915,767.49942 668.17098,741.73846 641.47769,631.24076 C 599.62772,584.4018 566.58829,631.89255 565.52271,631.32808 z"
- id="path586"
- sodipodi:nodetypes="cccccccc"
- <path
- d="M 229.39497,774.5896 C 242.4834,760.07101 277.217,763.91439 296.81216,764.99871 C 316.40732,766.08303 302.07402,767.42855 337.60553,765.15628 C 373.13704,762.88401 362.02858,748.77628 384.48102,755.30705 C 406.93347,761.83782 380.59606,766.83529 374.84399,778.80459 C 369.09193,790.7739 293.38329,854.35404 292.59114,849.64402 C 291.79899,844.93401 233.71215,863.01184 229.39497,774.5896 z"
- id="path587"
- sodipodi:nodetypes="csssssc" />
- <path
- d="M 421.90652,614.24296 C 411.97692,612.9158 376.59659,644.94333 343.79034,651.87704 C 310.9841,658.81076 303.5157,660.57503 274.36827,671.94966 C 245.22084,683.32428 238.45048,706.55273 263.06218,697.06578 C 268.35216,682.34897 321.38297,713.02971 349.24805,711.34422 C 374.97026,678.23015 427.20564,729.83591 423.28806,701.43629 C 400.4163,668.33567 407.87517,634.69764 421.90652,614.24296 z"
- id="path606"
- sodipodi:nodetypes="ccccccc"
- style="fill:#b77719;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1" />
- <path
- d="M 285.78887,780.25374 C 296.65202,781.36036 313.84261,785.4613 326.85566,776.26576 C 364.0656,766.65937 380.87885,756.97419 370.12898,768.08367 C 331.24998,779.30863 329.68576,819.12781 294.47494,829.07813 C 287.47801,827.87437 260.63969,792.31623 285.78887,780.25374 z"
- id="path607"
- sodipodi:nodetypes="ccccc"
- <path
- d="M 593.57646,636.53564 C 594.22721,646.1762 634.99245,663.48043 599.38557,671.07575 C 563.77868,678.67107 543.51402,679.37728 547.17283,683.8182 C 550.83164,688.25911 593.57686,676.937 595.22718,686.74954 C 596.8775,696.56207 557.69696,729.07923 540.2142,740.55495 C 522.73145,752.03067 488.78424,763.72296 480.17489,770.24582 C 619.9432,735.59561 681.58474,623.09094 593.57646,636.53564 z"
- id="path608"
- <path
- style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
- d="M 179.80716,777.76644 C 179.80716,777.76644 205.22775,720.43539 402.04071,656.54813 C 611.19218,588.65568 652.55855,656.54814 652.55855,656.54814 L 664.68037,727.25882 C 664.68037,727.25882 631.3411,648.14795 413.15239,726.24866 C 205.66766,800.51788 202.03051,832.31468 202.03051,832.31468 L 202.03051,832.31468"
- id="path3377"
- sodipodi:nodetypes="csccscc" />
- <path
- style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:7;stroke-dasharray:none"
- d="M 201.43877,704.81138 L 230.31478,868.68017"
- id="path3379"
- sodipodi:nodetypes="cc" />
- <path
- d="M 245.29375,665.58874 L 283.90363,864.29293"
- id="path3381"
- <path
- d="M 304.82097,632.30447 L 346.65565,835.76355"
- id="path3383"
- <path
- d="M 371.02185,601.06153 L 411.77458,809.0304"
- id="path3385"
- <path
- d="M 458.60926,577.75624 L 495.19884,797.37776"
- id="path3387"
- <path
- d="M 535.97259,574.55246 L 569.48094,784.78675"
- id="path3389"
- <path
- d="M 609.31633,586.22614 L 636.86529,765.76716"
- id="path3391"
- <path
- style="fill:#ff0000;fill-opacity:1;stroke:#ff0000;stroke-width:6;stroke-opacity:1"
- id="path3400"
- transform="matrix(1.9391717,0,0,2.2541963,-1250.2431,-833.32554)" />
- <path
- id="path3402"
- transform="matrix(1.9391717,0,0,2.2541963,-1181.6717,-983.32553)" />
- <rect
- style="opacity:1;fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:8.47010803;stroke-miterlimit:7;stroke-dasharray:none;stroke-opacity:1"
- id="rect3404"
- width="37.351372"
- height="35.199127"
- x="194.5947"
- y="517.55481"
- transform="matrix(0.9733357,-0.2293853,0.1545064,0.9879918,0,0)" />
- <rect
- style="opacity:1;fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:8.79132557;stroke-miterlimit:7;stroke-dasharray:none;stroke-opacity:1"
- id="rect3406"
- width="40.336361"
- height="35.113373"
- x="319.84579"
- y="552.48206"
- transform="matrix(0.9472137,-0.320603,0.3761615,0.9265541,0,0)" />
- </g>
-</svg>
Deleted: trunk/documents/logos/bender_head2.svg
--- trunk/documents/logos/bender_head2.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/bender_head2.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,261 +0,0 @@
-<svg
- width="1000"
- height="1000"
- id="svg2"
- version="1.0"
- sodipodi:docname="bender_head2.svg"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/bender_head_fav_icon.png"
- inkscape:export-xdpi="2.8800001"
- inkscape:export-ydpi="2.8800001">
- <defs
- id="defs4">
- <radialGradient
- r="0.40413386"
- fy="0.22549020"
- fx="0.68367344"
- cy="0.22549020"
- <radialGradient
- r="123.08747"
- fy="183.44996"
- fx="201.95493"
- cy="183.44996"
- cx="201.95493"
- <linearGradient
- <stop
- id="stop577" />
- <stop
- id="stop578" />
- </linearGradient>
- <linearGradient
- <stop
- id="stop584" />
- <stop
- id="stop585" />
- </linearGradient>
- </defs>
- id="base"
- inkscape:zoom="0.49497475"
- inkscape:cx="365.28142"
- inkscape:cy="457.40859"
- showgrid="false"
- <metadata
- id="metadata7">
- <rdf:RDF>
- <cc:Work
- rdf:about="">
- <dc:type
- </cc:Work>
- </rdf:RDF>
- </metadata>
- <g
- id="layer1">
- <rect
- style="opacity:1;fill:#00ffff;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
- id="rect3371"
- width="1000"
- x="2.8571429"
- <path
- id="path2453"
- <path
- id="path3229"
- <path
- id="path3226"
- <path
- id="path3231"
- <path
- id="path3233"
- <path
- id="path3239"
- <path
- id="path3242"
- <path
- id="path580"
- <path
- id="path586"
- <path
- id="path587"
- <path
- id="path606"
- <path
- id="path607"
- <path
- id="path608"
- <path
- style="fill:none;fill-rule:evenodd;stroke:#ffffff;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
- id="path3377"
- <path
- style="fill:#ffffff;fill-rule:evenodd;stroke:#ffffff;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:7;stroke-dasharray:none"
- id="path3379"
- <path
- id="path3381"
- <path
- id="path3383"
- <path
- id="path3385"
- <path
- id="path3387"
- <path
- id="path3389"
- <path
- id="path3391"
- <rect
- id="rect3404"
- width="37.351372"
- x="194.5947"
- y="517.55481"
- <rect
- id="rect3406"
- width="40.336361"
- x="319.84579"
- y="552.48206"
- </g>
-</svg>
Deleted: trunk/documents/logos/bender_head_red.svg
--- trunk/documents/logos/bender_head_red.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/bender_head_red.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,261 +0,0 @@
-<svg
- width="1000"
- height="1000"
- id="svg2"
- version="1.0"
- sodipodi:docname="bender_head_red.svg"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/bender_head_130.png"
- inkscape:export-xdpi="11.7"
- inkscape:export-ydpi="11.7">
- <defs
- id="defs4">
- <radialGradient
- r="0.40413386"
- fy="0.22549020"
- fx="0.68367344"
- cy="0.22549020"
- <radialGradient
- r="123.08747"
- fy="183.44996"
- fx="201.95493"
- cy="183.44996"
- cx="201.95493"
- <linearGradient
- <stop
- id="stop577" />
- <stop
- id="stop578" />
- </linearGradient>
- <linearGradient
- <stop
- id="stop584" />
- <stop
- id="stop585" />
- </linearGradient>
- </defs>
- id="base"
- inkscape:zoom="0.12374369"
- inkscape:cy="484.30843"
- showgrid="false"
- <metadata
- id="metadata7">
- <rdf:RDF>
- <cc:Work
- rdf:about="">
- <dc:type
- </cc:Work>
- </rdf:RDF>
- </metadata>
- <g
- id="layer1">
- <rect
- style="opacity:1;fill:#ff0000;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
- id="rect3371"
- width="1000"
- x="2.8571429"
- <path
- style="fill:#cccccc;fill-opacity:1;stroke:#d4d6d8;stroke-width:11.11559199999999947;stroke-opacity:1"
- id="path2453"
- <path
- style="opacity:1;fill:#808080;fill-opacity:1;stroke:#a7a9ab;stroke-width:9.88463497000000046;stroke-opacity:1"
- d="M 720.01021,249.52291 C 718.24824,307.2057 695.50301,440.57077 651.96564,506.38542 C 575.62671,515.63082 544.89592,496.67744 427.99977,525.41504 C 248.76943,569.47682 186.88083,638.23725 141.92509,605.53532 C 96.969323,572.83339 33.591095,461.9026 14.968994,415.63231 C -10.709046,351.83012 20.512064,281.929 340.3433,217.07938 C 549.51484,174.66729 675.97127,124.37515 720.01021,249.52291 z"
- id="path3229"
- <path
- id="path3226"
- <path
- style="fill:#ffffff;fill-opacity:1;stroke:#000000;stroke-width:0;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
- id="path3231"
- transform="matrix(1.6694906,0,0,1.6694906,-420.85919,-333.37473)" />
- <path
- id="path3233"
- <path
- id="path3239"
- <path
- style="fill:#808080;fill-rule:evenodd;stroke:#000000;stroke-width:1.44964647000000002px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
- id="path3242"
- <path
- id="path580"
- <path
- id="path586"
- <path
- id="path587"
- <path
- id="path606"
- <path
- id="path607"
- <path
- id="path608"
- <path
- style="fill:none;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:round;stroke-opacity:1;stroke-miterlimit:6.62500000000000000;stroke-dasharray:none"
- d="M 184.09287,772.05215 C 184.09287,772.05215 205.22775,720.43539 402.04071,656.54813 C 611.19218,588.65568 644.70141,643.691 644.70141,643.691 L 657.90516,708.4633 C 657.90516,708.4633 631.3411,648.14795 413.15239,726.24866 C 205.66766,800.51788 206.31622,832.31468 206.31622,832.31468"
- id="path3377"
- sodipodi:nodetypes="csccsc" />
- <path
- style="fill:#ffffff;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:6.62500000000000000;stroke-dasharray:none"
- d="M 202.86734,708.38281 L 232.45764,863.68017"
- id="path3379"
- <path
- d="M 246.72232,672.01731 L 282.47506,860.7215"
- id="path3381"
- <path
- d="M 304.82097,632.30447 L 347.36994,830.76355"
- id="path3383"
- <path
- d="M 371.73614,606.77582 L 411.06029,806.88754"
- id="path3385"
- <path
- d="M 459.32355,584.18481 L 494.48455,791.66347"
- id="path3387"
- <path
- d="M 537.40116,579.55246 L 568.76665,781.92961"
- id="path3389"
- <path
- d="M 601.45919,587.65471 L 629.00815,761.48144"
- id="path3391"
- <rect
- id="rect3404"
- width="37.351372"
- x="194.5947"
- y="517.55481"
- <rect
- id="rect3406"
- width="40.336361"
- x="356.79724"
- y="530.44727"
- transform="matrix(0.9662771,-0.2575045,0.3143034,0.9493226,0,0)" />
- </g>
-</svg>
Copied: trunk/documents/logos/logo_contest/bender_head.svg (from rev 6635, trunk/documents/logos/bender_head.svg)
--- trunk/documents/logos/logo_contest/bender_head.svg (rev 0)
+++ trunk/documents/logos/logo_contest/bender_head.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,306 @@
+<svg
+ width="1000"
+ height="1000"
+ id="svg2"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ version="1.0"
+ sodipodi:docname="bender_head.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape">
+ <defs
+ id="defs4">
+ inkscape:vp_x="0 : 526.18109 : 1"
+ inkscape:vp_z="744.09448 : 526.18109 : 1"
+ inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
+ id="perspective10" />
+ id="perspective2447"
+ sodipodi:type="inkscape:persp3d" />
+ <radialGradient
+ xlink:href="#linearGradient583"
+ r="0.40413386"
+ id="radialGradient582"
+ fy="0.22549020"
+ fx="0.68367344"
+ cy="0.22549020"
+ cx="0.68367344" />
+ <radialGradient
+ r="123.08747"
+ id="radialGradient579"
+ fy="183.44996"
+ fx="201.95493"
+ cy="183.44996"
+ cx="201.95493"
+ gradientTransform="scale(1.0032556,0.996755)"
+ gradientUnits="userSpaceOnUse" />
+ <linearGradient
+ id="linearGradient576">
+ <stop
+ style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
+ offset="0.00000000"
+ id="stop577" />
+ <stop
+ style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
+ offset="1.00000000"
+ id="stop578" />
+ </linearGradient>
+ <linearGradient
+ id="linearGradient583">
+ <stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
+ id="stop584" />
+ <stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
+ id="stop585" />
+ </linearGradient>
+ id="perspective3349"
+ inkscape:persp3d-origin="250 : 166.66667 : 1"
+ inkscape:vp_z="500 : 250 : 1"
+ inkscape:vp_x="0 : 250 : 1"
+ </defs>
+ id="base"
+ borderopacity="1.0"
+ gridtolerance="10000"
+ inkscape:pageopacity="0.0"
+ inkscape:zoom="0.35"
+ inkscape:cx="942.17942"
+ inkscape:cy="264.62643"
+ inkscape:document-units="px"
+ inkscape:current-layer="layer1"
+ showgrid="false"
+ inkscape:window-width="1400"
+ inkscape:window-height="975"
+ inkscape:window-y="25" />
+ <metadata
+ id="metadata7">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:type
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ inkscape:label="Layer 1"
+ inkscape:groupmode="layer"
+ id="layer1">
+ <rect
+ style="opacity:1;fill:#0000ff;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
+ id="rect3371"
+ width="1000"
+ height="1008.5714"
+ x="2.8571429"
+ y="-2.0463631e-12" />
+ <image
+ y="19.190197"
+ x="1033.7516"
+ id="image2449"
+ height="1683.3893"
+ width="1433.6854"
+ sodipodi:absref="/home/seven/data/work/mapbender/logo/bender_angry.jpg"
+ xlink:href="bender_angry.jpg" />
+ <path
+ style="fill:#ffffff;fill-opacity:1;stroke:#828786;stroke-width:11.11559199999999947;stroke-opacity:1"
+ d="M 587.41108,230.71741 C 587.41108,290.93793 727.52515,785.42175 734.98383,815.50102 C 549.17152,803.68624 321.43568,879.43073 177.38908,958.50641 C 176.31131,958.50641 95.384695,351.15844 95.384695,230.71741 C 95.384695,110.2764 205.5986,12.527151 341.39788,12.527151 C 477.19717,12.527151 587.41108,110.2764 587.41108,230.71741 z"
+ id="path2453"
+ sodipodi:nodetypes="cccssc" />
+ <path
+ style="opacity:1;fill:#cccccc;fill-opacity:1;stroke:#7c7c79;stroke-width:9.88463497000000046;stroke-opacity:1"
+ d="M 720.01021,249.52291 C 718.24824,307.2057 709.64515,435.52001 666.10778,501.33466 C 589.76885,510.58006 509.54058,519.91095 392.64443,548.64855 C 213.41409,592.71033 186.88083,638.23725 141.92509,605.53532 C 96.969323,572.83339 33.591095,461.9026 14.968994,415.63231 C -10.709046,351.83012 20.512064,281.929 340.3433,217.07938 C 549.51484,174.66729 675.97127,124.37515 720.01021,249.52291 z"
+ id="path3229"
+ sodipodi:nodetypes="ccscssc" />
+ <path
+ style="fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:8.69787883999999956;stroke-opacity:1"
+ d="M 674.34466,287.35225 C 671.30678,390.97207 720.24856,402.50711 399.70895,474.47597 C 83.235675,545.53185 107.4477,510.88197 75.340843,427.76326 C 53.204754,370.457 71.333136,316.45897 347.04783,258.21192 C 527.36691,220.11797 636.38037,174.94626 674.34466,287.35225 z"
+ id="path3226"
+ sodipodi:nodetypes="csssc" />
+ <path
+ sodipodi:type="arc"
+ style="fill:#ff0000;fill-opacity:1;stroke:#000000;stroke-width:0;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3231"
+ sodipodi:cx="415.1727"
+ sodipodi:cy="439.36533"
+ sodipodi:rx="65.659912"
+ sodipodi:ry="61.619305"
+ d="M 480.83261,439.36533 A 65.659912,61.619305 0 1 1 349.51279,439.36533 A 65.659912,61.619305 0 1 1 480.83261,439.36533 z"
+ transform="matrix(1.6694906,0,0,1.6694906,-420.85919,-329.37473)" />
+ <path
+ id="path3233"
+ transform="matrix(1.6372348,0,0,1.6372348,-164.613,-373.237)" />
+ <path
+ style="fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
+ id="path3235"
+ sodipodi:cx="386.88843"
+ sodipodi:cy="466.63947"
+ sodipodi:rx="25.253813"
+ sodipodi:ry="24.243662"
+ d="M 412.14224,466.63947 A 25.253813,24.243662 0 1 1 361.63461,466.63947 A 25.253813,24.243662 0 1 1 412.14224,466.63947 z"
+ transform="matrix(1.4496465,0,0,1.4496465,-1085.9012,-288.10519)" />
+ <path
+ id="path3237"
+ transform="matrix(1.4496465,0,0,1.4496465,-892.43581,-378.0622)" />
+ <path
+ style="fill:#0000ff;fill-opacity:1;stroke:#000000;stroke-width:8.69787883999999956;stroke-opacity:1"
+ d="M 648.126,630.73462 C 653.80739,657.21094 687.19916,734.83462 638.31741,763.48641 C 589.43567,792.13825 586.72198,782.30677 474.70917,797.81815 C 352.72151,814.71084 304.14617,870.40061 250.00929,873.8446 C 195.87243,877.28862 163.86111,747.11099 181.0472,726.18465 C 249.16702,643.23977 329.46623,615.6431 404.25244,588.3884 C 576.14643,556.14803 636.76323,577.78199 648.126,630.73462 z"
+ id="path3239"
+ sodipodi:nodetypes="csscscc" />
+ <path
+ style="fill:#ffffff;fill-rule:evenodd;stroke:#000000;stroke-width:1.44964647000000002px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
+ d="M 162.16362,1003.4118 C 162.16362,1003.4118 156.2315,994.12629 182.33813,979.00746 C 294.97789,913.77572 545.1953,822.94957 745.56238,835.49979 C 846.82693,860.32138 937.35394,1001.5432 937.35394,1001.5432 C 937.35394,1001.5432 162.16362,1003.4118 162.16362,1003.4118 z"
+ id="path3242"
+ sodipodi:nodetypes="csccc" />
+ <path
+ d="M 276.13146,653.57693 C 226.46511,698.77358 208.55775,684.63958 225.59757,699.38662 C 242.63738,714.13365 207.60587,736.69258 255.64106,710.65366 C 303.67625,684.61475 292.74446,721.92181 337.26265,726.91279 C 381.78084,731.90377 367.55505,686.66252 398.95738,726.11846 C 448.93114,749.86012 450.77616,725.20438 444.65194,685.99981 C 468.52773,637.50954 399.40762,676.69131 424.26422,639.80411 C 449.12083,602.91691 493.74252,585.43818 438.73851,593.12668 C 367.62865,626.24898 340.05615,652.75918 308.53226,650.00376 C 277.00837,647.24835 278.06457,653.52836 276.13146,653.57693 z"
+ id="path580"
+ sodipodi:nodetypes="cccccccccc"
+ style="fill:#00bd00;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1" />
+ <path
+ d="M 565.52271,631.32808 C 559.87456,661.22904 567.06016,669.32587 533.12232,675.30261 C 499.18449,681.27936 470.31986,682.79288 497.95878,697.07654 C 525.5977,711.3602 581.57275,680.58896 553.26474,708.4972 C 524.95672,736.40545 549.82311,734.20405 483.39036,760.50812 C 416.95761,786.81219 509.71641,780.24187 516.31727,779.09063 C 561.92915,767.49942 668.17098,741.73846 641.47769,631.24076 C 599.62772,584.4018 566.58829,631.89255 565.52271,631.32808 z"
+ id="path586"
+ sodipodi:nodetypes="cccccccc"
+ <path
+ d="M 229.39497,774.5896 C 242.4834,760.07101 277.217,763.91439 296.81216,764.99871 C 316.40732,766.08303 302.07402,767.42855 337.60553,765.15628 C 373.13704,762.88401 362.02858,748.77628 384.48102,755.30705 C 406.93347,761.83782 380.59606,766.83529 374.84399,778.80459 C 369.09193,790.7739 293.38329,854.35404 292.59114,849.64402 C 291.79899,844.93401 233.71215,863.01184 229.39497,774.5896 z"
+ id="path587"
+ sodipodi:nodetypes="csssssc" />
+ <path
+ d="M 421.90652,614.24296 C 411.97692,612.9158 376.59659,644.94333 343.79034,651.87704 C 310.9841,658.81076 303.5157,660.57503 274.36827,671.94966 C 245.22084,683.32428 238.45048,706.55273 263.06218,697.06578 C 268.35216,682.34897 321.38297,713.02971 349.24805,711.34422 C 374.97026,678.23015 427.20564,729.83591 423.28806,701.43629 C 400.4163,668.33567 407.87517,634.69764 421.90652,614.24296 z"
+ id="path606"
+ sodipodi:nodetypes="ccccccc"
+ style="fill:#b77719;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1" />
+ <path
+ d="M 285.78887,780.25374 C 296.65202,781.36036 313.84261,785.4613 326.85566,776.26576 C 364.0656,766.65937 380.87885,756.97419 370.12898,768.08367 C 331.24998,779.30863 329.68576,819.12781 294.47494,829.07813 C 287.47801,827.87437 260.63969,792.31623 285.78887,780.25374 z"
+ id="path607"
+ sodipodi:nodetypes="ccccc"
+ <path
+ d="M 593.57646,636.53564 C 594.22721,646.1762 634.99245,663.48043 599.38557,671.07575 C 563.77868,678.67107 543.51402,679.37728 547.17283,683.8182 C 550.83164,688.25911 593.57686,676.937 595.22718,686.74954 C 596.8775,696.56207 557.69696,729.07923 540.2142,740.55495 C 522.73145,752.03067 488.78424,763.72296 480.17489,770.24582 C 619.9432,735.59561 681.58474,623.09094 593.57646,636.53564 z"
+ id="path608"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
+ d="M 179.80716,777.76644 C 179.80716,777.76644 205.22775,720.43539 402.04071,656.54813 C 611.19218,588.65568 652.55855,656.54814 652.55855,656.54814 L 664.68037,727.25882 C 664.68037,727.25882 631.3411,648.14795 413.15239,726.24866 C 205.66766,800.51788 202.03051,832.31468 202.03051,832.31468 L 202.03051,832.31468"
+ id="path3377"
+ sodipodi:nodetypes="csccscc" />
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:7;stroke-dasharray:none"
+ d="M 201.43877,704.81138 L 230.31478,868.68017"
+ id="path3379"
+ sodipodi:nodetypes="cc" />
+ <path
+ d="M 245.29375,665.58874 L 283.90363,864.29293"
+ id="path3381"
+ <path
+ d="M 304.82097,632.30447 L 346.65565,835.76355"
+ id="path3383"
+ <path
+ d="M 371.02185,601.06153 L 411.77458,809.0304"
+ id="path3385"
+ <path
+ d="M 458.60926,577.75624 L 495.19884,797.37776"
+ id="path3387"
+ <path
+ d="M 535.97259,574.55246 L 569.48094,784.78675"
+ id="path3389"
+ <path
+ d="M 609.31633,586.22614 L 636.86529,765.76716"
+ id="path3391"
+ <path
+ style="fill:#ff0000;fill-opacity:1;stroke:#ff0000;stroke-width:6;stroke-opacity:1"
+ id="path3400"
+ transform="matrix(1.9391717,0,0,2.2541963,-1250.2431,-833.32554)" />
+ <path
+ id="path3402"
+ transform="matrix(1.9391717,0,0,2.2541963,-1181.6717,-983.32553)" />
+ <rect
+ style="opacity:1;fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:8.47010803;stroke-miterlimit:7;stroke-dasharray:none;stroke-opacity:1"
+ id="rect3404"
+ width="37.351372"
+ height="35.199127"
+ x="194.5947"
+ y="517.55481"
+ transform="matrix(0.9733357,-0.2293853,0.1545064,0.9879918,0,0)" />
+ <rect
+ style="opacity:1;fill:#000000;fill-opacity:1;stroke:#000000;stroke-width:8.79132557;stroke-miterlimit:7;stroke-dasharray:none;stroke-opacity:1"
+ id="rect3406"
+ width="40.336361"
+ height="35.113373"
+ x="319.84579"
+ y="552.48206"
+ transform="matrix(0.9472137,-0.320603,0.3761615,0.9265541,0,0)" />
+ </g>
+</svg>
Copied: trunk/documents/logos/logo_contest/bender_head2.svg (from rev 6635, trunk/documents/logos/bender_head2.svg)
--- trunk/documents/logos/logo_contest/bender_head2.svg (rev 0)
+++ trunk/documents/logos/logo_contest/bender_head2.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,261 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ width="1000"
+ height="1000"
+ id="svg2"
+ version="1.0"
+ sodipodi:docname="bender_head2.svg"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/bender_head_fav_icon.png"
+ inkscape:export-xdpi="2.8800001"
+ inkscape:export-ydpi="2.8800001">
+ <defs
+ id="defs4">
+ <inkscape:perspective
+ inkscape:vp_y="0 : 1000 : 0"
+ <radialGradient
+ r="0.40413386"
+ fy="0.22549020"
+ fx="0.68367344"
+ cy="0.22549020"
+ <radialGradient
+ r="123.08747"
+ fy="183.44996"
+ fx="201.95493"
+ cy="183.44996"
+ cx="201.95493"
+ <linearGradient
+ <stop
+ id="stop577" />
+ <stop
+ id="stop578" />
+ </linearGradient>
+ <linearGradient
+ <stop
+ id="stop584" />
+ <stop
+ id="stop585" />
+ </linearGradient>
+ </defs>
+ <sodipodi:namedview
+ id="base"
+ pagecolor="#ffffff"
+ bordercolor="#666666"
+ guidetolerance="10"
+ objecttolerance="10"
+ inkscape:pageshadow="2"
+ inkscape:zoom="0.49497475"
+ inkscape:cx="365.28142"
+ inkscape:cy="457.40859"
+ showgrid="false"
+ inkscape:window-x="0"
+ <metadata
+ id="metadata7">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ id="layer1">
+ <rect
+ style="opacity:1;fill:#00ffff;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
+ id="rect3371"
+ width="1000"
+ x="2.8571429"
+ <path
+ id="path2453"
+ <path
+ id="path3229"
+ <path
+ id="path3226"
+ <path
+ id="path3231"
+ <path
+ id="path3233"
+ <path
+ id="path3239"
+ <path
+ id="path3242"
+ <path
+ id="path580"
+ <path
+ id="path586"
+ <path
+ id="path587"
+ <path
+ id="path606"
+ <path
+ id="path607"
+ <path
+ id="path608"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#ffffff;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
+ id="path3377"
+ <path
+ style="fill:#ffffff;fill-rule:evenodd;stroke:#ffffff;stroke-width:7;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:7;stroke-dasharray:none"
+ id="path3379"
+ <path
+ id="path3381"
+ <path
+ id="path3383"
+ <path
+ id="path3385"
+ <path
+ id="path3387"
+ <path
+ id="path3389"
+ <path
+ id="path3391"
+ <rect
+ id="rect3404"
+ width="37.351372"
+ x="194.5947"
+ y="517.55481"
+ <rect
+ id="rect3406"
+ width="40.336361"
+ x="319.84579"
+ y="552.48206"
+ </g>
+</svg>
Copied: trunk/documents/logos/logo_contest/bender_head_red.svg (from rev 6635, trunk/documents/logos/bender_head_red.svg)
--- trunk/documents/logos/logo_contest/bender_head_red.svg (rev 0)
+++ trunk/documents/logos/logo_contest/bender_head_red.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,261 @@
+<svg
+ width="1000"
+ height="1000"
+ id="svg2"
+ version="1.0"
+ sodipodi:docname="bender_head_red.svg"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/bender_head_130.png"
+ inkscape:export-xdpi="11.7"
+ inkscape:export-ydpi="11.7">
+ <defs
+ id="defs4">
+ <radialGradient
+ r="0.40413386"
+ fy="0.22549020"
+ fx="0.68367344"
+ cy="0.22549020"
+ <radialGradient
+ r="123.08747"
+ fy="183.44996"
+ fx="201.95493"
+ cy="183.44996"
+ cx="201.95493"
+ <linearGradient
+ <stop
+ id="stop577" />
+ <stop
+ id="stop578" />
+ </linearGradient>
+ <linearGradient
+ <stop
+ id="stop584" />
+ <stop
+ id="stop585" />
+ </linearGradient>
+ </defs>
+ id="base"
+ inkscape:zoom="0.12374369"
+ inkscape:cy="484.30843"
+ showgrid="false"
+ <metadata
+ id="metadata7">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:type
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ id="layer1">
+ <rect
+ style="opacity:1;fill:#ff0000;fill-opacity:1;stroke:#000000;stroke-width:6;stroke-opacity:1"
+ id="rect3371"
+ width="1000"
+ x="2.8571429"
+ <path
+ style="fill:#cccccc;fill-opacity:1;stroke:#d4d6d8;stroke-width:11.11559199999999947;stroke-opacity:1"
+ id="path2453"
+ <path
+ style="opacity:1;fill:#808080;fill-opacity:1;stroke:#a7a9ab;stroke-width:9.88463497000000046;stroke-opacity:1"
+ d="M 720.01021,249.52291 C 718.24824,307.2057 695.50301,440.57077 651.96564,506.38542 C 575.62671,515.63082 544.89592,496.67744 427.99977,525.41504 C 248.76943,569.47682 186.88083,638.23725 141.92509,605.53532 C 96.969323,572.83339 33.591095,461.9026 14.968994,415.63231 C -10.709046,351.83012 20.512064,281.929 340.3433,217.07938 C 549.51484,174.66729 675.97127,124.37515 720.01021,249.52291 z"
+ id="path3229"
+ <path
+ id="path3226"
+ <path
+ style="fill:#ffffff;fill-opacity:1;stroke:#000000;stroke-width:0;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="path3231"
+ transform="matrix(1.6694906,0,0,1.6694906,-420.85919,-333.37473)" />
+ <path
+ id="path3233"
+ <path
+ id="path3239"
+ <path
+ style="fill:#808080;fill-rule:evenodd;stroke:#000000;stroke-width:1.44964647000000002px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
+ id="path3242"
+ <path
+ id="path580"
+ <path
+ id="path586"
+ <path
+ id="path587"
+ <path
+ id="path606"
+ <path
+ id="path607"
+ <path
+ id="path608"
+ <path
+ style="fill:none;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:round;stroke-opacity:1;stroke-miterlimit:6.62500000000000000;stroke-dasharray:none"
+ d="M 184.09287,772.05215 C 184.09287,772.05215 205.22775,720.43539 402.04071,656.54813 C 611.19218,588.65568 644.70141,643.691 644.70141,643.691 L 657.90516,708.4633 C 657.90516,708.4633 631.3411,648.14795 413.15239,726.24866 C 205.66766,800.51788 206.31622,832.31468 206.31622,832.31468"
+ id="path3377"
+ sodipodi:nodetypes="csccsc" />
+ <path
+ style="fill:#ffffff;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:6.62500000000000000;stroke-dasharray:none"
+ d="M 202.86734,708.38281 L 232.45764,863.68017"
+ id="path3379"
+ <path
+ d="M 246.72232,672.01731 L 282.47506,860.7215"
+ id="path3381"
+ <path
+ d="M 304.82097,632.30447 L 347.36994,830.76355"
+ id="path3383"
+ <path
+ d="M 371.73614,606.77582 L 411.06029,806.88754"
+ id="path3385"
+ <path
+ d="M 459.32355,584.18481 L 494.48455,791.66347"
+ id="path3387"
+ <path
+ d="M 537.40116,579.55246 L 568.76665,781.92961"
+ id="path3389"
+ <path
+ d="M 601.45919,587.65471 L 629.00815,761.48144"
+ id="path3391"
+ <rect
+ id="rect3404"
+ width="37.351372"
+ x="194.5947"
+ y="517.55481"
+ <rect
+ id="rect3406"
+ width="40.336361"
+ x="356.79724"
+ y="530.44727"
+ transform="matrix(0.9662771,-0.2575045,0.3143034,0.9493226,0,0)" />
+ </g>
+</svg>
Copied: trunk/documents/logos/logo_contest/mapbender_db_toennchen.svg (from rev 6635, trunk/documents/logos/mapbender_db_toennchen.svg)
--- trunk/documents/logos/logo_contest/mapbender_db_toennchen.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_db_toennchen.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,655 @@
+<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
+<svg
+ version="1.0"
+ id="OSGeo_x5F_logo"
+ width="200"
+ height="200"
+ viewBox="0 0 296.647 125.463"
+ overflow="visible"
+ enable-background="new 0 0 296.647 125.463"
+ xml:space="preserve"
+ sodipodi:docname="mapbender_db_toennchen.svg"
+ style="overflow:visible"><metadata
+ id="metadata241"><rdf:RDF><cc:Work
+ rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
+ id="defs239"><inkscape:perspective
+ inkscape:vp_x="0 : 62.731499 : 1"
+ inkscape:vp_z="296.647 : 62.731499 : 1"
+ inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
+ id="perspective243" /></defs><sodipodi:namedview
+ guidetolerance="10.0"
+ gridtolerance="10.0"
+ objecttolerance="10.0"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="2.6554016"
+ inkscape:cx="107.20501"
+ inkscape:cy="112.50522"
+ inkscape:current-layer="OSGeo_x5F_logo" />
+<g
+ id="Text"
+ display="none"
+ style="display:none">
+ <g
+ id="Associate">
+ <path
+ display="inline"
+ d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
+ id="path5"
+ style="fill:#0054a4;display:inline" />
+ <path
+ display="inline"
+ d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
+ id="path7"
+ <path
+ display="inline"
+ d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
+ id="path9"
+ <path
+ display="inline"
+ d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
+ id="path11"
+ <path
+ display="inline"
+ d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
+ id="path13"
+ <path
+ display="inline"
+ d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
+ id="path15"
+ <path
+ display="inline"
+ d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
+ id="path17"
+ <path
+ display="inline"
+ d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
+ id="path19"
+ <path
+ display="inline"
+ d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
+ id="path21"
+ <path
+ display="inline"
+ d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
+ id="path23"
+ <path
+ display="inline"
+ d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
+ id="path25"
+ <path
+ display="inline"
+ d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
+ id="path27"
+ <path
+ display="inline"
+ d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
+ id="path29"
+ <path
+ display="inline"
+ d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
+ id="path31"
+ <path
+ display="inline"
+ d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
+ id="path33"
+ <path
+ display="inline"
+ d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
+ id="path35"
+ <path
+ display="inline"
+ d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
+ id="path37"
+ </g>
+ <g
+ id="Supporting">
+ <path
+ display="inline"
+ d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
+ id="path40"
+ <path
+ display="inline"
+ d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
+ id="path42"
+ <path
+ display="inline"
+ d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
+ id="path44"
+ <path
+ display="inline"
+ d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
+ id="path46"
+ <path
+ display="inline"
+ d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
+ id="path48"
+ <path
+ display="inline"
+ d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
+ id="path50"
+ <path
+ display="inline"
+ d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
+ id="path52"
+ <path
+ display="inline"
+ d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
+ id="path54"
+ <path
+ display="inline"
+ d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
+ id="path56"
+ <path
+ display="inline"
+ d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
+ id="path58"
+ <path
+ display="inline"
+ d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
+ id="path60"
+ <path
+ display="inline"
+ d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
+ id="path62"
+ <path
+ display="inline"
+ d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
+ id="path64"
+ <path
+ display="inline"
+ d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
+ id="path66"
+ <path
+ display="inline"
+ d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
+ id="path68"
+ <path
+ display="inline"
+ d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
+ id="path70"
+ <path
+ display="inline"
+ d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
+ id="path72"
+ <path
+ display="inline"
+ d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
+ id="path74"
+ </g>
+ <g
+ id="Sustaining">
+ <path
+ display="inline"
+ d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
+ id="path77"
+ <path
+ display="inline"
+ d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
+ id="path79"
+ <path
+ display="inline"
+ d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
+ id="path81"
+ <path
+ display="inline"
+ d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
+ id="path83"
+ <path
+ display="inline"
+ d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
+ id="path85"
+ <path
+ display="inline"
+ d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
+ id="path87"
+ <path
+ display="inline"
+ d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
+ id="path89"
+ <path
+ display="inline"
+ d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
+ id="path91"
+ <path
+ display="inline"
+ d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
+ id="path93"
+ <path
+ display="inline"
+ d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
+ id="path95"
+ <path
+ display="inline"
+ d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
+ id="path97"
+ <path
+ display="inline"
+ d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
+ id="path99"
+ <path
+ display="inline"
+ d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
+ id="path101"
+ <path
+ display="inline"
+ d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
+ id="path103"
+ <path
+ display="inline"
+ d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
+ id="path105"
+ <path
+ display="inline"
+ d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
+ id="path107"
+ <path
+ display="inline"
+ d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
+ id="path109"
+ <path
+ display="inline"
+ d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
+ id="path111"
+ </g>
+ <g
+ id="Incubation">
+ <path
+ display="inline"
+ d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
+ id="path114"
+ <path
+ display="inline"
+ d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
+ id="path116"
+ <path
+ display="inline"
+ d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
+ id="path118"
+ <path
+ display="inline"
+ d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
+ id="path120"
+ <path
+ display="inline"
+ d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
+ id="path122"
+ <path
+ display="inline"
+ d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
+ id="path124"
+ <path
+ display="inline"
+ d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
+ id="path126"
+ <path
+ display="inline"
+ d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
+ id="path128"
+ <path
+ display="inline"
+ d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
+ id="path130"
+ <path
+ display="inline"
+ d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
+ id="path132"
+ <path
+ display="inline"
+ d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
+ id="path134"
+ <path
+ display="inline"
+ d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
+ id="path136"
+ <path
+ display="inline"
+ d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
+ id="path138"
+ <path
+ display="inline"
+ d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
+ id="path140"
+ <path
+ display="inline"
+ d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
+ id="path142"
+ <path
+ display="inline"
+ d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
+ id="path144"
+ <path
+ display="inline"
+ d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
+ id="path146"
+ <path
+ display="inline"
+ d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
+ id="path148"
+ <path
+ display="inline"
+ d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
+ id="path150"
+ </g>
+ <g
+ id="Project"
+ display="inline"
+ style="display:inline">
+ <path
+ d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
+ id="path153"
+ style="fill:#0054a4" />
+ <path
+ d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
+ id="path155"
+ <path
+ d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
+ id="path157"
+ <path
+ d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
+ id="path159"
+ <path
+ d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
+ id="path161"
+ <path
+ d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
+ id="path163"
+ <path
+ d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
+ id="path165"
+ </g>
+ <g
+ id="Your_Open_Source_Compass">
+ <path
+ display="inline"
+ d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
+ id="path168"
+ style="fill:#a0ce67;display:inline" />
+ <path
+ display="inline"
+ d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
+ id="path170"
+ <path
+ display="inline"
+ d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
+ id="path172"
+ <path
+ display="inline"
+ d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
+ id="path174"
+ <path
+ display="inline"
+ d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
+ id="path176"
+ <path
+ display="inline"
+ d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
+ id="path178"
+ <path
+ display="inline"
+ d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
+ id="path180"
+ <path
+ display="inline"
+ d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
+ id="path182"
+ <path
+ display="inline"
+ d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
+ id="path184"
+ <path
+ display="inline"
+ d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
+ id="path186"
+ <path
+ display="inline"
+ d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
+ id="path188"
+ <path
+ display="inline"
+ d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
+ id="path190"
+ <path
+ display="inline"
+ d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
+ id="path192"
+ <path
+ display="inline"
+ d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
+ id="path194"
+ <path
+ display="inline"
+ d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
+ id="path196"
+ <path
+ display="inline"
+ d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
+ id="path198"
+ <path
+ display="inline"
+ d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
+ id="path200"
+ <path
+ display="inline"
+ d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
+ id="path202"
+ <path
+ display="inline"
+ d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
+ id="path204"
+ <path
+ display="inline"
+ d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
+ id="path206"
+ <path
+ display="inline"
+ d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
+ id="path208"
+ </g>
+</g>
+<g
+ id="OSGeo"
+ display="none"
+ <path
+ display="inline"
+ d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
+ id="path211"
+ style="fill:#49a942;display:inline" />
+ <path
+ display="inline"
+ d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
+ id="path213"
+ <path
+ display="inline"
+ d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
+ id="path215"
+ <path
+ display="inline"
+ d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
+ id="path217"
+ <path
+ display="inline"
+ d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
+ id="path219"
+</g>
+<text
+ style="font-size:63.39215469px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ x="11.140328"
+ y="126.13584"
+ id="text2616"
+ transform="scale(0.7059967,1.4164372)"><tspan
+ sodipodi:role="line"
+ id="tspan2618"
+ x="11.140328"
+ y="126.13584"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Bitstream Vera Sans;-inkscape-font-specification:Bitstream Vera Sans Bold">Mapbender</tspan></text>
+<path
+ sodipodi:type="arc"
+ style="fill:#808080;stroke-width:6"
+ id="path2502"
+ sodipodi:cx="148.90392"
+ sodipodi:cy="-25.137407"
+ sodipodi:rx="84.918678"
+ sodipodi:ry="21.328411"
+ d="M 233.82259,-25.137407 A 84.918678,21.328411 0 1 1 63.985237,-25.137407 A 84.918678,21.328411 0 1 1 233.82259,-25.137407 z"
+ transform="matrix(0.855814,0,0,1,21.074896,-7.1094704)" /><path
+ style="fill:#999999;stroke-width:6;overflow:visible"
+ id="path2504"
+ sodipodi:rx="73.859497"
+ d="M 222.76341,-25.137407 A 73.859497,21.328411 0 1 1 75.044418,-25.137407 A 73.859497,21.328411 0 1 1 222.76341,-25.137407 z"
+ transform="translate(-0.3949772,90.84323)" /><rect
+ id="rect2508"
+ width="146.92906"
+ height="99.532585"
+ x="75.044411"
+ y="-33.826763" /><path
+ style="fill:#ffff00;stroke-width:6"
+ id="path2510"
+ sodipodi:cx="116.91129"
+ sodipodi:cy="1.3256211"
+ sodipodi:rx="15.798823"
+ sodipodi:ry="21.723381"
+ d="M 132.71012,1.3256211 A 15.798823,21.723381 0 1 1 101.11247,1.3256211 A 15.798823,21.723381 0 1 1 132.71012,1.3256211 z" /><path
+ style="fill:#ffff00;stroke-width:6;overflow:visible"
+ id="path2512"
+ transform="translate(65.170134,2.1423513)" /></svg>
\ No newline at end of file
Copied: trunk/documents/logos/logo_contest/mapbender_diagonal.svg (from rev 6635, trunk/documents/logos/mapbender_diagonal.svg)
--- trunk/documents/logos/logo_contest/mapbender_diagonal.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_diagonal.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,1250 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ version="1.0"
+ width="200"
+ height="200"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ sodipodi:docname="mapbender_diagonal.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_diagonal.png"
+ inkscape:export-xdpi="61.200001"
+ inkscape:export-ydpi="61.200001"><metadata
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_y="0 : 1000 : 0"
+ id="perspective243" /><inkscape:perspective
+ id="perspective3540"
+ sodipodi:type="inkscape:persp3d" /></defs><sodipodi:namedview
+ inkscape:window-height="975"
+ inkscape:window-width="1400"
+ inkscape:pageshadow="2"
+ inkscape:pageopacity="0.0"
+ borderopacity="1.0"
+ bordercolor="#666666"
+ pagecolor="#ffffff"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="3.7553051"
+ inkscape:cx="80.869466"
+ inkscape:cy="105.35938"
+ inkscape:window-x="0"
+ inkscape:window-y="25"
+<g
+ style="overflow:visible"
+ id="g3542"
+ transform="matrix(0.4211728,0.182269,-0.4747632,1.0363122,6.5648762,-12.913196)"><g
+ display="none"
+ id="g3544">
+ <g
+ id="g3546">
+ <path
+ id="path3548"
+ display="inline" />
+ <path
+ id="path3550"
+ <path
+ id="path3552"
+ <path
+ id="path3554"
+ <path
+ id="path3556"
+ <path
+ id="path3558"
+ <path
+ id="path3560"
+ <path
+ id="path3562"
+ <path
+ id="path3564"
+ <path
+ id="path3566"
+ <path
+ id="path3568"
+ <path
+ id="path3570"
+ <path
+ id="path3572"
+ <path
+ id="path3574"
+ <path
+ id="path3576"
+ <path
+ id="path3578"
+ <path
+ id="path3580"
+ </g>
+ <g
+ id="g3582">
+ <path
+ id="path3584"
+ <path
+ id="path3586"
+ <path
+ id="path3588"
+ <path
+ id="path3590"
+ <path
+ id="path3592"
+ <path
+ id="path3594"
+ <path
+ id="path3596"
+ <path
+ id="path3598"
+ <path
+ id="path3600"
+ <path
+ id="path3602"
+ <path
+ id="path3604"
+ <path
+ id="path3606"
+ <path
+ id="path3608"
+ <path
+ id="path3610"
+ <path
+ id="path3612"
+ <path
+ id="path3614"
+ <path
+ id="path3616"
+ <path
+ id="path3618"
+ </g>
+ <g
+ id="g3620">
+ <path
+ style="fill:#0054a4;display:inline"
+ id="path3622"
+ <path
+ id="path3624"
+ <path
+ id="path3626"
+ <path
+ id="path3628"
+ <path
+ id="path3630"
+ <path
+ id="path3632"
+ <path
+ id="path3634"
+ <path
+ id="path3636"
+ <path
+ id="path3638"
+ <path
+ id="path3640"
+ <path
+ id="path3642"
+ <path
+ id="path3644"
+ <path
+ id="path3646"
+ <path
+ id="path3648"
+ <path
+ id="path3650"
+ <path
+ id="path3652"
+ <path
+ id="path3654"
+ <path
+ id="path3656"
+ </g>
+ <g
+ id="g3658">
+ <path
+ id="path3660"
+ <path
+ id="path3662"
+ <path
+ id="path3664"
+ <path
+ id="path3666"
+ <path
+ id="path3668"
+ <path
+ id="path3670"
+ <path
+ id="path3672"
+ <path
+ id="path3674"
+ <path
+ id="path3676"
+ <path
+ id="path3678"
+ <path
+ id="path3680"
+ <path
+ id="path3682"
+ <path
+ id="path3684"
+ <path
+ id="path3686"
+ <path
+ id="path3688"
+ <path
+ id="path3690"
+ <path
+ id="path3692"
+ <path
+ id="path3694"
+ <path
+ id="path3696"
+ </g>
+ <g
+ display="inline"
+ id="g3698">
+ <path
+ id="path3700"
+ d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z" />
+ <path
+ id="path3702"
+ d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z" />
+ <path
+ id="path3704"
+ d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z" />
+ <path
+ id="path3706"
+ d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z" />
+ <path
+ id="path3708"
+ d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z" />
+ <path
+ id="path3710"
+ d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z" />
+ <path
+ id="path3712"
+ d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z" />
+ </g>
+ <g
+ id="g3714">
+ <path
+ id="path3716"
+ <path
+ id="path3718"
+ <path
+ id="path3720"
+ <path
+ id="path3722"
+ <path
+ id="path3724"
+ <path
+ id="path3726"
+ <path
+ id="path3728"
+ <path
+ id="path3730"
+ <path
+ id="path3732"
+ <path
+ id="path3734"
+ <path
+ id="path3736"
+ <path
+ id="path3738"
+ <path
+ id="path3740"
+ <path
+ id="path3742"
+ <path
+ id="path3744"
+ <path
+ id="path3746"
+ <path
+ id="path3748"
+ <path
+ id="path3750"
+ <path
+ id="path3752"
+ <path
+ id="path3754"
+ <path
+ id="path3756"
+ </g>
+</g><g
+ style="display:none"
+ display="none"
+ id="g3758">
+ <path
+ id="path3760"
+ <path
+ id="path3762"
+ <path
+ id="path3764"
+ <path
+ id="path3766"
+ <path
+ id="path3768"
+</g><g
+ transform="matrix(2.658509,0,0,1.0066382,2.3739382,-80.596613)"
+ id="Compass">
+ <path
+ style="fill:#49a942;fill-rule:evenodd"
+ id="path222"
+ d="M 54.232,117.368 C 28.032,116.453 7.532,94.47 8.447,68.269 C 9.361,42.065 31.345,21.569 57.546,22.484 C 75.658,23.117 91.043,33.819 98.515,49.021 C 99.665,49.057 100.817,49.06 101.976,48.846 C 94.225,31.979 77.475,20 57.657,19.308 C 29.667,18.33 6.187,40.227 5.209,68.219 C 4.233,96.205 26.127,119.687 54.118,120.665 C 61.711,120.929 68.969,119.499 75.539,116.731 C 75.222,115.748 75.025,114.623 74.698,113.516 C 68.439,116.223 61.5,117.621 54.232,117.368 z"
+ clip-rule="evenodd" />
+ <g
+ id="g224">
+ <circle
+ style="fill:#a0ce67"
+ sodipodi:ry="31.707001"
+ sodipodi:rx="31.707001"
+ sodipodi:cy="70.192001"
+ sodipodi:cx="55.669998"
+ id="circle226"
+ r="31.707001"
+ cy="70.192001"
+ cx="55.669998" />
+ </g>
+ <polygon
+ style="fill:#ffffff;stroke:#a0ce67;stroke-width:2;stroke-miterlimit:6"
+ id="polygon228"
+ points="61.494,53.061 26.327,4.407 38.873,63.876 3.379,93.238 49.515,86.588 78.884,121.407 72.411,75.859 107.593,46.548 61.494,53.061 "
+ stroke-miterlimit="6" />
+ <g
+ id="g230">
+ <polygon
+ id="polygon232"
+ points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
+ </g>
+ <path
+ style="fill:none"
+ id="path234"
+ d="" />
+ <path
+ style="fill:none"
+ id="path236"
+ d="" />
+</g></g><g
+ id="Text"
+ display="none"
+ style="display:none">
+ <g
+ id="Associate">
+ <path
+ display="inline"
+ d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
+ id="path5"
+ style="fill:#0054a4;display:inline" />
+ <path
+ display="inline"
+ d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
+ id="path7"
+ <path
+ display="inline"
+ d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
+ id="path9"
+ <path
+ display="inline"
+ d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
+ id="path11"
+ <path
+ display="inline"
+ d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
+ id="path13"
+ <path
+ display="inline"
+ d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
+ id="path15"
+ <path
+ display="inline"
+ d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
+ id="path17"
+ <path
+ display="inline"
+ d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
+ id="path19"
+ <path
+ display="inline"
+ d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
+ id="path21"
+ <path
+ display="inline"
+ d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
+ id="path23"
+ <path
+ display="inline"
+ d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
+ id="path25"
+ <path
+ display="inline"
+ d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
+ id="path27"
+ <path
+ display="inline"
+ d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
+ id="path29"
+ <path
+ display="inline"
+ d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
+ id="path31"
+ <path
+ display="inline"
+ d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
+ id="path33"
+ <path
+ display="inline"
+ d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
+ id="path35"
+ <path
+ display="inline"
+ d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
+ id="path37"
+ </g>
+ <g
+ id="Supporting">
+ <path
+ display="inline"
+ d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
+ id="path40"
+ <path
+ display="inline"
+ d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
+ id="path42"
+ <path
+ display="inline"
+ d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
+ id="path44"
+ <path
+ display="inline"
+ d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
+ id="path46"
+ <path
+ display="inline"
+ d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
+ id="path48"
+ <path
+ display="inline"
+ d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
+ id="path50"
+ <path
+ display="inline"
+ d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
+ id="path52"
+ <path
+ display="inline"
+ d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
+ id="path54"
+ <path
+ display="inline"
+ d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
+ id="path56"
+ <path
+ display="inline"
+ d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
+ id="path58"
+ <path
+ display="inline"
+ d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
+ id="path60"
+ <path
+ display="inline"
+ d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
+ id="path62"
+ <path
+ display="inline"
+ d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
+ id="path64"
+ <path
+ display="inline"
+ d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
+ id="path66"
+ <path
+ display="inline"
+ d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
+ id="path68"
+ <path
+ display="inline"
+ d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
+ id="path70"
+ <path
+ display="inline"
+ d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
+ id="path72"
+ <path
+ display="inline"
+ d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
+ id="path74"
+ </g>
+ <g
+ id="Sustaining">
+ <path
+ display="inline"
+ d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
+ id="path77"
+ <path
+ display="inline"
+ d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
+ id="path79"
+ <path
+ display="inline"
+ d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
+ id="path81"
+ <path
+ display="inline"
+ d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
+ id="path83"
+ <path
+ display="inline"
+ d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
+ id="path85"
+ <path
+ display="inline"
+ d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
+ id="path87"
+ <path
+ display="inline"
+ d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
+ id="path89"
+ <path
+ display="inline"
+ d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
+ id="path91"
+ <path
+ display="inline"
+ d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
+ id="path93"
+ <path
+ display="inline"
+ d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
+ id="path95"
+ <path
+ display="inline"
+ d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
+ id="path97"
+ <path
+ display="inline"
+ d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
+ id="path99"
+ <path
+ display="inline"
+ d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
+ id="path101"
+ <path
+ display="inline"
+ d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
+ id="path103"
+ <path
+ display="inline"
+ d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
+ id="path105"
+ <path
+ display="inline"
+ d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
+ id="path107"
+ <path
+ display="inline"
+ d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
+ id="path109"
+ <path
+ display="inline"
+ d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
+ id="path111"
+ </g>
+ <g
+ id="Incubation">
+ <path
+ display="inline"
+ d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
+ id="path114"
+ <path
+ display="inline"
+ d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
+ id="path116"
+ <path
+ display="inline"
+ d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
+ id="path118"
+ <path
+ display="inline"
+ d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
+ id="path120"
+ <path
+ display="inline"
+ d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
+ id="path122"
+ <path
+ display="inline"
+ d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
+ id="path124"
+ <path
+ display="inline"
+ d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
+ id="path126"
+ <path
+ display="inline"
+ d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
+ id="path128"
+ <path
+ display="inline"
+ d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
+ id="path130"
+ <path
+ display="inline"
+ d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
+ id="path132"
+ <path
+ display="inline"
+ d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
+ id="path134"
+ <path
+ display="inline"
+ d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
+ id="path136"
+ <path
+ display="inline"
+ d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
+ id="path138"
+ <path
+ display="inline"
+ d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
+ id="path140"
+ <path
+ display="inline"
+ d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
+ id="path142"
+ <path
+ display="inline"
+ d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
+ id="path144"
+ <path
+ display="inline"
+ d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
+ id="path146"
+ <path
+ display="inline"
+ d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
+ id="path148"
+ <path
+ display="inline"
+ d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
+ id="path150"
+ </g>
+ <g
+ id="Project"
+ display="inline"
+ style="display:inline">
+ <path
+ id="path153"
+ style="fill:#0054a4" />
+ <path
+ id="path155"
+ <path
+ id="path157"
+ <path
+ id="path159"
+ <path
+ id="path161"
+ <path
+ id="path163"
+ <path
+ id="path165"
+ </g>
+ <g
+ id="Your_Open_Source_Compass">
+ <path
+ display="inline"
+ d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
+ id="path168"
+ style="fill:#a0ce67;display:inline" />
+ <path
+ display="inline"
+ d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
+ id="path170"
+ <path
+ display="inline"
+ d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
+ id="path172"
+ <path
+ display="inline"
+ d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
+ id="path174"
+ <path
+ display="inline"
+ d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
+ id="path176"
+ <path
+ display="inline"
+ d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
+ id="path178"
+ <path
+ display="inline"
+ d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
+ id="path180"
+ <path
+ display="inline"
+ d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
+ id="path182"
+ <path
+ display="inline"
+ d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
+ id="path184"
+ <path
+ display="inline"
+ d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
+ id="path186"
+ <path
+ display="inline"
+ d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
+ id="path188"
+ <path
+ display="inline"
+ d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
+ id="path190"
+ <path
+ display="inline"
+ d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
+ id="path192"
+ <path
+ display="inline"
+ d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
+ id="path194"
+ <path
+ display="inline"
+ d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
+ id="path196"
+ <path
+ display="inline"
+ d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
+ id="path198"
+ <path
+ display="inline"
+ d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
+ id="path200"
+ <path
+ display="inline"
+ d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
+ id="path202"
+ <path
+ display="inline"
+ d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
+ id="path204"
+ <path
+ display="inline"
+ d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
+ id="path206"
+ <path
+ display="inline"
+ d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
+ id="path208"
+ </g>
+</g>
+<g
+ id="OSGeo"
+ display="none"
+ <path
+ display="inline"
+ d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
+ id="path211"
+ style="fill:#49a942;display:inline" />
+ <path
+ display="inline"
+ d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
+ id="path213"
+ <path
+ display="inline"
+ d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
+ id="path215"
+ <path
+ display="inline"
+ d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
+ id="path217"
+ <path
+ display="inline"
+ d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
+ id="path219"
+</g>
+<path
+ style="fill:#008000"
+ d="M 286.87254,201.50794 L 73.359882,201.50794 L 130.08949,148.86386 L 137.22852,157.17334 L 149.73521,145.40875 L 142.86208,137.01288 L 286.87254,-4.5997591 L 286.87254,201.50794 z"
+ id="rect2660"
+ sodipodi:nodetypes="cccccccc" /><path
+ transform="matrix(1,0,0,1.1357143,-8.9371638,-38.430172)"
+ style="fill:#ffffff"
+ d="M 273.70065,153.522 C 273.70065,175.10525 253.0558,192.62209 227.61839,192.62209 C 202.18099,192.62209 181.53614,175.10525 181.53614,153.522 C 181.53614,131.93875 202.18099,114.42191 227.61839,114.42191 C 253.0558,114.42191 273.70065,131.93875 273.70065,153.522 z"
+ id="path3829" /><path
+ sodipodi:type="arc"
+ id="path3827"
+ sodipodi:cx="211.1405"
+ sodipodi:cy="125.87266"
+ sodipodi:rx="48.595829"
+ sodipodi:ry="15.36075"
+ d="M 259.73633,125.87266 A 48.595829,15.36075 0 1 1 162.54467,125.87266 A 48.595829,15.36075 0 1 1 259.73633,125.87266 z"
+ transform="matrix(1.055678,-1.0206471,1.1066652,0.9736231,-144.07264,230.55011)" /><path
+ style="fill:#008000;overflow:visible"
+ id="path3831"
+ transform="matrix(0.9661511,-0.899479,0.8597691,1.0106566,-93.533829,200.30513)"
+ inkscape:transform-center-x="5.3222617"
+ inkscape:transform-center-y="-4.2813473" /><text
+ xml:space="preserve"
+ style="font-size:75.93405151px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ x="-128.87492"
+ y="123.78498"
+ id="text2616"
+ transform="matrix(0.485306,-0.4825086,0.9685605,1.097578,0,0)"><tspan
+ sodipodi:role="line"
+ id="tspan2618"
+ x="-128.87492"
+ y="123.78498"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Sans;-inkscape-font-specification:Sans Bold">Ma<tspan
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#0000ff;font-family:Sans;-inkscape-font-specification:Sans Bold"
+ id="tspan3823">p</tspan><tspan
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#ff0000;font-family:Sans;-inkscape-font-specification:Sans Bold"
+ id="tspan3825">b</tspan>ender</tspan></text>
+<path
+ style="fill:#ffffff;overflow:visible"
+ d="M 187.26086,167.23724 C 169.24551,151.64732 168.44559,120.70407 185.66746,103.26088 C 202.88934,85.817692 230.84298,86.298055 249.65895,104.03727 C 249.65895,104.03727 255.81365,119.9254 231.53462,143.1981 C 207.53637,166.20164 187.26086,167.23724 187.26086,167.23724 z"
+ id="path3838"
+ sodipodi:nodetypes="csszs" /></svg>
\ No newline at end of file
Copied: trunk/documents/logos/logo_contest/mapbender_dragon.svg (from rev 6635, trunk/documents/logos/mapbender_dragon.svg)
--- trunk/documents/logos/logo_contest/mapbender_dragon.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_dragon.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,500 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ version="1.0"
+ width="1000"
+ height="1000"
+ id="svg2"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ sodipodi:docname="mapbender_dragon.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape">
+ <metadata
+ id="metadata4098">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <sodipodi:namedview
+ inkscape:window-height="975"
+ inkscape:window-width="1400"
+ inkscape:pageshadow="2"
+ inkscape:pageopacity="0.0"
+ guidetolerance="10.0"
+ gridtolerance="10.0"
+ objecttolerance="10.0"
+ borderopacity="1.0"
+ bordercolor="#666666"
+ pagecolor="#ffffff"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="0.6986215"
+ inkscape:cx="500"
+ inkscape:cy="500"
+ inkscape:window-x="0"
+ inkscape:window-y="25"
+ inkscape:current-layer="svg2" />
+ <defs
+ id="defs4">
+ <inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 500 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="1000 : 500 : 1"
+ inkscape:persp3d-origin="500 : 333.33333 : 1"
+ id="perspective4100" />
+ id="perspective4267"
+ inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
+ inkscape:vp_z="744.09448 : 526.18109 : 1"
+ inkscape:vp_x="0 : 526.18109 : 1"
+ sodipodi:type="inkscape:persp3d" />
+ id="perspective5038"
+ </defs>
+ <image
+ y="80.668556"
+ x="379.29614"
+ id="image5040"
+ height="510.33273"
+ width="565.81177"
+ sodipodi:absref="/home/seven/data/work/mapbender/logo/map.png"
+ xlink:href="map.png" />
+ <g
+ id="layer2" />
+ <text
+ id="text4277"
+ y="117.27086"
+ x="49.206673"
+ style="font-size:33.16645813px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ transform="scale(1.1179906,0.8944619)"><tspan
+ y="117.27086"
+ x="49.206673"
+ id="tspan4279"
+ sodipodi:role="line">0000111011100110010010</tspan><tspan
+ id="tspan4287"
+ y="158.72893"
+ x="49.206673"
+ sodipodi:role="line">0001111011000111000110</tspan><tspan
+ id="tspan4298"
+ y="200.18701"
+ x="49.206673"
+ sodipodi:role="line">0111000001111010001100</tspan><tspan
+ id="tspan4300"
+ y="241.64508"
+ x="49.206673"
+ sodipodi:role="line">0011111000001100011100</tspan><tspan
+ id="tspan4302"
+ y="283.10315"
+ x="49.206673"
+ id="tspan4314"
+ y="324.56122"
+ x="49.206673"
+ id="tspan4336"
+ y="366.01929"
+ x="49.206673"
+ id="tspan4338"
+ y="407.47736"
+ x="49.206673"
+ id="tspan4340"
+ y="448.93542"
+ x="49.206673"
+ id="tspan4342"
+ y="490.39352"
+ x="49.206673"
+ id="tspan4344"
+ y="531.85156"
+ x="49.206673"
+ id="tspan4346"
+ y="573.30963"
+ x="49.206673"
+ id="tspan4348"
+ y="614.7677"
+ x="49.206673"
+ id="tspan4350"
+ y="656.22583"
+ x="49.206673"
+ id="tspan4352"
+ y="697.6839"
+ x="49.206673"
+ sodipodi:role="line" /></text>
+ <g
+ transform="matrix(1.4110648,0.164685,-0.1326582,1.3227349,107.36509,-64.958801)"
+ id="g4354">
+ <g
+ id="g4691"
+ transform="matrix(0.9424289,-0.3848325,0.2905881,0.9424289,-92.49501,114.45179)">
+ <path
+ id="path2514"
+ style="fill:#000080;stroke:none;stroke-opacity:1;display:inline"
+ d="M 255.95193,117.56609 C 255.54896,117.56609 254.4178,123.20635 253.94832,127.52188 C 253.49139,131.72208 253.89922,138.94579 254.89412,144.09827 C 255.96529,149.6458 255.29122,164.27908 253.76165,168.61439 C 252.62502,171.8359 249.48405,174.09758 246.12059,174.11496 C 245.18972,174.11978 244.4281,174.30818 244.4281,174.53809 C 244.4281,175.27314 245.67371,177.40765 246.82994,178.64485 C 247.44624,179.30428 249.34385,182.53009 251.03626,185.81301 L 254.11011,191.78649 L 254.29678,195.63191 C 254.52437,200.35779 253.97361,202.5607 252.65407,202.17784 C 250.43763,201.53476 246.7787,199.54064 244.4281,197.69774 C 243.00442,196.58156 240.04755,194.34682 237.85728,192.73229 C 233.13147,189.24869 228.82885,185.69261 225.41255,182.44049 C 224.04538,181.13902 221.35731,178.76462 219.43908,177.16392 C 213.97614,172.6053 205.52805,163.33501 198.1088,153.75538 C 196.64196,151.86145 194.90879,149.74217 194.26338,149.05127 C 193.61801,148.36038 191.06379,143.774 188.58858,138.
85903 C 186.11341,133.94406 183.9771,129.92561 183.83469,129.92371 C 183.69224,129.92182 183.35693,130.83125 183.08801,131.95221 C 181.96607,136.62906 183.251,144.2933 188.01612,161.25955 C 191.14582,172.40279 191.48912,179.94953 189.09881,185.05389 C 188.68497,185.93765 187.99494,187.46568 187.56811,188.4513 C 186.46589,190.99667 185.08934,192.19866 180.56173,194.52433 L 176.57941,196.56526 L 178.54568,198.30753 C 179.6256,199.26582 182.57279,201.65227 185.09161,203.60898 C 187.61042,205.56569 190.34741,208.07803 191.17709,209.19667 C 192.92871,211.55833 192.80304,211.96752 189.87039,213.29099 C 188.37754,213.96469 186.84833,214.14641 180.71106,214.38612 C 174.86694,214.61438 172.19114,214.91918 167.76854,215.8546 C 160.64382,217.36155 149.02128,218.64918 148.37964,218.00754 C 148.04206,217.66996 148.60538,216.83178 150.60725,214.70969 C 153.717,211.41322 155.54541,208.68699 157.65097,204.19389 C 159.16007,200.97355 161.04697,194.9336 160.6626,194.54922 C 160.54994,194.4365
6 159.04868,195.41674 157.32741,196.72705 C 147.0843,204.52445 135.21248,210.68272 121.7728,215.1577 C 114.82554,217.47092 111.78072,217.92043 103.24259,217.92043 C 99.657396,217.92043 96.627273,218.07913 96.509995,218.26888 C 97.890038,222.11499 119.19037,231.79283 121.76036,233.86213 C 134.21051,240.07656 150.65295,244.00722 166.17561,244.47749 C 172.90238,244.68128 173.48728,244.63353 175.67095,243.80548 C 176.98013,243.30902 177.84348,242.77969 177.64966,242.58589 C 177.46022,242.39643 176.11472,242.0697 174.66292,241.8641 C 171.18497,241.37156 164.36072,239.02088 159.40568,236.61242 C 155.29955,234.61657 149.25078,230.8569 149.25078,230.30294 C 149.25078,230.1305 151.80444,229.87234 154.92557,229.73048 C 158.04671,229.58863 163.46764,229.10904 166.97208,228.66023 C 175.03666,227.62742 191.40437,227.15047 194.74872,227.85133 C 196.08535,228.13143 197.03855,228.55109 197.03855,228.84691 C 197.03855,229.85881 195.42708,233.97418 194.17627,236.17685 C 193.47175,237.41751 19
1.85695,239.53044 190.57974,240.86852 L 188.25257,243.29524 L 191.1522,243.99215 C 195.19198,244.95334 199.57696,247.2089 202.19067,249.67939 C 204.33189,251.70327 204.3741,251.78849 203.60937,252.3799 C 202.56278,253.18927 199.23672,254.16008 197.46168,254.17194 C 196.68007,254.17716 195.32616,254.35919 194.45005,254.58262 C 193.57394,254.80604 190.25866,255.50689 187.08277,256.13821 C 176.83778,258.17473 160.86129,263.09582 151.29171,267.16424 C 146.2196,269.32061 136.80763,273.98908 133.62019,275.92533 C 127.64049,281.12024 120.29419,287.68779 117.05625,294.89111 C 115.66594,298.23259 114.59441,304.62296 114.60464,309.56345 C 115.1144,317.97373 121.66185,332.8172 129.79966,335.5605 C 135.19143,338.20567 144.81468,339.52892 152.0384,338.60946 C 158.78856,337.15301 166.46608,334.86786 172.21131,331.20484 C 177.6055,328.47641 182.95953,326.89508 187.705,323.05354 C 189.11646,323.05354 189.14337,323.07766 188.57614,323.94956 C 183.61381,331.57692 181.69318,335.84573 178.91902
,345.39184 C 178.13737,348.08159 177.35254,350.47091 177.17676,350.70574 C 177.00094,350.94057 176.55373,351.93529 176.18118,352.9209 C 175.04013,355.93992 173.79432,356.91325 170.26993,357.52546 C 168.37618,357.85442 164.48685,356.68797 164.17201,355.69608 C 164.049,355.3084 163.40922,354.24179 162.74087,353.31914 L 161.52128,351.6391 L 158.90789,351.81332 C 156.59787,351.96041 156.19541,352.10174 155.37359,353.13246 C 154.86293,353.77288 154.34053,354.81202 154.20378,355.43474 C 154.06699,356.05746 153.12021,357.6784 152.10062,359.03127 C 151.08103,360.38414 149.92821,362.1997 149.54945,363.07581 C 148.75382,364.91599 145.86236,377.65914 144.1111,387.03192 C 141.80215,399.38945 140.1601,404.91249 136.53226,412.45651 C 133.89612,417.93828 131.47093,420.85471 125.78001,425.39904 C 121.67464,428.67728 121.39733,429.27189 121.08834,435.41705 C 120.8768,439.62398 121.14991,441.39552 122.68127,445.49728 C 123.13816,446.72107 125.21812,449.29293 125.74267,449.29292 C 126.11602,44
9.29292 128.02434,445.07262 128.67963,442.80922 C 129.0159,441.6479 129.49581,440.99506 130.24767,440.64383 C 130.84139,440.36648 131.82317,439.90372 132.4255,439.62337 C 133.16282,439.28019 133.95289,438.23577 134.85222,436.42507 C 136.24671,433.6174 139.30435,429.94612 140.98747,429.04534 C 141.84463,428.58662 142.18482,428.62524 143.71287,429.39379 C 146.11444,430.6017 148.24277,432.96451 149.92279,436.30062 C 151.06631,438.57135 151.43822,439.93298 151.86417,443.38168 C 152.82765,451.18285 153.47112,452.12949 158.01187,452.47878 L 160.60037,452.67789 L 161.68307,454.86817 C 162.5305,456.58305 162.7682,457.64187 162.7782,459.7465 C 162.78525,461.22494 162.63854,462.43457 162.45464,462.43456 C 161.47758,462.43456 160.78623,466.18687 161.69551,466.55377 C 163.05989,467.10431 164.3407,466.46792 167.08408,463.86571 C 169.81997,461.27063 170.03189,460.03712 169.83437,448.07334 L 169.7597,443.05811 L 167.5072,440.30783 C 163.27237,435.10776 162.09743,432.56721 163.92312,432.567
2 C 164.92642,432.5672 175.73277,437.95538 176.72875,438.95135 C 177.35122,439.57381 178.26188,439.87512 179.87727,440.0216 C 182.42854,440.25294 184.35673,439.50696 186.84632,437.32109 L 188.24013,436.10151 L 191.21442,436.52463 C 194.7314,437.0138 197.38191,437.95584 198.25814,439.03846 C 199.2632,440.28028 200.40333,439.79481 200.54797,438.05533 C 200.6488,436.84301 200.38171,436.19163 199.0546,434.43391 C 198.16575,433.25659 197.43678,432.11114 197.43679,431.88274 C 197.43679,431.0887 194.20482,428.5676 191.56287,427.29063 C 190.10084,426.58399 188.39759,425.4211 187.76723,424.71457 C 186.24475,423.00822 184.62039,422.62791 178.91902,422.61141 C 174.60829,422.59894 173.86722,422.48592 171.35262,421.4665 C 169.28835,420.62963 168.56501,420.14263 168.565,419.58734 C 168.565,418.50922 172.40957,417.74996 176.52963,418.01931 C 179.59805,418.2199 179.81675,418.17117 182.42844,416.79972 C 184.89289,415.50561 185.32859,415.39997 187.20721,415.65481 C 189.73571,415.99782 193.202
15,417.2552 193.87759,418.06909 C 194.27746,418.55086 194.43631,418.57024 194.69894,418.1562 C 195.67529,416.61708 194.62394,413.46976 191.77443,409.40755 C 190.19867,407.16115 189.79327,406.86091 185.77607,404.95234 C 182.17749,403.24265 181.43264,402.7302 181.24619,401.8536 C 180.93166,400.37479 179.56583,399.75432 177.35099,400.08645 C 175.29408,400.3949 173.3475,401.81958 172.98288,403.2723 C 172.73116,404.27519 172.35295,404.42163 168.66456,404.92745 C 166.3318,405.24736 161.86898,404.44294 160.69993,403.4963 C 159.89757,402.8466 159.82197,402.4404 159.81636,398.0704 C 159.80556,389.66914 161.53843,385.69343 166.48673,382.75093 L 169.36147,381.046 L 175.13582,380.99622 C 179.13144,380.96214 181.45917,380.75631 182.71467,380.33665 C 183.97594,379.91505 184.82573,379.84408 185.50229,380.1002 C 186.03755,380.30284 188.45666,380.39415 190.86597,380.31176 C 194.47478,380.18836 195.56223,380.00201 197.03855,379.24152 C 199.45833,377.99502 200.52342,376.96127 201.63066,374.786
3 C 202.51462,373.05002 202.66823,372.94397 204.55517,372.72048 C 208.48464,372.25509 211.21493,370.2506 213.1296,366.42344 C 214.22191,364.24004 214.94291,363.32979 216.26567,362.4909 C 219.23034,360.61077 221.72043,356.26216 221.72891,352.94579 C 221.73034,352.38322 222.09022,351.38772 222.52537,350.73063 C 222.96056,350.07355 223.30796,349.25523 223.30939,348.9137 C 223.31086,348.57217 224.29364,347.4552 225.48722,346.42475 C 226.6808,345.39429 228.51764,343.39015 229.56909,341.96954 C 230.62054,340.54893 231.57518,339.39166 231.68469,339.39348 C 231.79421,339.39528 232.25365,340.06731 232.70516,340.88685 C 233.15672,341.70639 235.09767,345.19986 237.02349,348.65236 C 238.94925,352.10486 241.78407,357.66019 243.32052,360.99754 L 246.10814,367.05812 L 245.90903,370.64221 C 245.67702,374.85732 244.82291,377.36045 242.48672,380.62288 C 240.59281,383.26772 240.31935,385.32033 241.5907,387.40526 C 242.21927,388.43606 242.92573,388.82643 245.87169,389.74487 C 247.81156,390.3496
4 250.30201,391.30477 251.39715,391.86048 C 252.49229,392.4162 255.74104,393.81264 258.62754,394.97166 C 262.94011,396.70329 265.1765,397.9482 271.17184,401.94071 C 275.1847,404.61301 278.54201,406.85916 278.62623,406.93105 C 278.71046,407.00294 278.55115,407.62242 278.26533,408.31242 C 277.73939,409.58218 275.80352,411.05997 274.66881,411.0627 C 273.98397,411.06435 271.85562,413.16454 271.15939,414.52234 C 270.91408,415.00075 270.71138,415.7656 270.71138,416.21482 C 270.71138,416.66405 269.81536,418.73218 268.72022,420.81937 C 266.92464,424.24157 266.72906,424.8706 266.72907,427.20352 C 266.72907,428.99585 266.97482,430.33465 267.55042,431.55918 C 268.85152,434.32712 269.28517,434.47505 270.25093,432.48009 C 271.306,430.30058 274.23449,427.43163 277.23242,425.63549 C 279.5023,424.27554 279.60487,424.25665 280.77917,424.86391 C 281.59164,425.28406 282.62682,425.42447 283.92769,425.29948 C 286.94318,425.00973 287.95032,423.7328 289.39093,418.35532 C 289.94809,416.2756 291.608
73,414.24856 292.751,414.24855 C 293.22442,414.24855 294.8642,414.52115 296.39731,414.8459 C 297.93042,415.17064 300.13624,415.43944 301.30054,415.44325 C 303.6061,415.45078 304.22013,415.69807 306.70155,417.58374 C 307.60884,418.27319 309.91616,419.54536 311.82878,420.42114 L 315.31331,422.01407 L 315.31331,423.93056 C 315.31331,427.35075 317.07662,429.38135 320.05475,429.38135 C 320.93114,429.38135 322.27506,429.08726 323.04149,428.72178 C 324.23216,428.154 324.68532,428.12657 326.09045,428.54755 C 328.11553,429.15428 331.05252,431.99682 331.42924,433.71212 C 331.74523,435.15081 332.66585,435.35021 334.25419,434.30946 C 336.44164,432.87619 337.1963,428.70566 335.62311,426.70573 C 335.14352,426.09601 334.82666,425.09216 334.82665,424.17945 C 334.82665,423.34581 334.648,422.54804 334.42842,422.4123 C 333.89873,422.08493 332.59209,419.16859 332.23815,417.50907 C 331.82327,415.56377 330.26862,414.81428 325.51799,414.261 C 321.07548,413.74359 318.49258,412.95593 317.46625,411.8
2183 C 316.83366,411.12281 316.8436,411.07114 317.74003,410.73914 C 324.19198,408.34966 329.40759,406.68216 330.4461,406.68216 C 331.15121,406.68216 332.94325,406.98327 334.42842,407.34173 C 336.01553,407.7248 337.59138,407.8798 338.2614,407.71507 C 338.89466,407.55936 340.37976,406.39864 341.59659,405.11412 C 342.80124,403.84249 344.23488,402.69262 344.78244,402.56295 C 345.88773,402.30118 352.54923,398.5888 353.64309,397.62239 C 354.85909,396.5481 354.42326,395.73367 351.63949,393.8143 C 349.41863,392.28304 348.63269,391.95044 347.15938,391.94759 C 343.42632,391.94036 341.23245,391.4914 340.97435,390.67823 C 340.57512,389.42038 338.4172,388.36517 336.23291,388.36351 C 334.36982,388.3621 334.16101,388.47901 332.16348,390.54134 C 331.00263,391.73986 329.19808,393.10082 328.15627,393.56541 C 327.1145,394.03 325.63753,394.8384 324.87086,395.35745 C 324.10415,395.87651 322.3121,396.54889 320.88855,396.85082 C 319.46495,397.15274 317.67284,397.78514 316.90623,398.25707 C 315.972
9,398.83167 314.85453,399.11476 313.53371,399.11576 L 311.56744,399.11576 L 312.98614,397.62239 C 313.7713,396.80104 314.64726,395.68101 314.92752,395.13344 C 315.20776,394.58587 316.6558,393.01162 318.13826,391.63647 L 320.82632,389.13508 L 320.78899,385.26477 C 320.76999,383.06289 320.97387,380.87925 321.24945,380.19976 C 321.51594,379.54268 322.84363,378.00047 324.19885,376.76501 C 325.55407,375.52956 326.52186,374.3772 326.35179,374.2014 C 325.73102,373.55985 319.03893,373.51427 317.20491,374.13918 C 316.02638,374.54074 314.54435,374.66492 312.68747,374.53741 C 309.97304,374.35101 309.91005,374.37135 308.64293,375.69477 C 307.56161,376.82414 307.22343,377.67472 306.52733,381.00867 C 306.07139,383.19224 305.3349,386.05377 304.88462,387.36793 C 304.43438,388.68209 303.97119,390.15598 303.86415,390.64089 C 303.59778,391.8474 300.5428,393.26592 297.77868,393.46585 C 296.14808,393.5838 294.7986,393.36031 292.60167,392.61961 C 290.96549,392.06797 288.6215,391.34426 287.39977,3
91.00179 C 286.17807,390.65932 284.50829,389.92601 283.69124,389.37153 C 282.87419,388.81706 281.4608,387.97722 280.54272,387.51726 C 278.14815,386.31762 274.28263,383.32412 272.96388,381.64335 C 272.01875,380.43876 271.86333,379.92962 272.01808,378.51972 C 272.27816,376.14972 273.23498,374.89582 275.61461,373.8405 C 279.64061,372.05504 280.22016,370.56508 280.24405,361.94334 C 280.25368,358.47335 280.07111,353.45563 279.83337,350.79285 C 279.44828,346.48018 279.27429,345.76495 278.24044,344.24692 C 277.60208,343.30965 277.08308,342.49244 277.08308,342.42999 C 277.08308,342.36755 279.18873,342.3979 281.7623,342.49222 C 286.4332,342.66341 286.44476,342.6672 288.23357,344.09759 C 289.21919,344.88571 290.16563,345.75219 290.33673,346.02652 C 290.50785,346.30084 291.47056,346.88794 292.47722,347.33322 C 294.90349,348.40648 299.38865,348.41073 303.55303,347.34566 L 306.67666,346.5492 L 308.77982,347.58211 C 311.39019,348.85924 315.56971,349.36175 315.9231,348.4408 C 316.13002,347
.90154 316.42034,347.91357 318.44938,348.52791 C 322.29036,349.69087 323.90353,351.16282 322.68059,352.38578 C 321.88676,353.17959 321.90387,356.20787 322.71792,357.82413 C 323.99135,360.35237 327.58008,363.27493 329.40075,363.27492 C 329.72017,363.27492 330.34751,363.87069 330.79456,364.59406 C 331.24165,365.31746 332.81673,367.06471 334.30397,368.47682 C 335.79121,369.88895 337.55449,371.6973 338.21162,372.49647 C 338.86874,373.29565 340.92956,375.09029 342.79128,376.47879 C 347.10305,379.69451 352.56394,384.93135 355.59691,388.76174 C 358.98861,393.04522 359.2228,393.27428 363.6611,396.61437 C 368.66822,400.38253 368.98498,400.79829 367.84253,401.94071 C 367.08601,402.69726 366.72077,402.76132 364.51979,402.52561 C 361.75371,402.22939 361.27411,402.49654 361.04771,404.47944 C 360.93827,405.43792 360.67175,405.7067 359.66634,405.91058 C 357.75889,406.29736 355.31058,408.26607 352.48573,411.67249 C 350.11394,414.53258 349.43262,416.07077 349.68566,417.95708 C 350.07601,420.
8673 350.54858,420.92784 354.77556,418.67888 C 358.42133,416.73914 358.54773,416.70379 359.85301,417.26018 C 361.56879,417.99155 365.91471,418.00013 367.65586,417.27262 C 368.39621,416.96328 369.42124,416.29127 369.93325,415.77926 C 370.7458,414.96668 371.24632,414.84958 373.85334,414.85835 C 376.34487,414.86672 377.19332,415.05186 378.99301,415.99082 C 381.68303,417.39432 385.15367,420.64254 386.49719,423.00965 C 387.05833,423.99834 388.15042,425.78471 388.92391,426.97952 C 390.25372,429.03373 390.33228,429.34026 390.35505,432.64187 C 390.38341,436.74976 390.63674,437.12561 394.6236,439.08824 C 397.6897,440.5976 398.94193,442.59734 398.94192,445.97018 C 398.94192,448.46934 399.4697,450.03025 400.42284,450.32584 C 400.80945,450.44573 401.45699,450.72218 401.85399,450.93563 C 404.2466,452.22206 408.30131,447.43896 408.77326,442.77188 C 408.89882,441.53016 408.72714,439.78407 408.33769,438.29178 C 407.96133,436.84943 407.70388,434.23364 407.70301,431.92008 C 407.7013,427.4425
407.09815,425.93171 404.84072,424.76435 C 402.59454,423.60281 398.54393,419.72 398.54369,418.72866 C 398.54345,417.86197 398.65972,417.83264 402.33933,417.83264 C 404.4316,417.83264 407.43328,418.1272 409.00971,418.47976 C 411.82318,419.10899 411.95175,419.18961 415.64275,422.86031 C 419.16814,426.36629 419.50679,426.59373 421.04377,426.59373 C 421.9454,426.59373 423.0329,426.33041 423.45805,426.00883 C 424.36661,425.32163 426.69936,425.23641 428.2866,425.82216 C 428.90319,426.04969 430.43165,427.34891 431.68402,428.70933 C 433.53822,430.72355 434.02598,431.07214 434.34719,430.58849 C 434.93522,429.70301 435.31411,425.99861 435.04409,423.719 C 434.50338,419.15342 430.58297,413.56388 426.14611,411.02537 C 424.32014,409.98067 424.03051,409.63903 424.0305,408.61109 C 424.0305,407.80682 423.6211,407.01944 422.79848,406.19681 L 421.57889,404.97723 L 416.86234,405.21368 C 411.74104,405.47117 409.64364,405.12781 408.2008,403.79498 C 407.03725,402.72013 407.06179,402.6036 408.59903,
401.95316 C 409.31087,401.65196 410.70539,400.88905 411.71022,400.26067 C 412.715,399.63229 414.03209,399.11576 414.62229,399.11576 C 416.09013,399.11576 418.16179,398.20282 419.1895,397.09971 C 420.08242,396.14129 420.33074,394.5586 419.64996,394.13786 C 419.43093,394.0025 419.25173,393.54934 419.25173,393.12984 C 419.25173,392.09697 421.19172,391.15113 423.32115,391.15113 C 424.89126,391.15113 425.31424,391.39028 427.88837,393.73963 L 430.71333,396.32814 L 431.9578,394.92188 C 433.04672,393.68166 433.18984,393.23353 433.18983,391.10135 C 433.18983,388.13069 432.41889,386.39897 430.25287,384.53053 C 427.86105,382.46733 425.71439,381.43191 423.23404,381.13312 C 415.7999,380.23758 416.0586,380.22637 413.47737,381.63091 C 411.11888,382.91427 409.61697,383.15431 408.71104,382.40248 C 407.81677,381.66028 405.33394,383.86207 404.0816,386.50924 C 403.44391,387.85722 402.92441,389.3347 402.92424,389.79465 C 402.92392,390.62492 401.18063,393.33591 400.09928,394.18764 C 399.78898,394
.43206 397.95174,395.30574 396.01741,396.12902 C 393.03995,397.39626 392.22604,397.58389 390.69106,397.37349 C 387.87756,396.98786 385.79591,395.63178 385.04115,393.67741 C 384.6884,392.764 384.02249,391.59918 383.56023,391.0889 C 383.098,390.57863 381.79277,388.76672 380.66061,387.06925 C 379.52839,385.37179 378.4373,383.98296 378.23388,383.98296 C 377.65027,383.98296 374.25158,381.83749 374.25157,381.46912 C 374.25157,381.28673 373.2737,379.08908 372.08618,376.59079 C 370.34532,372.92838 369.3191,371.36707 366.77228,368.5266 C 360.41257,361.4335 354.72286,351.18213 356.28137,349.62305 C 356.6403,349.264 359.78161,349.13771 368.3901,349.1377 L 380.02592,349.1377 L 383.162,350.73063 C 384.88905,351.60674 386.39173,352.63717 386.49719,353.02046 C 386.64286,353.54991 387.07607,353.71019 388.32656,353.68003 C 391.18355,353.61113 391.62156,353.29232 393.97647,349.53594 C 397.0724,344.59749 400.28355,340.71902 402.04066,339.80415 C 403.36534,339.11445 405.31363,336.86719 405.3136
2,336.02096 C 405.31362,335.84051 406.69304,333.97019 408.38747,331.86441 C 410.10485,329.7301 411.7436,327.23837 412.08356,326.23939 C 412.71627,324.37999 414.87274,320.3381 417.08634,316.86851 C 417.7901,315.76547 419.51182,313.79423 420.90688,312.48796 C 424.16927,309.43313 425.2102,307.99583 426.83057,304.33666 C 427.55798,302.69396 428.57959,300.76707 429.10796,300.04323 C 429.93321,298.91272 430.27225,298.74425 431.50979,298.84853 C 433.17663,298.98898 433.47416,299.61203 433.53828,303.12952 C 433.60578,306.82993 434.45467,308.34792 437.88149,310.90748 C 439.54602,312.15073 441.10658,313.55768 441.34113,314.03111 C 441.70133,314.75807 442.27693,314.95152 445.04966,315.25069 C 450.97574,315.8901 455.50108,314.12924 458.17886,310.14835 C 459.41119,308.31639 460.15922,306.47882 459.8091,306.1287 C 459.72121,306.04083 458.48813,306.17412 457.07126,306.41493 C 454.59097,306.8365 454.43092,306.8094 452.93962,305.7927 C 452.08769,305.2119 451.19166,304.73695 450.94846,304.734
89 C 450.39496,304.73019 447.16551,299.33347 446.86659,297.91518 C 446.74314,297.32941 446.22342,296.66742 445.68434,296.42181 C 445.15302,296.17972 444.59746,295.67453 444.45231,295.28934 C 444.30716,294.90415 443.68796,293.90116 443.08339,293.06173 C 441.85326,291.35377 441.18882,288.21125 441.90114,287.49894 C 442.16015,287.23992 442.34916,285.68102 442.34915,283.79041 C 442.34915,280.56904 442.37345,280.49246 443.96697,278.4765 C 445.99779,275.90733 446.72875,273.9033 447.10304,269.9892 C 447.45305,266.32875 448.00174,265.55446 450.83646,264.71263 C 454.43723,263.64331 454.69434,263.33107 454.69433,259.90896 C 454.69433,256.08919 455.5866,254.19019 458.16639,252.55412 C 460.37379,251.15421 461.04147,251.11196 463.2812,252.23056 C 465.42751,253.30247 466.24305,253.02486 466.24305,251.23498 C 466.24305,249.46646 463.92793,247.10214 460.56825,245.42329 C 458.48625,244.3829 457.7138,244.20371 455.01789,244.20371 C 451.47865,244.20371 448.95899,245.18937 446.23191,247.63845 C
445.32084,248.45665 444.14303,249.0674 443.1954,249.21893 L 441.65225,249.46783 L 440.40777,255.6902 C 439.72341,259.10837 438.91811,262.14533 438.61573,262.44769 C 438.14821,262.91521 437.90577,262.67302 436.99792,260.81743 C 436.41076,259.61734 435.68117,257.22626 435.3801,255.50353 C 435.07904,253.7808 434.60415,251.54413 434.33474,250.53808 C 433.85149,248.73349 433.86534,248.69068 435.30543,246.80466 C 436.47611,245.27151 436.77392,244.54056 436.77391,243.13346 C 436.77391,241.21099 436.11315,239.63689 434.82009,238.46668 C 433.76904,237.51551 433.76747,236.837 434.83253,233.96169 C 435.44808,232.29987 436.2509,231.14254 437.70727,229.7927 C 438.81813,228.76306 439.63047,227.8207 439.51175,227.70199 C 439.08604,227.27626 435.01648,226.68153 432.51781,226.68152 C 429.39719,226.68152 427.79838,227.31433 425.84744,229.31981 C 423.53287,231.69907 422.53256,233.73751 422.08913,236.98576 C 421.80547,239.06351 421.43524,240.18848 420.81976,240.84363 C 420.31122,241.38492 419.
87558,242.48659 419.76196,243.49436 C 419.59403,244.98426 419.81653,245.69853 421.46689,248.79581 C 423.39644,252.41706 423.76311,253.82128 424.26695,259.54806 C 424.46567,261.80695 424.39279,262.44411 423.89361,262.85836 C 423.00986,263.59183 422.01919,262.95059 420.19753,260.46897 C 418.89415,258.69345 418.65606,258.04086 418.51749,255.86442 C 418.37173,253.57519 418.23734,253.24788 417.11123,252.40479 C 415.43308,251.14844 414.1643,250.79569 413.44004,251.39676 C 412.26521,252.37179 411.13073,251.28922 410.12974,248.2358 C 409.07769,245.02676 409.17106,243.81126 410.71464,240.32095 C 411.24699,239.11718 411.68534,238.04182 411.68533,237.93156 C 411.68533,237.52561 408.38075,238.27546 406.96877,239.00181 C 403.53889,240.76628 401.6834,244.19488 401.40598,249.2936 C 401.22188,252.67689 401.63923,254.82124 403.31002,259.06272 C 403.99215,260.79439 404.00192,261.09172 403.4718,262.36057 C 402.57937,264.49644 403.08667,266.2394 405.12695,268.03537 C 406.92788,269.62059 409.095
46,270.48699 411.24976,270.48699 C 412.87236,270.48699 416.13347,273.48355 418.66682,277.29425 C 421.21614,281.12896 421.13664,282.0473 417.95747,284.77354 C 414.82877,287.45648 410.02165,292.07053 408.64881,293.7213 C 402.15254,301.5329 394.80968,308.77889 387.82877,314.24267 C 385.9725,315.69552 383.99019,317.32897 383.43578,317.87653 C 381.61403,319.67571 380.45592,320.26324 378.70678,320.26592 C 377.41934,320.2679 376.75436,320.03091 376.01872,319.29523 C 375.48111,318.75762 375.04804,318.03971 375.04803,317.70231 C 375.04803,317.36491 375.95389,315.96114 377.06408,314.59112 L 379.08013,312.10218 L 378.9059,308.31898 C 378.80642,306.23822 378.50385,303.81897 378.23388,302.94285 C 377.74812,301.36626 377.76666,301.31319 380.01348,297.76584 L 382.27842,294.18176 L 382.07931,289.6021 C 381.96844,287.08328 381.6784,284.03682 381.43218,282.83216 C 381.15019,281.45256 381.07525,278.784 381.23306,275.62666 C 381.4626,271.03563 381.40316,270.4661 380.62327,268.80695 C 380.15491,
267.81061 379.16232,266.2782 378.40811,265.39709 C 377.04544,263.8051 377.03321,263.7661 377.03919,259.87163 C 377.04484,256.15321 376.97519,255.80885 375.62049,253.16392 C 374.46271,250.9035 373.70198,250.01973 371.62573,248.47225 C 369.15267,246.62902 369.07457,246.49758 369.07456,244.80105 C 369.07456,242.84923 369.6833,241.17645 370.51815,240.85607 C 370.82984,240.73647 372.22205,241.68195 373.74133,243.05879 C 375.20922,244.38902 377.57851,246.32148 379.00546,247.33978 C 381.46183,249.09272 381.75549,249.18797 384.60559,249.31849 C 386.26119,249.39431 388.41908,249.24668 389.39681,248.98248 L 391.17641,248.49714 L 389.48392,247.04111 C 387.94567,245.7138 387.30815,244.60194 388.09011,244.60194 C 388.25813,244.60194 389.33336,243.78762 390.4795,242.78501 C 391.96459,241.4859 392.57022,240.66669 392.57022,239.94761 C 392.57022,239.00631 392.46574,238.96449 391.13907,239.21337 C 390.35691,239.3601 389.50161,239.55907 389.23503,239.66138 C 388.95579,239.76853 388.36787,239.
03951 387.84122,237.94401 C 387.33837,236.89799 386.37238,235.1797 385.70072,234.12347 L 384.48114,232.20698 L 385.22782,230.7385 C 385.85137,229.51405 386.00302,228.13391 386.12384,222.33831 C 386.20429,218.48104 383.24726,210.96718 383.03755,210.50337 C 382.82325,210.02944 379.9602,215.20236 378.37078,219.92403 C 379.34495,215.03304 380.38484,213.91364 379.95126,209.43312 C 385.83734,209.71281 391.65512,209.78671 397.89656,209.80646 C 406.33238,209.7737 408.64185,209.87203 408.79815,210.27936 C 408.90719,210.56362 408.41053,211.95964 407.69057,213.3781 C 406.01135,216.6864 404.87554,220.02727 405.28874,220.44671 C 405.84088,221.00718 408.7121,219.97164 411.1502,218.34355 C 414.18624,216.31615 418.26053,212.06539 420.52109,208.56199 C 425.41794,200.9729 426.77478,198.04818 427.85104,192.76962 C 428.55603,189.31192 428.84932,180.10227 428.29905,178.75685 C 427.86394,177.69305 427.02317,178.50185 426.27056,180.71067 C 425.53299,182.87532 422.70888,186.62542 420.3842,188.51352
C 416.38416,191.76239 410.34662,194.59014 404.80339,195.81858 C 401.38127,196.57697 401.22536,196.84922 402.96157,199.30311 C 403.9016,200.63176 403.51066,201.66702 401.70465,202.60096 C 399.83045,203.57014 389.83594,202.14526 386.65897,201.87917 C 384.38799,201.69111 383.47493,201.67274 380.73527,201.30671 C 380.85801,200.86075 384.81341,196.80918 385.06604,194.1261 C 385.3646,190.955 384.98981,188.37663 385.29005,188.37663 C 385.54412,188.37663 386.93018,189.75461 387.51765,190.36779 C 388.34522,191.23162 388.72172,192.25966 389.22258,194.95989 C 390.00519,199.17883 390.51574,199.31543 392.49555,195.81858 C 393.82198,193.47577 393.84315,193.32611 394.00136,187.85395 C 394.12645,183.52758 394.33249,181.87729 394.92227,180.48667 C 395.34026,179.50105 395.80406,177.43367 395.95518,175.89456 C 396.22929,173.10266 396.23099,173.09253 394.79782,171.37712 C 393.00323,169.22918 392.93487,167.86243 394.53648,166.03833 C 396.23586,164.10283 398.87991,163.58766 405.38829,163.94762 C
408.66606,164.1289 410.49064,164.08844 410.49063,163.83561 C 410.49063,163.21382 407.97513,161.17069 405.23896,159.56707 L 402.72512,158.09859 L 397.74723,158.28526 C 392.52382,158.47297 390.62373,158.95819 387.79144,160.84888 C 386.72517,161.56066 385.85097,161.76837 384.00824,161.76979 C 381.15607,161.77198 377.28018,163.20867 375.9565,164.74408 C 375.4519,165.32942 373.84057,166.19859 372.1733,166.79746 C 370.57603,167.37121 368.05859,168.44776 366.58561,169.18685 C 365.11263,169.92593 363.64103,170.53089 363.31265,170.53088 C 362.31567,170.53088 361.62605,168.53059 361.33393,164.8063 C 360.89126,159.16317 359.48836,156.81551 355.92047,155.74654 C 354.66652,155.37084 354.23506,155.39188 353.71776,155.82121 C 353.07613,156.35372 353.08961,157.1888 353.76754,159.91552 C 354.01639,160.91649 353.78552,161.28687 351.68927,163.32538 C 349.59959,165.35755 346.65964,167.14466 344.12287,167.91749 C 343.41509,168.13311 342.41444,167.32336 338.32362,163.2756 C 335.60422,160.58484 3
31.63567,156.29323 329.51275,153.73049 C 327.38986,151.16775 324.24728,147.82409 322.51881,146.30098 C 318.48914,142.75009 311.77678,137.70391 311.48033,138.00035 C 311.10894,138.37173 313.25762,141.99963 315.0893,144.09827 C 317.7156,147.10733 318.48495,149.26296 318.77294,154.39006 L 319.02184,158.78305 L 320.58987,160.57509 C 321.45328,161.56072 322.78556,163.43718 323.55172,164.74408 C 325.03525,167.27457 325.16405,169.21721 323.92506,170.45621 C 323.42397,170.9573 323.15007,170.90701 321.78457,170.08287 C 318.09253,167.85461 314.91508,165.57912 314.91508,165.15476 C 314.91508,164.90318 314.33267,164.50678 313.62082,164.27118 C 312.90899,164.03557 309.45931,162.84698 305.95487,161.6329 C 302.45043,160.41881 298.14954,159.1367 296.39731,158.78305 C 294.64509,158.4294 291.68823,157.59068 289.82649,156.92879 C 285.81877,155.50394 281.48373,154.20339 280.75428,154.20339 C 280.36314,154.20339 280.3449,154.39606 280.65472,154.97496 C 280.88148,155.39862 281.06333,156.16024 281
.0654,156.66745 C 281.07129,158.10408 283.85887,162.14214 287.36243,165.80188 C 291.08355,169.6889 293.26653,172.39883 294.74216,174.94876 C 295.58351,176.40268 295.79511,177.29727 295.79996,179.32931 C 295.80331,180.73374 295.93775,182.0883 296.09864,182.34093 C 296.25956,182.59356 297.4477,182.99869 298.73692,183.23695 C 301.42224,183.73321 303.78164,185.4189 305.97976,188.41396 C 307.1946,190.06923 307.32735,190.51222 307.33623,192.96874 C 307.34169,194.46542 307.48309,195.61655 307.64735,195.53235 C 311.83292,193.38726 314.39899,192.92397 317.41647,193.75276 L 318.53649,194.05143 L 316.396,196.42837 C 313.70049,199.407 312.12746,202.45623 312.12746,204.69168 C 312.12746,205.6194 312.23793,206.37172 312.37635,206.37172 C 312.51478,206.37172 313.27206,205.97286 314.05639,205.48814 C 315.18685,204.78949 316.23931,204.58346 319.17118,204.45523 L 322.87971,204.29344 L 322.87971,210.82693 C 322.87971,216.81774 322.80524,217.50711 321.98369,219.11512 C 321.38255,220.29173 320.5
8424,221.11901 319.55696,221.6414 L 318.02626,222.42542 L 317.06802,221.26806 C 316.54426,220.63347 315.55646,219.21468 314.8653,218.11954 C 314.17413,217.02441 313.08945,215.38516 312.46346,214.47324 C 311.83744,213.56132 311.331,212.66945 311.33099,212.49452 C 311.33099,212.31959 310.62821,211.44999 309.7754,210.56559 C 307.54284,208.25042 301.77344,200.71389 301.77344,200.11201 C 301.77344,199.83154 300.01695,197.40506 297.87824,194.72344 C 293.82384,189.63973 285.55426,178.65904 283.70368,175.90701 C 283.11454,175.0309 281.90439,173.32846 281.01562,172.12381 C 280.12689,170.91916 278.88154,168.92767 278.25289,167.69348 C 277.6242,166.4593 276.86804,165.20106 276.56041,164.89342 C 275.80492,164.13796 272.88234,158.95758 270.1887,153.58115 C 267.08692,147.39008 263.92283,139.73719 261.3405,132.18866 C 260.12605,128.6386 258.88876,125.19222 258.59021,124.53514 C 258.2917,123.87806 257.6387,122.04122 257.13418,120.45327 C 256.62962,118.86532 256.09405,117.56609 255.95193,117
.56609 z M 373.76622,193.67809 C 374.45847,193.67567 375.11278,193.84364 375.65782,194.20077 C 377.90365,195.67228 379.18427,198.72434 379.0179,201.18226 C 376.0036,201.17722 376.62922,201.18937 375.1227,201.15737 C 374.09474,201.13554 372.80799,200.97184 372.26041,200.79647 C 371.71284,200.62111 370.59754,200.4574 369.78391,200.43558 C 367.76938,200.38152 367.31139,199.47574 368.25321,197.39906 C 369.25472,195.19074 371.6895,193.68534 373.76622,193.67809 z M 370.10747,208.7611 C 373.32777,209.05034 376.45065,209.256 379.55302,209.40823 C 377.33171,211.28105 373.80603,215.49151 371.86218,216.67596 C 371.09558,217.14307 370.36563,217.52138 370.24436,217.5222 C 369.3585,217.52818 365.66745,215.19372 364.69401,214.01278 C 363.26552,212.27975 363.20523,211.56844 364.39534,210.45359 C 365.72149,209.21132 367.231,208.76111 370.10747,208.7611 z M 360.47525,226.79352 C 360.49159,226.7897 360.51414,226.79225 360.53747,226.79352 C 361.23745,226.83179 364.57437,229.47603 365.57759,230.
83806 C 366.97311,232.73281 368.25313,235.34359 368.26565,236.33864 C 368.27728,237.26753 368.05005,237.23227 365.50292,235.8284 C 362.28003,234.0521 361.50817,233.19408 361.50816,231.38563 C 361.50816,230.54066 361.22977,229.19208 360.89837,228.39889 C 360.56696,227.60571 360.36246,226.89389 360.43791,226.81841 C 360.44878,226.80755 360.45891,226.79735 360.47525,226.79352 z M 324.31085,230.34027 C 324.37362,230.33322 324.43561,230.33696 324.49752,230.34027 C 325.32304,230.38448 326.03714,231.33555 326.05311,232.90389 C 326.07334,234.88731 327.15124,240.60127 328.03183,243.35747 C 328.79022,245.7313 328.80606,245.97579 328.20605,247.24022 C 324.6141,250.05812 324.0846,251.59762 322.44414,256.15065 C 321.54079,257.91653 321.06538,259.46686 320.95077,261.02899 C 320.74636,263.81662 321.0932,263.91485 323.55172,261.75078 C 325.50983,260.02718 327.93687,259.36293 329.91098,260.02096 C 331.39256,260.51483 331.82295,262.54754 331.26746,266.36778 C 330.67262,270.4586 330.32881,271.
02565 327.72071,272.07991 C 323.3314,273.85421 320.89544,275.70399 318.84761,278.8374 L 317.69025,280.62944 L 320.49032,281.10234 C 323.14859,281.55025 326.06557,283.06628 326.06556,284.01441 C 326.06556,284.20549 325.59968,284.92101 325.03264,285.59489 C 324.18206,286.60576 323.71175,286.82169 322.34458,286.81448 C 319.97112,286.80195 317.8028,285.6764 314.87774,282.93172 C 311.79595,280.03996 310.07323,277.27062 308.43137,272.60259 C 307.28677,269.34832 307.19759,268.69619 307.17445,263.51793 C 307.15271,258.65104 307.26209,257.61382 308.07047,255.35419 C 309.82361,250.45373 313.26066,248.19026 319.39518,247.8749 C 321.14524,248.00031 322.64723,247.98358 324.37121,248.28772 C 324.04619,244.36369 324.25854,242.77508 323.04149,236.58753 C 322.36923,232.58553 322.37457,232.29081 323.0166,231.31096 C 323.41566,230.7019 323.87144,230.38966 324.31085,230.34027 z M 208.30104,266.72868 C 211.75319,266.70923 213.49474,267.54958 214.87186,269.91453 C 215.72316,271.37641 215.77214,27
1.82753 215.61854,276.46046 C 215.43516,281.99101 214.71733,284.68726 212.59447,287.77272 L 211.38733,289.52743 L 208.22637,288.15851 C 204.45544,286.52817 200.54392,285.64169 197.10078,285.63223 L 194.58694,285.61978 L 196.60299,287.94695 C 197.71314,289.22335 198.63148,290.45869 198.63148,290.69723 C 198.63148,290.93577 198.76588,291.19668 198.93015,291.26969 C 199.09442,291.3427 199.65001,291.99654 200.16218,292.72573 C 201.00233,293.92179 201.03664,294.1697 200.57286,295.28934 C 199.24535,298.49423 197.03332,299.81017 191.42598,300.72769 L 188.81259,301.15081 L 183.59824,298.16407 L 178.3839,295.17734 L 175.19805,295.17734 C 169.9222,295.17734 169.74713,295.48435 172.93311,299.37121 C 176.31465,303.49665 176.7175,306.5441 174.25225,309.35189 C 172.76151,311.04974 171.28094,311.85273 168.36589,312.55019 C 164.72585,313.42108 164.02333,313.28967 162.51686,311.52972 C 160.26032,308.89344 154.22608,306.45025 150.8437,306.80072 L 149.63656,306.92517 L 151.4286,309.60078 C 153
.00711,311.94889 153.23309,312.5483 153.23309,314.42934 C 153.23309,317.27559 152.62547,318.85406 151.3166,319.45701 C 149.29996,320.38606 146.0351,320.37632 144.27288,319.43212 C 140.73834,317.5383 136.93601,313.3803 136.29581,310.69592 C 136.07543,309.77184 136.25636,309.60347 138.27452,308.76699 C 141.01356,307.63172 144.01921,304.97502 145.29335,302.56951 C 145.82379,301.56813 146.56058,300.65663 146.92361,300.54102 C 147.5347,300.34645 148.24387,299.223 147.94408,298.9232 C 147.87204,298.85116 146.65514,299.35543 145.24357,300.04323 C 143.01101,301.1311 142.28887,301.27917 139.73055,301.22548 C 137.67277,301.1823 136.41711,300.94352 135.54912,300.42902 C 134.4336,299.76779 134.31383,299.51673 134.36687,297.90273 C 134.47862,294.50536 137.14361,290.72127 140.62658,289.01719 L 142.71729,287.99673 L 145.94048,288.60652 C 149.6158,289.30371 152.46879,290.235 155.73448,291.77993 C 160.22271,293.90318 161.103,292.17472 157.45186,288.4074 C 154.91528,285.79012 152.69444,282.58
438 152.95931,281.9237 C 153.0642,281.66196 154.99674,280.4915 157.26518,279.33519 L 161.39684,277.23203 L 164.7818,277.6676 C 169.74277,278.2923 173.94021,279.51915 177.799,281.48813 C 179.67674,282.44628 181.60766,283.2304 182.09243,283.23039 C 182.93353,283.23039 182.95723,283.15451 182.54044,281.51302 C 182.03003,279.50276 179.62744,275.78981 178.62035,275.45243 C 177.592,275.10792 177.75202,274.51504 179.30481,273.0506 C 181.54721,270.93573 184.61995,269.96929 189.19837,269.92697 C 192.51568,269.89631 193.1645,270.00192 193.49181,270.58654 C 193.70402,270.96559 194.69949,271.75081 195.70697,272.34125 C 196.71445,272.93169 197.96269,273.81366 198.48214,274.29507 C 199.0016,274.77649 201.05468,275.99487 203.03692,277.00803 C 206.53753,278.79728 208.84815,279.30624 210.05575,278.53873 C 210.79224,278.07066 209.66078,275.21062 207.81569,272.87637 C 206.19852,270.83052 204.67951,267.4879 205.15252,267.0149 C 205.30301,266.86441 206.72245,266.73756 208.30104,266.72868 z" />
+ <path
+ id="path2480"
+ d="M 431.35117,424.37439 C 432.17587,422.22526 430.29459,416.75083 428.07787,414.84941 C 426.08205,413.13742 425.19077,412.68923 423.75041,412.67325 C 422.52585,412.65965 421.23227,413.7767 421.24302,414.83846 C 421.24533,415.06351 422.29272,415.73401 423.57065,416.32847 C 424.84857,416.92294 426.32513,417.77404 426.85191,418.21981 C 427.80241,419.02415 427.80365,419.03503 427.01324,419.65146 C 426.47176,420.07376 425.57933,420.23321 424.22562,420.14952 C 422.42039,420.03791 422.22259,420.11002 422.10731,420.92179 C 421.95685,421.9811 423.24967,422.61492 425.56085,422.61492 C 426.62743,422.61492 427.43015,422.94554 428.4221,423.79343 C 429.96501,425.11224 430.99002,425.31554 431.35117,424.37439 z" />
+ <path
+ id="path2533"
+ d="M 425.80321,239.0302 C 426.14286,239.0302 426.55957,238.38265 426.80397,237.47497 C 427.44556,235.0923 428.42664,234.10814 430.09766,234.17096 C 431.26316,234.21477 431.55383,234.06306 431.7422,233.31267 C 431.868,232.81134 432.42349,231.73429 432.97664,230.91922 C 433.52974,230.10415 433.98229,229.37877 433.98229,229.30726 C 433.98229,229.01743 430.33369,229.88402 429.30853,230.41734 C 426.74523,231.75084 424.8459,235.17091 424.83173,238.47871" />
+ <path
+ id="path2450"
+ style="fill:#ff0000"
+ d="M 424.0265,241.52826 C 422.99687,242.83725 423.00902,243.00665 424.43493,247.2188 C 425.09763,249.17638 425.7168,251.22604 425.8109,251.77361 C 425.905,252.32118 426.71986,257.60109 427.6217,263.50675 C 428.52353,269.41241 429.336,274.36502 429.4272,274.51255 C 429.67884,274.91969 428.49669,275.7699 428.05692,275.4981 C 427.84514,275.36722 427.54994,274.67978 427.40096,273.97045 C 427.2519,273.26112 426.64591,272.14315 426.0543,271.48607 C 425.46264,270.82899 424.50107,269.57456 423.91743,268.69845 C 423.33382,267.82234 421.23797,265.05992 419.25999,262.55975 C 416.36927,258.90586 415.66364,257.75519 415.66364,256.69501 C 415.66364,255.09386 414.22431,253.93816 412.70506,254.31946 C 411.26709,254.68038 407.83987,258.19034 407.52482,259.62485 C 407.37676,260.29887 406.90741,261.16551 406.48174,261.55071 C 405.50786,262.43208 405.46784,264.55128 406.40476,265.62758 C 407.08116,266.40459 413.05045,268.89756 414.23455,268.89756 C 414.55783,268.89756 416.31618,270.734
41 418.14199,272.97944 C 424.1987,280.42682 424.16939,280.36555 423.01253,283.14713 C 421.84845,285.94598 420.3474,287.63482 417.59498,289.24229 C 415.31152,290.57591 414.28449,291.5834 411.02213,295.68993 C 403.8599,304.70556 393.46068,314.67769 384.66319,320.96633 C 380.92937,323.63533 380.47232,323.85351 378.61469,323.85351 C 377.41315,323.85351 375.99751,323.54348 375.09373,323.08239 C 374.26238,322.65828 373.05992,322.25507 372.42152,322.18637 L 371.26083,322.06147 L 371.27505,325.44644 C 371.29484,330.1629 372.60036,332.02647 375.19388,331.04041 C 376.24215,330.64186 376.24462,330.64552 375.99206,332.22496 L 375.7387,333.8093 L 377.39531,333.8093 C 379.51625,333.8093 381.61704,332.93019 382.22912,331.78653 C 382.52604,331.23169 382.62405,330.07405 382.48674,328.74344 C 382.22343,326.19236 382.72982,325.77251 384.8504,326.78375 C 386.90766,327.76478 388.45045,327.62256 389.63734,326.34246 C 390.46909,325.44536 390.6158,324.97168 390.44854,323.72304 C 390.33624,322.88469
389.9204,321.84083 389.52448,321.40335 C 388.82033,320.62528 388.82714,320.61358 389.8355,320.86666 C 390.40246,321.00896 391.65132,320.91402 392.61074,320.65567 C 393.57016,320.39732 394.68775,320.1219 395.09423,320.04361 C 396.54506,319.76421 397.00335,319.01163 396.87886,317.11299 C 396.76537,315.38236 396.82861,315.25785 398.14735,314.61606 C 399.5543,313.93132 401.06806,313.59163 402.97718,313.53224 C 404.29668,313.49118 404.71968,312.48016 403.92485,311.26712 C 403.59133,310.75812 403.31846,309.9661 403.31846,309.50707 C 403.31846,308.7133 403.45446,308.68588 406.09912,308.94648 C 409.3144,309.26331 409.78543,308.84641 408.91899,306.45045 C 408.64585,305.69505 408.50742,304.99196 408.61136,304.88802 C 408.7153,304.78408 409.49336,305.16934 410.3404,305.74416 C 411.48719,306.52241 412.18047,306.72928 413.05534,306.5543 C 414.64425,306.23653 414.93902,305.66882 414.67013,303.44415 C 414.42247,301.39507 414.73759,301.10571 415.86276,302.34901 C 416.80473,303.38986 416.95
753,303.36097 417.76806,301.98889 C 418.61139,300.56127 418.63174,299.47263 417.84368,297.94869 C 417.1009,296.5123 417.62808,296.39624 419.55604,297.57172 C 421.26871,298.61594 421.50518,298.58227 422.22423,297.19178 C 422.98549,295.71967 422.99457,294.35009 422.25477,292.57955 C 421.93742,291.81999 421.73357,291.19853 421.80178,291.19853 C 421.87004,291.19853 422.60235,291.73614 423.42916,292.39322 C 424.256,293.0503 425.07106,293.58792 425.24043,293.58792 C 425.4098,293.58792 425.94534,292.7679 426.43051,291.76566 C 427.15644,290.26616 427.23326,289.76909 426.8643,288.9593 C 426.28842,287.69539 426.29738,287.61444 427.01324,287.61444 C 427.34178,287.61444 427.61059,287.94298 427.61059,288.34453 C 427.61059,289.46758 428.00838,289.62629 429.23422,288.99237 C 430.56718,288.30307 432.7876,288.22141 432.7876,288.86169 C 432.7876,289.82055 431.08707,291.99511 429.68123,292.83392 C 427.15282,294.34256 425.63568,296.04627 423.33577,299.95962 C 420.91126,304.08505 418.64771,307.1
7959 415.35688,310.86771 C 414.18648,312.1794 412.22885,314.87619 411.0066,316.86057 C 409.05718,320.02563 405.87181,324.98039 402.55987,329.99928 C 401.05739,332.27621 397.05496,336.16562 392.21792,340.04925 C 389.8907,341.9178 387.92769,343.60521 387.85577,343.79905 C 387.78385,343.99289 387.19101,343.87534 386.53834,343.53783 C 382.62687,341.51514 376.27198,340.94911 367.0794,341.80463 C 362.07164,342.27069 360.75532,342.7064 360.26347,344.06074 C 359.56015,345.99733 362.9685,346.36044 374.24757,345.55055 C 377.36727,345.32654 377.91345,345.40663 381.21662,346.57244 C 383.18786,347.26816 385.87593,348.33934 387.19009,348.95284 C 388.50425,349.56634 389.68541,350.0837 389.81487,350.10254 C 389.94434,350.12138 390.53703,349.2424 391.13202,348.14925 C 393.50676,343.78602 398.30043,338.06517 402.99912,333.98683 C 404.98128,332.26639 405.68213,331.21129 408.5398,325.64555 C 412.8258,317.29795 415.09493,313.88713 421.91894,305.53486 C 422.54524,304.76827 423.41008,303.43869 423
.84077,302.58026 C 424.90118,300.46671 428.74459,296.3812 430.71277,295.27542 L 432.31641,294.37442 L 433.54758,295.41038 C 434.71834,296.39551 434.77875,296.59017 434.77875,299.37807 C 434.77875,304.95405 436.28009,308.56004 438.7095,308.81915 C 439.52926,308.90658 439.81746,308.54309 440.89977,306.05684 C 442.0822,303.3405 442.23241,303.17201 443.83203,302.76734 C 444.87731,302.5029 445.76568,301.96285 446.16969,301.34621 C 446.80483,300.37687 446.78077,300.30754 445.22154,298.61597 C 444.3416,297.66136 443.13727,296.14837 442.54526,295.25376 C 441.95325,294.35916 441.04254,293.34787 440.52149,293.00646 C 438.7621,291.85367 438.24078,290.23517 438.72793,287.43792 C 438.96516,286.07545 439.16233,283.72095 439.16603,282.2057 L 439.17276,279.4507 L 441.55709,276.47289 C 443.98511,273.44054 444.44148,272.49107 445.90853,267.41967 C 446.65103,264.85281 446.88885,264.47697 448.14874,263.8791 C 449.95277,263.02305 451.32607,261.21316 451.95452,258.86355 C 452.42941,257.08791 452.
39994,256.92532 451.27223,255.10132 C 449.96288,252.98351 447.09223,250.57892 445.87332,250.57892 C 444.87344,250.57892 443.39413,253.74605 441.38653,260.18472 C 440.06249,264.43119 438.12696,268.1011 437.21147,268.1011 C 436.0014,268.1011 434.38052,263.05192 434.38052,259.28247 C 434.38052,257.58378 434.10327,255.87463 433.6332,254.67553 C 433.22219,253.62704 432.6704,251.48188 432.40701,249.90851 C 431.96115,247.24511 431.98373,246.97047 432.73459,245.92619 C 433.17818,245.30929 433.6551,244.16038 433.7944,243.37306 C 434.02833,242.05128 433.9535,241.90252 432.8185,241.43238 C 432.14238,241.15234 431.04139,240.29926 430.37184,239.53666 C 429.70226,238.77405 429.10917,238.21372 429.05382,238.29148 C 428.9985,238.36923 428.71205,239.19447 428.41728,240.12534 C 427.82049,242.01002 427.59354,241.10246 425.90707,241.01681" />
+ <path
+ id="path2448"
+ d="M 417.03722,266.70729 C 415.85658,265.4395 415.05443,264.91525 414.29516,264.91525 C 412.6691,264.91525 411.68133,264.2219 411.68133,263.08054 C 411.68133,262.08409 411.71255,262.07409 413.97116,262.34723 C 416.62302,262.66792 417.25657,263.05712 417.25657,264.36551 C 417.25657,264.89273 417.89386,266.01656 418.69673,266.90526 C 419.8395,268.17019 419.98915,268.49933 419.42147,268.49933 C 419.02798,268.49933 417.95507,267.69291 417.03722,266.70729 z" />
+ <path
+ id="path2420"
+ d="M 403.41802,323.13387 C 403.94727,322.67936 404.11493,321.9201 404.11493,319.97796 C 404.11493,317.68231 403.99578,317.30139 402.95086,316.25648 C 401.7828,315.08841 400.42934,314.79087 399.36048,315.46718 C 398.64092,315.92249 399.19183,318.62169 400.70077,322.03364 C 401.73303,324.36773 401.90172,324.43605 403.41802,323.13387 z" />
+ <path
+ id="path2416"
+ d="M 372.66085,313.96351 C 375.46576,312.48652 376.27731,308.31767 374.4955,304.53928 C 373.17445,301.73792 371.99608,300.81569 368.61633,299.93794 C 364.59587,298.8938 364.0313,298.93634 363.30643,300.33808 C 362.40727,302.07687 362.54247,303.65618 363.68217,304.72687 C 364.87455,305.84706 364.66329,306.32841 362.97403,306.34018 L 361.70327,306.34903 L 362.69885,307.14259 C 363.24642,307.57905 365.18959,308.65658 367.017,309.53712 C 369.81421,310.88494 370.26302,311.23032 369.85543,311.72144 C 369.11715,312.611 367.93532,312.42598 365.86348,311.09649 C 363.89944,309.83617 359.47756,308.8915 360.07618,309.86012 C 360.67627,310.83111 368.71641,314.62056 370.27146,314.66534 C 370.82246,314.6812 371.89768,314.36538 372.66085,313.96351 z" />
+ <path
+ id="path2412"
+ d="M 452.63816,310.6646 C 453.567,309.98152 454.2633,309.2199 454.18553,308.97212 C 454.10775,308.72433 452.97606,308.16319 451.6707,307.72513 C 450.36533,307.28708 448.85803,306.61506 448.32113,306.23177 C 447.40532,305.57797 445.13277,305.2503 445.13277,305.77206 C 445.13277,305.90252 445.51073,306.54005 445.97268,307.1888 C 447.00944,308.64478 446.7077,309.01821 444.99494,308.39886 C 443.0188,307.68428 442.34427,307.79181 442.35124,308.82027 C 442.36498,310.83752 444.30967,311.86887 448.14061,311.89062 C 450.67145,311.90499 451.11644,311.78369 452.63816,310.6646 z" />
+ <path
+ id="path2410"
+ d="M 355.77755,305.33575 C 359.73936,297.07954 361.46437,288.9081 361.7885,276.86219 C 362.01346,268.50263 361.58532,264.71785 359.86874,259.89079 C 359.41054,258.60224 358.9006,256.56234 358.73561,255.35769 C 358.52152,253.79456 357.16455,250.51247 353.99642,243.89503 C 351.55486,238.79521 349.55721,234.52157 349.55721,234.39804 C 349.55721,234.27451 348.59087,232.61124 347.40979,230.70187 C 343.62006,224.57534 342.24186,221.30863 340.93948,215.36567 C 340.58406,213.74395 339.85785,213.09723 339.48455,214.07003 C 339.09727,215.07924 340.67442,222.97 341.69927,225.15074 C 347.40844,237.299 348.96249,240.6565 350.70408,244.60544 C 356.77377,258.36801 359.23105,275.00008 357.08793,287.81356 C 356.52447,291.1822 354.13739,298.29557 352.0904,302.70585 C 350.18339,306.81455 350.07416,307.42329 350.94266,309.10274 C 352.25217,311.63507 353.05492,311.00961 355.77755,305.33575 z" />
+ <path
+ id="path2406"
+ d="M 348.96194,299.72242 L 350.05409,298.29052 L 349.2685,297.23347 C 347.98026,295.50012 345.38534,295.69211 344.36635,297.59617 C 344.00272,298.27556 344.14959,298.61396 345.31294,299.77732 C 346.0703,300.53467 346.95541,301.15431 347.27985,301.15431 C 347.60433,301.15431 348.36124,300.50996 348.96194,299.72242 z" />
+ <path
+ id="path2402"
+ d="M 375.60824,296.71641 C 376.1582,296.46584 377.10289,295.54693 377.70756,294.67438 C 378.5816,293.41309 378.83834,292.53237 378.96012,290.37726 C 379.1036,287.83789 379.03144,287.55261 377.81815,285.86316 C 376.28416,283.7271 374.36923,282.32747 371.19516,281.02238 C 368.31905,279.83982 366.92512,279.80411 365.84393,280.8853 C 365.10234,281.62686 365.04217,281.97959 365.31715,283.97159 C 365.70327,286.76878 365.71876,287.55242 365.41272,288.80914 C 365.18752,289.73411 365.42375,289.9273 368.74369,291.53324 C 370.70904,292.48393 372.25864,293.30636 372.1872,293.36087 C 372.11575,293.41538 370.48838,293.28057 368.57082,293.06129 C 366.65325,292.84202 364.96686,292.7801 364.82326,292.92371 C 364.33662,293.41035 366.07323,294.88979 368.47321,296.03311 C 371.0463,297.25888 373.83209,297.52567 375.60824,296.71641 z" />
+ <path
+ id="path2400"
+ d="M 343.41664,293.56814 C 345.03856,292.56574 345.55025,291.26191 344.59569,290.56391 C 343.43448,289.7148 340.22757,289.12555 338.79206,289.49753 C 337.11053,289.93325 335.66507,291.7457 336.25421,292.67969 C 337.28714,294.31723 341.3826,294.82525 343.41664,293.56814 z" />
+ <path
+ id="path2398"
+ d="M 352.17375,292.33899 C 352.94871,290.84043 352.46482,289.57134 350.8355,288.82896 C 349.97723,288.4379 349.64662,288.4855 348.78855,289.1236 C 347.42715,290.136 347.28212,291.44231 348.39916,292.63131 C 349.72232,294.03979 351.35985,293.91298 352.17375,292.33899 z" />
+ <path
+ id="path2396"
+ d="M 319.60172,290.78199 C 321.38106,290.4004 324.46863,288.4071 324.46863,287.63997 C 324.46863,287.46688 322.63511,287.83747 321.26619,287.7236 C 319.89727,287.60972 318.50511,286.57155 317.30046,286.15647 C 314.63156,285.23686 313.50436,285.3671 312.63391,286.69563 C 312.00733,287.65188 312.01358,287.792 312.74326,289.14079 C 313.81474,291.12142 315.80184,291.59693 319.60172,290.78199 z" />
+ <path
+ id="path2394"
+ d="M 312.22584,290.16694 C 312.35514,290.03763 312.22054,289.25038 311.92669,288.41751 C 311.63283,287.58464 311.34814,286.0328 311.29406,284.96899 C 311.12142,281.57463 310.11059,280.72955 308.56828,282.69026 C 307.21226,284.41416 307.61113,287.56246 309.43181,289.50604 C 310.21863,290.346 311.69707,290.69571 312.22584,290.16694 z" />
+ <path
+ id="path2392"
+ d="M 307.34468,288.78296 C 307.34468,288.3305 307.15472,287.60535 306.92251,287.1715 C 306.69034,286.73765 306.37243,285.62941 306.21613,284.70873 C 305.95839,283.19094 305.79428,283.00057 304.45702,282.66808 C 301.55391,281.94625 299.88739,283.56431 300.79544,286.22319 C 301.60019,288.57954 302.98962,289.6056 305.37574,289.6056 C 307.10008,289.6056 307.34468,289.50341 307.34468,288.78296 z" />
+ <path
+ id="path2390"
+ d="M 344.42007,287.60999 C 346.37518,287.0669 347.36626,285.94167 346.8081,284.89874 C 345.83697,283.08423 340.51632,281.68185 339.28284,282.91531 C 338.70951,283.48867 338.66252,285.1968 339.18253,286.56449 C 339.53488,287.49127 340.08532,287.72923 342.38905,287.95079 C 342.71759,287.98238 343.63157,287.82902 344.42007,287.60999 z" />
+ <path
+ id="path2386"
+ d="M 353.38772,284.6114 C 354.2172,283.34549 353.66772,281.86375 352.10478,281.15163 C 351.16061,280.72144 350.96237,280.78352 350.10777,281.77705 C 348.92403,283.15325 348.91128,283.89516 350.055,284.8493 C 351.31935,285.90403 352.6007,285.81256 353.38772,284.6114 z" />
+ <path
+ id="path2384"
+ d="M 303.15002,281.65194 C 304.08165,280.87876 303.96927,277.79836 302.99033,277.27443 C 301.14616,276.28748 298.62783,277.14324 298.55312,278.78224 C 298.53635,279.14989 298.4526,279.80911 298.36698,280.24716 C 298.01284,282.05927 298.52958,282.54396 300.60317,282.34471 C 301.66812,282.24238 302.81423,281.93063 303.15002,281.65194 z" />
+ <path
+ id="path2382"
+ d="M 347.84498,279.98182 C 348.84374,279.15292 348.44515,277.51949 347.00475,276.53875 C 345.26065,275.35119 341.597,274.9016 340.86374,275.78514 C 340.11745,276.68437 341.21371,279.02734 342.86286,280.05782 C 344.25098,280.92515 346.75434,280.88697 347.84498,279.98182 z" />
+ <path
+ id="path2380"
+ d="M 378.57124,279.03433 C 379.63054,277.68762 379.35915,275.99462 377.42036,271.85491 C 375.07824,266.85408 371.95176,264.44201 366.58814,263.49786 C 365.23204,263.25915 365.06526,263.33089 364.69164,264.31362 C 364.40922,265.05643 364.41248,265.87566 364.70208,266.95114 C 365.05073,268.24603 365.42451,268.65331 366.90111,269.3474 C 368.15777,269.93809 368.75352,270.49174 368.93022,271.23307 C 369.28771,272.73279 369.84245,273.30837 371.74213,274.15063 C 374.43577,275.3449 374.20101,275.6675 370.63823,275.6675 C 367.80382,275.6675 367.44386,275.7443 367.87029,276.2581 C 368.13985,276.58293 369.37142,277.15758 370.60709,277.53509 C 371.84277,277.91261 373.47778,278.63246 374.24044,279.13477 C 376.08218,280.34773 377.56515,280.31334 378.57124,279.03433 z" />
+ <path
+ id="path2378"
+ d="M 297.05159,277.61235 C 297.63758,275.65645 297.04764,274.38712 294.88855,272.95831 C 293.42314,271.98854 293.3687,271.98229 292.81046,272.71984 C 291.98771,273.80685 292.08237,275.5277 293.06059,277.26821 C 293.92607,278.80818 295.20347,279.68764 296.09101,279.3546 C 296.36281,279.25261 296.79505,278.4686 297.05159,277.61235 z" />
+ <path
+ id="path2374"
+ d="M 354.28215,278.24348 C 354.39401,278.13163 354.56239,276.97733 354.65633,275.67837 C 354.81865,273.4344 354.77795,273.30426 353.84023,273.0689 C 353.2974,272.93266 352.24607,272.8792 351.50393,272.95009 L 350.15456,273.07899 L 350.2053,275.43802 C 350.26423,278.17952 350.99284,279.05041 352.91315,278.67482 C 353.55426,278.54942 354.17033,278.35531 354.28215,278.24348 z" />
+ <path
+ id="path2372"
+ d="M 305.65147,275.23782 C 305.92876,274.69999 306.04182,273.74544 305.90718,273.07899 C 305.67131,271.91174 304.3307,270.09226 303.70651,270.09226 C 303.16627,270.09226 302.48952,273.34349 302.74562,274.70864 C 303.10733,276.63657 304.77385,276.94006 305.65147,275.23782 z" />
+ <path
+ id="path2370"
+ d="M 301.45292,270.88205 C 301.86947,268.07532 301.85171,267.93611 300.98715,267.23604 C 300.49278,266.83571 299.57466,266.50817 298.94689,266.50817 C 295.78139,266.50817 295.73471,272.5593 298.88727,274.23591 C 300.43484,275.05894 300.92881,274.4132 301.45292,270.88205 z" />
+ <path
+ id="path2368"
+ d="M 347.53237,272.06204 C 348.45567,271.3932 349.14329,270.64249 349.06038,270.39379 C 348.46901,268.6196 343.98615,267.48491 342.19774,268.65672 C 340.851,269.53913 340.93367,270.30943 342.54834,271.92412 C 344.23425,273.61003 345.35273,273.64098 347.53237,272.06204 z" />
+ <path
+ id="path2366"
+ d="M 293.89592,268.91136 C 294.57538,268.37692 294.96318,267.58999 295.11877,266.43011 C 295.37794,264.49775 295.05915,264.13405 293.09806,264.12488 C 291.41673,264.11702 290.9281,265.23957 291.48216,267.83725 C 291.91826,269.88202 292.39323,270.09338 293.89592,268.91136 z" />
+ <path
+ id="path2364"
+ d="M 353.53953,268.49933 C 354.50663,267.53226 354.53586,266.85875 353.68309,265.19415 C 352.51611,262.91626 351.49397,262.73918 350.34934,264.61658 C 349.19327,266.51264 349.3307,267.57646 350.85147,268.5037 C 352.45455,269.48112 352.55793,269.48095 353.53953,268.49933 z" />
+ <path
+ id="path2362"
+ d="M 303.83427,264.29195 C 304.56773,261.58113 303.10956,259.10917 300.53006,258.69058 C 299.44297,258.51417 298.957,258.67432 298.06182,259.50398 C 297.09475,260.40021 296.96318,260.7874 297.06843,262.42747 L 297.18977,264.3179 L 298.71874,264.18477 C 300.33126,264.04436 302.5659,264.74731 302.5659,265.39498 C 302.5659,266.23359 303.53758,265.38859 303.83427,264.29195 z" />
+ <path
+ id="path2360"
+ d="M 346.52472,264.88009 C 347.10622,264.42269 347.86975,263.492 348.22143,262.81188 C 348.84661,261.60296 348.83586,261.55377 347.7418,260.61271 C 346.78867,259.79283 346.35699,259.68653 344.83044,259.89577 C 341.63432,260.33385 340.47335,261.67606 340.97544,264.35252 C 341.22768,265.697 341.25337,265.71171 343.34898,265.71171 C 344.89436,265.71171 345.75351,265.48673 346.52472,264.88009 z" />
+ <path
+ id="path2358"
+ d="M 295.83877,260.85297 C 296.09675,260.37093 296.82256,258.18793 297.45173,256.00186 C 298.70672,251.6412 298.64563,251.39265 296.31597,251.38148 C 294.39439,251.37226 293.09914,252.76064 292.89799,255.04512 C 292.78832,256.29083 292.45803,257.16206 291.91667,257.63363 C 291.45078,258.03946 290.99528,259.0706 290.8551,260.03691 L 290.60955,261.7294 L 292.98963,261.7294 C 295.03454,261.7294 295.43576,261.60597 295.83877,260.85297 z" />
+ <path
+ id="path2356"
+ d="M 374.08393,260.33734 C 375.0097,258.92442 374.55134,257.07298 372.53939,254.09884 C 369.95539,250.27899 366.03675,248.04959 361.30504,247.70738 C 359.71474,247.59237 359.7122,247.59454 359.7519,249.02177 C 359.77376,249.80804 360.19035,251.24965 360.67763,252.22535 C 361.1649,253.20105 361.77424,255.06659 362.0317,256.37101 L 362.49974,258.74266 L 365.00159,259.01861 C 366.51801,259.18587 368.16498,259.67996 369.18302,260.27303 C 371.46568,261.60283 373.23948,261.62611 374.08393,260.33734 z" />
+ <path
+ id="path2354"
+ d="M 352.19418,259.52108 C 353.0918,258.15111 352.40075,255.81063 350.66816,254.35273 C 349.47574,253.34938 349.37454,253.32945 348.88329,254.00127 C 347.92442,255.31259 348.24094,257.58086 349.59847,259.12703 C 351.07185,260.80511 351.32743,260.84391 352.19418,259.52108 z" />
+ <path
+ id="path2352"
+ d="M 304.03844,256.75457 C 304.68377,255.4013 304.67656,255.3371 303.76991,254.37202 C 301.96628,252.45214 300.47319,252.70215 299.96656,255.00888 C 299.74976,255.99585 299.89771,256.36338 300.83698,257.17115 C 302.40127,258.51649 303.25098,258.40592 304.03844,256.75457 z" />
+ <path
+ id="path2350"
+ d="M 343.84813,257.06902 C 344.81611,256.43627 345.97313,254.25127 345.97313,253.05599 C 345.97313,251.44707 342.97636,251.03627 340.94566,252.36682 C 339.83097,253.09719 339.77848,253.77016 340.63906,256.29583 C 341.32521,258.30957 341.7819,258.41961 343.84813,257.06902 z" />
+ <path
+ id="path2348"
+ style="fill:#ffffff"
+ d="M 406.50432,253.56228 C 406.50432,251.47756 406.54338,251.39302 407.29086,251.85982 C 408.41961,252.56475 409.205,251.74823 408.61092,250.48741 C 407.87897,248.93396 407.30078,246.37209 407.30078,244.6823 C 407.30078,242.34402 406.6196,242.26109 405.61088,244.47656 C 404.58858,246.72182 404.40639,251.31642 405.23069,254.06344 C 405.93321,256.40466 406.50432,256.17993 406.50432,253.56228 z" />
+ <path
+ id="path2346"
+ d="M 454.14981,253.52653 C 454.78849,252.68922 456.09174,251.71815 457.28519,251.19035 C 459.06775,250.402 461.06202,248.61852 461.06202,247.81268 C 461.06202,247.66449 460.69664,247.15105 460.25006,246.67169 C 459.53058,245.89944 459.02849,245.80014 455.84333,245.80014 C 452.05754,245.80014 451.19015,246.05851 449.41376,247.71534 C 448.13822,248.90503 448.05659,249.42891 449.01553,250.27097 C 450.12986,251.2495 451.50448,251.54436 451.50448,250.80487 C 451.50448,250.46156 451.77328,250.18068 452.10182,250.18068 C 452.85098,250.18068 452.84747,250.3317 452.06307,251.84858 C 451.57182,252.79853 451.52451,253.29288 451.8554,254.01908 C 452.43821,255.2982 452.86906,255.20571 454.14981,253.52653 z" />
+ <path
+ id="path2344"
+ d="M 341.30669,249.24007 C 342.95203,248.54367 343.91025,247.45299 344.2149,245.92985 C 344.42747,244.86691 344.29351,244.61842 343.1245,243.90738 C 341.29487,242.79453 338.81193,242.42789 337.85403,243.12913 C 337.23091,243.58527 337.14764,243.98259 337.36767,245.4497 C 337.65029,247.33438 338.91631,249.78245 339.60836,249.78245 C 339.83766,249.78245 340.6019,249.53838 341.30669,249.24007 z" />
+ <path
+ id="path2537"
+ d="M 366.42033,173.52113 C 366.6869,171.57605 366.42228,171.35849 364.95734,172.31836 C 364.31081,172.74197 363.32001,172.85896 361.4328,172.7345 C 359.20365,172.5875 358.70188,172.67814 358.10728,173.3352 C 357.43507,174.07794 356.11664,174.58297 357.16725,176.09902 C 358.05463,177.37949 358.85046,177.91749 358.73409,179.38074 C 358.63047,180.68337 358.95517,182.27316 359.36846,182.43175 C 360.03064,182.68585 361.67042,180.12423 363.91175,176.70698" />
+ <path
+ id="path2340"
+ d="M 363.41933,179.94981 C 362.99072,180.4192 362.33965,181.40039 361.97252,182.13021 C 361.03297,183.99807 355.45363,188.19022 352.54395,189.2146 C 349.02382,190.45389 346.19037,190.33915 343.86282,188.86307 C 342.83538,188.2115 341.22143,186.96554 340.27623,186.09427 C 338.34656,184.31559 336.67849,183.53891 335.55432,183.89571 C 334.38925,184.26548 331.57937,182.38591 330.3296,180.40081 C 329.72015,179.4328 327.94527,177.48886 326.3854,176.08095 C 324.82552,174.67305 322.82895,172.75737 321.94854,171.82388 C 320.95065,170.7658 319.73652,169.9522 318.72458,169.66344 C 317.83182,169.40868 316.89634,169.04623 316.64577,168.85799 C 316.39516,168.66975 315.05113,167.96774 313.65903,167.29797 C 312.2669,166.6282 310.76947,165.76053 310.33141,165.36981 C 309.26797,164.42129 289.37305,158.98568 286.96478,158.98568 C 285.89533,158.98568 286.06454,160.27882 287.28141,161.40521 C 288.47045,162.50583 294.00249,169.22422 296.4898,172.58834 C 297.90755,174.50587 298.19539,175.
22939 298.42258,177.44666 C 298.68027,179.96218 298.73224,180.06113 299.9308,180.31944 C 303.57462,181.10476 305.16758,182.05229 307.2622,184.68034 C 308.4027,186.11131 309.33583,187.51471 309.33583,187.79903 C 309.33583,188.08335 309.77317,188.72681 310.30764,189.22894 C 311.07774,189.9524 311.98053,190.21297 314.65696,190.48425 C 316.51459,190.67254 318.81012,191.12005 319.75819,191.47872 C 321.92923,192.30009 324.46863,192.64931 324.46863,192.12652 C 324.46863,191.64296 323.13145,190.7342 319.49074,188.74361 C 317.95754,187.90532 317.06152,187.30481 317.49958,187.40916 C 317.93763,187.51351 318.92326,187.72121 319.68985,187.87072 C 320.45645,188.02024 321.44207,188.46103 321.88013,188.85026 C 322.31818,189.23949 323.05614,189.67272 323.52,189.81299 C 324.43319,190.08911 326.98306,189.27669 326.16111,188.9715 C 325.88733,188.86984 325.66332,188.54661 325.66332,188.2532 C 325.66332,186.89494 318.11393,183.50527 312.37514,182.28683 C 311.74697,182.15346 311.30971,181.96763 3
11.40349,181.87388 C 311.78404,181.49334 320.3858,183.61699 321.68101,184.41125 C 323.1608,185.3187 324.66141,185.52534 325.06219,184.87686 C 325.35227,184.40748 323.15809,183.00487 321.59754,182.66212 C 320.98637,182.52788 320.48631,182.2561 320.48631,182.05817 C 320.48631,181.0915 313.41647,178.39494 309.34635,177.80919 C 308.17216,177.64021 307.13688,177.27828 307.04576,177.00491 C 306.80631,176.28654 307.2757,176.35753 312.97487,177.90167 C 317.96288,179.25312 319.68985,179.55058 319.68985,179.05825 C 319.68985,178.21992 318.05973,176.31075 316.78535,175.65657 C 315.0759,174.77904 310.1262,173.38201 307.14556,172.93578 L 305.1544,172.63769 L 306.94644,172.55363 C 307.93207,172.5074 309.09689,172.3227 309.53495,172.14319 C 310.42786,171.77727 310.40242,171.76294 305.55263,169.90053 C 304.23847,169.39587 303.47685,168.97362 303.86015,168.96221 C 304.99037,168.92856 304.75836,167.34854 303.6232,167.34854 C 303.10956,167.34854 302.34799,166.96774 301.93072,166.50232 L 301.17
209,165.6561 L 302.5659,165.93301 C 305.22107,166.46052 307.90511,167.46894 309.71144,168.61769 C 310.70949,169.25241 312.2937,169.96611 313.23185,170.20367 C 314.5034,170.52567 315.41575,171.1684 316.81593,172.72866 C 317.84903,173.87983 319.8591,175.56921 321.28278,176.48283 C 323.72848,178.05233 326.50905,181.05435 329.65771,185.52472 L 330.81955,187.17429 L 329.43963,188.90969 C 327.36807,191.51489 326.65639,193.96678 326.67336,198.44043 C 326.68746,202.15431 326.72425,202.30447 328.08828,204.21479 C 328.85853,205.29351 329.68741,206.64261 329.93026,207.21279 C 330.66866,208.94659 333.56555,210.35753 336.38694,210.35753 C 339.2112,210.35753 339.50713,209.91474 337.11248,209.27195 C 335.16887,208.75022 332.30328,206.45616 331.39061,204.69128 C 329.53545,201.10379 329.28735,196.7682 330.72955,193.1391 C 331.28699,191.73635 333.63679,189.25127 334.4057,189.25127 C 334.5992,189.25127 335.04096,189.1425 335.38742,189.00955 C 335.87306,188.82319 336.01734,189.03377 336.01734,1
89.92901 C 336.01734,191.2405 336.53293,191.99696 338.07787,192.95217 C 339.47981,193.81897 339.78238,194.91438 339.02463,196.37975 C 338.68478,197.03691 338.40673,197.85228 338.40673,198.1917 C 338.40673,198.99073 339.55511,198.99471 339.86131,198.19674 C 340.20718,197.29546 342.1437,196.41943 343.79018,196.41943 L 345.23091,196.41943 L 344.35966,197.64297 C 343.13716,199.35985 342.39148,202.10332 342.37495,204.94514 C 342.3671,206.29212 342.10774,207.81353 341.7917,208.36638 C 340.93494,209.86513 341.07871,211.1888 342.22856,212.389 C 343.07874,213.27638 343.2736,213.88142 343.3237,215.78908 L 343.38463,218.10969 L 347.65892,218.97816 C 355.93489,220.65972 361.17315,223.07315 365.98769,227.42277 C 367.35498,228.65805 369.07056,231.55118 369.07056,232.62171 C 369.07056,232.84454 369.44505,234.02779 369.90278,235.25115 C 370.6274,237.18792 370.81549,237.40866 371.3576,236.95873 C 371.70004,236.67453 372.20105,235.91681 372.47098,235.27491 L 372.96168,234.10781 L 374.64835,23
7.66414 C 376.79497,242.19023 378.48809,244.26597 381.09141,245.56327 C 383.44779,246.73749 383.73507,246.77561 384.70114,246.04224 C 385.08444,245.75128 385.39721,245.35377 385.39622,245.15889 C 385.39518,244.96401 384.24991,242.78851 382.85112,240.32445 C 381.45237,237.8604 380.38344,235.84435 380.47575,235.84435 C 380.5681,235.84435 381.18472,236.46062 381.84606,237.21384 C 382.97318,238.49757 385.57996,239.77752 386.06974,239.28772 C 386.19081,239.16668 385.62185,238.15767 384.80544,237.0455 C 383.98903,235.93332 382.99285,234.15954 382.59167,233.10375 L 381.86227,231.18414 L 382.85096,229.23326 C 384.10471,226.75941 384.00703,224.87195 382.56997,223.80378 C 381.89887,223.30494 379.41804,222.63764 375.52669,221.90927 C 368.17816,220.53381 362.22858,219.06617 356.77428,217.28347 C 354.2481,216.4578 351.84454,215.93278 350.59074,215.93278 C 348.1548,215.93278 346.91913,215.19324 346.10686,213.24918 C 345.78863,212.48754 345.59362,211.799 345.67354,211.7191 C 345.75343,211.
63919 346.47797,211.75582 347.28359,211.97827 C 350.76027,212.93822 354.65422,209.98133 356.10442,205.28008 C 356.31305,204.60385 356.22134,204.38406 355.73056,204.38406 C 354.67445,204.38406 349.48513,206.95618 347.80997,208.30995 C 346.95851,208.99807 346.1157,209.56107 345.93709,209.56107 C 344.61265,209.56107 344.66542,199.92665 345.99894,198.27985 C 346.64726,197.47917 347.0785,197.4111 351.81184,197.36231 C 356.04886,197.31862 357.50424,197.13494 360.30946,196.28987 C 364.46939,195.03669 382.06278,186.36279 383.08779,185.05968 C 383.49562,184.54126 384.43998,183.89625 385.18639,183.62634 C 386.86724,183.01854 388.95179,179.62126 388.19985,178.71522 C 387.62564,178.02331 387.27487,174.11847 387.78696,174.11847 C 388.49207,174.11847 389.33098,175.89692 389.6025,177.96744 C 389.8394,179.77399 389.71221,180.3716 388.55742,182.87695 C 387.52753,184.40414 391.1524,186.72713 391.78377,181.59182 C 392.49055,180.43835 393.26933,179.36673 393.51444,179.21045 C 393.78297,179.0392
1 393.96002,177.64564 393.96002,175.70338 L 393.96002,172.48046 L 391.96887,170.72626 C 389.877,168.88334 388.21781,168.47 386.53245,169.37196 C 385.12171,170.12697 385.32597,169.50601 387.15895,167.46728 C 389.308,165.07704 392.18419,163.69254 396.94676,162.75578 C 400.13448,162.12878 402.28294,161.00327 401.59858,160.31888 C 401.44355,160.16387 399.79244,159.95703 397.92944,159.85925 C 394.17113,159.66199 391.04194,160.33031 387.61564,162.06206 C 386.03247,162.86223 385.23569,163.02013 383.50517,162.87662 C 381.41928,162.70364 381.30132,162.75009 379.33358,164.51926 C 378.21981,165.52062 376.99636,166.85332 376.61473,167.48081 C 376.04789,168.41293 375.60386,168.64329 374.18823,168.73966 C 373.23526,168.80454 371.2907,169.29861 369.86702,169.8376 C 367.31838,170.80249 367.27748,170.84145 367.21125,172.36846 C 367.1743,173.22146 367.1295,174.23296 367.1117,174.61626 C 367.09393,174.99956 366.87586,175.31317 366.62705,175.31317" />
+ <path
+ id="path2338"
+ d="M 315.30931,186.86188 C 314.98076,186.64956 314.89116,186.47585 315.11019,186.47585 C 315.32922,186.47585 315.77723,186.64956 316.10577,186.86188 C 316.43431,187.0742 316.52391,187.24791 316.30488,187.24791 C 316.08586,187.24791 315.63785,187.0742 315.30931,186.86188 z" />
+ <path
+ id="path2336"
+ d="M 365.45756,245.14908 C 367.19373,242.94191 365.82883,237.96577 362.80319,235.47178 C 361.45267,234.35857 361.22233,234.30747 357.8744,234.37834 C 353.47868,234.47138 352.85784,234.90562 353.5334,237.41447 C 353.85353,238.60337 354.33221,239.28924 355.17001,239.75944 C 356.00984,240.23078 356.29832,240.64519 356.16212,241.18471 C 356.05651,241.6031 356.42264,242.71759 356.97575,243.66136 C 358.00032,245.40966 358.20835,245.50967 361.70327,245.93399 C 364.30974,246.25043 364.64668,246.17999 365.45756,245.14908 z" />
+ <path
+ id="path2334"
+ d="M 310.20051,243.14991 C 310.93445,242.48572 311.13337,241.22151 310.68703,240.05835 C 310.52551,239.63743 309.94509,239.42843 308.9376,239.42843 C 307.35073,239.42843 306.94644,239.87314 306.94644,241.61871 C 306.94644,243.17748 307.38028,243.80898 308.45108,243.80898 C 309.01271,243.80898 309.79997,243.5124 310.20051,243.14991 z" />
+ <path
+ id="path2332"
+ d="M 346.69688,241.31622 C 346.97568,238.89179 342.79413,236.57972 342.45559,238.97115 C 342.12263,241.32342 343.3276,242.6859 345.5749,242.49828 C 346.34034,242.43438 346.59971,242.16113 346.69688,241.31622 z" />
+ <path
+ id="path2328"
+ d="M 339.68111,239.47325 C 340.81536,238.45982 340.90221,238.24407 340.4133,237.65495 C 339.66196,236.74963 338.08058,235.96867 336.33605,235.6414 L 334.89027,235.37016 L 335.27695,237.10062 C 336.08906,240.73459 337.4493,241.46738 339.68111,239.47325 z" />
+ <path
+ id="path2324"
+ d="M 311.84955,235.94391 C 312.19466,234.6845 312.59512,232.9901 312.73944,232.17858 C 312.9816,230.81698 312.91916,230.68233 311.93063,230.43422 C 309.6936,229.87276 307.83135,232.49865 308.56979,235.17314 C 308.93011,236.47802 310.26212,238.23374 310.8918,238.23374 C 311.07344,238.23374 311.5044,237.20332 311.84955,235.94391 z" />
+ <path
+ id="path2322"
+ d="M 307.4919,236.93949 C 307.94907,235.23357 307.73829,229.69903 307.18857,228.97486 C 306.02159,227.43754 304.89253,228.64103 304.53456,231.80389 C 304.32632,233.64346 304.41385,234.225 305.0159,235.00203 C 305.42062,235.52438 305.75175,236.16056 305.75175,236.41576 C 305.75175,236.92106 306.54264,237.83551 306.97966,237.83551 C 307.12931,237.83551 307.35985,237.4323 307.4919,236.93949 z" />
+ <path
+ id="path2320"
+ d="M 318.22962,237.11247 C 319.2234,236.01432 319.48508,234.11128 318.7286,233.48345 C 318.2248,233.06532 317.9767,233.059 317.50284,233.45225 C 316.99594,233.87296 315.8595,234.11425 313.85855,234.226 C 313.06404,234.27038 312.90454,235.45595 313.53033,236.66604 C 314.05774,237.686 314.35498,237.83551 315.85516,237.83551 C 317.01127,237.83551 317.78981,237.59844 318.22962,237.11247 z" />
+ <path
+ id="path2316"
+ d="M 343.17149,234.2776 C 343.76768,233.16365 343.69955,232.85724 342.55276,231.49436 C 341.29849,230.00374 340.28224,229.92949 339.66534,231.28342 C 338.99345,232.75812 339.09137,233.43311 340.09922,234.2739 C 341.26488,235.24631 342.65216,235.24799 343.17149,234.2776 z" />
+ <path
+ id="path2314"
+ d="M 302.48625,234.17178 C 303.73769,232.92033 302.59242,229.47265 300.92526,229.47265 C 299.26794,229.47265 298.89759,232.21223 300.35754,233.67218 C 301.45993,234.77456 301.80297,234.85508 302.48625,234.17178 z" />
+ <path
+ id="path2312"
+ d="M 296.74515,233.25998 C 298.2415,232.12702 296.63691,228.27795 294.66821,228.27795 C 292.89791,228.27795 292.04406,229.13131 292.33895,230.60588 C 292.92021,233.51204 294.86498,234.6835 296.74515,233.25998 z" />
+ <path
+ id="path2310"
+ d="M 358.94548,232.63375 C 359.33718,232.30865 359.06714,231.50143 357.71423,228.95338 C 356.23189,226.16161 355.67497,225.50246 353.86433,224.39684 C 352.36869,223.48356 351.25842,223.10375 350.08093,223.10259 C 348.1908,223.10072 346.37136,223.6797 346.37136,224.28304 C 346.37136,224.50597 347.17778,225.98421 348.1634,227.568 C 349.14903,229.1518 349.95545,230.575 349.95545,230.73068 C 349.95545,230.88635 350.11537,231.4286 350.31083,231.93567 C 350.64486,232.8022 350.89997,232.8634 354.55498,232.9539 C 356.82378,233.01007 358.65274,232.87671 358.94548,232.63375 z" />
+ <path
+ id="path2308"
+ d="M 337.39737,231.4782 C 338.39244,230.43956 338.46113,230.21708 337.96967,229.62447 C 337.25114,228.75812 335.14577,227.87972 333.78776,227.87972 C 332.79227,227.87972 332.74157,227.96771 332.96032,229.31565 C 333.50203,232.65389 335.38961,233.57387 337.39737,231.4782 z" />
+ <path
+ id="path2306"
+ d="M 315.27832,227.19391 C 316.00888,224.75881 316.02628,224.43277 315.47111,223.58546 C 315.13544,223.07315 314.55852,222.70976 314.18904,222.77791 C 313.27948,222.94569 311.9861,225.68531 312.27434,226.83367 C 312.48513,227.67351 313.9679,229.87088 314.32384,229.87088 C 314.40711,229.87088 314.8366,228.66624 315.27832,227.19391 z" />
+ <path
+ id="path2304"
+ d="M 304.59377,227.63636 C 305.11466,227.00872 305.22772,221.47451 304.7359,220.67873 C 304.61914,220.48983 303.81483,220.12291 302.94852,219.86336 C 301.57892,219.45301 301.27129,219.48385 300.59083,220.09965 C 299.58549,221.00945 298.84741,223.24484 299.19292,224.33341 C 299.34074,224.79911 300.09137,225.87715 300.86103,226.72905 C 302.36304,228.39162 303.69771,228.71604 304.59377,227.63636 z" />
+ <path
+ id="path2302"
+ d="M 310.70894,224.50185 C 310.67672,221.14285 308.67373,219.40733 307.78189,221.96567 C 307.08503,223.9646 307.24882,226.05749 308.19629,227.26202 L 309.04787,228.34466 L 309.88878,227.50301 C 310.54462,226.84656 310.7251,226.18617 310.70894,224.50185 z" />
+ <path
+ id="path2300"
+ d="M 291.68335,226.52772 L 292.79218,225.57396 L 291.99261,223.64055 C 290.99022,221.21674 289.96761,220.94643 288.48156,222.7125 C 287.22606,224.20456 287.20344,224.51141 288.22522,226.18724 C 289.16963,227.73623 290.16453,227.83418 291.68335,226.52772 z" />
+ <path
+ id="path2298"
+ d="M 298.49314,226.74936 C 298.90038,226.49089 298.8895,226.15939 298.43775,225.06297 C 298.12852,224.31239 297.74746,222.74472 297.59091,221.57924 C 297.43441,220.41376 297.08703,219.37602 296.81898,219.27316 C 295.89632,218.91911 294.22928,219.87097 293.97123,220.8992 C 293.13446,224.23307 296.20295,228.20285 298.49314,226.74936 z" />
+ <path
+ id="path2294"
+ d="M 335.23084,223.79785 C 337.06748,222.55344 337.12064,221.99382 335.46786,221.30323 C 333.5491,220.50153 331.23857,220.51543 331.23857,221.32868 C 331.23857,222.19803 332.31797,224.18402 332.92269,224.42734 C 333.74973,224.7601 333.85168,224.7323 335.23084,223.79785 z" />
+ <path
+ id="path2290"
+ d="M 383.90281,220.37318 C 384.44154,218.28344 384.28085,216.81662 382.83636,212.37084 C 381.76373,215.38825 380.78724,217.2674 380.25365,218.79798 C 379.89779,219.81885 379.97425,220.10272 380.83754,220.96604 C 382.20734,222.33584 383.4593,222.0937 383.90281,220.37318 z" />
+ <path
+ id="path2286"
+ d="M 376.08361,220.40678 C 376.84965,219.89997 377.83547,217.60906 378.09158,215.74052 C 378.33059,213.99683 379.10399,212.85299 379.09404,210.89345 C 376.81394,213.36102 375.9602,214.35244 375.01946,215.83322 C 373.67813,217.94454 373.25286,219.22225 373.59478,220.11331 C 373.8342,220.73723 375.31945,220.91236 376.08361,220.40678 z" />
+ <path
+ id="path2284"
+ d="M 287.97322,218.30723 C 287.91695,216.52941 285.96586,211.5248 285.12694,211.00632 C 284.89923,210.86559 284.16016,211.21558 283.48452,211.78408 C 282.49455,212.61708 282.25609,213.12255 282.25609,214.38804 C 282.25609,216.25704 283.05626,218.32586 284.23502,219.50464 C 284.86435,220.13395 285.47611,220.32653 286.55978,220.23645 L 288.03045,220.11421 L 287.97322,218.30723 z" />
+ <path
+ id="path2280"
+ d="M 337.26747,219.14277 C 338.15692,218.41212 338.17472,218.31008 337.59784,217.25117 C 336.71126,215.62376 334.95004,215.53967 333.49789,217.0554 L 332.38714,218.21476 L 333.70445,219.05822 C 335.34361,220.10774 336.07182,220.12502 337.26747,219.14277 z" />
+ <path
+ id="path2278"
+ d="M 293.43278,218.70639 C 294.96573,217.88597 294.11172,213.36546 292.23394,212.3605 C 290.08787,211.21195 288.37599,212.75333 288.8559,215.40206 C 289.33394,218.04022 290.08719,219.11863 291.45181,219.11863 C 292.1177,219.11863 293.0091,218.93312 293.43278,218.70639 z" />
+ <path
+ id="path2276"
+ d="M 307.24333,218.50609 C 308.04962,218.1692 309.00259,217.62816 309.36104,217.30378 C 309.96261,216.75938 309.94839,216.58201 309.1765,214.99834 C 308.03115,212.64846 305.82347,210.75639 304.71161,211.17172 C 303.38323,211.66792 302.1325,213.51929 302.32855,214.69921 C 302.42309,215.26816 302.51516,216.0231 302.53316,216.37686 C 302.58477,217.39057 304.13764,219.11863 304.99698,219.11863 C 305.4262,219.11863 306.43703,218.84299 307.24333,218.50609 z" />
+ <path
+ id="path2274"
+ d="M 300.3497,218.33202 C 301.24074,217.99325 301.3712,217.71099 301.3712,216.12197 C 301.3712,213.03026 299.79584,211.154 297.19993,211.154 C 296.17042,211.154 294.60127,212.82155 294.60127,213.91561 C 294.60127,214.87238 296.58757,217.79441 297.55814,218.26545 C 298.63786,218.78946 299.11654,218.80087 300.3497,218.33202 z" />
+ <path
+ id="path2270"
+ d="M 358.18147,214.88536 C 359.22045,213.5645 358.51397,207.89664 357.50067,206.97963 C 356.02966,208.94548 355.42535,209.62416 354.36518,211.11303 C 353.15516,212.81235 352.63729,214.49849 353.82796,215.11615 C 355.35837,215.91004 357.27617,216.03625 358.18147,214.88536 z" />
+ <path
+ id="path2268"
+ style="fill:#800000"
+ d="M 416.65966,208.43653 C 417.81186,207.05143 419.74285,204.09456 420.95068,201.86571 C 423.3971,197.35135 426.16293,190.60498 425.80484,190.02558 C 425.67701,189.81874 424.97768,189.6495 424.25075,189.6495 C 423.12343,189.6495 422.59681,190.02796 420.66945,192.22326 C 418.21356,195.02054 415.17298,196.81653 411.38265,197.70872 C 409.90987,198.05539 409.29194,198.39398 409.29194,198.8543 C 409.29194,199.89283 410.21699,200.39582 412.7276,200.72242 L 415.06629,201.02665 L 411.90262,202.6058 L 408.73891,204.18495 L 400.75214,204.31808 C 396.31238,204.39209 391.08515,204.24964 388.98213,203.99733 C 382.29268,203.19476 376.58706,202.8235 370.19918,202.77516 C 364.11038,202.72907 357.92007,203.39176 357.92007,204.08967 C 357.92007,204.74116 358.81108,206.175 359.99175,207.42351 C 361.13894,208.63663 361.20485,208.65423 362.38851,208.06372 C 363.2477,207.63512 364.84859,207.45545 367.8315,207.45287 C 371.92882,207.44934 373.5691,207.5073 387.98655,208.16506 C 395.24675,2
08.49629 409.01823,207.85451 410.9972,207.09273 C 411.60654,206.85816 412.21336,206.77449 412.34566,206.9068 C 412.56476,207.12592 412.05001,210.32822 411.41144,212.71838 C 411.16458,213.64238 411.22897,213.62465 412.8589,212.32015 C 413.79709,211.56925 415.50745,209.82162 416.65966,208.43653 z" />
+ <path
+ id="path2262"
+ d="M 303.66649,209.69949 L 304.56793,208.70757 L 302.93012,206.37272 C 302.02932,205.08856 300.95899,203.73623 300.5516,203.36755 C 299.85056,202.73309 299.74359,202.76458 298.5518,203.95635 C 297.4135,205.09467 297.31808,205.37427 297.55738,206.87072 C 297.859,208.75699 298.2908,209.39024 299.97608,210.41773 C 301.37917,211.27321 302.42046,211.07056 303.66649,209.69949 z" />
+ <path
+ id="path2256"
+ d="M 295.36097,209.00287 C 295.85514,208.47683 296.35683,207.32065 296.47582,206.43358 C 296.66339,205.03501 296.53906,204.66766 295.53986,203.66845 C 293.96935,202.09794 291.64145,201.67165 290.25636,202.70093 C 288.92269,203.69203 288.7759,205.12016 289.80114,207.12985 C 291.18548,209.84338 293.75738,210.70981 295.36097,209.00287 z" />
+ <path
+ id="path2250"
+ d="M 337.38857,204.69368 C 338.29347,203.40178 338.1615,202.87271 336.71425,201.99031 C 335.34704,201.15671 332.65101,200.92195 332.23195,201.60001 C 331.79979,202.29928 332.41036,203.35267 333.90337,204.48362 C 335.65443,205.81001 336.5681,205.86508 337.38857,204.69368 z" />
+ <path
+ id="path2246"
+ d="M 298.21271,201.14714 C 298.5426,200.5307 298.28559,200.04903 296.75176,198.40927 C 294.79079,196.31279 294.20045,196.06022 293.43031,196.98817 C 293.06147,197.43263 293.10424,197.84598 293.62612,198.87977 C 295.20483,202.00691 297.21952,203.00288 298.21271,201.14714 z" />
+ <path
+ id="path2240"
+ d="M 324.0704,200.0261 C 324.0704,198.32886 323.04686,197.21384 321.49284,197.21812 C 318.77822,197.22558 315.70754,199.11714 315.70754,200.78188 C 315.70754,201.55076 315.94206,201.59644 319.88897,201.59644 L 324.0704,201.59644 L 324.0704,200.0261 z" />
+ <path
+ id="path2232"
+ d="M 334.80971,197.82886 C 335.07525,197.50891 335.38304,196.56809 335.49371,195.73815 C 335.64747,194.58528 335.4912,193.97071 334.83169,193.13403 C 333.62628,191.60489 332.95578,191.76176 331.96299,193.80523 L 331.10484,195.57157 L 332.18755,196.99108 C 333.35548,198.52235 334.05,198.74424 334.80971,197.82886 z" />
+ <path
+ id="path2230"
+ d="M 382.80568,194.84951 C 383.21757,192.41153 382.70322,190.12689 381.57622,189.38844 C 380.67204,188.796 380.53759,188.82081 379.22442,189.82241 C 378.45839,190.40668 377.83165,191.11579 377.83165,191.39818 C 377.83165,191.68059 378.36604,192.88109 379.01914,194.06598 C 379.67224,195.25086 380.20985,196.59366 380.21383,197.04996 C 380.21781,197.50627 380.30221,199.50032 380.46409,199.66223 C 382.36548,196.73965 382.52262,196.52478 382.80568,194.84951 z" />
+ <path
+ id="path2226"
+ d="M 286.94626,192.61366 C 287.43306,192.2727 287.83133,191.6522 287.83133,191.23479 C 287.83133,189.99136 286.2797,186.22622 285.46249,185.48666 C 284.79784,184.88518 284.56321,184.86637 283.57926,185.33571 C 282.72831,185.74157 282.42391,186.19903 282.3263,187.21843 C 282.13961,189.16915 282.50773,190.25129 283.89605,191.83247 C 285.27381,193.40165 285.67467,193.50432 286.94626,192.61366 z" />
+ <path
+ id="path2224"
+ d="M 280.50622,192.24605 C 281.69745,191.74832 281.87518,191.51625 281.64974,190.75268 C 281.22989,189.33051 279.57966,185.94598 278.88156,185.0752 C 278.29472,184.34322 278.16689,184.32924 277.17119,184.88812 C 274.83672,186.1984 274.54044,189.61436 276.57683,191.7399 C 277.77125,192.9866 278.50702,193.08137 280.50622,192.24605 z" />
+ <path
+ id="path2220"
+ d="M 354.52682,185.70649 C 356.94588,184.34123 357.69049,183.53933 356.26096,183.83881 C 355.74979,183.9459 354.16169,184.14229 352.73188,184.27524 C 350.38406,184.49354 350.60261,180.7234 349.2481,179.80422 C 347.34647,178.51372 346.371,182.22096 346.37287,183.57647 C 346.37487,185.06647 347.73853,187.19443 348.84796,187.4389 C 350.77317,187.86313 352.15006,187.84097 352.26985,187.38383 C 352.3381,187.12334 353.35371,186.36853 354.52682,185.70649 z" />
+ <path
+ id="path2210"
+ d="M 356.83171,182.91485 C 357.72207,182.57633 357.76855,182.41312 357.52192,180.49077 C 357.23599,178.26202 356.74426,177.7181 355.00673,177.70865 C 353.28231,177.69928 352.41727,178.36396 351.89794,180.09735 C 351.48234,181.48445 351.51321,181.78242 352.14472,182.48024 C 352.92924,183.34711 355.15253,183.55326 356.83171,182.91485 z" />
+ <path
+ id="path2206"
+ d="M 337.39307,180.70739 C 336.85546,180.16978 336.41557,179.27376 336.41557,178.71623 C 336.41557,177.83023 336.58498,177.70256 337.76064,177.70256 C 338.5004,177.70256 339.33859,177.98318 339.62321,178.32616 C 340.30438,179.14693 342.15955,180.09195 343.08962,180.09195 C 343.49669,180.09195 344.17762,179.83113 344.60278,179.51235 C 345.32146,178.97348 345.26651,178.9362 343.82077,178.98184 C 342.64547,179.01895 342.08627,178.80934 341.53094,178.12352 C 340.38049,176.70279 340.63058,176.45402 343.07759,176.58493 C 345.13203,176.69483 345.35989,176.62772 345.36742,175.91051 C 345.37817,174.88522 346.8858,174.63854 348.13577,175.45754 C 349.29167,176.21493 353.26144,176.12232 354.90498,175.29964 C 357.20824,174.14674 360.03142,169.03209 360.06316,165.95473 C 360.08219,164.11258 358.23324,159.78214 357.4277,159.78214 C 356.54207,159.78214 353.66561,163.0604 353.16204,164.64365 C 352.85513,165.60862 352.2174,166.41376 351.32146,166.96749 C 350.56741,167.43351 350.0413,
167.96171 350.15225,168.14129 C 350.40461,168.54958 344.22075,170.81101 341.00507,171.48639 C 338.1439,172.08732 337.53512,172.37768 333.53608,175.04885 C 331.84284,176.17985 330.45401,177.38298 330.44979,177.72247 C 330.43804,178.66658 331.27516,179.29548 332.54353,179.29548 C 333.28555,179.29548 334.11017,179.71643 334.88394,180.49018 C 335.65782,181.26406 336.48228,181.68487 337.22458,181.68487 L 338.37053,181.68487 L 337.39307,180.70739 z" />
+ <path
+ id="path2202"
+ d="M 331.60788,171.47626 C 332.06187,170.89916 332.43326,169.99013 332.43326,169.4562 L 332.43326,168.48542 L 333.48515,169.31283 C 334.27289,169.93249 334.66909,170.03063 335.06298,169.70372 C 335.48407,169.35423 335.19507,168.70636 333.61342,166.45414 C 332.52688,164.90696 331.27922,163.38987 330.84089,163.08284 C 330.40252,162.7758 330.04387,162.3223 330.04387,162.07506 C 330.04387,161.82781 329.70521,161.25556 329.29133,160.80338 C 328.87741,160.35121 327.88247,158.90603 327.08031,157.59187 L 325.62183,155.20248 L 328.82843,158.54402 C 330.59208,160.38187 332.03503,162.1189 332.03503,162.40409 C 332.03503,162.68929 333.12618,164.18726 334.45982,165.73293 C 336.42939,168.01566 337.10221,168.54323 338.0439,168.54323 C 338.68151,168.54323 339.20319,168.38584 339.20319,168.19348 C 339.20319,168.00112 338.03837,166.58561 336.61469,165.0479 C 335.19101,163.5102 334.02619,161.98691 334.02619,161.66282 C 334.02619,160.49074 322.77674,149.02989 321.62625,149.02989 C 321.
20544,149.02989 321.11544,150.31462 321.26358,154.2069 C 321.38333,157.3527 321.7861,158.27851 324.1279,160.79079 C 325.09437,161.82764 328.45094,169.66467 328.45094,170.88438 C 328.45094,171.29304 329.99114,172.52555 330.5018,172.52555 C 330.65619,172.52555 331.15394,172.05337 331.60788,171.47626 z" />
+ <path
+ id="path3170"
+ d="M 349.67335,249.42454 C 349.95215,247.00011 345.7706,244.68804 345.43207,247.07947 C 345.0991,249.43174 346.30407,250.79422 348.55137,250.6066 C 349.31681,250.5427 349.57618,250.26945 349.67335,249.42454 z" />
+ <path
+ id="path3172"
+ d="M 339.82982,225.75444 C 340.32404,224.8811 340.3065,224.79252 339.50507,224.11223 C 338.27338,223.0667 336.81448,223.55085 336.10889,225.2393 L 335.56918,226.53076 L 336.90526,226.80352 C 338.56776,227.14289 339.16549,226.92848 339.82982,225.75444 z" />
+ <path
+ id="path5114"
+ d="M 393.07947,191.30261 C 393.49136,188.86463 392.977,186.57998 391.85001,185.84154 C 390.94582,185.2491 390.81138,185.27391 389.49821,186.2755 C 388.73217,186.85978 388.10544,187.56889 388.10544,187.85128 C 388.10544,188.13368 388.63982,189.33419 389.29292,190.51908 C 389.94602,191.70396 390.48364,193.04676 390.48762,193.50306 C 390.4916,193.95937 390.576,195.95342 390.73788,196.11533 C 392.63927,193.19275 392.7964,192.97788 393.07947,191.30261 z" />
+ </g>
+ </g>
+ <path
+ style="font-size:104.55381012px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ d="M 392.83206,713.20935 C 401.07681,713.20935 409.32157,713.20935 417.56633,713.20935 C 417.56633,706.95656 417.56633,700.70379 417.56633,694.451 C 421.36062,702.75151 426.4185,711.04281 433.8487,714.43269 C 441.98054,718.42379 451.85168,716.83355 458.57299,709.69499 C 464.98512,703.05781 469.06548,693.57111 471.77363,683.87768 C 475.79291,668.83455 476.4609,652.70303 475.535,636.98162 C 474.72116,624.10852 472.23633,611.20161 466.95424,599.99913 C 463.09365,591.75549 457.36234,584.16378 449.79306,581.55815 C 441.87177,578.85463 432.86775,581.12029 426.70486,588.0266 C 422.89063,592.01386 420.02253,597.21829 417.56633,602.57996 C 417.56633,579.42548 417.56633,556.27096 417.56633,533.11649 C 409.32157,533.11649 401.07681,533.11649 392.83206,533.11649 C 392.83206,593.14743 392.83206,653.17839 392.83206,713.20935 z M 743.9256,602.57996 C 740.20751,594.36978 735.182,586.43011 728.02783,582.72436 C 719.81169,578.58879 709.71346,580.08353 702.98296,587.51731 C 696.81958,593.
86296 692.87993,602.9411 690.17044,612.1892 C 686.1838,626.39239 685.31055,641.65148 685.89555,656.59318 C 686.39184,666.76589 687.75389,676.97108 690.64285,686.53117 C 693.73735,696.5741 698.51491,706.37685 705.93075,712.24565 C 713.59759,718.1182 723.85891,717.93051 731.53286,712.185 C 736.95801,707.94729 740.83275,701.32408 743.9256,694.451 C 743.9256,700.70379 743.9256,706.95656 743.9256,713.20935 C 752.22159,713.20935 760.51754,713.20935 768.81351,713.20935 C 768.81351,653.17839 768.81351,593.14743 768.81351,533.11649 C 760.51754,533.11649 752.22159,533.11649 743.9256,533.11649 C 743.9256,556.27096 743.9256,579.42548 743.9256,602.57996 z M 113.02238,633.11828 C 105.1873,602.34523 97.352205,571.57213 89.517135,540.79909 C 78.233925,540.88446 66.950731,540.9698 55.667535,541.05516 C 55.701662,598.67464 55.735822,656.29411 55.769948,713.91358 C 64.185411,713.97761 72.600862,714.04164 81.016325,714.10565 C 80.982185,672.1288 80.948035,630.15193 80.913905,588.17509 C 88.8343
35,618.82011 96.754775,649.46515 104.6752,680.11016 C 110.30827,680.06749 115.94133,680.02479 121.57439,679.98212 C 129.49481,648.93163 137.41526,617.88114 145.33569,586.83064 C 145.33569,628.95688 145.33569,671.08311 145.33569,713.20935 C 153.73407,713.20935 162.13246,713.20935 170.53085,713.20935 C 170.53085,655.61122 170.53085,598.01308 170.53085,540.41496 C 159.24765,540.41496 147.96445,540.41496 136.68126,540.41496 C 128.79496,571.31606 120.90867,602.21718 113.02238,633.11828 z M 339.72762,580.55652 C 332.66006,580.9947 326.04964,585.67618 321.64155,592.49847 C 319.48025,595.58095 317.69524,599.03122 316.06876,602.57996 C 316.06876,596.24182 316.06876,589.90368 316.06876,583.56554 C 307.80692,583.56554 299.54511,583.56554 291.28327,583.56554 C 291.28327,643.21235 291.28327,702.85919 291.28327,762.506 C 299.54511,762.506 307.80692,762.506 316.06876,762.506 C 316.06876,739.821 316.06876,717.136 316.06876,694.451 C 319.87266,702.72815 324.89708,710.94872 332.27046,714.4449
6 C 339.84781,718.06267 348.88265,717.10628 355.54023,711.13119 C 362.54753,704.89782 366.94242,695.15345 369.86047,685.24293 C 374.11084,670.60805 374.82806,654.77664 374.197,639.3498 C 373.4643,624.61485 370.607,609.65605 364.03711,597.21282 C 360.45269,590.50369 355.56136,584.44453 349.27696,581.96999 C 346.24189,580.64343 342.92531,580.19097 339.72762,580.55652 z M 528.99858,580.49249 C 519.83368,580.96826 510.61396,585.08081 503.95252,593.13549 C 495.82013,602.72351 491.35757,616.2602 489.66786,629.88657 C 488.03719,642.81008 488.14497,656.07142 489.87439,668.97039 C 491.78793,681.92596 496.10138,694.83984 504.00827,703.86218 C 509.76036,710.45319 517.19508,714.54511 524.90597,715.82442 C 535.83874,717.88779 547.028,715.51037 557.39011,711.01967 C 561.01543,709.42415 564.51078,707.42218 567.96916,705.33468 C 567.96916,694.68575 567.96916,684.03682 567.96916,673.38789 C 560.05238,680.54845 551.13711,686.60234 541.36014,688.39784 C 535.09498,689.55569 528.13283,689.43252
522.76865,684.68088 C 517.34341,680.00477 515.00414,671.72408 514.10318,663.88912 C 513.80122,662.16637 513.35146,659.26988 515.52199,659.77795 C 519.50415,660.07498 523.50356,659.77463 527.49532,659.87933 C 542.19856,659.87933 556.9018,659.87933 571.60504,659.87933 C 571.59097,648.9126 571.90256,637.83983 570.11824,627.03308 C 568.16043,613.90462 563.51214,601.06966 555.63692,591.83593 C 549.01237,583.95384 539.73525,580.06724 530.66055,580.45095 C 530.10658,580.4648 529.55258,580.47863 528.99858,580.49249 z M 640.02118,580.49249 C 632.75718,580.57991 626.03486,585.4637 621.27724,592.0962 C 618.86368,595.25787 616.95388,598.94803 615.03084,602.57996 C 615.03084,596.24182 615.03084,589.90368 615.03084,583.56554 C 606.78608,583.56554 598.54133,583.56554 590.29657,583.56554 C 590.29657,626.78014 590.29657,669.99474 590.29657,713.20935 C 598.54133,713.20935 606.78608,713.20935 615.03084,713.20935 C 615.07159,690.83663 614.93681,668.46088 615.12811,646.09021 C 615.36041,636.3271
3 616.62341,626.01839 621.43205,618.00918 C 624.45685,613.2475 629.73596,610.40613 634.51498,612.25069 C 638.7375,613.94078 641.57482,619.01742 642.18705,624.37755 C 643.19588,631.04301 643.0919,637.88049 643.2037,644.63887 C 643.28516,667.49555 643.23241,690.35252 643.24739,713.20935 C 651.54335,713.20935 659.83933,713.20935 668.13528,713.20935 C 668.0971,685.05016 668.22331,656.88795 668.04447,628.73072 C 667.71468,617.14513 666.26901,605.20188 661.57895,595.02229 C 658.24228,587.82862 652.47515,582.15799 645.78367,580.98582 C 643.89188,580.54902 641.94216,580.37293 640.02118,580.49249 z M 827.39738,580.49249 C 818.18061,581.05365 808.82458,585.08163 802.21786,593.36837 C 795.05862,601.8916 790.75346,613.55212 788.77869,625.53812 C 786.60699,637.99585 786.57957,650.90774 787.65742,663.54195 C 788.88878,676.36948 792.25264,689.23712 798.942,699.27804 C 804.50104,707.62258 812.43726,713.39974 820.99335,715.29575 C 832.15021,718.1135 843.75549,715.99236 854.4703,711.61145 C 8
58.55387,709.83535 862.56996,707.80412 866.41914,705.33468 C 866.41914,694.68575 866.41914,684.03682 866.41914,673.38789 C 859.88596,679.31795 852.70017,684.39068 844.8752,687.06772 C 838.62586,689.07743 831.8413,690.05932 825.60504,687.47264 C 821.92579,685.92722 818.75081,682.83862 816.64336,678.7657 C 813.71769,673.17699 812.64444,666.43933 812.18811,659.87933 C 831.47708,659.87933 850.76608,659.87933 870.05506,659.87933 C 870.0802,647.69151 870.31937,635.33429 867.94261,623.41431 C 865.61452,610.9891 860.7367,598.93387 852.89979,590.54389 C 846.95636,584.20716 839.23859,580.71763 831.45081,580.47959 C 830.10006,580.38452 828.74888,580.47657 827.39738,580.49249 z M 224.71069,580.55652 C 215.16028,581.08506 205.69117,583.37123 196.59657,587.0227 C 196.59657,597.56493 196.59657,608.10717 196.59657,618.64939 C 206.06156,609.87603 218.39787,606.63944 229.98528,608.53397 C 234.69398,609.26799 239.78005,612.01706 241.77541,617.78283 C 243.16824,621.67408 243.25481,626.04347 243
.19739,630.2373 C 233.9678,630.44271 224.64331,629.53337 215.50684,631.59363 C 208.3462,633.34909 201.00106,637.06443 196.4523,644.52118 C 191.72633,652.10583 190.10637,661.90726 189.86942,671.32886 C 189.42362,682.19544 191.03417,693.53846 195.96089,702.69056 C 200.04615,710.25261 206.75806,715.82015 214.14443,716.40241 C 221.50841,717.23951 229.47618,714.92414 234.86352,708.27908 C 238.34393,704.24259 240.95407,699.19455 243.19739,694.00286 C 243.19739,700.40501 243.19739,706.80718 243.19739,713.20935 C 251.51043,713.20935 259.82346,713.20935 268.13649,713.20935 C 268.09695,686.69961 268.22829,660.18755 268.0406,633.67935 C 267.66882,621.84908 266.32867,609.62918 261.57762,599.1885 C 258.26978,592.12067 252.89652,586.67239 246.71139,583.99449 C 239.7234,580.66123 232.10518,580.26702 224.71069,580.55652 z M 936.93483,580.55652 C 930.09007,581.03317 923.65577,585.62089 919.52456,592.39896 C 917.05936,596.18897 915.24796,600.55082 913.48084,604.88473 C 913.48084,597.77834 913
.48084,590.67194 913.48084,583.56554 C 905.23612,583.56554 896.99129,583.56554 888.74658,583.56554 C 888.74658,626.78014 888.74658,669.99474 888.74658,713.20935 C 896.99129,713.20935 905.23612,713.20935 913.48084,713.20935 C 913.52456,691.88558 913.38016,670.55861 913.58457,649.23695 C 913.89173,639.58679 915.21484,629.39011 920.07822,621.56745 C 923.63457,616.00751 929.51925,613.1376 935.1524,614.02861 C 939.09756,614.51866 942.93222,616.19972 946.25507,618.90548 C 946.23791,606.39991 946.22085,593.89437 946.2038,581.38879 C 943.14056,580.74506 940.04485,580.28397 936.93483,580.55652 z M 532.07118,608.0218 C 536.46356,608.21092 540.42655,611.68904 542.62948,616.33894 C 545.3352,621.65812 546.06851,628.08196 546.20504,634.27067 C 535.48516,634.27067 524.76526,634.27067 514.04536,634.27067 C 514.74197,626.25739 516.5905,617.73502 521.64782,612.26076 C 524.47272,609.07637 528.33033,607.8252 532.07118,608.0218 z M 830.57239,608.0218 C 835.02609,608.25222 839.00252,611.84398 841
.17278,616.6007 C 843.83748,621.83252 844.54919,628.18003 844.60383,634.27067 C 833.88393,634.27067 823.16405,634.27067 812.44414,634.27067 C 813.2306,626.22169 815.03944,617.57631 820.20382,612.13811 C 823.06621,609.07792 826.85378,607.8161 830.57239,608.0218 z M 333.48005,610.58268 C 338.3669,610.72431 342.59977,615.0557 344.66484,620.40184 C 347.85967,628.06176 348.52556,636.86739 348.81801,645.36206 C 348.89351,655.91744 348.58268,666.97889 344.69497,676.58898 C 342.70177,681.54234 338.99177,685.79122 334.42454,686.30903 C 329.94997,687.09305 325.1189,685.04974 322.33625,680.48409 C 318.10823,674.0274 316.92538,665.42982 316.37144,657.34282 C 315.75129,646.54245 315.9466,635.4359 318.62232,625.04881 C 320.3127,618.96383 323.64179,612.86432 328.88173,611.13568 C 330.37438,610.67608 331.93996,610.41375 333.48005,610.58268 z M 434.31191,610.51865 C 438.92193,610.51533 443.32851,613.87899 445.47966,618.96782 C 449.43964,627.07414 450.06804,636.86721 450.28506,646.14456 C 450
.44722,655.58844 449.96711,665.31483 447.11545,674.16272 C 445.27875,679.92156 441.54053,685.37024 436.383,686.24501 C 431.37295,687.39896 425.89011,684.71935 423.10004,679.31507 C 419.47826,673.04748 418.53677,665.16433 417.86694,657.66974 C 417.2286,646.46609 417.4068,634.89825 420.38401,624.18795 C 422.16099,618.18661 425.74333,612.15178 431.07298,610.96261 C 432.13848,610.70075 433.22355,610.4908 434.31191,610.51865 z M 728.61391,610.58268 C 733.56343,610.79577 737.86726,615.17723 739.88746,620.67085 C 743.55993,629.79048 743.93151,640.27225 743.9022,650.29179 C 743.78362,660.15961 742.93442,670.53681 738.65101,679.08582 C 736.32787,683.31858 732.49462,686.376 728.32729,686.48327 C 723.68101,686.84743 718.98205,683.89913 716.59452,678.85632 C 713.24883,672.6686 712.27891,665.04874 711.66351,657.7666 C 711.13075,645.89499 711.11825,633.55023 714.71002,622.34388 C 716.55489,616.83969 720.19778,611.79694 725.10601,610.82875 C 726.262,610.60924 727.44573,610.46268 728.61391,
610.58268 z M 232.23851,654.88565 C 235.89175,654.96064 239.54323,654.8617 243.19739,654.88565 C 243.32339,662.72841 242.97814,670.97913 239.76807,677.93613 C 237.37619,683.56515 233.09606,688.56768 227.78328,688.94514 C 223.24527,689.55016 218.13263,687.02259 216.28076,681.50376 C 214.31226,676.28844 214.39797,670.12403 215.6978,664.68095 C 217.03027,660.40874 220.01432,657.0747 223.58408,655.974 C 226.38444,654.90928 229.33626,654.84679 232.23851,654.88565 z"
+ id="text3266" />
+</svg>
Copied: trunk/documents/logos/logo_contest/mapbender_dragon2.svg (from rev 6635, trunk/documents/logos/mapbender_dragon2.svg)
--- trunk/documents/logos/logo_contest/mapbender_dragon2.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_dragon2.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,517 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ version="1.0"
+ width="1000"
+ height="1000"
+ id="svg2"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ sodipodi:docname="mapbender_dragon2.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_dragon2.png"
+ inkscape:export-xdpi="90"
+ inkscape:export-ydpi="90">
+ <metadata
+ id="metadata4098">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <sodipodi:namedview
+ inkscape:window-height="975"
+ inkscape:window-width="1400"
+ inkscape:pageshadow="2"
+ inkscape:pageopacity="0.0"
+ guidetolerance="10.0"
+ gridtolerance="10.0"
+ objecttolerance="10.0"
+ borderopacity="1.0"
+ bordercolor="#666666"
+ pagecolor="#ffffff"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="0.494"
+ inkscape:cx="562.34607"
+ inkscape:cy="461.72824"
+ inkscape:window-x="0"
+ inkscape:window-y="25"
+ inkscape:current-layer="svg2" />
+ <defs
+ id="defs4">
+ <inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 500 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="1000 : 500 : 1"
+ inkscape:persp3d-origin="500 : 333.33333 : 1"
+ id="perspective4100" />
+ id="perspective4267"
+ inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
+ inkscape:vp_z="744.09448 : 526.18109 : 1"
+ inkscape:vp_x="0 : 526.18109 : 1"
+ sodipodi:type="inkscape:persp3d" />
+ id="perspective5038"
+ </defs>
+ <g
+ style="display:inline"
+ id="layer2" />
+ <g
+ id="g5594"
+ transform="matrix(3.7735532,1.1641622,-0.9383907,4.6814487,-1261.4354,-1151.654)">
+ <g
+ id="g4354"
+ transform="matrix(1.4110648,0.164685,-0.1326582,1.3227349,107.36509,-64.958801)">
+ <g
+ transform="matrix(0.9424289,-0.3848325,0.2905881,0.9424289,-92.49501,114.45179)"
+ id="g4691">
+ <path
+ d="M 255.95193,117.56609 C 255.54896,117.56609 254.4178,123.20635 253.94832,127.52188 C 253.49139,131.72208 253.89922,138.94579 254.89412,144.09827 C 255.96529,149.6458 255.29122,164.27908 253.76165,168.61439 C 252.62502,171.8359 249.48405,174.09758 246.12059,174.11496 C 245.18972,174.11978 244.4281,174.30818 244.4281,174.53809 C 244.4281,175.27314 245.67371,177.40765 246.82994,178.64485 C 247.44624,179.30428 249.34385,182.53009 251.03626,185.81301 L 254.11011,191.78649 L 254.29678,195.63191 C 254.52437,200.35779 253.97361,202.5607 252.65407,202.17784 C 250.43763,201.53476 246.7787,199.54064 244.4281,197.69774 C 243.00442,196.58156 240.04755,194.34682 237.85728,192.73229 C 233.13147,189.24869 228.82885,185.69261 225.41255,182.44049 C 224.04538,181.13902 221.35731,178.76462 219.43908,177.16392 C 213.97614,172.6053 205.52805,163.33501 198.1088,153.75538 C 196.64196,151.86145 194.90879,149.74217 194.26338,149.05127 C 193.61801,148.36038 191.06379,143.774 188.58858,13
8.85903 C 186.11341,133.94406 183.9771,129.92561 183.83469,129.92371 C 183.69224,129.92182 183.35693,130.83125 183.08801,131.95221 C 181.96607,136.62906 183.251,144.2933 188.01612,161.25955 C 191.14582,172.40279 191.48912,179.94953 189.09881,185.05389 C 188.68497,185.93765 187.99494,187.46568 187.56811,188.4513 C 186.46589,190.99667 185.08934,192.19866 180.56173,194.52433 L 176.57941,196.56526 L 178.54568,198.30753 C 179.6256,199.26582 182.57279,201.65227 185.09161,203.60898 C 187.61042,205.56569 190.34741,208.07803 191.17709,209.19667 C 192.92871,211.55833 192.80304,211.96752 189.87039,213.29099 C 188.37754,213.96469 186.84833,214.14641 180.71106,214.38612 C 174.86694,214.61438 172.19114,214.91918 167.76854,215.8546 C 160.64382,217.36155 149.02128,218.64918 148.37964,218.00754 C 148.04206,217.66996 148.60538,216.83178 150.60725,214.70969 C 153.717,211.41322 155.54541,208.68699 157.65097,204.19389 C 159.16007,200.97355 161.04697,194.9336 160.6626,194.54922 C 160.54994,194.43
656 159.04868,195.41674 157.32741,196.72705 C 147.0843,204.52445 135.21248,210.68272 121.7728,215.1577 C 114.82554,217.47092 111.78072,217.92043 103.24259,217.92043 C 99.657396,217.92043 96.627273,218.07913 96.509995,218.26888 C 97.890038,222.11499 119.19037,231.79283 121.76036,233.86213 C 134.21051,240.07656 150.65295,244.00722 166.17561,244.47749 C 172.90238,244.68128 173.48728,244.63353 175.67095,243.80548 C 176.98013,243.30902 177.84348,242.77969 177.64966,242.58589 C 177.46022,242.39643 176.11472,242.0697 174.66292,241.8641 C 171.18497,241.37156 164.36072,239.02088 159.40568,236.61242 C 155.29955,234.61657 149.25078,230.8569 149.25078,230.30294 C 149.25078,230.1305 151.80444,229.87234 154.92557,229.73048 C 158.04671,229.58863 163.46764,229.10904 166.97208,228.66023 C 175.03666,227.62742 191.40437,227.15047 194.74872,227.85133 C 196.08535,228.13143 197.03855,228.55109 197.03855,228.84691 C 197.03855,229.85881 195.42708,233.97418 194.17627,236.17685 C 193.47175,237.41751
191.85695,239.53044 190.57974,240.86852 L 188.25257,243.29524 L 191.1522,243.99215 C 195.19198,244.95334 199.57696,247.2089 202.19067,249.67939 C 204.33189,251.70327 204.3741,251.78849 203.60937,252.3799 C 202.56278,253.18927 199.23672,254.16008 197.46168,254.17194 C 196.68007,254.17716 195.32616,254.35919 194.45005,254.58262 C 193.57394,254.80604 190.25866,255.50689 187.08277,256.13821 C 176.83778,258.17473 160.86129,263.09582 151.29171,267.16424 C 146.2196,269.32061 136.80763,273.98908 133.62019,275.92533 C 127.64049,281.12024 120.29419,287.68779 117.05625,294.89111 C 115.66594,298.23259 114.59441,304.62296 114.60464,309.56345 C 115.1144,317.97373 121.66185,332.8172 129.79966,335.5605 C 135.19143,338.20567 144.81468,339.52892 152.0384,338.60946 C 158.78856,337.15301 166.46608,334.86786 172.21131,331.20484 C 177.6055,328.47641 182.95953,326.89508 187.705,323.05354 C 189.11646,323.05354 189.14337,323.07766 188.57614,323.94956 C 183.61381,331.57692 181.69318,335.84573 178.919
02,345.39184 C 178.13737,348.08159 177.35254,350.47091 177.17676,350.70574 C 177.00094,350.94057 176.55373,351.93529 176.18118,352.9209 C 175.04013,355.93992 173.79432,356.91325 170.26993,357.52546 C 168.37618,357.85442 164.48685,356.68797 164.17201,355.69608 C 164.049,355.3084 163.40922,354.24179 162.74087,353.31914 L 161.52128,351.6391 L 158.90789,351.81332 C 156.59787,351.96041 156.19541,352.10174 155.37359,353.13246 C 154.86293,353.77288 154.34053,354.81202 154.20378,355.43474 C 154.06699,356.05746 153.12021,357.6784 152.10062,359.03127 C 151.08103,360.38414 149.92821,362.1997 149.54945,363.07581 C 148.75382,364.91599 145.86236,377.65914 144.1111,387.03192 C 141.80215,399.38945 140.1601,404.91249 136.53226,412.45651 C 133.89612,417.93828 131.47093,420.85471 125.78001,425.39904 C 121.67464,428.67728 121.39733,429.27189 121.08834,435.41705 C 120.8768,439.62398 121.14991,441.39552 122.68127,445.49728 C 123.13816,446.72107 125.21812,449.29293 125.74267,449.29292 C 126.11602,
449.29292 128.02434,445.07262 128.67963,442.80922 C 129.0159,441.6479 129.49581,440.99506 130.24767,440.64383 C 130.84139,440.36648 131.82317,439.90372 132.4255,439.62337 C 133.16282,439.28019 133.95289,438.23577 134.85222,436.42507 C 136.24671,433.6174 139.30435,429.94612 140.98747,429.04534 C 141.84463,428.58662 142.18482,428.62524 143.71287,429.39379 C 146.11444,430.6017 148.24277,432.96451 149.92279,436.30062 C 151.06631,438.57135 151.43822,439.93298 151.86417,443.38168 C 152.82765,451.18285 153.47112,452.12949 158.01187,452.47878 L 160.60037,452.67789 L 161.68307,454.86817 C 162.5305,456.58305 162.7682,457.64187 162.7782,459.7465 C 162.78525,461.22494 162.63854,462.43457 162.45464,462.43456 C 161.47758,462.43456 160.78623,466.18687 161.69551,466.55377 C 163.05989,467.10431 164.3407,466.46792 167.08408,463.86571 C 169.81997,461.27063 170.03189,460.03712 169.83437,448.07334 L 169.7597,443.05811 L 167.5072,440.30783 C 163.27237,435.10776 162.09743,432.56721 163.92312,432.5
672 C 164.92642,432.5672 175.73277,437.95538 176.72875,438.95135 C 177.35122,439.57381 178.26188,439.87512 179.87727,440.0216 C 182.42854,440.25294 184.35673,439.50696 186.84632,437.32109 L 188.24013,436.10151 L 191.21442,436.52463 C 194.7314,437.0138 197.38191,437.95584 198.25814,439.03846 C 199.2632,440.28028 200.40333,439.79481 200.54797,438.05533 C 200.6488,436.84301 200.38171,436.19163 199.0546,434.43391 C 198.16575,433.25659 197.43678,432.11114 197.43679,431.88274 C 197.43679,431.0887 194.20482,428.5676 191.56287,427.29063 C 190.10084,426.58399 188.39759,425.4211 187.76723,424.71457 C 186.24475,423.00822 184.62039,422.62791 178.91902,422.61141 C 174.60829,422.59894 173.86722,422.48592 171.35262,421.4665 C 169.28835,420.62963 168.56501,420.14263 168.565,419.58734 C 168.565,418.50922 172.40957,417.74996 176.52963,418.01931 C 179.59805,418.2199 179.81675,418.17117 182.42844,416.79972 C 184.89289,415.50561 185.32859,415.39997 187.20721,415.65481 C 189.73571,415.99782 193.2
0215,417.2552 193.87759,418.06909 C 194.27746,418.55086 194.43631,418.57024 194.69894,418.1562 C 195.67529,416.61708 194.62394,413.46976 191.77443,409.40755 C 190.19867,407.16115 189.79327,406.86091 185.77607,404.95234 C 182.17749,403.24265 181.43264,402.7302 181.24619,401.8536 C 180.93166,400.37479 179.56583,399.75432 177.35099,400.08645 C 175.29408,400.3949 173.3475,401.81958 172.98288,403.2723 C 172.73116,404.27519 172.35295,404.42163 168.66456,404.92745 C 166.3318,405.24736 161.86898,404.44294 160.69993,403.4963 C 159.89757,402.8466 159.82197,402.4404 159.81636,398.0704 C 159.80556,389.66914 161.53843,385.69343 166.48673,382.75093 L 169.36147,381.046 L 175.13582,380.99622 C 179.13144,380.96214 181.45917,380.75631 182.71467,380.33665 C 183.97594,379.91505 184.82573,379.84408 185.50229,380.1002 C 186.03755,380.30284 188.45666,380.39415 190.86597,380.31176 C 194.47478,380.18836 195.56223,380.00201 197.03855,379.24152 C 199.45833,377.99502 200.52342,376.96127 201.63066,374.7
863 C 202.51462,373.05002 202.66823,372.94397 204.55517,372.72048 C 208.48464,372.25509 211.21493,370.2506 213.1296,366.42344 C 214.22191,364.24004 214.94291,363.32979 216.26567,362.4909 C 219.23034,360.61077 221.72043,356.26216 221.72891,352.94579 C 221.73034,352.38322 222.09022,351.38772 222.52537,350.73063 C 222.96056,350.07355 223.30796,349.25523 223.30939,348.9137 C 223.31086,348.57217 224.29364,347.4552 225.48722,346.42475 C 226.6808,345.39429 228.51764,343.39015 229.56909,341.96954 C 230.62054,340.54893 231.57518,339.39166 231.68469,339.39348 C 231.79421,339.39528 232.25365,340.06731 232.70516,340.88685 C 233.15672,341.70639 235.09767,345.19986 237.02349,348.65236 C 238.94925,352.10486 241.78407,357.66019 243.32052,360.99754 L 246.10814,367.05812 L 245.90903,370.64221 C 245.67702,374.85732 244.82291,377.36045 242.48672,380.62288 C 240.59281,383.26772 240.31935,385.32033 241.5907,387.40526 C 242.21927,388.43606 242.92573,388.82643 245.87169,389.74487 C 247.81156,390.34
964 250.30201,391.30477 251.39715,391.86048 C 252.49229,392.4162 255.74104,393.81264 258.62754,394.97166 C 262.94011,396.70329 265.1765,397.9482 271.17184,401.94071 C 275.1847,404.61301 278.54201,406.85916 278.62623,406.93105 C 278.71046,407.00294 278.55115,407.62242 278.26533,408.31242 C 277.73939,409.58218 275.80352,411.05997 274.66881,411.0627 C 273.98397,411.06435 271.85562,413.16454 271.15939,414.52234 C 270.91408,415.00075 270.71138,415.7656 270.71138,416.21482 C 270.71138,416.66405 269.81536,418.73218 268.72022,420.81937 C 266.92464,424.24157 266.72906,424.8706 266.72907,427.20352 C 266.72907,428.99585 266.97482,430.33465 267.55042,431.55918 C 268.85152,434.32712 269.28517,434.47505 270.25093,432.48009 C 271.306,430.30058 274.23449,427.43163 277.23242,425.63549 C 279.5023,424.27554 279.60487,424.25665 280.77917,424.86391 C 281.59164,425.28406 282.62682,425.42447 283.92769,425.29948 C 286.94318,425.00973 287.95032,423.7328 289.39093,418.35532 C 289.94809,416.2756 291.6
0873,414.24856 292.751,414.24855 C 293.22442,414.24855 294.8642,414.52115 296.39731,414.8459 C 297.93042,415.17064 300.13624,415.43944 301.30054,415.44325 C 303.6061,415.45078 304.22013,415.69807 306.70155,417.58374 C 307.60884,418.27319 309.91616,419.54536 311.82878,420.42114 L 315.31331,422.01407 L 315.31331,423.93056 C 315.31331,427.35075 317.07662,429.38135 320.05475,429.38135 C 320.93114,429.38135 322.27506,429.08726 323.04149,428.72178 C 324.23216,428.154 324.68532,428.12657 326.09045,428.54755 C 328.11553,429.15428 331.05252,431.99682 331.42924,433.71212 C 331.74523,435.15081 332.66585,435.35021 334.25419,434.30946 C 336.44164,432.87619 337.1963,428.70566 335.62311,426.70573 C 335.14352,426.09601 334.82666,425.09216 334.82665,424.17945 C 334.82665,423.34581 334.648,422.54804 334.42842,422.4123 C 333.89873,422.08493 332.59209,419.16859 332.23815,417.50907 C 331.82327,415.56377 330.26862,414.81428 325.51799,414.261 C 321.07548,413.74359 318.49258,412.95593 317.46625,411
.82183 C 316.83366,411.12281 316.8436,411.07114 317.74003,410.73914 C 324.19198,408.34966 329.40759,406.68216 330.4461,406.68216 C 331.15121,406.68216 332.94325,406.98327 334.42842,407.34173 C 336.01553,407.7248 337.59138,407.8798 338.2614,407.71507 C 338.89466,407.55936 340.37976,406.39864 341.59659,405.11412 C 342.80124,403.84249 344.23488,402.69262 344.78244,402.56295 C 345.88773,402.30118 352.54923,398.5888 353.64309,397.62239 C 354.85909,396.5481 354.42326,395.73367 351.63949,393.8143 C 349.41863,392.28304 348.63269,391.95044 347.15938,391.94759 C 343.42632,391.94036 341.23245,391.4914 340.97435,390.67823 C 340.57512,389.42038 338.4172,388.36517 336.23291,388.36351 C 334.36982,388.3621 334.16101,388.47901 332.16348,390.54134 C 331.00263,391.73986 329.19808,393.10082 328.15627,393.56541 C 327.1145,394.03 325.63753,394.8384 324.87086,395.35745 C 324.10415,395.87651 322.3121,396.54889 320.88855,396.85082 C 319.46495,397.15274 317.67284,397.78514 316.90623,398.25707 C 315.9
729,398.83167 314.85453,399.11476 313.53371,399.11576 L 311.56744,399.11576 L 312.98614,397.62239 C 313.7713,396.80104 314.64726,395.68101 314.92752,395.13344 C 315.20776,394.58587 316.6558,393.01162 318.13826,391.63647 L 320.82632,389.13508 L 320.78899,385.26477 C 320.76999,383.06289 320.97387,380.87925 321.24945,380.19976 C 321.51594,379.54268 322.84363,378.00047 324.19885,376.76501 C 325.55407,375.52956 326.52186,374.3772 326.35179,374.2014 C 325.73102,373.55985 319.03893,373.51427 317.20491,374.13918 C 316.02638,374.54074 314.54435,374.66492 312.68747,374.53741 C 309.97304,374.35101 309.91005,374.37135 308.64293,375.69477 C 307.56161,376.82414 307.22343,377.67472 306.52733,381.00867 C 306.07139,383.19224 305.3349,386.05377 304.88462,387.36793 C 304.43438,388.68209 303.97119,390.15598 303.86415,390.64089 C 303.59778,391.8474 300.5428,393.26592 297.77868,393.46585 C 296.14808,393.5838 294.7986,393.36031 292.60167,392.61961 C 290.96549,392.06797 288.6215,391.34426 287.39977
,391.00179 C 286.17807,390.65932 284.50829,389.92601 283.69124,389.37153 C 282.87419,388.81706 281.4608,387.97722 280.54272,387.51726 C 278.14815,386.31762 274.28263,383.32412 272.96388,381.64335 C 272.01875,380.43876 271.86333,379.92962 272.01808,378.51972 C 272.27816,376.14972 273.23498,374.89582 275.61461,373.8405 C 279.64061,372.05504 280.22016,370.56508 280.24405,361.94334 C 280.25368,358.47335 280.07111,353.45563 279.83337,350.79285 C 279.44828,346.48018 279.27429,345.76495 278.24044,344.24692 C 277.60208,343.30965 277.08308,342.49244 277.08308,342.42999 C 277.08308,342.36755 279.18873,342.3979 281.7623,342.49222 C 286.4332,342.66341 286.44476,342.6672 288.23357,344.09759 C 289.21919,344.88571 290.16563,345.75219 290.33673,346.02652 C 290.50785,346.30084 291.47056,346.88794 292.47722,347.33322 C 294.90349,348.40648 299.38865,348.41073 303.55303,347.34566 L 306.67666,346.5492 L 308.77982,347.58211 C 311.39019,348.85924 315.56971,349.36175 315.9231,348.4408 C 316.13002,3
47.90154 316.42034,347.91357 318.44938,348.52791 C 322.29036,349.69087 323.90353,351.16282 322.68059,352.38578 C 321.88676,353.17959 321.90387,356.20787 322.71792,357.82413 C 323.99135,360.35237 327.58008,363.27493 329.40075,363.27492 C 329.72017,363.27492 330.34751,363.87069 330.79456,364.59406 C 331.24165,365.31746 332.81673,367.06471 334.30397,368.47682 C 335.79121,369.88895 337.55449,371.6973 338.21162,372.49647 C 338.86874,373.29565 340.92956,375.09029 342.79128,376.47879 C 347.10305,379.69451 352.56394,384.93135 355.59691,388.76174 C 358.98861,393.04522 359.2228,393.27428 363.6611,396.61437 C 368.66822,400.38253 368.98498,400.79829 367.84253,401.94071 C 367.08601,402.69726 366.72077,402.76132 364.51979,402.52561 C 361.75371,402.22939 361.27411,402.49654 361.04771,404.47944 C 360.93827,405.43792 360.67175,405.7067 359.66634,405.91058 C 357.75889,406.29736 355.31058,408.26607 352.48573,411.67249 C 350.11394,414.53258 349.43262,416.07077 349.68566,417.95708 C 350.07601,42
0.8673 350.54858,420.92784 354.77556,418.67888 C 358.42133,416.73914 358.54773,416.70379 359.85301,417.26018 C 361.56879,417.99155 365.91471,418.00013 367.65586,417.27262 C 368.39621,416.96328 369.42124,416.29127 369.93325,415.77926 C 370.7458,414.96668 371.24632,414.84958 373.85334,414.85835 C 376.34487,414.86672 377.19332,415.05186 378.99301,415.99082 C 381.68303,417.39432 385.15367,420.64254 386.49719,423.00965 C 387.05833,423.99834 388.15042,425.78471 388.92391,426.97952 C 390.25372,429.03373 390.33228,429.34026 390.35505,432.64187 C 390.38341,436.74976 390.63674,437.12561 394.6236,439.08824 C 397.6897,440.5976 398.94193,442.59734 398.94192,445.97018 C 398.94192,448.46934 399.4697,450.03025 400.42284,450.32584 C 400.80945,450.44573 401.45699,450.72218 401.85399,450.93563 C 404.2466,452.22206 408.30131,447.43896 408.77326,442.77188 C 408.89882,441.53016 408.72714,439.78407 408.33769,438.29178 C 407.96133,436.84943 407.70388,434.23364 407.70301,431.92008 C 407.7013,427.442
5 407.09815,425.93171 404.84072,424.76435 C 402.59454,423.60281 398.54393,419.72 398.54369,418.72866 C 398.54345,417.86197 398.65972,417.83264 402.33933,417.83264 C 404.4316,417.83264 407.43328,418.1272 409.00971,418.47976 C 411.82318,419.10899 411.95175,419.18961 415.64275,422.86031 C 419.16814,426.36629 419.50679,426.59373 421.04377,426.59373 C 421.9454,426.59373 423.0329,426.33041 423.45805,426.00883 C 424.36661,425.32163 426.69936,425.23641 428.2866,425.82216 C 428.90319,426.04969 430.43165,427.34891 431.68402,428.70933 C 433.53822,430.72355 434.02598,431.07214 434.34719,430.58849 C 434.93522,429.70301 435.31411,425.99861 435.04409,423.719 C 434.50338,419.15342 430.58297,413.56388 426.14611,411.02537 C 424.32014,409.98067 424.03051,409.63903 424.0305,408.61109 C 424.0305,407.80682 423.6211,407.01944 422.79848,406.19681 L 421.57889,404.97723 L 416.86234,405.21368 C 411.74104,405.47117 409.64364,405.12781 408.2008,403.79498 C 407.03725,402.72013 407.06179,402.6036 408.5990
3,401.95316 C 409.31087,401.65196 410.70539,400.88905 411.71022,400.26067 C 412.715,399.63229 414.03209,399.11576 414.62229,399.11576 C 416.09013,399.11576 418.16179,398.20282 419.1895,397.09971 C 420.08242,396.14129 420.33074,394.5586 419.64996,394.13786 C 419.43093,394.0025 419.25173,393.54934 419.25173,393.12984 C 419.25173,392.09697 421.19172,391.15113 423.32115,391.15113 C 424.89126,391.15113 425.31424,391.39028 427.88837,393.73963 L 430.71333,396.32814 L 431.9578,394.92188 C 433.04672,393.68166 433.18984,393.23353 433.18983,391.10135 C 433.18983,388.13069 432.41889,386.39897 430.25287,384.53053 C 427.86105,382.46733 425.71439,381.43191 423.23404,381.13312 C 415.7999,380.23758 416.0586,380.22637 413.47737,381.63091 C 411.11888,382.91427 409.61697,383.15431 408.71104,382.40248 C 407.81677,381.66028 405.33394,383.86207 404.0816,386.50924 C 403.44391,387.85722 402.92441,389.3347 402.92424,389.79465 C 402.92392,390.62492 401.18063,393.33591 400.09928,394.18764 C 399.78898,3
94.43206 397.95174,395.30574 396.01741,396.12902 C 393.03995,397.39626 392.22604,397.58389 390.69106,397.37349 C 387.87756,396.98786 385.79591,395.63178 385.04115,393.67741 C 384.6884,392.764 384.02249,391.59918 383.56023,391.0889 C 383.098,390.57863 381.79277,388.76672 380.66061,387.06925 C 379.52839,385.37179 378.4373,383.98296 378.23388,383.98296 C 377.65027,383.98296 374.25158,381.83749 374.25157,381.46912 C 374.25157,381.28673 373.2737,379.08908 372.08618,376.59079 C 370.34532,372.92838 369.3191,371.36707 366.77228,368.5266 C 360.41257,361.4335 354.72286,351.18213 356.28137,349.62305 C 356.6403,349.264 359.78161,349.13771 368.3901,349.1377 L 380.02592,349.1377 L 383.162,350.73063 C 384.88905,351.60674 386.39173,352.63717 386.49719,353.02046 C 386.64286,353.54991 387.07607,353.71019 388.32656,353.68003 C 391.18355,353.61113 391.62156,353.29232 393.97647,349.53594 C 397.0724,344.59749 400.28355,340.71902 402.04066,339.80415 C 403.36534,339.11445 405.31363,336.86719 405.31
362,336.02096 C 405.31362,335.84051 406.69304,333.97019 408.38747,331.86441 C 410.10485,329.7301 411.7436,327.23837 412.08356,326.23939 C 412.71627,324.37999 414.87274,320.3381 417.08634,316.86851 C 417.7901,315.76547 419.51182,313.79423 420.90688,312.48796 C 424.16927,309.43313 425.2102,307.99583 426.83057,304.33666 C 427.55798,302.69396 428.57959,300.76707 429.10796,300.04323 C 429.93321,298.91272 430.27225,298.74425 431.50979,298.84853 C 433.17663,298.98898 433.47416,299.61203 433.53828,303.12952 C 433.60578,306.82993 434.45467,308.34792 437.88149,310.90748 C 439.54602,312.15073 441.10658,313.55768 441.34113,314.03111 C 441.70133,314.75807 442.27693,314.95152 445.04966,315.25069 C 450.97574,315.8901 455.50108,314.12924 458.17886,310.14835 C 459.41119,308.31639 460.15922,306.47882 459.8091,306.1287 C 459.72121,306.04083 458.48813,306.17412 457.07126,306.41493 C 454.59097,306.8365 454.43092,306.8094 452.93962,305.7927 C 452.08769,305.2119 451.19166,304.73695 450.94846,304.7
3489 C 450.39496,304.73019 447.16551,299.33347 446.86659,297.91518 C 446.74314,297.32941 446.22342,296.66742 445.68434,296.42181 C 445.15302,296.17972 444.59746,295.67453 444.45231,295.28934 C 444.30716,294.90415 443.68796,293.90116 443.08339,293.06173 C 441.85326,291.35377 441.18882,288.21125 441.90114,287.49894 C 442.16015,287.23992 442.34916,285.68102 442.34915,283.79041 C 442.34915,280.56904 442.37345,280.49246 443.96697,278.4765 C 445.99779,275.90733 446.72875,273.9033 447.10304,269.9892 C 447.45305,266.32875 448.00174,265.55446 450.83646,264.71263 C 454.43723,263.64331 454.69434,263.33107 454.69433,259.90896 C 454.69433,256.08919 455.5866,254.19019 458.16639,252.55412 C 460.37379,251.15421 461.04147,251.11196 463.2812,252.23056 C 465.42751,253.30247 466.24305,253.02486 466.24305,251.23498 C 466.24305,249.46646 463.92793,247.10214 460.56825,245.42329 C 458.48625,244.3829 457.7138,244.20371 455.01789,244.20371 C 451.47865,244.20371 448.95899,245.18937 446.23191,247.63845
C 445.32084,248.45665 444.14303,249.0674 443.1954,249.21893 L 441.65225,249.46783 L 440.40777,255.6902 C 439.72341,259.10837 438.91811,262.14533 438.61573,262.44769 C 438.14821,262.91521 437.90577,262.67302 436.99792,260.81743 C 436.41076,259.61734 435.68117,257.22626 435.3801,255.50353 C 435.07904,253.7808 434.60415,251.54413 434.33474,250.53808 C 433.85149,248.73349 433.86534,248.69068 435.30543,246.80466 C 436.47611,245.27151 436.77392,244.54056 436.77391,243.13346 C 436.77391,241.21099 436.11315,239.63689 434.82009,238.46668 C 433.76904,237.51551 433.76747,236.837 434.83253,233.96169 C 435.44808,232.29987 436.2509,231.14254 437.70727,229.7927 C 438.81813,228.76306 439.63047,227.8207 439.51175,227.70199 C 439.08604,227.27626 435.01648,226.68153 432.51781,226.68152 C 429.39719,226.68152 427.79838,227.31433 425.84744,229.31981 C 423.53287,231.69907 422.53256,233.73751 422.08913,236.98576 C 421.80547,239.06351 421.43524,240.18848 420.81976,240.84363 C 420.31122,241.38492 41
9.87558,242.48659 419.76196,243.49436 C 419.59403,244.98426 419.81653,245.69853 421.46689,248.79581 C 423.39644,252.41706 423.76311,253.82128 424.26695,259.54806 C 424.46567,261.80695 424.39279,262.44411 423.89361,262.85836 C 423.00986,263.59183 422.01919,262.95059 420.19753,260.46897 C 418.89415,258.69345 418.65606,258.04086 418.51749,255.86442 C 418.37173,253.57519 418.23734,253.24788 417.11123,252.40479 C 415.43308,251.14844 414.1643,250.79569 413.44004,251.39676 C 412.26521,252.37179 411.13073,251.28922 410.12974,248.2358 C 409.07769,245.02676 409.17106,243.81126 410.71464,240.32095 C 411.24699,239.11718 411.68534,238.04182 411.68533,237.93156 C 411.68533,237.52561 408.38075,238.27546 406.96877,239.00181 C 403.53889,240.76628 401.6834,244.19488 401.40598,249.2936 C 401.22188,252.67689 401.63923,254.82124 403.31002,259.06272 C 403.99215,260.79439 404.00192,261.09172 403.4718,262.36057 C 402.57937,264.49644 403.08667,266.2394 405.12695,268.03537 C 406.92788,269.62059 409.0
9546,270.48699 411.24976,270.48699 C 412.87236,270.48699 416.13347,273.48355 418.66682,277.29425 C 421.21614,281.12896 421.13664,282.0473 417.95747,284.77354 C 414.82877,287.45648 410.02165,292.07053 408.64881,293.7213 C 402.15254,301.5329 394.80968,308.77889 387.82877,314.24267 C 385.9725,315.69552 383.99019,317.32897 383.43578,317.87653 C 381.61403,319.67571 380.45592,320.26324 378.70678,320.26592 C 377.41934,320.2679 376.75436,320.03091 376.01872,319.29523 C 375.48111,318.75762 375.04804,318.03971 375.04803,317.70231 C 375.04803,317.36491 375.95389,315.96114 377.06408,314.59112 L 379.08013,312.10218 L 378.9059,308.31898 C 378.80642,306.23822 378.50385,303.81897 378.23388,302.94285 C 377.74812,301.36626 377.76666,301.31319 380.01348,297.76584 L 382.27842,294.18176 L 382.07931,289.6021 C 381.96844,287.08328 381.6784,284.03682 381.43218,282.83216 C 381.15019,281.45256 381.07525,278.784 381.23306,275.62666 C 381.4626,271.03563 381.40316,270.4661 380.62327,268.80695 C 380.1549
1,267.81061 379.16232,266.2782 378.40811,265.39709 C 377.04544,263.8051 377.03321,263.7661 377.03919,259.87163 C 377.04484,256.15321 376.97519,255.80885 375.62049,253.16392 C 374.46271,250.9035 373.70198,250.01973 371.62573,248.47225 C 369.15267,246.62902 369.07457,246.49758 369.07456,244.80105 C 369.07456,242.84923 369.6833,241.17645 370.51815,240.85607 C 370.82984,240.73647 372.22205,241.68195 373.74133,243.05879 C 375.20922,244.38902 377.57851,246.32148 379.00546,247.33978 C 381.46183,249.09272 381.75549,249.18797 384.60559,249.31849 C 386.26119,249.39431 388.41908,249.24668 389.39681,248.98248 L 391.17641,248.49714 L 389.48392,247.04111 C 387.94567,245.7138 387.30815,244.60194 388.09011,244.60194 C 388.25813,244.60194 389.33336,243.78762 390.4795,242.78501 C 391.96459,241.4859 392.57022,240.66669 392.57022,239.94761 C 392.57022,239.00631 392.46574,238.96449 391.13907,239.21337 C 390.35691,239.3601 389.50161,239.55907 389.23503,239.66138 C 388.95579,239.76853 388.36787,23
9.03951 387.84122,237.94401 C 387.33837,236.89799 386.37238,235.1797 385.70072,234.12347 L 384.48114,232.20698 L 385.22782,230.7385 C 385.85137,229.51405 386.00302,228.13391 386.12384,222.33831 C 386.20429,218.48104 383.24726,210.96718 383.03755,210.50337 C 382.82325,210.02944 379.9602,215.20236 378.37078,219.92403 C 379.34495,215.03304 380.38484,213.91364 379.95126,209.43312 C 385.83734,209.71281 391.65512,209.78671 397.89656,209.80646 C 406.33238,209.7737 408.64185,209.87203 408.79815,210.27936 C 408.90719,210.56362 408.41053,211.95964 407.69057,213.3781 C 406.01135,216.6864 404.87554,220.02727 405.28874,220.44671 C 405.84088,221.00718 408.7121,219.97164 411.1502,218.34355 C 414.18624,216.31615 418.26053,212.06539 420.52109,208.56199 C 425.41794,200.9729 426.77478,198.04818 427.85104,192.76962 C 428.55603,189.31192 428.84932,180.10227 428.29905,178.75685 C 427.86394,177.69305 427.02317,178.50185 426.27056,180.71067 C 425.53299,182.87532 422.70888,186.62542 420.3842,188.513
52 C 416.38416,191.76239 410.34662,194.59014 404.80339,195.81858 C 401.38127,196.57697 401.22536,196.84922 402.96157,199.30311 C 403.9016,200.63176 403.51066,201.66702 401.70465,202.60096 C 399.83045,203.57014 389.83594,202.14526 386.65897,201.87917 C 384.38799,201.69111 383.47493,201.67274 380.73527,201.30671 C 380.85801,200.86075 384.81341,196.80918 385.06604,194.1261 C 385.3646,190.955 384.98981,188.37663 385.29005,188.37663 C 385.54412,188.37663 386.93018,189.75461 387.51765,190.36779 C 388.34522,191.23162 388.72172,192.25966 389.22258,194.95989 C 390.00519,199.17883 390.51574,199.31543 392.49555,195.81858 C 393.82198,193.47577 393.84315,193.32611 394.00136,187.85395 C 394.12645,183.52758 394.33249,181.87729 394.92227,180.48667 C 395.34026,179.50105 395.80406,177.43367 395.95518,175.89456 C 396.22929,173.10266 396.23099,173.09253 394.79782,171.37712 C 393.00323,169.22918 392.93487,167.86243 394.53648,166.03833 C 396.23586,164.10283 398.87991,163.58766 405.38829,163.94762
C 408.66606,164.1289 410.49064,164.08844 410.49063,163.83561 C 410.49063,163.21382 407.97513,161.17069 405.23896,159.56707 L 402.72512,158.09859 L 397.74723,158.28526 C 392.52382,158.47297 390.62373,158.95819 387.79144,160.84888 C 386.72517,161.56066 385.85097,161.76837 384.00824,161.76979 C 381.15607,161.77198 377.28018,163.20867 375.9565,164.74408 C 375.4519,165.32942 373.84057,166.19859 372.1733,166.79746 C 370.57603,167.37121 368.05859,168.44776 366.58561,169.18685 C 365.11263,169.92593 363.64103,170.53089 363.31265,170.53088 C 362.31567,170.53088 361.62605,168.53059 361.33393,164.8063 C 360.89126,159.16317 359.48836,156.81551 355.92047,155.74654 C 354.66652,155.37084 354.23506,155.39188 353.71776,155.82121 C 353.07613,156.35372 353.08961,157.1888 353.76754,159.91552 C 354.01639,160.91649 353.78552,161.28687 351.68927,163.32538 C 349.59959,165.35755 346.65964,167.14466 344.12287,167.91749 C 343.41509,168.13311 342.41444,167.32336 338.32362,163.2756 C 335.60422,160.58484
331.63567,156.29323 329.51275,153.73049 C 327.38986,151.16775 324.24728,147.82409 322.51881,146.30098 C 318.48914,142.75009 311.77678,137.70391 311.48033,138.00035 C 311.10894,138.37173 313.25762,141.99963 315.0893,144.09827 C 317.7156,147.10733 318.48495,149.26296 318.77294,154.39006 L 319.02184,158.78305 L 320.58987,160.57509 C 321.45328,161.56072 322.78556,163.43718 323.55172,164.74408 C 325.03525,167.27457 325.16405,169.21721 323.92506,170.45621 C 323.42397,170.9573 323.15007,170.90701 321.78457,170.08287 C 318.09253,167.85461 314.91508,165.57912 314.91508,165.15476 C 314.91508,164.90318 314.33267,164.50678 313.62082,164.27118 C 312.90899,164.03557 309.45931,162.84698 305.95487,161.6329 C 302.45043,160.41881 298.14954,159.1367 296.39731,158.78305 C 294.64509,158.4294 291.68823,157.59068 289.82649,156.92879 C 285.81877,155.50394 281.48373,154.20339 280.75428,154.20339 C 280.36314,154.20339 280.3449,154.39606 280.65472,154.97496 C 280.88148,155.39862 281.06333,156.16024 2
81.0654,156.66745 C 281.07129,158.10408 283.85887,162.14214 287.36243,165.80188 C 291.08355,169.6889 293.26653,172.39883 294.74216,174.94876 C 295.58351,176.40268 295.79511,177.29727 295.79996,179.32931 C 295.80331,180.73374 295.93775,182.0883 296.09864,182.34093 C 296.25956,182.59356 297.4477,182.99869 298.73692,183.23695 C 301.42224,183.73321 303.78164,185.4189 305.97976,188.41396 C 307.1946,190.06923 307.32735,190.51222 307.33623,192.96874 C 307.34169,194.46542 307.48309,195.61655 307.64735,195.53235 C 311.83292,193.38726 314.39899,192.92397 317.41647,193.75276 L 318.53649,194.05143 L 316.396,196.42837 C 313.70049,199.407 312.12746,202.45623 312.12746,204.69168 C 312.12746,205.6194 312.23793,206.37172 312.37635,206.37172 C 312.51478,206.37172 313.27206,205.97286 314.05639,205.48814 C 315.18685,204.78949 316.23931,204.58346 319.17118,204.45523 L 322.87971,204.29344 L 322.87971,210.82693 C 322.87971,216.81774 322.80524,217.50711 321.98369,219.11512 C 321.38255,220.29173 320
.58424,221.11901 319.55696,221.6414 L 318.02626,222.42542 L 317.06802,221.26806 C 316.54426,220.63347 315.55646,219.21468 314.8653,218.11954 C 314.17413,217.02441 313.08945,215.38516 312.46346,214.47324 C 311.83744,213.56132 311.331,212.66945 311.33099,212.49452 C 311.33099,212.31959 310.62821,211.44999 309.7754,210.56559 C 307.54284,208.25042 301.77344,200.71389 301.77344,200.11201 C 301.77344,199.83154 300.01695,197.40506 297.87824,194.72344 C 293.82384,189.63973 285.55426,178.65904 283.70368,175.90701 C 283.11454,175.0309 281.90439,173.32846 281.01562,172.12381 C 280.12689,170.91916 278.88154,168.92767 278.25289,167.69348 C 277.6242,166.4593 276.86804,165.20106 276.56041,164.89342 C 275.80492,164.13796 272.88234,158.95758 270.1887,153.58115 C 267.08692,147.39008 263.92283,139.73719 261.3405,132.18866 C 260.12605,128.6386 258.88876,125.19222 258.59021,124.53514 C 258.2917,123.87806 257.6387,122.04122 257.13418,120.45327 C 256.62962,118.86532 256.09405,117.56609 255.95193,1
17.56609 z M 373.76622,193.67809 C 374.45847,193.67567 375.11278,193.84364 375.65782,194.20077 C 377.90365,195.67228 379.18427,198.72434 379.0179,201.18226 C 376.0036,201.17722 376.62922,201.18937 375.1227,201.15737 C 374.09474,201.13554 372.80799,200.97184 372.26041,200.79647 C 371.71284,200.62111 370.59754,200.4574 369.78391,200.43558 C 367.76938,200.38152 367.31139,199.47574 368.25321,197.39906 C 369.25472,195.19074 371.6895,193.68534 373.76622,193.67809 z M 370.10747,208.7611 C 373.32777,209.05034 376.45065,209.256 379.55302,209.40823 C 377.33171,211.28105 373.80603,215.49151 371.86218,216.67596 C 371.09558,217.14307 370.36563,217.52138 370.24436,217.5222 C 369.3585,217.52818 365.66745,215.19372 364.69401,214.01278 C 363.26552,212.27975 363.20523,211.56844 364.39534,210.45359 C 365.72149,209.21132 367.231,208.76111 370.10747,208.7611 z M 360.47525,226.79352 C 360.49159,226.7897 360.51414,226.79225 360.53747,226.79352 C 361.23745,226.83179 364.57437,229.47603 365.57759,23
0.83806 C 366.97311,232.73281 368.25313,235.34359 368.26565,236.33864 C 368.27728,237.26753 368.05005,237.23227 365.50292,235.8284 C 362.28003,234.0521 361.50817,233.19408 361.50816,231.38563 C 361.50816,230.54066 361.22977,229.19208 360.89837,228.39889 C 360.56696,227.60571 360.36246,226.89389 360.43791,226.81841 C 360.44878,226.80755 360.45891,226.79735 360.47525,226.79352 z M 324.31085,230.34027 C 324.37362,230.33322 324.43561,230.33696 324.49752,230.34027 C 325.32304,230.38448 326.03714,231.33555 326.05311,232.90389 C 326.07334,234.88731 327.15124,240.60127 328.03183,243.35747 C 328.79022,245.7313 328.80606,245.97579 328.20605,247.24022 C 324.6141,250.05812 324.0846,251.59762 322.44414,256.15065 C 321.54079,257.91653 321.06538,259.46686 320.95077,261.02899 C 320.74636,263.81662 321.0932,263.91485 323.55172,261.75078 C 325.50983,260.02718 327.93687,259.36293 329.91098,260.02096 C 331.39256,260.51483 331.82295,262.54754 331.26746,266.36778 C 330.67262,270.4586 330.32881,27
1.02565 327.72071,272.07991 C 323.3314,273.85421 320.89544,275.70399 318.84761,278.8374 L 317.69025,280.62944 L 320.49032,281.10234 C 323.14859,281.55025 326.06557,283.06628 326.06556,284.01441 C 326.06556,284.20549 325.59968,284.92101 325.03264,285.59489 C 324.18206,286.60576 323.71175,286.82169 322.34458,286.81448 C 319.97112,286.80195 317.8028,285.6764 314.87774,282.93172 C 311.79595,280.03996 310.07323,277.27062 308.43137,272.60259 C 307.28677,269.34832 307.19759,268.69619 307.17445,263.51793 C 307.15271,258.65104 307.26209,257.61382 308.07047,255.35419 C 309.82361,250.45373 313.26066,248.19026 319.39518,247.8749 C 321.14524,248.00031 322.64723,247.98358 324.37121,248.28772 C 324.04619,244.36369 324.25854,242.77508 323.04149,236.58753 C 322.36923,232.58553 322.37457,232.29081 323.0166,231.31096 C 323.41566,230.7019 323.87144,230.38966 324.31085,230.34027 z M 208.30104,266.72868 C 211.75319,266.70923 213.49474,267.54958 214.87186,269.91453 C 215.72316,271.37641 215.77214,
271.82753 215.61854,276.46046 C 215.43516,281.99101 214.71733,284.68726 212.59447,287.77272 L 211.38733,289.52743 L 208.22637,288.15851 C 204.45544,286.52817 200.54392,285.64169 197.10078,285.63223 L 194.58694,285.61978 L 196.60299,287.94695 C 197.71314,289.22335 198.63148,290.45869 198.63148,290.69723 C 198.63148,290.93577 198.76588,291.19668 198.93015,291.26969 C 199.09442,291.3427 199.65001,291.99654 200.16218,292.72573 C 201.00233,293.92179 201.03664,294.1697 200.57286,295.28934 C 199.24535,298.49423 197.03332,299.81017 191.42598,300.72769 L 188.81259,301.15081 L 183.59824,298.16407 L 178.3839,295.17734 L 175.19805,295.17734 C 169.9222,295.17734 169.74713,295.48435 172.93311,299.37121 C 176.31465,303.49665 176.7175,306.5441 174.25225,309.35189 C 172.76151,311.04974 171.28094,311.85273 168.36589,312.55019 C 164.72585,313.42108 164.02333,313.28967 162.51686,311.52972 C 160.26032,308.89344 154.22608,306.45025 150.8437,306.80072 L 149.63656,306.92517 L 151.4286,309.60078 C 1
53.00711,311.94889 153.23309,312.5483 153.23309,314.42934 C 153.23309,317.27559 152.62547,318.85406 151.3166,319.45701 C 149.29996,320.38606 146.0351,320.37632 144.27288,319.43212 C 140.73834,317.5383 136.93601,313.3803 136.29581,310.69592 C 136.07543,309.77184 136.25636,309.60347 138.27452,308.76699 C 141.01356,307.63172 144.01921,304.97502 145.29335,302.56951 C 145.82379,301.56813 146.56058,300.65663 146.92361,300.54102 C 147.5347,300.34645 148.24387,299.223 147.94408,298.9232 C 147.87204,298.85116 146.65514,299.35543 145.24357,300.04323 C 143.01101,301.1311 142.28887,301.27917 139.73055,301.22548 C 137.67277,301.1823 136.41711,300.94352 135.54912,300.42902 C 134.4336,299.76779 134.31383,299.51673 134.36687,297.90273 C 134.47862,294.50536 137.14361,290.72127 140.62658,289.01719 L 142.71729,287.99673 L 145.94048,288.60652 C 149.6158,289.30371 152.46879,290.235 155.73448,291.77993 C 160.22271,293.90318 161.103,292.17472 157.45186,288.4074 C 154.91528,285.79012 152.69444,282.
58438 152.95931,281.9237 C 153.0642,281.66196 154.99674,280.4915 157.26518,279.33519 L 161.39684,277.23203 L 164.7818,277.6676 C 169.74277,278.2923 173.94021,279.51915 177.799,281.48813 C 179.67674,282.44628 181.60766,283.2304 182.09243,283.23039 C 182.93353,283.23039 182.95723,283.15451 182.54044,281.51302 C 182.03003,279.50276 179.62744,275.78981 178.62035,275.45243 C 177.592,275.10792 177.75202,274.51504 179.30481,273.0506 C 181.54721,270.93573 184.61995,269.96929 189.19837,269.92697 C 192.51568,269.89631 193.1645,270.00192 193.49181,270.58654 C 193.70402,270.96559 194.69949,271.75081 195.70697,272.34125 C 196.71445,272.93169 197.96269,273.81366 198.48214,274.29507 C 199.0016,274.77649 201.05468,275.99487 203.03692,277.00803 C 206.53753,278.79728 208.84815,279.30624 210.05575,278.53873 C 210.79224,278.07066 209.66078,275.21062 207.81569,272.87637 C 206.19852,270.83052 204.67951,267.4879 205.15252,267.0149 C 205.30301,266.86441 206.72245,266.73756 208.30104,266.72868 z"
+ style="fill:#000080;stroke:none;stroke-opacity:1;display:inline"
+ id="path2514" />
+ <path
+ d="M 431.35117,424.37439 C 432.17587,422.22526 430.29459,416.75083 428.07787,414.84941 C 426.08205,413.13742 425.19077,412.68923 423.75041,412.67325 C 422.52585,412.65965 421.23227,413.7767 421.24302,414.83846 C 421.24533,415.06351 422.29272,415.73401 423.57065,416.32847 C 424.84857,416.92294 426.32513,417.77404 426.85191,418.21981 C 427.80241,419.02415 427.80365,419.03503 427.01324,419.65146 C 426.47176,420.07376 425.57933,420.23321 424.22562,420.14952 C 422.42039,420.03791 422.22259,420.11002 422.10731,420.92179 C 421.95685,421.9811 423.24967,422.61492 425.56085,422.61492 C 426.62743,422.61492 427.43015,422.94554 428.4221,423.79343 C 429.96501,425.11224 430.99002,425.31554 431.35117,424.37439 z"
+ style="fill:#ffffff"
+ id="path2480" />
+ <path
+ d="M 425.80321,239.0302 C 426.14286,239.0302 426.55957,238.38265 426.80397,237.47497 C 427.44556,235.0923 428.42664,234.10814 430.09766,234.17096 C 431.26316,234.21477 431.55383,234.06306 431.7422,233.31267 C 431.868,232.81134 432.42349,231.73429 432.97664,230.91922 C 433.52974,230.10415 433.98229,229.37877 433.98229,229.30726 C 433.98229,229.01743 430.33369,229.88402 429.30853,230.41734 C 426.74523,231.75084 424.8459,235.17091 424.83173,238.47871"
+ id="path2533" />
+ <path
+ d="M 424.0265,241.52826 C 422.99687,242.83725 423.00902,243.00665 424.43493,247.2188 C 425.09763,249.17638 425.7168,251.22604 425.8109,251.77361 C 425.905,252.32118 426.71986,257.60109 427.6217,263.50675 C 428.52353,269.41241 429.336,274.36502 429.4272,274.51255 C 429.67884,274.91969 428.49669,275.7699 428.05692,275.4981 C 427.84514,275.36722 427.54994,274.67978 427.40096,273.97045 C 427.2519,273.26112 426.64591,272.14315 426.0543,271.48607 C 425.46264,270.82899 424.50107,269.57456 423.91743,268.69845 C 423.33382,267.82234 421.23797,265.05992 419.25999,262.55975 C 416.36927,258.90586 415.66364,257.75519 415.66364,256.69501 C 415.66364,255.09386 414.22431,253.93816 412.70506,254.31946 C 411.26709,254.68038 407.83987,258.19034 407.52482,259.62485 C 407.37676,260.29887 406.90741,261.16551 406.48174,261.55071 C 405.50786,262.43208 405.46784,264.55128 406.40476,265.62758 C 407.08116,266.40459 413.05045,268.89756 414.23455,268.89756 C 414.55783,268.89756 416.31618,270.7
3441 418.14199,272.97944 C 424.1987,280.42682 424.16939,280.36555 423.01253,283.14713 C 421.84845,285.94598 420.3474,287.63482 417.59498,289.24229 C 415.31152,290.57591 414.28449,291.5834 411.02213,295.68993 C 403.8599,304.70556 393.46068,314.67769 384.66319,320.96633 C 380.92937,323.63533 380.47232,323.85351 378.61469,323.85351 C 377.41315,323.85351 375.99751,323.54348 375.09373,323.08239 C 374.26238,322.65828 373.05992,322.25507 372.42152,322.18637 L 371.26083,322.06147 L 371.27505,325.44644 C 371.29484,330.1629 372.60036,332.02647 375.19388,331.04041 C 376.24215,330.64186 376.24462,330.64552 375.99206,332.22496 L 375.7387,333.8093 L 377.39531,333.8093 C 379.51625,333.8093 381.61704,332.93019 382.22912,331.78653 C 382.52604,331.23169 382.62405,330.07405 382.48674,328.74344 C 382.22343,326.19236 382.72982,325.77251 384.8504,326.78375 C 386.90766,327.76478 388.45045,327.62256 389.63734,326.34246 C 390.46909,325.44536 390.6158,324.97168 390.44854,323.72304 C 390.33624,322.884
69 389.9204,321.84083 389.52448,321.40335 C 388.82033,320.62528 388.82714,320.61358 389.8355,320.86666 C 390.40246,321.00896 391.65132,320.91402 392.61074,320.65567 C 393.57016,320.39732 394.68775,320.1219 395.09423,320.04361 C 396.54506,319.76421 397.00335,319.01163 396.87886,317.11299 C 396.76537,315.38236 396.82861,315.25785 398.14735,314.61606 C 399.5543,313.93132 401.06806,313.59163 402.97718,313.53224 C 404.29668,313.49118 404.71968,312.48016 403.92485,311.26712 C 403.59133,310.75812 403.31846,309.9661 403.31846,309.50707 C 403.31846,308.7133 403.45446,308.68588 406.09912,308.94648 C 409.3144,309.26331 409.78543,308.84641 408.91899,306.45045 C 408.64585,305.69505 408.50742,304.99196 408.61136,304.88802 C 408.7153,304.78408 409.49336,305.16934 410.3404,305.74416 C 411.48719,306.52241 412.18047,306.72928 413.05534,306.5543 C 414.64425,306.23653 414.93902,305.66882 414.67013,303.44415 C 414.42247,301.39507 414.73759,301.10571 415.86276,302.34901 C 416.80473,303.38986 416.
95753,303.36097 417.76806,301.98889 C 418.61139,300.56127 418.63174,299.47263 417.84368,297.94869 C 417.1009,296.5123 417.62808,296.39624 419.55604,297.57172 C 421.26871,298.61594 421.50518,298.58227 422.22423,297.19178 C 422.98549,295.71967 422.99457,294.35009 422.25477,292.57955 C 421.93742,291.81999 421.73357,291.19853 421.80178,291.19853 C 421.87004,291.19853 422.60235,291.73614 423.42916,292.39322 C 424.256,293.0503 425.07106,293.58792 425.24043,293.58792 C 425.4098,293.58792 425.94534,292.7679 426.43051,291.76566 C 427.15644,290.26616 427.23326,289.76909 426.8643,288.9593 C 426.28842,287.69539 426.29738,287.61444 427.01324,287.61444 C 427.34178,287.61444 427.61059,287.94298 427.61059,288.34453 C 427.61059,289.46758 428.00838,289.62629 429.23422,288.99237 C 430.56718,288.30307 432.7876,288.22141 432.7876,288.86169 C 432.7876,289.82055 431.08707,291.99511 429.68123,292.83392 C 427.15282,294.34256 425.63568,296.04627 423.33577,299.95962 C 420.91126,304.08505 418.64771,307
.17959 415.35688,310.86771 C 414.18648,312.1794 412.22885,314.87619 411.0066,316.86057 C 409.05718,320.02563 405.87181,324.98039 402.55987,329.99928 C 401.05739,332.27621 397.05496,336.16562 392.21792,340.04925 C 389.8907,341.9178 387.92769,343.60521 387.85577,343.79905 C 387.78385,343.99289 387.19101,343.87534 386.53834,343.53783 C 382.62687,341.51514 376.27198,340.94911 367.0794,341.80463 C 362.07164,342.27069 360.75532,342.7064 360.26347,344.06074 C 359.56015,345.99733 362.9685,346.36044 374.24757,345.55055 C 377.36727,345.32654 377.91345,345.40663 381.21662,346.57244 C 383.18786,347.26816 385.87593,348.33934 387.19009,348.95284 C 388.50425,349.56634 389.68541,350.0837 389.81487,350.10254 C 389.94434,350.12138 390.53703,349.2424 391.13202,348.14925 C 393.50676,343.78602 398.30043,338.06517 402.99912,333.98683 C 404.98128,332.26639 405.68213,331.21129 408.5398,325.64555 C 412.8258,317.29795 415.09493,313.88713 421.91894,305.53486 C 422.54524,304.76827 423.41008,303.43869 4
23.84077,302.58026 C 424.90118,300.46671 428.74459,296.3812 430.71277,295.27542 L 432.31641,294.37442 L 433.54758,295.41038 C 434.71834,296.39551 434.77875,296.59017 434.77875,299.37807 C 434.77875,304.95405 436.28009,308.56004 438.7095,308.81915 C 439.52926,308.90658 439.81746,308.54309 440.89977,306.05684 C 442.0822,303.3405 442.23241,303.17201 443.83203,302.76734 C 444.87731,302.5029 445.76568,301.96285 446.16969,301.34621 C 446.80483,300.37687 446.78077,300.30754 445.22154,298.61597 C 444.3416,297.66136 443.13727,296.14837 442.54526,295.25376 C 441.95325,294.35916 441.04254,293.34787 440.52149,293.00646 C 438.7621,291.85367 438.24078,290.23517 438.72793,287.43792 C 438.96516,286.07545 439.16233,283.72095 439.16603,282.2057 L 439.17276,279.4507 L 441.55709,276.47289 C 443.98511,273.44054 444.44148,272.49107 445.90853,267.41967 C 446.65103,264.85281 446.88885,264.47697 448.14874,263.8791 C 449.95277,263.02305 451.32607,261.21316 451.95452,258.86355 C 452.42941,257.08791 45
2.39994,256.92532 451.27223,255.10132 C 449.96288,252.98351 447.09223,250.57892 445.87332,250.57892 C 444.87344,250.57892 443.39413,253.74605 441.38653,260.18472 C 440.06249,264.43119 438.12696,268.1011 437.21147,268.1011 C 436.0014,268.1011 434.38052,263.05192 434.38052,259.28247 C 434.38052,257.58378 434.10327,255.87463 433.6332,254.67553 C 433.22219,253.62704 432.6704,251.48188 432.40701,249.90851 C 431.96115,247.24511 431.98373,246.97047 432.73459,245.92619 C 433.17818,245.30929 433.6551,244.16038 433.7944,243.37306 C 434.02833,242.05128 433.9535,241.90252 432.8185,241.43238 C 432.14238,241.15234 431.04139,240.29926 430.37184,239.53666 C 429.70226,238.77405 429.10917,238.21372 429.05382,238.29148 C 428.9985,238.36923 428.71205,239.19447 428.41728,240.12534 C 427.82049,242.01002 427.59354,241.10246 425.90707,241.01681"
+ style="fill:#ff0000"
+ id="path2450" />
+ <path
+ d="M 417.03722,266.70729 C 415.85658,265.4395 415.05443,264.91525 414.29516,264.91525 C 412.6691,264.91525 411.68133,264.2219 411.68133,263.08054 C 411.68133,262.08409 411.71255,262.07409 413.97116,262.34723 C 416.62302,262.66792 417.25657,263.05712 417.25657,264.36551 C 417.25657,264.89273 417.89386,266.01656 418.69673,266.90526 C 419.8395,268.17019 419.98915,268.49933 419.42147,268.49933 C 419.02798,268.49933 417.95507,267.69291 417.03722,266.70729 z"
+ id="path2448" />
+ <path
+ d="M 403.41802,323.13387 C 403.94727,322.67936 404.11493,321.9201 404.11493,319.97796 C 404.11493,317.68231 403.99578,317.30139 402.95086,316.25648 C 401.7828,315.08841 400.42934,314.79087 399.36048,315.46718 C 398.64092,315.92249 399.19183,318.62169 400.70077,322.03364 C 401.73303,324.36773 401.90172,324.43605 403.41802,323.13387 z"
+ id="path2420" />
+ <path
+ d="M 372.66085,313.96351 C 375.46576,312.48652 376.27731,308.31767 374.4955,304.53928 C 373.17445,301.73792 371.99608,300.81569 368.61633,299.93794 C 364.59587,298.8938 364.0313,298.93634 363.30643,300.33808 C 362.40727,302.07687 362.54247,303.65618 363.68217,304.72687 C 364.87455,305.84706 364.66329,306.32841 362.97403,306.34018 L 361.70327,306.34903 L 362.69885,307.14259 C 363.24642,307.57905 365.18959,308.65658 367.017,309.53712 C 369.81421,310.88494 370.26302,311.23032 369.85543,311.72144 C 369.11715,312.611 367.93532,312.42598 365.86348,311.09649 C 363.89944,309.83617 359.47756,308.8915 360.07618,309.86012 C 360.67627,310.83111 368.71641,314.62056 370.27146,314.66534 C 370.82246,314.6812 371.89768,314.36538 372.66085,313.96351 z"
+ id="path2416" />
+ <path
+ d="M 452.63816,310.6646 C 453.567,309.98152 454.2633,309.2199 454.18553,308.97212 C 454.10775,308.72433 452.97606,308.16319 451.6707,307.72513 C 450.36533,307.28708 448.85803,306.61506 448.32113,306.23177 C 447.40532,305.57797 445.13277,305.2503 445.13277,305.77206 C 445.13277,305.90252 445.51073,306.54005 445.97268,307.1888 C 447.00944,308.64478 446.7077,309.01821 444.99494,308.39886 C 443.0188,307.68428 442.34427,307.79181 442.35124,308.82027 C 442.36498,310.83752 444.30967,311.86887 448.14061,311.89062 C 450.67145,311.90499 451.11644,311.78369 452.63816,310.6646 z"
+ id="path2412" />
+ <path
+ d="M 355.77755,305.33575 C 359.73936,297.07954 361.46437,288.9081 361.7885,276.86219 C 362.01346,268.50263 361.58532,264.71785 359.86874,259.89079 C 359.41054,258.60224 358.9006,256.56234 358.73561,255.35769 C 358.52152,253.79456 357.16455,250.51247 353.99642,243.89503 C 351.55486,238.79521 349.55721,234.52157 349.55721,234.39804 C 349.55721,234.27451 348.59087,232.61124 347.40979,230.70187 C 343.62006,224.57534 342.24186,221.30863 340.93948,215.36567 C 340.58406,213.74395 339.85785,213.09723 339.48455,214.07003 C 339.09727,215.07924 340.67442,222.97 341.69927,225.15074 C 347.40844,237.299 348.96249,240.6565 350.70408,244.60544 C 356.77377,258.36801 359.23105,275.00008 357.08793,287.81356 C 356.52447,291.1822 354.13739,298.29557 352.0904,302.70585 C 350.18339,306.81455 350.07416,307.42329 350.94266,309.10274 C 352.25217,311.63507 353.05492,311.00961 355.77755,305.33575 z"
+ id="path2410" />
+ <path
+ d="M 348.96194,299.72242 L 350.05409,298.29052 L 349.2685,297.23347 C 347.98026,295.50012 345.38534,295.69211 344.36635,297.59617 C 344.00272,298.27556 344.14959,298.61396 345.31294,299.77732 C 346.0703,300.53467 346.95541,301.15431 347.27985,301.15431 C 347.60433,301.15431 348.36124,300.50996 348.96194,299.72242 z"
+ id="path2406" />
+ <path
+ d="M 375.60824,296.71641 C 376.1582,296.46584 377.10289,295.54693 377.70756,294.67438 C 378.5816,293.41309 378.83834,292.53237 378.96012,290.37726 C 379.1036,287.83789 379.03144,287.55261 377.81815,285.86316 C 376.28416,283.7271 374.36923,282.32747 371.19516,281.02238 C 368.31905,279.83982 366.92512,279.80411 365.84393,280.8853 C 365.10234,281.62686 365.04217,281.97959 365.31715,283.97159 C 365.70327,286.76878 365.71876,287.55242 365.41272,288.80914 C 365.18752,289.73411 365.42375,289.9273 368.74369,291.53324 C 370.70904,292.48393 372.25864,293.30636 372.1872,293.36087 C 372.11575,293.41538 370.48838,293.28057 368.57082,293.06129 C 366.65325,292.84202 364.96686,292.7801 364.82326,292.92371 C 364.33662,293.41035 366.07323,294.88979 368.47321,296.03311 C 371.0463,297.25888 373.83209,297.52567 375.60824,296.71641 z"
+ id="path2402" />
+ <path
+ d="M 343.41664,293.56814 C 345.03856,292.56574 345.55025,291.26191 344.59569,290.56391 C 343.43448,289.7148 340.22757,289.12555 338.79206,289.49753 C 337.11053,289.93325 335.66507,291.7457 336.25421,292.67969 C 337.28714,294.31723 341.3826,294.82525 343.41664,293.56814 z"
+ id="path2400" />
+ <path
+ d="M 352.17375,292.33899 C 352.94871,290.84043 352.46482,289.57134 350.8355,288.82896 C 349.97723,288.4379 349.64662,288.4855 348.78855,289.1236 C 347.42715,290.136 347.28212,291.44231 348.39916,292.63131 C 349.72232,294.03979 351.35985,293.91298 352.17375,292.33899 z"
+ id="path2398" />
+ <path
+ d="M 319.60172,290.78199 C 321.38106,290.4004 324.46863,288.4071 324.46863,287.63997 C 324.46863,287.46688 322.63511,287.83747 321.26619,287.7236 C 319.89727,287.60972 318.50511,286.57155 317.30046,286.15647 C 314.63156,285.23686 313.50436,285.3671 312.63391,286.69563 C 312.00733,287.65188 312.01358,287.792 312.74326,289.14079 C 313.81474,291.12142 315.80184,291.59693 319.60172,290.78199 z"
+ id="path2396" />
+ <path
+ d="M 312.22584,290.16694 C 312.35514,290.03763 312.22054,289.25038 311.92669,288.41751 C 311.63283,287.58464 311.34814,286.0328 311.29406,284.96899 C 311.12142,281.57463 310.11059,280.72955 308.56828,282.69026 C 307.21226,284.41416 307.61113,287.56246 309.43181,289.50604 C 310.21863,290.346 311.69707,290.69571 312.22584,290.16694 z"
+ id="path2394" />
+ <path
+ d="M 307.34468,288.78296 C 307.34468,288.3305 307.15472,287.60535 306.92251,287.1715 C 306.69034,286.73765 306.37243,285.62941 306.21613,284.70873 C 305.95839,283.19094 305.79428,283.00057 304.45702,282.66808 C 301.55391,281.94625 299.88739,283.56431 300.79544,286.22319 C 301.60019,288.57954 302.98962,289.6056 305.37574,289.6056 C 307.10008,289.6056 307.34468,289.50341 307.34468,288.78296 z"
+ id="path2392" />
+ <path
+ d="M 344.42007,287.60999 C 346.37518,287.0669 347.36626,285.94167 346.8081,284.89874 C 345.83697,283.08423 340.51632,281.68185 339.28284,282.91531 C 338.70951,283.48867 338.66252,285.1968 339.18253,286.56449 C 339.53488,287.49127 340.08532,287.72923 342.38905,287.95079 C 342.71759,287.98238 343.63157,287.82902 344.42007,287.60999 z"
+ id="path2390" />
+ <path
+ d="M 353.38772,284.6114 C 354.2172,283.34549 353.66772,281.86375 352.10478,281.15163 C 351.16061,280.72144 350.96237,280.78352 350.10777,281.77705 C 348.92403,283.15325 348.91128,283.89516 350.055,284.8493 C 351.31935,285.90403 352.6007,285.81256 353.38772,284.6114 z"
+ id="path2386" />
+ <path
+ d="M 303.15002,281.65194 C 304.08165,280.87876 303.96927,277.79836 302.99033,277.27443 C 301.14616,276.28748 298.62783,277.14324 298.55312,278.78224 C 298.53635,279.14989 298.4526,279.80911 298.36698,280.24716 C 298.01284,282.05927 298.52958,282.54396 300.60317,282.34471 C 301.66812,282.24238 302.81423,281.93063 303.15002,281.65194 z"
+ id="path2384" />
+ <path
+ d="M 347.84498,279.98182 C 348.84374,279.15292 348.44515,277.51949 347.00475,276.53875 C 345.26065,275.35119 341.597,274.9016 340.86374,275.78514 C 340.11745,276.68437 341.21371,279.02734 342.86286,280.05782 C 344.25098,280.92515 346.75434,280.88697 347.84498,279.98182 z"
+ id="path2382" />
+ <path
+ d="M 378.57124,279.03433 C 379.63054,277.68762 379.35915,275.99462 377.42036,271.85491 C 375.07824,266.85408 371.95176,264.44201 366.58814,263.49786 C 365.23204,263.25915 365.06526,263.33089 364.69164,264.31362 C 364.40922,265.05643 364.41248,265.87566 364.70208,266.95114 C 365.05073,268.24603 365.42451,268.65331 366.90111,269.3474 C 368.15777,269.93809 368.75352,270.49174 368.93022,271.23307 C 369.28771,272.73279 369.84245,273.30837 371.74213,274.15063 C 374.43577,275.3449 374.20101,275.6675 370.63823,275.6675 C 367.80382,275.6675 367.44386,275.7443 367.87029,276.2581 C 368.13985,276.58293 369.37142,277.15758 370.60709,277.53509 C 371.84277,277.91261 373.47778,278.63246 374.24044,279.13477 C 376.08218,280.34773 377.56515,280.31334 378.57124,279.03433 z"
+ id="path2380" />
+ <path
+ d="M 297.05159,277.61235 C 297.63758,275.65645 297.04764,274.38712 294.88855,272.95831 C 293.42314,271.98854 293.3687,271.98229 292.81046,272.71984 C 291.98771,273.80685 292.08237,275.5277 293.06059,277.26821 C 293.92607,278.80818 295.20347,279.68764 296.09101,279.3546 C 296.36281,279.25261 296.79505,278.4686 297.05159,277.61235 z"
+ id="path2378" />
+ <path
+ d="M 354.28215,278.24348 C 354.39401,278.13163 354.56239,276.97733 354.65633,275.67837 C 354.81865,273.4344 354.77795,273.30426 353.84023,273.0689 C 353.2974,272.93266 352.24607,272.8792 351.50393,272.95009 L 350.15456,273.07899 L 350.2053,275.43802 C 350.26423,278.17952 350.99284,279.05041 352.91315,278.67482 C 353.55426,278.54942 354.17033,278.35531 354.28215,278.24348 z"
+ id="path2374" />
+ <path
+ d="M 305.65147,275.23782 C 305.92876,274.69999 306.04182,273.74544 305.90718,273.07899 C 305.67131,271.91174 304.3307,270.09226 303.70651,270.09226 C 303.16627,270.09226 302.48952,273.34349 302.74562,274.70864 C 303.10733,276.63657 304.77385,276.94006 305.65147,275.23782 z"
+ id="path2372" />
+ <path
+ d="M 301.45292,270.88205 C 301.86947,268.07532 301.85171,267.93611 300.98715,267.23604 C 300.49278,266.83571 299.57466,266.50817 298.94689,266.50817 C 295.78139,266.50817 295.73471,272.5593 298.88727,274.23591 C 300.43484,275.05894 300.92881,274.4132 301.45292,270.88205 z"
+ id="path2370" />
+ <path
+ d="M 347.53237,272.06204 C 348.45567,271.3932 349.14329,270.64249 349.06038,270.39379 C 348.46901,268.6196 343.98615,267.48491 342.19774,268.65672 C 340.851,269.53913 340.93367,270.30943 342.54834,271.92412 C 344.23425,273.61003 345.35273,273.64098 347.53237,272.06204 z"
+ id="path2368" />
+ <path
+ d="M 293.89592,268.91136 C 294.57538,268.37692 294.96318,267.58999 295.11877,266.43011 C 295.37794,264.49775 295.05915,264.13405 293.09806,264.12488 C 291.41673,264.11702 290.9281,265.23957 291.48216,267.83725 C 291.91826,269.88202 292.39323,270.09338 293.89592,268.91136 z"
+ id="path2366" />
+ <path
+ d="M 353.53953,268.49933 C 354.50663,267.53226 354.53586,266.85875 353.68309,265.19415 C 352.51611,262.91626 351.49397,262.73918 350.34934,264.61658 C 349.19327,266.51264 349.3307,267.57646 350.85147,268.5037 C 352.45455,269.48112 352.55793,269.48095 353.53953,268.49933 z"
+ id="path2364" />
+ <path
+ d="M 303.83427,264.29195 C 304.56773,261.58113 303.10956,259.10917 300.53006,258.69058 C 299.44297,258.51417 298.957,258.67432 298.06182,259.50398 C 297.09475,260.40021 296.96318,260.7874 297.06843,262.42747 L 297.18977,264.3179 L 298.71874,264.18477 C 300.33126,264.04436 302.5659,264.74731 302.5659,265.39498 C 302.5659,266.23359 303.53758,265.38859 303.83427,264.29195 z"
+ id="path2362" />
+ <path
+ d="M 346.52472,264.88009 C 347.10622,264.42269 347.86975,263.492 348.22143,262.81188 C 348.84661,261.60296 348.83586,261.55377 347.7418,260.61271 C 346.78867,259.79283 346.35699,259.68653 344.83044,259.89577 C 341.63432,260.33385 340.47335,261.67606 340.97544,264.35252 C 341.22768,265.697 341.25337,265.71171 343.34898,265.71171 C 344.89436,265.71171 345.75351,265.48673 346.52472,264.88009 z"
+ id="path2360" />
+ <path
+ d="M 295.83877,260.85297 C 296.09675,260.37093 296.82256,258.18793 297.45173,256.00186 C 298.70672,251.6412 298.64563,251.39265 296.31597,251.38148 C 294.39439,251.37226 293.09914,252.76064 292.89799,255.04512 C 292.78832,256.29083 292.45803,257.16206 291.91667,257.63363 C 291.45078,258.03946 290.99528,259.0706 290.8551,260.03691 L 290.60955,261.7294 L 292.98963,261.7294 C 295.03454,261.7294 295.43576,261.60597 295.83877,260.85297 z"
+ id="path2358" />
+ <path
+ d="M 374.08393,260.33734 C 375.0097,258.92442 374.55134,257.07298 372.53939,254.09884 C 369.95539,250.27899 366.03675,248.04959 361.30504,247.70738 C 359.71474,247.59237 359.7122,247.59454 359.7519,249.02177 C 359.77376,249.80804 360.19035,251.24965 360.67763,252.22535 C 361.1649,253.20105 361.77424,255.06659 362.0317,256.37101 L 362.49974,258.74266 L 365.00159,259.01861 C 366.51801,259.18587 368.16498,259.67996 369.18302,260.27303 C 371.46568,261.60283 373.23948,261.62611 374.08393,260.33734 z"
+ id="path2356" />
+ <path
+ d="M 352.19418,259.52108 C 353.0918,258.15111 352.40075,255.81063 350.66816,254.35273 C 349.47574,253.34938 349.37454,253.32945 348.88329,254.00127 C 347.92442,255.31259 348.24094,257.58086 349.59847,259.12703 C 351.07185,260.80511 351.32743,260.84391 352.19418,259.52108 z"
+ id="path2354" />
+ <path
+ d="M 304.03844,256.75457 C 304.68377,255.4013 304.67656,255.3371 303.76991,254.37202 C 301.96628,252.45214 300.47319,252.70215 299.96656,255.00888 C 299.74976,255.99585 299.89771,256.36338 300.83698,257.17115 C 302.40127,258.51649 303.25098,258.40592 304.03844,256.75457 z"
+ id="path2352" />
+ <path
+ d="M 343.84813,257.06902 C 344.81611,256.43627 345.97313,254.25127 345.97313,253.05599 C 345.97313,251.44707 342.97636,251.03627 340.94566,252.36682 C 339.83097,253.09719 339.77848,253.77016 340.63906,256.29583 C 341.32521,258.30957 341.7819,258.41961 343.84813,257.06902 z"
+ id="path2350" />
+ <path
+ d="M 406.50432,253.56228 C 406.50432,251.47756 406.54338,251.39302 407.29086,251.85982 C 408.41961,252.56475 409.205,251.74823 408.61092,250.48741 C 407.87897,248.93396 407.30078,246.37209 407.30078,244.6823 C 407.30078,242.34402 406.6196,242.26109 405.61088,244.47656 C 404.58858,246.72182 404.40639,251.31642 405.23069,254.06344 C 405.93321,256.40466 406.50432,256.17993 406.50432,253.56228 z"
+ id="path2348" />
+ <path
+ d="M 454.14981,253.52653 C 454.78849,252.68922 456.09174,251.71815 457.28519,251.19035 C 459.06775,250.402 461.06202,248.61852 461.06202,247.81268 C 461.06202,247.66449 460.69664,247.15105 460.25006,246.67169 C 459.53058,245.89944 459.02849,245.80014 455.84333,245.80014 C 452.05754,245.80014 451.19015,246.05851 449.41376,247.71534 C 448.13822,248.90503 448.05659,249.42891 449.01553,250.27097 C 450.12986,251.2495 451.50448,251.54436 451.50448,250.80487 C 451.50448,250.46156 451.77328,250.18068 452.10182,250.18068 C 452.85098,250.18068 452.84747,250.3317 452.06307,251.84858 C 451.57182,252.79853 451.52451,253.29288 451.8554,254.01908 C 452.43821,255.2982 452.86906,255.20571 454.14981,253.52653 z"
+ id="path2346" />
+ <path
+ d="M 341.30669,249.24007 C 342.95203,248.54367 343.91025,247.45299 344.2149,245.92985 C 344.42747,244.86691 344.29351,244.61842 343.1245,243.90738 C 341.29487,242.79453 338.81193,242.42789 337.85403,243.12913 C 337.23091,243.58527 337.14764,243.98259 337.36767,245.4497 C 337.65029,247.33438 338.91631,249.78245 339.60836,249.78245 C 339.83766,249.78245 340.6019,249.53838 341.30669,249.24007 z"
+ id="path2344" />
+ <path
+ d="M 366.42033,173.52113 C 366.6869,171.57605 366.42228,171.35849 364.95734,172.31836 C 364.31081,172.74197 363.32001,172.85896 361.4328,172.7345 C 359.20365,172.5875 358.70188,172.67814 358.10728,173.3352 C 357.43507,174.07794 356.11664,174.58297 357.16725,176.09902 C 358.05463,177.37949 358.85046,177.91749 358.73409,179.38074 C 358.63047,180.68337 358.95517,182.27316 359.36846,182.43175 C 360.03064,182.68585 361.67042,180.12423 363.91175,176.70698"
+ id="path2537" />
+ <path
+ d="M 363.41933,179.94981 C 362.99072,180.4192 362.33965,181.40039 361.97252,182.13021 C 361.03297,183.99807 355.45363,188.19022 352.54395,189.2146 C 349.02382,190.45389 346.19037,190.33915 343.86282,188.86307 C 342.83538,188.2115 341.22143,186.96554 340.27623,186.09427 C 338.34656,184.31559 336.67849,183.53891 335.55432,183.89571 C 334.38925,184.26548 331.57937,182.38591 330.3296,180.40081 C 329.72015,179.4328 327.94527,177.48886 326.3854,176.08095 C 324.82552,174.67305 322.82895,172.75737 321.94854,171.82388 C 320.95065,170.7658 319.73652,169.9522 318.72458,169.66344 C 317.83182,169.40868 316.89634,169.04623 316.64577,168.85799 C 316.39516,168.66975 315.05113,167.96774 313.65903,167.29797 C 312.2669,166.6282 310.76947,165.76053 310.33141,165.36981 C 309.26797,164.42129 289.37305,158.98568 286.96478,158.98568 C 285.89533,158.98568 286.06454,160.27882 287.28141,161.40521 C 288.47045,162.50583 294.00249,169.22422 296.4898,172.58834 C 297.90755,174.50587 298.19539,17
5.22939 298.42258,177.44666 C 298.68027,179.96218 298.73224,180.06113 299.9308,180.31944 C 303.57462,181.10476 305.16758,182.05229 307.2622,184.68034 C 308.4027,186.11131 309.33583,187.51471 309.33583,187.79903 C 309.33583,188.08335 309.77317,188.72681 310.30764,189.22894 C 311.07774,189.9524 311.98053,190.21297 314.65696,190.48425 C 316.51459,190.67254 318.81012,191.12005 319.75819,191.47872 C 321.92923,192.30009 324.46863,192.64931 324.46863,192.12652 C 324.46863,191.64296 323.13145,190.7342 319.49074,188.74361 C 317.95754,187.90532 317.06152,187.30481 317.49958,187.40916 C 317.93763,187.51351 318.92326,187.72121 319.68985,187.87072 C 320.45645,188.02024 321.44207,188.46103 321.88013,188.85026 C 322.31818,189.23949 323.05614,189.67272 323.52,189.81299 C 324.43319,190.08911 326.98306,189.27669 326.16111,188.9715 C 325.88733,188.86984 325.66332,188.54661 325.66332,188.2532 C 325.66332,186.89494 318.11393,183.50527 312.37514,182.28683 C 311.74697,182.15346 311.30971,181.96763
311.40349,181.87388 C 311.78404,181.49334 320.3858,183.61699 321.68101,184.41125 C 323.1608,185.3187 324.66141,185.52534 325.06219,184.87686 C 325.35227,184.40748 323.15809,183.00487 321.59754,182.66212 C 320.98637,182.52788 320.48631,182.2561 320.48631,182.05817 C 320.48631,181.0915 313.41647,178.39494 309.34635,177.80919 C 308.17216,177.64021 307.13688,177.27828 307.04576,177.00491 C 306.80631,176.28654 307.2757,176.35753 312.97487,177.90167 C 317.96288,179.25312 319.68985,179.55058 319.68985,179.05825 C 319.68985,178.21992 318.05973,176.31075 316.78535,175.65657 C 315.0759,174.77904 310.1262,173.38201 307.14556,172.93578 L 305.1544,172.63769 L 306.94644,172.55363 C 307.93207,172.5074 309.09689,172.3227 309.53495,172.14319 C 310.42786,171.77727 310.40242,171.76294 305.55263,169.90053 C 304.23847,169.39587 303.47685,168.97362 303.86015,168.96221 C 304.99037,168.92856 304.75836,167.34854 303.6232,167.34854 C 303.10956,167.34854 302.34799,166.96774 301.93072,166.50232 L 301.
17209,165.6561 L 302.5659,165.93301 C 305.22107,166.46052 307.90511,167.46894 309.71144,168.61769 C 310.70949,169.25241 312.2937,169.96611 313.23185,170.20367 C 314.5034,170.52567 315.41575,171.1684 316.81593,172.72866 C 317.84903,173.87983 319.8591,175.56921 321.28278,176.48283 C 323.72848,178.05233 326.50905,181.05435 329.65771,185.52472 L 330.81955,187.17429 L 329.43963,188.90969 C 327.36807,191.51489 326.65639,193.96678 326.67336,198.44043 C 326.68746,202.15431 326.72425,202.30447 328.08828,204.21479 C 328.85853,205.29351 329.68741,206.64261 329.93026,207.21279 C 330.66866,208.94659 333.56555,210.35753 336.38694,210.35753 C 339.2112,210.35753 339.50713,209.91474 337.11248,209.27195 C 335.16887,208.75022 332.30328,206.45616 331.39061,204.69128 C 329.53545,201.10379 329.28735,196.7682 330.72955,193.1391 C 331.28699,191.73635 333.63679,189.25127 334.4057,189.25127 C 334.5992,189.25127 335.04096,189.1425 335.38742,189.00955 C 335.87306,188.82319 336.01734,189.03377 336.01734
,189.92901 C 336.01734,191.2405 336.53293,191.99696 338.07787,192.95217 C 339.47981,193.81897 339.78238,194.91438 339.02463,196.37975 C 338.68478,197.03691 338.40673,197.85228 338.40673,198.1917 C 338.40673,198.99073 339.55511,198.99471 339.86131,198.19674 C 340.20718,197.29546 342.1437,196.41943 343.79018,196.41943 L 345.23091,196.41943 L 344.35966,197.64297 C 343.13716,199.35985 342.39148,202.10332 342.37495,204.94514 C 342.3671,206.29212 342.10774,207.81353 341.7917,208.36638 C 340.93494,209.86513 341.07871,211.1888 342.22856,212.389 C 343.07874,213.27638 343.2736,213.88142 343.3237,215.78908 L 343.38463,218.10969 L 347.65892,218.97816 C 355.93489,220.65972 361.17315,223.07315 365.98769,227.42277 C 367.35498,228.65805 369.07056,231.55118 369.07056,232.62171 C 369.07056,232.84454 369.44505,234.02779 369.90278,235.25115 C 370.6274,237.18792 370.81549,237.40866 371.3576,236.95873 C 371.70004,236.67453 372.20105,235.91681 372.47098,235.27491 L 372.96168,234.10781 L 374.64835,
237.66414 C 376.79497,242.19023 378.48809,244.26597 381.09141,245.56327 C 383.44779,246.73749 383.73507,246.77561 384.70114,246.04224 C 385.08444,245.75128 385.39721,245.35377 385.39622,245.15889 C 385.39518,244.96401 384.24991,242.78851 382.85112,240.32445 C 381.45237,237.8604 380.38344,235.84435 380.47575,235.84435 C 380.5681,235.84435 381.18472,236.46062 381.84606,237.21384 C 382.97318,238.49757 385.57996,239.77752 386.06974,239.28772 C 386.19081,239.16668 385.62185,238.15767 384.80544,237.0455 C 383.98903,235.93332 382.99285,234.15954 382.59167,233.10375 L 381.86227,231.18414 L 382.85096,229.23326 C 384.10471,226.75941 384.00703,224.87195 382.56997,223.80378 C 381.89887,223.30494 379.41804,222.63764 375.52669,221.90927 C 368.17816,220.53381 362.22858,219.06617 356.77428,217.28347 C 354.2481,216.4578 351.84454,215.93278 350.59074,215.93278 C 348.1548,215.93278 346.91913,215.19324 346.10686,213.24918 C 345.78863,212.48754 345.59362,211.799 345.67354,211.7191 C 345.75343,21
1.63919 346.47797,211.75582 347.28359,211.97827 C 350.76027,212.93822 354.65422,209.98133 356.10442,205.28008 C 356.31305,204.60385 356.22134,204.38406 355.73056,204.38406 C 354.67445,204.38406 349.48513,206.95618 347.80997,208.30995 C 346.95851,208.99807 346.1157,209.56107 345.93709,209.56107 C 344.61265,209.56107 344.66542,199.92665 345.99894,198.27985 C 346.64726,197.47917 347.0785,197.4111 351.81184,197.36231 C 356.04886,197.31862 357.50424,197.13494 360.30946,196.28987 C 364.46939,195.03669 382.06278,186.36279 383.08779,185.05968 C 383.49562,184.54126 384.43998,183.89625 385.18639,183.62634 C 386.86724,183.01854 388.95179,179.62126 388.19985,178.71522 C 387.62564,178.02331 387.27487,174.11847 387.78696,174.11847 C 388.49207,174.11847 389.33098,175.89692 389.6025,177.96744 C 389.8394,179.77399 389.71221,180.3716 388.55742,182.87695 C 387.52753,184.40414 391.1524,186.72713 391.78377,181.59182 C 392.49055,180.43835 393.26933,179.36673 393.51444,179.21045 C 393.78297,179.03
921 393.96002,177.64564 393.96002,175.70338 L 393.96002,172.48046 L 391.96887,170.72626 C 389.877,168.88334 388.21781,168.47 386.53245,169.37196 C 385.12171,170.12697 385.32597,169.50601 387.15895,167.46728 C 389.308,165.07704 392.18419,163.69254 396.94676,162.75578 C 400.13448,162.12878 402.28294,161.00327 401.59858,160.31888 C 401.44355,160.16387 399.79244,159.95703 397.92944,159.85925 C 394.17113,159.66199 391.04194,160.33031 387.61564,162.06206 C 386.03247,162.86223 385.23569,163.02013 383.50517,162.87662 C 381.41928,162.70364 381.30132,162.75009 379.33358,164.51926 C 378.21981,165.52062 376.99636,166.85332 376.61473,167.48081 C 376.04789,168.41293 375.60386,168.64329 374.18823,168.73966 C 373.23526,168.80454 371.2907,169.29861 369.86702,169.8376 C 367.31838,170.80249 367.27748,170.84145 367.21125,172.36846 C 367.1743,173.22146 367.1295,174.23296 367.1117,174.61626 C 367.09393,174.99956 366.87586,175.31317 366.62705,175.31317"
+ id="path2340" />
+ <path
+ d="M 315.30931,186.86188 C 314.98076,186.64956 314.89116,186.47585 315.11019,186.47585 C 315.32922,186.47585 315.77723,186.64956 316.10577,186.86188 C 316.43431,187.0742 316.52391,187.24791 316.30488,187.24791 C 316.08586,187.24791 315.63785,187.0742 315.30931,186.86188 z"
+ id="path2338" />
+ <path
+ d="M 365.45756,245.14908 C 367.19373,242.94191 365.82883,237.96577 362.80319,235.47178 C 361.45267,234.35857 361.22233,234.30747 357.8744,234.37834 C 353.47868,234.47138 352.85784,234.90562 353.5334,237.41447 C 353.85353,238.60337 354.33221,239.28924 355.17001,239.75944 C 356.00984,240.23078 356.29832,240.64519 356.16212,241.18471 C 356.05651,241.6031 356.42264,242.71759 356.97575,243.66136 C 358.00032,245.40966 358.20835,245.50967 361.70327,245.93399 C 364.30974,246.25043 364.64668,246.17999 365.45756,245.14908 z"
+ id="path2336" />
+ <path
+ d="M 310.20051,243.14991 C 310.93445,242.48572 311.13337,241.22151 310.68703,240.05835 C 310.52551,239.63743 309.94509,239.42843 308.9376,239.42843 C 307.35073,239.42843 306.94644,239.87314 306.94644,241.61871 C 306.94644,243.17748 307.38028,243.80898 308.45108,243.80898 C 309.01271,243.80898 309.79997,243.5124 310.20051,243.14991 z"
+ id="path2334" />
+ <path
+ d="M 346.69688,241.31622 C 346.97568,238.89179 342.79413,236.57972 342.45559,238.97115 C 342.12263,241.32342 343.3276,242.6859 345.5749,242.49828 C 346.34034,242.43438 346.59971,242.16113 346.69688,241.31622 z"
+ id="path2332" />
+ <path
+ d="M 339.68111,239.47325 C 340.81536,238.45982 340.90221,238.24407 340.4133,237.65495 C 339.66196,236.74963 338.08058,235.96867 336.33605,235.6414 L 334.89027,235.37016 L 335.27695,237.10062 C 336.08906,240.73459 337.4493,241.46738 339.68111,239.47325 z"
+ id="path2328" />
+ <path
+ d="M 311.84955,235.94391 C 312.19466,234.6845 312.59512,232.9901 312.73944,232.17858 C 312.9816,230.81698 312.91916,230.68233 311.93063,230.43422 C 309.6936,229.87276 307.83135,232.49865 308.56979,235.17314 C 308.93011,236.47802 310.26212,238.23374 310.8918,238.23374 C 311.07344,238.23374 311.5044,237.20332 311.84955,235.94391 z"
+ id="path2324" />
+ <path
+ d="M 307.4919,236.93949 C 307.94907,235.23357 307.73829,229.69903 307.18857,228.97486 C 306.02159,227.43754 304.89253,228.64103 304.53456,231.80389 C 304.32632,233.64346 304.41385,234.225 305.0159,235.00203 C 305.42062,235.52438 305.75175,236.16056 305.75175,236.41576 C 305.75175,236.92106 306.54264,237.83551 306.97966,237.83551 C 307.12931,237.83551 307.35985,237.4323 307.4919,236.93949 z"
+ id="path2322" />
+ <path
+ d="M 318.22962,237.11247 C 319.2234,236.01432 319.48508,234.11128 318.7286,233.48345 C 318.2248,233.06532 317.9767,233.059 317.50284,233.45225 C 316.99594,233.87296 315.8595,234.11425 313.85855,234.226 C 313.06404,234.27038 312.90454,235.45595 313.53033,236.66604 C 314.05774,237.686 314.35498,237.83551 315.85516,237.83551 C 317.01127,237.83551 317.78981,237.59844 318.22962,237.11247 z"
+ id="path2320" />
+ <path
+ d="M 343.17149,234.2776 C 343.76768,233.16365 343.69955,232.85724 342.55276,231.49436 C 341.29849,230.00374 340.28224,229.92949 339.66534,231.28342 C 338.99345,232.75812 339.09137,233.43311 340.09922,234.2739 C 341.26488,235.24631 342.65216,235.24799 343.17149,234.2776 z"
+ id="path2316" />
+ <path
+ d="M 302.48625,234.17178 C 303.73769,232.92033 302.59242,229.47265 300.92526,229.47265 C 299.26794,229.47265 298.89759,232.21223 300.35754,233.67218 C 301.45993,234.77456 301.80297,234.85508 302.48625,234.17178 z"
+ id="path2314" />
+ <path
+ d="M 296.74515,233.25998 C 298.2415,232.12702 296.63691,228.27795 294.66821,228.27795 C 292.89791,228.27795 292.04406,229.13131 292.33895,230.60588 C 292.92021,233.51204 294.86498,234.6835 296.74515,233.25998 z"
+ id="path2312" />
+ <path
+ d="M 358.94548,232.63375 C 359.33718,232.30865 359.06714,231.50143 357.71423,228.95338 C 356.23189,226.16161 355.67497,225.50246 353.86433,224.39684 C 352.36869,223.48356 351.25842,223.10375 350.08093,223.10259 C 348.1908,223.10072 346.37136,223.6797 346.37136,224.28304 C 346.37136,224.50597 347.17778,225.98421 348.1634,227.568 C 349.14903,229.1518 349.95545,230.575 349.95545,230.73068 C 349.95545,230.88635 350.11537,231.4286 350.31083,231.93567 C 350.64486,232.8022 350.89997,232.8634 354.55498,232.9539 C 356.82378,233.01007 358.65274,232.87671 358.94548,232.63375 z"
+ id="path2310" />
+ <path
+ d="M 337.39737,231.4782 C 338.39244,230.43956 338.46113,230.21708 337.96967,229.62447 C 337.25114,228.75812 335.14577,227.87972 333.78776,227.87972 C 332.79227,227.87972 332.74157,227.96771 332.96032,229.31565 C 333.50203,232.65389 335.38961,233.57387 337.39737,231.4782 z"
+ id="path2308" />
+ <path
+ d="M 315.27832,227.19391 C 316.00888,224.75881 316.02628,224.43277 315.47111,223.58546 C 315.13544,223.07315 314.55852,222.70976 314.18904,222.77791 C 313.27948,222.94569 311.9861,225.68531 312.27434,226.83367 C 312.48513,227.67351 313.9679,229.87088 314.32384,229.87088 C 314.40711,229.87088 314.8366,228.66624 315.27832,227.19391 z"
+ id="path2306" />
+ <path
+ d="M 304.59377,227.63636 C 305.11466,227.00872 305.22772,221.47451 304.7359,220.67873 C 304.61914,220.48983 303.81483,220.12291 302.94852,219.86336 C 301.57892,219.45301 301.27129,219.48385 300.59083,220.09965 C 299.58549,221.00945 298.84741,223.24484 299.19292,224.33341 C 299.34074,224.79911 300.09137,225.87715 300.86103,226.72905 C 302.36304,228.39162 303.69771,228.71604 304.59377,227.63636 z"
+ id="path2304" />
+ <path
+ d="M 310.70894,224.50185 C 310.67672,221.14285 308.67373,219.40733 307.78189,221.96567 C 307.08503,223.9646 307.24882,226.05749 308.19629,227.26202 L 309.04787,228.34466 L 309.88878,227.50301 C 310.54462,226.84656 310.7251,226.18617 310.70894,224.50185 z"
+ id="path2302" />
+ <path
+ d="M 291.68335,226.52772 L 292.79218,225.57396 L 291.99261,223.64055 C 290.99022,221.21674 289.96761,220.94643 288.48156,222.7125 C 287.22606,224.20456 287.20344,224.51141 288.22522,226.18724 C 289.16963,227.73623 290.16453,227.83418 291.68335,226.52772 z"
+ id="path2300" />
+ <path
+ d="M 298.49314,226.74936 C 298.90038,226.49089 298.8895,226.15939 298.43775,225.06297 C 298.12852,224.31239 297.74746,222.74472 297.59091,221.57924 C 297.43441,220.41376 297.08703,219.37602 296.81898,219.27316 C 295.89632,218.91911 294.22928,219.87097 293.97123,220.8992 C 293.13446,224.23307 296.20295,228.20285 298.49314,226.74936 z"
+ id="path2298" />
+ <path
+ d="M 335.23084,223.79785 C 337.06748,222.55344 337.12064,221.99382 335.46786,221.30323 C 333.5491,220.50153 331.23857,220.51543 331.23857,221.32868 C 331.23857,222.19803 332.31797,224.18402 332.92269,224.42734 C 333.74973,224.7601 333.85168,224.7323 335.23084,223.79785 z"
+ id="path2294" />
+ <path
+ d="M 383.90281,220.37318 C 384.44154,218.28344 384.28085,216.81662 382.83636,212.37084 C 381.76373,215.38825 380.78724,217.2674 380.25365,218.79798 C 379.89779,219.81885 379.97425,220.10272 380.83754,220.96604 C 382.20734,222.33584 383.4593,222.0937 383.90281,220.37318 z"
+ id="path2290" />
+ <path
+ d="M 376.08361,220.40678 C 376.84965,219.89997 377.83547,217.60906 378.09158,215.74052 C 378.33059,213.99683 379.10399,212.85299 379.09404,210.89345 C 376.81394,213.36102 375.9602,214.35244 375.01946,215.83322 C 373.67813,217.94454 373.25286,219.22225 373.59478,220.11331 C 373.8342,220.73723 375.31945,220.91236 376.08361,220.40678 z"
+ id="path2286" />
+ <path
+ d="M 287.97322,218.30723 C 287.91695,216.52941 285.96586,211.5248 285.12694,211.00632 C 284.89923,210.86559 284.16016,211.21558 283.48452,211.78408 C 282.49455,212.61708 282.25609,213.12255 282.25609,214.38804 C 282.25609,216.25704 283.05626,218.32586 284.23502,219.50464 C 284.86435,220.13395 285.47611,220.32653 286.55978,220.23645 L 288.03045,220.11421 L 287.97322,218.30723 z"
+ id="path2284" />
+ <path
+ d="M 337.26747,219.14277 C 338.15692,218.41212 338.17472,218.31008 337.59784,217.25117 C 336.71126,215.62376 334.95004,215.53967 333.49789,217.0554 L 332.38714,218.21476 L 333.70445,219.05822 C 335.34361,220.10774 336.07182,220.12502 337.26747,219.14277 z"
+ id="path2280" />
+ <path
+ d="M 293.43278,218.70639 C 294.96573,217.88597 294.11172,213.36546 292.23394,212.3605 C 290.08787,211.21195 288.37599,212.75333 288.8559,215.40206 C 289.33394,218.04022 290.08719,219.11863 291.45181,219.11863 C 292.1177,219.11863 293.0091,218.93312 293.43278,218.70639 z"
+ id="path2278" />
+ <path
+ d="M 307.24333,218.50609 C 308.04962,218.1692 309.00259,217.62816 309.36104,217.30378 C 309.96261,216.75938 309.94839,216.58201 309.1765,214.99834 C 308.03115,212.64846 305.82347,210.75639 304.71161,211.17172 C 303.38323,211.66792 302.1325,213.51929 302.32855,214.69921 C 302.42309,215.26816 302.51516,216.0231 302.53316,216.37686 C 302.58477,217.39057 304.13764,219.11863 304.99698,219.11863 C 305.4262,219.11863 306.43703,218.84299 307.24333,218.50609 z"
+ id="path2276" />
+ <path
+ d="M 300.3497,218.33202 C 301.24074,217.99325 301.3712,217.71099 301.3712,216.12197 C 301.3712,213.03026 299.79584,211.154 297.19993,211.154 C 296.17042,211.154 294.60127,212.82155 294.60127,213.91561 C 294.60127,214.87238 296.58757,217.79441 297.55814,218.26545 C 298.63786,218.78946 299.11654,218.80087 300.3497,218.33202 z"
+ id="path2274" />
+ <path
+ d="M 358.18147,214.88536 C 359.22045,213.5645 358.51397,207.89664 357.50067,206.97963 C 356.02966,208.94548 355.42535,209.62416 354.36518,211.11303 C 353.15516,212.81235 352.63729,214.49849 353.82796,215.11615 C 355.35837,215.91004 357.27617,216.03625 358.18147,214.88536 z"
+ id="path2270" />
+ <path
+ d="M 416.65966,208.43653 C 417.81186,207.05143 419.74285,204.09456 420.95068,201.86571 C 423.3971,197.35135 426.16293,190.60498 425.80484,190.02558 C 425.67701,189.81874 424.97768,189.6495 424.25075,189.6495 C 423.12343,189.6495 422.59681,190.02796 420.66945,192.22326 C 418.21356,195.02054 415.17298,196.81653 411.38265,197.70872 C 409.90987,198.05539 409.29194,198.39398 409.29194,198.8543 C 409.29194,199.89283 410.21699,200.39582 412.7276,200.72242 L 415.06629,201.02665 L 411.90262,202.6058 L 408.73891,204.18495 L 400.75214,204.31808 C 396.31238,204.39209 391.08515,204.24964 388.98213,203.99733 C 382.29268,203.19476 376.58706,202.8235 370.19918,202.77516 C 364.11038,202.72907 357.92007,203.39176 357.92007,204.08967 C 357.92007,204.74116 358.81108,206.175 359.99175,207.42351 C 361.13894,208.63663 361.20485,208.65423 362.38851,208.06372 C 363.2477,207.63512 364.84859,207.45545 367.8315,207.45287 C 371.92882,207.44934 373.5691,207.5073 387.98655,208.16506 C 395.24675
,208.49629 409.01823,207.85451 410.9972,207.09273 C 411.60654,206.85816 412.21336,206.77449 412.34566,206.9068 C 412.56476,207.12592 412.05001,210.32822 411.41144,212.71838 C 411.16458,213.64238 411.22897,213.62465 412.8589,212.32015 C 413.79709,211.56925 415.50745,209.82162 416.65966,208.43653 z"
+ style="fill:#800000"
+ id="path2268" />
+ <path
+ d="M 303.66649,209.69949 L 304.56793,208.70757 L 302.93012,206.37272 C 302.02932,205.08856 300.95899,203.73623 300.5516,203.36755 C 299.85056,202.73309 299.74359,202.76458 298.5518,203.95635 C 297.4135,205.09467 297.31808,205.37427 297.55738,206.87072 C 297.859,208.75699 298.2908,209.39024 299.97608,210.41773 C 301.37917,211.27321 302.42046,211.07056 303.66649,209.69949 z"
+ id="path2262" />
+ <path
+ d="M 295.36097,209.00287 C 295.85514,208.47683 296.35683,207.32065 296.47582,206.43358 C 296.66339,205.03501 296.53906,204.66766 295.53986,203.66845 C 293.96935,202.09794 291.64145,201.67165 290.25636,202.70093 C 288.92269,203.69203 288.7759,205.12016 289.80114,207.12985 C 291.18548,209.84338 293.75738,210.70981 295.36097,209.00287 z"
+ id="path2256" />
+ <path
+ d="M 337.38857,204.69368 C 338.29347,203.40178 338.1615,202.87271 336.71425,201.99031 C 335.34704,201.15671 332.65101,200.92195 332.23195,201.60001 C 331.79979,202.29928 332.41036,203.35267 333.90337,204.48362 C 335.65443,205.81001 336.5681,205.86508 337.38857,204.69368 z"
+ id="path2250" />
+ <path
+ d="M 298.21271,201.14714 C 298.5426,200.5307 298.28559,200.04903 296.75176,198.40927 C 294.79079,196.31279 294.20045,196.06022 293.43031,196.98817 C 293.06147,197.43263 293.10424,197.84598 293.62612,198.87977 C 295.20483,202.00691 297.21952,203.00288 298.21271,201.14714 z"
+ id="path2246" />
+ <path
+ d="M 324.0704,200.0261 C 324.0704,198.32886 323.04686,197.21384 321.49284,197.21812 C 318.77822,197.22558 315.70754,199.11714 315.70754,200.78188 C 315.70754,201.55076 315.94206,201.59644 319.88897,201.59644 L 324.0704,201.59644 L 324.0704,200.0261 z"
+ id="path2240" />
+ <path
+ d="M 334.80971,197.82886 C 335.07525,197.50891 335.38304,196.56809 335.49371,195.73815 C 335.64747,194.58528 335.4912,193.97071 334.83169,193.13403 C 333.62628,191.60489 332.95578,191.76176 331.96299,193.80523 L 331.10484,195.57157 L 332.18755,196.99108 C 333.35548,198.52235 334.05,198.74424 334.80971,197.82886 z"
+ id="path2232" />
+ <path
+ d="M 382.80568,194.84951 C 383.21757,192.41153 382.70322,190.12689 381.57622,189.38844 C 380.67204,188.796 380.53759,188.82081 379.22442,189.82241 C 378.45839,190.40668 377.83165,191.11579 377.83165,191.39818 C 377.83165,191.68059 378.36604,192.88109 379.01914,194.06598 C 379.67224,195.25086 380.20985,196.59366 380.21383,197.04996 C 380.21781,197.50627 380.30221,199.50032 380.46409,199.66223 C 382.36548,196.73965 382.52262,196.52478 382.80568,194.84951 z"
+ id="path2230" />
+ <path
+ d="M 286.94626,192.61366 C 287.43306,192.2727 287.83133,191.6522 287.83133,191.23479 C 287.83133,189.99136 286.2797,186.22622 285.46249,185.48666 C 284.79784,184.88518 284.56321,184.86637 283.57926,185.33571 C 282.72831,185.74157 282.42391,186.19903 282.3263,187.21843 C 282.13961,189.16915 282.50773,190.25129 283.89605,191.83247 C 285.27381,193.40165 285.67467,193.50432 286.94626,192.61366 z"
+ id="path2226" />
+ <path
+ d="M 280.50622,192.24605 C 281.69745,191.74832 281.87518,191.51625 281.64974,190.75268 C 281.22989,189.33051 279.57966,185.94598 278.88156,185.0752 C 278.29472,184.34322 278.16689,184.32924 277.17119,184.88812 C 274.83672,186.1984 274.54044,189.61436 276.57683,191.7399 C 277.77125,192.9866 278.50702,193.08137 280.50622,192.24605 z"
+ id="path2224" />
+ <path
+ d="M 354.52682,185.70649 C 356.94588,184.34123 357.69049,183.53933 356.26096,183.83881 C 355.74979,183.9459 354.16169,184.14229 352.73188,184.27524 C 350.38406,184.49354 350.60261,180.7234 349.2481,179.80422 C 347.34647,178.51372 346.371,182.22096 346.37287,183.57647 C 346.37487,185.06647 347.73853,187.19443 348.84796,187.4389 C 350.77317,187.86313 352.15006,187.84097 352.26985,187.38383 C 352.3381,187.12334 353.35371,186.36853 354.52682,185.70649 z"
+ id="path2220" />
+ <path
+ d="M 356.83171,182.91485 C 357.72207,182.57633 357.76855,182.41312 357.52192,180.49077 C 357.23599,178.26202 356.74426,177.7181 355.00673,177.70865 C 353.28231,177.69928 352.41727,178.36396 351.89794,180.09735 C 351.48234,181.48445 351.51321,181.78242 352.14472,182.48024 C 352.92924,183.34711 355.15253,183.55326 356.83171,182.91485 z"
+ id="path2210" />
+ <path
+ d="M 337.39307,180.70739 C 336.85546,180.16978 336.41557,179.27376 336.41557,178.71623 C 336.41557,177.83023 336.58498,177.70256 337.76064,177.70256 C 338.5004,177.70256 339.33859,177.98318 339.62321,178.32616 C 340.30438,179.14693 342.15955,180.09195 343.08962,180.09195 C 343.49669,180.09195 344.17762,179.83113 344.60278,179.51235 C 345.32146,178.97348 345.26651,178.9362 343.82077,178.98184 C 342.64547,179.01895 342.08627,178.80934 341.53094,178.12352 C 340.38049,176.70279 340.63058,176.45402 343.07759,176.58493 C 345.13203,176.69483 345.35989,176.62772 345.36742,175.91051 C 345.37817,174.88522 346.8858,174.63854 348.13577,175.45754 C 349.29167,176.21493 353.26144,176.12232 354.90498,175.29964 C 357.20824,174.14674 360.03142,169.03209 360.06316,165.95473 C 360.08219,164.11258 358.23324,159.78214 357.4277,159.78214 C 356.54207,159.78214 353.66561,163.0604 353.16204,164.64365 C 352.85513,165.60862 352.2174,166.41376 351.32146,166.96749 C 350.56741,167.43351 350.041
3,167.96171 350.15225,168.14129 C 350.40461,168.54958 344.22075,170.81101 341.00507,171.48639 C 338.1439,172.08732 337.53512,172.37768 333.53608,175.04885 C 331.84284,176.17985 330.45401,177.38298 330.44979,177.72247 C 330.43804,178.66658 331.27516,179.29548 332.54353,179.29548 C 333.28555,179.29548 334.11017,179.71643 334.88394,180.49018 C 335.65782,181.26406 336.48228,181.68487 337.22458,181.68487 L 338.37053,181.68487 L 337.39307,180.70739 z"
+ id="path2206" />
+ <path
+ d="M 331.60788,171.47626 C 332.06187,170.89916 332.43326,169.99013 332.43326,169.4562 L 332.43326,168.48542 L 333.48515,169.31283 C 334.27289,169.93249 334.66909,170.03063 335.06298,169.70372 C 335.48407,169.35423 335.19507,168.70636 333.61342,166.45414 C 332.52688,164.90696 331.27922,163.38987 330.84089,163.08284 C 330.40252,162.7758 330.04387,162.3223 330.04387,162.07506 C 330.04387,161.82781 329.70521,161.25556 329.29133,160.80338 C 328.87741,160.35121 327.88247,158.90603 327.08031,157.59187 L 325.62183,155.20248 L 328.82843,158.54402 C 330.59208,160.38187 332.03503,162.1189 332.03503,162.40409 C 332.03503,162.68929 333.12618,164.18726 334.45982,165.73293 C 336.42939,168.01566 337.10221,168.54323 338.0439,168.54323 C 338.68151,168.54323 339.20319,168.38584 339.20319,168.19348 C 339.20319,168.00112 338.03837,166.58561 336.61469,165.0479 C 335.19101,163.5102 334.02619,161.98691 334.02619,161.66282 C 334.02619,160.49074 322.77674,149.02989 321.62625,149.02989 C 32
1.20544,149.02989 321.11544,150.31462 321.26358,154.2069 C 321.38333,157.3527 321.7861,158.27851 324.1279,160.79079 C 325.09437,161.82764 328.45094,169.66467 328.45094,170.88438 C 328.45094,171.29304 329.99114,172.52555 330.5018,172.52555 C 330.65619,172.52555 331.15394,172.05337 331.60788,171.47626 z"
+ id="path2202" />
+ <path
+ d="M 349.67335,249.42454 C 349.95215,247.00011 345.7706,244.68804 345.43207,247.07947 C 345.0991,249.43174 346.30407,250.79422 348.55137,250.6066 C 349.31681,250.5427 349.57618,250.26945 349.67335,249.42454 z"
+ id="path3170" />
+ <path
+ d="M 339.82982,225.75444 C 340.32404,224.8811 340.3065,224.79252 339.50507,224.11223 C 338.27338,223.0667 336.81448,223.55085 336.10889,225.2393 L 335.56918,226.53076 L 336.90526,226.80352 C 338.56776,227.14289 339.16549,226.92848 339.82982,225.75444 z"
+ id="path3172" />
+ <path
+ d="M 393.07947,191.30261 C 393.49136,188.86463 392.977,186.57998 391.85001,185.84154 C 390.94582,185.2491 390.81138,185.27391 389.49821,186.2755 C 388.73217,186.85978 388.10544,187.56889 388.10544,187.85128 C 388.10544,188.13368 388.63982,189.33419 389.29292,190.51908 C 389.94602,191.70396 390.48364,193.04676 390.48762,193.50306 C 390.4916,193.95937 390.576,195.95342 390.73788,196.11533 C 392.63927,193.19275 392.7964,192.97788 393.07947,191.30261 z"
+ id="path5114" />
+ </g>
+ </g>
+ </g>
+ <path
+ style="font-size:104.55381012px;font-style:normal;font-weight:normal;fill:#ff0000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ d="M 379.86966,923.3115 C 388.89499,923.3115 397.92022,923.3115 406.94555,923.3115 C 406.94555,914.25166 406.94555,905.19183 406.94555,896.132 C 411.09906,908.15879 416.63568,920.17226 424.76929,925.08397 C 433.67104,930.86677 444.47664,928.56269 451.83424,918.2194 C 458.85348,908.6026 463.32006,894.85709 466.28465,880.81209 C 470.68446,859.01578 471.41559,835.64232 470.40204,812.8632 C 469.51119,794.21105 466.79116,775.50994 461.009,759.27836 C 456.78292,747.33401 450.50903,736.33422 442.22315,732.5589 C 433.55194,728.64159 423.69553,731.92442 416.94919,741.93112 C 412.7739,747.70841 409.63428,755.2492 406.94555,763.01789 C 406.94555,729.46878 406.94555,695.91967 406.94555,662.37055 C 397.92022,662.37055 388.89499,662.37055 379.86966,662.37055 C 379.86966,749.35077 379.86966,836.33113 379.86966,923.3115 z M 764.20114,763.01789 C 760.13116,751.12194 754.62979,739.61791 746.7984,734.24863 C 737.80438,728.25646 726.75018,730.42217 719.38251,741.19318 C 712.63562,750.38762
708.32305,763.5411 705.35705,776.94089 C 700.99293,797.52025 700.03706,819.62953 700.67744,841.27892 C 701.22073,856.01839 702.71167,870.80495 705.87417,884.65681 C 709.26163,899.20821 714.49152,913.41172 722.60937,921.91517 C 731.00199,930.42398 742.23483,930.15201 750.63522,921.82722 C 756.57402,915.68711 760.81555,906.0906 764.20114,896.132 C 764.20114,905.19183 764.20114,914.25166 764.20114,923.3115 C 773.28252,923.3115 782.3639,923.3115 791.44529,923.3115 C 791.44529,836.33113 791.44529,749.35077 791.44529,662.37055 C 782.3639,662.37055 773.28252,662.37055 764.20114,662.37055 C 764.20114,695.91967 764.20114,729.46878 764.20114,763.01789 z M 73.570401,807.26557 C 64.993554,762.67768 56.416706,718.0898 47.839972,673.50206 C 35.488592,673.62575 23.137214,673.7494 10.785834,673.87308 C 10.823162,757.35926 10.8606,840.84555 10.897928,924.33183 C 20.110123,924.42456 29.322208,924.51729 38.534402,924.61017 C 38.496965,863.78883 38.459636,802.96748 38.422198,742.14629 C 47.092
53,786.54856 55.76275,830.95099 64.432973,875.35327 C 70.599358,875.2914 76.765743,875.22953 82.932018,875.16766 C 91.602242,830.17784 100.27258,785.18802 108.9428,740.19821 C 108.9428,801.23602 108.9428,862.27369 108.9428,923.3115 C 118.13627,923.3115 127.32975,923.3115 136.52323,923.3115 C 136.52323,839.85608 136.52323,756.4008 136.52323,672.94548 C 124.17185,672.94548 111.82047,672.94548 99.469086,672.94548 C 90.836192,717.71887 82.203297,762.49222 73.570401,807.26557 z M 321.73787,731.10751 C 314.00118,731.74243 306.76498,738.52557 301.93956,748.41056 C 299.57365,752.87687 297.61966,757.87595 295.83919,763.01789 C 295.83919,753.83432 295.83919,744.6509 295.83919,735.46732 C 286.79524,735.46732 277.75129,735.46732 268.70724,735.46732 C 268.70724,821.89116 268.70724,908.31484 268.70724,994.73854 C 277.75129,994.73854 286.79524,994.73854 295.83919,994.73854 C 295.83919,961.86969 295.83919,929.00084 295.83919,896.132 C 300.0032,908.12503 305.50326,920.03591 313.5747,925.1017
9 C 321.86945,930.34356 331.75958,928.95781 339.04745,920.30034 C 346.71813,911.26862 351.52909,897.14987 354.72334,882.79016 C 359.37612,861.58545 360.16122,838.6468 359.47038,816.29454 C 358.66832,794.94479 355.54051,773.27062 348.34875,755.24123 C 344.4249,745.52025 339.07054,736.74093 332.1912,733.15557 C 328.86877,731.23342 325.2383,730.57793 321.73787,731.10751 z M 528.92702,731.01478 C 518.89448,731.70418 508.80196,737.66288 501.50992,749.33353 C 492.60763,763.22581 487.72256,782.83946 485.87289,802.58308 C 484.08781,821.30825 484.20582,840.52287 486.09894,859.21254 C 488.19371,877.98422 492.91545,896.69534 501.5709,909.76811 C 507.86755,919.31797 516.00609,925.24683 524.44698,927.10043 C 536.41478,930.09014 548.66326,926.64547 560.00645,920.13879 C 563.97496,917.82703 567.80116,914.92628 571.58697,911.90165 C 571.58697,896.47221 571.58697,881.04261 571.58697,865.61317 C 562.92069,875.98833 553.16148,884.75983 542.4589,887.36137 C 535.60057,889.03908 527.97937,888.860
57 522.10734,881.97587 C 516.16853,875.20055 513.60777,863.20245 512.62148,851.85013 C 512.291,849.35406 511.79862,845.15726 514.1746,845.89345 C 518.53379,846.32378 522.91181,845.88853 527.28152,846.04023 C 543.37667,846.04023 559.47181,846.04023 575.56707,846.04023 C 575.55164,830.15031 575.89274,814.10667 573.93953,798.44858 C 571.79638,779.42638 566.70802,760.82958 558.08728,747.45051 C 550.83553,736.02994 540.68016,730.39855 530.74637,730.95465 C 530.13992,730.97465 529.53348,730.99464 528.92702,731.01478 z M 650.46012,731.01478 C 642.50844,731.14142 635.14974,738.21767 629.94174,747.82766 C 627.29964,752.40872 625.20904,757.7554 623.104,763.01789 C 623.104,753.83432 623.104,744.6509 623.104,735.46732 C 614.07866,735.46732 605.05344,735.46732 596.0281,735.46732 C 596.0281,798.082 596.0281,860.69668 596.0281,923.3115 C 605.05344,923.3115 614.07866,923.3115 623.104,923.3115 C 623.14855,890.89501 623.00109,858.47432 623.2105,826.06087 C 623.4648,811.91488 624.84736,796.978
36 630.11119,785.37363 C 633.42235,778.47429 639.20123,774.35732 644.43265,777.03 C 649.05489,779.47883 652.16091,786.83444 652.83106,794.60096 C 653.93536,804.25862 653.82152,814.16564 653.94391,823.95805 C 654.03312,857.07567 653.97543,890.19358 653.99174,923.3115 C 663.07313,923.3115 672.1545,923.3115 681.23578,923.3115 C 681.19396,882.51095 681.33222,841.70606 681.13639,800.90827 C 680.77536,784.12162 679.1929,766.81683 674.05879,752.06736 C 670.40621,741.64423 664.09314,733.42796 656.76815,731.72953 C 654.69726,731.09664 652.56298,730.84149 650.46012,731.01478 z M 855.5752,731.01478 C 845.48596,731.82792 835.24412,737.66404 828.01196,749.67098 C 820.175,762.02045 815.46223,778.91563 813.30047,796.28244 C 810.92318,814.33284 810.89318,833.04106 812.07314,851.3472 C 813.421,869.93328 817.10336,888.57745 824.42594,903.12596 C 830.51131,915.21665 839.19883,923.58723 848.56494,926.33453 C 860.77806,930.41717 873.48192,927.34385 885.2111,920.99626 C 889.68129,918.42283 894.07
758,915.47963 898.29119,911.90165 C 898.29119,896.47221 898.29119,881.04261 898.29119,865.61317 C 891.13949,874.20543 883.27341,881.55539 874.70762,885.43416 C 867.8667,888.34606 860.4398,889.76876 853.61323,886.02083 C 849.5856,883.78166 846.11014,879.30651 843.80312,873.40519 C 840.60045,865.30759 839.42565,855.54517 838.92615,846.04023 C 860.04113,846.04023 881.15622,846.04023 902.2713,846.04023 C 902.29878,828.38103 902.56062,810.47639 899.95892,793.20521 C 897.41042,775.20204 892.07073,757.73497 883.49191,745.5785 C 876.98585,736.3971 868.5374,731.34093 860.01244,730.99609 C 858.53377,730.8583 857.05465,730.99174 855.5752,731.01478 z M 195.83223,731.10751 C 185.37769,731.87341 175.01216,735.1858 165.05657,740.47654 C 165.05657,755.75139 165.05657,771.02639 165.05657,786.30123 C 175.41762,773.58924 188.92179,768.89965 201.60618,771.64479 C 206.76064,772.7083 212.32825,776.69153 214.51255,785.0456 C 216.03721,790.68379 216.132,797.01472 216.06906,803.09122 C 205.9657,803.
38883 195.75855,802.07132 185.75711,805.0564 C 177.9185,807.59998 169.87804,812.98317 164.8986,823.78751 C 159.72531,834.77702 157.95194,848.97865 157.69261,862.62983 C 157.20461,878.37456 158.96757,894.80986 164.36068,908.07055 C 168.83274,919.02732 176.18006,927.09435 184.26572,927.93791 C 192.32688,929.15081 201.04887,925.79597 206.9463,916.16787 C 210.75619,910.31928 213.61338,903.00512 216.06906,895.48274 C 216.06906,904.75889 216.06906,914.0352 216.06906,923.3115 C 225.16916,923.3115 234.26915,923.3115 243.36914,923.3115 C 243.3259,884.90081 243.46963,846.48693 243.26416,808.07856 C 242.85727,790.93736 241.3902,773.23165 236.18942,758.10387 C 232.56836,747.86316 226.68649,739.96899 219.91573,736.08891 C 212.26618,731.25921 203.92676,730.68805 195.83223,731.10751 z M 975.48261,731.10751 C 967.98981,731.79821 960.94637,738.44544 956.42407,748.2664 C 953.72549,753.75782 951.74261,760.07774 949.80822,766.35723 C 949.80822,756.06059 949.80822,745.76396 949.80822,735.46732 C
940.78299,735.46732 931.75755,735.46732 922.73232,735.46732 C 922.73232,798.082 922.73232,860.69668 922.73232,923.3115 C 931.75755,923.3115 940.78299,923.3115 949.80822,923.3115 C 949.85605,892.41493 949.69798,861.51372 949.92173,830.62034 C 950.25802,816.63794 951.70637,801.86369 957.03019,790.52934 C 960.92317,782.47332 967.36497,778.31505 973.53135,779.60604 C 977.85005,780.31616 982.04778,782.7518 985.68514,786.6723 C 985.66643,768.55264 985.64771,750.43312 985.62899,732.31345 C 982.2758,731.38078 978.88703,730.71268 975.48261,731.10751 z M 532.2905,770.90265 C 537.09874,771.17664 541.43691,776.21614 543.84836,782.95349 C 546.81021,790.66061 547.61304,799.96835 547.76246,808.93531 C 536.02771,808.93531 524.29296,808.93531 512.5582,808.93531 C 513.32075,797.32465 515.34425,784.97634 520.88043,777.04464 C 523.97277,772.43068 528.19556,770.61779 532.2905,770.90265 z M 859.05077,770.90265 C 863.92611,771.23648 868.27906,776.44073 870.65472,783.33282 C 873.57168,790.9133 874
.35076,800.11035 874.41064,808.93531 C 862.67589,808.93531 850.94114,808.93531 839.20638,808.93531 C 840.06724,797.27292 842.04738,784.74639 847.7007,776.86685 C 850.83408,772.43286 854.98014,770.6046 859.05077,770.90265 z M 314.89881,774.6132 C 320.24825,774.81836 324.88187,781.09423 327.14248,788.84033 C 330.63972,799.93909 331.36866,812.69773 331.68886,825.00591 C 331.77151,840.29974 331.43118,856.32701 327.17543,870.25132 C 324.99353,877.42827 320.9323,883.58461 315.93273,884.33486 C 311.03452,885.47096 305.74606,882.51023 302.70003,875.89502 C 298.07176,866.53975 296.77688,854.08248 296.17054,842.36503 C 295.49163,826.71622 295.70542,810.6236 298.63454,795.57348 C 300.48486,786.75677 304.12912,777.91906 309.86519,775.41445 C 311.49909,774.74853 313.21291,774.36847 314.89881,774.6132 z M 425.27645,774.52047 C 430.32288,774.51554 435.14665,779.38929 437.5014,786.76257 C 441.8363,798.50798 442.52418,812.69744 442.76173,826.13969 C 442.93928,839.82304 442.41374,853.91586 43
9.29206,866.73579 C 437.28148,875.08 433.18939,882.97461 427.54352,884.24213 C 422.05922,885.91419 416.05736,882.03165 413.00312,874.20123 C 409.03845,865.11995 408.00782,853.69779 407.27461,842.83869 C 406.57577,826.60552 406.77084,809.84466 410.03,794.32624 C 411.97512,785.63067 415.89667,776.8867 421.73082,775.16364 C 422.89719,774.78431 424.08501,774.48004 425.27645,774.52047 z M 747.43999,774.6132 C 752.85806,774.92196 757.5693,781.27028 759.78075,789.23023 C 763.80092,802.44384 764.20771,817.63117 764.17552,832.14867 C 764.0458,846.44636 763.11621,861.48214 758.4273,873.86899 C 755.88417,880.002 751.68808,884.43194 747.12614,884.58741 C 742.04009,885.11496 736.89624,880.8431 734.28271,873.53646 C 730.62028,864.57095 729.55856,853.5303 728.8849,842.97909 C 728.30166,825.77804 728.28797,807.89136 732.21981,791.65428 C 734.23926,783.67912 738.22703,776.37248 743.6,774.96978 C 744.86533,774.65159 746.16119,774.43933 747.43999,774.6132 z M 204.0728,838.80488 C 208.07184,838
.91341 212.06902,838.77011 216.06906,838.80488 C 216.20699,850.16836 215.82911,862.123 212.31511,872.20316 C 209.69677,880.3593 205.01147,887.60754 199.19571,888.15437 C 194.2281,889.03111 188.63149,885.36881 186.60427,877.37249 C 184.44941,869.81577 184.54322,860.88402 185.96607,852.99753 C 187.42473,846.80729 190.69132,841.97658 194.59897,840.38175 C 197.66448,838.83908 200.89573,838.74852 204.0728,838.80488 z"
+ id="text3266" />
+ <rect
+ style="fill:#ffffff;stroke-width:6"
+ id="rect5682"
+ width="1016.1943"
+ height="2052.6316"
+ x="-1024.2915"
+ y="-279.35223" />
+ <rect
+ id="rect5684"
+ width="1753.0364"
+ height="1388.6639"
+ x="-742.91492"
+ y="633.60321" />
+ <text
+ id="text4277"
+ y="-157.00433"
+ x="-1339.3473"
+ style="font-size:33.16645813px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ xml:space="preserve"
+ transform="scale(1.1179906,0.8944619)"><tspan
+ y="-157.00433"
+ x="-1339.3473"
+ id="tspan4279"
+ sodipodi:role="line">0000111011100110010010</tspan><tspan
+ id="tspan4287"
+ y="-115.54626"
+ x="-1339.3473"
+ sodipodi:role="line">0001111011000111000110</tspan><tspan
+ id="tspan4298"
+ y="-74.088196"
+ x="-1339.3473"
+ sodipodi:role="line">0111000001111010001100</tspan><tspan
+ id="tspan4300"
+ y="-32.630123"
+ x="-1339.3473"
+ sodipodi:role="line">0011111000001100011100</tspan><tspan
+ id="tspan4302"
+ y="8.8279753"
+ x="-1339.3473"
+ id="tspan4314"
+ y="50.28603"
+ x="-1339.3473"
+ id="tspan4336"
+ y="91.74411"
+ x="-1339.3473"
+ id="tspan4338"
+ y="133.20218"
+ x="-1339.3473"
+ id="tspan4340"
+ y="174.66025"
+ x="-1339.3473"
+ id="tspan4342"
+ y="216.11832"
+ x="-1339.3473"
+ id="tspan4344"
+ y="257.57639"
+ x="-1339.3473"
+ id="tspan4346"
+ y="299.03445"
+ x="-1339.3473"
+ id="tspan4348"
+ y="340.49255"
+ x="-1339.3473"
+ id="tspan4350"
+ y="381.95062"
+ x="-1339.3473"
+ id="tspan4352"
+ y="423.40869"
+ x="-1339.3473"
+ sodipodi:role="line" /></text>
+ <path
+ style="font-size:104.55381011999999430px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ d="M 388.06129,909.40409 C 397.08663,909.40409 406.11185,909.40409 415.13719,909.40409 C 415.13719,900.34425 415.13719,891.28442 415.13719,882.22459 C 419.29069,894.25138 424.82731,906.26485 432.96093,911.17656 C 441.86267,916.95936 452.66827,914.65528 460.02587,904.31199 C 467.04512,894.69519 471.5117,880.94968 474.47628,866.90468 C 478.87609,845.10837 479.60722,821.7349 478.59366,798.95579 C 477.70282,780.30364 474.98278,761.60252 469.20063,745.37095 C 464.97455,733.4266 458.70067,722.4268 450.41479,718.65149 C 441.74358,714.73418 431.88717,718.017 425.14082,728.02371 C 420.96554,733.801 417.82592,741.34178 415.13719,749.11048 C 415.13719,715.56137 415.13719,682.01225 415.13719,648.46314 C 406.11185,648.46314 397.08663,648.46314 388.06129,648.46314 C 388.06129,735.44336 388.06129,822.42372 388.06129,909.40409 z M 772.39277,749.11048 C 768.32279,737.21452 762.82141,725.7105 754.99004,720.34122 C 745.99602,714.34905 734.94181,716.51476 727.57414,727.28577 C 720.82725,73
6.48021 716.51469,749.63369 713.54868,763.03348 C 709.18456,783.61284 708.2287,805.72212 708.86908,827.37151 C 709.41236,842.11098 710.9033,856.89754 714.0658,870.7494 C 717.45326,885.3008 722.68315,899.50431 730.80101,908.00776 C 739.19362,916.51657 750.42647,916.2446 758.82685,907.91981 C 764.76566,901.7797 769.00718,892.18319 772.39277,882.22459 C 772.39277,891.28442 772.39277,900.34425 772.39277,909.40409 C 781.47415,909.40409 790.55554,909.40409 799.63691,909.40409 C 799.63691,822.42372 799.63691,735.44336 799.63691,648.46314 C 790.55554,648.46314 781.47415,648.46314 772.39277,648.46314 C 772.39277,682.01225 772.39277,715.56137 772.39277,749.11048 z M 81.762036,793.35816 C 73.185187,748.77027 64.608339,704.18239 56.0316,659.59465 C 43.680226,659.71834 31.328847,659.84199 18.977467,659.96567 C 19.009214,731.07795 19.041177,802.19031 19.072923,873.30268 C 19.078506,885.67659 19.083979,898.05051 19.089562,910.42442 C 28.301756,910.51715 37.513841,910.60988 46.726035,910.70
276 C 46.688598,849.88141 46.65127,789.06007 46.613831,728.23887 C 55.28416,772.64115 63.954384,817.04358 72.624607,861.44586 C 78.790992,861.38399 84.957377,861.32212 91.123652,861.26025 C 99.793876,816.27043 108.46421,771.28061 117.13443,726.2908 C 117.13443,787.32861 117.13443,848.36627 117.13443,909.40409 C 126.32791,909.40409 135.52138,909.40409 144.71486,909.40409 C 144.71486,825.94867 144.71486,742.49339 144.71486,659.03807 C 132.36348,659.03807 120.01211,659.03807 107.66072,659.03807 C 99.027826,703.81146 90.39493,748.58481 81.762036,793.35816 z M 329.92951,717.2001 C 322.19282,717.83502 314.95661,724.61816 310.1312,734.50315 C 307.76528,738.96946 305.8113,743.96854 304.03082,749.11048 C 304.03082,739.92691 304.03082,730.74348 304.03082,721.55991 C 294.98688,721.55991 285.94293,721.55991 276.89888,721.55991 C 276.89888,807.98375 276.89888,894.40743 276.89888,980.83112 C 285.94293,980.83112 294.98688,980.83112 304.03082,980.83112 C 304.03082,947.96228 304.03082,915.09
343 304.03082,882.22459 C 308.19484,894.21762 313.6949,906.1285 321.76634,911.19438 C 330.06109,916.43615 339.95121,915.0504 347.23909,906.39293 C 354.90976,897.36121 359.72072,883.24246 362.91497,868.88275 C 367.56776,847.67804 368.35286,824.73939 367.66201,802.38713 C 366.85994,781.03738 363.73215,759.36321 356.54038,741.33382 C 352.61654,731.61284 347.26218,722.83352 340.38283,719.24815 C 337.06041,717.32601 333.42993,716.67052 329.92951,717.2001 z M 537.11866,717.10737 C 527.08612,717.79677 516.9936,723.75547 509.70156,735.42612 C 500.79926,749.3184 495.91419,768.93205 494.06453,788.67567 C 492.27945,807.40084 492.39746,826.61546 494.29057,845.30513 C 496.38533,864.07681 501.10709,882.78793 509.76253,895.8607 C 516.05918,905.41056 524.19772,911.33941 532.63862,913.19302 C 544.60642,916.18273 556.8549,912.73806 568.19809,906.23138 C 572.16659,903.91962 575.9928,901.01887 579.7786,897.99424 C 579.7786,882.5648 579.7786,867.1352 579.7786,851.70575 C 571.11232,862.08092 561.
35311,870.85242 550.65053,873.45396 C 543.7922,875.13167 536.171,874.95316 530.29897,868.06845 C 524.36017,861.29314 521.79941,849.29503 520.81312,837.94271 C 520.48263,835.44665 519.99025,831.24984 522.36623,831.98604 C 526.72543,832.41637 531.10345,831.98112 535.47315,832.13282 C 551.5683,832.13282 567.66345,832.13282 583.75871,832.13282 C 583.74328,816.2429 584.08437,800.19926 582.13115,784.54117 C 579.98801,765.51897 574.89966,746.92217 566.27892,733.5431 C 559.02716,722.12253 548.8718,716.49114 538.938,717.04724 C 538.33155,717.06723 537.7251,717.08723 537.11866,717.10737 z M 658.65176,717.10737 C 650.70007,717.23401 643.34138,724.31026 638.13337,733.92025 C 635.49128,738.50131 633.40068,743.84799 631.29562,749.11048 C 631.29562,739.92691 631.29562,730.74348 631.29562,721.55991 C 622.27029,721.55991 613.24506,721.55991 604.21973,721.55991 C 604.21973,784.17459 604.21973,846.78927 604.21973,909.40409 C 613.24506,909.40409 622.27029,909.40409 631.29562,909.40409 C 631.340
17,876.9876 631.19273,844.56691 631.40214,812.15346 C 631.65643,798.00747 633.03899,783.07094 638.30283,771.46622 C 641.61399,764.56688 647.39285,760.44991 652.62428,763.12259 C 657.24652,765.57142 660.35254,772.92703 661.0227,780.69355 C 662.127,790.35121 662.01315,800.25823 662.13554,810.05064 C 662.22476,843.16826 662.16706,876.28617 662.18338,909.40409 C 671.26476,909.40409 680.34614,909.40409 689.42741,909.40409 C 689.3856,868.60354 689.52385,827.79865 689.32802,787.00086 C 688.967,770.21421 687.38454,752.90941 682.25043,738.15995 C 678.59785,727.73682 672.28477,719.52055 664.95979,717.82212 C 662.88889,717.18923 660.75462,716.93408 658.65176,717.10737 z M 863.76684,717.10737 C 853.67759,717.92051 843.43575,723.75663 836.20359,735.76357 C 828.36663,748.11304 823.65387,765.00822 821.49211,782.37503 C 819.11481,800.42543 819.08482,819.13365 820.26476,837.43979 C 821.61263,856.02587 825.29499,874.67004 832.61756,889.21854 C 838.70295,901.30924 847.39046,909.67982 856.75657
,912.42712 C 868.96969,916.50976 881.67356,913.43644 893.40272,907.08885 C 897.87291,904.51542 902.26922,901.57222 906.48283,897.99424 C 906.48283,882.5648 906.48283,867.1352 906.48283,851.70575 C 899.33113,860.29802 891.46505,867.64798 882.89926,871.52675 C 876.05834,874.43865 868.63144,875.86135 861.80486,872.11342 C 857.77724,869.87425 854.30177,865.3991 851.99476,859.49778 C 848.79208,851.40018 847.61728,841.63776 847.11779,832.13282 C 868.23276,832.13282 889.34784,832.13282 910.46293,832.13282 C 910.49042,814.47362 910.75225,796.56898 908.15056,779.2978 C 905.60205,761.29463 900.26236,743.82756 891.68354,731.67109 C 885.17749,722.48969 876.72904,717.43352 868.20408,717.08868 C 866.7254,716.95089 865.24628,717.08433 863.76684,717.10737 z M 204.02386,717.2001 C 193.56932,717.966 183.20378,721.27839 173.2482,726.56913 C 173.2482,741.84398 173.2482,757.11897 173.2482,772.39382 C 183.60925,759.68183 197.11343,754.99224 209.7978,757.73738 C 214.95228,758.80089 220.51988,762.7
8412 222.70419,771.13818 C 224.22884,776.77638 224.32364,783.10731 224.26069,789.18381 C 214.15732,789.48142 203.95019,788.16391 193.94874,791.14899 C 186.11014,793.69257 178.06968,799.07576 173.09024,809.8801 C 167.91694,820.86961 166.14358,835.07124 165.88425,848.72242 C 165.39625,864.46715 167.15921,880.90244 172.55232,894.16314 C 177.02437,905.11991 184.37169,913.18694 192.45736,914.0305 C 200.51851,915.2434 209.24051,911.88856 215.13793,902.26046 C 218.94782,896.41187 221.80502,889.0977 224.26069,881.57533 C 224.26069,890.85148 224.26069,900.12778 224.26069,909.40409 C 233.36079,909.40409 242.46079,909.40409 251.56078,909.40409 C 251.51754,870.9934 251.66127,832.57952 251.4558,794.17115 C 251.04891,777.02994 249.58183,759.32424 244.38105,744.19645 C 240.76,733.95575 234.87812,726.06158 228.10737,722.1815 C 220.45781,717.3518 212.1184,716.78064 204.02386,717.2001 z M 983.67424,717.2001 C 976.18145,717.8908 969.13801,724.53803 964.61571,734.35898 C 961.91712,739.85041 959
.93424,746.17032 957.99986,752.44982 C 957.99986,742.15318 957.99986,731.85655 957.99986,721.55991 C 948.97462,721.55991 939.94918,721.55991 930.92396,721.55991 C 930.92396,784.17459 930.92396,846.78927 930.92396,909.40409 C 939.94918,909.40409 948.97462,909.40409 957.99986,909.40409 C 958.04769,878.50752 957.88961,847.60631 958.11337,816.71293 C 958.44965,802.73053 959.89801,787.95628 965.22183,776.62193 C 969.1148,768.56591 975.5566,764.40764 981.72299,765.69863 C 986.04168,766.40875 990.23941,768.84439 993.87678,772.76489 C 993.85807,754.64523 993.83934,736.52571 993.82063,718.40604 C 990.46743,717.47337 987.07866,716.80527 983.67424,717.2001 z M 540.48214,756.99524 C 545.29037,757.26923 549.62855,762.30873 552.03999,769.04608 C 555.00184,776.7532 555.80467,786.06094 555.9541,795.0279 C 544.21935,795.0279 532.48459,795.0279 520.74984,795.0279 C 521.51239,783.41724 523.53588,771.06893 529.07207,763.13723 C 532.1644,758.52327 536.3872,756.71038 540.48214,756.99524 z M 867.2
4241,756.99524 C 872.11774,757.32907 876.4707,762.53331 878.84635,769.42541 C 881.76332,777.00589 882.5424,786.20294 882.60227,795.0279 C 870.86752,795.0279 859.13277,795.0279 847.39802,795.0279 C 848.25887,783.36551 850.23902,770.83898 855.89233,762.95944 C 859.02571,758.52544 863.17177,756.69719 867.24241,756.99524 z M 323.09044,760.70579 C 328.43988,760.91095 333.07351,767.18682 335.33411,774.93292 C 338.83136,786.03168 339.5603,798.79032 339.8805,811.0985 C 339.96314,826.39233 339.6228,842.4196 335.36706,856.34391 C 333.18516,863.52086 329.12394,869.6772 324.12436,870.42745 C 319.22615,871.56355 313.93769,868.60282 310.89166,861.98761 C 306.2634,852.63234 304.96851,840.17507 304.36218,828.45762 C 303.68326,812.80881 303.89706,796.71619 306.82617,781.66607 C 308.67649,772.84936 312.32075,764.01165 318.05683,761.50704 C 319.69073,760.84112 321.40455,760.46106 323.09044,760.70579 z M 433.46809,760.61305 C 438.51451,760.60813 443.33829,765.48187 445.69303,772.85516 C 450.027
93,784.60057 450.71582,798.79003 450.95337,812.23228 C 451.13092,825.91563 450.60536,840.00845 447.4837,852.82838 C 445.47312,861.17259 441.38102,869.0672 435.73515,870.33472 C 430.25085,872.00678 424.249,868.12424 421.19476,860.29382 C 417.23008,851.21254 416.19946,839.79038 415.46624,828.93128 C 414.7674,812.69811 414.96248,795.93725 418.22164,780.41883 C 420.16676,771.72326 424.0883,762.97929 429.92245,761.25623 C 431.08883,760.8769 432.27665,760.57263 433.46809,760.61305 z M 755.63163,760.70579 C 761.04969,761.01455 765.76093,767.36287 767.97239,775.32282 C 771.99256,788.53643 772.39934,803.72376 772.36715,818.24126 C 772.23744,832.53895 771.30785,847.57473 766.61894,859.96158 C 764.07579,866.09459 759.87971,870.52453 755.31778,870.68 C 750.23173,871.20755 745.08787,866.93569 742.47435,859.62905 C 738.81191,850.66354 737.7502,839.62289 737.07653,829.07168 C 736.49329,811.87063 736.47961,793.98395 740.41145,777.74687 C 742.43089,769.7717 746.41866,762.46507 751.79163,761.
06237 C 753.05696,760.74418 754.35283,760.53191 755.63163,760.70579 z M 212.26442,824.89747 C 216.26348,825.006 220.26066,824.8627 224.26069,824.89747 C 224.39862,836.26095 224.02075,848.21559 220.50674,858.29575 C 217.8884,866.45189 213.2031,873.70013 207.38735,874.24696 C 202.41973,875.1237 196.82312,871.4614 194.79591,863.46508 C 192.64105,855.90836 192.73486,846.97661 194.15771,839.09012 C 195.61635,832.89988 198.88296,828.06917 202.79061,826.47434 C 205.85612,824.93167 209.08736,824.84111 212.26442,824.89747 z"
+ id="path5686"
+ sodipodi:nodetypes="cccccccccccccccccccccccccccccccscccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccsccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc" />
+</svg>
Copied: trunk/documents/logos/logo_contest/mapbender_earth.svg (from rev 6635, trunk/documents/logos/mapbender_earth.svg)
--- trunk/documents/logos/logo_contest/mapbender_earth.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_earth.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,1356 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ version="1.0"
+ id="OSGeo_x5F_logo"
+ width="200"
+ height="200"
+ viewBox="0 0 296.647 125.463"
+ overflow="visible"
+ enable-background="new 0 0 296.647 125.463"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ sodipodi:docname="mapbender_earth.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ style="overflow:visible"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_hueben.png"
+ inkscape:export-xdpi="182.34"
+ inkscape:export-ydpi="182.34"><metadata
+ id="metadata241"><rdf:RDF><cc:Work
+ rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
+ id="defs239"><inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 62.731499 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="296.647 : 62.731499 : 1"
+ inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
+ id="perspective243" /><inkscape:perspective
+ id="perspective3540"
+ sodipodi:type="inkscape:persp3d" />
+<radialGradient
+ xlink:href="#linearGradient583"
+ r="0.40413386"
+ id="radialGradient582"
+ fy="0.22549020"
+ fx="0.68367344"
+ cy="0.22549020"
+ cx="0.68367344" /><radialGradient
+ r="123.08747"
+ id="radialGradient579"
+ fy="183.44996"
+ fx="201.95493"
+ cy="183.44996"
+ cx="201.95493"
+ gradientTransform="scale(1.0032556,0.996755)"
+ gradientUnits="userSpaceOnUse" /><linearGradient
+ id="linearGradient576"><stop
+ style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
+ offset="0.00000000"
+ id="stop577" /><stop
+ style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
+ offset="1.00000000"
+ id="stop578" /></linearGradient><linearGradient
+ id="linearGradient583"><stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
+ id="stop584" /><stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
+ id="stop585" /></linearGradient><inkscape:perspective
+ id="perspective4969"
+ inkscape:persp3d-origin="250 : 166.66667 : 1"
+ inkscape:vp_z="500 : 250 : 1"
+ inkscape:vp_x="0 : 250 : 1"
+ sodipodi:type="inkscape:persp3d" /><radialGradient
+ inkscape:collect="always"
+ id="radialGradient5042"
+ cx="201.95493"
+ cy="183.44996"
+ fx="201.95493"
+ fy="183.44996"
+ r="123.08747" /></defs><sodipodi:namedview
+ inkscape:window-height="975"
+ inkscape:window-width="1400"
+ inkscape:pageshadow="2"
+ inkscape:pageopacity="0.0"
+ guidetolerance="10.0"
+ gridtolerance="10.0"
+ objecttolerance="10.0"
+ borderopacity="1.0"
+ bordercolor="#666666"
+ pagecolor="#ffffff"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="2.6554017"
+ inkscape:cx="97.254594"
+ inkscape:cy="101.78646"
+ inkscape:window-x="0"
+ inkscape:window-y="25"
+ inkscape:current-layer="OSGeo_x5F_logo" />
+<g
+ id="g3544"
+ display="none"
+ style="display:none"
+ transform="matrix(0.4211728,0.182269,-0.4747632,1.0363122,6.5648762,-12.913196)">
+ <g
+ id="g3546">
+ <path
+ display="inline"
+ d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
+ id="path3548"
+ style="fill:#0054a4;display:inline" />
+ <path
+ display="inline"
+ d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
+ id="path3550"
+ <path
+ display="inline"
+ d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
+ id="path3552"
+ <path
+ display="inline"
+ d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
+ id="path3554"
+ <path
+ display="inline"
+ d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
+ id="path3556"
+ <path
+ display="inline"
+ d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
+ id="path3558"
+ <path
+ display="inline"
+ d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
+ id="path3560"
+ <path
+ display="inline"
+ d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
+ id="path3562"
+ <path
+ display="inline"
+ d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
+ id="path3564"
+ <path
+ display="inline"
+ d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
+ id="path3566"
+ <path
+ display="inline"
+ d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
+ id="path3568"
+ <path
+ display="inline"
+ d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
+ id="path3570"
+ <path
+ display="inline"
+ d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
+ id="path3572"
+ <path
+ display="inline"
+ d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
+ id="path3574"
+ <path
+ display="inline"
+ d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
+ id="path3576"
+ <path
+ display="inline"
+ d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
+ id="path3578"
+ <path
+ display="inline"
+ d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
+ id="path3580"
+ </g>
+ <g
+ id="g3582">
+ <path
+ display="inline"
+ d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
+ id="path3584"
+ <path
+ display="inline"
+ d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
+ id="path3586"
+ <path
+ display="inline"
+ d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
+ id="path3588"
+ <path
+ display="inline"
+ d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
+ id="path3590"
+ <path
+ display="inline"
+ d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
+ id="path3592"
+ <path
+ display="inline"
+ d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
+ id="path3594"
+ <path
+ display="inline"
+ d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
+ id="path3596"
+ <path
+ display="inline"
+ d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
+ id="path3598"
+ <path
+ display="inline"
+ d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
+ id="path3600"
+ <path
+ display="inline"
+ d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
+ id="path3602"
+ <path
+ display="inline"
+ d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
+ id="path3604"
+ <path
+ display="inline"
+ d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
+ id="path3606"
+ <path
+ display="inline"
+ d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
+ id="path3608"
+ <path
+ display="inline"
+ d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
+ id="path3610"
+ <path
+ display="inline"
+ d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
+ id="path3612"
+ <path
+ display="inline"
+ d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
+ id="path3614"
+ <path
+ display="inline"
+ d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
+ id="path3616"
+ <path
+ display="inline"
+ d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
+ id="path3618"
+ </g>
+ <g
+ id="g3620">
+ <path
+ display="inline"
+ d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
+ id="path3622"
+ <path
+ display="inline"
+ d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
+ id="path3624"
+ <path
+ display="inline"
+ d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
+ id="path3626"
+ <path
+ display="inline"
+ d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
+ id="path3628"
+ <path
+ display="inline"
+ d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
+ id="path3630"
+ <path
+ display="inline"
+ d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
+ id="path3632"
+ <path
+ display="inline"
+ d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
+ id="path3634"
+ <path
+ display="inline"
+ d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
+ id="path3636"
+ <path
+ display="inline"
+ d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
+ id="path3638"
+ <path
+ display="inline"
+ d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
+ id="path3640"
+ <path
+ display="inline"
+ d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
+ id="path3642"
+ <path
+ display="inline"
+ d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
+ id="path3644"
+ <path
+ display="inline"
+ d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
+ id="path3646"
+ <path
+ display="inline"
+ d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
+ id="path3648"
+ <path
+ display="inline"
+ d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
+ id="path3650"
+ <path
+ display="inline"
+ d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
+ id="path3652"
+ <path
+ display="inline"
+ d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
+ id="path3654"
+ <path
+ display="inline"
+ d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
+ id="path3656"
+ </g>
+ <g
+ id="g3658">
+ <path
+ display="inline"
+ d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
+ id="path3660"
+ <path
+ display="inline"
+ d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
+ id="path3662"
+ <path
+ display="inline"
+ d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
+ id="path3664"
+ <path
+ display="inline"
+ d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
+ id="path3666"
+ <path
+ display="inline"
+ d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
+ id="path3668"
+ <path
+ display="inline"
+ d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
+ id="path3670"
+ <path
+ display="inline"
+ d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
+ id="path3672"
+ <path
+ display="inline"
+ d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
+ id="path3674"
+ <path
+ display="inline"
+ d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
+ id="path3676"
+ <path
+ display="inline"
+ d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
+ id="path3678"
+ <path
+ display="inline"
+ d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
+ id="path3680"
+ <path
+ display="inline"
+ d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
+ id="path3682"
+ <path
+ display="inline"
+ d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
+ id="path3684"
+ <path
+ display="inline"
+ d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
+ id="path3686"
+ <path
+ display="inline"
+ d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
+ id="path3688"
+ <path
+ display="inline"
+ d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
+ id="path3690"
+ <path
+ display="inline"
+ d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
+ id="path3692"
+ <path
+ display="inline"
+ d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
+ id="path3694"
+ <path
+ display="inline"
+ d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
+ id="path3696"
+ </g>
+ <g
+ id="g3698"
+ display="inline"
+ style="display:inline">
+ <path
+ d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
+ id="path3700"
+ style="fill:#0054a4" />
+ <path
+ d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
+ id="path3702"
+ <path
+ d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
+ id="path3704"
+ <path
+ d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
+ id="path3706"
+ <path
+ d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
+ id="path3708"
+ <path
+ d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
+ id="path3710"
+ <path
+ d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
+ id="path3712"
+ </g>
+ <g
+ id="g3714">
+ <path
+ display="inline"
+ d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
+ id="path3716"
+ style="fill:#a0ce67;display:inline" />
+ <path
+ display="inline"
+ d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
+ id="path3718"
+ <path
+ display="inline"
+ d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
+ id="path3720"
+ <path
+ display="inline"
+ d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
+ id="path3722"
+ <path
+ display="inline"
+ d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
+ id="path3724"
+ <path
+ display="inline"
+ d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
+ id="path3726"
+ <path
+ display="inline"
+ d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
+ id="path3728"
+ <path
+ display="inline"
+ d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
+ id="path3730"
+ <path
+ display="inline"
+ d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
+ id="path3732"
+ <path
+ display="inline"
+ d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
+ id="path3734"
+ <path
+ display="inline"
+ d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
+ id="path3736"
+ <path
+ display="inline"
+ d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
+ id="path3738"
+ <path
+ display="inline"
+ d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
+ id="path3740"
+ <path
+ display="inline"
+ d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
+ id="path3742"
+ <path
+ display="inline"
+ d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
+ id="path3744"
+ <path
+ display="inline"
+ d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
+ id="path3746"
+ <path
+ display="inline"
+ d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
+ id="path3748"
+ <path
+ display="inline"
+ d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
+ id="path3750"
+ <path
+ display="inline"
+ d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
+ id="path3752"
+ <path
+ display="inline"
+ d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
+ id="path3754"
+ <path
+ display="inline"
+ d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
+ id="path3756"
+ </g>
+</g><g
+ id="g3758"
+ display="none"
+ <path
+ display="inline"
+ d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
+ id="path3760"
+ style="fill:#49a942;display:inline" />
+ <path
+ display="inline"
+ d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
+ id="path3762"
+ <path
+ display="inline"
+ d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
+ id="path3764"
+ <path
+ display="inline"
+ d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
+ id="path3766"
+ <path
+ display="inline"
+ d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
+ id="path3768"
+</g><g
+ id="g224"
+ transform="matrix(2.0488681,0.7896489,-0.8745125,1.6999927,94.926736,-101.86634)"
+ style="fill:#008000">
+ <circle
+ sodipodi:ry="31.707001"
+ sodipodi:rx="31.707001"
+ sodipodi:cy="70.192001"
+ sodipodi:cx="55.669998"
+ id="circle226"
+ r="31.707001"
+ cy="70.192001"
+ cx="55.669998" />
+ </g><g
+ id="g230"
+ <polygon
+ style="fill:#008000;fill-rule:evenodd"
+ id="polygon232"
+ points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
+ clip-rule="evenodd" />
+ </g><path
+ style="fill:none"
+ id="path234"
+ d="" /><path
+ style="fill:none"
+ id="path236"
+ d="" /><g
+ id="Text"
+ display="none"
+ style="display:none">
+ <g
+ id="Associate">
+ <path
+ display="inline"
+ id="path5"
+ <path
+ display="inline"
+ id="path7"
+ <path
+ display="inline"
+ id="path9"
+ <path
+ display="inline"
+ id="path11"
+ <path
+ display="inline"
+ id="path13"
+ <path
+ display="inline"
+ id="path15"
+ <path
+ display="inline"
+ id="path17"
+ <path
+ display="inline"
+ id="path19"
+ <path
+ display="inline"
+ id="path21"
+ <path
+ display="inline"
+ id="path23"
+ <path
+ display="inline"
+ id="path25"
+ <path
+ display="inline"
+ id="path27"
+ <path
+ display="inline"
+ id="path29"
+ <path
+ display="inline"
+ id="path31"
+ <path
+ display="inline"
+ id="path33"
+ <path
+ display="inline"
+ id="path35"
+ <path
+ display="inline"
+ id="path37"
+ </g>
+ <g
+ id="Supporting">
+ <path
+ display="inline"
+ id="path40"
+ <path
+ display="inline"
+ id="path42"
+ <path
+ display="inline"
+ id="path44"
+ <path
+ display="inline"
+ id="path46"
+ <path
+ display="inline"
+ id="path48"
+ <path
+ display="inline"
+ id="path50"
+ <path
+ display="inline"
+ id="path52"
+ <path
+ display="inline"
+ id="path54"
+ <path
+ display="inline"
+ id="path56"
+ <path
+ display="inline"
+ id="path58"
+ <path
+ display="inline"
+ id="path60"
+ <path
+ display="inline"
+ id="path62"
+ <path
+ display="inline"
+ id="path64"
+ <path
+ display="inline"
+ id="path66"
+ <path
+ display="inline"
+ id="path68"
+ <path
+ display="inline"
+ id="path70"
+ <path
+ display="inline"
+ id="path72"
+ <path
+ display="inline"
+ id="path74"
+ </g>
+ <g
+ id="Sustaining">
+ <path
+ display="inline"
+ id="path77"
+ <path
+ display="inline"
+ id="path79"
+ <path
+ display="inline"
+ id="path81"
+ <path
+ display="inline"
+ id="path83"
+ <path
+ display="inline"
+ id="path85"
+ <path
+ display="inline"
+ id="path87"
+ <path
+ display="inline"
+ id="path89"
+ <path
+ display="inline"
+ id="path91"
+ <path
+ display="inline"
+ id="path93"
+ <path
+ display="inline"
+ id="path95"
+ <path
+ display="inline"
+ id="path97"
+ <path
+ display="inline"
+ id="path99"
+ <path
+ display="inline"
+ id="path101"
+ <path
+ display="inline"
+ id="path103"
+ <path
+ display="inline"
+ id="path105"
+ <path
+ display="inline"
+ id="path107"
+ <path
+ display="inline"
+ id="path109"
+ <path
+ display="inline"
+ id="path111"
+ </g>
+ <g
+ id="Incubation">
+ <path
+ display="inline"
+ id="path114"
+ <path
+ display="inline"
+ id="path116"
+ <path
+ display="inline"
+ id="path118"
+ <path
+ display="inline"
+ id="path120"
+ <path
+ display="inline"
+ id="path122"
+ <path
+ display="inline"
+ id="path124"
+ <path
+ display="inline"
+ id="path126"
+ <path
+ display="inline"
+ id="path128"
+ <path
+ display="inline"
+ id="path130"
+ <path
+ display="inline"
+ id="path132"
+ <path
+ display="inline"
+ id="path134"
+ <path
+ display="inline"
+ id="path136"
+ <path
+ display="inline"
+ id="path138"
+ <path
+ display="inline"
+ id="path140"
+ <path
+ display="inline"
+ id="path142"
+ <path
+ display="inline"
+ id="path144"
+ <path
+ display="inline"
+ id="path146"
+ <path
+ display="inline"
+ id="path148"
+ <path
+ display="inline"
+ id="path150"
+ </g>
+ <g
+ id="Project"
+ display="inline"
+ <path
+ id="path153"
+ <path
+ id="path155"
+ <path
+ id="path157"
+ <path
+ id="path159"
+ <path
+ id="path161"
+ <path
+ id="path163"
+ <path
+ id="path165"
+ </g>
+ <g
+ id="Your_Open_Source_Compass">
+ <path
+ display="inline"
+ id="path168"
+ <path
+ display="inline"
+ id="path170"
+ <path
+ display="inline"
+ id="path172"
+ <path
+ display="inline"
+ id="path174"
+ <path
+ display="inline"
+ id="path176"
+ <path
+ display="inline"
+ id="path178"
+ <path
+ display="inline"
+ id="path180"
+ <path
+ display="inline"
+ id="path182"
+ <path
+ display="inline"
+ id="path184"
+ <path
+ display="inline"
+ id="path186"
+ <path
+ display="inline"
+ id="path188"
+ <path
+ display="inline"
+ id="path190"
+ <path
+ display="inline"
+ id="path192"
+ <path
+ display="inline"
+ id="path194"
+ <path
+ display="inline"
+ id="path196"
+ <path
+ display="inline"
+ id="path198"
+ <path
+ display="inline"
+ id="path200"
+ <path
+ display="inline"
+ id="path202"
+ <path
+ display="inline"
+ id="path204"
+ <path
+ display="inline"
+ id="path206"
+ <path
+ display="inline"
+ id="path208"
+ </g>
+</g>
+<g
+ id="OSGeo"
+ display="none"
+ <path
+ display="inline"
+ id="path211"
+ <path
+ display="inline"
+ id="path213"
+ <path
+ display="inline"
+ id="path215"
+ <path
+ display="inline"
+ id="path217"
+ <path
+ display="inline"
+ id="path219"
+</g>
+<g
+ id="g844"
+ transform="matrix(0.4044353,0,0,0.4044353,44.395399,-41.669222)"><path
+ transform="matrix(1.04752,0,0,1.05,-36.7186,-19.064)"
+ style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
+ sodipodi:type="arc"
+ sodipodi:ry="218.44479"
+ sodipodi:rx="219.86943"
+ sodipodi:cy="257.81122"
+ sodipodi:cx="273.056"
+ id="path575"
+ d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /><path
+ style="fill:#00bd00;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
+ sodipodi:nodetypes="cccccccccc"
+ id="path580"
+ d="M 118.71999,81.155861 C 62.684157,159.03618 47.487998,116.29698 61.734397,159.98594 C 75.980792,203.67489 37.990399,236.91649 89.277432,202.72513 C 140.56447,168.53378 129.16735,121.04578 171.90655,157.13666 C 214.64575,193.22753 259.28446,148.58882 235.54047,206.52417 C 211.79647,264.45953 246.93759,348.98817 278.27966,249.26337 C 309.62174,149.53858 235.54047,202.72513 265.93278,130.54338 C 296.3251,58.361623 342.86334,42.215703 287.77726,29.868824 C 212.74623,67.859222 181.40415,114.39746 151.01183,90.653461 C 120.61951,66.909463 120.61951,82.105621 118.71999,81.155861 z" /><path
+ sodipodi:nodetypes="cccccccc"
+ id="path586"
+ d="M 405.5475,188.47874 C 395.10014,254.96193 400.7987,277.75617 366.60734,273.00737 C 332.41598,268.25857 303.92318,255.91169 328.61694,304.34945 C 353.3107,352.78721 413.14558,311.94753 380.85374,361.33505 C 348.5619,410.72256 373.25566,419.2704 303.92318,443.96416 C 234.59071,468.65792 255.48543,480.05504 262.13375,481.0048 C 308.67199,479.10528 464.43261,442.06465 479.62877,264.45953 C 446.38718,132.4429 406.49726,190.37826 405.5475,188.47874 z" /><path
+ id="path587"
+ d="M 83.578876,378.43073 C 98.775035,351.83745 101.62431,338.54081 120.61951,351.83745 C 139.61471,365.13409 125.36831,360.38529 160.50943,374.63169 C 195.65055,388.87809 187.10271,349.93793 207.99743,377.48097 C 228.89215,405.02401 202.29887,402.17473 194.70079,426.86848 C 187.10271,451.56224 136.76543,454.41152 136.76543,443.0144 C 136.76543,431.61728 96.875515,447.7632 83.578876,378.43073 z" /><path
+ style="fill:#b77719;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
+ sodipodi:nodetypes="ccccccc"
+ id="path606"
+ d="M 267.83231,69.758743 C 258.33471,61.210903 218.44479,116.29698 185.20319,114.39746 C 151.96159,112.49794 144.36351,112.49794 113.97119,122.9453 C 83.578875,133.39266 73.131516,183.72994 98.775031,175.1821 C 106.37311,143.84002 167.15775,119.14626 194.70079,130.54338 C 222.24383,141.9405 237.43999,164.73474 248.83711,173.28258 C 245.98783,110.59842 250.73663,109.64866 267.83231,69.758743 z" /><path
+ sodipodi:nodetypes="ccccc"
+ id="path607"
+ d="M 107.32287,381.28001 C 117.77023,389.82785 133.91615,408.82305 148.16255,394.57665 C 186.15295,392.67713 204.19839,379.38049 191.85151,399.32545 C 151.96159,404.07424 183.30367,431.61728 147.21279,435.41632 C 140.56447,428.768 80.729596,395.52641 107.32287,381.28001 z" /><path
+ id="path608"
+ d="M 432.14078,216.02178 C 431.19102,238.81601 468.23165,301.50017 432.14078,299.60065 C 396.0499,297.70113 376.10494,288.20353 378.95422,300.55041 C 381.8035,312.89729 425.49246,310.04801 425.49246,333.79201 C 425.49246,357.53601 381.8035,411.67232 362.8083,428.768 C 343.8131,445.86368 308.67198,454.41152 299.17438,464.85888 C 441.63837,461.05984 520.46845,233.11746 432.14078,216.02178 z" /><path
+ style="fill:url(#radialGradient579);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
+ id="path588"
+ d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /></g><path
+ style="fill:#ff0000"
+ id="path3827"
+ sodipodi:cx="211.1405"
+ sodipodi:cy="125.87266"
+ sodipodi:rx="48.595829"
+ sodipodi:ry="15.36075"
+ d="M 259.73633,125.87266 A 48.595829,15.36075 0 1 1 162.54467,125.87266 A 48.595829,15.36075 0 1 1 259.73633,125.87266 z"
+ transform="matrix(2.8312969,-2.8697982,2.968043,2.7375785,-823.30798,323.61993)" /><rect
+ style="fill:#ffffff;stroke:#ffffff;stroke-width:0;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
+ id="rect5077"
+ width="118.24126"
+ height="79.141182"
+ x="-0.74978393"
+ y="132.66359" /><path
+ style="fill:#ffffff;overflow:visible"
+ id="path3831"
+ transform="matrix(2.6583088,-2.5712068,2.3656048,2.8890136,-711.24771,239.70023)"
+ inkscape:transform-center-x="14.643913"
+ inkscape:transform-center-y="-12.23846" /><g
+ id="g5044"
+ transform="translate(-240.07435,-0.4346669)"><path
+ sodipodi:nodetypes="cssssz"
+ id="path4991"
+ d="M 411.9947,92.414881 C 380.30504,121.70083 328.17179,138.70697 313.17635,120.23247 C 298.1809,101.75797 290.20452,77.537893 292.80966,51.961217 C 298.01994,0.80785346 343.59299,-36.496733 394.53522,-31.307958 C 420.00633,-28.713571 442.02084,-15.984644 457.01628,2.4898569 C 472.01172,20.964358 443.47194,63.325235 411.9947,92.414881 z"
+ style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt" /><path
+ id="path4993"
+ d="M 332.27987,-7.587752 C 309.61701,23.909798 303.47114,6.624557 309.23289,24.293915 C 314.99463,41.963268 299.62998,55.407345 320.37226,41.579152 C 341.11455,27.750963 336.50516,8.5451393 353.7904,23.141565 C 371.07564,37.737987 389.12911,19.684517 379.5262,43.115618 C 369.92329,66.546722 384.1356,100.73309 396.81144,60.400859 C 409.48728,20.068633 379.5262,41.579152 391.81792,12.386304 C 404.10965,-16.806546 422.93136,-23.336526 400.6526,-28.33004 C 370.30741,-12.965382 357.63156,5.8563241 345.33983,-3.7465873 C 333.04811,-13.349498 333.04811,-7.2036355 332.27987,-7.587752 z" /><path
+ id="path4997"
+ d="M 310.16816,89.337436 C 316.31402,78.582176 317.46637,73.204543 325.1487,78.582176 C 332.83103,83.959806 327.06928,82.039226 341.28159,87.800966 C 355.4939,93.562716 352.03685,77.813936 360.48741,88.953316 C 368.93798,100.0927 358.18271,98.940346 355.10978,108.92737 C 352.03685,118.9144 331.67868,120.06675 331.67868,115.45735 C 331.67868,110.84796 315.54579,117.37794 310.16816,89.337436 z" /><path
+ id="path4999"
+ d="M 392.58616,-12.197149 C 388.745,-15.654197 372.6121,6.624557 359.16803,5.8563241 C 345.72395,5.0880911 342.65102,5.0880911 330.35929,9.3133723 C 318.06757,13.538653 313.84229,33.896826 324.21343,30.439778 C 327.28636,17.763935 351.86981,7.7769064 363.00919,12.386304 C 374.14857,16.995702 380.29443,26.214497 384.90383,29.671545 C 383.75148,4.3198582 385.67206,3.9357417 392.58616,-12.197149 z" /><path
+ id="path5001"
+ d="M 319.77107,90.489786 C 323.99635,93.946836 330.52633,101.62917 336.28808,95.867416 C 351.65273,95.099186 358.95095,89.721556 353.95743,97.787996 C 337.82454,99.708576 350.50038,110.84796 335.90396,112.38442 C 333.21514,109.69561 309.01581,96.251536 319.77107,90.489786 z" /></g><path
+ id="path5005"
+ style="fill:url(#radialGradient5042);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt;stroke:#a1ce67;stroke-opacity:1"
+ transform="matrix(0.4236541,0,0,0.4246571,644.63706,-29.556585)" /><text
+ xml:space="preserve"
+ style="font-size:58.81839752px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ x="1.943607"
+ y="150.67944"
+ id="text2616"
+ transform="matrix(0.7804736,1.1445518e-2,-1.5592994e-2,1.2810446,0,0)"><tspan
+ sodipodi:role="line"
+ id="tspan2618"
+ x="1.943607"
+ y="150.67944"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Sans;-inkscape-font-specification:Sans Bold">Ma<tspan
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#0000ff;font-family:Sans;-inkscape-font-specification:Sans Bold"
+ id="tspan3823">p</tspan><tspan
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#ff0000;font-family:Sans;-inkscape-font-specification:Sans Bold"
+ id="tspan3825">b</tspan>ender</tspan></text>
+</svg>
\ No newline at end of file
Copied: trunk/documents/logos/logo_contest/mapbender_grounded.svg (from rev 6635, trunk/documents/logos/mapbender_grounded.svg)
--- trunk/documents/logos/logo_contest/mapbender_grounded.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_grounded.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,621 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ version="1.0"
+ id="OSGeo_x5F_logo"
+ width="200"
+ height="200"
+ viewBox="0 0 296.647 125.463"
+ overflow="visible"
+ enable-background="new 0 0 296.647 125.463"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ sodipodi:docname="mapbender_grounded.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ style="overflow:visible"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_valley.png"
+ inkscape:export-xdpi="61.200001"
+ inkscape:export-ydpi="61.200001"><metadata
+ id="metadata241"><rdf:RDF><cc:Work
+ rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
+ id="defs239"><inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 62.731499 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="296.647 : 62.731499 : 1"
+ inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
+ id="perspective243" /></defs><sodipodi:namedview
+ inkscape:window-height="975"
+ inkscape:window-width="1400"
+ inkscape:pageshadow="2"
+ inkscape:pageopacity="0.0"
+ guidetolerance="10.0"
+ gridtolerance="10.0"
+ objecttolerance="10.0"
+ borderopacity="1.0"
+ bordercolor="#666666"
+ pagecolor="#ffffff"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="3.7553051"
+ inkscape:cx="90.265265"
+ inkscape:cy="99.562976"
+ inkscape:window-x="0"
+ inkscape:window-y="25"
+ inkscape:current-layer="OSGeo_x5F_logo" />
+<g
+ id="Text"
+ display="none"
+ <g
+ id="Associate">
+ <path
+ display="inline"
+ d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
+ id="path5"
+ style="fill:#0054a4;display:inline" />
+ <path
+ display="inline"
+ d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
+ id="path7"
+ <path
+ display="inline"
+ d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
+ id="path9"
+ <path
+ display="inline"
+ d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
+ id="path11"
+ <path
+ display="inline"
+ d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
+ id="path13"
+ <path
+ display="inline"
+ d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
+ id="path15"
+ <path
+ display="inline"
+ d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
+ id="path17"
+ <path
+ display="inline"
+ d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
+ id="path19"
+ <path
+ display="inline"
+ d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
+ id="path21"
+ <path
+ display="inline"
+ d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
+ id="path23"
+ <path
+ display="inline"
+ d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
+ id="path25"
+ <path
+ display="inline"
+ d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
+ id="path27"
+ <path
+ display="inline"
+ d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
+ id="path29"
+ <path
+ display="inline"
+ d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
+ id="path31"
+ <path
+ display="inline"
+ d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
+ id="path33"
+ <path
+ display="inline"
+ d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
+ id="path35"
+ <path
+ display="inline"
+ d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
+ id="path37"
+ </g>
+ <g
+ id="Supporting">
+ <path
+ display="inline"
+ d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
+ id="path40"
+ <path
+ display="inline"
+ d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
+ id="path42"
+ <path
+ display="inline"
+ d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
+ id="path44"
+ <path
+ display="inline"
+ d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
+ id="path46"
+ <path
+ display="inline"
+ d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
+ id="path48"
+ <path
+ display="inline"
+ d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
+ id="path50"
+ <path
+ display="inline"
+ d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
+ id="path52"
+ <path
+ display="inline"
+ d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
+ id="path54"
+ <path
+ display="inline"
+ d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
+ id="path56"
+ <path
+ display="inline"
+ d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
+ id="path58"
+ <path
+ display="inline"
+ d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
+ id="path60"
+ <path
+ display="inline"
+ d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
+ id="path62"
+ <path
+ display="inline"
+ d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
+ id="path64"
+ <path
+ display="inline"
+ d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
+ id="path66"
+ <path
+ display="inline"
+ d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
+ id="path68"
+ <path
+ display="inline"
+ d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
+ id="path70"
+ <path
+ display="inline"
+ d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
+ id="path72"
+ <path
+ display="inline"
+ d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
+ id="path74"
+ </g>
+ <g
+ id="Sustaining">
+ <path
+ display="inline"
+ d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
+ id="path77"
+ <path
+ display="inline"
+ d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
+ id="path79"
+ <path
+ display="inline"
+ d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
+ id="path81"
+ <path
+ display="inline"
+ d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
+ id="path83"
+ <path
+ display="inline"
+ d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
+ id="path85"
+ <path
+ display="inline"
+ d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
+ id="path87"
+ <path
+ display="inline"
+ d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
+ id="path89"
+ <path
+ display="inline"
+ d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
+ id="path91"
+ <path
+ display="inline"
+ d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
+ id="path93"
+ <path
+ display="inline"
+ d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
+ id="path95"
+ <path
+ display="inline"
+ d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
+ id="path97"
+ <path
+ display="inline"
+ d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
+ id="path99"
+ <path
+ display="inline"
+ d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
+ id="path101"
+ <path
+ display="inline"
+ d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
+ id="path103"
+ <path
+ display="inline"
+ d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
+ id="path105"
+ <path
+ display="inline"
+ d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
+ id="path107"
+ <path
+ display="inline"
+ d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
+ id="path109"
+ <path
+ display="inline"
+ d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
+ id="path111"
+ </g>
+ <g
+ id="Incubation">
+ <path
+ display="inline"
+ d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
+ id="path114"
+ <path
+ display="inline"
+ d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
+ id="path116"
+ <path
+ display="inline"
+ d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
+ id="path118"
+ <path
+ display="inline"
+ d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
+ id="path120"
+ <path
+ display="inline"
+ d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
+ id="path122"
+ <path
+ display="inline"
+ d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
+ id="path124"
+ <path
+ display="inline"
+ d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
+ id="path126"
+ <path
+ display="inline"
+ d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
+ id="path128"
+ <path
+ display="inline"
+ d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
+ id="path130"
+ <path
+ display="inline"
+ d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
+ id="path132"
+ <path
+ display="inline"
+ d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
+ id="path134"
+ <path
+ display="inline"
+ d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
+ id="path136"
+ <path
+ display="inline"
+ d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
+ id="path138"
+ <path
+ display="inline"
+ d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
+ id="path140"
+ <path
+ display="inline"
+ d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
+ id="path142"
+ <path
+ display="inline"
+ d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
+ id="path144"
+ <path
+ display="inline"
+ d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
+ id="path146"
+ <path
+ display="inline"
+ d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
+ id="path148"
+ <path
+ display="inline"
+ d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
+ id="path150"
+ </g>
+ <g
+ id="Project"
+ display="inline"
+ style="display:inline">
+ <path
+ d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
+ id="path153"
+ style="fill:#0054a4" />
+ <path
+ d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
+ id="path155"
+ <path
+ d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
+ id="path157"
+ <path
+ d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
+ id="path159"
+ <path
+ d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
+ id="path161"
+ <path
+ d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
+ id="path163"
+ <path
+ d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
+ id="path165"
+ </g>
+ <g
+ <path
+ display="inline"
+ d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
+ id="path168"
+ style="fill:#a0ce67;display:inline" />
+ <path
+ display="inline"
+ d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
+ id="path170"
+ <path
+ display="inline"
+ d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
+ id="path172"
+ <path
+ display="inline"
+ d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
+ id="path174"
+ <path
+ display="inline"
+ d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
+ id="path176"
+ <path
+ display="inline"
+ d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
+ id="path178"
+ <path
+ display="inline"
+ d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
+ id="path180"
+ <path
+ display="inline"
+ d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
+ id="path182"
+ <path
+ display="inline"
+ d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
+ id="path184"
+ <path
+ display="inline"
+ d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
+ id="path186"
+ <path
+ display="inline"
+ d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
+ id="path188"
+ <path
+ display="inline"
+ d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
+ id="path190"
+ <path
+ display="inline"
+ d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
+ id="path192"
+ <path
+ display="inline"
+ d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
+ id="path194"
+ <path
+ display="inline"
+ d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
+ id="path196"
+ <path
+ display="inline"
+ d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
+ id="path198"
+ <path
+ display="inline"
+ d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
+ id="path200"
+ <path
+ display="inline"
+ d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
+ id="path202"
+ <path
+ display="inline"
+ d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
+ id="path204"
+ <path
+ display="inline"
+ d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
+ id="path206"
+ <path
+ display="inline"
+ d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
+ id="path208"
+ </g>
+</g>
+<g
+ id="OSGeo"
+ display="none"
+ style="display:none">
+ <path
+ display="inline"
+ d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
+ id="path211"
+ style="fill:#49a942;display:inline" />
+ <path
+ display="inline"
+ d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
+ id="path213"
+ <path
+ display="inline"
+ d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
+ id="path215"
+ <path
+ display="inline"
+ d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
+ id="path217"
+ <path
+ display="inline"
+ d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
+ id="path219"
+</g>
+<text
+ style="font-size:57.60910416px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ x="12.559419"
+ y="60.615295"
+ id="text2616"
+ transform="scale(0.7428897,1.3460949)"><tspan
+ id="tspan2618"
+ x="12.559419"
+ y="60.615295"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:DejaVu Sans;-inkscape-font-specification:DejaVu Sans Bold">Mapbender</tspan></text>
+<path
+ style="fill:#008000"
+ d="M 282.40396,200.39079 L 13.034026,200.39079 L 13.034026,89.799034 L 87.288494,136.01059 L 282.40396,89.799034 L 282.40396,200.39079 z"
+ id="rect2660"
+ sodipodi:nodetypes="cccccc" /></svg>
Copied: trunk/documents/logos/logo_contest/mapbender_grounded_holy.svg (from rev 6635, trunk/documents/logos/mapbender_grounded_holy.svg)
--- trunk/documents/logos/logo_contest/mapbender_grounded_holy.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_grounded_holy.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,1218 @@
+<svg
+ version="1.0"
+ width="200"
+ height="200"
+ xml:space="preserve"
+ sodipodi:docname="mapbender_grounded_holy.svg"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_grounded_holy.png"
+ id="perspective243" /><inkscape:perspective
+ id="perspective3540"
+ sodipodi:type="inkscape:persp3d" /></defs><sodipodi:namedview
+ id="base"
+ showgrid="false"
+ inkscape:zoom="2.6554017"
+ inkscape:cy="97.814879"
+<g
+ id="g3542"
+ transform="matrix(0.9474644,0,0,1.1845289,1.3570637,11.670385)"><g
+ display="none"
+ id="g3544">
+ <g
+ id="g3546">
+ <path
+ id="path3548"
+ display="inline" />
+ <path
+ id="path3550"
+ <path
+ id="path3552"
+ <path
+ id="path3554"
+ <path
+ id="path3556"
+ <path
+ id="path3558"
+ <path
+ id="path3560"
+ <path
+ id="path3562"
+ <path
+ id="path3564"
+ <path
+ id="path3566"
+ <path
+ id="path3568"
+ <path
+ id="path3570"
+ <path
+ id="path3572"
+ <path
+ id="path3574"
+ <path
+ id="path3576"
+ <path
+ id="path3578"
+ <path
+ id="path3580"
+ </g>
+ <g
+ id="g3582">
+ <path
+ id="path3584"
+ <path
+ id="path3586"
+ <path
+ id="path3588"
+ <path
+ id="path3590"
+ <path
+ id="path3592"
+ <path
+ id="path3594"
+ <path
+ id="path3596"
+ <path
+ id="path3598"
+ <path
+ id="path3600"
+ <path
+ id="path3602"
+ <path
+ id="path3604"
+ <path
+ id="path3606"
+ <path
+ id="path3608"
+ <path
+ id="path3610"
+ <path
+ id="path3612"
+ <path
+ id="path3614"
+ <path
+ id="path3616"
+ <path
+ id="path3618"
+ </g>
+ <g
+ id="g3620">
+ <path
+ id="path3622"
+ <path
+ id="path3624"
+ <path
+ id="path3626"
+ <path
+ id="path3628"
+ <path
+ id="path3630"
+ <path
+ id="path3632"
+ <path
+ id="path3634"
+ <path
+ id="path3636"
+ <path
+ id="path3638"
+ <path
+ id="path3640"
+ <path
+ id="path3642"
+ <path
+ id="path3644"
+ <path
+ id="path3646"
+ <path
+ id="path3648"
+ <path
+ id="path3650"
+ <path
+ id="path3652"
+ <path
+ id="path3654"
+ <path
+ id="path3656"
+ </g>
+ <g
+ id="g3658">
+ <path
+ id="path3660"
+ <path
+ id="path3662"
+ <path
+ id="path3664"
+ <path
+ id="path3666"
+ <path
+ id="path3668"
+ <path
+ id="path3670"
+ <path
+ id="path3672"
+ <path
+ id="path3674"
+ <path
+ id="path3676"
+ <path
+ id="path3678"
+ <path
+ id="path3680"
+ <path
+ id="path3682"
+ <path
+ id="path3684"
+ <path
+ id="path3686"
+ <path
+ id="path3688"
+ <path
+ id="path3690"
+ <path
+ id="path3692"
+ <path
+ id="path3694"
+ <path
+ id="path3696"
+ </g>
+ <g
+ display="inline"
+ id="g3698">
+ <path
+ id="path3700"
+ d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z" />
+ <path
+ id="path3702"
+ d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z" />
+ <path
+ id="path3704"
+ d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z" />
+ <path
+ id="path3706"
+ d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z" />
+ <path
+ id="path3708"
+ d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z" />
+ <path
+ id="path3710"
+ d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z" />
+ <path
+ id="path3712"
+ d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z" />
+ </g>
+ <g
+ id="g3714">
+ <path
+ id="path3716"
+ <path
+ id="path3718"
+ <path
+ id="path3720"
+ <path
+ id="path3722"
+ <path
+ id="path3724"
+ <path
+ id="path3726"
+ <path
+ id="path3728"
+ <path
+ id="path3730"
+ <path
+ id="path3732"
+ <path
+ id="path3734"
+ <path
+ id="path3736"
+ <path
+ id="path3738"
+ <path
+ id="path3740"
+ <path
+ id="path3742"
+ <path
+ id="path3744"
+ <path
+ id="path3746"
+ <path
+ id="path3748"
+ <path
+ id="path3750"
+ <path
+ id="path3752"
+ <path
+ id="path3754"
+ <path
+ id="path3756"
+ </g>
+</g><g
+ display="none"
+ id="g3758">
+ <path
+ id="path3760"
+ <path
+ id="path3762"
+ <path
+ id="path3764"
+ <path
+ id="path3766"
+ <path
+ id="path3768"
+</g><g
+ transform="matrix(2.658509,0,0,1.0066382,2.3739382,-80.596613)"
+ id="Compass">
+ <path
+ style="fill:#49a942;fill-rule:evenodd"
+ id="path222"
+ d="M 54.232,117.368 C 28.032,116.453 7.532,94.47 8.447,68.269 C 9.361,42.065 31.345,21.569 57.546,22.484 C 75.658,23.117 91.043,33.819 98.515,49.021 C 99.665,49.057 100.817,49.06 101.976,48.846 C 94.225,31.979 77.475,20 57.657,19.308 C 29.667,18.33 6.187,40.227 5.209,68.219 C 4.233,96.205 26.127,119.687 54.118,120.665 C 61.711,120.929 68.969,119.499 75.539,116.731 C 75.222,115.748 75.025,114.623 74.698,113.516 C 68.439,116.223 61.5,117.621 54.232,117.368 z"
+ clip-rule="evenodd" />
+ <g
+ id="g224">
+ <circle
+ style="fill:#a0ce67"
+ sodipodi:ry="31.707001"
+ sodipodi:rx="31.707001"
+ sodipodi:cy="70.192001"
+ sodipodi:cx="55.669998"
+ id="circle226"
+ r="31.707001"
+ cy="70.192001"
+ cx="55.669998" />
+ </g>
+ <polygon
+ style="fill:#ffffff;stroke:#a0ce67;stroke-width:2;stroke-miterlimit:6"
+ id="polygon228"
+ points="61.494,53.061 26.327,4.407 38.873,63.876 3.379,93.238 49.515,86.588 78.884,121.407 72.411,75.859 107.593,46.548 61.494,53.061 "
+ stroke-miterlimit="6" />
+ <g
+ id="g230">
+ <polygon
+ id="polygon232"
+ points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
+ </g>
+ <path
+ style="fill:none"
+ id="path234"
+ d="" />
+ <path
+ style="fill:none"
+ id="path236"
+ d="" />
+</g></g><g
+ id="Text"
+ display="none"
+ <g
+ id="Associate">
+ <path
+ display="inline"
+ d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
+ id="path5"
+ style="fill:#0054a4;display:inline" />
+ <path
+ display="inline"
+ d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
+ id="path7"
+ <path
+ display="inline"
+ d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
+ id="path9"
+ <path
+ display="inline"
+ d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
+ id="path11"
+ <path
+ display="inline"
+ d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
+ id="path13"
+ <path
+ display="inline"
+ d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
+ id="path15"
+ <path
+ display="inline"
+ d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
+ id="path17"
+ <path
+ display="inline"
+ d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
+ id="path19"
+ <path
+ display="inline"
+ d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
+ id="path21"
+ <path
+ display="inline"
+ d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
+ id="path23"
+ <path
+ display="inline"
+ d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
+ id="path25"
+ <path
+ display="inline"
+ d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
+ id="path27"
+ <path
+ display="inline"
+ d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
+ id="path29"
+ <path
+ display="inline"
+ d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
+ id="path31"
+ <path
+ display="inline"
+ d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
+ id="path33"
+ <path
+ display="inline"
+ d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
+ id="path35"
+ <path
+ display="inline"
+ d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
+ id="path37"
+ </g>
+ <g
+ id="Supporting">
+ <path
+ display="inline"
+ d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
+ id="path40"
+ <path
+ display="inline"
+ d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
+ id="path42"
+ <path
+ display="inline"
+ d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
+ id="path44"
+ <path
+ display="inline"
+ d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
+ id="path46"
+ <path
+ display="inline"
+ d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
+ id="path48"
+ <path
+ display="inline"
+ d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
+ id="path50"
+ <path
+ display="inline"
+ d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
+ id="path52"
+ <path
+ display="inline"
+ d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
+ id="path54"
+ <path
+ display="inline"
+ d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
+ id="path56"
+ <path
+ display="inline"
+ d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
+ id="path58"
+ <path
+ display="inline"
+ d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
+ id="path60"
+ <path
+ display="inline"
+ d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
+ id="path62"
+ <path
+ display="inline"
+ d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
+ id="path64"
+ <path
+ display="inline"
+ d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
+ id="path66"
+ <path
+ display="inline"
+ d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
+ id="path68"
+ <path
+ display="inline"
+ d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
+ id="path70"
+ <path
+ display="inline"
+ d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
+ id="path72"
+ <path
+ display="inline"
+ d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
+ id="path74"
+ </g>
+ <g
+ id="Sustaining">
+ <path
+ display="inline"
+ d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
+ id="path77"
+ <path
+ display="inline"
+ d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
+ id="path79"
+ <path
+ display="inline"
+ d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
+ id="path81"
+ <path
+ display="inline"
+ d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
+ id="path83"
+ <path
+ display="inline"
+ d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
+ id="path85"
+ <path
+ display="inline"
+ d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
+ id="path87"
+ <path
+ display="inline"
+ d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
+ id="path89"
+ <path
+ display="inline"
+ d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
+ id="path91"
+ <path
+ display="inline"
+ d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
+ id="path93"
+ <path
+ display="inline"
+ d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
+ id="path95"
+ <path
+ display="inline"
+ d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
+ id="path97"
+ <path
+ display="inline"
+ d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
+ id="path99"
+ <path
+ display="inline"
+ d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
+ id="path101"
+ <path
+ display="inline"
+ d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
+ id="path103"
+ <path
+ display="inline"
+ d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
+ id="path105"
+ <path
+ display="inline"
+ d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
+ id="path107"
+ <path
+ display="inline"
+ d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
+ id="path109"
+ <path
+ display="inline"
+ d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
+ id="path111"
+ </g>
+ <g
+ id="Incubation">
+ <path
+ display="inline"
+ d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
+ id="path114"
+ <path
+ display="inline"
+ d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
+ id="path116"
+ <path
+ display="inline"
+ d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
+ id="path118"
+ <path
+ display="inline"
+ d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
+ id="path120"
+ <path
+ display="inline"
+ d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
+ id="path122"
+ <path
+ display="inline"
+ d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
+ id="path124"
+ <path
+ display="inline"
+ d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
+ id="path126"
+ <path
+ display="inline"
+ d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
+ id="path128"
+ <path
+ display="inline"
+ d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
+ id="path130"
+ <path
+ display="inline"
+ d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
+ id="path132"
+ <path
+ display="inline"
+ d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
+ id="path134"
+ <path
+ display="inline"
+ d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
+ id="path136"
+ <path
+ display="inline"
+ d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
+ id="path138"
+ <path
+ display="inline"
+ d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
+ id="path140"
+ <path
+ display="inline"
+ d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
+ id="path142"
+ <path
+ display="inline"
+ d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
+ id="path144"
+ <path
+ display="inline"
+ d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
+ id="path146"
+ <path
+ display="inline"
+ d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
+ id="path148"
+ <path
+ display="inline"
+ d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
+ id="path150"
+ </g>
+ <g
+ id="Project"
+ display="inline"
+ style="display:inline">
+ <path
+ id="path153"
+ style="fill:#0054a4" />
+ <path
+ id="path155"
+ <path
+ id="path157"
+ <path
+ id="path159"
+ <path
+ id="path161"
+ <path
+ id="path163"
+ <path
+ id="path165"
+ </g>
+ <g
+ id="Your_Open_Source_Compass">
+ <path
+ display="inline"
+ d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
+ id="path168"
+ style="fill:#a0ce67;display:inline" />
+ <path
+ display="inline"
+ d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
+ id="path170"
+ <path
+ display="inline"
+ d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
+ id="path172"
+ <path
+ display="inline"
+ d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
+ id="path174"
+ <path
+ display="inline"
+ d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
+ id="path176"
+ <path
+ display="inline"
+ d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
+ id="path178"
+ <path
+ display="inline"
+ d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
+ id="path180"
+ <path
+ display="inline"
+ d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
+ id="path182"
+ <path
+ display="inline"
+ d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
+ id="path184"
+ <path
+ display="inline"
+ d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
+ id="path186"
+ <path
+ display="inline"
+ d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
+ id="path188"
+ <path
+ display="inline"
+ d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
+ id="path190"
+ <path
+ display="inline"
+ d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
+ id="path192"
+ <path
+ display="inline"
+ d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
+ id="path194"
+ <path
+ display="inline"
+ d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
+ id="path196"
+ <path
+ display="inline"
+ d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
+ id="path198"
+ <path
+ display="inline"
+ d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
+ id="path200"
+ <path
+ display="inline"
+ d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
+ id="path202"
+ <path
+ display="inline"
+ d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
+ id="path204"
+ <path
+ display="inline"
+ d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
+ id="path206"
+ <path
+ display="inline"
+ d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
+ id="path208"
+ </g>
+</g>
+<g
+ id="OSGeo"
+ display="none"
+ style="display:none">
+ <path
+ display="inline"
+ d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
+ id="path211"
+ style="fill:#49a942;display:inline" />
+ <path
+ display="inline"
+ d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
+ id="path213"
+ <path
+ display="inline"
+ d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
+ id="path215"
+ <path
+ display="inline"
+ d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
+ id="path217"
+ <path
+ display="inline"
+ d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
+ id="path219"
+</g>
+<path
+ style="fill:#008000"
+ d="M 282.40396,200.39079 L 13.034026,200.39079 L 13.034026,89.799034 L 94.397964,142.72509 L 282.40396,89.799034 L 282.40396,200.39079 z"
+ id="rect2660"
+ sodipodi:nodetypes="cccccc" /><text
+ xml:space="preserve"
+ style="font-size:61.51377869px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ x="18.320276"
+ y="80.174667"
+ id="text2616"
+ transform="scale(0.6850773,1.4596893)"><tspan
+ sodipodi:role="line"
+ id="tspan2618"
+ x="18.320276"
+ y="80.174667"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Serif;-inkscape-font-specification:Serif Bold">Mapbender</tspan></text>
+</svg>
\ No newline at end of file
Copied: trunk/documents/logos/logo_contest/mapbender_hueben.svg (from rev 6635, trunk/documents/logos/mapbender_hueben.svg)
--- trunk/documents/logos/logo_contest/mapbender_hueben.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mapbender_hueben.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,1355 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ version="1.0"
+ id="OSGeo_x5F_logo"
+ width="200"
+ height="200"
+ viewBox="0 0 296.647 125.463"
+ overflow="visible"
+ enable-background="new 0 0 296.647 125.463"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ sodipodi:docname="mapbender_hueben.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ style="overflow:visible"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_hueben.png"
+ inkscape:export-xdpi="182.34"
+ inkscape:export-ydpi="182.34"><metadata
+ id="metadata241"><rdf:RDF><cc:Work
+ rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
+ id="defs239"><inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 62.731499 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="296.647 : 62.731499 : 1"
+ inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
+ id="perspective243" /><inkscape:perspective
+ id="perspective3540"
+ sodipodi:type="inkscape:persp3d" />
+<radialGradient
+ xlink:href="#linearGradient583"
+ r="0.40413386"
+ id="radialGradient582"
+ fy="0.22549020"
+ fx="0.68367344"
+ cy="0.22549020"
+ cx="0.68367344" /><radialGradient
+ r="123.08747"
+ id="radialGradient579"
+ fy="183.44996"
+ fx="201.95493"
+ cy="183.44996"
+ cx="201.95493"
+ gradientTransform="scale(1.0032556,0.996755)"
+ gradientUnits="userSpaceOnUse" /><linearGradient
+ id="linearGradient576"><stop
+ style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
+ offset="0.00000000"
+ id="stop577" /><stop
+ style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
+ offset="1.00000000"
+ id="stop578" /></linearGradient><linearGradient
+ id="linearGradient583"><stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
+ id="stop584" /><stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
+ id="stop585" /></linearGradient><inkscape:perspective
+ id="perspective4969"
+ inkscape:persp3d-origin="250 : 166.66667 : 1"
+ inkscape:vp_z="500 : 250 : 1"
+ inkscape:vp_x="0 : 250 : 1"
+ sodipodi:type="inkscape:persp3d" /><radialGradient
+ inkscape:collect="always"
+ id="radialGradient5042"
+ cx="201.95493"
+ cy="183.44996"
+ fx="201.95493"
+ fy="183.44996"
+ r="123.08747" /></defs><sodipodi:namedview
+ inkscape:window-height="975"
+ inkscape:window-width="1400"
+ inkscape:pageshadow="2"
+ inkscape:pageopacity="0.0"
+ guidetolerance="10.0"
+ gridtolerance="10.0"
+ objecttolerance="10.0"
+ borderopacity="1.0"
+ bordercolor="#666666"
+ pagecolor="#ffffff"
+ id="base"
+ showgrid="false"
+ inkscape:zoom="2.6554017"
+ inkscape:cx="104.70077"
+ inkscape:cy="101.78646"
+ inkscape:window-x="0"
+ inkscape:window-y="25"
+ inkscape:current-layer="OSGeo_x5F_logo" />
+<g
+ id="g3544"
+ display="none"
+ transform="matrix(0.4211728,0.182269,-0.4747632,1.0363122,6.5648762,-12.913196)">
+ <g
+ id="g3546">
+ <path
+ display="inline"
+ id="path3548"
+ <path
+ display="inline"
+ id="path3550"
+ <path
+ display="inline"
+ id="path3552"
+ <path
+ display="inline"
+ id="path3554"
+ <path
+ display="inline"
+ id="path3556"
+ <path
+ display="inline"
+ id="path3558"
+ <path
+ display="inline"
+ id="path3560"
+ <path
+ display="inline"
+ id="path3562"
+ <path
+ display="inline"
+ id="path3564"
+ <path
+ display="inline"
+ id="path3566"
+ <path
+ display="inline"
+ id="path3568"
+ <path
+ display="inline"
+ id="path3570"
+ <path
+ display="inline"
+ id="path3572"
+ <path
+ display="inline"
+ id="path3574"
+ <path
+ display="inline"
+ id="path3576"
+ <path
+ display="inline"
+ id="path3578"
+ <path
+ display="inline"
+ id="path3580"
+ </g>
+ <g
+ id="g3582">
+ <path
+ display="inline"
+ id="path3584"
+ <path
+ display="inline"
+ id="path3586"
+ <path
+ display="inline"
+ id="path3588"
+ <path
+ display="inline"
+ id="path3590"
+ <path
+ display="inline"
+ id="path3592"
+ <path
+ display="inline"
+ id="path3594"
+ <path
+ display="inline"
+ id="path3596"
+ <path
+ display="inline"
+ id="path3598"
+ <path
+ display="inline"
+ id="path3600"
+ <path
+ display="inline"
+ id="path3602"
+ <path
+ display="inline"
+ id="path3604"
+ <path
+ display="inline"
+ id="path3606"
+ <path
+ display="inline"
+ id="path3608"
+ <path
+ display="inline"
+ id="path3610"
+ <path
+ display="inline"
+ id="path3612"
+ <path
+ display="inline"
+ id="path3614"
+ <path
+ display="inline"
+ id="path3616"
+ <path
+ display="inline"
+ id="path3618"
+ </g>
+ <g
+ id="g3620">
+ <path
+ display="inline"
+ id="path3622"
+ <path
+ display="inline"
+ id="path3624"
+ <path
+ display="inline"
+ id="path3626"
+ <path
+ display="inline"
+ id="path3628"
+ <path
+ display="inline"
+ id="path3630"
+ <path
+ display="inline"
+ id="path3632"
+ <path
+ display="inline"
+ id="path3634"
+ <path
+ display="inline"
+ id="path3636"
+ <path
+ display="inline"
+ id="path3638"
+ <path
+ display="inline"
+ id="path3640"
+ <path
+ display="inline"
+ id="path3642"
+ <path
+ display="inline"
+ id="path3644"
+ <path
+ display="inline"
+ id="path3646"
+ <path
+ display="inline"
+ id="path3648"
+ <path
+ display="inline"
+ id="path3650"
+ <path
+ display="inline"
+ id="path3652"
+ <path
+ display="inline"
+ id="path3654"
+ <path
+ display="inline"
+ id="path3656"
+ </g>
+ <g
+ id="g3658">
+ <path
+ display="inline"
+ id="path3660"
+ <path
+ display="inline"
+ id="path3662"
+ <path
+ display="inline"
+ id="path3664"
+ <path
+ display="inline"
+ id="path3666"
+ <path
+ display="inline"
+ id="path3668"
+ <path
+ display="inline"
+ id="path3670"
+ <path
+ display="inline"
+ id="path3672"
+ <path
+ display="inline"
+ id="path3674"
+ <path
+ display="inline"
+ id="path3676"
+ <path
+ display="inline"
+ id="path3678"
+ <path
+ display="inline"
+ id="path3680"
+ <path
+ display="inline"
+ id="path3682"
+ <path
+ display="inline"
+ id="path3684"
+ <path
+ display="inline"
+ id="path3686"
+ <path
+ display="inline"
+ id="path3688"
+ <path
+ display="inline"
+ id="path3690"
+ <path
+ display="inline"
+ id="path3692"
+ <path
+ display="inline"
+ id="path3694"
+ <path
+ display="inline"
+ id="path3696"
+ </g>
+ <g
+ id="g3698"
+ display="inline"
+ <path
+ d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
+ id="path3700"
+ <path
+ d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
+ id="path3702"
+ <path
+ d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
+ id="path3704"
+ <path
+ d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
+ id="path3706"
+ <path
+ d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
+ id="path3708"
+ <path
+ d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
+ id="path3710"
+ <path
+ d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
+ id="path3712"
+ </g>
+ <g
+ id="g3714">
+ <path
+ display="inline"
+ id="path3716"
+ <path
+ display="inline"
+ id="path3718"
+ <path
+ display="inline"
+ id="path3720"
+ <path
+ display="inline"
+ id="path3722"
+ <path
+ display="inline"
+ id="path3724"
+ <path
+ display="inline"
+ id="path3726"
+ <path
+ display="inline"
+ id="path3728"
+ <path
+ display="inline"
+ id="path3730"
+ <path
+ display="inline"
+ id="path3732"
+ <path
+ display="inline"
+ id="path3734"
+ <path
+ display="inline"
+ id="path3736"
+ <path
+ display="inline"
+ id="path3738"
+ <path
+ display="inline"
+ id="path3740"
+ <path
+ display="inline"
+ id="path3742"
+ <path
+ display="inline"
+ id="path3744"
+ <path
+ display="inline"
+ id="path3746"
+ <path
+ display="inline"
+ id="path3748"
+ <path
+ display="inline"
+ id="path3750"
+ <path
+ display="inline"
+ id="path3752"
+ <path
+ display="inline"
+ id="path3754"
+ <path
+ display="inline"
+ id="path3756"
+ </g>
+</g><g
+ id="g3758"
+ display="none"
+ <path
+ display="inline"
+ id="path3760"
+ <path
+ display="inline"
+ id="path3762"
+ <path
+ display="inline"
+ id="path3764"
+ <path
+ display="inline"
+ id="path3766"
+ <path
+ display="inline"
+ id="path3768"
+</g><g
+ id="g224"
+ transform="matrix(2.0488681,0.7896489,-0.8745125,1.6999927,94.926736,-101.86634)"
+ style="fill:#008000">
+ <circle
+ sodipodi:ry="31.707001"
+ sodipodi:rx="31.707001"
+ sodipodi:cy="70.192001"
+ sodipodi:cx="55.669998"
+ id="circle226"
+ r="31.707001"
+ cy="70.192001"
+ cx="55.669998" />
+ </g><polygon
+ style="fill:#ffffff;stroke:#a1ce67;stroke-width:2;stroke-miterlimit:6;stroke-opacity:1"
+ id="polygon228"
+ points="61.494,53.061 26.327,4.407 38.873,63.876 3.379,93.238 49.515,86.588 78.884,121.407 72.411,75.859 107.593,46.548 61.494,53.061 "
+ stroke-miterlimit="6"
+ transform="matrix(2.0488681,0.7896489,-0.8745125,1.6999927,94.926736,-101.86634)" /><g
+ id="g230"
+ <polygon
+ style="fill:#008000;fill-rule:evenodd"
+ id="polygon232"
+ points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
+ clip-rule="evenodd" />
+ </g><path
+ style="fill:none"
+ id="path234"
+ d="" /><path
+ style="fill:none"
+ id="path236"
+ d="" /><g
+ id="Text"
+ display="none"
+ <g
+ id="Associate">
+ <path
+ display="inline"
+ d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
+ id="path5"
+ style="fill:#0054a4;display:inline" />
+ <path
+ display="inline"
+ d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
+ id="path7"
+ <path
+ display="inline"
+ d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
+ id="path9"
+ <path
+ display="inline"
+ d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
+ id="path11"
+ <path
+ display="inline"
+ d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
+ id="path13"
+ <path
+ display="inline"
+ d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
+ id="path15"
+ <path
+ display="inline"
+ d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
+ id="path17"
+ <path
+ display="inline"
+ d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
+ id="path19"
+ <path
+ display="inline"
+ d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
+ id="path21"
+ <path
+ display="inline"
+ d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
+ id="path23"
+ <path
+ display="inline"
+ d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
+ id="path25"
+ <path
+ display="inline"
+ d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
+ id="path27"
+ <path
+ display="inline"
+ d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
+ id="path29"
+ <path
+ display="inline"
+ d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
+ id="path31"
+ <path
+ display="inline"
+ d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
+ id="path33"
+ <path
+ display="inline"
+ d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
+ id="path35"
+ <path
+ display="inline"
+ d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
+ id="path37"
+ </g>
+ <g
+ id="Supporting">
+ <path
+ display="inline"
+ d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
+ id="path40"
+ <path
+ display="inline"
+ d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
+ id="path42"
+ <path
+ display="inline"
+ d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
+ id="path44"
+ <path
+ display="inline"
+ d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
+ id="path46"
+ <path
+ display="inline"
+ d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
+ id="path48"
+ <path
+ display="inline"
+ d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
+ id="path50"
+ <path
+ display="inline"
+ d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
+ id="path52"
+ <path
+ display="inline"
+ d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
+ id="path54"
+ <path
+ display="inline"
+ d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
+ id="path56"
+ <path
+ display="inline"
+ d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
+ id="path58"
+ <path
+ display="inline"
+ d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
+ id="path60"
+ <path
+ display="inline"
+ d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
+ id="path62"
+ <path
+ display="inline"
+ d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
+ id="path64"
+ <path
+ display="inline"
+ d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
+ id="path66"
+ <path
+ display="inline"
+ d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
+ id="path68"
+ <path
+ display="inline"
+ d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
+ id="path70"
+ <path
+ display="inline"
+ d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
+ id="path72"
+ <path
+ display="inline"
+ d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
+ id="path74"
+ </g>
+ <g
+ id="Sustaining">
+ <path
+ display="inline"
+ d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
+ id="path77"
+ <path
+ display="inline"
+ d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
+ id="path79"
+ <path
+ display="inline"
+ d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
+ id="path81"
+ <path
+ display="inline"
+ d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
+ id="path83"
+ <path
+ display="inline"
+ d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
+ id="path85"
+ <path
+ display="inline"
+ d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
+ id="path87"
+ <path
+ display="inline"
+ d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
+ id="path89"
+ <path
+ display="inline"
+ d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
+ id="path91"
+ <path
+ display="inline"
+ d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
+ id="path93"
+ <path
+ display="inline"
+ d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
+ id="path95"
+ <path
+ display="inline"
+ d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
+ id="path97"
+ <path
+ display="inline"
+ d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
+ id="path99"
+ <path
+ display="inline"
+ d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
+ id="path101"
+ <path
+ display="inline"
+ d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
+ id="path103"
+ <path
+ display="inline"
+ d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
+ id="path105"
+ <path
+ display="inline"
+ d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
+ id="path107"
+ <path
+ display="inline"
+ d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
+ id="path109"
+ <path
+ display="inline"
+ d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
+ id="path111"
+ </g>
+ <g
+ id="Incubation">
+ <path
+ display="inline"
+ d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
+ id="path114"
+ <path
+ display="inline"
+ d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
+ id="path116"
+ <path
+ display="inline"
+ d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
+ id="path118"
+ <path
+ display="inline"
+ d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
+ id="path120"
+ <path
+ display="inline"
+ d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
+ id="path122"
+ <path
+ display="inline"
+ d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
+ id="path124"
+ <path
+ display="inline"
+ d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
+ id="path126"
+ <path
+ display="inline"
+ d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
+ id="path128"
+ <path
+ display="inline"
+ d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
+ id="path130"
+ <path
+ display="inline"
+ d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
+ id="path132"
+ <path
+ display="inline"
+ d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
+ id="path134"
+ <path
+ display="inline"
+ d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
+ id="path136"
+ <path
+ display="inline"
+ d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
+ id="path138"
+ <path
+ display="inline"
+ d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
+ id="path140"
+ <path
+ display="inline"
+ d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
+ id="path142"
+ <path
+ display="inline"
+ d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
+ id="path144"
+ <path
+ display="inline"
+ d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
+ id="path146"
+ <path
+ display="inline"
+ d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
+ id="path148"
+ <path
+ display="inline"
+ d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
+ id="path150"
+ </g>
+ <g
+ id="Project"
+ display="inline"
+ style="display:inline">
+ <path
+ id="path153"
+ style="fill:#0054a4" />
+ <path
+ id="path155"
+ <path
+ id="path157"
+ <path
+ id="path159"
+ <path
+ id="path161"
+ <path
+ id="path163"
+ <path
+ id="path165"
+ </g>
+ <g
+ id="Your_Open_Source_Compass">
+ <path
+ display="inline"
+ d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
+ id="path168"
+ style="fill:#a0ce67;display:inline" />
+ <path
+ display="inline"
+ d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
+ id="path170"
+ <path
+ display="inline"
+ d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
+ id="path172"
+ <path
+ display="inline"
+ d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
+ id="path174"
+ <path
+ display="inline"
+ d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
+ id="path176"
+ <path
+ display="inline"
+ d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
+ id="path178"
+ <path
+ display="inline"
+ d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
+ id="path180"
+ <path
+ display="inline"
+ d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
+ id="path182"
+ <path
+ display="inline"
+ d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
+ id="path184"
+ <path
+ display="inline"
+ d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
+ id="path186"
+ <path
+ display="inline"
+ d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
+ id="path188"
+ <path
+ display="inline"
+ d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
+ id="path190"
+ <path
+ display="inline"
+ d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
+ id="path192"
+ <path
+ display="inline"
+ d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
+ id="path194"
+ <path
+ display="inline"
+ d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
+ id="path196"
+ <path
+ display="inline"
+ d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
+ id="path198"
+ <path
+ display="inline"
+ d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
+ id="path200"
+ <path
+ display="inline"
+ d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
+ id="path202"
+ <path
+ display="inline"
+ d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
+ id="path204"
+ <path
+ display="inline"
+ d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
+ id="path206"
+ <path
+ display="inline"
+ d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
+ id="path208"
+ </g>
+</g>
+<g
+ id="OSGeo"
+ display="none"
+ style="display:none">
+ <path
+ display="inline"
+ d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
+ id="path211"
+ style="fill:#49a942;display:inline" />
+ <path
+ display="inline"
+ d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
+ id="path213"
+ <path
+ display="inline"
+ d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
+ id="path215"
+ <path
+ display="inline"
+ d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
+ id="path217"
+ <path
+ display="inline"
+ d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
+ id="path219"
+</g>
+<g
+ id="g844"
+ transform="matrix(0.4044353,0,0,0.4044353,44.395399,-41.669222)"><path
+ transform="matrix(1.04752,0,0,1.05,-36.7186,-19.064)"
+ style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
+ sodipodi:type="arc"
+ sodipodi:ry="218.44479"
+ sodipodi:rx="219.86943"
+ sodipodi:cy="257.81122"
+ sodipodi:cx="273.056"
+ id="path575"
+ d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /><path
+ style="fill:#00bd00;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
+ sodipodi:nodetypes="cccccccccc"
+ id="path580"
+ d="M 118.71999,81.155861 C 62.684157,159.03618 47.487998,116.29698 61.734397,159.98594 C 75.980792,203.67489 37.990399,236.91649 89.277432,202.72513 C 140.56447,168.53378 129.16735,121.04578 171.90655,157.13666 C 214.64575,193.22753 259.28446,148.58882 235.54047,206.52417 C 211.79647,264.45953 246.93759,348.98817 278.27966,249.26337 C 309.62174,149.53858 235.54047,202.72513 265.93278,130.54338 C 296.3251,58.361623 342.86334,42.215703 287.77726,29.868824 C 212.74623,67.859222 181.40415,114.39746 151.01183,90.653461 C 120.61951,66.909463 120.61951,82.105621 118.71999,81.155861 z" /><path
+ sodipodi:nodetypes="cccccccc"
+ id="path586"
+ d="M 405.5475,188.47874 C 395.10014,254.96193 400.7987,277.75617 366.60734,273.00737 C 332.41598,268.25857 303.92318,255.91169 328.61694,304.34945 C 353.3107,352.78721 413.14558,311.94753 380.85374,361.33505 C 348.5619,410.72256 373.25566,419.2704 303.92318,443.96416 C 234.59071,468.65792 255.48543,480.05504 262.13375,481.0048 C 308.67199,479.10528 464.43261,442.06465 479.62877,264.45953 C 446.38718,132.4429 406.49726,190.37826 405.5475,188.47874 z" /><path
+ id="path587"
+ d="M 83.578876,378.43073 C 98.775035,351.83745 101.62431,338.54081 120.61951,351.83745 C 139.61471,365.13409 125.36831,360.38529 160.50943,374.63169 C 195.65055,388.87809 187.10271,349.93793 207.99743,377.48097 C 228.89215,405.02401 202.29887,402.17473 194.70079,426.86848 C 187.10271,451.56224 136.76543,454.41152 136.76543,443.0144 C 136.76543,431.61728 96.875515,447.7632 83.578876,378.43073 z" /><path
+ style="fill:#b77719;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
+ sodipodi:nodetypes="ccccccc"
+ id="path606"
+ d="M 267.83231,69.758743 C 258.33471,61.210903 218.44479,116.29698 185.20319,114.39746 C 151.96159,112.49794 144.36351,112.49794 113.97119,122.9453 C 83.578875,133.39266 73.131516,183.72994 98.775031,175.1821 C 106.37311,143.84002 167.15775,119.14626 194.70079,130.54338 C 222.24383,141.9405 237.43999,164.73474 248.83711,173.28258 C 245.98783,110.59842 250.73663,109.64866 267.83231,69.758743 z" /><path
+ sodipodi:nodetypes="ccccc"
+ id="path607"
+ d="M 107.32287,381.28001 C 117.77023,389.82785 133.91615,408.82305 148.16255,394.57665 C 186.15295,392.67713 204.19839,379.38049 191.85151,399.32545 C 151.96159,404.07424 183.30367,431.61728 147.21279,435.41632 C 140.56447,428.768 80.729596,395.52641 107.32287,381.28001 z" /><path
+ id="path608"
+ d="M 432.14078,216.02178 C 431.19102,238.81601 468.23165,301.50017 432.14078,299.60065 C 396.0499,297.70113 376.10494,288.20353 378.95422,300.55041 C 381.8035,312.89729 425.49246,310.04801 425.49246,333.79201 C 425.49246,357.53601 381.8035,411.67232 362.8083,428.768 C 343.8131,445.86368 308.67198,454.41152 299.17438,464.85888 C 441.63837,461.05984 520.46845,233.11746 432.14078,216.02178 z" /><path
+ style="fill:url(#radialGradient579);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
+ id="path588"
+ d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /></g><path
+ style="fill:#ff0000"
+ id="path3827"
+ sodipodi:cx="211.1405"
+ sodipodi:cy="125.87266"
+ sodipodi:rx="48.595829"
+ sodipodi:ry="15.36075"
+ d="M 259.73633,125.87266 A 48.595829,15.36075 0 1 1 162.54467,125.87266 A 48.595829,15.36075 0 1 1 259.73633,125.87266 z"
+ transform="matrix(2.8312969,-2.8697982,2.968043,2.7375785,-823.30798,323.61993)" /><path
+ style="fill:#ffffff;overflow:visible"
+ id="path3831"
+ transform="matrix(2.6583088,-2.5712068,2.3656048,2.8890136,-711.24771,239.70023)"
+ inkscape:transform-center-x="14.643913"
+ inkscape:transform-center-y="-12.23846" /><g
+ id="g5044"
+ transform="translate(-240.07435,-0.4346669)"><path
+ sodipodi:nodetypes="cssssz"
+ id="path4991"
+ d="M 411.9947,92.414881 C 380.30504,121.70083 328.17179,138.70697 313.17635,120.23247 C 298.1809,101.75797 290.20452,77.537893 292.80966,51.961217 C 298.01994,0.80785346 343.59299,-36.496733 394.53522,-31.307958 C 420.00633,-28.713571 442.02084,-15.984644 457.01628,2.4898569 C 472.01172,20.964358 443.47194,63.325235 411.9947,92.414881 z"
+ style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt" /><path
+ id="path4993"
+ d="M 332.27987,-7.587752 C 309.61701,23.909798 303.47114,6.624557 309.23289,24.293915 C 314.99463,41.963268 299.62998,55.407345 320.37226,41.579152 C 341.11455,27.750963 336.50516,8.5451393 353.7904,23.141565 C 371.07564,37.737987 389.12911,19.684517 379.5262,43.115618 C 369.92329,66.546722 384.1356,100.73309 396.81144,60.400859 C 409.48728,20.068633 379.5262,41.579152 391.81792,12.386304 C 404.10965,-16.806546 422.93136,-23.336526 400.6526,-28.33004 C 370.30741,-12.965382 357.63156,5.8563241 345.33983,-3.7465873 C 333.04811,-13.349498 333.04811,-7.2036355 332.27987,-7.587752 z" /><path
+ id="path4997"
+ d="M 310.16816,89.337436 C 316.31402,78.582176 317.46637,73.204543 325.1487,78.582176 C 332.83103,83.959806 327.06928,82.039226 341.28159,87.800966 C 355.4939,93.562716 352.03685,77.813936 360.48741,88.953316 C 368.93798,100.0927 358.18271,98.940346 355.10978,108.92737 C 352.03685,118.9144 331.67868,120.06675 331.67868,115.45735 C 331.67868,110.84796 315.54579,117.37794 310.16816,89.337436 z" /><path
+ id="path4999"
+ d="M 392.58616,-12.197149 C 388.745,-15.654197 372.6121,6.624557 359.16803,5.8563241 C 345.72395,5.0880911 342.65102,5.0880911 330.35929,9.3133723 C 318.06757,13.538653 313.84229,33.896826 324.21343,30.439778 C 327.28636,17.763935 351.86981,7.7769064 363.00919,12.386304 C 374.14857,16.995702 380.29443,26.214497 384.90383,29.671545 C 383.75148,4.3198582 385.67206,3.9357417 392.58616,-12.197149 z" /><path
+ id="path5001"
+ d="M 319.77107,90.489786 C 323.99635,93.946836 330.52633,101.62917 336.28808,95.867416 C 351.65273,95.099186 358.95095,89.721556 353.95743,97.787996 C 337.82454,99.708576 350.50038,110.84796 335.90396,112.38442 C 333.21514,109.69561 309.01581,96.251536 319.77107,90.489786 z" /></g><path
+ id="path5005"
+ style="fill:url(#radialGradient5042);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt;stroke:#a1ce67;stroke-opacity:1"
+ transform="matrix(0.4236541,0,0,0.4246571,644.63706,-29.556585)" /><text
+ xml:space="preserve"
+ style="font-size:68.2170105px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ x="1.238516"
+ y="123.91986"
+ id="text2616"
+ transform="matrix(0.6729437,1.3274402e-2,-1.3444666e-2,1.4857432,0,0)"><tspan
+ sodipodi:role="line"
+ id="tspan2618"
+ x="1.238516"
+ y="123.91986"
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Sans;-inkscape-font-specification:Sans Bold">Ma<tspan
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#0000ff;font-family:Sans;-inkscape-font-specification:Sans Bold"
+ id="tspan3823">p</tspan><tspan
+ style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#ff0000;font-family:Sans;-inkscape-font-specification:Sans Bold"
+ id="tspan3825">b</tspan>ender</tspan></text>
+</svg>
\ No newline at end of file
Copied: trunk/documents/logos/logo_contest/mb_db2.svg (from rev 6635, trunk/documents/logos/mb_db2.svg)
--- trunk/documents/logos/logo_contest/mb_db2.svg (rev 0)
+++ trunk/documents/logos/logo_contest/mb_db2.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,254 @@
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<!-- Created with Inkscape (http://www.inkscape.org/) -->
+<svg
+ xmlns:dc="http://purl.org/dc/elements/1.1/"
+ xmlns:cc="http://creativecommons.org/ns#"
+ xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:svg="http://www.w3.org/2000/svg"
+ xmlns="http://www.w3.org/2000/svg"
+ xmlns:xlink="http://www.w3.org/1999/xlink"
+ xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
+ xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
+ width="1000"
+ height="1000"
+ id="svg2"
+ sodipodi:version="0.32"
+ inkscape:version="0.46"
+ version="1.0"
+ sodipodi:docname="mb_db2.svg"
+ inkscape:output_extension="org.inkscape.output.svg.inkscape"
+ inkscape:export-filename="/home/seven/data/work/mapbender/logo/mb_db.png"
+ inkscape:export-xdpi="12.24"
+ inkscape:export-ydpi="12.24">
+ <defs
+ id="defs4">
+ <inkscape:perspective
+ sodipodi:type="inkscape:persp3d"
+ inkscape:vp_x="0 : 526.18109 : 1"
+ inkscape:vp_y="0 : 1000 : 0"
+ inkscape:vp_z="744.09448 : 526.18109 : 1"
+ inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
+ id="perspective10" />
+ id="perspective2447"
+ sodipodi:type="inkscape:persp3d" />
+ <radialGradient
+ xlink:href="#linearGradient583"
+ r="0.40413386"
+ id="radialGradient582"
+ fy="0.22549020"
+ fx="0.68367344"
+ cy="0.22549020"
+ cx="0.68367344" />
+ <radialGradient
+ r="123.08747"
+ id="radialGradient579"
+ fy="183.44996"
+ fx="201.95493"
+ cy="183.44996"
+ cx="201.95493"
+ gradientTransform="scale(1.0032556,0.996755)"
+ gradientUnits="userSpaceOnUse" />
+ <linearGradient
+ id="linearGradient576">
+ <stop
+ style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
+ offset="0.00000000"
+ id="stop577" />
+ <stop
+ style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
+ offset="1.00000000"
+ id="stop578" />
+ </linearGradient>
+ <linearGradient
+ id="linearGradient583">
+ <stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
+ id="stop584" />
+ <stop
+ style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
+ id="stop585" />
+ </linearGradient>
+ id="perspective3349"
+ inkscape:persp3d-origin="250 : 166.66667 : 1"
+ inkscape:vp_z="500 : 250 : 1"
+ inkscape:vp_x="0 : 250 : 1"
+ </defs>
+ <sodipodi:namedview
+ id="base"
+ pagecolor="#ffffff"
+ bordercolor="#666666"
+ borderopacity="1.0"
+ gridtolerance="10000"
+ guidetolerance="10"
+ objecttolerance="10"
+ inkscape:pageopacity="0.0"
+ inkscape:pageshadow="2"
+ inkscape:zoom="0.45254834"
+ inkscape:cx="365.28142"
+ inkscape:cy="484.30843"
+ inkscape:document-units="px"
+ inkscape:current-layer="layer1"
+ showgrid="false"
+ inkscape:window-width="1400"
+ inkscape:window-height="975"
+ inkscape:window-x="0"
+ inkscape:window-y="25" />
+ <metadata
+ id="metadata7">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:format>image/svg+xml</dc:format>
+ <dc:type
+ rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ inkscape:label="Layer 1"
+ inkscape:groupmode="layer"
+ id="layer1">
+ <rect
+ style="opacity:1;fill:#ffffff;fill-opacity:1;stroke:#000000;stroke-width:0;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
+ id="rect3371"
+ width="1000.1917"
+ height="766.09583"
+ x="2.7612932"
+ y="-0.63721448" />
+ <path
+ style="opacity:1;fill:#008000;fill-opacity:1;stroke:#d4d6d8;stroke-width:0;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1"
+ id="path3450"
+ sodipodi:cx="-234.35539"
+ sodipodi:cy="-1101.1173"
+ sodipodi:rx="387.89859"
+ sodipodi:ry="161.6244"
+ d="M 153.5432,-1101.1173 A 387.89859,161.6244 0 1 1 -622.25398,-1101.1173 A 387.89859,161.6244 0 1 1 153.5432,-1101.1173 z"
+ transform="matrix(1.2493404,0,0,0.9308082,801.77636,1615.5572)" />
+ <rect
+ id="rect3454"
+ width="969.23474"
+ height="421.23575"
+ x="24.470806"
+ y="167.30396" />
+ <path
+ style="opacity:1;fill:#ff0000;fill-opacity:1;stroke:#d4d6d8;stroke-width:0;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1"
+ id="path3448"
+ transform="matrix(1.2493404,0,0,0.9308082,804.275,1180.9121)" />
+ <g
+ id="g3476"
+ transform="matrix(-1.5308565,-0.3451449,0.3520797,-1.5616152,915.4743,1764.1036)">
+ <path
+ sodipodi:nodetypes="csscscc"
+ id="path3239"
+ d="M 648.126,630.73462 C 653.80739,657.21094 687.19916,734.83462 638.31741,763.48641 C 589.43567,792.13825 586.72198,782.30677 474.70917,797.81815 C 352.72151,814.71084 304.14617,870.40061 250.00929,873.8446 C 195.87243,877.28862 163.86111,747.11099 181.0472,726.18465 C 249.16702,643.23977 329.46623,615.6431 404.25244,588.3884 C 576.14643,556.14803 636.76323,577.78199 648.126,630.73462 z"
+ style="fill:#0000ff;fill-opacity:1;stroke:#000000;stroke-width:8.69787884;stroke-opacity:1" />
+ <path
+ id="path580"
+ d="M 276.13146,653.57693 C 226.46511,698.77358 208.55775,684.63958 225.59757,699.38662 C 242.63738,714.13365 207.60587,736.69258 255.64106,710.65366 C 303.67625,684.61475 292.74446,721.92181 337.26265,726.91279 C 381.78084,731.90377 367.55505,686.66252 398.95738,726.11846 C 448.93114,749.86012 450.77616,725.20438 444.65194,685.99981 C 468.52773,637.50954 399.40762,676.69131 424.26422,639.80411 C 449.12083,602.91691 493.74252,585.43818 438.73851,593.12668 C 367.62865,626.24898 340.05615,652.75918 308.53226,650.00376 C 277.00837,647.24835 278.06457,653.52836 276.13146,653.57693 z" />
+ <path
+ id="path586"
+ d="M 565.52271,631.32808 C 559.87456,661.22904 567.06016,669.32587 533.12232,675.30261 C 499.18449,681.27936 470.31986,682.79288 497.95878,697.07654 C 525.5977,711.3602 581.57275,680.58896 553.26474,708.4972 C 524.95672,736.40545 549.82311,734.20405 483.39036,760.50812 C 416.95761,786.81219 509.71641,780.24187 516.31727,779.09063 C 561.92915,767.49942 668.17098,741.73846 641.47769,631.24076 C 599.62772,584.4018 566.58829,631.89255 565.52271,631.32808 z" />
+ <path
+ sodipodi:nodetypes="csssssc"
+ id="path587"
+ d="M 229.39497,774.5896 C 242.4834,760.07101 277.217,763.91439 296.81216,764.99871 C 316.40732,766.08303 302.07402,767.42855 337.60553,765.15628 C 373.13704,762.88401 362.02858,748.77628 384.48102,755.30705 C 406.93347,761.83782 380.59606,766.83529 374.84399,778.80459 C 369.09193,790.7739 293.38329,854.35404 292.59114,849.64402 C 291.79899,844.93401 233.71215,863.01184 229.39497,774.5896 z" />
+ <path
+ id="path606"
+ d="M 421.90652,614.24296 C 411.97692,612.9158 376.59659,644.94333 343.79034,651.87704 C 310.9841,658.81076 303.5157,660.57503 274.36827,671.94966 C 245.22084,683.32428 238.45048,706.55273 263.06218,697.06578 C 268.35216,682.34897 321.38297,713.02971 349.24805,711.34422 C 374.97026,678.23015 427.20564,729.83591 423.28806,701.43629 C 400.4163,668.33567 407.87517,634.69764 421.90652,614.24296 z" />
+ <path
+ id="path607"
+ d="M 285.78887,780.25374 C 296.65202,781.36036 313.84261,785.4613 326.85566,776.26576 C 364.0656,766.65937 380.87885,756.97419 370.12898,768.08367 C 331.24998,779.30863 329.68576,819.12781 294.47494,829.07813 C 287.47801,827.87437 260.63969,792.31623 285.78887,780.25374 z" />
+ <path
+ id="path608"
+ d="M 593.57646,636.53564 C 594.22721,646.1762 634.99245,663.48043 599.38557,671.07575 C 563.77868,678.67107 543.51402,679.37728 547.17283,683.8182 C 550.83164,688.25911 593.57686,676.937 595.22718,686.74954 C 596.8775,696.56207 557.69696,729.07923 540.2142,740.55495 C 522.73145,752.03067 488.78424,763.72296 480.17489,770.24582 C 619.9432,735.59561 681.58474,623.09094 593.57646,636.53564 z" />
+ <path
+ sodipodi:nodetypes="csccsc"
+ id="path3377"
+ d="M 184.09287,772.05215 C 184.09287,772.05215 205.22775,720.43539 402.04071,656.54813 C 611.19218,588.65568 644.70141,643.691 644.70141,643.691 L 657.90516,708.4633 C 657.90516,708.4633 631.3411,648.14795 413.15239,726.24866 C 205.66766,800.51788 206.31622,832.31468 206.31622,832.31468"
+ style="fill:none;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1" />
+ <path
+ sodipodi:nodetypes="cc"
+ id="path3379"
+ d="M 202.86734,708.38281 L 232.45764,863.68017"
+ style="fill:#ffffff;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:miter;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1" />
+ <path
+ id="path3381"
+ d="M 246.72232,672.01731 L 282.47506,860.7215"
+ <path
+ id="path3383"
+ d="M 304.82097,632.30447 L 347.36994,830.76355"
+ <path
+ id="path3385"
+ d="M 371.73614,606.77582 L 411.06029,806.88754"
+ <path
+ id="path3387"
+ d="M 459.32355,584.18481 L 494.48455,791.66347"
+ <path
+ id="path3389"
+ d="M 537.40116,579.55246 L 568.76665,781.92961"
+ <path
+ id="path3391"
+ d="M 601.45919,587.65471 L 629.00815,761.48144"
+ </g>
+ <text
+ style="font-size:190.1008606px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
+ x="8.5750723"
+ y="756.3833"
+ id="text3493"
+ transform="scale(0.8087213,1.2365199)"><tspan
+ id="tspan3495"
+ x="8.5750723"
+ y="756.3833"
+ style="font-weight:bold;-inkscape-font-specification:Bitstream Vera Sans Bold">Ma<tspan
+ style="font-weight:bold;fill:#ff0000;-inkscape-font-specification:Bitstream Vera Sans Bold"
+ id="tspan3497">p<tspan
+ style="font-weight:bold;fill:#0000ff;-inkscape-font-specification:Bitstream Vera Sans Bold"
+ id="tspan3499">b<tspan
+ style="font-weight:bold;fill:#000000;-inkscape-font-specification:Bitstream Vera Sans Bold"
+ id="tspan3501">ender</tspan></tspan></tspan></tspan></text>
+ </g>
+</svg>
Added: trunk/documents/logos/mapbender.png
(Binary files differ)
Property changes on: trunk/documents/logos/mapbender.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/documents/logos/mapbender.svg
--- trunk/documents/logos/mapbender.svg (rev 0)
+++ trunk/documents/logos/mapbender.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -0,0 +1,158 @@
+<svg
+ width="250"
+ height="250"
+ id="svg3838"
+ version="1.1"
+ inkscape:version="0.47pre4 r22446"
+ sodipodi:docname="mapbender_logo.svg"
+ inkscape:export-filename="/home/arnulf/Dropbox/osgeo/logos/mapbender_logo.png"
+ inkscape:export-xdpi="37.5"
+ inkscape:export-ydpi="37.5">
+ <defs
+ id="defs3840">
+ id="perspective3846" />
+ id="perspective3811"
+ inkscape:persp3d-origin="0.5 : 0.33333333 : 1"
+ inkscape:vp_z="1 : 0.5 : 1"
+ inkscape:vp_x="0 : 0.5 : 1"
+ </defs>
+ id="base"
+ inkscape:zoom="1"
+ inkscape:cx="126.94134"
+ inkscape:cy="89.439143"
+ showgrid="false"
+ inkscape:window-width="1280"
+ inkscape:window-height="950"
+ inkscape:window-maximized="1" />
+ <metadata
+ id="metadata3843">
+ <rdf:RDF>
+ <cc:Work
+ rdf:about="">
+ <dc:type
+ <dc:title></dc:title>
+ </cc:Work>
+ </rdf:RDF>
+ </metadata>
+ <g
+ inkscape:label="Ebene 1"
+ id="layer1"
+ transform="translate(-123.92857,-230.67989)">
+ <g
+ id="g3663"
+ transform="matrix(0.99607639,0,0,0.99607174,-429.27451,-51.909926)"
+ style="fill:#cccccc">
+ <g
+ id="g3665"
+ <path
+ d="m 680.875,409.197 -85.187,85.187 C 548.641,447.337 548.639,371.058 595.687,324.011 l 0,0 85.188,85.186 z"
+ id="path3667" />
+ </g>
+ </g>
+ <g
+ id="g3669"
+ transform="matrix(0.99607639,0,0,0.99607174,-429.27451,-51.909926)">
+ <g
+ id="g3671">
+ <path
+ style="fill:#ffffff"
+ d="m 680.875,409.197 85.187,85.188 c -47.047,47.048 -123.326,47.047 -170.373,-10e-4 l 0,0 85.186,-85.187 z"
+ id="path3673" />
+ </g>
+ </g>
+ <g
+ id="g3675"
+ style="fill:#87aade">
+ <g
+ id="g3677"
+ <path
+ d="m 680.875,409.197 85.187,-85.187 c 47.047,47.047 47.047,123.327 0,170.374 l 0,0 -85.187,-85.187 z"
+ id="path3679" />
+ </g>
+ </g>
+ <g
+ id="g3681"
+ style="fill:#ff8080">
+ <g
+ id="g3683"
+ <path
+ d="M 680.875,409.197 595.687,324.01 c 47.048,-47.048 123.328,-47.048 170.374,0 l 0,0 -85.186,85.187 z"
+ id="path3685" />
+ </g>
+ </g>
+ <polygon
+ id="polygon3687"
+ points="680.865,409.199 629.846,460.217 611.441,455.78 588.774,428.613 599.945,384.641 642.625,370.959 "
+ transform="matrix(0.99607639,0,0,0.99607174,-429.27451,-51.909926)" />
+ <polygon
+ id="polygon3689"
+ points="693.622,421.955 680.867,409.199 713.513,376.551 753.107,378.478 768.774,400.145 770.774,424.478 756.107,446.145 732.626,460.96 "
+ style="fill:#2a368f;fill-opacity:1"
+ <polygon
+ id="polygon3691"
+ points="640.184,355.004 656.941,324.478 680.866,321.477 707.369,329.641 718.598,350.745 716.855,366.815 711.046,379.018 680.866,409.199 652.5,380.832 647.566,375.898 "
+ style="fill:#ee0000;fill-opacity:1"
+ <g
+ id="g3697"
+ <image
+ style="opacity:0.75;overflow:visible"
+ overflow="visible"
+ width="230"
+ height="190"
+ xlink:href="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAOYAAAC+CAYAAAAht3MhAAAACXBIWXMAAAsSAAALEgHS3X78AAAA GXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAKX9JREFUeNrsnYly20AOREGKOpzE 2f//zE0cWze3UuXZQFA3AEqUrGNYxZLjOI6o4WMDGBwi9ahHPepRj3rUox71qMddHk39CO7j6Obz 0dZqu1r19ROtYNbjMhBm166voFYw6zEeiOd8zwOyj36uglrBrDDitUBfN2esWx98zf6+QlrBrDAC CNn30No1gSJ6r9HPVEgrmA8PpAejdwr5c0Ype/A1OyNYK6AVzIcE0gOxJV+jP0sAaATinnxd/iwO tBXQCuZDAenB2IKvW/L3kXIyKPfgVZ89+LqvgFYwHwnKSBnZOTGv9mumnkgx+wDEv+fOvOrvR6BW QCuYd6eSnjJOwKs9O/N3CFAGJ1JKC93OfL1VX+8caF1AK5wVzFtVyfK1VTcGYade9Wn/zoKsf7de Sw2KVUoN2la92q+3BNYdMH2RmVsBrWDepNlq/UILoj2n6nVqvq8BnRjVzIJp1dFCuAlet0RRkYpW 9axg3pRKWrNVqxsCsZwz82pPq6IIzCbwL5lSbsi5Nq8WVKaiR+pZ4axgfjWUyGRFMM7IOXcg7RzV 9MBEfiWDcg3OlfmzhbT8Lg2/9UGraVvB/BLT1QZ1yjkFQM7VKzotoPqcANVEAaACAPIvd8Z8RVCu nJNBuiXqua+mbQXzq0zX1lFIrYgLBeBCnXPzd1Y5tQ96qim7d3xLBuVSnSvz9SoJaDVtT73f6kdw lumKoJwa81SD+GJey9caTg0zMmVbopgRmHsC5saAaUH8UK+zz6+nn6+eemv1/P/7+vtZVjgrmJeG UkdaGZAaxm+fr/pcGMXUYG
bVMruPiVRTB3pWAMq/7/Fdvb8P8MAo72dN3k+Fs4J5VSitSloz9ZsC En1tFTOCciI4+wcdfRAEQnAWE1WD+fH53t6B/6vBnID3VJSzwlnBvDiUdj9yZqB8MQB+B19bxZw7 N30GykyuLNrTjEzal08w34kPPDXvz5qzm6qcFcxrQzk1gZ2FArBAaM9vBswslDZPVohaNsILoW0m EEo20Mq5+IRzAXzg6QkBqQpnBXOUIwPl3PiPBcgf4LX8nfUtZwNv9mwtJoJTBOfOlmjq7BPM+Sec aDsneoBEyfVHcNZbrYI5RC2F+JQaSm22FgDR+R34lhZKG3ltB9zo0QPGgjoxgHafYE6VaTsDMKLE h0zCA3pQ/D+Fr6pmBXOICYsSByyUBTYN4evnqb+nTdwFuOGHqk6fVBukrq36t60cp+7ZTKVO4hTB LJi2GqUtgFY4K5in+JX65kRQvpJTm7HWp7TBE3Rje10I7I3uQRm1Kumd4FYHgBxqwvbgvZaHQVP9 zQpm1q9k+5TWpyxQ/jSvr0Yti8mLIpoMSK/QGeajKsDstXivjQEUVcTYErVTMpBoiZiY1L16VDCZ X4nUUicNFJ9Sq+N/FJzat0RQdoL3/VhVCCpaZnAi1UedELxoL2txgv4tU0uvx5A9m+pvVjCHmrAd 8Ct1oOenOV8TUNpaSpahY7c0olIrFLRiNaGThPr1ErdDaYKHi9dTyMJZTdoKZtqEnTlgvgYmrI6+ 2vQ162tFRcyoYHkPVFODgkrQJo7faDskZNtreipp1d5T/GrSVjBdE7aVw60RndGThZIpZWOAZFk4 tmgZFStrNRKgcBPgJ9tSNBRx7QNljHJ0PeVnKlpN2gqm64+xHNgCpTZjX83rdxOBnZkgj4ZS36wW RFv76JVYZcBEXRNQkXZ5v3uloPahZaO+GSi3wBpgqt9U1XxiMIOAD9qz1JHYH0Yhvw+Acg+AZPWQ qEgZ1T5aH7
MF19IBGHVAS/95p8zvXnCergclS5bP9A7qq2pWxWRVI1NjxupIrFVNq5RzAmVvzFaU NK7PDzmsjSw/tyHmbO9ElVFZ2kI9dFbKXNfwzAHwjbl3mE+5dcxzr/NBU1XzScEM0u4mJhKrk9M1 lEgl50ppGJTlxkS1j+/yr9RKFygz1TwFTFu8vVTWgIbGKhnykyeOGWu7JCAwN0Y9J1U1q2I24mf5 eEnqFkov0GOh1Ar5oYC0pwZUm7QbOW6ExUzZliimrRnV0DPg9T1j9z6nBswtAXMdmOV7+Zem99Sq +XRgJtRySqKxrKZykTRftUpqIP+Y08Kpe+2wm7kniqnBZLWjSwM9+929A+dEBY2sYqKeQiiotf38 PTs5zOF9StV8VsVsJJdQgMB8EVwlovNebfTVQqmBfFOnhfMDgLMBgZ89uL6o08JcQa/VcuNAaZPi GZwITC+opR8Ik+prVlM2U2uJWoQsgFJ2Bkp9g64VlBbI35/nm1FOTy13xNzsZVjHBQT8VvzEBQuo NmlZgEtD+U3+FWDba+uUYu7lifc1nwrMZA8fqyovRjlt60kEZa98rXJzLpVSFiB/KTB/G8X8MGq2 Frx/mcmVRQ+eFQjKROYxmtWpldPz0VcKymJCz9UDAtWiPu2+5jMqZuOYeyxyiTrasYR0AX7l0piw BcpfCs6ioO8m6LM2AZ9d4P9Zc1an5nXCty68DX/0IGMVKp7lgc7l58+Vh0/xM88pDq9gPoCPme14 Z9tMTgVvIVhTbgWgZGBqtbRQIqX0cksRTMWH8zb7rVKiAUmoK57+ueghh3odoQ4OT2vOPg2Yyf6w XrNmdDPpm0jE3xp5B36lBpOZsMh8tQD1jlWgr3WnFCkDJdvjnRBA7TaNLi7XSQ0LB87M+IcK5gOb scyU1TcSmy/CTNgeBHyWKsr6x4D5G0Rjl3K8XzkESnateo8QnSiAxDoa2FP7hJJ0D1h3QNQVoZq
y T2rGet3Uo/aSTC2tf/kHRGT/gIDPKhHoQX6lrcdEWxwWTva7WAeHqCEXKsxmyfNoHIQF/cicrWA+ jxkb5ZTaSgyvrnIneIvEKuYfEoFF2yIMIu9GRe1GbISzdyK6LCg2FT5bZUJUE9W1elB681Cepoj6 mRSzITdgtjQK3Ty60p/5lkuJ0+5YZo9rumZu0M+Hku2v0zifETPvmSWxluMto9YJrDG4pyD4Y03Z p1HOZzZlbRSxc+CckihsA8xYu7Guc14RlKsklCcNgS0/SwD1PhsvSm33IW2ua5948E0dk3hIn9oK 5oMGfyYn+FI2HxaBaUu5bNUIylF1+/mcY8L9/bcGTmTCbgWnJ37Iv0lfL+pV57rqzwhZJZ0DJ2pv wrr4PcXR1uAPTPaekq9ZtNCrs1wBIL2k9N3YUAKlReMSUKnWWniNaOQPI9PYA7RGZJ8JzMQkaG9L IBrwI45i6hvbJnBnuhFcZAqzgbNPwsk6K6CsJK9jH/ucWbc+uJ9pKoQqmA8W+GHm7ITcMBkokY/J yp1s9g3sHHeJCOQIcLKHi1e03Tqf8RD/8ilU9NlMWU81W3OTZG8WVCBsm2uhhlpRtzu55LYAgbOX XGsQ1BzMmuGSgHMSPPy8jnwVzHs1YUFRtCTMWZsPipohiwHT7mHaYbCb4Ea+iE85AE4RPj8TPWg2 wvvcZhpQT5zPPDV6EKxvjcreuC8pAYxeV/FWch3KWQd1ZApugxs5m2J3yUMnIaBOdztwHewBwxQz A2em2/uBtWLX/VGSD7oHA9H6IKjSfiiM0ZxK5GdmWjfSNLtr3lxmG6UhZi0b18DUUsMuiYdi5vMv +6Ot4D3YHt0X9wpqd+cgNsHXGkxWtoRMKS8trCFQemrjdSH3aiq/QjlF8NwRO+LAvmYLt1HQLbM2 BcY9eb+oAuVuFbW7QyCbAa9ewroN2+vvp30d4p9FZ3+DUAq6sck1aSjZoKCsb98
m1mSv/PhGDpt1 ob1Za55DUG8Z0u6OYfSG3bAbASVlT4WH7hmgQ29ktBUSVYh8lZ8pgofj7oNXL8neAxJBqbOv9FwT rzImGux79FmX++wWAe1uGMhIAZl5xL7HKh0yVQ4oGpsZ0ioST4G+ZdOqd65RTghYRZlAtixsp6Cc yHFnQPSZe3M4+3sBtLszIFvhvWe8yclel3XdgjJTtHvOntq9Rgz7wB9lEHqzR1n1ykL+ZRL16udZ 4Mx73SdgvUlAuxuCsgkCBUMmHLeB2WTHH9jmzawHjaeckUktcr+b5U3ierNKiZLadTc9C2X5ma0T RPPOXRLW/0ekbwHQ7gaAHAKj3fvy/sz+TWeezrqRs2154VU7DDW32wSkt1ZBMcRlaILPB/n6tuVI SVUsoJSfWQMwdyQYtQeRcBZBtpDejInb3TiQCLwueEXAZudesoGzCM5+QNSxFd72UW5EQZsEjFHr yiFQ2jUoSilKKUshNhrdsCMgonmcuwBsb7vnS7omdF8EJVo0L58SNYCaku97kNo5HtqE0nDayV26 Or9xbjpv4zzKZLkFtcykLXpZO5GKsjEUWwKl7X+0TcCIkjos2PqVbf8cBLmuDWf3RVBGC19AmMrx iHJbwDwVXKKFqkM81bTzSXTvWOZneq0w2f/PAkr/h/OaNwHZmmqcBwza843gZA265nI4saxV0C6E l8ZFGVY6FZKN/9sCWEvDskaOe/f+/azkWqZtd+WFb5ILjzoJoB48KJLK6vzsjTUVPm4PBYJsJzgd NGDX4r2nlpjHX6GcTfCQmQTWSiYpw5qxczmsqGnUZ6ZN2I3gPrgITA3e2nlFVT4Twb125SvUs7ui SkpgsnZAFedyuN84B9/TkHYGJGTSdpIb6Br5mSJ+wfVUjiv1vSyjq3cdd8bdt8T89ywUppqt2Vrp gE9Xfm7q+JVbifORURWMrYtdC57TWcYzbNQ17JR67q/pd3ZXgtI
rTEYNsGwntoV5tf1emWp6wSCr nKxtJbrx0DZA1A3Ovk/93vRMyObKfk221cpUcD+kjHJqxUSj/awJi4bzsmCPByYr8l6C73UGzvK+ tnLYNPsqpm13RSgzGR9oLAE7rXJOyVMcmY6TQBGQD4tS8lrJt3xEcGoz6qrlX4FadsI7qaMHYqSa utn0BICpx1OwQI9XIOCBiaC0fYxmn193nz9TrqEAurVbKZc2bbsrLXZDVBIBacfeofF3C+cGYebV JIgydk4EmKXmRROp0Q1tHyQ2jH/xQNAZc1yycLJRfUit7b6mB2QP9i+1/4k6LViV/JDDroUFSvtg X4GHzNVM20sopud/dcRktSDayc0W0MiM9ZLQ0dfMzEVZRZI0ZWfAHNfv3Wtktb+CSRsl+U8lP1wp Uky2V6v/T1Ye15OvM3CiadYayvfP63kXPv7CXstOvf+LwdldUC1ZQGQm/ih1dLL5lHZsgRf1REGJ qHgX/Xu2teAN0Snv/+PzzzrwYBXzogNbB66TBZKtwVTiLCkB39+bzw9t9NvUuaj2FbV20aZs6Yn7 HlhdUfeKi8LZjbzYTcK8m5O9w+9mk/87UMyFo5SsoZO3oZ9Jjm/E79iWHRdfrsG2f0Sd8o5yOEdW TRaQY6PzPKsFDQOK8mhb8z4iGEV4FQlTzy1QTj1ifi7x1LEMmEdw3oRiDoByDvYLNZA/DJzf1c95 JlS0NzhWbqs4PpKNZE5VhPFFmVDfBPdktftnrVygPCwI+GQeKtZy0Q/IqExOhLd9ETlsa9JKXASN Wm8iQDWccwNmNqofgSk2WnvuQ7S7IpRlMRGQ+vwO1HIRBBsmxORkrUcQnOL8bMaXtkGT4kdaOJfC myZ3xsc6SDYYSTWjzg4ZtUSKOZF8f6Q++Xk3gVlv4UWAFvUsYK4ET3GbJX1M79iPtQ89hinLFtpC WRbWwvgKwLSpcWi8OlNIu9C9s6h64e3IA3tNmc8
gusFXBMxBU75GNGeZWjLFtPWrbHyEgM8aKZ1X K5m5ZuTDWhUtD7uyPeWNFOySSRPsGG0fuhtBLSV48mrT9bsBUp9WLVEGzlRyDZiz7SUkYcra6VUo 6TxjEhbV1Oq5AMrZKXN2LyOl6iVSI6MJ0KyonG0n9WRNsu1JspOyrVncm68nClCbUjhNbo+15v/x HjTarL2uYhoTtg0ikwujlH8h/KmA/GnUEpmvmdmJ3pN4L/6Uq0b8zgitAZSZv6duOcxMIsMQ8+lU C4c9UL2kAhbBZH7l3piZUT+kfQDm0NpQC+gk2LOORmIwGFHA7ix/szsTyibwsRZGKQuIPw2cWi2t UnqTtrwo3c5ZdHESIbxCaxZc6pOA2rzfbJ+hsRLbPdX0UiS95mVMKVlwxit0thUdXuPoJrG1FbXN RCBGwZ6MKX62v9md+dSNtgqKCVsU8Sc4f5go7EJ4yRUD0iuaRU9nCaKTUflW1GrEUyJmQk0S/vKY ye3ZipLJQDURB8joROvUS76bezQDZSJxWxoPTKb8vfgNrwf7m92Japnxq16AWiLF/KGCPQvByeMN iHx5VQaoTMgO7mFbHlF6HosGi+RG0E2SSRDZ6PA5ypnZLvK60tsb1qpK+dy9IuZz1glNDfPWKOqm 2JKovqf8+s+9Y45fXDG9wMHMCfi8GjhfTRR2QcLvDQiHe1UF0ayQ3jE9M8NVUfRO36iRr8R6/txD gy7PdbDjFbxaSbteY6xTR9ZqYvxgr/dSE8Quhnbab081absT1LI5Uy1fwdbIC4FSzM2OZjfa4tc1 WXg28ZiZ450TVke+oX6AeIt1SiTyEoBFgQxvNIKGrjVbTL2zwR8VK19qnXZqrfqEL4oeRiz1D/UT 2ptA0OD0yu4CUHrbI95e5Qzc5EI2ijeCh8La4bBsDmVv9r6iekpboI22cFo5nJi1cc6tcyPurwQq 8wczxcflnJAkAG/w7aXXaeZEkff
ARdL1oOgz2gcWQAbQwQXwQ0zZKL+SqaWX2bNwoGTj020ZD8qm 8VLe0JNYV5UwKFmxtoazvPfyntkU5pXgAba7KLHgzMBPT/x1lmfKRr1PDZRbtS2xVw9Qtl7XWqdy buWwlcnUwI7gzObheuu4B1so45iyA/IrkVqyPFjWU8dCqT8AvcC2pu6DwLkRfxS5yPCSJ11lsQZ7 kKLe+8q8R/RebfnXpbN+eieqzR6AuqAYQdkZM1b/DluUfK11elEPhxcDTbn2Tv1uCyebso2AXDuA ntQ2phtZLVGCOtoOWYDEAQalBbLU0ZXXd+eGX59hInn1oiuSmdSqaygL9vd9/VGnfr+2/CsKgJx8 qDmY4piw9iH4QbJ8NJQz9T39e1D946XXSRfZl2v4Bj5b5CpYOBGUXvuSteMvDy7lGxqVzQR9rGKi mspZYL5qU8gCqW/wPwZOpkRDggo6sqcX/ENd21JdT/mZztygWwPm2+dZ3r++SXUJ2O4K/qbnV64/ r30JopwTYBUUBdX+5RpYC+8Ji+GcdVrIv3rXb0SNd8FniuD0qlWYq3K2anZnZPmgxr26egQVOyOf siVQapV8N6rzpl4RmCgxPBuG19dVrq1Aqcu3dL7rnJh45RrKe/2t3rt+z5kk9ksGffRNx/ZvW7Ml VFRRg6nXj1k4ywuuk1XLlRx3iWCJJgxODaYHJYKzvNfBqtklVVIkV1Rr24PoxAEPSjHmq17YP0Zx fifVZ01MmD3JKNGBBVtpsZDjsq1vBMxWLWa5jnfz/vX7Rn7mDt0852b8GHPWgtka98HrfauvzYK5 ccDUJrwGZ4x1mpPA0jb6XJ0Ei17Bv5N/HfzWxIdG5XzlulgK5zAwzyyq9dqBoL2/vQkaWCh/g/PN mLKsM8BWhqfk2UVnT8cPc20TcPOu1HvUSv8BFHMnvJPBtVSzEd6Csjc+5Nz41juimB+Jh+c56zRT 72ctcSmdBMkFqDC
jNApbqOvXrs2HeoCXBzqK1Jb/103T6xJq6bWfRIGfFwfKKTGLtCllzde/EP4y r8gkZE+qneSS2JmptHa2DV7kuGC4ATfwh3rQvKsT3aAwc2istiJANfcKqvI5rIX3t9HXpYNevVFM G7CLAj7nrFOJjq8D85iB6XWRR3Cu5bC+Vvd0KvfDSnDd8NHe5hhRWdRCI+oFOxfcfoJFYDWYbwrE /yow34x/uVRm0TpYbJYi15K0r6nw7t4rcH2tAtNTD+1nub7l2B3yPuFEG+k7JxOmByb6zKznDqxl VBg+xjp1AxI4WJWJ15bG64fE7nfUaYO1jcmBmTBjJ4JHc6M2jah2D6mlfspan+yXOrVafgA/bRtE NzOWwU5dK8r20Ao6A/t76CZFN+o6SDC4dIqeLewV4R0IrCKia96TvdAVSKxA13zqOpW9VC/7JrIA J+J3xsgUks/luDqKjcJwzdluwN5lI3FB7UJwY2OUlL4navme8C3fgAmbeQJnq+JbtfBoxuLG3KCR 37wh6WjWB+ovZcI6Jm0PFNEC2oM4wEwOk8N7cM1oj8+OPhhznbzyMRHeAiZqwKWLrTOjPFAx+UZw Av1JPmYm8JPpNm7B7IG5h8zYNwCkVsul8P6srAVitOD6RmzF7762dqyBnmSLrIG5BQenXnpuCfA3 rXoiMFHk1j6MdpLPD77EOjEokSuGKohQYX7j3P9Rv2NUIniWj+kNm/FGAcwCtexJCpjds3wDQL6T jfntiYstctyYayeHCekIzs7s/bFr1DfqNnmDXm28OPA3944Zu1Nmo20pwjJl2MQuppKnrlOkuFFn iVkgJt5WISp2yPaoheZsl0wqiHrDRBdnAz5R0McmFPwBmSMrss0wOAkcmHTaT0Sd1/TNh0wfkeO6 xEzF/lWhJP6mhZPl1KKxEb0Bzxuv3o+4TlHQqElaezMQM2glN0oiy4CNdkPl7AKTQRJvauq8Ia/g GSm
m3Sp5J5vT1kfTFeT90Kim/nu1+GXhURHw3gSIWJsR1IPIK/P6EiiBv4ludn0ddnAQgphV+tvk gbHWSb+PLRCXbPL72rgonmoiOJFZ3Enc1f8sUzaaazkNnhTWjLU5sUuQwuVtTO/kuK2DnHOTl39D ns698Wt0ZDAqsu0lqLv8IqX04ESANmBbhf18VBguI6+T9it35v5dCa6GKjm2JeWy+IpbweVnzHJk s0MnjmKeFPzxmjVFMyW9JsAskOCVCDEod2NCOeBG1f5npvo9Or8UyiBS25jr1SF/FL0V4V3kZOxr dtSeBX1stdKLs4VVkvStMjPl7EikNzsD5awEA6aYURdrZNptBNfuWSjXwZ7fqFAm1ZP17mF7gML8 qluAMvFAsoEXb8+TXetFkibAe9apbzoWwOpEWVaSncKWGcLcSW763ME9YwNAXSKxAKUsoYZIEZQC tkm24o/kzmaKXPQmJzcrulGjwMpRoOOWoAweSJKAEgWSrvIQcvZlUZGzTULPjqtAKjwhPEStNEcL /rAuZdk3wz4s1MbC6wdDI3uXvMkTvqeAPTZ6w94ikAPUM9rWkGyk9cL7shk42T3nFa03ErcmRU2k RzNls6o5SUApEheesorw3VdC6QAqxORLRRbv4Uhcb/p3fMHWD+vbE7UH8WpD2cT0NuAgO2U7FfxB cLJu2KwxsJCAAGrUzNoZbsWpPviqLQbHDbhrGLPXgK75q681UE2vqdZWcG2op5iNc+9HTbJdc7ZL mLFs6yT7RpBi7h04WQPga4ymG/XGffTjxq/Za8/JRGErp5WhNQNYSA2KahMXOLSNvtfR2vug7FMq lff6jEDUY/ADI+qk7t17UdXL0OljqSHJbSL4I45qNgOfCN5o7r34g4BuUinrcfPHkOlj3r2Xdfc8 GNNjMNrkzzHihzwZmGPOskROSXKuRz3YvSaSG6DriUFPoESMRBw054DZJEAd8iTIzMxw
M2TA76pH Pc6596JZMpmC9Wbg16Mp5qlHkwBpyLiyCmM9Lgntzdxj7YA3fApMvfPEYOZvE/x8PepxSQFpRgT7 ZODbE/7zHgCa9QUZiDaI5EV3z/kA61Hh83YWoiBOxn+VZEykPwXMfgTfMPqQvInFZ+0B1aMeQYCG QeklBCAxyHAhckLgMqOYXrh5qNPsZQ+xVoLR/mg96jFUKVHmWube89y6PsGDJ3ohmP2AJwJrgITe iFfbOaRS5QBOLxWuHs95gHuiCcSgE57z7XVq8CK8XgfAUDnbE5XS25CN0pi8bghRO8FWkknA9ahK Kbk+sqiWMlOuFSXLRDy4gaFMVDZSyZ3ksiaiwTC6LcMs+UFJVc16OGrpKaW99xicExne24j1OUon y2Sjsl6eYab7G1JM1i9lRgBFfVOqv1mPSC1b8RvJsV49rLcsYiLLQrrLfjtAKVniuVcR0hPVRIOJ dDtB/Rr156yqWQ9PLVl/nqh1ZSe8PU5UrYIS4xmUcfCHVGpky2YQnDvBI7XZKD82aoE9ydoaCKqH WXuvF7I33oCNNkCmbKZ0cZBqWvayPqa2k6MC5+zIbvRBoclJtrs1i5hVKOvhRf6njgiwSV3lXmuI YmaK/Vmx9WhR2agC3JtRod+QfYrNHDDR1DDWiLeatFUtRfKzXMs8V3u/oel0rNs8YyAaBRj6mW0S ymyvHjQ0x2uai2Zs6lHxegDuPBkMqnBWE1aDOXWg1PfZglhnbIqANzAKKWbUEcEHU9m63v7l9gQ4 bXTWPsnQqPhvwidTW7O2+psVSjb8akYe/Prh/wIUMxrv4THguXVh8CfT8NlTTNYT1na4K2+qJX6m /eCWnx8a+n3ehR5csDfjvh4PqZTeRK6FAdKeCxNs1GBGask6PEY7FbQ9TpeEMurP6TVp3hizYOKY swvz+6L+suhi9xXOGoFV8QsE5Xd1WqssY8aiXsjs3ndnoNJrDKBsTFTW
Bn7sm1qaV/3k6EA0tVUf 4FZ9iN+E95gNn0Dq+02F86EjsEJMWM98tVB+S5ixdoKAJ0psekAaSgqm6cDdOIq5duAsZ/ELy1NM t9lvTXR2AX73JjANmEmrh99UKB8zAtsKTyAoZikC8gdRTGvGoiHEWwLlErhe9n5NJ7MP9TFRN2tv SIudN7gFiomCQJnws9faUuTfeLx9WdCqmg8fgdXm6xyYrz8SUE6BWu4dKJeC559khirT9qsTGq7t Oq8bXpSl7yUGe1UiXimNlxi8B/8eXtN+t6t3+GNFYNk+pYbxJzhfFaQFUG3K6qBPEYQCYhms/PZ5 /lZnmYD+oWClA4rY/UjB/PsPPuH0QtJsDNmQ8XyZmZJ78VsO5jMqKpyPBuXEQPlioHwlUGowX4zL pdVyp+IperAygvJN/k1Ct3EWZM4OB1OppteFPYKzMzZ7J4dV41FPFZZEf1Z7kwrnQ0Bp0zqRP6mh /M/n+RNAuTBxEG3C6uHKywSUGkwUAErN3MmAiaJgmeJTb4gnqw6PAPXamVhzVqpZ+/BQdsB8/aaU 8pVA+apM2IVjwu6UT1nUssBXgPxlzNh3ORy4bPfyJVLLEEzHnM1WhZ80XVfyk4p7x5wNC1IrnA8B 5QxA+cNA+ZNAaU3YibpfrFq+K7X8Dc435Vt+qAAQLOiIApGTjE+WVM0MoKzhUXbuiSTN13SHsgrn Q0D5AszX/5wAZfl/SxR2DQI+HpTvKujDfEuJ1DIFZlI1G8HNjJgZGzXZ0v8XA2wIjBXOx4ISpdn9 CCKwrwpe5ldqKDck4BOBWSKxyLcMgz5pME9QTRsQYp3IrGIObbTFuvmJY9JWOB8Tyu+OT+kFe2Zy nA8bRWF/Gd+yfN/6llumlpn99BSYjmoiQCfC21Oi2fReN2w5E9Qhf1/hfAwofzpQ6mT1GQn2IBNW R2EtmHrfcjmGWqbBTKqmBWzinNmu6x6QQ0CtcD4WlAs5
TK8rAP7HgPmqTFwEpb7/tQm7Ukr5B0DJ 9i2XghPXexk4aDkNJlHNCE7U7boNIB06jddrWy8Dvq5w3ieUKPrqBXvKvmc70K/8FURivX3LwdPP J0M+RKOaFhQPzkwb+nagWesNGxqilhXO+4BybqKvPwaYr1EE1ubA2pS7X+Zk2yNWLQebsCeBqVRT kv4mGxpk/dDMtCW2pTKkv2yfUNQK53NBqYM9ngn7S3gyQbg9MrSAYjL0AzVwZnxONklpiFoOBbap cD4dlOV7NtCzkMOqEWa+2mDPbxLs+a2isF7AZ3+qWp4EZhAIkgCaCMr2BPiiAbgVzueAEqXa2cZa SCltHuwfJwLrRWE3cpwPO9i3PAtMEAiSwMSMhtO2ctog0YyJ60VsK5xfC2W2yPnHAChfiPnaEvN1 OcB8fQNQrj2/8tQa4O7Mz7o34Wb2JMwEgTK+ooa2c97LGNfUm/dSW5SMc0Sd0q8J5UoOk9NR1QhK ubPm6+CePhdRTMfXFOLjRSqXGfU+xMQ9RTlTU3+rao6ilpncV5Y8UMAcA8oPEoH9TdQSgUlnk5zz EJ+c82EDOL1oacYEPSfoE8E5FEz4Wk3a0fxKXeQ8BVDq3FebPHAJKH8TKN+E71duBI8CkXMtq8m5 H7rjb2bMmSGKempktkkGf2pFyoUOU3Dv9XryEtLRlsiPM6D8MFAiv/LNUUqqlmO4O92Inz/yN8Xx O89VO5HjuRKS8Du9QbzemO7mAv7sM6mlOAEfVuysfUutkj/OVMoPOc5/9aBk+5Wj+pWjKmbgb3om pJdmJ8DEPVdNGZwWyFSTr6qaF1FL1BIElXB5yQPnKOVv4FO+kwjs6H7lRRTT9KIVOe6K7m11iPhJ ApFpHCmnCB714M361GZK7VE7XjTWa6Slu9vpdpO67aRtOXkKlBrA/wpPt0NKub2UX3kpU1bDycCU E03W1MOZwBkN3kUDYTSgeotGK30FdFjQ
B8HJyrnQOINv4jdnPgXKXwGUXnL66H7lxcBUcArwN3cB gENMYQ/ORo57t7C5nmzuykoO60h3SjHrMVwpM4rJRhrYaVx2HCMbY5CB8r9BsAcNyPLGtt8umMlg 0FgqGZlMZeFZJ202HDdqTl3Vclxzlk0XR6PYUbd0uRCUUQ7sqH7lxcEE/qYYxbmk8rTCR7LNnFMv OJtY3VhTrWYCDQLSxhK83sT2ZN38RQFzDpR/HCi314TyoorpwCmfFxqZPqeqdCfHvWrZmDbUvQ/1 vG2kmrGn+pcZ9bTr05I/N3I8Fk/7lV73gQjKPwko99eA8tKmLIJTm7Tbkcxl1DVvooI1PbkhMnWe 9fjag7UstZDY7gN3DeXFwbwSnCj6OgVRuj052ViFaqKOs+6Z9fK2sdC2lt2WsybsXUN5FTAvBGcf LPRO/tXf9XI4bNRuh2zB4rNRDPUY17LxIuZojLqeK6IfvOXnUKtJb0vkJqG8GpgXVE62yDOziDvx J/+i/cujZkoWzhr4OcuqsUBulI+oZ0/q/cpGBXkKmMWMXQK1vEsorwrmFeDUWyJzFQQqYNqi2BK1 s0NHLZgunPVIrU8j/gBkPZl8qfxE2xKkrKW3tl751l1AKTJSruyQI6jj7B3HPzJnUcrdRo7LfN7V Ar3JYVkPCpfT0p6aKztoraPRGqjNqY3E6rX1Cp1Zn567gPLqijmCcjJAbRrWXD1pxTxVdbMlBuQa mLPV37yMGbtR/iPawmpM5NVaQ1viX2ogo+SBm4Lyy8AcwaxlvuXGgIn8ED21KcqL3MqFynqeEErm dqCu/TrvWY/EW8vhaAMEprWEhiQP3ASUX2LKjmDWeoDayN5K+HjutwBOpJo18HP6GmfK/BjMSGGX BEa7tu/3BuWXKuZIZi0yY1fK3JkYxbRtCu1obtS419vrrMdw1dRN2/S+JEr0sGq5lMMJXXaOpY4j vJsg391AeRNgngGnB+YM
gLk1CvphFs/rfNbf2sLd0xHU6rIywF6OU+3mJEq7AWv7oSK8nouyv8W1 7W548Tw4ewfMpRxWiGgw7QIuSRSW+pYVyrPX14KJygF7wePWZw6YuoRvKcfbYHcD5U2BeQacNvCj F8+m5bEaTLSHeZW6uyc2ae36CnAZdMxgLbgGEw0F0q9r9fe7e4Dy5sBMwtkHiomGx9haPdS1wBs2 Wk3Yy6ytVU/7Pf1ARXWY9sFsU/k2ghNG9re+rjdbQUF6keoNab3npWv29OJpxdQLuBWcN6snNe0r lF+2tmh97d6m7Vqg3RWWB30369rc2QJ6xbV2rHwLont6AXfEdK3BnttZ24kcF67b3k578+BlRQl3 ta7NnS8gmk6NOg9Ys3dPFq5CeVtr2wqfOo7M3r3wMr+7WtfmjheQDS5Ci8cW0K3LrFB++dp6TcJR wAg1777LdW3udAFFcuP7UMQPLdooMw3rMeraesOlRI6LpVFQsL/XdW3udAFFhnVeF2cBj7ZDKpQ3 tbYivPVLT9ZW7n1dmztfRDZJTMTPvZR7fpo+oXqK8H5MfbDGd7muzQMsYGbxogWsUN7u2qK19AY8 PUSxQfMEiyiPuHBPCmj6uPd1bZ5xISuMj7e+dU3vbCHPeerWox71qEc96lGPetSjHvWoRz0GHf8T YAAYUnbp8aFV9AAAAABJRU5ErkJggg=="
+ transform="translate(565.7866,294.3364)"
+ id="image3699" />
+ <g
+ id="g3701">
+ <path
+ style="fill:none;stroke:#ffffff;stroke-width:18"
+ d="m 734.167,462.586 c 16.295,-16.295 37.069,-32.934 37.069,-53.551 0,-20.617 -16.714,-37.334 -37.332,-37.334 -10.813,0 -20.552,4.598 -27.37,11.943 l -1.152,1.086 c 7.854,-6.844 12.816,-16.92 12.816,-28.154 0,-20.617 -16.715,-37.334 -37.332,-37.334 -20.619,0 -37.334,16.717 -37.334,37.334 0,11.322 5.041,21.467 13,28.313 l -1.291,-1.244 c -6.818,-7.346 -16.558,-11.943 -27.37,-11.943 -20.618,0 -37.333,16.717 -37.333,37.334 0,20.617 20.775,37.256 37.07,53.551"
+ id="path3703" />
+ </g>
+ </g>
+ </g>
+</svg>
Deleted: trunk/documents/logos/mapbender_db_toennchen.svg
--- trunk/documents/logos/mapbender_db_toennchen.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_db_toennchen.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,655 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- version="1.0"
- id="OSGeo_x5F_logo"
- width="200"
- height="200"
- viewBox="0 0 296.647 125.463"
- overflow="visible"
- enable-background="new 0 0 296.647 125.463"
- xml:space="preserve"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- sodipodi:docname="mapbender_db_toennchen.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape"
- style="overflow:visible"><metadata
- id="metadata241"><rdf:RDF><cc:Work
- rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
- id="defs239"><inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 62.731499 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="296.647 : 62.731499 : 1"
- inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
- id="perspective243" /></defs><sodipodi:namedview
- inkscape:window-height="975"
- inkscape:window-width="1400"
- inkscape:pageshadow="2"
- inkscape:pageopacity="0.0"
- guidetolerance="10.0"
- gridtolerance="10.0"
- objecttolerance="10.0"
- borderopacity="1.0"
- bordercolor="#666666"
- pagecolor="#ffffff"
- id="base"
- showgrid="false"
- inkscape:zoom="2.6554016"
- inkscape:cx="107.20501"
- inkscape:cy="112.50522"
- inkscape:window-x="0"
- inkscape:window-y="25"
- inkscape:current-layer="OSGeo_x5F_logo" />
-<g
- id="Text"
- display="none"
- style="display:none">
- <g
- id="Associate">
- <path
- display="inline"
- d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
- id="path5"
- style="fill:#0054a4;display:inline" />
- <path
- display="inline"
- d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
- id="path7"
- <path
- display="inline"
- d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
- id="path9"
- <path
- display="inline"
- d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
- id="path11"
- <path
- display="inline"
- d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
- id="path13"
- <path
- display="inline"
- d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
- id="path15"
- <path
- display="inline"
- d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
- id="path17"
- <path
- display="inline"
- d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
- id="path19"
- <path
- display="inline"
- d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
- id="path21"
- <path
- display="inline"
- d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
- id="path23"
- <path
- display="inline"
- d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
- id="path25"
- <path
- display="inline"
- d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
- id="path27"
- <path
- display="inline"
- d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
- id="path29"
- <path
- display="inline"
- d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
- id="path31"
- <path
- display="inline"
- d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
- id="path33"
- <path
- display="inline"
- d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
- id="path35"
- <path
- display="inline"
- d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
- id="path37"
- </g>
- <g
- id="Supporting">
- <path
- display="inline"
- d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
- id="path40"
- <path
- display="inline"
- d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
- id="path42"
- <path
- display="inline"
- d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
- id="path44"
- <path
- display="inline"
- d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
- id="path46"
- <path
- display="inline"
- d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
- id="path48"
- <path
- display="inline"
- d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
- id="path50"
- <path
- display="inline"
- d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
- id="path52"
- <path
- display="inline"
- d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
- id="path54"
- <path
- display="inline"
- d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
- id="path56"
- <path
- display="inline"
- d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
- id="path58"
- <path
- display="inline"
- d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
- id="path60"
- <path
- display="inline"
- d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
- id="path62"
- <path
- display="inline"
- d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
- id="path64"
- <path
- display="inline"
- d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
- id="path66"
- <path
- display="inline"
- d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
- id="path68"
- <path
- display="inline"
- d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
- id="path70"
- <path
- display="inline"
- d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
- id="path72"
- <path
- display="inline"
- d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
- id="path74"
- </g>
- <g
- id="Sustaining">
- <path
- display="inline"
- d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
- id="path77"
- <path
- display="inline"
- d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
- id="path79"
- <path
- display="inline"
- d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
- id="path81"
- <path
- display="inline"
- d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
- id="path83"
- <path
- display="inline"
- d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
- id="path85"
- <path
- display="inline"
- d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
- id="path87"
- <path
- display="inline"
- d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
- id="path89"
- <path
- display="inline"
- d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
- id="path91"
- <path
- display="inline"
- d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
- id="path93"
- <path
- display="inline"
- d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
- id="path95"
- <path
- display="inline"
- d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
- id="path97"
- <path
- display="inline"
- d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
- id="path99"
- <path
- display="inline"
- d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
- id="path101"
- <path
- display="inline"
- d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
- id="path103"
- <path
- display="inline"
- d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
- id="path105"
- <path
- display="inline"
- d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
- id="path107"
- <path
- display="inline"
- d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
- id="path109"
- <path
- display="inline"
- d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
- id="path111"
- </g>
- <g
- id="Incubation">
- <path
- display="inline"
- d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
- id="path114"
- <path
- display="inline"
- d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
- id="path116"
- <path
- display="inline"
- d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
- id="path118"
- <path
- display="inline"
- d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
- id="path120"
- <path
- display="inline"
- d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
- id="path122"
- <path
- display="inline"
- d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
- id="path124"
- <path
- display="inline"
- d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
- id="path126"
- <path
- display="inline"
- d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
- id="path128"
- <path
- display="inline"
- d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
- id="path130"
- <path
- display="inline"
- d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
- id="path132"
- <path
- display="inline"
- d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
- id="path134"
- <path
- display="inline"
- d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
- id="path136"
- <path
- display="inline"
- d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
- id="path138"
- <path
- display="inline"
- d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
- id="path140"
- <path
- display="inline"
- d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
- id="path142"
- <path
- display="inline"
- d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
- id="path144"
- <path
- display="inline"
- d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
- id="path146"
- <path
- display="inline"
- d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
- id="path148"
- <path
- display="inline"
- d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
- id="path150"
- </g>
- <g
- id="Project"
- display="inline"
- style="display:inline">
- <path
- d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
- id="path153"
- style="fill:#0054a4" />
- <path
- d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
- id="path155"
- <path
- d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
- id="path157"
- <path
- d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
- id="path159"
- <path
- d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
- id="path161"
- <path
- d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
- id="path163"
- <path
- d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
- id="path165"
- </g>
- <g
- id="Your_Open_Source_Compass">
- <path
- display="inline"
- d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
- id="path168"
- style="fill:#a0ce67;display:inline" />
- <path
- display="inline"
- d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
- id="path170"
- <path
- display="inline"
- d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
- id="path172"
- <path
- display="inline"
- d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
- id="path174"
- <path
- display="inline"
- d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
- id="path176"
- <path
- display="inline"
- d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
- id="path178"
- <path
- display="inline"
- d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
- id="path180"
- <path
- display="inline"
- d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
- id="path182"
- <path
- display="inline"
- d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
- id="path184"
- <path
- display="inline"
- d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
- id="path186"
- <path
- display="inline"
- d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
- id="path188"
- <path
- display="inline"
- d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
- id="path190"
- <path
- display="inline"
- d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
- id="path192"
- <path
- display="inline"
- d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
- id="path194"
- <path
- display="inline"
- d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
- id="path196"
- <path
- display="inline"
- d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
- id="path198"
- <path
- display="inline"
- d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
- id="path200"
- <path
- display="inline"
- d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
- id="path202"
- <path
- display="inline"
- d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
- id="path204"
- <path
- display="inline"
- d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
- id="path206"
- <path
- display="inline"
- d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
- id="path208"
- </g>
-</g>
-<g
- id="OSGeo"
- display="none"
- <path
- display="inline"
- d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
- id="path211"
- style="fill:#49a942;display:inline" />
- <path
- display="inline"
- d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
- id="path213"
- <path
- display="inline"
- d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
- id="path215"
- <path
- display="inline"
- d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
- id="path217"
- <path
- display="inline"
- d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
- id="path219"
-</g>
-<text
- style="font-size:63.39215469px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- x="11.140328"
- y="126.13584"
- id="text2616"
- transform="scale(0.7059967,1.4164372)"><tspan
- sodipodi:role="line"
- id="tspan2618"
- x="11.140328"
- y="126.13584"
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Bitstream Vera Sans;-inkscape-font-specification:Bitstream Vera Sans Bold">Mapbender</tspan></text>
-<path
- sodipodi:type="arc"
- style="fill:#808080;stroke-width:6"
- id="path2502"
- sodipodi:cx="148.90392"
- sodipodi:cy="-25.137407"
- sodipodi:rx="84.918678"
- sodipodi:ry="21.328411"
- d="M 233.82259,-25.137407 A 84.918678,21.328411 0 1 1 63.985237,-25.137407 A 84.918678,21.328411 0 1 1 233.82259,-25.137407 z"
- transform="matrix(0.855814,0,0,1,21.074896,-7.1094704)" /><path
- style="fill:#999999;stroke-width:6;overflow:visible"
- id="path2504"
- sodipodi:rx="73.859497"
- d="M 222.76341,-25.137407 A 73.859497,21.328411 0 1 1 75.044418,-25.137407 A 73.859497,21.328411 0 1 1 222.76341,-25.137407 z"
- transform="translate(-0.3949772,90.84323)" /><rect
- id="rect2508"
- width="146.92906"
- height="99.532585"
- x="75.044411"
- y="-33.826763" /><path
- style="fill:#ffff00;stroke-width:6"
- id="path2510"
- sodipodi:cx="116.91129"
- sodipodi:cy="1.3256211"
- sodipodi:rx="15.798823"
- sodipodi:ry="21.723381"
- d="M 132.71012,1.3256211 A 15.798823,21.723381 0 1 1 101.11247,1.3256211 A 15.798823,21.723381 0 1 1 132.71012,1.3256211 z" /><path
- style="fill:#ffff00;stroke-width:6;overflow:visible"
- id="path2512"
- transform="translate(65.170134,2.1423513)" /></svg>
\ No newline at end of file
Deleted: trunk/documents/logos/mapbender_diagonal.svg
--- trunk/documents/logos/mapbender_diagonal.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_diagonal.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,1250 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- version="1.0"
- id="OSGeo_x5F_logo"
- width="200"
- height="200"
- viewBox="0 0 296.647 125.463"
- overflow="visible"
- enable-background="new 0 0 296.647 125.463"
- xml:space="preserve"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- sodipodi:docname="mapbender_diagonal.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape"
- style="overflow:visible"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_diagonal.png"
- inkscape:export-xdpi="61.200001"
- inkscape:export-ydpi="61.200001"><metadata
- id="metadata241"><rdf:RDF><cc:Work
- rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
- id="defs239"><inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 62.731499 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="296.647 : 62.731499 : 1"
- inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
- id="perspective243" /><inkscape:perspective
- id="perspective3540"
- sodipodi:type="inkscape:persp3d" /></defs><sodipodi:namedview
- inkscape:window-height="975"
- inkscape:window-width="1400"
- inkscape:pageshadow="2"
- inkscape:pageopacity="0.0"
- guidetolerance="10.0"
- gridtolerance="10.0"
- objecttolerance="10.0"
- borderopacity="1.0"
- bordercolor="#666666"
- pagecolor="#ffffff"
- id="base"
- showgrid="false"
- inkscape:zoom="3.7553051"
- inkscape:cx="80.869466"
- inkscape:cy="105.35938"
- inkscape:window-x="0"
- inkscape:window-y="25"
- inkscape:current-layer="OSGeo_x5F_logo" />
-<g
- id="g3542"
- transform="matrix(0.4211728,0.182269,-0.4747632,1.0363122,6.5648762,-12.913196)"><g
- style="display:none"
- display="none"
- id="g3544">
- <g
- id="g3546">
- <path
- id="path3548"
- d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
- display="inline" />
- <path
- style="fill:#0054a4;display:inline"
- id="path3550"
- d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
- <path
- id="path3552"
- d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
- <path
- id="path3554"
- d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
- <path
- id="path3556"
- d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
- <path
- id="path3558"
- d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
- <path
- id="path3560"
- d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
- <path
- id="path3562"
- d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
- <path
- id="path3564"
- d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
- <path
- id="path3566"
- d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
- <path
- id="path3568"
- d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
- <path
- id="path3570"
- d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
- <path
- id="path3572"
- d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
- <path
- id="path3574"
- d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
- <path
- id="path3576"
- d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
- <path
- id="path3578"
- d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
- <path
- id="path3580"
- d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
- </g>
- <g
- id="g3582">
- <path
- id="path3584"
- d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
- <path
- id="path3586"
- d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
- <path
- id="path3588"
- d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
- <path
- id="path3590"
- d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
- <path
- id="path3592"
- d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
- <path
- id="path3594"
- d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
- <path
- id="path3596"
- d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
- <path
- id="path3598"
- <path
- id="path3600"
- <path
- id="path3602"
- <path
- id="path3604"
- <path
- id="path3606"
- <path
- id="path3608"
- <path
- id="path3610"
- <path
- id="path3612"
- <path
- id="path3614"
- <path
- id="path3616"
- <path
- id="path3618"
- </g>
- <g
- id="g3620">
- <path
- id="path3622"
- <path
- id="path3624"
- <path
- id="path3626"
- <path
- id="path3628"
- <path
- id="path3630"
- <path
- id="path3632"
- <path
- id="path3634"
- <path
- id="path3636"
- <path
- id="path3638"
- <path
- id="path3640"
- <path
- id="path3642"
- <path
- id="path3644"
- <path
- id="path3646"
- <path
- id="path3648"
- <path
- id="path3650"
- <path
- id="path3652"
- <path
- id="path3654"
- <path
- id="path3656"
- </g>
- <g
- id="g3658">
- <path
- id="path3660"
- <path
- id="path3662"
- <path
- id="path3664"
- <path
- id="path3666"
- <path
- id="path3668"
- <path
- id="path3670"
- <path
- id="path3672"
- <path
- id="path3674"
- <path
- id="path3676"
- <path
- id="path3678"
- <path
- id="path3680"
- <path
- id="path3682"
- <path
- id="path3684"
- <path
- id="path3686"
- <path
- id="path3688"
- <path
- id="path3690"
- <path
- id="path3692"
- <path
- id="path3694"
- <path
- id="path3696"
- </g>
- <g
- display="inline"
- id="g3698">
- <path
- id="path3700"
- d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z" />
- <path
- id="path3702"
- d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z" />
- <path
- id="path3704"
- d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z" />
- <path
- id="path3706"
- d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z" />
- <path
- id="path3708"
- d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z" />
- <path
- id="path3710"
- d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z" />
- <path
- id="path3712"
- d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z" />
- </g>
- <g
- id="g3714">
- <path
- id="path3716"
- <path
- id="path3718"
- <path
- id="path3720"
- <path
- id="path3722"
- <path
- id="path3724"
- <path
- id="path3726"
- <path
- id="path3728"
- <path
- id="path3730"
- <path
- id="path3732"
- <path
- id="path3734"
- <path
- id="path3736"
- <path
- id="path3738"
- <path
- id="path3740"
- <path
- id="path3742"
- <path
- id="path3744"
- <path
- id="path3746"
- <path
- id="path3748"
- <path
- id="path3750"
- <path
- id="path3752"
- <path
- id="path3754"
- <path
- id="path3756"
- </g>
-</g><g
- display="none"
- id="g3758">
- <path
- id="path3760"
- <path
- id="path3762"
- <path
- id="path3764"
- <path
- id="path3766"
- <path
- id="path3768"
-</g><g
- transform="matrix(2.658509,0,0,1.0066382,2.3739382,-80.596613)"
- id="Compass">
- <path
- style="fill:#49a942;fill-rule:evenodd"
- id="path222"
- d="M 54.232,117.368 C 28.032,116.453 7.532,94.47 8.447,68.269 C 9.361,42.065 31.345,21.569 57.546,22.484 C 75.658,23.117 91.043,33.819 98.515,49.021 C 99.665,49.057 100.817,49.06 101.976,48.846 C 94.225,31.979 77.475,20 57.657,19.308 C 29.667,18.33 6.187,40.227 5.209,68.219 C 4.233,96.205 26.127,119.687 54.118,120.665 C 61.711,120.929 68.969,119.499 75.539,116.731 C 75.222,115.748 75.025,114.623 74.698,113.516 C 68.439,116.223 61.5,117.621 54.232,117.368 z"
- clip-rule="evenodd" />
- <g
- id="g224">
- <circle
- style="fill:#a0ce67"
- sodipodi:ry="31.707001"
- sodipodi:rx="31.707001"
- sodipodi:cy="70.192001"
- sodipodi:cx="55.669998"
- id="circle226"
- r="31.707001"
- cy="70.192001"
- cx="55.669998" />
- </g>
- <polygon
- style="fill:#ffffff;stroke:#a0ce67;stroke-width:2;stroke-miterlimit:6"
- id="polygon228"
- points="61.494,53.061 26.327,4.407 38.873,63.876 3.379,93.238 49.515,86.588 78.884,121.407 72.411,75.859 107.593,46.548 61.494,53.061 "
- stroke-miterlimit="6" />
- <g
- id="g230">
- <polygon
- id="polygon232"
- points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
- </g>
- <path
- style="fill:none"
- id="path234"
- d="" />
- <path
- style="fill:none"
- id="path236"
- d="" />
-</g></g><g
- id="Text"
- display="none"
- style="display:none">
- <g
- id="Associate">
- <path
- display="inline"
- id="path5"
- style="fill:#0054a4;display:inline" />
- <path
- display="inline"
- id="path7"
- <path
- display="inline"
- id="path9"
- <path
- display="inline"
- id="path11"
- <path
- display="inline"
- id="path13"
- <path
- display="inline"
- id="path15"
- <path
- display="inline"
- id="path17"
- <path
- display="inline"
- id="path19"
- <path
- display="inline"
- id="path21"
- <path
- display="inline"
- id="path23"
- <path
- display="inline"
- id="path25"
- <path
- display="inline"
- id="path27"
- <path
- display="inline"
- id="path29"
- <path
- display="inline"
- id="path31"
- <path
- display="inline"
- id="path33"
- <path
- display="inline"
- id="path35"
- <path
- display="inline"
- id="path37"
- </g>
- <g
- id="Supporting">
- <path
- display="inline"
- id="path40"
- <path
- display="inline"
- id="path42"
- <path
- display="inline"
- id="path44"
- <path
- display="inline"
- id="path46"
- <path
- display="inline"
- id="path48"
- <path
- display="inline"
- id="path50"
- <path
- display="inline"
- id="path52"
- <path
- display="inline"
- d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
- id="path54"
- <path
- display="inline"
- d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
- id="path56"
- <path
- display="inline"
- d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
- id="path58"
- <path
- display="inline"
- d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
- id="path60"
- <path
- display="inline"
- d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
- id="path62"
- <path
- display="inline"
- d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
- id="path64"
- <path
- display="inline"
- d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
- id="path66"
- <path
- display="inline"
- d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
- id="path68"
- <path
- display="inline"
- d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
- id="path70"
- <path
- display="inline"
- d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
- id="path72"
- <path
- display="inline"
- d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
- id="path74"
- </g>
- <g
- id="Sustaining">
- <path
- display="inline"
- d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
- id="path77"
- <path
- display="inline"
- d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
- id="path79"
- <path
- display="inline"
- d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
- id="path81"
- <path
- display="inline"
- d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
- id="path83"
- <path
- display="inline"
- d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
- id="path85"
- <path
- display="inline"
- d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
- id="path87"
- <path
- display="inline"
- d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
- id="path89"
- <path
- display="inline"
- d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
- id="path91"
- <path
- display="inline"
- d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
- id="path93"
- <path
- display="inline"
- d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
- id="path95"
- <path
- display="inline"
- d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
- id="path97"
- <path
- display="inline"
- d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
- id="path99"
- <path
- display="inline"
- d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
- id="path101"
- <path
- display="inline"
- d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
- id="path103"
- <path
- display="inline"
- d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
- id="path105"
- <path
- display="inline"
- d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
- id="path107"
- <path
- display="inline"
- d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
- id="path109"
- <path
- display="inline"
- d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
- id="path111"
- </g>
- <g
- id="Incubation">
- <path
- display="inline"
- d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
- id="path114"
- <path
- display="inline"
- d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
- id="path116"
- <path
- display="inline"
- d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
- id="path118"
- <path
- display="inline"
- d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
- id="path120"
- <path
- display="inline"
- d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
- id="path122"
- <path
- display="inline"
- d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
- id="path124"
- <path
- display="inline"
- d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
- id="path126"
- <path
- display="inline"
- d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
- id="path128"
- <path
- display="inline"
- d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
- id="path130"
- <path
- display="inline"
- d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
- id="path132"
- <path
- display="inline"
- d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
- id="path134"
- <path
- display="inline"
- d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
- id="path136"
- <path
- display="inline"
- d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
- id="path138"
- <path
- display="inline"
- d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
- id="path140"
- <path
- display="inline"
- d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
- id="path142"
- <path
- display="inline"
- d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
- id="path144"
- <path
- display="inline"
- d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
- id="path146"
- <path
- display="inline"
- d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
- id="path148"
- <path
- display="inline"
- d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
- id="path150"
- </g>
- <g
- id="Project"
- display="inline"
- style="display:inline">
- <path
- id="path153"
- style="fill:#0054a4" />
- <path
- id="path155"
- <path
- id="path157"
- <path
- id="path159"
- <path
- id="path161"
- <path
- id="path163"
- <path
- id="path165"
- </g>
- <g
- id="Your_Open_Source_Compass">
- <path
- display="inline"
- d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
- id="path168"
- style="fill:#a0ce67;display:inline" />
- <path
- display="inline"
- d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
- id="path170"
- <path
- display="inline"
- d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
- id="path172"
- <path
- display="inline"
- d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
- id="path174"
- <path
- display="inline"
- d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
- id="path176"
- <path
- display="inline"
- d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
- id="path178"
- <path
- display="inline"
- d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
- id="path180"
- <path
- display="inline"
- d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
- id="path182"
- <path
- display="inline"
- d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
- id="path184"
- <path
- display="inline"
- d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
- id="path186"
- <path
- display="inline"
- d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
- id="path188"
- <path
- display="inline"
- d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
- id="path190"
- <path
- display="inline"
- d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
- id="path192"
- <path
- display="inline"
- d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
- id="path194"
- <path
- display="inline"
- d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
- id="path196"
- <path
- display="inline"
- d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
- id="path198"
- <path
- display="inline"
- d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
- id="path200"
- <path
- display="inline"
- d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
- id="path202"
- <path
- display="inline"
- d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
- id="path204"
- <path
- display="inline"
- d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
- id="path206"
- <path
- display="inline"
- d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
- id="path208"
- </g>
-</g>
-<g
- id="OSGeo"
- display="none"
- <path
- display="inline"
- d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
- id="path211"
- style="fill:#49a942;display:inline" />
- <path
- display="inline"
- d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
- id="path213"
- <path
- display="inline"
- d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
- id="path215"
- <path
- display="inline"
- d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
- id="path217"
- <path
- display="inline"
- d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
- id="path219"
-</g>
-<path
- style="fill:#008000"
- d="M 286.87254,201.50794 L 73.359882,201.50794 L 130.08949,148.86386 L 137.22852,157.17334 L 149.73521,145.40875 L 142.86208,137.01288 L 286.87254,-4.5997591 L 286.87254,201.50794 z"
- id="rect2660"
- sodipodi:nodetypes="cccccccc" /><path
- transform="matrix(1,0,0,1.1357143,-8.9371638,-38.430172)"
- style="fill:#ffffff"
- d="M 273.70065,153.522 C 273.70065,175.10525 253.0558,192.62209 227.61839,192.62209 C 202.18099,192.62209 181.53614,175.10525 181.53614,153.522 C 181.53614,131.93875 202.18099,114.42191 227.61839,114.42191 C 253.0558,114.42191 273.70065,131.93875 273.70065,153.522 z"
- id="path3829" /><path
- sodipodi:type="arc"
- id="path3827"
- sodipodi:cx="211.1405"
- sodipodi:cy="125.87266"
- sodipodi:rx="48.595829"
- sodipodi:ry="15.36075"
- d="M 259.73633,125.87266 A 48.595829,15.36075 0 1 1 162.54467,125.87266 A 48.595829,15.36075 0 1 1 259.73633,125.87266 z"
- transform="matrix(1.055678,-1.0206471,1.1066652,0.9736231,-144.07264,230.55011)" /><path
- style="fill:#008000;overflow:visible"
- id="path3831"
- transform="matrix(0.9661511,-0.899479,0.8597691,1.0106566,-93.533829,200.30513)"
- inkscape:transform-center-x="5.3222617"
- inkscape:transform-center-y="-4.2813473" /><text
- xml:space="preserve"
- style="font-size:75.93405151px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- x="-128.87492"
- y="123.78498"
- id="text2616"
- transform="matrix(0.485306,-0.4825086,0.9685605,1.097578,0,0)"><tspan
- sodipodi:role="line"
- id="tspan2618"
- x="-128.87492"
- y="123.78498"
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Sans;-inkscape-font-specification:Sans Bold">Ma<tspan
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#0000ff;font-family:Sans;-inkscape-font-specification:Sans Bold"
- id="tspan3823">p</tspan><tspan
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#ff0000;font-family:Sans;-inkscape-font-specification:Sans Bold"
- id="tspan3825">b</tspan>ender</tspan></text>
-<path
- style="fill:#ffffff;overflow:visible"
- d="M 187.26086,167.23724 C 169.24551,151.64732 168.44559,120.70407 185.66746,103.26088 C 202.88934,85.817692 230.84298,86.298055 249.65895,104.03727 C 249.65895,104.03727 255.81365,119.9254 231.53462,143.1981 C 207.53637,166.20164 187.26086,167.23724 187.26086,167.23724 z"
- id="path3838"
- sodipodi:nodetypes="csszs" /></svg>
\ No newline at end of file
Deleted: trunk/documents/logos/mapbender_dragon.svg
--- trunk/documents/logos/mapbender_dragon.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_dragon.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,500 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Created with Inkscape (http://www.inkscape.org/) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:xlink="http://www.w3.org/1999/xlink"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- version="1.0"
- width="1000"
- height="1000"
- id="svg2"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- sodipodi:docname="mapbender_dragon.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape">
- <metadata
- id="metadata4098">
- <rdf:RDF>
- <cc:Work
- rdf:about="">
- <dc:format>image/svg+xml</dc:format>
- <dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
- </cc:Work>
- </rdf:RDF>
- </metadata>
- <sodipodi:namedview
- inkscape:window-height="975"
- inkscape:window-width="1400"
- inkscape:pageshadow="2"
- inkscape:pageopacity="0.0"
- guidetolerance="10.0"
- gridtolerance="10.0"
- objecttolerance="10.0"
- borderopacity="1.0"
- bordercolor="#666666"
- pagecolor="#ffffff"
- id="base"
- showgrid="false"
- inkscape:zoom="0.6986215"
- inkscape:cx="500"
- inkscape:cy="500"
- inkscape:window-x="0"
- inkscape:window-y="25"
- inkscape:current-layer="svg2" />
- <defs
- id="defs4">
- <inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 500 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="1000 : 500 : 1"
- inkscape:persp3d-origin="500 : 333.33333 : 1"
- id="perspective4100" />
- id="perspective4267"
- inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
- inkscape:vp_z="744.09448 : 526.18109 : 1"
- inkscape:vp_x="0 : 526.18109 : 1"
- sodipodi:type="inkscape:persp3d" />
- id="perspective5038"
- </defs>
- <image
- y="80.668556"
- x="379.29614"
- id="image5040"
- height="510.33273"
- width="565.81177"
- sodipodi:absref="/home/seven/data/work/mapbender/logo/map.png"
- xlink:href="map.png" />
- <g
- id="layer2" />
- <text
- id="text4277"
- y="117.27086"
- x="49.206673"
- style="font-size:33.16645813px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- transform="scale(1.1179906,0.8944619)"><tspan
- y="117.27086"
- x="49.206673"
- id="tspan4279"
- sodipodi:role="line">0000111011100110010010</tspan><tspan
- id="tspan4287"
- y="158.72893"
- x="49.206673"
- sodipodi:role="line">0001111011000111000110</tspan><tspan
- id="tspan4298"
- y="200.18701"
- x="49.206673"
- sodipodi:role="line">0111000001111010001100</tspan><tspan
- id="tspan4300"
- y="241.64508"
- x="49.206673"
- sodipodi:role="line">0011111000001100011100</tspan><tspan
- id="tspan4302"
- y="283.10315"
- x="49.206673"
- id="tspan4314"
- y="324.56122"
- x="49.206673"
- id="tspan4336"
- y="366.01929"
- x="49.206673"
- id="tspan4338"
- y="407.47736"
- x="49.206673"
- id="tspan4340"
- y="448.93542"
- x="49.206673"
- id="tspan4342"
- y="490.39352"
- x="49.206673"
- id="tspan4344"
- y="531.85156"
- x="49.206673"
- id="tspan4346"
- y="573.30963"
- x="49.206673"
- id="tspan4348"
- y="614.7677"
- x="49.206673"
- id="tspan4350"
- y="656.22583"
- x="49.206673"
- id="tspan4352"
- y="697.6839"
- x="49.206673"
- sodipodi:role="line" /></text>
- <g
- transform="matrix(1.4110648,0.164685,-0.1326582,1.3227349,107.36509,-64.958801)"
- id="g4354">
- <g
- id="g4691"
- transform="matrix(0.9424289,-0.3848325,0.2905881,0.9424289,-92.49501,114.45179)">
- <path
- id="path2514"
- style="fill:#000080;stroke:none;stroke-opacity:1;display:inline"
- d="M 255.95193,117.56609 C 255.54896,117.56609 254.4178,123.20635 253.94832,127.52188 C 253.49139,131.72208 253.89922,138.94579 254.89412,144.09827 C 255.96529,149.6458 255.29122,164.27908 253.76165,168.61439 C 252.62502,171.8359 249.48405,174.09758 246.12059,174.11496 C 245.18972,174.11978 244.4281,174.30818 244.4281,174.53809 C 244.4281,175.27314 245.67371,177.40765 246.82994,178.64485 C 247.44624,179.30428 249.34385,182.53009 251.03626,185.81301 L 254.11011,191.78649 L 254.29678,195.63191 C 254.52437,200.35779 253.97361,202.5607 252.65407,202.17784 C 250.43763,201.53476 246.7787,199.54064 244.4281,197.69774 C 243.00442,196.58156 240.04755,194.34682 237.85728,192.73229 C 233.13147,189.24869 228.82885,185.69261 225.41255,182.44049 C 224.04538,181.13902 221.35731,178.76462 219.43908,177.16392 C 213.97614,172.6053 205.52805,163.33501 198.1088,153.75538 C 196.64196,151.86145 194.90879,149.74217 194.26338,149.05127 C 193.61801,148.36038 191.06379,143.774 188.58858,138.
85903 C 186.11341,133.94406 183.9771,129.92561 183.83469,129.92371 C 183.69224,129.92182 183.35693,130.83125 183.08801,131.95221 C 181.96607,136.62906 183.251,144.2933 188.01612,161.25955 C 191.14582,172.40279 191.48912,179.94953 189.09881,185.05389 C 188.68497,185.93765 187.99494,187.46568 187.56811,188.4513 C 186.46589,190.99667 185.08934,192.19866 180.56173,194.52433 L 176.57941,196.56526 L 178.54568,198.30753 C 179.6256,199.26582 182.57279,201.65227 185.09161,203.60898 C 187.61042,205.56569 190.34741,208.07803 191.17709,209.19667 C 192.92871,211.55833 192.80304,211.96752 189.87039,213.29099 C 188.37754,213.96469 186.84833,214.14641 180.71106,214.38612 C 174.86694,214.61438 172.19114,214.91918 167.76854,215.8546 C 160.64382,217.36155 149.02128,218.64918 148.37964,218.00754 C 148.04206,217.66996 148.60538,216.83178 150.60725,214.70969 C 153.717,211.41322 155.54541,208.68699 157.65097,204.19389 C 159.16007,200.97355 161.04697,194.9336 160.6626,194.54922 C 160.54994,194.4365
6 159.04868,195.41674 157.32741,196.72705 C 147.0843,204.52445 135.21248,210.68272 121.7728,215.1577 C 114.82554,217.47092 111.78072,217.92043 103.24259,217.92043 C 99.657396,217.92043 96.627273,218.07913 96.509995,218.26888 C 97.890038,222.11499 119.19037,231.79283 121.76036,233.86213 C 134.21051,240.07656 150.65295,244.00722 166.17561,244.47749 C 172.90238,244.68128 173.48728,244.63353 175.67095,243.80548 C 176.98013,243.30902 177.84348,242.77969 177.64966,242.58589 C 177.46022,242.39643 176.11472,242.0697 174.66292,241.8641 C 171.18497,241.37156 164.36072,239.02088 159.40568,236.61242 C 155.29955,234.61657 149.25078,230.8569 149.25078,230.30294 C 149.25078,230.1305 151.80444,229.87234 154.92557,229.73048 C 158.04671,229.58863 163.46764,229.10904 166.97208,228.66023 C 175.03666,227.62742 191.40437,227.15047 194.74872,227.85133 C 196.08535,228.13143 197.03855,228.55109 197.03855,228.84691 C 197.03855,229.85881 195.42708,233.97418 194.17627,236.17685 C 193.47175,237.41751 19
1.85695,239.53044 190.57974,240.86852 L 188.25257,243.29524 L 191.1522,243.99215 C 195.19198,244.95334 199.57696,247.2089 202.19067,249.67939 C 204.33189,251.70327 204.3741,251.78849 203.60937,252.3799 C 202.56278,253.18927 199.23672,254.16008 197.46168,254.17194 C 196.68007,254.17716 195.32616,254.35919 194.45005,254.58262 C 193.57394,254.80604 190.25866,255.50689 187.08277,256.13821 C 176.83778,258.17473 160.86129,263.09582 151.29171,267.16424 C 146.2196,269.32061 136.80763,273.98908 133.62019,275.92533 C 127.64049,281.12024 120.29419,287.68779 117.05625,294.89111 C 115.66594,298.23259 114.59441,304.62296 114.60464,309.56345 C 115.1144,317.97373 121.66185,332.8172 129.79966,335.5605 C 135.19143,338.20567 144.81468,339.52892 152.0384,338.60946 C 158.78856,337.15301 166.46608,334.86786 172.21131,331.20484 C 177.6055,328.47641 182.95953,326.89508 187.705,323.05354 C 189.11646,323.05354 189.14337,323.07766 188.57614,323.94956 C 183.61381,331.57692 181.69318,335.84573 178.91902
,345.39184 C 178.13737,348.08159 177.35254,350.47091 177.17676,350.70574 C 177.00094,350.94057 176.55373,351.93529 176.18118,352.9209 C 175.04013,355.93992 173.79432,356.91325 170.26993,357.52546 C 168.37618,357.85442 164.48685,356.68797 164.17201,355.69608 C 164.049,355.3084 163.40922,354.24179 162.74087,353.31914 L 161.52128,351.6391 L 158.90789,351.81332 C 156.59787,351.96041 156.19541,352.10174 155.37359,353.13246 C 154.86293,353.77288 154.34053,354.81202 154.20378,355.43474 C 154.06699,356.05746 153.12021,357.6784 152.10062,359.03127 C 151.08103,360.38414 149.92821,362.1997 149.54945,363.07581 C 148.75382,364.91599 145.86236,377.65914 144.1111,387.03192 C 141.80215,399.38945 140.1601,404.91249 136.53226,412.45651 C 133.89612,417.93828 131.47093,420.85471 125.78001,425.39904 C 121.67464,428.67728 121.39733,429.27189 121.08834,435.41705 C 120.8768,439.62398 121.14991,441.39552 122.68127,445.49728 C 123.13816,446.72107 125.21812,449.29293 125.74267,449.29292 C 126.11602,44
9.29292 128.02434,445.07262 128.67963,442.80922 C 129.0159,441.6479 129.49581,440.99506 130.24767,440.64383 C 130.84139,440.36648 131.82317,439.90372 132.4255,439.62337 C 133.16282,439.28019 133.95289,438.23577 134.85222,436.42507 C 136.24671,433.6174 139.30435,429.94612 140.98747,429.04534 C 141.84463,428.58662 142.18482,428.62524 143.71287,429.39379 C 146.11444,430.6017 148.24277,432.96451 149.92279,436.30062 C 151.06631,438.57135 151.43822,439.93298 151.86417,443.38168 C 152.82765,451.18285 153.47112,452.12949 158.01187,452.47878 L 160.60037,452.67789 L 161.68307,454.86817 C 162.5305,456.58305 162.7682,457.64187 162.7782,459.7465 C 162.78525,461.22494 162.63854,462.43457 162.45464,462.43456 C 161.47758,462.43456 160.78623,466.18687 161.69551,466.55377 C 163.05989,467.10431 164.3407,466.46792 167.08408,463.86571 C 169.81997,461.27063 170.03189,460.03712 169.83437,448.07334 L 169.7597,443.05811 L 167.5072,440.30783 C 163.27237,435.10776 162.09743,432.56721 163.92312,432.567
2 C 164.92642,432.5672 175.73277,437.95538 176.72875,438.95135 C 177.35122,439.57381 178.26188,439.87512 179.87727,440.0216 C 182.42854,440.25294 184.35673,439.50696 186.84632,437.32109 L 188.24013,436.10151 L 191.21442,436.52463 C 194.7314,437.0138 197.38191,437.95584 198.25814,439.03846 C 199.2632,440.28028 200.40333,439.79481 200.54797,438.05533 C 200.6488,436.84301 200.38171,436.19163 199.0546,434.43391 C 198.16575,433.25659 197.43678,432.11114 197.43679,431.88274 C 197.43679,431.0887 194.20482,428.5676 191.56287,427.29063 C 190.10084,426.58399 188.39759,425.4211 187.76723,424.71457 C 186.24475,423.00822 184.62039,422.62791 178.91902,422.61141 C 174.60829,422.59894 173.86722,422.48592 171.35262,421.4665 C 169.28835,420.62963 168.56501,420.14263 168.565,419.58734 C 168.565,418.50922 172.40957,417.74996 176.52963,418.01931 C 179.59805,418.2199 179.81675,418.17117 182.42844,416.79972 C 184.89289,415.50561 185.32859,415.39997 187.20721,415.65481 C 189.73571,415.99782 193.202
15,417.2552 193.87759,418.06909 C 194.27746,418.55086 194.43631,418.57024 194.69894,418.1562 C 195.67529,416.61708 194.62394,413.46976 191.77443,409.40755 C 190.19867,407.16115 189.79327,406.86091 185.77607,404.95234 C 182.17749,403.24265 181.43264,402.7302 181.24619,401.8536 C 180.93166,400.37479 179.56583,399.75432 177.35099,400.08645 C 175.29408,400.3949 173.3475,401.81958 172.98288,403.2723 C 172.73116,404.27519 172.35295,404.42163 168.66456,404.92745 C 166.3318,405.24736 161.86898,404.44294 160.69993,403.4963 C 159.89757,402.8466 159.82197,402.4404 159.81636,398.0704 C 159.80556,389.66914 161.53843,385.69343 166.48673,382.75093 L 169.36147,381.046 L 175.13582,380.99622 C 179.13144,380.96214 181.45917,380.75631 182.71467,380.33665 C 183.97594,379.91505 184.82573,379.84408 185.50229,380.1002 C 186.03755,380.30284 188.45666,380.39415 190.86597,380.31176 C 194.47478,380.18836 195.56223,380.00201 197.03855,379.24152 C 199.45833,377.99502 200.52342,376.96127 201.63066,374.786
3 C 202.51462,373.05002 202.66823,372.94397 204.55517,372.72048 C 208.48464,372.25509 211.21493,370.2506 213.1296,366.42344 C 214.22191,364.24004 214.94291,363.32979 216.26567,362.4909 C 219.23034,360.61077 221.72043,356.26216 221.72891,352.94579 C 221.73034,352.38322 222.09022,351.38772 222.52537,350.73063 C 222.96056,350.07355 223.30796,349.25523 223.30939,348.9137 C 223.31086,348.57217 224.29364,347.4552 225.48722,346.42475 C 226.6808,345.39429 228.51764,343.39015 229.56909,341.96954 C 230.62054,340.54893 231.57518,339.39166 231.68469,339.39348 C 231.79421,339.39528 232.25365,340.06731 232.70516,340.88685 C 233.15672,341.70639 235.09767,345.19986 237.02349,348.65236 C 238.94925,352.10486 241.78407,357.66019 243.32052,360.99754 L 246.10814,367.05812 L 245.90903,370.64221 C 245.67702,374.85732 244.82291,377.36045 242.48672,380.62288 C 240.59281,383.26772 240.31935,385.32033 241.5907,387.40526 C 242.21927,388.43606 242.92573,388.82643 245.87169,389.74487 C 247.81156,390.3496
4 250.30201,391.30477 251.39715,391.86048 C 252.49229,392.4162 255.74104,393.81264 258.62754,394.97166 C 262.94011,396.70329 265.1765,397.9482 271.17184,401.94071 C 275.1847,404.61301 278.54201,406.85916 278.62623,406.93105 C 278.71046,407.00294 278.55115,407.62242 278.26533,408.31242 C 277.73939,409.58218 275.80352,411.05997 274.66881,411.0627 C 273.98397,411.06435 271.85562,413.16454 271.15939,414.52234 C 270.91408,415.00075 270.71138,415.7656 270.71138,416.21482 C 270.71138,416.66405 269.81536,418.73218 268.72022,420.81937 C 266.92464,424.24157 266.72906,424.8706 266.72907,427.20352 C 266.72907,428.99585 266.97482,430.33465 267.55042,431.55918 C 268.85152,434.32712 269.28517,434.47505 270.25093,432.48009 C 271.306,430.30058 274.23449,427.43163 277.23242,425.63549 C 279.5023,424.27554 279.60487,424.25665 280.77917,424.86391 C 281.59164,425.28406 282.62682,425.42447 283.92769,425.29948 C 286.94318,425.00973 287.95032,423.7328 289.39093,418.35532 C 289.94809,416.2756 291.608
73,414.24856 292.751,414.24855 C 293.22442,414.24855 294.8642,414.52115 296.39731,414.8459 C 297.93042,415.17064 300.13624,415.43944 301.30054,415.44325 C 303.6061,415.45078 304.22013,415.69807 306.70155,417.58374 C 307.60884,418.27319 309.91616,419.54536 311.82878,420.42114 L 315.31331,422.01407 L 315.31331,423.93056 C 315.31331,427.35075 317.07662,429.38135 320.05475,429.38135 C 320.93114,429.38135 322.27506,429.08726 323.04149,428.72178 C 324.23216,428.154 324.68532,428.12657 326.09045,428.54755 C 328.11553,429.15428 331.05252,431.99682 331.42924,433.71212 C 331.74523,435.15081 332.66585,435.35021 334.25419,434.30946 C 336.44164,432.87619 337.1963,428.70566 335.62311,426.70573 C 335.14352,426.09601 334.82666,425.09216 334.82665,424.17945 C 334.82665,423.34581 334.648,422.54804 334.42842,422.4123 C 333.89873,422.08493 332.59209,419.16859 332.23815,417.50907 C 331.82327,415.56377 330.26862,414.81428 325.51799,414.261 C 321.07548,413.74359 318.49258,412.95593 317.46625,411.8
2183 C 316.83366,411.12281 316.8436,411.07114 317.74003,410.73914 C 324.19198,408.34966 329.40759,406.68216 330.4461,406.68216 C 331.15121,406.68216 332.94325,406.98327 334.42842,407.34173 C 336.01553,407.7248 337.59138,407.8798 338.2614,407.71507 C 338.89466,407.55936 340.37976,406.39864 341.59659,405.11412 C 342.80124,403.84249 344.23488,402.69262 344.78244,402.56295 C 345.88773,402.30118 352.54923,398.5888 353.64309,397.62239 C 354.85909,396.5481 354.42326,395.73367 351.63949,393.8143 C 349.41863,392.28304 348.63269,391.95044 347.15938,391.94759 C 343.42632,391.94036 341.23245,391.4914 340.97435,390.67823 C 340.57512,389.42038 338.4172,388.36517 336.23291,388.36351 C 334.36982,388.3621 334.16101,388.47901 332.16348,390.54134 C 331.00263,391.73986 329.19808,393.10082 328.15627,393.56541 C 327.1145,394.03 325.63753,394.8384 324.87086,395.35745 C 324.10415,395.87651 322.3121,396.54889 320.88855,396.85082 C 319.46495,397.15274 317.67284,397.78514 316.90623,398.25707 C 315.972
9,398.83167 314.85453,399.11476 313.53371,399.11576 L 311.56744,399.11576 L 312.98614,397.62239 C 313.7713,396.80104 314.64726,395.68101 314.92752,395.13344 C 315.20776,394.58587 316.6558,393.01162 318.13826,391.63647 L 320.82632,389.13508 L 320.78899,385.26477 C 320.76999,383.06289 320.97387,380.87925 321.24945,380.19976 C 321.51594,379.54268 322.84363,378.00047 324.19885,376.76501 C 325.55407,375.52956 326.52186,374.3772 326.35179,374.2014 C 325.73102,373.55985 319.03893,373.51427 317.20491,374.13918 C 316.02638,374.54074 314.54435,374.66492 312.68747,374.53741 C 309.97304,374.35101 309.91005,374.37135 308.64293,375.69477 C 307.56161,376.82414 307.22343,377.67472 306.52733,381.00867 C 306.07139,383.19224 305.3349,386.05377 304.88462,387.36793 C 304.43438,388.68209 303.97119,390.15598 303.86415,390.64089 C 303.59778,391.8474 300.5428,393.26592 297.77868,393.46585 C 296.14808,393.5838 294.7986,393.36031 292.60167,392.61961 C 290.96549,392.06797 288.6215,391.34426 287.39977,3
91.00179 C 286.17807,390.65932 284.50829,389.92601 283.69124,389.37153 C 282.87419,388.81706 281.4608,387.97722 280.54272,387.51726 C 278.14815,386.31762 274.28263,383.32412 272.96388,381.64335 C 272.01875,380.43876 271.86333,379.92962 272.01808,378.51972 C 272.27816,376.14972 273.23498,374.89582 275.61461,373.8405 C 279.64061,372.05504 280.22016,370.56508 280.24405,361.94334 C 280.25368,358.47335 280.07111,353.45563 279.83337,350.79285 C 279.44828,346.48018 279.27429,345.76495 278.24044,344.24692 C 277.60208,343.30965 277.08308,342.49244 277.08308,342.42999 C 277.08308,342.36755 279.18873,342.3979 281.7623,342.49222 C 286.4332,342.66341 286.44476,342.6672 288.23357,344.09759 C 289.21919,344.88571 290.16563,345.75219 290.33673,346.02652 C 290.50785,346.30084 291.47056,346.88794 292.47722,347.33322 C 294.90349,348.40648 299.38865,348.41073 303.55303,347.34566 L 306.67666,346.5492 L 308.77982,347.58211 C 311.39019,348.85924 315.56971,349.36175 315.9231,348.4408 C 316.13002,347
.90154 316.42034,347.91357 318.44938,348.52791 C 322.29036,349.69087 323.90353,351.16282 322.68059,352.38578 C 321.88676,353.17959 321.90387,356.20787 322.71792,357.82413 C 323.99135,360.35237 327.58008,363.27493 329.40075,363.27492 C 329.72017,363.27492 330.34751,363.87069 330.79456,364.59406 C 331.24165,365.31746 332.81673,367.06471 334.30397,368.47682 C 335.79121,369.88895 337.55449,371.6973 338.21162,372.49647 C 338.86874,373.29565 340.92956,375.09029 342.79128,376.47879 C 347.10305,379.69451 352.56394,384.93135 355.59691,388.76174 C 358.98861,393.04522 359.2228,393.27428 363.6611,396.61437 C 368.66822,400.38253 368.98498,400.79829 367.84253,401.94071 C 367.08601,402.69726 366.72077,402.76132 364.51979,402.52561 C 361.75371,402.22939 361.27411,402.49654 361.04771,404.47944 C 360.93827,405.43792 360.67175,405.7067 359.66634,405.91058 C 357.75889,406.29736 355.31058,408.26607 352.48573,411.67249 C 350.11394,414.53258 349.43262,416.07077 349.68566,417.95708 C 350.07601,420.
8673 350.54858,420.92784 354.77556,418.67888 C 358.42133,416.73914 358.54773,416.70379 359.85301,417.26018 C 361.56879,417.99155 365.91471,418.00013 367.65586,417.27262 C 368.39621,416.96328 369.42124,416.29127 369.93325,415.77926 C 370.7458,414.96668 371.24632,414.84958 373.85334,414.85835 C 376.34487,414.86672 377.19332,415.05186 378.99301,415.99082 C 381.68303,417.39432 385.15367,420.64254 386.49719,423.00965 C 387.05833,423.99834 388.15042,425.78471 388.92391,426.97952 C 390.25372,429.03373 390.33228,429.34026 390.35505,432.64187 C 390.38341,436.74976 390.63674,437.12561 394.6236,439.08824 C 397.6897,440.5976 398.94193,442.59734 398.94192,445.97018 C 398.94192,448.46934 399.4697,450.03025 400.42284,450.32584 C 400.80945,450.44573 401.45699,450.72218 401.85399,450.93563 C 404.2466,452.22206 408.30131,447.43896 408.77326,442.77188 C 408.89882,441.53016 408.72714,439.78407 408.33769,438.29178 C 407.96133,436.84943 407.70388,434.23364 407.70301,431.92008 C 407.7013,427.4425
407.09815,425.93171 404.84072,424.76435 C 402.59454,423.60281 398.54393,419.72 398.54369,418.72866 C 398.54345,417.86197 398.65972,417.83264 402.33933,417.83264 C 404.4316,417.83264 407.43328,418.1272 409.00971,418.47976 C 411.82318,419.10899 411.95175,419.18961 415.64275,422.86031 C 419.16814,426.36629 419.50679,426.59373 421.04377,426.59373 C 421.9454,426.59373 423.0329,426.33041 423.45805,426.00883 C 424.36661,425.32163 426.69936,425.23641 428.2866,425.82216 C 428.90319,426.04969 430.43165,427.34891 431.68402,428.70933 C 433.53822,430.72355 434.02598,431.07214 434.34719,430.58849 C 434.93522,429.70301 435.31411,425.99861 435.04409,423.719 C 434.50338,419.15342 430.58297,413.56388 426.14611,411.02537 C 424.32014,409.98067 424.03051,409.63903 424.0305,408.61109 C 424.0305,407.80682 423.6211,407.01944 422.79848,406.19681 L 421.57889,404.97723 L 416.86234,405.21368 C 411.74104,405.47117 409.64364,405.12781 408.2008,403.79498 C 407.03725,402.72013 407.06179,402.6036 408.59903,
401.95316 C 409.31087,401.65196 410.70539,400.88905 411.71022,400.26067 C 412.715,399.63229 414.03209,399.11576 414.62229,399.11576 C 416.09013,399.11576 418.16179,398.20282 419.1895,397.09971 C 420.08242,396.14129 420.33074,394.5586 419.64996,394.13786 C 419.43093,394.0025 419.25173,393.54934 419.25173,393.12984 C 419.25173,392.09697 421.19172,391.15113 423.32115,391.15113 C 424.89126,391.15113 425.31424,391.39028 427.88837,393.73963 L 430.71333,396.32814 L 431.9578,394.92188 C 433.04672,393.68166 433.18984,393.23353 433.18983,391.10135 C 433.18983,388.13069 432.41889,386.39897 430.25287,384.53053 C 427.86105,382.46733 425.71439,381.43191 423.23404,381.13312 C 415.7999,380.23758 416.0586,380.22637 413.47737,381.63091 C 411.11888,382.91427 409.61697,383.15431 408.71104,382.40248 C 407.81677,381.66028 405.33394,383.86207 404.0816,386.50924 C 403.44391,387.85722 402.92441,389.3347 402.92424,389.79465 C 402.92392,390.62492 401.18063,393.33591 400.09928,394.18764 C 399.78898,394
.43206 397.95174,395.30574 396.01741,396.12902 C 393.03995,397.39626 392.22604,397.58389 390.69106,397.37349 C 387.87756,396.98786 385.79591,395.63178 385.04115,393.67741 C 384.6884,392.764 384.02249,391.59918 383.56023,391.0889 C 383.098,390.57863 381.79277,388.76672 380.66061,387.06925 C 379.52839,385.37179 378.4373,383.98296 378.23388,383.98296 C 377.65027,383.98296 374.25158,381.83749 374.25157,381.46912 C 374.25157,381.28673 373.2737,379.08908 372.08618,376.59079 C 370.34532,372.92838 369.3191,371.36707 366.77228,368.5266 C 360.41257,361.4335 354.72286,351.18213 356.28137,349.62305 C 356.6403,349.264 359.78161,349.13771 368.3901,349.1377 L 380.02592,349.1377 L 383.162,350.73063 C 384.88905,351.60674 386.39173,352.63717 386.49719,353.02046 C 386.64286,353.54991 387.07607,353.71019 388.32656,353.68003 C 391.18355,353.61113 391.62156,353.29232 393.97647,349.53594 C 397.0724,344.59749 400.28355,340.71902 402.04066,339.80415 C 403.36534,339.11445 405.31363,336.86719 405.3136
2,336.02096 C 405.31362,335.84051 406.69304,333.97019 408.38747,331.86441 C 410.10485,329.7301 411.7436,327.23837 412.08356,326.23939 C 412.71627,324.37999 414.87274,320.3381 417.08634,316.86851 C 417.7901,315.76547 419.51182,313.79423 420.90688,312.48796 C 424.16927,309.43313 425.2102,307.99583 426.83057,304.33666 C 427.55798,302.69396 428.57959,300.76707 429.10796,300.04323 C 429.93321,298.91272 430.27225,298.74425 431.50979,298.84853 C 433.17663,298.98898 433.47416,299.61203 433.53828,303.12952 C 433.60578,306.82993 434.45467,308.34792 437.88149,310.90748 C 439.54602,312.15073 441.10658,313.55768 441.34113,314.03111 C 441.70133,314.75807 442.27693,314.95152 445.04966,315.25069 C 450.97574,315.8901 455.50108,314.12924 458.17886,310.14835 C 459.41119,308.31639 460.15922,306.47882 459.8091,306.1287 C 459.72121,306.04083 458.48813,306.17412 457.07126,306.41493 C 454.59097,306.8365 454.43092,306.8094 452.93962,305.7927 C 452.08769,305.2119 451.19166,304.73695 450.94846,304.734
89 C 450.39496,304.73019 447.16551,299.33347 446.86659,297.91518 C 446.74314,297.32941 446.22342,296.66742 445.68434,296.42181 C 445.15302,296.17972 444.59746,295.67453 444.45231,295.28934 C 444.30716,294.90415 443.68796,293.90116 443.08339,293.06173 C 441.85326,291.35377 441.18882,288.21125 441.90114,287.49894 C 442.16015,287.23992 442.34916,285.68102 442.34915,283.79041 C 442.34915,280.56904 442.37345,280.49246 443.96697,278.4765 C 445.99779,275.90733 446.72875,273.9033 447.10304,269.9892 C 447.45305,266.32875 448.00174,265.55446 450.83646,264.71263 C 454.43723,263.64331 454.69434,263.33107 454.69433,259.90896 C 454.69433,256.08919 455.5866,254.19019 458.16639,252.55412 C 460.37379,251.15421 461.04147,251.11196 463.2812,252.23056 C 465.42751,253.30247 466.24305,253.02486 466.24305,251.23498 C 466.24305,249.46646 463.92793,247.10214 460.56825,245.42329 C 458.48625,244.3829 457.7138,244.20371 455.01789,244.20371 C 451.47865,244.20371 448.95899,245.18937 446.23191,247.63845 C
445.32084,248.45665 444.14303,249.0674 443.1954,249.21893 L 441.65225,249.46783 L 440.40777,255.6902 C 439.72341,259.10837 438.91811,262.14533 438.61573,262.44769 C 438.14821,262.91521 437.90577,262.67302 436.99792,260.81743 C 436.41076,259.61734 435.68117,257.22626 435.3801,255.50353 C 435.07904,253.7808 434.60415,251.54413 434.33474,250.53808 C 433.85149,248.73349 433.86534,248.69068 435.30543,246.80466 C 436.47611,245.27151 436.77392,244.54056 436.77391,243.13346 C 436.77391,241.21099 436.11315,239.63689 434.82009,238.46668 C 433.76904,237.51551 433.76747,236.837 434.83253,233.96169 C 435.44808,232.29987 436.2509,231.14254 437.70727,229.7927 C 438.81813,228.76306 439.63047,227.8207 439.51175,227.70199 C 439.08604,227.27626 435.01648,226.68153 432.51781,226.68152 C 429.39719,226.68152 427.79838,227.31433 425.84744,229.31981 C 423.53287,231.69907 422.53256,233.73751 422.08913,236.98576 C 421.80547,239.06351 421.43524,240.18848 420.81976,240.84363 C 420.31122,241.38492 419.
87558,242.48659 419.76196,243.49436 C 419.59403,244.98426 419.81653,245.69853 421.46689,248.79581 C 423.39644,252.41706 423.76311,253.82128 424.26695,259.54806 C 424.46567,261.80695 424.39279,262.44411 423.89361,262.85836 C 423.00986,263.59183 422.01919,262.95059 420.19753,260.46897 C 418.89415,258.69345 418.65606,258.04086 418.51749,255.86442 C 418.37173,253.57519 418.23734,253.24788 417.11123,252.40479 C 415.43308,251.14844 414.1643,250.79569 413.44004,251.39676 C 412.26521,252.37179 411.13073,251.28922 410.12974,248.2358 C 409.07769,245.02676 409.17106,243.81126 410.71464,240.32095 C 411.24699,239.11718 411.68534,238.04182 411.68533,237.93156 C 411.68533,237.52561 408.38075,238.27546 406.96877,239.00181 C 403.53889,240.76628 401.6834,244.19488 401.40598,249.2936 C 401.22188,252.67689 401.63923,254.82124 403.31002,259.06272 C 403.99215,260.79439 404.00192,261.09172 403.4718,262.36057 C 402.57937,264.49644 403.08667,266.2394 405.12695,268.03537 C 406.92788,269.62059 409.095
46,270.48699 411.24976,270.48699 C 412.87236,270.48699 416.13347,273.48355 418.66682,277.29425 C 421.21614,281.12896 421.13664,282.0473 417.95747,284.77354 C 414.82877,287.45648 410.02165,292.07053 408.64881,293.7213 C 402.15254,301.5329 394.80968,308.77889 387.82877,314.24267 C 385.9725,315.69552 383.99019,317.32897 383.43578,317.87653 C 381.61403,319.67571 380.45592,320.26324 378.70678,320.26592 C 377.41934,320.2679 376.75436,320.03091 376.01872,319.29523 C 375.48111,318.75762 375.04804,318.03971 375.04803,317.70231 C 375.04803,317.36491 375.95389,315.96114 377.06408,314.59112 L 379.08013,312.10218 L 378.9059,308.31898 C 378.80642,306.23822 378.50385,303.81897 378.23388,302.94285 C 377.74812,301.36626 377.76666,301.31319 380.01348,297.76584 L 382.27842,294.18176 L 382.07931,289.6021 C 381.96844,287.08328 381.6784,284.03682 381.43218,282.83216 C 381.15019,281.45256 381.07525,278.784 381.23306,275.62666 C 381.4626,271.03563 381.40316,270.4661 380.62327,268.80695 C 380.15491,
267.81061 379.16232,266.2782 378.40811,265.39709 C 377.04544,263.8051 377.03321,263.7661 377.03919,259.87163 C 377.04484,256.15321 376.97519,255.80885 375.62049,253.16392 C 374.46271,250.9035 373.70198,250.01973 371.62573,248.47225 C 369.15267,246.62902 369.07457,246.49758 369.07456,244.80105 C 369.07456,242.84923 369.6833,241.17645 370.51815,240.85607 C 370.82984,240.73647 372.22205,241.68195 373.74133,243.05879 C 375.20922,244.38902 377.57851,246.32148 379.00546,247.33978 C 381.46183,249.09272 381.75549,249.18797 384.60559,249.31849 C 386.26119,249.39431 388.41908,249.24668 389.39681,248.98248 L 391.17641,248.49714 L 389.48392,247.04111 C 387.94567,245.7138 387.30815,244.60194 388.09011,244.60194 C 388.25813,244.60194 389.33336,243.78762 390.4795,242.78501 C 391.96459,241.4859 392.57022,240.66669 392.57022,239.94761 C 392.57022,239.00631 392.46574,238.96449 391.13907,239.21337 C 390.35691,239.3601 389.50161,239.55907 389.23503,239.66138 C 388.95579,239.76853 388.36787,239.
03951 387.84122,237.94401 C 387.33837,236.89799 386.37238,235.1797 385.70072,234.12347 L 384.48114,232.20698 L 385.22782,230.7385 C 385.85137,229.51405 386.00302,228.13391 386.12384,222.33831 C 386.20429,218.48104 383.24726,210.96718 383.03755,210.50337 C 382.82325,210.02944 379.9602,215.20236 378.37078,219.92403 C 379.34495,215.03304 380.38484,213.91364 379.95126,209.43312 C 385.83734,209.71281 391.65512,209.78671 397.89656,209.80646 C 406.33238,209.7737 408.64185,209.87203 408.79815,210.27936 C 408.90719,210.56362 408.41053,211.95964 407.69057,213.3781 C 406.01135,216.6864 404.87554,220.02727 405.28874,220.44671 C 405.84088,221.00718 408.7121,219.97164 411.1502,218.34355 C 414.18624,216.31615 418.26053,212.06539 420.52109,208.56199 C 425.41794,200.9729 426.77478,198.04818 427.85104,192.76962 C 428.55603,189.31192 428.84932,180.10227 428.29905,178.75685 C 427.86394,177.69305 427.02317,178.50185 426.27056,180.71067 C 425.53299,182.87532 422.70888,186.62542 420.3842,188.51352
C 416.38416,191.76239 410.34662,194.59014 404.80339,195.81858 C 401.38127,196.57697 401.22536,196.84922 402.96157,199.30311 C 403.9016,200.63176 403.51066,201.66702 401.70465,202.60096 C 399.83045,203.57014 389.83594,202.14526 386.65897,201.87917 C 384.38799,201.69111 383.47493,201.67274 380.73527,201.30671 C 380.85801,200.86075 384.81341,196.80918 385.06604,194.1261 C 385.3646,190.955 384.98981,188.37663 385.29005,188.37663 C 385.54412,188.37663 386.93018,189.75461 387.51765,190.36779 C 388.34522,191.23162 388.72172,192.25966 389.22258,194.95989 C 390.00519,199.17883 390.51574,199.31543 392.49555,195.81858 C 393.82198,193.47577 393.84315,193.32611 394.00136,187.85395 C 394.12645,183.52758 394.33249,181.87729 394.92227,180.48667 C 395.34026,179.50105 395.80406,177.43367 395.95518,175.89456 C 396.22929,173.10266 396.23099,173.09253 394.79782,171.37712 C 393.00323,169.22918 392.93487,167.86243 394.53648,166.03833 C 396.23586,164.10283 398.87991,163.58766 405.38829,163.94762 C
408.66606,164.1289 410.49064,164.08844 410.49063,163.83561 C 410.49063,163.21382 407.97513,161.17069 405.23896,159.56707 L 402.72512,158.09859 L 397.74723,158.28526 C 392.52382,158.47297 390.62373,158.95819 387.79144,160.84888 C 386.72517,161.56066 385.85097,161.76837 384.00824,161.76979 C 381.15607,161.77198 377.28018,163.20867 375.9565,164.74408 C 375.4519,165.32942 373.84057,166.19859 372.1733,166.79746 C 370.57603,167.37121 368.05859,168.44776 366.58561,169.18685 C 365.11263,169.92593 363.64103,170.53089 363.31265,170.53088 C 362.31567,170.53088 361.62605,168.53059 361.33393,164.8063 C 360.89126,159.16317 359.48836,156.81551 355.92047,155.74654 C 354.66652,155.37084 354.23506,155.39188 353.71776,155.82121 C 353.07613,156.35372 353.08961,157.1888 353.76754,159.91552 C 354.01639,160.91649 353.78552,161.28687 351.68927,163.32538 C 349.59959,165.35755 346.65964,167.14466 344.12287,167.91749 C 343.41509,168.13311 342.41444,167.32336 338.32362,163.2756 C 335.60422,160.58484 3
31.63567,156.29323 329.51275,153.73049 C 327.38986,151.16775 324.24728,147.82409 322.51881,146.30098 C 318.48914,142.75009 311.77678,137.70391 311.48033,138.00035 C 311.10894,138.37173 313.25762,141.99963 315.0893,144.09827 C 317.7156,147.10733 318.48495,149.26296 318.77294,154.39006 L 319.02184,158.78305 L 320.58987,160.57509 C 321.45328,161.56072 322.78556,163.43718 323.55172,164.74408 C 325.03525,167.27457 325.16405,169.21721 323.92506,170.45621 C 323.42397,170.9573 323.15007,170.90701 321.78457,170.08287 C 318.09253,167.85461 314.91508,165.57912 314.91508,165.15476 C 314.91508,164.90318 314.33267,164.50678 313.62082,164.27118 C 312.90899,164.03557 309.45931,162.84698 305.95487,161.6329 C 302.45043,160.41881 298.14954,159.1367 296.39731,158.78305 C 294.64509,158.4294 291.68823,157.59068 289.82649,156.92879 C 285.81877,155.50394 281.48373,154.20339 280.75428,154.20339 C 280.36314,154.20339 280.3449,154.39606 280.65472,154.97496 C 280.88148,155.39862 281.06333,156.16024 281
.0654,156.66745 C 281.07129,158.10408 283.85887,162.14214 287.36243,165.80188 C 291.08355,169.6889 293.26653,172.39883 294.74216,174.94876 C 295.58351,176.40268 295.79511,177.29727 295.79996,179.32931 C 295.80331,180.73374 295.93775,182.0883 296.09864,182.34093 C 296.25956,182.59356 297.4477,182.99869 298.73692,183.23695 C 301.42224,183.73321 303.78164,185.4189 305.97976,188.41396 C 307.1946,190.06923 307.32735,190.51222 307.33623,192.96874 C 307.34169,194.46542 307.48309,195.61655 307.64735,195.53235 C 311.83292,193.38726 314.39899,192.92397 317.41647,193.75276 L 318.53649,194.05143 L 316.396,196.42837 C 313.70049,199.407 312.12746,202.45623 312.12746,204.69168 C 312.12746,205.6194 312.23793,206.37172 312.37635,206.37172 C 312.51478,206.37172 313.27206,205.97286 314.05639,205.48814 C 315.18685,204.78949 316.23931,204.58346 319.17118,204.45523 L 322.87971,204.29344 L 322.87971,210.82693 C 322.87971,216.81774 322.80524,217.50711 321.98369,219.11512 C 321.38255,220.29173 320.5
8424,221.11901 319.55696,221.6414 L 318.02626,222.42542 L 317.06802,221.26806 C 316.54426,220.63347 315.55646,219.21468 314.8653,218.11954 C 314.17413,217.02441 313.08945,215.38516 312.46346,214.47324 C 311.83744,213.56132 311.331,212.66945 311.33099,212.49452 C 311.33099,212.31959 310.62821,211.44999 309.7754,210.56559 C 307.54284,208.25042 301.77344,200.71389 301.77344,200.11201 C 301.77344,199.83154 300.01695,197.40506 297.87824,194.72344 C 293.82384,189.63973 285.55426,178.65904 283.70368,175.90701 C 283.11454,175.0309 281.90439,173.32846 281.01562,172.12381 C 280.12689,170.91916 278.88154,168.92767 278.25289,167.69348 C 277.6242,166.4593 276.86804,165.20106 276.56041,164.89342 C 275.80492,164.13796 272.88234,158.95758 270.1887,153.58115 C 267.08692,147.39008 263.92283,139.73719 261.3405,132.18866 C 260.12605,128.6386 258.88876,125.19222 258.59021,124.53514 C 258.2917,123.87806 257.6387,122.04122 257.13418,120.45327 C 256.62962,118.86532 256.09405,117.56609 255.95193,117
.56609 z M 373.76622,193.67809 C 374.45847,193.67567 375.11278,193.84364 375.65782,194.20077 C 377.90365,195.67228 379.18427,198.72434 379.0179,201.18226 C 376.0036,201.17722 376.62922,201.18937 375.1227,201.15737 C 374.09474,201.13554 372.80799,200.97184 372.26041,200.79647 C 371.71284,200.62111 370.59754,200.4574 369.78391,200.43558 C 367.76938,200.38152 367.31139,199.47574 368.25321,197.39906 C 369.25472,195.19074 371.6895,193.68534 373.76622,193.67809 z M 370.10747,208.7611 C 373.32777,209.05034 376.45065,209.256 379.55302,209.40823 C 377.33171,211.28105 373.80603,215.49151 371.86218,216.67596 C 371.09558,217.14307 370.36563,217.52138 370.24436,217.5222 C 369.3585,217.52818 365.66745,215.19372 364.69401,214.01278 C 363.26552,212.27975 363.20523,211.56844 364.39534,210.45359 C 365.72149,209.21132 367.231,208.76111 370.10747,208.7611 z M 360.47525,226.79352 C 360.49159,226.7897 360.51414,226.79225 360.53747,226.79352 C 361.23745,226.83179 364.57437,229.47603 365.57759,230.
83806 C 366.97311,232.73281 368.25313,235.34359 368.26565,236.33864 C 368.27728,237.26753 368.05005,237.23227 365.50292,235.8284 C 362.28003,234.0521 361.50817,233.19408 361.50816,231.38563 C 361.50816,230.54066 361.22977,229.19208 360.89837,228.39889 C 360.56696,227.60571 360.36246,226.89389 360.43791,226.81841 C 360.44878,226.80755 360.45891,226.79735 360.47525,226.79352 z M 324.31085,230.34027 C 324.37362,230.33322 324.43561,230.33696 324.49752,230.34027 C 325.32304,230.38448 326.03714,231.33555 326.05311,232.90389 C 326.07334,234.88731 327.15124,240.60127 328.03183,243.35747 C 328.79022,245.7313 328.80606,245.97579 328.20605,247.24022 C 324.6141,250.05812 324.0846,251.59762 322.44414,256.15065 C 321.54079,257.91653 321.06538,259.46686 320.95077,261.02899 C 320.74636,263.81662 321.0932,263.91485 323.55172,261.75078 C 325.50983,260.02718 327.93687,259.36293 329.91098,260.02096 C 331.39256,260.51483 331.82295,262.54754 331.26746,266.36778 C 330.67262,270.4586 330.32881,271.
02565 327.72071,272.07991 C 323.3314,273.85421 320.89544,275.70399 318.84761,278.8374 L 317.69025,280.62944 L 320.49032,281.10234 C 323.14859,281.55025 326.06557,283.06628 326.06556,284.01441 C 326.06556,284.20549 325.59968,284.92101 325.03264,285.59489 C 324.18206,286.60576 323.71175,286.82169 322.34458,286.81448 C 319.97112,286.80195 317.8028,285.6764 314.87774,282.93172 C 311.79595,280.03996 310.07323,277.27062 308.43137,272.60259 C 307.28677,269.34832 307.19759,268.69619 307.17445,263.51793 C 307.15271,258.65104 307.26209,257.61382 308.07047,255.35419 C 309.82361,250.45373 313.26066,248.19026 319.39518,247.8749 C 321.14524,248.00031 322.64723,247.98358 324.37121,248.28772 C 324.04619,244.36369 324.25854,242.77508 323.04149,236.58753 C 322.36923,232.58553 322.37457,232.29081 323.0166,231.31096 C 323.41566,230.7019 323.87144,230.38966 324.31085,230.34027 z M 208.30104,266.72868 C 211.75319,266.70923 213.49474,267.54958 214.87186,269.91453 C 215.72316,271.37641 215.77214,27
1.82753 215.61854,276.46046 C 215.43516,281.99101 214.71733,284.68726 212.59447,287.77272 L 211.38733,289.52743 L 208.22637,288.15851 C 204.45544,286.52817 200.54392,285.64169 197.10078,285.63223 L 194.58694,285.61978 L 196.60299,287.94695 C 197.71314,289.22335 198.63148,290.45869 198.63148,290.69723 C 198.63148,290.93577 198.76588,291.19668 198.93015,291.26969 C 199.09442,291.3427 199.65001,291.99654 200.16218,292.72573 C 201.00233,293.92179 201.03664,294.1697 200.57286,295.28934 C 199.24535,298.49423 197.03332,299.81017 191.42598,300.72769 L 188.81259,301.15081 L 183.59824,298.16407 L 178.3839,295.17734 L 175.19805,295.17734 C 169.9222,295.17734 169.74713,295.48435 172.93311,299.37121 C 176.31465,303.49665 176.7175,306.5441 174.25225,309.35189 C 172.76151,311.04974 171.28094,311.85273 168.36589,312.55019 C 164.72585,313.42108 164.02333,313.28967 162.51686,311.52972 C 160.26032,308.89344 154.22608,306.45025 150.8437,306.80072 L 149.63656,306.92517 L 151.4286,309.60078 C 153
.00711,311.94889 153.23309,312.5483 153.23309,314.42934 C 153.23309,317.27559 152.62547,318.85406 151.3166,319.45701 C 149.29996,320.38606 146.0351,320.37632 144.27288,319.43212 C 140.73834,317.5383 136.93601,313.3803 136.29581,310.69592 C 136.07543,309.77184 136.25636,309.60347 138.27452,308.76699 C 141.01356,307.63172 144.01921,304.97502 145.29335,302.56951 C 145.82379,301.56813 146.56058,300.65663 146.92361,300.54102 C 147.5347,300.34645 148.24387,299.223 147.94408,298.9232 C 147.87204,298.85116 146.65514,299.35543 145.24357,300.04323 C 143.01101,301.1311 142.28887,301.27917 139.73055,301.22548 C 137.67277,301.1823 136.41711,300.94352 135.54912,300.42902 C 134.4336,299.76779 134.31383,299.51673 134.36687,297.90273 C 134.47862,294.50536 137.14361,290.72127 140.62658,289.01719 L 142.71729,287.99673 L 145.94048,288.60652 C 149.6158,289.30371 152.46879,290.235 155.73448,291.77993 C 160.22271,293.90318 161.103,292.17472 157.45186,288.4074 C 154.91528,285.79012 152.69444,282.58
438 152.95931,281.9237 C 153.0642,281.66196 154.99674,280.4915 157.26518,279.33519 L 161.39684,277.23203 L 164.7818,277.6676 C 169.74277,278.2923 173.94021,279.51915 177.799,281.48813 C 179.67674,282.44628 181.60766,283.2304 182.09243,283.23039 C 182.93353,283.23039 182.95723,283.15451 182.54044,281.51302 C 182.03003,279.50276 179.62744,275.78981 178.62035,275.45243 C 177.592,275.10792 177.75202,274.51504 179.30481,273.0506 C 181.54721,270.93573 184.61995,269.96929 189.19837,269.92697 C 192.51568,269.89631 193.1645,270.00192 193.49181,270.58654 C 193.70402,270.96559 194.69949,271.75081 195.70697,272.34125 C 196.71445,272.93169 197.96269,273.81366 198.48214,274.29507 C 199.0016,274.77649 201.05468,275.99487 203.03692,277.00803 C 206.53753,278.79728 208.84815,279.30624 210.05575,278.53873 C 210.79224,278.07066 209.66078,275.21062 207.81569,272.87637 C 206.19852,270.83052 204.67951,267.4879 205.15252,267.0149 C 205.30301,266.86441 206.72245,266.73756 208.30104,266.72868 z" />
- <path
- id="path2480"
- d="M 431.35117,424.37439 C 432.17587,422.22526 430.29459,416.75083 428.07787,414.84941 C 426.08205,413.13742 425.19077,412.68923 423.75041,412.67325 C 422.52585,412.65965 421.23227,413.7767 421.24302,414.83846 C 421.24533,415.06351 422.29272,415.73401 423.57065,416.32847 C 424.84857,416.92294 426.32513,417.77404 426.85191,418.21981 C 427.80241,419.02415 427.80365,419.03503 427.01324,419.65146 C 426.47176,420.07376 425.57933,420.23321 424.22562,420.14952 C 422.42039,420.03791 422.22259,420.11002 422.10731,420.92179 C 421.95685,421.9811 423.24967,422.61492 425.56085,422.61492 C 426.62743,422.61492 427.43015,422.94554 428.4221,423.79343 C 429.96501,425.11224 430.99002,425.31554 431.35117,424.37439 z" />
- <path
- id="path2533"
- d="M 425.80321,239.0302 C 426.14286,239.0302 426.55957,238.38265 426.80397,237.47497 C 427.44556,235.0923 428.42664,234.10814 430.09766,234.17096 C 431.26316,234.21477 431.55383,234.06306 431.7422,233.31267 C 431.868,232.81134 432.42349,231.73429 432.97664,230.91922 C 433.52974,230.10415 433.98229,229.37877 433.98229,229.30726 C 433.98229,229.01743 430.33369,229.88402 429.30853,230.41734 C 426.74523,231.75084 424.8459,235.17091 424.83173,238.47871" />
- <path
- id="path2450"
- style="fill:#ff0000"
- d="M 424.0265,241.52826 C 422.99687,242.83725 423.00902,243.00665 424.43493,247.2188 C 425.09763,249.17638 425.7168,251.22604 425.8109,251.77361 C 425.905,252.32118 426.71986,257.60109 427.6217,263.50675 C 428.52353,269.41241 429.336,274.36502 429.4272,274.51255 C 429.67884,274.91969 428.49669,275.7699 428.05692,275.4981 C 427.84514,275.36722 427.54994,274.67978 427.40096,273.97045 C 427.2519,273.26112 426.64591,272.14315 426.0543,271.48607 C 425.46264,270.82899 424.50107,269.57456 423.91743,268.69845 C 423.33382,267.82234 421.23797,265.05992 419.25999,262.55975 C 416.36927,258.90586 415.66364,257.75519 415.66364,256.69501 C 415.66364,255.09386 414.22431,253.93816 412.70506,254.31946 C 411.26709,254.68038 407.83987,258.19034 407.52482,259.62485 C 407.37676,260.29887 406.90741,261.16551 406.48174,261.55071 C 405.50786,262.43208 405.46784,264.55128 406.40476,265.62758 C 407.08116,266.40459 413.05045,268.89756 414.23455,268.89756 C 414.55783,268.89756 416.31618,270.734
41 418.14199,272.97944 C 424.1987,280.42682 424.16939,280.36555 423.01253,283.14713 C 421.84845,285.94598 420.3474,287.63482 417.59498,289.24229 C 415.31152,290.57591 414.28449,291.5834 411.02213,295.68993 C 403.8599,304.70556 393.46068,314.67769 384.66319,320.96633 C 380.92937,323.63533 380.47232,323.85351 378.61469,323.85351 C 377.41315,323.85351 375.99751,323.54348 375.09373,323.08239 C 374.26238,322.65828 373.05992,322.25507 372.42152,322.18637 L 371.26083,322.06147 L 371.27505,325.44644 C 371.29484,330.1629 372.60036,332.02647 375.19388,331.04041 C 376.24215,330.64186 376.24462,330.64552 375.99206,332.22496 L 375.7387,333.8093 L 377.39531,333.8093 C 379.51625,333.8093 381.61704,332.93019 382.22912,331.78653 C 382.52604,331.23169 382.62405,330.07405 382.48674,328.74344 C 382.22343,326.19236 382.72982,325.77251 384.8504,326.78375 C 386.90766,327.76478 388.45045,327.62256 389.63734,326.34246 C 390.46909,325.44536 390.6158,324.97168 390.44854,323.72304 C 390.33624,322.88469
389.9204,321.84083 389.52448,321.40335 C 388.82033,320.62528 388.82714,320.61358 389.8355,320.86666 C 390.40246,321.00896 391.65132,320.91402 392.61074,320.65567 C 393.57016,320.39732 394.68775,320.1219 395.09423,320.04361 C 396.54506,319.76421 397.00335,319.01163 396.87886,317.11299 C 396.76537,315.38236 396.82861,315.25785 398.14735,314.61606 C 399.5543,313.93132 401.06806,313.59163 402.97718,313.53224 C 404.29668,313.49118 404.71968,312.48016 403.92485,311.26712 C 403.59133,310.75812 403.31846,309.9661 403.31846,309.50707 C 403.31846,308.7133 403.45446,308.68588 406.09912,308.94648 C 409.3144,309.26331 409.78543,308.84641 408.91899,306.45045 C 408.64585,305.69505 408.50742,304.99196 408.61136,304.88802 C 408.7153,304.78408 409.49336,305.16934 410.3404,305.74416 C 411.48719,306.52241 412.18047,306.72928 413.05534,306.5543 C 414.64425,306.23653 414.93902,305.66882 414.67013,303.44415 C 414.42247,301.39507 414.73759,301.10571 415.86276,302.34901 C 416.80473,303.38986 416.95
753,303.36097 417.76806,301.98889 C 418.61139,300.56127 418.63174,299.47263 417.84368,297.94869 C 417.1009,296.5123 417.62808,296.39624 419.55604,297.57172 C 421.26871,298.61594 421.50518,298.58227 422.22423,297.19178 C 422.98549,295.71967 422.99457,294.35009 422.25477,292.57955 C 421.93742,291.81999 421.73357,291.19853 421.80178,291.19853 C 421.87004,291.19853 422.60235,291.73614 423.42916,292.39322 C 424.256,293.0503 425.07106,293.58792 425.24043,293.58792 C 425.4098,293.58792 425.94534,292.7679 426.43051,291.76566 C 427.15644,290.26616 427.23326,289.76909 426.8643,288.9593 C 426.28842,287.69539 426.29738,287.61444 427.01324,287.61444 C 427.34178,287.61444 427.61059,287.94298 427.61059,288.34453 C 427.61059,289.46758 428.00838,289.62629 429.23422,288.99237 C 430.56718,288.30307 432.7876,288.22141 432.7876,288.86169 C 432.7876,289.82055 431.08707,291.99511 429.68123,292.83392 C 427.15282,294.34256 425.63568,296.04627 423.33577,299.95962 C 420.91126,304.08505 418.64771,307.1
7959 415.35688,310.86771 C 414.18648,312.1794 412.22885,314.87619 411.0066,316.86057 C 409.05718,320.02563 405.87181,324.98039 402.55987,329.99928 C 401.05739,332.27621 397.05496,336.16562 392.21792,340.04925 C 389.8907,341.9178 387.92769,343.60521 387.85577,343.79905 C 387.78385,343.99289 387.19101,343.87534 386.53834,343.53783 C 382.62687,341.51514 376.27198,340.94911 367.0794,341.80463 C 362.07164,342.27069 360.75532,342.7064 360.26347,344.06074 C 359.56015,345.99733 362.9685,346.36044 374.24757,345.55055 C 377.36727,345.32654 377.91345,345.40663 381.21662,346.57244 C 383.18786,347.26816 385.87593,348.33934 387.19009,348.95284 C 388.50425,349.56634 389.68541,350.0837 389.81487,350.10254 C 389.94434,350.12138 390.53703,349.2424 391.13202,348.14925 C 393.50676,343.78602 398.30043,338.06517 402.99912,333.98683 C 404.98128,332.26639 405.68213,331.21129 408.5398,325.64555 C 412.8258,317.29795 415.09493,313.88713 421.91894,305.53486 C 422.54524,304.76827 423.41008,303.43869 423
.84077,302.58026 C 424.90118,300.46671 428.74459,296.3812 430.71277,295.27542 L 432.31641,294.37442 L 433.54758,295.41038 C 434.71834,296.39551 434.77875,296.59017 434.77875,299.37807 C 434.77875,304.95405 436.28009,308.56004 438.7095,308.81915 C 439.52926,308.90658 439.81746,308.54309 440.89977,306.05684 C 442.0822,303.3405 442.23241,303.17201 443.83203,302.76734 C 444.87731,302.5029 445.76568,301.96285 446.16969,301.34621 C 446.80483,300.37687 446.78077,300.30754 445.22154,298.61597 C 444.3416,297.66136 443.13727,296.14837 442.54526,295.25376 C 441.95325,294.35916 441.04254,293.34787 440.52149,293.00646 C 438.7621,291.85367 438.24078,290.23517 438.72793,287.43792 C 438.96516,286.07545 439.16233,283.72095 439.16603,282.2057 L 439.17276,279.4507 L 441.55709,276.47289 C 443.98511,273.44054 444.44148,272.49107 445.90853,267.41967 C 446.65103,264.85281 446.88885,264.47697 448.14874,263.8791 C 449.95277,263.02305 451.32607,261.21316 451.95452,258.86355 C 452.42941,257.08791 452.
39994,256.92532 451.27223,255.10132 C 449.96288,252.98351 447.09223,250.57892 445.87332,250.57892 C 444.87344,250.57892 443.39413,253.74605 441.38653,260.18472 C 440.06249,264.43119 438.12696,268.1011 437.21147,268.1011 C 436.0014,268.1011 434.38052,263.05192 434.38052,259.28247 C 434.38052,257.58378 434.10327,255.87463 433.6332,254.67553 C 433.22219,253.62704 432.6704,251.48188 432.40701,249.90851 C 431.96115,247.24511 431.98373,246.97047 432.73459,245.92619 C 433.17818,245.30929 433.6551,244.16038 433.7944,243.37306 C 434.02833,242.05128 433.9535,241.90252 432.8185,241.43238 C 432.14238,241.15234 431.04139,240.29926 430.37184,239.53666 C 429.70226,238.77405 429.10917,238.21372 429.05382,238.29148 C 428.9985,238.36923 428.71205,239.19447 428.41728,240.12534 C 427.82049,242.01002 427.59354,241.10246 425.90707,241.01681" />
- <path
- id="path2448"
- d="M 417.03722,266.70729 C 415.85658,265.4395 415.05443,264.91525 414.29516,264.91525 C 412.6691,264.91525 411.68133,264.2219 411.68133,263.08054 C 411.68133,262.08409 411.71255,262.07409 413.97116,262.34723 C 416.62302,262.66792 417.25657,263.05712 417.25657,264.36551 C 417.25657,264.89273 417.89386,266.01656 418.69673,266.90526 C 419.8395,268.17019 419.98915,268.49933 419.42147,268.49933 C 419.02798,268.49933 417.95507,267.69291 417.03722,266.70729 z" />
- <path
- id="path2420"
- d="M 403.41802,323.13387 C 403.94727,322.67936 404.11493,321.9201 404.11493,319.97796 C 404.11493,317.68231 403.99578,317.30139 402.95086,316.25648 C 401.7828,315.08841 400.42934,314.79087 399.36048,315.46718 C 398.64092,315.92249 399.19183,318.62169 400.70077,322.03364 C 401.73303,324.36773 401.90172,324.43605 403.41802,323.13387 z" />
- <path
- id="path2416"
- d="M 372.66085,313.96351 C 375.46576,312.48652 376.27731,308.31767 374.4955,304.53928 C 373.17445,301.73792 371.99608,300.81569 368.61633,299.93794 C 364.59587,298.8938 364.0313,298.93634 363.30643,300.33808 C 362.40727,302.07687 362.54247,303.65618 363.68217,304.72687 C 364.87455,305.84706 364.66329,306.32841 362.97403,306.34018 L 361.70327,306.34903 L 362.69885,307.14259 C 363.24642,307.57905 365.18959,308.65658 367.017,309.53712 C 369.81421,310.88494 370.26302,311.23032 369.85543,311.72144 C 369.11715,312.611 367.93532,312.42598 365.86348,311.09649 C 363.89944,309.83617 359.47756,308.8915 360.07618,309.86012 C 360.67627,310.83111 368.71641,314.62056 370.27146,314.66534 C 370.82246,314.6812 371.89768,314.36538 372.66085,313.96351 z" />
- <path
- id="path2412"
- d="M 452.63816,310.6646 C 453.567,309.98152 454.2633,309.2199 454.18553,308.97212 C 454.10775,308.72433 452.97606,308.16319 451.6707,307.72513 C 450.36533,307.28708 448.85803,306.61506 448.32113,306.23177 C 447.40532,305.57797 445.13277,305.2503 445.13277,305.77206 C 445.13277,305.90252 445.51073,306.54005 445.97268,307.1888 C 447.00944,308.64478 446.7077,309.01821 444.99494,308.39886 C 443.0188,307.68428 442.34427,307.79181 442.35124,308.82027 C 442.36498,310.83752 444.30967,311.86887 448.14061,311.89062 C 450.67145,311.90499 451.11644,311.78369 452.63816,310.6646 z" />
- <path
- id="path2410"
- d="M 355.77755,305.33575 C 359.73936,297.07954 361.46437,288.9081 361.7885,276.86219 C 362.01346,268.50263 361.58532,264.71785 359.86874,259.89079 C 359.41054,258.60224 358.9006,256.56234 358.73561,255.35769 C 358.52152,253.79456 357.16455,250.51247 353.99642,243.89503 C 351.55486,238.79521 349.55721,234.52157 349.55721,234.39804 C 349.55721,234.27451 348.59087,232.61124 347.40979,230.70187 C 343.62006,224.57534 342.24186,221.30863 340.93948,215.36567 C 340.58406,213.74395 339.85785,213.09723 339.48455,214.07003 C 339.09727,215.07924 340.67442,222.97 341.69927,225.15074 C 347.40844,237.299 348.96249,240.6565 350.70408,244.60544 C 356.77377,258.36801 359.23105,275.00008 357.08793,287.81356 C 356.52447,291.1822 354.13739,298.29557 352.0904,302.70585 C 350.18339,306.81455 350.07416,307.42329 350.94266,309.10274 C 352.25217,311.63507 353.05492,311.00961 355.77755,305.33575 z" />
- <path
- id="path2406"
- d="M 348.96194,299.72242 L 350.05409,298.29052 L 349.2685,297.23347 C 347.98026,295.50012 345.38534,295.69211 344.36635,297.59617 C 344.00272,298.27556 344.14959,298.61396 345.31294,299.77732 C 346.0703,300.53467 346.95541,301.15431 347.27985,301.15431 C 347.60433,301.15431 348.36124,300.50996 348.96194,299.72242 z" />
- <path
- id="path2402"
- d="M 375.60824,296.71641 C 376.1582,296.46584 377.10289,295.54693 377.70756,294.67438 C 378.5816,293.41309 378.83834,292.53237 378.96012,290.37726 C 379.1036,287.83789 379.03144,287.55261 377.81815,285.86316 C 376.28416,283.7271 374.36923,282.32747 371.19516,281.02238 C 368.31905,279.83982 366.92512,279.80411 365.84393,280.8853 C 365.10234,281.62686 365.04217,281.97959 365.31715,283.97159 C 365.70327,286.76878 365.71876,287.55242 365.41272,288.80914 C 365.18752,289.73411 365.42375,289.9273 368.74369,291.53324 C 370.70904,292.48393 372.25864,293.30636 372.1872,293.36087 C 372.11575,293.41538 370.48838,293.28057 368.57082,293.06129 C 366.65325,292.84202 364.96686,292.7801 364.82326,292.92371 C 364.33662,293.41035 366.07323,294.88979 368.47321,296.03311 C 371.0463,297.25888 373.83209,297.52567 375.60824,296.71641 z" />
- <path
- id="path2400"
- d="M 343.41664,293.56814 C 345.03856,292.56574 345.55025,291.26191 344.59569,290.56391 C 343.43448,289.7148 340.22757,289.12555 338.79206,289.49753 C 337.11053,289.93325 335.66507,291.7457 336.25421,292.67969 C 337.28714,294.31723 341.3826,294.82525 343.41664,293.56814 z" />
- <path
- id="path2398"
- d="M 352.17375,292.33899 C 352.94871,290.84043 352.46482,289.57134 350.8355,288.82896 C 349.97723,288.4379 349.64662,288.4855 348.78855,289.1236 C 347.42715,290.136 347.28212,291.44231 348.39916,292.63131 C 349.72232,294.03979 351.35985,293.91298 352.17375,292.33899 z" />
- <path
- id="path2396"
- d="M 319.60172,290.78199 C 321.38106,290.4004 324.46863,288.4071 324.46863,287.63997 C 324.46863,287.46688 322.63511,287.83747 321.26619,287.7236 C 319.89727,287.60972 318.50511,286.57155 317.30046,286.15647 C 314.63156,285.23686 313.50436,285.3671 312.63391,286.69563 C 312.00733,287.65188 312.01358,287.792 312.74326,289.14079 C 313.81474,291.12142 315.80184,291.59693 319.60172,290.78199 z" />
- <path
- id="path2394"
- d="M 312.22584,290.16694 C 312.35514,290.03763 312.22054,289.25038 311.92669,288.41751 C 311.63283,287.58464 311.34814,286.0328 311.29406,284.96899 C 311.12142,281.57463 310.11059,280.72955 308.56828,282.69026 C 307.21226,284.41416 307.61113,287.56246 309.43181,289.50604 C 310.21863,290.346 311.69707,290.69571 312.22584,290.16694 z" />
- <path
- id="path2392"
- d="M 307.34468,288.78296 C 307.34468,288.3305 307.15472,287.60535 306.92251,287.1715 C 306.69034,286.73765 306.37243,285.62941 306.21613,284.70873 C 305.95839,283.19094 305.79428,283.00057 304.45702,282.66808 C 301.55391,281.94625 299.88739,283.56431 300.79544,286.22319 C 301.60019,288.57954 302.98962,289.6056 305.37574,289.6056 C 307.10008,289.6056 307.34468,289.50341 307.34468,288.78296 z" />
- <path
- id="path2390"
- d="M 344.42007,287.60999 C 346.37518,287.0669 347.36626,285.94167 346.8081,284.89874 C 345.83697,283.08423 340.51632,281.68185 339.28284,282.91531 C 338.70951,283.48867 338.66252,285.1968 339.18253,286.56449 C 339.53488,287.49127 340.08532,287.72923 342.38905,287.95079 C 342.71759,287.98238 343.63157,287.82902 344.42007,287.60999 z" />
- <path
- id="path2386"
- d="M 353.38772,284.6114 C 354.2172,283.34549 353.66772,281.86375 352.10478,281.15163 C 351.16061,280.72144 350.96237,280.78352 350.10777,281.77705 C 348.92403,283.15325 348.91128,283.89516 350.055,284.8493 C 351.31935,285.90403 352.6007,285.81256 353.38772,284.6114 z" />
- <path
- id="path2384"
- d="M 303.15002,281.65194 C 304.08165,280.87876 303.96927,277.79836 302.99033,277.27443 C 301.14616,276.28748 298.62783,277.14324 298.55312,278.78224 C 298.53635,279.14989 298.4526,279.80911 298.36698,280.24716 C 298.01284,282.05927 298.52958,282.54396 300.60317,282.34471 C 301.66812,282.24238 302.81423,281.93063 303.15002,281.65194 z" />
- <path
- id="path2382"
- d="M 347.84498,279.98182 C 348.84374,279.15292 348.44515,277.51949 347.00475,276.53875 C 345.26065,275.35119 341.597,274.9016 340.86374,275.78514 C 340.11745,276.68437 341.21371,279.02734 342.86286,280.05782 C 344.25098,280.92515 346.75434,280.88697 347.84498,279.98182 z" />
- <path
- id="path2380"
- d="M 378.57124,279.03433 C 379.63054,277.68762 379.35915,275.99462 377.42036,271.85491 C 375.07824,266.85408 371.95176,264.44201 366.58814,263.49786 C 365.23204,263.25915 365.06526,263.33089 364.69164,264.31362 C 364.40922,265.05643 364.41248,265.87566 364.70208,266.95114 C 365.05073,268.24603 365.42451,268.65331 366.90111,269.3474 C 368.15777,269.93809 368.75352,270.49174 368.93022,271.23307 C 369.28771,272.73279 369.84245,273.30837 371.74213,274.15063 C 374.43577,275.3449 374.20101,275.6675 370.63823,275.6675 C 367.80382,275.6675 367.44386,275.7443 367.87029,276.2581 C 368.13985,276.58293 369.37142,277.15758 370.60709,277.53509 C 371.84277,277.91261 373.47778,278.63246 374.24044,279.13477 C 376.08218,280.34773 377.56515,280.31334 378.57124,279.03433 z" />
- <path
- id="path2378"
- d="M 297.05159,277.61235 C 297.63758,275.65645 297.04764,274.38712 294.88855,272.95831 C 293.42314,271.98854 293.3687,271.98229 292.81046,272.71984 C 291.98771,273.80685 292.08237,275.5277 293.06059,277.26821 C 293.92607,278.80818 295.20347,279.68764 296.09101,279.3546 C 296.36281,279.25261 296.79505,278.4686 297.05159,277.61235 z" />
- <path
- id="path2374"
- d="M 354.28215,278.24348 C 354.39401,278.13163 354.56239,276.97733 354.65633,275.67837 C 354.81865,273.4344 354.77795,273.30426 353.84023,273.0689 C 353.2974,272.93266 352.24607,272.8792 351.50393,272.95009 L 350.15456,273.07899 L 350.2053,275.43802 C 350.26423,278.17952 350.99284,279.05041 352.91315,278.67482 C 353.55426,278.54942 354.17033,278.35531 354.28215,278.24348 z" />
- <path
- id="path2372"
- d="M 305.65147,275.23782 C 305.92876,274.69999 306.04182,273.74544 305.90718,273.07899 C 305.67131,271.91174 304.3307,270.09226 303.70651,270.09226 C 303.16627,270.09226 302.48952,273.34349 302.74562,274.70864 C 303.10733,276.63657 304.77385,276.94006 305.65147,275.23782 z" />
- <path
- id="path2370"
- d="M 301.45292,270.88205 C 301.86947,268.07532 301.85171,267.93611 300.98715,267.23604 C 300.49278,266.83571 299.57466,266.50817 298.94689,266.50817 C 295.78139,266.50817 295.73471,272.5593 298.88727,274.23591 C 300.43484,275.05894 300.92881,274.4132 301.45292,270.88205 z" />
- <path
- id="path2368"
- d="M 347.53237,272.06204 C 348.45567,271.3932 349.14329,270.64249 349.06038,270.39379 C 348.46901,268.6196 343.98615,267.48491 342.19774,268.65672 C 340.851,269.53913 340.93367,270.30943 342.54834,271.92412 C 344.23425,273.61003 345.35273,273.64098 347.53237,272.06204 z" />
- <path
- id="path2366"
- d="M 293.89592,268.91136 C 294.57538,268.37692 294.96318,267.58999 295.11877,266.43011 C 295.37794,264.49775 295.05915,264.13405 293.09806,264.12488 C 291.41673,264.11702 290.9281,265.23957 291.48216,267.83725 C 291.91826,269.88202 292.39323,270.09338 293.89592,268.91136 z" />
- <path
- id="path2364"
- d="M 353.53953,268.49933 C 354.50663,267.53226 354.53586,266.85875 353.68309,265.19415 C 352.51611,262.91626 351.49397,262.73918 350.34934,264.61658 C 349.19327,266.51264 349.3307,267.57646 350.85147,268.5037 C 352.45455,269.48112 352.55793,269.48095 353.53953,268.49933 z" />
- <path
- id="path2362"
- d="M 303.83427,264.29195 C 304.56773,261.58113 303.10956,259.10917 300.53006,258.69058 C 299.44297,258.51417 298.957,258.67432 298.06182,259.50398 C 297.09475,260.40021 296.96318,260.7874 297.06843,262.42747 L 297.18977,264.3179 L 298.71874,264.18477 C 300.33126,264.04436 302.5659,264.74731 302.5659,265.39498 C 302.5659,266.23359 303.53758,265.38859 303.83427,264.29195 z" />
- <path
- id="path2360"
- d="M 346.52472,264.88009 C 347.10622,264.42269 347.86975,263.492 348.22143,262.81188 C 348.84661,261.60296 348.83586,261.55377 347.7418,260.61271 C 346.78867,259.79283 346.35699,259.68653 344.83044,259.89577 C 341.63432,260.33385 340.47335,261.67606 340.97544,264.35252 C 341.22768,265.697 341.25337,265.71171 343.34898,265.71171 C 344.89436,265.71171 345.75351,265.48673 346.52472,264.88009 z" />
- <path
- id="path2358"
- d="M 295.83877,260.85297 C 296.09675,260.37093 296.82256,258.18793 297.45173,256.00186 C 298.70672,251.6412 298.64563,251.39265 296.31597,251.38148 C 294.39439,251.37226 293.09914,252.76064 292.89799,255.04512 C 292.78832,256.29083 292.45803,257.16206 291.91667,257.63363 C 291.45078,258.03946 290.99528,259.0706 290.8551,260.03691 L 290.60955,261.7294 L 292.98963,261.7294 C 295.03454,261.7294 295.43576,261.60597 295.83877,260.85297 z" />
- <path
- id="path2356"
- d="M 374.08393,260.33734 C 375.0097,258.92442 374.55134,257.07298 372.53939,254.09884 C 369.95539,250.27899 366.03675,248.04959 361.30504,247.70738 C 359.71474,247.59237 359.7122,247.59454 359.7519,249.02177 C 359.77376,249.80804 360.19035,251.24965 360.67763,252.22535 C 361.1649,253.20105 361.77424,255.06659 362.0317,256.37101 L 362.49974,258.74266 L 365.00159,259.01861 C 366.51801,259.18587 368.16498,259.67996 369.18302,260.27303 C 371.46568,261.60283 373.23948,261.62611 374.08393,260.33734 z" />
- <path
- id="path2354"
- d="M 352.19418,259.52108 C 353.0918,258.15111 352.40075,255.81063 350.66816,254.35273 C 349.47574,253.34938 349.37454,253.32945 348.88329,254.00127 C 347.92442,255.31259 348.24094,257.58086 349.59847,259.12703 C 351.07185,260.80511 351.32743,260.84391 352.19418,259.52108 z" />
- <path
- id="path2352"
- d="M 304.03844,256.75457 C 304.68377,255.4013 304.67656,255.3371 303.76991,254.37202 C 301.96628,252.45214 300.47319,252.70215 299.96656,255.00888 C 299.74976,255.99585 299.89771,256.36338 300.83698,257.17115 C 302.40127,258.51649 303.25098,258.40592 304.03844,256.75457 z" />
- <path
- id="path2350"
- d="M 343.84813,257.06902 C 344.81611,256.43627 345.97313,254.25127 345.97313,253.05599 C 345.97313,251.44707 342.97636,251.03627 340.94566,252.36682 C 339.83097,253.09719 339.77848,253.77016 340.63906,256.29583 C 341.32521,258.30957 341.7819,258.41961 343.84813,257.06902 z" />
- <path
- id="path2348"
- style="fill:#ffffff"
- d="M 406.50432,253.56228 C 406.50432,251.47756 406.54338,251.39302 407.29086,251.85982 C 408.41961,252.56475 409.205,251.74823 408.61092,250.48741 C 407.87897,248.93396 407.30078,246.37209 407.30078,244.6823 C 407.30078,242.34402 406.6196,242.26109 405.61088,244.47656 C 404.58858,246.72182 404.40639,251.31642 405.23069,254.06344 C 405.93321,256.40466 406.50432,256.17993 406.50432,253.56228 z" />
- <path
- id="path2346"
- d="M 454.14981,253.52653 C 454.78849,252.68922 456.09174,251.71815 457.28519,251.19035 C 459.06775,250.402 461.06202,248.61852 461.06202,247.81268 C 461.06202,247.66449 460.69664,247.15105 460.25006,246.67169 C 459.53058,245.89944 459.02849,245.80014 455.84333,245.80014 C 452.05754,245.80014 451.19015,246.05851 449.41376,247.71534 C 448.13822,248.90503 448.05659,249.42891 449.01553,250.27097 C 450.12986,251.2495 451.50448,251.54436 451.50448,250.80487 C 451.50448,250.46156 451.77328,250.18068 452.10182,250.18068 C 452.85098,250.18068 452.84747,250.3317 452.06307,251.84858 C 451.57182,252.79853 451.52451,253.29288 451.8554,254.01908 C 452.43821,255.2982 452.86906,255.20571 454.14981,253.52653 z" />
- <path
- id="path2344"
- d="M 341.30669,249.24007 C 342.95203,248.54367 343.91025,247.45299 344.2149,245.92985 C 344.42747,244.86691 344.29351,244.61842 343.1245,243.90738 C 341.29487,242.79453 338.81193,242.42789 337.85403,243.12913 C 337.23091,243.58527 337.14764,243.98259 337.36767,245.4497 C 337.65029,247.33438 338.91631,249.78245 339.60836,249.78245 C 339.83766,249.78245 340.6019,249.53838 341.30669,249.24007 z" />
- <path
- id="path2537"
- d="M 366.42033,173.52113 C 366.6869,171.57605 366.42228,171.35849 364.95734,172.31836 C 364.31081,172.74197 363.32001,172.85896 361.4328,172.7345 C 359.20365,172.5875 358.70188,172.67814 358.10728,173.3352 C 357.43507,174.07794 356.11664,174.58297 357.16725,176.09902 C 358.05463,177.37949 358.85046,177.91749 358.73409,179.38074 C 358.63047,180.68337 358.95517,182.27316 359.36846,182.43175 C 360.03064,182.68585 361.67042,180.12423 363.91175,176.70698" />
- <path
- id="path2340"
- d="M 363.41933,179.94981 C 362.99072,180.4192 362.33965,181.40039 361.97252,182.13021 C 361.03297,183.99807 355.45363,188.19022 352.54395,189.2146 C 349.02382,190.45389 346.19037,190.33915 343.86282,188.86307 C 342.83538,188.2115 341.22143,186.96554 340.27623,186.09427 C 338.34656,184.31559 336.67849,183.53891 335.55432,183.89571 C 334.38925,184.26548 331.57937,182.38591 330.3296,180.40081 C 329.72015,179.4328 327.94527,177.48886 326.3854,176.08095 C 324.82552,174.67305 322.82895,172.75737 321.94854,171.82388 C 320.95065,170.7658 319.73652,169.9522 318.72458,169.66344 C 317.83182,169.40868 316.89634,169.04623 316.64577,168.85799 C 316.39516,168.66975 315.05113,167.96774 313.65903,167.29797 C 312.2669,166.6282 310.76947,165.76053 310.33141,165.36981 C 309.26797,164.42129 289.37305,158.98568 286.96478,158.98568 C 285.89533,158.98568 286.06454,160.27882 287.28141,161.40521 C 288.47045,162.50583 294.00249,169.22422 296.4898,172.58834 C 297.90755,174.50587 298.19539,175.
22939 298.42258,177.44666 C 298.68027,179.96218 298.73224,180.06113 299.9308,180.31944 C 303.57462,181.10476 305.16758,182.05229 307.2622,184.68034 C 308.4027,186.11131 309.33583,187.51471 309.33583,187.79903 C 309.33583,188.08335 309.77317,188.72681 310.30764,189.22894 C 311.07774,189.9524 311.98053,190.21297 314.65696,190.48425 C 316.51459,190.67254 318.81012,191.12005 319.75819,191.47872 C 321.92923,192.30009 324.46863,192.64931 324.46863,192.12652 C 324.46863,191.64296 323.13145,190.7342 319.49074,188.74361 C 317.95754,187.90532 317.06152,187.30481 317.49958,187.40916 C 317.93763,187.51351 318.92326,187.72121 319.68985,187.87072 C 320.45645,188.02024 321.44207,188.46103 321.88013,188.85026 C 322.31818,189.23949 323.05614,189.67272 323.52,189.81299 C 324.43319,190.08911 326.98306,189.27669 326.16111,188.9715 C 325.88733,188.86984 325.66332,188.54661 325.66332,188.2532 C 325.66332,186.89494 318.11393,183.50527 312.37514,182.28683 C 311.74697,182.15346 311.30971,181.96763 3
11.40349,181.87388 C 311.78404,181.49334 320.3858,183.61699 321.68101,184.41125 C 323.1608,185.3187 324.66141,185.52534 325.06219,184.87686 C 325.35227,184.40748 323.15809,183.00487 321.59754,182.66212 C 320.98637,182.52788 320.48631,182.2561 320.48631,182.05817 C 320.48631,181.0915 313.41647,178.39494 309.34635,177.80919 C 308.17216,177.64021 307.13688,177.27828 307.04576,177.00491 C 306.80631,176.28654 307.2757,176.35753 312.97487,177.90167 C 317.96288,179.25312 319.68985,179.55058 319.68985,179.05825 C 319.68985,178.21992 318.05973,176.31075 316.78535,175.65657 C 315.0759,174.77904 310.1262,173.38201 307.14556,172.93578 L 305.1544,172.63769 L 306.94644,172.55363 C 307.93207,172.5074 309.09689,172.3227 309.53495,172.14319 C 310.42786,171.77727 310.40242,171.76294 305.55263,169.90053 C 304.23847,169.39587 303.47685,168.97362 303.86015,168.96221 C 304.99037,168.92856 304.75836,167.34854 303.6232,167.34854 C 303.10956,167.34854 302.34799,166.96774 301.93072,166.50232 L 301.17
209,165.6561 L 302.5659,165.93301 C 305.22107,166.46052 307.90511,167.46894 309.71144,168.61769 C 310.70949,169.25241 312.2937,169.96611 313.23185,170.20367 C 314.5034,170.52567 315.41575,171.1684 316.81593,172.72866 C 317.84903,173.87983 319.8591,175.56921 321.28278,176.48283 C 323.72848,178.05233 326.50905,181.05435 329.65771,185.52472 L 330.81955,187.17429 L 329.43963,188.90969 C 327.36807,191.51489 326.65639,193.96678 326.67336,198.44043 C 326.68746,202.15431 326.72425,202.30447 328.08828,204.21479 C 328.85853,205.29351 329.68741,206.64261 329.93026,207.21279 C 330.66866,208.94659 333.56555,210.35753 336.38694,210.35753 C 339.2112,210.35753 339.50713,209.91474 337.11248,209.27195 C 335.16887,208.75022 332.30328,206.45616 331.39061,204.69128 C 329.53545,201.10379 329.28735,196.7682 330.72955,193.1391 C 331.28699,191.73635 333.63679,189.25127 334.4057,189.25127 C 334.5992,189.25127 335.04096,189.1425 335.38742,189.00955 C 335.87306,188.82319 336.01734,189.03377 336.01734,1
89.92901 C 336.01734,191.2405 336.53293,191.99696 338.07787,192.95217 C 339.47981,193.81897 339.78238,194.91438 339.02463,196.37975 C 338.68478,197.03691 338.40673,197.85228 338.40673,198.1917 C 338.40673,198.99073 339.55511,198.99471 339.86131,198.19674 C 340.20718,197.29546 342.1437,196.41943 343.79018,196.41943 L 345.23091,196.41943 L 344.35966,197.64297 C 343.13716,199.35985 342.39148,202.10332 342.37495,204.94514 C 342.3671,206.29212 342.10774,207.81353 341.7917,208.36638 C 340.93494,209.86513 341.07871,211.1888 342.22856,212.389 C 343.07874,213.27638 343.2736,213.88142 343.3237,215.78908 L 343.38463,218.10969 L 347.65892,218.97816 C 355.93489,220.65972 361.17315,223.07315 365.98769,227.42277 C 367.35498,228.65805 369.07056,231.55118 369.07056,232.62171 C 369.07056,232.84454 369.44505,234.02779 369.90278,235.25115 C 370.6274,237.18792 370.81549,237.40866 371.3576,236.95873 C 371.70004,236.67453 372.20105,235.91681 372.47098,235.27491 L 372.96168,234.10781 L 374.64835,23
7.66414 C 376.79497,242.19023 378.48809,244.26597 381.09141,245.56327 C 383.44779,246.73749 383.73507,246.77561 384.70114,246.04224 C 385.08444,245.75128 385.39721,245.35377 385.39622,245.15889 C 385.39518,244.96401 384.24991,242.78851 382.85112,240.32445 C 381.45237,237.8604 380.38344,235.84435 380.47575,235.84435 C 380.5681,235.84435 381.18472,236.46062 381.84606,237.21384 C 382.97318,238.49757 385.57996,239.77752 386.06974,239.28772 C 386.19081,239.16668 385.62185,238.15767 384.80544,237.0455 C 383.98903,235.93332 382.99285,234.15954 382.59167,233.10375 L 381.86227,231.18414 L 382.85096,229.23326 C 384.10471,226.75941 384.00703,224.87195 382.56997,223.80378 C 381.89887,223.30494 379.41804,222.63764 375.52669,221.90927 C 368.17816,220.53381 362.22858,219.06617 356.77428,217.28347 C 354.2481,216.4578 351.84454,215.93278 350.59074,215.93278 C 348.1548,215.93278 346.91913,215.19324 346.10686,213.24918 C 345.78863,212.48754 345.59362,211.799 345.67354,211.7191 C 345.75343,211.
63919 346.47797,211.75582 347.28359,211.97827 C 350.76027,212.93822 354.65422,209.98133 356.10442,205.28008 C 356.31305,204.60385 356.22134,204.38406 355.73056,204.38406 C 354.67445,204.38406 349.48513,206.95618 347.80997,208.30995 C 346.95851,208.99807 346.1157,209.56107 345.93709,209.56107 C 344.61265,209.56107 344.66542,199.92665 345.99894,198.27985 C 346.64726,197.47917 347.0785,197.4111 351.81184,197.36231 C 356.04886,197.31862 357.50424,197.13494 360.30946,196.28987 C 364.46939,195.03669 382.06278,186.36279 383.08779,185.05968 C 383.49562,184.54126 384.43998,183.89625 385.18639,183.62634 C 386.86724,183.01854 388.95179,179.62126 388.19985,178.71522 C 387.62564,178.02331 387.27487,174.11847 387.78696,174.11847 C 388.49207,174.11847 389.33098,175.89692 389.6025,177.96744 C 389.8394,179.77399 389.71221,180.3716 388.55742,182.87695 C 387.52753,184.40414 391.1524,186.72713 391.78377,181.59182 C 392.49055,180.43835 393.26933,179.36673 393.51444,179.21045 C 393.78297,179.0392
1 393.96002,177.64564 393.96002,175.70338 L 393.96002,172.48046 L 391.96887,170.72626 C 389.877,168.88334 388.21781,168.47 386.53245,169.37196 C 385.12171,170.12697 385.32597,169.50601 387.15895,167.46728 C 389.308,165.07704 392.18419,163.69254 396.94676,162.75578 C 400.13448,162.12878 402.28294,161.00327 401.59858,160.31888 C 401.44355,160.16387 399.79244,159.95703 397.92944,159.85925 C 394.17113,159.66199 391.04194,160.33031 387.61564,162.06206 C 386.03247,162.86223 385.23569,163.02013 383.50517,162.87662 C 381.41928,162.70364 381.30132,162.75009 379.33358,164.51926 C 378.21981,165.52062 376.99636,166.85332 376.61473,167.48081 C 376.04789,168.41293 375.60386,168.64329 374.18823,168.73966 C 373.23526,168.80454 371.2907,169.29861 369.86702,169.8376 C 367.31838,170.80249 367.27748,170.84145 367.21125,172.36846 C 367.1743,173.22146 367.1295,174.23296 367.1117,174.61626 C 367.09393,174.99956 366.87586,175.31317 366.62705,175.31317" />
- <path
- id="path2338"
- d="M 315.30931,186.86188 C 314.98076,186.64956 314.89116,186.47585 315.11019,186.47585 C 315.32922,186.47585 315.77723,186.64956 316.10577,186.86188 C 316.43431,187.0742 316.52391,187.24791 316.30488,187.24791 C 316.08586,187.24791 315.63785,187.0742 315.30931,186.86188 z" />
- <path
- id="path2336"
- d="M 365.45756,245.14908 C 367.19373,242.94191 365.82883,237.96577 362.80319,235.47178 C 361.45267,234.35857 361.22233,234.30747 357.8744,234.37834 C 353.47868,234.47138 352.85784,234.90562 353.5334,237.41447 C 353.85353,238.60337 354.33221,239.28924 355.17001,239.75944 C 356.00984,240.23078 356.29832,240.64519 356.16212,241.18471 C 356.05651,241.6031 356.42264,242.71759 356.97575,243.66136 C 358.00032,245.40966 358.20835,245.50967 361.70327,245.93399 C 364.30974,246.25043 364.64668,246.17999 365.45756,245.14908 z" />
- <path
- id="path2334"
- d="M 310.20051,243.14991 C 310.93445,242.48572 311.13337,241.22151 310.68703,240.05835 C 310.52551,239.63743 309.94509,239.42843 308.9376,239.42843 C 307.35073,239.42843 306.94644,239.87314 306.94644,241.61871 C 306.94644,243.17748 307.38028,243.80898 308.45108,243.80898 C 309.01271,243.80898 309.79997,243.5124 310.20051,243.14991 z" />
- <path
- id="path2332"
- d="M 346.69688,241.31622 C 346.97568,238.89179 342.79413,236.57972 342.45559,238.97115 C 342.12263,241.32342 343.3276,242.6859 345.5749,242.49828 C 346.34034,242.43438 346.59971,242.16113 346.69688,241.31622 z" />
- <path
- id="path2328"
- d="M 339.68111,239.47325 C 340.81536,238.45982 340.90221,238.24407 340.4133,237.65495 C 339.66196,236.74963 338.08058,235.96867 336.33605,235.6414 L 334.89027,235.37016 L 335.27695,237.10062 C 336.08906,240.73459 337.4493,241.46738 339.68111,239.47325 z" />
- <path
- id="path2324"
- d="M 311.84955,235.94391 C 312.19466,234.6845 312.59512,232.9901 312.73944,232.17858 C 312.9816,230.81698 312.91916,230.68233 311.93063,230.43422 C 309.6936,229.87276 307.83135,232.49865 308.56979,235.17314 C 308.93011,236.47802 310.26212,238.23374 310.8918,238.23374 C 311.07344,238.23374 311.5044,237.20332 311.84955,235.94391 z" />
- <path
- id="path2322"
- d="M 307.4919,236.93949 C 307.94907,235.23357 307.73829,229.69903 307.18857,228.97486 C 306.02159,227.43754 304.89253,228.64103 304.53456,231.80389 C 304.32632,233.64346 304.41385,234.225 305.0159,235.00203 C 305.42062,235.52438 305.75175,236.16056 305.75175,236.41576 C 305.75175,236.92106 306.54264,237.83551 306.97966,237.83551 C 307.12931,237.83551 307.35985,237.4323 307.4919,236.93949 z" />
- <path
- id="path2320"
- d="M 318.22962,237.11247 C 319.2234,236.01432 319.48508,234.11128 318.7286,233.48345 C 318.2248,233.06532 317.9767,233.059 317.50284,233.45225 C 316.99594,233.87296 315.8595,234.11425 313.85855,234.226 C 313.06404,234.27038 312.90454,235.45595 313.53033,236.66604 C 314.05774,237.686 314.35498,237.83551 315.85516,237.83551 C 317.01127,237.83551 317.78981,237.59844 318.22962,237.11247 z" />
- <path
- id="path2316"
- d="M 343.17149,234.2776 C 343.76768,233.16365 343.69955,232.85724 342.55276,231.49436 C 341.29849,230.00374 340.28224,229.92949 339.66534,231.28342 C 338.99345,232.75812 339.09137,233.43311 340.09922,234.2739 C 341.26488,235.24631 342.65216,235.24799 343.17149,234.2776 z" />
- <path
- id="path2314"
- d="M 302.48625,234.17178 C 303.73769,232.92033 302.59242,229.47265 300.92526,229.47265 C 299.26794,229.47265 298.89759,232.21223 300.35754,233.67218 C 301.45993,234.77456 301.80297,234.85508 302.48625,234.17178 z" />
- <path
- id="path2312"
- d="M 296.74515,233.25998 C 298.2415,232.12702 296.63691,228.27795 294.66821,228.27795 C 292.89791,228.27795 292.04406,229.13131 292.33895,230.60588 C 292.92021,233.51204 294.86498,234.6835 296.74515,233.25998 z" />
- <path
- id="path2310"
- d="M 358.94548,232.63375 C 359.33718,232.30865 359.06714,231.50143 357.71423,228.95338 C 356.23189,226.16161 355.67497,225.50246 353.86433,224.39684 C 352.36869,223.48356 351.25842,223.10375 350.08093,223.10259 C 348.1908,223.10072 346.37136,223.6797 346.37136,224.28304 C 346.37136,224.50597 347.17778,225.98421 348.1634,227.568 C 349.14903,229.1518 349.95545,230.575 349.95545,230.73068 C 349.95545,230.88635 350.11537,231.4286 350.31083,231.93567 C 350.64486,232.8022 350.89997,232.8634 354.55498,232.9539 C 356.82378,233.01007 358.65274,232.87671 358.94548,232.63375 z" />
- <path
- id="path2308"
- d="M 337.39737,231.4782 C 338.39244,230.43956 338.46113,230.21708 337.96967,229.62447 C 337.25114,228.75812 335.14577,227.87972 333.78776,227.87972 C 332.79227,227.87972 332.74157,227.96771 332.96032,229.31565 C 333.50203,232.65389 335.38961,233.57387 337.39737,231.4782 z" />
- <path
- id="path2306"
- d="M 315.27832,227.19391 C 316.00888,224.75881 316.02628,224.43277 315.47111,223.58546 C 315.13544,223.07315 314.55852,222.70976 314.18904,222.77791 C 313.27948,222.94569 311.9861,225.68531 312.27434,226.83367 C 312.48513,227.67351 313.9679,229.87088 314.32384,229.87088 C 314.40711,229.87088 314.8366,228.66624 315.27832,227.19391 z" />
- <path
- id="path2304"
- d="M 304.59377,227.63636 C 305.11466,227.00872 305.22772,221.47451 304.7359,220.67873 C 304.61914,220.48983 303.81483,220.12291 302.94852,219.86336 C 301.57892,219.45301 301.27129,219.48385 300.59083,220.09965 C 299.58549,221.00945 298.84741,223.24484 299.19292,224.33341 C 299.34074,224.79911 300.09137,225.87715 300.86103,226.72905 C 302.36304,228.39162 303.69771,228.71604 304.59377,227.63636 z" />
- <path
- id="path2302"
- d="M 310.70894,224.50185 C 310.67672,221.14285 308.67373,219.40733 307.78189,221.96567 C 307.08503,223.9646 307.24882,226.05749 308.19629,227.26202 L 309.04787,228.34466 L 309.88878,227.50301 C 310.54462,226.84656 310.7251,226.18617 310.70894,224.50185 z" />
- <path
- id="path2300"
- d="M 291.68335,226.52772 L 292.79218,225.57396 L 291.99261,223.64055 C 290.99022,221.21674 289.96761,220.94643 288.48156,222.7125 C 287.22606,224.20456 287.20344,224.51141 288.22522,226.18724 C 289.16963,227.73623 290.16453,227.83418 291.68335,226.52772 z" />
- <path
- id="path2298"
- d="M 298.49314,226.74936 C 298.90038,226.49089 298.8895,226.15939 298.43775,225.06297 C 298.12852,224.31239 297.74746,222.74472 297.59091,221.57924 C 297.43441,220.41376 297.08703,219.37602 296.81898,219.27316 C 295.89632,218.91911 294.22928,219.87097 293.97123,220.8992 C 293.13446,224.23307 296.20295,228.20285 298.49314,226.74936 z" />
- <path
- id="path2294"
- d="M 335.23084,223.79785 C 337.06748,222.55344 337.12064,221.99382 335.46786,221.30323 C 333.5491,220.50153 331.23857,220.51543 331.23857,221.32868 C 331.23857,222.19803 332.31797,224.18402 332.92269,224.42734 C 333.74973,224.7601 333.85168,224.7323 335.23084,223.79785 z" />
- <path
- id="path2290"
- d="M 383.90281,220.37318 C 384.44154,218.28344 384.28085,216.81662 382.83636,212.37084 C 381.76373,215.38825 380.78724,217.2674 380.25365,218.79798 C 379.89779,219.81885 379.97425,220.10272 380.83754,220.96604 C 382.20734,222.33584 383.4593,222.0937 383.90281,220.37318 z" />
- <path
- id="path2286"
- d="M 376.08361,220.40678 C 376.84965,219.89997 377.83547,217.60906 378.09158,215.74052 C 378.33059,213.99683 379.10399,212.85299 379.09404,210.89345 C 376.81394,213.36102 375.9602,214.35244 375.01946,215.83322 C 373.67813,217.94454 373.25286,219.22225 373.59478,220.11331 C 373.8342,220.73723 375.31945,220.91236 376.08361,220.40678 z" />
- <path
- id="path2284"
- d="M 287.97322,218.30723 C 287.91695,216.52941 285.96586,211.5248 285.12694,211.00632 C 284.89923,210.86559 284.16016,211.21558 283.48452,211.78408 C 282.49455,212.61708 282.25609,213.12255 282.25609,214.38804 C 282.25609,216.25704 283.05626,218.32586 284.23502,219.50464 C 284.86435,220.13395 285.47611,220.32653 286.55978,220.23645 L 288.03045,220.11421 L 287.97322,218.30723 z" />
- <path
- id="path2280"
- d="M 337.26747,219.14277 C 338.15692,218.41212 338.17472,218.31008 337.59784,217.25117 C 336.71126,215.62376 334.95004,215.53967 333.49789,217.0554 L 332.38714,218.21476 L 333.70445,219.05822 C 335.34361,220.10774 336.07182,220.12502 337.26747,219.14277 z" />
- <path
- id="path2278"
- d="M 293.43278,218.70639 C 294.96573,217.88597 294.11172,213.36546 292.23394,212.3605 C 290.08787,211.21195 288.37599,212.75333 288.8559,215.40206 C 289.33394,218.04022 290.08719,219.11863 291.45181,219.11863 C 292.1177,219.11863 293.0091,218.93312 293.43278,218.70639 z" />
- <path
- id="path2276"
- d="M 307.24333,218.50609 C 308.04962,218.1692 309.00259,217.62816 309.36104,217.30378 C 309.96261,216.75938 309.94839,216.58201 309.1765,214.99834 C 308.03115,212.64846 305.82347,210.75639 304.71161,211.17172 C 303.38323,211.66792 302.1325,213.51929 302.32855,214.69921 C 302.42309,215.26816 302.51516,216.0231 302.53316,216.37686 C 302.58477,217.39057 304.13764,219.11863 304.99698,219.11863 C 305.4262,219.11863 306.43703,218.84299 307.24333,218.50609 z" />
- <path
- id="path2274"
- d="M 300.3497,218.33202 C 301.24074,217.99325 301.3712,217.71099 301.3712,216.12197 C 301.3712,213.03026 299.79584,211.154 297.19993,211.154 C 296.17042,211.154 294.60127,212.82155 294.60127,213.91561 C 294.60127,214.87238 296.58757,217.79441 297.55814,218.26545 C 298.63786,218.78946 299.11654,218.80087 300.3497,218.33202 z" />
- <path
- id="path2270"
- d="M 358.18147,214.88536 C 359.22045,213.5645 358.51397,207.89664 357.50067,206.97963 C 356.02966,208.94548 355.42535,209.62416 354.36518,211.11303 C 353.15516,212.81235 352.63729,214.49849 353.82796,215.11615 C 355.35837,215.91004 357.27617,216.03625 358.18147,214.88536 z" />
- <path
- id="path2268"
- style="fill:#800000"
- d="M 416.65966,208.43653 C 417.81186,207.05143 419.74285,204.09456 420.95068,201.86571 C 423.3971,197.35135 426.16293,190.60498 425.80484,190.02558 C 425.67701,189.81874 424.97768,189.6495 424.25075,189.6495 C 423.12343,189.6495 422.59681,190.02796 420.66945,192.22326 C 418.21356,195.02054 415.17298,196.81653 411.38265,197.70872 C 409.90987,198.05539 409.29194,198.39398 409.29194,198.8543 C 409.29194,199.89283 410.21699,200.39582 412.7276,200.72242 L 415.06629,201.02665 L 411.90262,202.6058 L 408.73891,204.18495 L 400.75214,204.31808 C 396.31238,204.39209 391.08515,204.24964 388.98213,203.99733 C 382.29268,203.19476 376.58706,202.8235 370.19918,202.77516 C 364.11038,202.72907 357.92007,203.39176 357.92007,204.08967 C 357.92007,204.74116 358.81108,206.175 359.99175,207.42351 C 361.13894,208.63663 361.20485,208.65423 362.38851,208.06372 C 363.2477,207.63512 364.84859,207.45545 367.8315,207.45287 C 371.92882,207.44934 373.5691,207.5073 387.98655,208.16506 C 395.24675,2
08.49629 409.01823,207.85451 410.9972,207.09273 C 411.60654,206.85816 412.21336,206.77449 412.34566,206.9068 C 412.56476,207.12592 412.05001,210.32822 411.41144,212.71838 C 411.16458,213.64238 411.22897,213.62465 412.8589,212.32015 C 413.79709,211.56925 415.50745,209.82162 416.65966,208.43653 z" />
- <path
- id="path2262"
- d="M 303.66649,209.69949 L 304.56793,208.70757 L 302.93012,206.37272 C 302.02932,205.08856 300.95899,203.73623 300.5516,203.36755 C 299.85056,202.73309 299.74359,202.76458 298.5518,203.95635 C 297.4135,205.09467 297.31808,205.37427 297.55738,206.87072 C 297.859,208.75699 298.2908,209.39024 299.97608,210.41773 C 301.37917,211.27321 302.42046,211.07056 303.66649,209.69949 z" />
- <path
- id="path2256"
- d="M 295.36097,209.00287 C 295.85514,208.47683 296.35683,207.32065 296.47582,206.43358 C 296.66339,205.03501 296.53906,204.66766 295.53986,203.66845 C 293.96935,202.09794 291.64145,201.67165 290.25636,202.70093 C 288.92269,203.69203 288.7759,205.12016 289.80114,207.12985 C 291.18548,209.84338 293.75738,210.70981 295.36097,209.00287 z" />
- <path
- id="path2250"
- d="M 337.38857,204.69368 C 338.29347,203.40178 338.1615,202.87271 336.71425,201.99031 C 335.34704,201.15671 332.65101,200.92195 332.23195,201.60001 C 331.79979,202.29928 332.41036,203.35267 333.90337,204.48362 C 335.65443,205.81001 336.5681,205.86508 337.38857,204.69368 z" />
- <path
- id="path2246"
- d="M 298.21271,201.14714 C 298.5426,200.5307 298.28559,200.04903 296.75176,198.40927 C 294.79079,196.31279 294.20045,196.06022 293.43031,196.98817 C 293.06147,197.43263 293.10424,197.84598 293.62612,198.87977 C 295.20483,202.00691 297.21952,203.00288 298.21271,201.14714 z" />
- <path
- id="path2240"
- d="M 324.0704,200.0261 C 324.0704,198.32886 323.04686,197.21384 321.49284,197.21812 C 318.77822,197.22558 315.70754,199.11714 315.70754,200.78188 C 315.70754,201.55076 315.94206,201.59644 319.88897,201.59644 L 324.0704,201.59644 L 324.0704,200.0261 z" />
- <path
- id="path2232"
- d="M 334.80971,197.82886 C 335.07525,197.50891 335.38304,196.56809 335.49371,195.73815 C 335.64747,194.58528 335.4912,193.97071 334.83169,193.13403 C 333.62628,191.60489 332.95578,191.76176 331.96299,193.80523 L 331.10484,195.57157 L 332.18755,196.99108 C 333.35548,198.52235 334.05,198.74424 334.80971,197.82886 z" />
- <path
- id="path2230"
- d="M 382.80568,194.84951 C 383.21757,192.41153 382.70322,190.12689 381.57622,189.38844 C 380.67204,188.796 380.53759,188.82081 379.22442,189.82241 C 378.45839,190.40668 377.83165,191.11579 377.83165,191.39818 C 377.83165,191.68059 378.36604,192.88109 379.01914,194.06598 C 379.67224,195.25086 380.20985,196.59366 380.21383,197.04996 C 380.21781,197.50627 380.30221,199.50032 380.46409,199.66223 C 382.36548,196.73965 382.52262,196.52478 382.80568,194.84951 z" />
- <path
- id="path2226"
- d="M 286.94626,192.61366 C 287.43306,192.2727 287.83133,191.6522 287.83133,191.23479 C 287.83133,189.99136 286.2797,186.22622 285.46249,185.48666 C 284.79784,184.88518 284.56321,184.86637 283.57926,185.33571 C 282.72831,185.74157 282.42391,186.19903 282.3263,187.21843 C 282.13961,189.16915 282.50773,190.25129 283.89605,191.83247 C 285.27381,193.40165 285.67467,193.50432 286.94626,192.61366 z" />
- <path
- id="path2224"
- d="M 280.50622,192.24605 C 281.69745,191.74832 281.87518,191.51625 281.64974,190.75268 C 281.22989,189.33051 279.57966,185.94598 278.88156,185.0752 C 278.29472,184.34322 278.16689,184.32924 277.17119,184.88812 C 274.83672,186.1984 274.54044,189.61436 276.57683,191.7399 C 277.77125,192.9866 278.50702,193.08137 280.50622,192.24605 z" />
- <path
- id="path2220"
- d="M 354.52682,185.70649 C 356.94588,184.34123 357.69049,183.53933 356.26096,183.83881 C 355.74979,183.9459 354.16169,184.14229 352.73188,184.27524 C 350.38406,184.49354 350.60261,180.7234 349.2481,179.80422 C 347.34647,178.51372 346.371,182.22096 346.37287,183.57647 C 346.37487,185.06647 347.73853,187.19443 348.84796,187.4389 C 350.77317,187.86313 352.15006,187.84097 352.26985,187.38383 C 352.3381,187.12334 353.35371,186.36853 354.52682,185.70649 z" />
- <path
- id="path2210"
- d="M 356.83171,182.91485 C 357.72207,182.57633 357.76855,182.41312 357.52192,180.49077 C 357.23599,178.26202 356.74426,177.7181 355.00673,177.70865 C 353.28231,177.69928 352.41727,178.36396 351.89794,180.09735 C 351.48234,181.48445 351.51321,181.78242 352.14472,182.48024 C 352.92924,183.34711 355.15253,183.55326 356.83171,182.91485 z" />
- <path
- id="path2206"
- d="M 337.39307,180.70739 C 336.85546,180.16978 336.41557,179.27376 336.41557,178.71623 C 336.41557,177.83023 336.58498,177.70256 337.76064,177.70256 C 338.5004,177.70256 339.33859,177.98318 339.62321,178.32616 C 340.30438,179.14693 342.15955,180.09195 343.08962,180.09195 C 343.49669,180.09195 344.17762,179.83113 344.60278,179.51235 C 345.32146,178.97348 345.26651,178.9362 343.82077,178.98184 C 342.64547,179.01895 342.08627,178.80934 341.53094,178.12352 C 340.38049,176.70279 340.63058,176.45402 343.07759,176.58493 C 345.13203,176.69483 345.35989,176.62772 345.36742,175.91051 C 345.37817,174.88522 346.8858,174.63854 348.13577,175.45754 C 349.29167,176.21493 353.26144,176.12232 354.90498,175.29964 C 357.20824,174.14674 360.03142,169.03209 360.06316,165.95473 C 360.08219,164.11258 358.23324,159.78214 357.4277,159.78214 C 356.54207,159.78214 353.66561,163.0604 353.16204,164.64365 C 352.85513,165.60862 352.2174,166.41376 351.32146,166.96749 C 350.56741,167.43351 350.0413,
167.96171 350.15225,168.14129 C 350.40461,168.54958 344.22075,170.81101 341.00507,171.48639 C 338.1439,172.08732 337.53512,172.37768 333.53608,175.04885 C 331.84284,176.17985 330.45401,177.38298 330.44979,177.72247 C 330.43804,178.66658 331.27516,179.29548 332.54353,179.29548 C 333.28555,179.29548 334.11017,179.71643 334.88394,180.49018 C 335.65782,181.26406 336.48228,181.68487 337.22458,181.68487 L 338.37053,181.68487 L 337.39307,180.70739 z" />
- <path
- id="path2202"
- d="M 331.60788,171.47626 C 332.06187,170.89916 332.43326,169.99013 332.43326,169.4562 L 332.43326,168.48542 L 333.48515,169.31283 C 334.27289,169.93249 334.66909,170.03063 335.06298,169.70372 C 335.48407,169.35423 335.19507,168.70636 333.61342,166.45414 C 332.52688,164.90696 331.27922,163.38987 330.84089,163.08284 C 330.40252,162.7758 330.04387,162.3223 330.04387,162.07506 C 330.04387,161.82781 329.70521,161.25556 329.29133,160.80338 C 328.87741,160.35121 327.88247,158.90603 327.08031,157.59187 L 325.62183,155.20248 L 328.82843,158.54402 C 330.59208,160.38187 332.03503,162.1189 332.03503,162.40409 C 332.03503,162.68929 333.12618,164.18726 334.45982,165.73293 C 336.42939,168.01566 337.10221,168.54323 338.0439,168.54323 C 338.68151,168.54323 339.20319,168.38584 339.20319,168.19348 C 339.20319,168.00112 338.03837,166.58561 336.61469,165.0479 C 335.19101,163.5102 334.02619,161.98691 334.02619,161.66282 C 334.02619,160.49074 322.77674,149.02989 321.62625,149.02989 C 321.
20544,149.02989 321.11544,150.31462 321.26358,154.2069 C 321.38333,157.3527 321.7861,158.27851 324.1279,160.79079 C 325.09437,161.82764 328.45094,169.66467 328.45094,170.88438 C 328.45094,171.29304 329.99114,172.52555 330.5018,172.52555 C 330.65619,172.52555 331.15394,172.05337 331.60788,171.47626 z" />
- <path
- id="path3170"
- d="M 349.67335,249.42454 C 349.95215,247.00011 345.7706,244.68804 345.43207,247.07947 C 345.0991,249.43174 346.30407,250.79422 348.55137,250.6066 C 349.31681,250.5427 349.57618,250.26945 349.67335,249.42454 z" />
- <path
- id="path3172"
- d="M 339.82982,225.75444 C 340.32404,224.8811 340.3065,224.79252 339.50507,224.11223 C 338.27338,223.0667 336.81448,223.55085 336.10889,225.2393 L 335.56918,226.53076 L 336.90526,226.80352 C 338.56776,227.14289 339.16549,226.92848 339.82982,225.75444 z" />
- <path
- id="path5114"
- d="M 393.07947,191.30261 C 393.49136,188.86463 392.977,186.57998 391.85001,185.84154 C 390.94582,185.2491 390.81138,185.27391 389.49821,186.2755 C 388.73217,186.85978 388.10544,187.56889 388.10544,187.85128 C 388.10544,188.13368 388.63982,189.33419 389.29292,190.51908 C 389.94602,191.70396 390.48364,193.04676 390.48762,193.50306 C 390.4916,193.95937 390.576,195.95342 390.73788,196.11533 C 392.63927,193.19275 392.7964,192.97788 393.07947,191.30261 z" />
- </g>
- </g>
- <path
- style="font-size:104.55381012px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- d="M 392.83206,713.20935 C 401.07681,713.20935 409.32157,713.20935 417.56633,713.20935 C 417.56633,706.95656 417.56633,700.70379 417.56633,694.451 C 421.36062,702.75151 426.4185,711.04281 433.8487,714.43269 C 441.98054,718.42379 451.85168,716.83355 458.57299,709.69499 C 464.98512,703.05781 469.06548,693.57111 471.77363,683.87768 C 475.79291,668.83455 476.4609,652.70303 475.535,636.98162 C 474.72116,624.10852 472.23633,611.20161 466.95424,599.99913 C 463.09365,591.75549 457.36234,584.16378 449.79306,581.55815 C 441.87177,578.85463 432.86775,581.12029 426.70486,588.0266 C 422.89063,592.01386 420.02253,597.21829 417.56633,602.57996 C 417.56633,579.42548 417.56633,556.27096 417.56633,533.11649 C 409.32157,533.11649 401.07681,533.11649 392.83206,533.11649 C 392.83206,593.14743 392.83206,653.17839 392.83206,713.20935 z M 743.9256,602.57996 C 740.20751,594.36978 735.182,586.43011 728.02783,582.72436 C 719.81169,578.58879 709.71346,580.08353 702.98296,587.51731 C 696.81958,593.
86296 692.87993,602.9411 690.17044,612.1892 C 686.1838,626.39239 685.31055,641.65148 685.89555,656.59318 C 686.39184,666.76589 687.75389,676.97108 690.64285,686.53117 C 693.73735,696.5741 698.51491,706.37685 705.93075,712.24565 C 713.59759,718.1182 723.85891,717.93051 731.53286,712.185 C 736.95801,707.94729 740.83275,701.32408 743.9256,694.451 C 743.9256,700.70379 743.9256,706.95656 743.9256,713.20935 C 752.22159,713.20935 760.51754,713.20935 768.81351,713.20935 C 768.81351,653.17839 768.81351,593.14743 768.81351,533.11649 C 760.51754,533.11649 752.22159,533.11649 743.9256,533.11649 C 743.9256,556.27096 743.9256,579.42548 743.9256,602.57996 z M 113.02238,633.11828 C 105.1873,602.34523 97.352205,571.57213 89.517135,540.79909 C 78.233925,540.88446 66.950731,540.9698 55.667535,541.05516 C 55.701662,598.67464 55.735822,656.29411 55.769948,713.91358 C 64.185411,713.97761 72.600862,714.04164 81.016325,714.10565 C 80.982185,672.1288 80.948035,630.15193 80.913905,588.17509 C 88.8343
35,618.82011 96.754775,649.46515 104.6752,680.11016 C 110.30827,680.06749 115.94133,680.02479 121.57439,679.98212 C 129.49481,648.93163 137.41526,617.88114 145.33569,586.83064 C 145.33569,628.95688 145.33569,671.08311 145.33569,713.20935 C 153.73407,713.20935 162.13246,713.20935 170.53085,713.20935 C 170.53085,655.61122 170.53085,598.01308 170.53085,540.41496 C 159.24765,540.41496 147.96445,540.41496 136.68126,540.41496 C 128.79496,571.31606 120.90867,602.21718 113.02238,633.11828 z M 339.72762,580.55652 C 332.66006,580.9947 326.04964,585.67618 321.64155,592.49847 C 319.48025,595.58095 317.69524,599.03122 316.06876,602.57996 C 316.06876,596.24182 316.06876,589.90368 316.06876,583.56554 C 307.80692,583.56554 299.54511,583.56554 291.28327,583.56554 C 291.28327,643.21235 291.28327,702.85919 291.28327,762.506 C 299.54511,762.506 307.80692,762.506 316.06876,762.506 C 316.06876,739.821 316.06876,717.136 316.06876,694.451 C 319.87266,702.72815 324.89708,710.94872 332.27046,714.4449
6 C 339.84781,718.06267 348.88265,717.10628 355.54023,711.13119 C 362.54753,704.89782 366.94242,695.15345 369.86047,685.24293 C 374.11084,670.60805 374.82806,654.77664 374.197,639.3498 C 373.4643,624.61485 370.607,609.65605 364.03711,597.21282 C 360.45269,590.50369 355.56136,584.44453 349.27696,581.96999 C 346.24189,580.64343 342.92531,580.19097 339.72762,580.55652 z M 528.99858,580.49249 C 519.83368,580.96826 510.61396,585.08081 503.95252,593.13549 C 495.82013,602.72351 491.35757,616.2602 489.66786,629.88657 C 488.03719,642.81008 488.14497,656.07142 489.87439,668.97039 C 491.78793,681.92596 496.10138,694.83984 504.00827,703.86218 C 509.76036,710.45319 517.19508,714.54511 524.90597,715.82442 C 535.83874,717.88779 547.028,715.51037 557.39011,711.01967 C 561.01543,709.42415 564.51078,707.42218 567.96916,705.33468 C 567.96916,694.68575 567.96916,684.03682 567.96916,673.38789 C 560.05238,680.54845 551.13711,686.60234 541.36014,688.39784 C 535.09498,689.55569 528.13283,689.43252
522.76865,684.68088 C 517.34341,680.00477 515.00414,671.72408 514.10318,663.88912 C 513.80122,662.16637 513.35146,659.26988 515.52199,659.77795 C 519.50415,660.07498 523.50356,659.77463 527.49532,659.87933 C 542.19856,659.87933 556.9018,659.87933 571.60504,659.87933 C 571.59097,648.9126 571.90256,637.83983 570.11824,627.03308 C 568.16043,613.90462 563.51214,601.06966 555.63692,591.83593 C 549.01237,583.95384 539.73525,580.06724 530.66055,580.45095 C 530.10658,580.4648 529.55258,580.47863 528.99858,580.49249 z M 640.02118,580.49249 C 632.75718,580.57991 626.03486,585.4637 621.27724,592.0962 C 618.86368,595.25787 616.95388,598.94803 615.03084,602.57996 C 615.03084,596.24182 615.03084,589.90368 615.03084,583.56554 C 606.78608,583.56554 598.54133,583.56554 590.29657,583.56554 C 590.29657,626.78014 590.29657,669.99474 590.29657,713.20935 C 598.54133,713.20935 606.78608,713.20935 615.03084,713.20935 C 615.07159,690.83663 614.93681,668.46088 615.12811,646.09021 C 615.36041,636.3271
3 616.62341,626.01839 621.43205,618.00918 C 624.45685,613.2475 629.73596,610.40613 634.51498,612.25069 C 638.7375,613.94078 641.57482,619.01742 642.18705,624.37755 C 643.19588,631.04301 643.0919,637.88049 643.2037,644.63887 C 643.28516,667.49555 643.23241,690.35252 643.24739,713.20935 C 651.54335,713.20935 659.83933,713.20935 668.13528,713.20935 C 668.0971,685.05016 668.22331,656.88795 668.04447,628.73072 C 667.71468,617.14513 666.26901,605.20188 661.57895,595.02229 C 658.24228,587.82862 652.47515,582.15799 645.78367,580.98582 C 643.89188,580.54902 641.94216,580.37293 640.02118,580.49249 z M 827.39738,580.49249 C 818.18061,581.05365 808.82458,585.08163 802.21786,593.36837 C 795.05862,601.8916 790.75346,613.55212 788.77869,625.53812 C 786.60699,637.99585 786.57957,650.90774 787.65742,663.54195 C 788.88878,676.36948 792.25264,689.23712 798.942,699.27804 C 804.50104,707.62258 812.43726,713.39974 820.99335,715.29575 C 832.15021,718.1135 843.75549,715.99236 854.4703,711.61145 C 8
58.55387,709.83535 862.56996,707.80412 866.41914,705.33468 C 866.41914,694.68575 866.41914,684.03682 866.41914,673.38789 C 859.88596,679.31795 852.70017,684.39068 844.8752,687.06772 C 838.62586,689.07743 831.8413,690.05932 825.60504,687.47264 C 821.92579,685.92722 818.75081,682.83862 816.64336,678.7657 C 813.71769,673.17699 812.64444,666.43933 812.18811,659.87933 C 831.47708,659.87933 850.76608,659.87933 870.05506,659.87933 C 870.0802,647.69151 870.31937,635.33429 867.94261,623.41431 C 865.61452,610.9891 860.7367,598.93387 852.89979,590.54389 C 846.95636,584.20716 839.23859,580.71763 831.45081,580.47959 C 830.10006,580.38452 828.74888,580.47657 827.39738,580.49249 z M 224.71069,580.55652 C 215.16028,581.08506 205.69117,583.37123 196.59657,587.0227 C 196.59657,597.56493 196.59657,608.10717 196.59657,618.64939 C 206.06156,609.87603 218.39787,606.63944 229.98528,608.53397 C 234.69398,609.26799 239.78005,612.01706 241.77541,617.78283 C 243.16824,621.67408 243.25481,626.04347 243
.19739,630.2373 C 233.9678,630.44271 224.64331,629.53337 215.50684,631.59363 C 208.3462,633.34909 201.00106,637.06443 196.4523,644.52118 C 191.72633,652.10583 190.10637,661.90726 189.86942,671.32886 C 189.42362,682.19544 191.03417,693.53846 195.96089,702.69056 C 200.04615,710.25261 206.75806,715.82015 214.14443,716.40241 C 221.50841,717.23951 229.47618,714.92414 234.86352,708.27908 C 238.34393,704.24259 240.95407,699.19455 243.19739,694.00286 C 243.19739,700.40501 243.19739,706.80718 243.19739,713.20935 C 251.51043,713.20935 259.82346,713.20935 268.13649,713.20935 C 268.09695,686.69961 268.22829,660.18755 268.0406,633.67935 C 267.66882,621.84908 266.32867,609.62918 261.57762,599.1885 C 258.26978,592.12067 252.89652,586.67239 246.71139,583.99449 C 239.7234,580.66123 232.10518,580.26702 224.71069,580.55652 z M 936.93483,580.55652 C 930.09007,581.03317 923.65577,585.62089 919.52456,592.39896 C 917.05936,596.18897 915.24796,600.55082 913.48084,604.88473 C 913.48084,597.77834 913
.48084,590.67194 913.48084,583.56554 C 905.23612,583.56554 896.99129,583.56554 888.74658,583.56554 C 888.74658,626.78014 888.74658,669.99474 888.74658,713.20935 C 896.99129,713.20935 905.23612,713.20935 913.48084,713.20935 C 913.52456,691.88558 913.38016,670.55861 913.58457,649.23695 C 913.89173,639.58679 915.21484,629.39011 920.07822,621.56745 C 923.63457,616.00751 929.51925,613.1376 935.1524,614.02861 C 939.09756,614.51866 942.93222,616.19972 946.25507,618.90548 C 946.23791,606.39991 946.22085,593.89437 946.2038,581.38879 C 943.14056,580.74506 940.04485,580.28397 936.93483,580.55652 z M 532.07118,608.0218 C 536.46356,608.21092 540.42655,611.68904 542.62948,616.33894 C 545.3352,621.65812 546.06851,628.08196 546.20504,634.27067 C 535.48516,634.27067 524.76526,634.27067 514.04536,634.27067 C 514.74197,626.25739 516.5905,617.73502 521.64782,612.26076 C 524.47272,609.07637 528.33033,607.8252 532.07118,608.0218 z M 830.57239,608.0218 C 835.02609,608.25222 839.00252,611.84398 841
.17278,616.6007 C 843.83748,621.83252 844.54919,628.18003 844.60383,634.27067 C 833.88393,634.27067 823.16405,634.27067 812.44414,634.27067 C 813.2306,626.22169 815.03944,617.57631 820.20382,612.13811 C 823.06621,609.07792 826.85378,607.8161 830.57239,608.0218 z M 333.48005,610.58268 C 338.3669,610.72431 342.59977,615.0557 344.66484,620.40184 C 347.85967,628.06176 348.52556,636.86739 348.81801,645.36206 C 348.89351,655.91744 348.58268,666.97889 344.69497,676.58898 C 342.70177,681.54234 338.99177,685.79122 334.42454,686.30903 C 329.94997,687.09305 325.1189,685.04974 322.33625,680.48409 C 318.10823,674.0274 316.92538,665.42982 316.37144,657.34282 C 315.75129,646.54245 315.9466,635.4359 318.62232,625.04881 C 320.3127,618.96383 323.64179,612.86432 328.88173,611.13568 C 330.37438,610.67608 331.93996,610.41375 333.48005,610.58268 z M 434.31191,610.51865 C 438.92193,610.51533 443.32851,613.87899 445.47966,618.96782 C 449.43964,627.07414 450.06804,636.86721 450.28506,646.14456 C 450
.44722,655.58844 449.96711,665.31483 447.11545,674.16272 C 445.27875,679.92156 441.54053,685.37024 436.383,686.24501 C 431.37295,687.39896 425.89011,684.71935 423.10004,679.31507 C 419.47826,673.04748 418.53677,665.16433 417.86694,657.66974 C 417.2286,646.46609 417.4068,634.89825 420.38401,624.18795 C 422.16099,618.18661 425.74333,612.15178 431.07298,610.96261 C 432.13848,610.70075 433.22355,610.4908 434.31191,610.51865 z M 728.61391,610.58268 C 733.56343,610.79577 737.86726,615.17723 739.88746,620.67085 C 743.55993,629.79048 743.93151,640.27225 743.9022,650.29179 C 743.78362,660.15961 742.93442,670.53681 738.65101,679.08582 C 736.32787,683.31858 732.49462,686.376 728.32729,686.48327 C 723.68101,686.84743 718.98205,683.89913 716.59452,678.85632 C 713.24883,672.6686 712.27891,665.04874 711.66351,657.7666 C 711.13075,645.89499 711.11825,633.55023 714.71002,622.34388 C 716.55489,616.83969 720.19778,611.79694 725.10601,610.82875 C 726.262,610.60924 727.44573,610.46268 728.61391,
610.58268 z M 232.23851,654.88565 C 235.89175,654.96064 239.54323,654.8617 243.19739,654.88565 C 243.32339,662.72841 242.97814,670.97913 239.76807,677.93613 C 237.37619,683.56515 233.09606,688.56768 227.78328,688.94514 C 223.24527,689.55016 218.13263,687.02259 216.28076,681.50376 C 214.31226,676.28844 214.39797,670.12403 215.6978,664.68095 C 217.03027,660.40874 220.01432,657.0747 223.58408,655.974 C 226.38444,654.90928 229.33626,654.84679 232.23851,654.88565 z"
- id="text3266" />
-</svg>
Deleted: trunk/documents/logos/mapbender_dragon2.svg
--- trunk/documents/logos/mapbender_dragon2.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_dragon2.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,517 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Created with Inkscape (http://www.inkscape.org/) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- version="1.0"
- width="1000"
- height="1000"
- id="svg2"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- sodipodi:docname="mapbender_dragon2.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_dragon2.png"
- inkscape:export-xdpi="90"
- inkscape:export-ydpi="90">
- <metadata
- id="metadata4098">
- <rdf:RDF>
- <cc:Work
- rdf:about="">
- <dc:format>image/svg+xml</dc:format>
- <dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
- </cc:Work>
- </rdf:RDF>
- </metadata>
- <sodipodi:namedview
- inkscape:window-height="975"
- inkscape:window-width="1400"
- inkscape:pageshadow="2"
- inkscape:pageopacity="0.0"
- guidetolerance="10.0"
- gridtolerance="10.0"
- objecttolerance="10.0"
- borderopacity="1.0"
- bordercolor="#666666"
- pagecolor="#ffffff"
- id="base"
- showgrid="false"
- inkscape:zoom="0.494"
- inkscape:cx="562.34607"
- inkscape:cy="461.72824"
- inkscape:window-x="0"
- inkscape:window-y="25"
- inkscape:current-layer="svg2" />
- <defs
- id="defs4">
- <inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 500 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="1000 : 500 : 1"
- inkscape:persp3d-origin="500 : 333.33333 : 1"
- id="perspective4100" />
- id="perspective4267"
- inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
- inkscape:vp_z="744.09448 : 526.18109 : 1"
- inkscape:vp_x="0 : 526.18109 : 1"
- sodipodi:type="inkscape:persp3d" />
- id="perspective5038"
- </defs>
- <g
- style="display:inline"
- id="layer2" />
- <g
- id="g5594"
- transform="matrix(3.7735532,1.1641622,-0.9383907,4.6814487,-1261.4354,-1151.654)">
- <g
- id="g4354"
- transform="matrix(1.4110648,0.164685,-0.1326582,1.3227349,107.36509,-64.958801)">
- <g
- transform="matrix(0.9424289,-0.3848325,0.2905881,0.9424289,-92.49501,114.45179)"
- id="g4691">
- <path
- d="M 255.95193,117.56609 C 255.54896,117.56609 254.4178,123.20635 253.94832,127.52188 C 253.49139,131.72208 253.89922,138.94579 254.89412,144.09827 C 255.96529,149.6458 255.29122,164.27908 253.76165,168.61439 C 252.62502,171.8359 249.48405,174.09758 246.12059,174.11496 C 245.18972,174.11978 244.4281,174.30818 244.4281,174.53809 C 244.4281,175.27314 245.67371,177.40765 246.82994,178.64485 C 247.44624,179.30428 249.34385,182.53009 251.03626,185.81301 L 254.11011,191.78649 L 254.29678,195.63191 C 254.52437,200.35779 253.97361,202.5607 252.65407,202.17784 C 250.43763,201.53476 246.7787,199.54064 244.4281,197.69774 C 243.00442,196.58156 240.04755,194.34682 237.85728,192.73229 C 233.13147,189.24869 228.82885,185.69261 225.41255,182.44049 C 224.04538,181.13902 221.35731,178.76462 219.43908,177.16392 C 213.97614,172.6053 205.52805,163.33501 198.1088,153.75538 C 196.64196,151.86145 194.90879,149.74217 194.26338,149.05127 C 193.61801,148.36038 191.06379,143.774 188.58858,13
8.85903 C 186.11341,133.94406 183.9771,129.92561 183.83469,129.92371 C 183.69224,129.92182 183.35693,130.83125 183.08801,131.95221 C 181.96607,136.62906 183.251,144.2933 188.01612,161.25955 C 191.14582,172.40279 191.48912,179.94953 189.09881,185.05389 C 188.68497,185.93765 187.99494,187.46568 187.56811,188.4513 C 186.46589,190.99667 185.08934,192.19866 180.56173,194.52433 L 176.57941,196.56526 L 178.54568,198.30753 C 179.6256,199.26582 182.57279,201.65227 185.09161,203.60898 C 187.61042,205.56569 190.34741,208.07803 191.17709,209.19667 C 192.92871,211.55833 192.80304,211.96752 189.87039,213.29099 C 188.37754,213.96469 186.84833,214.14641 180.71106,214.38612 C 174.86694,214.61438 172.19114,214.91918 167.76854,215.8546 C 160.64382,217.36155 149.02128,218.64918 148.37964,218.00754 C 148.04206,217.66996 148.60538,216.83178 150.60725,214.70969 C 153.717,211.41322 155.54541,208.68699 157.65097,204.19389 C 159.16007,200.97355 161.04697,194.9336 160.6626,194.54922 C 160.54994,194.43
656 159.04868,195.41674 157.32741,196.72705 C 147.0843,204.52445 135.21248,210.68272 121.7728,215.1577 C 114.82554,217.47092 111.78072,217.92043 103.24259,217.92043 C 99.657396,217.92043 96.627273,218.07913 96.509995,218.26888 C 97.890038,222.11499 119.19037,231.79283 121.76036,233.86213 C 134.21051,240.07656 150.65295,244.00722 166.17561,244.47749 C 172.90238,244.68128 173.48728,244.63353 175.67095,243.80548 C 176.98013,243.30902 177.84348,242.77969 177.64966,242.58589 C 177.46022,242.39643 176.11472,242.0697 174.66292,241.8641 C 171.18497,241.37156 164.36072,239.02088 159.40568,236.61242 C 155.29955,234.61657 149.25078,230.8569 149.25078,230.30294 C 149.25078,230.1305 151.80444,229.87234 154.92557,229.73048 C 158.04671,229.58863 163.46764,229.10904 166.97208,228.66023 C 175.03666,227.62742 191.40437,227.15047 194.74872,227.85133 C 196.08535,228.13143 197.03855,228.55109 197.03855,228.84691 C 197.03855,229.85881 195.42708,233.97418 194.17627,236.17685 C 193.47175,237.41751
191.85695,239.53044 190.57974,240.86852 L 188.25257,243.29524 L 191.1522,243.99215 C 195.19198,244.95334 199.57696,247.2089 202.19067,249.67939 C 204.33189,251.70327 204.3741,251.78849 203.60937,252.3799 C 202.56278,253.18927 199.23672,254.16008 197.46168,254.17194 C 196.68007,254.17716 195.32616,254.35919 194.45005,254.58262 C 193.57394,254.80604 190.25866,255.50689 187.08277,256.13821 C 176.83778,258.17473 160.86129,263.09582 151.29171,267.16424 C 146.2196,269.32061 136.80763,273.98908 133.62019,275.92533 C 127.64049,281.12024 120.29419,287.68779 117.05625,294.89111 C 115.66594,298.23259 114.59441,304.62296 114.60464,309.56345 C 115.1144,317.97373 121.66185,332.8172 129.79966,335.5605 C 135.19143,338.20567 144.81468,339.52892 152.0384,338.60946 C 158.78856,337.15301 166.46608,334.86786 172.21131,331.20484 C 177.6055,328.47641 182.95953,326.89508 187.705,323.05354 C 189.11646,323.05354 189.14337,323.07766 188.57614,323.94956 C 183.61381,331.57692 181.69318,335.84573 178.919
02,345.39184 C 178.13737,348.08159 177.35254,350.47091 177.17676,350.70574 C 177.00094,350.94057 176.55373,351.93529 176.18118,352.9209 C 175.04013,355.93992 173.79432,356.91325 170.26993,357.52546 C 168.37618,357.85442 164.48685,356.68797 164.17201,355.69608 C 164.049,355.3084 163.40922,354.24179 162.74087,353.31914 L 161.52128,351.6391 L 158.90789,351.81332 C 156.59787,351.96041 156.19541,352.10174 155.37359,353.13246 C 154.86293,353.77288 154.34053,354.81202 154.20378,355.43474 C 154.06699,356.05746 153.12021,357.6784 152.10062,359.03127 C 151.08103,360.38414 149.92821,362.1997 149.54945,363.07581 C 148.75382,364.91599 145.86236,377.65914 144.1111,387.03192 C 141.80215,399.38945 140.1601,404.91249 136.53226,412.45651 C 133.89612,417.93828 131.47093,420.85471 125.78001,425.39904 C 121.67464,428.67728 121.39733,429.27189 121.08834,435.41705 C 120.8768,439.62398 121.14991,441.39552 122.68127,445.49728 C 123.13816,446.72107 125.21812,449.29293 125.74267,449.29292 C 126.11602,
449.29292 128.02434,445.07262 128.67963,442.80922 C 129.0159,441.6479 129.49581,440.99506 130.24767,440.64383 C 130.84139,440.36648 131.82317,439.90372 132.4255,439.62337 C 133.16282,439.28019 133.95289,438.23577 134.85222,436.42507 C 136.24671,433.6174 139.30435,429.94612 140.98747,429.04534 C 141.84463,428.58662 142.18482,428.62524 143.71287,429.39379 C 146.11444,430.6017 148.24277,432.96451 149.92279,436.30062 C 151.06631,438.57135 151.43822,439.93298 151.86417,443.38168 C 152.82765,451.18285 153.47112,452.12949 158.01187,452.47878 L 160.60037,452.67789 L 161.68307,454.86817 C 162.5305,456.58305 162.7682,457.64187 162.7782,459.7465 C 162.78525,461.22494 162.63854,462.43457 162.45464,462.43456 C 161.47758,462.43456 160.78623,466.18687 161.69551,466.55377 C 163.05989,467.10431 164.3407,466.46792 167.08408,463.86571 C 169.81997,461.27063 170.03189,460.03712 169.83437,448.07334 L 169.7597,443.05811 L 167.5072,440.30783 C 163.27237,435.10776 162.09743,432.56721 163.92312,432.5
672 C 164.92642,432.5672 175.73277,437.95538 176.72875,438.95135 C 177.35122,439.57381 178.26188,439.87512 179.87727,440.0216 C 182.42854,440.25294 184.35673,439.50696 186.84632,437.32109 L 188.24013,436.10151 L 191.21442,436.52463 C 194.7314,437.0138 197.38191,437.95584 198.25814,439.03846 C 199.2632,440.28028 200.40333,439.79481 200.54797,438.05533 C 200.6488,436.84301 200.38171,436.19163 199.0546,434.43391 C 198.16575,433.25659 197.43678,432.11114 197.43679,431.88274 C 197.43679,431.0887 194.20482,428.5676 191.56287,427.29063 C 190.10084,426.58399 188.39759,425.4211 187.76723,424.71457 C 186.24475,423.00822 184.62039,422.62791 178.91902,422.61141 C 174.60829,422.59894 173.86722,422.48592 171.35262,421.4665 C 169.28835,420.62963 168.56501,420.14263 168.565,419.58734 C 168.565,418.50922 172.40957,417.74996 176.52963,418.01931 C 179.59805,418.2199 179.81675,418.17117 182.42844,416.79972 C 184.89289,415.50561 185.32859,415.39997 187.20721,415.65481 C 189.73571,415.99782 193.2
0215,417.2552 193.87759,418.06909 C 194.27746,418.55086 194.43631,418.57024 194.69894,418.1562 C 195.67529,416.61708 194.62394,413.46976 191.77443,409.40755 C 190.19867,407.16115 189.79327,406.86091 185.77607,404.95234 C 182.17749,403.24265 181.43264,402.7302 181.24619,401.8536 C 180.93166,400.37479 179.56583,399.75432 177.35099,400.08645 C 175.29408,400.3949 173.3475,401.81958 172.98288,403.2723 C 172.73116,404.27519 172.35295,404.42163 168.66456,404.92745 C 166.3318,405.24736 161.86898,404.44294 160.69993,403.4963 C 159.89757,402.8466 159.82197,402.4404 159.81636,398.0704 C 159.80556,389.66914 161.53843,385.69343 166.48673,382.75093 L 169.36147,381.046 L 175.13582,380.99622 C 179.13144,380.96214 181.45917,380.75631 182.71467,380.33665 C 183.97594,379.91505 184.82573,379.84408 185.50229,380.1002 C 186.03755,380.30284 188.45666,380.39415 190.86597,380.31176 C 194.47478,380.18836 195.56223,380.00201 197.03855,379.24152 C 199.45833,377.99502 200.52342,376.96127 201.63066,374.7
863 C 202.51462,373.05002 202.66823,372.94397 204.55517,372.72048 C 208.48464,372.25509 211.21493,370.2506 213.1296,366.42344 C 214.22191,364.24004 214.94291,363.32979 216.26567,362.4909 C 219.23034,360.61077 221.72043,356.26216 221.72891,352.94579 C 221.73034,352.38322 222.09022,351.38772 222.52537,350.73063 C 222.96056,350.07355 223.30796,349.25523 223.30939,348.9137 C 223.31086,348.57217 224.29364,347.4552 225.48722,346.42475 C 226.6808,345.39429 228.51764,343.39015 229.56909,341.96954 C 230.62054,340.54893 231.57518,339.39166 231.68469,339.39348 C 231.79421,339.39528 232.25365,340.06731 232.70516,340.88685 C 233.15672,341.70639 235.09767,345.19986 237.02349,348.65236 C 238.94925,352.10486 241.78407,357.66019 243.32052,360.99754 L 246.10814,367.05812 L 245.90903,370.64221 C 245.67702,374.85732 244.82291,377.36045 242.48672,380.62288 C 240.59281,383.26772 240.31935,385.32033 241.5907,387.40526 C 242.21927,388.43606 242.92573,388.82643 245.87169,389.74487 C 247.81156,390.34
964 250.30201,391.30477 251.39715,391.86048 C 252.49229,392.4162 255.74104,393.81264 258.62754,394.97166 C 262.94011,396.70329 265.1765,397.9482 271.17184,401.94071 C 275.1847,404.61301 278.54201,406.85916 278.62623,406.93105 C 278.71046,407.00294 278.55115,407.62242 278.26533,408.31242 C 277.73939,409.58218 275.80352,411.05997 274.66881,411.0627 C 273.98397,411.06435 271.85562,413.16454 271.15939,414.52234 C 270.91408,415.00075 270.71138,415.7656 270.71138,416.21482 C 270.71138,416.66405 269.81536,418.73218 268.72022,420.81937 C 266.92464,424.24157 266.72906,424.8706 266.72907,427.20352 C 266.72907,428.99585 266.97482,430.33465 267.55042,431.55918 C 268.85152,434.32712 269.28517,434.47505 270.25093,432.48009 C 271.306,430.30058 274.23449,427.43163 277.23242,425.63549 C 279.5023,424.27554 279.60487,424.25665 280.77917,424.86391 C 281.59164,425.28406 282.62682,425.42447 283.92769,425.29948 C 286.94318,425.00973 287.95032,423.7328 289.39093,418.35532 C 289.94809,416.2756 291.6
0873,414.24856 292.751,414.24855 C 293.22442,414.24855 294.8642,414.52115 296.39731,414.8459 C 297.93042,415.17064 300.13624,415.43944 301.30054,415.44325 C 303.6061,415.45078 304.22013,415.69807 306.70155,417.58374 C 307.60884,418.27319 309.91616,419.54536 311.82878,420.42114 L 315.31331,422.01407 L 315.31331,423.93056 C 315.31331,427.35075 317.07662,429.38135 320.05475,429.38135 C 320.93114,429.38135 322.27506,429.08726 323.04149,428.72178 C 324.23216,428.154 324.68532,428.12657 326.09045,428.54755 C 328.11553,429.15428 331.05252,431.99682 331.42924,433.71212 C 331.74523,435.15081 332.66585,435.35021 334.25419,434.30946 C 336.44164,432.87619 337.1963,428.70566 335.62311,426.70573 C 335.14352,426.09601 334.82666,425.09216 334.82665,424.17945 C 334.82665,423.34581 334.648,422.54804 334.42842,422.4123 C 333.89873,422.08493 332.59209,419.16859 332.23815,417.50907 C 331.82327,415.56377 330.26862,414.81428 325.51799,414.261 C 321.07548,413.74359 318.49258,412.95593 317.46625,411
.82183 C 316.83366,411.12281 316.8436,411.07114 317.74003,410.73914 C 324.19198,408.34966 329.40759,406.68216 330.4461,406.68216 C 331.15121,406.68216 332.94325,406.98327 334.42842,407.34173 C 336.01553,407.7248 337.59138,407.8798 338.2614,407.71507 C 338.89466,407.55936 340.37976,406.39864 341.59659,405.11412 C 342.80124,403.84249 344.23488,402.69262 344.78244,402.56295 C 345.88773,402.30118 352.54923,398.5888 353.64309,397.62239 C 354.85909,396.5481 354.42326,395.73367 351.63949,393.8143 C 349.41863,392.28304 348.63269,391.95044 347.15938,391.94759 C 343.42632,391.94036 341.23245,391.4914 340.97435,390.67823 C 340.57512,389.42038 338.4172,388.36517 336.23291,388.36351 C 334.36982,388.3621 334.16101,388.47901 332.16348,390.54134 C 331.00263,391.73986 329.19808,393.10082 328.15627,393.56541 C 327.1145,394.03 325.63753,394.8384 324.87086,395.35745 C 324.10415,395.87651 322.3121,396.54889 320.88855,396.85082 C 319.46495,397.15274 317.67284,397.78514 316.90623,398.25707 C 315.9
729,398.83167 314.85453,399.11476 313.53371,399.11576 L 311.56744,399.11576 L 312.98614,397.62239 C 313.7713,396.80104 314.64726,395.68101 314.92752,395.13344 C 315.20776,394.58587 316.6558,393.01162 318.13826,391.63647 L 320.82632,389.13508 L 320.78899,385.26477 C 320.76999,383.06289 320.97387,380.87925 321.24945,380.19976 C 321.51594,379.54268 322.84363,378.00047 324.19885,376.76501 C 325.55407,375.52956 326.52186,374.3772 326.35179,374.2014 C 325.73102,373.55985 319.03893,373.51427 317.20491,374.13918 C 316.02638,374.54074 314.54435,374.66492 312.68747,374.53741 C 309.97304,374.35101 309.91005,374.37135 308.64293,375.69477 C 307.56161,376.82414 307.22343,377.67472 306.52733,381.00867 C 306.07139,383.19224 305.3349,386.05377 304.88462,387.36793 C 304.43438,388.68209 303.97119,390.15598 303.86415,390.64089 C 303.59778,391.8474 300.5428,393.26592 297.77868,393.46585 C 296.14808,393.5838 294.7986,393.36031 292.60167,392.61961 C 290.96549,392.06797 288.6215,391.34426 287.39977
,391.00179 C 286.17807,390.65932 284.50829,389.92601 283.69124,389.37153 C 282.87419,388.81706 281.4608,387.97722 280.54272,387.51726 C 278.14815,386.31762 274.28263,383.32412 272.96388,381.64335 C 272.01875,380.43876 271.86333,379.92962 272.01808,378.51972 C 272.27816,376.14972 273.23498,374.89582 275.61461,373.8405 C 279.64061,372.05504 280.22016,370.56508 280.24405,361.94334 C 280.25368,358.47335 280.07111,353.45563 279.83337,350.79285 C 279.44828,346.48018 279.27429,345.76495 278.24044,344.24692 C 277.60208,343.30965 277.08308,342.49244 277.08308,342.42999 C 277.08308,342.36755 279.18873,342.3979 281.7623,342.49222 C 286.4332,342.66341 286.44476,342.6672 288.23357,344.09759 C 289.21919,344.88571 290.16563,345.75219 290.33673,346.02652 C 290.50785,346.30084 291.47056,346.88794 292.47722,347.33322 C 294.90349,348.40648 299.38865,348.41073 303.55303,347.34566 L 306.67666,346.5492 L 308.77982,347.58211 C 311.39019,348.85924 315.56971,349.36175 315.9231,348.4408 C 316.13002,3
47.90154 316.42034,347.91357 318.44938,348.52791 C 322.29036,349.69087 323.90353,351.16282 322.68059,352.38578 C 321.88676,353.17959 321.90387,356.20787 322.71792,357.82413 C 323.99135,360.35237 327.58008,363.27493 329.40075,363.27492 C 329.72017,363.27492 330.34751,363.87069 330.79456,364.59406 C 331.24165,365.31746 332.81673,367.06471 334.30397,368.47682 C 335.79121,369.88895 337.55449,371.6973 338.21162,372.49647 C 338.86874,373.29565 340.92956,375.09029 342.79128,376.47879 C 347.10305,379.69451 352.56394,384.93135 355.59691,388.76174 C 358.98861,393.04522 359.2228,393.27428 363.6611,396.61437 C 368.66822,400.38253 368.98498,400.79829 367.84253,401.94071 C 367.08601,402.69726 366.72077,402.76132 364.51979,402.52561 C 361.75371,402.22939 361.27411,402.49654 361.04771,404.47944 C 360.93827,405.43792 360.67175,405.7067 359.66634,405.91058 C 357.75889,406.29736 355.31058,408.26607 352.48573,411.67249 C 350.11394,414.53258 349.43262,416.07077 349.68566,417.95708 C 350.07601,42
0.8673 350.54858,420.92784 354.77556,418.67888 C 358.42133,416.73914 358.54773,416.70379 359.85301,417.26018 C 361.56879,417.99155 365.91471,418.00013 367.65586,417.27262 C 368.39621,416.96328 369.42124,416.29127 369.93325,415.77926 C 370.7458,414.96668 371.24632,414.84958 373.85334,414.85835 C 376.34487,414.86672 377.19332,415.05186 378.99301,415.99082 C 381.68303,417.39432 385.15367,420.64254 386.49719,423.00965 C 387.05833,423.99834 388.15042,425.78471 388.92391,426.97952 C 390.25372,429.03373 390.33228,429.34026 390.35505,432.64187 C 390.38341,436.74976 390.63674,437.12561 394.6236,439.08824 C 397.6897,440.5976 398.94193,442.59734 398.94192,445.97018 C 398.94192,448.46934 399.4697,450.03025 400.42284,450.32584 C 400.80945,450.44573 401.45699,450.72218 401.85399,450.93563 C 404.2466,452.22206 408.30131,447.43896 408.77326,442.77188 C 408.89882,441.53016 408.72714,439.78407 408.33769,438.29178 C 407.96133,436.84943 407.70388,434.23364 407.70301,431.92008 C 407.7013,427.442
5 407.09815,425.93171 404.84072,424.76435 C 402.59454,423.60281 398.54393,419.72 398.54369,418.72866 C 398.54345,417.86197 398.65972,417.83264 402.33933,417.83264 C 404.4316,417.83264 407.43328,418.1272 409.00971,418.47976 C 411.82318,419.10899 411.95175,419.18961 415.64275,422.86031 C 419.16814,426.36629 419.50679,426.59373 421.04377,426.59373 C 421.9454,426.59373 423.0329,426.33041 423.45805,426.00883 C 424.36661,425.32163 426.69936,425.23641 428.2866,425.82216 C 428.90319,426.04969 430.43165,427.34891 431.68402,428.70933 C 433.53822,430.72355 434.02598,431.07214 434.34719,430.58849 C 434.93522,429.70301 435.31411,425.99861 435.04409,423.719 C 434.50338,419.15342 430.58297,413.56388 426.14611,411.02537 C 424.32014,409.98067 424.03051,409.63903 424.0305,408.61109 C 424.0305,407.80682 423.6211,407.01944 422.79848,406.19681 L 421.57889,404.97723 L 416.86234,405.21368 C 411.74104,405.47117 409.64364,405.12781 408.2008,403.79498 C 407.03725,402.72013 407.06179,402.6036 408.5990
3,401.95316 C 409.31087,401.65196 410.70539,400.88905 411.71022,400.26067 C 412.715,399.63229 414.03209,399.11576 414.62229,399.11576 C 416.09013,399.11576 418.16179,398.20282 419.1895,397.09971 C 420.08242,396.14129 420.33074,394.5586 419.64996,394.13786 C 419.43093,394.0025 419.25173,393.54934 419.25173,393.12984 C 419.25173,392.09697 421.19172,391.15113 423.32115,391.15113 C 424.89126,391.15113 425.31424,391.39028 427.88837,393.73963 L 430.71333,396.32814 L 431.9578,394.92188 C 433.04672,393.68166 433.18984,393.23353 433.18983,391.10135 C 433.18983,388.13069 432.41889,386.39897 430.25287,384.53053 C 427.86105,382.46733 425.71439,381.43191 423.23404,381.13312 C 415.7999,380.23758 416.0586,380.22637 413.47737,381.63091 C 411.11888,382.91427 409.61697,383.15431 408.71104,382.40248 C 407.81677,381.66028 405.33394,383.86207 404.0816,386.50924 C 403.44391,387.85722 402.92441,389.3347 402.92424,389.79465 C 402.92392,390.62492 401.18063,393.33591 400.09928,394.18764 C 399.78898,3
94.43206 397.95174,395.30574 396.01741,396.12902 C 393.03995,397.39626 392.22604,397.58389 390.69106,397.37349 C 387.87756,396.98786 385.79591,395.63178 385.04115,393.67741 C 384.6884,392.764 384.02249,391.59918 383.56023,391.0889 C 383.098,390.57863 381.79277,388.76672 380.66061,387.06925 C 379.52839,385.37179 378.4373,383.98296 378.23388,383.98296 C 377.65027,383.98296 374.25158,381.83749 374.25157,381.46912 C 374.25157,381.28673 373.2737,379.08908 372.08618,376.59079 C 370.34532,372.92838 369.3191,371.36707 366.77228,368.5266 C 360.41257,361.4335 354.72286,351.18213 356.28137,349.62305 C 356.6403,349.264 359.78161,349.13771 368.3901,349.1377 L 380.02592,349.1377 L 383.162,350.73063 C 384.88905,351.60674 386.39173,352.63717 386.49719,353.02046 C 386.64286,353.54991 387.07607,353.71019 388.32656,353.68003 C 391.18355,353.61113 391.62156,353.29232 393.97647,349.53594 C 397.0724,344.59749 400.28355,340.71902 402.04066,339.80415 C 403.36534,339.11445 405.31363,336.86719 405.31
362,336.02096 C 405.31362,335.84051 406.69304,333.97019 408.38747,331.86441 C 410.10485,329.7301 411.7436,327.23837 412.08356,326.23939 C 412.71627,324.37999 414.87274,320.3381 417.08634,316.86851 C 417.7901,315.76547 419.51182,313.79423 420.90688,312.48796 C 424.16927,309.43313 425.2102,307.99583 426.83057,304.33666 C 427.55798,302.69396 428.57959,300.76707 429.10796,300.04323 C 429.93321,298.91272 430.27225,298.74425 431.50979,298.84853 C 433.17663,298.98898 433.47416,299.61203 433.53828,303.12952 C 433.60578,306.82993 434.45467,308.34792 437.88149,310.90748 C 439.54602,312.15073 441.10658,313.55768 441.34113,314.03111 C 441.70133,314.75807 442.27693,314.95152 445.04966,315.25069 C 450.97574,315.8901 455.50108,314.12924 458.17886,310.14835 C 459.41119,308.31639 460.15922,306.47882 459.8091,306.1287 C 459.72121,306.04083 458.48813,306.17412 457.07126,306.41493 C 454.59097,306.8365 454.43092,306.8094 452.93962,305.7927 C 452.08769,305.2119 451.19166,304.73695 450.94846,304.7
3489 C 450.39496,304.73019 447.16551,299.33347 446.86659,297.91518 C 446.74314,297.32941 446.22342,296.66742 445.68434,296.42181 C 445.15302,296.17972 444.59746,295.67453 444.45231,295.28934 C 444.30716,294.90415 443.68796,293.90116 443.08339,293.06173 C 441.85326,291.35377 441.18882,288.21125 441.90114,287.49894 C 442.16015,287.23992 442.34916,285.68102 442.34915,283.79041 C 442.34915,280.56904 442.37345,280.49246 443.96697,278.4765 C 445.99779,275.90733 446.72875,273.9033 447.10304,269.9892 C 447.45305,266.32875 448.00174,265.55446 450.83646,264.71263 C 454.43723,263.64331 454.69434,263.33107 454.69433,259.90896 C 454.69433,256.08919 455.5866,254.19019 458.16639,252.55412 C 460.37379,251.15421 461.04147,251.11196 463.2812,252.23056 C 465.42751,253.30247 466.24305,253.02486 466.24305,251.23498 C 466.24305,249.46646 463.92793,247.10214 460.56825,245.42329 C 458.48625,244.3829 457.7138,244.20371 455.01789,244.20371 C 451.47865,244.20371 448.95899,245.18937 446.23191,247.63845
C 445.32084,248.45665 444.14303,249.0674 443.1954,249.21893 L 441.65225,249.46783 L 440.40777,255.6902 C 439.72341,259.10837 438.91811,262.14533 438.61573,262.44769 C 438.14821,262.91521 437.90577,262.67302 436.99792,260.81743 C 436.41076,259.61734 435.68117,257.22626 435.3801,255.50353 C 435.07904,253.7808 434.60415,251.54413 434.33474,250.53808 C 433.85149,248.73349 433.86534,248.69068 435.30543,246.80466 C 436.47611,245.27151 436.77392,244.54056 436.77391,243.13346 C 436.77391,241.21099 436.11315,239.63689 434.82009,238.46668 C 433.76904,237.51551 433.76747,236.837 434.83253,233.96169 C 435.44808,232.29987 436.2509,231.14254 437.70727,229.7927 C 438.81813,228.76306 439.63047,227.8207 439.51175,227.70199 C 439.08604,227.27626 435.01648,226.68153 432.51781,226.68152 C 429.39719,226.68152 427.79838,227.31433 425.84744,229.31981 C 423.53287,231.69907 422.53256,233.73751 422.08913,236.98576 C 421.80547,239.06351 421.43524,240.18848 420.81976,240.84363 C 420.31122,241.38492 41
9.87558,242.48659 419.76196,243.49436 C 419.59403,244.98426 419.81653,245.69853 421.46689,248.79581 C 423.39644,252.41706 423.76311,253.82128 424.26695,259.54806 C 424.46567,261.80695 424.39279,262.44411 423.89361,262.85836 C 423.00986,263.59183 422.01919,262.95059 420.19753,260.46897 C 418.89415,258.69345 418.65606,258.04086 418.51749,255.86442 C 418.37173,253.57519 418.23734,253.24788 417.11123,252.40479 C 415.43308,251.14844 414.1643,250.79569 413.44004,251.39676 C 412.26521,252.37179 411.13073,251.28922 410.12974,248.2358 C 409.07769,245.02676 409.17106,243.81126 410.71464,240.32095 C 411.24699,239.11718 411.68534,238.04182 411.68533,237.93156 C 411.68533,237.52561 408.38075,238.27546 406.96877,239.00181 C 403.53889,240.76628 401.6834,244.19488 401.40598,249.2936 C 401.22188,252.67689 401.63923,254.82124 403.31002,259.06272 C 403.99215,260.79439 404.00192,261.09172 403.4718,262.36057 C 402.57937,264.49644 403.08667,266.2394 405.12695,268.03537 C 406.92788,269.62059 409.0
9546,270.48699 411.24976,270.48699 C 412.87236,270.48699 416.13347,273.48355 418.66682,277.29425 C 421.21614,281.12896 421.13664,282.0473 417.95747,284.77354 C 414.82877,287.45648 410.02165,292.07053 408.64881,293.7213 C 402.15254,301.5329 394.80968,308.77889 387.82877,314.24267 C 385.9725,315.69552 383.99019,317.32897 383.43578,317.87653 C 381.61403,319.67571 380.45592,320.26324 378.70678,320.26592 C 377.41934,320.2679 376.75436,320.03091 376.01872,319.29523 C 375.48111,318.75762 375.04804,318.03971 375.04803,317.70231 C 375.04803,317.36491 375.95389,315.96114 377.06408,314.59112 L 379.08013,312.10218 L 378.9059,308.31898 C 378.80642,306.23822 378.50385,303.81897 378.23388,302.94285 C 377.74812,301.36626 377.76666,301.31319 380.01348,297.76584 L 382.27842,294.18176 L 382.07931,289.6021 C 381.96844,287.08328 381.6784,284.03682 381.43218,282.83216 C 381.15019,281.45256 381.07525,278.784 381.23306,275.62666 C 381.4626,271.03563 381.40316,270.4661 380.62327,268.80695 C 380.1549
1,267.81061 379.16232,266.2782 378.40811,265.39709 C 377.04544,263.8051 377.03321,263.7661 377.03919,259.87163 C 377.04484,256.15321 376.97519,255.80885 375.62049,253.16392 C 374.46271,250.9035 373.70198,250.01973 371.62573,248.47225 C 369.15267,246.62902 369.07457,246.49758 369.07456,244.80105 C 369.07456,242.84923 369.6833,241.17645 370.51815,240.85607 C 370.82984,240.73647 372.22205,241.68195 373.74133,243.05879 C 375.20922,244.38902 377.57851,246.32148 379.00546,247.33978 C 381.46183,249.09272 381.75549,249.18797 384.60559,249.31849 C 386.26119,249.39431 388.41908,249.24668 389.39681,248.98248 L 391.17641,248.49714 L 389.48392,247.04111 C 387.94567,245.7138 387.30815,244.60194 388.09011,244.60194 C 388.25813,244.60194 389.33336,243.78762 390.4795,242.78501 C 391.96459,241.4859 392.57022,240.66669 392.57022,239.94761 C 392.57022,239.00631 392.46574,238.96449 391.13907,239.21337 C 390.35691,239.3601 389.50161,239.55907 389.23503,239.66138 C 388.95579,239.76853 388.36787,23
9.03951 387.84122,237.94401 C 387.33837,236.89799 386.37238,235.1797 385.70072,234.12347 L 384.48114,232.20698 L 385.22782,230.7385 C 385.85137,229.51405 386.00302,228.13391 386.12384,222.33831 C 386.20429,218.48104 383.24726,210.96718 383.03755,210.50337 C 382.82325,210.02944 379.9602,215.20236 378.37078,219.92403 C 379.34495,215.03304 380.38484,213.91364 379.95126,209.43312 C 385.83734,209.71281 391.65512,209.78671 397.89656,209.80646 C 406.33238,209.7737 408.64185,209.87203 408.79815,210.27936 C 408.90719,210.56362 408.41053,211.95964 407.69057,213.3781 C 406.01135,216.6864 404.87554,220.02727 405.28874,220.44671 C 405.84088,221.00718 408.7121,219.97164 411.1502,218.34355 C 414.18624,216.31615 418.26053,212.06539 420.52109,208.56199 C 425.41794,200.9729 426.77478,198.04818 427.85104,192.76962 C 428.55603,189.31192 428.84932,180.10227 428.29905,178.75685 C 427.86394,177.69305 427.02317,178.50185 426.27056,180.71067 C 425.53299,182.87532 422.70888,186.62542 420.3842,188.513
52 C 416.38416,191.76239 410.34662,194.59014 404.80339,195.81858 C 401.38127,196.57697 401.22536,196.84922 402.96157,199.30311 C 403.9016,200.63176 403.51066,201.66702 401.70465,202.60096 C 399.83045,203.57014 389.83594,202.14526 386.65897,201.87917 C 384.38799,201.69111 383.47493,201.67274 380.73527,201.30671 C 380.85801,200.86075 384.81341,196.80918 385.06604,194.1261 C 385.3646,190.955 384.98981,188.37663 385.29005,188.37663 C 385.54412,188.37663 386.93018,189.75461 387.51765,190.36779 C 388.34522,191.23162 388.72172,192.25966 389.22258,194.95989 C 390.00519,199.17883 390.51574,199.31543 392.49555,195.81858 C 393.82198,193.47577 393.84315,193.32611 394.00136,187.85395 C 394.12645,183.52758 394.33249,181.87729 394.92227,180.48667 C 395.34026,179.50105 395.80406,177.43367 395.95518,175.89456 C 396.22929,173.10266 396.23099,173.09253 394.79782,171.37712 C 393.00323,169.22918 392.93487,167.86243 394.53648,166.03833 C 396.23586,164.10283 398.87991,163.58766 405.38829,163.94762
C 408.66606,164.1289 410.49064,164.08844 410.49063,163.83561 C 410.49063,163.21382 407.97513,161.17069 405.23896,159.56707 L 402.72512,158.09859 L 397.74723,158.28526 C 392.52382,158.47297 390.62373,158.95819 387.79144,160.84888 C 386.72517,161.56066 385.85097,161.76837 384.00824,161.76979 C 381.15607,161.77198 377.28018,163.20867 375.9565,164.74408 C 375.4519,165.32942 373.84057,166.19859 372.1733,166.79746 C 370.57603,167.37121 368.05859,168.44776 366.58561,169.18685 C 365.11263,169.92593 363.64103,170.53089 363.31265,170.53088 C 362.31567,170.53088 361.62605,168.53059 361.33393,164.8063 C 360.89126,159.16317 359.48836,156.81551 355.92047,155.74654 C 354.66652,155.37084 354.23506,155.39188 353.71776,155.82121 C 353.07613,156.35372 353.08961,157.1888 353.76754,159.91552 C 354.01639,160.91649 353.78552,161.28687 351.68927,163.32538 C 349.59959,165.35755 346.65964,167.14466 344.12287,167.91749 C 343.41509,168.13311 342.41444,167.32336 338.32362,163.2756 C 335.60422,160.58484
331.63567,156.29323 329.51275,153.73049 C 327.38986,151.16775 324.24728,147.82409 322.51881,146.30098 C 318.48914,142.75009 311.77678,137.70391 311.48033,138.00035 C 311.10894,138.37173 313.25762,141.99963 315.0893,144.09827 C 317.7156,147.10733 318.48495,149.26296 318.77294,154.39006 L 319.02184,158.78305 L 320.58987,160.57509 C 321.45328,161.56072 322.78556,163.43718 323.55172,164.74408 C 325.03525,167.27457 325.16405,169.21721 323.92506,170.45621 C 323.42397,170.9573 323.15007,170.90701 321.78457,170.08287 C 318.09253,167.85461 314.91508,165.57912 314.91508,165.15476 C 314.91508,164.90318 314.33267,164.50678 313.62082,164.27118 C 312.90899,164.03557 309.45931,162.84698 305.95487,161.6329 C 302.45043,160.41881 298.14954,159.1367 296.39731,158.78305 C 294.64509,158.4294 291.68823,157.59068 289.82649,156.92879 C 285.81877,155.50394 281.48373,154.20339 280.75428,154.20339 C 280.36314,154.20339 280.3449,154.39606 280.65472,154.97496 C 280.88148,155.39862 281.06333,156.16024 2
81.0654,156.66745 C 281.07129,158.10408 283.85887,162.14214 287.36243,165.80188 C 291.08355,169.6889 293.26653,172.39883 294.74216,174.94876 C 295.58351,176.40268 295.79511,177.29727 295.79996,179.32931 C 295.80331,180.73374 295.93775,182.0883 296.09864,182.34093 C 296.25956,182.59356 297.4477,182.99869 298.73692,183.23695 C 301.42224,183.73321 303.78164,185.4189 305.97976,188.41396 C 307.1946,190.06923 307.32735,190.51222 307.33623,192.96874 C 307.34169,194.46542 307.48309,195.61655 307.64735,195.53235 C 311.83292,193.38726 314.39899,192.92397 317.41647,193.75276 L 318.53649,194.05143 L 316.396,196.42837 C 313.70049,199.407 312.12746,202.45623 312.12746,204.69168 C 312.12746,205.6194 312.23793,206.37172 312.37635,206.37172 C 312.51478,206.37172 313.27206,205.97286 314.05639,205.48814 C 315.18685,204.78949 316.23931,204.58346 319.17118,204.45523 L 322.87971,204.29344 L 322.87971,210.82693 C 322.87971,216.81774 322.80524,217.50711 321.98369,219.11512 C 321.38255,220.29173 320
.58424,221.11901 319.55696,221.6414 L 318.02626,222.42542 L 317.06802,221.26806 C 316.54426,220.63347 315.55646,219.21468 314.8653,218.11954 C 314.17413,217.02441 313.08945,215.38516 312.46346,214.47324 C 311.83744,213.56132 311.331,212.66945 311.33099,212.49452 C 311.33099,212.31959 310.62821,211.44999 309.7754,210.56559 C 307.54284,208.25042 301.77344,200.71389 301.77344,200.11201 C 301.77344,199.83154 300.01695,197.40506 297.87824,194.72344 C 293.82384,189.63973 285.55426,178.65904 283.70368,175.90701 C 283.11454,175.0309 281.90439,173.32846 281.01562,172.12381 C 280.12689,170.91916 278.88154,168.92767 278.25289,167.69348 C 277.6242,166.4593 276.86804,165.20106 276.56041,164.89342 C 275.80492,164.13796 272.88234,158.95758 270.1887,153.58115 C 267.08692,147.39008 263.92283,139.73719 261.3405,132.18866 C 260.12605,128.6386 258.88876,125.19222 258.59021,124.53514 C 258.2917,123.87806 257.6387,122.04122 257.13418,120.45327 C 256.62962,118.86532 256.09405,117.56609 255.95193,1
17.56609 z M 373.76622,193.67809 C 374.45847,193.67567 375.11278,193.84364 375.65782,194.20077 C 377.90365,195.67228 379.18427,198.72434 379.0179,201.18226 C 376.0036,201.17722 376.62922,201.18937 375.1227,201.15737 C 374.09474,201.13554 372.80799,200.97184 372.26041,200.79647 C 371.71284,200.62111 370.59754,200.4574 369.78391,200.43558 C 367.76938,200.38152 367.31139,199.47574 368.25321,197.39906 C 369.25472,195.19074 371.6895,193.68534 373.76622,193.67809 z M 370.10747,208.7611 C 373.32777,209.05034 376.45065,209.256 379.55302,209.40823 C 377.33171,211.28105 373.80603,215.49151 371.86218,216.67596 C 371.09558,217.14307 370.36563,217.52138 370.24436,217.5222 C 369.3585,217.52818 365.66745,215.19372 364.69401,214.01278 C 363.26552,212.27975 363.20523,211.56844 364.39534,210.45359 C 365.72149,209.21132 367.231,208.76111 370.10747,208.7611 z M 360.47525,226.79352 C 360.49159,226.7897 360.51414,226.79225 360.53747,226.79352 C 361.23745,226.83179 364.57437,229.47603 365.57759,23
0.83806 C 366.97311,232.73281 368.25313,235.34359 368.26565,236.33864 C 368.27728,237.26753 368.05005,237.23227 365.50292,235.8284 C 362.28003,234.0521 361.50817,233.19408 361.50816,231.38563 C 361.50816,230.54066 361.22977,229.19208 360.89837,228.39889 C 360.56696,227.60571 360.36246,226.89389 360.43791,226.81841 C 360.44878,226.80755 360.45891,226.79735 360.47525,226.79352 z M 324.31085,230.34027 C 324.37362,230.33322 324.43561,230.33696 324.49752,230.34027 C 325.32304,230.38448 326.03714,231.33555 326.05311,232.90389 C 326.07334,234.88731 327.15124,240.60127 328.03183,243.35747 C 328.79022,245.7313 328.80606,245.97579 328.20605,247.24022 C 324.6141,250.05812 324.0846,251.59762 322.44414,256.15065 C 321.54079,257.91653 321.06538,259.46686 320.95077,261.02899 C 320.74636,263.81662 321.0932,263.91485 323.55172,261.75078 C 325.50983,260.02718 327.93687,259.36293 329.91098,260.02096 C 331.39256,260.51483 331.82295,262.54754 331.26746,266.36778 C 330.67262,270.4586 330.32881,27
1.02565 327.72071,272.07991 C 323.3314,273.85421 320.89544,275.70399 318.84761,278.8374 L 317.69025,280.62944 L 320.49032,281.10234 C 323.14859,281.55025 326.06557,283.06628 326.06556,284.01441 C 326.06556,284.20549 325.59968,284.92101 325.03264,285.59489 C 324.18206,286.60576 323.71175,286.82169 322.34458,286.81448 C 319.97112,286.80195 317.8028,285.6764 314.87774,282.93172 C 311.79595,280.03996 310.07323,277.27062 308.43137,272.60259 C 307.28677,269.34832 307.19759,268.69619 307.17445,263.51793 C 307.15271,258.65104 307.26209,257.61382 308.07047,255.35419 C 309.82361,250.45373 313.26066,248.19026 319.39518,247.8749 C 321.14524,248.00031 322.64723,247.98358 324.37121,248.28772 C 324.04619,244.36369 324.25854,242.77508 323.04149,236.58753 C 322.36923,232.58553 322.37457,232.29081 323.0166,231.31096 C 323.41566,230.7019 323.87144,230.38966 324.31085,230.34027 z M 208.30104,266.72868 C 211.75319,266.70923 213.49474,267.54958 214.87186,269.91453 C 215.72316,271.37641 215.77214,
271.82753 215.61854,276.46046 C 215.43516,281.99101 214.71733,284.68726 212.59447,287.77272 L 211.38733,289.52743 L 208.22637,288.15851 C 204.45544,286.52817 200.54392,285.64169 197.10078,285.63223 L 194.58694,285.61978 L 196.60299,287.94695 C 197.71314,289.22335 198.63148,290.45869 198.63148,290.69723 C 198.63148,290.93577 198.76588,291.19668 198.93015,291.26969 C 199.09442,291.3427 199.65001,291.99654 200.16218,292.72573 C 201.00233,293.92179 201.03664,294.1697 200.57286,295.28934 C 199.24535,298.49423 197.03332,299.81017 191.42598,300.72769 L 188.81259,301.15081 L 183.59824,298.16407 L 178.3839,295.17734 L 175.19805,295.17734 C 169.9222,295.17734 169.74713,295.48435 172.93311,299.37121 C 176.31465,303.49665 176.7175,306.5441 174.25225,309.35189 C 172.76151,311.04974 171.28094,311.85273 168.36589,312.55019 C 164.72585,313.42108 164.02333,313.28967 162.51686,311.52972 C 160.26032,308.89344 154.22608,306.45025 150.8437,306.80072 L 149.63656,306.92517 L 151.4286,309.60078 C 1
53.00711,311.94889 153.23309,312.5483 153.23309,314.42934 C 153.23309,317.27559 152.62547,318.85406 151.3166,319.45701 C 149.29996,320.38606 146.0351,320.37632 144.27288,319.43212 C 140.73834,317.5383 136.93601,313.3803 136.29581,310.69592 C 136.07543,309.77184 136.25636,309.60347 138.27452,308.76699 C 141.01356,307.63172 144.01921,304.97502 145.29335,302.56951 C 145.82379,301.56813 146.56058,300.65663 146.92361,300.54102 C 147.5347,300.34645 148.24387,299.223 147.94408,298.9232 C 147.87204,298.85116 146.65514,299.35543 145.24357,300.04323 C 143.01101,301.1311 142.28887,301.27917 139.73055,301.22548 C 137.67277,301.1823 136.41711,300.94352 135.54912,300.42902 C 134.4336,299.76779 134.31383,299.51673 134.36687,297.90273 C 134.47862,294.50536 137.14361,290.72127 140.62658,289.01719 L 142.71729,287.99673 L 145.94048,288.60652 C 149.6158,289.30371 152.46879,290.235 155.73448,291.77993 C 160.22271,293.90318 161.103,292.17472 157.45186,288.4074 C 154.91528,285.79012 152.69444,282.
58438 152.95931,281.9237 C 153.0642,281.66196 154.99674,280.4915 157.26518,279.33519 L 161.39684,277.23203 L 164.7818,277.6676 C 169.74277,278.2923 173.94021,279.51915 177.799,281.48813 C 179.67674,282.44628 181.60766,283.2304 182.09243,283.23039 C 182.93353,283.23039 182.95723,283.15451 182.54044,281.51302 C 182.03003,279.50276 179.62744,275.78981 178.62035,275.45243 C 177.592,275.10792 177.75202,274.51504 179.30481,273.0506 C 181.54721,270.93573 184.61995,269.96929 189.19837,269.92697 C 192.51568,269.89631 193.1645,270.00192 193.49181,270.58654 C 193.70402,270.96559 194.69949,271.75081 195.70697,272.34125 C 196.71445,272.93169 197.96269,273.81366 198.48214,274.29507 C 199.0016,274.77649 201.05468,275.99487 203.03692,277.00803 C 206.53753,278.79728 208.84815,279.30624 210.05575,278.53873 C 210.79224,278.07066 209.66078,275.21062 207.81569,272.87637 C 206.19852,270.83052 204.67951,267.4879 205.15252,267.0149 C 205.30301,266.86441 206.72245,266.73756 208.30104,266.72868 z"
- style="fill:#000080;stroke:none;stroke-opacity:1;display:inline"
- id="path2514" />
- <path
- d="M 431.35117,424.37439 C 432.17587,422.22526 430.29459,416.75083 428.07787,414.84941 C 426.08205,413.13742 425.19077,412.68923 423.75041,412.67325 C 422.52585,412.65965 421.23227,413.7767 421.24302,414.83846 C 421.24533,415.06351 422.29272,415.73401 423.57065,416.32847 C 424.84857,416.92294 426.32513,417.77404 426.85191,418.21981 C 427.80241,419.02415 427.80365,419.03503 427.01324,419.65146 C 426.47176,420.07376 425.57933,420.23321 424.22562,420.14952 C 422.42039,420.03791 422.22259,420.11002 422.10731,420.92179 C 421.95685,421.9811 423.24967,422.61492 425.56085,422.61492 C 426.62743,422.61492 427.43015,422.94554 428.4221,423.79343 C 429.96501,425.11224 430.99002,425.31554 431.35117,424.37439 z"
- style="fill:#ffffff"
- id="path2480" />
- <path
- d="M 425.80321,239.0302 C 426.14286,239.0302 426.55957,238.38265 426.80397,237.47497 C 427.44556,235.0923 428.42664,234.10814 430.09766,234.17096 C 431.26316,234.21477 431.55383,234.06306 431.7422,233.31267 C 431.868,232.81134 432.42349,231.73429 432.97664,230.91922 C 433.52974,230.10415 433.98229,229.37877 433.98229,229.30726 C 433.98229,229.01743 430.33369,229.88402 429.30853,230.41734 C 426.74523,231.75084 424.8459,235.17091 424.83173,238.47871"
- id="path2533" />
- <path
- d="M 424.0265,241.52826 C 422.99687,242.83725 423.00902,243.00665 424.43493,247.2188 C 425.09763,249.17638 425.7168,251.22604 425.8109,251.77361 C 425.905,252.32118 426.71986,257.60109 427.6217,263.50675 C 428.52353,269.41241 429.336,274.36502 429.4272,274.51255 C 429.67884,274.91969 428.49669,275.7699 428.05692,275.4981 C 427.84514,275.36722 427.54994,274.67978 427.40096,273.97045 C 427.2519,273.26112 426.64591,272.14315 426.0543,271.48607 C 425.46264,270.82899 424.50107,269.57456 423.91743,268.69845 C 423.33382,267.82234 421.23797,265.05992 419.25999,262.55975 C 416.36927,258.90586 415.66364,257.75519 415.66364,256.69501 C 415.66364,255.09386 414.22431,253.93816 412.70506,254.31946 C 411.26709,254.68038 407.83987,258.19034 407.52482,259.62485 C 407.37676,260.29887 406.90741,261.16551 406.48174,261.55071 C 405.50786,262.43208 405.46784,264.55128 406.40476,265.62758 C 407.08116,266.40459 413.05045,268.89756 414.23455,268.89756 C 414.55783,268.89756 416.31618,270.7
3441 418.14199,272.97944 C 424.1987,280.42682 424.16939,280.36555 423.01253,283.14713 C 421.84845,285.94598 420.3474,287.63482 417.59498,289.24229 C 415.31152,290.57591 414.28449,291.5834 411.02213,295.68993 C 403.8599,304.70556 393.46068,314.67769 384.66319,320.96633 C 380.92937,323.63533 380.47232,323.85351 378.61469,323.85351 C 377.41315,323.85351 375.99751,323.54348 375.09373,323.08239 C 374.26238,322.65828 373.05992,322.25507 372.42152,322.18637 L 371.26083,322.06147 L 371.27505,325.44644 C 371.29484,330.1629 372.60036,332.02647 375.19388,331.04041 C 376.24215,330.64186 376.24462,330.64552 375.99206,332.22496 L 375.7387,333.8093 L 377.39531,333.8093 C 379.51625,333.8093 381.61704,332.93019 382.22912,331.78653 C 382.52604,331.23169 382.62405,330.07405 382.48674,328.74344 C 382.22343,326.19236 382.72982,325.77251 384.8504,326.78375 C 386.90766,327.76478 388.45045,327.62256 389.63734,326.34246 C 390.46909,325.44536 390.6158,324.97168 390.44854,323.72304 C 390.33624,322.884
69 389.9204,321.84083 389.52448,321.40335 C 388.82033,320.62528 388.82714,320.61358 389.8355,320.86666 C 390.40246,321.00896 391.65132,320.91402 392.61074,320.65567 C 393.57016,320.39732 394.68775,320.1219 395.09423,320.04361 C 396.54506,319.76421 397.00335,319.01163 396.87886,317.11299 C 396.76537,315.38236 396.82861,315.25785 398.14735,314.61606 C 399.5543,313.93132 401.06806,313.59163 402.97718,313.53224 C 404.29668,313.49118 404.71968,312.48016 403.92485,311.26712 C 403.59133,310.75812 403.31846,309.9661 403.31846,309.50707 C 403.31846,308.7133 403.45446,308.68588 406.09912,308.94648 C 409.3144,309.26331 409.78543,308.84641 408.91899,306.45045 C 408.64585,305.69505 408.50742,304.99196 408.61136,304.88802 C 408.7153,304.78408 409.49336,305.16934 410.3404,305.74416 C 411.48719,306.52241 412.18047,306.72928 413.05534,306.5543 C 414.64425,306.23653 414.93902,305.66882 414.67013,303.44415 C 414.42247,301.39507 414.73759,301.10571 415.86276,302.34901 C 416.80473,303.38986 416.
95753,303.36097 417.76806,301.98889 C 418.61139,300.56127 418.63174,299.47263 417.84368,297.94869 C 417.1009,296.5123 417.62808,296.39624 419.55604,297.57172 C 421.26871,298.61594 421.50518,298.58227 422.22423,297.19178 C 422.98549,295.71967 422.99457,294.35009 422.25477,292.57955 C 421.93742,291.81999 421.73357,291.19853 421.80178,291.19853 C 421.87004,291.19853 422.60235,291.73614 423.42916,292.39322 C 424.256,293.0503 425.07106,293.58792 425.24043,293.58792 C 425.4098,293.58792 425.94534,292.7679 426.43051,291.76566 C 427.15644,290.26616 427.23326,289.76909 426.8643,288.9593 C 426.28842,287.69539 426.29738,287.61444 427.01324,287.61444 C 427.34178,287.61444 427.61059,287.94298 427.61059,288.34453 C 427.61059,289.46758 428.00838,289.62629 429.23422,288.99237 C 430.56718,288.30307 432.7876,288.22141 432.7876,288.86169 C 432.7876,289.82055 431.08707,291.99511 429.68123,292.83392 C 427.15282,294.34256 425.63568,296.04627 423.33577,299.95962 C 420.91126,304.08505 418.64771,307
.17959 415.35688,310.86771 C 414.18648,312.1794 412.22885,314.87619 411.0066,316.86057 C 409.05718,320.02563 405.87181,324.98039 402.55987,329.99928 C 401.05739,332.27621 397.05496,336.16562 392.21792,340.04925 C 389.8907,341.9178 387.92769,343.60521 387.85577,343.79905 C 387.78385,343.99289 387.19101,343.87534 386.53834,343.53783 C 382.62687,341.51514 376.27198,340.94911 367.0794,341.80463 C 362.07164,342.27069 360.75532,342.7064 360.26347,344.06074 C 359.56015,345.99733 362.9685,346.36044 374.24757,345.55055 C 377.36727,345.32654 377.91345,345.40663 381.21662,346.57244 C 383.18786,347.26816 385.87593,348.33934 387.19009,348.95284 C 388.50425,349.56634 389.68541,350.0837 389.81487,350.10254 C 389.94434,350.12138 390.53703,349.2424 391.13202,348.14925 C 393.50676,343.78602 398.30043,338.06517 402.99912,333.98683 C 404.98128,332.26639 405.68213,331.21129 408.5398,325.64555 C 412.8258,317.29795 415.09493,313.88713 421.91894,305.53486 C 422.54524,304.76827 423.41008,303.43869 4
23.84077,302.58026 C 424.90118,300.46671 428.74459,296.3812 430.71277,295.27542 L 432.31641,294.37442 L 433.54758,295.41038 C 434.71834,296.39551 434.77875,296.59017 434.77875,299.37807 C 434.77875,304.95405 436.28009,308.56004 438.7095,308.81915 C 439.52926,308.90658 439.81746,308.54309 440.89977,306.05684 C 442.0822,303.3405 442.23241,303.17201 443.83203,302.76734 C 444.87731,302.5029 445.76568,301.96285 446.16969,301.34621 C 446.80483,300.37687 446.78077,300.30754 445.22154,298.61597 C 444.3416,297.66136 443.13727,296.14837 442.54526,295.25376 C 441.95325,294.35916 441.04254,293.34787 440.52149,293.00646 C 438.7621,291.85367 438.24078,290.23517 438.72793,287.43792 C 438.96516,286.07545 439.16233,283.72095 439.16603,282.2057 L 439.17276,279.4507 L 441.55709,276.47289 C 443.98511,273.44054 444.44148,272.49107 445.90853,267.41967 C 446.65103,264.85281 446.88885,264.47697 448.14874,263.8791 C 449.95277,263.02305 451.32607,261.21316 451.95452,258.86355 C 452.42941,257.08791 45
2.39994,256.92532 451.27223,255.10132 C 449.96288,252.98351 447.09223,250.57892 445.87332,250.57892 C 444.87344,250.57892 443.39413,253.74605 441.38653,260.18472 C 440.06249,264.43119 438.12696,268.1011 437.21147,268.1011 C 436.0014,268.1011 434.38052,263.05192 434.38052,259.28247 C 434.38052,257.58378 434.10327,255.87463 433.6332,254.67553 C 433.22219,253.62704 432.6704,251.48188 432.40701,249.90851 C 431.96115,247.24511 431.98373,246.97047 432.73459,245.92619 C 433.17818,245.30929 433.6551,244.16038 433.7944,243.37306 C 434.02833,242.05128 433.9535,241.90252 432.8185,241.43238 C 432.14238,241.15234 431.04139,240.29926 430.37184,239.53666 C 429.70226,238.77405 429.10917,238.21372 429.05382,238.29148 C 428.9985,238.36923 428.71205,239.19447 428.41728,240.12534 C 427.82049,242.01002 427.59354,241.10246 425.90707,241.01681"
- style="fill:#ff0000"
- id="path2450" />
- <path
- d="M 417.03722,266.70729 C 415.85658,265.4395 415.05443,264.91525 414.29516,264.91525 C 412.6691,264.91525 411.68133,264.2219 411.68133,263.08054 C 411.68133,262.08409 411.71255,262.07409 413.97116,262.34723 C 416.62302,262.66792 417.25657,263.05712 417.25657,264.36551 C 417.25657,264.89273 417.89386,266.01656 418.69673,266.90526 C 419.8395,268.17019 419.98915,268.49933 419.42147,268.49933 C 419.02798,268.49933 417.95507,267.69291 417.03722,266.70729 z"
- id="path2448" />
- <path
- d="M 403.41802,323.13387 C 403.94727,322.67936 404.11493,321.9201 404.11493,319.97796 C 404.11493,317.68231 403.99578,317.30139 402.95086,316.25648 C 401.7828,315.08841 400.42934,314.79087 399.36048,315.46718 C 398.64092,315.92249 399.19183,318.62169 400.70077,322.03364 C 401.73303,324.36773 401.90172,324.43605 403.41802,323.13387 z"
- id="path2420" />
- <path
- d="M 372.66085,313.96351 C 375.46576,312.48652 376.27731,308.31767 374.4955,304.53928 C 373.17445,301.73792 371.99608,300.81569 368.61633,299.93794 C 364.59587,298.8938 364.0313,298.93634 363.30643,300.33808 C 362.40727,302.07687 362.54247,303.65618 363.68217,304.72687 C 364.87455,305.84706 364.66329,306.32841 362.97403,306.34018 L 361.70327,306.34903 L 362.69885,307.14259 C 363.24642,307.57905 365.18959,308.65658 367.017,309.53712 C 369.81421,310.88494 370.26302,311.23032 369.85543,311.72144 C 369.11715,312.611 367.93532,312.42598 365.86348,311.09649 C 363.89944,309.83617 359.47756,308.8915 360.07618,309.86012 C 360.67627,310.83111 368.71641,314.62056 370.27146,314.66534 C 370.82246,314.6812 371.89768,314.36538 372.66085,313.96351 z"
- id="path2416" />
- <path
- d="M 452.63816,310.6646 C 453.567,309.98152 454.2633,309.2199 454.18553,308.97212 C 454.10775,308.72433 452.97606,308.16319 451.6707,307.72513 C 450.36533,307.28708 448.85803,306.61506 448.32113,306.23177 C 447.40532,305.57797 445.13277,305.2503 445.13277,305.77206 C 445.13277,305.90252 445.51073,306.54005 445.97268,307.1888 C 447.00944,308.64478 446.7077,309.01821 444.99494,308.39886 C 443.0188,307.68428 442.34427,307.79181 442.35124,308.82027 C 442.36498,310.83752 444.30967,311.86887 448.14061,311.89062 C 450.67145,311.90499 451.11644,311.78369 452.63816,310.6646 z"
- id="path2412" />
- <path
- d="M 355.77755,305.33575 C 359.73936,297.07954 361.46437,288.9081 361.7885,276.86219 C 362.01346,268.50263 361.58532,264.71785 359.86874,259.89079 C 359.41054,258.60224 358.9006,256.56234 358.73561,255.35769 C 358.52152,253.79456 357.16455,250.51247 353.99642,243.89503 C 351.55486,238.79521 349.55721,234.52157 349.55721,234.39804 C 349.55721,234.27451 348.59087,232.61124 347.40979,230.70187 C 343.62006,224.57534 342.24186,221.30863 340.93948,215.36567 C 340.58406,213.74395 339.85785,213.09723 339.48455,214.07003 C 339.09727,215.07924 340.67442,222.97 341.69927,225.15074 C 347.40844,237.299 348.96249,240.6565 350.70408,244.60544 C 356.77377,258.36801 359.23105,275.00008 357.08793,287.81356 C 356.52447,291.1822 354.13739,298.29557 352.0904,302.70585 C 350.18339,306.81455 350.07416,307.42329 350.94266,309.10274 C 352.25217,311.63507 353.05492,311.00961 355.77755,305.33575 z"
- id="path2410" />
- <path
- d="M 348.96194,299.72242 L 350.05409,298.29052 L 349.2685,297.23347 C 347.98026,295.50012 345.38534,295.69211 344.36635,297.59617 C 344.00272,298.27556 344.14959,298.61396 345.31294,299.77732 C 346.0703,300.53467 346.95541,301.15431 347.27985,301.15431 C 347.60433,301.15431 348.36124,300.50996 348.96194,299.72242 z"
- id="path2406" />
- <path
- d="M 375.60824,296.71641 C 376.1582,296.46584 377.10289,295.54693 377.70756,294.67438 C 378.5816,293.41309 378.83834,292.53237 378.96012,290.37726 C 379.1036,287.83789 379.03144,287.55261 377.81815,285.86316 C 376.28416,283.7271 374.36923,282.32747 371.19516,281.02238 C 368.31905,279.83982 366.92512,279.80411 365.84393,280.8853 C 365.10234,281.62686 365.04217,281.97959 365.31715,283.97159 C 365.70327,286.76878 365.71876,287.55242 365.41272,288.80914 C 365.18752,289.73411 365.42375,289.9273 368.74369,291.53324 C 370.70904,292.48393 372.25864,293.30636 372.1872,293.36087 C 372.11575,293.41538 370.48838,293.28057 368.57082,293.06129 C 366.65325,292.84202 364.96686,292.7801 364.82326,292.92371 C 364.33662,293.41035 366.07323,294.88979 368.47321,296.03311 C 371.0463,297.25888 373.83209,297.52567 375.60824,296.71641 z"
- id="path2402" />
- <path
- d="M 343.41664,293.56814 C 345.03856,292.56574 345.55025,291.26191 344.59569,290.56391 C 343.43448,289.7148 340.22757,289.12555 338.79206,289.49753 C 337.11053,289.93325 335.66507,291.7457 336.25421,292.67969 C 337.28714,294.31723 341.3826,294.82525 343.41664,293.56814 z"
- id="path2400" />
- <path
- d="M 352.17375,292.33899 C 352.94871,290.84043 352.46482,289.57134 350.8355,288.82896 C 349.97723,288.4379 349.64662,288.4855 348.78855,289.1236 C 347.42715,290.136 347.28212,291.44231 348.39916,292.63131 C 349.72232,294.03979 351.35985,293.91298 352.17375,292.33899 z"
- id="path2398" />
- <path
- d="M 319.60172,290.78199 C 321.38106,290.4004 324.46863,288.4071 324.46863,287.63997 C 324.46863,287.46688 322.63511,287.83747 321.26619,287.7236 C 319.89727,287.60972 318.50511,286.57155 317.30046,286.15647 C 314.63156,285.23686 313.50436,285.3671 312.63391,286.69563 C 312.00733,287.65188 312.01358,287.792 312.74326,289.14079 C 313.81474,291.12142 315.80184,291.59693 319.60172,290.78199 z"
- id="path2396" />
- <path
- d="M 312.22584,290.16694 C 312.35514,290.03763 312.22054,289.25038 311.92669,288.41751 C 311.63283,287.58464 311.34814,286.0328 311.29406,284.96899 C 311.12142,281.57463 310.11059,280.72955 308.56828,282.69026 C 307.21226,284.41416 307.61113,287.56246 309.43181,289.50604 C 310.21863,290.346 311.69707,290.69571 312.22584,290.16694 z"
- id="path2394" />
- <path
- d="M 307.34468,288.78296 C 307.34468,288.3305 307.15472,287.60535 306.92251,287.1715 C 306.69034,286.73765 306.37243,285.62941 306.21613,284.70873 C 305.95839,283.19094 305.79428,283.00057 304.45702,282.66808 C 301.55391,281.94625 299.88739,283.56431 300.79544,286.22319 C 301.60019,288.57954 302.98962,289.6056 305.37574,289.6056 C 307.10008,289.6056 307.34468,289.50341 307.34468,288.78296 z"
- id="path2392" />
- <path
- d="M 344.42007,287.60999 C 346.37518,287.0669 347.36626,285.94167 346.8081,284.89874 C 345.83697,283.08423 340.51632,281.68185 339.28284,282.91531 C 338.70951,283.48867 338.66252,285.1968 339.18253,286.56449 C 339.53488,287.49127 340.08532,287.72923 342.38905,287.95079 C 342.71759,287.98238 343.63157,287.82902 344.42007,287.60999 z"
- id="path2390" />
- <path
- d="M 353.38772,284.6114 C 354.2172,283.34549 353.66772,281.86375 352.10478,281.15163 C 351.16061,280.72144 350.96237,280.78352 350.10777,281.77705 C 348.92403,283.15325 348.91128,283.89516 350.055,284.8493 C 351.31935,285.90403 352.6007,285.81256 353.38772,284.6114 z"
- id="path2386" />
- <path
- d="M 303.15002,281.65194 C 304.08165,280.87876 303.96927,277.79836 302.99033,277.27443 C 301.14616,276.28748 298.62783,277.14324 298.55312,278.78224 C 298.53635,279.14989 298.4526,279.80911 298.36698,280.24716 C 298.01284,282.05927 298.52958,282.54396 300.60317,282.34471 C 301.66812,282.24238 302.81423,281.93063 303.15002,281.65194 z"
- id="path2384" />
- <path
- d="M 347.84498,279.98182 C 348.84374,279.15292 348.44515,277.51949 347.00475,276.53875 C 345.26065,275.35119 341.597,274.9016 340.86374,275.78514 C 340.11745,276.68437 341.21371,279.02734 342.86286,280.05782 C 344.25098,280.92515 346.75434,280.88697 347.84498,279.98182 z"
- id="path2382" />
- <path
- d="M 378.57124,279.03433 C 379.63054,277.68762 379.35915,275.99462 377.42036,271.85491 C 375.07824,266.85408 371.95176,264.44201 366.58814,263.49786 C 365.23204,263.25915 365.06526,263.33089 364.69164,264.31362 C 364.40922,265.05643 364.41248,265.87566 364.70208,266.95114 C 365.05073,268.24603 365.42451,268.65331 366.90111,269.3474 C 368.15777,269.93809 368.75352,270.49174 368.93022,271.23307 C 369.28771,272.73279 369.84245,273.30837 371.74213,274.15063 C 374.43577,275.3449 374.20101,275.6675 370.63823,275.6675 C 367.80382,275.6675 367.44386,275.7443 367.87029,276.2581 C 368.13985,276.58293 369.37142,277.15758 370.60709,277.53509 C 371.84277,277.91261 373.47778,278.63246 374.24044,279.13477 C 376.08218,280.34773 377.56515,280.31334 378.57124,279.03433 z"
- id="path2380" />
- <path
- d="M 297.05159,277.61235 C 297.63758,275.65645 297.04764,274.38712 294.88855,272.95831 C 293.42314,271.98854 293.3687,271.98229 292.81046,272.71984 C 291.98771,273.80685 292.08237,275.5277 293.06059,277.26821 C 293.92607,278.80818 295.20347,279.68764 296.09101,279.3546 C 296.36281,279.25261 296.79505,278.4686 297.05159,277.61235 z"
- id="path2378" />
- <path
- d="M 354.28215,278.24348 C 354.39401,278.13163 354.56239,276.97733 354.65633,275.67837 C 354.81865,273.4344 354.77795,273.30426 353.84023,273.0689 C 353.2974,272.93266 352.24607,272.8792 351.50393,272.95009 L 350.15456,273.07899 L 350.2053,275.43802 C 350.26423,278.17952 350.99284,279.05041 352.91315,278.67482 C 353.55426,278.54942 354.17033,278.35531 354.28215,278.24348 z"
- id="path2374" />
- <path
- d="M 305.65147,275.23782 C 305.92876,274.69999 306.04182,273.74544 305.90718,273.07899 C 305.67131,271.91174 304.3307,270.09226 303.70651,270.09226 C 303.16627,270.09226 302.48952,273.34349 302.74562,274.70864 C 303.10733,276.63657 304.77385,276.94006 305.65147,275.23782 z"
- id="path2372" />
- <path
- d="M 301.45292,270.88205 C 301.86947,268.07532 301.85171,267.93611 300.98715,267.23604 C 300.49278,266.83571 299.57466,266.50817 298.94689,266.50817 C 295.78139,266.50817 295.73471,272.5593 298.88727,274.23591 C 300.43484,275.05894 300.92881,274.4132 301.45292,270.88205 z"
- id="path2370" />
- <path
- d="M 347.53237,272.06204 C 348.45567,271.3932 349.14329,270.64249 349.06038,270.39379 C 348.46901,268.6196 343.98615,267.48491 342.19774,268.65672 C 340.851,269.53913 340.93367,270.30943 342.54834,271.92412 C 344.23425,273.61003 345.35273,273.64098 347.53237,272.06204 z"
- id="path2368" />
- <path
- d="M 293.89592,268.91136 C 294.57538,268.37692 294.96318,267.58999 295.11877,266.43011 C 295.37794,264.49775 295.05915,264.13405 293.09806,264.12488 C 291.41673,264.11702 290.9281,265.23957 291.48216,267.83725 C 291.91826,269.88202 292.39323,270.09338 293.89592,268.91136 z"
- id="path2366" />
- <path
- d="M 353.53953,268.49933 C 354.50663,267.53226 354.53586,266.85875 353.68309,265.19415 C 352.51611,262.91626 351.49397,262.73918 350.34934,264.61658 C 349.19327,266.51264 349.3307,267.57646 350.85147,268.5037 C 352.45455,269.48112 352.55793,269.48095 353.53953,268.49933 z"
- id="path2364" />
- <path
- d="M 303.83427,264.29195 C 304.56773,261.58113 303.10956,259.10917 300.53006,258.69058 C 299.44297,258.51417 298.957,258.67432 298.06182,259.50398 C 297.09475,260.40021 296.96318,260.7874 297.06843,262.42747 L 297.18977,264.3179 L 298.71874,264.18477 C 300.33126,264.04436 302.5659,264.74731 302.5659,265.39498 C 302.5659,266.23359 303.53758,265.38859 303.83427,264.29195 z"
- id="path2362" />
- <path
- d="M 346.52472,264.88009 C 347.10622,264.42269 347.86975,263.492 348.22143,262.81188 C 348.84661,261.60296 348.83586,261.55377 347.7418,260.61271 C 346.78867,259.79283 346.35699,259.68653 344.83044,259.89577 C 341.63432,260.33385 340.47335,261.67606 340.97544,264.35252 C 341.22768,265.697 341.25337,265.71171 343.34898,265.71171 C 344.89436,265.71171 345.75351,265.48673 346.52472,264.88009 z"
- id="path2360" />
- <path
- d="M 295.83877,260.85297 C 296.09675,260.37093 296.82256,258.18793 297.45173,256.00186 C 298.70672,251.6412 298.64563,251.39265 296.31597,251.38148 C 294.39439,251.37226 293.09914,252.76064 292.89799,255.04512 C 292.78832,256.29083 292.45803,257.16206 291.91667,257.63363 C 291.45078,258.03946 290.99528,259.0706 290.8551,260.03691 L 290.60955,261.7294 L 292.98963,261.7294 C 295.03454,261.7294 295.43576,261.60597 295.83877,260.85297 z"
- id="path2358" />
- <path
- d="M 374.08393,260.33734 C 375.0097,258.92442 374.55134,257.07298 372.53939,254.09884 C 369.95539,250.27899 366.03675,248.04959 361.30504,247.70738 C 359.71474,247.59237 359.7122,247.59454 359.7519,249.02177 C 359.77376,249.80804 360.19035,251.24965 360.67763,252.22535 C 361.1649,253.20105 361.77424,255.06659 362.0317,256.37101 L 362.49974,258.74266 L 365.00159,259.01861 C 366.51801,259.18587 368.16498,259.67996 369.18302,260.27303 C 371.46568,261.60283 373.23948,261.62611 374.08393,260.33734 z"
- id="path2356" />
- <path
- d="M 352.19418,259.52108 C 353.0918,258.15111 352.40075,255.81063 350.66816,254.35273 C 349.47574,253.34938 349.37454,253.32945 348.88329,254.00127 C 347.92442,255.31259 348.24094,257.58086 349.59847,259.12703 C 351.07185,260.80511 351.32743,260.84391 352.19418,259.52108 z"
- id="path2354" />
- <path
- d="M 304.03844,256.75457 C 304.68377,255.4013 304.67656,255.3371 303.76991,254.37202 C 301.96628,252.45214 300.47319,252.70215 299.96656,255.00888 C 299.74976,255.99585 299.89771,256.36338 300.83698,257.17115 C 302.40127,258.51649 303.25098,258.40592 304.03844,256.75457 z"
- id="path2352" />
- <path
- d="M 343.84813,257.06902 C 344.81611,256.43627 345.97313,254.25127 345.97313,253.05599 C 345.97313,251.44707 342.97636,251.03627 340.94566,252.36682 C 339.83097,253.09719 339.77848,253.77016 340.63906,256.29583 C 341.32521,258.30957 341.7819,258.41961 343.84813,257.06902 z"
- id="path2350" />
- <path
- d="M 406.50432,253.56228 C 406.50432,251.47756 406.54338,251.39302 407.29086,251.85982 C 408.41961,252.56475 409.205,251.74823 408.61092,250.48741 C 407.87897,248.93396 407.30078,246.37209 407.30078,244.6823 C 407.30078,242.34402 406.6196,242.26109 405.61088,244.47656 C 404.58858,246.72182 404.40639,251.31642 405.23069,254.06344 C 405.93321,256.40466 406.50432,256.17993 406.50432,253.56228 z"
- id="path2348" />
- <path
- d="M 454.14981,253.52653 C 454.78849,252.68922 456.09174,251.71815 457.28519,251.19035 C 459.06775,250.402 461.06202,248.61852 461.06202,247.81268 C 461.06202,247.66449 460.69664,247.15105 460.25006,246.67169 C 459.53058,245.89944 459.02849,245.80014 455.84333,245.80014 C 452.05754,245.80014 451.19015,246.05851 449.41376,247.71534 C 448.13822,248.90503 448.05659,249.42891 449.01553,250.27097 C 450.12986,251.2495 451.50448,251.54436 451.50448,250.80487 C 451.50448,250.46156 451.77328,250.18068 452.10182,250.18068 C 452.85098,250.18068 452.84747,250.3317 452.06307,251.84858 C 451.57182,252.79853 451.52451,253.29288 451.8554,254.01908 C 452.43821,255.2982 452.86906,255.20571 454.14981,253.52653 z"
- id="path2346" />
- <path
- d="M 341.30669,249.24007 C 342.95203,248.54367 343.91025,247.45299 344.2149,245.92985 C 344.42747,244.86691 344.29351,244.61842 343.1245,243.90738 C 341.29487,242.79453 338.81193,242.42789 337.85403,243.12913 C 337.23091,243.58527 337.14764,243.98259 337.36767,245.4497 C 337.65029,247.33438 338.91631,249.78245 339.60836,249.78245 C 339.83766,249.78245 340.6019,249.53838 341.30669,249.24007 z"
- id="path2344" />
- <path
- d="M 366.42033,173.52113 C 366.6869,171.57605 366.42228,171.35849 364.95734,172.31836 C 364.31081,172.74197 363.32001,172.85896 361.4328,172.7345 C 359.20365,172.5875 358.70188,172.67814 358.10728,173.3352 C 357.43507,174.07794 356.11664,174.58297 357.16725,176.09902 C 358.05463,177.37949 358.85046,177.91749 358.73409,179.38074 C 358.63047,180.68337 358.95517,182.27316 359.36846,182.43175 C 360.03064,182.68585 361.67042,180.12423 363.91175,176.70698"
- id="path2537" />
- <path
- d="M 363.41933,179.94981 C 362.99072,180.4192 362.33965,181.40039 361.97252,182.13021 C 361.03297,183.99807 355.45363,188.19022 352.54395,189.2146 C 349.02382,190.45389 346.19037,190.33915 343.86282,188.86307 C 342.83538,188.2115 341.22143,186.96554 340.27623,186.09427 C 338.34656,184.31559 336.67849,183.53891 335.55432,183.89571 C 334.38925,184.26548 331.57937,182.38591 330.3296,180.40081 C 329.72015,179.4328 327.94527,177.48886 326.3854,176.08095 C 324.82552,174.67305 322.82895,172.75737 321.94854,171.82388 C 320.95065,170.7658 319.73652,169.9522 318.72458,169.66344 C 317.83182,169.40868 316.89634,169.04623 316.64577,168.85799 C 316.39516,168.66975 315.05113,167.96774 313.65903,167.29797 C 312.2669,166.6282 310.76947,165.76053 310.33141,165.36981 C 309.26797,164.42129 289.37305,158.98568 286.96478,158.98568 C 285.89533,158.98568 286.06454,160.27882 287.28141,161.40521 C 288.47045,162.50583 294.00249,169.22422 296.4898,172.58834 C 297.90755,174.50587 298.19539,17
5.22939 298.42258,177.44666 C 298.68027,179.96218 298.73224,180.06113 299.9308,180.31944 C 303.57462,181.10476 305.16758,182.05229 307.2622,184.68034 C 308.4027,186.11131 309.33583,187.51471 309.33583,187.79903 C 309.33583,188.08335 309.77317,188.72681 310.30764,189.22894 C 311.07774,189.9524 311.98053,190.21297 314.65696,190.48425 C 316.51459,190.67254 318.81012,191.12005 319.75819,191.47872 C 321.92923,192.30009 324.46863,192.64931 324.46863,192.12652 C 324.46863,191.64296 323.13145,190.7342 319.49074,188.74361 C 317.95754,187.90532 317.06152,187.30481 317.49958,187.40916 C 317.93763,187.51351 318.92326,187.72121 319.68985,187.87072 C 320.45645,188.02024 321.44207,188.46103 321.88013,188.85026 C 322.31818,189.23949 323.05614,189.67272 323.52,189.81299 C 324.43319,190.08911 326.98306,189.27669 326.16111,188.9715 C 325.88733,188.86984 325.66332,188.54661 325.66332,188.2532 C 325.66332,186.89494 318.11393,183.50527 312.37514,182.28683 C 311.74697,182.15346 311.30971,181.96763
311.40349,181.87388 C 311.78404,181.49334 320.3858,183.61699 321.68101,184.41125 C 323.1608,185.3187 324.66141,185.52534 325.06219,184.87686 C 325.35227,184.40748 323.15809,183.00487 321.59754,182.66212 C 320.98637,182.52788 320.48631,182.2561 320.48631,182.05817 C 320.48631,181.0915 313.41647,178.39494 309.34635,177.80919 C 308.17216,177.64021 307.13688,177.27828 307.04576,177.00491 C 306.80631,176.28654 307.2757,176.35753 312.97487,177.90167 C 317.96288,179.25312 319.68985,179.55058 319.68985,179.05825 C 319.68985,178.21992 318.05973,176.31075 316.78535,175.65657 C 315.0759,174.77904 310.1262,173.38201 307.14556,172.93578 L 305.1544,172.63769 L 306.94644,172.55363 C 307.93207,172.5074 309.09689,172.3227 309.53495,172.14319 C 310.42786,171.77727 310.40242,171.76294 305.55263,169.90053 C 304.23847,169.39587 303.47685,168.97362 303.86015,168.96221 C 304.99037,168.92856 304.75836,167.34854 303.6232,167.34854 C 303.10956,167.34854 302.34799,166.96774 301.93072,166.50232 L 301.
17209,165.6561 L 302.5659,165.93301 C 305.22107,166.46052 307.90511,167.46894 309.71144,168.61769 C 310.70949,169.25241 312.2937,169.96611 313.23185,170.20367 C 314.5034,170.52567 315.41575,171.1684 316.81593,172.72866 C 317.84903,173.87983 319.8591,175.56921 321.28278,176.48283 C 323.72848,178.05233 326.50905,181.05435 329.65771,185.52472 L 330.81955,187.17429 L 329.43963,188.90969 C 327.36807,191.51489 326.65639,193.96678 326.67336,198.44043 C 326.68746,202.15431 326.72425,202.30447 328.08828,204.21479 C 328.85853,205.29351 329.68741,206.64261 329.93026,207.21279 C 330.66866,208.94659 333.56555,210.35753 336.38694,210.35753 C 339.2112,210.35753 339.50713,209.91474 337.11248,209.27195 C 335.16887,208.75022 332.30328,206.45616 331.39061,204.69128 C 329.53545,201.10379 329.28735,196.7682 330.72955,193.1391 C 331.28699,191.73635 333.63679,189.25127 334.4057,189.25127 C 334.5992,189.25127 335.04096,189.1425 335.38742,189.00955 C 335.87306,188.82319 336.01734,189.03377 336.01734
,189.92901 C 336.01734,191.2405 336.53293,191.99696 338.07787,192.95217 C 339.47981,193.81897 339.78238,194.91438 339.02463,196.37975 C 338.68478,197.03691 338.40673,197.85228 338.40673,198.1917 C 338.40673,198.99073 339.55511,198.99471 339.86131,198.19674 C 340.20718,197.29546 342.1437,196.41943 343.79018,196.41943 L 345.23091,196.41943 L 344.35966,197.64297 C 343.13716,199.35985 342.39148,202.10332 342.37495,204.94514 C 342.3671,206.29212 342.10774,207.81353 341.7917,208.36638 C 340.93494,209.86513 341.07871,211.1888 342.22856,212.389 C 343.07874,213.27638 343.2736,213.88142 343.3237,215.78908 L 343.38463,218.10969 L 347.65892,218.97816 C 355.93489,220.65972 361.17315,223.07315 365.98769,227.42277 C 367.35498,228.65805 369.07056,231.55118 369.07056,232.62171 C 369.07056,232.84454 369.44505,234.02779 369.90278,235.25115 C 370.6274,237.18792 370.81549,237.40866 371.3576,236.95873 C 371.70004,236.67453 372.20105,235.91681 372.47098,235.27491 L 372.96168,234.10781 L 374.64835,
237.66414 C 376.79497,242.19023 378.48809,244.26597 381.09141,245.56327 C 383.44779,246.73749 383.73507,246.77561 384.70114,246.04224 C 385.08444,245.75128 385.39721,245.35377 385.39622,245.15889 C 385.39518,244.96401 384.24991,242.78851 382.85112,240.32445 C 381.45237,237.8604 380.38344,235.84435 380.47575,235.84435 C 380.5681,235.84435 381.18472,236.46062 381.84606,237.21384 C 382.97318,238.49757 385.57996,239.77752 386.06974,239.28772 C 386.19081,239.16668 385.62185,238.15767 384.80544,237.0455 C 383.98903,235.93332 382.99285,234.15954 382.59167,233.10375 L 381.86227,231.18414 L 382.85096,229.23326 C 384.10471,226.75941 384.00703,224.87195 382.56997,223.80378 C 381.89887,223.30494 379.41804,222.63764 375.52669,221.90927 C 368.17816,220.53381 362.22858,219.06617 356.77428,217.28347 C 354.2481,216.4578 351.84454,215.93278 350.59074,215.93278 C 348.1548,215.93278 346.91913,215.19324 346.10686,213.24918 C 345.78863,212.48754 345.59362,211.799 345.67354,211.7191 C 345.75343,21
1.63919 346.47797,211.75582 347.28359,211.97827 C 350.76027,212.93822 354.65422,209.98133 356.10442,205.28008 C 356.31305,204.60385 356.22134,204.38406 355.73056,204.38406 C 354.67445,204.38406 349.48513,206.95618 347.80997,208.30995 C 346.95851,208.99807 346.1157,209.56107 345.93709,209.56107 C 344.61265,209.56107 344.66542,199.92665 345.99894,198.27985 C 346.64726,197.47917 347.0785,197.4111 351.81184,197.36231 C 356.04886,197.31862 357.50424,197.13494 360.30946,196.28987 C 364.46939,195.03669 382.06278,186.36279 383.08779,185.05968 C 383.49562,184.54126 384.43998,183.89625 385.18639,183.62634 C 386.86724,183.01854 388.95179,179.62126 388.19985,178.71522 C 387.62564,178.02331 387.27487,174.11847 387.78696,174.11847 C 388.49207,174.11847 389.33098,175.89692 389.6025,177.96744 C 389.8394,179.77399 389.71221,180.3716 388.55742,182.87695 C 387.52753,184.40414 391.1524,186.72713 391.78377,181.59182 C 392.49055,180.43835 393.26933,179.36673 393.51444,179.21045 C 393.78297,179.03
921 393.96002,177.64564 393.96002,175.70338 L 393.96002,172.48046 L 391.96887,170.72626 C 389.877,168.88334 388.21781,168.47 386.53245,169.37196 C 385.12171,170.12697 385.32597,169.50601 387.15895,167.46728 C 389.308,165.07704 392.18419,163.69254 396.94676,162.75578 C 400.13448,162.12878 402.28294,161.00327 401.59858,160.31888 C 401.44355,160.16387 399.79244,159.95703 397.92944,159.85925 C 394.17113,159.66199 391.04194,160.33031 387.61564,162.06206 C 386.03247,162.86223 385.23569,163.02013 383.50517,162.87662 C 381.41928,162.70364 381.30132,162.75009 379.33358,164.51926 C 378.21981,165.52062 376.99636,166.85332 376.61473,167.48081 C 376.04789,168.41293 375.60386,168.64329 374.18823,168.73966 C 373.23526,168.80454 371.2907,169.29861 369.86702,169.8376 C 367.31838,170.80249 367.27748,170.84145 367.21125,172.36846 C 367.1743,173.22146 367.1295,174.23296 367.1117,174.61626 C 367.09393,174.99956 366.87586,175.31317 366.62705,175.31317"
- id="path2340" />
- <path
- d="M 315.30931,186.86188 C 314.98076,186.64956 314.89116,186.47585 315.11019,186.47585 C 315.32922,186.47585 315.77723,186.64956 316.10577,186.86188 C 316.43431,187.0742 316.52391,187.24791 316.30488,187.24791 C 316.08586,187.24791 315.63785,187.0742 315.30931,186.86188 z"
- id="path2338" />
- <path
- d="M 365.45756,245.14908 C 367.19373,242.94191 365.82883,237.96577 362.80319,235.47178 C 361.45267,234.35857 361.22233,234.30747 357.8744,234.37834 C 353.47868,234.47138 352.85784,234.90562 353.5334,237.41447 C 353.85353,238.60337 354.33221,239.28924 355.17001,239.75944 C 356.00984,240.23078 356.29832,240.64519 356.16212,241.18471 C 356.05651,241.6031 356.42264,242.71759 356.97575,243.66136 C 358.00032,245.40966 358.20835,245.50967 361.70327,245.93399 C 364.30974,246.25043 364.64668,246.17999 365.45756,245.14908 z"
- id="path2336" />
- <path
- d="M 310.20051,243.14991 C 310.93445,242.48572 311.13337,241.22151 310.68703,240.05835 C 310.52551,239.63743 309.94509,239.42843 308.9376,239.42843 C 307.35073,239.42843 306.94644,239.87314 306.94644,241.61871 C 306.94644,243.17748 307.38028,243.80898 308.45108,243.80898 C 309.01271,243.80898 309.79997,243.5124 310.20051,243.14991 z"
- id="path2334" />
- <path
- d="M 346.69688,241.31622 C 346.97568,238.89179 342.79413,236.57972 342.45559,238.97115 C 342.12263,241.32342 343.3276,242.6859 345.5749,242.49828 C 346.34034,242.43438 346.59971,242.16113 346.69688,241.31622 z"
- id="path2332" />
- <path
- d="M 339.68111,239.47325 C 340.81536,238.45982 340.90221,238.24407 340.4133,237.65495 C 339.66196,236.74963 338.08058,235.96867 336.33605,235.6414 L 334.89027,235.37016 L 335.27695,237.10062 C 336.08906,240.73459 337.4493,241.46738 339.68111,239.47325 z"
- id="path2328" />
- <path
- d="M 311.84955,235.94391 C 312.19466,234.6845 312.59512,232.9901 312.73944,232.17858 C 312.9816,230.81698 312.91916,230.68233 311.93063,230.43422 C 309.6936,229.87276 307.83135,232.49865 308.56979,235.17314 C 308.93011,236.47802 310.26212,238.23374 310.8918,238.23374 C 311.07344,238.23374 311.5044,237.20332 311.84955,235.94391 z"
- id="path2324" />
- <path
- d="M 307.4919,236.93949 C 307.94907,235.23357 307.73829,229.69903 307.18857,228.97486 C 306.02159,227.43754 304.89253,228.64103 304.53456,231.80389 C 304.32632,233.64346 304.41385,234.225 305.0159,235.00203 C 305.42062,235.52438 305.75175,236.16056 305.75175,236.41576 C 305.75175,236.92106 306.54264,237.83551 306.97966,237.83551 C 307.12931,237.83551 307.35985,237.4323 307.4919,236.93949 z"
- id="path2322" />
- <path
- d="M 318.22962,237.11247 C 319.2234,236.01432 319.48508,234.11128 318.7286,233.48345 C 318.2248,233.06532 317.9767,233.059 317.50284,233.45225 C 316.99594,233.87296 315.8595,234.11425 313.85855,234.226 C 313.06404,234.27038 312.90454,235.45595 313.53033,236.66604 C 314.05774,237.686 314.35498,237.83551 315.85516,237.83551 C 317.01127,237.83551 317.78981,237.59844 318.22962,237.11247 z"
- id="path2320" />
- <path
- d="M 343.17149,234.2776 C 343.76768,233.16365 343.69955,232.85724 342.55276,231.49436 C 341.29849,230.00374 340.28224,229.92949 339.66534,231.28342 C 338.99345,232.75812 339.09137,233.43311 340.09922,234.2739 C 341.26488,235.24631 342.65216,235.24799 343.17149,234.2776 z"
- id="path2316" />
- <path
- d="M 302.48625,234.17178 C 303.73769,232.92033 302.59242,229.47265 300.92526,229.47265 C 299.26794,229.47265 298.89759,232.21223 300.35754,233.67218 C 301.45993,234.77456 301.80297,234.85508 302.48625,234.17178 z"
- id="path2314" />
- <path
- d="M 296.74515,233.25998 C 298.2415,232.12702 296.63691,228.27795 294.66821,228.27795 C 292.89791,228.27795 292.04406,229.13131 292.33895,230.60588 C 292.92021,233.51204 294.86498,234.6835 296.74515,233.25998 z"
- id="path2312" />
- <path
- d="M 358.94548,232.63375 C 359.33718,232.30865 359.06714,231.50143 357.71423,228.95338 C 356.23189,226.16161 355.67497,225.50246 353.86433,224.39684 C 352.36869,223.48356 351.25842,223.10375 350.08093,223.10259 C 348.1908,223.10072 346.37136,223.6797 346.37136,224.28304 C 346.37136,224.50597 347.17778,225.98421 348.1634,227.568 C 349.14903,229.1518 349.95545,230.575 349.95545,230.73068 C 349.95545,230.88635 350.11537,231.4286 350.31083,231.93567 C 350.64486,232.8022 350.89997,232.8634 354.55498,232.9539 C 356.82378,233.01007 358.65274,232.87671 358.94548,232.63375 z"
- id="path2310" />
- <path
- d="M 337.39737,231.4782 C 338.39244,230.43956 338.46113,230.21708 337.96967,229.62447 C 337.25114,228.75812 335.14577,227.87972 333.78776,227.87972 C 332.79227,227.87972 332.74157,227.96771 332.96032,229.31565 C 333.50203,232.65389 335.38961,233.57387 337.39737,231.4782 z"
- id="path2308" />
- <path
- d="M 315.27832,227.19391 C 316.00888,224.75881 316.02628,224.43277 315.47111,223.58546 C 315.13544,223.07315 314.55852,222.70976 314.18904,222.77791 C 313.27948,222.94569 311.9861,225.68531 312.27434,226.83367 C 312.48513,227.67351 313.9679,229.87088 314.32384,229.87088 C 314.40711,229.87088 314.8366,228.66624 315.27832,227.19391 z"
- id="path2306" />
- <path
- d="M 304.59377,227.63636 C 305.11466,227.00872 305.22772,221.47451 304.7359,220.67873 C 304.61914,220.48983 303.81483,220.12291 302.94852,219.86336 C 301.57892,219.45301 301.27129,219.48385 300.59083,220.09965 C 299.58549,221.00945 298.84741,223.24484 299.19292,224.33341 C 299.34074,224.79911 300.09137,225.87715 300.86103,226.72905 C 302.36304,228.39162 303.69771,228.71604 304.59377,227.63636 z"
- id="path2304" />
- <path
- d="M 310.70894,224.50185 C 310.67672,221.14285 308.67373,219.40733 307.78189,221.96567 C 307.08503,223.9646 307.24882,226.05749 308.19629,227.26202 L 309.04787,228.34466 L 309.88878,227.50301 C 310.54462,226.84656 310.7251,226.18617 310.70894,224.50185 z"
- id="path2302" />
- <path
- d="M 291.68335,226.52772 L 292.79218,225.57396 L 291.99261,223.64055 C 290.99022,221.21674 289.96761,220.94643 288.48156,222.7125 C 287.22606,224.20456 287.20344,224.51141 288.22522,226.18724 C 289.16963,227.73623 290.16453,227.83418 291.68335,226.52772 z"
- id="path2300" />
- <path
- d="M 298.49314,226.74936 C 298.90038,226.49089 298.8895,226.15939 298.43775,225.06297 C 298.12852,224.31239 297.74746,222.74472 297.59091,221.57924 C 297.43441,220.41376 297.08703,219.37602 296.81898,219.27316 C 295.89632,218.91911 294.22928,219.87097 293.97123,220.8992 C 293.13446,224.23307 296.20295,228.20285 298.49314,226.74936 z"
- id="path2298" />
- <path
- d="M 335.23084,223.79785 C 337.06748,222.55344 337.12064,221.99382 335.46786,221.30323 C 333.5491,220.50153 331.23857,220.51543 331.23857,221.32868 C 331.23857,222.19803 332.31797,224.18402 332.92269,224.42734 C 333.74973,224.7601 333.85168,224.7323 335.23084,223.79785 z"
- id="path2294" />
- <path
- d="M 383.90281,220.37318 C 384.44154,218.28344 384.28085,216.81662 382.83636,212.37084 C 381.76373,215.38825 380.78724,217.2674 380.25365,218.79798 C 379.89779,219.81885 379.97425,220.10272 380.83754,220.96604 C 382.20734,222.33584 383.4593,222.0937 383.90281,220.37318 z"
- id="path2290" />
- <path
- d="M 376.08361,220.40678 C 376.84965,219.89997 377.83547,217.60906 378.09158,215.74052 C 378.33059,213.99683 379.10399,212.85299 379.09404,210.89345 C 376.81394,213.36102 375.9602,214.35244 375.01946,215.83322 C 373.67813,217.94454 373.25286,219.22225 373.59478,220.11331 C 373.8342,220.73723 375.31945,220.91236 376.08361,220.40678 z"
- id="path2286" />
- <path
- d="M 287.97322,218.30723 C 287.91695,216.52941 285.96586,211.5248 285.12694,211.00632 C 284.89923,210.86559 284.16016,211.21558 283.48452,211.78408 C 282.49455,212.61708 282.25609,213.12255 282.25609,214.38804 C 282.25609,216.25704 283.05626,218.32586 284.23502,219.50464 C 284.86435,220.13395 285.47611,220.32653 286.55978,220.23645 L 288.03045,220.11421 L 287.97322,218.30723 z"
- id="path2284" />
- <path
- d="M 337.26747,219.14277 C 338.15692,218.41212 338.17472,218.31008 337.59784,217.25117 C 336.71126,215.62376 334.95004,215.53967 333.49789,217.0554 L 332.38714,218.21476 L 333.70445,219.05822 C 335.34361,220.10774 336.07182,220.12502 337.26747,219.14277 z"
- id="path2280" />
- <path
- d="M 293.43278,218.70639 C 294.96573,217.88597 294.11172,213.36546 292.23394,212.3605 C 290.08787,211.21195 288.37599,212.75333 288.8559,215.40206 C 289.33394,218.04022 290.08719,219.11863 291.45181,219.11863 C 292.1177,219.11863 293.0091,218.93312 293.43278,218.70639 z"
- id="path2278" />
- <path
- d="M 307.24333,218.50609 C 308.04962,218.1692 309.00259,217.62816 309.36104,217.30378 C 309.96261,216.75938 309.94839,216.58201 309.1765,214.99834 C 308.03115,212.64846 305.82347,210.75639 304.71161,211.17172 C 303.38323,211.66792 302.1325,213.51929 302.32855,214.69921 C 302.42309,215.26816 302.51516,216.0231 302.53316,216.37686 C 302.58477,217.39057 304.13764,219.11863 304.99698,219.11863 C 305.4262,219.11863 306.43703,218.84299 307.24333,218.50609 z"
- id="path2276" />
- <path
- d="M 300.3497,218.33202 C 301.24074,217.99325 301.3712,217.71099 301.3712,216.12197 C 301.3712,213.03026 299.79584,211.154 297.19993,211.154 C 296.17042,211.154 294.60127,212.82155 294.60127,213.91561 C 294.60127,214.87238 296.58757,217.79441 297.55814,218.26545 C 298.63786,218.78946 299.11654,218.80087 300.3497,218.33202 z"
- id="path2274" />
- <path
- d="M 358.18147,214.88536 C 359.22045,213.5645 358.51397,207.89664 357.50067,206.97963 C 356.02966,208.94548 355.42535,209.62416 354.36518,211.11303 C 353.15516,212.81235 352.63729,214.49849 353.82796,215.11615 C 355.35837,215.91004 357.27617,216.03625 358.18147,214.88536 z"
- id="path2270" />
- <path
- d="M 416.65966,208.43653 C 417.81186,207.05143 419.74285,204.09456 420.95068,201.86571 C 423.3971,197.35135 426.16293,190.60498 425.80484,190.02558 C 425.67701,189.81874 424.97768,189.6495 424.25075,189.6495 C 423.12343,189.6495 422.59681,190.02796 420.66945,192.22326 C 418.21356,195.02054 415.17298,196.81653 411.38265,197.70872 C 409.90987,198.05539 409.29194,198.39398 409.29194,198.8543 C 409.29194,199.89283 410.21699,200.39582 412.7276,200.72242 L 415.06629,201.02665 L 411.90262,202.6058 L 408.73891,204.18495 L 400.75214,204.31808 C 396.31238,204.39209 391.08515,204.24964 388.98213,203.99733 C 382.29268,203.19476 376.58706,202.8235 370.19918,202.77516 C 364.11038,202.72907 357.92007,203.39176 357.92007,204.08967 C 357.92007,204.74116 358.81108,206.175 359.99175,207.42351 C 361.13894,208.63663 361.20485,208.65423 362.38851,208.06372 C 363.2477,207.63512 364.84859,207.45545 367.8315,207.45287 C 371.92882,207.44934 373.5691,207.5073 387.98655,208.16506 C 395.24675
,208.49629 409.01823,207.85451 410.9972,207.09273 C 411.60654,206.85816 412.21336,206.77449 412.34566,206.9068 C 412.56476,207.12592 412.05001,210.32822 411.41144,212.71838 C 411.16458,213.64238 411.22897,213.62465 412.8589,212.32015 C 413.79709,211.56925 415.50745,209.82162 416.65966,208.43653 z"
- style="fill:#800000"
- id="path2268" />
- <path
- d="M 303.66649,209.69949 L 304.56793,208.70757 L 302.93012,206.37272 C 302.02932,205.08856 300.95899,203.73623 300.5516,203.36755 C 299.85056,202.73309 299.74359,202.76458 298.5518,203.95635 C 297.4135,205.09467 297.31808,205.37427 297.55738,206.87072 C 297.859,208.75699 298.2908,209.39024 299.97608,210.41773 C 301.37917,211.27321 302.42046,211.07056 303.66649,209.69949 z"
- id="path2262" />
- <path
- d="M 295.36097,209.00287 C 295.85514,208.47683 296.35683,207.32065 296.47582,206.43358 C 296.66339,205.03501 296.53906,204.66766 295.53986,203.66845 C 293.96935,202.09794 291.64145,201.67165 290.25636,202.70093 C 288.92269,203.69203 288.7759,205.12016 289.80114,207.12985 C 291.18548,209.84338 293.75738,210.70981 295.36097,209.00287 z"
- id="path2256" />
- <path
- d="M 337.38857,204.69368 C 338.29347,203.40178 338.1615,202.87271 336.71425,201.99031 C 335.34704,201.15671 332.65101,200.92195 332.23195,201.60001 C 331.79979,202.29928 332.41036,203.35267 333.90337,204.48362 C 335.65443,205.81001 336.5681,205.86508 337.38857,204.69368 z"
- id="path2250" />
- <path
- d="M 298.21271,201.14714 C 298.5426,200.5307 298.28559,200.04903 296.75176,198.40927 C 294.79079,196.31279 294.20045,196.06022 293.43031,196.98817 C 293.06147,197.43263 293.10424,197.84598 293.62612,198.87977 C 295.20483,202.00691 297.21952,203.00288 298.21271,201.14714 z"
- id="path2246" />
- <path
- d="M 324.0704,200.0261 C 324.0704,198.32886 323.04686,197.21384 321.49284,197.21812 C 318.77822,197.22558 315.70754,199.11714 315.70754,200.78188 C 315.70754,201.55076 315.94206,201.59644 319.88897,201.59644 L 324.0704,201.59644 L 324.0704,200.0261 z"
- id="path2240" />
- <path
- d="M 334.80971,197.82886 C 335.07525,197.50891 335.38304,196.56809 335.49371,195.73815 C 335.64747,194.58528 335.4912,193.97071 334.83169,193.13403 C 333.62628,191.60489 332.95578,191.76176 331.96299,193.80523 L 331.10484,195.57157 L 332.18755,196.99108 C 333.35548,198.52235 334.05,198.74424 334.80971,197.82886 z"
- id="path2232" />
- <path
- d="M 382.80568,194.84951 C 383.21757,192.41153 382.70322,190.12689 381.57622,189.38844 C 380.67204,188.796 380.53759,188.82081 379.22442,189.82241 C 378.45839,190.40668 377.83165,191.11579 377.83165,191.39818 C 377.83165,191.68059 378.36604,192.88109 379.01914,194.06598 C 379.67224,195.25086 380.20985,196.59366 380.21383,197.04996 C 380.21781,197.50627 380.30221,199.50032 380.46409,199.66223 C 382.36548,196.73965 382.52262,196.52478 382.80568,194.84951 z"
- id="path2230" />
- <path
- d="M 286.94626,192.61366 C 287.43306,192.2727 287.83133,191.6522 287.83133,191.23479 C 287.83133,189.99136 286.2797,186.22622 285.46249,185.48666 C 284.79784,184.88518 284.56321,184.86637 283.57926,185.33571 C 282.72831,185.74157 282.42391,186.19903 282.3263,187.21843 C 282.13961,189.16915 282.50773,190.25129 283.89605,191.83247 C 285.27381,193.40165 285.67467,193.50432 286.94626,192.61366 z"
- id="path2226" />
- <path
- d="M 280.50622,192.24605 C 281.69745,191.74832 281.87518,191.51625 281.64974,190.75268 C 281.22989,189.33051 279.57966,185.94598 278.88156,185.0752 C 278.29472,184.34322 278.16689,184.32924 277.17119,184.88812 C 274.83672,186.1984 274.54044,189.61436 276.57683,191.7399 C 277.77125,192.9866 278.50702,193.08137 280.50622,192.24605 z"
- id="path2224" />
- <path
- d="M 354.52682,185.70649 C 356.94588,184.34123 357.69049,183.53933 356.26096,183.83881 C 355.74979,183.9459 354.16169,184.14229 352.73188,184.27524 C 350.38406,184.49354 350.60261,180.7234 349.2481,179.80422 C 347.34647,178.51372 346.371,182.22096 346.37287,183.57647 C 346.37487,185.06647 347.73853,187.19443 348.84796,187.4389 C 350.77317,187.86313 352.15006,187.84097 352.26985,187.38383 C 352.3381,187.12334 353.35371,186.36853 354.52682,185.70649 z"
- id="path2220" />
- <path
- d="M 356.83171,182.91485 C 357.72207,182.57633 357.76855,182.41312 357.52192,180.49077 C 357.23599,178.26202 356.74426,177.7181 355.00673,177.70865 C 353.28231,177.69928 352.41727,178.36396 351.89794,180.09735 C 351.48234,181.48445 351.51321,181.78242 352.14472,182.48024 C 352.92924,183.34711 355.15253,183.55326 356.83171,182.91485 z"
- id="path2210" />
- <path
- d="M 337.39307,180.70739 C 336.85546,180.16978 336.41557,179.27376 336.41557,178.71623 C 336.41557,177.83023 336.58498,177.70256 337.76064,177.70256 C 338.5004,177.70256 339.33859,177.98318 339.62321,178.32616 C 340.30438,179.14693 342.15955,180.09195 343.08962,180.09195 C 343.49669,180.09195 344.17762,179.83113 344.60278,179.51235 C 345.32146,178.97348 345.26651,178.9362 343.82077,178.98184 C 342.64547,179.01895 342.08627,178.80934 341.53094,178.12352 C 340.38049,176.70279 340.63058,176.45402 343.07759,176.58493 C 345.13203,176.69483 345.35989,176.62772 345.36742,175.91051 C 345.37817,174.88522 346.8858,174.63854 348.13577,175.45754 C 349.29167,176.21493 353.26144,176.12232 354.90498,175.29964 C 357.20824,174.14674 360.03142,169.03209 360.06316,165.95473 C 360.08219,164.11258 358.23324,159.78214 357.4277,159.78214 C 356.54207,159.78214 353.66561,163.0604 353.16204,164.64365 C 352.85513,165.60862 352.2174,166.41376 351.32146,166.96749 C 350.56741,167.43351 350.041
3,167.96171 350.15225,168.14129 C 350.40461,168.54958 344.22075,170.81101 341.00507,171.48639 C 338.1439,172.08732 337.53512,172.37768 333.53608,175.04885 C 331.84284,176.17985 330.45401,177.38298 330.44979,177.72247 C 330.43804,178.66658 331.27516,179.29548 332.54353,179.29548 C 333.28555,179.29548 334.11017,179.71643 334.88394,180.49018 C 335.65782,181.26406 336.48228,181.68487 337.22458,181.68487 L 338.37053,181.68487 L 337.39307,180.70739 z"
- id="path2206" />
- <path
- d="M 331.60788,171.47626 C 332.06187,170.89916 332.43326,169.99013 332.43326,169.4562 L 332.43326,168.48542 L 333.48515,169.31283 C 334.27289,169.93249 334.66909,170.03063 335.06298,169.70372 C 335.48407,169.35423 335.19507,168.70636 333.61342,166.45414 C 332.52688,164.90696 331.27922,163.38987 330.84089,163.08284 C 330.40252,162.7758 330.04387,162.3223 330.04387,162.07506 C 330.04387,161.82781 329.70521,161.25556 329.29133,160.80338 C 328.87741,160.35121 327.88247,158.90603 327.08031,157.59187 L 325.62183,155.20248 L 328.82843,158.54402 C 330.59208,160.38187 332.03503,162.1189 332.03503,162.40409 C 332.03503,162.68929 333.12618,164.18726 334.45982,165.73293 C 336.42939,168.01566 337.10221,168.54323 338.0439,168.54323 C 338.68151,168.54323 339.20319,168.38584 339.20319,168.19348 C 339.20319,168.00112 338.03837,166.58561 336.61469,165.0479 C 335.19101,163.5102 334.02619,161.98691 334.02619,161.66282 C 334.02619,160.49074 322.77674,149.02989 321.62625,149.02989 C 32
1.20544,149.02989 321.11544,150.31462 321.26358,154.2069 C 321.38333,157.3527 321.7861,158.27851 324.1279,160.79079 C 325.09437,161.82764 328.45094,169.66467 328.45094,170.88438 C 328.45094,171.29304 329.99114,172.52555 330.5018,172.52555 C 330.65619,172.52555 331.15394,172.05337 331.60788,171.47626 z"
- id="path2202" />
- <path
- d="M 349.67335,249.42454 C 349.95215,247.00011 345.7706,244.68804 345.43207,247.07947 C 345.0991,249.43174 346.30407,250.79422 348.55137,250.6066 C 349.31681,250.5427 349.57618,250.26945 349.67335,249.42454 z"
- id="path3170" />
- <path
- d="M 339.82982,225.75444 C 340.32404,224.8811 340.3065,224.79252 339.50507,224.11223 C 338.27338,223.0667 336.81448,223.55085 336.10889,225.2393 L 335.56918,226.53076 L 336.90526,226.80352 C 338.56776,227.14289 339.16549,226.92848 339.82982,225.75444 z"
- id="path3172" />
- <path
- d="M 393.07947,191.30261 C 393.49136,188.86463 392.977,186.57998 391.85001,185.84154 C 390.94582,185.2491 390.81138,185.27391 389.49821,186.2755 C 388.73217,186.85978 388.10544,187.56889 388.10544,187.85128 C 388.10544,188.13368 388.63982,189.33419 389.29292,190.51908 C 389.94602,191.70396 390.48364,193.04676 390.48762,193.50306 C 390.4916,193.95937 390.576,195.95342 390.73788,196.11533 C 392.63927,193.19275 392.7964,192.97788 393.07947,191.30261 z"
- id="path5114" />
- </g>
- </g>
- </g>
- <path
- style="font-size:104.55381012px;font-style:normal;font-weight:normal;fill:#ff0000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- d="M 379.86966,923.3115 C 388.89499,923.3115 397.92022,923.3115 406.94555,923.3115 C 406.94555,914.25166 406.94555,905.19183 406.94555,896.132 C 411.09906,908.15879 416.63568,920.17226 424.76929,925.08397 C 433.67104,930.86677 444.47664,928.56269 451.83424,918.2194 C 458.85348,908.6026 463.32006,894.85709 466.28465,880.81209 C 470.68446,859.01578 471.41559,835.64232 470.40204,812.8632 C 469.51119,794.21105 466.79116,775.50994 461.009,759.27836 C 456.78292,747.33401 450.50903,736.33422 442.22315,732.5589 C 433.55194,728.64159 423.69553,731.92442 416.94919,741.93112 C 412.7739,747.70841 409.63428,755.2492 406.94555,763.01789 C 406.94555,729.46878 406.94555,695.91967 406.94555,662.37055 C 397.92022,662.37055 388.89499,662.37055 379.86966,662.37055 C 379.86966,749.35077 379.86966,836.33113 379.86966,923.3115 z M 764.20114,763.01789 C 760.13116,751.12194 754.62979,739.61791 746.7984,734.24863 C 737.80438,728.25646 726.75018,730.42217 719.38251,741.19318 C 712.63562,750.38762
708.32305,763.5411 705.35705,776.94089 C 700.99293,797.52025 700.03706,819.62953 700.67744,841.27892 C 701.22073,856.01839 702.71167,870.80495 705.87417,884.65681 C 709.26163,899.20821 714.49152,913.41172 722.60937,921.91517 C 731.00199,930.42398 742.23483,930.15201 750.63522,921.82722 C 756.57402,915.68711 760.81555,906.0906 764.20114,896.132 C 764.20114,905.19183 764.20114,914.25166 764.20114,923.3115 C 773.28252,923.3115 782.3639,923.3115 791.44529,923.3115 C 791.44529,836.33113 791.44529,749.35077 791.44529,662.37055 C 782.3639,662.37055 773.28252,662.37055 764.20114,662.37055 C 764.20114,695.91967 764.20114,729.46878 764.20114,763.01789 z M 73.570401,807.26557 C 64.993554,762.67768 56.416706,718.0898 47.839972,673.50206 C 35.488592,673.62575 23.137214,673.7494 10.785834,673.87308 C 10.823162,757.35926 10.8606,840.84555 10.897928,924.33183 C 20.110123,924.42456 29.322208,924.51729 38.534402,924.61017 C 38.496965,863.78883 38.459636,802.96748 38.422198,742.14629 C 47.092
53,786.54856 55.76275,830.95099 64.432973,875.35327 C 70.599358,875.2914 76.765743,875.22953 82.932018,875.16766 C 91.602242,830.17784 100.27258,785.18802 108.9428,740.19821 C 108.9428,801.23602 108.9428,862.27369 108.9428,923.3115 C 118.13627,923.3115 127.32975,923.3115 136.52323,923.3115 C 136.52323,839.85608 136.52323,756.4008 136.52323,672.94548 C 124.17185,672.94548 111.82047,672.94548 99.469086,672.94548 C 90.836192,717.71887 82.203297,762.49222 73.570401,807.26557 z M 321.73787,731.10751 C 314.00118,731.74243 306.76498,738.52557 301.93956,748.41056 C 299.57365,752.87687 297.61966,757.87595 295.83919,763.01789 C 295.83919,753.83432 295.83919,744.6509 295.83919,735.46732 C 286.79524,735.46732 277.75129,735.46732 268.70724,735.46732 C 268.70724,821.89116 268.70724,908.31484 268.70724,994.73854 C 277.75129,994.73854 286.79524,994.73854 295.83919,994.73854 C 295.83919,961.86969 295.83919,929.00084 295.83919,896.132 C 300.0032,908.12503 305.50326,920.03591 313.5747,925.1017
9 C 321.86945,930.34356 331.75958,928.95781 339.04745,920.30034 C 346.71813,911.26862 351.52909,897.14987 354.72334,882.79016 C 359.37612,861.58545 360.16122,838.6468 359.47038,816.29454 C 358.66832,794.94479 355.54051,773.27062 348.34875,755.24123 C 344.4249,745.52025 339.07054,736.74093 332.1912,733.15557 C 328.86877,731.23342 325.2383,730.57793 321.73787,731.10751 z M 528.92702,731.01478 C 518.89448,731.70418 508.80196,737.66288 501.50992,749.33353 C 492.60763,763.22581 487.72256,782.83946 485.87289,802.58308 C 484.08781,821.30825 484.20582,840.52287 486.09894,859.21254 C 488.19371,877.98422 492.91545,896.69534 501.5709,909.76811 C 507.86755,919.31797 516.00609,925.24683 524.44698,927.10043 C 536.41478,930.09014 548.66326,926.64547 560.00645,920.13879 C 563.97496,917.82703 567.80116,914.92628 571.58697,911.90165 C 571.58697,896.47221 571.58697,881.04261 571.58697,865.61317 C 562.92069,875.98833 553.16148,884.75983 542.4589,887.36137 C 535.60057,889.03908 527.97937,888.860
57 522.10734,881.97587 C 516.16853,875.20055 513.60777,863.20245 512.62148,851.85013 C 512.291,849.35406 511.79862,845.15726 514.1746,845.89345 C 518.53379,846.32378 522.91181,845.88853 527.28152,846.04023 C 543.37667,846.04023 559.47181,846.04023 575.56707,846.04023 C 575.55164,830.15031 575.89274,814.10667 573.93953,798.44858 C 571.79638,779.42638 566.70802,760.82958 558.08728,747.45051 C 550.83553,736.02994 540.68016,730.39855 530.74637,730.95465 C 530.13992,730.97465 529.53348,730.99464 528.92702,731.01478 z M 650.46012,731.01478 C 642.50844,731.14142 635.14974,738.21767 629.94174,747.82766 C 627.29964,752.40872 625.20904,757.7554 623.104,763.01789 C 623.104,753.83432 623.104,744.6509 623.104,735.46732 C 614.07866,735.46732 605.05344,735.46732 596.0281,735.46732 C 596.0281,798.082 596.0281,860.69668 596.0281,923.3115 C 605.05344,923.3115 614.07866,923.3115 623.104,923.3115 C 623.14855,890.89501 623.00109,858.47432 623.2105,826.06087 C 623.4648,811.91488 624.84736,796.978
36 630.11119,785.37363 C 633.42235,778.47429 639.20123,774.35732 644.43265,777.03 C 649.05489,779.47883 652.16091,786.83444 652.83106,794.60096 C 653.93536,804.25862 653.82152,814.16564 653.94391,823.95805 C 654.03312,857.07567 653.97543,890.19358 653.99174,923.3115 C 663.07313,923.3115 672.1545,923.3115 681.23578,923.3115 C 681.19396,882.51095 681.33222,841.70606 681.13639,800.90827 C 680.77536,784.12162 679.1929,766.81683 674.05879,752.06736 C 670.40621,741.64423 664.09314,733.42796 656.76815,731.72953 C 654.69726,731.09664 652.56298,730.84149 650.46012,731.01478 z M 855.5752,731.01478 C 845.48596,731.82792 835.24412,737.66404 828.01196,749.67098 C 820.175,762.02045 815.46223,778.91563 813.30047,796.28244 C 810.92318,814.33284 810.89318,833.04106 812.07314,851.3472 C 813.421,869.93328 817.10336,888.57745 824.42594,903.12596 C 830.51131,915.21665 839.19883,923.58723 848.56494,926.33453 C 860.77806,930.41717 873.48192,927.34385 885.2111,920.99626 C 889.68129,918.42283 894.07
758,915.47963 898.29119,911.90165 C 898.29119,896.47221 898.29119,881.04261 898.29119,865.61317 C 891.13949,874.20543 883.27341,881.55539 874.70762,885.43416 C 867.8667,888.34606 860.4398,889.76876 853.61323,886.02083 C 849.5856,883.78166 846.11014,879.30651 843.80312,873.40519 C 840.60045,865.30759 839.42565,855.54517 838.92615,846.04023 C 860.04113,846.04023 881.15622,846.04023 902.2713,846.04023 C 902.29878,828.38103 902.56062,810.47639 899.95892,793.20521 C 897.41042,775.20204 892.07073,757.73497 883.49191,745.5785 C 876.98585,736.3971 868.5374,731.34093 860.01244,730.99609 C 858.53377,730.8583 857.05465,730.99174 855.5752,731.01478 z M 195.83223,731.10751 C 185.37769,731.87341 175.01216,735.1858 165.05657,740.47654 C 165.05657,755.75139 165.05657,771.02639 165.05657,786.30123 C 175.41762,773.58924 188.92179,768.89965 201.60618,771.64479 C 206.76064,772.7083 212.32825,776.69153 214.51255,785.0456 C 216.03721,790.68379 216.132,797.01472 216.06906,803.09122 C 205.9657,803.
38883 195.75855,802.07132 185.75711,805.0564 C 177.9185,807.59998 169.87804,812.98317 164.8986,823.78751 C 159.72531,834.77702 157.95194,848.97865 157.69261,862.62983 C 157.20461,878.37456 158.96757,894.80986 164.36068,908.07055 C 168.83274,919.02732 176.18006,927.09435 184.26572,927.93791 C 192.32688,929.15081 201.04887,925.79597 206.9463,916.16787 C 210.75619,910.31928 213.61338,903.00512 216.06906,895.48274 C 216.06906,904.75889 216.06906,914.0352 216.06906,923.3115 C 225.16916,923.3115 234.26915,923.3115 243.36914,923.3115 C 243.3259,884.90081 243.46963,846.48693 243.26416,808.07856 C 242.85727,790.93736 241.3902,773.23165 236.18942,758.10387 C 232.56836,747.86316 226.68649,739.96899 219.91573,736.08891 C 212.26618,731.25921 203.92676,730.68805 195.83223,731.10751 z M 975.48261,731.10751 C 967.98981,731.79821 960.94637,738.44544 956.42407,748.2664 C 953.72549,753.75782 951.74261,760.07774 949.80822,766.35723 C 949.80822,756.06059 949.80822,745.76396 949.80822,735.46732 C
940.78299,735.46732 931.75755,735.46732 922.73232,735.46732 C 922.73232,798.082 922.73232,860.69668 922.73232,923.3115 C 931.75755,923.3115 940.78299,923.3115 949.80822,923.3115 C 949.85605,892.41493 949.69798,861.51372 949.92173,830.62034 C 950.25802,816.63794 951.70637,801.86369 957.03019,790.52934 C 960.92317,782.47332 967.36497,778.31505 973.53135,779.60604 C 977.85005,780.31616 982.04778,782.7518 985.68514,786.6723 C 985.66643,768.55264 985.64771,750.43312 985.62899,732.31345 C 982.2758,731.38078 978.88703,730.71268 975.48261,731.10751 z M 532.2905,770.90265 C 537.09874,771.17664 541.43691,776.21614 543.84836,782.95349 C 546.81021,790.66061 547.61304,799.96835 547.76246,808.93531 C 536.02771,808.93531 524.29296,808.93531 512.5582,808.93531 C 513.32075,797.32465 515.34425,784.97634 520.88043,777.04464 C 523.97277,772.43068 528.19556,770.61779 532.2905,770.90265 z M 859.05077,770.90265 C 863.92611,771.23648 868.27906,776.44073 870.65472,783.33282 C 873.57168,790.9133 874
.35076,800.11035 874.41064,808.93531 C 862.67589,808.93531 850.94114,808.93531 839.20638,808.93531 C 840.06724,797.27292 842.04738,784.74639 847.7007,776.86685 C 850.83408,772.43286 854.98014,770.6046 859.05077,770.90265 z M 314.89881,774.6132 C 320.24825,774.81836 324.88187,781.09423 327.14248,788.84033 C 330.63972,799.93909 331.36866,812.69773 331.68886,825.00591 C 331.77151,840.29974 331.43118,856.32701 327.17543,870.25132 C 324.99353,877.42827 320.9323,883.58461 315.93273,884.33486 C 311.03452,885.47096 305.74606,882.51023 302.70003,875.89502 C 298.07176,866.53975 296.77688,854.08248 296.17054,842.36503 C 295.49163,826.71622 295.70542,810.6236 298.63454,795.57348 C 300.48486,786.75677 304.12912,777.91906 309.86519,775.41445 C 311.49909,774.74853 313.21291,774.36847 314.89881,774.6132 z M 425.27645,774.52047 C 430.32288,774.51554 435.14665,779.38929 437.5014,786.76257 C 441.8363,798.50798 442.52418,812.69744 442.76173,826.13969 C 442.93928,839.82304 442.41374,853.91586 43
9.29206,866.73579 C 437.28148,875.08 433.18939,882.97461 427.54352,884.24213 C 422.05922,885.91419 416.05736,882.03165 413.00312,874.20123 C 409.03845,865.11995 408.00782,853.69779 407.27461,842.83869 C 406.57577,826.60552 406.77084,809.84466 410.03,794.32624 C 411.97512,785.63067 415.89667,776.8867 421.73082,775.16364 C 422.89719,774.78431 424.08501,774.48004 425.27645,774.52047 z M 747.43999,774.6132 C 752.85806,774.92196 757.5693,781.27028 759.78075,789.23023 C 763.80092,802.44384 764.20771,817.63117 764.17552,832.14867 C 764.0458,846.44636 763.11621,861.48214 758.4273,873.86899 C 755.88417,880.002 751.68808,884.43194 747.12614,884.58741 C 742.04009,885.11496 736.89624,880.8431 734.28271,873.53646 C 730.62028,864.57095 729.55856,853.5303 728.8849,842.97909 C 728.30166,825.77804 728.28797,807.89136 732.21981,791.65428 C 734.23926,783.67912 738.22703,776.37248 743.6,774.96978 C 744.86533,774.65159 746.16119,774.43933 747.43999,774.6132 z M 204.0728,838.80488 C 208.07184,838
.91341 212.06902,838.77011 216.06906,838.80488 C 216.20699,850.16836 215.82911,862.123 212.31511,872.20316 C 209.69677,880.3593 205.01147,887.60754 199.19571,888.15437 C 194.2281,889.03111 188.63149,885.36881 186.60427,877.37249 C 184.44941,869.81577 184.54322,860.88402 185.96607,852.99753 C 187.42473,846.80729 190.69132,841.97658 194.59897,840.38175 C 197.66448,838.83908 200.89573,838.74852 204.0728,838.80488 z"
- id="text3266" />
- <rect
- style="fill:#ffffff;stroke-width:6"
- id="rect5682"
- width="1016.1943"
- height="2052.6316"
- x="-1024.2915"
- y="-279.35223" />
- <rect
- id="rect5684"
- width="1753.0364"
- height="1388.6639"
- x="-742.91492"
- y="633.60321" />
- <text
- id="text4277"
- y="-157.00433"
- x="-1339.3473"
- style="font-size:33.16645813px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- xml:space="preserve"
- transform="scale(1.1179906,0.8944619)"><tspan
- y="-157.00433"
- x="-1339.3473"
- id="tspan4279"
- sodipodi:role="line">0000111011100110010010</tspan><tspan
- id="tspan4287"
- y="-115.54626"
- x="-1339.3473"
- sodipodi:role="line">0001111011000111000110</tspan><tspan
- id="tspan4298"
- y="-74.088196"
- x="-1339.3473"
- sodipodi:role="line">0111000001111010001100</tspan><tspan
- id="tspan4300"
- y="-32.630123"
- x="-1339.3473"
- sodipodi:role="line">0011111000001100011100</tspan><tspan
- id="tspan4302"
- y="8.8279753"
- x="-1339.3473"
- id="tspan4314"
- y="50.28603"
- x="-1339.3473"
- id="tspan4336"
- y="91.74411"
- x="-1339.3473"
- id="tspan4338"
- y="133.20218"
- x="-1339.3473"
- id="tspan4340"
- y="174.66025"
- x="-1339.3473"
- id="tspan4342"
- y="216.11832"
- x="-1339.3473"
- id="tspan4344"
- y="257.57639"
- x="-1339.3473"
- id="tspan4346"
- y="299.03445"
- x="-1339.3473"
- id="tspan4348"
- y="340.49255"
- x="-1339.3473"
- id="tspan4350"
- y="381.95062"
- x="-1339.3473"
- id="tspan4352"
- y="423.40869"
- x="-1339.3473"
- sodipodi:role="line" /></text>
- <path
- style="font-size:104.55381011999999430px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- d="M 388.06129,909.40409 C 397.08663,909.40409 406.11185,909.40409 415.13719,909.40409 C 415.13719,900.34425 415.13719,891.28442 415.13719,882.22459 C 419.29069,894.25138 424.82731,906.26485 432.96093,911.17656 C 441.86267,916.95936 452.66827,914.65528 460.02587,904.31199 C 467.04512,894.69519 471.5117,880.94968 474.47628,866.90468 C 478.87609,845.10837 479.60722,821.7349 478.59366,798.95579 C 477.70282,780.30364 474.98278,761.60252 469.20063,745.37095 C 464.97455,733.4266 458.70067,722.4268 450.41479,718.65149 C 441.74358,714.73418 431.88717,718.017 425.14082,728.02371 C 420.96554,733.801 417.82592,741.34178 415.13719,749.11048 C 415.13719,715.56137 415.13719,682.01225 415.13719,648.46314 C 406.11185,648.46314 397.08663,648.46314 388.06129,648.46314 C 388.06129,735.44336 388.06129,822.42372 388.06129,909.40409 z M 772.39277,749.11048 C 768.32279,737.21452 762.82141,725.7105 754.99004,720.34122 C 745.99602,714.34905 734.94181,716.51476 727.57414,727.28577 C 720.82725,73
6.48021 716.51469,749.63369 713.54868,763.03348 C 709.18456,783.61284 708.2287,805.72212 708.86908,827.37151 C 709.41236,842.11098 710.9033,856.89754 714.0658,870.7494 C 717.45326,885.3008 722.68315,899.50431 730.80101,908.00776 C 739.19362,916.51657 750.42647,916.2446 758.82685,907.91981 C 764.76566,901.7797 769.00718,892.18319 772.39277,882.22459 C 772.39277,891.28442 772.39277,900.34425 772.39277,909.40409 C 781.47415,909.40409 790.55554,909.40409 799.63691,909.40409 C 799.63691,822.42372 799.63691,735.44336 799.63691,648.46314 C 790.55554,648.46314 781.47415,648.46314 772.39277,648.46314 C 772.39277,682.01225 772.39277,715.56137 772.39277,749.11048 z M 81.762036,793.35816 C 73.185187,748.77027 64.608339,704.18239 56.0316,659.59465 C 43.680226,659.71834 31.328847,659.84199 18.977467,659.96567 C 19.009214,731.07795 19.041177,802.19031 19.072923,873.30268 C 19.078506,885.67659 19.083979,898.05051 19.089562,910.42442 C 28.301756,910.51715 37.513841,910.60988 46.726035,910.70
276 C 46.688598,849.88141 46.65127,789.06007 46.613831,728.23887 C 55.28416,772.64115 63.954384,817.04358 72.624607,861.44586 C 78.790992,861.38399 84.957377,861.32212 91.123652,861.26025 C 99.793876,816.27043 108.46421,771.28061 117.13443,726.2908 C 117.13443,787.32861 117.13443,848.36627 117.13443,909.40409 C 126.32791,909.40409 135.52138,909.40409 144.71486,909.40409 C 144.71486,825.94867 144.71486,742.49339 144.71486,659.03807 C 132.36348,659.03807 120.01211,659.03807 107.66072,659.03807 C 99.027826,703.81146 90.39493,748.58481 81.762036,793.35816 z M 329.92951,717.2001 C 322.19282,717.83502 314.95661,724.61816 310.1312,734.50315 C 307.76528,738.96946 305.8113,743.96854 304.03082,749.11048 C 304.03082,739.92691 304.03082,730.74348 304.03082,721.55991 C 294.98688,721.55991 285.94293,721.55991 276.89888,721.55991 C 276.89888,807.98375 276.89888,894.40743 276.89888,980.83112 C 285.94293,980.83112 294.98688,980.83112 304.03082,980.83112 C 304.03082,947.96228 304.03082,915.09
343 304.03082,882.22459 C 308.19484,894.21762 313.6949,906.1285 321.76634,911.19438 C 330.06109,916.43615 339.95121,915.0504 347.23909,906.39293 C 354.90976,897.36121 359.72072,883.24246 362.91497,868.88275 C 367.56776,847.67804 368.35286,824.73939 367.66201,802.38713 C 366.85994,781.03738 363.73215,759.36321 356.54038,741.33382 C 352.61654,731.61284 347.26218,722.83352 340.38283,719.24815 C 337.06041,717.32601 333.42993,716.67052 329.92951,717.2001 z M 537.11866,717.10737 C 527.08612,717.79677 516.9936,723.75547 509.70156,735.42612 C 500.79926,749.3184 495.91419,768.93205 494.06453,788.67567 C 492.27945,807.40084 492.39746,826.61546 494.29057,845.30513 C 496.38533,864.07681 501.10709,882.78793 509.76253,895.8607 C 516.05918,905.41056 524.19772,911.33941 532.63862,913.19302 C 544.60642,916.18273 556.8549,912.73806 568.19809,906.23138 C 572.16659,903.91962 575.9928,901.01887 579.7786,897.99424 C 579.7786,882.5648 579.7786,867.1352 579.7786,851.70575 C 571.11232,862.08092 561.
35311,870.85242 550.65053,873.45396 C 543.7922,875.13167 536.171,874.95316 530.29897,868.06845 C 524.36017,861.29314 521.79941,849.29503 520.81312,837.94271 C 520.48263,835.44665 519.99025,831.24984 522.36623,831.98604 C 526.72543,832.41637 531.10345,831.98112 535.47315,832.13282 C 551.5683,832.13282 567.66345,832.13282 583.75871,832.13282 C 583.74328,816.2429 584.08437,800.19926 582.13115,784.54117 C 579.98801,765.51897 574.89966,746.92217 566.27892,733.5431 C 559.02716,722.12253 548.8718,716.49114 538.938,717.04724 C 538.33155,717.06723 537.7251,717.08723 537.11866,717.10737 z M 658.65176,717.10737 C 650.70007,717.23401 643.34138,724.31026 638.13337,733.92025 C 635.49128,738.50131 633.40068,743.84799 631.29562,749.11048 C 631.29562,739.92691 631.29562,730.74348 631.29562,721.55991 C 622.27029,721.55991 613.24506,721.55991 604.21973,721.55991 C 604.21973,784.17459 604.21973,846.78927 604.21973,909.40409 C 613.24506,909.40409 622.27029,909.40409 631.29562,909.40409 C 631.340
17,876.9876 631.19273,844.56691 631.40214,812.15346 C 631.65643,798.00747 633.03899,783.07094 638.30283,771.46622 C 641.61399,764.56688 647.39285,760.44991 652.62428,763.12259 C 657.24652,765.57142 660.35254,772.92703 661.0227,780.69355 C 662.127,790.35121 662.01315,800.25823 662.13554,810.05064 C 662.22476,843.16826 662.16706,876.28617 662.18338,909.40409 C 671.26476,909.40409 680.34614,909.40409 689.42741,909.40409 C 689.3856,868.60354 689.52385,827.79865 689.32802,787.00086 C 688.967,770.21421 687.38454,752.90941 682.25043,738.15995 C 678.59785,727.73682 672.28477,719.52055 664.95979,717.82212 C 662.88889,717.18923 660.75462,716.93408 658.65176,717.10737 z M 863.76684,717.10737 C 853.67759,717.92051 843.43575,723.75663 836.20359,735.76357 C 828.36663,748.11304 823.65387,765.00822 821.49211,782.37503 C 819.11481,800.42543 819.08482,819.13365 820.26476,837.43979 C 821.61263,856.02587 825.29499,874.67004 832.61756,889.21854 C 838.70295,901.30924 847.39046,909.67982 856.75657
,912.42712 C 868.96969,916.50976 881.67356,913.43644 893.40272,907.08885 C 897.87291,904.51542 902.26922,901.57222 906.48283,897.99424 C 906.48283,882.5648 906.48283,867.1352 906.48283,851.70575 C 899.33113,860.29802 891.46505,867.64798 882.89926,871.52675 C 876.05834,874.43865 868.63144,875.86135 861.80486,872.11342 C 857.77724,869.87425 854.30177,865.3991 851.99476,859.49778 C 848.79208,851.40018 847.61728,841.63776 847.11779,832.13282 C 868.23276,832.13282 889.34784,832.13282 910.46293,832.13282 C 910.49042,814.47362 910.75225,796.56898 908.15056,779.2978 C 905.60205,761.29463 900.26236,743.82756 891.68354,731.67109 C 885.17749,722.48969 876.72904,717.43352 868.20408,717.08868 C 866.7254,716.95089 865.24628,717.08433 863.76684,717.10737 z M 204.02386,717.2001 C 193.56932,717.966 183.20378,721.27839 173.2482,726.56913 C 173.2482,741.84398 173.2482,757.11897 173.2482,772.39382 C 183.60925,759.68183 197.11343,754.99224 209.7978,757.73738 C 214.95228,758.80089 220.51988,762.7
8412 222.70419,771.13818 C 224.22884,776.77638 224.32364,783.10731 224.26069,789.18381 C 214.15732,789.48142 203.95019,788.16391 193.94874,791.14899 C 186.11014,793.69257 178.06968,799.07576 173.09024,809.8801 C 167.91694,820.86961 166.14358,835.07124 165.88425,848.72242 C 165.39625,864.46715 167.15921,880.90244 172.55232,894.16314 C 177.02437,905.11991 184.37169,913.18694 192.45736,914.0305 C 200.51851,915.2434 209.24051,911.88856 215.13793,902.26046 C 218.94782,896.41187 221.80502,889.0977 224.26069,881.57533 C 224.26069,890.85148 224.26069,900.12778 224.26069,909.40409 C 233.36079,909.40409 242.46079,909.40409 251.56078,909.40409 C 251.51754,870.9934 251.66127,832.57952 251.4558,794.17115 C 251.04891,777.02994 249.58183,759.32424 244.38105,744.19645 C 240.76,733.95575 234.87812,726.06158 228.10737,722.1815 C 220.45781,717.3518 212.1184,716.78064 204.02386,717.2001 z M 983.67424,717.2001 C 976.18145,717.8908 969.13801,724.53803 964.61571,734.35898 C 961.91712,739.85041 959
.93424,746.17032 957.99986,752.44982 C 957.99986,742.15318 957.99986,731.85655 957.99986,721.55991 C 948.97462,721.55991 939.94918,721.55991 930.92396,721.55991 C 930.92396,784.17459 930.92396,846.78927 930.92396,909.40409 C 939.94918,909.40409 948.97462,909.40409 957.99986,909.40409 C 958.04769,878.50752 957.88961,847.60631 958.11337,816.71293 C 958.44965,802.73053 959.89801,787.95628 965.22183,776.62193 C 969.1148,768.56591 975.5566,764.40764 981.72299,765.69863 C 986.04168,766.40875 990.23941,768.84439 993.87678,772.76489 C 993.85807,754.64523 993.83934,736.52571 993.82063,718.40604 C 990.46743,717.47337 987.07866,716.80527 983.67424,717.2001 z M 540.48214,756.99524 C 545.29037,757.26923 549.62855,762.30873 552.03999,769.04608 C 555.00184,776.7532 555.80467,786.06094 555.9541,795.0279 C 544.21935,795.0279 532.48459,795.0279 520.74984,795.0279 C 521.51239,783.41724 523.53588,771.06893 529.07207,763.13723 C 532.1644,758.52327 536.3872,756.71038 540.48214,756.99524 z M 867.2
4241,756.99524 C 872.11774,757.32907 876.4707,762.53331 878.84635,769.42541 C 881.76332,777.00589 882.5424,786.20294 882.60227,795.0279 C 870.86752,795.0279 859.13277,795.0279 847.39802,795.0279 C 848.25887,783.36551 850.23902,770.83898 855.89233,762.95944 C 859.02571,758.52544 863.17177,756.69719 867.24241,756.99524 z M 323.09044,760.70579 C 328.43988,760.91095 333.07351,767.18682 335.33411,774.93292 C 338.83136,786.03168 339.5603,798.79032 339.8805,811.0985 C 339.96314,826.39233 339.6228,842.4196 335.36706,856.34391 C 333.18516,863.52086 329.12394,869.6772 324.12436,870.42745 C 319.22615,871.56355 313.93769,868.60282 310.89166,861.98761 C 306.2634,852.63234 304.96851,840.17507 304.36218,828.45762 C 303.68326,812.80881 303.89706,796.71619 306.82617,781.66607 C 308.67649,772.84936 312.32075,764.01165 318.05683,761.50704 C 319.69073,760.84112 321.40455,760.46106 323.09044,760.70579 z M 433.46809,760.61305 C 438.51451,760.60813 443.33829,765.48187 445.69303,772.85516 C 450.027
93,784.60057 450.71582,798.79003 450.95337,812.23228 C 451.13092,825.91563 450.60536,840.00845 447.4837,852.82838 C 445.47312,861.17259 441.38102,869.0672 435.73515,870.33472 C 430.25085,872.00678 424.249,868.12424 421.19476,860.29382 C 417.23008,851.21254 416.19946,839.79038 415.46624,828.93128 C 414.7674,812.69811 414.96248,795.93725 418.22164,780.41883 C 420.16676,771.72326 424.0883,762.97929 429.92245,761.25623 C 431.08883,760.8769 432.27665,760.57263 433.46809,760.61305 z M 755.63163,760.70579 C 761.04969,761.01455 765.76093,767.36287 767.97239,775.32282 C 771.99256,788.53643 772.39934,803.72376 772.36715,818.24126 C 772.23744,832.53895 771.30785,847.57473 766.61894,859.96158 C 764.07579,866.09459 759.87971,870.52453 755.31778,870.68 C 750.23173,871.20755 745.08787,866.93569 742.47435,859.62905 C 738.81191,850.66354 737.7502,839.62289 737.07653,829.07168 C 736.49329,811.87063 736.47961,793.98395 740.41145,777.74687 C 742.43089,769.7717 746.41866,762.46507 751.79163,761.
06237 C 753.05696,760.74418 754.35283,760.53191 755.63163,760.70579 z M 212.26442,824.89747 C 216.26348,825.006 220.26066,824.8627 224.26069,824.89747 C 224.39862,836.26095 224.02075,848.21559 220.50674,858.29575 C 217.8884,866.45189 213.2031,873.70013 207.38735,874.24696 C 202.41973,875.1237 196.82312,871.4614 194.79591,863.46508 C 192.64105,855.90836 192.73486,846.97661 194.15771,839.09012 C 195.61635,832.89988 198.88296,828.06917 202.79061,826.47434 C 205.85612,824.93167 209.08736,824.84111 212.26442,824.89747 z"
- id="path5686"
- sodipodi:nodetypes="cccccccccccccccccccccccccccccccscccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccsccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc" />
-</svg>
Deleted: trunk/documents/logos/mapbender_earth.svg
--- trunk/documents/logos/mapbender_earth.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_earth.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,1356 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:xlink="http://www.w3.org/1999/xlink"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- version="1.0"
- id="OSGeo_x5F_logo"
- width="200"
- height="200"
- viewBox="0 0 296.647 125.463"
- overflow="visible"
- enable-background="new 0 0 296.647 125.463"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- sodipodi:docname="mapbender_earth.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape"
- style="overflow:visible"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_hueben.png"
- inkscape:export-xdpi="182.34"
- inkscape:export-ydpi="182.34"><metadata
- id="metadata241"><rdf:RDF><cc:Work
- rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
- id="defs239"><inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 62.731499 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="296.647 : 62.731499 : 1"
- inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
- id="perspective243" /><inkscape:perspective
- id="perspective3540"
- sodipodi:type="inkscape:persp3d" />
-<radialGradient
- xlink:href="#linearGradient583"
- r="0.40413386"
- id="radialGradient582"
- fy="0.22549020"
- fx="0.68367344"
- cy="0.22549020"
- cx="0.68367344" /><radialGradient
- r="123.08747"
- id="radialGradient579"
- fy="183.44996"
- fx="201.95493"
- cy="183.44996"
- cx="201.95493"
- gradientTransform="scale(1.0032556,0.996755)"
- gradientUnits="userSpaceOnUse" /><linearGradient
- id="linearGradient576"><stop
- style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
- offset="0.00000000"
- id="stop577" /><stop
- style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
- offset="1.00000000"
- id="stop578" /></linearGradient><linearGradient
- id="linearGradient583"><stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
- id="stop584" /><stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
- id="stop585" /></linearGradient><inkscape:perspective
- id="perspective4969"
- inkscape:persp3d-origin="250 : 166.66667 : 1"
- inkscape:vp_z="500 : 250 : 1"
- inkscape:vp_x="0 : 250 : 1"
- sodipodi:type="inkscape:persp3d" /><radialGradient
- inkscape:collect="always"
- id="radialGradient5042"
- cx="201.95493"
- cy="183.44996"
- fx="201.95493"
- fy="183.44996"
- r="123.08747" /></defs><sodipodi:namedview
- inkscape:window-height="975"
- inkscape:window-width="1400"
- inkscape:pageshadow="2"
- inkscape:pageopacity="0.0"
- guidetolerance="10.0"
- gridtolerance="10.0"
- objecttolerance="10.0"
- borderopacity="1.0"
- bordercolor="#666666"
- pagecolor="#ffffff"
- id="base"
- showgrid="false"
- inkscape:zoom="2.6554017"
- inkscape:cx="97.254594"
- inkscape:cy="101.78646"
- inkscape:window-x="0"
- inkscape:window-y="25"
- inkscape:current-layer="OSGeo_x5F_logo" />
-<g
- id="g3544"
- display="none"
- style="display:none"
- transform="matrix(0.4211728,0.182269,-0.4747632,1.0363122,6.5648762,-12.913196)">
- <g
- id="g3546">
- <path
- display="inline"
- d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
- id="path3548"
- style="fill:#0054a4;display:inline" />
- <path
- display="inline"
- d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
- id="path3550"
- <path
- display="inline"
- d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
- id="path3552"
- <path
- display="inline"
- d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
- id="path3554"
- <path
- display="inline"
- d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
- id="path3556"
- <path
- display="inline"
- d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
- id="path3558"
- <path
- display="inline"
- d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
- id="path3560"
- <path
- display="inline"
- d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
- id="path3562"
- <path
- display="inline"
- d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
- id="path3564"
- <path
- display="inline"
- d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
- id="path3566"
- <path
- display="inline"
- d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
- id="path3568"
- <path
- display="inline"
- d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
- id="path3570"
- <path
- display="inline"
- d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
- id="path3572"
- <path
- display="inline"
- d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
- id="path3574"
- <path
- display="inline"
- d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
- id="path3576"
- <path
- display="inline"
- d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
- id="path3578"
- <path
- display="inline"
- d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
- id="path3580"
- </g>
- <g
- id="g3582">
- <path
- display="inline"
- d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
- id="path3584"
- <path
- display="inline"
- d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
- id="path3586"
- <path
- display="inline"
- d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
- id="path3588"
- <path
- display="inline"
- d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
- id="path3590"
- <path
- display="inline"
- d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
- id="path3592"
- <path
- display="inline"
- d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
- id="path3594"
- <path
- display="inline"
- d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
- id="path3596"
- <path
- display="inline"
- d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
- id="path3598"
- <path
- display="inline"
- d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
- id="path3600"
- <path
- display="inline"
- d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
- id="path3602"
- <path
- display="inline"
- d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
- id="path3604"
- <path
- display="inline"
- d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
- id="path3606"
- <path
- display="inline"
- d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
- id="path3608"
- <path
- display="inline"
- d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
- id="path3610"
- <path
- display="inline"
- d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
- id="path3612"
- <path
- display="inline"
- d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
- id="path3614"
- <path
- display="inline"
- d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
- id="path3616"
- <path
- display="inline"
- d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
- id="path3618"
- </g>
- <g
- id="g3620">
- <path
- display="inline"
- d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
- id="path3622"
- <path
- display="inline"
- d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
- id="path3624"
- <path
- display="inline"
- d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
- id="path3626"
- <path
- display="inline"
- d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
- id="path3628"
- <path
- display="inline"
- d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
- id="path3630"
- <path
- display="inline"
- d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
- id="path3632"
- <path
- display="inline"
- d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
- id="path3634"
- <path
- display="inline"
- d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
- id="path3636"
- <path
- display="inline"
- d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
- id="path3638"
- <path
- display="inline"
- d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
- id="path3640"
- <path
- display="inline"
- d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
- id="path3642"
- <path
- display="inline"
- d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
- id="path3644"
- <path
- display="inline"
- d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
- id="path3646"
- <path
- display="inline"
- d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
- id="path3648"
- <path
- display="inline"
- d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
- id="path3650"
- <path
- display="inline"
- d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
- id="path3652"
- <path
- display="inline"
- d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
- id="path3654"
- <path
- display="inline"
- d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
- id="path3656"
- </g>
- <g
- id="g3658">
- <path
- display="inline"
- d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
- id="path3660"
- <path
- display="inline"
- d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
- id="path3662"
- <path
- display="inline"
- d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
- id="path3664"
- <path
- display="inline"
- d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
- id="path3666"
- <path
- display="inline"
- d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
- id="path3668"
- <path
- display="inline"
- d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
- id="path3670"
- <path
- display="inline"
- d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
- id="path3672"
- <path
- display="inline"
- d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
- id="path3674"
- <path
- display="inline"
- d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
- id="path3676"
- <path
- display="inline"
- d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
- id="path3678"
- <path
- display="inline"
- d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
- id="path3680"
- <path
- display="inline"
- d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
- id="path3682"
- <path
- display="inline"
- d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
- id="path3684"
- <path
- display="inline"
- d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
- id="path3686"
- <path
- display="inline"
- d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
- id="path3688"
- <path
- display="inline"
- d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
- id="path3690"
- <path
- display="inline"
- d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
- id="path3692"
- <path
- display="inline"
- d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
- id="path3694"
- <path
- display="inline"
- d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
- id="path3696"
- </g>
- <g
- id="g3698"
- display="inline"
- style="display:inline">
- <path
- d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
- id="path3700"
- style="fill:#0054a4" />
- <path
- d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
- id="path3702"
- <path
- d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
- id="path3704"
- <path
- d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
- id="path3706"
- <path
- d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
- id="path3708"
- <path
- d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
- id="path3710"
- <path
- d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
- id="path3712"
- </g>
- <g
- id="g3714">
- <path
- display="inline"
- d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
- id="path3716"
- style="fill:#a0ce67;display:inline" />
- <path
- display="inline"
- d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
- id="path3718"
- <path
- display="inline"
- d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
- id="path3720"
- <path
- display="inline"
- d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
- id="path3722"
- <path
- display="inline"
- d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
- id="path3724"
- <path
- display="inline"
- d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
- id="path3726"
- <path
- display="inline"
- d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
- id="path3728"
- <path
- display="inline"
- d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
- id="path3730"
- <path
- display="inline"
- d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
- id="path3732"
- <path
- display="inline"
- d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
- id="path3734"
- <path
- display="inline"
- d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
- id="path3736"
- <path
- display="inline"
- d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
- id="path3738"
- <path
- display="inline"
- d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
- id="path3740"
- <path
- display="inline"
- d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
- id="path3742"
- <path
- display="inline"
- d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
- id="path3744"
- <path
- display="inline"
- d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
- id="path3746"
- <path
- display="inline"
- d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
- id="path3748"
- <path
- display="inline"
- d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
- id="path3750"
- <path
- display="inline"
- d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
- id="path3752"
- <path
- display="inline"
- d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
- id="path3754"
- <path
- display="inline"
- d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
- id="path3756"
- </g>
-</g><g
- id="g3758"
- display="none"
- <path
- display="inline"
- d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
- id="path3760"
- style="fill:#49a942;display:inline" />
- <path
- display="inline"
- d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
- id="path3762"
- <path
- display="inline"
- d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
- id="path3764"
- <path
- display="inline"
- d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
- id="path3766"
- <path
- display="inline"
- d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
- id="path3768"
-</g><g
- id="g224"
- transform="matrix(2.0488681,0.7896489,-0.8745125,1.6999927,94.926736,-101.86634)"
- style="fill:#008000">
- <circle
- sodipodi:ry="31.707001"
- sodipodi:rx="31.707001"
- sodipodi:cy="70.192001"
- sodipodi:cx="55.669998"
- id="circle226"
- r="31.707001"
- cy="70.192001"
- cx="55.669998" />
- </g><g
- id="g230"
- <polygon
- style="fill:#008000;fill-rule:evenodd"
- id="polygon232"
- points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
- clip-rule="evenodd" />
- </g><path
- style="fill:none"
- id="path234"
- d="" /><path
- style="fill:none"
- id="path236"
- d="" /><g
- id="Text"
- display="none"
- style="display:none">
- <g
- id="Associate">
- <path
- display="inline"
- id="path5"
- <path
- display="inline"
- id="path7"
- <path
- display="inline"
- id="path9"
- <path
- display="inline"
- id="path11"
- <path
- display="inline"
- id="path13"
- <path
- display="inline"
- id="path15"
- <path
- display="inline"
- id="path17"
- <path
- display="inline"
- id="path19"
- <path
- display="inline"
- id="path21"
- <path
- display="inline"
- id="path23"
- <path
- display="inline"
- id="path25"
- <path
- display="inline"
- id="path27"
- <path
- display="inline"
- id="path29"
- <path
- display="inline"
- id="path31"
- <path
- display="inline"
- id="path33"
- <path
- display="inline"
- id="path35"
- <path
- display="inline"
- id="path37"
- </g>
- <g
- id="Supporting">
- <path
- display="inline"
- id="path40"
- <path
- display="inline"
- id="path42"
- <path
- display="inline"
- id="path44"
- <path
- display="inline"
- id="path46"
- <path
- display="inline"
- id="path48"
- <path
- display="inline"
- id="path50"
- <path
- display="inline"
- id="path52"
- <path
- display="inline"
- id="path54"
- <path
- display="inline"
- id="path56"
- <path
- display="inline"
- id="path58"
- <path
- display="inline"
- id="path60"
- <path
- display="inline"
- id="path62"
- <path
- display="inline"
- id="path64"
- <path
- display="inline"
- id="path66"
- <path
- display="inline"
- id="path68"
- <path
- display="inline"
- id="path70"
- <path
- display="inline"
- id="path72"
- <path
- display="inline"
- id="path74"
- </g>
- <g
- id="Sustaining">
- <path
- display="inline"
- id="path77"
- <path
- display="inline"
- id="path79"
- <path
- display="inline"
- id="path81"
- <path
- display="inline"
- id="path83"
- <path
- display="inline"
- id="path85"
- <path
- display="inline"
- id="path87"
- <path
- display="inline"
- id="path89"
- <path
- display="inline"
- id="path91"
- <path
- display="inline"
- id="path93"
- <path
- display="inline"
- id="path95"
- <path
- display="inline"
- id="path97"
- <path
- display="inline"
- id="path99"
- <path
- display="inline"
- id="path101"
- <path
- display="inline"
- id="path103"
- <path
- display="inline"
- id="path105"
- <path
- display="inline"
- id="path107"
- <path
- display="inline"
- id="path109"
- <path
- display="inline"
- id="path111"
- </g>
- <g
- id="Incubation">
- <path
- display="inline"
- id="path114"
- <path
- display="inline"
- id="path116"
- <path
- display="inline"
- id="path118"
- <path
- display="inline"
- id="path120"
- <path
- display="inline"
- id="path122"
- <path
- display="inline"
- id="path124"
- <path
- display="inline"
- id="path126"
- <path
- display="inline"
- id="path128"
- <path
- display="inline"
- id="path130"
- <path
- display="inline"
- id="path132"
- <path
- display="inline"
- id="path134"
- <path
- display="inline"
- id="path136"
- <path
- display="inline"
- id="path138"
- <path
- display="inline"
- id="path140"
- <path
- display="inline"
- id="path142"
- <path
- display="inline"
- id="path144"
- <path
- display="inline"
- id="path146"
- <path
- display="inline"
- id="path148"
- <path
- display="inline"
- id="path150"
- </g>
- <g
- id="Project"
- display="inline"
- <path
- id="path153"
- <path
- id="path155"
- <path
- id="path157"
- <path
- id="path159"
- <path
- id="path161"
- <path
- id="path163"
- <path
- id="path165"
- </g>
- <g
- id="Your_Open_Source_Compass">
- <path
- display="inline"
- id="path168"
- <path
- display="inline"
- id="path170"
- <path
- display="inline"
- id="path172"
- <path
- display="inline"
- id="path174"
- <path
- display="inline"
- id="path176"
- <path
- display="inline"
- id="path178"
- <path
- display="inline"
- id="path180"
- <path
- display="inline"
- id="path182"
- <path
- display="inline"
- id="path184"
- <path
- display="inline"
- id="path186"
- <path
- display="inline"
- id="path188"
- <path
- display="inline"
- id="path190"
- <path
- display="inline"
- id="path192"
- <path
- display="inline"
- id="path194"
- <path
- display="inline"
- id="path196"
- <path
- display="inline"
- id="path198"
- <path
- display="inline"
- id="path200"
- <path
- display="inline"
- id="path202"
- <path
- display="inline"
- id="path204"
- <path
- display="inline"
- id="path206"
- <path
- display="inline"
- id="path208"
- </g>
-</g>
-<g
- id="OSGeo"
- display="none"
- <path
- display="inline"
- id="path211"
- <path
- display="inline"
- id="path213"
- <path
- display="inline"
- id="path215"
- <path
- display="inline"
- id="path217"
- <path
- display="inline"
- id="path219"
-</g>
-<g
- id="g844"
- transform="matrix(0.4044353,0,0,0.4044353,44.395399,-41.669222)"><path
- transform="matrix(1.04752,0,0,1.05,-36.7186,-19.064)"
- style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
- sodipodi:type="arc"
- sodipodi:ry="218.44479"
- sodipodi:rx="219.86943"
- sodipodi:cy="257.81122"
- sodipodi:cx="273.056"
- id="path575"
- d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /><path
- style="fill:#00bd00;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
- sodipodi:nodetypes="cccccccccc"
- id="path580"
- d="M 118.71999,81.155861 C 62.684157,159.03618 47.487998,116.29698 61.734397,159.98594 C 75.980792,203.67489 37.990399,236.91649 89.277432,202.72513 C 140.56447,168.53378 129.16735,121.04578 171.90655,157.13666 C 214.64575,193.22753 259.28446,148.58882 235.54047,206.52417 C 211.79647,264.45953 246.93759,348.98817 278.27966,249.26337 C 309.62174,149.53858 235.54047,202.72513 265.93278,130.54338 C 296.3251,58.361623 342.86334,42.215703 287.77726,29.868824 C 212.74623,67.859222 181.40415,114.39746 151.01183,90.653461 C 120.61951,66.909463 120.61951,82.105621 118.71999,81.155861 z" /><path
- sodipodi:nodetypes="cccccccc"
- id="path586"
- d="M 405.5475,188.47874 C 395.10014,254.96193 400.7987,277.75617 366.60734,273.00737 C 332.41598,268.25857 303.92318,255.91169 328.61694,304.34945 C 353.3107,352.78721 413.14558,311.94753 380.85374,361.33505 C 348.5619,410.72256 373.25566,419.2704 303.92318,443.96416 C 234.59071,468.65792 255.48543,480.05504 262.13375,481.0048 C 308.67199,479.10528 464.43261,442.06465 479.62877,264.45953 C 446.38718,132.4429 406.49726,190.37826 405.5475,188.47874 z" /><path
- id="path587"
- d="M 83.578876,378.43073 C 98.775035,351.83745 101.62431,338.54081 120.61951,351.83745 C 139.61471,365.13409 125.36831,360.38529 160.50943,374.63169 C 195.65055,388.87809 187.10271,349.93793 207.99743,377.48097 C 228.89215,405.02401 202.29887,402.17473 194.70079,426.86848 C 187.10271,451.56224 136.76543,454.41152 136.76543,443.0144 C 136.76543,431.61728 96.875515,447.7632 83.578876,378.43073 z" /><path
- style="fill:#b77719;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
- sodipodi:nodetypes="ccccccc"
- id="path606"
- d="M 267.83231,69.758743 C 258.33471,61.210903 218.44479,116.29698 185.20319,114.39746 C 151.96159,112.49794 144.36351,112.49794 113.97119,122.9453 C 83.578875,133.39266 73.131516,183.72994 98.775031,175.1821 C 106.37311,143.84002 167.15775,119.14626 194.70079,130.54338 C 222.24383,141.9405 237.43999,164.73474 248.83711,173.28258 C 245.98783,110.59842 250.73663,109.64866 267.83231,69.758743 z" /><path
- sodipodi:nodetypes="ccccc"
- id="path607"
- d="M 107.32287,381.28001 C 117.77023,389.82785 133.91615,408.82305 148.16255,394.57665 C 186.15295,392.67713 204.19839,379.38049 191.85151,399.32545 C 151.96159,404.07424 183.30367,431.61728 147.21279,435.41632 C 140.56447,428.768 80.729596,395.52641 107.32287,381.28001 z" /><path
- id="path608"
- d="M 432.14078,216.02178 C 431.19102,238.81601 468.23165,301.50017 432.14078,299.60065 C 396.0499,297.70113 376.10494,288.20353 378.95422,300.55041 C 381.8035,312.89729 425.49246,310.04801 425.49246,333.79201 C 425.49246,357.53601 381.8035,411.67232 362.8083,428.768 C 343.8131,445.86368 308.67198,454.41152 299.17438,464.85888 C 441.63837,461.05984 520.46845,233.11746 432.14078,216.02178 z" /><path
- style="fill:url(#radialGradient579);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
- id="path588"
- d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /></g><path
- style="fill:#ff0000"
- id="path3827"
- sodipodi:cx="211.1405"
- sodipodi:cy="125.87266"
- sodipodi:rx="48.595829"
- sodipodi:ry="15.36075"
- d="M 259.73633,125.87266 A 48.595829,15.36075 0 1 1 162.54467,125.87266 A 48.595829,15.36075 0 1 1 259.73633,125.87266 z"
- transform="matrix(2.8312969,-2.8697982,2.968043,2.7375785,-823.30798,323.61993)" /><rect
- style="fill:#ffffff;stroke:#ffffff;stroke-width:0;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
- id="rect5077"
- width="118.24126"
- height="79.141182"
- x="-0.74978393"
- y="132.66359" /><path
- style="fill:#ffffff;overflow:visible"
- id="path3831"
- transform="matrix(2.6583088,-2.5712068,2.3656048,2.8890136,-711.24771,239.70023)"
- inkscape:transform-center-x="14.643913"
- inkscape:transform-center-y="-12.23846" /><g
- id="g5044"
- transform="translate(-240.07435,-0.4346669)"><path
- sodipodi:nodetypes="cssssz"
- id="path4991"
- d="M 411.9947,92.414881 C 380.30504,121.70083 328.17179,138.70697 313.17635,120.23247 C 298.1809,101.75797 290.20452,77.537893 292.80966,51.961217 C 298.01994,0.80785346 343.59299,-36.496733 394.53522,-31.307958 C 420.00633,-28.713571 442.02084,-15.984644 457.01628,2.4898569 C 472.01172,20.964358 443.47194,63.325235 411.9947,92.414881 z"
- style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt" /><path
- id="path4993"
- d="M 332.27987,-7.587752 C 309.61701,23.909798 303.47114,6.624557 309.23289,24.293915 C 314.99463,41.963268 299.62998,55.407345 320.37226,41.579152 C 341.11455,27.750963 336.50516,8.5451393 353.7904,23.141565 C 371.07564,37.737987 389.12911,19.684517 379.5262,43.115618 C 369.92329,66.546722 384.1356,100.73309 396.81144,60.400859 C 409.48728,20.068633 379.5262,41.579152 391.81792,12.386304 C 404.10965,-16.806546 422.93136,-23.336526 400.6526,-28.33004 C 370.30741,-12.965382 357.63156,5.8563241 345.33983,-3.7465873 C 333.04811,-13.349498 333.04811,-7.2036355 332.27987,-7.587752 z" /><path
- id="path4997"
- d="M 310.16816,89.337436 C 316.31402,78.582176 317.46637,73.204543 325.1487,78.582176 C 332.83103,83.959806 327.06928,82.039226 341.28159,87.800966 C 355.4939,93.562716 352.03685,77.813936 360.48741,88.953316 C 368.93798,100.0927 358.18271,98.940346 355.10978,108.92737 C 352.03685,118.9144 331.67868,120.06675 331.67868,115.45735 C 331.67868,110.84796 315.54579,117.37794 310.16816,89.337436 z" /><path
- id="path4999"
- d="M 392.58616,-12.197149 C 388.745,-15.654197 372.6121,6.624557 359.16803,5.8563241 C 345.72395,5.0880911 342.65102,5.0880911 330.35929,9.3133723 C 318.06757,13.538653 313.84229,33.896826 324.21343,30.439778 C 327.28636,17.763935 351.86981,7.7769064 363.00919,12.386304 C 374.14857,16.995702 380.29443,26.214497 384.90383,29.671545 C 383.75148,4.3198582 385.67206,3.9357417 392.58616,-12.197149 z" /><path
- id="path5001"
- d="M 319.77107,90.489786 C 323.99635,93.946836 330.52633,101.62917 336.28808,95.867416 C 351.65273,95.099186 358.95095,89.721556 353.95743,97.787996 C 337.82454,99.708576 350.50038,110.84796 335.90396,112.38442 C 333.21514,109.69561 309.01581,96.251536 319.77107,90.489786 z" /></g><path
- id="path5005"
- style="fill:url(#radialGradient5042);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt;stroke:#a1ce67;stroke-opacity:1"
- transform="matrix(0.4236541,0,0,0.4246571,644.63706,-29.556585)" /><text
- xml:space="preserve"
- style="font-size:58.81839752px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- x="1.943607"
- y="150.67944"
- id="text2616"
- transform="matrix(0.7804736,1.1445518e-2,-1.5592994e-2,1.2810446,0,0)"><tspan
- sodipodi:role="line"
- id="tspan2618"
- x="1.943607"
- y="150.67944"
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Sans;-inkscape-font-specification:Sans Bold">Ma<tspan
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#0000ff;font-family:Sans;-inkscape-font-specification:Sans Bold"
- id="tspan3823">p</tspan><tspan
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#ff0000;font-family:Sans;-inkscape-font-specification:Sans Bold"
- id="tspan3825">b</tspan>ender</tspan></text>
-</svg>
\ No newline at end of file
Deleted: trunk/documents/logos/mapbender_grounded.svg
--- trunk/documents/logos/mapbender_grounded.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_grounded.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,621 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- version="1.0"
- id="OSGeo_x5F_logo"
- width="200"
- height="200"
- viewBox="0 0 296.647 125.463"
- overflow="visible"
- enable-background="new 0 0 296.647 125.463"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- sodipodi:docname="mapbender_grounded.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape"
- style="overflow:visible"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_valley.png"
- inkscape:export-xdpi="61.200001"
- inkscape:export-ydpi="61.200001"><metadata
- id="metadata241"><rdf:RDF><cc:Work
- rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
- id="defs239"><inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 62.731499 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="296.647 : 62.731499 : 1"
- inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
- id="perspective243" /></defs><sodipodi:namedview
- inkscape:window-height="975"
- inkscape:window-width="1400"
- inkscape:pageshadow="2"
- inkscape:pageopacity="0.0"
- guidetolerance="10.0"
- gridtolerance="10.0"
- objecttolerance="10.0"
- borderopacity="1.0"
- bordercolor="#666666"
- pagecolor="#ffffff"
- id="base"
- showgrid="false"
- inkscape:zoom="3.7553051"
- inkscape:cx="90.265265"
- inkscape:cy="99.562976"
- inkscape:window-x="0"
- inkscape:window-y="25"
- inkscape:current-layer="OSGeo_x5F_logo" />
-<g
- id="Text"
- display="none"
- <g
- id="Associate">
- <path
- display="inline"
- d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
- id="path5"
- style="fill:#0054a4;display:inline" />
- <path
- display="inline"
- d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
- id="path7"
- <path
- display="inline"
- d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
- id="path9"
- <path
- display="inline"
- d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
- id="path11"
- <path
- display="inline"
- d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
- id="path13"
- <path
- display="inline"
- d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
- id="path15"
- <path
- display="inline"
- d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
- id="path17"
- <path
- display="inline"
- d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
- id="path19"
- <path
- display="inline"
- d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
- id="path21"
- <path
- display="inline"
- d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
- id="path23"
- <path
- display="inline"
- d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
- id="path25"
- <path
- display="inline"
- d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
- id="path27"
- <path
- display="inline"
- d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
- id="path29"
- <path
- display="inline"
- d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
- id="path31"
- <path
- display="inline"
- d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
- id="path33"
- <path
- display="inline"
- d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
- id="path35"
- <path
- display="inline"
- d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
- id="path37"
- </g>
- <g
- id="Supporting">
- <path
- display="inline"
- d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
- id="path40"
- <path
- display="inline"
- d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
- id="path42"
- <path
- display="inline"
- d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
- id="path44"
- <path
- display="inline"
- d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
- id="path46"
- <path
- display="inline"
- d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
- id="path48"
- <path
- display="inline"
- d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
- id="path50"
- <path
- display="inline"
- d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
- id="path52"
- <path
- display="inline"
- d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
- id="path54"
- <path
- display="inline"
- d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
- id="path56"
- <path
- display="inline"
- d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
- id="path58"
- <path
- display="inline"
- d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
- id="path60"
- <path
- display="inline"
- d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
- id="path62"
- <path
- display="inline"
- d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
- id="path64"
- <path
- display="inline"
- d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
- id="path66"
- <path
- display="inline"
- d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
- id="path68"
- <path
- display="inline"
- d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
- id="path70"
- <path
- display="inline"
- d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
- id="path72"
- <path
- display="inline"
- d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
- id="path74"
- </g>
- <g
- id="Sustaining">
- <path
- display="inline"
- d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
- id="path77"
- <path
- display="inline"
- d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
- id="path79"
- <path
- display="inline"
- d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
- id="path81"
- <path
- display="inline"
- d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
- id="path83"
- <path
- display="inline"
- d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
- id="path85"
- <path
- display="inline"
- d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
- id="path87"
- <path
- display="inline"
- d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
- id="path89"
- <path
- display="inline"
- d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
- id="path91"
- <path
- display="inline"
- d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
- id="path93"
- <path
- display="inline"
- d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
- id="path95"
- <path
- display="inline"
- d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
- id="path97"
- <path
- display="inline"
- d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
- id="path99"
- <path
- display="inline"
- d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
- id="path101"
- <path
- display="inline"
- d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
- id="path103"
- <path
- display="inline"
- d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
- id="path105"
- <path
- display="inline"
- d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
- id="path107"
- <path
- display="inline"
- d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
- id="path109"
- <path
- display="inline"
- d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
- id="path111"
- </g>
- <g
- id="Incubation">
- <path
- display="inline"
- d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
- id="path114"
- <path
- display="inline"
- d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
- id="path116"
- <path
- display="inline"
- d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
- id="path118"
- <path
- display="inline"
- d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
- id="path120"
- <path
- display="inline"
- d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
- id="path122"
- <path
- display="inline"
- d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
- id="path124"
- <path
- display="inline"
- d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
- id="path126"
- <path
- display="inline"
- d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
- id="path128"
- <path
- display="inline"
- d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
- id="path130"
- <path
- display="inline"
- d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
- id="path132"
- <path
- display="inline"
- d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
- id="path134"
- <path
- display="inline"
- d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
- id="path136"
- <path
- display="inline"
- d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
- id="path138"
- <path
- display="inline"
- d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
- id="path140"
- <path
- display="inline"
- d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
- id="path142"
- <path
- display="inline"
- d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
- id="path144"
- <path
- display="inline"
- d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
- id="path146"
- <path
- display="inline"
- d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
- id="path148"
- <path
- display="inline"
- d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
- id="path150"
- </g>
- <g
- id="Project"
- display="inline"
- style="display:inline">
- <path
- d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
- id="path153"
- style="fill:#0054a4" />
- <path
- d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
- id="path155"
- <path
- d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
- id="path157"
- <path
- d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
- id="path159"
- <path
- d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
- id="path161"
- <path
- d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
- id="path163"
- <path
- d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
- id="path165"
- </g>
- <g
- <path
- display="inline"
- d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
- id="path168"
- style="fill:#a0ce67;display:inline" />
- <path
- display="inline"
- d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
- id="path170"
- <path
- display="inline"
- d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
- id="path172"
- <path
- display="inline"
- d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
- id="path174"
- <path
- display="inline"
- d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
- id="path176"
- <path
- display="inline"
- d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
- id="path178"
- <path
- display="inline"
- d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
- id="path180"
- <path
- display="inline"
- d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
- id="path182"
- <path
- display="inline"
- d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
- id="path184"
- <path
- display="inline"
- d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
- id="path186"
- <path
- display="inline"
- d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
- id="path188"
- <path
- display="inline"
- d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
- id="path190"
- <path
- display="inline"
- d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
- id="path192"
- <path
- display="inline"
- d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
- id="path194"
- <path
- display="inline"
- d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
- id="path196"
- <path
- display="inline"
- d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
- id="path198"
- <path
- display="inline"
- d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
- id="path200"
- <path
- display="inline"
- d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
- id="path202"
- <path
- display="inline"
- d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
- id="path204"
- <path
- display="inline"
- d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
- id="path206"
- <path
- display="inline"
- d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
- id="path208"
- </g>
-</g>
-<g
- id="OSGeo"
- display="none"
- style="display:none">
- <path
- display="inline"
- d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
- id="path211"
- style="fill:#49a942;display:inline" />
- <path
- display="inline"
- d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
- id="path213"
- <path
- display="inline"
- d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
- id="path215"
- <path
- display="inline"
- d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
- id="path217"
- <path
- display="inline"
- d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
- id="path219"
-</g>
-<text
- style="font-size:57.60910416px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- x="12.559419"
- y="60.615295"
- id="text2616"
- transform="scale(0.7428897,1.3460949)"><tspan
- id="tspan2618"
- x="12.559419"
- y="60.615295"
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:DejaVu Sans;-inkscape-font-specification:DejaVu Sans Bold">Mapbender</tspan></text>
-<path
- style="fill:#008000"
- d="M 282.40396,200.39079 L 13.034026,200.39079 L 13.034026,89.799034 L 87.288494,136.01059 L 282.40396,89.799034 L 282.40396,200.39079 z"
- id="rect2660"
- sodipodi:nodetypes="cccccc" /></svg>
Deleted: trunk/documents/logos/mapbender_grounded_holy.svg
--- trunk/documents/logos/mapbender_grounded_holy.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_grounded_holy.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,1218 +0,0 @@
-<svg
- version="1.0"
- width="200"
- height="200"
- xml:space="preserve"
- sodipodi:docname="mapbender_grounded_holy.svg"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_grounded_holy.png"
- id="perspective243" /><inkscape:perspective
- id="perspective3540"
- sodipodi:type="inkscape:persp3d" /></defs><sodipodi:namedview
- id="base"
- showgrid="false"
- inkscape:zoom="2.6554017"
- inkscape:cy="97.814879"
-<g
- id="g3542"
- transform="matrix(0.9474644,0,0,1.1845289,1.3570637,11.670385)"><g
- display="none"
- id="g3544">
- <g
- id="g3546">
- <path
- id="path3548"
- display="inline" />
- <path
- id="path3550"
- <path
- id="path3552"
- <path
- id="path3554"
- <path
- id="path3556"
- <path
- id="path3558"
- <path
- id="path3560"
- <path
- id="path3562"
- <path
- id="path3564"
- <path
- id="path3566"
- <path
- id="path3568"
- <path
- id="path3570"
- <path
- id="path3572"
- <path
- id="path3574"
- <path
- id="path3576"
- <path
- id="path3578"
- <path
- id="path3580"
- </g>
- <g
- id="g3582">
- <path
- id="path3584"
- <path
- id="path3586"
- <path
- id="path3588"
- <path
- id="path3590"
- <path
- id="path3592"
- <path
- id="path3594"
- <path
- id="path3596"
- <path
- id="path3598"
- <path
- id="path3600"
- <path
- id="path3602"
- <path
- id="path3604"
- <path
- id="path3606"
- <path
- id="path3608"
- <path
- id="path3610"
- <path
- id="path3612"
- <path
- id="path3614"
- <path
- id="path3616"
- <path
- id="path3618"
- </g>
- <g
- id="g3620">
- <path
- id="path3622"
- <path
- id="path3624"
- <path
- id="path3626"
- <path
- id="path3628"
- <path
- id="path3630"
- <path
- id="path3632"
- <path
- id="path3634"
- <path
- id="path3636"
- <path
- id="path3638"
- <path
- id="path3640"
- <path
- id="path3642"
- <path
- id="path3644"
- <path
- id="path3646"
- <path
- id="path3648"
- <path
- id="path3650"
- <path
- id="path3652"
- <path
- id="path3654"
- <path
- id="path3656"
- </g>
- <g
- id="g3658">
- <path
- id="path3660"
- <path
- id="path3662"
- <path
- id="path3664"
- <path
- id="path3666"
- <path
- id="path3668"
- <path
- id="path3670"
- <path
- id="path3672"
- <path
- id="path3674"
- <path
- id="path3676"
- <path
- id="path3678"
- <path
- id="path3680"
- <path
- id="path3682"
- <path
- id="path3684"
- <path
- id="path3686"
- <path
- id="path3688"
- <path
- id="path3690"
- <path
- id="path3692"
- <path
- id="path3694"
- <path
- id="path3696"
- </g>
- <g
- display="inline"
- id="g3698">
- <path
- id="path3700"
- d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z" />
- <path
- id="path3702"
- d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z" />
- <path
- id="path3704"
- d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z" />
- <path
- id="path3706"
- d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z" />
- <path
- id="path3708"
- d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z" />
- <path
- id="path3710"
- d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z" />
- <path
- id="path3712"
- d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z" />
- </g>
- <g
- id="g3714">
- <path
- id="path3716"
- <path
- id="path3718"
- <path
- id="path3720"
- <path
- id="path3722"
- <path
- id="path3724"
- <path
- id="path3726"
- <path
- id="path3728"
- <path
- id="path3730"
- <path
- id="path3732"
- <path
- id="path3734"
- <path
- id="path3736"
- <path
- id="path3738"
- <path
- id="path3740"
- <path
- id="path3742"
- <path
- id="path3744"
- <path
- id="path3746"
- <path
- id="path3748"
- <path
- id="path3750"
- <path
- id="path3752"
- <path
- id="path3754"
- <path
- id="path3756"
- </g>
-</g><g
- display="none"
- id="g3758">
- <path
- id="path3760"
- <path
- id="path3762"
- <path
- id="path3764"
- <path
- id="path3766"
- <path
- id="path3768"
-</g><g
- transform="matrix(2.658509,0,0,1.0066382,2.3739382,-80.596613)"
- id="Compass">
- <path
- style="fill:#49a942;fill-rule:evenodd"
- id="path222"
- d="M 54.232,117.368 C 28.032,116.453 7.532,94.47 8.447,68.269 C 9.361,42.065 31.345,21.569 57.546,22.484 C 75.658,23.117 91.043,33.819 98.515,49.021 C 99.665,49.057 100.817,49.06 101.976,48.846 C 94.225,31.979 77.475,20 57.657,19.308 C 29.667,18.33 6.187,40.227 5.209,68.219 C 4.233,96.205 26.127,119.687 54.118,120.665 C 61.711,120.929 68.969,119.499 75.539,116.731 C 75.222,115.748 75.025,114.623 74.698,113.516 C 68.439,116.223 61.5,117.621 54.232,117.368 z"
- clip-rule="evenodd" />
- <g
- id="g224">
- <circle
- style="fill:#a0ce67"
- sodipodi:ry="31.707001"
- sodipodi:rx="31.707001"
- sodipodi:cy="70.192001"
- sodipodi:cx="55.669998"
- id="circle226"
- r="31.707001"
- cy="70.192001"
- cx="55.669998" />
- </g>
- <polygon
- style="fill:#ffffff;stroke:#a0ce67;stroke-width:2;stroke-miterlimit:6"
- id="polygon228"
- points="61.494,53.061 26.327,4.407 38.873,63.876 3.379,93.238 49.515,86.588 78.884,121.407 72.411,75.859 107.593,46.548 61.494,53.061 "
- stroke-miterlimit="6" />
- <g
- id="g230">
- <polygon
- id="polygon232"
- points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
- </g>
- <path
- style="fill:none"
- id="path234"
- d="" />
- <path
- style="fill:none"
- id="path236"
- d="" />
-</g></g><g
- id="Text"
- display="none"
- <g
- id="Associate">
- <path
- display="inline"
- d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
- id="path5"
- style="fill:#0054a4;display:inline" />
- <path
- display="inline"
- d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
- id="path7"
- <path
- display="inline"
- d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
- id="path9"
- <path
- display="inline"
- d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
- id="path11"
- <path
- display="inline"
- d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
- id="path13"
- <path
- display="inline"
- d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
- id="path15"
- <path
- display="inline"
- d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
- id="path17"
- <path
- display="inline"
- d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
- id="path19"
- <path
- display="inline"
- d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
- id="path21"
- <path
- display="inline"
- d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
- id="path23"
- <path
- display="inline"
- d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
- id="path25"
- <path
- display="inline"
- d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
- id="path27"
- <path
- display="inline"
- d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
- id="path29"
- <path
- display="inline"
- d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
- id="path31"
- <path
- display="inline"
- d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
- id="path33"
- <path
- display="inline"
- d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
- id="path35"
- <path
- display="inline"
- d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
- id="path37"
- </g>
- <g
- id="Supporting">
- <path
- display="inline"
- d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
- id="path40"
- <path
- display="inline"
- d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
- id="path42"
- <path
- display="inline"
- d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
- id="path44"
- <path
- display="inline"
- d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
- id="path46"
- <path
- display="inline"
- d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
- id="path48"
- <path
- display="inline"
- d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
- id="path50"
- <path
- display="inline"
- d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
- id="path52"
- <path
- display="inline"
- d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
- id="path54"
- <path
- display="inline"
- d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
- id="path56"
- <path
- display="inline"
- d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
- id="path58"
- <path
- display="inline"
- d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
- id="path60"
- <path
- display="inline"
- d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
- id="path62"
- <path
- display="inline"
- d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
- id="path64"
- <path
- display="inline"
- d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
- id="path66"
- <path
- display="inline"
- d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
- id="path68"
- <path
- display="inline"
- d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
- id="path70"
- <path
- display="inline"
- d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
- id="path72"
- <path
- display="inline"
- d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
- id="path74"
- </g>
- <g
- id="Sustaining">
- <path
- display="inline"
- d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
- id="path77"
- <path
- display="inline"
- d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
- id="path79"
- <path
- display="inline"
- d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
- id="path81"
- <path
- display="inline"
- d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
- id="path83"
- <path
- display="inline"
- d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
- id="path85"
- <path
- display="inline"
- d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
- id="path87"
- <path
- display="inline"
- d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
- id="path89"
- <path
- display="inline"
- d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
- id="path91"
- <path
- display="inline"
- d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
- id="path93"
- <path
- display="inline"
- d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
- id="path95"
- <path
- display="inline"
- d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
- id="path97"
- <path
- display="inline"
- d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
- id="path99"
- <path
- display="inline"
- d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
- id="path101"
- <path
- display="inline"
- d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
- id="path103"
- <path
- display="inline"
- d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
- id="path105"
- <path
- display="inline"
- d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
- id="path107"
- <path
- display="inline"
- d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
- id="path109"
- <path
- display="inline"
- d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
- id="path111"
- </g>
- <g
- id="Incubation">
- <path
- display="inline"
- d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
- id="path114"
- <path
- display="inline"
- d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
- id="path116"
- <path
- display="inline"
- d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
- id="path118"
- <path
- display="inline"
- d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
- id="path120"
- <path
- display="inline"
- d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
- id="path122"
- <path
- display="inline"
- d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
- id="path124"
- <path
- display="inline"
- d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
- id="path126"
- <path
- display="inline"
- d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
- id="path128"
- <path
- display="inline"
- d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
- id="path130"
- <path
- display="inline"
- d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
- id="path132"
- <path
- display="inline"
- d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
- id="path134"
- <path
- display="inline"
- d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
- id="path136"
- <path
- display="inline"
- d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
- id="path138"
- <path
- display="inline"
- d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
- id="path140"
- <path
- display="inline"
- d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
- id="path142"
- <path
- display="inline"
- d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
- id="path144"
- <path
- display="inline"
- d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
- id="path146"
- <path
- display="inline"
- d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
- id="path148"
- <path
- display="inline"
- d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
- id="path150"
- </g>
- <g
- id="Project"
- display="inline"
- style="display:inline">
- <path
- id="path153"
- style="fill:#0054a4" />
- <path
- id="path155"
- <path
- id="path157"
- <path
- id="path159"
- <path
- id="path161"
- <path
- id="path163"
- <path
- id="path165"
- </g>
- <g
- id="Your_Open_Source_Compass">
- <path
- display="inline"
- d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
- id="path168"
- style="fill:#a0ce67;display:inline" />
- <path
- display="inline"
- d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
- id="path170"
- <path
- display="inline"
- d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
- id="path172"
- <path
- display="inline"
- d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
- id="path174"
- <path
- display="inline"
- d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
- id="path176"
- <path
- display="inline"
- d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
- id="path178"
- <path
- display="inline"
- d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
- id="path180"
- <path
- display="inline"
- d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
- id="path182"
- <path
- display="inline"
- d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
- id="path184"
- <path
- display="inline"
- d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
- id="path186"
- <path
- display="inline"
- d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
- id="path188"
- <path
- display="inline"
- d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
- id="path190"
- <path
- display="inline"
- d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
- id="path192"
- <path
- display="inline"
- d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
- id="path194"
- <path
- display="inline"
- d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
- id="path196"
- <path
- display="inline"
- d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
- id="path198"
- <path
- display="inline"
- d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
- id="path200"
- <path
- display="inline"
- d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
- id="path202"
- <path
- display="inline"
- d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
- id="path204"
- <path
- display="inline"
- d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
- id="path206"
- <path
- display="inline"
- d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
- id="path208"
- </g>
-</g>
-<g
- id="OSGeo"
- display="none"
- style="display:none">
- <path
- display="inline"
- d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
- id="path211"
- style="fill:#49a942;display:inline" />
- <path
- display="inline"
- d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
- id="path213"
- <path
- display="inline"
- d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
- id="path215"
- <path
- display="inline"
- d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
- id="path217"
- <path
- display="inline"
- d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
- id="path219"
-</g>
-<path
- style="fill:#008000"
- d="M 282.40396,200.39079 L 13.034026,200.39079 L 13.034026,89.799034 L 94.397964,142.72509 L 282.40396,89.799034 L 282.40396,200.39079 z"
- id="rect2660"
- sodipodi:nodetypes="cccccc" /><text
- xml:space="preserve"
- style="font-size:61.51377869px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- x="18.320276"
- y="80.174667"
- id="text2616"
- transform="scale(0.6850773,1.4596893)"><tspan
- sodipodi:role="line"
- id="tspan2618"
- x="18.320276"
- y="80.174667"
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Serif;-inkscape-font-specification:Serif Bold">Mapbender</tspan></text>
-</svg>
\ No newline at end of file
Deleted: trunk/documents/logos/mapbender_hueben.svg
--- trunk/documents/logos/mapbender_hueben.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mapbender_hueben.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,1355 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Generator: Adobe Illustrator 12.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 51448) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:xlink="http://www.w3.org/1999/xlink"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- version="1.0"
- id="OSGeo_x5F_logo"
- width="200"
- height="200"
- viewBox="0 0 296.647 125.463"
- overflow="visible"
- enable-background="new 0 0 296.647 125.463"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- sodipodi:docname="mapbender_hueben.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape"
- style="overflow:visible"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/mapbender_hueben.png"
- inkscape:export-xdpi="182.34"
- inkscape:export-ydpi="182.34"><metadata
- id="metadata241"><rdf:RDF><cc:Work
- rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" /></cc:Work></rdf:RDF></metadata><defs
- id="defs239"><inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 62.731499 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="296.647 : 62.731499 : 1"
- inkscape:persp3d-origin="148.3235 : 41.820999 : 1"
- id="perspective243" /><inkscape:perspective
- id="perspective3540"
- sodipodi:type="inkscape:persp3d" />
-<radialGradient
- xlink:href="#linearGradient583"
- r="0.40413386"
- id="radialGradient582"
- fy="0.22549020"
- fx="0.68367344"
- cy="0.22549020"
- cx="0.68367344" /><radialGradient
- r="123.08747"
- id="radialGradient579"
- fy="183.44996"
- fx="201.95493"
- cy="183.44996"
- cx="201.95493"
- gradientTransform="scale(1.0032556,0.996755)"
- gradientUnits="userSpaceOnUse" /><linearGradient
- id="linearGradient576"><stop
- style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
- offset="0.00000000"
- id="stop577" /><stop
- style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
- offset="1.00000000"
- id="stop578" /></linearGradient><linearGradient
- id="linearGradient583"><stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
- id="stop584" /><stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
- id="stop585" /></linearGradient><inkscape:perspective
- id="perspective4969"
- inkscape:persp3d-origin="250 : 166.66667 : 1"
- inkscape:vp_z="500 : 250 : 1"
- inkscape:vp_x="0 : 250 : 1"
- sodipodi:type="inkscape:persp3d" /><radialGradient
- inkscape:collect="always"
- id="radialGradient5042"
- cx="201.95493"
- cy="183.44996"
- fx="201.95493"
- fy="183.44996"
- r="123.08747" /></defs><sodipodi:namedview
- inkscape:window-height="975"
- inkscape:window-width="1400"
- inkscape:pageshadow="2"
- inkscape:pageopacity="0.0"
- guidetolerance="10.0"
- gridtolerance="10.0"
- objecttolerance="10.0"
- borderopacity="1.0"
- bordercolor="#666666"
- pagecolor="#ffffff"
- id="base"
- showgrid="false"
- inkscape:zoom="2.6554017"
- inkscape:cx="104.70077"
- inkscape:cy="101.78646"
- inkscape:window-x="0"
- inkscape:window-y="25"
- inkscape:current-layer="OSGeo_x5F_logo" />
-<g
- id="g3544"
- display="none"
- transform="matrix(0.4211728,0.182269,-0.4747632,1.0363122,6.5648762,-12.913196)">
- <g
- id="g3546">
- <path
- display="inline"
- id="path3548"
- <path
- display="inline"
- id="path3550"
- <path
- display="inline"
- id="path3552"
- <path
- display="inline"
- id="path3554"
- <path
- display="inline"
- id="path3556"
- <path
- display="inline"
- id="path3558"
- <path
- display="inline"
- id="path3560"
- <path
- display="inline"
- id="path3562"
- <path
- display="inline"
- id="path3564"
- <path
- display="inline"
- id="path3566"
- <path
- display="inline"
- id="path3568"
- <path
- display="inline"
- id="path3570"
- <path
- display="inline"
- id="path3572"
- <path
- display="inline"
- id="path3574"
- <path
- display="inline"
- id="path3576"
- <path
- display="inline"
- id="path3578"
- <path
- display="inline"
- id="path3580"
- </g>
- <g
- id="g3582">
- <path
- display="inline"
- id="path3584"
- <path
- display="inline"
- id="path3586"
- <path
- display="inline"
- id="path3588"
- <path
- display="inline"
- id="path3590"
- <path
- display="inline"
- id="path3592"
- <path
- display="inline"
- id="path3594"
- <path
- display="inline"
- id="path3596"
- <path
- display="inline"
- id="path3598"
- <path
- display="inline"
- id="path3600"
- <path
- display="inline"
- id="path3602"
- <path
- display="inline"
- id="path3604"
- <path
- display="inline"
- id="path3606"
- <path
- display="inline"
- id="path3608"
- <path
- display="inline"
- id="path3610"
- <path
- display="inline"
- id="path3612"
- <path
- display="inline"
- id="path3614"
- <path
- display="inline"
- id="path3616"
- <path
- display="inline"
- id="path3618"
- </g>
- <g
- id="g3620">
- <path
- display="inline"
- id="path3622"
- <path
- display="inline"
- id="path3624"
- <path
- display="inline"
- id="path3626"
- <path
- display="inline"
- id="path3628"
- <path
- display="inline"
- id="path3630"
- <path
- display="inline"
- id="path3632"
- <path
- display="inline"
- id="path3634"
- <path
- display="inline"
- id="path3636"
- <path
- display="inline"
- id="path3638"
- <path
- display="inline"
- id="path3640"
- <path
- display="inline"
- id="path3642"
- <path
- display="inline"
- id="path3644"
- <path
- display="inline"
- id="path3646"
- <path
- display="inline"
- id="path3648"
- <path
- display="inline"
- id="path3650"
- <path
- display="inline"
- id="path3652"
- <path
- display="inline"
- id="path3654"
- <path
- display="inline"
- id="path3656"
- </g>
- <g
- id="g3658">
- <path
- display="inline"
- id="path3660"
- <path
- display="inline"
- id="path3662"
- <path
- display="inline"
- id="path3664"
- <path
- display="inline"
- id="path3666"
- <path
- display="inline"
- id="path3668"
- <path
- display="inline"
- id="path3670"
- <path
- display="inline"
- id="path3672"
- <path
- display="inline"
- id="path3674"
- <path
- display="inline"
- id="path3676"
- <path
- display="inline"
- id="path3678"
- <path
- display="inline"
- id="path3680"
- <path
- display="inline"
- id="path3682"
- <path
- display="inline"
- id="path3684"
- <path
- display="inline"
- id="path3686"
- <path
- display="inline"
- id="path3688"
- <path
- display="inline"
- id="path3690"
- <path
- display="inline"
- id="path3692"
- <path
- display="inline"
- id="path3694"
- <path
- display="inline"
- id="path3696"
- </g>
- <g
- id="g3698"
- display="inline"
- <path
- d="M 236.4,114.176 C 236.086,114.176 235.638,114.155 235.255,114.108 L 234.202,119.712 L 231.827,119.712 L 234.694,104.586 C 235.86,104.542 237.114,104.496 238.526,104.496 C 241.485,104.496 243.143,105.886 243.143,108.238 C 243.144,111.644 240.05,114.176 236.4,114.176 z M 238.101,106.49 C 237.497,106.49 237.115,106.49 236.712,106.533 L 235.659,112.047 C 235.973,112.114 236.309,112.137 236.688,112.137 C 238.817,112.137 240.633,110.59 240.633,108.575 C 240.634,107.318 239.962,106.49 238.101,106.49 z"
- id="path3700"
- <path
- d="M 250.558,110.657 C 248.699,110.12 246.615,113.84 245.964,117.244 L 245.495,119.711 L 243.141,119.711 L 244.26,113.885 C 244.551,112.317 244.932,110.232 245.225,108.574 L 247.51,108.574 C 247.354,109.492 247.061,110.59 246.455,112.338 L 246.5,112.359 C 247.732,109.805 249.01,108.013 251.051,108.349 L 250.558,110.657 z"
- id="path3702"
- <path
- d="M 254.742,119.934 C 251.806,119.934 250.529,118.478 250.529,115.946 C 250.529,111.397 253.486,108.35 257.095,108.35 C 260.142,108.35 261.353,110.032 261.353,112.406 C 261.353,116.977 258.148,119.934 254.742,119.934 z M 256.736,110.389 C 254.451,110.389 252.996,113.01 252.996,115.565 C 252.996,117.022 253.576,117.874 255.078,117.874 C 257.183,117.874 258.865,115.589 258.865,112.675 C 258.865,111.195 258.214,110.389 256.736,110.389 z"
- id="path3704"
- <path
- d="M 264.623,120.898 C 264.062,123.765 262.764,125.356 259.805,125.356 C 259.268,125.356 258.752,125.265 258.326,125.154 L 258.82,123.093 C 259.222,123.25 259.693,123.339 260.05,123.339 C 261.419,123.339 261.933,122.622 262.335,120.537 L 264.644,108.573 L 266.974,108.573 L 264.623,120.898 z M 266.257,106.916 C 265.429,106.916 264.823,106.244 264.845,105.482 C 264.866,104.585 265.63,103.912 266.482,103.912 C 267.31,103.912 267.918,104.562 267.892,105.324 C 267.871,106.244 267.109,106.916 266.257,106.916 z"
- id="path3706"
- <path
- d="M 270.582,114.959 C 270.537,115.252 270.49,115.744 270.49,116.08 C 270.49,117.603 271.052,118.006 272.732,118.006 C 273.787,118.006 274.927,117.761 275.914,117.358 L 275.914,119.24 C 274.771,119.665 273.404,119.934 271.949,119.934 C 269.26,119.934 268.094,118.746 268.094,116.237 C 268.094,111.778 270.694,108.35 274.278,108.35 C 276.835,108.35 277.708,109.649 277.708,110.971 C 277.707,113.481 275.175,114.803 270.582,114.959 z M 274.009,110.143 C 272.396,110.143 271.32,111.598 270.872,113.301 C 273.919,113.19 275.352,112.563 275.352,111.285 C 275.353,110.546 274.837,110.143 274.009,110.143 z"
- id="path3708"
- <path
- d="M 286.802,110.77 C 286.265,110.524 285.636,110.368 284.896,110.368 C 282.298,110.368 281.111,113.28 281.111,115.61 C 281.111,116.753 281.513,117.806 283.261,117.806 C 284.07,117.806 284.921,117.627 285.593,117.313 L 285.413,119.418 C 284.628,119.687 283.643,119.911 282.589,119.911 C 279.653,119.911 278.601,118.365 278.601,116.146 C 278.601,111.89 281.044,108.371 285.054,108.371 C 285.929,108.371 286.644,108.484 287.363,108.685 L 286.802,110.77 z"
- id="path3710"
- <path
- d="M 295.109,110.434 L 292.261,110.434 L 291.232,115.901 C 290.941,117.448 291.164,117.874 292.171,117.874 C 292.778,117.874 293.226,117.807 293.651,117.717 L 293.473,119.665 C 292.778,119.823 291.948,119.912 291.297,119.912 C 288.967,119.912 288.318,118.814 288.834,116.216 L 289.932,110.435 L 287.825,110.435 L 288.206,108.576 L 290.29,108.576 L 290.962,105.035 L 293.405,104.519 L 292.622,108.576 L 295.489,108.576 L 295.109,110.434 z"
- id="path3712"
- </g>
- <g
- id="g3714">
- <path
- display="inline"
- id="path3716"
- <path
- display="inline"
- id="path3718"
- <path
- display="inline"
- id="path3720"
- <path
- display="inline"
- id="path3722"
- <path
- display="inline"
- id="path3724"
- <path
- display="inline"
- id="path3726"
- <path
- display="inline"
- id="path3728"
- <path
- display="inline"
- id="path3730"
- <path
- display="inline"
- id="path3732"
- <path
- display="inline"
- id="path3734"
- <path
- display="inline"
- id="path3736"
- <path
- display="inline"
- id="path3738"
- <path
- display="inline"
- id="path3740"
- <path
- display="inline"
- id="path3742"
- <path
- display="inline"
- id="path3744"
- <path
- display="inline"
- id="path3746"
- <path
- display="inline"
- id="path3748"
- <path
- display="inline"
- id="path3750"
- <path
- display="inline"
- id="path3752"
- <path
- display="inline"
- id="path3754"
- <path
- display="inline"
- id="path3756"
- </g>
-</g><g
- id="g3758"
- display="none"
- <path
- display="inline"
- id="path3760"
- <path
- display="inline"
- id="path3762"
- <path
- display="inline"
- id="path3764"
- <path
- display="inline"
- id="path3766"
- <path
- display="inline"
- id="path3768"
-</g><g
- id="g224"
- transform="matrix(2.0488681,0.7896489,-0.8745125,1.6999927,94.926736,-101.86634)"
- style="fill:#008000">
- <circle
- sodipodi:ry="31.707001"
- sodipodi:rx="31.707001"
- sodipodi:cy="70.192001"
- sodipodi:cx="55.669998"
- id="circle226"
- r="31.707001"
- cy="70.192001"
- cx="55.669998" />
- </g><polygon
- style="fill:#ffffff;stroke:#a1ce67;stroke-width:2;stroke-miterlimit:6;stroke-opacity:1"
- id="polygon228"
- points="61.494,53.061 26.327,4.407 38.873,63.876 3.379,93.238 49.515,86.588 78.884,121.407 72.411,75.859 107.593,46.548 61.494,53.061 "
- stroke-miterlimit="6"
- transform="matrix(2.0488681,0.7896489,-0.8745125,1.6999927,94.926736,-101.86634)" /><g
- id="g230"
- <polygon
- style="fill:#008000;fill-rule:evenodd"
- id="polygon232"
- points="58.606,66.663 76.371,60.624 60.143,69.772 69.983,74.904 59.123,73.172 65.45,91.554 55.707,74.987 50.335,84.403 51.976,73.643 34.388,79.515 50.561,70.082 40.388,64.431 52.106,66.806 46.326,49.022 55.255,65.431 60.669,55.451 58.606,66.663 "
- clip-rule="evenodd" />
- </g><path
- style="fill:none"
- id="path234"
- d="" /><path
- style="fill:none"
- id="path236"
- d="" /><g
- id="Text"
- display="none"
- <g
- id="Associate">
- <path
- display="inline"
- d="M 125.807,106.395 C 125.067,106.149 124.284,106.038 123.702,106.038 C 121.573,106.038 120.678,107.179 120.678,108.298 C 120.678,110.829 125.181,110.898 125.181,114.505 C 125.181,117.372 122.649,119.589 119.065,119.589 C 118.191,119.589 117.206,119.521 116.466,119.298 L 116.915,116.989 C 117.564,117.26 118.461,117.462 119.245,117.462 C 121.395,117.462 122.582,116.452 122.582,114.907 C 122.582,112.487 118.125,112.466 118.125,108.858 C 118.125,106.239 120.095,104.02 123.859,104.02 C 124.666,104.02 125.382,104.065 126.234,104.221 L 125.807,106.395 z"
- id="path5"
- style="fill:#0054a4;display:inline" />
- <path
- display="inline"
- d="M 130.755,119.545 C 130.263,119.545 129.838,119.498 129.344,119.432 L 128.336,124.83 L 125.984,124.83 L 128.134,113.562 C 128.515,111.5 128.874,109.666 129.097,108.232 L 131.427,108.232 C 131.248,109.148 130.957,110.156 130.284,112.261 L 130.329,112.286 C 131.45,109.843 133.13,107.983 135.258,107.983 C 136.916,107.983 137.811,109.057 137.811,111.434 C 137.812,115.58 135.64,119.545 130.755,119.545 z M 134.385,110.045 C 132.503,110.045 130.307,114.121 129.882,116.631 L 129.748,117.416 C 130.15,117.572 130.755,117.66 131.182,117.66 C 134.139,117.66 135.393,114.435 135.393,111.861 C 135.393,110.582 135.012,110.045 134.385,110.045 z"
- id="path7"
- <path
- display="inline"
- d="M 143.366,119.588 C 140.431,119.588 139.155,118.133 139.155,115.602 C 139.155,111.053 142.112,108.008 145.719,108.008 C 148.766,108.008 149.975,109.688 149.975,112.063 C 149.974,116.631 146.771,119.588 143.366,119.588 z M 145.359,110.045 C 143.074,110.045 141.618,112.666 141.618,115.219 C 141.618,116.678 142.201,117.528 143.702,117.528 C 145.807,117.528 147.488,115.243 147.488,112.331 C 147.488,110.854 146.838,110.045 145.359,110.045 z"
- id="path9"
- <path
- display="inline"
- d="M 160.412,119.365 L 158.058,119.365 L 159.425,112.308 C 159.739,110.716 159.446,110.044 158.573,110.044 C 156.782,110.044 154.587,114.03 154.093,116.72 L 153.601,119.365 L 151.249,119.365 L 152.37,113.541 C 152.727,111.682 153.087,109.73 153.331,108.232 L 155.661,108.232 C 155.526,108.925 155.237,110.113 154.52,112.197 L 154.563,112.218 C 155.618,110.023 157.274,107.984 159.514,107.984 C 161.619,107.984 162.291,109.484 161.866,111.748 L 160.412,119.365 z"
- id="path11"
- <path
- display="inline"
- d="M 170.646,110.066 C 170.154,109.888 169.593,109.82 169.056,109.82 C 167.734,109.82 167.062,110.402 167.062,111.254 C 167.062,112.846 170.22,113.406 170.22,115.869 C 170.22,117.728 168.585,119.588 165.292,119.588 C 164.554,119.588 163.948,119.52 163.388,119.408 L 163.79,117.349 C 164.352,117.527 164.956,117.638 165.561,117.638 C 166.883,117.638 167.756,117.124 167.756,116.115 C 167.756,114.482 164.619,114.168 164.619,111.5 C 164.619,109.553 166.166,108.008 169.189,108.008 C 169.927,108.008 170.533,108.074 171.093,108.186 L 170.646,110.066 z"
- id="path13"
- <path
- display="inline"
- d="M 176.56,119.588 C 173.624,119.588 172.347,118.133 172.347,115.602 C 172.347,111.053 175.304,108.008 178.911,108.008 C 181.958,108.008 183.167,109.688 183.167,112.063 C 183.167,116.631 179.964,119.588 176.56,119.588 z M 178.552,110.045 C 176.267,110.045 174.812,112.666 174.812,115.219 C 174.812,116.678 175.394,117.528 176.896,117.528 C 179.001,117.528 180.681,115.243 180.681,112.331 C 180.681,110.854 180.031,110.045 178.552,110.045 z"
- id="path15"
- <path
- display="inline"
- d="M 191.857,110.314 C 189.998,109.777 187.914,113.496 187.265,116.9 L 186.794,119.365 L 184.442,119.365 L 185.563,113.541 C 185.852,111.973 186.235,109.889 186.524,108.232 L 188.811,108.232 C 188.653,109.148 188.362,110.248 187.756,111.994 L 187.801,112.015 C 189.033,109.462 190.311,107.671 192.35,108.007 L 191.857,110.314 z"
- id="path17"
- <path
- display="inline"
- d="M 199.291,114.549 C 198.396,114.549 197.77,113.832 197.791,113.002 C 197.836,112.039 198.643,111.301 199.516,111.301 C 200.412,111.301 201.039,112.039 201.018,112.846 C 200.994,113.832 200.189,114.549 199.291,114.549 z"
- id="path19"
- <path
- display="inline"
- d="M 216.74,119.365 L 216.248,116.027 L 210.244,116.027 L 208.474,119.365 L 205.943,119.365 L 214.142,104.242 L 216.808,104.242 L 219.316,119.365 L 216.74,119.365 z M 215.195,109.33 C 215.06,108.568 214.97,107.783 214.925,106.998 L 214.904,106.998 C 214.59,107.76 214.209,108.59 213.761,109.394 L 211.23,114.078 L 215.978,114.078 L 215.195,109.33 z"
- id="path21"
- <path
- display="inline"
- d="M 228.007,110.066 C 227.513,109.888 226.954,109.82 226.415,109.82 C 225.095,109.82 224.423,110.402 224.423,111.254 C 224.423,112.846 227.581,113.406 227.581,115.869 C 227.581,117.728 225.944,119.588 222.651,119.588 C 221.913,119.588 221.307,119.52 220.749,119.408 L 221.151,117.349 C 221.712,117.527 222.315,117.638 222.921,117.638 C 224.243,117.638 225.116,117.124 225.116,116.115 C 225.116,114.482 221.979,114.168 221.979,111.5 C 221.979,109.553 223.526,108.008 226.549,108.008 C 227.289,108.008 227.893,108.074 228.453,108.186 L 228.007,110.066 z"
- id="path23"
- <path
- display="inline"
- d="M 236.496,110.066 C 236.002,109.888 235.443,109.82 234.904,109.82 C 233.584,109.82 232.912,110.402 232.912,111.254 C 232.912,112.846 236.07,113.406 236.07,115.869 C 236.07,117.728 234.435,119.588 231.142,119.588 C 230.402,119.588 229.796,119.52 229.238,119.408 L 229.64,117.349 C 230.201,117.527 230.806,117.638 231.41,117.638 C 232.732,117.638 233.607,117.124 233.607,116.115 C 233.607,114.482 230.47,114.168 230.47,111.5 C 230.47,109.553 232.015,108.008 235.04,108.008 C 235.778,108.008 236.382,108.074 236.942,108.186 L 236.496,110.066 z"
- id="path25"
- <path
- display="inline"
- d="M 242.408,119.588 C 239.474,119.588 238.197,118.133 238.197,115.602 C 238.197,111.053 241.154,108.008 244.761,108.008 C 247.806,108.008 249.017,109.688 249.017,112.063 C 249.017,116.631 245.814,119.588 242.408,119.588 z M 244.402,110.045 C 242.117,110.045 240.662,112.666 240.662,115.219 C 240.662,116.678 241.244,117.528 242.744,117.528 C 244.849,117.528 246.531,115.243 246.531,112.331 C 246.531,110.854 245.88,110.045 244.402,110.045 z"
- id="path27"
- <path
- display="inline"
- d="M 258.535,110.428 C 257.998,110.18 257.371,110.024 256.631,110.024 C 254.033,110.024 252.846,112.934 252.846,115.266 C 252.846,116.409 253.248,117.461 254.996,117.461 C 255.803,117.461 256.654,117.281 257.326,116.967 L 257.146,119.072 C 256.363,119.342 255.376,119.566 254.324,119.566 C 251.388,119.566 250.336,118.021 250.336,115.802 C 250.336,111.546 252.779,108.029 256.789,108.029 C 257.662,108.029 258.379,108.142 259.096,108.343 L 258.535,110.428 z"
- id="path29"
- <path
- display="inline"
- d="M 261.781,119.365 L 259.429,119.365 L 261.556,108.232 L 263.91,108.232 L 261.781,119.365 z M 263.238,106.574 C 262.386,106.574 261.781,105.902 261.804,105.14 C 261.825,104.242 262.587,103.57 263.439,103.57 C 264.269,103.57 264.873,104.22 264.851,104.982 C 264.828,105.902 264.066,106.574 263.238,106.574 z"
- id="path31"
- <path
- display="inline"
- d="M 273.921,119.365 L 271.591,119.365 C 271.794,118.447 272.175,117.125 272.78,115.287 L 272.735,115.266 C 271.881,116.946 270.27,119.612 267.76,119.612 C 266.125,119.612 265.229,118.536 265.229,116.163 C 265.229,112.017 267.403,108.052 272.286,108.052 C 273.585,108.052 274.839,108.165 275.983,108.388 C 274.884,114.057 274.392,116.609 273.921,119.365 z M 271.882,109.912 C 268.903,109.912 267.65,113.16 267.65,115.736 C 267.65,117.013 268.031,117.548 268.658,117.548 C 270.539,117.548 272.668,113.448 273.162,110.917 L 273.316,110.112 C 272.914,110.002 272.443,109.912 271.882,109.912 z"
- id="path33"
- <path
- display="inline"
- d="M 284.472,110.092 L 281.626,110.092 L 280.597,115.555 C 280.306,117.102 280.529,117.528 281.536,117.528 C 282.141,117.528 282.589,117.462 283.015,117.372 L 282.837,119.321 C 282.142,119.477 281.314,119.567 280.663,119.567 C 278.333,119.567 277.684,118.469 278.198,115.87 L 279.296,110.093 L 277.191,110.093 L 277.572,108.234 L 279.656,108.234 L 280.328,104.695 L 282.769,104.179 L 281.986,108.234 L 284.853,108.234 L 284.472,110.092 z"
- id="path35"
- <path
- display="inline"
- d="M 287.808,114.615 C 287.763,114.906 287.718,115.4 287.718,115.736 C 287.718,117.259 288.279,117.66 289.958,117.66 C 291.011,117.66 292.153,117.416 293.14,117.014 L 293.14,118.895 C 291.997,119.321 290.63,119.588 289.175,119.588 C 286.486,119.588 285.321,118.4 285.321,115.891 C 285.321,111.436 287.919,108.008 291.503,108.008 C 294.058,108.008 294.933,109.305 294.933,110.629 C 294.933,113.137 292.4,114.457 287.808,114.615 z M 291.236,109.799 C 289.623,109.799 288.548,111.254 288.099,112.959 C 291.146,112.846 292.579,112.219 292.579,110.941 C 292.58,110.203 292.066,109.799 291.236,109.799 z"
- id="path37"
- </g>
- <g
- id="Supporting">
- <path
- display="inline"
- d="M 112.149,106.585 C 111.408,106.338 110.622,106.227 110.038,106.227 C 107.905,106.227 107.007,107.371 107.007,108.495 C 107.007,111.033 111.52,111.099 111.52,114.715 C 111.52,117.59 108.982,119.815 105.389,119.815 C 104.514,119.815 103.525,119.747 102.785,119.521 L 103.234,117.209 C 103.886,117.478 104.784,117.679 105.57,117.679 C 107.726,117.679 108.916,116.669 108.916,115.12 C 108.916,112.693 104.447,112.672 104.447,109.056 C 104.447,106.429 106.424,104.206 110.196,104.206 C 111.004,104.206 111.723,104.25 112.576,104.407 L 112.149,106.585 z"
- id="path40"
- <path
- display="inline"
- d="M 116.885,119.768 C 116.391,119.768 115.965,119.722 115.47,119.656 L 114.459,125.068 L 112.101,125.068 L 114.257,113.772 C 114.639,111.707 114.999,109.865 115.223,108.427 L 117.558,108.427 C 117.378,109.348 117.086,110.359 116.412,112.47 L 116.457,112.491 C 117.58,110.043 119.265,108.179 121.397,108.179 C 123.059,108.179 123.958,109.257 123.958,111.638 C 123.959,115.792 121.781,119.768 116.885,119.768 z M 120.523,110.245 C 118.637,110.245 116.437,114.333 116.01,116.847 L 115.875,117.635 C 116.279,117.792 116.885,117.882 117.312,117.882 C 120.275,117.882 121.533,114.647 121.533,112.065 C 121.534,110.785 121.152,110.245 120.523,110.245 z"
- id="path42"
- <path
- display="inline"
- d="M 129.302,119.813 C 126.36,119.813 125.08,118.351 125.08,115.814 C 125.08,111.255 128.044,108.201 131.66,108.201 C 134.714,108.201 135.927,109.886 135.927,112.265 C 135.927,116.847 132.715,119.813 129.302,119.813 z M 131.3,110.245 C 129.009,110.245 127.55,112.872 127.55,115.433 C 127.55,116.892 128.133,117.745 129.638,117.745 C 131.749,117.745 133.433,115.454 133.433,112.534 C 133.434,111.054 132.782,110.245 131.3,110.245 z"
- id="path44"
- <path
- display="inline"
- d="M 146.165,119.588 L 143.807,119.588 L 145.179,112.514 C 145.492,110.919 145.201,110.245 144.326,110.245 C 142.528,110.245 140.327,114.243 139.833,116.938 L 139.339,119.587 L 136.981,119.587 L 138.104,113.748 C 138.463,111.885 138.823,109.931 139.069,108.426 L 141.405,108.426 C 141.269,109.122 140.978,110.312 140.26,112.401 L 140.304,112.423 C 141.361,110.222 143.021,108.179 145.268,108.179 C 147.379,108.179 148.053,109.684 147.626,111.952 L 146.165,119.588 z"
- id="path46"
- <path
- display="inline"
- d="M 156.202,110.269 C 155.708,110.09 155.147,110.022 154.607,110.022 C 153.284,110.022 152.61,110.606 152.61,111.46 C 152.61,113.055 155.775,113.614 155.775,116.084 C 155.775,117.948 154.136,119.814 150.836,119.814 C 150.095,119.814 149.488,119.746 148.926,119.632 L 149.331,117.567 C 149.893,117.747 150.499,117.858 151.104,117.858 C 152.43,117.858 153.305,117.341 153.305,116.332 C 153.305,114.693 150.161,114.378 150.161,111.707 C 150.161,109.753 151.71,108.202 154.742,108.202 C 155.483,108.202 156.09,108.27 156.651,108.382 L 156.202,110.269 z"
- id="path48"
- <path
- display="inline"
- d="M 161.905,119.813 C 158.963,119.813 157.683,118.351 157.683,115.814 C 157.683,111.255 160.647,108.201 164.263,108.201 C 167.317,108.201 168.531,109.886 168.531,112.265 C 168.531,116.847 165.319,119.813 161.905,119.813 z M 163.904,110.245 C 161.614,110.245 160.153,112.872 160.153,115.433 C 160.153,116.892 160.737,117.745 162.242,117.745 C 164.352,117.745 166.037,115.454 166.037,112.534 C 166.037,111.054 165.385,110.245 163.904,110.245 z"
- id="path50"
- <path
- display="inline"
- d="M 177.016,110.516 C 175.153,109.976 173.064,113.704 172.412,117.119 L 171.941,119.589 L 169.584,119.589 L 170.706,113.75 C 170.997,112.178 171.38,110.091 171.671,108.428 L 173.963,108.428 C 173.806,109.349 173.513,110.449 172.906,112.199 L 172.952,112.223 C 174.186,109.661 175.466,107.866 177.512,108.202 L 177.016,110.516 z"
- id="path52"
- <path
- display="inline"
- d="M 184.019,114.76 C 183.123,114.76 182.493,114.04 182.516,113.209 C 182.56,112.244 183.37,111.503 184.245,111.503 C 185.143,111.503 185.771,112.244 185.75,113.054 C 185.727,114.04 184.918,114.76 184.019,114.76 z"
- id="path54"
- <path
- display="inline"
- d="M 200.883,106.585 C 200.144,106.338 199.356,106.227 198.772,106.227 C 196.639,106.227 195.741,107.371 195.741,108.495 C 195.741,111.033 200.256,111.099 200.256,114.715 C 200.256,117.59 197.718,119.815 194.124,119.815 C 193.249,119.815 192.261,119.747 191.52,119.521 L 191.969,117.209 C 192.62,117.478 193.518,117.679 194.303,117.679 C 196.459,117.679 197.65,116.669 197.65,115.12 C 197.65,112.693 193.181,112.672 193.181,109.056 C 193.181,106.429 195.159,104.206 198.93,104.206 C 199.739,104.206 200.456,104.25 201.31,104.407 L 200.883,106.585 z"
- id="path56"
- <path
- display="inline"
- d="M 212.064,114.266 C 211.706,116.152 211.346,118.129 211.078,119.588 L 208.764,119.588 C 208.9,118.893 209.191,117.702 209.888,115.613 L 209.842,115.591 C 208.81,117.792 207.147,119.835 204.903,119.835 C 202.792,119.835 202.118,118.33 202.545,116.062 L 204.004,108.427 L 206.341,108.427 L 204.993,115.501 C 204.678,117.094 204.969,117.768 205.847,117.768 C 207.643,117.768 209.843,113.772 210.337,111.077 L 210.832,108.428 L 213.189,108.428 L 212.064,114.266 z"
- id="path58"
- <path
- display="inline"
- d="M 217.993,119.768 C 217.499,119.768 217.072,119.722 216.577,119.656 L 215.567,125.068 L 213.209,125.068 L 215.365,113.772 C 215.746,111.707 216.105,109.865 216.33,108.427 L 218.667,108.427 C 218.485,109.348 218.194,110.359 217.521,112.47 L 217.567,112.491 C 218.689,110.043 220.374,108.179 222.506,108.179 C 224.168,108.179 225.066,109.257 225.066,111.638 C 225.065,115.792 222.888,119.768 217.993,119.768 z M 221.63,110.245 C 219.742,110.245 217.541,114.333 217.115,116.847 L 216.981,117.635 C 217.383,117.792 217.992,117.882 218.419,117.882 C 221.383,117.882 222.641,114.647 222.641,112.065 C 222.641,110.785 222.258,110.245 221.63,110.245 z"
- id="path60"
- <path
- display="inline"
- d="M 229.893,119.768 C 229.399,119.768 228.972,119.722 228.478,119.656 L 227.467,125.068 L 225.109,125.068 L 227.266,113.772 C 227.646,111.707 228.005,109.865 228.23,108.427 L 230.567,108.427 C 230.385,109.348 230.094,110.359 229.421,112.47 L 229.467,112.491 C 230.589,110.043 232.274,108.179 234.406,108.179 C 236.069,108.179 236.966,109.257 236.966,111.638 C 236.965,115.792 234.789,119.768 229.893,119.768 z M 233.531,110.245 C 231.643,110.245 229.443,114.333 229.016,116.847 L 228.882,117.635 C 229.284,117.792 229.893,117.882 230.32,117.882 C 233.284,117.882 234.542,114.647 234.542,112.065 C 234.542,110.785 234.159,110.245 233.531,110.245 z"
- id="path62"
- <path
- display="inline"
- d="M 242.308,119.813 C 239.366,119.813 238.085,118.351 238.085,115.814 C 238.085,111.255 241.05,108.201 244.665,108.201 C 247.719,108.201 248.934,109.886 248.934,112.265 C 248.934,116.847 245.722,119.813 242.308,119.813 z M 244.307,110.245 C 242.017,110.245 240.555,112.872 240.555,115.433 C 240.555,116.892 241.139,117.745 242.645,117.745 C 244.755,117.745 246.44,115.454 246.44,112.534 C 246.44,111.054 245.789,110.245 244.307,110.245 z"
- id="path64"
- <path
- display="inline"
- d="M 257.419,110.516 C 255.556,109.976 253.466,113.704 252.816,117.119 L 252.343,119.589 L 249.985,119.589 L 251.11,113.75 C 251.401,112.178 251.781,110.091 252.075,108.428 L 254.365,108.428 C 254.208,109.349 253.917,110.449 253.31,112.199 L 253.354,112.223 C 254.59,109.661 255.87,107.866 257.913,108.202 L 257.419,110.516 z"
- id="path66"
- <path
- display="inline"
- d="M 265.433,110.291 L 262.58,110.291 L 261.547,115.77 C 261.254,117.319 261.48,117.746 262.49,117.746 C 263.095,117.746 263.545,117.678 263.971,117.589 L 263.791,119.542 C 263.095,119.699 262.264,119.789 261.614,119.789 C 259.278,119.789 258.626,118.688 259.142,116.083 L 260.243,110.291 L 258.132,110.291 L 258.515,108.427 L 260.604,108.427 L 261.278,104.879 L 263.723,104.362 L 262.938,108.426 L 265.813,108.426 L 265.433,110.291 z"
- id="path68"
- <path
- display="inline"
- d="M 268.351,119.588 L 265.993,119.588 L 268.126,108.427 L 270.484,108.427 L 268.351,119.588 z M 269.81,106.765 C 268.957,106.765 268.351,106.091 268.373,105.327 C 268.394,104.43 269.158,103.756 270.012,103.756 C 270.843,103.756 271.449,104.406 271.427,105.17 C 271.405,106.091 270.642,106.765 269.81,106.765 z"
- id="path70"
- <path
- display="inline"
- d="M 280.746,119.588 L 278.389,119.588 L 279.758,112.514 C 280.073,110.919 279.779,110.245 278.904,110.245 C 277.108,110.245 274.908,114.243 274.413,116.938 L 273.919,119.587 L 271.562,119.587 L 272.686,113.748 C 273.044,111.885 273.404,109.931 273.651,108.426 L 275.987,108.426 C 275.851,109.122 275.56,110.312 274.841,112.401 L 274.887,112.423 C 275.942,110.222 277.604,108.179 279.849,108.179 C 281.96,108.179 282.633,109.684 282.207,111.952 L 280.746,119.588 z"
- id="path72"
- <path
- display="inline"
- d="M 292.443,120.463 C 291.905,123.316 290.107,125.269 285.796,125.269 C 284.538,125.269 283.527,125.09 282.674,124.821 L 283.236,122.552 C 284.111,122.979 285.235,123.204 286.246,123.204 C 288.469,123.204 289.77,122.35 290.221,120.058 C 290.512,118.531 290.782,117.677 291.477,115.567 L 291.433,115.567 C 290.624,117.162 289.007,119.835 286.494,119.835 C 284.853,119.835 283.957,118.757 283.957,116.377 C 283.957,112.223 286.157,108.247 291.029,108.247 C 292.333,108.247 293.589,108.359 294.735,108.584 L 292.443,120.463 z M 290.624,110.111 C 287.638,110.111 286.38,113.366 286.38,115.95 C 286.38,117.229 286.763,117.767 287.391,117.767 C 289.277,117.767 291.412,113.659 291.906,111.121 L 292.061,110.311 C 291.658,110.201 291.185,110.111 290.624,110.111 z"
- id="path74"
- </g>
- <g
- id="Sustaining">
- <path
- display="inline"
- d="M 114.405,106.354 C 113.664,106.108 112.88,105.997 112.297,105.997 C 110.166,105.997 109.269,107.14 109.269,108.262 C 109.269,110.797 113.776,110.863 113.776,114.474 C 113.776,117.345 111.241,119.567 107.654,119.567 C 106.779,119.567 105.793,119.499 105.052,119.274 L 105.5,116.964 C 106.151,117.234 107.049,117.434 107.833,117.434 C 109.986,117.434 111.175,116.425 111.175,114.878 C 111.175,112.455 106.713,112.433 106.713,108.821 C 106.713,106.197 108.686,103.977 112.454,103.977 C 113.261,103.977 113.979,104.021 114.831,104.178 L 114.405,106.354 z"
- id="path77"
- <path
- display="inline"
- d="M 119.359,119.521 C 118.866,119.521 118.441,119.475 117.947,119.41 L 116.937,124.815 L 114.582,124.815 L 116.735,113.533 C 117.116,111.471 117.474,109.631 117.699,108.195 L 120.032,108.195 C 119.853,109.115 119.561,110.125 118.888,112.233 L 118.933,112.254 C 120.055,109.809 121.737,107.947 123.867,107.947 C 125.528,107.947 126.424,109.024 126.424,111.401 C 126.424,115.551 124.25,119.521 119.359,119.521 z M 122.993,110.01 C 121.108,110.01 118.91,114.094 118.484,116.604 L 118.351,117.391 C 118.754,117.548 119.359,117.637 119.787,117.637 C 122.747,117.637 124.004,114.407 124.004,111.828 C 124.003,110.55 123.621,110.01 122.993,110.01 z"
- id="path79"
- <path
- display="inline"
- d="M 131.984,119.566 C 129.046,119.566 127.768,118.107 127.768,115.572 C 127.768,111.019 130.728,107.969 134.34,107.969 C 137.39,107.969 138.602,109.651 138.602,112.029 C 138.602,116.604 135.395,119.566 131.984,119.566 z M 133.981,110.01 C 131.693,110.01 130.234,112.634 130.234,115.193 C 130.234,116.65 130.817,117.503 132.32,117.503 C 134.428,117.503 136.111,115.215 136.111,112.299 C 136.111,110.818 135.46,110.01 133.981,110.01 z"
- id="path81"
- <path
- display="inline"
- d="M 149.05,119.341 L 146.694,119.341 L 148.064,112.276 C 148.377,110.683 148.086,110.01 147.212,110.01 C 145.417,110.01 143.218,114.004 142.725,116.696 L 142.233,119.342 L 139.878,119.342 L 140.999,113.511 C 141.357,111.65 141.718,109.699 141.963,108.196 L 144.296,108.196 C 144.161,108.891 143.87,110.08 143.153,112.166 L 143.196,112.188 C 144.251,109.99 145.91,107.949 148.154,107.949 C 150.261,107.949 150.935,109.453 150.509,111.719 L 149.05,119.341 z"
- id="path83"
- <path
- display="inline"
- d="M 159.298,110.034 C 158.804,109.854 158.243,109.787 157.706,109.787 C 156.382,109.787 155.708,110.37 155.708,111.223 C 155.708,112.816 158.872,113.375 158.872,115.842 C 158.872,117.703 157.233,119.567 153.936,119.567 C 153.198,119.567 152.59,119.499 152.032,119.385 L 152.432,117.323 C 152.994,117.503 153.6,117.614 154.205,117.614 C 155.529,117.614 156.402,117.098 156.402,116.089 C 156.402,114.453 153.263,114.138 153.263,111.471 C 153.263,109.52 154.812,107.971 157.837,107.971 C 158.577,107.971 159.183,108.038 159.743,108.15 L 159.298,110.034 z"
- id="path85"
- <path
- display="inline"
- d="M 165.216,119.566 C 162.278,119.566 161.001,118.107 161.001,115.572 C 161.001,111.019 163.96,107.969 167.571,107.969 C 170.622,107.969 171.835,109.651 171.835,112.029 C 171.835,116.604 168.628,119.566 165.216,119.566 z M 167.214,110.01 C 164.927,110.01 163.468,112.634 163.468,115.193 C 163.468,116.65 164.05,117.503 165.554,117.503 C 167.661,117.503 169.345,115.215 169.345,112.299 C 169.345,110.818 168.693,110.01 167.214,110.01 z"
- id="path87"
- <path
- display="inline"
- d="M 180.535,110.281 C 178.674,109.741 176.588,113.464 175.935,116.875 L 175.466,119.341 L 173.111,119.341 L 174.232,113.51 C 174.523,111.94 174.904,109.855 175.195,108.195 L 177.486,108.195 C 177.328,109.115 177.035,110.214 176.429,111.962 L 176.476,111.986 C 177.708,109.427 178.986,107.633 181.029,107.97 L 180.535,110.281 z"
- id="path89"
- <path
- display="inline"
- d="M 187.976,114.52 C 187.081,114.52 186.453,113.801 186.476,112.971 C 186.519,112.007 187.328,111.267 188.201,111.267 C 189.099,111.267 189.726,112.007 189.705,112.816 C 189.683,113.801 188.875,114.52 187.976,114.52 z"
- id="path91"
- <path
- display="inline"
- d="M 205.267,106.354 C 204.529,106.108 203.742,105.997 203.16,105.997 C 201.029,105.997 200.131,107.14 200.131,108.262 C 200.131,110.797 204.641,110.863 204.641,114.474 C 204.641,117.345 202.106,119.567 198.518,119.567 C 197.643,119.567 196.655,119.499 195.916,119.274 L 196.365,116.964 C 197.015,117.234 197.912,117.434 198.695,117.434 C 200.849,117.434 202.039,116.425 202.039,114.878 C 202.039,112.455 197.574,112.433 197.574,108.821 C 197.574,106.197 199.551,103.977 203.316,103.977 C 204.125,103.977 204.841,104.021 205.693,104.178 L 205.267,106.354 z"
- id="path93"
- <path
- display="inline"
- d="M 216.66,114.025 C 216.301,115.909 215.943,117.883 215.674,119.34 L 213.363,119.34 C 213.498,118.646 213.789,117.457 214.484,115.37 L 214.439,115.349 C 213.408,117.547 211.748,119.587 209.505,119.587 C 207.398,119.587 206.724,118.084 207.15,115.818 L 208.607,108.193 L 210.941,108.193 L 209.595,115.258 C 209.281,116.849 209.572,117.522 210.447,117.522 C 212.242,117.522 214.439,113.531 214.933,110.838 L 215.427,108.192 L 217.781,108.192 L 216.66,114.025 z"
- id="path95"
- <path
- display="inline"
- d="M 225.898,110.034 C 225.404,109.854 224.843,109.787 224.306,109.787 C 222.982,109.787 222.308,110.37 222.308,111.223 C 222.308,112.816 225.472,113.375 225.472,115.842 C 225.472,117.703 223.833,119.567 220.536,119.567 C 219.798,119.567 219.19,119.499 218.632,119.385 L 219.034,117.323 C 219.595,117.503 220.2,117.614 220.805,117.614 C 222.129,117.614 223.002,117.098 223.002,116.089 C 223.002,114.453 219.863,114.138 219.863,111.471 C 219.863,109.52 221.412,107.971 224.437,107.971 C 225.177,107.971 225.783,108.038 226.345,108.15 L 225.898,110.034 z"
- id="path97"
- <path
- display="inline"
- d="M 234.98,110.056 L 232.132,110.056 L 231.101,115.529 C 230.808,117.077 231.033,117.503 232.042,117.503 C 232.647,117.503 233.095,117.435 233.521,117.346 L 233.341,119.297 C 232.648,119.454 231.818,119.543 231.167,119.543 C 228.835,119.543 228.183,118.444 228.698,115.843 L 229.798,110.057 L 227.691,110.057 L 228.072,108.196 L 230.16,108.196 L 230.832,104.652 L 233.275,104.136 L 232.49,108.196 L 235.361,108.196 L 234.98,110.056 z"
- id="path99"
- <path
- display="inline"
- d="M 244.49,119.341 L 242.156,119.341 C 242.359,118.422 242.74,117.098 243.345,115.26 L 243.3,115.237 C 242.448,116.919 240.833,119.589 238.321,119.589 C 236.684,119.589 235.786,118.512 235.786,116.135 C 235.786,111.987 237.962,108.017 242.852,108.017 C 244.151,108.017 245.407,108.128 246.553,108.353 C 245.453,114.025 244.96,116.582 244.49,119.341 z M 242.449,109.877 C 239.467,109.877 238.211,113.128 238.211,115.708 C 238.211,116.986 238.59,117.523 239.219,117.523 C 241.104,117.523 243.233,113.42 243.727,110.885 L 243.885,110.077 C 243.48,109.967 243.009,109.877 242.449,109.877 z"
- id="path101"
- <path
- display="inline"
- d="M 250.228,119.341 L 247.873,119.341 L 250.004,108.195 L 252.359,108.195 L 250.228,119.341 z M 251.685,106.534 C 250.833,106.534 250.228,105.861 250.249,105.098 C 250.274,104.202 251.036,103.53 251.888,103.53 C 252.718,103.53 253.324,104.178 253.302,104.941 C 253.279,105.861 252.515,106.534 251.685,106.534 z"
- id="path103"
- <path
- display="inline"
- d="M 262.833,119.341 L 260.478,119.341 L 261.845,112.276 C 262.159,110.683 261.866,110.01 260.993,110.01 C 259.198,110.01 257.001,114.004 256.507,116.696 L 256.013,119.342 L 253.659,119.342 L 254.78,113.511 C 255.139,111.65 255.497,109.699 255.745,108.196 L 258.077,108.196 C 257.942,108.891 257.651,110.08 256.932,112.166 L 256.979,112.188 C 258.032,109.99 259.692,107.949 261.934,107.949 C 264.041,107.949 264.715,109.453 264.289,111.719 L 262.833,119.341 z"
- id="path105"
- <path
- display="inline"
- d="M 268.593,119.341 L 266.239,119.341 L 268.368,108.195 L 270.723,108.195 L 268.593,119.341 z M 270.052,106.534 C 269.198,106.534 268.593,105.861 268.616,105.098 C 268.639,104.202 269.401,103.53 270.255,103.53 C 271.085,103.53 271.689,104.178 271.667,104.941 C 271.644,105.861 270.882,106.534 270.052,106.534 z"
- id="path107"
- <path
- display="inline"
- d="M 281.199,119.341 L 278.844,119.341 L 280.211,112.276 C 280.525,110.683 280.232,110.01 279.359,110.01 C 277.564,110.01 275.367,114.004 274.873,116.696 L 274.381,119.342 L 272.026,119.342 L 273.149,113.511 C 273.506,111.65 273.866,109.699 274.112,108.196 L 276.446,108.196 C 276.309,108.891 276.018,110.08 275.3,112.166 L 275.347,112.188 C 276.4,109.99 278.06,107.949 280.302,107.949 C 282.409,107.949 283.083,109.453 282.657,111.719 L 281.199,119.341 z"
- id="path109"
- <path
- display="inline"
- d="M 293.105,120.215 C 292.568,123.065 290.773,125.016 286.466,125.016 C 285.21,125.016 284.2,124.836 283.349,124.568 L 283.91,122.302 C 284.783,122.728 285.906,122.953 286.916,122.953 C 289.137,122.953 290.436,122.1 290.887,119.811 C 291.178,118.286 291.446,117.433 292.141,115.326 L 292.096,115.326 C 291.289,116.918 289.674,119.588 287.164,119.588 C 285.525,119.588 284.629,118.511 284.629,116.134 C 284.629,111.986 286.826,108.016 291.693,108.016 C 292.994,108.016 294.248,108.127 295.392,108.352 L 293.105,120.215 z M 291.289,109.877 C 288.307,109.877 287.049,113.128 287.049,115.708 C 287.049,116.986 287.432,117.523 288.059,117.523 C 289.944,117.523 292.075,113.42 292.569,110.885 L 292.725,110.077 C 292.322,109.967 291.849,109.877 291.289,109.877 z"
- id="path111"
- </g>
- <g
- id="Incubation">
- <path
- display="inline"
- d="M 105.248,114.293 C 104.935,114.293 104.487,114.272 104.107,114.226 L 103.054,119.823 L 100.682,119.823 L 103.547,104.714 C 104.712,104.669 105.965,104.624 107.375,104.624 C 110.33,104.624 111.985,106.012 111.985,108.362 C 111.985,111.764 108.897,114.293 105.248,114.293 z M 106.95,106.615 C 106.345,106.615 105.966,106.615 105.562,106.66 L 104.51,112.168 C 104.823,112.234 105.159,112.257 105.54,112.257 C 107.666,112.257 109.479,110.712 109.479,108.697 C 109.479,107.443 108.808,106.615 106.95,106.615 z"
- id="path114"
- <path
- display="inline"
- d="M 119.617,110.778 C 117.76,110.242 115.677,113.957 115.027,117.359 L 114.558,119.822 L 112.207,119.822 L 113.326,114.002 C 113.617,112.436 113.998,110.354 114.289,108.697 L 116.572,108.697 C 116.416,109.614 116.124,110.712 115.52,112.457 L 115.564,112.479 C 116.795,109.927 118.07,108.137 120.109,108.473 L 119.617,110.778 z"
- id="path116"
- <path
- display="inline"
- d="M 124.021,120.045 C 121.088,120.045 119.813,118.591 119.813,116.062 C 119.813,111.518 122.768,108.474 126.372,108.474 C 129.416,108.474 130.626,110.153 130.626,112.526 C 130.625,117.091 127.424,120.045 124.021,120.045 z M 126.013,110.51 C 123.73,110.51 122.274,113.129 122.274,115.68 C 122.274,117.137 122.856,117.987 124.357,117.987 C 126.461,117.987 128.14,115.705 128.14,112.794 C 128.139,111.316 127.49,110.51 126.013,110.51 z"
- id="path118"
- <path
- display="inline"
- d="M 134.114,121.008 C 133.553,123.873 132.256,125.463 129.302,125.463 C 128.765,125.463 128.249,125.373 127.823,125.262 L 128.316,123.201 C 128.719,123.359 129.19,123.448 129.547,123.448 C 130.912,123.448 131.427,122.732 131.83,120.649 L 134.135,108.697 L 136.464,108.697 L 134.114,121.008 z M 135.747,107.041 C 134.921,107.041 134.315,106.369 134.338,105.608 C 134.36,104.712 135.121,104.041 135.971,104.041 C 136.8,104.041 137.404,104.69 137.382,105.451 C 137.361,106.369 136.6,107.041 135.747,107.041 z"
- id="path120"
- <path
- display="inline"
- d="M 140.292,115.076 C 140.246,115.368 140.201,115.859 140.201,116.195 C 140.201,117.717 140.761,118.12 142.44,118.12 C 143.493,118.12 144.633,117.875 145.619,117.471 L 145.619,119.352 C 144.477,119.778 143.112,120.045 141.657,120.045 C 138.971,120.045 137.806,118.859 137.806,116.352 C 137.806,111.899 140.403,108.474 143.983,108.474 C 146.536,108.474 147.409,109.772 147.409,111.092 C 147.409,113.6 144.879,114.919 140.292,115.076 z M 143.715,110.264 C 142.104,110.264 141.028,111.719 140.582,113.42 C 143.626,113.308 145.059,112.682 145.059,111.406 C 145.058,110.667 144.543,110.264 143.715,110.264 z"
- id="path122"
- <path
- display="inline"
- d="M 156.72,110.891 C 156.183,110.645 155.554,110.489 154.816,110.489 C 152.22,110.489 151.035,113.398 151.035,115.727 C 151.035,116.868 151.437,117.92 153.183,117.92 C 153.99,117.92 154.839,117.74 155.511,117.427 L 155.331,119.531 C 154.548,119.799 153.563,120.023 152.511,120.023 C 149.577,120.023 148.527,118.478 148.527,116.261 C 148.527,112.009 150.966,108.495 154.972,108.495 C 155.847,108.495 156.562,108.606 157.279,108.808 L 156.72,110.891 z"
- id="path124"
- <path
- display="inline"
- d="M 165.242,110.555 L 162.398,110.555 L 161.369,116.016 C 161.078,117.563 161.301,117.987 162.308,117.987 C 162.913,117.987 163.359,117.921 163.785,117.831 L 163.607,119.778 C 162.914,119.934 162.084,120.024 161.437,120.024 C 159.107,120.024 158.458,118.927 158.972,116.331 L 160.07,110.556 L 157.965,110.556 L 158.348,108.699 L 160.43,108.699 L 161.102,105.162 L 163.54,104.648 L 162.757,108.699 L 165.622,108.699 L 165.242,110.555 z"
- id="path126"
- <path
- display="inline"
- d="M 173.585,119.822 L 171.233,119.822 L 173.36,108.697 L 175.71,108.697 L 173.585,119.822 z M 175.039,107.041 C 174.189,107.041 173.586,106.369 173.607,105.608 C 173.63,104.712 174.392,104.041 175.242,104.041 C 176.07,104.041 176.674,104.69 176.652,105.451 C 176.628,106.369 175.867,107.041 175.039,107.041 z"
- id="path128"
- <path
- display="inline"
- d="M 186.164,119.822 L 183.814,119.822 L 185.181,112.771 C 185.492,111.181 185.202,110.509 184.329,110.509 C 182.536,110.509 180.343,114.493 179.85,117.179 L 179.36,119.822 L 177.008,119.822 L 178.127,114.002 C 178.484,112.145 178.844,110.196 179.088,108.697 L 181.418,108.697 C 181.283,109.391 180.992,110.578 180.277,112.659 L 180.32,112.681 C 181.373,110.488 183.029,108.451 185.267,108.451 C 187.372,108.451 188.042,109.949 187.619,112.211 L 186.164,119.822 z"
- id="path130"
- <path
- display="inline"
- d="M 196.859,119.822 L 194.464,119.822 L 197.329,104.713 L 199.724,104.713 L 196.859,119.822 z"
- id="path132"
- <path
- display="inline"
- d="M 209.417,119.822 L 207.065,119.822 L 208.43,112.771 C 208.744,111.181 208.451,110.509 207.58,110.509 C 205.789,110.509 203.596,114.493 203.103,117.179 L 202.609,119.822 L 200.259,119.822 L 201.38,114.002 C 201.737,112.145 202.095,110.196 202.341,108.697 L 204.669,108.697 C 204.534,109.391 204.245,110.578 203.526,112.659 L 203.573,112.681 C 204.624,110.488 206.28,108.451 208.518,108.451 C 210.622,108.451 211.293,109.949 210.868,112.211 L 209.417,119.822 z"
- id="path134"
- <path
- display="inline"
- d="M 221.054,110.891 C 220.517,110.645 219.89,110.489 219.15,110.489 C 216.556,110.489 215.371,113.398 215.371,115.727 C 215.371,116.868 215.771,117.92 217.517,117.92 C 218.324,117.92 219.175,117.74 219.847,117.427 L 219.667,119.531 C 218.882,119.799 217.899,120.023 216.845,120.023 C 213.913,120.023 212.863,118.478 212.863,116.261 C 212.863,112.009 215.302,108.495 219.308,108.495 C 220.181,108.495 220.898,108.606 221.615,108.808 L 221.054,110.891 z"
- id="path136"
- <path
- display="inline"
- d="M 232.111,114.517 C 231.754,116.398 231.394,118.368 231.127,119.823 L 228.822,119.823 C 228.955,119.128 229.246,117.942 229.939,115.86 L 229.896,115.838 C 228.865,118.032 227.21,120.069 224.97,120.069 C 222.866,120.069 222.195,118.57 222.62,116.309 L 224.073,108.698 L 226.403,108.698 L 225.059,115.749 C 224.745,117.339 225.038,118.01 225.909,118.01 C 227.702,118.01 229.895,114.027 230.386,111.34 L 230.88,108.698 L 233.23,108.698 L 232.111,114.517 z"
- id="path138"
- <path
- display="inline"
- d="M 238.244,120.002 C 236.855,120.002 235.646,119.867 234.551,119.62 L 237.639,103.481 L 239.967,103.481 L 239.004,108.585 C 238.826,109.503 238.533,110.488 237.774,112.748 L 237.819,112.771 C 238.938,110.308 240.616,108.451 242.743,108.451 C 244.399,108.451 245.294,109.525 245.294,111.898 C 245.292,116.039 243.123,120.002 238.244,120.002 z M 241.869,110.51 C 239.988,110.51 237.84,114.607 237.369,117.091 L 237.213,117.942 C 237.639,118.054 238.086,118.143 238.645,118.143 C 241.624,118.143 242.877,114.898 242.877,112.324 C 242.876,111.047 242.496,110.51 241.869,110.51 z"
- id="path140"
- <path
- display="inline"
- d="M 255.296,119.822 L 252.968,119.822 C 253.171,118.904 253.55,117.584 254.156,115.748 L 254.111,115.727 C 253.261,117.405 251.65,120.069 249.142,120.069 C 247.509,120.069 246.613,118.995 246.613,116.622 C 246.613,112.48 248.785,108.518 253.664,108.518 C 254.961,108.518 256.215,108.631 257.357,108.854 C 256.259,114.517 255.767,117.068 255.296,119.822 z M 253.261,110.376 C 250.284,110.376 249.031,113.621 249.031,116.195 C 249.031,117.47 249.41,118.008 250.039,118.008 C 251.918,118.008 254.043,113.911 254.537,111.382 L 254.693,110.577 C 254.291,110.465 253.82,110.376 253.261,110.376 z"
- id="path142"
- <path
- display="inline"
- d="M 265.837,110.555 L 262.993,110.555 L 261.964,116.016 C 261.675,117.563 261.898,117.987 262.905,117.987 C 263.51,117.987 263.958,117.921 264.384,117.831 L 264.204,119.778 C 263.511,119.934 262.683,120.024 262.032,120.024 C 259.704,120.024 259.055,118.927 259.571,116.331 L 260.667,110.556 L 258.563,110.556 L 258.942,108.699 L 261.024,108.699 L 261.696,105.162 L 264.135,104.648 L 263.354,108.699 L 266.219,108.699 L 265.837,110.555 z"
- id="path144"
- <path
- display="inline"
- d="M 268.97,119.822 L 266.62,119.822 L 268.747,108.697 L 271.097,108.697 L 268.97,119.822 z M 270.425,107.041 C 269.575,107.041 268.97,106.369 268.993,105.608 C 269.014,104.712 269.774,104.041 270.626,104.041 C 271.454,104.041 272.058,104.69 272.036,105.451 C 272.015,106.369 271.253,107.041 270.425,107.041 z"
- id="path146"
- <path
- display="inline"
- d="M 276.646,120.045 C 273.714,120.045 272.439,118.591 272.439,116.062 C 272.439,111.518 275.392,108.474 278.998,108.474 C 282.041,108.474 283.252,110.153 283.252,112.526 C 283.251,117.091 280.05,120.045 276.646,120.045 z M 278.64,110.51 C 276.357,110.51 274.9,113.129 274.9,115.68 C 274.9,117.137 275.482,117.987 276.982,117.987 C 279.087,117.987 280.765,115.705 280.765,112.794 C 280.765,111.316 280.117,110.51 278.64,110.51 z"
- id="path148"
- <path
- display="inline"
- d="M 293.679,119.822 L 291.327,119.822 L 292.694,112.771 C 293.006,111.181 292.715,110.509 291.844,110.509 C 290.051,110.509 287.858,114.493 287.365,117.179 L 286.873,119.822 L 284.523,119.822 L 285.642,114.002 C 285.999,112.145 286.359,110.196 286.603,108.697 L 288.931,108.697 C 288.796,109.391 288.507,110.578 287.79,112.659 L 287.835,112.681 C 288.888,110.488 290.542,108.451 292.782,108.451 C 294.886,108.451 295.557,109.949 295.132,112.211 L 293.679,119.822 z"
- id="path150"
- </g>
- <g
- id="Project"
- display="inline"
- style="display:inline">
- <path
- id="path153"
- style="fill:#0054a4" />
- <path
- id="path155"
- <path
- id="path157"
- <path
- id="path159"
- <path
- id="path161"
- <path
- id="path163"
- <path
- id="path165"
- </g>
- <g
- id="Your_Open_Source_Compass">
- <path
- display="inline"
- d="M 87.951,115.211 L 87.082,119.959 L 85.378,119.959 L 86.248,115.211 L 83.902,106.766 L 85.681,106.766 L 86.853,111.225 C 87.061,112.004 87.231,112.768 87.383,113.51 L 87.402,113.51 C 87.839,112.709 88.385,111.851 88.934,110.969 L 91.582,106.766 L 93.492,106.766 L 87.951,115.211"
- id="path168"
- style="fill:#a0ce67;display:inline" />
- <path
- display="inline"
- d="M 94.741,120.137 C 92.375,120.137 91.297,118.907 91.297,116.678 C 91.297,112.807 93.679,110.071 96.745,110.071 C 99.224,110.071 100.244,111.516 100.244,113.569 C 100.244,117.576 97.575,120.137 94.741,120.137 M 96.479,111.557 C 94.418,111.557 93.038,113.94 93.038,116.385 C 93.038,117.83 93.607,118.633 95.024,118.633 C 96.858,118.633 98.467,116.598 98.467,113.764 C 98.467,112.336 97.842,111.557 96.479,111.557"
- id="path170"
- <path
- display="inline"
- d="M 108.849,119.959 L 107.186,119.959 C 107.318,119.315 107.565,118.201 108.224,116.131 L 108.189,116.131 C 107.297,118.183 105.824,120.156 103.856,120.156 C 102.117,120.156 101.511,118.886 101.89,116.853 L 103.1,110.246 L 104.781,110.246 L 103.63,116.461 C 103.345,117.987 103.612,118.652 104.443,118.652 C 106.182,118.652 108.131,114.838 108.567,112.435 L 108.963,110.246 L 110.627,110.246 L 108.849,119.959"
- id="path172"
- <path
- display="inline"
- d="M 117.947,111.771 C 116.209,111.261 114.354,115.074 113.861,117.773 L 113.465,119.959 L 111.799,119.959 L 113.576,110.246 L 115.205,110.246 C 115.052,111.086 114.789,112.121 114.239,113.824 L 114.276,113.844 C 115.337,111.479 116.473,109.759 118.287,110.071 L 117.947,111.771"
- id="path174"
- <path
- display="inline"
- d="M 127.311,120.157 C 124.227,120.157 122.751,118.359 122.751,115.347 C 122.751,110.576 125.89,106.572 130.052,106.572 C 133.02,106.572 134.646,108.33 134.646,111.381 C 134.646,116.402 131.356,120.157 127.311,120.157 M 129.769,108.153 C 126.745,108.153 124.587,111.357 124.587,115.095 C 124.587,117.224 125.606,118.552 127.555,118.552 C 130.449,118.552 132.814,115.484 132.814,111.573 C 132.814,109.484 131.832,108.153 129.769,108.153"
- id="path176"
- <path
- display="inline"
- d="M 138.562,120.1 C 138.09,120.1 137.672,120.058 137.238,119.981 L 136.367,124.79 L 134.705,124.79 L 137.37,110.247 L 139.036,110.247 C 138.867,111.087 138.62,112.046 137.976,114.138 L 138.016,114.158 C 138.979,111.87 140.456,110.053 142.386,110.053 C 143.744,110.053 144.484,110.953 144.484,113.004 C 144.483,116.58 142.684,120.1 138.562,120.1 M 141.796,111.557 C 140.019,111.557 138.108,115.447 137.672,117.733 L 137.522,118.477 C 137.919,118.612 138.487,118.709 138.885,118.709 C 141.648,118.709 142.761,115.736 142.761,113.335 C 142.762,112.064 142.385,111.557 141.796,111.557"
- id="path178"
- <path
- display="inline"
- d="M 147.585,115.678 C 147.528,115.975 147.49,116.461 147.49,116.813 C 147.49,118.319 148.001,118.709 149.514,118.709 C 150.402,118.709 151.349,118.493 152.161,118.144 L 152.161,119.553 C 151.253,119.922 150.156,120.137 148.927,120.137 C 146.771,120.137 145.769,119.182 145.769,116.991 C 145.769,113.217 147.793,110.071 150.914,110.071 C 152.919,110.071 153.675,111.127 153.675,112.28 C 153.675,114.371 151.612,115.522 147.585,115.678 M 150.725,111.398 C 149.229,111.398 148.228,112.75 147.793,114.388 C 150.706,114.271 151.993,113.667 151.993,112.492 C 151.994,111.789 151.482,111.398 150.725,111.398"
- id="path180"
- <path
- display="inline"
- d="M 162.223,119.959 L 160.561,119.959 L 161.713,113.744 C 161.998,112.22 161.733,111.556 160.883,111.556 C 159.142,111.556 157.212,115.366 156.778,117.773 L 156.381,119.959 L 154.718,119.959 L 155.663,114.878 C 155.908,113.492 156.249,111.672 156.492,110.246 L 158.14,110.246 C 158.024,110.892 157.762,112.004 157.099,114.078 L 157.138,114.078 C 158.024,112.025 159.521,110.051 161.486,110.051 C 163.225,110.051 163.813,111.322 163.455,113.354 L 162.223,119.959"
- id="path182"
- <path
- display="inline"
- d="M 176.9,108.371 C 176.277,108.137 175.597,108.057 175.123,108.057 C 173.232,108.057 172.381,109.172 172.381,110.227 C 172.381,112.612 176.277,112.692 176.277,115.819 C 176.277,118.261 174.195,120.158 171.229,120.158 C 170.547,120.158 169.751,120.079 169.127,119.884 L 169.449,118.163 C 169.978,118.398 170.734,118.575 171.378,118.575 C 173.345,118.575 174.461,117.577 174.461,116.112 C 174.461,113.825 170.584,113.805 170.584,110.638 C 170.584,108.469 172.229,106.573 175.293,106.573 C 175.937,106.573 176.504,106.612 177.223,106.766 L 176.9,108.371"
- id="path184"
- <path
- display="inline"
- d="M 181.404,120.137 C 179.04,120.137 177.959,118.907 177.959,116.678 C 177.959,112.807 180.345,110.071 183.409,110.071 C 185.888,110.071 186.908,111.516 186.908,113.569 C 186.908,117.576 184.241,120.137 181.404,120.137 M 183.144,111.557 C 181.082,111.557 179.701,113.94 179.701,116.385 C 179.701,117.83 180.267,118.633 181.685,118.633 C 183.52,118.633 185.127,116.598 185.127,113.764 C 185.127,112.336 184.505,111.557 183.144,111.557"
- id="path186"
- <path
- display="inline"
- d="M 195.512,119.959 L 193.848,119.959 C 193.982,119.315 194.227,118.201 194.888,116.131 L 194.85,116.131 C 193.961,118.183 192.485,120.156 190.521,120.156 C 188.777,120.156 188.172,118.886 188.552,116.853 L 189.761,110.246 L 191.445,110.246 L 190.292,116.461 C 190.009,117.987 190.272,118.652 191.108,118.652 C 192.845,118.652 194.796,114.838 195.229,112.435 L 195.625,110.246 L 197.291,110.246 L 195.512,119.959"
- id="path188"
- <path
- display="inline"
- d="M 204.591,111.771 C 202.852,111.261 200.998,115.074 200.503,117.773 L 200.11,119.959 L 198.443,119.959 L 200.221,110.246 L 201.848,110.246 C 201.697,111.086 201.431,112.121 200.883,113.824 L 200.92,113.844 C 201.979,111.479 203.115,109.759 204.931,110.071 L 204.591,111.771"
- id="path190"
- <path
- display="inline"
- d="M 211.815,111.907 C 211.304,111.672 210.758,111.535 210.093,111.535 C 207.711,111.535 206.596,114.311 206.596,116.521 C 206.596,117.535 206.915,118.574 208.564,118.574 C 209.299,118.574 210.093,118.397 210.682,118.105 L 210.567,119.648 C 209.907,119.902 209.036,120.116 208.088,120.116 C 205.65,120.116 204.818,118.75 204.818,116.912 C 204.818,113.198 206.842,110.09 210.207,110.09 C 210.984,110.09 211.606,110.207 212.194,110.381 L 211.815,111.907"
- id="path192"
- <path
- display="inline"
- d="M 214.482,115.678 C 214.425,115.975 214.388,116.461 214.388,116.813 C 214.388,118.319 214.898,118.709 216.414,118.709 C 217.298,118.709 218.246,118.493 219.06,118.144 L 219.06,119.553 C 218.153,119.922 217.055,120.137 215.826,120.137 C 213.671,120.137 212.669,119.182 212.669,116.991 C 212.669,113.217 214.691,110.071 217.811,110.071 C 219.817,110.071 220.574,111.127 220.574,112.28 C 220.573,114.371 218.511,115.522 214.482,115.678 M 217.622,111.398 C 216.128,111.398 215.126,112.75 214.691,114.388 C 217.601,114.271 218.889,113.667 218.889,112.492 C 218.889,111.789 218.378,111.398 217.622,111.398"
- id="path194"
- <path
- display="inline"
- d="M 235.836,108.682 C 234.947,108.35 234.058,108.213 233.187,108.213 C 229.482,108.213 227.988,111.966 227.988,115.289 C 227.988,117.185 228.745,118.516 231.203,118.516 C 232.262,118.516 233.301,118.281 234.172,117.87 L 234.096,119.493 C 233.077,119.884 231.884,120.117 230.694,120.117 C 227.044,120.117 226.097,117.909 226.097,115.584 C 226.097,110.97 228.611,106.649 233.434,106.649 C 234.512,106.649 235.42,106.807 236.252,107.043 L 235.836,108.682"
- id="path196"
- <path
- display="inline"
- d="M 239.489,120.137 C 237.123,120.137 236.046,118.907 236.046,116.678 C 236.046,112.807 238.428,110.071 241.493,110.071 C 243.97,110.071 244.991,111.516 244.991,113.569 C 244.991,117.576 242.327,120.137 239.489,120.137 M 241.226,111.557 C 239.165,111.557 237.787,113.94 237.787,116.385 C 237.787,117.83 238.351,118.633 239.769,118.633 C 241.606,118.633 243.211,116.598 243.211,113.764 C 243.211,112.336 242.59,111.557 241.226,111.557"
- id="path198"
- <path
- display="inline"
- d="M 259.309,119.959 L 257.625,119.959 L 258.779,113.744 C 259.063,112.22 258.798,111.535 258.022,111.535 C 256.414,111.535 254.448,115.134 253.956,117.773 L 253.56,119.959 L 251.895,119.959 L 253.048,113.744 C 253.332,112.22 253.085,111.535 252.272,111.535 C 250.684,111.535 248.717,115.134 248.225,117.773 L 247.828,119.959 L 246.166,119.959 L 247.109,114.878 C 247.375,113.432 247.697,111.672 247.94,110.246 L 249.587,110.246 C 249.476,110.892 249.208,112.025 248.546,114.078 L 248.585,114.078 C 249.453,112.045 250.929,110.051 252.859,110.051 C 254.069,110.051 254.751,110.735 254.751,111.946 C 254.751,112.552 254.599,113.12 254.297,114.096 L 254.334,114.116 C 255.204,112.026 256.68,110.052 258.609,110.052 C 260.311,110.052 260.897,111.323 260.517,113.355 L 259.309,119.959"
- id="path200"
- <path
- display="inline"
- d="M 265.117,120.1 C 264.644,120.1 264.225,120.058 263.793,119.981 L 262.921,124.79 L 261.258,124.79 L 263.926,110.247 L 265.587,110.247 C 265.42,111.087 265.171,112.046 264.53,114.138 L 264.565,114.158 C 265.533,111.87 267.006,110.053 268.937,110.053 C 270.297,110.053 271.034,110.953 271.034,113.004 C 271.034,116.58 269.24,120.1 265.117,120.1 M 268.351,111.557 C 266.572,111.557 264.662,115.447 264.225,117.733 L 264.074,118.477 C 264.471,118.612 265.041,118.709 265.436,118.709 C 268.2,118.709 269.316,115.736 269.316,113.335 C 269.316,112.064 268.937,111.557 268.351,111.557"
- id="path202"
- <path
- display="inline"
- d="M 279.376,119.959 L 277.693,119.959 C 277.864,119.122 278.222,117.83 278.791,116.012 L 278.752,115.995 C 278.071,117.498 276.652,120.157 274.366,120.157 C 273.004,120.157 272.264,119.257 272.264,117.205 C 272.264,113.626 274.06,110.09 278.165,110.09 C 279.242,110.09 280.244,110.207 281.117,110.385 C 280.115,115.818 279.773,117.635 279.376,119.959 M 277.881,111.479 C 275.083,111.479 273.986,114.467 273.986,116.872 C 273.986,118.144 274.366,118.653 274.951,118.653 C 276.727,118.653 278.657,114.762 279.092,112.436 L 279.228,111.657 C 278.847,111.557 278.413,111.479 277.881,111.479"
- id="path204"
- <path
- display="inline"
- d="M 287.983,111.635 C 287.527,111.479 287.038,111.399 286.567,111.399 C 285.335,111.399 284.691,112.004 284.691,112.827 C 284.691,114.372 287.546,114.78 287.546,116.972 C 287.546,118.593 286.167,120.138 283.499,120.138 C 282.875,120.138 282.363,120.101 281.892,120 L 282.194,118.438 C 282.686,118.592 283.195,118.692 283.726,118.692 C 284.955,118.692 285.787,118.183 285.787,117.167 C 285.787,115.624 282.95,115.367 282.95,113.022 C 282.95,111.358 284.237,110.071 286.677,110.071 C 287.34,110.071 287.814,110.13 288.287,110.208 L 287.983,111.635"
- id="path206"
- <path
- display="inline"
- d="M 295.095,111.635 C 294.639,111.479 294.15,111.399 293.674,111.399 C 292.445,111.399 291.802,112.004 291.802,112.827 C 291.802,114.372 294.657,114.78 294.657,116.972 C 294.657,118.593 293.279,120.138 290.612,120.138 C 289.988,120.138 289.474,120.101 289.002,120 L 289.307,118.438 C 289.797,118.592 290.309,118.692 290.836,118.692 C 292.065,118.692 292.9,118.183 292.9,117.167 C 292.9,115.624 290.06,115.367 290.06,113.022 C 290.06,111.358 291.348,110.071 293.787,110.071 C 294.45,110.071 294.922,110.13 295.394,110.208 L 295.095,111.635"
- id="path208"
- </g>
-</g>
-<g
- id="OSGeo"
- display="none"
- style="display:none">
- <path
- display="inline"
- d="M 107.322,56.194 C 103.756,60.995 101.945,67.04 101.945,74.162 C 101.945,81.726 103.717,88.016 107.221,92.861 C 110.742,97.736 115.686,100.209 121.919,100.209 C 128.744,100.209 134.062,97.869 137.731,93.26 C 141.38,88.664 143.234,82.239 143.234,74.162 C 143.234,66.277 141.385,60.04 137.742,55.616 C 134.089,51.173 128.765,48.92 121.919,48.92 C 115.821,48.92 110.914,51.37 107.322,56.194 M 112.797,88.125 C 110.62,84.412 109.516,79.713 109.516,74.162 C 109.516,68.392 110.592,63.775 112.708,60.444 C 114.804,57.149 117.905,55.478 121.922,55.478 C 131.167,55.478 135.659,61.589 135.659,74.163 C 135.659,80.329 134.468,85.181 132.121,88.579 C 129.796,91.944 126.363,93.649 121.922,93.649 C 118.018,93.648 114.95,91.791 112.797,88.125"
- id="path211"
- style="fill:#49a942;display:inline" />
- <path
- display="inline"
- d="M 151.834,52.611 C 149.191,55.063 147.853,58.197 147.853,61.923 C 147.853,64.97 148.537,67.625 149.887,69.801 C 151.236,71.981 153.633,73.885 157.019,75.461 L 160.965,77.308 C 164.447,78.95 166.647,80.476 167.497,81.844 C 168.347,83.213 168.777,84.717 168.777,86.311 C 168.777,88.434 168.009,90.206 166.491,91.573 C 164.97,92.949 162.92,93.649 160.388,93.649 C 158.954,93.649 157.304,93.346 155.478,92.74 C 153.653,92.14 152.112,91.382 150.895,90.483 L 150.609,90.272 L 147.962,96.961 L 148.142,97.08 C 151.253,99.156 155.054,100.209 159.441,100.209 C 164.44,100.209 168.488,98.89 171.482,96.287 C 174.488,93.678 176.014,90.454 176.014,86.703 C 176.014,83.275 175.319,80.408 173.945,78.173 C 172.57,75.939 170.156,73.994 166.771,72.395 L 162.749,70.485 C 160.187,69.247 158.47,68.28 157.656,67.603 C 156.853,66.942 156.217,66.106 155.768,65.122 C 155.316,64.131 155.087,63.018 155.087,61.811 C 155.087,59.862 155.722,58.244 156.973,57.006 C 158.223,55.766 159.976,55.139 162.178,55.1
39 C 163.706,55.139 165.398,55.442 167.201,56.034 C 169.002,56.63 170.356,57.252 171.23,57.883 L 171.525,58.103 L 173.684,51.749 L 173.543,51.63 C 171.375,49.835 167.5,48.922 162.021,48.922 C 157.899,48.92 154.469,50.162 151.834,52.611"
- id="path213"
- <path
- display="inline"
- d="M 187.21,56.094 C 182.896,60.845 180.706,67.123 180.706,74.746 C 180.706,82.392 182.702,88.61 186.64,93.228 C 190.589,97.858 196.043,100.208 202.853,100.208 C 205.869,100.208 209.024,99.731 212.224,98.804 C 215.436,97.872 217.978,96.616 219.784,95.081 L 219.882,95.002 L 219.882,73.232 L 205.869,73.232 L 205.869,79.451 L 212.647,79.451 L 212.647,90.566 C 210.512,92.605 207.693,93.648 204.258,93.648 C 199.348,93.648 195.421,91.935 192.578,88.549 C 189.725,85.153 188.282,80.599 188.282,75.017 C 188.282,69.142 189.754,64.361 192.661,60.809 C 195.556,57.27 199.562,55.477 204.577,55.477 C 207.729,55.477 211.002,56.72 214.303,59.165 L 214.563,59.357 L 217.576,53.362 L 217.416,53.224 C 214.169,50.37 209.916,48.919 204.771,48.919 C 197.441,48.92 191.531,51.336 187.21,56.094"
- id="path215"
- <path
- display="inline"
- d="M 231.083,67.17 C 227.454,70.781 225.612,75.63 225.612,81.588 C 225.612,87.332 227.408,91.966 230.946,95.375 C 234.13,98.467 238.05,100.036 242.607,100.036 C 245.75,100.036 248.635,99.555 251.2,98.601 C 253.252,97.872 254.806,96.991 255.812,95.974 L 255.958,95.826 L 253.01,90.787 L 252.767,91.007 C 250.4,93.097 247.401,94.158 243.849,94.158 C 240.745,94.158 238.178,93.191 236.211,91.287 C 234.031,89.146 232.918,86.041 232.868,82.078 L 258.629,82.078 L 258.683,81.879 C 259.023,80.676 259.195,79.344 259.195,77.92 C 259.195,73.289 257.752,69.516 254.896,66.707 C 251.956,63.787 247.848,62.305 242.689,62.305 C 238.238,62.305 234.337,63.944 231.083,67.17 M 236.043,70.855 C 237.897,69.084 240.231,68.185 242.975,68.185 C 245.913,68.185 248.268,69.099 249.966,70.907 C 251.453,72.502 252.193,74.524 252.252,76.875 L 233.097,76.875 C 233.389,74.508 234.345,72.465 236.043,70.855"
- id="path217"
- <path
- display="inline"
- d="M 268.197,67.503 C 265.186,70.942 263.659,75.51 263.659,81.088 C 263.659,86.838 265.122,91.484 268.011,94.889 C 270.907,98.304 274.997,100.036 280.172,100.036 C 285.232,100.036 289.285,98.322 292.23,94.939 C 295.163,91.566 296.648,86.908 296.648,81.087 C 296.648,75.247 295.196,70.608 292.33,67.302 C 289.453,63.986 285.365,62.304 280.173,62.304 C 275.246,62.305 271.214,64.054 268.197,67.503 M 270.895,81.088 C 270.895,77.008 271.751,73.768 273.437,71.458 C 275.107,69.176 277.371,68.02 280.171,68.02 C 286.388,68.02 289.413,72.291 289.413,81.088 C 289.413,85.191 288.579,88.465 286.932,90.824 C 285.309,93.148 283.035,94.324 280.171,94.324 C 273.928,94.324 270.895,89.996 270.895,81.088"
- id="path219"
-</g>
-<g
- id="g844"
- transform="matrix(0.4044353,0,0,0.4044353,44.395399,-41.669222)"><path
- transform="matrix(1.04752,0,0,1.05,-36.7186,-19.064)"
- style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
- sodipodi:type="arc"
- sodipodi:ry="218.44479"
- sodipodi:rx="219.86943"
- sodipodi:cy="257.81122"
- sodipodi:cx="273.056"
- id="path575"
- d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /><path
- style="fill:#00bd00;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
- sodipodi:nodetypes="cccccccccc"
- id="path580"
- d="M 118.71999,81.155861 C 62.684157,159.03618 47.487998,116.29698 61.734397,159.98594 C 75.980792,203.67489 37.990399,236.91649 89.277432,202.72513 C 140.56447,168.53378 129.16735,121.04578 171.90655,157.13666 C 214.64575,193.22753 259.28446,148.58882 235.54047,206.52417 C 211.79647,264.45953 246.93759,348.98817 278.27966,249.26337 C 309.62174,149.53858 235.54047,202.72513 265.93278,130.54338 C 296.3251,58.361623 342.86334,42.215703 287.77726,29.868824 C 212.74623,67.859222 181.40415,114.39746 151.01183,90.653461 C 120.61951,66.909463 120.61951,82.105621 118.71999,81.155861 z" /><path
- sodipodi:nodetypes="cccccccc"
- id="path586"
- d="M 405.5475,188.47874 C 395.10014,254.96193 400.7987,277.75617 366.60734,273.00737 C 332.41598,268.25857 303.92318,255.91169 328.61694,304.34945 C 353.3107,352.78721 413.14558,311.94753 380.85374,361.33505 C 348.5619,410.72256 373.25566,419.2704 303.92318,443.96416 C 234.59071,468.65792 255.48543,480.05504 262.13375,481.0048 C 308.67199,479.10528 464.43261,442.06465 479.62877,264.45953 C 446.38718,132.4429 406.49726,190.37826 405.5475,188.47874 z" /><path
- id="path587"
- d="M 83.578876,378.43073 C 98.775035,351.83745 101.62431,338.54081 120.61951,351.83745 C 139.61471,365.13409 125.36831,360.38529 160.50943,374.63169 C 195.65055,388.87809 187.10271,349.93793 207.99743,377.48097 C 228.89215,405.02401 202.29887,402.17473 194.70079,426.86848 C 187.10271,451.56224 136.76543,454.41152 136.76543,443.0144 C 136.76543,431.61728 96.875515,447.7632 83.578876,378.43073 z" /><path
- style="fill:#b77719;fill-opacity:1;fill-rule:evenodd;stroke:none;stroke-width:1pt;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
- sodipodi:nodetypes="ccccccc"
- id="path606"
- d="M 267.83231,69.758743 C 258.33471,61.210903 218.44479,116.29698 185.20319,114.39746 C 151.96159,112.49794 144.36351,112.49794 113.97119,122.9453 C 83.578875,133.39266 73.131516,183.72994 98.775031,175.1821 C 106.37311,143.84002 167.15775,119.14626 194.70079,130.54338 C 222.24383,141.9405 237.43999,164.73474 248.83711,173.28258 C 245.98783,110.59842 250.73663,109.64866 267.83231,69.758743 z" /><path
- sodipodi:nodetypes="ccccc"
- id="path607"
- d="M 107.32287,381.28001 C 117.77023,389.82785 133.91615,408.82305 148.16255,394.57665 C 186.15295,392.67713 204.19839,379.38049 191.85151,399.32545 C 151.96159,404.07424 183.30367,431.61728 147.21279,435.41632 C 140.56447,428.768 80.729596,395.52641 107.32287,381.28001 z" /><path
- id="path608"
- d="M 432.14078,216.02178 C 431.19102,238.81601 468.23165,301.50017 432.14078,299.60065 C 396.0499,297.70113 376.10494,288.20353 378.95422,300.55041 C 381.8035,312.89729 425.49246,310.04801 425.49246,333.79201 C 425.49246,357.53601 381.8035,411.67232 362.8083,428.768 C 343.8131,445.86368 308.67198,454.41152 299.17438,464.85888 C 441.63837,461.05984 520.46845,233.11746 432.14078,216.02178 z" /><path
- style="fill:url(#radialGradient579);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt"
- id="path588"
- d="M 492.92543,257.81122 A 219.86943,218.44479 0 1 1 53.186569,257.81122 A 219.86943,218.44479 0 1 1 492.92543,257.81122 z" /></g><path
- style="fill:#ff0000"
- id="path3827"
- sodipodi:cx="211.1405"
- sodipodi:cy="125.87266"
- sodipodi:rx="48.595829"
- sodipodi:ry="15.36075"
- d="M 259.73633,125.87266 A 48.595829,15.36075 0 1 1 162.54467,125.87266 A 48.595829,15.36075 0 1 1 259.73633,125.87266 z"
- transform="matrix(2.8312969,-2.8697982,2.968043,2.7375785,-823.30798,323.61993)" /><path
- style="fill:#ffffff;overflow:visible"
- id="path3831"
- transform="matrix(2.6583088,-2.5712068,2.3656048,2.8890136,-711.24771,239.70023)"
- inkscape:transform-center-x="14.643913"
- inkscape:transform-center-y="-12.23846" /><g
- id="g5044"
- transform="translate(-240.07435,-0.4346669)"><path
- sodipodi:nodetypes="cssssz"
- id="path4991"
- d="M 411.9947,92.414881 C 380.30504,121.70083 328.17179,138.70697 313.17635,120.23247 C 298.1809,101.75797 290.20452,77.537893 292.80966,51.961217 C 298.01994,0.80785346 343.59299,-36.496733 394.53522,-31.307958 C 420.00633,-28.713571 442.02084,-15.984644 457.01628,2.4898569 C 472.01172,20.964358 443.47194,63.325235 411.9947,92.414881 z"
- style="fill:#0000ff;fill-opacity:1;fill-rule:evenodd;stroke-width:3pt" /><path
- id="path4993"
- d="M 332.27987,-7.587752 C 309.61701,23.909798 303.47114,6.624557 309.23289,24.293915 C 314.99463,41.963268 299.62998,55.407345 320.37226,41.579152 C 341.11455,27.750963 336.50516,8.5451393 353.7904,23.141565 C 371.07564,37.737987 389.12911,19.684517 379.5262,43.115618 C 369.92329,66.546722 384.1356,100.73309 396.81144,60.400859 C 409.48728,20.068633 379.5262,41.579152 391.81792,12.386304 C 404.10965,-16.806546 422.93136,-23.336526 400.6526,-28.33004 C 370.30741,-12.965382 357.63156,5.8563241 345.33983,-3.7465873 C 333.04811,-13.349498 333.04811,-7.2036355 332.27987,-7.587752 z" /><path
- id="path4997"
- d="M 310.16816,89.337436 C 316.31402,78.582176 317.46637,73.204543 325.1487,78.582176 C 332.83103,83.959806 327.06928,82.039226 341.28159,87.800966 C 355.4939,93.562716 352.03685,77.813936 360.48741,88.953316 C 368.93798,100.0927 358.18271,98.940346 355.10978,108.92737 C 352.03685,118.9144 331.67868,120.06675 331.67868,115.45735 C 331.67868,110.84796 315.54579,117.37794 310.16816,89.337436 z" /><path
- id="path4999"
- d="M 392.58616,-12.197149 C 388.745,-15.654197 372.6121,6.624557 359.16803,5.8563241 C 345.72395,5.0880911 342.65102,5.0880911 330.35929,9.3133723 C 318.06757,13.538653 313.84229,33.896826 324.21343,30.439778 C 327.28636,17.763935 351.86981,7.7769064 363.00919,12.386304 C 374.14857,16.995702 380.29443,26.214497 384.90383,29.671545 C 383.75148,4.3198582 385.67206,3.9357417 392.58616,-12.197149 z" /><path
- id="path5001"
- d="M 319.77107,90.489786 C 323.99635,93.946836 330.52633,101.62917 336.28808,95.867416 C 351.65273,95.099186 358.95095,89.721556 353.95743,97.787996 C 337.82454,99.708576 350.50038,110.84796 335.90396,112.38442 C 333.21514,109.69561 309.01581,96.251536 319.77107,90.489786 z" /></g><path
- id="path5005"
- style="fill:url(#radialGradient5042);fill-opacity:1;fill-rule:evenodd;stroke-width:3pt;stroke:#a1ce67;stroke-opacity:1"
- transform="matrix(0.4236541,0,0,0.4246571,644.63706,-29.556585)" /><text
- xml:space="preserve"
- style="font-size:68.2170105px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- x="1.238516"
- y="123.91986"
- id="text2616"
- transform="matrix(0.6729437,1.3274402e-2,-1.3444666e-2,1.4857432,0,0)"><tspan
- sodipodi:role="line"
- id="tspan2618"
- x="1.238516"
- y="123.91986"
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;font-family:Sans;-inkscape-font-specification:Sans Bold">Ma<tspan
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#0000ff;font-family:Sans;-inkscape-font-specification:Sans Bold"
- id="tspan3823">p</tspan><tspan
- style="font-style:normal;font-variant:normal;font-weight:bold;font-stretch:normal;fill:#ff0000;font-family:Sans;-inkscape-font-specification:Sans Bold"
- id="tspan3825">b</tspan>ender</tspan></text>
-</svg>
\ No newline at end of file
Deleted: trunk/documents/logos/mb_db2.svg
--- trunk/documents/logos/mb_db2.svg 2010-08-10 07:59:05 UTC (rev 6726)
+++ trunk/documents/logos/mb_db2.svg 2010-08-10 08:01:11 UTC (rev 6727)
@@ -1,254 +0,0 @@
-<?xml version="1.0" encoding="UTF-8" standalone="no"?>
-<!-- Created with Inkscape (http://www.inkscape.org/) -->
-<svg
- xmlns:dc="http://purl.org/dc/elements/1.1/"
- xmlns:cc="http://creativecommons.org/ns#"
- xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
- xmlns:svg="http://www.w3.org/2000/svg"
- xmlns="http://www.w3.org/2000/svg"
- xmlns:xlink="http://www.w3.org/1999/xlink"
- xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
- xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
- width="1000"
- height="1000"
- id="svg2"
- sodipodi:version="0.32"
- inkscape:version="0.46"
- version="1.0"
- sodipodi:docname="mb_db2.svg"
- inkscape:output_extension="org.inkscape.output.svg.inkscape"
- inkscape:export-filename="/home/seven/data/work/mapbender/logo/mb_db.png"
- inkscape:export-xdpi="12.24"
- inkscape:export-ydpi="12.24">
- <defs
- id="defs4">
- <inkscape:perspective
- sodipodi:type="inkscape:persp3d"
- inkscape:vp_x="0 : 526.18109 : 1"
- inkscape:vp_y="0 : 1000 : 0"
- inkscape:vp_z="744.09448 : 526.18109 : 1"
- inkscape:persp3d-origin="372.04724 : 350.78739 : 1"
- id="perspective10" />
- id="perspective2447"
- sodipodi:type="inkscape:persp3d" />
- <radialGradient
- xlink:href="#linearGradient583"
- r="0.40413386"
- id="radialGradient582"
- fy="0.22549020"
- fx="0.68367344"
- cy="0.22549020"
- cx="0.68367344" />
- <radialGradient
- r="123.08747"
- id="radialGradient579"
- fy="183.44996"
- fx="201.95493"
- cy="183.44996"
- cx="201.95493"
- gradientTransform="scale(1.0032556,0.996755)"
- gradientUnits="userSpaceOnUse" />
- <linearGradient
- id="linearGradient576">
- <stop
- style="stop-color: rgb(0, 108, 255); stop-opacity: 1;"
- offset="0.00000000"
- id="stop577" />
- <stop
- style="stop-color: rgb(0, 0, 255); stop-opacity: 1;"
- offset="1.00000000"
- id="stop578" />
- </linearGradient>
- <linearGradient
- id="linearGradient583">
- <stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.466667;"
- id="stop584" />
- <stop
- style="stop-color: rgb(255, 255, 255); stop-opacity: 0.108333;"
- id="stop585" />
- </linearGradient>
- id="perspective3349"
- inkscape:persp3d-origin="250 : 166.66667 : 1"
- inkscape:vp_z="500 : 250 : 1"
- inkscape:vp_x="0 : 250 : 1"
- </defs>
- <sodipodi:namedview
- id="base"
- pagecolor="#ffffff"
- bordercolor="#666666"
- borderopacity="1.0"
- gridtolerance="10000"
- guidetolerance="10"
- objecttolerance="10"
- inkscape:pageopacity="0.0"
- inkscape:pageshadow="2"
- inkscape:zoom="0.45254834"
- inkscape:cx="365.28142"
- inkscape:cy="484.30843"
- inkscape:document-units="px"
- inkscape:current-layer="layer1"
- showgrid="false"
- inkscape:window-width="1400"
- inkscape:window-height="975"
- inkscape:window-x="0"
- inkscape:window-y="25" />
- <metadata
- id="metadata7">
- <rdf:RDF>
- <cc:Work
- rdf:about="">
- <dc:format>image/svg+xml</dc:format>
- <dc:type
- rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
- </cc:Work>
- </rdf:RDF>
- </metadata>
- <g
- inkscape:label="Layer 1"
- inkscape:groupmode="layer"
- id="layer1">
- <rect
- style="opacity:1;fill:#ffffff;fill-opacity:1;stroke:#000000;stroke-width:0;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
- id="rect3371"
- width="1000.1917"
- height="766.09583"
- x="2.7612932"
- y="-0.63721448" />
- <path
- style="opacity:1;fill:#008000;fill-opacity:1;stroke:#d4d6d8;stroke-width:0;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1"
- id="path3450"
- sodipodi:cx="-234.35539"
- sodipodi:cy="-1101.1173"
- sodipodi:rx="387.89859"
- sodipodi:ry="161.6244"
- d="M 153.5432,-1101.1173 A 387.89859,161.6244 0 1 1 -622.25398,-1101.1173 A 387.89859,161.6244 0 1 1 153.5432,-1101.1173 z"
- transform="matrix(1.2493404,0,0,0.9308082,801.77636,1615.5572)" />
- <rect
- id="rect3454"
- width="969.23474"
- height="421.23575"
- x="24.470806"
- y="167.30396" />
- <path
- style="opacity:1;fill:#ff0000;fill-opacity:1;stroke:#d4d6d8;stroke-width:0;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1"
- id="path3448"
- transform="matrix(1.2493404,0,0,0.9308082,804.275,1180.9121)" />
- <g
- id="g3476"
- transform="matrix(-1.5308565,-0.3451449,0.3520797,-1.5616152,915.4743,1764.1036)">
- <path
- sodipodi:nodetypes="csscscc"
- id="path3239"
- d="M 648.126,630.73462 C 653.80739,657.21094 687.19916,734.83462 638.31741,763.48641 C 589.43567,792.13825 586.72198,782.30677 474.70917,797.81815 C 352.72151,814.71084 304.14617,870.40061 250.00929,873.8446 C 195.87243,877.28862 163.86111,747.11099 181.0472,726.18465 C 249.16702,643.23977 329.46623,615.6431 404.25244,588.3884 C 576.14643,556.14803 636.76323,577.78199 648.126,630.73462 z"
- style="fill:#0000ff;fill-opacity:1;stroke:#000000;stroke-width:8.69787884;stroke-opacity:1" />
- <path
- id="path580"
- d="M 276.13146,653.57693 C 226.46511,698.77358 208.55775,684.63958 225.59757,699.38662 C 242.63738,714.13365 207.60587,736.69258 255.64106,710.65366 C 303.67625,684.61475 292.74446,721.92181 337.26265,726.91279 C 381.78084,731.90377 367.55505,686.66252 398.95738,726.11846 C 448.93114,749.86012 450.77616,725.20438 444.65194,685.99981 C 468.52773,637.50954 399.40762,676.69131 424.26422,639.80411 C 449.12083,602.91691 493.74252,585.43818 438.73851,593.12668 C 367.62865,626.24898 340.05615,652.75918 308.53226,650.00376 C 277.00837,647.24835 278.06457,653.52836 276.13146,653.57693 z" />
- <path
- id="path586"
- d="M 565.52271,631.32808 C 559.87456,661.22904 567.06016,669.32587 533.12232,675.30261 C 499.18449,681.27936 470.31986,682.79288 497.95878,697.07654 C 525.5977,711.3602 581.57275,680.58896 553.26474,708.4972 C 524.95672,736.40545 549.82311,734.20405 483.39036,760.50812 C 416.95761,786.81219 509.71641,780.24187 516.31727,779.09063 C 561.92915,767.49942 668.17098,741.73846 641.47769,631.24076 C 599.62772,584.4018 566.58829,631.89255 565.52271,631.32808 z" />
- <path
- sodipodi:nodetypes="csssssc"
- id="path587"
- d="M 229.39497,774.5896 C 242.4834,760.07101 277.217,763.91439 296.81216,764.99871 C 316.40732,766.08303 302.07402,767.42855 337.60553,765.15628 C 373.13704,762.88401 362.02858,748.77628 384.48102,755.30705 C 406.93347,761.83782 380.59606,766.83529 374.84399,778.80459 C 369.09193,790.7739 293.38329,854.35404 292.59114,849.64402 C 291.79899,844.93401 233.71215,863.01184 229.39497,774.5896 z" />
- <path
- id="path606"
- d="M 421.90652,614.24296 C 411.97692,612.9158 376.59659,644.94333 343.79034,651.87704 C 310.9841,658.81076 303.5157,660.57503 274.36827,671.94966 C 245.22084,683.32428 238.45048,706.55273 263.06218,697.06578 C 268.35216,682.34897 321.38297,713.02971 349.24805,711.34422 C 374.97026,678.23015 427.20564,729.83591 423.28806,701.43629 C 400.4163,668.33567 407.87517,634.69764 421.90652,614.24296 z" />
- <path
- id="path607"
- d="M 285.78887,780.25374 C 296.65202,781.36036 313.84261,785.4613 326.85566,776.26576 C 364.0656,766.65937 380.87885,756.97419 370.12898,768.08367 C 331.24998,779.30863 329.68576,819.12781 294.47494,829.07813 C 287.47801,827.87437 260.63969,792.31623 285.78887,780.25374 z" />
- <path
- id="path608"
- d="M 593.57646,636.53564 C 594.22721,646.1762 634.99245,663.48043 599.38557,671.07575 C 563.77868,678.67107 543.51402,679.37728 547.17283,683.8182 C 550.83164,688.25911 593.57686,676.937 595.22718,686.74954 C 596.8775,696.56207 557.69696,729.07923 540.2142,740.55495 C 522.73145,752.03067 488.78424,763.72296 480.17489,770.24582 C 619.9432,735.59561 681.58474,623.09094 593.57646,636.53564 z" />
- <path
- sodipodi:nodetypes="csccsc"
- id="path3377"
- d="M 184.09287,772.05215 C 184.09287,772.05215 205.22775,720.43539 402.04071,656.54813 C 611.19218,588.65568 644.70141,643.691 644.70141,643.691 L 657.90516,708.4633 C 657.90516,708.4633 631.3411,648.14795 413.15239,726.24866 C 205.66766,800.51788 206.31622,832.31468 206.31622,832.31468"
- style="fill:none;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1" />
- <path
- sodipodi:nodetypes="cc"
- id="path3379"
- d="M 202.86734,708.38281 L 232.45764,863.68017"
- style="fill:#ffffff;fill-rule:evenodd;stroke:#ffffff;stroke-width:12;stroke-linecap:round;stroke-linejoin:miter;stroke-miterlimit:6.625;stroke-dasharray:none;stroke-opacity:1" />
- <path
- id="path3381"
- d="M 246.72232,672.01731 L 282.47506,860.7215"
- <path
- id="path3383"
- d="M 304.82097,632.30447 L 347.36994,830.76355"
- <path
- id="path3385"
- d="M 371.73614,606.77582 L 411.06029,806.88754"
- <path
- id="path3387"
- d="M 459.32355,584.18481 L 494.48455,791.66347"
- <path
- id="path3389"
- d="M 537.40116,579.55246 L 568.76665,781.92961"
- <path
- id="path3391"
- d="M 601.45919,587.65471 L 629.00815,761.48144"
- </g>
- <text
- style="font-size:190.1008606px;font-style:normal;font-weight:normal;fill:#000000;fill-opacity:1;stroke:none;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;font-family:Bitstream Vera Sans"
- x="8.5750723"
- y="756.3833"
- id="text3493"
- transform="scale(0.8087213,1.2365199)"><tspan
- id="tspan3495"
- x="8.5750723"
- y="756.3833"
- style="font-weight:bold;-inkscape-font-specification:Bitstream Vera Sans Bold">Ma<tspan
- style="font-weight:bold;fill:#ff0000;-inkscape-font-specification:Bitstream Vera Sans Bold"
- id="tspan3497">p<tspan
- style="font-weight:bold;fill:#0000ff;-inkscape-font-specification:Bitstream Vera Sans Bold"
- id="tspan3499">b<tspan
- style="font-weight:bold;fill:#000000;-inkscape-font-specification:Bitstream Vera Sans Bold"
- id="tspan3501">ender</tspan></tspan></tspan></tspan></text>
- </g>
-</svg>
More information about the Mapbender_commits
