[Mapbender-commits] r6816 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 26 03:35:20 EDT 2010
Author: kmq
Date: 2010-08-26 07:35:20 +0000 (Thu, 26 Aug 2010)
New Revision: 6816
   trunk/mapbender/http/php/mod_editElements.php
changed the way elements are renamed and copied see ticket #677
Modified: trunk/mapbender/http/php/mod_editElements.php
--- trunk/mapbender/http/php/mod_editElements.php	2010-08-25 22:36:51 UTC (rev 6815)
+++ trunk/mapbender/http/php/mod_editElements.php	2010-08-26 07:35:20 UTC (rev 6816)
@@ -110,7 +110,7 @@
 </style>
 <?php
 # handle database updates etc.....
-if(isset($mySave) && ($mySave == '1' || $mySave == '2')) {
+if((isset($mySave) && ($mySave == '1' || $mySave == '2')) || isset($myDuplicate)) {
 	# check module-permission ---------------------------------------------------------
 	# e_attributes
 	# e_js_file
@@ -163,8 +163,9 @@
 	if ($mySave == '1'){
 		//copy element vars
+		//If the name of the element  (e_id) was  changed in the update, then the elementvarrs must be copied from the old e_id to the new e_id
 		$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2";
-		$v = array($e_id_,$_POST["originGuiOfSelectedElement"]);
+		$v = array($orig_e_id_,$_POST["originGuiOfSelectedElement"]);
 		$t = array('s','s');
 		$c = 0;
 		$res_vars = db_prep_query($sql,$v,$t);
@@ -172,7 +173,7 @@
 		db_begin();
 		$sql = "DELETE FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2 ";
-		$v = array($e_id_,$guiList1);
+		$v = array($orig_e_id_,$guiList1);
 		$res = db_prep_query($sql,$v,$t);
@@ -222,6 +223,62 @@
 		$v = array($guiDesc,$guiId);
+	}elseif($myDuplicate == '1'){
+		//copy element vars
+		$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2";
+		$t = array('s','s');
+		$c = 0;
+		$res_vars = db_prep_query($sql,$v,$t);
+		db_begin();
+		//$sql = "DELETE FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2 ";
+		//$v = array($orig_e_id_,$guiList1);
+		//$t = array('s','s');
+		//$res = db_prep_query($sql,$v,$t);
+		if($e_left == ''){$e_left = NULL;}
+		if($e_top == ''){$e_top = NULL;}
+		if($e_width < 1){$e_width = NULL;}
+		if($e_height < 1){$e_height = NULL;}
+		if($e_z_index < 1){$e_z_index = NULL;}
+		if($e_pos == ''){$e_pos = 2;}
+		if($e_public == ''){$e_public = 1;}
+		$sql = "INSERT INTO gui_element(fkey_gui_id,e_id,e_pos,e_public,e_comment,e_element,e_src,";
+		$sql .= "e_attributes,e_left,e_top,e_width,e_height,e_z_index,e_more_styles,e_content,";
+		$sql .= "e_closetag,e_js_file,e_mb_mod,e_target,e_requires,e_url,e_title) ";
+		$sql .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22)";
+		$v = array($guiList1,$e_id_,$e_pos,$e_public,$e_comment,$e_element,$e_src,$e_attributes,$e_left,
+			$e_top,$e_width,$e_height,$e_z_index,$e_more_styles,$e_content,$e_closetag,$e_js_file,
+			$e_mb_mod,$e_target,$e_requires,$e_url,$e_title);
+		$t = array('s','s','i','i','s','s','s','s','i','i','i','i','i','s','s','s','s','s','s','s','s','s');
+		$res = db_prep_query($sql,$v,$t);
+		if(!$res){
+			db_rollback();
+		while($row = db_fetch_array($res_vars)){
+			$sql = array();
+			$v = array();
+			$t = array();
+			$r = array();
+			$sql[$c] = "INSERT INTO gui_element_vars (fkey_gui_id,fkey_e_id,var_name,var_value,context,var_type) ";
+			$sql[$c] .= "VALUES ($1,$2,$3,$4,$5,$6)";
+			$v[$c] = array($guiList1,$e_id_,$row["var_name"],$row["var_value"],$row["context"],$row["var_type"]);
+			$t[$c] = array('s','s','s','s','s','s');
+			$r[$c] = db_prep_query($sql[$c],$v[$c],$t[$c]);
+			if(!$r){
+				db_rollback();
+			$c++;
+		db_commit();
@@ -352,6 +409,14 @@
       document.form1.submit();
+function thisDuplicate(){
+	var newName = prompt("Enter new name: ");
+	document.form1.e_id_.value = newName;
+	document.form1.myDuplicate.value = 1;
+	document.form1.submit();
 function thisShow(){   document.form1.myShow.value = 1;
@@ -467,6 +532,7 @@
 	   echo "</div>\n";
 	   echo "<div class='buttonbar'>\n";
 	   echo "<input type='button' class='' name='' value='save' onclick='thisSave()'> \n";
+	   echo "<input type='button' class='' name='' value='duplicate' onclick='thisDuplicate()'> \n";
 	   echo "<input type='button' class='' name='' value='delete' onclick='thisDelete()'> \n";
 	   echo "<input type='button' class='' name='' value='show' onclick='thisShow()'> \n";
 	   echo "<input type='button' class='' name='' value='sql' onclick='thisExport()'> \n";
@@ -551,7 +617,7 @@
 	$t = array();
 	if($row = db_fetch_array($res)){
-		echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id_' value='".$row["e_id"]."'></td></tr>\n";
+		echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id_' value='".$row["e_id"]."'><input type='hidden' class='textfield' name='orig_e_id_' value='".$row["e_id"]."'></td></tr>\n";
 		echo "<tr><td>Position: </td><td><input type='text' class='textfield' name='e_pos' value='".$row["e_pos"]."'></td></tr>\n";
 		echo "<tr><td>ON/OFF: </td><td><input type='text' class='textfield' name='e_public' value='".$row["e_public"]."'></td></tr>\n";
 		echo "<tr><td>Comment: </td><td><textarea cols='32' rows='5'  name='e_comment' >".stripslashes($row["e_comment"])."</textarea></td></tr>\n";
@@ -576,7 +642,7 @@
 	echo "</table>";
 else if(isset($guiList1)){
-	echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id_' value='".$e_id_."'></td></tr>\n";
+	echo "<tr><td>ID: </td><td><input type='text' class='textfield' name='e_id_' value='".$e_id_."'><input type='hidden' class='textfield' name='orig_e_id_' value='".$row["e_id"]."'></td></tr>\n";
 	echo "<tr><td>Position: </td><td><input type='text' class='textfield' name='e_pos' value='".$e_pos."'></td></tr>\n";
 	echo "<tr><td>ON/OFF: </td><td><input type='text' class='textfield' name='e_public' value='".$e_public."'></td></tr>\n";
 	echo "<tr><td>Comment: </td><td><textarea cols='32' rows='5'  name='e_comment' >".stripslashes($e_comment)."</textarea></td></tr>\n";
@@ -602,6 +668,7 @@
 echo "<input type='hidden' name='originGuiOfSelectedElement' value='" . $_POST["originGuiOfSelectedElement"] . "'>";
 echo "<input type='hidden' name='myDelete'>";
+echo "<input type='hidden' name='myDuplicate'>";
 echo "<input type='hidden' name='mySave'>";
 echo "<input type='hidden' name='myShow'>";
 echo "<input type='hidden' name='all'>";
More information about the Mapbender_commits mailing list
