[Mapbender-commits] r6830 - in trunk/mapbender: core resources/db resources/db/pgsql resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Aug 29 13:00:01 EDT 2010
Author: tbaschetti
Date: 2010-08-29 17:00:01 +0000 (Sun, 29 Aug 2010)
New Revision: 6830
Added:
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
Removed:
   trunk/mapbender/resources/db/mysql/
   trunk/mapbender/resources/db/pgsql/ISO-8859-1/
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
   trunk/mapbender/core/globalSettings.php
   trunk/mapbender/resources/db/install.bat
   trunk/mapbender/resources/db/install.sh
   trunk/mapbender/resources/db/update.bat
   trunk/mapbender/resources/db/update.sh
updated install.sh/install.bat
 - merged changes from 2.6
 - cleaned up a bit
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php	2010-08-28 23:04:58 UTC (rev 6829)
+++ trunk/mapbender/core/globalSettings.php	2010-08-29 17:00:01 UTC (rev 6830)
@@ -109,6 +109,7 @@
 require_once(dirname(__FILE__) . "/../http/classes/class_locale.php");
 $localeObj = new Mb_locale(Mapbender::session()->get("mb_lang"));
 // establish database connection
Modified: trunk/mapbender/resources/db/install.bat
--- trunk/mapbender/resources/db/install.bat	2010-08-28 23:04:58 UTC (rev 6829)
+++ trunk/mapbender/resources/db/install.bat	2010-08-29 17:00:01 UTC (rev 6830)
@@ -131,8 +131,10 @@
 psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6rc1_to_2.6_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
 echo   update to 2.6.1
 psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6_to_2.6.1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo   update to 2.6.2
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.6.2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
 echo   update to 2.7
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.2_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
 echo   update sequences
 psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_sequences.txt 2>> err_sequences.txt
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh	2010-08-28 23:04:58 UTC (rev 6829)
+++ trunk/mapbender/resources/db/install.sh	2010-08-29 17:00:01 UTC (rev 6830)
@@ -1,4 +1,4 @@
-#/bin/bash
+#!/bin/bash
 # create database for mapbender
@@ -6,7 +6,6 @@
 function show_disclaimer() {
     # Disclaimer
     echo ""
-    echo "DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!"
     echo "The script will create a database for you and will import the Mapbender data to the new database"
     echo "It will also compile the Mapbender.mo files"
     echo ""
@@ -16,7 +15,7 @@
     # echo " * write access to mapbender/log"
     # echo " * write access to mapbender/http/tmp"
     # echo " * write access to mapbender/resources/locale/ and subdirectories"
-    echo " * provide a database user that can create a database"
+    echo " * provide a database user that is a superuser"
     echo ""
     echo ""
     echo "If everything is prepared you can continue."
@@ -123,32 +122,47 @@
         echo ""
         exit 1;
     fi
-    echo "Your password will be asked several times, this is normal (unless .pgpass is used)"
+    echo "Your password will be asked twice, this is normal (unless .pgpass is used)"
     echo "creating database"
     createdb -U $DBUSER  -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
-    echo "creating schema"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/pgsql_schema_2.5.sql $DBNAME > log_schema.txt 2> err_schema.txt
-    echo "loading data"
-    psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/pgsql_data_2.5.sql $DBNAME > log_data.txt 2> err_data.txt
-	echo "setting sequences"
-    psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.5.sql $DBNAME > log_sequences.txt 2> err_squences.txt
-	echo "update to 2.5.1rc1"
-    psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql $DBNAME > log_update.txt 2> err_update.txt
-	echo "update to 2.5.1"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
-	echo "update to 2.6rc1"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1_to_2.6rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
-	echo "update to 2.6"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6rc1_to_2.6_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
-	echo "update to 2.6.1"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
-	echo "update to 2.7"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
-	echo "update sequences"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.7.sql $DBNAME >> log_sequences.txt 2>> err_squences.txt
+    cat pgsql/pgsql_schema_2.5.sql  \
+      pgsql/$DBENCODING/pgsql_data_2.5.sql \
+      pgsql/pgsql_serial_set_sequences_2.5.sql \
+      pgsql/$DBENCODING/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql \
+      pgsql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql \
+      pgsql/$DBENCODING/update/update_2.5.1_to_2.6rc1_pgsql_$DBENCODING.sql \
+      pgsql/$DBENCODING/update/update_2.6rc1_to_2.6_pgsql_$DBENCODING.sql \
+      pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql \
+      pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql \
+      pgsql/$DBENCODING/update/update_2.6.2_to_2.7rc1_pgsql_$DBENCODING.sql \
+      pgsql/pgsql_serial_set_sequences_2.7.sql \
+	> _install.sql
+    echo "inserting data (this might take a few minutes)"
+    psql -U $DBUSER -h $DBHOST -p $DBPORT -f _install.sql $DBNAME > log_schema.txt 2> error.log
+    rm _install.sql
+    echo ""
+function update_mapbender_conf(){
+	# creating mapbender.conf
+	if [ -f ../../conf/mapbender.conf ]
+	then
+	echo "mapbender.conf already exists, not changed"
+	else
+	echo "Creating mapbender.conf..."
+	echo -n "Please enter the password for user $DBUSER: "
+	stty -echo
+	read password
+	stty echo
+	echo ""
+	sed -e "s/%%DBSERVER%%/$DBHOST/g" -e "s/%%DBPORT%%/$DBPORT/g" -e "s/%%DBNAME%%/$DBNAME/g" -e "s/%%DBOWNER%%/$DBUSER/g"  -e "s/%%DBPASSWORD%%/$password/g" ../../conf/mapbender.conf-dist >../../conf/mapbender.conf
+	fi
+	echo ""
 function set_permissions(){
     echo "The installer can set the permissions to the files"
     echo "and directory for you. If you want the installer to"
@@ -175,16 +189,6 @@
           chmod -R o+rw ../locale
           echo "setting execute rights on mapbender/tools/i18n_update_mo.sh"
           chmod -R o+rx ../../tools/i18n_update_mo.sh
-          # creating mapbender.conf
-          if [ -f ../../conf/mapbender.conf ]
-          then
-            echo "mapbender.conf already exists, not changed"
-          else
-            cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
-          fi
-          echo ""
-          echo "please check and edit the entries in your mapbender.conf manually!"
     fi
@@ -232,7 +236,7 @@
 echo "Creating Mapbender administration database"
 create_pgsql_db;
+update_mapbender_conf;
 set_permissions;
 compile_po;
Deleted: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-08-28 23:04:58 UTC (rev 6829)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-08-29 17:00:01 UTC (rev 6830)
@@ -1,2697 +0,0 @@
--- remove event handlers, are now in the script
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'featureInfo1';
-UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
--- new definition of addWMSfromfilteredList_ajax due to i18n
-UPDATE gui_element set e_attributes = '', e_js_file = 'mod_addWmsFromFilteredList_button.php' where e_id = 'addWMSfromfilteredList_ajax';
--- polish entries for translations table, delete old ones first to avoid multi entries for one locale
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Pan';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Display complete map';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom in';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom out';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Back';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Forward';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Coordinates';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom by rectangle';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Redraw';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Query';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Logout';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'WMS preferences';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS from filtered list';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set map center';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Help';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Show WMS infos';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Save workspace as web map context document';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Resize Mapsize';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Rubber';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Get Area';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnię');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Close Polygon';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Move back to your GUI list';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Legend';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Print';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Imprint';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Maps';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Search';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Meetingpoint';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Metadatasearch';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS from List';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Info';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Change Projection';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Copyright';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Digitize';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Overview';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglądowa');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Drag Mapsize';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Mapframe';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Navigation Frame';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scale Select';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalę');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scale Text';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalę');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scalebar';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set Background';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom to Coordinates';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Change Password';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Load a web map context document';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Logo';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Measure distance';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
-DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set language';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
--- update wfs conf module
-e_attributes = 'href = "../php/mod_wfs_conf_client.php" target="AdminFrame"'
-WHERE e_id = 'wfs_conf' AND fkey_gui_id IN ('admin1', 'admin_de_services', 'admin_en_services');
-ALTER TABLE wfs_conf ADD COLUMN
-wfs_conf_type int4 NOT NULL DEFAULT 0;
--- new wfs conf columns
-ALTER TABLE wfs_conf_element ADD COLUMN
-f_helptext text;
-f_category_name varchar(255) NOT NULL DEFAULT '';
--- reload uses Mapbender API
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'reload';
--- init event is now triggered by jQuery
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body';
--- mapframe layers are now added dynamically by the modules
-UPDATE gui_element SET e_content = '' WHERE e_id = 'mapframe1';
--- file extension is now .js
-UPDATE gui_element SET e_js_file = 'mod_log.js' WHERE e_id = 'log';
-UPDATE gui_element SET e_js_file = 'mod_resize_mapsize.js' WHERE e_id = 'resizeMapsize';
-UPDATE gui_element SET e_js_file = 'mod_sandclock.js' WHERE e_id = 'sandclock';
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomFull';
-UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_zoomFull.js' WHERE e_id = 'zoomFull';
-UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_repaint.js' WHERE e_id = 'repaint';
-UPDATE gui_element SET e_js_file = 'mod_changeEPSG.js' WHERE e_id = 'changeEPSG';
-UPDATE gui_element SET e_js_file = 'mod_scalebar.js' WHERE e_id = 'scalebar';
--- parameter: skip WMS request if current SRS is not supported
--- I'm not sure how to insert this dynamically into all applications that have either mapframe1 or overview
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
-SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars
-WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
--- element var skipWmsIfSrsNotSupported for gui element overview
-SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported'
-AND fkey_e_id = 'overview');
----------------------------------------------MONITORING BEGIN
--- Index: idx_mb_monitor_status
--- DROP INDEX idx_mb_monitor_status;
-CREATE INDEX idx_mb_monitor_status
-  ON mb_monitor
-  USING btree
-  (status);
--- Index: idx_mb_monitor_upload_id
--- DROP INDEX idx_mb_monitor_upload_id;
-CREATE INDEX idx_mb_monitor_upload_id
-  ON mb_monitor
-  USING btree
-  (upload_id);
--- Table: mb_wms_availability
--- DROP TABLE mb_wms_availability;
-CREATE TABLE mb_wms_availability
-  fkey_wms_id integer,
-  fkey_upload_id character varying,
-  last_status integer,
-  availability real,
-  image integer,
-  status_comment character varying,
-  average_resp_time real,
-  upload_url character varying,
-  map_url character varying,
-  CONSTRAINT mb_wms_availability_fkey_wms_id_wms_id FOREIGN KEY (fkey_wms_id)
-      REFERENCES wms (wms_id) MATCH SIMPLE
-      ON UPDATE CASCADE ON DELETE CASCADE
-WITH OIDS;
--- Function: mb_monitor_after()
--- DROP FUNCTION mb_monitor_after();
-CREATE OR REPLACE FUNCTION mb_monitor_after()
-  RETURNS "trigger" AS
-$BODY$DECLARE
-   availability_new REAL;
-   average_res_cap REAL;
-   count_monitors REAL;
-    BEGIN
-     IF TG_OP = 'UPDATE' THEN
-     count_monitors := count(fkey_wms_id) from mb_monitor where fkey_wms_id=NEW.fkey_wms_id;
-      --the following should be adopted if the duration of storing is changed!!!
-      average_res_cap := ((select average_resp_time from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors+(NEW.timestamp_end-NEW.timestamp_begin))/(count_monitors+1);
-     IF NEW.status > -1 THEN --service gives caps
-      availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors + 100)/(count_monitors+1) as numeric),2);
-     ELSE --service has problems with caps
-      availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors)/(count_monitors+1) as numeric),2);
-     END IF;
-      UPDATE mb_wms_availability SET average_resp_time=average_res_cap,last_status=NEW.status, availability=availability_new, image=NEW.image, status_comment=NEW.status_comment,upload_url=NEW.upload_url,map_url=NEW.map_url WHERE mb_wms_availability.fkey_wms_id=NEW.fkey_wms_id;
-      RETURN NEW;
-     END IF;
-     IF TG_OP = 'INSERT' THEN
-	IF (select count(fkey_wms_id) from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id) > 0  then -- service is not new
-			UPDATE mb_wms_availability set fkey_upload_id=NEW.upload_id,last_status=NEW.status,status_comment=NEW.status_comment,upload_url=NEW.upload_url where fkey_wms_id=NEW.fkey_wms_id;
-		else --service has not yet been monitored
-			INSERT INTO mb_wms_availability (fkey_upload_id,fkey_wms_id,last_status,status_comment,upload_url,map_url,average_resp_time,availability) VALUES (NEW.upload_id,NEW.fkey_wms_id,NEW.status,NEW.status_comment,NEW.upload_url::text,NEW.map_url,0,100);
-		end if;
-      RETURN NEW;
-     END IF;
-    END;
-$BODY$
-  LANGUAGE 'plpgsql' VOLATILE;
--- Trigger: mb_monitor_after on mb_monitor
--- DROP TRIGGER mb_monitor_after ON mb_monitor;
-CREATE TRIGGER mb_monitor_after
-  AFTER INSERT OR UPDATE
-  ON mb_monitor
-  FOR EACH ROW
-  EXECUTE PROCEDURE mb_monitor_after();
--- Table: mb_user_abo_ows
--- DROP TABLE mb_user_abo_ows;
-CREATE TABLE mb_user_abo_ows
-  fkey_mb_user_id integer,
-  fkey_wfs_id integer,
-  CONSTRAINT mb_user_abo_ows_user_id_fkey FOREIGN KEY (fkey_mb_user_id)
-      REFERENCES mb_user (mb_user_id) MATCH SIMPLE
-      ON UPDATE CASCADE ON DELETE CASCADE,
-  CONSTRAINT mb_user_abo_ows_wfs_fkey FOREIGN KEY (fkey_wfs_id)
-      REFERENCES wfs (wfs_id) MATCH SIMPLE
-  CONSTRAINT mb_user_abo_ows_wms_fkey FOREIGN KEY (fkey_wms_id)
-WITHOUT OIDS;
--- Index: idx_wms_id
--- DROP INDEX idx_wms_id;
-CREATE INDEX idx_wms_id
-  ON wms
-  USING btree
-  (wms_id);
--- add monitor subscriber notification to admin1
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-SELECT gui.gui_id, 'monitor_abo_show',2,1,'monitoring','Show subscriptions','a','','href = "../php/mod_abo_show.php?sessionID" target = "AdminFrame" ',8,1080,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Manage monitoring subscriptions','a','','','','AdminFrame','http://www.mapbender.org/'
-FROM gui WHERE gui.gui_id = 'admin1' AND gui.gui_id
-WHERE e_id = 'monitor_abo_show' AND fkey_gui_id = 'admin1');
--- add monitor results to admin1
-SELECT gui.gui_id, 'monitor_results',2,1,'monitoring results','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" target = "AdminFrame" ',8,1110,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','View monitoring results','a','','','','AdminFrame','http://www.mapbender.org/'
-WHERE e_id = 'monitor_results');
----------------------------------------------MONITORING END
--- OWS Proxy log
-CREATE TABLE mb_proxy_log (
-    proxy_log_timestamp timestamp default now(),
-    fkey_wms_id integer NOT NULL,
-    fkey_mb_user_id integer NOT NULL,
-    request varchar(4096),
-    pixel bigint,
-    price real
-with oids;
-ALTER TABLE wms ADD COLUMN wms_proxylog integer;
-ALTER TABLE wms ALTER COLUMN wms_proxylog SET STORAGE PLAIN;
-ALTER TABLE wms ADD COLUMN wms_pricevolume integer;
-ALTER TABLE wms ALTER COLUMN wms_pricevolume SET STORAGE PLAIN;
--- http auth
-ALTER TABLE wms ADD COLUMN wms_username VARCHAR(255) NOT NULL DEFAULT '';
-ALTER TABLE wms ADD COLUMN wms_password VARCHAR(255) NOT NULL DEFAULT '';
-ALTER TABLE wms ADD COLUMN wms_auth_type VARCHAR(255) NOT NULL DEFAULT '';
--- Column: mb_user_digest
--- ALTER TABLE mb_user DROP COLUMN mb_user_digest;
-ALTER TABLE mb_user ADD COLUMN mb_user_digest text;
-ALTER TABLE mb_user ALTER COLUMN mb_user_digest SET STORAGE EXTENDED;
---Initial filling with empty strings
-UPDATE mb_user set mb_user_digest='';
---howto set up the http_auth digest hash
---update mb_user set mb_user_digest=md5(mb_user_name || ';' || mb_user_email || ':' || '<realm_name>' || ':' || 'password') where mb_user_id = <ID>;
--- http://www.mapbender.org/FeatureInfo#considerScalehints --
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
--- greek updates for translations table
-update translations set msgstr = 'Περίγραμμα/Κορνίζα πλοήγησης' where msgid = 'Navigation Frame' and locale = 'gr';
-update translations set msgstr = 'Φόρτωση κειμένου διαδυκτιακού χάρτη' where msgid = 'Load a web map context document' and locale = 'gr';
-update translations set msgstr = 'Αποθήκευση χώρου εργασίας με μορφή κείμενου διαδυκτιακού χάρτη' where msgid = 'Save workspace as web map context document' and locale = 'gr';
-UPDATE gui_element SET e_js_file = 'mod_selArea.js' WHERE e_id = 'selArea1';
-UPDATE gui_element SET e_js_file = 'mod_zoomIn1.js' WHERE e_id = 'zoomIn1';
-UPDATE gui_element SET e_js_file = 'mod_overview.js' WHERE e_id = 'overview';
-UPDATE gui_element SET e_js_file = 'mod_zoomOut1.js' WHERE e_id = 'zoomOut1';
--- set white background to Mapframe1
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='mapframe1';
--- background to overview
-UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='overview';
-UPDATE gui_element SET e_js_file = 'mod_pan.js' WHERE e_id = 'pan1';
--- remove title tag of Mapframe1 because it's displayed  im Map
-UPDATE gui_element SET e_title='' WHERE e_id='mapframe1';
-UPDATE gui_element SET e_title='' WHERE e_id='overview';
--- resize admin frame in admin guis
-UPDATE gui_element SET e_width = 1000 WHERE e_id = 'AdminFrame';
--- CSW handling add CSW administration to admin2_de , admin2_en, admin1
--- admin2_en
-SELECT gui.gui_id, 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' Catalog Management', 'div', '', '', '', '', ''
-FROM gui WHERE gui.gui_id = 'admin2_en' AND gui.gui_id
-WHERE e_id = 'headline_Configure_CSW');
-SELECT gui.gui_id, 'loadCSW', 3, 1, 'Add Catalog', 'Add Catalog', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
-WHERE e_id = 'loadCSW');
-SELECT gui.gui_id, 'loadCSWGUI', 3, 1, 'Link Catalog to GUI', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
-WHERE e_id = 'loadCSWGUI');
--- admin2_de
-SELECT gui.gui_id, 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' CSW Verwaltung', 'div', '', '', '', '', ''
-FROM gui WHERE gui.gui_id = 'admin2_de' AND gui.gui_id
-SELECT gui.gui_id, 'loadCSW', 3, 1, 'CSW laden', 'CSW laden', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
-SELECT gui.gui_id, 'loadCSWGUI', 3, 1, 'CSW einer Applikation zuordnen', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
--- admin1
-SELECT gui.gui_id, 'loadCSW',3,1,'Add Catalog','Add Catalog','a','','href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ',8,1140,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Add Catalog','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI'
-SELECT gui.gui_id, 'loadCSWGUI',3,1,'Link Catalog to GUI','Link Catalog to GUI','a','','href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ',8,1160,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Link Catalog to GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI'
--- add CSW search to gui1
-SELECT gui.gui_id,'addCSW',2,1,'search via a CSW Client','Search CSW','img','../img/button_gray/csw_off.png','onclick=''var searchCSWPopup = new mb_popup({title:"Search Catalog",url:"../javascripts/mod_searchCSW_ajax.php?sessionID",width:720, height:600,left:20, top:20});searchCSWPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Search Catalog"',925,60,24,24,1,'','','','mod_addCSW.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW'
-FROM gui WHERE gui.gui_id = 'gui1' AND gui.gui_id
-WHERE e_id = 'addCSW');
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'resizeMapsize';
--- CSW Support - new Tables to build up CSW support
-CREATE TABLE cat
-  cat_id serial NOT NULL, -- auto generated
-  cat_version character varying(50) NOT NULL DEFAULT ''::character varying, -- get from cat version from xml - service_type_version
-  --cat_name character varying(255), -- ows-service-id:title
-  cat_title character varying(255) NOT NULL DEFAULT ''::character varying, --ows-service-id:title
-  cat_abstract text, --ows-service-id:abstract
-  --cat_keywords do we need them? There maybe a special table? - cs:keywords - another table to hold kw
-  --UploadUrl
-  cat_upload_url character varying(255),
-  fees character varying(50), --servicetype-fees
-  accessconstraints text, -- servicetype-accessconstraints
-  --ServiceProvider
-  providername character varying(255),
-  providersite character varying(255),
-  --ServiceContact
-  individualname character varying(255),
-  positionname character varying(255),
-  --ContactInfo
-  voice character varying(255), -- Phone
-  facsimile character varying(255),
-  --Address
-  deliverypoint character varying(255),
-  city character varying(255),
-  administrativearea character varying(255),
-  postalcode character varying(255),
-  country character varying(255),
-  electronicmailaddress character varying(255),
-  --Whole Cap-doc
-  cat_getcapabilities_doc text,
-  --Information about Owner
-  cat_owner integer,
-  --Actuality
-  cat_timestamp integer
-ALTER TABLE ONLY cat
-    ADD CONSTRAINT cat_pkey PRIMARY KEY (cat_id);
-CREATE TABLE cat_keyword (
-    fkey_cat_id integer NOT NULL,
-    fkey_keyword_id integer NOT NULL
-ALTER TABLE ONLY cat_keyword
-    ADD CONSTRAINT pk_cat_keyword PRIMARY KEY (fkey_cat_id, fkey_keyword_id);
-    ADD CONSTRAINT fkey_keyword_id_fkey_cat_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
-    ADD CONSTRAINT fkey_cat_id_fkey_keyword_id FOREIGN KEY (fkey_cat_id) REFERENCES cat(cat_id) ON UPDATE CASCADE ON DELETE CASCADE;
-CREATE TABLE gui_cat
-  fkey_gui_id character varying(50) NOT NULL DEFAULT ''::character varying,
-  fkey_cat_id integer NOT NULL DEFAULT 0,
-  CONSTRAINT fkey_cat_gui_id FOREIGN KEY (fkey_gui_id)
-      REFERENCES gui (gui_id) MATCH SIMPLE
-  CONSTRAINT fkey_cat_cat_id FOREIGN KEY (fkey_cat_id)
-      REFERENCES cat (cat_id) MATCH SIMPLE
-CREATE TABLE cat_op_conf
-  fk_cat_id integer NOT NULL,
-  param_name character varying(255) NOT NULL,
-  param_value text NOT NULL,
-  param_type character varying(255) NOT NULL,
-  CONSTRAINT pk_con_cat_op PRIMARY KEY (fk_cat_id, param_type, param_name, param_value),
-  CONSTRAINT fk_cat_conf_to_cat FOREIGN KEY (fk_cat_id)
--- remove obsolete src from treeGDE (no longer a frame)
-UPDATE gui_element SET e_src = '' WHERE e_id = 'treeGDE';
--- remove frameborder = 0 from treeGDE (no longer a frame)
-UPDATE gui_element SET e_attributes = 'onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"' WHERE e_id = 'treeGDE';
--- remove frameborder = 0 from switchLocale_noreload
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'switchLocale_noreload';
--- add title
-UPDATE gui_element SET e_content = '<select style="font-family: Arial, sans-serif; font-size:12" title="Set background" name="mod_setBackground_list" onchange="mod_setBackground_change(this)"><option value="0"></option></select>' WHERE e_id = 'setBackground';
--- remove nobr tag from mapbender
-UPDATE gui_element SET e_content = '<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>' WHERE e_id = 'mapbender';
--- correct URL encoding
-UPDATE gui_element SET e_attributes = E'onclick="printWindow = window.open(\'../print/mod_printPDF.php?target=mapframe1&amp;sessionID&amp;conf=printPDF_b.conf\',\'printWin\',\'width=260, height=380, resizable=yes\');printWindow.focus();"  onmouseover="this.src = this.src.replace(/_off/,\'_over\');" onmouseout="this.src = this.src.replace(/_over/, \'_off\');"' WHERE e_id = 'printPDF';
--- added mandatory action attribute
-UPDATE gui_element SET e_attributes = 'action="window.location.href"' WHERE e_id = 'setBackground';
-UPDATE gui_element SET e_attributes = 'action="window.location.href" onsubmit="return mod_scaleText()"' WHERE e_id = 'scaleText';
-UPDATE gui_element SET e_content = '<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>' WHERE e_id = 'switchLocale_noreload';
--- attributes only valid for printPDF button (img)
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element = 'iframe';
--- New NavFrame element-vars (color and hoverColor) see http://trac.osgeo.org/mapbender/ticket/540
--- element var backGroundColor for gui element navFrame
-SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var'
-FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor'
-AND fkey_e_id = 'navFrame');
--- element var backGroundHoverColor for gui element navFrame
-SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var'
-WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
-ALTER TABLE mb_user_wmc ADD COLUMN
-wmc_timestamp_create INTEGER;
-CREATE TABLE wmc_md_topic_category (
-    fkey_wmc_id character varying(20) NOT NULL,
-    fkey_md_topic_category_id integer NOT NULL
-ALTER TABLE ONLY wmc_md_topic_category
-    ADD CONSTRAINT wmc_md_topic_category_fkey_wmc_id_fkey FOREIGN KEY (fkey_wmc_id) REFERENCES mb_user_wmc (wmc_id) ON UPDATE CASCADE ON DELETE CASCADE;
--- jQuery UI
-SELECT gui.gui_id,'jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','',''
-FROM gui WHERE gui.gui_id NOT LIKE 'admin%' AND gui.gui_id NOT LIKE 'wms%' AND gui.gui_id
-WHERE e_id = 'jq_ui');
-SELECT gui_element.fkey_gui_id, 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css'
-FROM gui_element WHERE gui_element.e_id = 'jq_ui' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'css'
-AND fkey_e_id = 'jq_ui');
--- jQuery datatables
-SELECT gui.gui_id,'jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/'
-WHERE e_id = 'jq_datatables');
-SELECT gui_element.fkey_gui_id, 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css'
-FROM gui_element WHERE gui_element.e_id = 'jq_datatables' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'defaultCss'
-AND fkey_e_id = 'jq_datatables');
--- jQuery UI tabs
-SELECT gui.gui_id,'jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui',''
-WHERE e_id = 'jq_ui_tabs');
--- jQuery upload
-SELECT gui.gui_id,'jq_upload',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../plugins/jq_upload.js','','',''
-WHERE e_id = 'jq_upload');
--- jQuery datatables CSS in Body
-SELECT gui_element.fkey_gui_id, 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css'
-FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id = 'gui1' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jquery_datatables'
-AND fkey_e_id = 'body');
--- add jquery ui dialog to gui1
-SELECT gui.gui_id,'jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui',''
-WHERE e_id = 'jq_ui_dialog');
-wmc_public INTEGER NOT NULL DEFAULT 0;
--- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
-UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
--- overwrite WMC documents if name and user are identical (0 == old behaviour, 1 == overwrite)
--- element var overwrite for gui element savewmc
-SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id
-WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
--- add history to map object
-UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1' OR e_id = 'overview';
-		ADD COLUMN abstract TEXT,
-		ADD COLUMN srs CHARACTER VARYING,
-		ADD COLUMN minx DOUBLE PRECISION DEFAULT 0,
-		ADD COLUMN miny DOUBLE PRECISION DEFAULT 0,
-		ADD COLUMN maxx DOUBLE PRECISION DEFAULT 0,
-		ADD COLUMN maxy DOUBLE PRECISION DEFAULT 0;
-CREATE TABLE wmc_keyword (
-	fkey_keyword_id	INTEGER REFERENCES keyword(keyword_id) ON DELETE CASCADE ON UPDATE CASCADE,
-	fkey_wmc_id CHARACTER VARYING(20) REFERENCES mb_user_wmc(wmc_id) ON DELETE CASCADE ON UPDATE CASCADE
-ALTER TABLE ONLY wmc_keyword
-     ADD CONSTRAINT pk_wmc_keyword PRIMARY KEY (fkey_wmc_id, fkey_keyword_id);
--- disable publish WMC and delete WMC for gui1
-SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'loadwmc'
-AND gui_element.fkey_gui_id
-WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
--- element var publishWmc for gui element loadwmc
-SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element
-WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id
-WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
--- add publish WMC to admin1
-SELECT gui.gui_id, 'wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame',''
-WHERE e_id = 'wmcPublic' AND fkey_gui_id = 'admin1');
--- add required modules for loadwmc and savewmc
-UPDATE gui_element SET e_attributes = 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
-UPDATE gui_element SET e_requires = 'jq_ui_dialog' WHERE e_id = 'savewmc';
--- set new element vars for existing gui elements of non-standard guis
--- element var switchwms for gui element treeGDE
-SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id
-WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
--- element i18n for all guis
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-SELECT DISTINCT fkey_gui_id,'i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','','','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext'
-FROM gui_element WHERE gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'i18n');
--- increase fields for wfs featuretype attributes name
-ALTER TABLE wfs_element ALTER COLUMN element_name TYPE VARCHAR(255);
--- add georss in gui1
-SELECT gui.gui_id,'addGeoRSS',2,1,'add a GeoRSS Feed to a running application','Add GeoRSS','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','',''
-WHERE e_id = 'addGeoRSS');
-SELECT gui_element.fkey_gui_id, 'addGeoRSS', 'loadGeorssFromSession', '1', '' ,'php_var'
-FROM gui_element WHERE gui_element.e_id = 'addGeoRSS' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'loadGeorssFromSession'
-AND fkey_e_id = 'addGeoRSS');
--- element var initializeOnLoad for gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'initializeOnLoad', '0', 'start gazetteer onload' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'initializeOnLoad' AND fkey_e_id = 'gazetteerWFS');
--- element var enableSearchWithoutParams for gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'enableSearchWithoutParams' AND fkey_e_id = 'gazetteerWFS');
-UPDATE gui_element SET e_js_file = '../plugins/mb_selectMapsize.js', e_attributes = '' WHERE e_id = 'selectMapsize';
-INSERT INTO cat VALUES (2, '2.0.2', 'NLR CSW', '			NLR CSW: XQuery based catalog service conform to the HTTP protocol binding  of the OpenGIS Catalogue Service specification version 2.0.2/2.0.1		', 'http://geomatics.nlr.nl/excat/csw?request=GetCapabilities&service=CSW&version=2.0.2', 'NONE', 'NONE', NULL, NULL, 'Rob van Swol', 'Senior Scientist NLR-ASSP', NULL, NULL, '', NULL, NULL, NULL, NULL, 'vanswol at nlr.nl', '<?xml version="1.0" encoding="UTF-8"?><csw:Capabilities xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows" xmlns:xlink="http://www.w3.org/1999/xlink" version="2.0.2">
-	<ows:ServiceIdentification>
-		<ows:Title>NLR CSW</ows:Title>
-		<ows:Abstract>
-			NLR CSW: XQuery based catalog service conform to the HTTP protocol binding
- of the OpenGIS Catalogue Service specification version 2.0.2/2.0.1
-		</ows:Abstract>
-		<ows:Keywords>
-			<ows:Keyword>CSW</ows:Keyword>
-			<ows:Keyword>geospatial</ows:Keyword>
-			<ows:Keyword>catalogue</ows:Keyword>
-		</ows:Keywords>
-		<ows:ServiceType>CSW</ows:ServiceType>
-		<ows:ServiceTypeVersion>2.0.2</ows:ServiceTypeVersion>
-		<ows:Fees>NONE</ows:Fees>
-		<ows:AccessConstraints>NONE</ows:AccessConstraints>
-	</ows:ServiceIdentification>
-	<ows:ServiceProvider>
-		<ows:ProviderName>National Aerospace Laboratory NLR</ows:ProviderName>
-		<ows:ProviderSite xlink:href="http://geomatics.nlr.nl/excat"/>
-		<ows:ServiceContact>
-			<ows:IndividualName>Rob van Swol</ows:IndividualName>
-			<ows:PositionName>Senior Scientist NLR-ASSP</ows:PositionName>
-			<ows:ContactInfo>
-				<ows:Phone>
-					<ows:Voice>+31 527 248252</ows:Voice>
-				</ows:Phone>
-				<ows:Address>
-					<ows:ElectronicMailAddress>vanswol at nlr.nl</ows:ElectronicMailAddress>
-				</ows:Address>
-			</ows:ContactInfo>
-		</ows:ServiceContact>
-	</ows:ServiceProvider>
-	<ows:OperationsMetadata>
-		<ows:Operation name="GetCapabilities">
-			<ows:DCP>
-				<ows:HTTP>
-					<ows:Get xlink:href="http://geomatics.nlr.nl/excat/csw"/>
-					<ows:Post xlink:href="http://geomatics.nlr.nl/excat/csw"/>
-				</ows:HTTP>
-			</ows:DCP>
-			<ows:Parameter name="sections">
-				<ows:Value>ServiceIdentification</ows:Value>
-				<ows:Value>ServiceProvider</ows:Value>
-				<ows:Value>OperationsMetadata</ows:Value>
-				<ows:Value>Filter_Capabilities</ows:Value>
-			</ows:Parameter>
-		</ows:Operation>
-		<ows:Operation name="DescribeRecord">
-			<ows:DCP>
-				<ows:HTTP>
-				</ows:HTTP>
-			</ows:DCP>
-			<ows:Parameter name="TypeName">
-				<ows:Value>csw:Record</ows:Value>
-				<ows:Value>gmd:MD_Metadata</ows:Value>
-			</ows:Parameter>
-			<ows:Parameter name="OutputFormat">
-				<ows:Value>application/xml</ows:Value>
-			</ows:Parameter>
-			<ows:Parameter name="SchemaLanguage">
-				<ows:Value>XMLSCHEMA</ows:Value>
-				<ows:Value>http://www.w3.org/XML/Schema</ows:Value>
-			</ows:Parameter>
-		</ows:Operation>
-		<ows:Operation name="GetDomain">
-			<ows:DCP>
-				<ows:HTTP>
-					<ows:Get  xlink:href="http://geomatics.nlr.nl/excat/csw" />
-					<ows:Post xlink:href="http://geomatics.nlr.nl/excat/csw"  />
-				</ows:HTTP>
-			</ows:DCP>
-		</ows:Operation>
-		<ows:Operation name="GetRecords">
-			<ows:DCP>
-				<ows:HTTP>
-				</ows:HTTP>
-			</ows:DCP>
-			</ows:Parameter>
-			</ows:Parameter>
-			<ows:Parameter name="OutputSchema">
-				<ows:Value>OGCCORE</ows:Value>
-				<ows:Value>http://www.opengis.net/cat/csw/2.0.2</ows:Value>
-				<!--ows:Value>http://www.isotc211.org/2005/gmd</ows:Value-->
-				<!--ows:Value>ISO19139</ows:Value-->
-				<!--ows:Value>CEN</ows:Value-->
-				<!--ows:Value>ISO19115</ows:Value-->
-			</ows:Parameter>
-			<ows:Parameter name="ResultType">
-				<ows:Value>results</ows:Value>
-				<ows:Value>hits</ows:Value>
-			</ows:Parameter>
-			<ows:Parameter name="ElementSetName">
-				<ows:Value>summary</ows:Value>
-				<ows:Value>brief</ows:Value>
-				<ows:Value>full</ows:Value>
-			</ows:Parameter>
-			<ows:Parameter name="ConstraintLanguage">
-				<ows:Value>Filter</ows:Value>
-				<ows:Value>CQL_Text</ows:Value>
-			</ows:Parameter>
-		</ows:Operation>
-		<ows:Operation name="GetRecordById">
-			<ows:DCP>
-				<ows:HTTP>
-				</ows:HTTP>
-			</ows:DCP>
-			</ows:Parameter>
-				<ows:Value>http://www.isotc211.org/2005/gmd</ows:Value>
-				<ows:Value>ISO19139</ows:Value>
-				<ows:Value>ISO19139NL</ows:Value>
-			</ows:Parameter>
-			</ows:Parameter>
-		</ows:Operation>
-		<ows:Operation name="Transaction">
-			<ows:DCP>
-				<ows:HTTP>
-				</ows:HTTP>
-			</ows:DCP>
-		</ows:Operation>
-		<ows:Operation name="Harvest">
-			<ows:DCP>
-				<ows:HTTP>
-				</ows:HTTP>
-			</ows:DCP>
-		</ows:Operation>
-		<!-- Parameters -->
-		<ows:Parameter name="service">
-		</ows:Parameter>
-		<ows:Parameter name="version">
-			<ows:Value>2.0.2</ows:Value>
-			<ows:Value>2.0.1</ows:Value>
-			<ows:Value>2.0.0</ows:Value>
-		</ows:Parameter>
-	</ows:OperationsMetadata>
-	<ogc:Filter_Capabilities>
-		<ogc:Spatial_Capabilities>
-			<ogc:GeometryOperands>
-				<ogc:GeometryOperand>gml:Envelope</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Point</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:LineString</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Polygon</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:ArcByCenterPoint</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:CircleByCenterPoint</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Arc</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Circle</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:ArcByBulge</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Bezier</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Clothoid</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:CubicSpline</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Geodesic</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:OffsetCurve</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Triangle</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:PolyhedralSurface</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:TriangulatedSurface</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Tin</ogc:GeometryOperand>
-				<ogc:GeometryOperand>gml:Solid</ogc:GeometryOperand>
-			</ogc:GeometryOperands>
-			<ogc:SpatialOperators>
-				<ogc:SpatialOperator name="BBOX"/>
-				<ogc:SpatialOperator name="Within"/>
-				<ogc:SpatialOperator name="Equals"/>
-				<ogc:SpatialOperator name="Overlaps"/>
-				<ogc:SpatialOperator name="Disjoint"/>
-				<ogc:SpatialOperator name="Intersects"/>
-				<ogc:SpatialOperator name="Touches"/>
-				<ogc:SpatialOperator name="Crosses"/>
-				<ogc:SpatialOperator name="Contains"/>
-				<ogc:SpatialOperator name="Beyond"/>
-				<ogc:SpatialOperator name="DWithin"/>
-				<!-- The ''SpatialOperator'' element can have a GeometryOperands child -->
-			</ogc:SpatialOperators>
-		</ogc:Spatial_Capabilities>
-		<ogc:Scalar_Capabilities>
-			<ogc:LogicalOperators/>
-			<ogc:ComparisonOperators>
-				<ogc:ComparisonOperator>EqualTo</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>Like</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>LessThan</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>GreaterThan</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>LessThanEqualTo</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>GreaterThanEqualTo</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>NotEqualTo</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>Between</ogc:ComparisonOperator>
-				<ogc:ComparisonOperator>NullCheck</ogc:ComparisonOperator>
-			</ogc:ComparisonOperators>
-			<ogc:ArithmeticOperators>
-				<ogc:SimpleArithmetic>
-				<ogc:Functions>
-					<ogc:FunctionNames>
-						<ogc:FunctionName nArgs="1">MIN</ogc:FunctionName>
-					</ogc:FunctionNames>
-				</ogc:Functions>
-			</ogc:ArithmeticOperators>
-		</ogc:Scalar_Capabilities>
-		<ogc:Id_Capabilities>
-			<ogc:EID/>
-			<ogc:FID/>
-		</ogc:Id_Capabilities>
-	</ogc:Filter_Capabilities>
-</csw:Capabilities>
-', 1, 1260622475);
--- Data for Name: cat_keyword; Type: TABLE DATA; Schema: public; Owner: postgres
--- Data for Name: cat_op_conf; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'getcapabilities');
-INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'getcapabilities');
-INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'describerecord');
-INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'describerecord');
-INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'getrecords');
-INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'getrecords');
-INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'getrecordbyid');
-INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'getrecordbyid');
-INSERT INTO gui_cat VALUES ('gui1', 2);
--- mapframe1 is now a jQuery plugin
-UPDATE gui_element SET e_js_file = '../plugins/mb_map.js' WHERE e_id = 'mapframe1';
-UPDATE gui_element SET e_js_file = '../plugins/mb_overview.js' WHERE e_id = 'overview';
---dragmapsize is themeroller ready
-UPDATE gui_element SET e_attributes = 'class="ui-state-default"', e_more_styles = 'font-size:1px; cursor:move; width:10; height:10;' WHERE e_id = 'dragMapSize';
---tabs are themeroller ready
-UPDATE gui_element_vars SET var_value = 'position:absolute;visibility:visible;cursor:pointer;' WHERE var_name = 'tab_style' AND fkey_e_id = 'tabs';
---nav frame is themeroller ready
-DELETE FROM gui_element_vars WHERE var_name = 'backGroundColor' AND fkey_e_id = 'navFrame';
-DELETE FROM gui_element_vars WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame';
--- set UI classes for treeGDE
-UPDATE gui_element SET e_more_styles = 'visibility:hidden;overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
-WHERE e_id = 'treeGDE' AND fkey_gui_id IN
-(SELECT a.fkey_gui_id FROM gui_element AS a, gui_element AS b WHERE a.e_id = 'tabs' AND b.e_id = 'treeGDE' AND a.fkey_gui_id = b.fkey_gui_id);
--- remove expanding treeGDE in gui1
-UPDATE gui_element SET e_more_styles = 'overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
-WHERE e_id = 'treeGDE' AND fkey_gui_id IN ('gui1');
--- add new container toolbox_jquery
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('toolbox_jquery','toolbox_jquery','All jQuery related elements in Mapbender',1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','body',1,1,'body (obligatory)','','body','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_datatables',1,1,'jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_jgrowl',1,1,'A growl like widget to display messages','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_jgrowl.js','../extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js','','','http://stanlemon.net/projects/jgrowl.html');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_accordion',2,1,'accordion from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js','','jq_ui','http://docs.jquery.com/UI/Accordion');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_logo',2,1,'Logo','jQuery UI Logo','img','../img/jquery_ui_logo.png','',35,15,NULL ,NULL ,5,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js','','jq_ui','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_slider',5,1,'slider from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js','','jq_ui','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_themeroller',1,1,'A button that opens the ThemeRoller from a remote site','Themeroller','a','','class=''ui-state-default ui-corner-all''
-href="javascript:(function(){if%20(!/Firefox/.test(navigator.userAgent)){alert(navigator.userAgent);%20return%20false;%20};%20if(window.jquitr){%20jquitr.addThemeRoller();%20}%20else{%20jquitr%20=%20{};%20jquitr.s%20=%20document.createElement(''script'');%20jquitr.s.src%20=%20''http://jqueryui.com/themeroller/developertool/developertool.js.php'';%20document.getElementsByTagName(''head'')[0].appendChild(jquitr.s);}%20})();"',320,15,NULL ,NULL ,NULL ,'text-decoration:none;padding:0.4em 1em 0.4em 20px','Custom theme','a','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'body', 'jq_ui_effects_transfer', '.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ', '', 'text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'body', 'jq_ui_theme', '../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css', 'UI Theme from Themeroller', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'blind', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'bounce', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'clip', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'drop', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'explode', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'fold', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'highlight', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'pulsate', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'scale', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'transfer', '1', '1 = effect active', 'php_var');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('toolbox_jquery','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js','','jq_ui','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('toolbox_jquery', 1, 'owner');
--- add jq_ui_theme
-SELECT gui_element.fkey_gui_id, 'body', 'jq_ui_theme',
-'../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css', 'UI Theme from Themeroller' ,'file/css'
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jq_ui_theme');
--- add resultList to applications with element gazetteerWFS
-e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-SELECT gui_element.fkey_gui_id, 'resultList',2,1,'','Result List','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,
-'','','div','mod_ResultList.js','../../lib/resultGeometryListController.js, ../../lib/resultGeometryListModel.js','mapframe1','',''
-from gui_element WHERE
-gui_element.e_id = 'gazetteerWFS' AND
-gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList');
--- add element var position to element resultList
-'resultList', 'position', '[100,100]', 'position of the result list dialog' ,'var'
-from gui_element
-WHERE
-gui_element.e_id = 'resultList' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'position');
--- add element var resultListHeight to element resultList
-'resultList', 'resultListHeight', '400', 'height of the result list dialog' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'resultListHeight');
--- add element var resultListTitle to element resultList
-'resultList', 'resultListTitle', 'Search results', 'title of the result list dialog' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'resultListTitle');
--- add element var resultListWidth to element resultList
-'resultList', 'resultListWidth', '800', 'width of the result list dialog' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'resultListWidth');
--- add jq_ui_dialog to applications with element gazetteerWFS
-Select gui_element.fkey_gui_id ,'jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js','','jq_ui',''
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_dialog');
--- add jq_ui to applications with element gazetteerWFS
-Select gui_element.fkey_gui_id ,'jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','',
-'','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','',''
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui');
--- add jq_datatables to applications with element gazetteerWFS
-'jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_datatables');
--- add CSS for jQuery datatables
-'body', 'jq_datatables_css', '../extensions/dataTables-1.5/media/css/demo_table_jui.min.css', 'css-file for jQuery datatables' ,'file/css'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'body' AND var_name = 'jq_datatables_css');
--- add resultList_DetailPopup to all resultLists to keep old functionality
- e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-	SELECT fkey_gui_id,'resultList_DetailPopup',2,1,'Detail Popup For resultList','','div','','',
-	NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/mb_resultList_DetailPopup.js', '', 'resultList','', 'http://www.mapbender.org/resultList_DetailPopup'
-	FROM gui_element WHERE
-		(	gui_element.e_id = 'resultList' AND
-  			gui_element.fkey_gui_id NOT IN ( SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList_DetailPopup')
--- add element var detailPopupHeight to element resultList_DetailPopup
-'resultList_DetailPopup', 'detailPopupHeight', '250', 'height of the result list detail popup' ,'var'
-from gui_element
-WHERE
-gui_element.e_id = 'resultList_DetailPopup' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'detailPopupHeight');
--- add element var detailPopupTitle to element resultList_DetailPopup
-'resultList_DetailPopup', 'detailPopupTitle', 'Details', 'title of the result list detail popup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'detailPopupTitle');
--- add element var detailPopupWidth to element resultList_DetailPopup
-'resultList_DetailPopup', 'detailPopupWidth', '350', 'width of the result list detail popup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'detailPopupWidth');
--- add element var position to element resultList_DetailPopup
-'resultList_DetailPopup', 'position', '[200,200]', 'position of the result list detail popup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'position');
--- add element var openLinkFromSearch to element resultList_DetailPopup
-'resultList_DetailPopup', 'openLinkFromSearch', '0', 'open link directly if feature attr is defined as link' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'openLinkFromSearch');
--- add resultList_Zoom to applications with element gazetteerWFS
-'resultList_Zoom',2,1,'zoom functionality for resultList','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/mb_resultList_Zoom.js','','resultList,mapframe1','','http://www.mapbender.org/resultList_Zoom'
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList_Zoom');
--- add resultList_Highlight to applications with element gazetteerWFS
-'resultList_Highlight',2,1,'highlighting functionality for resultList','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/mb_resultList_Highlight.js','','resultList,mapframe1,overview','','http://www.mapbender.org/resultList_Highlight'
-NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList_Highlight');
--- add element var maxHighlightedPoints to element resultList_Highlight
-'resultList_Highlight', 'maxHighlightedPoints', '500', 'max number of points to highlight' ,'var'
-from gui_element
-WHERE
-gui_element.e_id = 'resultList_Highlight' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'maxHighlightedPoints');
--- add element var resultHighlightColor to element resultList_Highlight
-'resultList_Highlight', 'resultHighlightColor', '#ff0000', 'color of the highlighting' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'resultHighlightColor');
--- add element var resultHighlightLineWidth to element resultList_Highlight
-'resultList_Highlight', 'resultHighlightLineWidth', '2', 'width of the highlighting line' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'resultHighlightLineWidth');
--- add element var resultHighlightZIndex to element resultList_Highlight
-'resultList_Highlight', 'resultHighlightZIndex', '100', 'zindex of the highlighting' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'resultHighlightZIndex');
--- delete deprecated element var maxHighlightedPoints of element gazetteerWFS
-DELETE FROM gui_element_vars WHERE fkey_e_id = 'gazetteerWFS' AND var_name = 'maxHighlightedPoints';
--- added PRIMARYKEy for Table gui_gui_category
-Alter Table gui_gui_category ADD
-  CONSTRAINT pk_gui_gui_category PRIMARY KEY (fkey_gui_id, fkey_gui_category_id);
--- add Application toolbox_jquery to category
-INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id)
-VALUES('toolbox_jquery',2);
--- missing wz_jsgraphics in gazetteer
--- replacing obsolete tablesorter
-UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/wz_jsgraphics.js' WHERE e_id = 'gazetteerWFS';
--- translation entry
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('de', 'Add GeoRSS', 'GeoRSS hinzufügen');
--- remove deprecated attributes of gui element addWMS
-UPDATE gui_element set e_attributes = '' WHERE e_id = 'addWMS';
--- remove onmouseover and onmouseout attributes for imprint
-UPDATE gui_element set e_attributes = 'frameborder = "0"' WHERE e_id = 'imprint' AND fkey_gui_id = 'gui';
-INSERT INTO translations (locale, msgid, msgstr ) VALUES ('de', 'Search CSW', 'Katalogsuche');
--- deactivate slippy map by default
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
-SELECT DISTINCT fkey_gui_id, 'mapframe1' AS fkey_e_id, 'slippy' AS var_name, '0' AS var_value,
-'1 = Activates an animated, pseudo slippy map' AS context, 'var' AS var_type FROM gui_element
-WHERE e_id = 'mapframe1' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars
-WHERE var_name = 'slippy');
--- gui_digitze: added new printPDF (with rotation and pdf Template)
--- does not work with 4326 :(
---Delete from gui_element where fkey_gui_id = 'gui_digitize' and e_id = 'printPDF';
---INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes,
--- e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES(
---'gui_digitize','printPDF',2,1,'pdf print','Print','div','','',1,1,2,2,5,'','<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>','div','../plugins/mb_print.js','../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../exten
 sions/jquery.form.min.js','mapframe1','','http://www.mapbender.org/index.php/Print');
---INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES(
---'gui_digitize', 'printPDF', 'mbPrintConfig', '{"A4 landscape": "A4_lanscape_template.json","A4 portrait": "A4_portrait_template.json","A4 landscape": "A4_landscape_template.json","A3 landscape": "A3_landscape_template.json"}', '' ,'var');
---'gui_digitize', 'body', 'print_css', '../css/print_div.css', '' ,'file/css');
--- standard gui gui_wfs_conf entries for search
-INSERT INTO  gui_wfs_conf(fkey_gui_id, fkey_wfs_conf_id)
-SELECT 'gui',wfs_conf_id from wfs_conf WHERE wfs_conf_id = 1
-AND wfs_conf_id
-NOT IN (SELECT fkey_wfs_conf_id FROM gui_wfs_conf WHERE fkey_gui_id = 'gui');
-SELECT 'gui2',wfs_conf_id from wfs_conf WHERE wfs_conf_id = 1
-AND wfs_conf_id
-NOT IN (SELECT fkey_wfs_conf_id FROM gui_wfs_conf WHERE fkey_gui_id = 'gui2');
--- remove obsolete attributes from savewmc
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'savewmc';
--- insert datepicker in toolbox_jquery
-e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_datepicker', 5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.datepicker.js','','jq_ui','');
--- remove obsolete js from dialog
-UPDATE gui_element SET e_js_file = '' WHERE e_id = 'jq_ui_dialog';
--- add element var featureInfoLayerPopup to element featureInfoTunnel
-'featureInfoTunnel', 'featureInfoLayerPopup', 'true', 'display featureInfo in dialog popup' ,'var'
-from gui_element
-WHERE
-gui_element.e_id = 'featureInfoTunnel' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoLayerPopup');
--- add element var featureInfoPopupHeight to element featureInfoTunnel
-'featureInfoTunnel', 'featureInfoPopupHeight', '200', 'height of the featureInfo dialog popup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoPopupHeight');
--- add element var featureInfoPopupWidth to element featureInfoTunnel
-'featureInfoTunnel', 'featureInfoPopupWidth', '270', 'width of the featureInfo dialog popup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoPopupWidth');
-'featureInfoTunnel', 'featureInfoPopupPosition', '[100,100]', 'position of the featureInfoPopup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoPopupPosition');
--- add element var featureInfoLayerPopup to element featureInfo1
-'featureInfo1', 'featureInfoLayerPopup', 'true', 'display featureInfo in dialog popup' ,'var'
-from gui_element
-WHERE
-gui_element.e_id = 'featureInfo1' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoLayerPopup');
--- add element var featureInfoPopupHeight to element featureInfo1
-'featureInfo1', 'featureInfoPopupHeight', '200', 'height of the featureInfo dialog popup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoPopupHeight');
--- add element var featureInfoPopupWidth to element featureInfo1
-'featureInfo1', 'featureInfoPopupWidth', '270', 'width of the featureInfo dialog popup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoPopupWidth');
-'featureInfo1', 'featureInfoPopupPosition', '[100,100]', 'position of the featureInfoPopup' ,'var'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoPopupPosition');
--- add element var meetingPoint_export_url to element meetingPoint
-'meetingPoint', 'meetingPoint_export_url', '', 'set the export url for your meeting point (has to be a URL pointing to ..mapbender/frames/login.php)' ,'var'
-from gui_element
-WHERE
-gui_element.e_id = 'meetingPoint' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'meetingPoint' AND var_name = 'meetingPoint_export_url');
--- move resultList_Popup back (after resultList)
- UPDATE gui_element SET e_pos = 3 WHERE e_id = 'resultList_Popup';
- --Things to be done for merging with geoportal.rlp***
---Adoption of the group table to allow contact information for groups
-alter table mb_group add column mb_group_title character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_ext_id bigint;
-alter table mb_group add column mb_group_address character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_postcode character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_city character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_stateorprovince character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_country character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_voicetelephone character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_facsimiletelephone character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_email character varying(255) NOT NULL DEFAULT ''::character varying;
-alter table mb_group add column mb_group_logo_path text NOT NULL DEFAULT ''::character varying;
-alter table mb_user_mb_group add column mb_user_mb_group_type integer;
---Adoption for adminsitration of conformities in the mapbender database***
---searchable
-ALTER TABLE layer ADD COLUMN layer_searchable integer;
-ALTER TABLE layer ALTER COLUMN layer_searchable SET STORAGE PLAIN;
-ALTER TABLE layer ALTER COLUMN layer_searchable SET DEFAULT 1;
--- Column: featuretype_searchable
--- ALTER TABLE wfs_featuretype DROP COLUMN featuretype_searchable;
---ALTER TABLE wfs_featuretype ADD COLUMN featuretype_searchable integer;
---ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_searchable SET STORAGE PLAIN;
---ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_searchable SET DEFAULT 1;
--- Column: wms_timestamp_create
-ALTER TABLE wms ADD COLUMN wms_timestamp_create integer;
-ALTER TABLE wms ALTER COLUMN wms_timestamp_create SET STORAGE PLAIN;
---network accessibility
-ALTER TABLE wms ADD COLUMN wms_network_access integer;
-ALTER TABLE wms ALTER COLUMN wms_network_access SET STORAGE PLAIN;
--- Column: wfs_timestamp_create
--- ALTER TABLE wfs DROP COLUMN wfs_timestamp_create;
-ALTER TABLE wfs ADD COLUMN wfs_timestamp_create integer;
-ALTER TABLE wfs ALTER COLUMN wfs_timestamp_create SET STORAGE PLAIN;
-ALTER TABLE wfs ADD COLUMN wfs_network_access integer;
-ALTER TABLE wfs ALTER COLUMN wfs_network_access SET STORAGE PLAIN;
---table for inspire metadata add on fields - for layer and featuretypes
--- Table: inspire_md_data
-CREATE TABLE inspire_md_data
-  data_id serial NOT NULL,
-  data_time_begin integer, --timestamp
-  data_time_end integer, --timestamp
-  data_lineage text,
-  data_spatial_res_value varchar(255), --
-  data_spatial_res_type integer, --look up types like 1:equivalentScale, 2:Distance - see guidance paper for metadata
-  CONSTRAINT data_id_pkey PRIMARY KEY (data_id)
-WITH OIDS;
---ALTER TABLE inspire_md_data OWNER TO "postgres";
---ok
---Conformity is a metadata information which is defined for spatial data services and spatial data sets - the information about the conformity should be generated automatically by the service registry
---mainly the available metadata information should be tested. This can be done when resitrating the service and when edit the service metadata.
--- There should be a list of available specifications (ir, or regulations) wherefor the services can be tested. This list have to be stored in the database.
--- Table: conformity
-CREATE TABLE conformity
-  conformity_id serial NOT NULL,
-  conformity_key varchar(255),
-  fkey_spec_class_key character varying(255),
-  conformity_code_en character varying(255),
-  conformity_code_fr character varying(255),
-  conformity_code_de character varying(255),
-  conformity_symbol character varying(255),
-  conformity_description_de text,
-  CONSTRAINT conformity_pkey PRIMARY KEY (conformity_id)
-WITH OIDS;
---ALTER TABLE conformity OWNER TO "postgres";
-INSERT INTO conformity (fkey_spec_class_key, conformity_key, conformity_code_en, conformity_code_de, conformity_code_fr, conformity_symbol, conformity_description_de) VALUES ('inspire','1','conformant','Konform','','','Die Ressource stimmt mit der angegebenen Spezifikation in vollem Umfang überein.');
-INSERT INTO conformity (fkey_spec_class_key, conformity_key, conformity_code_en, conformity_code_de, conformity_code_fr, conformity_symbol, conformity_description_de) VALUES ('inspire','2','notConformant','Nicht konform','','','Die Ressource stimmt mit der angegebenen Spezifikation nicht überein.');
-INSERT INTO conformity (fkey_spec_class_key, conformity_key, conformity_code_en, conformity_code_de, conformity_code_fr, conformity_symbol, conformity_description_de) VALUES ('inspire','3','notEvaluated','Nicht überprüft','','','Die Übereinstimmung ist nicht überprüft worden.');
--- Table spec_classification:
-CREATE TABLE spec_classification
-  spec_class_id serial NOT NULL,
- -- spec_key varchar(5) NOT NULL,
-  spec_class_key character varying(255) UNIQUE,
-  spec_class_code_de character varying(255),
-  spec_class_code_en character varying(255),
-  spec_class_code_fr character varying(255),
-  spec_class_description_en text,
-  spec_class_description_de text,
-  spec_class_description_fr text,
-  spec_class_timestamp integer,
-  CONSTRAINT spec_class_id_pkey PRIMARY KEY (spec_class_id)
-WITH OIDS;
-INSERT INTO spec_classification (spec_class_key, spec_class_code_de, spec_class_description_de) VALUES ('inspire','INSPIRE','Klasse der Inspire Spezifikationen/Regulations');
--- specification table:
-CREATE TABLE spec
-  spec_id serial NOT NULL,
-  spec_key varchar(50) NOT NULL,
-  spec_code_en character varying,
-  spec_code_de character varying,
-  spec_code_fr character varying,
-  spec_link_en character varying,
-  spec_link_de character varying,
-  spec_link_fr character varying,
-  spec_description_en text,
-  spec_description_de text,
-  spec_description_fr text,
-  spec_timestamp integer,
-  CONSTRAINT spec_id_pkey PRIMARY KEY (spec_id),
-  CONSTRAINT spec_spec_class_fkey FOREIGN KEY (fkey_spec_class_key)
-      REFERENCES spec_classification (spec_class_key) MATCH SIMPLE
-      ON UPDATE CASCADE ON DELETE CASCADE
-WITH OIDS;
-INSERT INTO spec (spec_key, spec_code_en, spec_link_en, spec_description_en, fkey_spec_class_key, spec_timestamp) VALUES ('ir_interop','INSPIRE Implementing rules laying down technical arrangements','http://www.geoportal.rlp.de/','INSPIRE Implementing rules laying down technical arrangements for the interoperability and harmonisation of orthoimagery','inspire',extract(epoch FROM (to_timestamp('2011-05-15','YYYY-MM-DD'))));
---conformity relation table:
--- Table: conformity_relation
-CREATE TABLE conformity_relation
-  relation_id serial NOT NULL,
-  fkey_wms_id integer,
-  fkey_wfs_id integer,
-  fkey_inspire_md_id integer,
-  fkey_conformity_id integer,
-  fkey_spec_id integer,
-  CONSTRAINT relation_id_pkey PRIMARY KEY (relation_id),
-  CONSTRAINT conformity_relation_wms_id_fkey FOREIGN KEY (fkey_wms_id)
-      REFERENCES wms (wms_id) MATCH SIMPLE
-      ON UPDATE CASCADE ON DELETE CASCADE,
-  CONSTRAINT conformity_relation_wfs_id_fkey FOREIGN KEY (fkey_wfs_id)
-      REFERENCES wfs (wfs_id) MATCH SIMPLE
-  CONSTRAINT conformity_relation_inspire_md_fkey FOREIGN KEY (fkey_inspire_md_id)
-      REFERENCES inspire_md_data (data_id) MATCH SIMPLE
-  CONSTRAINT conformity_relation_conformity_fkey FOREIGN KEY (fkey_conformity_id)
-      REFERENCES conformity (conformity_id) MATCH SIMPLE
-  CONSTRAINT conformity_relation_spec_fkey FOREIGN KEY (fkey_spec_id)
-      REFERENCES spec (spec_id) MATCH SIMPLE
-WITH OIDS;
--- Table: custom_category
-CREATE TABLE custom_category
-  custom_category_id serial NOT NULL,
-  custom_category_key varchar(5) NOT NULL,
-  custom_category_code_en character varying(255),
-  custom_category_code_de character varying(255),
-  custom_category_code_fr character varying(255),
-  custom_category_symbol character varying(255),
-  custom_category_description_de text,
-  CONSTRAINT custom_category_pkey PRIMARY KEY (custom_category_id)
-WITH OIDS;
-INSERT INTO custom_category (custom_category_key, custom_category_code_en, custom_category_code_de, custom_category_code_fr, custom_category_symbol, custom_category_description_de) VALUES ('dc1','dummy category','Dummy Kategorie','','','Demo Kategorie zur Klassifizierung von Mapbender Registry Inhalten');
--- Table: layer_custom_category
-CREATE TABLE layer_custom_category
-  fkey_layer_id integer NOT NULL,
-  fkey_custom_category_id integer NOT NULL,
-  CONSTRAINT layer_custom_category_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id)
-      REFERENCES layer (layer_id) MATCH SIMPLE
-  CONSTRAINT layer_custom_category_fkey_custom_category_id_fkey FOREIGN KEY (fkey_custom_category_id)
-      REFERENCES custom_category (custom_category_id) MATCH SIMPLE
--- Table: wfs_featuretype_custom_category
-CREATE TABLE wfs_featuretype_custom_category
-  fkey_featuretype_id integer NOT NULL,
-  CONSTRAINT wfs_featuretype_custom_category_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
-      REFERENCES wfs_featuretype (featuretype_id) MATCH SIMPLE
-  CONSTRAINT wfs_featuretype_custom_category_fkey_custom_category_id_fkey FOREIGN KEY (fkey_custom_category_id)
---functions to collect the categories into strings
-CREATE OR REPLACE FUNCTION f_collect_custom_cat_layer(integer)
-  RETURNS text AS
-  $BODY$DECLARE
-  i_layer_id ALIAS FOR $1;
-  custom_cat_string  TEXT;
-  custom_cat_record  RECORD;
-BEGIN
-custom_cat_string := '';
-FOR custom_cat_record IN SELECT layer_custom_category.fkey_custom_category_id from layer_custom_category WHERE layer_custom_category.fkey_layer_id=$1  LOOP
-custom_cat_string := custom_cat_string || '{' ||custom_cat_record.fkey_custom_category_id || '}';
-END LOOP ;
-RETURN custom_cat_string;
-END;
-$BODY$
-  LANGUAGE 'plpgsql' VOLATILE STRICT;
-CREATE OR REPLACE FUNCTION f_collect_custom_cat_wfs_featuretype(integer)
-  RETURNS text AS
-  $BODY$DECLARE
-  i_featuretype_id ALIAS FOR $1;
-BEGIN
-FOR custom_cat_record IN SELECT wfs_featuretype_custom_category.fkey_custom_category_id from wfs_featuretype_custom_category WHERE wfs_featuretype_custom_category.fkey_featuretype_id=$1  LOOP
-END LOOP ;
-END;
-$BODY$
--- Table: inspire_category
-CREATE TABLE inspire_category
-  inspire_category_id serial NOT NULL,
-  inspire_category_key varchar(5) NOT NULL,
-  inspire_category_code_en character varying(255),
-  inspire_category_code_de character varying(255),
-  inspire_category_code_fr character varying(255),
-  inspire_category_symbol character varying(255),
-  inspire_category_description_de text,
-  CONSTRAINT inspire_category_pkey PRIMARY KEY (inspire_category_id)
-WITH OIDS;
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.1','Coordinate reference systems','Koordinatenreferenzsysteme','','','Systeme zur eindeutigen räumlichen Referenzierung von Geodaten anhand eines Koordinatensatzes (x, y, z) und/oder Angaben zu Breite, Länge und Höhe auf der Grundlage eines geodätischen horizontalen und vertikalen Datums.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.2','Geographical grid systems','Geografische Gittersysteme','','','Harmonisiertes Gittersystem mit Mehrfachauflösung, gemeinsamem Ursprungspunkt und standardisierter Lokalisierung und Größe der Gitterzellen.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.3','Geographical names','Geografische Bezeichnungen','','','Namen von Gebieten, Regionen, Orten, Großstädten, Vororten, Städten oder Siedlungen sowie jedes geografische oder topografische Merkmal von öffentlichem oder historischem Interesse.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.4','Administrative units','Verwaltungseinheiten','','','Lokale, regionale und nationale Verwaltungseinheiten, die die Gebiete abgrenzen, in denen die Mitgliedstaaten Hoheitsbefugnisse haben und/oder ausüben und die durch Verwaltungsgrenzen voneinander getrennt sind.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.5','Addresses','Adressen','','','Lokalisierung von Grundstücken anhand von Adressdaten, in der Regel Straßenname, Hausnummer und Postleitzahl.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.6','Cadastral parcels','Flurstücke/Grundstücke (Katasterparzellen)','','','Gebiete, die anhand des Grundbuchs oder gleichwertiger Verzeichnisse bestimmt werden. ');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.7','Transport networks','Verkehrsnetze','','','Verkehrsnetze und zugehörige Infrastruktureinrichtungen für Straßen-, Schienen- und Luftverkehr sowie Schifffahrt. Umfasst auch die Verbindungen zwischen den verschiedenen Netzen. Umfasst auch das transeuropäische Verkehrsnetz im Sinne der Entscheidung Nr. 1692/96/EG des Europäischen Parlaments und des Rates vom 23. Juli 1996 über gemeinschaftliche Leitlinien für den Aufbau eines transeuropäischen Verkehrsnetzes und künftiger Überarbeitungen dieser Entscheidung. ');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.8','Hydrography','Gewässernetz','','','Elemente des Gewässernetzes, einschließlich Meeresgebieten und allen sonstigen Wasserkörpern und hiermit verbundenen Teilsystemen, darunter Einzugsgebiete und Teileinzugsgebiete. Gegebenenfalls gemäß den Definitionen der Richtlinie 2000/60/EG des Europäischen Parlaments und des Rates vom 23. Oktober 2000 zur Schaffung eines Ordnungsrahmens für Maßnahmen der Gemeinschaft im Bereich der Wasserpolitik und in Form von Netzen.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.9','Protected sites','Schutzgebiete','','','Gebiete, die im Rahmen des internationalen und des gemeinschaftlichen Rechts sowie des Rechts der Mitgliedstaaten ausgewiesen sind oder verwaltet werden, um spezifische Erhaltungsziele zu erreichen.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.1','Elevation','Höhe','','','Digitale Höhenmodelle für Land-, Eis- und Meeresflächen. Dazu gehören Geländemodell, Tiefenmessung und Küstenlinie.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.2','Land cover','Bodenbedeckung','','','Physische und biologische Bedeckung der Erdoberfläche, einschließlich künstlicher Flächen, landwirtschaftlicher Flächen, Wäldern, natürlicher (naturnaher) Gebiete, Feuchtgebieten und Wasserkörpern.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.3','Orthoimagery','Orthofotografie','','','Georeferenzierte Bilddaten der Erdoberfläche von satelliten- oder luftfahrzeuggestützten Sensoren.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.4','Geology','Geologie','','','Geologische Beschreibung anhand von Zusammensetzung und Struktur. Dies umfasst auch Grundgestein, Grundwasserleiter und Geomorphologie.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.1','Statistical units','Statistische Einheiten','','','Einheiten für die Verbreitung oder Verwendung statistischer Daten.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.2','Buildings','Gebäude','','','Geografischer Standort von Gebäuden.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.3','Soil','Boden','','','Beschreibung von Boden und Unterboden anhand von Tiefe, Textur, Struktur und Gehalt an Teilchen sowie organischem Material, Steinigkeit, Erosion, gegebenenfalls durchschnittliches Gefälle und erwartete Wasserspeicherkapazität.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.4','Land use','Bodennutzung','','','Beschreibung von Gebieten anhand ihrer derzeitigen und geplanten künftigen Funktion oder ihres sozioökonomischen Zwecks (z. B. Wohn-, Industrie- oder Gewerbegebiete, land- oder forstwirtschaftliche Flächen, Freizeitgebiete).');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.5','Human health and safety','Gesundheit und Sicherheit','','','Geografische Verteilung verstärkt auftretender pathologischer Befunde (Allergien, Krebserkrankungen, Erkrankungen der Atemwege usw.), Informationen über Auswirkungen auf die Gesundheit (Biomarker, Rückgang der Fruchtbarkeit, Epidemien) oder auf das Wohlbefinden (Ermüdung, Stress usw.) der Menschen in unmittelbarem Zusammenhang mit der Umweltqualität (Luftverschmutzung, Chemikalien, Abbau der Ozonschicht, Lärm usw.) oder in mittelbarem Zusammenhang mit der Umweltqualität (Nahrung, genetisch veränderte Organismen usw.).');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.6','Utility and governmental services','Versorgungswirtschaft und staatliche Dienste','','','Versorgungseinrichtungen wie Abwasser- und Abfallentsorgung, Energieversorgung und Wasserversorgung; staatliche Verwaltungs- und Sozialdienste wie öffentliche Verwaltung, Katastrophenschutz, Schulen und Krankenhäuser.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.7','Environmental monitoring facilities','Umweltüberwachung','','','Standort und Betrieb von Umweltüberwachungseinrichtungen einschließlich Beobachtung und Messung von Schadstoffen, des Zustands von Umweltmedien und anderen Parametern des Ökosystems (Artenvielfalt, ökologischer Zustand der Vegetation usw.) durch oder im Auftrag von öffentlichen Behörden.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.8','Production and industrial facilities','Produktions- und Industrieanlagen','','','Standorte für industrielle Produktion, einschließlich durch die Richtlinie 96/61/EG des Rates vom 24. September 1996 über die integrierte Vermeidung und Verminderung der Umweltverschmutzung erfasste Anlagen und Einrichtungen zur Wasserentnahme sowie Bergbau- und Lagerstandorte.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.9','Agricultural and aquaculture facilities','Landwirtschaftliche Anlagen und Aquakulturanlagen','','','Landwirtschaftliche Anlagen und Produktionsstätten (einschließlich Bewässerungssystemen, Gewächshäusern und Ställen).');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.10','Population distribution — demography','Verteilung der Bevölkerung — Demografie','','','Geografische Verteilung der Bevölkerung, einschließlich Bevölkerungsmerkmalen und Tätigkeitsebenen, zusammengefasst nach Gitter, Region, Verwaltungseinheit oder sonstigen analytischen Einheiten.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.11','Area management/restriction/regulation zones and reporting units','Bewirtschaftungsgebiete/Schutzgebiete/geregelte Gebiete und Berichterstattungseinheiten','','','Auf internationaler, europäischer, nationaler, regionaler und lokaler Ebene bewirtschaftete, geregelte oder zu Zwecken der Berichterstattung herangezogene Gebiete. Dazu zählen Deponien, Trinkwasserschutzgebiete, nitratempfindliche Gebiete, geregelte Fahrwasser auf See oder auf großen Binnengewässern, Gebiete für die Abfallverklappung, Lärmschutzgebiete, für Exploration und Bergbau ausgewiesene Gebiete, Flussgebietseinheiten, entsprechende Berichterstattungseinheiten und Gebiete des Küstenzonenmanagements.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.12','Natural risk zones','Gebiete mit naturbedingten Risiken','','','Gefährdete Gebiete, eingestuft nach naturbedingten Risiken (sämtliche atmosphärischen, hydrologischen, seismischen, vulkanischen Phänomene sowie Naturfeuer, die aufgrund ihres örtlichen Auftretens sowie ihrer Schwere und Häufigkeit signifikante Auswirkungen auf die Gesellschaft haben können), z. B. Überschwemmungen, Erdrutsche und Bodensenkungen, Lawinen, Waldbrände, Erdbeben oder Vulkanausbrüche.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.13','Atmospheric conditions','Atmosphärische Bedingungen','','','Physikalische Bedingungen in der Atmosphäre. Dazu zählen Geodaten auf der Grundlage von Messungen, Modellen oder einer Kombination aus beiden sowie Angabe der Messstandorte.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.14','Meteorological geographical features','Meteorologisch-geografische Kennwerte','','','Witterungsbedingungen und deren Messung; Niederschlag, Temperatur, Gesamtverdunstung (Evapotranspiration), Windgeschwindigkeit und Windrichtung.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.15','Oceanographic geographical features','Ozeanografisch-geografische Kennwerte','','','Physikalische Bedingungen der Ozeane (Strömungsverhältnisse, Salinität, Wellenhöhe usw.).');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.16','Sea regions','Meeresregionen','','','Physikalische Bedingungen von Meeren und salzhaltigen Gewässern, aufgeteilt nach Regionen und Teilregionen mit gemeinsamen Merkmalen.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.17','Bio-geographical regions','Biogeografische Regionen','','','Gebiete mit relativ homogenen ökologischen Bedingungen und gemeinsamen Merkmalen.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.18','Habitats and biotopes','Lebensräume und Biotope','','','Geografische Gebiete mit spezifischen ökologischen Bedingungen, Prozessen, Strukturen und (lebensunterstützenden) Funktionen als physische Grundlage für dort lebende Organismen. Dies umfasst auch durch geografische, abiotische und biotische Merkmale gekennzeichnete natürliche oder naturnahe terrestrische und aquatische Gebiete.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.19','Species distribution','Verteilung der Arten','','','Geografische Verteilung des Auftretens von Tier- und Pflanzenarten, zusammengefasst in Gittern, Region, Verwaltungseinheit oder sonstigen analytischen Einheiten.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.20','Energy resources','Energiequellen','','','Energiequellen wie Kohlenwasserstoffe, Wasserkraft, Bioenergie, Sonnen- und Windenergie usw., gegebenenfalls mit Tiefen- bzw. Höhenangaben zur Ausdehnung der Energiequelle.');
-INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.21','Mineral resources','Mineralische Bodenschätze','','','Mineralische Bodenschätze wie Metallerze, Industrieminerale usw., gegebenenfalls mit Tiefen- bzw. Höhenangaben zur Ausdehnung der Bodenschätze.');
--- Table: layer_inspire_category
-CREATE TABLE layer_inspire_category
-  fkey_inspire_category_id integer NOT NULL,
-  CONSTRAINT layer_inspire_category_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id)
-  CONSTRAINT layer_inspire_category_fkey_inspire_category_id_fkey FOREIGN KEY (fkey_inspire_category_id)
-      REFERENCES inspire_category (inspire_category_id) MATCH SIMPLE
--- Table: wfs_featuretype_inspire_category
-CREATE TABLE wfs_featuretype_inspire_category
-  CONSTRAINT wfs_featuretype_inspire_category_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
-  CONSTRAINT wfs_featuretype_inspire_category_fkey_inspire_category_id_fkey FOREIGN KEY (fkey_inspire_category_id)
-CREATE OR REPLACE FUNCTION f_collect_inspire_cat_layer(integer)
-  RETURNS text AS
-  $BODY$DECLARE
-  inspire_cat_string  TEXT;
-  inspire_cat_record  RECORD;
-BEGIN
-inspire_cat_string := '';
-FOR inspire_cat_record IN SELECT layer_inspire_category.fkey_inspire_category_id from layer_inspire_category WHERE layer_inspire_category.fkey_layer_id=$1  LOOP
-inspire_cat_string := inspire_cat_string || '{' ||inspire_cat_record.fkey_inspire_category_id || '}';
-END LOOP ;
-RETURN inspire_cat_string;
-END;
-$BODY$
-CREATE OR REPLACE FUNCTION f_collect_inspire_cat_wfs_featuretype(integer)
-  RETURNS text AS
-  $BODY$DECLARE
-BEGIN
-FOR inspire_cat_record IN SELECT wfs_featuretype_inspire_category.fkey_inspire_category_id from wfs_featuretype_inspire_category WHERE wfs_featuretype_inspire_category.fkey_featuretype_id=$1  LOOP
-END LOOP ;
-END;
-$BODY$
--- Table: wfs_featuretype_md_topic_category
-CREATE TABLE wfs_featuretype_md_topic_category
-  fkey_md_topic_category_id integer NOT NULL,
-  CONSTRAINT wfs_featuretype_md_topic_category_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
-  CONSTRAINT wfs_featuretype_md_topic_category_fkey_md_topic_cat_id_fkey FOREIGN KEY (fkey_md_topic_category_id)
-      REFERENCES md_topic_category (md_topic_category_id) MATCH SIMPLE
-WITHOUT OIDS;
-CREATE OR REPLACE FUNCTION f_collect_topic_cat_layer(integer)
-  RETURNS text AS
-  $BODY$DECLARE
-  topic_cat_string  TEXT;
-  topic_cat_record  RECORD;
-BEGIN
-topic_cat_string := '';
-FOR topic_cat_record IN SELECT layer_md_topic_category.fkey_md_topic_category_id from layer_md_topic_category WHERE layer_md_topic_category.fkey_layer_id=$1  LOOP
-topic_cat_string := topic_cat_string || '{' ||topic_cat_record.fkey_md_topic_category_id || '}';
-END LOOP ;
-RETURN topic_cat_string;
-END;
-$BODY$
-CREATE OR REPLACE FUNCTION f_collect_topic_cat_wfs_featuretype(integer)
-  RETURNS text AS
-  $BODY$DECLARE
-BEGIN
-FOR topic_cat_record IN SELECT wfs_featuretype_md_topic_category.fkey_md_topic_category_id from wfs_featuretype_md_topic_category WHERE wfs_featuretype_md_topic_category.fkey_featuretype_id=$1  LOOP
-END LOOP ;
-END;
-$BODY$
---generate the group for the decentral registrating institutions
--- View: registrating_groups
-CREATE OR REPLACE VIEW registrating_groups AS
- SELECT f.fkey_mb_group_id, f.fkey_mb_user_id
-   FROM mb_user_mb_group f, mb_user_mb_group s
-  WHERE f.mb_user_mb_group_type = 1 AND s.fkey_mb_group_id = 36 AND f.fkey_mb_user_id = s.fkey_mb_user_id
-  ORDER BY f.fkey_mb_group_id, f.fkey_mb_user_id;
--- Function: f_getwfs_tou(integer)
-CREATE OR REPLACE FUNCTION f_getwfs_tou(integer)
-  RETURNS integer AS
-$BODY$
-DECLARE
-   wfs_tou int4;
-BEGIN
-wfs_tou := fkey_termsofuse_id from wfs_termsofuse where wfs_termsofuse.fkey_wfs_id=$1;
-RETURN wfs_tou;
-END;
-$BODY$
-  LANGUAGE 'plpgsql' VOLATILE;
--- Function: f_getwms_tou(integer)
-CREATE OR REPLACE FUNCTION f_getwms_tou(integer)
-$BODY$
-DECLARE
-   wms_tou int4;
-BEGIN
-wms_tou := fkey_termsofuse_id from wms_termsofuse where wms_termsofuse.fkey_wms_id=$1;
-RETURN wms_tou;
-END;
-$BODY$
--- Function: f_collect_epsg(integer)
-CREATE OR REPLACE FUNCTION f_collect_epsg(integer)
-  RETURNS text AS
-$BODY$DECLARE
-  epsg_string  TEXT;
-  epsg_record  RECORD;
-BEGIN
-epsg_string := '';
-FOR epsg_record IN SELECT layer_epsg.epsg from layer_epsg WHERE layer_epsg.fkey_layer_id=$1  LOOP
-epsg_string := epsg_string ||  epsg_record.epsg || ';';
-END LOOP ;
-RETURN epsg_string;
-    --CASE
-      --WHEN LEN(epsg) > 0 THEN LEFT(epsg, LEN(epsg) - 1)
-     -- ELSE epsg
-END;
-$BODY$
--- Function: f_layer_load_count(integer)
-CREATE OR REPLACE FUNCTION f_layer_load_count(integer)
-$BODY$
-DECLARE
-   layer_rel int4;
-BEGIN
-layer_rel := load_count from layer_load_count where layer_load_count.fkey_layer_id=$1;
-RETURN layer_rel;
-END;
-$BODY$
--- Function: f_collect_searchtext(integer, integer)
-CREATE OR REPLACE FUNCTION f_collect_searchtext(integer, integer)
-  RETURNS text AS
-$BODY$DECLARE
-    p_wms_id ALIAS FOR $1;
-    p_layer_id ALIAS FOR $2;
-    r_keywords RECORD;
-    l_result TEXT;
-BEGIN
-    l_result := '';
-    l_result := l_result || (SELECT COALESCE(wms_title, '') || ' ' || COALESCE(wms_abstract, '') FROM wms WHERE wms_id = p_wms_id);
-    l_result := l_result || (SELECT COALESCE(layer_name, '')|| ' ' || COALESCE(layer_title, '')  || ' ' || COALESCE(layer_abstract, '') FROM layer WHERE layer_id = p_layer_id);
-    FOR r_keywords IN SELECT DISTINCT keyword FROM
-        (SELECT keyword FROM layer_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id AND L.fkey_layer_id = p_layer_id)
-        ) AS __keywords__ LOOP
-        l_result := l_result || ' ' || COALESCE(r_keywords.keyword, '');
-    END LOOP;
-    FOR r_keywords IN SELECT DISTINCT md_topic_category_code_de FROM
-        (SELECT md_topic_category_code_de FROM md_topic_category T JOIN layer_md_topic_category C ON (C.fkey_md_topic_category_id = T.md_topic_category_id AND C.fkey_layer_id = p_layer_id)
-        l_result := l_result || ' ' || COALESCE(r_keywords.md_topic_category_code_de, '');
-    END LOOP;
-   l_result := UPPER(l_result);
-   l_result := replace(replace(replace(replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE'),'ä','AE'),'ü','UE'),'ö','OE');
-    RETURN l_result;
-END;
-$BODY$
--- Function: f_collect_searchtext_wfs(integer, integer)
--- DROP FUNCTION f_collect_searchtext_wfs(integer, integer)
-CREATE OR REPLACE FUNCTION f_collect_searchtext_wfs(integer, integer)
-  RETURNS text AS
-$BODY$
-DECLARE
-   p_wfs_id ALIAS FOR $1;
-   p_featuretype_id ALIAS FOR $2;
-   l_result TEXT;
-BEGIN
-   l_result := '';
-   l_result := l_result || (SELECT COALESCE(wfs_title, '') || ' ' || COALESCE(wfs_abstract, '') FROM wfs WHERE wfs_id = p_wfs_id);
-   l_result := l_result || (SELECT COALESCE(featuretype_name, '')|| ' ' || COALESCE(featuretype_title, '')  || ' ' || COALESCE(featuretype_abstract, '') FROM wfs_featuretype WHERE featuretype_id = p_featuretype_id);
-       (SELECT keyword FROM wfs_featuretype_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id AND L.fkey_featuretype_id = p_featuretype_id)
-   END LOOP;
-  l_result := replace(replace(replace(replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE'),'ü','UE'),'ö','OE'),'ä','AE');
-   RETURN l_result;
-END;
-$BODY$
--- Function: f_getwfsmodultype(integer)
-CREATE OR REPLACE FUNCTION f_getwfsmodultype(integer)
-$BODY$
-DECLARE
-    i_search INT4;
-BEGIN
-i_search := count(*) from wfs_conf, wfs_conf_element where wfs_conf.wfs_conf_id=$1 and wfs_conf.wfs_conf_id=wfs_conf_element.fkey_wfs_conf_id and f_search=1;
-IF i_search > 0 THEN
-RETURN 1;
-else
-RETURN 0;
-END IF;
-END;
-$BODY$
--- View: search_wms_view
-CREATE OR REPLACE VIEW search_wms_view AS
- SELECT DISTINCT ON (wms_unref.layer_id) wms_unref.wms_id, wms_unref.availability, wms_unref.status, wms_unref.wms_title, wms_unref.wms_abstract, wms_unref.stateorprovince, wms_unref.country, wms_unref.accessconstraints, wms_unref.termsofuse, wms_unref.wms_owner, wms_unref.layer_id, wms_unref.epsg, wms_unref.layer_title, wms_unref.layer_abstract, wms_unref.layer_name, wms_unref.layer_parent, wms_unref.layer_pos, wms_unref.layer_queryable, wms_unref.load_count, wms_unref.searchtext, wms_unref.wms_timestamp, wms_unref.department, wms_unref.user_mb_group_name, f_collect_custom_cat_layer(wms_unref.layer_id) AS md_custom_cats, f_collect_inspire_cat_layer(wms_unref.layer_id) AS md_inspire_cats, f_collect_topic_cat_layer(wms_unref.layer_id) AS md_topic_cats, geometryfromtext(((((((((((((((((((('POLYGON(('::text || layer_epsg.minx::text) || ' '::text) || layer_epsg.miny::text) || ','::text) || layer_epsg.minx::text) || ' '::text) || layer_epsg.maxy::text) || ','::text) || layer_epsg
 .maxx::text) || ' '::text) || layer_epsg.maxy::text) || ','::text) || layer_epsg.maxx::text) || ' '::text) || layer_epsg.miny::text) || ','::text) || layer_epsg.minx::text) || ' '::text) || layer_epsg.miny::text) || '))'::text, 4326) AS the_geom, (((((layer_epsg.minx::text || ','::text) || layer_epsg.miny::text) || ','::text) || layer_epsg.maxx::text) || ','::text) || layer_epsg.maxy::text AS bbox, wms_unref.wms_proxylog, wms_unref.wms_network_access, wms_unref.wms_pricevolume
-   FROM ( SELECT wms_uncat.wms_id, wms_uncat.availability, wms_uncat.status, wms_uncat.wms_title, wms_uncat.wms_abstract, wms_uncat.stateorprovince, wms_uncat.country, wms_uncat.accessconstraints, wms_uncat.termsofuse, wms_uncat.wms_owner, wms_uncat.layer_id, wms_uncat.epsg, wms_uncat.layer_title, wms_uncat.layer_abstract, wms_uncat.layer_name, wms_uncat.layer_parent, wms_uncat.layer_pos, wms_uncat.layer_queryable, wms_uncat.load_count, wms_uncat.searchtext, wms_uncat.wms_timestamp, wms_uncat.department, wms_uncat.user_mb_group_name, wms_uncat.wms_proxylog, wms_uncat.wms_network_access, wms_uncat.wms_pricevolume
-           FROM ( SELECT wms_dep.wms_id, wms_dep.availability, wms_dep.status, wms_dep.wms_title, wms_dep.wms_abstract, wms_dep.stateorprovince, wms_dep.country, wms_dep.accessconstraints, wms_dep.termsofuse, wms_dep.wms_owner, layer.layer_id, f_collect_epsg(layer.layer_id) AS epsg, layer.layer_title, layer.layer_abstract, layer.layer_name, layer.layer_parent, layer.layer_pos, layer.layer_queryable, f_layer_load_count(layer.layer_id) AS load_count, f_collect_searchtext(wms_dep.wms_id, layer.layer_id) AS searchtext, wms_dep.wms_timestamp, wms_dep.department, wms_dep.user_mb_group_name, wms_dep.wms_proxylog, wms_dep.wms_network_access, wms_dep.wms_pricevolume
-                   FROM ( SELECT wms.wms_id, wms.wms_title, wms.wms_abstract, wms.stateorprovince, wms.country, mb_wms_availability.availability, mb_wms_availability.last_status AS status, wms.accessconstraints, f_getwms_tou(wms.wms_id) AS termsofuse, wms.wms_timestamp, wms.wms_owner, wms.wms_proxylog, wms.wms_network_access, wms.wms_pricevolume, user_dep.fkey_mb_group_id AS department, user_dep.fkey_mb_group_id, user_dep.fkey_mb_group_id AS wms_department, user_dep.fkey_mb_group_id AS user_mb_group_name
-                           FROM registrating_groups user_dep, wms, mb_wms_availability
-                          WHERE wms.wms_owner = user_dep.fkey_mb_user_id AND wms.wms_id = mb_wms_availability.fkey_wms_id) wms_dep, layer
-                  WHERE layer.fkey_wms_id = wms_dep.wms_id AND layer.layer_searchable = 1) wms_uncat) wms_unref, layer_epsg
-  WHERE layer_epsg.epsg::text = 'EPSG:4326'::text AND wms_unref.layer_id = layer_epsg.fkey_layer_id
-  ORDER BY wms_unref.layer_id;
--- View: search_wfs_view
-CREATE OR REPLACE VIEW search_wfs_view AS
- SELECT wfs_dep.wfs_id, wfs_dep.wfs_title, wfs_dep.wfs_abstract, wfs_dep.administrativearea, wfs_dep.country, wfs_dep.accessconstraints, wfs_dep.termsofuse, wfs_dep.wfs_owner, wfs_featuretype.featuretype_id, wfs_featuretype.featuretype_srs, wfs_featuretype.featuretype_title, wfs_featuretype.featuretype_abstract, f_collect_searchtext_wfs(wfs_dep.wfs_id, wfs_featuretype.featuretype_id) AS searchtext, wfs_element.element_type, wfs_conf.wfs_conf_id, wfs_conf.wfs_conf_abstract, wfs_conf.wfs_conf_description, f_getwfsmodultype(wfs_conf.wfs_conf_id) AS modultype, wfs_dep.wfs_timestamp, wfs_dep.department, wfs_dep.mb_group_name
-   FROM ( SELECT wfs.wfs_id, wfs.wfs_title, wfs.wfs_abstract, wfs.administrativearea, wfs.country, wfs.accessconstraints, f_getwfs_tou(wfs.wfs_id) AS termsofuse, wfs.wfs_timestamp, wfs.wfs_owner, user_dep.mb_group_id AS department, user_dep.mb_group_name
-           FROM ( SELECT registrating_groups.fkey_mb_user_id AS mb_user_id, mb_group.mb_group_id, mb_group.mb_group_name
-                   FROM registrating_groups, mb_group
-                  WHERE registrating_groups.fkey_mb_group_id = mb_group.mb_group_id) user_dep, wfs
-          WHERE user_dep.mb_user_id = wfs.wfs_owner) wfs_dep, wfs_featuretype, wfs_element, wfs_conf
-  WHERE wfs_featuretype.fkey_wfs_id = wfs_dep.wfs_id AND wfs_featuretype.featuretype_searchable = 1 AND wfs_element.element_type::text ~~ '%Type'::text AND wfs_featuretype.featuretype_id = wfs_element.fkey_featuretype_id AND wfs_featuretype.featuretype_id = wfs_conf.fkey_featuretype_id
-  ORDER BY wfs_featuretype.featuretype_id;
--- Table: content_metadata
--- DROP TABLE content_metadata;
-CREATE TABLE content_metadata
-  metadata_id serial NOT NULL,
-  link_type character varying(255),
-  schemaid character varying(32) NOT NULL,
-  origin integer NOT NULL DEFAULT 1,
-  createdate integer,
-  changedate integer,
-  data text NOT NULL,
-  link character varying(255),
-  harvestresult integer,
-  harvestexception text,
-  uuid character varying(250),
-  title character varying(255),
-  abstract text,
-  temp_reference_1 integer,
-  temp_reference_2 integer,
-  spatial_res_type integer,
-  spatial_res_value character varying(20),
-  ref_system character varying(20),
-  format text,
-  inspire_charset character varying(10),
-  inspire_top_consistance boolean,
-  CONSTRAINT metadata_pkey PRIMARY KEY (metadata_id),
-  CONSTRAINT metadata_uuid_key UNIQUE (uuid)
-WITH OIDS;
--- Table: ows_relation_metadata
--- DROP TABLE ows_relation_metadata;
-CREATE TABLE ows_relation_metadata
-  fkey_metadata_id integer NOT NULL,
-  CONSTRAINT ows_relation_metadata_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id)
-  CONSTRAINT ows_relation_metadata_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
-  CONSTRAINT ows_relation_metadata_fkey_metadata_id_fkey FOREIGN KEY (fkey_metadata_id)
-      REFERENCES content_metadata (metadata_id) MATCH SIMPLE
-WITHOUT OIDS;
--- add CSS for resultList
-'body', 'resultListCss', '../css/resultList.css', 'css for resultList elements' ,'file/css'
-from gui_element
-WHERE
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'body' AND var_name = 'resultListCss');
--- add element var withPasswordInsertion to element editFilteredUser
-'editFilteredUser', 'withPasswordInsertion', 'true', 'define if admin can set the new user' ,'php_var'
-from gui_element
-WHERE
-gui_element.e_id = 'editFilteredUser' AND
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'editFilteredUser' AND var_name = 'withPasswordInsertion');
--- increase size of target field
-ALTER TABLE gui_element ALTER COLUMN e_target TYPE VARCHAR(255);
---function to collect the md categories for a single wmc into a column
-CREATE OR REPLACE FUNCTION f_collect_topic_cat_wmc(character varying)
-  RETURNS text AS
-  $BODY$DECLARE
-  i_wmc_id ALIAS FOR $1;
-BEGIN
-FOR topic_cat_record IN SELECT wmc_md_topic_category.fkey_md_topic_category_id from wmc_md_topic_category WHERE wmc_md_topic_category.fkey_wmc_id=$1  LOOP
-END LOOP ;
-END;
-$BODY$
-ALTER FUNCTION f_collect_topic_cat_wmc(character varying) OWNER TO postgres;
--- Function: f_collect_searchtext_wmc(varchar)
--- DROP FUNCTION f_collect_searchtext_wmc(varchar);
-CREATE OR REPLACE FUNCTION f_collect_searchtext_wmc(varchar)
-  RETURNS text AS
-$BODY$
-DECLARE
-    p_wmc_id ALIAS FOR $1;
-    l_result TEXT;
-BEGIN
-    l_result := '';
-    l_result := l_result || (SELECT COALESCE(wmc_title, '') || ' ' || COALESCE(abstract, '') FROM mb_user_wmc WHERE wmc_id = p_wmc_id);
-        (SELECT keyword FROM wmc_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id )
-    END LOOP;
-   l_result := replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE');
-    RETURN l_result;
-END;
-$BODY$
-ALTER FUNCTION f_collect_searchtext_wmc(varchar) OWNER TO postgres;
---set mb_user_mb_group_type
---of mb_user_mb_group to 1 for root!
-UPDATE mb_user_mb_group SET mb_user_mb_group_type = 1 WHERE fkey_mb_user_id = 1 AND fkey_mb_group_id = 20;
---generate demo group for decentral registrating and publishing services
--- View: search_wmc_view
--- DROP VIEW search_wmc_view;
---TODO: get group information out of mb_group table instead of ows information, cause in this case there can be more than one different service in a resource
---TODO: set public flag to some wmc docs to generate usefull results
-CREATE OR REPLACE VIEW search_wmc_view AS
- SELECT wmc_dep.fkey_user_id as user_id, wmc_dep.wmc_id , wmc_dep.srs as wmc_srs, wmc_dep.wmc_title , wmc_dep.abstract as wmc_abstract, f_collect_searchtext_wmc(wmc_dep.wmc_id) AS searchtext
-  , wmc_dep.wmc_timestamp, wmc_dep.department, wmc_dep.mb_group_name,wmc_dep.mb_group_title,wmc_dep.mb_group_country, wmc_dep.mb_group_stateorprovince ,f_collect_topic_cat_wmc(wmc_dep.wmc_id) as md_topic_cats,transform(geometryfromtext(((((((((((((((((((('POLYGON(('::text || wmc_dep.minx::text) || ' '::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.minx::text) || ' '::text) || wmc_dep.maxy::text) || ','::text) || wmc_dep.maxx::text) || ' '::text) || wmc_dep.maxy::text) || ','::text) || wmc_dep.maxx::text) || ' '::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.minx::text) || ' '::text) || wmc_dep.miny::text) || '))'::text, regexp_replace(UPPER(wmc_dep.srs), 'EPSG:', '')::INTEGER),4326) AS the_geom, (((((wmc_dep.minx::text || ','::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.maxx::text) || ','::text) || wmc_dep.maxy::text AS bbox
-	FROM ( SELECT mb_user_wmc.wmc_public, mb_user_wmc.maxy ,mb_user_wmc.maxx ,mb_user_wmc.miny ,mb_user_wmc.minx ,mb_user_wmc.srs ,mb_user_wmc.wmc_id, mb_user_wmc.wmc_title, mb_user_wmc.abstract, mb_user_wmc.wmc_timestamp, mb_user_wmc.fkey_user_id, user_dep.mb_group_id AS department, user_dep.mb_group_name,
-user_dep.mb_group_title,user_dep.mb_group_country, user_dep.mb_group_stateorprovince
-		FROM ( SELECT registrating_groups.fkey_mb_user_id AS mb_user_id, mb_group.mb_group_id, mb_group.mb_group_name, mb_group.mb_group_title, mb_group.mb_group_country, mb_group.mb_group_stateorprovince
-			FROM registrating_groups, mb_group WHERE registrating_groups.fkey_mb_group_id = mb_group.mb_group_id) as user_dep, mb_user_wmc
-		WHERE user_dep.mb_user_id = mb_user_wmc.fkey_user_id) wmc_dep WHERE  wmc_dep.wmc_public = 1 ORDER BY wmc_dep.wmc_id;
-ALTER TABLE search_wmc_view OWNER TO postgres;
--- insert deleteWFSConf modul in admin1
--- add delete wfs conf module from geoportal.rlp
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','deleteWFSConf',2,1,'delete wfs conf','','a','','href = "../javascripts/mod_deleteWfsConf_client.html" target="AdminFrame"',10,1204,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS CONF','a','','','','AdminFrame','');
--- element var removeSpatialRequestHighlight for gazetteerWFS
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'removeSpatialRequestHighlight', '0', 'remove spatialrequest highlighting when firing search' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'removeSpatialRequestHighlight' AND fkey_e_id = 'gazetteerWFS');
--- compatibility with UI Layout
-UPDATE gui_element SET e_content = '<ul></ul><div class=''ui-layout-content''></div>' WHERE e_id = 'mb_tabs_horizontal';
--- Table: layer_preview
-CREATE TABLE layer_preview
-  layer_map_preview_filename character varying(100),
-  layer_extent_preview_filename character varying(100),
-  layer_legend_preview_filename character varying(100),
-  CONSTRAINT fkey_layer_id FOREIGN KEY (fkey_layer_id)
-  CONSTRAINT layer_preview_fkey_layer_id_key UNIQUE (fkey_layer_id)
-WITH (OIDS=FALSE);
--- Table: termsofuse
-CREATE TABLE termsofuse
-  termsofuse_id integer NOT NULL,
-  "name" character varying(255),
-  symbollink character varying(255),
-  description character varying(255),
-  descriptionlink character varying(255),
-  CONSTRAINT termsofuse_pkey PRIMARY KEY (termsofuse_id)
-WITH OIDS;
--- Table: wfs_termsofuse
-CREATE TABLE wfs_termsofuse
-  fkey_termsofuse_id integer,
-  CONSTRAINT wfs_termsofuse_fkey_wfs_id_fkey FOREIGN KEY (fkey_wfs_id)
-  CONSTRAINT wfs_termsofuse_termsofuse_fkey FOREIGN KEY (fkey_termsofuse_id)
-      REFERENCES termsofuse (termsofuse_id) MATCH SIMPLE
-WITH OIDS;
--- Table: wms_termsofuse
-CREATE TABLE wms_termsofuse
-  CONSTRAINT wms_termsofuse_termsofuse_fkey FOREIGN KEY (fkey_termsofuse_id)
-  CONSTRAINT wms_termsofuse_wms_fkey FOREIGN KEY (fkey_wms_id)
-WITH OIDS;
--- Table: layer_md_topic_category
-CREATE TABLE layer_md_topic_category
-  CONSTRAINT layer_md_topic_category_fkey_layer_id_fkey FOREIGN KEY
-(fkey_layer_id)
-  CONSTRAINT layer_md_topic_category_fkey_md_topic_category_id_fkey FOREIGN
-KEY (fkey_md_topic_category_id)
-WITHOUT OIDS;
--- terms of use content
-INSERT INTO termsofuse (termsofuse_id, name, symbollink, description, descriptionlink) VALUES (1, 'CC by-nc-nd','http://i.creativecommons.org/l/by-nc-nd/3.0/de/88x31.png','Creative Commons: Namensnennung - Keine kommerzielle Nutzung - Keine Bearbeitungen 3.0 Deutschland','http://creativecommons.org/licenses/by-nc-nd/3.0/de/');
---update to jQuery 1.4.2 and jQuery UI 1.8.1
-DELETE FROM gui_element WHERE e_id IN ('jq_ui_widget','jq_ui_mouse','jq_ui_position');
-UPDATE gui_element SET e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js' WHERE e_id = 'jq_ui';
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','' FROM gui_element WHERE e_id = 'jq_ui' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_widget');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','' FROM gui_element WHERE e_id = 'jq_ui_widget' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_mouse');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','' FROM gui_element WHERE e_id = 'jq_ui_widget' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_position');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_autocomplete',4,1,'jQuery UI autocomplete','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.autocomplete.min.js','','jq_ui,jq_ui_widget,jq_ui_position','');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_progressbar',4,1,'jQuery UI progressbar','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.progressbar.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_selectable',4,1,'jQuery UI selectable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.selectable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse','');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_sortable',4,1,'jQuery UI sortable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.sortable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse','');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','' FROM gui_element WHERE e_id = 'jq_ui_dialog' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_button');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','' FROM gui_element WHERE e_id = 'jq_ui_draggable' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_droppable');
-UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.accordion.min.js' WHERE e_id = 'jq_ui_accordion';
-UPDATE gui_element SET e_requires = 'jq_ui', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.datepicker.min.js' WHERE e_id = 'jq_ui_datepicker';
-UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js' WHERE e_id = 'jq_ui_dialog';
-UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_mouse,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js' WHERE e_id = 'jq_ui_draggable';
-UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_mouse,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js' WHERE e_id = 'jq_ui_resizable';
-UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_mouse,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.slider.min.js' WHERE e_id = 'jq_ui_slider';
-UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js' WHERE e_id = 'jq_ui_tabs';
-UPDATE gui_element SET e_pos = 1 WHERE e_id = 'jq_ui_widget';
-UPDATE gui_element SET e_pos = 1 WHERE e_id = 'jq_ui_position';
-UPDATE gui_element SET e_pos = 2 WHERE e_id = 'jq_ui_mouse';
-UPDATE gui_element SET e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.effects.core.min.js' WHERE e_id = 'jq_ui_effects';
--- saveWmcTarget for element loadwmc
-SELECT gui_element.fkey_gui_id, 'loadwmc', 'saveWmcTarget', 'savewmc', '' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'saveWmcTarget'
-AND fkey_e_id = 'loadwmc');
--- color pink in body had effect on other elements
-UPDATE gui_element_vars
-set var_value = 'digitizeGeometryList {position:absolute; top:50px; left:0px;}
-.digitizeGeometryListItem {color:#000000; font-size:10px;}
-body {font-family: Arial, Helvetica, sans-serif; font-size:12px; background-color:#ffffff; margin-top: 0px; margin-left:0px;}
-.button {height:18px; width:32px;}'
-where fkey_gui_id = 'gui_digitize' and fkey_e_id = 'digitize'
-and var_name = 'text css';
--- more fields in mb_user
-alter table mb_user add column mb_user_firstname character varying(255) DEFAULT ''::character varying;
-alter table mb_user add column mb_user_lastname character varying(255) DEFAULT ''::character varying;
-alter table mb_user add column mb_user_academictitle character varying(255) DEFAULT ''::character varying;
--- mapframe1: initWms.php is replaced by initWmcObj.php
-UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php' WHERE e_id = 'mapframe1';
--- overview: initWms.php is replaced by initWmcObj.php
-UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php' WHERE e_id = 'overview';
--- missing foreign key in layer_load_count
-ALTER TABLE ONLY layer_load_count
-    ADD CONSTRAINT layer_load_count_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
--- adds Mapbender favicon to all applications whch do not have favicon yet
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.ico', 'refers to image to use as favicon' ,'php_var'
-FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon'
-AND fkey_e_id = 'body');
-UPDATE gui_element_vars set var_value = '../img/favicon.ico'
-WHERE var_name = 'favicon'
-AND var_value = '../img/favicon.png' and (fkey_gui_id IN ('gui', 'gui1', 'gui_digitize', 'gui2') OR fkey_gui_id LIKE 'admin%' OR fkey_gui_id LIKE 'wms%');
--- tabs - expandable
-'tabs', 'expandable', '0', '1 = expand the tabs to fit the document vertically, default is 0' ,'php_var'
-FROM gui_element WHERE gui_element.e_id = 'tabs' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'expandable'
-AND fkey_e_id = 'tabs');
--- draggable in map applications
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-SELECT gui.gui_id,'jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/'
-FROM gui WHERE gui.gui_id NOT LIKE 'admin%' AND gui.gui_id NOT LIKE 'wms%' AND gui.gui_id
-WHERE e_id = 'jq_ui_draggable');
--- resize map applications
-SELECT gui.gui_id,'jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/'
-WHERE e_id = 'jq_ui_resizable');
--- add new column gui_layer_title
-alter table gui_layer add column gui_layer_title character varying(255) NOT NULL DEFAULT ''::character varying;
--- fill gui_layer_title with layer_titles from layer
-UPDATE gui_layer SET gui_layer_title = (SELECT layer_title FROM layer WHERE gui_layer.fkey_layer_id = layer.layer_id);
---adoptions for managing georss/kml urls and data in the mapbender database
--- Table: datalink
--- DROP TABLE datalink;
-CREATE TABLE datalink
-  datalink_id serial NOT NULL,
-  datalink_type character varying(50) NOT NULL DEFAULT ''::character varying, --georss,kml,gml,geojson
-  datalink_type_version character varying(50) NOT NULL DEFAULT ''::character varying, --1.0,3.x?
-  datalink_url text,
-  datalink_owner integer,
-  datalink_timestamp integer,
-  datalink_timestamp_create integer,
-  datalink_timestamp_last_usage integer,
-  datalink_abstract text,
-  datalink_title character varying(255) NOT NULL DEFAULT ''::character varying,
-  datalink_data text, --maybe we want a data access for inspire and the data should stand on the geoportal cause the institutions have no webserver
-  --the following things have s.th. todo with metadata and maybe edited or filled or may not be present
-  datalink_network_access integer,
-  datalink_owsproxy character varying(50),
-  fees character varying(255),
-  accessconstraints text,
-  crs character varying(50) NOT NULL DEFAULT ''::character varying,
-  minx double precision DEFAULT 0,
-  miny double precision DEFAULT 0,
-  maxx double precision DEFAULT 0,
-  maxy double precision DEFAULT 0,
-  CONSTRAINT pk_datalink_id PRIMARY KEY (datalink_id),
---delete orphaned datalinks automatically
-  CONSTRAINT datalink_owner_fkey FOREIGN KEY (datalink_owner)
-    REFERENCES mb_user (mb_user_id) MATCH SIMPLE
-WITH (
-  OIDS=FALSE
--- Table: datalink_keyword
--- DROP TABLE datalink_keyword;
-CREATE TABLE datalink_keyword
-  fkey_datalink_id integer NOT NULL,
-  fkey_keyword_id integer NOT NULL,
-  CONSTRAINT pk_datalink_keyword PRIMARY KEY (fkey_datalink_id, fkey_keyword_id),
-  CONSTRAINT fkey_keyword_id_fkey_datalink_id FOREIGN KEY (fkey_keyword_id)
-      REFERENCES keyword (keyword_id) MATCH SIMPLE
-  CONSTRAINT fkey_datalink_id_fkey_keyword_id FOREIGN KEY (fkey_datalink_id)
-      REFERENCES datalink (datalink_id) MATCH SIMPLE
-WITH (
-  OIDS=FALSE
--- Table: datalink_md_topic_category
--- DROP TABLE datalink_md_topic_category;
-CREATE TABLE datalink_md_topic_category
-  CONSTRAINT datalink_md_topic_category_fkey_datalink_id_fkey FOREIGN KEY (fkey_datalink_id)
-  CONSTRAINT datalink_md_topic_category_fkey_md_topic_category_id_fkey FOREIGN KEY (fkey_md_topic_category_id)
-WITH (
-  OIDS=FALSE
--- add new zoomto coords to gui as a new tab
-e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
-e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
-e_mb_mod, e_target, e_requires, e_url) VALUES ('gui','coordsLookup',
-10,1,'','Coordinate lookup','div','','',1,1,NULL ,NULL ,NULL ,
-'z-index:9999;visibility:hidden','','div','mod_coordsLookup.js','',
-'mapframe1','','http://www.mapbender.org/coordsLookup');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
-var_value, context, var_type) VALUES ('gui', 'coordsLookup',
-'perimeters', '[50,200,1000,10000]', '' ,'var');
-var_value, context, var_type) VALUES('gui', 'coordsLookup',
-'projections', '[''EPSG:4326'',''EPSG:31467'',''EPSG:31468'',''EPSG:31469'',''EPSG:25832'',''EPSG:25833'']',
-'' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_frameHeight[7]', '240', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_ids[7]', 'coordsLookup', '' ,'php_var');
--- element var saveInSession for gui element savewmc
-SELECT gui_element.fkey_gui_id, 'savewmc', 'saveInSession', '0', '' ,'var'
-FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id
-WHERE var_name = 'saveInSession' AND fkey_e_id = 'savewmc');
--- previously, this had been a php var
-UPDATE gui_element_vars SET var_type = 'var' WHERE var_name = 'saveInSession' AND fkey_e_id = 'savewmc';
Copied: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql (from rev 6829, trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql)
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	2010-08-29 17:00:01 UTC (rev 6830)
@@ -0,0 +1,2697 @@
+-- remove event handlers, are now in the script
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'featureInfo1';
+UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
+-- new definition of addWMSfromfilteredList_ajax due to i18n
+UPDATE gui_element set e_attributes = '', e_js_file = 'mod_addWmsFromFilteredList_button.php' where e_id = 'addWMSfromfilteredList_ajax';
+-- polish entries for translations table, delete old ones first to avoid multi entries for one locale
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Pan';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Pan', 'Przesuń');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Display complete map';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Display complete map', 'Pokaż calą mapę');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom in';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom in', 'Powiększ');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom out';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom out', 'Pomniejsz');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Back';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Back', 'Wróć');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Forward';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Forward', 'Do przodu');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Coordinates';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Coordinates', 'Współrzędne');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom by rectangle';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom by rectangle', 'Wybierz fragment mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Redraw';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Redraw', 'Załaduj ponownie');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Query';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Query', 'Szukaj danych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Logout';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logout', 'Wymelduj');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'WMS preferences';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'WMS preferences', 'Ustawienia WMS');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS from filtered list';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from filtered list', 'Dodaj WMS z listy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set map center';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set map center', 'Zaznacz środek mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Help';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Help', 'Pomoc');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Show WMS infos';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Show WMS infos', 'Informacje WMS');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Save workspace as web map context document';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Save workspace as web map context document', 'Zapisz widok jako web map context dokument');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Resize Mapsize';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Resize Mapsize', 'Zmień rozmiar mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Rubber';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Rubber', 'Usuń szkic');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Get Area';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Get Area', 'Oblicz powierzchnię');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Close Polygon';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Close Polygon', 'Zamknij poligon');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Move back to your GUI list';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Move back to your GUI list', 'Z powrotem do listy GUI');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Legend';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Legend', 'Legenda');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Print';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Print', 'Drukuj');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Imprint';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Imprint', 'Imprint');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Maps';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Maps', 'Mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Search';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Search', 'Szukaj');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Meetingpoint';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Meetingpoint', 'Miejsce spotkań');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Metadatasearch';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Metadatasearch', 'Wyszukiwanie metadanych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS', 'Dodaj WMS');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Adding WMS from List';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Adding WMS from List', 'Dodaj WMS z listy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Info';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Info', 'Informacja');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Change Projection';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Projection', 'Zmień układ współrzędnych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Copyright';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Copyright', 'Copyright');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Digitize';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Digitize', 'Dygitalizacja');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Overview';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Overview', 'Mapa przeglądowa');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Drag Mapsize';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Drag Mapsize', 'Powiększ');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Mapframe';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Mapframe', 'Okno mapy');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Navigation Frame';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Navigation Frame', 'Pasek narzędzi');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scale Select';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Select', 'Wybierz skalę');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scale Text';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scale Text', 'Wpisz skalę');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Scalebar';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Scalebar', 'Podziałka');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set Background';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set Background', 'Wybierz mapę tematyczną jako tło');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Zoom to Coordinates';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Zoom to Coordinates', 'Powiększ według współrzędnych');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Change Password';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Change Password', 'Zmień hasło');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Load a web map context document';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Load a web map context document', 'Załaduj web map context dokument');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Logo';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Logo', 'Logo');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Measure distance';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Measure distance', 'Zmierz odległość');
+DELETE FROM translations WHERE locale = 'pl' AND msgid = 'Set language';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('pl', 'Set language', 'Wybierz język');
+-- update wfs conf module
+e_attributes = 'href = "../php/mod_wfs_conf_client.php" target="AdminFrame"'
+WHERE e_id = 'wfs_conf' AND fkey_gui_id IN ('admin1', 'admin_de_services', 'admin_en_services');
+ALTER TABLE wfs_conf ADD COLUMN
+wfs_conf_type int4 NOT NULL DEFAULT 0;
+-- new wfs conf columns
+ALTER TABLE wfs_conf_element ADD COLUMN
+f_helptext text;
+f_category_name varchar(255) NOT NULL DEFAULT '';
+-- reload uses Mapbender API
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'reload';
+-- init event is now triggered by jQuery
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body';
+-- mapframe layers are now added dynamically by the modules
+UPDATE gui_element SET e_content = '' WHERE e_id = 'mapframe1';
+-- file extension is now .js
+UPDATE gui_element SET e_js_file = 'mod_log.js' WHERE e_id = 'log';
+UPDATE gui_element SET e_js_file = 'mod_resize_mapsize.js' WHERE e_id = 'resizeMapsize';
+UPDATE gui_element SET e_js_file = 'mod_sandclock.js' WHERE e_id = 'sandclock';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomFull';
+UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_zoomFull.js' WHERE e_id = 'zoomFull';
+UPDATE gui_element SET e_attributes = '', e_js_file = 'mod_repaint.js' WHERE e_id = 'repaint';
+UPDATE gui_element SET e_js_file = 'mod_changeEPSG.js' WHERE e_id = 'changeEPSG';
+UPDATE gui_element SET e_js_file = 'mod_scalebar.js' WHERE e_id = 'scalebar';
+-- parameter: skip WMS request if current SRS is not supported
+-- I'm not sure how to insert this dynamically into all applications that have either mapframe1 or overview
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars
+WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
+-- element var skipWmsIfSrsNotSupported for gui element overview
+SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported'
+AND fkey_e_id = 'overview');
+---------------------------------------------MONITORING BEGIN
+-- Index: idx_mb_monitor_status
+-- DROP INDEX idx_mb_monitor_status;
+CREATE INDEX idx_mb_monitor_status
+  ON mb_monitor
+  USING btree
+  (status);
+-- Index: idx_mb_monitor_upload_id
+-- DROP INDEX idx_mb_monitor_upload_id;
+CREATE INDEX idx_mb_monitor_upload_id
+  ON mb_monitor
+  USING btree
+  (upload_id);
+-- Table: mb_wms_availability
+-- DROP TABLE mb_wms_availability;
+CREATE TABLE mb_wms_availability
+  fkey_wms_id integer,
+  fkey_upload_id character varying,
+  last_status integer,
+  availability real,
+  image integer,
+  status_comment character varying,
+  average_resp_time real,
+  upload_url character varying,
+  map_url character varying,
+  CONSTRAINT mb_wms_availability_fkey_wms_id_wms_id FOREIGN KEY (fkey_wms_id)
+      REFERENCES wms (wms_id) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE CASCADE
+WITH OIDS;
+-- Function: mb_monitor_after()
+-- DROP FUNCTION mb_monitor_after();
+CREATE OR REPLACE FUNCTION mb_monitor_after()
+  RETURNS "trigger" AS
+$BODY$DECLARE
+   availability_new REAL;
+   average_res_cap REAL;
+   count_monitors REAL;
+    BEGIN
+     IF TG_OP = 'UPDATE' THEN
+     count_monitors := count(fkey_wms_id) from mb_monitor where fkey_wms_id=NEW.fkey_wms_id;
+      --the following should be adopted if the duration of storing is changed!!!
+      average_res_cap := ((select average_resp_time from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors+(NEW.timestamp_end-NEW.timestamp_begin))/(count_monitors+1);
+     IF NEW.status > -1 THEN --service gives caps
+      availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors + 100)/(count_monitors+1) as numeric),2);
+     ELSE --service has problems with caps
+      availability_new := round(cast(((select availability from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id)*count_monitors)/(count_monitors+1) as numeric),2);
+     END IF;
+      UPDATE mb_wms_availability SET average_resp_time=average_res_cap,last_status=NEW.status, availability=availability_new, image=NEW.image, status_comment=NEW.status_comment,upload_url=NEW.upload_url,map_url=NEW.map_url WHERE mb_wms_availability.fkey_wms_id=NEW.fkey_wms_id;
+      RETURN NEW;
+     END IF;
+     IF TG_OP = 'INSERT' THEN
+	IF (select count(fkey_wms_id) from mb_wms_availability where fkey_wms_id=NEW.fkey_wms_id) > 0  then -- service is not new
+			UPDATE mb_wms_availability set fkey_upload_id=NEW.upload_id,last_status=NEW.status,status_comment=NEW.status_comment,upload_url=NEW.upload_url where fkey_wms_id=NEW.fkey_wms_id;
+		else --service has not yet been monitored
+			INSERT INTO mb_wms_availability (fkey_upload_id,fkey_wms_id,last_status,status_comment,upload_url,map_url,average_resp_time,availability) VALUES (NEW.upload_id,NEW.fkey_wms_id,NEW.status,NEW.status_comment,NEW.upload_url::text,NEW.map_url,0,100);
+		end if;
+      RETURN NEW;
+     END IF;
+    END;
+$BODY$
+  LANGUAGE 'plpgsql' VOLATILE;
+-- Trigger: mb_monitor_after on mb_monitor
+-- DROP TRIGGER mb_monitor_after ON mb_monitor;
+CREATE TRIGGER mb_monitor_after
+  AFTER INSERT OR UPDATE
+  ON mb_monitor
+  FOR EACH ROW
+  EXECUTE PROCEDURE mb_monitor_after();
+-- Table: mb_user_abo_ows
+-- DROP TABLE mb_user_abo_ows;
+CREATE TABLE mb_user_abo_ows
+  fkey_mb_user_id integer,
+  fkey_wfs_id integer,
+  CONSTRAINT mb_user_abo_ows_user_id_fkey FOREIGN KEY (fkey_mb_user_id)
+      REFERENCES mb_user (mb_user_id) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE CASCADE,
+  CONSTRAINT mb_user_abo_ows_wfs_fkey FOREIGN KEY (fkey_wfs_id)
+      REFERENCES wfs (wfs_id) MATCH SIMPLE
+  CONSTRAINT mb_user_abo_ows_wms_fkey FOREIGN KEY (fkey_wms_id)
+WITHOUT OIDS;
+-- Index: idx_wms_id
+-- DROP INDEX idx_wms_id;
+CREATE INDEX idx_wms_id
+  ON wms
+  USING btree
+  (wms_id);
+-- add monitor subscriber notification to admin1
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+SELECT gui.gui_id, 'monitor_abo_show',2,1,'monitoring','Show subscriptions','a','','href = "../php/mod_abo_show.php?sessionID" target = "AdminFrame" ',8,1080,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Manage monitoring subscriptions','a','','','','AdminFrame','http://www.mapbender.org/'
+FROM gui WHERE gui.gui_id = 'admin1' AND gui.gui_id
+WHERE e_id = 'monitor_abo_show' AND fkey_gui_id = 'admin1');
+-- add monitor results to admin1
+SELECT gui.gui_id, 'monitor_results',2,1,'monitoring results','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID" target = "AdminFrame" ',8,1110,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','View monitoring results','a','','','','AdminFrame','http://www.mapbender.org/'
+WHERE e_id = 'monitor_results');
+---------------------------------------------MONITORING END
+-- OWS Proxy log
+CREATE TABLE mb_proxy_log (
+    proxy_log_timestamp timestamp default now(),
+    fkey_wms_id integer NOT NULL,
+    fkey_mb_user_id integer NOT NULL,
+    request varchar(4096),
+    pixel bigint,
+    price real
+with oids;
+ALTER TABLE wms ADD COLUMN wms_proxylog integer;
+ALTER TABLE wms ALTER COLUMN wms_proxylog SET STORAGE PLAIN;
+ALTER TABLE wms ADD COLUMN wms_pricevolume integer;
+ALTER TABLE wms ALTER COLUMN wms_pricevolume SET STORAGE PLAIN;
+-- http auth
+ALTER TABLE wms ADD COLUMN wms_username VARCHAR(255) NOT NULL DEFAULT '';
+ALTER TABLE wms ADD COLUMN wms_password VARCHAR(255) NOT NULL DEFAULT '';
+ALTER TABLE wms ADD COLUMN wms_auth_type VARCHAR(255) NOT NULL DEFAULT '';
+-- Column: mb_user_digest
+-- ALTER TABLE mb_user DROP COLUMN mb_user_digest;
+ALTER TABLE mb_user ADD COLUMN mb_user_digest text;
+ALTER TABLE mb_user ALTER COLUMN mb_user_digest SET STORAGE EXTENDED;
+--Initial filling with empty strings
+UPDATE mb_user set mb_user_digest='';
+--howto set up the http_auth digest hash
+--update mb_user set mb_user_digest=md5(mb_user_name || ';' || mb_user_email || ':' || '<realm_name>' || ':' || 'password') where mb_user_id = <ID>;
+-- http://www.mapbender.org/FeatureInfo#considerScalehints --
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- greek updates for translations table
+update translations set msgstr = 'Περίγραμμα/Κορνίζα πλοήγησης' where msgid = 'Navigation Frame' and locale = 'gr';
+update translations set msgstr = 'Φόρτωση κειμένου διαδυκτιακού χάρτη' where msgid = 'Load a web map context document' and locale = 'gr';
+update translations set msgstr = 'Αποθήκευση χώρου εργασίας με μορφή κείμενου διαδυκτιακού χάρτη' where msgid = 'Save workspace as web map context document' and locale = 'gr';
+UPDATE gui_element SET e_js_file = 'mod_selArea.js' WHERE e_id = 'selArea1';
+UPDATE gui_element SET e_js_file = 'mod_zoomIn1.js' WHERE e_id = 'zoomIn1';
+UPDATE gui_element SET e_js_file = 'mod_overview.js' WHERE e_id = 'overview';
+UPDATE gui_element SET e_js_file = 'mod_zoomOut1.js' WHERE e_id = 'zoomOut1';
+-- set white background to Mapframe1
+UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='mapframe1';
+-- background to overview
+UPDATE gui_element set e_more_styles='overflow:hidden;background-color:#ffffff' where e_id='overview';
+UPDATE gui_element SET e_js_file = 'mod_pan.js' WHERE e_id = 'pan1';
+-- remove title tag of Mapframe1 because it's displayed  im Map
+UPDATE gui_element SET e_title='' WHERE e_id='mapframe1';
+UPDATE gui_element SET e_title='' WHERE e_id='overview';
+-- resize admin frame in admin guis
+UPDATE gui_element SET e_width = 1000 WHERE e_id = 'AdminFrame';
+-- CSW handling add CSW administration to admin2_de , admin2_en, admin1
+-- admin2_en
+SELECT gui.gui_id, 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' Catalog Management', 'div', '', '', '', '', ''
+FROM gui WHERE gui.gui_id = 'admin2_en' AND gui.gui_id
+WHERE e_id = 'headline_Configure_CSW');
+SELECT gui.gui_id, 'loadCSW', 3, 1, 'Add Catalog', 'Add Catalog', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
+WHERE e_id = 'loadCSW');
+SELECT gui.gui_id, 'loadCSWGUI', 3, 1, 'Link Catalog to GUI', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
+WHERE e_id = 'loadCSWGUI');
+-- admin2_de
+SELECT gui.gui_id, 'headline_Configure_CSW', 3, 1, 'Catalog Management', 'Catalog Management', 'div', '', '', 5, 760, 193, 66, 2, '', ' CSW Verwaltung', 'div', '', '', '', '', ''
+FROM gui WHERE gui.gui_id = 'admin2_de' AND gui.gui_id
+SELECT gui.gui_id, 'loadCSW', 3, 1, 'CSW laden', 'CSW laden', 'a', '', 'href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ', 8, 780, 190, 20, 5, '', 'Add Catalog', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
+SELECT gui.gui_id, 'loadCSWGUI', 3, 1, 'CSW einer Applikation zuordnen', 'Link Catalog to GUI', 'a', '', 'href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ', 8, 800, 190, 20, 5, '', 'Link Catalog to GUI', 'a', '', '', '', 'AdminFrame', 'http://www.mapbender.org/index.php/newGUI'
+-- admin1
+SELECT gui.gui_id, 'loadCSW',3,1,'Add Catalog','Add Catalog','a','','href = "../php/mod_loadCatalogCapabilities.php?sessionID" target = "AdminFrame" ',8,1140,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Add Catalog','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI'
+SELECT gui.gui_id, 'loadCSWGUI',3,1,'Link Catalog to GUI','Link Catalog to GUI','a','','href = "../php/mod_loadCatalogToGUI.php?sessionID" target = "AdminFrame" ',8,1160,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Link Catalog to GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI'
+-- add CSW search to gui1
+SELECT gui.gui_id,'addCSW',2,1,'search via a CSW Client','Search CSW','img','../img/button_gray/csw_off.png','onclick=''var searchCSWPopup = new mb_popup({title:"Search Catalog",url:"../javascripts/mod_searchCSW_ajax.php?sessionID",width:720, height:600,left:20, top:20});searchCSWPopup.show()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Search Catalog"',925,60,24,24,1,'','','','mod_addCSW.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW'
+FROM gui WHERE gui.gui_id = 'gui1' AND gui.gui_id
+WHERE e_id = 'addCSW');
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'resizeMapsize';
+-- CSW Support - new Tables to build up CSW support
+CREATE TABLE cat
+  cat_id serial NOT NULL, -- auto generated
+  cat_version character varying(50) NOT NULL DEFAULT ''::character varying, -- get from cat version from xml - service_type_version
+  --cat_name character varying(255), -- ows-service-id:title
+  cat_title character varying(255) NOT NULL DEFAULT ''::character varying, --ows-service-id:title
+  cat_abstract text, --ows-service-id:abstract
+  --cat_keywords do we need them? There maybe a special table? - cs:keywords - another table to hold kw
+  --UploadUrl
+  cat_upload_url character varying(255),
+  fees character varying(50), --servicetype-fees
+  accessconstraints text, -- servicetype-accessconstraints
+  --ServiceProvider
+  providername character varying(255),
+  providersite character varying(255),
+  --ServiceContact
+  individualname character varying(255),
+  positionname character varying(255),
+  --ContactInfo
+  voice character varying(255), -- Phone
+  facsimile character varying(255),
+  --Address
+  deliverypoint character varying(255),
+  city character varying(255),
+  administrativearea character varying(255),
+  postalcode character varying(255),
+  country character varying(255),
+  electronicmailaddress character varying(255),
+  --Whole Cap-doc
+  cat_getcapabilities_doc text,
+  --Information about Owner
+  cat_owner integer,
+  --Actuality
+  cat_timestamp integer
+ALTER TABLE ONLY cat
+    ADD CONSTRAINT cat_pkey PRIMARY KEY (cat_id);
+CREATE TABLE cat_keyword (
+    fkey_cat_id integer NOT NULL,
+    fkey_keyword_id integer NOT NULL
+ALTER TABLE ONLY cat_keyword
+    ADD CONSTRAINT pk_cat_keyword PRIMARY KEY (fkey_cat_id, fkey_keyword_id);
+    ADD CONSTRAINT fkey_keyword_id_fkey_cat_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT fkey_cat_id_fkey_keyword_id FOREIGN KEY (fkey_cat_id) REFERENCES cat(cat_id) ON UPDATE CASCADE ON DELETE CASCADE;
+CREATE TABLE gui_cat
+  fkey_gui_id character varying(50) NOT NULL DEFAULT ''::character varying,
+  fkey_cat_id integer NOT NULL DEFAULT 0,
+  CONSTRAINT fkey_cat_gui_id FOREIGN KEY (fkey_gui_id)
+      REFERENCES gui (gui_id) MATCH SIMPLE
+  CONSTRAINT fkey_cat_cat_id FOREIGN KEY (fkey_cat_id)
+      REFERENCES cat (cat_id) MATCH SIMPLE
+CREATE TABLE cat_op_conf
+  fk_cat_id integer NOT NULL,
+  param_name character varying(255) NOT NULL,
+  param_value text NOT NULL,
+  param_type character varying(255) NOT NULL,
+  CONSTRAINT pk_con_cat_op PRIMARY KEY (fk_cat_id, param_type, param_name, param_value),
+  CONSTRAINT fk_cat_conf_to_cat FOREIGN KEY (fk_cat_id)
+-- remove obsolete src from treeGDE (no longer a frame)
+UPDATE gui_element SET e_src = '' WHERE e_id = 'treeGDE';
+-- remove frameborder = 0 from treeGDE (no longer a frame)
+UPDATE gui_element SET e_attributes = 'onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"' WHERE e_id = 'treeGDE';
+-- remove frameborder = 0 from switchLocale_noreload
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'switchLocale_noreload';
+-- add title
+UPDATE gui_element SET e_content = '<select style="font-family: Arial, sans-serif; font-size:12" title="Set background" name="mod_setBackground_list" onchange="mod_setBackground_change(this)"><option value="0"></option></select>' WHERE e_id = 'setBackground';
+-- remove nobr tag from mapbender
+UPDATE gui_element SET e_content = '<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>' WHERE e_id = 'mapbender';
+-- correct URL encoding
+UPDATE gui_element SET e_attributes = E'onclick="printWindow = window.open(\'../print/mod_printPDF.php?target=mapframe1&amp;sessionID&amp;conf=printPDF_b.conf\',\'printWin\',\'width=260, height=380, resizable=yes\');printWindow.focus();"  onmouseover="this.src = this.src.replace(/_off/,\'_over\');" onmouseout="this.src = this.src.replace(/_over/, \'_off\');"' WHERE e_id = 'printPDF';
+-- added mandatory action attribute
+UPDATE gui_element SET e_attributes = 'action="window.location.href"' WHERE e_id = 'setBackground';
+UPDATE gui_element SET e_attributes = 'action="window.location.href" onsubmit="return mod_scaleText()"' WHERE e_id = 'scaleText';
+UPDATE gui_element SET e_content = '<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>' WHERE e_id = 'switchLocale_noreload';
+-- attributes only valid for printPDF button (img)
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element = 'iframe';
+-- New NavFrame element-vars (color and hoverColor) see http://trac.osgeo.org/mapbender/ticket/540
+-- element var backGroundColor for gui element navFrame
+SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor'
+AND fkey_e_id = 'navFrame');
+-- element var backGroundHoverColor for gui element navFrame
+SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var'
+WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
+ALTER TABLE mb_user_wmc ADD COLUMN
+wmc_timestamp_create INTEGER;
+CREATE TABLE wmc_md_topic_category (
+    fkey_wmc_id character varying(20) NOT NULL,
+    fkey_md_topic_category_id integer NOT NULL
+ALTER TABLE ONLY wmc_md_topic_category
+    ADD CONSTRAINT wmc_md_topic_category_fkey_wmc_id_fkey FOREIGN KEY (fkey_wmc_id) REFERENCES mb_user_wmc (wmc_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- jQuery UI
+SELECT gui.gui_id,'jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','',''
+FROM gui WHERE gui.gui_id NOT LIKE 'admin%' AND gui.gui_id NOT LIKE 'wms%' AND gui.gui_id
+WHERE e_id = 'jq_ui');
+SELECT gui_element.fkey_gui_id, 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css'
+FROM gui_element WHERE gui_element.e_id = 'jq_ui' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'css'
+AND fkey_e_id = 'jq_ui');
+-- jQuery datatables
+SELECT gui.gui_id,'jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/'
+WHERE e_id = 'jq_datatables');
+SELECT gui_element.fkey_gui_id, 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css'
+FROM gui_element WHERE gui_element.e_id = 'jq_datatables' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'defaultCss'
+AND fkey_e_id = 'jq_datatables');
+-- jQuery UI tabs
+SELECT gui.gui_id,'jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui',''
+WHERE e_id = 'jq_ui_tabs');
+-- jQuery upload
+SELECT gui.gui_id,'jq_upload',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../plugins/jq_upload.js','','',''
+WHERE e_id = 'jq_upload');
+-- jQuery datatables CSS in Body
+SELECT gui_element.fkey_gui_id, 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css'
+FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id = 'gui1' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jquery_datatables'
+AND fkey_e_id = 'body');
+-- add jquery ui dialog to gui1
+SELECT gui.gui_id,'jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui',''
+WHERE e_id = 'jq_ui_dialog');
+wmc_public INTEGER NOT NULL DEFAULT 0;
+-- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
+UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
+-- overwrite WMC documents if name and user are identical (0 == old behaviour, 1 == overwrite)
+-- element var overwrite for gui element savewmc
+SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id
+WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
+-- add history to map object
+UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1' OR e_id = 'overview';
+		ADD COLUMN abstract TEXT,
+		ADD COLUMN srs CHARACTER VARYING,
+		ADD COLUMN minx DOUBLE PRECISION DEFAULT 0,
+		ADD COLUMN miny DOUBLE PRECISION DEFAULT 0,
+		ADD COLUMN maxx DOUBLE PRECISION DEFAULT 0,
+		ADD COLUMN maxy DOUBLE PRECISION DEFAULT 0;
+CREATE TABLE wmc_keyword (
+	fkey_keyword_id	INTEGER REFERENCES keyword(keyword_id) ON DELETE CASCADE ON UPDATE CASCADE,
+	fkey_wmc_id CHARACTER VARYING(20) REFERENCES mb_user_wmc(wmc_id) ON DELETE CASCADE ON UPDATE CASCADE
+ALTER TABLE ONLY wmc_keyword
+     ADD CONSTRAINT pk_wmc_keyword PRIMARY KEY (fkey_wmc_id, fkey_keyword_id);
+-- disable publish WMC and delete WMC for gui1
+SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'loadwmc'
+AND gui_element.fkey_gui_id
+WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
+-- element var publishWmc for gui element loadwmc
+SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element
+WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id
+WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
+-- add publish WMC to admin1
+SELECT gui.gui_id, 'wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame',''
+WHERE e_id = 'wmcPublic' AND fkey_gui_id = 'admin1');
+-- add required modules for loadwmc and savewmc
+UPDATE gui_element SET e_attributes = 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
+UPDATE gui_element SET e_requires = 'jq_ui_dialog' WHERE e_id = 'savewmc';
+-- set new element vars for existing gui elements of non-standard guis
+-- element var switchwms for gui element treeGDE
+SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id
+WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
+-- element i18n for all guis
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+SELECT DISTINCT fkey_gui_id,'i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','','','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext'
+FROM gui_element WHERE gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'i18n');
+-- increase fields for wfs featuretype attributes name
+ALTER TABLE wfs_element ALTER COLUMN element_name TYPE VARCHAR(255);
+-- add georss in gui1
+SELECT gui.gui_id,'addGeoRSS',2,1,'add a GeoRSS Feed to a running application','Add GeoRSS','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','',''
+WHERE e_id = 'addGeoRSS');
+SELECT gui_element.fkey_gui_id, 'addGeoRSS', 'loadGeorssFromSession', '1', '' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'addGeoRSS' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'loadGeorssFromSession'
+AND fkey_e_id = 'addGeoRSS');
+-- element var initializeOnLoad for gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'initializeOnLoad', '0', 'start gazetteer onload' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'initializeOnLoad' AND fkey_e_id = 'gazetteerWFS');
+-- element var enableSearchWithoutParams for gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'enableSearchWithoutParams' AND fkey_e_id = 'gazetteerWFS');
+UPDATE gui_element SET e_js_file = '../plugins/mb_selectMapsize.js', e_attributes = '' WHERE e_id = 'selectMapsize';
+INSERT INTO cat VALUES (2, '2.0.2', 'NLR CSW', '			NLR CSW: XQuery based catalog service conform to the HTTP protocol binding  of the OpenGIS Catalogue Service specification version 2.0.2/2.0.1		', 'http://geomatics.nlr.nl/excat/csw?request=GetCapabilities&service=CSW&version=2.0.2', 'NONE', 'NONE', NULL, NULL, 'Rob van Swol', 'Senior Scientist NLR-ASSP', NULL, NULL, '', NULL, NULL, NULL, NULL, 'vanswol at nlr.nl', '<?xml version="1.0" encoding="UTF-8"?><csw:Capabilities xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows" xmlns:xlink="http://www.w3.org/1999/xlink" version="2.0.2">
+	<ows:ServiceIdentification>
+		<ows:Title>NLR CSW</ows:Title>
+		<ows:Abstract>
+			NLR CSW: XQuery based catalog service conform to the HTTP protocol binding
+ of the OpenGIS Catalogue Service specification version 2.0.2/2.0.1
+		</ows:Abstract>
+		<ows:Keywords>
+			<ows:Keyword>CSW</ows:Keyword>
+			<ows:Keyword>geospatial</ows:Keyword>
+			<ows:Keyword>catalogue</ows:Keyword>
+		</ows:Keywords>
+		<ows:ServiceType>CSW</ows:ServiceType>
+		<ows:ServiceTypeVersion>2.0.2</ows:ServiceTypeVersion>
+		<ows:Fees>NONE</ows:Fees>
+		<ows:AccessConstraints>NONE</ows:AccessConstraints>
+	</ows:ServiceIdentification>
+	<ows:ServiceProvider>
+		<ows:ProviderName>National Aerospace Laboratory NLR</ows:ProviderName>
+		<ows:ProviderSite xlink:href="http://geomatics.nlr.nl/excat"/>
+		<ows:ServiceContact>
+			<ows:IndividualName>Rob van Swol</ows:IndividualName>
+			<ows:PositionName>Senior Scientist NLR-ASSP</ows:PositionName>
+			<ows:ContactInfo>
+				<ows:Phone>
+					<ows:Voice>+31 527 248252</ows:Voice>
+				</ows:Phone>
+				<ows:Address>
+					<ows:ElectronicMailAddress>vanswol at nlr.nl</ows:ElectronicMailAddress>
+				</ows:Address>
+			</ows:ContactInfo>
+		</ows:ServiceContact>
+	</ows:ServiceProvider>
+	<ows:OperationsMetadata>
+		<ows:Operation name="GetCapabilities">
+			<ows:DCP>
+				<ows:HTTP>
+					<ows:Get xlink:href="http://geomatics.nlr.nl/excat/csw"/>
+					<ows:Post xlink:href="http://geomatics.nlr.nl/excat/csw"/>
+				</ows:HTTP>
+			</ows:DCP>
+			<ows:Parameter name="sections">
+				<ows:Value>ServiceIdentification</ows:Value>
+				<ows:Value>ServiceProvider</ows:Value>
+				<ows:Value>OperationsMetadata</ows:Value>
+				<ows:Value>Filter_Capabilities</ows:Value>
+			</ows:Parameter>
+		</ows:Operation>
+		<ows:Operation name="DescribeRecord">
+			<ows:DCP>
+				<ows:HTTP>
+				</ows:HTTP>
+			</ows:DCP>
+			<ows:Parameter name="TypeName">
+				<ows:Value>csw:Record</ows:Value>
+				<ows:Value>gmd:MD_Metadata</ows:Value>
+			</ows:Parameter>
+			<ows:Parameter name="OutputFormat">
+				<ows:Value>application/xml</ows:Value>
+			</ows:Parameter>
+			<ows:Parameter name="SchemaLanguage">
+				<ows:Value>XMLSCHEMA</ows:Value>
+				<ows:Value>http://www.w3.org/XML/Schema</ows:Value>
+			</ows:Parameter>
+		</ows:Operation>
+		<ows:Operation name="GetDomain">
+			<ows:DCP>
+				<ows:HTTP>
+					<ows:Get  xlink:href="http://geomatics.nlr.nl/excat/csw" />
+					<ows:Post xlink:href="http://geomatics.nlr.nl/excat/csw"  />
+				</ows:HTTP>
+			</ows:DCP>
+		</ows:Operation>
+		<ows:Operation name="GetRecords">
+			<ows:DCP>
+				<ows:HTTP>
+				</ows:HTTP>
+			</ows:DCP>
+			</ows:Parameter>
+			</ows:Parameter>
+			<ows:Parameter name="OutputSchema">
+				<ows:Value>OGCCORE</ows:Value>
+				<ows:Value>http://www.opengis.net/cat/csw/2.0.2</ows:Value>
+				<!--ows:Value>http://www.isotc211.org/2005/gmd</ows:Value-->
+				<!--ows:Value>ISO19139</ows:Value-->
+				<!--ows:Value>CEN</ows:Value-->
+				<!--ows:Value>ISO19115</ows:Value-->
+			</ows:Parameter>
+			<ows:Parameter name="ResultType">
+				<ows:Value>results</ows:Value>
+				<ows:Value>hits</ows:Value>
+			</ows:Parameter>
+			<ows:Parameter name="ElementSetName">
+				<ows:Value>summary</ows:Value>
+				<ows:Value>brief</ows:Value>
+				<ows:Value>full</ows:Value>
+			</ows:Parameter>
+			<ows:Parameter name="ConstraintLanguage">
+				<ows:Value>Filter</ows:Value>
+				<ows:Value>CQL_Text</ows:Value>
+			</ows:Parameter>
+		</ows:Operation>
+		<ows:Operation name="GetRecordById">
+			<ows:DCP>
+				<ows:HTTP>
+				</ows:HTTP>
+			</ows:DCP>
+			</ows:Parameter>
+				<ows:Value>http://www.isotc211.org/2005/gmd</ows:Value>
+				<ows:Value>ISO19139</ows:Value>
+				<ows:Value>ISO19139NL</ows:Value>
+			</ows:Parameter>
+			</ows:Parameter>
+		</ows:Operation>
+		<ows:Operation name="Transaction">
+			<ows:DCP>
+				<ows:HTTP>
+				</ows:HTTP>
+			</ows:DCP>
+		</ows:Operation>
+		<ows:Operation name="Harvest">
+			<ows:DCP>
+				<ows:HTTP>
+				</ows:HTTP>
+			</ows:DCP>
+		</ows:Operation>
+		<!-- Parameters -->
+		<ows:Parameter name="service">
+		</ows:Parameter>
+		<ows:Parameter name="version">
+			<ows:Value>2.0.2</ows:Value>
+			<ows:Value>2.0.1</ows:Value>
+			<ows:Value>2.0.0</ows:Value>
+		</ows:Parameter>
+	</ows:OperationsMetadata>
+	<ogc:Filter_Capabilities>
+		<ogc:Spatial_Capabilities>
+			<ogc:GeometryOperands>
+				<ogc:GeometryOperand>gml:Envelope</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Point</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:LineString</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Polygon</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:ArcByCenterPoint</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:CircleByCenterPoint</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Arc</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Circle</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:ArcByBulge</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Bezier</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Clothoid</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:CubicSpline</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Geodesic</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:OffsetCurve</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Triangle</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:PolyhedralSurface</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:TriangulatedSurface</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Tin</ogc:GeometryOperand>
+				<ogc:GeometryOperand>gml:Solid</ogc:GeometryOperand>
+			</ogc:GeometryOperands>
+			<ogc:SpatialOperators>
+				<ogc:SpatialOperator name="BBOX"/>
+				<ogc:SpatialOperator name="Within"/>
+				<ogc:SpatialOperator name="Equals"/>
+				<ogc:SpatialOperator name="Overlaps"/>
+				<ogc:SpatialOperator name="Disjoint"/>
+				<ogc:SpatialOperator name="Intersects"/>
+				<ogc:SpatialOperator name="Touches"/>
+				<ogc:SpatialOperator name="Crosses"/>
+				<ogc:SpatialOperator name="Contains"/>
+				<ogc:SpatialOperator name="Beyond"/>
+				<ogc:SpatialOperator name="DWithin"/>
+				<!-- The ''SpatialOperator'' element can have a GeometryOperands child -->
+			</ogc:SpatialOperators>
+		</ogc:Spatial_Capabilities>
+		<ogc:Scalar_Capabilities>
+			<ogc:LogicalOperators/>
+			<ogc:ComparisonOperators>
+				<ogc:ComparisonOperator>EqualTo</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>Like</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>LessThan</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>GreaterThan</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>LessThanEqualTo</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>GreaterThanEqualTo</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>NotEqualTo</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>Between</ogc:ComparisonOperator>
+				<ogc:ComparisonOperator>NullCheck</ogc:ComparisonOperator>
+			</ogc:ComparisonOperators>
+			<ogc:ArithmeticOperators>
+				<ogc:SimpleArithmetic>
+				<ogc:Functions>
+					<ogc:FunctionNames>
+						<ogc:FunctionName nArgs="1">MIN</ogc:FunctionName>
+					</ogc:FunctionNames>
+				</ogc:Functions>
+			</ogc:ArithmeticOperators>
+		</ogc:Scalar_Capabilities>
+		<ogc:Id_Capabilities>
+			<ogc:EID/>
+			<ogc:FID/>
+		</ogc:Id_Capabilities>
+	</ogc:Filter_Capabilities>
+</csw:Capabilities>
+', 1, 1260622475);
+-- Data for Name: cat_keyword; Type: TABLE DATA; Schema: public; Owner: postgres
+-- Data for Name: cat_op_conf; Type: TABLE DATA; Schema: public; Owner: postgres
+INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'getcapabilities');
+INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'getcapabilities');
+INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'describerecord');
+INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'describerecord');
+INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'getrecords');
+INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'getrecords');
+INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'getrecordbyid');
+INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'getrecordbyid');
+INSERT INTO gui_cat VALUES ('gui1', 2);
+-- mapframe1 is now a jQuery plugin
+UPDATE gui_element SET e_js_file = '../plugins/mb_map.js' WHERE e_id = 'mapframe1';
+UPDATE gui_element SET e_js_file = '../plugins/mb_overview.js' WHERE e_id = 'overview';
+--dragmapsize is themeroller ready
+UPDATE gui_element SET e_attributes = 'class="ui-state-default"', e_more_styles = 'font-size:1px; cursor:move; width:10; height:10;' WHERE e_id = 'dragMapSize';
+--tabs are themeroller ready
+UPDATE gui_element_vars SET var_value = 'position:absolute;visibility:visible;cursor:pointer;' WHERE var_name = 'tab_style' AND fkey_e_id = 'tabs';
+--nav frame is themeroller ready
+DELETE FROM gui_element_vars WHERE var_name = 'backGroundColor' AND fkey_e_id = 'navFrame';
+DELETE FROM gui_element_vars WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame';
+-- set UI classes for treeGDE
+UPDATE gui_element SET e_more_styles = 'visibility:hidden;overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
+WHERE e_id = 'treeGDE' AND fkey_gui_id IN
+(SELECT a.fkey_gui_id FROM gui_element AS a, gui_element AS b WHERE a.e_id = 'tabs' AND b.e_id = 'treeGDE' AND a.fkey_gui_id = b.fkey_gui_id);
+-- remove expanding treeGDE in gui1
+UPDATE gui_element SET e_more_styles = 'overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
+WHERE e_id = 'treeGDE' AND fkey_gui_id IN ('gui1');
+-- add new container toolbox_jquery
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('toolbox_jquery','toolbox_jquery','All jQuery related elements in Mapbender',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','body',1,1,'body (obligatory)','','body','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_datatables',1,1,'jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_jgrowl',1,1,'A growl like widget to display messages','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_jgrowl.js','../extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js','','','http://stanlemon.net/projects/jgrowl.html');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_accordion',2,1,'accordion from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js','','jq_ui','http://docs.jquery.com/UI/Accordion');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_logo',2,1,'Logo','jQuery UI Logo','img','../img/jquery_ui_logo.png','',35,15,NULL ,NULL ,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_slider',5,1,'slider from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_themeroller',1,1,'A button that opens the ThemeRoller from a remote site','Themeroller','a','','class=''ui-state-default ui-corner-all''
+href="javascript:(function(){if%20(!/Firefox/.test(navigator.userAgent)){alert(navigator.userAgent);%20return%20false;%20};%20if(window.jquitr){%20jquitr.addThemeRoller();%20}%20else{%20jquitr%20=%20{};%20jquitr.s%20=%20document.createElement(''script'');%20jquitr.s.src%20=%20''http://jqueryui.com/themeroller/developertool/developertool.js.php'';%20document.getElementsByTagName(''head'')[0].appendChild(jquitr.s);}%20})();"',320,15,NULL ,NULL ,NULL ,'text-decoration:none;padding:0.4em 1em 0.4em 20px','Custom theme','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'body', 'jq_ui_effects_transfer', '.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ', '', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'body', 'jq_ui_theme', '../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css', 'UI Theme from Themeroller', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'blind', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'bounce', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'clip', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'drop', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'explode', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'fold', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'highlight', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'pulsate', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'scale', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'transfer', '1', '1 = effect active', 'php_var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('toolbox_jquery','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js','','jq_ui','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('toolbox_jquery', 1, 'owner');
+-- add jq_ui_theme
+SELECT gui_element.fkey_gui_id, 'body', 'jq_ui_theme',
+'../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css', 'UI Theme from Themeroller' ,'file/css'
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jq_ui_theme');
+-- add resultList to applications with element gazetteerWFS
+e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+SELECT gui_element.fkey_gui_id, 'resultList',2,1,'','Result List','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,
+'','','div','mod_ResultList.js','../../lib/resultGeometryListController.js, ../../lib/resultGeometryListModel.js','mapframe1','',''
+from gui_element WHERE
+gui_element.e_id = 'gazetteerWFS' AND
+gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList');
+-- add element var position to element resultList
+'resultList', 'position', '[100,100]', 'position of the result list dialog' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'resultList' AND
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'position');
+-- add element var resultListHeight to element resultList
+'resultList', 'resultListHeight', '400', 'height of the result list dialog' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'resultListHeight');
+-- add element var resultListTitle to element resultList
+'resultList', 'resultListTitle', 'Search results', 'title of the result list dialog' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'resultListTitle');
+-- add element var resultListWidth to element resultList
+'resultList', 'resultListWidth', '800', 'width of the result list dialog' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList' AND var_name = 'resultListWidth');
+-- add jq_ui_dialog to applications with element gazetteerWFS
+Select gui_element.fkey_gui_id ,'jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js','','jq_ui',''
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_dialog');
+-- add jq_ui to applications with element gazetteerWFS
+Select gui_element.fkey_gui_id ,'jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','',
+'','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','',''
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui');
+-- add jq_datatables to applications with element gazetteerWFS
+'jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_datatables');
+-- add CSS for jQuery datatables
+'body', 'jq_datatables_css', '../extensions/dataTables-1.5/media/css/demo_table_jui.min.css', 'css-file for jQuery datatables' ,'file/css'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'body' AND var_name = 'jq_datatables_css');
+-- add resultList_DetailPopup to all resultLists to keep old functionality
+ e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+	SELECT fkey_gui_id,'resultList_DetailPopup',2,1,'Detail Popup For resultList','','div','','',
+	NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/mb_resultList_DetailPopup.js', '', 'resultList','', 'http://www.mapbender.org/resultList_DetailPopup'
+	FROM gui_element WHERE
+		(	gui_element.e_id = 'resultList' AND
+  			gui_element.fkey_gui_id NOT IN ( SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList_DetailPopup')
+-- add element var detailPopupHeight to element resultList_DetailPopup
+'resultList_DetailPopup', 'detailPopupHeight', '250', 'height of the result list detail popup' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'resultList_DetailPopup' AND
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'detailPopupHeight');
+-- add element var detailPopupTitle to element resultList_DetailPopup
+'resultList_DetailPopup', 'detailPopupTitle', 'Details', 'title of the result list detail popup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'detailPopupTitle');
+-- add element var detailPopupWidth to element resultList_DetailPopup
+'resultList_DetailPopup', 'detailPopupWidth', '350', 'width of the result list detail popup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'detailPopupWidth');
+-- add element var position to element resultList_DetailPopup
+'resultList_DetailPopup', 'position', '[200,200]', 'position of the result list detail popup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'position');
+-- add element var openLinkFromSearch to element resultList_DetailPopup
+'resultList_DetailPopup', 'openLinkFromSearch', '0', 'open link directly if feature attr is defined as link' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_DetailPopup' AND var_name = 'openLinkFromSearch');
+-- add resultList_Zoom to applications with element gazetteerWFS
+'resultList_Zoom',2,1,'zoom functionality for resultList','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/mb_resultList_Zoom.js','','resultList,mapframe1','','http://www.mapbender.org/resultList_Zoom'
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList_Zoom');
+-- add resultList_Highlight to applications with element gazetteerWFS
+'resultList_Highlight',2,1,'highlighting functionality for resultList','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/mb_resultList_Highlight.js','','resultList,mapframe1,overview','','http://www.mapbender.org/resultList_Highlight'
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'resultList_Highlight');
+-- add element var maxHighlightedPoints to element resultList_Highlight
+'resultList_Highlight', 'maxHighlightedPoints', '500', 'max number of points to highlight' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'resultList_Highlight' AND
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'maxHighlightedPoints');
+-- add element var resultHighlightColor to element resultList_Highlight
+'resultList_Highlight', 'resultHighlightColor', '#ff0000', 'color of the highlighting' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'resultHighlightColor');
+-- add element var resultHighlightLineWidth to element resultList_Highlight
+'resultList_Highlight', 'resultHighlightLineWidth', '2', 'width of the highlighting line' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'resultHighlightLineWidth');
+-- add element var resultHighlightZIndex to element resultList_Highlight
+'resultList_Highlight', 'resultHighlightZIndex', '100', 'zindex of the highlighting' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'resultList_Highlight' AND var_name = 'resultHighlightZIndex');
+-- delete deprecated element var maxHighlightedPoints of element gazetteerWFS
+DELETE FROM gui_element_vars WHERE fkey_e_id = 'gazetteerWFS' AND var_name = 'maxHighlightedPoints';
+-- added PRIMARYKEy for Table gui_gui_category
+Alter Table gui_gui_category ADD
+  CONSTRAINT pk_gui_gui_category PRIMARY KEY (fkey_gui_id, fkey_gui_category_id);
+-- add Application toolbox_jquery to category
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id)
+VALUES('toolbox_jquery',2);
+-- missing wz_jsgraphics in gazetteer
+-- replacing obsolete tablesorter
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/wz_jsgraphics.js' WHERE e_id = 'gazetteerWFS';
+-- translation entry
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('de', 'Add GeoRSS', 'GeoRSS hinzufügen');
+-- remove deprecated attributes of gui element addWMS
+UPDATE gui_element set e_attributes = '' WHERE e_id = 'addWMS';
+-- remove onmouseover and onmouseout attributes for imprint
+UPDATE gui_element set e_attributes = 'frameborder = "0"' WHERE e_id = 'imprint' AND fkey_gui_id = 'gui';
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('de', 'Search CSW', 'Katalogsuche');
+-- deactivate slippy map by default
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT DISTINCT fkey_gui_id, 'mapframe1' AS fkey_e_id, 'slippy' AS var_name, '0' AS var_value,
+'1 = Activates an animated, pseudo slippy map' AS context, 'var' AS var_type FROM gui_element
+WHERE e_id = 'mapframe1' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars
+WHERE var_name = 'slippy');
+-- gui_digitze: added new printPDF (with rotation and pdf Template)
+-- does not work with 4326 :(
+--Delete from gui_element where fkey_gui_id = 'gui_digitize' and e_id = 'printPDF';
+--INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes,
+-- e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES(
+--'gui_digitize','printPDF',2,1,'pdf print','Print','div','','',1,1,2,2,5,'','<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>','div','../plugins/mb_print.js','../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../exten
 sions/jquery.form.min.js','mapframe1','','http://www.mapbender.org/index.php/Print');
+--INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES(
+--'gui_digitize', 'printPDF', 'mbPrintConfig', '{"A4 landscape": "A4_lanscape_template.json","A4 portrait": "A4_portrait_template.json","A4 landscape": "A4_landscape_template.json","A3 landscape": "A3_landscape_template.json"}', '' ,'var');
+--'gui_digitize', 'body', 'print_css', '../css/print_div.css', '' ,'file/css');
+-- standard gui gui_wfs_conf entries for search
+INSERT INTO  gui_wfs_conf(fkey_gui_id, fkey_wfs_conf_id)
+SELECT 'gui',wfs_conf_id from wfs_conf WHERE wfs_conf_id = 1
+AND wfs_conf_id
+NOT IN (SELECT fkey_wfs_conf_id FROM gui_wfs_conf WHERE fkey_gui_id = 'gui');
+SELECT 'gui2',wfs_conf_id from wfs_conf WHERE wfs_conf_id = 1
+AND wfs_conf_id
+NOT IN (SELECT fkey_wfs_conf_id FROM gui_wfs_conf WHERE fkey_gui_id = 'gui2');
+-- remove obsolete attributes from savewmc
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'savewmc';
+-- insert datepicker in toolbox_jquery
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_datepicker', 5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.datepicker.js','','jq_ui','');
+-- remove obsolete js from dialog
+UPDATE gui_element SET e_js_file = '' WHERE e_id = 'jq_ui_dialog';
+-- add element var featureInfoLayerPopup to element featureInfoTunnel
+'featureInfoTunnel', 'featureInfoLayerPopup', 'true', 'display featureInfo in dialog popup' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'featureInfoTunnel' AND
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoLayerPopup');
+-- add element var featureInfoPopupHeight to element featureInfoTunnel
+'featureInfoTunnel', 'featureInfoPopupHeight', '200', 'height of the featureInfo dialog popup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoPopupHeight');
+-- add element var featureInfoPopupWidth to element featureInfoTunnel
+'featureInfoTunnel', 'featureInfoPopupWidth', '270', 'width of the featureInfo dialog popup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoPopupWidth');
+'featureInfoTunnel', 'featureInfoPopupPosition', '[100,100]', 'position of the featureInfoPopup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfoTunnel' AND var_name = 'featureInfoPopupPosition');
+-- add element var featureInfoLayerPopup to element featureInfo1
+'featureInfo1', 'featureInfoLayerPopup', 'true', 'display featureInfo in dialog popup' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'featureInfo1' AND
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoLayerPopup');
+-- add element var featureInfoPopupHeight to element featureInfo1
+'featureInfo1', 'featureInfoPopupHeight', '200', 'height of the featureInfo dialog popup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoPopupHeight');
+-- add element var featureInfoPopupWidth to element featureInfo1
+'featureInfo1', 'featureInfoPopupWidth', '270', 'width of the featureInfo dialog popup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoPopupWidth');
+'featureInfo1', 'featureInfoPopupPosition', '[100,100]', 'position of the featureInfoPopup' ,'var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoPopupPosition');
+-- add element var meetingPoint_export_url to element meetingPoint
+'meetingPoint', 'meetingPoint_export_url', '', 'set the export url for your meeting point (has to be a URL pointing to ..mapbender/frames/login.php)' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'meetingPoint' AND
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'meetingPoint' AND var_name = 'meetingPoint_export_url');
+-- move resultList_Popup back (after resultList)
+ UPDATE gui_element SET e_pos = 3 WHERE e_id = 'resultList_Popup';
+ --Things to be done for merging with geoportal.rlp***
+--Adoption of the group table to allow contact information for groups
+alter table mb_group add column mb_group_title character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_ext_id bigint;
+alter table mb_group add column mb_group_address character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_postcode character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_city character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_stateorprovince character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_country character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_voicetelephone character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_facsimiletelephone character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_email character varying(255) NOT NULL DEFAULT ''::character varying;
+alter table mb_group add column mb_group_logo_path text NOT NULL DEFAULT ''::character varying;
+alter table mb_user_mb_group add column mb_user_mb_group_type integer;
+--Adoption for adminsitration of conformities in the mapbender database***
+--searchable
+ALTER TABLE layer ADD COLUMN layer_searchable integer;
+ALTER TABLE layer ALTER COLUMN layer_searchable SET STORAGE PLAIN;
+ALTER TABLE layer ALTER COLUMN layer_searchable SET DEFAULT 1;
+-- Column: featuretype_searchable
+-- ALTER TABLE wfs_featuretype DROP COLUMN featuretype_searchable;
+--ALTER TABLE wfs_featuretype ADD COLUMN featuretype_searchable integer;
+--ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_searchable SET STORAGE PLAIN;
+--ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_searchable SET DEFAULT 1;
+ALTER TABLE wfs_featuretype ADD COLUMN featuretype_searchable integer;
+-- Column: wms_timestamp_create
+ALTER TABLE wms ADD COLUMN wms_timestamp_create integer;
+ALTER TABLE wms ALTER COLUMN wms_timestamp_create SET STORAGE PLAIN;
+--network accessibility
+ALTER TABLE wms ADD COLUMN wms_network_access integer;
+ALTER TABLE wms ALTER COLUMN wms_network_access SET STORAGE PLAIN;
+-- Column: wfs_timestamp_create
+-- ALTER TABLE wfs DROP COLUMN wfs_timestamp_create;
+ALTER TABLE wfs ADD COLUMN wfs_timestamp_create integer;
+ALTER TABLE wfs ALTER COLUMN wfs_timestamp_create SET STORAGE PLAIN;
+ALTER TABLE wfs ADD COLUMN wfs_network_access integer;
+ALTER TABLE wfs ALTER COLUMN wfs_network_access SET STORAGE PLAIN;
+--table for inspire metadata add on fields - for layer and featuretypes
+-- Table: inspire_md_data
+CREATE TABLE inspire_md_data
+  data_id serial NOT NULL,
+  data_time_begin integer, --timestamp
+  data_time_end integer, --timestamp
+  data_lineage text,
+  data_spatial_res_value varchar(255), --
+  data_spatial_res_type integer, --look up types like 1:equivalentScale, 2:Distance - see guidance paper for metadata
+  CONSTRAINT data_id_pkey PRIMARY KEY (data_id)
+WITH OIDS;
+--ALTER TABLE inspire_md_data OWNER TO "postgres";
+--ok
+--Conformity is a metadata information which is defined for spatial data services and spatial data sets - the information about the conformity should be generated automatically by the service registry
+--mainly the available metadata information should be tested. This can be done when resitrating the service and when edit the service metadata.
+-- There should be a list of available specifications (ir, or regulations) wherefor the services can be tested. This list have to be stored in the database.
+-- Table: conformity
+CREATE TABLE conformity
+  conformity_id serial NOT NULL,
+  conformity_key varchar(255),
+  fkey_spec_class_key character varying(255),
+  conformity_code_en character varying(255),
+  conformity_code_fr character varying(255),
+  conformity_code_de character varying(255),
+  conformity_symbol character varying(255),
+  conformity_description_de text,
+  CONSTRAINT conformity_pkey PRIMARY KEY (conformity_id)
+WITH OIDS;
+--ALTER TABLE conformity OWNER TO "postgres";
+INSERT INTO conformity (fkey_spec_class_key, conformity_key, conformity_code_en, conformity_code_de, conformity_code_fr, conformity_symbol, conformity_description_de) VALUES ('inspire','1','conformant','Konform','','','Die Ressource stimmt mit der angegebenen Spezifikation in vollem Umfang überein.');
+INSERT INTO conformity (fkey_spec_class_key, conformity_key, conformity_code_en, conformity_code_de, conformity_code_fr, conformity_symbol, conformity_description_de) VALUES ('inspire','2','notConformant','Nicht konform','','','Die Ressource stimmt mit der angegebenen Spezifikation nicht überein.');
+INSERT INTO conformity (fkey_spec_class_key, conformity_key, conformity_code_en, conformity_code_de, conformity_code_fr, conformity_symbol, conformity_description_de) VALUES ('inspire','3','notEvaluated','Nicht überprüft','','','Die Übereinstimmung ist nicht überprüft worden.');
+-- Table spec_classification:
+CREATE TABLE spec_classification
+  spec_class_id serial NOT NULL,
+ -- spec_key varchar(5) NOT NULL,
+  spec_class_key character varying(255) UNIQUE,
+  spec_class_code_de character varying(255),
+  spec_class_code_en character varying(255),
+  spec_class_code_fr character varying(255),
+  spec_class_description_en text,
+  spec_class_description_de text,
+  spec_class_description_fr text,
+  spec_class_timestamp integer,
+  CONSTRAINT spec_class_id_pkey PRIMARY KEY (spec_class_id)
+WITH OIDS;
+INSERT INTO spec_classification (spec_class_key, spec_class_code_de, spec_class_description_de) VALUES ('inspire','INSPIRE','Klasse der Inspire Spezifikationen/Regulations');
+-- specification table:
+CREATE TABLE spec
+  spec_id serial NOT NULL,
+  spec_key varchar(50) NOT NULL,
+  spec_code_en character varying,
+  spec_code_de character varying,
+  spec_code_fr character varying,
+  spec_link_en character varying,
+  spec_link_de character varying,
+  spec_link_fr character varying,
+  spec_description_en text,
+  spec_description_de text,
+  spec_description_fr text,
+  spec_timestamp integer,
+  CONSTRAINT spec_id_pkey PRIMARY KEY (spec_id),
+  CONSTRAINT spec_spec_class_fkey FOREIGN KEY (fkey_spec_class_key)
+      REFERENCES spec_classification (spec_class_key) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE CASCADE
+WITH OIDS;
+INSERT INTO spec (spec_key, spec_code_en, spec_link_en, spec_description_en, fkey_spec_class_key, spec_timestamp) VALUES ('ir_interop','INSPIRE Implementing rules laying down technical arrangements','http://www.geoportal.rlp.de/','INSPIRE Implementing rules laying down technical arrangements for the interoperability and harmonisation of orthoimagery','inspire',extract(epoch FROM (to_timestamp('2011-05-15','YYYY-MM-DD'))));
+--conformity relation table:
+-- Table: conformity_relation
+CREATE TABLE conformity_relation
+  relation_id serial NOT NULL,
+  fkey_wms_id integer,
+  fkey_wfs_id integer,
+  fkey_inspire_md_id integer,
+  fkey_conformity_id integer,
+  fkey_spec_id integer,
+  CONSTRAINT relation_id_pkey PRIMARY KEY (relation_id),
+  CONSTRAINT conformity_relation_wms_id_fkey FOREIGN KEY (fkey_wms_id)
+      REFERENCES wms (wms_id) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE CASCADE,
+  CONSTRAINT conformity_relation_wfs_id_fkey FOREIGN KEY (fkey_wfs_id)
+      REFERENCES wfs (wfs_id) MATCH SIMPLE
+  CONSTRAINT conformity_relation_inspire_md_fkey FOREIGN KEY (fkey_inspire_md_id)
+      REFERENCES inspire_md_data (data_id) MATCH SIMPLE
+  CONSTRAINT conformity_relation_conformity_fkey FOREIGN KEY (fkey_conformity_id)
+      REFERENCES conformity (conformity_id) MATCH SIMPLE
+  CONSTRAINT conformity_relation_spec_fkey FOREIGN KEY (fkey_spec_id)
+      REFERENCES spec (spec_id) MATCH SIMPLE
+WITH OIDS;
+-- Table: custom_category
+CREATE TABLE custom_category
+  custom_category_id serial NOT NULL,
+  custom_category_key varchar(5) NOT NULL,
+  custom_category_code_en character varying(255),
+  custom_category_code_de character varying(255),
+  custom_category_code_fr character varying(255),
+  custom_category_symbol character varying(255),
+  custom_category_description_de text,
+  CONSTRAINT custom_category_pkey PRIMARY KEY (custom_category_id)
+WITH OIDS;
+INSERT INTO custom_category (custom_category_key, custom_category_code_en, custom_category_code_de, custom_category_code_fr, custom_category_symbol, custom_category_description_de) VALUES ('dc1','dummy category','Dummy Kategorie','','','Demo Kategorie zur Klassifizierung von Mapbender Registry Inhalten');
+-- Table: layer_custom_category
+CREATE TABLE layer_custom_category
+  fkey_layer_id integer NOT NULL,
+  fkey_custom_category_id integer NOT NULL,
+  CONSTRAINT layer_custom_category_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id)
+      REFERENCES layer (layer_id) MATCH SIMPLE
+  CONSTRAINT layer_custom_category_fkey_custom_category_id_fkey FOREIGN KEY (fkey_custom_category_id)
+      REFERENCES custom_category (custom_category_id) MATCH SIMPLE
+-- Table: wfs_featuretype_custom_category
+CREATE TABLE wfs_featuretype_custom_category
+  fkey_featuretype_id integer NOT NULL,
+  CONSTRAINT wfs_featuretype_custom_category_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
+      REFERENCES wfs_featuretype (featuretype_id) MATCH SIMPLE
+  CONSTRAINT wfs_featuretype_custom_category_fkey_custom_category_id_fkey FOREIGN KEY (fkey_custom_category_id)
+--functions to collect the categories into strings
+CREATE OR REPLACE FUNCTION f_collect_custom_cat_layer(integer)
+  RETURNS text AS
+  $BODY$DECLARE
+  i_layer_id ALIAS FOR $1;
+  custom_cat_string  TEXT;
+  custom_cat_record  RECORD;
+BEGIN
+custom_cat_string := '';
+FOR custom_cat_record IN SELECT layer_custom_category.fkey_custom_category_id from layer_custom_category WHERE layer_custom_category.fkey_layer_id=$1  LOOP
+custom_cat_string := custom_cat_string || '{' ||custom_cat_record.fkey_custom_category_id || '}';
+END LOOP ;
+RETURN custom_cat_string;
+END;
+$BODY$
+  LANGUAGE 'plpgsql' VOLATILE STRICT;
+CREATE OR REPLACE FUNCTION f_collect_custom_cat_wfs_featuretype(integer)
+  RETURNS text AS
+  $BODY$DECLARE
+  i_featuretype_id ALIAS FOR $1;
+BEGIN
+FOR custom_cat_record IN SELECT wfs_featuretype_custom_category.fkey_custom_category_id from wfs_featuretype_custom_category WHERE wfs_featuretype_custom_category.fkey_featuretype_id=$1  LOOP
+END LOOP ;
+END;
+$BODY$
+-- Table: inspire_category
+CREATE TABLE inspire_category
+  inspire_category_id serial NOT NULL,
+  inspire_category_key varchar(5) NOT NULL,
+  inspire_category_code_en character varying(255),
+  inspire_category_code_de character varying(255),
+  inspire_category_code_fr character varying(255),
+  inspire_category_symbol character varying(255),
+  inspire_category_description_de text,
+  CONSTRAINT inspire_category_pkey PRIMARY KEY (inspire_category_id)
+WITH OIDS;
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.1','Coordinate reference systems','Koordinatenreferenzsysteme','','','Systeme zur eindeutigen räumlichen Referenzierung von Geodaten anhand eines Koordinatensatzes (x, y, z) und/oder Angaben zu Breite, Länge und Höhe auf der Grundlage eines geodätischen horizontalen und vertikalen Datums.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.2','Geographical grid systems','Geografische Gittersysteme','','','Harmonisiertes Gittersystem mit Mehrfachauflösung, gemeinsamem Ursprungspunkt und standardisierter Lokalisierung und Größe der Gitterzellen.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.3','Geographical names','Geografische Bezeichnungen','','','Namen von Gebieten, Regionen, Orten, Großstädten, Vororten, Städten oder Siedlungen sowie jedes geografische oder topografische Merkmal von öffentlichem oder historischem Interesse.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.4','Administrative units','Verwaltungseinheiten','','','Lokale, regionale und nationale Verwaltungseinheiten, die die Gebiete abgrenzen, in denen die Mitgliedstaaten Hoheitsbefugnisse haben und/oder ausüben und die durch Verwaltungsgrenzen voneinander getrennt sind.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.5','Addresses','Adressen','','','Lokalisierung von Grundstücken anhand von Adressdaten, in der Regel Straßenname, Hausnummer und Postleitzahl.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.6','Cadastral parcels','Flurstücke/Grundstücke (Katasterparzellen)','','','Gebiete, die anhand des Grundbuchs oder gleichwertiger Verzeichnisse bestimmt werden. ');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.7','Transport networks','Verkehrsnetze','','','Verkehrsnetze und zugehörige Infrastruktureinrichtungen für Straßen-, Schienen- und Luftverkehr sowie Schifffahrt. Umfasst auch die Verbindungen zwischen den verschiedenen Netzen. Umfasst auch das transeuropäische Verkehrsnetz im Sinne der Entscheidung Nr. 1692/96/EG des Europäischen Parlaments und des Rates vom 23. Juli 1996 über gemeinschaftliche Leitlinien für den Aufbau eines transeuropäischen Verkehrsnetzes und künftiger Überarbeitungen dieser Entscheidung. ');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.8','Hydrography','Gewässernetz','','','Elemente des Gewässernetzes, einschließlich Meeresgebieten und allen sonstigen Wasserkörpern und hiermit verbundenen Teilsystemen, darunter Einzugsgebiete und Teileinzugsgebiete. Gegebenenfalls gemäß den Definitionen der Richtlinie 2000/60/EG des Europäischen Parlaments und des Rates vom 23. Oktober 2000 zur Schaffung eines Ordnungsrahmens für Maßnahmen der Gemeinschaft im Bereich der Wasserpolitik und in Form von Netzen.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('1.9','Protected sites','Schutzgebiete','','','Gebiete, die im Rahmen des internationalen und des gemeinschaftlichen Rechts sowie des Rechts der Mitgliedstaaten ausgewiesen sind oder verwaltet werden, um spezifische Erhaltungsziele zu erreichen.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.1','Elevation','Höhe','','','Digitale Höhenmodelle für Land-, Eis- und Meeresflächen. Dazu gehören Geländemodell, Tiefenmessung und Küstenlinie.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.2','Land cover','Bodenbedeckung','','','Physische und biologische Bedeckung der Erdoberfläche, einschließlich künstlicher Flächen, landwirtschaftlicher Flächen, Wäldern, natürlicher (naturnaher) Gebiete, Feuchtgebieten und Wasserkörpern.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.3','Orthoimagery','Orthofotografie','','','Georeferenzierte Bilddaten der Erdoberfläche von satelliten- oder luftfahrzeuggestützten Sensoren.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('2.4','Geology','Geologie','','','Geologische Beschreibung anhand von Zusammensetzung und Struktur. Dies umfasst auch Grundgestein, Grundwasserleiter und Geomorphologie.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.1','Statistical units','Statistische Einheiten','','','Einheiten für die Verbreitung oder Verwendung statistischer Daten.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.2','Buildings','Gebäude','','','Geografischer Standort von Gebäuden.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.3','Soil','Boden','','','Beschreibung von Boden und Unterboden anhand von Tiefe, Textur, Struktur und Gehalt an Teilchen sowie organischem Material, Steinigkeit, Erosion, gegebenenfalls durchschnittliches Gefälle und erwartete Wasserspeicherkapazität.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.4','Land use','Bodennutzung','','','Beschreibung von Gebieten anhand ihrer derzeitigen und geplanten künftigen Funktion oder ihres sozioökonomischen Zwecks (z. B. Wohn-, Industrie- oder Gewerbegebiete, land- oder forstwirtschaftliche Flächen, Freizeitgebiete).');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.5','Human health and safety','Gesundheit und Sicherheit','','','Geografische Verteilung verstärkt auftretender pathologischer Befunde (Allergien, Krebserkrankungen, Erkrankungen der Atemwege usw.), Informationen über Auswirkungen auf die Gesundheit (Biomarker, Rückgang der Fruchtbarkeit, Epidemien) oder auf das Wohlbefinden (Ermüdung, Stress usw.) der Menschen in unmittelbarem Zusammenhang mit der Umweltqualität (Luftverschmutzung, Chemikalien, Abbau der Ozonschicht, Lärm usw.) oder in mittelbarem Zusammenhang mit der Umweltqualität (Nahrung, genetisch veränderte Organismen usw.).');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.6','Utility and governmental services','Versorgungswirtschaft und staatliche Dienste','','','Versorgungseinrichtungen wie Abwasser- und Abfallentsorgung, Energieversorgung und Wasserversorgung; staatliche Verwaltungs- und Sozialdienste wie öffentliche Verwaltung, Katastrophenschutz, Schulen und Krankenhäuser.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.7','Environmental monitoring facilities','Umweltüberwachung','','','Standort und Betrieb von Umweltüberwachungseinrichtungen einschließlich Beobachtung und Messung von Schadstoffen, des Zustands von Umweltmedien und anderen Parametern des Ökosystems (Artenvielfalt, ökologischer Zustand der Vegetation usw.) durch oder im Auftrag von öffentlichen Behörden.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.8','Production and industrial facilities','Produktions- und Industrieanlagen','','','Standorte für industrielle Produktion, einschließlich durch die Richtlinie 96/61/EG des Rates vom 24. September 1996 über die integrierte Vermeidung und Verminderung der Umweltverschmutzung erfasste Anlagen und Einrichtungen zur Wasserentnahme sowie Bergbau- und Lagerstandorte.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.9','Agricultural and aquaculture facilities','Landwirtschaftliche Anlagen und Aquakulturanlagen','','','Landwirtschaftliche Anlagen und Produktionsstätten (einschließlich Bewässerungssystemen, Gewächshäusern und Ställen).');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.10','Population distribution — demography','Verteilung der Bevölkerung — Demografie','','','Geografische Verteilung der Bevölkerung, einschließlich Bevölkerungsmerkmalen und Tätigkeitsebenen, zusammengefasst nach Gitter, Region, Verwaltungseinheit oder sonstigen analytischen Einheiten.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.11','Area management/restriction/regulation zones and reporting units','Bewirtschaftungsgebiete/Schutzgebiete/geregelte Gebiete und Berichterstattungseinheiten','','','Auf internationaler, europäischer, nationaler, regionaler und lokaler Ebene bewirtschaftete, geregelte oder zu Zwecken der Berichterstattung herangezogene Gebiete. Dazu zählen Deponien, Trinkwasserschutzgebiete, nitratempfindliche Gebiete, geregelte Fahrwasser auf See oder auf großen Binnengewässern, Gebiete für die Abfallverklappung, Lärmschutzgebiete, für Exploration und Bergbau ausgewiesene Gebiete, Flussgebietseinheiten, entsprechende Berichterstattungseinheiten und Gebiete des Küstenzonenmanagements.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.12','Natural risk zones','Gebiete mit naturbedingten Risiken','','','Gefährdete Gebiete, eingestuft nach naturbedingten Risiken (sämtliche atmosphärischen, hydrologischen, seismischen, vulkanischen Phänomene sowie Naturfeuer, die aufgrund ihres örtlichen Auftretens sowie ihrer Schwere und Häufigkeit signifikante Auswirkungen auf die Gesellschaft haben können), z. B. Überschwemmungen, Erdrutsche und Bodensenkungen, Lawinen, Waldbrände, Erdbeben oder Vulkanausbrüche.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.13','Atmospheric conditions','Atmosphärische Bedingungen','','','Physikalische Bedingungen in der Atmosphäre. Dazu zählen Geodaten auf der Grundlage von Messungen, Modellen oder einer Kombination aus beiden sowie Angabe der Messstandorte.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.14','Meteorological geographical features','Meteorologisch-geografische Kennwerte','','','Witterungsbedingungen und deren Messung; Niederschlag, Temperatur, Gesamtverdunstung (Evapotranspiration), Windgeschwindigkeit und Windrichtung.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.15','Oceanographic geographical features','Ozeanografisch-geografische Kennwerte','','','Physikalische Bedingungen der Ozeane (Strömungsverhältnisse, Salinität, Wellenhöhe usw.).');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.16','Sea regions','Meeresregionen','','','Physikalische Bedingungen von Meeren und salzhaltigen Gewässern, aufgeteilt nach Regionen und Teilregionen mit gemeinsamen Merkmalen.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.17','Bio-geographical regions','Biogeografische Regionen','','','Gebiete mit relativ homogenen ökologischen Bedingungen und gemeinsamen Merkmalen.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.18','Habitats and biotopes','Lebensräume und Biotope','','','Geografische Gebiete mit spezifischen ökologischen Bedingungen, Prozessen, Strukturen und (lebensunterstützenden) Funktionen als physische Grundlage für dort lebende Organismen. Dies umfasst auch durch geografische, abiotische und biotische Merkmale gekennzeichnete natürliche oder naturnahe terrestrische und aquatische Gebiete.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.19','Species distribution','Verteilung der Arten','','','Geografische Verteilung des Auftretens von Tier- und Pflanzenarten, zusammengefasst in Gittern, Region, Verwaltungseinheit oder sonstigen analytischen Einheiten.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.20','Energy resources','Energiequellen','','','Energiequellen wie Kohlenwasserstoffe, Wasserkraft, Bioenergie, Sonnen- und Windenergie usw., gegebenenfalls mit Tiefen- bzw. Höhenangaben zur Ausdehnung der Energiequelle.');
+INSERT INTO inspire_category (inspire_category_key, inspire_category_code_en, inspire_category_code_de, inspire_category_code_fr, inspire_category_symbol, inspire_category_description_de) VALUES ('3.21','Mineral resources','Mineralische Bodenschätze','','','Mineralische Bodenschätze wie Metallerze, Industrieminerale usw., gegebenenfalls mit Tiefen- bzw. Höhenangaben zur Ausdehnung der Bodenschätze.');
+-- Table: layer_inspire_category
+CREATE TABLE layer_inspire_category
+  fkey_inspire_category_id integer NOT NULL,
+  CONSTRAINT layer_inspire_category_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id)
+  CONSTRAINT layer_inspire_category_fkey_inspire_category_id_fkey FOREIGN KEY (fkey_inspire_category_id)
+      REFERENCES inspire_category (inspire_category_id) MATCH SIMPLE
+-- Table: wfs_featuretype_inspire_category
+CREATE TABLE wfs_featuretype_inspire_category
+  CONSTRAINT wfs_featuretype_inspire_category_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
+  CONSTRAINT wfs_featuretype_inspire_category_fkey_inspire_category_id_fkey FOREIGN KEY (fkey_inspire_category_id)
+CREATE OR REPLACE FUNCTION f_collect_inspire_cat_layer(integer)
+  RETURNS text AS
+  $BODY$DECLARE
+  inspire_cat_string  TEXT;
+  inspire_cat_record  RECORD;
+BEGIN
+inspire_cat_string := '';
+FOR inspire_cat_record IN SELECT layer_inspire_category.fkey_inspire_category_id from layer_inspire_category WHERE layer_inspire_category.fkey_layer_id=$1  LOOP
+inspire_cat_string := inspire_cat_string || '{' ||inspire_cat_record.fkey_inspire_category_id || '}';
+END LOOP ;
+RETURN inspire_cat_string;
+END;
+$BODY$
+CREATE OR REPLACE FUNCTION f_collect_inspire_cat_wfs_featuretype(integer)
+  RETURNS text AS
+  $BODY$DECLARE
+BEGIN
+FOR inspire_cat_record IN SELECT wfs_featuretype_inspire_category.fkey_inspire_category_id from wfs_featuretype_inspire_category WHERE wfs_featuretype_inspire_category.fkey_featuretype_id=$1  LOOP
+END LOOP ;
+END;
+$BODY$
+-- Table: wfs_featuretype_md_topic_category
+CREATE TABLE wfs_featuretype_md_topic_category
+  fkey_md_topic_category_id integer NOT NULL,
+  CONSTRAINT wfs_featuretype_md_topic_category_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
+  CONSTRAINT wfs_featuretype_md_topic_category_fkey_md_topic_cat_id_fkey FOREIGN KEY (fkey_md_topic_category_id)
+      REFERENCES md_topic_category (md_topic_category_id) MATCH SIMPLE
+WITHOUT OIDS;
+CREATE OR REPLACE FUNCTION f_collect_topic_cat_layer(integer)
+  RETURNS text AS
+  $BODY$DECLARE
+  topic_cat_string  TEXT;
+  topic_cat_record  RECORD;
+BEGIN
+topic_cat_string := '';
+FOR topic_cat_record IN SELECT layer_md_topic_category.fkey_md_topic_category_id from layer_md_topic_category WHERE layer_md_topic_category.fkey_layer_id=$1  LOOP
+topic_cat_string := topic_cat_string || '{' ||topic_cat_record.fkey_md_topic_category_id || '}';
+END LOOP ;
+RETURN topic_cat_string;
+END;
+$BODY$
+CREATE OR REPLACE FUNCTION f_collect_topic_cat_wfs_featuretype(integer)
+  RETURNS text AS
+  $BODY$DECLARE
+BEGIN
+FOR topic_cat_record IN SELECT wfs_featuretype_md_topic_category.fkey_md_topic_category_id from wfs_featuretype_md_topic_category WHERE wfs_featuretype_md_topic_category.fkey_featuretype_id=$1  LOOP
+END LOOP ;
+END;
+$BODY$
+--generate the group for the decentral registrating institutions
+-- View: registrating_groups
+CREATE OR REPLACE VIEW registrating_groups AS
+ SELECT f.fkey_mb_group_id, f.fkey_mb_user_id
+   FROM mb_user_mb_group f, mb_user_mb_group s
+  WHERE f.mb_user_mb_group_type = 1 AND s.fkey_mb_group_id = 36 AND f.fkey_mb_user_id = s.fkey_mb_user_id
+  ORDER BY f.fkey_mb_group_id, f.fkey_mb_user_id;
+-- Function: f_getwfs_tou(integer)
+CREATE OR REPLACE FUNCTION f_getwfs_tou(integer)
+  RETURNS integer AS
+$BODY$
+DECLARE
+   wfs_tou int4;
+BEGIN
+wfs_tou := fkey_termsofuse_id from wfs_termsofuse where wfs_termsofuse.fkey_wfs_id=$1;
+RETURN wfs_tou;
+END;
+$BODY$
+  LANGUAGE 'plpgsql' VOLATILE;
+-- Function: f_getwms_tou(integer)
+CREATE OR REPLACE FUNCTION f_getwms_tou(integer)
+$BODY$
+DECLARE
+   wms_tou int4;
+BEGIN
+wms_tou := fkey_termsofuse_id from wms_termsofuse where wms_termsofuse.fkey_wms_id=$1;
+RETURN wms_tou;
+END;
+$BODY$
+-- Function: f_collect_epsg(integer)
+CREATE OR REPLACE FUNCTION f_collect_epsg(integer)
+  RETURNS text AS
+$BODY$DECLARE
+  epsg_string  TEXT;
+  epsg_record  RECORD;
+BEGIN
+epsg_string := '';
+FOR epsg_record IN SELECT layer_epsg.epsg from layer_epsg WHERE layer_epsg.fkey_layer_id=$1  LOOP
+epsg_string := epsg_string ||  epsg_record.epsg || ';';
+END LOOP ;
+RETURN epsg_string;
+    --CASE
+      --WHEN LEN(epsg) > 0 THEN LEFT(epsg, LEN(epsg) - 1)
+     -- ELSE epsg
+END;
+$BODY$
+-- Function: f_layer_load_count(integer)
+CREATE OR REPLACE FUNCTION f_layer_load_count(integer)
+$BODY$
+DECLARE
+   layer_rel int4;
+BEGIN
+layer_rel := load_count from layer_load_count where layer_load_count.fkey_layer_id=$1;
+RETURN layer_rel;
+END;
+$BODY$
+-- Function: f_collect_searchtext(integer, integer)
+CREATE OR REPLACE FUNCTION f_collect_searchtext(integer, integer)
+  RETURNS text AS
+$BODY$DECLARE
+    p_wms_id ALIAS FOR $1;
+    p_layer_id ALIAS FOR $2;
+    r_keywords RECORD;
+    l_result TEXT;
+BEGIN
+    l_result := '';
+    l_result := l_result || (SELECT COALESCE(wms_title, '') || ' ' || COALESCE(wms_abstract, '') FROM wms WHERE wms_id = p_wms_id);
+    l_result := l_result || (SELECT COALESCE(layer_name, '')|| ' ' || COALESCE(layer_title, '')  || ' ' || COALESCE(layer_abstract, '') FROM layer WHERE layer_id = p_layer_id);
+    FOR r_keywords IN SELECT DISTINCT keyword FROM
+        (SELECT keyword FROM layer_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id AND L.fkey_layer_id = p_layer_id)
+        ) AS __keywords__ LOOP
+        l_result := l_result || ' ' || COALESCE(r_keywords.keyword, '');
+    END LOOP;
+    FOR r_keywords IN SELECT DISTINCT md_topic_category_code_de FROM
+        (SELECT md_topic_category_code_de FROM md_topic_category T JOIN layer_md_topic_category C ON (C.fkey_md_topic_category_id = T.md_topic_category_id AND C.fkey_layer_id = p_layer_id)
+        l_result := l_result || ' ' || COALESCE(r_keywords.md_topic_category_code_de, '');
+    END LOOP;
+   l_result := UPPER(l_result);
+   l_result := replace(replace(replace(replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE'),'ä','AE'),'ü','UE'),'ö','OE');
+    RETURN l_result;
+END;
+$BODY$
+-- Function: f_collect_searchtext_wfs(integer, integer)
+-- DROP FUNCTION f_collect_searchtext_wfs(integer, integer)
+CREATE OR REPLACE FUNCTION f_collect_searchtext_wfs(integer, integer)
+  RETURNS text AS
+$BODY$
+DECLARE
+   p_wfs_id ALIAS FOR $1;
+   p_featuretype_id ALIAS FOR $2;
+   l_result TEXT;
+BEGIN
+   l_result := '';
+   l_result := l_result || (SELECT COALESCE(wfs_title, '') || ' ' || COALESCE(wfs_abstract, '') FROM wfs WHERE wfs_id = p_wfs_id);
+   l_result := l_result || (SELECT COALESCE(featuretype_name, '')|| ' ' || COALESCE(featuretype_title, '')  || ' ' || COALESCE(featuretype_abstract, '') FROM wfs_featuretype WHERE featuretype_id = p_featuretype_id);
+       (SELECT keyword FROM wfs_featuretype_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id AND L.fkey_featuretype_id = p_featuretype_id)
+   END LOOP;
+  l_result := replace(replace(replace(replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE'),'ü','UE'),'ö','OE'),'ä','AE');
+   RETURN l_result;
+END;
+$BODY$
+-- Function: f_getwfsmodultype(integer)
+CREATE OR REPLACE FUNCTION f_getwfsmodultype(integer)
+$BODY$
+DECLARE
+    i_search INT4;
+BEGIN
+i_search := count(*) from wfs_conf, wfs_conf_element where wfs_conf.wfs_conf_id=$1 and wfs_conf.wfs_conf_id=wfs_conf_element.fkey_wfs_conf_id and f_search=1;
+IF i_search > 0 THEN
+RETURN 1;
+else
+RETURN 0;
+END IF;
+END;
+$BODY$
+-- View: search_wms_view
+CREATE OR REPLACE VIEW search_wms_view AS
+ SELECT DISTINCT ON (wms_unref.layer_id) wms_unref.wms_id, wms_unref.availability, wms_unref.status, wms_unref.wms_title, wms_unref.wms_abstract, wms_unref.stateorprovince, wms_unref.country, wms_unref.accessconstraints, wms_unref.termsofuse, wms_unref.wms_owner, wms_unref.layer_id, wms_unref.epsg, wms_unref.layer_title, wms_unref.layer_abstract, wms_unref.layer_name, wms_unref.layer_parent, wms_unref.layer_pos, wms_unref.layer_queryable, wms_unref.load_count, wms_unref.searchtext, wms_unref.wms_timestamp, wms_unref.department, wms_unref.user_mb_group_name, f_collect_custom_cat_layer(wms_unref.layer_id) AS md_custom_cats, f_collect_inspire_cat_layer(wms_unref.layer_id) AS md_inspire_cats, f_collect_topic_cat_layer(wms_unref.layer_id) AS md_topic_cats, geometryfromtext(((((((((((((((((((('POLYGON(('::text || layer_epsg.minx::text) || ' '::text) || layer_epsg.miny::text) || ','::text) || layer_epsg.minx::text) || ' '::text) || layer_epsg.maxy::text) || ','::text) || layer_epsg
 .maxx::text) || ' '::text) || layer_epsg.maxy::text) || ','::text) || layer_epsg.maxx::text) || ' '::text) || layer_epsg.miny::text) || ','::text) || layer_epsg.minx::text) || ' '::text) || layer_epsg.miny::text) || '))'::text, 4326) AS the_geom, (((((layer_epsg.minx::text || ','::text) || layer_epsg.miny::text) || ','::text) || layer_epsg.maxx::text) || ','::text) || layer_epsg.maxy::text AS bbox, wms_unref.wms_proxylog, wms_unref.wms_network_access, wms_unref.wms_pricevolume
+   FROM ( SELECT wms_uncat.wms_id, wms_uncat.availability, wms_uncat.status, wms_uncat.wms_title, wms_uncat.wms_abstract, wms_uncat.stateorprovince, wms_uncat.country, wms_uncat.accessconstraints, wms_uncat.termsofuse, wms_uncat.wms_owner, wms_uncat.layer_id, wms_uncat.epsg, wms_uncat.layer_title, wms_uncat.layer_abstract, wms_uncat.layer_name, wms_uncat.layer_parent, wms_uncat.layer_pos, wms_uncat.layer_queryable, wms_uncat.load_count, wms_uncat.searchtext, wms_uncat.wms_timestamp, wms_uncat.department, wms_uncat.user_mb_group_name, wms_uncat.wms_proxylog, wms_uncat.wms_network_access, wms_uncat.wms_pricevolume
+           FROM ( SELECT wms_dep.wms_id, wms_dep.availability, wms_dep.status, wms_dep.wms_title, wms_dep.wms_abstract, wms_dep.stateorprovince, wms_dep.country, wms_dep.accessconstraints, wms_dep.termsofuse, wms_dep.wms_owner, layer.layer_id, f_collect_epsg(layer.layer_id) AS epsg, layer.layer_title, layer.layer_abstract, layer.layer_name, layer.layer_parent, layer.layer_pos, layer.layer_queryable, f_layer_load_count(layer.layer_id) AS load_count, f_collect_searchtext(wms_dep.wms_id, layer.layer_id) AS searchtext, wms_dep.wms_timestamp, wms_dep.department, wms_dep.user_mb_group_name, wms_dep.wms_proxylog, wms_dep.wms_network_access, wms_dep.wms_pricevolume
+                   FROM ( SELECT wms.wms_id, wms.wms_title, wms.wms_abstract, wms.stateorprovince, wms.country, mb_wms_availability.availability, mb_wms_availability.last_status AS status, wms.accessconstraints, f_getwms_tou(wms.wms_id) AS termsofuse, wms.wms_timestamp, wms.wms_owner, wms.wms_proxylog, wms.wms_network_access, wms.wms_pricevolume, user_dep.fkey_mb_group_id AS department, user_dep.fkey_mb_group_id, user_dep.fkey_mb_group_id AS wms_department, user_dep.fkey_mb_group_id AS user_mb_group_name
+                           FROM registrating_groups user_dep, wms, mb_wms_availability
+                          WHERE wms.wms_owner = user_dep.fkey_mb_user_id AND wms.wms_id = mb_wms_availability.fkey_wms_id) wms_dep, layer
+                  WHERE layer.fkey_wms_id = wms_dep.wms_id AND layer.layer_searchable = 1) wms_uncat) wms_unref, layer_epsg
+  WHERE layer_epsg.epsg::text = 'EPSG:4326'::text AND wms_unref.layer_id = layer_epsg.fkey_layer_id
+  ORDER BY wms_unref.layer_id;
+-- View: search_wfs_view
+CREATE OR REPLACE VIEW search_wfs_view AS
+ SELECT wfs_dep.wfs_id, wfs_dep.wfs_title, wfs_dep.wfs_abstract, wfs_dep.administrativearea, wfs_dep.country, wfs_dep.accessconstraints, wfs_dep.termsofuse, wfs_dep.wfs_owner, wfs_featuretype.featuretype_id, wfs_featuretype.featuretype_srs, wfs_featuretype.featuretype_title, wfs_featuretype.featuretype_abstract, f_collect_searchtext_wfs(wfs_dep.wfs_id, wfs_featuretype.featuretype_id) AS searchtext, wfs_element.element_type, wfs_conf.wfs_conf_id, wfs_conf.wfs_conf_abstract, wfs_conf.wfs_conf_description, f_getwfsmodultype(wfs_conf.wfs_conf_id) AS modultype, wfs_dep.wfs_timestamp, wfs_dep.department, wfs_dep.mb_group_name
+   FROM ( SELECT wfs.wfs_id, wfs.wfs_title, wfs.wfs_abstract, wfs.administrativearea, wfs.country, wfs.accessconstraints, f_getwfs_tou(wfs.wfs_id) AS termsofuse, wfs.wfs_timestamp, wfs.wfs_owner, user_dep.mb_group_id AS department, user_dep.mb_group_name
+           FROM ( SELECT registrating_groups.fkey_mb_user_id AS mb_user_id, mb_group.mb_group_id, mb_group.mb_group_name
+                   FROM registrating_groups, mb_group
+                  WHERE registrating_groups.fkey_mb_group_id = mb_group.mb_group_id) user_dep, wfs
+          WHERE user_dep.mb_user_id = wfs.wfs_owner) wfs_dep, wfs_featuretype, wfs_element, wfs_conf
+  WHERE wfs_featuretype.fkey_wfs_id = wfs_dep.wfs_id AND wfs_featuretype.featuretype_searchable = 1 AND wfs_element.element_type::text ~~ '%Type'::text AND wfs_featuretype.featuretype_id = wfs_element.fkey_featuretype_id AND wfs_featuretype.featuretype_id = wfs_conf.fkey_featuretype_id
+  ORDER BY wfs_featuretype.featuretype_id;
+-- Table: content_metadata
+-- DROP TABLE content_metadata;
+CREATE TABLE content_metadata
+  metadata_id serial NOT NULL,
+  link_type character varying(255),
+  schemaid character varying(32) NOT NULL,
+  origin integer NOT NULL DEFAULT 1,
+  createdate integer,
+  changedate integer,
+  data text NOT NULL,
+  link character varying(255),
+  harvestresult integer,
+  harvestexception text,
+  uuid character varying(250),
+  title character varying(255),
+  abstract text,
+  temp_reference_1 integer,
+  temp_reference_2 integer,
+  spatial_res_type integer,
+  spatial_res_value character varying(20),
+  ref_system character varying(20),
+  format text,
+  inspire_charset character varying(10),
+  inspire_top_consistance boolean,
+  CONSTRAINT metadata_pkey PRIMARY KEY (metadata_id),
+  CONSTRAINT metadata_uuid_key UNIQUE (uuid)
+WITH OIDS;
+-- Table: ows_relation_metadata
+-- DROP TABLE ows_relation_metadata;
+CREATE TABLE ows_relation_metadata
+  fkey_metadata_id integer NOT NULL,
+  CONSTRAINT ows_relation_metadata_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id)
+  CONSTRAINT ows_relation_metadata_fkey_featuretype_id_fkey FOREIGN KEY (fkey_featuretype_id)
+  CONSTRAINT ows_relation_metadata_fkey_metadata_id_fkey FOREIGN KEY (fkey_metadata_id)
+      REFERENCES content_metadata (metadata_id) MATCH SIMPLE
+WITHOUT OIDS;
+-- add CSS for resultList
+'body', 'resultListCss', '../css/resultList.css', 'css for resultList elements' ,'file/css'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'body' AND var_name = 'resultListCss');
+-- add element var withPasswordInsertion to element editFilteredUser
+'editFilteredUser', 'withPasswordInsertion', 'true', 'define if admin can set the new user' ,'php_var'
+from gui_element
+WHERE
+gui_element.e_id = 'editFilteredUser' AND
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'editFilteredUser' AND var_name = 'withPasswordInsertion');
+-- increase size of target field
+ALTER TABLE gui_element ALTER COLUMN e_target TYPE VARCHAR(255);
+--function to collect the md categories for a single wmc into a column
+CREATE OR REPLACE FUNCTION f_collect_topic_cat_wmc(character varying)
+  RETURNS text AS
+  $BODY$DECLARE
+  i_wmc_id ALIAS FOR $1;
+BEGIN
+FOR topic_cat_record IN SELECT wmc_md_topic_category.fkey_md_topic_category_id from wmc_md_topic_category WHERE wmc_md_topic_category.fkey_wmc_id=$1  LOOP
+END LOOP ;
+END;
+$BODY$
+ALTER FUNCTION f_collect_topic_cat_wmc(character varying) OWNER TO postgres;
+-- Function: f_collect_searchtext_wmc(varchar)
+-- DROP FUNCTION f_collect_searchtext_wmc(varchar);
+CREATE OR REPLACE FUNCTION f_collect_searchtext_wmc(varchar)
+  RETURNS text AS
+$BODY$
+DECLARE
+    p_wmc_id ALIAS FOR $1;
+    l_result TEXT;
+BEGIN
+    l_result := '';
+    l_result := l_result || (SELECT COALESCE(wmc_title, '') || ' ' || COALESCE(abstract, '') FROM mb_user_wmc WHERE wmc_id = p_wmc_id);
+        (SELECT keyword FROM wmc_keyword L JOIN keyword K ON (K.keyword_id = L.fkey_keyword_id )
+    END LOOP;
+   l_result := replace(replace(replace(replace(l_result,'Ä','AE'),'ß','SS'),'Ö','OE'),'Ü','UE');
+    RETURN l_result;
+END;
+$BODY$
+ALTER FUNCTION f_collect_searchtext_wmc(varchar) OWNER TO postgres;
+--set mb_user_mb_group_type
+--of mb_user_mb_group to 1 for root!
+UPDATE mb_user_mb_group SET mb_user_mb_group_type = 1 WHERE fkey_mb_user_id = 1 AND fkey_mb_group_id = 20;
+--generate demo group for decentral registrating and publishing services
+-- View: search_wmc_view
+-- DROP VIEW search_wmc_view;
+--TODO: get group information out of mb_group table instead of ows information, cause in this case there can be more than one different service in a resource
+--TODO: set public flag to some wmc docs to generate usefull results
+CREATE OR REPLACE VIEW search_wmc_view AS
+ SELECT wmc_dep.fkey_user_id as user_id, wmc_dep.wmc_id , wmc_dep.srs as wmc_srs, wmc_dep.wmc_title , wmc_dep.abstract as wmc_abstract, f_collect_searchtext_wmc(wmc_dep.wmc_id) AS searchtext
+  , wmc_dep.wmc_timestamp, wmc_dep.department, wmc_dep.mb_group_name,wmc_dep.mb_group_title,wmc_dep.mb_group_country, wmc_dep.mb_group_stateorprovince ,f_collect_topic_cat_wmc(wmc_dep.wmc_id) as md_topic_cats,transform(geometryfromtext(((((((((((((((((((('POLYGON(('::text || wmc_dep.minx::text) || ' '::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.minx::text) || ' '::text) || wmc_dep.maxy::text) || ','::text) || wmc_dep.maxx::text) || ' '::text) || wmc_dep.maxy::text) || ','::text) || wmc_dep.maxx::text) || ' '::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.minx::text) || ' '::text) || wmc_dep.miny::text) || '))'::text, regexp_replace(UPPER(wmc_dep.srs), 'EPSG:', '')::INTEGER),4326) AS the_geom, (((((wmc_dep.minx::text || ','::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.maxx::text) || ','::text) || wmc_dep.maxy::text AS bbox
+	FROM ( SELECT mb_user_wmc.wmc_public, mb_user_wmc.maxy ,mb_user_wmc.maxx ,mb_user_wmc.miny ,mb_user_wmc.minx ,mb_user_wmc.srs ,mb_user_wmc.wmc_id, mb_user_wmc.wmc_title, mb_user_wmc.abstract, mb_user_wmc.wmc_timestamp, mb_user_wmc.fkey_user_id, user_dep.mb_group_id AS department, user_dep.mb_group_name,
+user_dep.mb_group_title,user_dep.mb_group_country, user_dep.mb_group_stateorprovince
+		FROM ( SELECT registrating_groups.fkey_mb_user_id AS mb_user_id, mb_group.mb_group_id, mb_group.mb_group_name, mb_group.mb_group_title, mb_group.mb_group_country, mb_group.mb_group_stateorprovince
+			FROM registrating_groups, mb_group WHERE registrating_groups.fkey_mb_group_id = mb_group.mb_group_id) as user_dep, mb_user_wmc
+		WHERE user_dep.mb_user_id = mb_user_wmc.fkey_user_id) wmc_dep WHERE  wmc_dep.wmc_public = 1 ORDER BY wmc_dep.wmc_id;
+ALTER TABLE search_wmc_view OWNER TO postgres;
+-- insert deleteWFSConf modul in admin1
+-- add delete wfs conf module from geoportal.rlp
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','deleteWFSConf',2,1,'delete wfs conf','','a','','href = "../javascripts/mod_deleteWfsConf_client.html" target="AdminFrame"',10,1204,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS CONF','a','','','','AdminFrame','');
+-- element var removeSpatialRequestHighlight for gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'removeSpatialRequestHighlight', '0', 'remove spatialrequest highlighting when firing search' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'removeSpatialRequestHighlight' AND fkey_e_id = 'gazetteerWFS');
+-- compatibility with UI Layout
+UPDATE gui_element SET e_content = '<ul></ul><div class=''ui-layout-content''></div>' WHERE e_id = 'mb_tabs_horizontal';
+-- Table: layer_preview
+CREATE TABLE layer_preview
+  layer_map_preview_filename character varying(100),
+  layer_extent_preview_filename character varying(100),
+  layer_legend_preview_filename character varying(100),
+  CONSTRAINT fkey_layer_id FOREIGN KEY (fkey_layer_id)
+  CONSTRAINT layer_preview_fkey_layer_id_key UNIQUE (fkey_layer_id)
+WITH (OIDS=FALSE);
+-- Table: termsofuse
+CREATE TABLE termsofuse
+  termsofuse_id integer NOT NULL,
+  "name" character varying(255),
+  symbollink character varying(255),
+  description character varying(255),
+  descriptionlink character varying(255),
+  CONSTRAINT termsofuse_pkey PRIMARY KEY (termsofuse_id)
+WITH OIDS;
+-- Table: wfs_termsofuse
+CREATE TABLE wfs_termsofuse
+  fkey_termsofuse_id integer,
+  CONSTRAINT wfs_termsofuse_fkey_wfs_id_fkey FOREIGN KEY (fkey_wfs_id)
+  CONSTRAINT wfs_termsofuse_termsofuse_fkey FOREIGN KEY (fkey_termsofuse_id)
+      REFERENCES termsofuse (termsofuse_id) MATCH SIMPLE
+WITH OIDS;
+-- Table: wms_termsofuse
+CREATE TABLE wms_termsofuse
+  CONSTRAINT wms_termsofuse_termsofuse_fkey FOREIGN KEY (fkey_termsofuse_id)
+  CONSTRAINT wms_termsofuse_wms_fkey FOREIGN KEY (fkey_wms_id)
+WITH OIDS;
+-- Table: layer_md_topic_category
+CREATE TABLE layer_md_topic_category
+  CONSTRAINT layer_md_topic_category_fkey_layer_id_fkey FOREIGN KEY
+(fkey_layer_id)
+  CONSTRAINT layer_md_topic_category_fkey_md_topic_category_id_fkey FOREIGN
+KEY (fkey_md_topic_category_id)
+WITHOUT OIDS;
+-- terms of use content
+INSERT INTO termsofuse (termsofuse_id, name, symbollink, description, descriptionlink) VALUES (1, 'CC by-nc-nd','http://i.creativecommons.org/l/by-nc-nd/3.0/de/88x31.png','Creative Commons: Namensnennung - Keine kommerzielle Nutzung - Keine Bearbeitungen 3.0 Deutschland','http://creativecommons.org/licenses/by-nc-nd/3.0/de/');
+--update to jQuery 1.4.2 and jQuery UI 1.8.1
+DELETE FROM gui_element WHERE e_id IN ('jq_ui_widget','jq_ui_mouse','jq_ui_position');
+UPDATE gui_element SET e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js' WHERE e_id = 'jq_ui';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','' FROM gui_element WHERE e_id = 'jq_ui' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_widget');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','' FROM gui_element WHERE e_id = 'jq_ui_widget' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_mouse');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','' FROM gui_element WHERE e_id = 'jq_ui_widget' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_position');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_autocomplete',4,1,'jQuery UI autocomplete','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.autocomplete.min.js','','jq_ui,jq_ui_widget,jq_ui_position','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_progressbar',4,1,'jQuery UI progressbar','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.progressbar.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_selectable',4,1,'jQuery UI selectable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.selectable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES ('toolbox_jquery','jq_ui_sortable',4,1,'jQuery UI sortable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.sortable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','' FROM gui_element WHERE e_id = 'jq_ui_dialog' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_button');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT fkey_gui_id,'jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','' FROM gui_element WHERE e_id = 'jq_ui_draggable' AND fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_droppable');
+UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.accordion.min.js' WHERE e_id = 'jq_ui_accordion';
+UPDATE gui_element SET e_requires = 'jq_ui', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.datepicker.min.js' WHERE e_id = 'jq_ui_datepicker';
+UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js' WHERE e_id = 'jq_ui_dialog';
+UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_mouse,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js' WHERE e_id = 'jq_ui_draggable';
+UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_mouse,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js' WHERE e_id = 'jq_ui_resizable';
+UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_mouse,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.slider.min.js' WHERE e_id = 'jq_ui_slider';
+UPDATE gui_element SET e_requires = 'jq_ui,jq_ui_widget', e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js' WHERE e_id = 'jq_ui_tabs';
+UPDATE gui_element SET e_pos = 1 WHERE e_id = 'jq_ui_widget';
+UPDATE gui_element SET e_pos = 1 WHERE e_id = 'jq_ui_position';
+UPDATE gui_element SET e_pos = 2 WHERE e_id = 'jq_ui_mouse';
+UPDATE gui_element SET e_mb_mod = '../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.effects.core.min.js' WHERE e_id = 'jq_ui_effects';
+-- saveWmcTarget for element loadwmc
+SELECT gui_element.fkey_gui_id, 'loadwmc', 'saveWmcTarget', 'savewmc', '' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'saveWmcTarget'
+AND fkey_e_id = 'loadwmc');
+-- color pink in body had effect on other elements
+UPDATE gui_element_vars
+set var_value = 'digitizeGeometryList {position:absolute; top:50px; left:0px;}
+.digitizeGeometryListItem {color:#000000; font-size:10px;}
+body {font-family: Arial, Helvetica, sans-serif; font-size:12px; background-color:#ffffff; margin-top: 0px; margin-left:0px;}
+.button {height:18px; width:32px;}'
+where fkey_gui_id = 'gui_digitize' and fkey_e_id = 'digitize'
+and var_name = 'text css';
+-- more fields in mb_user
+alter table mb_user add column mb_user_firstname character varying(255) DEFAULT ''::character varying;
+alter table mb_user add column mb_user_lastname character varying(255) DEFAULT ''::character varying;
+alter table mb_user add column mb_user_academictitle character varying(255) DEFAULT ''::character varying;
+-- mapframe1: initWms.php is replaced by initWmcObj.php
+UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php' WHERE e_id = 'mapframe1';
+-- overview: initWms.php is replaced by initWmcObj.php
+UPDATE gui_element SET e_mb_mod = '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php' WHERE e_id = 'overview';
+-- missing foreign key in layer_load_count
+ALTER TABLE ONLY layer_load_count
+    ADD CONSTRAINT layer_load_count_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- adds Mapbender favicon to all applications whch do not have favicon yet
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.ico', 'refers to image to use as favicon' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon'
+AND fkey_e_id = 'body');
+UPDATE gui_element_vars set var_value = '../img/favicon.ico'
+WHERE var_name = 'favicon'
+AND var_value = '../img/favicon.png' and (fkey_gui_id IN ('gui', 'gui1', 'gui_digitize', 'gui2') OR fkey_gui_id LIKE 'admin%' OR fkey_gui_id LIKE 'wms%');
+-- tabs - expandable
+'tabs', 'expandable', '0', '1 = expand the tabs to fit the document vertically, default is 0' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'tabs' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'expandable'
+AND fkey_e_id = 'tabs');
+-- draggable in map applications
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+SELECT gui.gui_id,'jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/'
+FROM gui WHERE gui.gui_id NOT LIKE 'admin%' AND gui.gui_id NOT LIKE 'wms%' AND gui.gui_id
+WHERE e_id = 'jq_ui_draggable');
+-- resize map applications
+SELECT gui.gui_id,'jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/'
+WHERE e_id = 'jq_ui_resizable');
+-- add new column gui_layer_title
+alter table gui_layer add column gui_layer_title character varying(255) NOT NULL DEFAULT ''::character varying;
+-- fill gui_layer_title with layer_titles from layer
+UPDATE gui_layer SET gui_layer_title = (SELECT layer_title FROM layer WHERE gui_layer.fkey_layer_id = layer.layer_id);
+--adoptions for managing georss/kml urls and data in the mapbender database
+-- Table: datalink
+-- DROP TABLE datalink;
+CREATE TABLE datalink
+  datalink_id serial NOT NULL,
+  datalink_type character varying(50) NOT NULL DEFAULT ''::character varying, --georss,kml,gml,geojson
+  datalink_type_version character varying(50) NOT NULL DEFAULT ''::character varying, --1.0,3.x?
+  datalink_url text,
+  datalink_owner integer,
+  datalink_timestamp integer,
+  datalink_timestamp_create integer,
+  datalink_timestamp_last_usage integer,
+  datalink_abstract text,
+  datalink_title character varying(255) NOT NULL DEFAULT ''::character varying,
+  datalink_data text, --maybe we want a data access for inspire and the data should stand on the geoportal cause the institutions have no webserver
+  --the following things have s.th. todo with metadata and maybe edited or filled or may not be present
+  datalink_network_access integer,
+  datalink_owsproxy character varying(50),
+  fees character varying(255),
+  accessconstraints text,
+  crs character varying(50) NOT NULL DEFAULT ''::character varying,
+  minx double precision DEFAULT 0,
+  miny double precision DEFAULT 0,
+  maxx double precision DEFAULT 0,
+  maxy double precision DEFAULT 0,
+  CONSTRAINT pk_datalink_id PRIMARY KEY (datalink_id),
+--delete orphaned datalinks automatically
+  CONSTRAINT datalink_owner_fkey FOREIGN KEY (datalink_owner)
+    REFERENCES mb_user (mb_user_id) MATCH SIMPLE
+WITH (
+  OIDS=FALSE
+-- Table: datalink_keyword
+-- DROP TABLE datalink_keyword;
+CREATE TABLE datalink_keyword
+  fkey_datalink_id integer NOT NULL,
+  fkey_keyword_id integer NOT NULL,
+  CONSTRAINT pk_datalink_keyword PRIMARY KEY (fkey_datalink_id, fkey_keyword_id),
+  CONSTRAINT fkey_keyword_id_fkey_datalink_id FOREIGN KEY (fkey_keyword_id)
+      REFERENCES keyword (keyword_id) MATCH SIMPLE
+  CONSTRAINT fkey_datalink_id_fkey_keyword_id FOREIGN KEY (fkey_datalink_id)
+      REFERENCES datalink (datalink_id) MATCH SIMPLE
+WITH (
+  OIDS=FALSE
+-- Table: datalink_md_topic_category
+-- DROP TABLE datalink_md_topic_category;
+CREATE TABLE datalink_md_topic_category
+  CONSTRAINT datalink_md_topic_category_fkey_datalink_id_fkey FOREIGN KEY (fkey_datalink_id)
+  CONSTRAINT datalink_md_topic_category_fkey_md_topic_category_id_fkey FOREIGN KEY (fkey_md_topic_category_id)
+WITH (
+  OIDS=FALSE
+-- add new zoomto coords to gui as a new tab
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url) VALUES ('gui','coordsLookup',
+10,1,'','Coordinate lookup','div','','',1,1,NULL ,NULL ,NULL ,
+'z-index:9999;visibility:hidden','','div','mod_coordsLookup.js','',
+'mapframe1','','http://www.mapbender.org/coordsLookup');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('gui', 'coordsLookup',
+'perimeters', '[50,200,1000,10000]', '' ,'var');
+var_value, context, var_type) VALUES('gui', 'coordsLookup',
+'projections', '[''EPSG:4326'',''EPSG:31467'',''EPSG:31468'',''EPSG:31469'',''EPSG:25832'',''EPSG:25833'']',
+'' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_frameHeight[7]', '240', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_ids[7]', 'coordsLookup', '' ,'php_var');
+-- element var saveInSession for gui element savewmc
+SELECT gui_element.fkey_gui_id, 'savewmc', 'saveInSession', '0', '' ,'var'
+FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id
+WHERE var_name = 'saveInSession' AND fkey_e_id = 'savewmc');
+-- previously, this had been a php var
+UPDATE gui_element_vars SET var_type = 'var' WHERE var_name = 'saveInSession' AND fkey_e_id = 'savewmc';
Modified: trunk/mapbender/resources/db/update.bat
--- trunk/mapbender/resources/db/update.bat	2010-08-28 23:04:58 UTC (rev 6829)
+++ trunk/mapbender/resources/db/update.bat	2010-08-29 17:00:01 UTC (rev 6830)
@@ -104,8 +104,10 @@
 echo performing updates
 echo   update to 2.6.1
 psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6_to_2.6.1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo   update to 2.6.2
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.6.2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
 echo   update to 2.7
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.2_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
 echo   update to 2.7
 psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
 goto END:
Modified: trunk/mapbender/resources/db/update.sh
--- trunk/mapbender/resources/db/update.sh	2010-08-28 23:04:58 UTC (rev 6829)
+++ trunk/mapbender/resources/db/update.sh	2010-08-29 17:00:01 UTC (rev 6830)
@@ -95,8 +95,10 @@
     fi
 	echo "update to 2.6.1"
 	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+	echo "update to 2.6.2"
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
 	echo "update to 2.7"
-	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.2_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
     echo "update sequences"
     psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.7.sql $DBNAME >> log_update.txt 2>> err_update.txt
More information about the Mapbender_commits mailing list
