[Mapbender-commits] r7178 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Dec 2 07:53:15 EST 2010
Author: christoph
Date: 2010-12-02 04:53:15 -0800 (Thu, 02 Dec 2010)
New Revision: 7178
Removed:
   trunk/mapbender/http/plugins/mb_twitter.php
   trunk/mapbender/http/plugins/mb_twitter_signin.js
   trunk/mapbender/http/plugins/mb_twitter_update.js
obsolete
Deleted: trunk/mapbender/http/plugins/mb_twitter.php
--- trunk/mapbender/http/plugins/mb_twitter.php	2010-12-01 09:44:48 UTC (rev 7177)
+++ trunk/mapbender/http/plugins/mb_twitter.php	2010-12-02 12:53:15 UTC (rev 7178)
@@ -1,130 +0,0 @@
-<?php
-# License:
-# Copyright (c) 2009, Open Source Geospatial Foundation
-# This program is dual licensed under the GNU General Public License
-# and Simplified BSD license.
-# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-require_once dirname(__FILE__) . "/../../core/globalSettings.php";
-require_once '../extensions/epicode/EpiCurl.php';
-require_once '../extensions/epicode/EpiOAuth.php';
-require_once '../extensions/epicode/EpiTwitter.php';
-$gui_id = Mapbender::session()->get("mb_user_gui");
-$e_id = "twitter_signin";
-require_once '../include/dyn_php.php';
-$ajaxResponse = new AjaxResponse($_POST);
-if (!isset($consumerKey) || !isset($consumerSecret)) {
-	$ajaxResponse->setSuccess(false);
-	$ajaxResponse->setMessage(_mb("Element vars consumerKey and consumerSecret are not set. If you don't have them, get them from Twitter."));
-	$ajaxResponse->send();
-function isSignedIn ($token = null) {
-	global $Twitter;
-	if (!is_null($token)) {
-		try {
-			$Twitter->setToken($token);
-			$accessToken = $Twitter->getAccessToken();
-			Mapbender::session()->set("twitter_token", $accessToken->oauth_token);
-			Mapbender::session()->set("twitter_token_secret", $accessToken->oauth_token_secret);
-		catch (Exception $e) {
-			Mapbender::session()->delete("twitter_token");
-			Mapbender::session()->delete("twitter_token_secret");
-			return false;
-	if (Mapbender::session()->exists("twitter_token") && Mapbender::session()->exists("twitter_token_secret")) {
-			Mapbender::session()->get("twitter_token"),
-			Mapbender::session()->get("twitter_token_secret")
-		new mb_exception("token: " . Mapbender::session()->get("twitter_token"));
-		new mb_exception("token_secret: " . Mapbender::session()->get("twitter_token_secret"));
-		return true;
-	return false;
-$Twitter = new EpiTwitter($consumerKey, $consumerSecret);
-switch ($ajaxResponse->getMethod()) {
-	case "isSignedIn" :
-		$token = $ajaxResponse->getParameter("token");
-		if (isSignedIn($token)) {
-			$ajaxResponse->setResult(array("signedIn" => true));
-			$ajaxResponse->setMessage(_mb("Signed in."));
-		$ajaxResponse->setResult(array("signedIn" => false));
-		$ajaxResponse->setMessage(_mb("Not signed in."));
-		$ajaxResponse->setSuccess(true);
-		break;
-	case "signin" :
-		try {
-			$url = $Twitter->getAuthenticateUrl();
-			$ajaxResponse->setMessage(_mb("Could not connect to Twitter."));
-		$ajaxResponse->setResult(array("url" => $url));
-		break;
-	case "signout" :
-		$ajaxResponse->setResult(array("signedOut" => true));
-		$ajaxResponse->setMessage(_mb("Signed out."));
-		break;
-	case "update":
-		if (!isSignedIn()) {
-		$Twitter = new EpiTwitter($consumerKey, $consumerSecret);
-		$status = $ajaxResponse->getParameter("status");
-		$lat = $ajaxResponse->getParameter("lat");
-		$lon = $ajaxResponse->getParameter("lon");
-		try {
-			$newStatus = $Twitter->post_statusesUpdate(array(
-				'status' => $text,
-				'lat' => $lat,
-				'long' => $long
-			"res" => serialize($newStatus)
-		break;
-	default:
-		$ajaxResponse->setMessage(_mb("An unknown error occured."));
-		break;
-$ajaxResponse->send();
Deleted: trunk/mapbender/http/plugins/mb_twitter_signin.js
--- trunk/mapbender/http/plugins/mb_twitter_signin.js	2010-12-01 09:44:48 UTC (rev 7177)
+++ trunk/mapbender/http/plugins/mb_twitter_signin.js	2010-12-02 12:53:15 UTC (rev 7178)
@@ -1,171 +0,0 @@
- * Package: twitter_signin
- * Description:
- * Authenticate with Twitter
- * Files:
- *  - http/plugins/mb_twitter_signin.js
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
- * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','twitter_signin',
- * > 1,1,'Authenticate with Twitter','Authenticate with Twitter','img',
- * > '../img/twitter_signin.png','',900,10,NULL ,NULL ,NULL ,'','','',
- * > '../plugins/mb_twitter_signin.js','','','','');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES('<appId>', 'twitter_signin',
- * > 'consumerKey', '<your key>', '' ,'php_var');
- * > 'consumerSecret', '<your secret>',
- * > '' ,'php_var');
- * Help:
- * http://www.mapbender.org/Twitter_signin
- * Maintainer:
- * http://www.mapbender.org/User:Christoph_Baudson
- * Parameters:
- * consumerKey      - your consumer key from Twitter (PHP var)
- * consumerSecret   - your consumer secret from Twitter (PHP var)
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-var $this = $(this);
-var originalI18nObject = {
-	"logIn" : "Log in at Twitter",
-	"logOut" : "Log out at Twitter"
-var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
-var TwitterSignin = function (options) {
-	var that = this;
-	this.isSignedIn = function () {
-		var req = new Mapbender.Ajax.Request({
-			url: "../plugins/mb_twitter.php",
-			method: "isSignedIn",
-			parameters: {
-				token: getOauthToken()
-			callback: function (obj, result, message) {
-				if (!result) {
-					alert(message);
-					$this.text(translatedI18nObject.logIn);
-					return;
-				if (obj.signedIn) {
-					alert(message);
-					$this.text(translatedI18nObject.logOut);
-					$this.mapbender(function () {
-						this.signedIn = true;
-						this.events.signedIn.trigger();
-				else {
-						this.signedIn = false;
-						this.events.signedOut.trigger();
-		req.send();
-	this.events = {
-		signedIn: new Mapbender.Event(),
-		signedOut: new Mapbender.Event()
-	var getOauthToken = function () {
-		var getString = document.location.search.substr(1,document.location.search.length);
-		if (getString === '') {
-			return null;
-		var gArr = getString.split('&');
-		for (i = 0; i < gArr.length; ++i) {
-			var v = '';
-			vArr = gArr[i].split('=');
-	        	if (vArr.length > 1) {
-				v = vArr[1];
-			var key = unescape(vArr[0]);
-			if (key === "oauth_token") {
-				return unescape(v);
-		return null;
-	$this.click(function () {
-		var method = that.signedIn ? "signout" : "signin";
-			method: method,
-			parameters: {
-				if (!result) {
-					alert(message);
-					return;
-				if (method === "signin" && obj.url && typeof obj.url === "string") {
-				  window.location.href = obj.url;
-				else if (method === "signout") {
-					var newUrl = window.location.href.replace(/oauth_token\=[0-9a-zA-Z]+/g, "");
-					window.location.href = newUrl;
-		req.send();
-$this.mapbender(new TwitterSignin());
-Mapbender.events.init.register(function () {
-	// check if signed in
-		this.isSignedIn();
-	Mapbender.events.localize.register(function () {
-		Mapbender.modules.i18n.queue(options.id, originalI18nObj, function (translatedObj) {
-			if (typeof translatedObj !== "object") {
-				return;
-			translatedI18nObj = translatedObj;
-			try {
-			catch (exc) {
-				new Mb_warning("Error when translating: " . exc.message);
Deleted: trunk/mapbender/http/plugins/mb_twitter_update.js
--- trunk/mapbender/http/plugins/mb_twitter_update.js	2010-12-01 09:44:48 UTC (rev 7177)
+++ trunk/mapbender/http/plugins/mb_twitter_update.js	2010-12-02 12:53:15 UTC (rev 7178)
@@ -1,116 +0,0 @@
-$twitterUpdate = $(this);
-var that = this;
-Mapbender.events.beforeInit.register(function () {
-	var signIn = Mapbender.modules.twitter_signin;
-	if (signIn !== undefined) {
-		signIn.events.signedIn.register(function () {
-			$twitterUpdate.fadeIn();
-		signIn.events.signedOut.register(function () {
-			$twitterUpdate.fadeOut();
-	var updateStatus = function (status, lat, lon, callback) {
-			method: "update",
-			parameters: {
-				status: status,
-				lat: lat,
-				lon: lon
-				if (!result) {
-					alert(message);
-					return;
-				if (typeof callback === "function") {
-					callback();
-				alert("Updated");
-				new Mapbender.Notice($.toJSON(obj));
-		req.send();
-	var button = new Mapbender.Button({
-		domElement: that,
-		over: options.src.replace(/_off/, "_over"),
-		on: options.src.replace(/_off/, "_on"),
-		off: options.src,
-		name: options.id,
-		go: function () {
- 			options.$target.each(function () {
-				var $twitterStatus, m;
-				var cancel = function () {
-						$twitterStatus.fadeOut("slow", function () {
-							m.remove();
-							$(this).remove();
-				$(this).mapbender(function () {
-					this.events.afterMapRequest.register(cancel);
-	 			$(this).css("cursor", "pointer")
-	 			.mousedown(function (e) {
-					mb_disableThisButton(options.id);
-					var map = $(this).mapbender();
-					var height = map.getHeight();
-					var width = map.getWidth();
-					var offset = 10;
-					var pix = map.getMousePosition(e);
-					var p = map.convertPixelToReal(pix);
-					m = new Mapbender.Marker(p, map);
-					$twitterStatus = $("<div style='z-index:999;position:absolute;top:" +
-						(pix.y + parseInt(this.style.top, 10)) + "px;" +
-						"left:" + (offset + parseInt(this.style.left, 10)) + "px;width:"+(width-2*offset)+"px;display:none'>" +
-						"<div style='width:100%;height:10px;background-position:" + (pix.x-offset-10) + "px 0px;background-image:url(http://s.twimg.com/a/1266605807/images/arr2.gif);background-repeat:no-repeat;'/>" +
-						"<div style='background-color:#fff;height:110px;padding:8px;'>" +
-						"<div>What's happening?<span class='chars-left' style='float:right'>140</span></div>" +
-						"<textarea rows='2' cols='70'></textarea>" +
-						"<br><span style='float:right;margin:10px;'>" +
-						"<span id='twitter_update_send' style='cursor:pointer;margin:5px;padding:5px;' " +
-						"class='ui-state-default ui-corner-all'>update</span>" +
-						"<a id='twitter_cancel' href='#'>cancel</a></span>" +
-						"</div></div>").appendTo("body").fadeIn("slow");
-					var $charsLeft = $("span.chars-left", $twitterStatus);
-					var $textarea = $("textarea", $twitterStatus);
-					$textarea.focus().keypress(function () {
-						var chars = $textarea.val().length;
-						var avail = 140 - chars;
-						$charsLeft.text(avail);
-					var $button = $("#twitter_update_send");
-					$button.click(function () {
-							m.remove();
-						// show sandclock
-						updateStatus($textarea.val(), p.y, p.x, function () {
-							// hide sandclock
-					var $cancel = $("#twitter_cancel");
-					$cancel.click(function () {
-						return cancel();
-					return false;
-		stop: function () {
-				$(this).css("cursor", "default").unbind("mousedown");
More information about the Mapbender_commits mailing list
