[Mapbender-commits] r7181 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Dec 2 10:54:14 EST 2010
Author: verenadiewald
Date: 2010-12-02 07:54:14 -0800 (Thu, 02 Dec 2010)
New Revision: 7181
   trunk/mapbender/http/javascripts/geometry.js
new function getDist and getAggregatedDist for measuring in digitize
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	2010-12-02 15:46:06 UTC (rev 7180)
+++ trunk/mapbender/http/javascripts/geometry.js	2010-12-02 15:54:14 UTC (rev 7181)
@@ -1090,7 +1090,7 @@
 	this.addPointByCoordinates = function(x,y,z){
 		var newPoint = new Point(x,y,z);
 		this.add(newPoint);
-//		updateDist();
+		updateDist();
@@ -1143,17 +1143,34 @@
 	 * @private
 	var updateDist = function(){
- * DISABLED BECAUSE IT IS TOO SLOW
 		dist[0] = 0;
 		totaldist[0] = 0;
 		for (var i = 1 ; i < that.count(); i++){
 			dist[i] = that.get(i-1).dist(that.get(i));
 			totaldist[i] = totaldist[i-1] + dist[i];
+	 * gets the distance between two points i and i+1
+	 * @param {Integer} i index
+	 * @param {Integer} numberOfDigits round to numberOfDigits (optional)
+	 * @return the distance
+	 * @type Float
+	this.getDist = function(i, numberOfDigits) {
+		var indexA = this.getIndex(i);
+		var indexB = this.getIndex(i+1);
+		if (indexA === false || indexB === false) {
+			return 0;
+		if (typeof(numberOfDigits) == "number") {
+			return roundToDigits(dist[indexB], numberOfDigits);
+		return dist[indexB];
 	 * gets the distance between the last and last but one point of this {@link Geometry}.
 	 * @param {Integer} numberOfDigitis round to numberOfDigits (optional)
@@ -1168,6 +1185,26 @@
+	 * gets the total distance between two points i and i+1
+	 * @type Float
+	this.getAggregatedDist = function(i, numberOfDigits) {
+			return 0;
+			return roundToDigits(totaldist[indexB], numberOfDigits);
+		return totaldist[indexB];
 	 * gets the length of the outer rim of this {@link Geometry}.
More information about the Mapbender_commits mailing list
