[Mapbender-commits] r7188 - trunk/mapbender/http/widgets
svn_mapbender at osgeo.org
Fri Dec 3 10:11:33 EST 2010
Author: christoph
Date: 2010-12-03 07:11:33 -0800 (Fri, 03 Dec 2010)
New Revision: 7188
trunk/mapbender/http/widgets/w_measure.js
add panSubElement
Modified: trunk/mapbender/http/widgets/w_measure.js
--- trunk/mapbender/http/widgets/w_measure.js 2010-12-03 15:11:11 UTC (rev 7187)
+++ trunk/mapbender/http/widgets/w_measure.js 2010-12-03 15:11:33 UTC (rev 7188)
@@ -24,26 +24,30 @@
_isPolygon: function (pos) {
var len = this._measurePoints.length;
- if (len < 2) {
+ var max = pos ? len - 1 : len - 2;
+ if (pos && len < 2 || !pos && len < 3) {
return false;
+ var posLocal = pos ? pos : this._measurePoints[len - 1];
var p0 = this._measurePoints[0].pos;
- var pn = this._measurePoints[len - 1].pos;
- for (var i = 0; i < len - 1; i++) {
+ var pn = this._measurePoints[max].pos;
+ for (var i = 0; i < max; i++) {
var pi = this._measurePoints[i].pos;
var pj = this._measurePoints[i + 1].pos;
if (i > 0 && this._lineIntersect(
pi.x, pi.y, pj.x, pj.y,
- p0.x, p0.y, pos.x, pos.y)
+ p0.x, p0.y, posLocal.x, posLocal.y)
return false;
if (this._lineIntersect(
- pn.x, pn.y, pos.x, pos.y)
+ pn.x, pn.y, posLocal.x, posLocal.y)
this._currentPolygonIsInvalid = true;
return false;
@@ -168,6 +172,14 @@
return null;
+ _calculateTotalDistance: function () {
+ for (var i = 0; i < count(this._measurePoints); i++) {
+ _calculatePerimeter: function () {
_isPointSnapped: function (p1, p2) {
return p1.dist(p2) <= this.options.measurePointDiameter/2;
@@ -194,31 +206,31 @@
var str_path = "";
- if (!drawOptions.highlightFirst) {
+ if (pos && drawOptions && !drawOptions.highlightFirst) {
this._measurePoints.push(pos);
if (len > 0) {
for (var k=0; k < len; k++) {
- if (drawOptions.highlightLast && k === len - 1) {
- continue;
var pk = this._measurePoints[k].pos;
var q = this._measurePoints[k].mousePos;
str_path += (k === 0) ? 'M' : 'L';
str_path += q.x + ' ' + q.y;
- if (drawOptions.drawPoints &&
- (k === 0 && !this._polygonIsInvalid || k >= len - 2)) {
+ if (drawOptions && drawOptions.highlightLast && k === len - 1) {
+ continue;
+ if (drawOptions && drawOptions.drawPoints &&
+ (k === 0 && !this._polygonIsInvalid || k >= len - 2 && !drawOptions.highlightFirst)) {
var circle = this._canvas.circle(q.x, q.y, this.options.measurePointDiameter);
if (k === 0) {
circle.attr({
- fill: drawOptions.highlightFirst ?
+ fill: drawOptions && drawOptions.highlightFirst ?
this.options.pointFillSnapped : this.options.pointFillDefault,
stroke: "none",
opacity: this.options.opacity
@@ -226,7 +238,7 @@
else {
circle.attr({
- fill: drawOptions.highlightLast && k === len - 2 ?
+ fill: drawOptions && drawOptions.highlightLast && k === len - 2 ?
stroke: "none",
@@ -235,12 +247,12 @@
this._measurePoints.pop();
- if (this._isPolygon(this._measurePoints, pos) && !drawOptions.highlightLast && !this.polygonIsInvalid) {
+ if (this._isPolygon(this._measurePoints, pos) && drawOptions && !drawOptions.highlightLast && !this.polygonIsInvalid) {
var poly = this._canvas.path(str_path + 'Z');
poly.attr({
@@ -255,9 +267,9 @@
var line = this._canvas.path(str_path);
line.attr({
- stroke: drawOptions.highlightFirst || drawOptions.highlightLast ?
+ stroke: drawOptions && (drawOptions.highlightFirst || drawOptions.highlightLast) ?
this.options.lineStrokeSnapped : this.options.lineStrokeDefault,
- "stroke-width": drawOptions.highlightLast ?
+ "stroke-width": drawOptions && drawOptions.highlightLast ?
this.options.lineStrokeWidthSnapped : this.options.lineStrokeWidthDefault,
@@ -284,26 +296,38 @@
this._map.convertPixelToReal(mousePos)
- this._trigger("onmeasure", null, pos);
+ var measureData = {
+ pos: pos
- var previousPoint = this._measurePoints.length > 0 ?
- this._measurePoints[this._measurePoints.length - 1].pos : null;
+ var len = this._measurePoints.length;
+ var previousPoint = len > 0 ?
+ this._measurePoints[len - 1].pos : null;
this._currentDistance = this._calculateDistance(
previousPoint,
pos.pos
- if (this._measurePoints.length > 0) {
- this._trigger("onmeasuredistance", null, this._currentDistance);
+ if (len > 0) {
+ measureData.currentDistance = this._currentDistance;
+ measureData.totalDistance = this._measurePoints[len - 1].totalDistance + this._currentDistance;
+ if (len > 1) {
+ measureData.perimeter = measureData.totalDistance + this._calculateDistance(
+ this._measurePoints[0].pos,
+ pos.pos
if (this._isPolygon(this._measurePoints, pos) && !this._polygonIsInvalid) {
this._currentArea = this._calculateArea(pos);
- this._trigger("onmeasurearea", null, this._currentArea);
+ measureData.area = this._currentArea;
+ this._trigger("update", null, measureData);
this._draw(pos, {
highlightFirst: firstPointSnapped,
highlightLast: lastPointSnapped,
@@ -313,6 +337,8 @@
_reinitialize: function (e) {
this._canvas.clear();
this._measurePoints = [];
+ this._measurePoints.closedPolygon = false;
+ this._measurePoints.closedLine = false;
// hideMeasureData();
@@ -336,13 +362,18 @@
_addPoint: function (e) {
var mousePos = this._map.getMousePosition(e);
var pos = {
mousePos: mousePos,
pos: this._map.convertPixelToReal(mousePos),
- distance: this._currentDistance
+ distance: this._currentDistance,
+ totalDistance: len > 0 ?
+ this._measurePoints[len - 1].totalDistance + this._currentDistance :
- this._trigger("pointadded", null, pos);
+// this._trigger("pointadded", null, pos);
var firstPointSnapped = this._isFirstPointSnapped(mousePos);
var lastPointSnapped = this._isLastPointSnapped(mousePos);
@@ -360,6 +391,8 @@
drawPoints: false
this._addLastPoint(e);
+ this._measurePoints.closedPolygon = firstPointSnapped;
+ this._measurePoints.closedLine = lastPointSnapped;
else {
@@ -376,9 +409,53 @@
return true;
+ _redraw: function () {
+ if (!$(this.element).data("mb_measure")) {
+ return;
+ if (len === 0) {
+ return;
+ for (var i = 0; i < len; i++) {
+ var p = this._measurePoints[i];
+ p.mousePos = this._map.convertRealToPixel(p.pos);
+ if (this._measurePoints.closedPolygon) {
+ this._draw(undefined, {
+ highlightFirst: true,
+ highlightLast: false,
+ drawPoints: false
+ else if (this._measurePoints.closedLine) {
+ highlightFirst: false,
+ highlightLast: true,
+ drawPoints: false
+ else {
+ drawPoints: false
_init: function () {
+ if (this._measurePoints.closedLine || this._measurePoints.closedPolygon) {
+ this._measurePoints = [];
+ this.element
+ .bind("click", $.proxy(this, "_addPoint"))
+ .bind("mousemove", $.proxy(this, "_measure"))
+ .css("cursor", "crosshair");
_create: function () {
// ":maps" is a Mapbender selector which
// checks if an element is a Mapbender map
this.element = this.element.filter(":maps");
@@ -387,28 +464,34 @@
$.error("This widget must be applied to a Mapbender map.");
- this.element
- .bind("click", $.proxy(this, "_addPoint"))
- .bind("mousemove", $.proxy(this, "_measure"))
- .css("cursor", "crosshair");
this._map = this.element.mapbender();
+ this._map.events.afterMapRequest.register($.proxy(this._redraw, this));
this._srs = this._map.getSrs();
- var $canvas = $("<div />").css({
+ this._$canvas = $("<div />").css({
"z-index": 100,
"position": "relative"
}).appendTo(this.element);
- this._canvas = Raphael($canvas.get(0), this._map.getWidth(), this._map.getHeight());
+ this._canvas = Raphael(this._$canvas.get(0), this._map.getWidth(), this._map.getHeight());
+ mb_registerPanSubElement($(this._canvas.canvas).parent().get(0));
- destroy: function () {
+ // the measured geometry will be available, the events will be deleted
+ deactivate: function () {
this.element
.unbind("click", this._addPoint)
.unbind("mousemove", this._measure)
+ .unbind("click", this._reinitialize)
.css("cursor", "default");
+ // delete everything
+ destroy: function () {
+ this.deactivate();
+ this._$canvas.remove();
+ this._map.events.afterMapRequest.unregister($.proxy(this._redraw, this));
$.Widget.prototype.destroy.apply(this, arguments); // default destroy
+ $(this.element).data("mb_measure", null);
More information about the Mapbender_commits
