[Mapbender-commits] r7194 - in trunk/mapbender/http: plugins widgets
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Dec 9 10:37:34 EST 2010
Author: christoph
Date: 2010-12-09 07:37:34 -0800 (Thu, 09 Dec 2010)
New Revision: 7194
   trunk/mapbender/http/plugins/mb_measure_widget.js
   trunk/mapbender/http/widgets/w_measure.js
bug fixes
Modified: trunk/mapbender/http/plugins/mb_measure_widget.js
--- trunk/mapbender/http/plugins/mb_measure_widget.js	2010-12-08 10:58:17 UTC (rev 7193)
+++ trunk/mapbender/http/plugins/mb_measure_widget.js	2010-12-09 15:37:34 UTC (rev 7194)
@@ -49,21 +49,23 @@
 			"<div>Aktuelle Koordinaten: <span class='mb-measure-current-point' /></div>" +
 			"<div>Distanz (zum letzten Punkt): <span class='mb-measure-distance-last' />  <span class='mb-measure-distance-last-unit' /></div>" +
 			"<div>Distanz (gesamt): <span class='mb-measure-distance-total' /> <span class='mb-measure-distance-total-unit' /></div>" +
+			"<div>Umring (gesamt): <span class='mb-measure-perimeter' /> <span class='mb-measure-perimeter-unit' /></div>" +
 			"<div>Fläche: <span class='mb-measure-area' /> <span class='mb-measure-area-unit' /></div>" +
 			"<a class='mb-measure-clear' href='#' title='Messung löschen'/>";
 	var hideMeasureData = function () {
 		measureDialog.find(".mb-measure-clicked-point").parent().hide();
-//		measureDialog.find(".mb-measure-current-point").parent().hide();
+		measureDialog.find(".mb-measure-current-point").parent().hide();
 		measureDialog.find(".mb-measure-distance-last").parent().hide();
 		measureDialog.find(".mb-measure-distance-total").parent().hide();
+		measureDialog.find(".mb-measure-perimeter").parent().hide();
 		measureDialog.find(".mb-measure-area").parent().hide();
 	var changeDialogContent = function () {
 		measureDialog.html(informationHtml);
 		hideMeasureData();
-		o.$target.unbind("mouseenter", changeDialogContent);
+		o.$target.unbind("click", changeDialogContent);
 	var create = function () {
@@ -93,107 +95,99 @@
-	var updateCurrentPoint = function (evt, p) {
-		measureDialog.find(".mb-measure-current-point").text(
-			p.pos.x + " " + p.pos.y
-		).parent().show();
-	var updateClickedPoint = function (evt, p) {
-		totalDistance = typeof totalDistance === "number" ? totalDistance + currentDistance : currentDistance;
-		measureDialog.find(".mb-measure-clicked-point").text(
-	var updateDistance = function (evt, dist) {
-		if (typeof dist !== "number") {
-			return;
+	var updateCurrentPoint = function (evt, data) {
+		if (data.pos) {
+			var p = data.pos;
+			measureDialog.find(".mb-measure-current-point").text(
+				p.pos.x + " " + p.pos.y
+			).parent().show();
-		var lastDistanceUnit = "m";
-		currentDistance = dist;
-		displayDistance = dist;
-		if (displayDistance > 10000){
-			displayDistance /= 1000;
-			lastDistanceUnit = "km";
-		measureDialog.find(".mb-measure-distance-last-unit").html(lastDistanceUnit);
-		measureDialog.find(".mb-measure-distance-last").text(Math.round(displayDistance*10)/10).parent().show();
-		var totalDistanceUnit = "m";
-		var displayTotalDistance = typeof totalDistance === "number" ? totalDistance + dist : dist;
-		if (displayTotalDistance > 10000){
-			displayTotalDistance = displayTotalDistance / 1000;
-			totalDistanceUnit = "km";
-		measureDialog.find(".mb-measure-distance-total-unit").html(totalDistanceUnit);
-		measureDialog.find(".mb-measure-distance-total").text(Math.round(displayTotalDistance*10)/10).parent().show();
-	var updateArea = function (evt, area) {
-		if (area === null) {
-			return;
+	var updateClickedPoint = function (evt, data) {
+		if (data.pos) {
+			var p = data.pos;
+			measureDialog.find(".mb-measure-clicked-point").text(
-		var areaUnit = "m&sup2;";
-		if (area > 10000000){
-			area /= 1000000;
-			areaUnit = "km&sup2;";
-		else if (area > 100000){
-			area /= 10000;
-			areaUnit = "ha";
-		area = Math.round(area*10)/10;
-		measureDialog.find(".mb-measure-area-unit").html(areaUnit);
-		measureDialog.find(".mb-measure-area").text(area).parent().show();
-	var updateView = function (evt, data) {
-		if (perimeter === null) {
-			return;
-		if (data.distance) {
+	var updateCurrentDistance = function (evt, data) {
+		if (data.currentDistance) {
-			var displayDistance = data.distance;
+			var displayDistance = data.currentDistance;
+	var updateTotalDistance = function (evt, data) {
 		if (data.totalDistance) {
+			var displayTotalDistance = data.totalDistance;
+	var updatePerimeter = function (evt, data) {
+		if (data.perimeter) {
+			var unit = "m";
+			var displayPerimeter = data.perimeter;
+			if (displayPerimeter > 10000){
+				displayPerimeter = displayPerimeter / 1000;
+				totalDistanceUnit = "km";
+			measureDialog.find(".mb-measure-perimeter-unit").html(unit);
+			measureDialog.find(".mb-measure-perimeter").text(Math.round(displayPerimeter*10)/10).parent().show();
+	var updateArea = function (evt, data) {
+		if (data.area) {
+			var areaUnit = "m&sup2;";
+			var area = data.area;
+			if (area > 10000000){
+				area /= 1000000;
+				areaUnit = "km&sup2;";
+			else if (area > 100000){
+				area /= 10000;
+				areaUnit = "ha";
+			area = Math.round(area*10)/10;
+			measureDialog.find(".mb-measure-area-unit").html(areaUnit);
+			measureDialog.find(".mb-measure-area").text(area).parent().show();
+	var updateView = function (evt, data) {
+		updateCurrentPoint(evt, data);
+		updateCurrentDistance(evt, data);
+		updateTotalDistance(evt, data);
+		updateArea(evt, data);
+		updatePerimeter(evt, data);
 	this.activate = function () {
 		if (o.$target.size() > 0) {
 			o.$target
 				.mb_measure()
 				.bind("mb_measureupdate", updateView)
-/*				.bind("mb_measurepointadded", updateClickedPoint)
-				.bind("mb_measureonmeasure", updateCurrentPoint)
-				.bind("mb_measureonmeasuredistance", updateDistance)
-				.bind("mb_measureonmeasurearea", updateArea)
-				.bind("mb_measureonmeasureperimeter", updatePerimeter)
-				.bind("mouseenter", changeDialogContent);
+				.bind("mb_measurepointadded", updateClickedPoint)
+				.bind("click", changeDialogContent);
 		measureDialog.dialog("open");
Modified: trunk/mapbender/http/widgets/w_measure.js
--- trunk/mapbender/http/widgets/w_measure.js	2010-12-08 10:58:17 UTC (rev 7193)
+++ trunk/mapbender/http/widgets/w_measure.js	2010-12-09 15:37:34 UTC (rev 7194)
@@ -92,15 +92,18 @@
 		if (this._measurePoints.length < 2) {
 			return null;
-		var area = 0;
+		this._measurePoints.push(pos);
+		var part, area = 0;
 		var p0 = this._measurePoints[0].pos, pi, pj;
 		for (var i = 0; i < this._measurePoints.length - 1; i++)  {
 			pi = this._measurePoints[i].pos;
 			pj = this._measurePoints[i + 1].pos;
-			area += (pi.y + pj.y) * (pi.x - pj.x) / 2;
+			part = (pi.y + pj.y) * (pi.x - pj.x) / 2;
+			area += part;
-		area += (p0.y + pj.y) * (p0.x - pj.x) / 2;
+		part = (pj.y + p0.y) * (pj.x - p0.x) / 2;
+		area += part;
+		this._measurePoints.pop();
 		return Math.abs(area);
 	_calculateAreaGeographic: function (pos) {
@@ -172,14 +175,6 @@
 		return null;
-	_calculateTotalDistance: function () {
-		for (var i = 0; i < count(this._measurePoints); i++) {
-	_calculatePerimeter: function () {
 	_isPointSnapped: function (p1, p2) {
 		return p1.dist(p2) <= this.options.measurePointDiameter/2;
@@ -276,59 +271,61 @@
 		line.toFront();
 	_measure: function (e) {
-		if (this._srs !== this._map.getSrs()){
-//			button.stop();
-			return;
 		var mousePos = this._map.getMousePosition(e);
 		var firstPointSnapped = this._isFirstPointSnapped(mousePos)
 			&& !this._polygonIsInvalid;
 		var lastPointSnapped = this._isLastPointSnapped(mousePos);
-		var pos = {
-			mousePos: mousePos,
-			pos: firstPointSnapped ?
-				this._measurePoints[0].pos : lastPointSnapped ?
-					this._measurePoints[this._measurePoints.length - 1].pos :
-					this._map.convertPixelToReal(mousePos)
 		var measureData = {
-			pos: pos
+			pos: {
+				mousePos: mousePos,
+				pos: firstPointSnapped ?
+					this._measurePoints[0].pos : lastPointSnapped ?
+						this._measurePoints[this._measurePoints.length - 1].pos :
+						this._map.convertPixelToReal(mousePos)
+		// calculate distance
 		var len = this._measurePoints.length;
 		var previousPoint = len > 0 ?
 			this._measurePoints[len - 1].pos : null;
 		this._currentDistance = this._calculateDistance(
 			previousPoint,
-			pos.pos
+			measureData.pos.pos
+		// calculate total distance and perimeter
 		if (len > 0) {
 			measureData.currentDistance = this._currentDistance;
-			measureData.totalDistance = this._measurePoints[len - 1].totalDistance + this._currentDistance;
+			this._totalDistance = this._currentDistance;
+			measureData.totalDistance = this._totalDistance ;
 			if (len > 1) {
+				this._totalDistance = this._measurePoints[len - 1].totalDistance + this._currentDistance;
 				measureData.perimeter = measureData.totalDistance + this._calculateDistance(
-					pos.pos
-		if (this._isPolygon(this._measurePoints, pos) && !this._polygonIsInvalid) {
-			this._currentArea = this._calculateArea(pos);
+		// calculate area
+		if (this._isPolygon(this._measurePoints, measureData.pos) && !this._polygonIsInvalid) {
+			this._currentArea = this._calculateArea(measureData.pos);
 			measureData.area = this._currentArea;
 		this._trigger("update", null, measureData);
-		this._draw(pos, {
+		this._draw(measureData.pos, {
 			highlightFirst: firstPointSnapped,
 			highlightLast: lastPointSnapped,
 			drawPoints: true
@@ -340,8 +337,6 @@
 		this._measurePoints.closedPolygon = false;
 		this._measurePoints.closedLine = false;
-//			hideMeasureData();
 		this._polygonIsInvalid = false;
 		this._currentPolygonIsInvalid = false;
 		this._totalDistance = 0;
@@ -364,28 +359,29 @@
-		var pos = {
-			pos: this._map.convertPixelToReal(mousePos),
-			distance: this._currentDistance,
-			totalDistance: len > 0 ?
-				this._measurePoints[len - 1].totalDistance + this._currentDistance :
-				this._currentDistance
+		var data = {
+			pos: {
+				pos: this._map.convertPixelToReal(mousePos)
-//		this._trigger("pointadded", null, pos);
+		if (this._totalDistance) {
+			data.pos.totalDistance = this._totalDistance;
+		this._trigger("pointadded", e, data);
 		var firstPointSnapped = this._isFirstPointSnapped(mousePos);
-		this._isPolygon(this._measurePoints, pos);
+		this._isPolygon(this._measurePoints, data.pos);
 		if (this._currentPolygonIsInvalid) {
 			this._polygonIsInvalid = true;
 		if (lastPointSnapped || firstPointSnapped) {
-			this._draw(pos, {
+			this._draw(data.pos, {
 				drawPoints: false
@@ -395,13 +391,13 @@
 			this._measurePoints.closedLine = lastPointSnapped;
 		else {
-			this._measurePoints.push(pos);
+			this._measurePoints.push(data.pos);
 			this._totalDistance += this._currentDistance;
 			this._currentDistance = 0;
-			lastPointSnapped = this._isLastPointSnapped(pos.mousePos);
-			this._draw(pos, {
+			lastPointSnapped = this._isLastPointSnapped(mousePos);
 				drawPoints: true
More information about the Mapbender_commits mailing list
