[Mapbender-commits] r7224 - trunk/mapbender/core
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Dec 11 10:19:51 EST 2010
Author: arnulf
Date: 2010-12-11 07:19:51 -0800 (Sat, 11 Dec 2010)
New Revision: 7224
   trunk/mapbender/core/system.php
prepared statements set, core conf formatted
Modified: trunk/mapbender/core/system.php
--- trunk/mapbender/core/system.php	2010-12-11 15:19:46 UTC (rev 7223)
+++ trunk/mapbender/core/system.php	2010-12-11 15:19:51 UTC (rev 7224)
@@ -1,6 +1,6 @@
 <?php
 # $Id$
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2010 OSGeo
 # This program is free software; you can redistribute it and/or modify
 # it under the terms of the GNU General Public License as published by
@@ -16,7 +16,6 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 //define("SESSION_NAME", "TRUNK_SESSID");
 # configuration file
@@ -35,7 +34,8 @@
 define("MB_RESOLUTION", "28.35");
 define("MB_FEATURE_COUNT", "100");
-define("MB_SECURITY_PROXY", "http://wms.wheregroup.com/mapbender/tools/security_proxy.php?mb_ows_security_proxy=");
+define("MB_SECURITY_PROXY", "");
 # available log levels
@@ -82,11 +82,14 @@
 define("MB_BASEDIR",realpath(dirname(__FILE__)."/../"));
+if(!defined("PREPAREDSTATEMENTS")){
+	define("PREPAREDSTATEMENTS", true);
 function secure($path,$folder = "",$fileExt = null) {
-    $secure = true;
+	$secure = true;
 	if(!defined("MB_BASEDIR")){ throw new Exception("MB_BASEDIR must be defined in core/system.php"); }
 	$basedir = realpath(MB_BASEDIR."/".$folder);
 	$path = realpath($path);
 	// $path must be within the basedir (and optionally within the subdirectory within basedir given by the $folder parameter
@@ -94,10 +97,10 @@
 	// PATH END
 	if(!empty($fileExt) AND substr($path,-strlen($fileExt)) != $fileExt){
-	    $secure = false;
+		$secure = false;
-    if($secure){
+	if($secure){
 		return $path;
 	} else {
 		throw new Exception("This path is not allowed! '$path'");
@@ -108,11 +111,11 @@
  *	@security_patch Helper
 function security_patch_log($file,$line) {
-    $h = fopen(dirname(__FILE__)."/../log/security_patch.log","a+");
-    if($h) {
+	$h = fopen(dirname(__FILE__)."/../log/security_patch.log","a+");
+	if($h) {
 		fwrite($h,date("Y.m.d H:i")." FILE : ".$file." | LINE : ".$line." | POST : ".implode(",",array_keys($_POST))." | GET : ".implode(",",array_keys($_GET))." | FILE : ".implode(",",array_keys($_FILE))." |\n");
 		fclose($h);
@@ -120,19 +123,19 @@
 // http://roshanbh.com.np/2007/12/getting-real-ip-address-in-php.html
 function getRealIpAddr() {
-    if (!empty($_SERVER['HTTP_CLIENT_IP']))   //check ip from share internet
-      $ip=$_SERVER['HTTP_CLIENT_IP'];
-    elseif (!empty($_SERVER['HTTP_X_FORWARDED_FOR']))   //to check ip is pass from proxy
-      $ip=$_SERVER['HTTP_X_FORWARDED_FOR'];
-    else
-      $ip=$_SERVER['REMOTE_ADDR'];
-    return $ip;
+	if (!empty($_SERVER['HTTP_CLIENT_IP']))   //check ip from share internet
+		$ip=$_SERVER['HTTP_CLIENT_IP'];
+	elseif (!empty($_SERVER['HTTP_X_FORWARDED_FOR']))   //to check ip is pass from proxy
+		$ip=$_SERVER['HTTP_X_FORWARDED_FOR'];
+	else
+		$ip=$_SERVER['REMOTE_ADDR'];
+	return $ip;
More information about the Mapbender_commits mailing list
