[Mapbender-commits] r7291 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Dec 12 07:24:49 EST 2010
Author: christoph
Date: 2010-12-12 04:24:49 -0800 (Sun, 12 Dec 2010)
New Revision: 7291
Removed:
   trunk/mapbender/http/php/nestedSets.php
http://www.mapbender.org/Talk:Import_request_variables
Deleted: trunk/mapbender/http/php/nestedSets.php
--- trunk/mapbender/http/php/nestedSets.php	2010-12-12 12:23:34 UTC (rev 7290)
+++ trunk/mapbender/http/php/nestedSets.php	2010-12-12 12:24:49 UTC (rev 7291)
@@ -1,413 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
- * @security_patch irv open
-security_patch_log(__FILE__,__LINE__);
-import_request_variables("PG");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>nestedSets</title>
-<?php
-include '../include/dyn_css.php';
-<style type="text/css">
-	input{
-		width: 164px;
-	body{
-		font-family : Arial, Helvetica, sans-serif;
-		font-size: 12px;
-</style>
-</head>
-<!-- <link rel='stylesheet' type='text/css' href='administration.css'> -->
-<script type="text/javascript">
-function validate(value){
-	var permission = true;
-	if(value == 'insert'){
-		if(document.forms[0].title.value == ''){alert("Bitte geben Sie einen Titel an."); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("Wählen Sie eine Position."); permission = false; return;}
-      	if(document.forms[0].title.value == ''){alert("<?php echo _mb("Please insert a title.") ?>"); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("Please choose a position."); permission = false; return;}
-      if(document.forms[0].wmsList.selectedIndex > 0 && document.forms[0].layer.selectedIndex == 0){alert("Wählen Sie einen Layer."); permission = false; return;}
-		if(permission == true){document.forms[0].action.value = "insert"; document.forms[0].submit();}
-	if(value == 'delete'){
-		//permission = confirm("Soll das Objekt mit Inhalten gelöscht werden?");
-		permission = confirm("Do you want to delete the object and the content of the object?");
-		document.forms[0].action.value = "delete";
-		document.forms[0].submit();
-	if(value == 'update'){
-		if(document.forms[0].left.value == ''){alert("Bitte wählen Sie eine Position."); permission = false; return;}
-		if(document.forms[0].title.value == ''){alert("Please fill in a labeling."); permission = false; return;}
-		if(permission == true){document.forms[0].action.value = "update"; document.forms[0].submit();}
-	if(value == 'add'){
-		if(document.forms[0].guiList.selectedIndex == 0){alert("Bitte wählen Sie eine GUI."); permission = false; return;}
-		if(document.forms[0].wmsList.selectedIndex == 0){alert("Bitte wählen Sie einen WMS."); permission = false; return;}
-		if(document.forms[0].layer.selectedIndex == 0){alert("Bitte wählen Sie eine Ebene."); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("Please fill in a position."); permission = false; return;}
-		if(document.forms[0].guiList.selectedIndex == 0){alert("Please choose a GUI."); permission = false; return;}
-		if(document.forms[0].wmsList.selectedIndex == 0){alert("Please choose a WMS."); permission = false; return;}
-		if(document.forms[0].layer.selectedIndex == 0){alert("Please choose a layer."); permission = false; return;}
-		if(permission == true){document.forms[0].action.value = "add"; document.forms[0].submit();}
-function rmWMS(obj){
-	if(obj.value == ''){
-		document.forms[0].wmsList.selectedIndex = 0;
-</script>
-<body >
-<?php
-if(isset($action)){
-   if($layer == 'Ordner'){$layer = "";}
-if(isset($action) && $action == "insert"){
-	$temp = explode("###", $layer);
-	$sql = "SELECT rgt FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
-	$v = array($left, $guiList);
-	$t = array("i", "s");
-	$res = db_prep_query($sql, $v, $t);
-	if($pos == 'in'){$left = $left + 1;}
-	else if($pos == 'hinter'){$left = db_result($res,0,"rgt") + 1;}
-	else{ $left = $left + 2;}
-	$sql = "UPDATE gui_treegde SET rgt=rgt+2 WHERE rgt >= $1 AND fkey_gui_id = $2";
-	db_prep_query($sql, $v, $t);
-#echo $sql . " 1: ".$left." 2:".$guiList."<br>";
-	$sql = "UPDATE gui_treegde SET lft=lft+2 WHERE lft >= $1 AND fkey_gui_id = $2";
-	$sql = "INSERT INTO gui_treegde(fkey_gui_id, fkey_layer_id, lft,rgt, ";
-	$sql .= "my_layer_title, layer, wms_id) VALUES($1, $2, $3, $4, $5, $6, $7)";
-#echo $sql . "<br>";
-	$v = array($guiList, $temp[0], $left, ($left+1), $name, $temp[1], $wmsList);
-	$t = array("s", "s", "i", "i", "s", "s", "s");
-	if($layer == ""){
-		$left = $left + 1;
-		$sql = "UPDATE gui_treegde SET rgt=rgt+2 WHERE rgt >=". $left." AND fkey_gui_id = '".$guiList."'";
-		db_query($sql);
-		$sql = "UPDATE gui_treegde SET lft=lft+2 WHERE lft >=".$left." AND fkey_gui_id = '".$guiList."'";
-		db_query($sql);
-		#hier ist noch was falsch
-		$sql = "INSERT INTO gui_treegde(fkey_gui_id,my_layer_title,lft,rgt,layer) VALUES('".$guiList."','new',".$left.",".($left+1).",'new')";
-		#echo $sql . "<br />";
-		db_query($sql);
-if(isset($action) && $action == "delete"){
-	if($left){
-		$right = db_result($res,0,"rgt");
-		$sql = "DELETE FROM gui_treegde WHERE lft BETWEEN $1 and $2 AND fkey_gui_id = $3";
-		$v = array($left, $right, $guiList);
-		$t = array("i", "i", "s");
-		$sql = "UPDATE gui_treegde SET lft=lft-$1 WHERE lft > $2 AND fkey_gui_id = $3";
-		$v = array($right-$left+1, $right, $guiList);
-#echo $sql . " r:".$right." l:".$left." 2:".$guiList."<br>";
-		$sql = "UPDATE gui_treegde SET rgt=rgt-$1 WHERE rgt > $2 AND fkey_gui_id = $3";
-if(isset($action) && $action == "update"){
-	$sql = "UPDATE gui_treegde SET ";
-	$sql .= "my_layer_title = $1, ";
-	$sql .= "fkey_layer_id = $2, ";
-	$sql .= "layer = $3, ";
-	$sql .= "wms_id = $4";
-	$sql .= " WHERE lft = $5 AND fkey_gui_id = $6";
-	$v = array($name, $temp[0], $temp[1], $wmsList, $left, $guiList);
-	$t = array("s", "s", "s", "s", "i", "s");
-if(isset($action) && $action == "add"){
-	$sql_val = "SELECT * FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
-	$res_val = db_prep_query($sql_val, $v, $t);
-	$sql .= "fkey_layer_id = $1, layer = $2, wms_id =  $3 ";
-	$sql .= "WHERE lft = $4 AND fkey_gui_id = $5";
-	$v = array();
-	$t = array("s", "s", "s", "i", "s");
-	if (db_result($res_val, 0, "fkey_layer_id") != '') {
-		array_push($v, db_result($res_val, 0, "fkey_layer_id") . "," . $temp[0]);
-	else {
-		array_push($v, $temp[0]);
-	if (db_result($res_val, 0, "layer") != '') {
-		array_push($v, db_result($res_val, 0, "layer") . "," . $temp[1]);
-	else {
-		array_push($v, $temp[1]);
-	if (db_result($res_val, 0, "wms_id") != '') {
-		array_push($v, db_result($res_val, 0, "wms_id") . "," . $wmsList);
-	else {
-		array_push($v, $wmsList);
-	array_push($v, $left);
-	array_push($v, $guiList);
-<br />
-<b>Create your own tree for your GUI. Include the element treeconfGDE to see this tree</b><br />
-Find detailed infos in the (<a href='http://www.mapbender.org/index.php/ConfTreeGde' target='_blank'>Mapbender Wiki</a>)<br />
-1. Select the GUI you want to create the new tree for <br />
-2. Select an element in the folder view<br />
-<br />
-<br />
-<?php
-if(isset($guiList) && $guiList != ""){
-	echo "<iframe ID='foldertree' name='foldertree' height='400' width='300' src='mod_treefolderAdmin.php?guiList=".urlencode($guiList)."' scrolling='auto' frameborder='1'></iframe>";
-else{
-	echo "<iframe ID='foldertree' name='foldertree' height='400' width='300' src='../html/mod_blank.html' scrolling='auto' frameborder='1'></iframe>";
-<div style='position:absolute;top:50px;left:350px'>
-<form action='<?php $self; ?>' method='POST'>
-<br><br>
-<table >
-<tr><td></td><td></td></tr>
-<?php
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$admin = new administration();
-$ownguis = $admin->getGuisByOwner(Mapbender::session()->get("mb_user_id"),true);
-$sql = "SELECT * FROM gui WHERE gui_id IN (";
-$v = $ownguis;
-$t = array();
-for ($i = 1; $i <= count($ownguis); $i++){
-	if ($i > 1) {
-		$sql .= ",";
-	$sql .= "$" . $i;
-	array_push($t, "s");
-$sql .= ") ORDER BY gui_name";
-$res = db_prep_query($sql, $v, $t);
-$cnt = 0;
-echo "<select class='guiList' size='10' name='guiList' class='guiList'  onchange='document.forms[0].submit()'>";
-echo "<option value=''>GUI ...</option>";
-while($row = db_fetch_array($res)){
-	echo "<option value='".$row["gui_id"]."' ";
-	if(isset($guiList) && $guiList == $row["gui_id"]){
-		echo "selected";
-	echo ">".$row["gui_name"]."</option>";
-	$cnt++;
-echo "</select><br>";
-echo "<tr>";
-   #echo "<td>Beschriftung:</td>";
-   echo "<td>Labeling:</td>";
-   echo "<td><input type='text' size='16' name='name' value='";
-   echo htmlentities($name, ENT_QUOTES);
-   echo "'></td>";
-echo "</tr>";
-<tr>
-<td>WMS: </td>
-<td>
-	<select name='wmsList' onchange='document.forms[0].submit()'>
-	<option value=''>WMS ...</option>
-	<?php
-	if(isset($guiList) && $guiList != ""){
-		$sql = "SELECT gui_wms.fkey_wms_id, wms.wms_title FROM gui_wms ";
-		$sql .= "INNER JOIN wms ON gui_wms.fkey_wms_id = wms.wms_id  ";
-		$sql .= "WHERE gui_wms.fkey_gui_id = $1 ";
-		$sql .= "ORDER BY wms.wms_title";
-		$v = array($guiList);
-		$t = array("s");
-		$cnt = 0;
-		while($row = db_fetch_array($res)){
-			echo "<option value='".$row["fkey_wms_id"]."' ";
-			if($wmsList == $row["fkey_wms_id"]){
-				echo "selected";
-			echo ">";
-			echo $row["wms_title"];
-			echo "</option>";
-			$cnt++;
-	else{echo "<option value=''>no gui selected</option>";}
-	echo"</select>";
-	echo"</td>   </tr><tr>";
-	#echo"<td>Ordner oder Ebene: </td>";
-	echo"<td>Folder or Layer: </td>";
-	echo"<td>";
-	echo"<select name='layer' onchange='rmWMS(this)'>";
-	#echo"<option value=''>Ordner</option>";
-	echo"<option value=''>Folder</option>";
-	if(isset($wmsList) && $wmsList != ""){
-		$sql_l = "SELECT gui_layer.fkey_layer_id, layer.layer_name, layer.layer_title FROM gui_layer ";
-		$sql_l .= "LEFT JOIN layer ON gui_layer.fkey_layer_id = layer.layer_id ";
-		$sql_l .= "WHERE gui_layer.gui_layer_wms_id = $1 AND layer.layer_parent = '0' AND gui_layer.fkey_gui_id = $2";
-		$sql_l .= " ORDER BY layer.layer_title";
-		$v = array($wmsList, $guiList);
-		$res_l = db_prep_query($sql_l, $v, $t);
-		$cnt = 0;
-		while($row = db_fetch_array($res_l)){
-			echo "<option value='".$row["fkey_layer_id"]."###".$row["layer_name"]."'>";
-			echo $row["layer_title"];
-			echo "</option>";
-			$cnt++;
-	</select>
-</td>
-</tr>
-<tr>
-   <td>Position: </td>
-   <td>
-   <select name='pos'>
-<?php
-	#echo "<option value='hinter'>hinter</option>";
-	echo "<option value='hinter'>behind</option>";
-	echo "<option value='in' ";
-	if($pos == 'in'){
-		echo "selected";
-	echo ">in</option>";
-	echo"</select>      </td>   </tr><tr>";
-	#echo"<td>Hinter bzw. in Element Nr.:</td>";
-	echo"<td>Insert behind or <br>in element with number:</td>";
-	echo "<td><input type='text' size='1' name='left' ";
-	if($left)
-		echo "value='".htmlentities($left,ENT_QUOTES)."'";
-	echo "></td>";
-</tr>
-<tr>
-	<td>
-	<!--<input class='abutton' type='button' name="insert" value='einf&uuml;gen' onclick="validate('insert')"></td>
-	<input class='abutton' type='button' name="insert" value='create new element' onclick="validate('insert')"></td>
-	<td></td>
-</tr>
-<tr>
-	<td>
-	<input class='abutton' type='button' name="delete" value='l&ouml;schen' onclick="validate('delete')"></td>
-	<input class='abutton' type='button' name="delete" value='delete element' onclick="validate('delete')"></td>
-   <td></td>
-</tr>
-<tr>
-	<td>
-	<input class='abutton' type='button' name="update" value='&amlndern' onclick="validate('update')"></td>
-	<input class='abutton' type='button' name="update" value='change element' onclick="validate('update')"></td>
-	<td></td>
-</tr>
-<tr>
-	<td>
-	<input class='abutton' type='button' name="update" value='Ebene verbinden' onclick="validate('add')"></td>
-	<input class='abutton' type='button' name="update" value='join layer' onclick="validate('add')"></td>
-	<td></td>
-</tr>
-<input type='hidden' name="action">
-</table>
-</form>
-</div>
-</body>
-</html>
More information about the Mapbender_commits mailing list
