[Mapbender-commits] r7308 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Dec 14 06:34:46 EST 2010
Author: armin11
Date: 2010-12-14 03:34:46 -0800 (Tue, 14 Dec 2010)
New Revision: 7308
Added:
   trunk/mapbender/http/php/mod_wmc2ol_old.php
   trunk/mapbender/http/php/mod_wmc2ol.php
new functions for the openlayers client to digitize, show georss and some more
Modified: trunk/mapbender/http/php/mod_wmc2ol.php
--- trunk/mapbender/http/php/mod_wmc2ol.php	2010-12-14 10:53:41 UTC (rev 7307)
+++ trunk/mapbender/http/php/mod_wmc2ol.php	2010-12-14 11:34:46 UTC (rev 7308)
@@ -12,15 +12,17 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#http://www.geoportal.rlp.de/mapbender/php/mod_wmc2ol.php?wmc_id=45_1291218568&withDigitize=1&xID=xCoord&yID=yCoord&LayerSwitcher=1
+#http://www.geoportal.rlp.de/mapbender/php/mod_wmc2ol.php?wmc_id=45_1291218568&GEORSS=1&LayerSwitcher=1
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 $userId = Mapbender::session()->get("mb_user_id");
 //check for parameter wmc_id
-if (!isset($_GET["wmc_id"])) {
+if(!isset($_GET["wmc_id"])){
 	echo 'Error: wmc_id not requested<br>';
-	die;
+	die();
 	//must leave script
@@ -32,37 +34,98 @@
 	$userId = PUBLIC_USER;
+if (isset($_REQUEST["wmc_id"]) & $_REQUEST["wmc_id"] != "") {
+	//validate to csv integer list
+	$testMatch = $_REQUEST["wmc_id"];
+	$pattern = '/^[0-9_]*$/';
+ 	if (!preg_match($pattern,$testMatch)){
+		echo 'wmc_id: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$wmc_id = $testMatch;
+	$testMatch = NULL;
+//dummy parameter for drawing georss points:
+$pointRadius = "10";
+$fillColor = "#666666"; //grey
+if (isset($_REQUEST["pointRadius"]) & $_REQUEST["pointRadius"] != "") {
+	$testMatch = $_REQUEST["pointRadius"];
+	$pattern = '/^[0-9]{2}|^[1-9]{1}$/';
+		echo 'pointRadius: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$pointRadius = $testMatch;
+if (isset($_REQUEST["fillColor"]) & $_REQUEST["fillColor"] != "") {
+	$testMatch = $_REQUEST["fillColor"];
+	$pattern = '/^#[0-9a-f]{3}|#[0-9a-f]{6}$/';
+		echo 'fillColor: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$fillColor = $testMatch;
+if (isset($_REQUEST["markerUrl"]) & $_REQUEST["markerUrl"] != "") {
+	$testMatch = $_REQUEST["markerUrl"];
+	$pattern = '/^[\d,]*$/';
+		echo 'markerUrl: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
 //the next functions should come from class administration, but they are not included as they are needed
 //TODO
 function getLayerPermission($wms_id, $layer_id, $user_id){
-	//$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
-	$array_guis = getGuisByPermission($user_id,true);
-	$v = array();
-	$t = array();
-	$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
-	$c = 1;
-	//generate guilist assigned to specific user
-	for($i=0; $i<count($array_guis); $i++){
-		if($i>0){ $sql .= ",";}
-		$sql .= "$".$c;
-		$c++;
-		array_push($v, $array_guis[$i]);
-		array_push($t, 's');
+		//$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
+		$array_guis = getGuisByPermission($user_id,true);
+		$v = array();
+		$t = array();
+		$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
+		$c = 1;
+		//generate guilist assigned to specific user
+		for($i=0; $i<count($array_guis); $i++){
+			if($i>0){ $sql .= ",";}
+			$sql .= "$".$c;
+			$c++;
+			array_push($v, $array_guis[$i]);
+			array_push($t, 's');
+		$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1"; //status 1 must be
+		array_push($v,$layer_id);
+		array_push($t,'i');
+		$res = db_prep_query($sql,$v,$t);
+		if($row = db_fetch_array($res)){
+			return true;
+		else{
+			return false;
-	$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1"; //status 1 must be
-	array_push($v,$layer_id);
-	array_push($t,'i');
-	$res = db_prep_query($sql,$v,$t);
-	if($row = db_fetch_array($res)){
-		return true;
-	else{
-		return false;
 function getGuisByPermission($mb_user_id,$ignoreublic){
 	$arrayGuis = array();
 	$mb_user_groups = array();
@@ -111,9 +174,8 @@
 //end of functions which m,ay be included from class_administration in next versions
 //Function to create an OpenLayers Javascript from a mapbender wmc document
-function createOlFromWMC_id($wmc_id){
+function createOlFromWMC_id($wmc_id, $pointRadius, $fillColor){
 	global $userId;
 	//Get WMC out of mb Database
 	$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_serial_id = $1";
@@ -121,10 +183,14 @@
 	$wmc = db_fetch_row($res);
 	//Read out WMC into XML object
 	$xml=simplexml_load_string($wmc[0], "SimpleXMLElement", LIBXML_NOBLANKS);
-	//generate general html data
-	$html='';
-	$html.="<html xmlns='http://www.w3.org/1999/xhtml'>\n";
-	$html.="<head>\n";
+	if ($_REQUEST['withoutBody'] == '1') {
+	} else {
+		//generate general html data
+		$html='';
+		$html.="<html xmlns='http://www.w3.org/1999/xhtml'>\n";
+		$html.="<head>\n";
 	//define global variables for extent out of WMC File
 	$windowWidth=$xml->General->Window->attributes()->width;
 	$windowHeight=$xml->General->Window->attributes()->height;
@@ -147,19 +213,45 @@
 	        $html.="color: #444;\n";
 	        $html.="}\n";
 	$html.="</style>\n";
-	//Generate Title
-	$html.="<title>".$xml->General->Title."</title>\n";
-	//include OL libs from local source - must be minimized
-	$html.="<script src='../extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
+	//don't show any html, title and/or body tag when integrate it into external website
+	} else {
+		//Generate Title
+		$html.="<title>".$xml->General->Title."</title>\n";
+	//include OL libs from local source - must be minimized, for new functions use the newest openlayers lib - directly from ol site
+	$e = new mb_exception('georss request : '.$_REQUEST['GEORSS']);
+	if(isset($_REQUEST["withDigitize"]) or isset($_REQUEST["GEORSS"])){
+		if(($_REQUEST["withDigitize"]=='1') or ($_REQUEST["GEORSS"]!='')){
+			$html.="<script src='http://".$_SERVER['HTTP_HOST']."/mapbender/extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
+			#$html.="<script src='../../openlayers/OpenLayers.js'></script>\n";
+	} else {
+		//use the minimized version
+		//$html.="<script src='../../openlayers/build/geoportal_ol_geoportal.js'></script>\n";
+		$html.="<script src='http://".$_SERVER['HTTP_HOST']."/mapbender/extensions/OpenLayers-2.8/OpenLayers.js'></script>\n"; //TODO minimize this or use other lib
+	//begin part for javascript code
 	$html.="<script type='text/javascript'>\n";
 	//check for queryable layers
 	$layer_array_queryable=array();
 	$layer_array=$xml->LayerList->Layer;
-	$html.="var map;\n";
+	if(isset($_REQUEST["withDigitize"])){
+		if($_REQUEST["withDigitize"]=='1'){
+			$html.="var map, controls, select, selectedFeature;
+;\n";
+	} else {
+		$html.="var map, vectors, controls,select, selectedFeature;
+;\n";
+	//initialize markers
+	$html.="var markers = new OpenLayers.Layer.Markers(\"Markers\", {'calculateInRange': function() { return true; }});\n";
+	//check for some queryable layer in web map context document
 	$someLayerQueryable=false;
 	for ($i=0; $i<count($layer_array); $i++) {
 		$html.="var layer".$i.";\n";
-		$mb_extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+		$mb_extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org');
 		$layer_array_queryable[$i]=$mb_extensions->querylayer;
 		if (($layer_array_queryable[$i]=='1') and ($xml->LayerList->Layer[$i]->attributes()->hidden=='0')){
 			$someLayerQueryable=true;
@@ -176,7 +268,7 @@
 	$centraly=floor(($maxy+$miny)/2);
 	$dx=$maxx-$minx;//in meters
 	$dy=$maxy-$miny;//in meters
-	//define zoom levels
+	//define zoom levels TODO: maybe those are not needed any longer - check it and maybe forget them cause we work with wms
 	$numberZoomLevels=20;
 	//define central position in projected system
 	$html.="var lat = $centralx;\n";
@@ -185,23 +277,24 @@
 	$centralPointy=($maxy+$miny)/2;
 	//startzoom faktor - check if usefull
      	$html.="var zoom = 10;\n";
+	$html.="\n";
 	//start function for initialize client
-	$html.="function init(){\n";
-	//define ol map object
-	$html.="map = new OpenLayers.Map( 'map' );\n";
-	$html.=" var markers;\n";
+	$html.="function initGeoportal(){\n";
+	//define ol central map object
+	$html.="	map = new OpenLayers.Map('map');\n";
 	//define options for ol map object
-	$html.="var options = {\n";
-        	$html.=" projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
-		if ($xml->General->BoundingBox['SRS']=='EPSG:4326'){
-			echo 'Please choose an other coordinatereferencesystem. Converting Scales to Geographic Coordinates is not yet implemented!';
-			return;
-		$html.=" units: \"m\",\n";
-		$html.="numZoomLevels: ".$numberZoomLevels.",\n";
-		$html.="minResolution: 0.01\n";
-	$html.="};\n";
-	//New for given GET Params mb_myBBOX and mb_myBBOXEpsg******************************************
+	$html.="	var options = {\n";
+        $html.="		projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
+	if ($xml->General->BoundingBox['SRS']=='EPSG:4326'){
+		echo 'Please choose an other coordinatereferencesystem. Converting Scales to Geographic Coordinates is not yet implemented!';
+		return;
+	$html.="		units: \"m\",\n";
+	$html.="		fractionalZoom : true,\n";
+	$html.="		numZoomLevels: ".$numberZoomLevels.",\n";
+	$html.="		minResolution: 0.01\n";
+	$html.="	};\n";
+	//If GET params mb_myBBOX and mb_myBBOXEpsg are given****
 	//Before defining the bounds check if mb_myBBOX and mb_myBBOXEpsg are defined.
 	//Check for given mb_myBBOX
 	if(isset($_REQUEST["mb_myBBOX"])){
@@ -259,24 +352,22 @@
 			return;
-	//define variable bounds
-	$html.="var bounds = new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy.");\n";
-	//if some layer defined, create base layer -> first layer in wmc
+	//define the javascript variable bounds
+	$html.="	var bounds = new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy.");\n";
+	//if some layer defined, create base layer -> first layer in the wmc document
 	if (count($layer_array) != 0){
 		$i=0;
-		$html.="layer0 = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
-		$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+		$html.="	layer0 = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
+		$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org');
 		$layer_id=dom_import_simplexml($extensions->layer_id)->nodeValue;
 		$wms_id=$extensions->wms_id;
-//	?!	$has_permission=getLayerPermission($wms_id,$layer_id,2);//problem: guest user must have fix id
 		$has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id
 		//echo $layer_id."<br>";
 		if ($has_permission || $layer_id==''){
-			$html.="\"".$xml->LayerList->Layer[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href."\",\n";
-			$html.="{\n";
-			$html.="layers: \"".$xml->LayerList->Layer[$i]->Name."\",\n";
+			$html.="		\"".$xml->LayerList->Layer[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href."\",\n";
+			$html.="		{\n";
+			$html.="		layers: \"".$xml->LayerList->Layer[$i]->Name."\",\n";
 			//get FormatList and the current active format -> TODO: make a function for getting actual format for request
 			$format='png';
 			foreach ($xml->LayerList->Layer[$i]->FormatList->Format as $current_format) {
@@ -284,49 +375,50 @@
 					$format=$current_format;
-			#$format=str_replace('image/','',$format);
-			$html.="format: \"".$format."\",\n";
-			$html.="transparent: \"On\"\n";
-			$html.="},\n";
-			$html.="{\n";
-	             	$html.="maxExtent: new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy."),\n";
+			//$format=str_replace('image/jpeg','jpeg',$format);
+			$html.="		format: \"".$format."\",\n";
+			$html.="		transparent: \"On\"\n";
+			$html.="		},\n";
+			$html.="		{\n";
+	             	$html.="		maxExtent: new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy."),\n";
                         // then check map.baseLayer.resolutions[0] for
                         // a reasonable value.
-			$html.="projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
-              		$html.="units: \"m\",\n";
 			$minScale=dom_import_simplexml($extensions->gui_minscale)->nodeValue;
 			$maxScale=dom_import_simplexml($extensions->gui_maxscale)->nodeValue;
+			$maxScale=$extensions->guiScaleHint->attributes()->max;
 			if (!$maxScale){
 				$maxScale='10000000';
 			if (!$minScale){
 				$minScale='0.1';
-			$html.="minScale: ".$minScale.",\n";
-			$html.="maxScale: ".$maxScale.",\n";
-			$html.="singleTile: true\n";
-                 	//Only neccesary for working with scales.
-                	$html.="  } );\n";
-          		$html.=" map.addLayer(layer0);\n";
+			$html.="		minScale: ".$minScale.",\n";
+			$html.="		maxScale: ".$maxScale.",\n";
+			$html.="		singleTile: true\n";
+                 	//Only necessary for working with scales.
+                	$html.="	} );\n";
+          		$html.="	map.addLayer(layer0);\n";
 		} else {
-			echo "Guest don't have permission on Base-Layer or ".$layer_id." therefor OpenLayers client will not be generated!<br>";
+			echo "Guest don't have permission on Base-Layer or ".$layer_id." therefor OpenLayers client will not be generated! Check if the layer does exists any longer or if someone has removed the permission to access this service.<br>";
 	//create the overlay layers for which the user guest has permissions
 	for ($i=1; $i<count($layer_array); $i++) {
+		#$layer_id=$extensions->layer_id;
 		$has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id TODO
 		if (($xml->LayerList->Layer[$i]->attributes()->hidden=='0' && $has_permission) ||
 			($layer_id=='' && $xml->LayerList->Layer[$i]->attributes()->hidden=='0')){
-			$html.="layer".$i." = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
-			$html.="{\n";
+			$html.="	layer".$i." = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
+			$html.="		{\n";
 			//Get FormatList and the current active format
 			$format='png';
@@ -334,17 +426,18 @@
-			$html.="transparent: \"TRUE\"\n";
-			$html.="},\n";
-			$html.="{\n";
-			$html.="singleTile: true,\n";
-			//$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+			$format=str_replace('image/jpeg','jpeg',$format);
+#			$format=str_replace('image/','',$format);
+			$html.="		transparent: \"TRUE\"\n";
+			$html.="		},\n";
+			$html.="		{\n";
+			$html.="		singleTile: true,\n";
+			//$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org');
 			if (!$maxScale){
@@ -353,96 +446,259 @@
 			if (!$minScale){
 				$minScale='0.1';
-			$html.="'isBaseLayer': false\n";
-                	$html.="  } );\n";
-          		$html.=" map.addLayer(layer".$i.");\n";
+			$html.="		'isBaseLayer': false\n";
+                	$html.="	} );\n";
+			$html.="	layer".$i.".alwaysInRange = true;\n";
+          		$html.="	map.addLayer(layer".$i.");\n";
-	//do some global things
-	//vector layer for logo or link
-	//$html.="var vector = new OpenLayers.Layer.Vector('Simple Geometry',\n";
-	//$html.="{attribution:'test'});\n";
-  	//$html.="map.addLayer(vector);\n";
-   	//$html.="map.addControl(new OpenLayers.Control.Attribution({'div':OpenLayers.Util.getElement('attribution')}));\n";
-	//Check if central marker should be set and draw one
+	$html.="\n";
+	$html.="	map.addLayer(markers);\n";
+	if(isset($_REQUEST["LayerSwitcher"]) && $_REQUEST["LayerSwitcher"] == '1'){
+        	$html.="	map.addControl(new OpenLayers.Control.LayerSwitcher());\n";
 	if(isset($_REQUEST["mb_drawCentre"])&isset($centralx)&isset($centraly)){
 		if ($_REQUEST["mb_drawCentre"]='1'){
-			$html.="var markers = new OpenLayers.Layer.Markers(\"Markers\", {'calculateInRange': function() { return true; }});\n";
-			$html.="var size = new OpenLayers.Size(15,20);\n";
-			$html.="calculateOffset = function(size) {return new OpenLayers.Pixel(-(size.w/2), -size.h); };\n";
-			$html.="var icon = new OpenLayers.Icon('../extensions/OpenLayers-2.8/img/marker.png',size, null, calculateOffset);\n";
-			$html.="markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(".$centralx.",".$centraly."),icon));\n";
-			$html.="map.addLayer(markers);\n";
+			$html.="	var size = new OpenLayers.Size(15,20);\n";
+			$html.="	calculateOffset = function(size) {return new OpenLayers.Pixel(-(size.w/2), -size.h); };\n";
+			$html.="	var icon = new OpenLayers.Icon('http://".$_SERVER['HTTP_HOST']."/mapbender/img/marker/red.png',size, null, calculateOffset);\n";
+			$html.="	markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(".$centralx.",".$centraly."),icon));\n";
 		else {
-			echo "alert('The REQUEST parameter mb_drawCentre is outside of his realm!');";
+			echo "alert('The REQUEST parameter mb_drawCentre is outside of its realm!');";
  			return;
 	//Zoom to extent of given mb_myBBOX
-		$html.="var newBounds = new OpenLayers.Bounds(".$minx_new.",".$miny_new.",".$maxx_new.",".$maxy_new.");\n";
-		$html.="map.setCenter(new OpenLayers.LonLat(".$centralx.",".$centraly."),zoom);\n";
-		$html.="map.zoomToExtent(newBounds);\n";
+		$html.="	var newBounds = new OpenLayers.Bounds(".$minx_new.",".$miny_new.",".$maxx_new.",".$maxy_new.");\n";
+		$html.="	map.setCenter(new OpenLayers.LonLat(".$centralx.",".$centraly."),zoom);\n";
+		$html.="	map.zoomToExtent(newBounds);\n";
 	} else {
-		$html.="map.zoomToExtent(bounds);\n";
+		$html.="	map.zoomToExtent(bounds);\n";
 	if(isset($_REQUEST["showCoords"])){
 		if($_REQUEST["showCoords"]=='1'){
-			$html.="var mp = new OpenLayers.Control.MousePosition({'div':OpenLayers.Util.getElement('showpos'),'numDigits':2});\n";
-			$html.="mp.numDigits = 2;\n";
-			$html.="map.addControl(mp);";
+			$html.="	var mp = new OpenLayers.Control.MousePosition({'div':OpenLayers.Util.getElement('showpos'),'numDigits':2});\n";
+			$html.="	mp.numDigits = 2;\n";
+			$html.="	map.addControl(mp);";
-	//Generate the possibility to do GetFeatureInfo if this was activated in wmc
-	if ($someLayerQueryable){
-		$html.="map.events.register('click', map, function (e) {\n";
+//new part showing georss content **************
+	if(isset($_REQUEST["GEORSS"])){
+		if($_REQUEST["GEORSS"]!=''){
+			$html.="	var pointVectorLayer = new OpenLayers.Layer.Vector(\"Vector Layer\", {\n";
+                	$html.="		styleMap: new OpenLayers.StyleMap({\n";
+                	$html.="    			pointRadius: \"".$pointRadius."\", // based on feature.attributes.type\n";
+                 	$html.="   			fillColor: \"".$fillColor."\"\n";
+                	$html.="		})\n";
+			$html.="	});\n";
+			//end of definition of the point vector layer
+			//push the features to the layer
+			$html.="	map.addLayer(pointVectorLayer);\n";
+			$html.="	pointVectorLayer.addFeatures(createFeaturesFromGeoRSS());\n";
+			//define the controls for the features in the point vector layer
+			//add the vector layer to map
+			$html.="	selectControl = new OpenLayers.Control.SelectFeature(pointVectorLayer,
+                {onSelect: onFeatureSelect, onUnselect: onFeatureUnselect});\n";
+            		$html.="	map.addControl(selectControl);\n";
+           		$html.="	selectControl.activate();  \n";
+	//Generate the possibility to do ***GetFeatureInfo*** if this was activated in the originating wmc
+	if ($someLayerQueryable && $_REQUEST['withDigitize'] != '1'){
+		$html.="	map.events.register('click', map, function (e) {\n";
 		//loop for all layers
 		for ($i=0; $i<count($layer_array); $i++){
 			if ($layer_array_queryable[$i]=='1'){
-				$html.="var url".$i." =  layer".$i.".getFullRequestString({\n";
-                $html.=" REQUEST: \"GetFeatureInfo\",\n";
-                $html.=" FEATURE_COUNT: \"100\",\n";
-				$html.="EXCEPTIONS: \"application/vnd.ogc.se_xml\",\n";
-				$html.="BBOX: layer".$i.".map.getExtent().toBBOX(),\n";
-				$html.="X: e.xy.x,\n";
-				$html.="Y: e.xy.y,\n";
-				$html.="INFO_FORMAT: 'text/html',\n";
-				$html.="QUERY_LAYERS: layer".$i.".params.LAYERS,\n";
-				$html.=" WIDTH: layer".$i.".map.size.w,\n";
-				$html.="HEIGHT: layer".$i.".map.size.h});\n";
-				$html.="window.open(url".$i.",target=\"_blank\",\"width=300,height=400,left=100,top=200\");\n";
+				$html.="	var url".$i." =  layer".$i.".getFullRequestString({\n";
+                      		$html.="	 REQUEST: \"GetFeatureInfo\",\n";
+				$html.="	 FEATURE_COUNT: \"100\",\n";
+				$html.="	 EXCEPTIONS: \"application/vnd.ogc.se_xml\",\n";
+				$html.="	 BBOX: layer".$i.".map.getExtent().toBBOX(),\n";
+				$html.="	 X: e.xy.x,\n";
+				$html.="	 Y: e.xy.y,\n";
+				$html.="	 INFO_FORMAT: 'text/html',\n";
+				$html.="	 QUERY_LAYERS: layer".$i.".params.LAYERS,\n";
+				$html.="	 WIDTH: layer".$i.".map.size.w,\n";
+				$html.="	 HEIGHT: layer".$i.".map.size.h});\n";
+				$html.="	 window.open(url".$i.",target=\"_blank\",\"scrollbars=1,width=250,height=400,left=100,top=200\");\n";
-		$html.="OpenLayers.Event.stop(e);\n";
-		$html.=" });\n";
+		$html.="	OpenLayers.Event.stop(e);\n";
+		$html.="	});\n";
-	//end GetfeatureInfo
-	$html.="}\n";//End of function
+	//Define event to pull coordinates from mouseclick to some predefined element (getElementById) - it is needed for ***Digitizing Function***
+	if ($_REQUEST['withDigitize'] == '1'){
+		$html.="		var lonlat = map.getLonLatFromViewPortPx(new OpenLayers.Pixel(e.xy.x , e.xy.y) );\n";
+		//Delete all markers which are digitized before
+		$html.="		while (markers.markers.length > 0 ) {\n";
+		$html.="			markers.removeMarker(markers.markers[0]);\n";
+		$html.="		}\n";
+		$html.="		markers.addMarker(new OpenLayers.Marker(lonlat,icon));\n";
+          	$html.="		var digX = String.substr(lonlat.lon,0,10);\n";
+		$html.="		var digY = String.substr(lonlat.lat,0,10);\n";
+		if (isset($_REQUEST['xID']) && isset($_REQUEST['yID']) && $_REQUEST['xID'] != '' && $_REQUEST['yID'] != '') {
+			$html.="		document.getElementById(\"".$_REQUEST['xID']."\").value = digX;\n";
+			$html.="		document.getElementById(\"".$_REQUEST['yID']."\").value = digY;\n";
+		$html.="		markers.destroy;\n";
+		//$html.="	alert('something to show lonlat: '+lonlat);\n";
+		$html.="	});\n";
+	//end of click function for digitizing
+	$html.="}\n";//End of central function initGeoportal()
+	//functions only needed, if georss objects are given - for generating popups - after initGeoportal()!
+			$html.="function onPopupClose(evt) {\n";
+            		$html.="	selectControl.unselect(selectedFeature);\n";
+        		$html.="}\n";
+        		$html.="function onFeatureSelect(feature) {\n";
+           		$html.="	selectedFeature = feature;\n";
+           		$html.="	popup = new OpenLayers.Popup.FramedCloud(\"chicken\", \n";
+                        $html.="	feature.geometry.getBounds().getCenterLonLat(),
+                                     null,
+                                     \"<div class='georsstitle'>\" + feature.attributes['title'] +\"</div><br/>\"+\"<div class='georssdescription'>\" +feature.attributes['description']+\"</div><br/><div class='georsslink'><a href='\"+feature.attributes['link']+\"' target='_blank'>Weitere Informationen</a></div>\",
+                                     null, true, onPopupClose);\n";
+            		$html.="	feature.popup = popup;\n";
+            		$html.="	map.addPopup(popup);\n";
+        		$html.="}\n";
+        		$html.="function onFeatureUnselect(feature) {\n";
+            		$html.="	map.removePopup(feature.popup);\n";
+            		$html.="	feature.popup.destroy();\n";
+           		$html.=" 	feature.popup = null;\n";
+        		$html.="}\n";
+			$html.="function createFeaturesFromGeoRSS() {\n";
+			//First check if some georss is send in the request variable GEORSS
+			if (isset($_REQUEST['GEORSS']) && $_REQUEST['GEORSS'] != '' && $_REQUEST['GEORSS'] != '1') {
+				$georssXml = simplexml_load_string(stripslashes($_REQUEST['GEORSS']));
+				if($georssXml===FALSE) {
+					//It was not a XML string
+					$html.= "alert('The content of the request parameter GEORSS was not a valid XML String!');\n";
+					$html.="}\n";
+				} else {
+					//It was a valid XML string
+					$featureCount = 0;
+					foreach ($georssXml->entry as $item){
+						$featureCount++;
+					#$featureCountPlus = $featureCount+1;
+					$html.="	var pointFeatures = new Array(".$featureCount.");\n";
+					//***Generate the Points from GeoRSS***
+					for ($i=0; $i<$featureCount; $i++) {
+						$georssElements = $georssXml->entry[$i]->children('http://www.georss.org/georss');
+						$gmlElements = $georssElements->children('http://www.opengis.net/gml');
+						$coords = explode(" ", $gmlElements->Point->pos);
+    						$html.="	var point = new OpenLayers.Geometry.Point(";
+						$html.="".$coords[0].",".$coords[1].");\n";
+						$html.="	pointFeatures[".$i."] = new OpenLayers.Feature.Vector(point, {title: \"".$georssXml->entry[$i]->title."\", description : \"".str_replace("\"", "'",$georssXml->entry[$i]->content)."\", link : \"".$georssXml->entry[$i]->id."\"});\n";
+					$html.="	return pointFeatures;\n";
+        				$html.="}\n";
+			} else {
+				if (file_exists('/tmp/georss_test_v1a.xml')) {
+    					$georssXml = simplexml_load_file('/tmp/georss_test_v1a.xml');
+						$featureCount++;
+					$featureCountPlus = $featureCount+1;
+					$html.="	var pointFeatures = new Array(".$featureCountPlus.");\n";
+					//***Generate Dummy Point for testing
+					$html.="	var point = new OpenLayers.Geometry.Point(2594468.92,5530693.03);\n";
+                			$html.="	pointFeatures[".$featureCount."] = new OpenLayers.Feature.Vector(point, {description : \"Testbeschreibung\", link : \"Testlink\"});\n";
+        				$html.="}\n";
+				} else {
+   					$html.="	alert('No GeoRSS found - use only dummy point!');\n";
+                			$html.="	var pointFeature = new OpenLayers.Feature.Vector(point, {description : \"Testbeschreibung\", link : \"Testlink\"});\n";
+           				$html.="	return pointFeature;\n";
+        				$html.="}\n";
+			//TODO: validate the content of the XML
+			//pull out the relevant content: name, id, description
+			//filter out javascript content!
+			//transform to specific coordinate reference system
+			//generate the single attributes for the layer presentation
+	//end of javascripting part
  	$html.="</script>\n";
- 	$html.=" </head>\n";
-  	$html.="<body onload='init()'>\n";
-   	$html.="<div id='tags'></div>\n";
+	} else {
+ 		$html.=" </head>\n";
+  		$html.="<body onload='initGeoportal()'>\n";
+    	$html.="<div id='tags'></div>\n";
    	$html.="<div id='map' class='smallmap'></div>\n";//class dont exists
-   	$html.="<div id='docs'>\n";
-  	$html.="\n";
-   	$html.="</div>\n";
+	//show textareas with coordinates which are digitized
+	if(isset($_REQUEST["withDebug"])){
+		if($_REQUEST["withDebug"]=='1'){
+			$html.="<input type=\"textarea\" name=\"xCoord\" value=\"0\" id=\"xCoord\"/>\n";
+			$html.="<input type=\"textarea\" name=\"yCoord\" value=\"0\" id=\"yCoord\"/>\n";
+	//echo "<a href = 'http://www.geoportal.rlp.de' target='_blank'> <img src = '../img/geoportal_rlp.png' title=\"GeoPortal Rheinland-Pfalz\" border=0></a>";
+    	$html.="<div id='docs'>\n";
+     	$html.="\n";
+    	$html.="</div>\n";
 	//Show coords if wished
 	if($_REQUEST["mb_showCoords"]=='1'){
-//		$html.="<div id='srs' class='csrs'>Koordinaten in <a href = '../../../mediawiki/index.php/".$xml->General->BoundingBox['SRS']."' target='_blank'>".$xml->General->BoundingBox['SRS']."</a>:</div>\n";
-		$html.="<div id='srs' class='csrs'>Koordinaten in ".$xml->General->BoundingBox['SRS'].":</div>\n";
+		//$html.="<div id='srs' class='csrs'>Koordinaten in <a href = '../../../mediawiki/index.php/".$xml->General->BoundingBox['SRS']."' target='_blank'>".$xml->General->BoundingBox['SRS']."</a>:</div>\n"; //only for geoportal.rlp
+		$html.="<div id='srs' class='csrs'>Koordinaten in ".$xml->General->BoundingBox['SRS'].":</div>\n";
 	$html.="<div id='showpos'></div>\n";
 	$html.="<div id='attribution'></div>\n";
-  	$html.="</body>\n";
-	$html.="</html>\n";
+	} else {
+  		$html.="</body>\n";
+		$html.="</html>\n";
 	//Print out HTML code
 	echo $html;
+//end of function createOlfromWMC_id()
-//end of function createOlfromWMC_id()
-createOlfromWMC_id($_GET["wmc_id"]);
\ No newline at end of file
+createOlfromWMC_id($_GET["wmc_id"], $pointRadius, $fillColor);
Copied: trunk/mapbender/http/php/mod_wmc2ol_old.php (from rev 7301, trunk/mapbender/http/php/mod_wmc2ol.php)
--- trunk/mapbender/http/php/mod_wmc2ol_old.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_wmc2ol_old.php	2010-12-14 11:34:46 UTC (rev 7308)
@@ -0,0 +1,448 @@
+<?php
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+$userId = Mapbender::session()->get("mb_user_id");
+//check for parameter wmc_id
+if (!isset($_GET["wmc_id"])) {
+	echo 'Error: wmc_id not requested<br>';
+	die;
+	//must leave script
+function _e ($str) {
+	return htmlentities($str, ENT_QUOTES, CHARSET);
+if (!$userId) {
+	$userId = PUBLIC_USER;
+//the next functions should come from class administration, but they are not included as they are needed
+//TODO
+function getLayerPermission($wms_id, $layer_id, $user_id){
+	$v = array();
+	$t = array();
+	$c = 1;
+		$sql .= "$".$c;
+		$c++;
+		return true;
+	else{
+		return false;
+function getGuisByPermission($mb_user_id,$ignoreublic){
+	$arrayGuis = array();
+	$mb_user_groups = array();
+	$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
+	$v = array($mb_user_id);
+	$t = array("i");
+	$res_groups = db_prep_query($sql_groups,$v,$t);
+	$cnt_groups = 0;
+	while($row = db_fetch_array($res_groups)){
+		$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
+		$cnt_groups++;
+	if($cnt_groups > 0){
+		$v = array();
+		$t = array();
+		$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
+		$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
+		for($i=0; $i<count($mb_user_groups);$i++){
+			if($i > 0){$sql_g .= ",";}
+			$sql_g .= "$".strval($i+1);
+			array_push($v,$mb_user_groups[$i]);
+			array_push($t,"i");
+		$sql_g .= ") GROUP BY gui.gui_id";
+		$res_g = db_prep_query($sql_g,$v,$t);
+		while($row = db_fetch_array($res_g)){
+			array_push($arrayGuis,$row["gui_id"]);
+	$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
+	$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
+	if (!isset($ignore_public) OR $ignore_public== false){
+		$sql_guis .= " AND gui.gui_public = 1 ";
+	$sql_guis .= " GROUP BY gui.gui_id";
+	$t = array("i");
+	$res_guis = db_prep_query($sql_guis,$v,$t);
+	$guis = array();
+	while($row = db_fetch_array($res_guis)){
+		if(!in_array($row['gui_id'],$arrayGuis)){
+	return $arrayGuis;
+//end of functions which m,ay be included from class_administration in next versions
+//Function to create an OpenLayers Javascript from a mapbender wmc document
+function createOlFromWMC_id($wmc_id){
+	global $userId;
+	//Get WMC out of mb Database
+	$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_serial_id = $1";
+	$res = db_prep_query($sql, array($wmc_id), array("s"));
+	$wmc = db_fetch_row($res);
+	//Read out WMC into XML object
+	$xml=simplexml_load_string($wmc[0], "SimpleXMLElement", LIBXML_NOBLANKS);
+	$html='';
+	//define global variables for extent out of WMC File
+	$windowWidth=$xml->General->Window->attributes()->width;
+	$windowHeight=$xml->General->Window->attributes()->height;
+	$htmlWidth=$windowWidth+40;
+	$htmlHeight=$windowHeight+70;
+	//define CSS
+   	$html.="<style type='text/css'>\n";
+        $html.=" #map {\n";
+        	$html.="width: ".$windowWidth."px;\n";
+        	$html.="height: ".$windowHeight."px;\n";
+        	$html.="border: 1px solid black;\n";
+		$html.="overflow:visible;\n";
+        $html.="}\n";
+	$html.=" #srs {\n";
+	        $html.="font-size: 80%;\n";
+	        $html.="color: #444;\n";
+	        $html.="}\n";
+	$html.=" #showpos {\n";
+	        $html.="}\n";
+	$html.="</style>\n";
+	//Generate Title
+	$html.="<script src='../extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
+	$html.="<script type='text/javascript'>\n";
+	//check for queryable layers
+	$layer_array_queryable=array();
+	$layer_array=$xml->LayerList->Layer;
+	$html.="var map;\n";
+	$someLayerQueryable=false;
+	for ($i=0; $i<count($layer_array); $i++) {
+		$html.="var layer".$i.";\n";
+		$mb_extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+		$layer_array_queryable[$i]=$mb_extensions->querylayer;
+		if (($layer_array_queryable[$i]=='1') and ($xml->LayerList->Layer[$i]->attributes()->hidden=='0')){
+			$someLayerQueryable=true;
+	//define special BBOX
+	$out_box=0.3;
+	//get min/max extents for olbox
+	$minx = $xml->General->BoundingBox->attributes()->minx;
+	$miny = $xml->General->BoundingBox['miny'];
+	$maxx = $xml->General->BoundingBox['maxx'];
+	$maxy = $xml->General->BoundingBox['maxy'];
+	$centralx=floor(($maxx+$minx)/2);
+	$centraly=floor(($maxy+$miny)/2);
+	$dx=$maxx-$minx;//in meters
+	$dy=$maxy-$miny;//in meters
+	$numberZoomLevels=20;
+	//define central position in projected system
+	$html.="var lat = $centralx;\n";
+       	$html.="var lon = $centraly;\n";
+	$centralPointx=($maxx+$minx)/2;
+	$centralPointy=($maxy+$miny)/2;
+	//startzoom faktor - check if usefull
+     	$html.="var zoom = 10;\n";
+	//start function for initialize client
+	$html.="function init(){\n";
+	//define ol map object
+	$html.="map = new OpenLayers.Map( 'map' );\n";
+	$html.=" var markers;\n";
+	//define options for ol map object
+	$html.="var options = {\n";
+			return;
+		$html.="numZoomLevels: ".$numberZoomLevels.",\n";
+		$html.="minResolution: 0.01\n";
+	$html.="};\n";
+	//New for given GET Params mb_myBBOX and mb_myBBOXEpsg******************************************
+	//Before defining the bounds check if mb_myBBOX and mb_myBBOXEpsg are defined.
+	//Check for given mb_myBBOX
+	if(isset($_REQUEST["mb_myBBOX"])){
+		//Check for numerical values for BBOX
+		$array_bbox=explode(',',$_REQUEST["mb_myBBOX"]);
+		if ((is_numeric($array_bbox[0])) and (is_numeric($array_bbox[1])) and (is_numeric($array_bbox[2])) and (is_numeric($array_bbox[3])) ) {
+			if(isset($_REQUEST["mb_myBBOXEpsg"])){
+				//Check epsg
+				$targetEpsg=intval($_REQUEST["mb_myBBOXEpsg"]);
+				if (($targetEpsg >= 1) and ($targetEpsg <= 50001)) {
+					#echo "is in the codespace of the epsg registry\n";
+					} else {
+					#echo "is outside\n";
+ 					echo "alert('The REQUEST parameter mb_myBBOXEpsg is not in the epsg realm - please define another EPSG Code.');";
+ 					return;
+				//Check if epsg is equal to BBOXEpsg
+				//Get epsg code out of WMC
+				$xml_epsg=str_replace('EPSG:','',$xml->General->BoundingBox['SRS']);
+				if ($_REQUEST["mb_myBBOXEpsg"]!=$xml_epsg){
+					//Transform the given BBOX to epsg of WMC
+					$sql= "select asewkt(transform(GeometryFromText ( 'LINESTRING ( ".$array_bbox[0]." ".$array_bbox[1].",".$array_bbox[2]." ".$array_bbox[3]." )', $targetEpsg ),".intval($xml_epsg)."))";
+					$e = new mb_notice("mod_wms2ol.php: sql (transform)=".$sql);
+					$res = db_query($sql);
+					//read out result
+					$text_bbox = db_fetch_row($res);
+					$e = new mb_notice("mod_wms2ol.php: text_bbox=".$text_bbox[0]);
+					$pattern = '~LINESTRING\((.*)\)~i';
+					preg_match($pattern, $text_bbox[0], $subpattern);
+					$e = new mb_notice("mod_wms2ol.php: subpattern=".$subpattern[1]);
+					//exchange blancspaces
+					$new_bbox = str_replace(" ", ",", $subpattern[1]);
+					//set new BBOX
+					$array_bbox_new=explode(',',$new_bbox);
+					$minx_new=$array_bbox_new[0];
+					$miny_new=$array_bbox_new[1];
+					$maxx_new=$array_bbox_new[2];
+					$maxy_new=$array_bbox_new[3];
+					$centralx=($maxx_new+$minx_new)/2;
+					$centraly=($maxy_new+$miny_new)/2;
+				else
+				//Set the new BBOX unaltered
+				$minx=$array_bbox[0];
+				$miny=$array_bbox[1];
+				$maxx=$array_bbox[2];
+				$maxy=$array_bbox[3];
+		else
+			echo "alert('The REQUEST parameters for mb_myBBOX are not numeric - please give numeric values!');";
+			return;
+	//define variable bounds
+	$html.="var bounds = new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy.");\n";
+	//if some layer defined, create base layer -> first layer in wmc
+	if (count($layer_array) != 0){
+		$i=0;
+		$html.="layer0 = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
+		$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+		$layer_id=dom_import_simplexml($extensions->layer_id)->nodeValue;
+		$wms_id=$extensions->wms_id;
+//	?!	$has_permission=getLayerPermission($wms_id,$layer_id,2);//problem: guest user must have fix id
+		$has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id
+		//echo $layer_id."<br>";
+		if ($has_permission || $layer_id==''){
+			$html.="\"".$xml->LayerList->Layer[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href."\",\n";
+			$html.="{\n";
+			$html.="layers: \"".$xml->LayerList->Layer[$i]->Name."\",\n";
+			//get FormatList and the current active format -> TODO: make a function for getting actual format for request
+			$format='png';
+			foreach ($xml->LayerList->Layer[$i]->FormatList->Format as $current_format) {
+				if ($current_format->attributes()->current=='1'){
+					$format=$current_format;
+			#$format=str_replace('image/','',$format);
+			$html.="format: \"".$format."\",\n";
+			$html.="transparent: \"On\"\n";
+			$html.="},\n";
+			$html.="{\n";
+	             	$html.="maxExtent: new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy."),\n";
+                        // then check map.baseLayer.resolutions[0] for
+                        // a reasonable value.
+			$html.="projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
+              		$html.="units: \"m\",\n";
+			$minScale=dom_import_simplexml($extensions->gui_minscale)->nodeValue;
+			$maxScale=dom_import_simplexml($extensions->gui_maxscale)->nodeValue;
+			if (!$maxScale){
+				$maxScale='10000000';
+			if (!$minScale){
+				$minScale='0.1';
+			$html.="minScale: ".$minScale.",\n";
+			$html.="maxScale: ".$maxScale.",\n";
+			$html.="singleTile: true\n";
+                 	//Only neccesary for working with scales.
+                	$html.="  } );\n";
+		} else {
+			echo "Guest don't have permission on Base-Layer or ".$layer_id." therefor OpenLayers client will not be generated!<br>";
+	//create the overlay layers for which the user guest has permissions
+	for ($i=1; $i<count($layer_array); $i++) {
+		$has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id TODO
+		if (($xml->LayerList->Layer[$i]->attributes()->hidden=='0' && $has_permission) ||
+			($layer_id=='' && $xml->LayerList->Layer[$i]->attributes()->hidden=='0')){
+			$html.="layer".$i." = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
+			$html.="{\n";
+			//Get FormatList and the current active format
+			$format='png';
+			$html.="transparent: \"TRUE\"\n";
+			$html.="},\n";
+			$html.="{\n";
+			$html.="singleTile: true,\n";
+			//$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+			if (!$maxScale){
+			if (!$minScale){
+				$minScale='0.1';
+			$html.="'isBaseLayer': false\n";
+                	$html.="  } );\n";
+	//do some global things
+	//vector layer for logo or link
+	//$html.="var vector = new OpenLayers.Layer.Vector('Simple Geometry',\n";
+	//$html.="{attribution:'test'});\n";
+  	//$html.="map.addLayer(vector);\n";
+   	//$html.="map.addControl(new OpenLayers.Control.Attribution({'div':OpenLayers.Util.getElement('attribution')}));\n";
+	//Check if central marker should be set and draw one
+	if(isset($_REQUEST["mb_drawCentre"])&isset($centralx)&isset($centraly)){
+		if ($_REQUEST["mb_drawCentre"]='1'){
+			$html.="var size = new OpenLayers.Size(15,20);\n";
+			$html.="calculateOffset = function(size) {return new OpenLayers.Pixel(-(size.w/2), -size.h); };\n";
+			$html.="var icon = new OpenLayers.Icon('../extensions/OpenLayers-2.8/img/marker.png',size, null, calculateOffset);\n";
+			$html.="markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(".$centralx.",".$centraly."),icon));\n";
+			$html.="map.addLayer(markers);\n";
+		else {
+			echo "alert('The REQUEST parameter mb_drawCentre is outside of his realm!');";
+ 			return;
+	//Zoom to extent of given mb_myBBOX
+		$html.="var newBounds = new OpenLayers.Bounds(".$minx_new.",".$miny_new.",".$maxx_new.",".$maxy_new.");\n";
+		$html.="map.setCenter(new OpenLayers.LonLat(".$centralx.",".$centraly."),zoom);\n";
+		$html.="map.zoomToExtent(newBounds);\n";
+	} else {
+		$html.="map.zoomToExtent(bounds);\n";
+	if(isset($_REQUEST["showCoords"])){
+		if($_REQUEST["showCoords"]=='1'){
+			$html.="var mp = new OpenLayers.Control.MousePosition({'div':OpenLayers.Util.getElement('showpos'),'numDigits':2});\n";
+			$html.="mp.numDigits = 2;\n";
+			$html.="map.addControl(mp);";
+	//Generate the possibility to do GetFeatureInfo if this was activated in wmc
+	if ($someLayerQueryable){
+		$html.="map.events.register('click', map, function (e) {\n";
+		//loop for all layers
+		for ($i=0; $i<count($layer_array); $i++){
+			if ($layer_array_queryable[$i]=='1'){
+				$html.="var url".$i." =  layer".$i.".getFullRequestString({\n";
+				$html.="EXCEPTIONS: \"application/vnd.ogc.se_xml\",\n";
+				$html.="BBOX: layer".$i.".map.getExtent().toBBOX(),\n";
+				$html.="X: e.xy.x,\n";
+				$html.="Y: e.xy.y,\n";
+				$html.="INFO_FORMAT: 'text/html',\n";
+				$html.="QUERY_LAYERS: layer".$i.".params.LAYERS,\n";
+				$html.="HEIGHT: layer".$i.".map.size.h});\n";
+				$html.="window.open(url".$i.",target=\"_blank\",\"width=300,height=400,left=100,top=200\");\n";
+		$html.="OpenLayers.Event.stop(e);\n";
+		$html.=" });\n";
+	//end GetfeatureInfo
+	$html.="}\n";//End of function
+ 	$html.="</script>\n";
+  	$html.="<body onload='init()'>\n";
+   	$html.="<div id='map' class='smallmap'></div>\n";//class dont exists
+  	$html.="\n";
+	//Show coords if wished
+	if($_REQUEST["mb_showCoords"]=='1'){
+//		$html.="<div id='srs' class='csrs'>Koordinaten in <a href = '../../../mediawiki/index.php/".$xml->General->BoundingBox['SRS']."' target='_blank'>".$xml->General->BoundingBox['SRS']."</a>:</div>\n";
+	$html.="<div id='showpos'></div>\n";
+	$html.="<div id='attribution'></div>\n";
+	//Print out HTML code
+	echo $html;
+createOlfromWMC_id($_GET["wmc_id"]);
More information about the Mapbender_commits mailing list
