[Mapbender-commits] r7312 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Dec 15 16:17:10 EST 2010
Author: marc
Date: 2010-12-15 13:17:10 -0800 (Wed, 15 Dec 2010)
New Revision: 7312
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
deactivate expandable because this does'nt work in IE
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	2010-12-15 21:04:02 UTC (rev 7311)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql	2010-12-15 21:17:10 UTC (rev 7312)
@@ -3170,7 +3170,7 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'expandable', '1', '1 = expand the tabs to fit the document vertically, default is 0', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'expandable', '0', '1 = expand the tabs to fit the document vertically, default is 0', 'php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '4', 'define which tab should be opened when a gui is opened', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
More information about the Mapbender_commits mailing list
