[Mapbender-commits] r7318 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Dec 16 06:40:51 EST 2010
Author: armin11
Date: 2010-12-16 03:40:51 -0800 (Thu, 16 Dec 2010)
New Revision: 7318
   trunk/mapbender/http/javascripts/map.php
   trunk/mapbender/http/javascripts/mod_loadwmc.js
   trunk/mapbender/http/php/mod_wmc2ol.php
New possibility to get url of openlayers client aut ouf the load wmc table.
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php	2010-12-16 11:12:51 UTC (rev 7317)
+++ trunk/mapbender/http/javascripts/map.php	2010-12-16 11:40:51 UTC (rev 7318)
@@ -38,6 +38,12 @@
 echo "Mapbender.sessionName = '".session_name()."';\n";
 echo "var mb_session_name = Mapbender.sessionName;\n";
 echo "Mapbender.loginUrl = '".Mapbender::session()->get("mb_login")."';\n";
+if (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == "on") {
+		echo "Mapbender.baseUrl = 'https://".$_SERVER['HTTP_HOST']."';\n";
+	else {
+		echo "Mapbender.baseUrl = 'http://".$_SERVER['HTTP_HOST']."';\n";
 echo "Mapbender.userId = '".Mapbender::session()->get("mb_user_id")."';\n";
 echo "var mb_myLogin = Mapbender.loginUrl;\n";
 echo "var mb_styleID = '".md5(Mapbender::session()->get("mb_user_name"))."';\n";
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js	2010-12-16 11:12:51 UTC (rev 7317)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js	2010-12-16 11:40:51 UTC (rev 7318)
@@ -9,6 +9,7 @@
 options.publishWmc = typeof options.publishWmc === "number" ? options.publishWmc : 0;
 options.showWmc = typeof options.showWmc === "number" ? options.showWmc : 1;
 options.openLayers = typeof options.openLayers === "number" ? options.openLayers : 1;
+options.openLayersUrl = typeof options.openLayersUrl === "number" ? options.openLayersUrl : 1;
 options.deleteWmc = typeof options.deleteWmc === "number" ? options.deleteWmc : 1;
 options.uploadWmc = typeof options.uploadWmc === "number" ? options.uploadWmc : 1;
 options.listWmc = typeof options.listWmc === "number" ? options.listWmc : 1;
@@ -38,6 +39,7 @@
 	"labelDelete": "delete",
 	"labelEditWmc": "edit",
 	"labelOpenLayers": "OpenLayers",
+	"labelOpenLayersUrl": "Link",
 	"labelCurrentState": "currentState",
 	"labelDeleteWmc": "delete this WMC",
 	"confirmDelete": "Do you really want to delete WMC '%s'?",
@@ -64,6 +66,7 @@
 	var $wmcPopup = null;
 	var $wmcDisplayPopup = null;
 	var $wmcOpenLayersPopup = null;
+	var $wmcOpenLayersUrlPopup = null;
 	var wmcPopupHtml = null;
 	var wmcListTableInitialized = false;
@@ -98,6 +101,11 @@
 		title: translatedI18nObject.labelOpenLayersExport
+	var OPENLAYERSURL_WMC_OPTIONS = {
+		src: "../img/url.png",
+		title: translatedI18nObject.labelOpenLayersUrl
 	var DELETE_WMC_OPTIONS = {
 		src: "../img/button_gray/del_disabled.png",
 		title: translatedI18nObject.labelDeleteWmc,
@@ -188,7 +196,7 @@
 	this.showOpenLayers = function (id) {
 		this.hideOpenLayers();
 		var url = "../php/mod_wmc2ol.php?wmc_id=" + id + "&" + mb_session_name + "=" + mb_nr;
-		var $wmcOpenLayersPopup = $('<div class="wmcOpenLayersPopup"><iframe style="width:99%;height:99%;" src="' + url + '"></iframe></div>');
+		var $wmcOpenLayersPopup = $('<div class="wmcOpenLayersPopup"><iframe style="width:99%;height:99%;" src="' + url + '" frameborder="0"></iframe></div>');
 		$wmcOpenLayersPopup.dialog({
 			title: translatedI18nObject.labelOpenLayers,
 			bgiframe: true,
@@ -205,7 +213,28 @@
 			$('.wmcOpenLayersPopup').dialog('destroy');
+	//following is added to give a window with an interated link which can be included in external applications
+	this.showOpenLayersUrl = function (id) {
+		this.hideOpenLayersUrl();
+		var url = "/mapbender/php/mod_wmc2ol.php?wmc_id=" + id ;
+		var $wmcOpenLayersUrlPopup = $('<div><input size="35" type="text" value="' + Mapbender.baseUrl + url + '"/></div>');
+		$wmcOpenLayersUrlPopup.dialog({
+			title: translatedI18nObject.labelOpenLayersUrl,
+			bgiframe: true,
+			autoOpen: true,
+			modal: false,
+			width: 350,
+			height: 90,
+			pos: [600,40]
+	this.hideOpenLayersUrl = function () {
+		if($('.wmcOpenLayersUrlPopup').size() > 0) {
+			$('.wmcOpenLayersUrlPopup').dialog('destroy');
+	//end of the link-handle popup
 	this.refreshList = function () {
 		var req = new Mapbender.Ajax.Request({
 			url: serverSideFileName,
@@ -278,6 +307,7 @@
 				(options.publishWmc ? "<th>" + t.labelPublic + "</td>" : "") +
 				(options.showWmc ? "<th>" + t.labelShow + "</td>" : "") +
 				(options.openLayers ? "<th>" + t.labelOpenLayers + "</td>" : "") +
+				(options.openLayersUrl ? "<th>" + t.labelOpenLayersUrl + "</td>" : "") +
 				(options.editWmc ? "<th>" + t.labelEditWmc + "</td>" : "") +
 				(options.deleteWmc ? "<th>" + t.labelDelete + "</td>" : "") +
 				"</tr></thead></table>";
@@ -464,6 +494,14 @@
+	var createOpenLayersUrlWmcCell = function (wmc) {
+		return createTableCell(
+			OPENLAYERSURL_WMC_OPTIONS, function(){
+				that.showOpenLayersUrl(wmc.id);
 	var createDisplayWmcCell = function (wmc) {
@@ -575,6 +613,9 @@
 				if (options.openLayers) {
 					$tr.append(createOpenLayersWmcCell(currentWmc));
+				if (options.openLayersUrl) {
+					$tr.append(createOpenLayersUrlWmcCell(currentWmc));
 				if (options.editWmc) {
 					$tr.append(createEditWmcCell(currentWmc));
@@ -759,4 +800,4 @@
-$loadWmc.mapbender(new LoadWmcApi());
\ No newline at end of file
+$loadWmc.mapbender(new LoadWmcApi());
Modified: trunk/mapbender/http/php/mod_wmc2ol.php
--- trunk/mapbender/http/php/mod_wmc2ol.php	2010-12-16 11:12:51 UTC (rev 7317)
+++ trunk/mapbender/http/php/mod_wmc2ol.php	2010-12-16 11:40:51 UTC (rev 7318)
@@ -301,6 +301,10 @@
 		//Check for numerical values for BBOX
 		$array_bbox=explode(',',$_REQUEST["mb_myBBOX"]);
 		if ((is_numeric($array_bbox[0])) and (is_numeric($array_bbox[1])) and (is_numeric($array_bbox[2])) and (is_numeric($array_bbox[3])) ) {
+			$minx_new=$array_bbox[0];
+			$miny_new=$array_bbox[1];
+			$maxx_new=$array_bbox[2];
+			$maxy_new=$array_bbox[3];
 			if(isset($_REQUEST["mb_myBBOXEpsg"])){
 				//Check epsg
 				$targetEpsg=intval($_REQUEST["mb_myBBOXEpsg"]);
@@ -339,10 +343,10 @@
 				else
 				//Set the new BBOX unaltered
-				$minx=$array_bbox[0];
-				$miny=$array_bbox[1];
-				$maxx=$array_bbox[2];
-				$maxy=$array_bbox[3];
@@ -611,7 +615,7 @@
     						$html.="	var point = new OpenLayers.Geometry.Point(";
 						$html.="".$coords[0].",".$coords[1].");\n";
-						$html.="	pointFeatures[".$i."] = new OpenLayers.Feature.Vector(point, {title: \"".$georssXml->entry[$i]->title."\", description : \"".str_replace("\"", "'",$georssXml->entry[$i]->content)."\", link : \"".$georssXml->entry[$i]->id."\"});\n";
+						$html.="	pointFeatures[".$i."] = new OpenLayers.Feature.Vector(point, {title: \"".$georssXml->entry[$i]->title."\", description : \"".str_replace("\"", "'",$georssXml->entry[$i]->content)."\", link : \"".$georssXml->entry[$i]->link."\"});\n";
 					$html.="	return pointFeatures;\n";
         				$html.="}\n";
@@ -678,7 +682,7 @@
-	//echo "<a href = 'http://www.geoportal.rlp.de' target='_blank'> <img src = '../img/geoportal_rlp.png' title=\"GeoPortal Rheinland-Pfalz\" border=0></a>";
+	//echo "<a href = 'http://www.geoportal.rlp.de' target='_blank'> <img src = '".$_SERVER['HTTP_HOST']."/mapbender/img/geoportal_rlp.png' title=\"GeoPortal Rheinland-Pfalz\" border=0></a>";
     	$html.="<div id='docs'>\n";
      	$html.="\n";
     	$html.="</div>\n";
More information about the Mapbender_commits mailing list
