[Mapbender-commits] r7329 - in trunk/mapbender/http: classes geoportal php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 17 07:01:51 EST 2010
Author: armin11
Date: 2010-12-17 04:01:51 -0800 (Fri, 17 Dec 2010)
New Revision: 7329
Added:
   trunk/mapbender/http/geoportal/gaz.php
   trunk/mapbender/http/geoportal/gaz_geom.php
   trunk/mapbender/http/geoportal/gaz_wiki.php
   trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php
   trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php
   trunk/mapbender/http/classes/class_metadata_new.php
   trunk/mapbender/http/php/mod_callMetadata.php
Some modules from the geoportal.rlp project
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php	2010-12-17 11:28:38 UTC (rev 7328)
+++ trunk/mapbender/http/classes/class_metadata_new.php	2010-12-17 12:01:51 UTC (rev 7329)
@@ -811,6 +811,7 @@
 		$isTextSearch = "false";
 		$e = new mb_exception("Number of used searchstrings: ".count($searchStringArray));
 		//textsearch
 		if ($this->searchText != NULL) {
 			for($i=0; $i < count($searchStringArray); $i++){
 				$isTextSearch = "true";
@@ -822,7 +823,7 @@
 				$e = new mb_notice("Part of string".$i.": ".$searchStringArray[$i]);
 				$e = new mb_notice("converted: ".$this->replaceChars_all($searchStringArray[$i]));
 				$va = "%".trim(strtoupper($this->replaceChars_all($searchStringArray[$i])))."%";
-				$e = new mb_notice($this->searchResources." Searchtext in SQL: ".$va);
+				$e = new mb_exception($this->searchResources." Searchtext in SQL: ".$va);
 				array_push($v,$va);
 				array_push($t,"s");
@@ -1430,6 +1431,7 @@
 	private function generateSearchStringArray() {
 		//'wfs test array' -> ('wfs' 'test' 'array')
 		$asstr = array();
 		if ($this->searchText != "false"){
 			$asstr = split(",",$this->searchText);
 			//delete left and right whitespaces
@@ -1437,7 +1439,15 @@
 				$asstr[$i]=ltrim($asstr[$i]);
 				$asstr[$i]=rtrim($asstr[$i]);
+		} else {
+			$asstr[0]='%';
+		//check for single wildcard search
+		$e = new mb_exception('class_metadata_new: searchText: '.$this->searchText);
+		if ((count($asstr) == 1) && (($asstr[0]=='*') || ($asstr[0]==='false'))) {
+			$asstr[0]='%';
+		$e = new mb_exception('class_metadata_new: asstr[0]: '.$asstr[0]);
 		return $asstr;
Added: trunk/mapbender/http/geoportal/gaz.php
--- trunk/mapbender/http/geoportal/gaz.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/gaz.php	2010-12-17 12:01:51 UTC (rev 7329)
@@ -0,0 +1,145 @@
+<?php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#Function to wrap the search criteria from the portal search and distribute them to the different search moduls:
+#Gazetteer Modul:	gaz_geom.php
+#wiki Modul:		gaz_wiki.php
+#OpenSearch Modul:	mod_readOpenSearchResults.php
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/geoportal.conf");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once("/data/mapbender/http/classes/class_mb_exception.php");
+$n = new mb_exception("-- gaz.php was invoked--");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+$resdir = RESULT_DIR;
+//exception wrapper
+function throwE($t){
+	$e = new mb_exception("portal search: ".$t."!");
+(isset($_SERVER["argv"][1]))? ($userId = $_SERVER["argv"][1]) : (throwE('userId lacks ...'));
+(isset($_SERVER["argv"][2]))? ($searchId = $_SERVER["argv"][2]) : (throwE('searchId lacks ...'));
+(isset($_SERVER["argv"][3]))? ($searchText = $_SERVER["argv"][3]) : (throwE('searchText lacks ...'));
+(isset($_SERVER["argv"][4]))? ($searchEPSG = $_SERVER["argv"][4]) : (throwE('searchEPSG lacks ...'));
+(isset($_SERVER["argv"][5]))? ($registratingDepartments = $_SERVER["argv"][5]) : (throwE('registratingDepartments lacks ...'));
+(isset($_SERVER["argv"][6]))? ($isoCategories = $_SERVER["argv"][6]) : (throwE('isoCategories lacks ...'));
+(isset($_SERVER["argv"][7]))? ($regTimeBegin = $_SERVER["argv"][7]) : (throwE('regTimeBegin lacks ...'));
+(isset($_SERVER["argv"][8]))? ($regTimeEnd = $_SERVER["argv"][8]) : (throwE('regTimeEnd lacks ...'));
+(isset($_SERVER["argv"][9]))? ($searchBbox = $_SERVER["argv"][9]) : (throwE('searchBbox lacks ...'));
+(isset($_SERVER["argv"][10]))? ($searchTypeBbox = $_SERVER["argv"][10]) : (throwE('searchTypeBbox lacks ...'));
+(isset($_SERVER["argv"][11]))? ($searchResources = $_SERVER["argv"][11]) : (throwE('searchResources lacks ...'));
+(isset($_SERVER["argv"][12]))? ($timeBegin= $_SERVER["argv"][12]) : (throwE('timeBegin lacks ...'));
+(isset($_SERVER["argv"][13]))? ($timeEnd = $_SERVER["argv"][13]) : (throwE('timeEnd lacks ...'));
+(isset($_SERVER["argv"][14]))? ($orderBy = $_SERVER["argv"][14]) : (throwE('orderBy lacks ...'));
+//define standard searchEPSG if the client has not yet been initialized - therefor the needed EPSG is not known
+if(!isset($searchEPSG) || $searchEPSG = '' || empty($searchEPSG)){$searchEPSG = "EPSG:31466";}
+else{$searchEPSG = $_SERVER["argv"][4];}
+//if the searchText has more than one element the commas has to be exchanged by plus -> opensearch!
+$searchTextOS = str_replace(",","+",$searchText);
+if ($searchTextOS ==='false' || $searchTextOS ==='*'){
+	$searchTextOS = '1';
+$openSearchFilter = "";
+//generate portalu search filter:
+//needed filter criteria:
+//1. searchText - anyText Field
+//2. isoCategories
+//3. regTimeBegin
+//4. regTimeEnd
+//5. searchBbox
+//6. searchTypeBbox
+//7. timeBegin
+//8. timeEnd
+//9. orderBy
+//check if orderBy is set
+if (isset($regTimeBegin) & ($regTimeBegin != 'false')){
+	$openSearchFilter .= "+t1:".$regTimeBegin;
+if (isset($regTimeEnd) & ($regTimeEnd != 'false')){
+	$openSearchFilter .= "+t2:".$regTimeEnd;
+if (isset($searchBbox) & ($searchBbox != 'false')){
+	//parse bbox
+	$spatialFilterCoords = explode(',',$searchBbox);
+	//definition of the spatial filter
+	$openSearchFilter .= "+x1:".$spatialFilterCoords[0];
+	$openSearchFilter .= "+x2:".$spatialFilterCoords[2];
+        $openSearchFilter .= "+y1:".$spatialFilterCoords[1];
+        $openSearchFilter .= "+y2:".$spatialFilterCoords[3];
+if (isset($searchTypeBbox) & ($searchTypeBbox != 'false')){
+	#if ($searchTypeBbox == 'intersects') {
+	#	$openSearchFilter .= "+coord:intersect";
+	#if ($searchTypeBbox == 'outside') {
+	#	$openSearchFilter .= "+coord:include";
+	if ($searchTypeBbox == 'inside') {
+		$openSearchFilter .= "+coord:inside";
+if (isset($orderBy) & ($orderBy != 'false')){
+	if ($orderBy == 'rank') {
+		$openSearchFilter .= "+ranking:score";
+	if ($orderBy == 'date') {
+		$openSearchFilter .= "+ranking:date";
+} else {
+$searchTextOS .= $openSearchFilter;
+// check if some extended is requested - in the old version this is defined by one parameter. The new interface would not distinguish between this two kind of search cases. Every search is a also an extented search. See mod_callMetadata.php
+#Geometry search:
+$exec = "php5 /data/mapbender/http/geoportal/gaz_geom.php '".$userId."' '".$searchText."' '".$searchEPSG."' > ".$resdir."/".$searchId."_geom.xml &";
+exec($exec);
+#wiki search:
+$exec = "php5 /data/mapbender/http/geoportal/gaz_wiki.php '".$searchText."' > ".$resdir."/".$searchId."_wiki.xml &";
+exec($exec);
+#OpenSearch Search over distributed instances of Portal-U - configuration in mapbender database
+$exec = "php5 /data/mapbender/http/geoportal/mod_readOpenSearchResults.php '".$searchId."' '".$searchTextOS."' > ".$resdir."/request_".$id."_opensearch.xml &";
+//$exec = "php5 /data/mapbender/http/x_geoportal/mod_readOpenSearchResults.php '".$searchId."' '".$searchTextOS."' '+t1:2006-05-01+t2:2010-07-01' > ".$resdir."/request_".$id."_opensearch.xml &";
+exec($exec);
Added: trunk/mapbender/http/geoportal/gaz_geom.php
--- trunk/mapbender/http/geoportal/gaz_geom.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/gaz_geom.php	2010-12-17 12:01:51 UTC (rev 7329)
@@ -0,0 +1,649 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/gaz_service.php
+(isset($_SERVER["argv"][1]))? ($user_id = $_SERVER["argv"][1]) : ($e = new mb_exception("geom: user lacks!"));
+(isset($_SERVER["argv"][2]))? ($sstr = $_SERVER["argv"][2]) : ($e = new mb_exception("geom: string lacks!"));
+(isset($_SERVER["argv"][3]))? ($epsg = $_SERVER["argv"][3]) : ($e = new mb_exception("geom: epsg lacks!"));
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+$con = pg_connect("host=".GEOMDB_HOST." port=".GEOMDB_PORT." dbname=".GEOMDB_NAME." user=".GEOMDB_USER." password=".GEOMDB_PASSWORD)
+or die('Verbindungsaufbau fehlgeschlagen: ' . pg_last_error());
+function replaceChars($text){
+	$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß","tr." );
+	$repwith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss","tr");
+	if(CHARSET=="UTF-8")
+		$text = utf8_decode($text);
+	$ret = str_replace($search, $repwith, $text);
+		$ret = utf8_encode($ret);
+	return $ret;
+/******* conf ***********************************/
+$factor = 1;
+if (intval($epsg) == 4326) $factor = 0.00001;
+/******* wohnplätze *******************/
+$bufferWP = 1000*$factor;
+$arrayWP = array();
+$arrayWPKey = array();
+/******* gemeinde *********************/
+$bufferG = 100*$factor;
+$arrayG = array();
+$toleranceG = 100*$factor;
+/******* kreis *********************/
+$bufferK = 100*$factor;
+$arrayK = array();
+$toleranceK = 1000*$factor;
+/******* verbandsgemeinde *********************/
+$bufferV = 100*$factor;
+$arrayV = array();
+$toleranceV = 1000*$factor;
+/******* strasse *********************/
+$bufferSTR = 100*$factor;
+$arraySTR = array();
+$toleranceSTR = 100*$factor;
+/******* Strasse / Hsnr ****************/
+$bufferSH = 100*$factor;
+$arraySH = array();
+$toleranceSH = 1000*$factor;
+/****** Workflow *********************************/
+$astr = split(",",replaceChars($sstr));
+if(count($astr) == 1){
+	$astr[0] = trim($astr[0]);
+	$plz = getPlz($astr[0]);
+	$hsnr = getNr($astr[0]);
+	if($plz != false){
+		//checkSize($astr[0]);
+		checkWP($plz, strtoupper(getCity($astr[0])));
+		checkGfromWP();
+	else if($hsnr != false){
+	else if($hsnr == false && $plz == false){
+		checkWP(false,strtoupper($astr[0]));
+		checkG(strtoupper($astr[0]));
+		checkGfromWP();
+		checkK(strtoupper($astr[0]));
+		checkVg($astr[0]);
+else if(count($astr) == 2){
+	$astr[1] = trim($astr[1]);
+	$ckeys = array();
+	$cnames = array();
+	$cmissing = array();
+	$myplz = false;
+	$mycity = false;
+	$mystr = false;
+	$mynr = false;
+	$myzs = false;
+	$both = array();
+	// 1.
+	if(getPlz($astr[0])){
+		$myplz = getPlz($astr[0]);
+		if(getNr($astr[1])){
+			$mynr = getNr($astr[1]);
+			$myzs = getAppendix($astr[1]);
+			$mystr = getStrn($astr[1]);
+		else{
+			$mystr = trim($astr[1]);
+	else if(getNr($astr[0])){
+		$mynr = getNr($astr[0]);
+		$myzs = getAppendix($astr[0]);
+		$mystr = getStrn($astr[0]);
+		if(getPlz($astr[1])){
+			$myplz = getPlz($astr[1]);
+		else{
+			$mycity = trim($astr[1]);
+	else{
+			$mycity = getCity($astr[0]);
+		else{
+			array_push($both,$astr[0]);
+			array_push($both,$astr[1]);
+	// workflow
+	if(count($both) == 2){
+		$a = "%".strtoupper(trim($both[0]))."%";
+		$b = "%".strtoupper(trim($both[1]))."%";
+		$v = array($a, $a);
+		$t = array('s', 's');
+		$sql = "SELECT DISTINCT * FROM (SELECT DISTINCT gem_schl_neu, gemeinde AS gem FROM gis.verwaltungseinheit ";
+		$sql .= "WHERE gemeinde_upper LIKE $1";
+		$sql .= "UNION SELECT DISTINCT gem_schl_neu, gemeinde_gem_teile AS gem FROM gis.wohnplatz ";
+		$sql .= "WHERE gemeinde_gem_teile_upper LIKE $2) AS str";
+		$res = db_prep_query($sql,$v,$t);
+		while($row = db_fetch_array($res)){
+			array_push($ckeys, $row['gem_schl_neu']);
+			array_push($cnames, encode($row['gem']));
+			array_push($cmissing, $b);
+		$v = array($b, $b);
+			array_push($cmissing, $a);
+		if(count($ckeys)>0){
+			for($i=0; $i<count($ckeys); $i++){
+				$v = array($ckeys[$i], $cmissing[$i]);
+				$t = array('i', 's');
+				$sql = "SELECT DISTINCT str_name_ewois, ";
+				$sql .= "SRID(the_geom) AS srid, AsGML(the_geom) AS gml ,";
+				$sql .= "(xmin(the_geom) - ".$bufferSH.") as minx, ";
+				$sql .= "(ymin(the_geom) - ".$bufferSH.") as miny, ";
+				$sql .= "(xmax(the_geom) + ".$bufferSH.") as maxx, ";
+				$sql .= "(ymax(the_geom) + ".$bufferSH.") as maxy ";
+				$sql .= "FROM gis.strassenschluessel WHERE gem_schl = $1 ";
+				$sql .= " AND (str_name_ewois_upper LIKE $2)";
+				if (isset($epsg) && is_numeric($epsg) && intval($epsg) != 31466) {
+					$sql = str_replace("the_geom", "transform(the_geom,".$epsg.")", $sql);
+					$show = encode($row["str_name_ewois"])."  ".$cnames[$i];
+					stack_it($arraySTR,"str",$show,"str",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
+	else{
+//	echo $myplz ."#";
+//	echo $mycity ."#";
+//	echo $mystr ."#";
+//	echo $mynr ."#";
+//	echo $myzs ."#";
+//	print_r($both);
+		checkSH($mystr,$mynr,$myzs,$myplz,$mycity);
+//$fillSH = checkSH("Akazienweg",30,false,56075,"Koblenz");
+xml_output();
+function checkMinLength($str) {
+	if (strlen($str) < 3) {
+		//errorOutput();
+		null_output();
+		die();
+//Strasse Hausnummer
+function checkSH($s,$h,$z,$p,$o){
+	global $bufferSH, $arraySH, $epsg;
+	if ($o && $s) {
+		$str_schl = array();
+		$str_schl_gem = array();
+		$ckeys = array();
+		$a = "%".strtoupper(trim($o))."%";
+			array_push($cnames, $row['gem']);
+				$v = array($ckeys[$i], "%". strtoupper(trim($s)). "%");
+				$sql = "SELECT DISTINCT str_schl_alt ";
+				$sql .= " AND str_name_ewois_upper ILIKE $2";
+					array_push($str_schl, $row['str_schl_alt']);
+					array_push($str_schl_gem, $cnames[$i]);
+			if (count($str_schl > 0)) {
+				$v = array($h);
+				$t = array('i');
+				$sql = "SELECT DISTINCT name, hausnummer, zusatz, plz, post_ortsname, ";
+				$sql .= "FROM gis.hauskoordinaten ";
+				$sql .= "WHERE hausnummer = $1 AND strschl IN (";
+				for($i=0; $i<count($str_schl); $i++){
+					if($i > 0){$sql .= ",";}
+					$sql .= "$".($i+2);
+					array_push($v,$str_schl[$i]);
+					array_push($t,'i');
+				$sql .= ")";
+#$show = $row["name"]." ".$row["hausnummer"];
+				if($row["zusatz"] != 'null'){
+				#	$show .= $row["zusatz"];
+$show = $row["name"]." ".$row["hausnummer"].$row["zusatz"];
+	else
+{$show = $row["name"]." ".$row["hausnummer"];}
+		$show .= ", " . $row["plz"]. " " . $row["post_ortsname"];
+	stack_it($arraySH,"haus",$show,"sh",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
+	else {
+		//is this 'else' obsolete?
+		$sql .= "WHERE name ILIKE $1 AND hausnummer = $2 ";
+		$v = array("%".$s."%",$h);
+		$t = array('s','i');
+		if($z){
+			$sql .= "AND zusatz = $" . (count($v)+1);
+			array_push($v,$z);
+			array_push($t,'s');
+		if($p){
+			$sql .= "AND plz = $" . (count($v)+1);
+			array_push($v,$p);
+		if($o){
+			$sql .= "AND post_ortsname ILIKE $" . (count($v)+1);
+			array_push($v,"%".$o."%");
+		#$sql .= " GROUP BY the_geom, name, hausnummer, zusatz, plz, post_ortsname";
+			$show = $row["name"]." ".$row["hausnummer"];
+			if($row["zusatz"] != null){
+				$show .= $row["zusatz"];
+	return true;
+//Wohnplatz
+function checkWP($plz,$name){
+	global $bufferWP, $arrayWP, $arrayWPKey, $epsg;
+	$v = array();
+	$t = array();
+	checkMinLength($name);
+	$sql = "SELECT DISTINCT gemeinde_gem_teile, gem_schl_neu, postleitzahl,";
+	$sql .= "(xmin(the_geom) - ".$bufferWP.") as minx, ";
+	$sql .= "(ymin(the_geom) - ".$bufferWP.") as miny, ";
+	$sql .= "(xmax(the_geom) + ".$bufferWP.") as maxx, ";
+	$sql .= "(ymax(the_geom) + ".$bufferWP.") as maxy ";
+	$sql .= "FROM gis.wohnplatz WHERE ";
+	if($plz == false){
+		$sql .= "gemeinde_gem_teile_upper ILIKE $1 ";
+		array_push($v,"%".$name."%");
+	else if($name == false){
+		$sql .= "postleitzahl = $1 ";
+		array_push($v,$plz);
+	else{
+		$sql .= "postleitzahl = $1 AND gemeinde_gem_teile_upper ILIKE $2 ";
+	$sql .= "GROUP BY the_geom, gemeinde_gem_teile, gem_schl_neu, postleitzahl";
+		$show = encode($row["gemeinde_gem_teile"]);
+		$show.= " (Wohnplatz)";
+		if(intval($row['postleitzahl'])> 1){ $show .= " (".$row['postleitzahl'].")"; }
+		stack_it($arrayWP,"wohnplatz",$show,"wp",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
+		if(!in_array($row["gem_schl_neu"],$arrayWPKey)){
+			array_push($arrayWPKey,$row["gem_schl_neu"]);
+	return true;
+function checkGfromWP(){
+	global $arrayWPKey, $bufferG, $arrayG, $toleranceG, $epsg;
+	if(count($arrayWPKey) == 0){
+		return false;
+	$v = array();
+	$t = array();
+	$sql = "SELECT DISTINCT gemeinde, ";
+	$sql .= "SRID(the_geom) AS srid, AsGML(Simplify(the_geom,$toleranceG)) AS gml ,";
+	$sql .= "(xmin(the_geom) - ".$bufferG.") as minx, ";
+	$sql .= "(ymin(the_geom) - ".$bufferG.") as miny, ";
+	$sql .= "(xmax(the_geom) + ".$bufferG.") as maxx, ";
+	$sql .= "(ymax(the_geom) + ".$bufferG.") as maxy ";
+	$sql .= "FROM gis.verwaltungseinheit WHERE gem_schl_neu IN(";
+	for($i=0; $i<count($arrayWPKey); $i++){
+		$sql .= "$".($i+1);
+		array_push($v,$arrayWPKey[$i]);
+	$sql .= ") GROUP BY the_geom, gemeinde";
+		stack_it($arrayG,"gemeinde",encode($row["gemeinde"]." (Wohnplatz)"),"g",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
+function checkG($str){
+	global $bufferG, $arrayG, $toleranceG, $arrayWPKey, $epsg;
+	checkMinLength($str);
+	$tmp = array();
+	$sql = "SELECT DISTINCT gemeinde, gem_schl_neu, ";
+	$sql .= "FROM gis.verwaltungseinheit WHERE gemeinde_upper ILIKE $1 ";
+	#$sql .= "GROUP BY the_geom, gemeinde, gem_schl_neu";
+	$v = array("%".$str."%");
+	$t = array('s');
+		stack_it($arrayG,"gemeinde",encode($row["gemeinde"]." (Gemeinde)"),"g",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
+		$tmp[count($tmp)] = $row["gem_schl_neu"];
+	$arrayWPKey = array_diff($arrayWPKey,$tmp);
+function checkK($str){
+	global $bufferK, $arrayK, $toleranceK, $epsg;
+	$sql = "SELECT DISTINCT kreis, ";
+	$sql .= "SRID(the_geom) AS srid, AsGML(Simplify(the_geom,".$toleranceK.")) AS gml ,";
+	$sql .= "(xmin(the_geom)-".$bufferK.") as minx, ";
+	$sql .= "(ymin(the_geom)-".$bufferK.") as miny, ";
+	$sql .= "(xmax(the_geom)+".$bufferK.") as maxx, ";
+	$sql .= "(ymax(the_geom)+".$bufferK.") as maxy ";
+	$sql .= "FROM gis.kreis_pl WHERE kreis_upper ILIKE $1 ";
+	$t = array('s');
+		stack_it($arrayK,"kreis",encode($row["kreis"]." (Landkreis)"),"k",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
+function checkVg($str){
+	global $bufferV, $arrayV, $toleranceV, $epsg;
+	$sql = "SELECT DISTINCT vg, ";
+	$sql .= "SRID(the_geom) AS srid, AsGML(Simplify(the_geom,".$toleranceV.")) AS gml ,";
+	$sql .= "(xmin(the_geom)-".$bufferV.") as minx, ";
+	$sql .= "(ymin(the_geom)-".$bufferV.") as miny, ";
+	$sql .= "(xmax(the_geom)+".$bufferV.") as maxx, ";
+	$sql .= "(ymax(the_geom)+".$bufferV.") as maxy ";
+	$sql .= "FROM gis.vg_fl WHERE vg ILIKE $1 ";
+	$t = array('s');
+		stack_it($arrayV,"verbandsgemeinde",encode($row["vg"]." (Verbandsgemeinde)"),"vg",$row["srid"],$row["minx"],$row["miny"],$row["maxx"],$row["maxy"],$row["gml"]);
+function stack_it(&$stack,$category,$showtitle,$prefix,$srid,$minx,$miny,$maxx,$maxy,$gml){
+	$doc = new DOMDocument();
+	$member = $doc->createElement("member");
+	$doc->appendChild($member);
+	$member->setAttribute('id',$prefix.count($stack));
+	$fc = $doc->createElement("FeatureCollection");
+	$member->appendChild($fc);
+	$fc->setAttribute("xmlns:gml","http://www.opengis.net/gml");
+	$bb = $doc->createElement("boundedBy");
+	$fc->appendChild($bb);
+	$box = $doc->createElement("Box");
+	$bb->appendChild($box);
+	$box->setAttribute('srsName',"EPSG:".$srid);
+	$c = $doc->createElement("coordinates");
+	$box->appendChild($c);
+	$coords = $doc->createTextNode($minx.",".$miny." ".$maxx.",".$maxy);
+	$c->appendChild($coords);
+	$fm = $doc->createElement("featureMember");
+	$fc->appendChild($fm);
+	$wp = $doc->createElement($category);
+	$fm->appendChild($wp);
+	$title = $doc->createElement("title");
+	$wp->appendChild($title);
+	$ttitle = $doc->createTextNode($showtitle);
+	$title->appendChild($ttitle);
+	$geom = $doc->createElement("the_geom");
+	$wp->appendChild($geom);
+	$myNode = @simplexml_load_string($gml);
+	$mySNode = dom_import_simplexml($myNode);
+	$domNode = $doc->importNode($mySNode, true);
+	$geom->appendChild($domNode);
+	array_push($stack,$member);
+function null_output(){
+	global $sstr, $arrayWP, $arrayG, $arrayK, $arraySH, $arraySTR, $arrayV;
+	$doc = new DOMDocument('1.0');
+	$doc->encoding = CHARSET;
+	$result = $doc->createElement("result");
+	$doc->appendChild($result);
+	$ready = $doc->createElement('ready');
+	$result->appendChild($ready);
+	$tready = $doc->createTextNode("true");
+	$ready->appendChild($tready);
+	echo $doc->saveXML();
+function xml_output(){
+	for($i=0; $i<count($arrayWP); $i++){
+		$domNode = $doc->importNode($arrayWP[$i], true);
+		$result->appendChild($domNode);
+	for($i=0; $i<count($arrayG); $i++){
+		$domNode = $doc->importNode($arrayG[$i], true);
+	for($i=0; $i<count($arrayK); $i++){
+		$domNode = $doc->importNode($arrayK[$i], true);
+	for($i=0; $i<count($arraySH); $i++){
+		$domNode = $doc->importNode($arraySH[$i], true);
+	for($i=0; $i<count($arraySTR); $i++){
+		$domNode = $doc->importNode($arraySTR[$i], true);
+	for($i=0; $i<count($arrayV); $i++){
+		$domNode = $doc->importNode($arrayV[$i], true);
+function encode($s){
+#	if(CHARSET == 'UTF-8'){
+#		$s = utf8_encode($s);
+	return $s;
+function getPlz($str){
+	$p = "/.*(\d{5}).*/";
+	$am = array();
+ 	if(preg_match($p, $str, $am)){
+ 		return $am[1];
+ 	else{
+ 		return false;
+function getCity($str){
+	$p = "/(^\d{5}){0,1}(.*)/";
+	$am = array();
+ 		return trim($am[2]);
+ 	else{
+ 		return false;
+function getNr($str){
+	$p = "/.*[^0-9](\d{1,4})[^0-9]*/";
+	$am = array();
+ 		return $am[(count($am)-1)];
+ 	else{
+ 		return false;
+function getStrn($str){
+	$p = "/^(\D+)\d/";
+	$am = array();
+ 		return trim($am[1]);
+ 	else{
+ 		return false;
+function getAppendix($str){
+	$p = "/.*\d+.*(\D{1})/";
+	$am = array();
+ 		return $am[1];
+ 	else{
+ 		return false;
+function getCKeysByName($city){
+	global $ckeys;
+	$city = "%".strtoupper(trim($city))."%";
+	$sql = "SELECT gem_schl_neu FROM gis.wohnplatz ";
+	$sql .= "WHERE gemeinde_gem_teile_upper ILIKE $1 ";
+	$v = array($city);
+	$t = array('s');
Added: trunk/mapbender/http/geoportal/gaz_wiki.php
--- trunk/mapbender/http/geoportal/gaz_wiki.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/gaz_wiki.php	2010-12-17 12:01:51 UTC (rev 7329)
@@ -0,0 +1,102 @@
+<?php
+# $Id: gaz_wiki.php 468 2006-11-15 15:54:05Z rothstein $
+# http://www.mapbender.org/index.php/gaz_wiki.php
+# Copyright (C) 2002 Melchior Moos
+//disable warnings
+ini_set('display_errors', 0);
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+//Vars
+$url = WIKI_URL;
+$term = "";
+(isset($_SERVER["argv"][1]))? ($term = $_SERVER["argv"][1]) : ($e = new mb_exception("wiki_search: searchstring lacks!"));
+if (($term === 'false') || ($term === '*')) {
+	$term = 'e'; //use wiki search wildcard
+$maxresults = WIKI_MAX_RESULTS;
+#http://www.gdi-rp-dienste3.rlp.de/mediawiki/api.php?action=query&list=allpages&apfrom=inspire&aplimit=500
+#http://www.gdi-rp-dienste3.rlp.de/mediawiki/api.php?action=query&list=search&srsearch=inspire&srwhat=text
+//get url for links
+$surl = "mediawiki/index.php/";
+//search mediawiki from localhost -> this will be much faster than over www
+$searchurl = $url;
+//$searchurl.="Special:Search?search=".urlencode($term)."&fulltext=Search&limit=".$maxresults."&offset=0";//OLD Version - now new mediwiki API is used
+$searchurl.="/api.php?action=query&list=search&srsearch=".urlencode($term)."&srwhat=text&format=xml";
+$e = new mb_notice("gaz_wiki: url to load: ".$searchurl);
+//load result by connector:
+$wikiConnectorObject = new connector($searchurl);
+$e = new mb_notice("gaz_wiki: read from connector".$wikiConnectorObject->file);
+//get results
+$wikiXmlString = $wikiConnectorObject->file;
+//load as xml object
+$wikiXmlObject = new SimpleXMLElement($wikiXmlString);
+$e = new mb_notice("gaz_wiki: xml after parsing with php simplexml: ".$wikiXmlObject->asXML());
+//get the list of results
+$lists = $wikiXmlObject->xpath('/api/query/search/p/@title');
+$e = new mb_exception("gaz_wiki: number of results: ".count($lists));
+//debug
+//while(list( , $node) = each($lists)) {
+//	$e = new mb_exception('/api/query/search/p/@title: '.$node);
+//create output xml
+$xml = new DOMDocument('1.0');
+$xml->encoding = CHARSET;
+$resultnode = $xml->createElement("result");
+$xml->appendChild($resultnode);
+if(count($lists)==0) {//no results returned
+	$ready = $xml->createElement('ready');
+	$resultnode->appendChild($ready);
+	$tready = $xml->createTextNode("true");
+	echo $xml->saveXML();
+} else {
+	//parse title matches
+	while(list( , $node) = each($lists)) {
+     		$e = new mb_exception('/api/query/search/p/@title: '.$node);
+		$link = $surl.$node;
+		$title = $node;
+		$m = $xml->createElement('member');
+		$resultnode->appendChild($m);
+		//create title
+		$ntitle = $xml->createElement('title');
+		$m->appendChild($ntitle);
+		$ttitle = $xml->createTextNode($title);
+		$ntitle->appendChild($ttitle);
+		//abstract
+		$abst = $xml->createElement('abstract');
+		$m->appendChild($abst);
+		$tabst = $xml->createTextNode("");
+		$abst->appendChild($tabst);
+		//url
+		$nurl = $xml->createElement('url');
+		$m->appendChild($nurl);
+		$turl = $xml->createTextNode($link);
+		$nurl->appendChild($turl);
Added: trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php
--- trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_readOpenSearchResults.php	2010-12-17 12:01:51 UTC (rev 7329)
@@ -0,0 +1,476 @@
+<?php
+#example for local request (aware of having configured curl or http connection in mapbender.conf):
+#http://localhost/mapbender/geoportal/mod_readOpenSearchResults.php?q=ah4
+#***things to be done first (globals, ...)
+#require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+#require_once(dirname(__FILE__)."/../../conf/geoportal.conf");
+echo $resdir;
+function logit($text){
+	 	if($h = fopen(dirname(__FILE__)."/../tmp/opensearch_log.txt","a")){
+					$content = $text .chr(13).chr(10);
+					if(!fwrite($h,$content)){
+						#exit;
+					fclose($h);
+#require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+#test if script was requested over http or from cli
+#if it came from cli, use output to tmp folder - > typo3 would find it and will show it in template, there should be an identifier from the gaz.php script which controls the different search moduls
+#if it came as http request it should generate its own html window
+#Maybe problematic: if requested from command-line, how would mapbender get the content? Should be tested.
+#check if requested as cli
+if (isset($argv[0])&isset($argv[1])){
+	echo "\nthe script was invoked from commandline\n";
+	$from_cli=true;
+	#do something with the searchstring if needed
+	#from cli no pagenumber will be given. Therefor everytime page number 1 will be requested
+	$request_p = 1;
+	$_REQUEST["q"] = $argv[2];//.$argv[3];//$searchPortaluFilter = $argv[3];
+	$cli_id = $argv[1];
+	echo "\nID: ".$argv[1]."\n";
+	echo "\nSearchstring: ".$argv[2]."\n";
+	else
+		echo "\n<br>no commandline args set!\n<br>";
+		$from_cli=false;
+#When script was not invoked from cli it should have been invoked per http - check the params
+if (!$from_cli){
+	#***Validation of GET Parameters
+	#handle errors
+	if(!isset($_REQUEST["q"]) ) {
+		echo "No search string found! Please send a query!<br>";
+		die();
+	if(!isset($_REQUEST["p"]) ) {
+		$request_p=1;
+	else
+		$request_p=$_REQUEST["p"];
+	if(!isset($_REQUEST["request_id"]) or $_REQUEST["request_id"]=='') {
+		echo "<br> request_id is not set <br>";
+		$requeststring="&request_id=from_http";
+		$cli_id="from_http";
+	else
+		echo "<br>request_id is set<br>";
+		$cli_id=$_REQUEST["request_id"];
+	echo "<br>Search string: <b>".$_REQUEST["q"]."</b> will be send<br>";
+#***get the information out of the mapbender-db
+#get urls to search interfaces (opensearch):
+$sql_os = "SELECT * from gp_opensearch ORDER BY os_id";
+#do db select
+$res_os = db_query($sql_os);
+#initialize count of search interfaces
+$cnt_os = 0;
+#initialize result array
+$os_list=array(array());
+#fill result array
+while($row_os = db_fetch_array($res_os)){
+	$os_list[$cnt_os] ['id']= $row_os["os_id"];
+	$os_list[$cnt_os] ['name']= $row_os["os_name"];
+	$os_list[$cnt_os] ['url']= $row_os["os_url"];
+	$os_list[$cnt_os] ['h']= $row_os["os_h"];
+	$os_list[$cnt_os] ['standardfilter']= $row_os["os_standard_filter"];
+	$os_list[$cnt_os] ['version']= $row_os["os_version"];
+#os_standard_filter
+	$cnt_os++;
+if (!$from_cli) {
+#give out count of interfaces to use
+	echo "\nCount of registrated OpenSearch Interfaces: ".count($os_list)."\n";
+#get command_line args
+#$cli_id="1234567-1234567-1234567-test";
+#if the request came from http and the first request came from a commandline - add a get parameter to the following requests and change set the $cli_id
+#if(!isset($_REQUEST["request_id"]) ) {
+#		$cli_id=$_REQUEST["request_id"];
+#		$requeststring="&request_id=".$cli_id;
+	#else
+	#	$requeststring="";
+#string to add to further requests:
+$requeststring="&request_id=".$cli_id;
+#***write xml with list of opensearch catalogs
+#$from_cli=true;# for testing only
+#if ($from_cli) {
+	#write out xml 'is really no xml!' with opensearch-catalogs
+if ($from_cli) {
+echo "\nFolder to write to: ".$resdir."\n";
+echo "\nFile to open: ".$resdir."/".$cli_id."_os.xml\n";
+	if($os_catalogs_file_handle = fopen($resdir."/".$cli_id."_os.xml","w")){
+		fwrite($os_catalogs_file_handle,"<interfaces>\n");
+		for ($i_c = 0; $i_c < count($os_list); $i_c++) {
+			$content = $os_list[$i_c] ['name'];
+			fwrite($os_catalogs_file_handle,"<opensearchinterface>");
+			fwrite($os_catalogs_file_handle,$content);
+			fwrite($os_catalogs_file_handle,"</opensearchinterface>\n");
+		fwrite($os_catalogs_file_handle,"</interfaces>\n");
+		fclose($os_catalogs_file_handle);
+	else
+		if ($from_cli) {
+			echo "\nCouldn't open file!\n";
+#$from_cli=false;# for testing only
+#***loop for things to do for each registrated search interface - only if the search should be done in all interfaces!
+#use only one catalogue if a further page is requested
+$start_cat=0;
+$end_cat=count($os_list);
+$cat=$_REQUEST["cat"];
+if (isset($cat)){
+$start_cat=(int)$cat;
+$end_cat=(int)$cat+1;
+for ($i_si = $start_cat; $i_si < $end_cat ; $i_si++) {
+	$openSearchUrl[$i_si]=$os_list[$i_si] ['url'];
+	$openSearchWrapperDetail="mod_readOpenSearchResultsDetail.php";
+	#define opensearch search url and opensearch detail url
+	$openSearchUrlSearch[$i_si]=$openSearchUrl[$i_si]."query?";
+	$openSearchUrlDetail[$i_si]=$openSearchUrl[$i_si]."detail?";
+	#get resultlists
+	$url=$openSearchUrlSearch[$i_si]."q=".$_REQUEST["q"].$os_list[$i_si] ['standardfilter']."&h=".$os_list[$i_si] ['h']."&p=".$request_p;
+	if (!$from_cli) {
+	echo "<br> url: ".$url."<br>";
+	else
+	#echo "url: ".$url."\n";
+	#$e = new mb_exception("metadataurl= ".$url);
+	logit("metadataurl : ".$url);
+	//$e = new mb_exception("metadataurl= ".$url);
+	#create connector object
+	$openSearchObject = new connector($url);
+	#get results
+	$openSearchResult = $openSearchObject->file;
+	#save resultset in temporary folder identified by sessionid, katalog_id and page_id! Now there would be more tmp files than before!
+	#this has to be done in order to give the information to typo3
+	#**************to be done!************************************
+	#$e = new mb_exception('external xml : '.$openSearchResult);
+	#parse result to simplexml
+	$openSearchXml=simplexml_load_string($openSearchResult);
+	#read out array with docids and plugids
+	#read out number of results - there are two ways: with namespaces and without!:
+	$n_results=$openSearchXml->channel->totalResults;
+	if ($os_list[$i_si] ['version']=='2') {
+		$opensearchElements=$openSearchXml->channel->children('http://a9.com/-/spec/opensearch/1.1/');
+		$n_results=$opensearchElements->totalResults;
+	if (!isset($n_results)) {
+		$n_results = 0;
+	//$e = new mb_exception("n_results(".$i_si.")= ".$n_results);
+	if ($from_cli) {
+		logit( "Number of Results in Catalogue ".$i_si.": ".$n_results."\n");
+	#calculate number of needed pages to show all results:
+	$number_of_pages=ceil((real)$n_results/(real)$os_list[$i_si] ['h']);
+	#do some debugging output
+	#var_dump($openSearchXml);
+	#show total results
+#do a html output for showing results of the different opensearch catalogues
+if (!$from_cli) {
+	echo "<b>".$n_results."</b> Ergebnisse in Katalog <b>".$os_list[$i_si] ['name']."</b><br><br>";
+	#show Pagenumbers
+	if ((int)$request_p>1) {
+	echo "<a href=\"mod_readOpenSearchResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p-1)."&cat=".$i_si.$requeststring."\"> Vorige Seite </a> ";
+	echo "Seite: <b>".$request_p."</b> von <b>".$number_of_pages."</b>";
+	if ((int)$request_p < (int)$number_of_pages) {
+	echo " <a href=\"mod_readOpenSearchResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p+1)."&cat=".$i_si.$requeststring."\"> Nächste Seite </a>";
+	echo "<br><br>";
+else
+#echo "Keine Blättermöglichkeit in CLI\n";
+$from_cli=true; //- do this everytime
+if ($from_cli) { #do these things if the request was done from the commandline - it is done by the central search function
+	#generate the output for each page! Like: xyz_os1_1_10.xml = this means: searchid_os#catalogid_#page_#totalpages.xml
+	#open the specific file for writing
+	#number of the actual catalog:
+	$catalog_number=(int)$i_si+1;
+	logit($resdir."/".$cli_id."_os".$catalog_number."_".$request_p.".xml");
+	if($os_catalogs_file_handle = fopen($resdir."/".$cli_id."_os".$catalog_number."_".$request_p.".xml","w")){
+		fwrite($os_catalogs_file_handle,"<resultlist>\n");
+		#logit("<resultlist>\n");
+		fwrite($os_catalogs_file_handle,"<querystring>".urlencode($_REQUEST["q"])."</querystring>\n");
+		#logit("<querystring>".urlencode($_REQUEST["q"])."</querystring>\n");
+		fwrite($os_catalogs_file_handle,"<totalresults>".$n_results."</totalresults>\n");
+		#logit("<totalresults>".$n_results."</totalresults>\n");
+		fwrite($os_catalogs_file_handle,"<npages>".$number_of_pages."</npages>\n");
+		#logit("<npages>".$number_of_pages."</npages>\n");
+		fwrite($os_catalogs_file_handle,"<nresults>".(int)$os_list[$i_si] ['h']."</nresults>\n");
+		//write rssurl only, if opensearch version not equal to 1
+		if ($os_list[$i_si] ['version']=='1') {
+			fwrite($os_catalogs_file_handle,"<rssurl></rssurl>\n");
+		else
+			fwrite($os_catalogs_file_handle,"<rssurl>".urlencode($openSearchXml->channel->link)."</rssurl>\n");
+		#logit("<nresults>".(int)$os_list[$i_si] ['h']."</nresults>\n");
+		#loop for single results in first list
+		#problematic: if less than 10 results are in the list, let the loop run only nresults times
+		if ($n_results < (int)$os_list[$i_si] ['h']) {
+			$upperLimit = $n_results;
+		else
+			$upperLimit = (int)$os_list[$i_si] ['h'];
+ 		for ($i=0; $i < $upperLimit; $i++) {
+			#filter nur dann, wenn docid und plugid gesetzt! Nur notwendig, wenn alle abgefragt werden!
+			#TODO: Get $plugid, $docid, $docuuid, $wms_url, $bbox out of result!!!
+			#if ($os_list[$i_si] ['version']=='2') {
+			#	$opensearchElements=$openSearchXml->channel->children('http://a9.com/-/spec/opensearch/1.1/');
+			unset($wms_url);
+			$link = $openSearchXml->channel->item[$i]->link;
+				$plugid = $openSearchXml->channel->item[$i]->plugid;
+				$docid = $openSearchXml->channel->item[$i]->docid;
+				#$link = urlencode($link);
+				if (isset($openSearchXml->channel->item[$i]->{'wms-url'})) {
+					$wms_url = $openSearchXml->channel->item[$i]->{'wms-url'};
+					#adopt wms url to 1.3.0 - REQUEST has no VERSION set - set this to 1.1.1
+					$wms_url = correctWmsUrl($wms_url);
+					$wms_url = urlencode($wms_url);
+				$source = $openSearchXml->channel->item[$i]->source;
+			else {
+				$ingridElements=$openSearchXml->channel->item[$i]->children('http://www.portalu.de/opensearch/extension/1.0');
+				$link = urlencode($link);
+				$plugid = $ingridElements->plugid;
+				$source = $ingridElements->source;
+				$docid = $ingridElements->docid;
+				if (isset($ingridElements->{'wms-url'})) {
+					$wms_url = $ingridElements->{'wms-url'};
+				$georssElements=$openSearchXml->channel->item[$i]->children('http://www.georss.org/georss');
+				if (isset($georssElements->{'box'})) {
+					$bbox = $ingridElements->{'box'};
+				else
+					$bbox = null;
+				$docuuid = $ingridElements->docuuid;
+			if (isset($plugid)&isset($docid)){
+				#Do result XML output to file
+				fwrite($os_catalogs_file_handle,"<result>\n");
+				#Tags for catalogtitle and link to detailed information
+				fwrite($os_catalogs_file_handle,"<catalogtitle>");
+				fwrite($os_catalogs_file_handle,$source." (ID=".$docid.")");
+				fwrite($os_catalogs_file_handle,"</catalogtitle>\n");
+				fwrite($os_catalogs_file_handle,"<catalogtitlelink>");
+				fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=html"));
+				fwrite($os_catalogs_file_handle,"</catalogtitlelink>\n");
+				#Tags for objecttitle and abstract
+				fwrite($os_catalogs_file_handle,"<title>");
+				fwrite($os_catalogs_file_handle,$openSearchXml->channel->item[$i]->title);
+				fwrite($os_catalogs_file_handle,"</title>\n");
+				fwrite($os_catalogs_file_handle,"<abstract>");
+				fwrite($os_catalogs_file_handle,substr($openSearchXml->channel->item[$i]->description,0,250)."...");
+				fwrite($os_catalogs_file_handle,"</abstract>\n");
+				#Tag for link to original metadata view
+				fwrite($os_catalogs_file_handle,"<urlmdorig>");
+					fwrite($os_catalogs_file_handle,urlencode($link));
+				else
+					fwrite($os_catalogs_file_handle,$link);
+				#fwrite($os_catalogs_file_handle,$link);
+				fwrite($os_catalogs_file_handle,"</urlmdorig>\n");
+				#if a wms resource is found, the url will be in the list
+				if (isset($wms_url)){
+					fwrite($os_catalogs_file_handle,"<wmscapurl>");
+					fwrite($os_catalogs_file_handle,$wms_url);
+					fwrite($os_catalogs_file_handle,"</wmscapurl>\n");
+					fwrite($os_catalogs_file_handle,"<mbaddurl>");
+					fwrite($os_catalogs_file_handle,"testurl");
+					fwrite($os_catalogs_file_handle,"</mbaddurl>\n");
+				else #add empty tags
+					fwrite($os_catalogs_file_handle,"<wmscapurl></wmscapurl>\n<mbaddurl></mbaddurl>\n");
+				if (isset($bbox)){
+					fwrite($os_catalogs_file_handle,"<georssurl>");
+					$urlToId = $openSearchUrlSearch[$i_si]."q=t01_object.obj_id:".$docuuid.$os_list[$i_si] ['standardfilter']."&h=".$os_list[$i_si] ['h']."&p=".$request_p;
+					fwrite($os_catalogs_file_handle,urlencode($urlToId));
+					fwrite($os_catalogs_file_handle,"</georssurl>\n");
+				else
+				#fwrite($os_catalogs_file_handle,"");
+				fwrite($os_catalogs_file_handle,"<iso19139url>");
+				fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=iso19139"));
+				fwrite($os_catalogs_file_handle,"</iso19139url>\n");
+				fwrite($os_catalogs_file_handle,"<inspireurl>");
+				fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=inspire"));
+				fwrite($os_catalogs_file_handle,"</inspireurl>\n");
+				#end of resultlist
+				fwrite($os_catalogs_file_handle,"</result>\n");
+	fwrite($os_catalogs_file_handle,"</resultlist>\n");
+	#logit("</resultlist>\n");
+#$from_cli=false;
+#do html version
+if (!$from_cli) {
+	for ($i=0; $i < (int)$os_list[$i_si] ['h']; $i++) {
+			echo("<a href=\"".$openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=html\" target=\"_blank\" onclick='window.open(this.href,\"Details\",\"width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes\"); return false'><b> ".$openSearchXml->channel->item[$i]->title."</b></a>");
+			echo("<a href=\"\"><img border=\"0\" alt=\"In Karte übernehmen\" src=\"img/map.png\"></a><br>");
+			else
+			echo "<br>";
+			echo("<b><i>".$source." (ID=".$docid.")</b></i><br>");
+			echo("<i>".substr($openSearchXml->channel->item[$i]->description,0,250)." ...</i><br>");
+			echo("<a href=\"".$link."\">Originäre Metadaten<a><br>");
+				echo(" <a href=\"".urldecode($wms_url)."\">WMS GetCapabilities<a><br>");
+			echo("");
+			echo("<b>Alternative Formate:</b><br><a href=\"".$openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=iso19139\" onclick='window.open(this.href,\"Details ISO19139\",\"width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes\"); return false' target=\"_blank\"><img border=\"0\" src=\"img/iso19139.png\" alt=\"ISO19139\"></a><a href=\"".$openSearchWrapperDetail."?osid=".$os_list[$i_si] ['id']."&plugid=".$plugid."&docid=".$docid."&mdtype=inspire\" onclick='window.open(this.href,\"Details INSPIRE\",\"width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes\"); return false' target=\"_blank\"><img border=\"0\" alt=\"INSPIRE\" src=\"img/inspire_tr_36.png\"></a><br><br>");
+			#wenn AUSGABE IN DATEI ERWUENSCHT
+			#logit($openSearchResult);
+			#logit("test");
+function correctWmsUrl($wms_url) {
+	$findme1   = "VERSION=";
+	$findme2 = "version=";
+	$pos1 = strpos($wms_url, $findme1);
+	$pos2 = strpos($wms_url, $findme2);
+	if ($pos1 === false && $pos2 === false) {
+		$wms_url .= "&amp;VERSION=1.1.1";
+	//exchange &? with & and &amp;
+	$wms_url = str_replace('&?', '&', $wms_url);
+	$wms_url = str_replace('&amp;?', '&', $wms_url);
+	$wms_url = str_replace('&amp;', '&', $wms_url);
+return $wms_url;
Added: trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php
--- trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_readOpenSearchResultsDetail.php	2010-12-17 12:01:51 UTC (rev 7329)
@@ -0,0 +1,1279 @@
+<?php
+#session_start();
+#http://localhost/mapbender/geoportal/mod_readOpenSearchResultsDetail.php?osid=1&...
+#function logit($text){
+	 	#if($h = fopen("/home/armin/Desktop/opensearch_log.txt","a")){
+				#	$content = $text .chr(13).chr(10);
+				#	if(!fwrite($h,$content)){
+				#		#exit;
+				#	fclose($h);
+function display_text($string) {
+    $string = eregi_replace("[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]", "<a href=\"\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@([0-9a-z](-?[0-9a-z])*\.)+[a-z]{2}([zmuvtg]|fo|me)?$", "<a href=\"mailto:\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("\n", "<br>", $string);
+    return $string;
+	$md_ident=array(
+		array(	ibus => "object_node.fk_obj_uuid",
+			iso19139 => "MD_Metadata.parentIdentifier",
+			iso19139explode => "false" ,
+			inspire => "",
+			inspiremandatory => "false",
+			iso_name => "",
+			html => "Identifikator des übergeordneten Objektes",
+			gdescription => ""),
+		array(	ibus => "t01_object",
+			iso19139 => "MD_Metadata.fileIdentifier",
+			inspire => "",
+			iso_name => "",
+			html => "Objectidentifikator",
+		array(	ibus => "t01_object.obj_name",
+			iso19139 => "MD_Metadata.identificationInfo?",
+			inspire => "",
+			iso_name => "",
+			html => "Objektname",
+		array(	ibus => "t01_object.obj_class",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "ID der Objektklasse",
+			gdescription => "Relevant sind 1 und 3"),
+		array(	ibus => "t01_object.info_note",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.purpose",
+			inspire => "",
+			iso_name => "",
+			html => "Herstellungszweck",
+			gdescription => "Zusatzinformation"),
+		array(	ibus => "t01_object.loc_descr",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.description",
+			inspire => "",
+			iso_name => "",
+			html => "Raumbezug:Erläuterung",
+			gdescription => "Raumbezug"),
+		array(	ibus => "t01_object.time_from",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_Extent.temporalElement.EX_TemporalExtent.....",
+			inspire => "",
+			iso_name => "",
+			html => "Zeitbezug des Dateninhalts von:",
+			gdescription => "Zeitbezug"),
+		array(	ibus => "t01_object.time_to",
+			inspire => "",
+			iso_name => "",
+			html => "Zeitbezug des Dateninhalts bis:",
+	array(	ibus => "t011_obj_literatur.base",
+			iso19139 => "MD_Metadata.identificationInfo.MD_Identification.descriptiveKeywords.MD_Keywords.keyword",
+			iso19139explode => "true" ,
+			inspire => "B 3.1 Keyword value",
+			inspiremandatory => "true",
+			iso_name => "descriptive Keywords",
+			html => "INSPIRE Thema",
+		array(	ibus => "t04_search.searchterm",
+			html => "Suchbegriffe",
+		array(	ibus => "title",
+			iso19139 => "identificationInfo[1]/*/citation/*/title",
+			inspire => "B 1.1 Resource title",
+			iso_name => "Title",
+			html => "Titel",
+		array(	ibus => "t0113_dataset_reference.reference_date",
+			iso19139 => "",
+			inspire => "B 5.2 Date of publication",
+			iso_name => "Date of publication",
+			html => "Veröffentlichungsdatum",
+		array(	ibus => "t01_object.time_status",
+			iso19139 => "",
+			inspire => "B 5.3 Date of revision",
+			iso_name => "Date of revision",
+			html => "Datum der letzten Ãœberarbeitung",
+		array(	ibus => "txx", #to find
+			iso19139 => "",
+			inspire => "B 5.4 Date of creation",
+			iso_name => "Date of creation",
+			html => "Erzeugungsdatum",
+		array(	ibus => "summary",
+			iso19139 => "identificationInfo[1]/*/abstract",
+			inspire => "B 1.2 Resource abstract",
+			iso_name => "abstract",
+			html => "Zusammenfassung",
+		array(	ibus => "t011_obj_serv.type",
+			iso19139 => "MD_Metadata.identificationInfo.SV_ServiceIdentification.serviceType",
+			inspire => "B 2.2 Spatial data service type",
+			iso_name => "ServiceType",
+			html => "Typ des Dienstes",
+		array(	ibus => "t011_obj_serv_version.version",
+			iso19139 => "MD_Metadata.identificationInfo.SV_ServiceIdentification.serviceTypeVersion",
+			inspire => "",
+			iso_name => "Service Type Version",
+			html => "Version des Dienstes",
+		array(	ibus => "x1",
+	//array(	ibus => "spatial_ref_value.x1",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.WestBoundLongitude",
+			inspire => "B 4.1 Geographic bounding box - western longitude",
+			iso_name => "WestBoundLongitude",
+			html => "Westliche Begrenzung (geographische Länge)",
+		array(	ibus => "y1",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.SouthBoundLatitude",
+			inspire => "B 4.1 Geographic bounding box - southern latitude",
+			iso_name => "SouthBoundLatitude",
+			html => "Südliche Begrenzung (geographische Breite)",
+		array(	ibus => "x2",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.EastBoundLongitude",
+			inspire => "B 4.1 Geographic bounding box - eastern longitude",
+			iso_name => "EastBoundLongitude",
+			html => "Östliche Begrenzung (geographische Länge)",
+		array(	ibus => "y2",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.extent.EX_GeographicBoundingBox.NorthBoundLatitude",
+			inspire => "B 4.1 Geographic bounding box - northern latitude",
+			iso_name => "NorthBoundLatitude",
+			html => "Nördliche Begrenzung (geographische Breite)",
+		array(	ibus => "t01_object.metadata_language",
+			iso19139 => "MD_Metadata.language",
+			inspire => "B 10.3 Metadata language",
+			iso_name => "Metadata language",
+			html => "Sprache des Metadatensatzes",
+			iso19139 => "MD_Metadata.identificationInfo.MD_Identification.citation.CI_Citation.alternateTitle",
+			inspire => "",
+			iso_name => "Dataset alternate title",
+			html => "Kurzbezeichnung",
+		array(	ibus => "t011_object_geo.special_base",
+			iso19139 => "MD_Metadata.dataQualityInfo.lineage.LI_Lineage.statement",
+			inspire => "B 6.1 Lineage",
+			iso_name => "B 1.6 Lineage",
+			html => "Informationen zum Herstellungsprozess",
+		array(	ibus => "t011_object_geo.rec_exact",
+			iso19139 => "MD_Metadata.dataQualityInfo.lineage.DQ_DataQuality.report.DQ_RelativeInternalPositionAccuracy.value",
+			inspire => "",
+			iso_name => "",
+			html => "Fachliche Grundlage",
+		array(	ibus => "t011_object_geo_scale.scale",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.spatialResolution.MD_Resolution.equivalentScale.MD_RepresentativeFraction.denominator",
+			inspire => "B 6.2 Spatial Resolution",
+			iso_name => "",
+			html => "Erstellungsmaßstab->Maßstab",
+		array(	ibus => "t011_object_geo_scale.resolution_ground",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.spatialResolution.MD_Resolution.distance",
+			iso_name => "",
+			html => "Erstellungsmaßstab->Bodenauflösung",
+#The resolutions for services will be hold in different objects!
+		array(	ibus => "t011_object_serv_scale.scale",
+			iso_name => "",
+			gdescription => "Auflösung bei Diensten"),
+		array(	ibus => "t011_object_serv_scale.resolution_ground",
+			iso_name => "",
+		array(	ibus => "t011_obj_geo_spatial_rep",
+			iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.spatialRepresentationType.MD_SpatialRepresentationTypeCode",
+			inspire => "",
+			iso_name => "",
+			html => "Digitale Repräsentation",
+		array(	ibus => "t011_obj_geo.hierarchy_level",
+			iso19139 => "MD_Metadata.hierachyLevelName",
+			inspire => "B 1.3 Resource Type",
+			iso_name => "hierachyLevelName",
+			html => "Datensatz/Datenserie",
+		array(	ibus => "t012_obj_obj.object_from_id",
+			inspire => "",
+			iso_name => "Parent Identifier",
+			html => "Identifikator des übergeordneten Datensatzes",
+		array(	ibus => "t02_address.city",
+			iso19139 => "",
+			iso19139explode => "" ,
+			inspire => "",
+			iso_name => "",
+			html => "Stadt",
+		array(	ibus => "t02_address.institution",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Organisation",
+		array(	ibus => "t02_address.firstname",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Vorname",
+		array(	ibus => "t02_address.lastname",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Nachname",
+		array(	ibus => "t02_address.postcode",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Postleitzahl",
+		array(	ibus => "t02_address.street",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Straße",
+		array(	ibus => "t021_communication.comm_value",
+			iso19139 => "",
+			inspire => "B 10.1 Metadata point of contact email",
+			iso_name => "",
+			html => "Email - Verantwortlicher für Metadaten",
+array(	ibus => "t011_obj_literature.publisher",
+			iso19139 => "",
+			inspire => "B 10.1 Metadata Contact Organisation",
+			iso_name => "",
+			html => "Verantwortliche Organisation für Metadaten",
+          array(	ibus => "t011_obj_literature_publishing",
+			iso19139 => "",
+			inspire => "B 9.1 Responsible party organisation",
+			iso_name => "",
+			html => "Verantwortliche Organisation",
+ 	array(	ibus => "t012_obj_adr.special_name",
+			iso19139 => "",
+			inspire => "B 9.2 Responsible party role",
+			iso_name => "",
+			html => "Rolle der verantwortlichen Organisation",
+		array(	ibus => "t017_url_ref.content",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Art des Links",
+		array(	ibus => "t017_url_ref.url_link",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Link",
+		array(	ibus => "t01_object.obj_id",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "Objektidentifikator",
+		array(	ibus => "t01_object.obj_uuid",
+			iso19139 => "?",
+			inspire => "",
+			iso_name => "",
+			html => "Eindeutiger Objektidentifikator",
+			iso19139 => "",
+			inspire => "B 1.5 Unique resource identifier",
+			iso_name => "",
+			html => "Name des Objektes",
+		array(	ibus => "t01_object.mod_time",
+			iso19139 => "",
+			inspire => "B 10.2 Metadata date",
+			iso_name => "",
+			html => "Datum des Metadatensatzes",
+		array(	ibus => "t011_obj_serv_type.serv_type_key",
+			inspire => "B 2.2 Spatial Data Service Type",
+			iso_name => "",
+			html => "Version des Services",
+ 		array(	ibus => "t011_obj_serv_op_connpoint.connect_point",
+			iso19139 => "",
+			inspire => "",
+			iso_name => "",
+			html => "URL zum Online Aufruf",
+ 		array(	ibus => "t01_object.avail_access_note",
+			iso19139 => "identificationInfo[1]/*/resourceConstraints/*/accessConstraints",
+			inspire => "B 8.1 Condition applying to access and use",
+			iso_name => "",
+			html => "Zugriffsbeschränkungen",
+ 		array(	ibus => "t01_object.fees",
+			iso19139 => "identificationInfo[1]/*/resourceConstraints/*/useLimitation",
+			inspire => "B 8.2 Limitations on public access",
+			iso_name => "",
+			html => "Kosten/Gebühren",
+ 		array(	ibus => "t01_object.data_language",
+			iso19139 => "",
+			inspire => "B 1.7 Resource Language",
+			iso_name => "",
+			html => "Sprache des Datensatzes",
+		array(	ibus => "t011_obj_geo_topic_cat.topic_category",
+			iso19139 => "identificationInfo[1]/*/topicCategory",
+			inspire => "B 2.1 Topic Category",
+			iso_name => "Topic Category",
+			html => "Kategorie",
+			gdescription => "ISO Kategorie")
+		#array(	ibus => "t011_obj_geo_topic_cat.topic.topic_category",
+			#iso19139 => "MD_Metadata.identificationInfo.MD_DataIdentification.topicCategory",
+			#iso19139explode => "true" ,
+			#inspire => "",
+			#inspiremandatory => "false",
+			#iso_name => "Dataset topic category",
+			#html => "Kategorisierung",
+			#gdescription => "")
+if(!isset($_REQUEST["osid"]) )
+	echo "no opensearch id set";
+	die();
+else
+	if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') )
+		echo "opensearch interface no.: ".$_REQUEST["osid"]." will be requested<br>";
+#get url to search interface (opensearch):
+$sql_os = "SELECT * from gp_opensearch where os_id = $1";
+#do db select
+$v_os = array($_REQUEST["osid"]);
+$t_os = array('i');
+$res_os = db_prep_query($sql_os,$v_os,$t_os);
+$cnt_os = 0;
+#fill result array
+	$cnt_os++;
+#echo "\nCount of registrated OpenSearch Interfaces: ".count($os_list)."\n";
+	#define opensearch detail url
+	$openSearchUrlDetail=$os_list[0] ['url']."detail?";
+	#get resultlists
+	$url=$openSearchUrlDetail."plugid=".$_REQUEST['plugid']."&docid=".$_REQUEST['docid'];
+if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') )
+	echo "<br> REQUEST: ".$url."<br>";
+	#get results
+	$openSearchDetail = $openSearchObject->file;
+	#$openSearchXml=simplexml_load_string($openSearchDetail);
+		$openSearchDetailXML=simplexml_load_string($openSearchDetail);
+		#*****************************bbox********************************************
+		#do things for getting the bbox of the object in crs of last defined mapbender
+		#read out the epsg from session
+		#read out  the bbox if exists
+		#transform bbox from wgs84 to last epsg of mapbender
+		#extract objects to iso19139 elements
+		#count unidentified elements
+		$i=0;
+		#get list for ibus variables - cause php is row major
+		$ibus_names = array();
+		for($a = 0; $a < count($md_ident); $a++) {
+			$ibus_names[$a] = $md_ident[$a]["ibus"];
+				echo "ibus_names[".$a."]=".$md_ident[$a]["ibus"]."<br>";
+		#define array of key-value pairs
+		$detail_array=array();
+		#read key-value pairs
+		$j=0;
+		foreach ( $openSearchDetailXML->channel->item->details->detail as $detail) {
+			$detail_key=(string)$detail->{'detail-key'};		#cast explicitly to string
+			$detail_value=(string)$detail->{'detail-value'};
+			$detail_array[$detail_key] = $detail_value;
+			$detail_keys[$j]=$detail_key;
+	#	echo "Key: ".$detail->{'detail-key'}."<br>";
+	#	echo "array: ".$detail_array[$detail_key]."<br>";	#gives values
+		#check if key is in array else count failures
+				if (in_array($detail_key, $ibus_names)) {
+					echo "Key <b>".$detail_key."</b> exists in lookup table!<br>";
+					$i++;
+				$j++;
+			echo "<br>".$i." elements have been identified!<br>";
+#$test1=in_array('t04_search.searchterm', $ibus_names);
+#$test2=array_search('t04_search.searchterm', $ibus_names);
+#if ($test1){echo "found at position: ".$test2."<br>";}
+#else
+#{echo "not found<br>";}
+	var_dump($detail_keys);
+if ($_REQUEST['mdtype']=='debug'){
+		echo "DEBUG Metadatenanzeige<br>";
+		#define table
+		echo "<html><table border=\"1\"><br>";
+		echo "<tr>";
+		#loop for each detail - tag - sometimes there are other tags in there - if one detail has more than one entry! - maybe this must be interpreted but later!
+		foreach ($detail_keys as $detailkey) {
+			#echo "<td>";
+			if (in_array($detailkey, $ibus_names)==false){
+				echo  "<td >".$detailkey."</td>";
+				else {
+				echo "<td bgcolor=\"green\">".$md_ident[array_search($detailkey, $ibus_names)]['html']."(".$detailkey.")</td>";
+			#echo "</td>";
+			echo "<td>";
+			echo $detail_array[$detailkey];
+			echo "</tr>";
+		echo "</table></html>";
+if ($_REQUEST['mdtype']=='html'){
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de">
+	<head>
+		<title>GeoPortal Rheinland-Pfalz - Metadaten</title>
+		<meta name="description" content="Metadaten" xml:lang="de" />
+		<meta name="keywords" content="Metadaten" xml:lang="de" />
+		<meta http-equiv="cache-control" content="no-cache">
+		<meta http-equiv="pragma" content="no-cache">
+		<meta http-equiv="expires" content="0">
+		<meta http-equiv="content-language" content="de" />
+		<meta http-equiv="content-style-type" content="text/css" />
+<?php
+	echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+		<link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/screen.css" media="screen" />
+		<link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/print.css" media="print" />
+	</head>
+	<body id="top" class="popup">
+	<div id="header_gray">
+	<a href="javascript:window.print()">Drucken <img src="../../../portal/fileadmin/design/images/icon_print.gif" width="14" height="14" alt="" /></a>
+	<a href="javascript:window.close()">Fenster schlie&szlig;en <img src="../../../portal/fileadmin/design/images/icon_close.gif" width="14" height="14" alt="" /></a>
+	</div>
+	<div id="header_redbottom"></div>
+	<div id="header_red"></div>
+	<div class="content">
+<?php
+		echo "<h1>Detailinformationen:</h1>";
+		#define table
+		echo "<html><table class='contenttable-0-wide'>";
+		echo "<tr>";
+			if (in_array($detailkey, $ibus_names)==true){
+				echo "<td>".$md_ident[array_search($detailkey, $ibus_names)]['html']."</td>";
+				echo "<td>";
+				echo display_text($detail_array[$detailkey]);
+				echo "</td></tr>";
+if ($_REQUEST['mdtype']=='iso19139') {
+//echo '<br><b>ISO19139 output comming soon!</b><br>';
+$iso19139 = new DOMDocument('1.0');
+$iso19139->encoding = 'UTF-8';
+#$iso19139->standalone = false;
+#Creating the "MD_Metadata" node
+$MD_Metadata = $iso19139->createElementNS('http://www.isotc211.org/2005/gmd', 'gmd:MD_Metadata');
+#$MD_Metadata=$iso19139->registerNamespace('srv','http://www.iso211.org/2005/srv');
+#$wmt_ms_capabilities->setAttribute("updateSequence", $wms_row["wms_timestamp"]);
+$MD_Metadata = $iso19139->appendChild($MD_Metadata);
+$MD_Metadata->setAttribute("xmlns:srv", "http://www.isotc211.org/2005/srv");
+$MD_Metadata->setAttribute("xmlns:gml", "http://www.opengis.net/gml");
+$MD_Metadata->setAttribute("xmlns:gco", "http://www.isotc211.org/2005/gco");
+$MD_Metadata->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+$MD_Metadata->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
+$MD_Metadata->setAttribute("xsi:schemaLocation", "http://www.isotc211.org/2005/gmd ./xsd/gmd/gmd.xsd://www.isotc211.org/2005/srv ./xsd/srv/srv.xsd");
+#generate language part B 10.3 (if available)
+$language = $iso19139->createElement("gmd:language");
+$languagecode = $iso19139->createElement("gmd:LanguageCode");
+if (isset($detail_array['t01_object.metadata_language'])) {
+$languageText = $iso19139->createTextNode($detail_array['t01_object.metadata_language']);
+else {
+$languageText = $iso19139->createTextNode("not yet defined");
+$languagecode->appendChild($languageText);
+$language ->appendChild($languagecode);
+$language=$MD_Metadata->appendChild($language);
+#generate MD_Scope part B 1.3 (if available)
+$hierarchyLevel = $iso19139->createElement("gmd:hierarchyLevel");
+$scopecode = $iso19139->createElement("gmd:MD_ScopeCode");
+if (isset($detail_array['t011_obj_geo.hierarchy_level'])) {
+$scopeText = $iso19139->createTextNode($detail_array['t011_obj_geo.hierarchy_level']);
+else {
+$scopeText = $iso19139->createTextNode("not yet defined");
+$scopecode->appendChild($scopeText);
+$hierarchyLevel->appendChild($scopecode);
+$hierarchyLevel=$MD_Metadata->appendChild($hierarchyLevel);
+#Part B 10.1
+$contact=$iso19139->createElement("gmd:contact");
+$CI_ResponsibleParty=$iso19139->createElement("gmd:CI_ResponsibleParty");
+$organisationName=$iso19139->createElement("gmd:organisationName");
+$organisationName_cs=$iso19139->createElement("gco:CharacterString");
+if (isset($detail_array['t011_obj_literatur.publisher'])) {
+$organisationNameText=$iso19139->createTextNode($detail_array['t011_obj_literatur.publisher']);
+else
+$organisationNameText=$iso19139->createTextNode('not given');
+$contactInfo=$iso19139->createElement("gmd:contactInfo");
+$CI_Contact=$iso19139->createElement("gmd:CI_Contact");
+$address=$iso19139->createElement("gmd:address");
+$CI_Address=$iso19139->createElement("gmd:CI_Address");
+$electronicMailAddress=$iso19139->createElement("gmd:electronicMailAddress");
+$electronicMailAddress_cs=$iso19139->createElement("gco:CharacterString");
+if (isset($detail_array['t021_communication.comm_value'])) {
+$electronicMailAddressText=$iso19139->createTextNode($detail_array['t021_communication.comm_value']);
+else
+$electronicMailAddressText=$iso19139->createTextNode('not given');
+#create xml tree
+$organisationName_cs->appendChild($organisationNameText);
+$organisationName->appendChild($organisationName_cs);
+$CI_ResponsibleParty->appendChild($organisationName);
+$electronicMailAddress_cs->appendChild($electronicMailAddressText);
+$electronicMailAddress->appendChild($electronicMailAddress_cs);
+$CI_Address->appendChild($electronicMailAddress);
+$address->appendChild($CI_Address);
+$CI_Contact->appendChild($address);
+$contactInfo->appendChild($CI_Contact);
+$CI_ResponsibleParty->appendChild($contactInfo);
+$contact->appendChild($CI_ResponsibleParty);
+$MD_Metadata->appendChild($contact);
+#generate dateStamp part B 10.2 (if available)
+$dateStamp = $iso19139->createElement("gmd:dateStamp");
+$mddate = $iso19139->createElement("gco:Date");
+if (isset($detail_array['t01_object.mod_time'])) {
+$mddateText = $iso19139->createTextNode($detail_array['t01_object.mod_time']);
+else {
+$mddateText = $iso19139->createTextNode("not yet defined");
+$mddate->appendChild($mddateText);
+$dateStamp->appendChild($mddate);
+$dateStamp=$MD_Metadata->appendChild($dateStamp);
+#do the things for identification
+#create nodes
+$identificationInfo=$iso19139->createElement("gmd:identificationInfo");
+$MD_DataIdentification=$iso19139->createElement("gmd:MD_DataIdentification");
+#add attribut
+$MD_DataIdentification->setAttribute("id", "dataId");
+$citation=$iso19139->createElement("gmd:citation");
+$CI_Citation=$iso19139->createElement("gmd:CI_Citation");
+#create nodes for things which are defined - howto do the multiplicities? Ask Martin!
+#Create Resource title element B 1.1
+$title=$iso19139->createElement("gmd:title");
+$title_cs=$iso19139->createElement("gco:CharacterString");
+if (isset($detail_array['title'])) {
+$titleText = $iso19139->createTextNode($detail_array['title']);
+else {
+$titleText = $iso19139->createTextNode("not yet defined");
+$title_cs->appendChild($titleText);
+$title->appendChild($title_cs);
+$CI_Citation->appendChild($title);
+#Create date elements B5.2-5.4
+#Do things for B 5.2 date of publication
+if (isset($detail_array['t0113_dataset_reference.reference_date'])) {
+$date1=$iso19139->createElement("gmd:date");
+$CI_Date=$iso19139->createElement("gmd:CI_Date");
+$date2=$iso19139->createElement("gmd:date");
+$gcoDate=$iso19139->createElement("gco:Date");
+$dateType=$iso19139->createElement("gmd:dateType");
+$dateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
+$dateTypeCodeText=$iso19139->createTextNode('publication');
+$dateText= $iso19139->createTextNode($detail_array['t0113_dataset_reference.reference_date']);
+$dateTypeCode->appendChild($dateTypeCodeText);
+$dateType->appendChild($dateTypeCode);
+$gcoDate->appendChild($dateText);
+$date2->appendChild($gcoDate);
+$CI_Date->appendChild($date2);
+$CI_Date->appendChild($dateType);
+$date1->appendChild($CI_Date);
+$CI_Citation->appendChild($date1);
+#Do things for B 5.3 date of revision
+if (isset($detail_array['t01_object.time_status'])) {
+$dateTypeCodeText=$iso19139->createTextNode('revision');
+#Do things for B 5.4 date of creation
+if (isset($detail_array['txx'])) {
+$dateTypeCodeText=$iso19139->createTextNode('creation');
+#Do things for B 1.5 Resource unique identifier
+$identifier=$iso19139->createElement("gmd:identifier");
+$rs_identifier=$iso19139->createElement("gmd:RS_Identifier");
+$code=$iso19139->createElement("gmd:code");
+$code_cs=$iso19139->createElement("gco:CharacterString");
+$codeText=$iso19139->createTextNode($detail_array['t01_object.obj_id']);
+$code_cs->appendChild($codeText);
+$code->appendChild($code_cs);
+$rs_identifier->appendChild($code);
+$identifier->appendChild($rs_identifier);
+$CI_Citation->appendChild($identifier);
+#create tree
+$citation->appendChild($CI_Citation);
+$MD_DataIdentification->appendChild($citation);
+#Create part for abstract B 1.2
+$abstract=$iso19139->createElement("gmd:abstract");
+$abstract_cs=$iso19139->createElement("gco:CharacterString");
+if (isset($detail_array['summary'])) {
+$abstractText = $iso19139->createTextNode($detail_array['summary']);
+else {
+$abstractText = $iso19139->createTextNode("not yet defined");
+$abstract_cs->appendChild($abstractText);
+$abstract->appendChild($abstract_cs);
+$MD_DataIdentification->appendChild($abstract);
+#End for abstract
+#Create part for point of contact
+#Define relevant objects
+$pointOfContact=$iso19139->createElement("gmd:pointOfContact");
+$orgaName_cs=$iso19139->createElement("gco:CharacterString");
+$address_1=$iso19139->createElement("gmd:adress");
+$email_cs=$iso19139->createElement("gco:CharacterString");
+$role=$iso19139->createElement("gmd:role");
+$CI_RoleCode=$iso19139->createElement("gmd:CI_RoleCode");
+if (isset($detail_array['t011_obj_literature_publishing'])) {
+$resOrgaText = $iso19139->createTextNode($detail_array['t011_obj_literature_publishing']);
+else {
+$resOrgaText= $iso19139->createTextNode("not yet defined");
+if (isset($detail_array['tmail'])) {
+$resMailText = $iso19139->createTextNode($detail_array['tmail']);
+else {
+$resMailText = $iso19139->createTextNode("really wanted by INSPIRE?");
+if (isset($detail_array['t012_obj_adr.special_name'])) {
+$resRoleText = $iso19139->createTextNode($detail_array['t012_obj_adr.special_name']);
+else {
+$resRoleText = $iso19139->createTextNode("not yet defined");
+#put them in xml
+$orgaName_cs->appendChild($resOrgaText);
+$CI_ResponsibleParty->appendChild($orgaName_cs);
+$email_cs->appendChild($resMailText);
+$electronicMailAddress->appendChild($email_cs);
+$address_1->appendChild($CI_Address);
+$CI_Contact->appendChild($address_1);
+$CI_RoleCode->appendChild($resRoleText);
+$role->appendChild($CI_RoleCode);
+$CI_ResponsibleParty->appendChild($role);
+$pointOfContact->appendChild($CI_ResponsibleParty);
+$MD_DataIdentification->appendChild($pointOfContact);
+#Part B 3 INSPIRE Category
+#do only if INSPIRE keyword (Annex I-III) is set
+if (isset($detail_array['t011_obj_literatur.base'])) {
+$descriptiveKeywords=$iso19139->createElement("gmd:descriptiveKeywords");
+$MD_Keywords=$iso19139->createElement("gmd:MD_Keywords");
+$keyword=$iso19139->createElement("gmd:keyword");
+$keyword_cs=$iso19139->createElement("gco:CharacterString");
+$keywordText = $iso19139->createTextNode($detail_array['t011_obj_literatur.base']);
+$thesaurusName=$iso19139->createElement("gmd:thesaurusName");
+$titleText=$iso19139->createTextNode('GEMET Thesaurus version 1.0.0'); # to be adopted to get dynamically
+$date_1=$iso19139->createElement("gmd:date");
+$date_2=$iso19139->createElement("gmd:date");
+$date_date=$iso19139->createElement("gco:Date");
+$dateText=$iso19139->createTextNode('2008-12-08');
+$CI_DateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
+$CI_DateTypeCodeText=$iso19139->createTextNode('publication'); #to be adopted to get dynamically
+#write to xml tree
+$keyword_cs->appendChild($keywordText);
+$keyword->appendChild($keyword_cs);
+$MD_Keywords->appendChild($keyword);
+$CI_DateTypeCode->appendChild($CI_DateTypeCodeText);
+$dateType->appendChild($CI_DateTypeCode);
+$date_date->appendChild($dateText);
+$date_2->appendChild($date_date);
+$CI_Date->appendChild($date_2);
+$date_1->appendChild($CI_Date);
+$CI_Citation->appendChild($date_1);
+$thesaurusName->appendChild($CI_Citation);
+$MD_Keywords->appendChild($thesaurusName);
+$descriptiveKeywords->appendChild($MD_Keywords);
+$MD_DataIdentification->appendChild($descriptiveKeywords);
+#Resource Constraints B 8
+if (isset($detail_array['t01_object.avail_access_note'])){
+$resourceConstraints1=$iso19139->createElement("gmd:resourceConstraints");
+$MD_LegalConstraints1=$iso19139->createElement("gmd:MD_LegalConstraints");
+$accessConstraints=$iso19139->createElement("gmd:accessConstraints");
+$MD_RestrictionCode=$iso19139->createElement("gmd:MD_RestrictionCode");
+$MD_RestrictionCodeText=$iso19139->createTextNode($detail_array['t01_object.avail_access_note']);
+$MD_RestrictionCode->appendChild($MD_RestrictionCodeText);
+$accessConstraints->appendChild($MD_RestrictionCode);
+$MD_LegalConstraints1->appendChild($accessConstraints);
+$resourceConstraints1->appendChild($MD_LegalConstraints1);
+$MD_DataIdentification->appendChild($resourceConstraints1);
+if(isset($detail_array['t01_object.fees'])){
+$resourceConstraints2=$iso19139->createElement("gmd:resourceConstraints");
+$MD_LegalConstraints2=$iso19139->createElement("gmd:MD_LegalConstraints");
+$useLimitation=$iso19139->createElement("gmd:useLimitation");
+$useLimitation_cs=$iso19139->createElement("gco:CharacterString");
+$useLimitationText=$iso19139->createTextNode($detail_array['t01_object.fees']);
+$useLimitation_cs->appendChild($useLimitationText);
+$useLimitation->appendChild($useLimitation_cs);
+$MD_LegalConstraints2->appendChild($useLimitation);
+$resourceConstraints2->appendChild($MD_LegalConstraints2);
+$MD_DataIdentification->appendChild($resourceConstraints2);
+# Part B 1.7 Dataset Language
+if(isset($detail_array['t01_object.data_language'])){
+$language=$iso19139->createElement("gmd:language");
+$LanguageCode=$iso19139->createElement("gmd:LanguageCode");
+$LanguageCodeText=$iso19139->createTextNode($detail_array['t01_object.data_language']);
+$LanguageCode->appendChild($LanguageCodeText);
+$language->appendChild($LanguageCode);
+$MD_DataIdentification->appendChild($language);
+#Topic Category B 2.1
+if(isset($detail_array['t011_obj_geo_topic_cat.topic_category'])){
+$topicCategory=$iso19139->createElement("gmd:topicCategory");
+$MD_TopicCategoryCode=$iso19139->createElement("gmd:MD_TopicCategoryCode");
+$MD_TopicCategoryText=$iso19139->createTextNode($detail_array['t011_obj_geo_topic_cat.topic_category']);
+$MD_TopicCategoryCode->appendChild($MD_TopicCategoryText);
+$topicCategory->appendChild($MD_TopicCategoryCode);
+$MD_DataIdentification->appendChild($topicCategory);
+if(isset($detail_array['x1']) and isset($detail_array['x2']) and isset($detail_array['y1']) and isset($detail_array['y2'])){
+$extent=$iso19139->createElement("gmd:extent");
+$EX_Extent=$iso19139->createElement("gmd:EX_Extent");
+$geographicElement=$iso19139->createElement("gmd:geographicElement");
+$EX_GeographicBoundingBox=$iso19139->createElement("gmd:EX_GeographicBoundingBox");
+$westBoundLongitude=$iso19139->createElement("gmd:westBoundLongitude");
+$wb_dec=$iso19139->createElement("gco:Decimal");
+$wb_text=$iso19139->createTextNode($detail_array['x1']);
+$eastBoundLongitude=$iso19139->createElement("gmd:eastBoundLongitude");
+$eb_dec=$iso19139->createElement("gco:Decimal");
+$eb_text=$iso19139->createTextNode($detail_array['x2']);
+$southBoundLatitude=$iso19139->createElement("gmd:southBoundLatitude");
+$sb_dec=$iso19139->createElement("gco:Decimal");
+$sb_text=$iso19139->createTextNode($detail_array['y1']);
+$northBoundLatitude=$iso19139->createElement("gmd:northBoundLatitude");
+$nb_dec=$iso19139->createElement("gco:Decimal");
+$nb_text=$iso19139->createTextNode($detail_array['y2']);
+$wb_dec->appendChild($wb_text);
+$westBoundLongitude->appendChild($wb_dec);
+$EX_GeographicBoundingBox->appendChild($westBoundLongitude);
+$eb_dec->appendChild($eb_text);
+$eastBoundLongitude->appendChild($eb_dec);
+$EX_GeographicBoundingBox->appendChild($eastBoundLongitude);
+$sb_dec->appendChild($sb_text);
+$southBoundLatitude->appendChild($sb_dec);
+$EX_GeographicBoundingBox->appendChild($southBoundLatitude);
+$nb_dec->appendChild($nb_text);
+$northBoundLatitude->appendChild($nb_dec);
+$EX_GeographicBoundingBox->appendChild($northBoundLatitude);
+$geographicElement->appendChild($EX_GeographicBoundingBox);
+$EX_Extent->appendChild($geographicElement);
+$extent->appendChild($EX_Extent);
+$MD_DataIdentification->appendChild($extent);
+$identificationInfo->appendChild($MD_DataIdentification);
+$MD_Metadata->appendChild($identificationInfo);
+header("Content-type: application/xhtml+xml; charset=UTF-8");
+echo $iso19139->saveXml();
+if ($_REQUEST['mdtype']=='inspire') {
+	<head>
+<?php
+	</head>
+	</div>
+<?php
+		echo "<img border=\"0\" src=\"img/inspire_tr_100.png\" alt=\"INSPIRE Logo\"><h1>INSPIRE Metadaten:</h1>";
+		#define table
+		echo "<tr>";
+				if ($md_ident[array_search($detailkey, $ibus_names)]['inspiremandatory']=='true') {
+					echo "<td>".$md_ident[array_search($detailkey, $ibus_names)]['inspire']."</td>";
+					echo "<td>";
+echo '<br><b>INSPIRE output not completly implemented!<b><br>';
+#phpinfo();
+#$xmltest = new DOMDocument;
+#$xmltest=simplexml_load_file('/home/armin/Desktop/GDI-RP/metadaten/detail_portalu.xml');
+#$xsl = new DOMDocument;
+#var_dump($xmltest);
+//$xsl->load('simplesearch_overview.xsl');
+#$xsl=simplexml_load_file('/home/workspace/mapbender_rp/http/geoportal/opensearch2html.xsl');
+// Configure the transformer
+#var_dump($xsl);
+#$proc = new XSLTProcessor;
+#$proc->importStyleSheet($xsl); // attach the xsl rules
+#var_dump($proc);
+#$trans = $proc->transformToXML($xmltest);
+#var_dump($trans);
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2010-12-17 11:28:38 UTC (rev 7328)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2010-12-17 12:01:51 UTC (rev 7329)
@@ -20,7 +20,7 @@
 session_start();
 //initialize request parameters:
 $searchId = "dummysearch";
-$searchText = "e";
+$searchText = "*";
 #$registratingDepartments = "33,29,30,31,35,40,61,101,87,44";
 $registratingDepartments = NULL;
 #$isoCategories = "1,2,3";
@@ -80,6 +80,9 @@
 	$searchText = $testMatch;
 	$testMatch = NULL;
+	if ($searchText ==='false') {
+		$searchText ='*';
 if (isset($_REQUEST["registratingDepartments"]) & $_REQUEST["registratingDepartments"] != "") {
 	//validate to csv integer list
More information about the Mapbender_commits mailing list
