[Mapbender-commits] r7341 - in trunk/mapbender/http: css javascripts plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Dec 20 06:44:22 EST 2010
Author: kmq
Date: 2010-12-20 03:44:22 -0800 (Mon, 20 Dec 2010)
New Revision: 7341
Added:
   trunk/mapbender/http/css/wfsconftree.css
   trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
   trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php
   trunk/mapbender/http/plugins/wfsConfTree.js
merge from RLP and wfsConfTree
Added: trunk/mapbender/http/css/wfsconftree.css
--- trunk/mapbender/http/css/wfsconftree.css	                        (rev 0)
+++ trunk/mapbender/http/css/wfsconftree.css	2010-12-20 11:44:22 UTC (rev 7341)
@@ -0,0 +1,134 @@
+li{ border: 1px solid black; }
+ul{ border: 1px dotted blue; }
+a{ border: 1px dotted red; }
+/* The Whole feed Tree */
+ul.conftree {
+	overflow: auto;
+	width: 10em;
+/*	background-image: url("http://localhost:8888/vertical_dots.png");*/
+	background-repeat: repeat-y	;
+	background-position: 20px;
+ul.conftree, ul.conftree ul {
+	list-style-type: none;
+	margin-left: 0;
+	padding-left: 0;
+ul.conftree a{
+	font-size: x-small;
+ul.conftree  li{
+	padding-left: 2px;
+/*	margin-left: 1em;*/
+ul.conftree button {
+	padding: 0;
+	margin-left: 0;
+	background-color: transparent;
+	width: 20px;
+	height: 20px;
+	vertical-align: middle;
+	border: none;
+ul.conftree a:link, ul.conftree a:visited, ul.conftree a:hover, ul.conftree a:active {
+	text-decoration: none;
+	color: black;
+/* a Root Node  */
+ul.conftree  li.wfsconf.open{
+	padding-left: 0;
+ul.conftree li.wfsconf ul li{
+	margin-left:  0.2em;
+ul.conftree li.wfsconf > button.add{
+	background-image:  url("../img/add.png");
+	background-repeat: no-repeat;
+	background-position: 50% 50%;
+ul.conftree li.open.wfsconf > button.toggle{
+	background-image: url("../img/geowfsconf_logo_folder.png");
+ul.conftree li.closed.wfsconf > button.toggle{
+ul.conftree li.wfsconf.open, ul.conftree li.wfsconf.closed {
+	background-image: none;
+/*  a Feed Node */
+ul.conftree li.open > button.toggle{
+	background-image: url("../img/tree_new/expanded_folder.png");
+	background-position: 0 0;
+ul.conftree li.closed >  button.toggle{
+	background-image: url("../img/tree_new/closed_folder.png");
+ul.conftree li button.remove{
+	background-image: url("../img/button_digitize/geomRemove.png");
+ul.conftree li.open, ul.conftree li.closed {
+	background-repeat: repeat-x	;
+	background-position: 10px 10px;
+	padding-bottom: 0.5em;
+ul.conftree li.closed >ul{
+	display: none;
+ul.conftree li.wfsconf  li input{
+	margin: 0;
+/* a FeedItem Node */
+ul.conftree  ul ul {
+	padding: 0;
+ul.conftree  ul ul li {
+	padding: 0;
+	border: 1px solid transparent;
+ul.conftree  ul ul li:hover {
+	border: 1px dotted gray;
Added: trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
--- trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php	2010-12-20 11:44:22 UTC (rev 7341)
@@ -0,0 +1,1224 @@
+<?php
+# $Id: mod_wfsGazetteerEditor_client.php 1414 2008-01-17 08:55:06Z diewald $
+# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
+# http://www.mapbender.org/index.php/WFS_gazetteer
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+$gui_id = $_SESSION["mb_user_gui"];
+$target = $_REQUEST["e_target"];
+$e_id_css = $_REQUEST["e_id_css"];
+$isLoaded = $_REQUEST["isLoaded"];
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db($DB,$con);
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset='<?php echo CHARSET;?>'">
+<title>mod_wfsGazetteerEditor</title>
+<STYLE TYPE="text/css">
+div.mainDiv {
+	width: 330px;
+input.op {
+	width: 32px;
+div.helptext {
+	visibility: hidden;
+	display: none;
+	position: absolute;
+	top: 5%;
+	left: 5%;
+	width: 90%;
+	padding: 5px;
+	color: #000;
+	background-color: #CCC;
+	border: 1px solid #000;
+	z-index:1000;
+div.helptext p {
+	margin: 0 ;
+div.helptext a.close {
+	display: block;
+	margin: 5px auto;
+	text-align: center;
+a img {
+	border: 0;
+</STYLE>
+<?php
+include '../include/dyn_css.php';
+<script type="text/javascript">
+<?php
+	include '../include/dyn_js.php';
+	include '../include/dyn_php.php';
+	//include("../../conf/" . $wfs_spatial_request_conf_filename);
+	echo "var targetString = '" . $target . "';";
+	echo "var e_id_css = '" . $e_id_css . "';";
+	require(dirname(__FILE__)."/../javascripts/wfsFilter.js");
+// Element var maxHighlightedPoints
+try{
+	if (maxHighlightedPoints){
+		maxHighlightedPoints = Number(maxHighlightedPoints);
+		if (isNaN(maxHighlightedPoints)) {
+			var e = new parent.Mb_warning("mod_wfsGazetteerEditor_client.php: Element var maxHighlightedPoints must be a number.");
+catch(e){
+	maxHighlightedPoints = 0;
+	var e = new parent.Mb_warning("mod_wfsGazetteerEditor_client.php: Element var maxHighlightedPoints is not set, see 'edit element vars'.");
+var otherFrame = parent.window.frames[e_id_css];
+<?php
+//var global_selectedWfsConfId = otherFrame.global_selectedWfsConfId;
+$wfsConfId = $_GET['wfsConfId'];
+echo "var global_selectedWfsConfId = $wfsConfId;\n";
+parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString: global_selectedWfsConfId }, function(json,status){
+	global_wfsConfObj = json['0'];
+//var global_wfsConfObj = otherFrame.global_wfsConfObj;
+var targetArray = targetString.split(",");
+var global_resultHighlight;
+var requestGeometryHighlight;
+var point_px = 10;
+var resultGeom = null;
+var cw_fillcolor = "#cc33cc";
+var frameName = e_id_css + "_";
+var inputNotEnough = [];
+var button_point = "point";
+var button_polygon = "polygon";
+var button_rectangle = "rectangle";
+var button_extent = "extent";
+var mb_wfs_tolerance = 8;
+var activeButton = null;
+var mod_wfs_spatialRequest_geometry = null;
+var mod_wfs_spatialRequest_frameName = "";
+var mod_wfs_spatialRequest_epsg;
+var mod_wfs_spatialRequest_width;
+var mod_wfs_spatialRequest_height;
+var buttonWfs_id = [];
+var buttonWfs_on = [];
+var buttonWfs_src = [];
+var buttonWfs_title_off = [];
+var buttonWfs_title_on = [];
+var buttonWfs_x = [];
+var buttonWfs_y = [];
+ * This Geometry contains the geometry of the optinal spatial constraint
+var spatialRequestGeom = null;
+ * Something like box, polygon, point, extent
+var spatialRequestType = null;
+ * This Geometry contains the result from the WFS request
+var geomArray = null;
+var frameIsReady = function () {
+	init_wfsSpatialRequest();
+	appendWfsForm();
+	appendStyles();
+	setWfsInfo();
+	// creates a Highlight object for the request geometry
+	var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":100};
+	requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
+	parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
+function showHelptext(helptextId) {
+	hideHelptext();
+	document.getElementById('helptext' + helptextId).style.visibility = 'visible';
+	document.getElementById('helptext' + helptextId).style.display    = 'block';
+function hideHelptext(helptextId) {
+	if(helptextId) {
+		document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
+		document.getElementById('helptext' + helptextId).style.display    = 'none';
+	var helptext = document.getElementsByTagName('div');
+	for(var i = 0; i < helptext.length; i++) {
+		if(helptext[i].className === 'helptext') {
+			helptext[i].style.visibility = 'hidden';
+			helptext[i].style.display    = 'none';
+function trim(string) {
+	return string.replace(/^\s+/, '').replace(/\s+$/, '');
+function removeChildNodes(node) {
+	if (node) {
+		while (node.childNodes.length > 0) {
+			var childNode = node.firstChild;
+			node.removeChild(childNode);
+ * removes whitespaces and endlines before and after a string
+function trimString (str) {
+	return str.replace(/^\s+|\s+|\n+$/g, '');
+function openwindow(Adresse) {
+	Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+	Fenster1.focus();
+function setWfsInfo() {
+	// append bulb image
+	var bulbNode = document.getElementById("wfsInfo");
+	var imgNode = document.createElement("img");
+	imgNode.id = "wfsInfoImg";
+	imgNode.src = "../x_geoportal/img/info.png";
+	imgNode.border = 0;
+	bulbNode.appendChild(imgNode);
+	bulbNode.href = "javascript:openwindow('../x_geoportal/mod_featuretypeMetadata.php?wfs_conf_id=" + global_selectedWfsConfId.toString() + "');";
+	bulbNode.style.display = "inline";
+	// set image (pre configured or editor)
+	var wfsPreConfiguredOrEditor = document.getElementById("wfsPreConfiguredOrEditor");
+	var preConfigured = false;
+	for (var i=0; i < global_wfsConfObj[global_selectedWfsConfId].element.length; i++) {
+		if (parseInt(global_wfsConfObj[global_selectedWfsConfId].element[i].f_search)) {
+			preConfigured = true;
+			break;
+	if (preConfigured) {
+		wfsPreConfiguredOrEditor.src = "../x_geoportal/img/modul_suche.png";
+		wfsPreConfiguredOrEditor.title = "Modultyp: Suche";
+	else {
+		wfsPreConfiguredOrEditor.src = "../x_geoportal/img/modul_download.png";
+		wfsPreConfiguredOrEditor.title = "Modultyp: Download";
+	wfsPreConfiguredOrEditor.style.display = 'inline';
+	// set wfsGeomType image
+	var wfsGeomTypeNode = document.getElementById("wfsGeomType");
+	var wfsGeomType = "";
+		if (parseInt(global_wfsConfObj[global_selectedWfsConfId].element[i].f_geom)) {
+			wfsGeomType = global_wfsConfObj[global_selectedWfsConfId].element[i].element_type;
+	if (wfsGeomType.match(/Point/)) {
+		wfsGeomTypeNode.src = "../x_geoportal/img/wfs_pkt.gif";
+		wfsGeomTypeNode.style.display = 'inline';
+		wfsGeomTypeNode.title = 'Geometrietyp: Punkt';
+	else if (wfsGeomType.match(/Line/)) {
+		wfsGeomTypeNode.src = "../x_geoportal/img/wfs_l.gif";
+		wfsGeomTypeNode.title = 'Geometrietyp: Linie';
+	else if (wfsGeomType.match(/Polygon/)) {
+		wfsGeomTypeNode.src = "../x_geoportal/img/wfs_p.gif";
+		wfsGeomTypeNode.title = 'Geometrietyp: Fläche';
+	else {
+		var e = new parent.Mb_exception("WFS gazetteer: geometry type unknown.");
+ * BUTTON HANDLING
+function addButtonWfs(id, isOn, src, title, x, y) {
+	buttonWfs_id.push(id);
+	buttonWfs_on.push(isOn);
+	buttonWfs_src.push(src);
+	buttonWfs_title_off.push(title);
+	buttonWfs_title_on.push(title);
+	buttonWfs_x.push(x);
+	buttonWfs_y.push(y);
+function init_wfsSpatialRequest() {
+	buttonWfs_id = [];
+	buttonWfs_on = [];
+	buttonWfs_src = [];
+	buttonWfs_title_off = [];
+	buttonWfs_title_on = [];
+	buttonWfs_x = [];
+	buttonWfs_y = [];
+	addButtonWfs("rectangle", buttonRectangle.status, buttonRectangle.img, buttonRectangle.title, buttonRectangle.x, buttonRectangle.y);
+	addButtonWfs("polygon", buttonPolygon.status, buttonPolygon.img, buttonPolygon.title, buttonPolygon.x, buttonPolygon.y);
+	addButtonWfs("point", buttonPoint.status, buttonPoint.img, buttonPoint.title, buttonPoint.x, buttonPoint.y);
+	addButtonWfs("extent", buttonExtent.status, buttonExtent.img, buttonExtent.title, buttonExtent.x, buttonExtent.y);
+	displayButtons();
+function wfsInitFunction (j) {
+	var functionCall = "parent.mb_regButton_frame('initWfsButton', '"+frameName+"', "+j+")";
+	var x = new Function ("", functionCall);
+	x();
+function initWfsButton(ind, pos) {
+	parent.mb_button[ind] = document.getElementById(buttonWfs_id[pos]);
+	parent.mb_button[ind].img_over = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_over");
+	parent.mb_button[ind].img_on = buttonWfs_imgdir + buttonWfs_src[pos].replace(/_off/,"_on");
+	parent.mb_button[ind].img_off = buttonWfs_imgdir + buttonWfs_src[pos];
+	parent.mb_button[ind].status = 0;
+	parent.mb_button[ind].elName = buttonWfs_id[pos];
+	parent.mb_button[ind].frameName = frameName;
+	parent.mb_button[ind].go = new Function ("requestGeometryHighlight.clean();wfsEnable(parent.mb_button["+ind+"], " + pos + ")");
+	parent.mb_button[ind].stop = new Function ("wfsDisable(parent.mb_button["+ind+"], " + pos + ")");
+	var ind = parent.getMapObjIndexByName("mapframe1");
+	mod_wfs_spatialRequest_width = parent.mb_mapObj[ind].width;
+	mod_wfs_spatialRequest_height = parent.mb_mapObj[ind].height;
+	mod_wfs_spatialRequest_epsg = parent.mb_mapObj[ind].epsg;
+	parent.mb_registerPanSubElement("measuring");
+function displayButtons() {
+	for (var i = 0 ; i < buttonWfs_id.length ; i ++) {
+		if (parseInt(buttonWfs_on[i])==1) {
+			var currentImg = document.createElement("img");
+			currentImg.id = buttonWfs_id[i];
+			currentImg.name = buttonWfs_id[i];
+			currentImg.title = buttonWfs_title_off[i];
+			currentImg.src = buttonWfs_imgdir+buttonWfs_src[i];
+			currentImg.style.position = "absolute";
+			currentImg.style.top = buttonWfs_y[i];
+			currentImg.style.left = buttonWfs_x[i];
+			currentImg.onmouseover = new Function("wfsInitFunction("+i+")");
+			document.getElementById("displaySpatialButtons").appendChild(currentImg);
+function disableButtons() {
+	removeChildNodes(document.getElementById("displaySpatialButtons"));
+function wfsEnable(obj) {
+   	var el = parent.window.frames["mapframe1"].document;
+   	el.onmouseover = null;
+   	el.onmousedown = null;
+   	el.onmouseup = null;
+   	el.onmousemove = null;
+	if (obj.id == button_point) {
+		if (activeButton == null) {
+			activeButton = obj;
+	if (obj.id == button_polygon) {
+	else if (obj.id == button_rectangle){
+	else if (obj.id == button_extent){
+	callRequestGeometryConstructor(obj, "mapframe1");
+function wfsDisable(obj) {
+	el.ondblclick = null;
+	parent.writeTag("mapframe1","measure_display","");
+	parent.writeTag("mapframe1","measure_sub","");
+	activeButton = null;
+ * Request geometry
+function callRequestGeometryConstructor(pressedButton,target){
+	var selectedType = pressedButton.id;
+	spatialRequestType = selectedType;
+	var geometryConstructor = new parent.RequestGeometryConstructor(target);
+	geometryConstructor.getGeometry(selectedType,function(target,queryGeom){
+		// callback function; called when query geometry has been
+		// constructed by user.
+		if (queryGeom !='') {
+			spatialRequestGeom = queryGeom;
+			// disable the selected button
+			parent.mb_disableThisButton(pressedButton.elName);
+			// spatialRequestGeom is a Geometry, but for the highlight
+			// a MultiGeometry is needed.
+			var multiGeom;
+			// a line represents a bbox...but highlight must be a polyon
+			// (extent or box selection)
+			if (spatialRequestGeom.geomType == parent.geomType.line) {
+				multiGeom = new parent.MultiGeometry(parent.geomType.polygon);
+				newGeom = new parent.Geometry(parent.geomType.polygon);
+				var p1 = spatialRequestGeom.get(0);
+				var p2 = spatialRequestGeom.get(1);
+				newGeom.addPoint(p1);
+				newGeom.addPointByCoordinates(p1.x, p2.y);
+				newGeom.addPoint(p2);
+				newGeom.addPointByCoordinates(p2.x, p1.y);
+				newGeom.close();
+				multiGeom.add(newGeom);
+			// standard case
+			// (polygon and point selection)
+			else {
+				multiGeom = new parent.MultiGeometry(spatialRequestGeom.geomType);
+				multiGeom.add(spatialRequestGeom);
+			// add highlight of geometry
+			requestGeometryHighlight.add(multiGeom);
+			requestGeometryHighlight.paint();
+			// add button for geometry deletion
+			var deleteGeomButton = document.getElementById("deleteRequestGeometry");
+			deleteGeomButton.style.display = "block";
+			deleteGeomButton.onclick = function () {
+				spatialRequestGeom = null;
+				this.style.display = "none";
+				requestGeometryHighlight.clean();
+ * Appends styles to the pre-configured WFS form
+function appendStyles() {
+	var styleObj;
+	var rule = global_wfsConfObj[global_selectedWfsConfId].g_style + global_wfsConfObj[global_selectedWfsConfId].g_res_style;
+	if (parent.ie) {
+		var styleSheetObj=document.createStyleSheet();
+		styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
+		styleObj.setAttribute("type","text/css");
+		ruleArray = rule.split("}");
+		for (var i=0; i < ruleArray.length - 1; i++) {
+			var currentRule = trimString(ruleArray[i]);
+			var nameValueArray = currentRule.split("{");
+			var name = nameValueArray[0];
+			var value = nameValueArray[1];
+			styleSheetObj.addRule(name,value);
+	else {
+		styleObj=document.createElement("style");
+		document.getElementsByTagName("head")[0].appendChild(styleObj);
+		styleObj.appendChild(document.createTextNode(rule+"\n"));
+function isSearchPreconfigured () {
+	var wfsConfElementArray = global_wfsConfObj[global_selectedWfsConfId].element;
+	for (var i = 0; i < wfsConfElementArray.length; i++){
+		if (parseInt(wfsConfElementArray[i].f_search)) {
+			return true;
+	return false;
+function appendWfsForm() {
+	var form = document.getElementById("wfsForm");
+	removeChildNodes(form);
+	if(!isSearchPreconfigured()){
+		 * Appends the WFS editor
+		document.getElementById("mainDiv").style.display = "block";
+		fillLeftList();
+	else{
+		 * Appends the pre-configured WFS form
+		var divContainer = document.createElement("div");
+		divContainer.className = global_wfsConfObj[global_selectedWfsConfId].g_label_id;
+		divContainer.innerHTML = global_wfsConfObj[global_selectedWfsConfId].g_label;
+		form.appendChild(divContainer);
+				var spanNode = document.createElement("span");
+				spanNode.setAttribute("id", "ttttt");
+				spanNode.className = wfsConfElementArray[i].f_label_id;
+				spanNode.innerHTML = wfsConfElementArray[i].f_label;
+				var inputNode = document.createElement("input");
+				inputNode.type = "text";
+				inputNode.className = wfsConfElementArray[i].f_style_id;
+				inputNode.id = wfsConfElementArray[i].element_name;
+				if(wfsConfElementArray[i].f_helptext.length > 0) {
+					var helptextNode    = document.createElement('span');
+					var helptextDisplay = document.createElement('div');
+					helptextDisplay.id        = 'helptext' + i;
+					helptextDisplay.className = 'helptext';
+					var helptext = document.createElement('p');
+					helptext.innerHTML  = wfsConfElementArray[i].f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
+					helptext.innerHTML += '<a href="#" class="close" onclick="hideHelptext(' + i + ')">close</a>';
+					helptextDisplay.appendChild(helptext);
+					helptextNode.innerHTML = ' <a href="#" onclick="showHelptext(' + i + ')"><img src="img/help.png" width="16" height="16" alt="?" /></a> ';
+				form.appendChild(spanNode);
+				form.appendChild(inputNode);
+				if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextNode); }
+				if(wfsConfElementArray[i].f_helptext.length > 0) { form.appendChild(helptextDisplay); }
+				form.appendChild(document.createElement("br"));
+		var submitButton = document.createElement("input");
+		submitButton.type = "submit";
+		submitButton.id = "wfsForm_Submit";
+		submitButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
+		submitButton.value = global_wfsConfObj[global_selectedWfsConfId].g_button;
+		form.appendChild(submitButton);
+	checkSrs();
+function checkSrs(){
+	//check SRS
+	var submit = document.getElementById("wfsForm_Submit");
+	var submit_attr = document.getElementById("attrPanel_Submit");
+	if(global_wfsConfObj[global_selectedWfsConfId].featuretype_srs!=parent.mb_mapObj[ind].getSRS()){
+		var msg = "Das Projektionssystem von Karte und WFS-Featuretype ist unterschiedlich, Abfrage nicht moeglich!\n";
+		msg += parent.mb_mapObj[ind].getSRS()+" und "+global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
+		alert(msg);
+		//disable Submit Button
+		if(submit)submit.disabled = true;
+		if(submit_attr)submit_attr.disabled = true;
+	else{
+		if(submit)submit.disabled = false;
+		if(submit_attr)submit_attr.disabled = false;
+//------------------------------------------------- start Editor functions
+function fillLeftList() {
+	deleteSelectOptions(document.attrPanel.leftList);
+	deleteSelectOptions(document.attrPanel.rightList);
+	deleteFilterText();
+	var wfsConf = global_wfsConfObj[global_selectedWfsConfId];
+	for (var i = 0 ; i < wfsConf.element.length ; i++) {
+		// do not include geometry column
+		if (wfsConf.element[i].f_geom != 1) {
+			var lLOption = document.createElement("option");
+			lLOption.id = "lLOPtion"+i+"_"+wfsConf.element[i].element_type;
+			lLOption.value = i;
+			lLOption.innerHTML = wfsConf.element[i].element_name;
+			document.getElementById("leftList").appendChild(lLOption);
+ function fillRightList() {
+ 	var chosenLayer = global_wfsConfObj[global_selectedWfsConfId].featuretype_name;
+	var layerAttr=document.getElementById("leftList");
+	var chosenAttr =layerAttr.options[layerAttr.selectedIndex].text;
+	var wfs_getfeature = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature;
+	document.getElementById("progressWheel").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Get features...</td></tr></table>";
+	var properties = {"command":"getFeature", "wfsFeatureTypeName":chosenLayer, "wfsGetFeatureAttr":chosenAttr, "wfsGetFeature":wfs_getfeature};
+	parent.$.post("../x_geoportal/mod_wfsGazetteerEditor_server.php", properties, function (result, status) {
+		if (status == "success") {
+		   var arrFeatureColumnValues = eval('(' + result + ')');
+      	   var i = 0;
+      	   for( var i=0; i<arrFeatureColumnValues.length; i++){
+      	   		removeChildNodes(document.getElementById("progressWheel"));
+      	   		if(arrFeatureColumnValues[i]!=''){
+	    	    	var rLOption = document.createElement("option");
+	   				rLOption.id = "rLOption"+i;
+	   				rLOption.value = i;
+	   				rLOption.innerHTML = arrFeatureColumnValues[i];
+	   				document.getElementById("rightList").appendChild(rLOption);
+ * writeLeftValueInString()
+ * @param {}
+ * Doppelklick auf Listeneintrag (Links) => Listenwert wir in Textarea geschrieben
+function writeLeftValueInString(){
+	var chosenAttr = layerAttr.options[layerAttr.selectedIndex].text;
+	if(layerAttr.options[layerAttr.selectedIndex].id.match("int") || layerAttr.options[layerAttr.selectedIndex].id.match("float")){
+		controlOperators("int");
+	else if(layerAttr.options[layerAttr.selectedIndex].id.match("string")){
+		controlOperators("string");
+	else if(layerAttr.options[layerAttr.selectedIndex].id.match("date")){
+		controlOperators("date");
+	else{
+		controlOperators("all");
+	var attrTxt = "[" + chosenAttr + "]";
+	insertAtCursor(document.attrPanel.attrRequestText, attrTxt);
+function hideOperators(){
+	document.getElementById('greaterThan').style.visibility = "hidden";
+	document.getElementById('lessThan').style.visibility = "hidden";
+	document.getElementById('lessThanOrEqualTo').style.visibility = "hidden";
+	document.getElementById('greaterThanOrEqualTo').style.visibility = "hidden";
+	document.getElementById('and').style.visibility = "hidden";
+	document.getElementById('like').style.visibility = "hidden";
+	document.getElementById('equal').style.visibility = "hidden";
+	document.getElementById('notEqual').style.visibility = "hidden";
+function controlOperators(opType){
+	document.getElementById('greaterThan').style.visibility = "visible";
+	document.getElementById('lessThan').style.visibility = "visible";
+	document.getElementById('lessThanOrEqualTo').style.visibility = "visible";
+	document.getElementById('greaterThanOrEqualTo').style.visibility = "visible";
+	document.getElementById('and').style.visibility = "visible";
+	document.getElementById('like').style.visibility = "visible";
+	document.getElementById('equal').style.visibility = "visible";
+	document.getElementById('notEqual').style.visibility = "visible";
+	if(opType=='int'){
+	else if(opType=='string'){
+	else if(opType=='date'){
+		// do something
+	else{
+		// do something
+ * writeRightValueInString()
+ * @param {}
+ * Doppelklick auf Listeneintrag (Rechts) => Listenwert wir in Textarea geschrieben
+function writeRightValueInString(){
+ 	var chosenVal =document.getElementById("rightList").options[document.getElementById("rightList").selectedIndex].text;
+	insertAtCursor(document.attrPanel.attrRequestText,chosenVal);
+* insertOperator
+* @param {type} param
+ function insertOperator(value) {
+	var wert = value;
+ 	insertAtCursor(document.attrPanel.attrRequestText, wert);
+ * insertAtCursor
+ * @param {Textfeld, String} param
+ * Fuegt an die Cursorstelle einen Text(String) ein
+function insertAtCursor(myField, myValue) {
+//IE support
+	if (document.selection) {
+		myField.focus();
+		sel = document.selection.createRange();
+		sel.text = myValue;
+//MOZILLA/NETSCAPE support
+	else if (myField.selectionStart || myField.selectionStart == '0') {
+		var startPos = myField.selectionStart;
+		var endPos = myField.selectionEnd;
+		myField.value = myField.value.substring(0, startPos)
+		+ myValue
+		+ myField.value.substring(endPos, myField.value.length);
+	} else {
+	myField.value += myValue;
+ * deleteSelectOptions()
+ * @param {}
+function deleteSelectOptions(field){
+	var numOfOpt = field.length;
+	for (i=0; i <numOfOpt; i++){
+		field.options[field.length-1] = null;
+ * deleteFilterText()
+ * @param {type}
+ * Button loescht Eintrag im Textfeld (attrRequestText)
+ function deleteFilterText() {
+ 	document.attrPanel.attrRequestText.value="";
+function createWfsFilter () {
+	var wfsFilter = new WfsFilter();
+	 * Add filter from WFS editor
+	if (!isSearchPreconfigured()) {
+		var filter = document.attrPanel.attrRequestText.value;
+		if (!wfsFilter.parse(filter)) {
+			alert("Keine gültige Filterbedingung gesetzt.");
+			return false;
+	 * Add filter from pre configured searches
+	var filterParameterCount = getNumberOfFilterParameters();
+	var el = global_wfsConfObj[global_selectedWfsConfId].element;
+	if (filterParameterCount != 0) {
+		for (var i = 0; i < el.length; i++) {
+			if (el[i]['f_search'] == 1) {
+				var a = document.getElementById(el[i]['element_name']).value.split(",");
+				wfsFilter.addPreConfigured(el[i]['element_name'], a, el[i]['f_toupper'], el[i]['f_operator']);
+	 * Add filter from request geometry
+	if (spatialRequestGeom != null) {
+		// get SRS
+		var srs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
+		// get geometry column name
+		var geometryColumnName = "";
+		for (var j = 0; j < el.length; j++) {
+			if (el[j].f_geom == 1) {
+				geometryColumnName = el[j].element_name;
+		// get filter option
+		var filterOption = "";
+		var selectedButton;
+		if (spatialRequestGeom.geomType == parent.geomType.polygon) {
+			selectedButton = buttonPolygon;
+		else
+				selectedButton = buttonRectangle;
+		if (selectedButton.filteroption == 'within') {
+			filterOption = "Within";
+		else
+			if (selectedButton.filteroption == 'intersects') {
+				filterOption = "Intersects";
+		// add spatial filter
+		wfsFilter.addSpatial(spatialRequestGeom, geometryColumnName, filterOption, srs);
+	return wfsFilter.toString();
+ * The filter is calculated from the WFS editor or the pre-comfigured
+ * search form, with optional request geometry
+ function makeRequest() {
+	// hide the result and detail popup
+ 	if (typeof(resultGeometryPopup) != "undefined") {
+ 		resultGeometryPopup.hide();
+ 	if (typeof(wfsPopup) != "undefined") {
+ 		wfsPopup.hide();
+	// empty the result geometry
+	if(geomArray != null && geomArray.count()>0){
+ 		geomArray.empty();
+	// set the Highlight object for the result geometry
+	global_resultHighlight = new parent.Highlight(targetArray, "wfsGazetteerEditorHighlight", styleProperties, 2);
+	 * Send WFS request
+	document.getElementById("progressWheel").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
+	var u = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature + parent.mb_getConjunctionCharacter(global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature);
+	u += "REQUEST=getFeature&Typename="+global_wfsConfObj[global_selectedWfsConfId].featuretype_name+"&Version=1.0.0&service=WFS";
+	u += "&filter=";
+	var exportToShape = document.getElementById("exportToShape").checked;
+	var parameters = {
+		command:"getSearchResults",
+		"wfs_conf_id":global_selectedWfsConfId,
+		"frame":this.name,
+		"url":u,
+		"filter":createWfsFilter(),
+		"backlink":"",
+		"exportToShape":exportToShape
+		parent.mb_ajax_get("../x_geoportal/mod_wfsGazetteerEditor_server.php", parameters, function (jsCode, status) {
+			if(status=='success'){
+				for (var i=0; i < parent.wms.length; i++) {
+					for (var j=0; j < parent.wms[i].objLayer.length; j++) {
+						var currentLayer = parent.wms[i].objLayer[j];
+						var wms_id = parent.wms[i].wms_id;
+						if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
+							var layer_name = currentLayer.layer_name;
+							parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
+							parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
+				var geoObj = eval('(' + jsCode + ')');
+	       		if (!exportToShape) {
+	       			if (jsCode) {
+			        	if (typeof(geoObj) == 'object') {
+							geomArray = new parent.GeometryArray();
+							geomArray.importGeoJSON(geoObj);
+							displayPopup(geomArray);
+						else {
+							displayPopup();
+		       		else {
+						alert("Kein Ergebnis.");
+	       		else {
+	       			if (jsCode) {
+						var htmlCodeDownload = "<iframe style='visibility:visible' src='../x_geoportal/download.php?download=" + geoObj.filename + "'></iframe>";
+						var downloadPopup = new parent.mb_popup("Download", htmlCodeDownload, 1, 1, -10, 1);
+						downloadPopup.show();
+						//downloadPopup.hide();
+		       		else {
+						alert("Beim Export ist ein Fehler aufgetreten.");
+				document.getElementById("progressWheel").innerHTML = "";
+	else{
+		if(inputNotEnough.length==0){
+		       			if (jsCode) {
+							else {
+								displayPopup();
+			       		else {
+		       		else {
+		       			if (jsCode) {
+			       		else {
+		else{
+			return false;
+	return false;
+function getListTitle(geom){
+	var resultObj = {};
+		var currentElement = wfsConf.element[i];
+		if (currentElement.f_show == 1 && geom.e.getElementValueByName(currentElement.element_name) != false) {
+			var pos = currentElement.f_respos;
+			if (pos > 0) {
+				resultObj[pos] = geom.e.getElementValueByName(currentElement.element_name);
+	return resultObj;
+function createListOfGeometries(){
+	var listOfGeom = "<table style='background-color:#EEEEEE;'>\n";
+	if (geomArray != null && geomArray.count() > 0) {
+		for (var i = 0 ; i < geomArray.count(); i ++) {
+			if (geomArray.get(i).get(-1).isComplete()) {
+				listOfGeom += "\t<tr>\n\t\t ";
+				var resultElObj = getListTitle(geomArray.get(i));
+				for (var wfsConfEl in resultElObj) {
+					if(resultElObj[wfsConfEl]!=''){
+						listOfGeom += "<td style='cursor:pointer;\n";
+						if ((i % 2) === 0) {
+							listOfGeom += "color:black'";
+						else {
+						listOfGeom += "\t\t\t onmouseover=\"window.frames['"+frameName+"'].setResult('over',"+i+")\" ";
+						listOfGeom += " onmouseout=\"window.frames['"+frameName+"'].setResult('out',"+i+")\" ";
+						listOfGeom += " onclick=\"window.frames['"+frameName+"'].setResult('click',"+i+"); window.frames['"+frameName+"'].showWfs("+i+");\" ";
+						listOfGeom += ">"+ resultElObj[wfsConfEl] +"</td>";
+				listOfGeom += "\t\t</tr>\n";
+	listOfGeom += "</table>\n";
+	return listOfGeom;
+function displayPopup(geom){
+	geomArray = geom;
+	var contentHtml = "Kein Ergebnis";
+	if (geomArray != null && geomArray.count() > 0){
+		contentHtml = createListOfGeometries();
+	if (typeof(resultGeometryPopup) == "undefined") {
+		resultGeometryPopup = new parent.mb_popup(searchPopupTitle,contentHtml,searchPopupWidth,searchPopupHeight,searchPopupX,searchPopupY);
+	else {
+//		resultGeometryPopup.hide();
+		resultGeometryPopup.setHtml(contentHtml);
+//		resultGeometryPopup = new parent.mb_popup(searchPopupTitle,contentHtml,searchPopupWidth,searchPopupHeight,searchPopupX,searchPopupY);
+	resultGeometryPopup.show();
+function showWfs(geometryIndex) {
+	var wfsElement = geomArray.get(geometryIndex).e;
+	var resultHtml = "";
+	resultHtml += "<table style='background-color:#EEEEEE;'>\n";
+	var details = 0;
+	for (var i = 0 ; i <wfsConf.element.length; i ++) {
+		if(wfsConf.element[i].f_show_detail == 1){
+			resultHtml +="<tr><td>\n";
+			resultHtml += wfsConf.element[i].element_name;
+			resultHtml +="</td>\n";
+			resultHtml += "<td>\n";
+			var elementVal = wfsElement.getElementValueByName(wfsConf.element[i].element_name);
+			resultHtml += elementVal;
+			resultHtml += "</td></tr>\n";
+			details = 1;
+//	if(details != 1){
+//		resultHtml +="<tr><td>Keine Informationen</td></tr>\n";
+	resultHtml += "</table>\n";
+	if(details == 1){
+		if (typeof(wfsPopup) == "undefined") {
+			wfsPopup = new parent.mb_popup(detailPopupTitle,resultHtml,detailPopupWidth,detailPopupHeight,detailPopupX,detailPopupY);
+		else {
+			wfsPopup.hide();
+			wfsPopup.setHtml(resultHtml);
+		wfsPopup.show();
+//------------------------------------------------- end Editor functions
+function getNumberOfFilterParameters(){
+	var cnt = 0;
+	inputNotEnough = [];
+	for (var i = 0; i < el.length; i++){
+		if( el[i]['f_search'] == 1){
+			if (document.getElementById(el[i]['element_name']).value != '') {
+				cnt++;
+			if(document.getElementById(el[i]['element_name']).value.length < el[i]['f_min_input']){
+				inputNotEnough.push(el[i]['element_name']+"("+el[i]['f_min_input']+")");
+	if(inputNotEnough.length>0){
+		alert("Pflichtfelder: "+inputNotEnough.join(', '));
+		return false;
+	return cnt;
+* event -> {over || out || click}
+* geom -> commaseparated coordinates x1,y1,x2,y2 ...
+function setResult(event, index){
+	var currentGeom = geomArray.get(index);
+	if (maxHighlightedPoints > 0 && currentGeom.getTotalPointCount() > maxHighlightedPoints) {
+		currentGeom = currentGeom.getBBox4();
+	if (event == "over") {
+		global_resultHighlight.add(currentGeom, cw_fillcolor);
+		global_resultHighlight.paint();
+	else if (event == "out"){
+		global_resultHighlight.del(currentGeom, cw_fillcolor);
+	else if (event == "click"){
+		var bbox = currentGeom.getBBox();
+		var bufferFloat = parseFloat(global_wfsConfObj[global_selectedWfsConfId].g_buffer);
+		var buffer = new parent.Point(bufferFloat,bufferFloat);
+		bbox[0] = bbox[0].minus(buffer);
+		bbox[1] = bbox[1].plus(buffer);
+		parent.mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
+		parent.zoom(targetArray[0], 'true', 1.0);
+	return true;
+</script>
+</head>
+<body leftmargin='0' topmargin='10' bgcolor='#ffffff' onload='frameIsReady()'> <!-- onload='initModWfsGazetteer();init_wfsSpatialRequest();'  -->
+	<!-- WFS conf info -->
+	<img src = "" name='wfsPreConfiguredOrEditor' id='wfsPreConfiguredOrEditor' style='display:none'>
+	<img src = "" name='wfsGeomType' id='wfsGeomType' style='display:none'>
+	<a name='wfsInfo' title='Informationen anzeigen' id='wfsInfo' style='display:none'></a><form name='attrPanel' id='attrPanel' onsubmit='return makeRequest();'>
+	<div class='mainDiv' id='mainDiv' style="display:none">
+	<b>Räumliche Auswahl</b>
+	<div name='displaySpatialButtons' id='displaySpatialButtons' style='width:180px'></div>
+	<input type="button" id="deleteRequestGeometry" name="deleteRequestGeometry" value="löschen" style="position:absolute;top:70px;left:120px;display:none">
+	<br><br>
+	<b>Attributauswahl</b>
+	  <table>
+	  	<tr valign='top'>
+	  		<td width='30%'>&nbsp;</td><td width='35%'>&nbsp;</td><td width='35%' style='font-size:12px;'>Beispielinhalte (erste 20 Einträge)</td>
+	  	</tr>
+	    <tr valign='top'>
+	      	<td width='30%'>
+	      		<select name='leftList' id='leftList' onChange='fillRightList();' onDblClick='writeLeftValueInString();' size='8' style='width:120px;'></select>
+			</td>
+			<td width='35%'>
+				<input id='greaterThan' class='op' onClick='insertOperator(value);' type='button' value='>>' name='op1'>
+				<input id='greaterThanOrEqualTo' class='op' onClick='insertOperator(value);' type='button' value='>=' name='op2'><br>
+				<input id='lessThan' class='op' onClick='insertOperator(value);' type='button' value='<<' name='op3'>
+				<input id='lessThanOrEqualTo' class='op' onClick='insertOperator(value);' type='button' value='<=' name='op4'><br>
+				<input id='equal' class='op' onClick='insertOperator(value);' type='button' value='==' name='op5'>
+				<input id='notEqual' class='op' onClick='insertOperator(value);' type='button' value='<>' name='op6'><br>
+				<input id='like' class='op' onClick='insertOperator(value);' type='button' value=' LIKE ' name='op7'>
+				<input id='and' class='op' onClick='insertOperator(value);' type='button' value=' AND ' name='op8'><br>
+			</td>
+			<td width='35%'>
+				<select name='rightList' id='rightList' onDblClick='writeRightValueInString();' size='8' style='width:120px;'>
+				</select>
+			</td>
+		</tr>
+	  </table>
+	<br>
+	<table>
+	    <tr>
+	      	<td style='width:80%;height:40' colspan=4>
+	      		<textarea cols='48' rows='5' name='attrRequestText' id='attrRequestText' ></textarea>
+			</td>
+	    </tr>
+	    <tr >
+	      	<td>
+	      		 <input type='submit' id='attrPanel_Submit' value='Anfrage
+starten'>
+	      	</td>
+			<td>
+				<input onClick='deleteFilterText();' type='button' value='Filter
+zur&uuml;cksetzen'>
+			</td>
+	      	<td>
+				<div name='displayCheckbox' id='displayCheckbox' style='width:180px'>
+					<input type='checkbox' name='exportToShape' id='exportToShape'>Daten exportieren
+				</div>
+	      	</td>
+	    </tr>
+	  </table>
+	</div>
+</form>
+<form name='wfsForm' id='wfsForm' onsubmit='return makeRequest()'></form>
+<div name='progressWheel' id='progressWheel' style='width:180px'></div>
+</body>
+</html>
Added: trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php
--- trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php	2010-12-20 11:44:22 UTC (rev 7341)
@@ -0,0 +1,253 @@
+<?php
+# $Id: mod_wfsGazetteerEditor_server.php 1376 2007-11-09 14:34:37Z baudson $
+# http://www.mapbender.org/index.php/Administration
+session_start();
+require_once(dirname(__FILE__)."/../classes/class_gml2.php");
+require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+$command = $_REQUEST["command"];
+$wfsFeatureTypeName = $_REQUEST["wfsFeatureTypeName"];
+#$wfsDescribeFeatureType = $_REQUEST["wfsDescribeFeatureType"];
+$wfsGetFeatureAttr = $_REQUEST["wfsGetFeatureAttr"];
+$wfsGetFeature = $_REQUEST["wfsGetFeature"];
+$wfsFilter = $_REQUEST["wfsFilter"];
+$exportToShape = $_REQUEST["exportToShape"] == "true" ? true : false;
+ * checks if a variable name is valid.
+ * Currently a valid name would be sth. like $_SESSION["mb_user_id"]
+ * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
+function isValidVarName ($varname) {
+	if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
+		return true;
+	return false;
+ * If access to the WFS conf is restricted, modify the filter.
+ function checkAccessConstraint($filter, $wfs_conf_id) {
+	/* wfs_conf_element */
+	$sql = "SELECT * FROM wfs_conf_element ";
+	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+	$sql .= "ORDER BY wfs_conf_element.f_respos";
+	$v = array($wfs_conf_id);
+	$t = array('i');
+	$res = db_prep_query($sql,$v,$t);
+	while($row = db_fetch_array($res)){
+		if (!empty($row["f_auth_varname"])) {
+			$auth_varname = $row["f_auth_varname"];
+			$element_name = $row["element_name"];
+	if (!empty($auth_varname)) {
+		if (isValidVarName($auth_varname)) {
+			$user = eval("return " . $auth_varname . ";");
+			if ($user) {
+				$pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
+				$replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
+				$filter = mb_eregi_replace($pattern, $replacement, $filter);
+			else {
+				$e = new mb_exception("mod_wfsGazetteerEditor_server: checkAccessConstraint: invalid value of variable containing user information!");
+		else {
+			$e = new mb_exception("mod_wfsGazetteerEditor_server: checkAccessConstraint: var name is not valid! (" . $auth_varname . ")");
+	return $filter;
+if ($command == "getWfsConf") {
+	$wfsConfIdString = $_GET["wfsConfIdString"];
+	if ($wfsConfIdString != "") {
+		//array_keys(array_flip()) produces an array with unique entries
+		$wfsConfIdArray = array_keys(array_flip(mb_split(",", $wfsConfIdString)));
+	else {
+		echo "{}";
+		die();
+	$obj = new WfsConf();
+	$obj->load($wfsConfIdArray);
+	$json = new Services_JSON();
+	$output = $json->encode($obj->confArray);
+	echo $output;
+else if ($command == "getSearchResults") {
+	$wfs_conf_id = $_REQUEST["wfs_conf_id"];
+	$backlink = $_REQUEST["backlink"];
+	$frame = $_REQUEST["frame"];
+	$filter = $_REQUEST["filter"];
+	$url = $_REQUEST["url"];
+	/* wfs_conf */
+	$sql = "SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+	$sql .= "WHERE wfs_conf.wfs_conf_id = $1";
+	$t = array('i');
+	if ($row = db_fetch_array($res)) {
+		$g_res_style  = $row["g_res_style"];
+	else {
+		die("wfs_conf " . $wfs_conf_id . "data not available");
+	$sql .= "AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;";
+	$t = array('i');
+	#echo $sql;
+	$col = array();
+	while ($row = db_fetch_array($res)) {
+		array_push($col, $row["element_name"]);
+	if (count($col) == 0) {
+		die("wfs_conf_element data not available");
+	// append authorisation condition to filter
+	$filter = checkAccessConstraint($filter, $wfs_conf_id);
+	$admin = new administration();
+	$req = urldecode($url).urlencode($admin->char_decode(stripslashes($filter)));
+	$mygml = new gml2();
+	$mygml->parseFile($req);
+	if (!empty($exportToShape)) {
+		$filenamePrefix = md5(microtime());
+		$mygml->toShape($filenamePrefix);
+		header("Content-type:application/x-json; charset=utf-8");
+		echo "{'filename':'" . $filenamePrefix . ".zip'}";
+	else {
+		echo $mygml->toGeoJSON();
+else if($command == "getFeature"){
+	$wfsGetFeature=$admin->checkURL($wfsGetFeature);
+	$url = $wfsGetFeature."REQUEST=getFeature&VERSION=1.0.0&SERVICE=WFS&MAXFEATURES=20".
+		   "&typename=".$wfsFeatureTypeName; //."&propertyname=".$wfsGetFeatureAttr;
+		   //"&filter=<ogc:Filter><ogc:Not><ogc:PropertyIsNull><ogc:PropertyName>".$wfsGetFeatureAttr."</ogc:PropertyName></ogc:PropertyIsNull></ogc:Not></ogc:Filter>";
+	#echo $url;
+	$e = new mb_exception("URL: " . $url);
+	$x = new connector($url);
+	$data = $x->file;
+	//$data = file_get_contents($url);
+	$parser = xml_parser_create();
+	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+	xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,"UTF-8");
+	xml_parse_into_struct($parser,$data,$values,$tags);
+	$code = xml_get_error_code($parser);
+	xml_parser_free($parser);
+	if ($code) {
+		$line = xml_get_current_line_number($parser);
+		$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
+	function sepNameSpace($s){
+		$c = mb_strpos($s,":");
+		if($c>0){
+			return mb_substr($s,$c+1);
+		else{
+			return $s;
+	$featureNameToUpper = mb_strtoupper($wfsGetFeatureAttr);
+	$featureValuesArray = array();
+	foreach ($values as $element) {
+		if(mb_strtoupper($element[tag]) == $featureNameToUpper || sepNameSpace(mb_strtoupper($element[tag])) == $featureNameToUpper){
+			array_push($featureValuesArray, $element[value]);
+//	$featureValues = join("|", $featureValuesArray);
+	echo $json->encode($featureValuesArray);
+// the way below only works with propertyname in REQUEST-Url
+//	$sxe = new SimpleXMLElement($data);
+//	list($ns, $ns_url) = explode(":", $wfsFeatureTypeName);
+//	$sxe->registerXPathNamespace($ns, 'http://namespace_url_default');
+//	$m = array();
+//	$m['columnValues'] = $sxe->xpath('//'.$ns.':'.$wfsGetFeatureAttr);
+//	$columnValues = array();
+//	$i=0;
+//	foreach ($m['columnValues'] as $columnValue) {
+//		$domNode = dom_import_simplexml($columnValue);
+//	    $columnValues[$i]=$domNode->nodeValue;
+//	    $i++;
+//	    $json = new Services_Json();
+//		$jsonEncodedValue = $json->encode($columnValues);
+//	echo $jsonEncodedValue;
+else {
+	echo "please enter a valid command.";
Added: trunk/mapbender/http/plugins/wfsConfTree.js
--- trunk/mapbender/http/plugins/wfsConfTree.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/wfsConfTree.js	2010-12-20 11:44:22 UTC (rev 7341)
@@ -0,0 +1,108 @@
+var $confTree = $(this);
+var ConfTree = function(o){
+	$confTree.children().remove();
+	$confTree.addClass('conftree');
+	var $WFSConffolder = $('<li class="open wfsconf"><button class="toggle" name="toggle" value="toggle"></button><a href="#">WFSConf</a><ul></ul></li>');
+	$confTree.append($WFSConffolder);
+	$addButton = $('<button class="add" name="addwfsconf" value="addwfsconf"></button>');
+	$addButton.click(function(){
+		$('<div ><input class="feedurl" /></div>').dialog({
+			"title": "WFSConf feed hinzufügen",
+			"buttons":{
+				"OK": function(){
+					$('#mapframe1').geowfsconf({ url: $(this).find('.feedurl').val()});
+					$(this).dialog('destroy');
+	$WFSConffolder.find("a").after($addButton);
+	var $wfsConfDialog = $("<div></div>").dialog({
+		width: 300,
+		height: 400,
+		autoOpen: false,
+		buttons:{
+			"schliessen": function(){
+					$(this).dialog("close");
+	mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString:"2,3,4,5,6"}, function(json,status){
+		aWFSConf = json;
+		console.log(aWFSConf);
+		for(var i in  aWFSConf){
+			// group by featyretype
+			$featuretypeFolder = $WFSConffolder.find("li.featuregroup_"+aWFSConf[i].featuretype_id);
+			if($featuretypeFolder.size() == 0){
+				$featuretypeFolder = $('<li class="featuregroup_"'+ aWFSConf[i].featuretype_id + '">'+ aWFSConf[i].wfs_conf_abstract + '<ul></ul></li>');
+				$WFSConffolder.find(" > ul").append($featuretypeFolder);
+				$featuretypeList = $featuretypeFolder.find("ul");
+			}else{
+			switch(aWFSConf[i].wfs_conf_type){
+					/* search */
+					case "0":
+						$wfsconfEntry = $('<li><a href="#">Suche</a></li>');
+					break;
+					/* digitize */
+					case "1":
+						$wfsconfEntry = $('<li><a href="#">Erfassung</a></li>');
+					break;
+					/* download */
+					case "2":
+						$wfsconfEntry = $('<li><a href="#">Download</a></li>');
+					break;
+			$featuretypeList.append($wfsconfEntry);
+			$wfsconfEntry.find("a").click((function(wfsConf){
+				return function(){
+				switch(wfsConf.wfs_conf_type){
+					/* search */
+					case "0":
+						var $iframe = $('<iframe style="width: 100%; height: 100%;" src="../javascripts/mod_wfsGazetteerEditor_client.php?wfsConfId='+wfsConf.wfs_conf_id +'"></iframe>');
+						$wfsConfDialog.empty();
+						$wfsConfDialog.append($iframe);
+						$wfsConfDialog.dialog("open");
+					break;
+					/* digitize */
+					case "1":
+					break;
+					/* download */
+					case "2":
+					break;
+			})(aWFSConf[i]));
+Mapbender.events.init.register(function(){
+	$confTree.mapbender(new ConfTree(options));
More information about the Mapbender_commits mailing list
