[Mapbender-commits] r7358 - trunk/mapbender
    svn_mapbender at osgeo.org
    Wed Dec 22 06:06:36 EST 2010
Author: astrid_emde
Date: 2010-12-22 03:06:36 -0800 (Wed, 22 Dec 2010)
New Revision: 7358
   trunk/mapbender/Changes.txt
tickets from 2.7 added
Modified: trunk/mapbender/Changes.txt
--- trunk/mapbender/Changes.txt	2010-12-22 11:04:06 UTC (rev 7357)
+++ trunk/mapbender/Changes.txt	2010-12-22 11:06:36 UTC (rev 7358)
@@ -6,7 +6,152 @@
 Changelog 2.7
 http://trac.osgeo.org/mapbender/report/48
+20	addWMS beim Login
+82	Problems with dynamicOverview and setBackground
+344	zebra: handle gui-categories in guilist / adminitstrate gui categories
+365	calculate new Scalehint if epsg 4326 is choosed
+389	Configurable Treefolder
+412	Copyright transfer to OSGeo
+418	Digitizing: add one-click clone button
+424	Update points instantly
+426	Allow objects and arrays in element vars
+437	Open save dialogue immediately after a geometry has been created
+438	AddWMSfromFilteredList_Ajax - added new script to handle the button
+439	treeGDE translations i18n
+447	digitizing: Nontransactional geometries are not display
+450	cannot create polygon, gml interpretation error
+478	Layers auto-checked in treeGDE initially
+481	Add WFS conf profiles
+489	Zoom in on double click
+497	arrange Element does not work with some browser
+498	gazetteerWFS send search request on load of the application
+499	gazetteerWFS - search without param selection
+501	Setting the password for a created user
+512	Resize Mapsize does not work
+517	Add WMS from tree
+518	Wrapper for session access
+519	Add customization for metadata gazetteer
+520	jQuery UI Dialog Manager
+521	toggle overview map (show/hide)
+523	Owsproxy log
+524	Transform coordinates and zoom to
+525	Coordinate lookup
+529	Featureinfo Request ignores WMS Scalehints
+533	GeoRSS feed
+534	possibility to disable mousewheel zoom
+537	Meetingpoint:  Usability improvement textfield
+541	wrong german translation for Opacity up / down
+542	map refresh should be run automatically after Opacity up / down
+544	Add FirePHP to Mapbender
+545	WFS spatial request fails if object properties contain values with linefeeds
+549	i18n provide translations (.po) for the different locales
+550	Error in feature data results when you've checked the queries only inside a WMS.
+582	setSpatialRequest - motion to add respect for scale hints for spatial request
+586	continue a previously digitized line
+587	split a line into segments with another line
+588	Allow loading jQuery from Google CDN for performance boost
+589	treeGDE - added functionality to switch layer style (menu -> change_style)
+592	Mb_myBBOX - new startup parameters mb_myBBOXEpsg and mb_myBBOXEpsg_transform
+593	resultList - new module to display results in a sortable table
+595	BBOXes for all SRS in WMS-Capabilities
+596	WFS setSpatialRequest - bug in open dialog form
+597	WFS setSpatialRequest - bug in select by polygon at high scale
+598	Bug: help-button (mod_help.php) does not work and blocks application
+599	Drop MySQL Support of installscript
+600	Drop ISO-8859-1 Support of installscript
+601	Button help not working
+602	Button addWMS
+604	update script for windows
+605	showDetail Popup
+606	install.bat
+611	resultList configure vendor specific from resultList results
+614	DetailPopup adds unzoomable highlight feature
+616	zoomBar for navigation with ui slider
+617	application name and description overlap
+631	New startup parameters visiblelayers, querylayers, visiblelayers_regexpr,querylayers_regexpr
+636	missing translation for measure tools
+637	missing translation for entries in treeGDE-Menu
+649	LoadWMC: Delete WMC gets the wrong wmc_id for deletion
+652	Categories in treeGDE are clickable
+654	zoomCoords: Does not work in IE
+655	loadwmc: Add possibility to edit wmc using savewmc
+665	Tabs not working with Firefox 3.6+
+666	Log module element vars are not accepted
+672	combine and merge polygons malfunction
+673	.ui.tabs.js not found
+675	Make layer titles editable
+676	Remove MySQL-Check
+677	Element vars disappear if application element id changes
+678	new module coordsLookup
+679	gazetteerMetadata: Keyword and metadata popup as jquery ui dialogs
+680	addWMSfromfilteredList_ajax: Open as jquery ui dialog
+681	LoadWMC: show as jquery-ui dialog
+682	AddCSW: Open in jquery-ui dialog
+683	new Mapbender logo has to be used in applications, splash, print
+684	enhance install-script
+685	resize Mapasize Button(under the Map) is missing
+686	(old fashioned )popup-replacement winows
+687	(old) print  (resize Mapframe)
+688	AddWMSFromFilteredListAjax checkboxes
+692	Customize Tree
+695	SaveWMC (overwrite)
+697	Buttons (opacity) in IE8
+698	WMC (export openLayers)
+700	WMS Metadata Link
+701	legend in gui1
+702	Display SQL of current application
+703	CustomizeTree: Draggable problem in IE
+708	Add HQ print to template print module
+712	gazetteerWFS: Enable possibility to request WFS with different srs
+713	GUI Layer styles not set correctly
+714	Close polygon disabled after panning
+716	Make snapping optional in digitizing module
+718	Non-transactional geometries are not visible during digitizing
+719	Impossible to store features in another WFS-T
+721	WFS 1.1.0 DescribeFeatureType is always done via POST
+722	WFS 1.1.0 DescribeFeatureType Response is parsed incorrectly
+726	LoadWms: Hand down all supported srs from parent layer to child layers
+727	LoadWms: Create bboxes for all supported srs
+729	gui_layer_visible of root layer is not updated if all/none sublayers are visible/querylayer
+730	Add jQuery UI CSS classes to tabs module
+731	Gazetter fails to load WFS config
+732	enhanced Metadatainformations for service and layer
+736	addWMS from filtered list - error when you want to load a WMS
+737	WFS Upload fails if a single featuretype is unavailable
+741	Resize mapsize partially defect
+742	Button wrapper
+744	OpenLayers Export über WMS - Mod_wmc2ol
+745	SearchInterface
+751	wms/wfs column fees changed TYPE to text
+397	WFS list all WFS does not list wfs_conf which are not in a gui already
+474	Split tree over several vertical tabs
+653	measure - display line from last clickpoint to mouseover-position
+674	Delete WFSConf broken
+117	Adding WMS (module AddWMS) does not automatically make added layer(s) visible
+327	handlesublayers - grouped layers - sometimes defect
+538	MeetingPoint: Text of meetingPoint hides behind navframe if it is positioned near the border of the mapframe
+471	Error when writing combined polygons to the wfs server
+530	Start application in a specific SRS
+594	KML temporary import into user interface
+623	Add image to print frame to show which side is the top side
+690	digtizing (special functons)
+691	Edit Application Elements
+22	if a feature info delivers no result, an empty frame or window appears
+167	mod_dynamicOverview: wrong calculated bbox
+302	treefolder2 - handlesublayers
+394	Logging
+434	Load WFS fails when abstract (keyword) is empty
+531	TreeGDE: Checkboxes are out of sync with map
+626	Issues with setSpatial_Request and mod_wfs.php
+689	Meeting Point
+694	Help Button in IE8
+696	measure (IE8)
+735	css change - legendimage with black shadow
+738	install-script throws error
+740	WFS gazetteer defect
+750	edit user - delete user and change user fails
 Changelog 2.6.1
More information about the Mapbender_commits
