[Mapbender-commits] r7414 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Dec 26 17:52:24 EST 2010
Author: marc
Date: 2010-12-26 14:52:24 -0800 (Sun, 26 Dec 2010)
New Revision: 7414
   trunk/mapbender/http/php/mod_wmc2ol.php
some path and whitespace corrections
Modified: trunk/mapbender/http/php/mod_wmc2ol.php
--- trunk/mapbender/http/php/mod_wmc2ol.php	2010-12-26 22:47:24 UTC (rev 7413)
+++ trunk/mapbender/http/php/mod_wmc2ol.php	2010-12-26 22:52:24 UTC (rev 7414)
@@ -39,11 +39,11 @@
 if (isset($_REQUEST["wmc_id"]) & $_REQUEST["wmc_id"] != "") {
 	//validate to csv integer list
 	$testMatch = $_REQUEST["wmc_id"];
-	$pattern = '/^[0-9_]*$/';
- 	if (!preg_match($pattern,$testMatch)){
+	$pattern = '/^[0-9_]*$/';
+	if (!preg_match($pattern,$testMatch)){
 		echo 'wmc_id: <b>'.$testMatch.'</b> is not valid.<br/>';
 		die();
 	$wmc_id = $testMatch;
 	$testMatch = NULL;
@@ -53,17 +53,17 @@
 //dummy parameter for drawing georss points:
-$pointRadius = "10";
+$pointRadius = "10";
 $fillColor = "#666666"; //grey
 if (isset($_REQUEST["pointRadius"]) & $_REQUEST["pointRadius"] != "") {
 	$testMatch = $_REQUEST["pointRadius"];
 	$pattern = '/^[0-9]{2}|^[1-9]{1}$/';
 		echo 'pointRadius: <b>'.$testMatch.'</b> is not valid.<br/>';
-		die();
+		die();
 	$pointRadius = $testMatch;
 	$testMatch = NULL;
@@ -72,10 +72,10 @@
 if (isset($_REQUEST["fillColor"]) & $_REQUEST["fillColor"] != "") {
 	$testMatch = $_REQUEST["fillColor"];
-	$pattern = '/^#[0-9a-f]{3}|#[0-9a-f]{6}$/';
+	$pattern = '/^#[0-9a-f]{3}|#[0-9a-f]{6}$/';
 		echo 'fillColor: <b>'.$testMatch.'</b> is not valid.<br/>';
-		die();
+		die();
 	$fillColor = $testMatch;
 	$testMatch = NULL;
@@ -84,10 +84,10 @@
 if (isset($_REQUEST["markerUrl"]) & $_REQUEST["markerUrl"] != "") {
 	$testMatch = $_REQUEST["markerUrl"];
-	$pattern = '/^[\d,]*$/';
+	$pattern = '/^[\d,]*$/';
 		echo 'markerUrl: <b>'.$testMatch.'</b> is not valid.<br/>';
-		die();
+		die();
 	$testMatch = NULL;
@@ -184,7 +184,7 @@
 	//Read out WMC into XML object
 	$xml=simplexml_load_string($wmc[0], "SimpleXMLElement", LIBXML_NOBLANKS);
 	if ($_REQUEST['withoutBody'] == '1') {
 	} else {
 		//generate general html data
 		$html='';
@@ -197,21 +197,20 @@
 	$htmlWidth=$windowWidth+40;
 	$htmlHeight=$windowHeight+70;
 	//define CSS
-   	$html.="<style type='text/css'>\n";
-        $html.=" #map {\n";
-        	$html.="width: ".$windowWidth."px;\n";
-        	$html.="height: ".$windowHeight."px;\n";
-        	$html.="border: 1px solid black;\n";
-		$html.="overflow:visible;\n";
-        $html.="}\n";
+	$html.="<style type='text/css'>\n";
+	$html.=" #map {\n";$html.="width: ".$windowWidth."px;\n";
+	$html.="height: ".$windowHeight."px;\n";
+	$html.="border: 1px solid black;\n";
+	$html.="overflow:visible;\n";
+	$html.="}\n";
 	$html.=" #srs {\n";
-	        $html.="font-size: 80%;\n";
-	        $html.="color: #444;\n";
-	        $html.="}\n";
+	$html.="font-size: 80%;\n";
+	$html.="color: #444;\n";
+	$html.="}\n";
 	$html.=" #showpos {\n";
-	        $html.="}\n";
+	$html.="}\n";
 	$html.="</style>\n";
 	//don't show any html, title and/or body tag when integrate it into external website
@@ -223,13 +222,13 @@
 	$e = new mb_exception('georss request : '.$_REQUEST['GEORSS']);
 	if(isset($_REQUEST["withDigitize"]) or isset($_REQUEST["GEORSS"])){
 		if(($_REQUEST["withDigitize"]=='1') or ($_REQUEST["GEORSS"]!='')){
-			$html.="<script src='http://".$_SERVER['HTTP_HOST']."/mapbender/extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
-			#$html.="<script src='../../openlayers/OpenLayers.js'></script>\n";
+			#$html.="<script src='http://".$_SERVER['HTTP_HOST']."/mapbender/extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
+			$html.="<script src='../extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
 	} else {
 		//use the minimized version
 		//$html.="<script src='../../openlayers/build/geoportal_ol_geoportal.js'></script>\n";
-		$html.="<script src='http://".$_SERVER['HTTP_HOST']."/mapbender/extensions/OpenLayers-2.8/OpenLayers.js'></script>\n"; //TODO minimize this or use other lib
+		$html.="<script src='../extensions/OpenLayers-2.8/OpenLayers.js'></script>\n"; //TODO minimize this or use other lib
 	//begin part for javascript code
 	$html.="<script type='text/javascript'>\n";
@@ -272,11 +271,11 @@
 	$numberZoomLevels=20;
 	//define central position in projected system
 	$html.="var lat = $centralx;\n";
-       	$html.="var lon = $centraly;\n";
+	$html.="var lon = $centraly;\n";
 	$centralPointx=($maxx+$minx)/2;
 	$centralPointy=($maxy+$miny)/2;
 	//startzoom faktor - check if usefull
-     	$html.="var zoom = 10;\n";
+	$html.="var zoom = 10;\n";
 	$html.="\n";
 	//start function for initialize client
 	$html.="function initGeoportal(){\n";
@@ -284,7 +283,7 @@
 	$html.="	map = new OpenLayers.Map('map');\n";
 	//define options for ol map object
 	$html.="	var options = {\n";
-        $html.="		projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
+	$html.="		projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
 	if ($xml->General->BoundingBox['SRS']=='EPSG:4326'){
 		echo 'Please choose an other coordinatereferencesystem. Converting Scales to Geographic Coordinates is not yet implemented!';
 		return;
@@ -314,8 +313,8 @@
 					#echo "is in the codespace of the epsg registry\n";
 					} else {
 					#echo "is outside\n";
- 					echo "alert('The REQUEST parameter mb_myBBOXEpsg is not in the epsg realm - please define another EPSG Code.');";
- 					return;
+					echo "alert('The REQUEST parameter mb_myBBOXEpsg is not in the epsg realm - please define another EPSG Code.');";
+					return;
 				//Check if epsg is equal to BBOXEpsg
 				//Get epsg code out of WMC
@@ -388,11 +387,11 @@
 			$html.="		transparent: \"On\"\n";
 			$html.="		},\n";
 			$html.="		{\n";
-	             	$html.="		maxExtent: new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy."),\n";
-                        // then check map.baseLayer.resolutions[0] for
-                        // a reasonable value.
+			$html.="		maxExtent: new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy."),\n";
+			// then check map.baseLayer.resolutions[0] for
+			// a reasonable value.
-              		$html.="		units: \"m\",\n";
+			$html.="		units: \"m\",\n";
 			$html.="		numZoomLevels: ".$numberZoomLevels.",\n";
 			$minScale=dom_import_simplexml($extensions->gui_minscale)->nodeValue;
 			$maxScale=dom_import_simplexml($extensions->gui_maxscale)->nodeValue;
@@ -406,9 +405,9 @@
 			$html.="		minScale: ".$minScale.",\n";
 			$html.="		maxScale: ".$maxScale.",\n";
 			$html.="		singleTile: true\n";
-                 	//Only necessary for working with scales.
-                	$html.="	} );\n";
-          		$html.="	map.addLayer(layer0);\n";
+			//Only necessary for working with scales.
+			$html.="	} );\n";
+			$html.="	map.addLayer(layer0);\n";
 		} else {
 			echo "Guest don't have permission on Base-Layer or ".$layer_id." therefor OpenLayers client will not be generated! Check if the layer does exists any longer or if someone has removed the permission to access this service.<br>";
@@ -440,9 +439,9 @@
 			$html.="		transparent: \"TRUE\"\n";
 			$html.="		},\n";
 			$html.="		{\n";
 			$html.="		singleTile: true,\n";
 			//$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org');
@@ -457,29 +456,29 @@
 			$html.="		'isBaseLayer': false\n";
-                	$html.="	} );\n";
+			$html.="	} );\n";
 			$html.="	layer".$i.".alwaysInRange = true;\n"; //TODO: there is a problem with calculating the scale hints - therefor this is only a workaround - must be fixed!
-          		$html.="	map.addLayer(layer".$i.");\n";
+			$html.="	map.addLayer(layer".$i.");\n";
 	$html.="\n";
 	$html.="	markers.alwaysInRange = true;\n";
 	$html.="	map.addLayer(markers);\n";
 	if(isset($_REQUEST["LayerSwitcher"]) && $_REQUEST["LayerSwitcher"] == '1'){
-        	$html.="	map.addControl(new OpenLayers.Control.LayerSwitcher());\n";
+		$html.="	map.addControl(new OpenLayers.Control.LayerSwitcher());\n";
 	if(isset($_REQUEST["mb_drawCentre"])&isset($centralx)&isset($centraly)){
 		if ($_REQUEST["mb_drawCentre"]='1'){
 			$html.="	var size = new OpenLayers.Size(15,20);\n";
 			$html.="	calculateOffset = function(size) {return new OpenLayers.Pixel(-(size.w/2), -size.h); };\n";
-			$html.="	var icon = new OpenLayers.Icon('http://".$_SERVER['HTTP_HOST']."/mapbender/img/marker/red.png',size, null, calculateOffset);\n";
+			$html.="	var icon = new OpenLayers.Icon('../img/marker/red.png',size, null, calculateOffset);\n";
 			$html.="	markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(".$centralx.",".$centraly."),icon));\n";
 		else {
 			echo "alert('The REQUEST parameter mb_drawCentre is outside of its realm!');";
- 			return;
+			return;
 	//Zoom to extent of given mb_myBBOX
@@ -502,10 +501,10 @@
 	if(isset($_REQUEST["GEORSS"])){
 		if($_REQUEST["GEORSS"]!=''){
 			$html.="	var pointVectorLayer = new OpenLayers.Layer.Vector(\"Vector Layer\", {\n";
-                	$html.="		styleMap: new OpenLayers.StyleMap({\n";
-                	$html.="    			pointRadius: \"".$pointRadius."\", // based on feature.attributes.type\n";
-                 	$html.="   			fillColor: \"".$fillColor."\"\n";
-                	$html.="		})\n";
+			$html.="		styleMap: new OpenLayers.StyleMap({\n";
+			$html.="    			pointRadius: \"".$pointRadius."\", // based on feature.attributes.type\n";
+			$html.="   			fillColor: \"".$fillColor."\"\n";
+			$html.="		})\n";
 			$html.="	});\n";
 			//end of definition of the point vector layer
 			//push the features to the layer
@@ -515,9 +514,9 @@
 			//define the controls for the features in the point vector layer
 			//add the vector layer to map
 			$html.="	selectControl = new OpenLayers.Control.SelectFeature(pointVectorLayer,
-                {onSelect: onFeatureSelect, onUnselect: onFeatureUnselect});\n";
-            		$html.="	map.addControl(selectControl);\n";
-           		$html.="	selectControl.activate();  \n";
+					{onSelect: onFeatureSelect, onUnselect: onFeatureUnselect});\n";
+			$html.="	map.addControl(selectControl);\n";
+			$html.="	selectControl.activate();  \n";
@@ -528,7 +527,7 @@
 		for ($i=0; $i<count($layer_array); $i++){
 			if ($layer_array_queryable[$i]=='1'){
 				$html.="	var url".$i." =  layer".$i.".getFullRequestString({\n";
-                      		$html.="	 REQUEST: \"GetFeatureInfo\",\n";
+				$html.="	 REQUEST: \"GetFeatureInfo\",\n";
 				$html.="	 FEATURE_COUNT: \"100\",\n";
 				$html.="	 EXCEPTIONS: \"application/vnd.ogc.se_xml\",\n";
 				$html.="	 BBOX: layer".$i.".map.getExtent().toBBOX(),\n";
@@ -555,9 +554,9 @@
 		$html.="		}\n";
 		$html.="		markers.addMarker(new OpenLayers.Marker(lonlat,icon));\n";
-          	$html.="		var digX = String.substr(lonlat.lon,0,10);\n";
+		$html.="		var digX = String.substr(lonlat.lon,0,10);\n";
 		$html.="		var digY = String.substr(lonlat.lat,0,10);\n";
 		if (isset($_REQUEST['xID']) && isset($_REQUEST['yID']) && $_REQUEST['xID'] != '' && $_REQUEST['yID'] != '') {
 			$html.="		document.getElementById(\"".$_REQUEST['xID']."\").value = digX;\n";
@@ -576,25 +575,25 @@
 			$html.="function onPopupClose(evt) {\n";
-            		$html.="	selectControl.unselect(selectedFeature);\n";
-        		$html.="}\n";
+			$html.="	selectControl.unselect(selectedFeature);\n";
+			$html.="}\n";
-        		$html.="function onFeatureSelect(feature) {\n";
-           		$html.="	selectedFeature = feature;\n";
-           		$html.="	popup = new OpenLayers.Popup.FramedCloud(\"chicken\", \n";
-                        $html.="	feature.geometry.getBounds().getCenterLonLat(),
-                                     null,
-                                     \"<div class='georsstitle'>\" + feature.attributes['title'] +\"</div><br/>\"+\"<div class='georssdescription'>\" +feature.attributes['description']+\"</div><br/><div class='georsslink'><a href='\"+feature.attributes['link']+\"' target='_blank'>Weitere Informationen</a></div>\",
-                                     null, true, onPopupClose);\n";
-            		$html.="	feature.popup = popup;\n";
-            		$html.="	map.addPopup(popup);\n";
-        		$html.="}\n";
+			$html.="function onFeatureSelect(feature) {\n";
+			$html.="	selectedFeature = feature;\n";
+			$html.="	popup = new OpenLayers.Popup.FramedCloud(\"chicken\", \n";
+			$html.="	feature.geometry.getBounds().getCenterLonLat(),
+					null,
+					\"<div class='georsstitle'>\" + feature.attributes['title'] +\"</div><br/>\"+\"<div class='georssdescription'>\" +feature.attributes['description']+\"</div><br/><div class='georsslink'><a href='\"+feature.attributes['link']+\"' target='_blank'>Weitere Informationen</a></div>\",
+					null, true, onPopupClose);\n";
+			$html.="	feature.popup = popup;\n";
+			$html.="	map.addPopup(popup);\n";
+			$html.="}\n";
-        		$html.="function onFeatureUnselect(feature) {\n";
-            		$html.="	map.removePopup(feature.popup);\n";
-            		$html.="	feature.popup.destroy();\n";
-           		$html.=" 	feature.popup = null;\n";
-        		$html.="}\n";
+			$html.="function onFeatureUnselect(feature) {\n";
+			$html.="	map.removePopup(feature.popup);\n";
+			$html.="	feature.popup.destroy();\n";
+			$html.=" 	feature.popup = null;\n";
+			$html.="}\n";
 			$html.="function createFeaturesFromGeoRSS() {\n";
 			//First check if some georss is send in the request variable GEORSS
@@ -618,18 +617,18 @@
 						$gmlElements = $georssElements->children('http://www.opengis.net/gml');
 						$coords = explode(" ", $gmlElements->Point->pos);
-    						$html.="	var point = new OpenLayers.Geometry.Point(";
+						$html.="	var point = new OpenLayers.Geometry.Point(";
 						$html.="".$coords[0].",".$coords[1].");\n";
 						$html.="	pointFeatures[".$i."] = new OpenLayers.Feature.Vector(point, {title: \"".$georssXml->entry[$i]->title."\", description : \"".str_replace("\"", "'",$georssXml->entry[$i]->content)."\", link : \"".$georssXml->entry[$i]->link->attributes()->href."\"});\n";
 					$html.="	return pointFeatures;\n";
-        				$html.="}\n";
+					$html.="}\n";
 			} else {
 				if (file_exists('/tmp/georss_test_v1a.xml')) {
-    					$georssXml = simplexml_load_file('/tmp/georss_test_v1a.xml');
+					$georssXml = simplexml_load_file('/tmp/georss_test_v1a.xml');
 					$featureCount = 0;
 					foreach ($georssXml->entry as $item){
 						$featureCount++;
@@ -642,26 +641,26 @@
 					//***Generate Dummy Point for testing
 					$html.="	var point = new OpenLayers.Geometry.Point(2594468.92,5530693.03);\n";
-                			$html.="	pointFeatures[".$featureCount."] = new OpenLayers.Feature.Vector(point, {description : \"Testbeschreibung\", link : \"Testlink\"});\n";
+					$html.="	pointFeatures[".$featureCount."] = new OpenLayers.Feature.Vector(point, {description : \"Testbeschreibung\", link : \"Testlink\"});\n";
-           				$html.="	return pointFeatures;\n";
-        				$html.="}\n";
+					$html.="	return pointFeatures;\n";
+					$html.="}\n";
 				} else {
-   					$html.="	alert('No GeoRSS found - use only dummy point!');\n";
+					$html.="	alert('No GeoRSS found - use only dummy point!');\n";
-                			$html.="	var pointFeature = new OpenLayers.Feature.Vector(point, {description : \"Testbeschreibung\", link : \"Testlink\"});\n";
-           				$html.="	return pointFeature;\n";
-        				$html.="}\n";
+					$html.="	var pointFeature = new OpenLayers.Feature.Vector(point, {description : \"Testbeschreibung\", link : \"Testlink\"});\n";
+					$html.="	return pointFeature;\n";
+					$html.="}\n";
 			//TODO: validate the content of the XML
 			//pull out the relevant content: name, id, description
 			//filter out javascript content!
@@ -670,27 +669,28 @@
 	//end of javascripting part
- 	$html.="</script>\n";
+	$html.="</script>\n";
 	} else {
- 		$html.=" </head>\n";
-  		$html.="<body onload='initGeoportal()'>\n";
+		$html.=" </head>\n";
+		$html.="<body onload='initGeoportal()'>\n";
-    	$html.="<div id='tags'></div>\n";
-   	$html.="<div id='map' class='smallmap'></div>\n";//class dont exists
+		$html.="<div id='tags'></div>\n";
+		$html.="<div id='map' class='smallmap'></div>\n";//class dont exists
 	//show textareas with coordinates which are digitized
 	if(isset($_REQUEST["withDebug"])){
 		if($_REQUEST["withDebug"]=='1'){
-			$html.="<input type=\"textarea\" name=\"xCoord\" value=\"0\" id=\"xCoord\"/>\n";
-			$html.="<input type=\"textarea\" name=\"yCoord\" value=\"0\" id=\"yCoord\"/>\n";
+			$html.="<input type=\"textarea\" name=\"xCoord\" value=\"0\" id=\"xCoord\"/>\n";
+			$html.="<input type=\"textarea\" name=\"yCoord\" value=\"0\" id=\"yCoord\"/>\n";
 	//echo "<a href = 'http://www.geoportal.rlp.de' target='_blank'> <img src = '".$_SERVER['HTTP_HOST']."/mapbender/img/geoportal_rlp.png' title=\"GeoPortal Rheinland-Pfalz\" border=0></a>";
-    	$html.="<div id='docs'>\n";
-     	$html.="\n";
-    	$html.="</div>\n";
+		$html.="<div id='docs'>\n";
+		$html.="\n";
+		$html.="</div>\n";
 	//Show coords if wished
 	if($_REQUEST["mb_showCoords"]=='1'){
 		//$html.="<div id='srs' class='csrs'>Koordinaten in <a href = '../../../mediawiki/index.php/".$xml->General->BoundingBox['SRS']."' target='_blank'>".$xml->General->BoundingBox['SRS']."</a>:</div>\n"; //only for geoportal.rlp
@@ -701,7 +701,7 @@
 	} else {
-  		$html.="</body>\n";
+		$html.="</body>\n";
 		$html.="</html>\n";
 	//Print out HTML code
More information about the Mapbender_commits mailing list
