[Mapbender-commits] r5574 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Feb 20 10:02:40 EST 2010
Author: christoph
Date: 2010-02-20 10:02:40 -0500 (Sat, 20 Feb 2010)
New Revision: 5574
   trunk/mapbender/http/plugins/mb_cookie.js
   trunk/mapbender/http/plugins/mb_twitter.php
   trunk/mapbender/http/plugins/mb_twitter_signin.js
Modified: trunk/mapbender/http/plugins/mb_cookie.js
--- trunk/mapbender/http/plugins/mb_cookie.js	2010-02-20 14:57:13 UTC (rev 5573)
+++ trunk/mapbender/http/plugins/mb_cookie.js	2010-02-20 15:02:40 UTC (rev 5574)
@@ -60,7 +60,9 @@
 		cookieExists = true;
 		var storedMapState = $.parseJSON('(' + cookieData[i].replace(cookieName + '=','') + ')');
+		if (!storedMapState) {
+			return;
 		currentMapState.epsg   = storedMapState.epsg;
 		var currentWmsLayers = [];
Modified: trunk/mapbender/http/plugins/mb_twitter.php
--- trunk/mapbender/http/plugins/mb_twitter.php	2010-02-20 14:57:13 UTC (rev 5573)
+++ trunk/mapbender/http/plugins/mb_twitter.php	2010-02-20 15:02:40 UTC (rev 5574)
@@ -23,17 +23,45 @@
 	$ajaxResponse->send();
+function isSignedIn ($token = null) {
+	global $Twitter;
+	if (!is_null($token)) {
+		try {
+			$Twitter->setToken($token);
+			$accessToken = $Twitter->getAccessToken();
+			Mapbender::session()->set("twitter_token", $accessToken->oauth_token);
+			Mapbender::session()->set("twitter_token_secret", $accessToken->oauth_token_secret);
+		catch (Exception $e) {
+			Mapbender::session()->delete("twitter_token");
+			Mapbender::session()->delete("twitter_token_secret");
+			return false;
+	if (Mapbender::session()->exists("twitter_token") && Mapbender::session()->exists("twitter_token_secret")) {
+			Mapbender::session()->exists("twitter_token"),
+			Mapbender::session()->exists("twitter_token_secret")
+		return true;
+	return false;
 $Twitter = new EpiTwitter($consumerKey, $consumerSecret);
 switch ($ajaxResponse->getMethod()) {
 	case "isSignedIn" :
 		$token = $ajaxResponse->getParameter("token");
-		if (!is_null($token)) {
-			$ajaxResponse->setSuccess(true);
+		if (isSignedIn($token)) {
 			$ajaxResponse->setResult(array("signedIn" => true));
 			$ajaxResponse->setMessage(_mb("Signed in."));
 		$ajaxResponse->setResult(array("signedIn" => false));
 		$ajaxResponse->setMessage(_mb("Not signed in."));
@@ -55,20 +83,21 @@
 		break;
 	case "signout" :
-		try {
-			$url = $Twitter->getAuthenticateUrl();
-		catch (Exception $e) {
-			$ajaxResponse->setSuccess(false);
-			$ajaxResponse->setMessage(_mb("Could not connect to Twitter."));
-			$ajaxResponse->send();
-		$ajaxResponse->setResult(array("url" => $url));
+		$ajaxResponse->setResult(array("signedOut" => true));
+		$ajaxResponse->setMessage(_mb("Signed out."));
 		break;
 	case "update":
+		if (!isSignedId()) {
+			$ajaxResponse->setResult(array("signedIn" => false));
+			$ajaxResponse->setMessage(_mb("Not signed in."));
+			$ajaxResponse->setSuccess(true);
+			$ajaxResponse->send();
 		$status = $ajaxResponse->getParameter("status");
 		$lat = $ajaxResponse->getParameter("lat");
Modified: trunk/mapbender/http/plugins/mb_twitter_signin.js
--- trunk/mapbender/http/plugins/mb_twitter_signin.js	2010-02-20 14:57:13 UTC (rev 5573)
+++ trunk/mapbender/http/plugins/mb_twitter_signin.js	2010-02-20 15:02:40 UTC (rev 5574)
@@ -44,57 +44,65 @@
 var $this = $(this);
-$this.mapbender({
-	signedIn: false
+var originalI18nObject = {
+	"logIn" : "Log in at Twitter",
+	"logOut" : "Log out at Twitter"
-var getOauthToken = function () {
-	var getString = document.location.search.substr(1,document.location.search.length);
-	if (getString === '') {
-		return null;
+var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
-	var gArr = getString.split('&');
-	for (i = 0; i < gArr.length; ++i) {
-		var v = '';
-		vArr = gArr[i].split('=');
-        	if (vArr.length > 1) {
-			v = vArr[1];
-		var key = unescape(vArr[0]);
-		if (key === "oauth_token") {
-			return unescape(v);
-	return null;
+var TwitterSignin = function (options) {
+	this.isSignedIn = function () {
+		var req = new Mapbender.Ajax.Request({
+			url: "../plugins/mb_twitter.php",
+			method: "isSignedIn",
+			parameters: {
+				token: getOauthToken()
+			callback: function (obj, result, message) {
+				if (!result) {
+					alert(message);
+					$this.text(translatedI18nObject.logIn);
+					return;
+				if (obj.signedIn) {
+					alert(message);
+					$this.text(translatedI18nObject.logOut);
+				$this.mapbender("signedIn", obj.signedIn);
+		req.send();
+	this.signedIn = false;
-Mapbender.events.init.register(function () {
-	// check if signed in
-	var req = new Mapbender.Ajax.Request({
-		url: "../plugins/mb_twitter.php",
-		method: "isSignedIn",
-		parameters: {
-			token: getOauthToken()
-		callback: function (obj, result, message) {
-			if (!result) {
-				alert(message);
-				return;
+	var getOauthToken = function () {
+		var getString = document.location.search.substr(1,document.location.search.length);
+		if (getString === '') {
+			return null;
+		var gArr = getString.split('&');
+		for (i = 0; i < gArr.length; ++i) {
+			var v = '';
+			vArr = gArr[i].split('=');
+	        	if (vArr.length > 1) {
+				v = vArr[1];
-			if (obj.signedIn) {
-				alert(message);
+			var key = unescape(vArr[0]);
+			if (key === "oauth_token") {
+				return unescape(v);
-			$this.mapbender("signedIn", obj.signedIn);
-			alert($this.mapbender("signedIn"));
-	req.send();
+		return null;
 	$this.click(function () {
 			method: "signin",
@@ -111,5 +119,32 @@
 		req.send();
+$this.mapbender(new TwitterSignin());
+Mapbender.events.init.register(function () {
+	// check if signed in
+	$this.mapbender(function () {
+		this.isSignedIn();
+	Mapbender.events.localize.register(function () {
+		Mapbender.modules.i18n.queue(options.id, originalI18nObj, function (translatedObj) {
+			if (typeof translatedObj !== "object") {
+				return;
+			translatedI18nObj = translatedObj;
+			try {
+			catch (exc) {
+				new Mb_warning("Error when translating: " . exc.message);
\ No newline at end of file
More information about the Mapbender_commits mailing list
