[Mapbender-commits] r5592 - trunk/mapbender
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Feb 20 17:15:13 EST 2010
Author: astrid_emde
Date: 2010-02-20 17:15:10 -0500 (Sat, 20 Feb 2010)
New Revision: 5592
   trunk/mapbender/Changes.txt
text changes for 2.7 and resolved tickets added
Modified: trunk/mapbender/Changes.txt
--- trunk/mapbender/Changes.txt	2010-02-20 22:13:52 UTC (rev 5591)
+++ trunk/mapbender/Changes.txt	2010-02-20 22:15:10 UTC (rev 5592)
@@ -1,21 +1,172 @@
-The following Link gives a review on the changes in Mapbender you can get in the WIKI
+You can get an overview on the changes in Mapbender from the Version History:
 http://www.mapbender.org/index.php/Version_History
-Also have a look in the trac for detailed informations:
-http://trac.osgeo.org/mapbender/query?status=closed&milestone=2.5.1+release
+The mapbender trac provides different reports. The reports give detailed information about the enhancements
-Changelog 2.6
+Changelog 2.7
+http://trac.osgeo.org/mapbender/report/48
-see
-http://trac.osgeo.org/mapbender/query?status=closed&group=type&milestone=2.6+release&order=priority
+Changelog 2.6.1
+http://trac.osgeo.org/mapbender/report/51
+#543    session_write_closed called in wrong places
+#546	Allow only unique features in digitize feature list
+#528	Black background in legend PDF-output
+#548	treeGDE: Interaction between activated sublayers and WMS checkbox/folder on load
+#535	mousewheel scrolling - no zoom when the user scolls in a list treeGDE, legend, whole browser
+#554	Mapframe colored from body
+#553	resizeMapsize mode auto causes distorted map image
+#564	MeetingPoint: Highlight image disappears after map request
+#565	PrintPDF: Print temporary highlight objects
+#562	provide an update script to update the user defined applications
+#580	Meetingpoint: email Link stops at |
+#552	treeGDE - element_var openfolder does not have any effect on treeGDE
+#561	getMap-Request STYLE=undefined when Layer-name contains spaces (SLD)
+#583	Missing mod_add_SLD breaks use of mb_vendorspecific array
+#567	add Dokumentation_mapbender26_de.pdf to the next version (german Documentation)
+#568	addWMSfromfilteredList - does not add a WMS to an application
+#557	EPSG 4326: rounding in showCoords_div
+#585	mousewheel and classic zoom functions..
+#560	mysql_connect() instead mysql_dconnect() in database-mysql.php
+#581	WFS Gazetteer returns no result ("Arranging search results" message is never removed)
+#566	update wms - layer-update isn't correct
+#591    WFS mod_digitize_tab.php - error on display field entries of selected features with selectboxes
+Changelog 2.6
+http://trac.osgeo.org/mapbender/report/42
+ket	Summary
+#245	Update OSGeo Mapbender Wiki page
+#442	Wrong quotes in WFS tooltip element var SQL
+#507	MySQL / ISO translation of the update scripts
+#491	BBox out of range
+#171	Umlaute wrong in 'Add WMS from Filtered List'
+#515	IE: wrong calculated click pos when browser window has scrollbars (spatial request, digitize)
+#227	load WMS without getFeatureInfo-Request is not possible
+#242	admin tool to edit an application visually
+#257	Digitize: Saving of attributes of digitize object fails when id of attribute field is a javascript keyword
+#307	balloon style popups with popup.js
+#392	load wmc fails
+#26	Titled GUIs (new zebra)
+#54	How to compress all relevant JS files?
+#153	changing the php header (license)
+#174	Meta-Data-Search underruns security
+#203	OGC WFS 1.1 Support
+#208	copy gui
+#220	module addWMSfromfilteredList_ajax does not work with IE
+#231	Splash screen for Mapbender
+#232	add other languages .po files to release
+#236	wms capabilites load: remove duplicates in various elements
+#243	mousewheel-zomm (in/out)
+#247	Mod Pan: cursor pointer if you choose pan function
+#252	incorrect Mapview on switch background/foreground Layers
+#253	Problem with Digitize using GeoServer 1.6.3
+#267	Define NOT_PROXY_HOSTS in mapbender.conf
+#270	AddWMSfromFilteredList: Handling of added WMS (from another Gui) is not user-friendly
+#274	Digitize: Define search result style in element var text css
+#275	Digitize: Define search result style in element var text css
+#279	switchLocale_noreloead - Default-Language
+#287	Digitizing: Split and merge polygons
+#290	myMapIds is not defined
+#291	top.ie may be unreachable
+#292	i18n - .po - File
+#296	WFS Gazetteer and GeoServer 1.6.3/1.6.4
+#305	Digitizing: Polygons with holes
+#306	Digitizing: Compute difference between polygons, and create polygons with holes
+#318	Store scope along with registered functions
+#319	Mousewheel zoom not working in IE
+#323	Convert global map functions to map object methods
+#324	CURL: Request fails, URL not properly encoded
+#334	Missing argument 4 for Mapbender_point
+#335	Tooltip: Tooltip popup should disappear onmouseout
+#336	target hard wired in wfs.js
+#339	WFS Gazetteer: Configuring search fields as selectboxes or checkboxes
+#340	configure EPSG-List in mod_changeEPSG.php
+#342	Admin applications have to be initialised by init(), not mod_adminNavigation_init()
+#347	incorrect geometry parsed in GML class
+#348	Monitoring with diff-like capability
+#350	enable an event to concatenate the return values of its string output on trigger
+#355	"Remove from database" button after digitize error
+#360	replace iframes in map applications by div tags
+#363	Legend incorrect for grouped layers after add WMS
+#371	sorting WFS results with jquery
+#375	Find blog software with automail functionality
+#379	Digitize: Problems with whitespaces in formElementHtml of wfs_conf
+#381	spash screen
+#383	i18n for gazetteerWFS
+#390	tab-elements - increase the framesize onmouseover
+#391	mod_setBackground_change is not defined
+#393	Featuretype namespace not found for WFS 1.0.0
+#395	new overview div does not show the rectangle which is shown in mapframe1
+#396	WFS - update WFS
+#398	Link to Mapbender help in gui
+#399	Mapbender does not save the upload URL anymore
+#400	admin2_de - WMS GUI Einstellungen - style selectbox style and prio
+#403	.sh to add_translations to Mapbender.po
+#404	.sh to update your Mapbender.mo files
+#406	Highlight colour of WFS results
+#409	Meetingpoint produces error
+#410	Update OSGeo Logo to new version
+#411	Update portal start page wording
+#413	clearFilterButtonLabel undefined
+#414	possibly wrong comment or incomplete code
+#415	treeGDE: the declaration of an alternative css-file takes no effect
+#416	highlightPOI incompatible to map div
+#417	meeting point incompatible to map div
+#419	too many hits in gazetteer because of built-in *
+#420	Geometry edit in div tag doesn't work
+#421	navigation during digitize works but creates new basepoints
+#422	tabs wideout
+#423	WFS Configuration: Problems with German Umlaute
+#425	Allow the same JavaScript to be loaded multiple times
+#427	Mapbender copyright does not show up
+#430	scalebar is not displayed
+#435	SQL-Export of GUI elements, emty null-Values
+#445	parser error: GML3 contains GML2 syntax
+#446	add short comments to *.conf files
+#449	sticky legend hardcoded
+#452	Tooltips for Measure Buttons don´t show up
+#461	element vars of featureInfoTunnel doesn' take an effect...
+#462	Digitize: Handling of Select boxes and mandatory attribute does not work properly
+#464	WFS configuration: HTML input is not working.
+#465	WFS configuration: HTML input is not working.
+#466	Zoom To Coordinates doesn't work
+#467	Zoom To Coordinates doesn't work
+#469	Legends from Geoserver do not show up
+#473	undefined default GUI values
+#475	gazetteerWFS: Add possibility to configure the wfsInfo, wfsGeomType and removeWfsConf icons
+#477	layout in IE6/7 is broken
+#479	Overview: wms[i].objLayers[ii] is not defined
+#480	MB2.6 Installation - some guis not loading
+#482	gazetteerWFS: Add possibility to configure spatialRequestHint and progressIndicator infos
+#483	UseMap Module doesn't work.
+#488	Spatial search doesn't work
+#494	gazetteerWFS: If no params are defined as showDetail infos, don't show detailPopup
+#432	allow https connection in class connector
+#495	Measure tool's mapframe button not working in Mapbender 2.6
+#509	Problem with OWS proxy and GetFeatureinfo
+#496	tooltip Demo doesn't work
+#492	getMap Error with Intergraph WMS
+#508	PostgreSQL 8.4 does not work with pgsql_data_2.5.sql
+#510	Bug in Module "SelectMapsize"
+#514	favicon for Mapbender GUI
+#490	Digitizing doesn't work in IE 7/8
+#513	log module doesn´t work in branch-version
+#429	Print - new font LiberationSans-Regular causes error
+#472	treeGDE - incorrect WMS Status at GUI Start
+#463	titling in wfs-conf selection
+#532	class_connector: Sending http post data using curl
+#502	Querystring preperation doesn't fail nicely when a placeholder is not found
+#516	set focus on print-window and on digitize-window
+#511	Unable to delete digitized polygon
+#443	WFS 1.1.0
 Changelog 2.5.1
 374	WFS tables column size is too small
 380	missing trsid in data SQL
 28	"change personal settings" cannot be de-activated
@@ -49,4 +200,4 @@
 332	element_var and line-break leads to errors
 346	mod_editGuiWms.php - getCapabilities Request Link
 356	"update" and "delete" button after a digitize error
-313	'ZoomFull' has CloseTag img
\ No newline at end of file
+313	'ZoomFull' has CloseTag img
More information about the Mapbender_commits mailing list
