[Mapbender-commits] r5603 - in trunk/mapbender/http: javascripts plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Feb 23 07:55:35 EST 2010
Author: kmq
Date: 2010-02-23 07:55:34 -0500 (Tue, 23 Feb 2010)
New Revision: 5603
Added:
   trunk/mapbender/http/plugins/mb_resultList_DetailPopup.js
   trunk/mapbender/http/javascripts/mod_ResultList.js
moved what happens when a row in the result list is clicked into it's own function
Modified: trunk/mapbender/http/javascripts/mod_ResultList.js
--- trunk/mapbender/http/javascripts/mod_ResultList.js	2010-02-23 12:54:15 UTC (rev 5602)
+++ trunk/mapbender/http/javascripts/mod_ResultList.js	2010-02-23 12:55:34 UTC (rev 5603)
@@ -51,6 +51,9 @@
 	var popupButtons = [];
 	var me = this;
+	me.options = options;
+	me.rowclick = new Mapbender.Event();
 	this.addRowcallback = function(callback){
 		//disaabled
 		// the signature of the callback function (columns)
@@ -171,7 +174,7 @@
 	this.show = function(){
-		var resultHighlight = new Highlight(
+		me.resultHighlight = new Highlight(
 			options.target,
 			"resultListHighlight",
 			{"position":"absolute", "top":"0px", "left":"0px", "z-index":options.resultHighlightZIndex},
@@ -183,10 +186,9 @@
 			$('#'+options.id).css("display","block");
-		$('.infoPopup').dialog('close');
 			options.target,
@@ -197,74 +199,7 @@
 			(function() {
 			var row = rowNodes[rowNodeIndex];
 			$(".wfsFproperty", row).click(function(){
-// make thhis call a callback...
-				// go up to the row, which has the "modelindex" set
-				var modelIndex = $(row).data("modelindex");
-				var feature = me.model.getFeature(modelIndex);
-				if(me.detailColumns.length > 0) {
-					var infoPopupHtml = "<table>";
-					for (var columnIndex in me.detailColumns) {
-						infoPopupHtml += "<tr>";
-						infoPopupHtml += "<td>" + me.detailColumns[columnIndex].label + "</td>";
-						infoPopupHtml += "<td>" + me.model.getFeatureProperty(modelIndex, me.detailColumns[columnIndex].name)+ "</td>";
-						infoPopupHtml += "</tr>";
-					infoPopupHtml += "</table>";
-					var infoPopup = $('<div class="infoPopup"></div>');
-					infoPopup.append(infoPopupHtml);
-					buttonList = $("<ul></ul>").css("list-style-type","none");
-					for (var c in popupButtons){
-						var callback = function() {
-							var  args =  {
-								WFSConf: me.WFSConf,
-								geoJSON: feature,
-								selectedRows: me.getSelected()
-							popupButtons[c].callback.call(this,args);
-						var button = $("<li><button type='button' class='ui-state-default ui-corner-all'>"+popupButtons[c].title+"</button></li>").click(callback);
-						button.css("display","inline");
-						buttonList.append(button);
-					infoPopup.append(buttonList);
-					infoPopup.dialog({
-						title : "Details",
-						autoOpen : false,
-						draggable : true,
-						width : options.infoPopupWidth,
-						height : options.infoPopupHeight
-					infoPopup.dialog("open");
-				if (options.maxHighlightedPoints > 0 && feature.getTotalPointCount() > options.maxHighlightedPoints) {
-					feature = feature.getBBox4();
-				resultHighlight.del(feature, options.resultHighlightColor);
-				var bbox = feature.getBBox();
-				var bufferFloat = parseFloat(me.WFSConf.g_buffer);
-				var buffer = new Point(bufferFloat,bufferFloat);
-				bbox[0] = bbox[0].minus(buffer);
-				bbox[1] = bbox[1].plus(buffer);
-				//mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
-				//zoom(targetArray[0], 'true', 1.0);
-				var map = Mapbender.modules[options.target[0]];
-				map.calculateExtent(
-					new Mapbender.Extent(bbox[0], bbox[1])
-				map.setMapRequest();
-				resultHighlight.add(feature, options.resultHighlightColor);
-				resultHighlight.paint();
-			return false;
+				me.rowclick.trigger((function(){return row;})());
@@ -276,8 +211,8 @@
+				me.resultHighlight.add(feature, options.resultHighlightColor);
+				me.resultHighlight.paint();
 			}).mouseout(function () {
 				var i = $(this).data("modelindex");
 				var feature = me.model.getFeature(i);
@@ -286,8 +221,8 @@
+				me.resultHighlight.del(feature, options.resultHighlightColor);
 			// make rows selectable only when there are Global Buttons that could actually do womething with that selection
@@ -304,9 +239,7 @@
 			// set style of cursor to pointer for the result table
-			$(".wfsFproperty", row).css("cursor","pointer");
+			if(me.rowclick.getProperties().count > 0) {$(".wfsFproperty", row).css("cursor","pointer")};
@@ -338,6 +271,8 @@
 ResultGeometryList.prototype = new ResultGeometryListController(options);
 ResultGeometryList.prototype.constructor = ResultGeometryList;
 Mapbender.modules[options.id] = $.extend(
 	new ResultGeometryList(), Mapbender.modules[options.id]
Added: trunk/mapbender/http/plugins/mb_resultList_DetailPopup.js
--- trunk/mapbender/http/plugins/mb_resultList_DetailPopup.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_resultList_DetailPopup.js	2010-02-23 12:55:34 UTC (rev 5603)
@@ -0,0 +1,69 @@
+Mapbender.modules[options.target].rowclick.register(function(row){
+	var me = Mapbender.modules[options.target];
+	var modelIndex = $(row).data("modelindex");
+	var feature = me.model.getFeature(modelIndex);
+	$('.infoPopup').dialog('close');
+	if(me.detailColumns.length > 0) {
+		var infoPopupHtml = "<table>";
+		for (var columnIndex in me.detailColumns) {
+			infoPopupHtml += "<tr>";
+			infoPopupHtml += "<td>" + me.detailColumns[columnIndex].label + "</td>";
+			infoPopupHtml += "<td>" + me.model.getFeatureProperty(modelIndex, me.detailColumns[columnIndex].name)+ "</td>";
+			infoPopupHtml += "</tr>";
+		infoPopupHtml += "</table>";
+		var infoPopup = $('<div class="infoPopup"></div>');
+		infoPopup.append(infoPopupHtml);
+		buttonList = $("<ul></ul>").css("list-style-type","none");
+		for (var c in me.popupButtons){
+			var callback = function() {
+				var  args =  {
+					WFSConf: me.WFSConf,
+					geoJSON: feature,
+					selectedRows: me.getSelected()
+				me.popupButtons[c].callback.call(this,args);
+			var button = $("<li><button type='button' class='ui-state-default ui-corner-all'>"+popupButtons[c].title+"</button></li>").click(callback);
+			button.css("display","inline");
+			buttonList.append(button);
+		infoPopup.append(buttonList);
+		infoPopup.dialog({
+			title : "Details",
+			autoOpen : false,
+			draggable : true,
+			width : options.infoPopupWidth,
+			height : options.infoPopupHeight
+		infoPopup.dialog("open");
+	if (options.maxHighlightedPoints > 0 && feature.getTotalPointCount() > options.maxHighlightedPoints) {
+		feature = feature.getBBox4();
+	var bbox = feature.getBBox();
+	var bufferFloat = parseFloat(me.WFSConf.g_buffer);
+	var buffer = new Point(bufferFloat,bufferFloat);
+	bbox[0] = bbox[0].minus(buffer);
+	bbox[1] = bbox[1].plus(buffer);
+	var map = Mapbender.modules[me.options.target[0]];
+	map.calculateExtent(
+		new Mapbender.Extent(bbox[0], bbox[1])
+	map.setMapRequest();
+return false;
More information about the Mapbender_commits mailing list
