[Mapbender-commits] r5635 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Wed Feb 24 11:06:36 EST 2010
Author: christoph
Date: 2010-02-24 11:06:35 -0500 (Wed, 24 Feb 2010)
New Revision: 5635
trunk/mapbender/lib/marker.js
Modified: trunk/mapbender/lib/marker.js
--- trunk/mapbender/lib/marker.js 2010-02-24 15:54:36 UTC (rev 5634)
+++ trunk/mapbender/lib/marker.js 2010-02-24 16:06:35 UTC (rev 5635)
@@ -1,3 +1,35 @@
+ * Package: Mapbender.Marker
+ * Description:
+ * A very basic marker class. Put a (custom) marker at a given location
+ * Files:
+ * - lib/marker.js
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+ * Constructor: Mapbender.Marker
+ * Parameters:
+ * p - a <Mapbender.Point> to specify the location
+ * map - a <Mapbender.Map> on which the point is rendered
+ * options.img.url - *[optional]* a link to a custom marker image
+ * options.img.offset - *[optional]* a <Mapbender.Point> specifying the offset,
+ * default is (0,0). Usually these values are below zero because the image
+ * has to be translated to top and left
+ * options.img.width - *[optional]* use this to resize the marker image width
+ * (height must also be specified)
+ * options.img.height - *[optional]* use this to resize the marker image height
+ * (width must also be specified)
Mapbender.Marker = function (p, map) {
var options = {};
if (arguments.length > 2 && typeof arguments[2] === "object") {
@@ -48,6 +80,12 @@
h.paint();
+ * Method: remove
+ * Description:
+ * Remove the marker from the map.
this.remove = function () {
h.clean();
More information about the Mapbender_commits
