[Mapbender-commits] r5653 - in trunk/mapbender/documents/api_js: Data files/lib index javascript search
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Feb 25 05:19:41 EST 2010
Author: christoph
Date: 2010-02-25 05:19:40 -0500 (Thu, 25 Feb 2010)
New Revision: 5653
Added:
   trunk/mapbender/documents/api_js/search/FunctionsI.html
   trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
   trunk/mapbender/documents/api_js/Data/FileInfo.nd
   trunk/mapbender/documents/api_js/Data/IndexInfo.nd
   trunk/mapbender/documents/api_js/Data/SymbolTable.nd
   trunk/mapbender/documents/api_js/files/lib/basic-js.html
   trunk/mapbender/documents/api_js/files/lib/event-js.html
   trunk/mapbender/documents/api_js/index/Functions.html
   trunk/mapbender/documents/api_js/index/General.html
   trunk/mapbender/documents/api_js/index/General2.html
   trunk/mapbender/documents/api_js/javascript/searchdata.js
   trunk/mapbender/documents/api_js/search/FunctionsE.html
   trunk/mapbender/documents/api_js/search/FunctionsR.html
   trunk/mapbender/documents/api_js/search/FunctionsT.html
   trunk/mapbender/documents/api_js/search/FunctionsU.html
   trunk/mapbender/documents/api_js/search/GeneralE.html
   trunk/mapbender/documents/api_js/search/GeneralF.html
   trunk/mapbender/documents/api_js/search/GeneralI.html
   trunk/mapbender/documents/api_js/search/GeneralR.html
   trunk/mapbender/documents/api_js/search/GeneralT.html
   trunk/mapbender/documents/api_js/search/GeneralU.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/Data/FileInfo.nd	2010-02-25 10:19:40 UTC (rev 5653)
@@ -124,7 +124,7 @@
 /home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php	1262603806	0	/home/cbaudson/workspace/trunk/http/php/mod_createJSObjFromDBByWMS.php
 /home/cbaudson/workspace/trunk/http/classes/class_administration.php	1267021310	0	/home/cbaudson/workspace/trunk/http/classes/class_administration.php
 /home/cbaudson/workspace/trunk/http/javascripts/mod_saveWKT.js	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWKT.js
-/home/cbaudson/workspace/trunk/lib/event.js	1267021316	1	Event
+/home/cbaudson/workspace/trunk/lib/event.js	1267093100	1	Event
 /home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeSliderYear.js	1261043062	1	wmsTimeSliderYear
 /home/cbaudson/workspace/trunk/http/javascripts/mod_saveWmcKml.php	1246283992	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_saveWmcKml.php
 /home/cbaudson/workspace/trunk/http/php/mod_user_filteredGui.php	1246283969	0	/home/cbaudson/workspace/trunk/http/php/mod_user_filteredGui.php
@@ -549,7 +549,7 @@
 /home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SelectAll.js	1261565683	0	/home/cbaudson/workspace/trunk/http/plugins/mb_resultList_SelectAll.js
 /home/cbaudson/workspace/trunk/lib/button.js	1263903592	1	Button
 /home/cbaudson/workspace/trunk/tools/send_post.php	1246284046	0	/home/cbaudson/workspace/trunk/tools/send_post.php
-/home/cbaudson/workspace/trunk/lib/basic.js	1263995832	1	mapbender
+/home/cbaudson/workspace/trunk/lib/basic.js	1267093100	1	mapbender
 /home/cbaudson/workspace/trunk/http/plugins/jq_ui_effects.js	1264753004	1	jq_ui_effects
 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/mail.php	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/mail.php
 /home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php	1267021307	0	/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromfilteredList_ajax.php
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
Modified: trunk/mapbender/documents/api_js/Data/SymbolTable.nd
Modified: trunk/mapbender/documents/api_js/files/lib/basic-js.html
--- trunk/mapbender/documents/api_js/files/lib/basic-js.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/files/lib/basic-js.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,10 @@
-<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mapbender"></a>mapbender</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This jQuery plugin grants access to the Mapbender API from a DOM element.&nbsp; You can supply various arguments to achieve different things:</p><p>Passing no arguments will return the API object of the Mapbender element associated with the DOM element, usage</p><p>var api = $(&ldquo;#myelement&rdquo;).mapbender();</p><p>Passing an object serves as a setter: the object is the new API object associated with the DOM element, usage</p><p>$(&ldquo;#myelement&rdquo;).mapbender(new CustomApiObject());</p><p>Passing a string serves as an attribute getter.&nbsp; It returns the value of any public attribute of the API object, usage</p><p>$(&ldquo;#myelement&rdquo;).mapbender(&ldquo;aSpecificAttribute&rdquo;)</p><p>Passing a function executes the function in the scope of the API object.&nbsp; This is a shortcut to fetching the API object first, and then calling its method.&nbsp; By this, you don&rsquo;t need to check whether the API object exists, if none exists, the function is simply not executed.&nbsp; Usage</p><p>$(&ldquo;#myelement&rdquo;).mapbender(function () { // this refers to the API object!! console.log(this.options); });</p><h4 class=CHeading>Files</h4><ul><li>lib/basic.js</li></ul><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright &copy; 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license.&nbsp; <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#mapbender" >mapbender</a></td><td class=SDescription>This jQuery plugin grants access to the Mapbender API from a DOM element. </td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mapbender.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mapbender.cookiesEnables" >cookiesEnables</a></td><td class=SDescription>Checks whether cookies are enabled in the browser</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#mapbender.cloneObject" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">cloneObject</a></td><td class=SDescription>Clone an object recursively. </td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mapbender.getConjunctionChar" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">getConjunctionChar</a></td><td class=SDescription>returns the character necessary to append to a string in order to attach more GET parameters</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div id=Content><div class="CClass"><div class=CTopic id=MainTopic><h1 class=CTitle><a name="mapbender"></a>mapbender</h1><div class=CBody><h4 class=CHeading>Description</h4><p>This jQuery plugin grants access to the Mapbender API from a DOM element.&nbsp; You can supply various arguments to achieve different things:</p><p>Passing no arguments will return the API object of the Mapbender element associated with the DOM element, usage</p><blockquote><pre>var api = $(&quot;#myelement&quot;).mapbender();</pre></blockquote><p>Passing an object serves as a setter: the object is the new API object associated with the DOM element, usage</p><blockquote><pre>$(&quot;#myelement&quot;).mapbender(new CustomApiObject());</pre></blockquote><p>Passing a string serves as an attribute getter.&nbsp; It returns the value of any public attribute of the API object, usage</p><blockquote><pre>$(&quot;#myelement&quot;).mapbender(&quot;aSpecificAttribute&quot;)</pre></blockquote><p>Passing a function executes the function in the scope of the API object.&nbsp; This is a shortcut to fetching the API object first, and then calling its method.&nbsp; By this, you don&rsquo;t need to check whether the API object exists, if none exists, the function is simply not executed.&nbsp; Usage</p><blockquote><pre>$(&quot;#myelement&quot;).mapbender(function () {
+       // this refers to the API object!!
+       console.log(this.options);
+});</pre></blockquote><h4 class=CHeading>Files</h4><ul><li>lib/basic.js</li></ul><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright &copy; 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license.&nbsp; <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#mapbender" >mapbender</a></td><td class=SDescription>This jQuery plugin grants access to the Mapbender API from a DOM element. </td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#mapbender.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mapbender.cookiesEnables" >cookiesEnables</a></td><td class=SDescription>Checks whether cookies are enabled in the browser</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#mapbender.cloneObject" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">cloneObject</a></td><td class=SDescription>Clone an object recursively. </td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#mapbender.getConjunctionChar" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">getConjunctionChar</a></td><td class=SDescription>returns the character necessary to append to a string in order to attach more GET parameters</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
 <div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="mapbender.Functions"></a>Functions</h3></div></div>
Modified: trunk/mapbender/documents/api_js/files/lib/event-js.html
--- trunk/mapbender/documents/api_js/files/lib/event-js.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/files/lib/event-js.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -20,8 +20,20 @@
 // trigger the event
-eventAfterMapRequest.trigger();</pre></blockquote></div></div></div>
+eventAfterMapRequest.trigger();</pre></blockquote><h4 class=CHeading>Files</h4><ul><li>lib/event.js</li></ul><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright &copy; 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license.&nbsp; <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p><!--START_ND_SUMMARY--><div class=Summary><div class=STitle>Summary</div><div class=SBorder><table border=0 cellspacing=0 cellpadding=0 class=STable><tr class="SMain"><td class=SEntry><a href="#Event" >Event</a></td><td class=SDescription>An event. </td></tr><tr class="SGroup SIndent1"><td class=SEntry><a href="#Event.Functions" >Functions</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Event.Mapbender.Event" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')">Mapbender.<wbr>Event</a></td><td class=SDescription></td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Event.register" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')">register</a></td><td class=SDescription>A function that needs to be executed, when the event occurs, has to be registered via this function.</td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Event.unregister" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')">unregister</a></td><td class=SDescription>Exclude a previously registered function from the event permanently</td></tr><tr class="SFunction SIndent2"><td class=SEntry><a href="#Event.isRegistered" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')">isRegistered</a></td><td class=SDescription>Checks if a function is already registered with this event. </td></tr><tr class="SFunction SIndent2 SMarked"><td class=SEntry><a href="#Event.trigger" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')">trigger</a></td><td class=SDescription>This function triggers the event.</td></tr></table></div></div><!--END_ND_SUMMARY--></div></div></div>
+<div class="CGroup"><div class=CTopic><h3 class=CTitle><a name="Event.Functions"></a>Functions</h3></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Event.Mapbender.Event"></a>Mapbender.<wbr>Event</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var MapbenderEvent = Mapbender.Event = function ()</td></tr></table></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Event.register"></a>register</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.register = function(</td><td class=PParameter nowrap>aFunction,</td></tr><tr><td></td><td class=PParameter nowrap>scope</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>A function that needs to be executed, when the event occurs, has to be registered via this function.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>closure</td><td class=CDLDescription>a function (or a string for backwards compatibility) which is called (evaluated) when the trigger method is called.</td></tr><tr><td class=CDLEntry>scope</td><td class=CDLDescription><b>[optional]</b> if given, the function is not simply executed, but called with JavaScript&rsquo;s call function</td></tr></table><blockquote><pre>func.call(scope, argumentObj)</pre></blockquote></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Event.unregister"></a>unregister</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.unregister = function(</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Exclude a previously registered function from the event permanently</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>closure</td><td class=CDLDescription>a function (or a string for backwards compatibility)</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Event.isRegistered"></a>isRegistered</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.isRegistered = function (</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>Checks if a function is already registered with this event.&nbsp; This can be used to avoid duplicate registers.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>closure</td><td class=CDLDescription>a function (or a string for backwards compatibility)</td></tr></table></div></div></div>
+<div class="CFunction"><div class=CTopic><h3 class=CTitle><a name="Event.trigger"></a>trigger</h3><div class=CBody><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.trigger = function(</td><td class=PParameter nowrap>properties,</td></tr><tr><td></td><td class=PParameter nowrap>booleanOperator</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote><h4 class=CHeading>Description</h4><p>This function triggers the event.</p><h4 class=CHeading>Parameters</h4><table border=0 cellspacing=0 cellpadding=0 class=CDescriptionList><tr><td class=CDLEntry>properties</td><td class=CDLDescription>an object containing the arguments to be passed to the registered functions</td></tr><tr><td class=CDLEntry>operator</td><td class=CDLDescription><b>[optional]</b> a string that specifies how the return values of the individual registered functions shall be combined.&nbsp; Available operators are &ldquo;AND&rdquo;, &ldquo;OR&rdquo; and &ldquo;CAT&rdquo; (string concatenation).&nbsp; The default return value is the return value of the last registered function.</td></tr></table></div></div></div>
 </div><!--Content-->
@@ -36,7 +48,7 @@
 <!--START_ND_TOOLTIPS-->
-<!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var MapbenderEvent = Mapbender.Event = function ()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.register = function(</td><td class=PParameter nowrap>aFunction,</td></tr><tr><td></td><td class=PParameter nowrap>scope</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>A function that needs to be executed, when the event occurs, has to be registered via this function.</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.unregister = function(</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Exclude a previously registered function from the event permanently</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.isRegistered = function (</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Checks if a function is already registered with this event. </div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.trigger = function(</td><td class=PParameter nowrap>properties,</td></tr><tr><td></td><td class=PParameter nowrap>booleanOperator</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>This function triggers the event.</div></div><!--END_ND_TOOLTIPS-->
Modified: trunk/mapbender/documents/api_js/index/Functions.html
--- trunk/mapbender/documents/api_js/index/Functions.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/index/Functions.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; F &middot; <a href="#G">G</a> &middot; <a href="#H">H</a> &middot; I &middot; J &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Exception</a>, <span class=IParent>Exception</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>Extent</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>Map</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Marker.Mapbender.Marker" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>Marker</a>, <span class=IParent>Marker.<wbr>Mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Notice.Notice" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>Notice</a>, <span class=IParent>Notice</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/point-js.html#Point.Point" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>Point</a>, <span class=IParent>Point</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>remove</a>, <span class=IParent>Marker</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request"  class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Request.send" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.set" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Warning.Warning" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=ISymbol>Warning</a>, <span class=IParent>Warning</span></td></tr></table>
+<div id=Index><div class=IPageTitle>Function Index</div><div class=INavigationBar>$#! &middot; 0-9 &middot; <a href="#A">A</a> &middot; B &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; F &middot; <a href="#G">G</a> &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; J &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; O &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; Z</div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.Mapbender.Event" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>Event</a>, <span class=IParent>Event.<wbr>Mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>Exception</a>, <span class=IParent>Exception</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>Extent</a>, <span class=IParent>Extent</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.isRegistered" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>isRegistered</a>, <span class=IParent>Event</span></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>Map</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Marker.Mapbender.Marker" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>Marker</a>, <span class=IParent>Marker.<wbr>Mapbender</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Notice.Notice" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>Notice</a>, <span class=IParent>Notice</span></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/point-js.html#Point.Point" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>Point</a>, <span class=IParent>Point</span></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.register" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=ISymbol>register</a>, <span class=IParent>Event</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=ISymbol>remove</a>, <span class=IParent>Marker</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request"  class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Request.send" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.set" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" id=link42 onMouseOver="ShowTip(event, 'tt42', 'link42')" onMouseOut="HideTip('tt42')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.trigger" id=link43 onMouseOver="ShowTip(event, 'tt43', 'link43')" onMouseOut="HideTip('tt43')" class=ISymbol>trigger</a>, <span class=IParent>Event</span></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.unregister" id=link44 onMouseOver="ShowTip(event, 'tt44', 'link44')" onMouseOut="HideTip('tt44')" class=ISymbol>unregister</a>, <span class=IParent>Event</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link45 onMouseOver="ShowTip(event, 'tt45', 'link45')" onMouseOut="HideTip('tt45')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/exception-js.html#Warning.Warning" id=link46 onMouseOver="ShowTip(event, 'tt46', 'link46')" onMouseOut="HideTip('tt46')" class=ISymbol>Warning</a>, <span class=IParent>Warning</span></td></tr></table>
 <div class=CToolTip id="tt1"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function(</td><td class=PParameter nowrap>feature</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Feature to the Model Parameters: feature - a geoJSON featuree</div></div><div class=CToolTip id="tt2"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeature = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature to the geometry array</div></div><div class=CToolTip id="tt3"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function(</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a FeatureCollection to the Model Parameters: geoJSON - a geoJSON featureCollection</div></div><div class=CToolTip id="tt4"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addFeatureCollection = function (</td><td class=PParameter nowrap>geoJSON</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Add a feature collection to the geometry array</div></div><div class=CToolTip id="tt5"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var addFeatureCollection_callback = function(</td><td class=PParameter nowrap>featureEntryCollection</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: The callback received from the Model upon successfully adding a Feature Parameters: featureEntryCollection - an array of (index,featureCollection) tuples</div></div><div class=CToolTip id="tt6"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addGlobalButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Descriptions: adds a Button to the bottom of the resultList Parameters: buttondef: {Object} an object with five properties, &ldquo;title&rdquo;, &ldquo;type&rdquo; (either button or select)  &ldquo;classes&rdquo; (the classes the button should have), &ldquo;selectoptions&rdquo; (an array in case the type is select), &ldquo;callback&rdquo;</div></div><div class=CToolTip id="tt7"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.addPopupButton = function(</td><td class=PParameter nowrap>buttondef</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list Parameters: buttondef: {Object} an object with two properties: &ldquo;title&rdquo; and  &ldquo;callback&rdquo;, a function that gets the  feature that corresponds to the popup as it&rsquo;s argument</div></div><!--END_ND_TOOLTIPS-->
@@ -25,52 +25,56 @@
-<div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt14"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var MapbenderEvent = Mapbender.Event = function ()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt15"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt16"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt17"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt18"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt19"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt20"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt21"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt22"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt23"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt24"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.isRegistered = function (</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Checks if a function is already registered with this event. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt24"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt25"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt26"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt27"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt28"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt29"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt30"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt31"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt32"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt30"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt31"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.register = function(</td><td class=PParameter nowrap>aFunction,</td></tr><tr><td></td><td class=PParameter nowrap>scope</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>A function that needs to be executed, when the event occurs, has to be registered via this function.</div></div><div class=CToolTip id="tt32"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt36"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt37"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><div class=CToolTip id="tt40"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt40"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt42"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><div class=CToolTip id="tt43"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.trigger = function(</td><td class=PParameter nowrap>properties,</td></tr><tr><td></td><td class=PParameter nowrap>booleanOperator</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>This function triggers the event.</div></div><!--END_ND_TOOLTIPS-->
 <!--START_ND_TOOLTIPS-->
-<div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt44"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.unregister = function(</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Exclude a previously registered function from the event permanently</div></div><div class=CToolTip id="tt45"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<!--START_ND_TOOLTIPS-->
+<div class=CToolTip id="tt46"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
 </div><!--Index-->
Modified: trunk/mapbender/documents/api_js/index/General.html
--- trunk/mapbender/documents/api_js/index/General.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/index/General.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar><a href="#Symbols">$#!</a> &middot; 0-9 &middot; <a href="#A">A</a> &middot; <a href="#B">B</a> &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; <a href="#G">G</a> &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; <a href="#J">J</a> &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; <a href="#O">O</a> &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="General2.html#S">S</a> &middot; <a href="General2.html#T">T</a> &middot; <a href="General2.html#U">U</a> &middot; V &middot; <a href="General2.html#W">W</a> &middot; X &middot; Y &middot; <a href="General2.html#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="Symbols"></a>$#!</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_wms-php.html#Application_element_name" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>&lt;Application element name&gt;</a></td></tr><tr><td class=IHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>AddWmsFromTree</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.afterWfs" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>afterWfs</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.beforeInsert" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>beforeInsert</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.beforeUpdate" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>beforeUpdate</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.beforeUpdateOrInsert" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>beforeUpdateOrInsert</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/button-js.html#Button" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>changeEPSG</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.clickDelete" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>clickDelete</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.closeGeometry" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>closeGeometry</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>cookie</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>coordsLookup</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>digitize</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>doubleclickZoom</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=ISymbol>Event</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events"  class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Exception</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=IParent>Exception</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Extent</span><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>Extent</a></div></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=ISymbol>firebug_lite</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions"  class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Functions"  class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions"  class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions"  class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions"  class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Marker.Functions"  class=IParent>Marker</a><a href="../files/lib/exception-js.html#Notice.Functions"  class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions"  class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions"  class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions"  class=IParent>printPDF</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions"  class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions"  class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions"  class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions"  class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions"  class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties"  class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>gazetteerWFS</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.geometryInserted" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>geometryInserted</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link42 onMouseOver="ShowTip(event, 'tt42', 'link42')" onMouseOut="HideTip('tt42')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link43 onMouseOver="ShowTip(event, 'tt43', 'link43')" onMouseOut="HideTip('tt43')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link44 onMouseOver="ShowTip(event, 'tt44', 'link44')" onMouseOut="HideTip('tt44')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" id=link45 onMouseOver="ShowTip(event, 'tt45', 'link45')" onMouseOut="HideTip('tt45')" class=ISymbol>i18n</a></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_datatables-js.html#jq_datatables" id=link46 onMouseOver="ShowTip(event, 'tt46', 'link46')" onMouseOut="HideTip('tt46')" class=ISymbol>jq_datatables</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/jq_jgrowl-js.html#jq_jgrowl" id=link47 onMouseOver="ShowTip(event, 'tt47', 'link47')" onMouseOut="HideTip('tt47')" class=ISymbol>jq_jgrowl</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_accordion-js.html#jq_ui_accordion" id=link48 onMouseOver="ShowTip(event, 'tt48', 'link48')" onMouseOut="HideTip('tt48')" class=ISymbol>jq_ui_accordion</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>jq_ui_effects</span><div class=ISubIndex><a href="../files/http/javascripts/jq_ui_effects-php.html#jq_ui_effects" id=link49 onMouseOver="ShowTip(event, 'tt49', 'link49')" onMouseOut="HideTip('tt49')" class=IFile>http/<wbr>javascripts/<wbr>jq_ui_effects.php</a><a href="../files/http/plugins/jq_ui_effects-js.html#jq_ui_effects" id=link50 onMouseOver="ShowTip(event, 'tt49', 'link50')" onMouseOut="HideTip('tt49')" class=IFile>http/<wbr>plugins/<wbr>jq_ui_effects.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_resizable-js.html#jq_ui_resizable" id=link51 onMouseOver="ShowTip(event, 'tt50', 'link51')" onMouseOut="HideTip('tt50')" class=ISymbol>jq_ui_resizable</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/list-js.html#List" id=link52 onMouseOver="ShowTip(event, 'tt51', 'link52')" onMouseOut="HideTip('tt51')" class=ISymbol>List</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link53 onMouseOver="ShowTip(event, 'tt52', 'link53')" onMouseOut="HideTip('tt52')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" id=link54 onMouseOver="ShowTip(event, 'tt53', 'link54')" onMouseOut="HideTip('tt53')" class=ISymbol>Log</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Map</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" id=link55 onMouseOver="ShowTip(event, 'tt54', 'link55')" onMouseOut="HideTip('tt54')" class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link56 onMouseOver="ShowTip(event, 'tt55', 'link56')" onMouseOut="HideTip('tt55')" class=IParent>Map</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender" id=link57 onMouseOver="ShowTip(event, 'tt56', 'link57')" onMouseOut="HideTip('tt56')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link58 onMouseOver="ShowTip(event, 'tt57', 'link58')" onMouseOut="HideTip('tt57')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" id=link59 onMouseOver="ShowTip(event, 'tt58', 'link59')" onMouseOut="HideTip('tt58')" class=ISymbol>mapframe1</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Marker</span><div class=ISubIndex><a href="../files/lib/marker-js.html#Marker" id=link60 onMouseOver="ShowTip(event, 'tt59', 'link60')" onMouseOut="HideTip('tt59')" class=IParent>Global</a><a href="../files/lib/marker-js.html#Marker.Mapbender.Marker" id=link61 onMouseOver="ShowTip(event, 'tt60', 'link61')" onMouseOut="HideTip('tt60')" class=IParent>Marker.<wbr>Mapbender</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" id=link62 onMouseOver="ShowTip(event, 'tt61', 'link62')" onMouseOut="HideTip('tt61')" class=ISymbol>mb_navigation</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" id=link63 onMouseOver="ShowTip(event, 'tt62', 'link63')" onMouseOut="HideTip('tt62')" class=ISymbol>mb_resultList_transferToDigitize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" id=link64 onMouseOver="ShowTip(event, 'tt63', 'link64')" onMouseOut="HideTip('tt63')" class=ISymbol>mb_zoomIn</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" id=link65 onMouseOver="ShowTip(event, 'tt64', 'link65')" onMouseOut="HideTip('tt64')" class=ISymbol>mb_zoomOut</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link66 onMouseOver="ShowTip(event, 'tt65', 'link66')" onMouseOut="HideTip('tt65')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" id=link67 onMouseOver="ShowTip(event, 'tt66', 'link67')" onMouseOut="HideTip('tt66')" class=ISymbol>mousewheelZoom</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Notice</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Notice" id=link68 onMouseOver="ShowTip(event, 'tt67', 'link68')" onMouseOut="HideTip('tt67')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Notice.Notice" id=link69 onMouseOver="ShowTip(event, 'tt68', 'link69')" onMouseOut="HideTip('tt68')" class=IParent>Notice</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Notification" id=link70 onMouseOver="ShowTip(event, 'tt69', 'link70')" onMouseOut="HideTip('tt69')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol-js.html#ol" id=link71 onMouseOver="ShowTip(event, 'tt70', 'link71')" onMouseOut="HideTip('tt70')" class=ISymbol>ol</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_keyboardDefaults-js.html#ol_keyboardDefaults" id=link72 onMouseOver="ShowTip(event, 'tt71', 'link72')" onMouseOut="HideTip('tt71')" class=ISymbol>ol_keyboardDefaults</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_layerSwitch-js.html#ol_layerSwitch" id=link73 onMouseOver="ShowTip(event, 'tt72', 'link73')" onMouseOut="HideTip('tt72')" class=ISymbol>ol_layerSwitch</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_mousePosition-js.html#ol_mousePosition" id=link74 onMouseOver="ShowTip(event, 'tt73', 'link74')" onMouseOut="HideTip('tt73')" class=ISymbol>ol_mousePosition</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_overview-js.html#ol_overviewMap" id=link75 onMouseOver="ShowTip(event, 'tt74', 'link75')" onMouseOut="HideTip('tt74')" class=ISymbol>ol_overviewMap</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_panZoomBar-js.html#ol_panZoomBar" id=link76 onMouseOver="ShowTip(event, 'tt75', 'link76')" onMouseOut="HideTip('tt75')" class=ISymbol>ol_panZoomBar</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onFormReset" id=link77 onMouseOver="ShowTip(event, 'tt76', 'link77')" onMouseOut="HideTip('tt76')" class=ISymbol>onFormReset</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onWfsConfSelect" id=link78 onMouseOver="ShowTip(event, 'tt77', 'link78')" onMouseOut="HideTip('tt77')" class=ISymbol>onWfsConfSelect</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.openDialog" id=link79 onMouseOver="ShowTip(event, 'tt78', 'link79')" onMouseOut="HideTip('tt78')" class=ISymbol>openDialog</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_overview-js.html#Overview" id=link80 onMouseOver="ShowTip(event, 'tt79', 'link80')" onMouseOut="HideTip('tt79')" class=ISymbol>Overview</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_overviewToggle-js.html#overviewToggle" id=link81 onMouseOver="ShowTip(event, 'tt80', 'link81')" onMouseOut="HideTip('tt80')" class=ISymbol>overviewToggle</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Point</span><div class=ISubIndex><a href="../files/lib/point-js.html#Point" id=link82 onMouseOver="ShowTip(event, 'tt81', 'link82')" onMouseOut="HideTip('tt81')" class=IParent>Global</a><a href="../files/lib/point-js.html#Point.Point" id=link83 onMouseOver="ShowTip(event, 'tt82', 'link83')" onMouseOut="HideTip('tt82')" class=IParent>Point</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.printBox" id=link84 onMouseOver="ShowTip(event, 'tt83', 'link84')" onMouseOut="HideTip('tt83')" class=ISymbol>printBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" id=link85 onMouseOver="ShowTip(event, 'tt84', 'link85')" onMouseOut="HideTip('tt84')" class=ISymbol>printPDF</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Properties</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Ajax.Properties"  class=IParent>Ajax</a><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.Properties"  class=IParent>digitize</a><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.Properties"  class=IParent>gazetteerWFS</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Properties"  class=IParent>printPDF</a></div></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" id=link86 onMouseOver="ShowTip(event, 'tt85', 'link86')" onMouseOut="HideTip('tt85')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" id=link87 onMouseOver="ShowTip(event, 'tt86', 'link87')" onMouseOut="HideTip('tt86')" class=ISymbol>Reload</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" id=link88 onMouseOver="ShowTip(event, 'tt87', 'link88')" onMouseOut="HideTip('tt87')" class=ISymbol>remove</a>, <span class=IParent>Marker</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>repaint</span><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" id=link89 onMouseOver="ShowTip(event, 'tt88', 'link89')" onMouseOut="HideTip('tt88')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" id=link90 onMouseOver="ShowTip(event, 'tt88', 'link90')" onMouseOut="HideTip('tt88')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Request" id=link91 onMouseOver="ShowTip(event, 'tt89', 'link91')" onMouseOut="HideTip('tt89')" class=IParent>Global</a><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request"  class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" id=link92 onMouseOver="ShowTip(event, 'tt90', 'link92')" onMouseOut="HideTip('tt90')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" id=link93 onMouseOver="ShowTip(event, 'tt91', 'link93')" onMouseOut="HideTip('tt91')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" id=link94 onMouseOver="ShowTip(event, 'tt92', 'link94')" onMouseOut="HideTip('tt92')" class=ISymbol>resize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" id=link95 onMouseOver="ShowTip(event, 'tt93', 'link95')" onMouseOut="HideTip('tt93')" class=ISymbol>ResizeMapsize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js"  class=ISymbol>resultGeometryListController.js</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>ResultGeometryListModel</span><div class=ISubIndex><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" id=link96 onMouseOver="ShowTip(event, 'tt94', 'link96')" onMouseOut="HideTip('tt94')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link97 onMouseOver="ShowTip(event, 'tt95', 'link97')" onMouseOut="HideTip('tt95')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" id=link98 onMouseOver="ShowTip(event, 'tt96', 'link98')" onMouseOut="HideTip('tt96')" class=ISymbol>resultList</a></td></tr></table>
+<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar><a href="#Symbols">$#!</a> &middot; 0-9 &middot; <a href="#A">A</a> &middot; <a href="#B">B</a> &middot; <a href="#C">C</a> &middot; <a href="#D">D</a> &middot; <a href="#E">E</a> &middot; <a href="#F">F</a> &middot; <a href="#G">G</a> &middot; <a href="#H">H</a> &middot; <a href="#I">I</a> &middot; <a href="#J">J</a> &middot; K &middot; <a href="#L">L</a> &middot; <a href="#M">M</a> &middot; <a href="#N">N</a> &middot; <a href="#O">O</a> &middot; <a href="#P">P</a> &middot; Q &middot; <a href="#R">R</a> &middot; <a href="General2.html#S">S</a> &middot; <a href="General2.html#T">T</a> &middot; <a href="General2.html#U">U</a> &middot; V &middot; <a href="General2.html#W">W</a> &middot; X &middot; Y &middot; <a href="General2.html#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="Symbols"></a>$#!</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_wms-php.html#Application_element_name" id=link1 onMouseOver="ShowTip(event, 'tt1', 'link1')" onMouseOut="HideTip('tt1')" class=ISymbol>&lt;Application element name&gt;</a></td></tr><tr><td class=IHeading><a name="A"></a>A</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.actualConfig" id=link2 onMouseOver="ShowTip(event, 'tt2', 'link2')" onMouseOut="HideTip('tt2')" class=ISymbol>actualConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeature</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeature" id=link3 onMouseOver="ShowTip(event, 'tt3', 'link3')" onMouseOut="HideTip('tt3')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeature" id=link4 onMouseOver="ShowTip(event, 'tt4', 'link4')" onMouseOut="HideTip('tt4')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>addFeatureCollection</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection" id=link5 onMouseOver="ShowTip(event, 'tt5', 'link5')" onMouseOut="HideTip('tt5')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.addFeatureCollection" id=link6 onMouseOver="ShowTip(event, 'tt6', 'link6')" onMouseOut="HideTip('tt6')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#addFeatureCollection_callback" id=link7 onMouseOver="ShowTip(event, 'tt7', 'link7')" onMouseOut="HideTip('tt7')" class=ISymbol>addFeatureCollection_callback</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addGlobalButton" id=link8 onMouseOver="ShowTip(event, 'tt8', 'link8')" onMouseOut="HideTip('tt8')" class=ISymbol>addGlobalButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.addPopupButton" id=link9 onMouseOver="ShowTip(event, 'tt9', 'link9')" onMouseOut="HideTip('tt9')" class=ISymbol>addPopupButton</a>, <span class=IParent>resultList</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_addWMSfromTree-js.html#AddWmsFromTree" id=link10 onMouseOver="ShowTip(event, 'tt10', 'link10')" onMouseOut="HideTip('tt10')" class=ISymbol>AddWmsFromTree</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.afterWfs" id=link11 onMouseOver="ShowTip(event, 'tt11', 'link11')" onMouseOut="HideTip('tt11')" class=ISymbol>afterWfs</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax" id=link12 onMouseOver="ShowTip(event, 'tt12', 'link12')" onMouseOut="HideTip('tt12')" class=ISymbol>Ajax</a></td></tr><tr><td class=IHeading><a name="B"></a>B</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.beforeInsert" id=link13 onMouseOver="ShowTip(event, 'tt13', 'link13')" onMouseOut="HideTip('tt13')" class=ISymbol>beforeInsert</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.beforeUpdate" id=link14 onMouseOver="ShowTip(event, 'tt14', 'link14')" onMouseOut="HideTip('tt14')" class=ISymbol>beforeUpdate</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.beforeUpdateOrInsert" id=link15 onMouseOver="ShowTip(event, 'tt15', 'link15')" onMouseOut="HideTip('tt15')" class=ISymbol>beforeUpdateOrInsert</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/button-js.html#Button" id=link16 onMouseOver="ShowTip(event, 'tt16', 'link16')" onMouseOut="HideTip('tt16')" class=ISymbol>Button</a></td></tr><tr><td class=IHeading><a name="C"></a>C</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_changeEPSG-js.html#changeEPSG" id=link17 onMouseOver="ShowTip(event, 'tt17', 'link17')" onMouseOut="HideTip('tt17')" class=ISymbol>changeEPSG</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.clickDelete" id=link18 onMouseOver="ShowTip(event, 'tt18', 'link18')" onMouseOut="HideTip('tt18')" class=ISymbol>clickDelete</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cloneObject" id=link19 onMouseOver="ShowTip(event, 'tt19', 'link19')" onMouseOut="HideTip('tt19')" class=ISymbol>cloneObject</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.closeGeometry" id=link20 onMouseOver="ShowTip(event, 'tt20', 'link20')" onMouseOut="HideTip('tt20')" class=ISymbol>closeGeometry</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_cookie-js.html#cookie" id=link21 onMouseOver="ShowTip(event, 'tt21', 'link21')" onMouseOut="HideTip('tt21')" class=ISymbol>cookie</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.cookiesEnables" id=link22 onMouseOver="ShowTip(event, 'tt22', 'link22')" onMouseOut="HideTip('tt22')" class=ISymbol>cookiesEnables</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_coordsLookup-js.html#coordsLookup" id=link23 onMouseOver="ShowTip(event, 'tt23', 'link23')" onMouseOut="HideTip('tt23')" class=ISymbol>coordsLookup</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.createPrintBox" id=link24 onMouseOver="ShowTip(event, 'tt24', 'link24')" onMouseOut="HideTip('tt24')" class=ISymbol>createPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="D"></a>D</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeature" id=link25 onMouseOver="ShowTip(event, 'tt25', 'link25')" onMouseOut="HideTip('tt25')" class=ISymbol>deleteFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.deleteFeatureCollection" id=link26 onMouseOver="ShowTip(event, 'tt26', 'link26')" onMouseOut="HideTip('tt26')" class=ISymbol>deleteFeatureCollection</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.destroyPrintBox" id=link27 onMouseOver="ShowTip(event, 'tt27', 'link27')" onMouseOut="HideTip('tt27')" class=ISymbol>destroyPrintBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize" id=link28 onMouseOver="ShowTip(event, 'tt28', 'link28')" onMouseOut="HideTip('tt28')" class=ISymbol>digitize</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_doubleclickZoom-js.html#doubleclickZoom" id=link29 onMouseOver="ShowTip(event, 'tt29', 'link29')" onMouseOut="HideTip('tt29')" class=ISymbol>doubleclickZoom</a></td></tr><tr><td class=IHeading><a name="E"></a>E</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Event</span><div class=ISubIndex><a href="../files/lib/event-js.html#Event" id=link30 onMouseOver="ShowTip(event, 'tt30', 'link30')" onMouseOut="HideTip('tt30')" class=IParent>Global</a><a href="../files/lib/event-js.html#Event.Mapbender.Event" id=link31 onMouseOver="ShowTip(event, 'tt31', 'link31')" onMouseOut="HideTip('tt31')" class=IParent>Event.<wbr>Mapbender</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events"  class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Exception</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" id=link32 onMouseOver="ShowTip(event, 'tt32', 'link32')" onMouseOut="HideTip('tt32')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" id=link33 onMouseOver="ShowTip(event, 'tt33', 'link33')" onMouseOut="HideTip('tt33')" class=IParent>Exception</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Extent</span><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" id=link34 onMouseOver="ShowTip(event, 'tt34', 'link34')" onMouseOut="HideTip('tt34')" class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" id=link35 onMouseOver="ShowTip(event, 'tt35', 'link35')" onMouseOut="HideTip('tt35')" class=IParent>Extent</a></div></td></tr><tr><td class=IHeading><a name="F"></a>F</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" id=link36 onMouseOver="ShowTip(event, 'tt36', 'link36')" onMouseOut="HideTip('tt36')" class=ISymbol>firebug_lite</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Functions</span><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions"  class=IParent>Global</a><a href="../files/lib/event-js.html#Event.Functions"  class=IParent>Event</a><a href="../files/lib/exception-js.html#Exception.Functions"  class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions"  class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions"  class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions"  class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Marker.Functions"  class=IParent>Marker</a><a href="../files/lib/exception-js.html#Notice.Functions"  class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions"  class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions"  class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions"  class=IParent>printPDF</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions"  class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions"  class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions"  class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions"  class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions"  class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties"  class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="G"></a>G</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS" id=link37 onMouseOver="ShowTip(event, 'tt37', 'link37')" onMouseOut="HideTip('tt37')" class=ISymbol>gazetteerWFS</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.geometryInserted" id=link38 onMouseOver="ShowTip(event, 'tt38', 'link38')" onMouseOut="HideTip('tt38')" class=ISymbol>geometryInserted</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender.getConjunctionChar" id=link39 onMouseOver="ShowTip(event, 'tt39', 'link39')" onMouseOut="HideTip('tt39')" class=ISymbol>getConjunctionChar</a>, <span class=IParent>mapbender</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeature" id=link40 onMouseOver="ShowTip(event, 'tt40', 'link40')" onMouseOut="HideTip('tt40')" class=ISymbol>getFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.getFeatureProperty" id=link41 onMouseOver="ShowTip(event, 'tt41', 'link41')" onMouseOut="HideTip('tt41')" class=ISymbol>getFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.getPDFMapSize" id=link42 onMouseOver="ShowTip(event, 'tt42', 'link42')" onMouseOut="HideTip('tt42')" class=ISymbol>getPDFMapSize</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.getSelected" id=link43 onMouseOver="ShowTip(event, 'tt43', 'link43')" onMouseOut="HideTip('tt43')" class=ISymbol>getSelected</a>, <span class=IParent>resultList</span></td></tr><tr><td class=IHeading><a name="H"></a>H</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.hide" id=link44 onMouseOver="ShowTip(event, 'tt44', 'link44')" onMouseOut="HideTip('tt44')" class=ISymbol>hide</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.hookForm" id=link45 onMouseOver="ShowTip(event, 'tt45', 'link45')" onMouseOut="HideTip('tt45')" class=ISymbol>hookForm</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="I"></a>I</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" id=link46 onMouseOver="ShowTip(event, 'tt46', 'link46')" onMouseOut="HideTip('tt46')" class=ISymbol>i18n</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.isRegistered" id=link47 onMouseOver="ShowTip(event, 'tt47', 'link47')" onMouseOut="HideTip('tt47')" class=ISymbol>isRegistered</a>, <span class=IParent>Event</span></td></tr><tr><td class=IHeading><a name="J"></a>J</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_datatables-js.html#jq_datatables" id=link48 onMouseOver="ShowTip(event, 'tt48', 'link48')" onMouseOut="HideTip('tt48')" class=ISymbol>jq_datatables</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/jq_jgrowl-js.html#jq_jgrowl" id=link49 onMouseOver="ShowTip(event, 'tt49', 'link49')" onMouseOut="HideTip('tt49')" class=ISymbol>jq_jgrowl</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_accordion-js.html#jq_ui_accordion" id=link50 onMouseOver="ShowTip(event, 'tt50', 'link50')" onMouseOut="HideTip('tt50')" class=ISymbol>jq_ui_accordion</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>jq_ui_effects</span><div class=ISubIndex><a href="../files/http/javascripts/jq_ui_effects-php.html#jq_ui_effects" id=link51 onMouseOver="ShowTip(event, 'tt51', 'link51')" onMouseOut="HideTip('tt51')" class=IFile>http/<wbr>javascripts/<wbr>jq_ui_effects.php</a><a href="../files/http/plugins/jq_ui_effects-js.html#jq_ui_effects" id=link52 onMouseOver="ShowTip(event, 'tt51', 'link52')" onMouseOut="HideTip('tt51')" class=IFile>http/<wbr>plugins/<wbr>jq_ui_effects.js</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/jq_ui_resizable-js.html#jq_ui_resizable" id=link53 onMouseOver="ShowTip(event, 'tt52', 'link53')" onMouseOut="HideTip('tt52')" class=ISymbol>jq_ui_resizable</a></td></tr><tr><td class=IHeading><a name="L"></a>L</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/list-js.html#List" id=link54 onMouseOver="ShowTip(event, 'tt53', 'link54')" onMouseOut="HideTip('tt53')" class=ISymbol>List</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.loadConfig" id=link55 onMouseOver="ShowTip(event, 'tt54', 'link55')" onMouseOut="HideTip('tt54')" class=ISymbol>loadConfig</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_log-js.html#Log" id=link56 onMouseOver="ShowTip(event, 'tt55', 'link56')" onMouseOut="HideTip('tt55')" class=ISymbol>Log</a></td></tr><tr><td class=IHeading><a name="M"></a>M</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Map</span><div class=ISubIndex><a href="../files/http/javascripts/map_obj-js.html#Map" id=link57 onMouseOver="ShowTip(event, 'tt56', 'link57')" onMouseOut="HideTip('tt56')" class=IParent>Global</a><a href="../files/http/javascripts/map_obj-js.html#Map.Map" id=link58 onMouseOver="ShowTip(event, 'tt57', 'link58')" onMouseOut="HideTip('tt57')" class=IParent>Map</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/basic-js.html#mapbender" id=link59 onMouseOver="ShowTip(event, 'tt58', 'link59')" onMouseOut="HideTip('tt58')" class=ISymbol>mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/core-php.html#Mapbender" id=link60 onMouseOver="ShowTip(event, 'tt59', 'link60')" onMouseOut="HideTip('tt59')" class=ISymbol>Mapbender</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_map-js.html#mapframe1" id=link61 onMouseOver="ShowTip(event, 'tt60', 'link61')" onMouseOut="HideTip('tt60')" class=ISymbol>mapframe1</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Marker</span><div class=ISubIndex><a href="../files/lib/marker-js.html#Marker" id=link62 onMouseOver="ShowTip(event, 'tt61', 'link62')" onMouseOut="HideTip('tt61')" class=IParent>Global</a><a href="../files/lib/marker-js.html#Marker.Mapbender.Marker" id=link63 onMouseOver="ShowTip(event, 'tt62', 'link63')" onMouseOut="HideTip('tt62')" class=IParent>Marker.<wbr>Mapbender</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_navigation-js.html#mb_navigation" id=link64 onMouseOver="ShowTip(event, 'tt63', 'link64')" onMouseOut="HideTip('tt63')" class=ISymbol>mb_navigation</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_resultList_transferToDigitize-js.html#mb_resultList_transferToDigitize" id=link65 onMouseOver="ShowTip(event, 'tt64', 'link65')" onMouseOut="HideTip('tt64')" class=ISymbol>mb_resultList_transferToDigitize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomIn-js.html#mb_zoomIn" id=link66 onMouseOver="ShowTip(event, 'tt65', 'link66')" onMouseOut="HideTip('tt65')" class=ISymbol>mb_zoomIn</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_zoomOut-js.html#mb_zoomOut" id=link67 onMouseOver="ShowTip(event, 'tt66', 'link67')" onMouseOut="HideTip('tt66')" class=ISymbol>mb_zoomOut</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.mod_printPDF_init" id=link68 onMouseOver="ShowTip(event, 'tt67', 'link68')" onMouseOut="HideTip('tt67')" class=ISymbol>mod_printPDF_init</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_mousewheelZoom-js.html#mousewheelZoom" id=link69 onMouseOver="ShowTip(event, 'tt68', 'link69')" onMouseOut="HideTip('tt68')" class=ISymbol>mousewheelZoom</a></td></tr><tr><td class=IHeading><a name="N"></a>N</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Notice</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Notice" id=link70 onMouseOver="ShowTip(event, 'tt69', 'link70')" onMouseOut="HideTip('tt69')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Notice.Notice" id=link71 onMouseOver="ShowTip(event, 'tt70', 'link71')" onMouseOut="HideTip('tt70')" class=IParent>Notice</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Notification" id=link72 onMouseOver="ShowTip(event, 'tt71', 'link72')" onMouseOut="HideTip('tt71')" class=ISymbol>Notification</a></td></tr><tr><td class=IHeading><a name="O"></a>O</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol-js.html#ol" id=link73 onMouseOver="ShowTip(event, 'tt72', 'link73')" onMouseOut="HideTip('tt72')" class=ISymbol>ol</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_keyboardDefaults-js.html#ol_keyboardDefaults" id=link74 onMouseOver="ShowTip(event, 'tt73', 'link74')" onMouseOut="HideTip('tt73')" class=ISymbol>ol_keyboardDefaults</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_layerSwitch-js.html#ol_layerSwitch" id=link75 onMouseOver="ShowTip(event, 'tt74', 'link75')" onMouseOut="HideTip('tt74')" class=ISymbol>ol_layerSwitch</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_mousePosition-js.html#ol_mousePosition" id=link76 onMouseOver="ShowTip(event, 'tt75', 'link76')" onMouseOut="HideTip('tt75')" class=ISymbol>ol_mousePosition</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_overview-js.html#ol_overviewMap" id=link77 onMouseOver="ShowTip(event, 'tt76', 'link77')" onMouseOut="HideTip('tt76')" class=ISymbol>ol_overviewMap</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/ol_panZoomBar-js.html#ol_panZoomBar" id=link78 onMouseOver="ShowTip(event, 'tt77', 'link78')" onMouseOut="HideTip('tt77')" class=ISymbol>ol_panZoomBar</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onFormReset" id=link79 onMouseOver="ShowTip(event, 'tt78', 'link79')" onMouseOut="HideTip('tt78')" class=ISymbol>onFormReset</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.events.onWfsConfSelect" id=link80 onMouseOver="ShowTip(event, 'tt79', 'link80')" onMouseOut="HideTip('tt79')" class=ISymbol>onWfsConfSelect</a>, <span class=IParent>gazetteerWFS.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.events.openDialog" id=link81 onMouseOver="ShowTip(event, 'tt80', 'link81')" onMouseOut="HideTip('tt80')" class=ISymbol>openDialog</a>, <span class=IParent>digitize.<wbr>events</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_overview-js.html#Overview" id=link82 onMouseOver="ShowTip(event, 'tt81', 'link82')" onMouseOut="HideTip('tt81')" class=ISymbol>Overview</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_overviewToggle-js.html#overviewToggle" id=link83 onMouseOver="ShowTip(event, 'tt82', 'link83')" onMouseOut="HideTip('tt82')" class=ISymbol>overviewToggle</a></td></tr><tr><td class=IHeading><a name="P"></a>P</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Point</span><div class=ISubIndex><a href="../files/lib/point-js.html#Point" id=link84 onMouseOver="ShowTip(event, 'tt83', 'link84')" onMouseOut="HideTip('tt83')" class=IParent>Global</a><a href="../files/lib/point-js.html#Point.Point" id=link85 onMouseOver="ShowTip(event, 'tt84', 'link85')" onMouseOut="HideTip('tt84')" class=IParent>Point</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.printBox" id=link86 onMouseOver="ShowTip(event, 'tt85', 'link86')" onMouseOut="HideTip('tt85')" class=ISymbol>printBox</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF" id=link87 onMouseOver="ShowTip(event, 'tt86', 'link87')" onMouseOut="HideTip('tt86')" class=ISymbol>printPDF</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Properties</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Ajax.Properties"  class=IParent>Ajax</a><a href="../files/http/javascripts/mod_digitize_tab-php.html#digitize.Properties"  class=IParent>digitize</a><a href="../files/http/javascripts/mod_wfs_gazetteer_client-php.html#gazetteerWFS.Properties"  class=IParent>gazetteerWFS</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Properties"  class=IParent>printPDF</a></div></td></tr><tr><td class=IHeading><a name="R"></a>R</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.register" id=link88 onMouseOver="ShowTip(event, 'tt87', 'link88')" onMouseOut="HideTip('tt87')" class=ISymbol>register</a>, <span class=IParent>Event</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" id=link89 onMouseOver="ShowTip(event, 'tt88', 'link89')" onMouseOut="HideTip('tt88')" class=ISymbol>reload</a>, <span class=IParent>Reload</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" id=link90 onMouseOver="ShowTip(event, 'tt89', 'link90')" onMouseOut="HideTip('tt89')" class=ISymbol>Reload</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" id=link91 onMouseOver="ShowTip(event, 'tt90', 'link91')" onMouseOut="HideTip('tt90')" class=ISymbol>remove</a>, <span class=IParent>Marker</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>repaint</span><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" id=link92 onMouseOver="ShowTip(event, 'tt91', 'link92')" onMouseOut="HideTip('tt91')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" id=link93 onMouseOver="ShowTip(event, 'tt91', 'link93')" onMouseOut="HideTip('tt91')" class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Request</span><div class=ISubIndex><a href="../files/lib/ajax-js.html#Request" id=link94 onMouseOver="ShowTip(event, 'tt92', 'link94')" onMouseOut="HideTip('tt92')" class=IParent>Global</a><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request"  class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" id=link95 onMouseOver="ShowTip(event, 'tt93', 'link95')" onMouseOut="HideTip('tt93')" class=IParent>Request.<wbr>Mapbender.Ajax</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" id=link96 onMouseOver="ShowTip(event, 'tt94', 'link96')" onMouseOut="HideTip('tt94')" class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" id=link97 onMouseOver="ShowTip(event, 'tt95', 'link97')" onMouseOut="HideTip('tt95')" class=ISymbol>resize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" id=link98 onMouseOver="ShowTip(event, 'tt96', 'link98')" onMouseOut="HideTip('tt96')" class=ISymbol>ResizeMapsize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js"  class=ISymbol>resultGeometryListController.js</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>ResultGeometryListModel</span><div class=ISubIndex><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" id=link99 onMouseOver="ShowTip(event, 'tt97', 'link99')" onMouseOut="HideTip('tt97')" class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" id=link100 onMouseOver="ShowTip(event, 'tt98', 'link100')" onMouseOut="HideTip('tt98')" class=IParent>ResultGeometryListModel</a></div></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" id=link101 onMouseOver="ShowTip(event, 'tt99', 'link101')" onMouseOut="HideTip('tt99')" class=ISymbol>resultList</a></td></tr></table>
 <!--START_ND_TOOLTIPS-->
 <div class=CToolTip id="tt1"><div class=CClass>A description</div></div><!--END_ND_TOOLTIPS-->
@@ -33,51 +33,51 @@
-<div class=CToolTip id="tt30"><div class=CClass>An event. </div></div><div class=CToolTip id="tt31"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt32"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt33"><div class=CClass>An extent is also known as a bounding box.</div></div><div class=CToolTip id="tt34"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt30"><div class=CClass>An event. </div></div><div class=CToolTip id="tt31"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var MapbenderEvent = Mapbender.Event = function ()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt32"><div class=CClass>Logs an exception in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt33"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Exception = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt34"><div class=CClass>An extent is also known as a bounding box.</div></div><div class=CToolTip id="tt35"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Extent = function (</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt35"><div class=CClass>Simply includes the Firebug lite JavaScript and CSS</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt36"><div class=CClass>Simply includes the Firebug lite JavaScript and CSS</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt36"><div class=CClass>A WFS gazetteer for pre configured WFS configurations.</div></div><div class=CToolTip id="tt37"><div class=CProperty>This Mapbender.Event is fired after a feature has been inserted by WFS-T</div></div><div class=CToolTip id="tt38"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt40"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt42"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt37"><div class=CClass>A WFS gazetteer for pre configured WFS configurations.</div></div><div class=CToolTip id="tt38"><div class=CProperty>This Mapbender.Event is fired after a feature has been inserted by WFS-T</div></div><div class=CToolTip id="tt39"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.getConjunctionChar = function (</td><td class=PParameter nowrap>url</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>returns the character necessary to append to a string in order to attach more GET parameters</div></div><div class=CToolTip id="tt40"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeature = function (</td><td class=PParameter nowrap>index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a feature in the geometry array</div></div><div class=CToolTip id="tt41"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.getFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Get a property of a feature in the geometry array</div></div><div class=CToolTip id="tt42"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var getPDFMapSize = function (</td><td class=PParameter nowrap>key</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>checks the actual config for the size w/h values.</div></div><div class=CToolTip id="tt43"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.getSelected = function()</td></tr></table></blockquote>Description: gets all rows from the datatable which are selected Returns: an an array of DOMTableRow</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt43"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt44"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt44"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.hide = function (</td><td class=PParameter nowrap>nodeId</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Hides the sandclock</div></div><div class=CToolTip id="tt45"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var hookForm = function ()</td></tr></table></blockquote>utility method to connect the form plugin to the print form.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt45"><div class=CClass>Internationalization module, collects data from all elements and sends them to the server in a single POST request. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt46"><div class=CClass>Internationalization module, collects data from all elements and sends them to the server in a single POST request. </div></div><div class=CToolTip id="tt47"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.isRegistered = function (</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Checks if a function is already registered with this event. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt46"><div class=CClass>Includes the jQuery plugin datatables, use like this</div></div><div class=CToolTip id="tt47"><div class=CClass>The container for the jQuery plugin jGrowl</div></div><div class=CToolTip id="tt48"><div class=CClass>Accordion from the jQuery UI framework</div></div><div class=CToolTip id="tt49"><div class=CClass>A collection of jQuery UI effects</div></div><div class=CToolTip id="tt50"><div class=CClass>Resizable from the jQuery UI framework</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt48"><div class=CClass>Includes the jQuery plugin datatables, use like this</div></div><div class=CToolTip id="tt49"><div class=CClass>The container for the jQuery plugin jGrowl</div></div><div class=CToolTip id="tt50"><div class=CClass>Accordion from the jQuery UI framework</div></div><div class=CToolTip id="tt51"><div class=CClass>A collection of jQuery UI effects</div></div><div class=CToolTip id="tt52"><div class=CClass>Resizable from the jQuery UI framework</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt51"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><div class=CToolTip id="tt52"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><div class=CToolTip id="tt53"><div class=CClass>Logs the accesses to the guis in the database or a logfile The accesses will be written in the mapbender database on table mb_log or into mapbender/log/mb_access_$DATE.log. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt53"><div class=CClass>A List object is an array of arbitrary objects with additional methods.</div></div><div class=CToolTip id="tt54"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.loadConfig = function (</td><td class=PParameter nowrap>configFilename,</td></tr><tr><td></td><td class=PParameter nowrap>callback</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>GETs the config, build corresponding form, remove an existing printBox</div></div><div class=CToolTip id="tt55"><div class=CClass>Logs the accesses to the guis in the database or a logfile The accesses will be written in the mapbender database on table mb_log or into mapbender/log/mb_access_$DATE.log. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt54"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt55"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt56"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt57"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt58"><div class=CClass>The main map in Mapbender</div></div><div class=CToolTip id="tt59"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt60"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt61"><div class=CClass>Adds navigation arrows on top of the map</div></div><div class=CToolTip id="tt62"><div class=CClass>A description</div></div><div class=CToolTip id="tt63"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt64"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><div class=CToolTip id="tt65"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><div class=CToolTip id="tt66"><div class=CClass>Zoom in/out with the mousewheel. </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt56"><div class=CClass>This is the central module for displaying the composite map overlay.</div></div><div class=CToolTip id="tt57"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Map = function(</td><td class=PParameter nowrap>frameName,</td></tr><tr><td></td><td class=PParameter nowrap>elementName,</td></tr><tr><td></td><td class=PParameter nowrap>width,</td></tr><tr><td></td><td class=PParameter nowrap>height,</td></tr><tr><td></td><td class=PParameter nowrap>wms_index</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt58"><div class=CClass>This jQuery plugin grants access to the Mapbender API from a DOM element. </div></div><div class=CToolTip id="tt59"><div class=CClass>All Mapbender functionality is within this namespace</div></div><div class=CToolTip id="tt60"><div class=CClass>The main map in Mapbender</div></div><div class=CToolTip id="tt61"><div class=CClass>A very basic marker class. </div></div><div class=CToolTip id="tt62"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Marker = function (</td><td class=PParameter nowrap>p,</td></tr><tr><td></td><td class=PParameter nowrap>map</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt63"><div class=CClass>Adds navigation arrows on top of the map</div></div><div class=CToolTip id="tt64"><div class=CClass>A description</div></div><div class=CToolTip id="tt65"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt66"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><div class=CToolTip id="tt67"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var mod_printPDF_init = function ()</td></tr></table></blockquote>initializes the print modules, generates template chooser and loads first configuration.</div></div><div class=CToolTip id="tt68"><div class=CClass>Zoom in/out with the mousewheel. </div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt67"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt68"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt69"><div class=CClass>An AJAX notification (it doesn&rsquo;t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt69"><div class=CClass>Logs a notice in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt70"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Notice = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt71"><div class=CClass>An AJAX notification (it doesn&rsquo;t expect a reply from the server)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt70"><div class=CClass>An OpenLayers Map, configured with WMS from Mapbender application settings</div></div><div class=CToolTip id="tt71"><div class=CClass>An OpenLayers KeyboardDefaults</div></div><div class=CToolTip id="tt72"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt73"><div class=CClass>An OpenLayers MousePosition</div></div><div class=CToolTip id="tt74"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt75"><div class=CClass>An OpenLayers panZoomBar</div></div><div class=CToolTip id="tt76"><div class=CProperty>event is fired whenever the form is resetted</div></div><div class=CToolTip id="tt77"><div class=CProperty>event is fired whenever a new WFS is selected</div></div><div class=CToolTip id="tt78"><div class=CProperty>This Mapbender.Event is fired before the user opens the dialog for inserting or updating. </div></div><div class=CToolTip id="tt79"><div class=CClass>Use the overview map to navigate the main map window. </div></div><div class=CToolTip id="tt80"><div class=CClass>shows and hides the overview module with a jQuery animation</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt72"><div class=CClass>An OpenLayers Map, configured with WMS from Mapbender application settings</div></div><div class=CToolTip id="tt73"><div class=CClass>An OpenLayers KeyboardDefaults</div></div><div class=CToolTip id="tt74"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt75"><div class=CClass>An OpenLayers MousePosition</div></div><div class=CToolTip id="tt76"><div class=CClass>An OpenLayers Layer Switch</div></div><div class=CToolTip id="tt77"><div class=CClass>An OpenLayers panZoomBar</div></div><div class=CToolTip id="tt78"><div class=CProperty>event is fired whenever the form is resetted</div></div><div class=CToolTip id="tt79"><div class=CProperty>event is fired whenever a new WFS is selected</div></div><div class=CToolTip id="tt80"><div class=CProperty>This Mapbender.Event is fired before the user opens the dialog for inserting or updating. </div></div><div class=CToolTip id="tt81"><div class=CClass>Use the overview map to navigate the main map window. </div></div><div class=CToolTip id="tt82"><div class=CClass>shows and hides the overview module with a jQuery animation</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt81"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><div class=CToolTip id="tt82"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><div class=CToolTip id="tt83"><div class=CProperty>the movable printframe</div></div><div class=CToolTip id="tt84"><div class=CClass>Mapbender print PDF with PDF templates module.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt83"><div class=CClass>A class representing a two- (or three-) dimensional point.</div></div><div class=CToolTip id="tt84"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Point = function (</td><td class=PParameter nowrap>x,</td></tr><tr><td></td><td class=PParameter nowrap>y,</td></tr><tr><td></td><td class=PParameter nowrap>z</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>just pass a Point in order to clone it.</div></div><div class=CToolTip id="tt85"><div class=CProperty>the movable printframe</div></div><div class=CToolTip id="tt86"><div class=CClass>Mapbender print PDF with PDF templates module.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt85"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt86"><div class=CClass>A button that reloads the whole window.</div></div><div class=CToolTip id="tt87"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt88"><div class=CClass>Repaints a map. </div></div><div class=CToolTip id="tt89"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt90"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt91"><div class=CProperty>counts the number of requests that have been made</div></div><div class=CToolTip id="tt92"><div class=CClass>Adds a resizable plugin to the module in target, for example mapframe1</div></div><div class=CToolTip id="tt93"><div class=CClass>This modul dynamically resizes the mapframe in relation to the browsersize. </div></div><div class=CToolTip id="tt94"><div class=CClass>A feature collection of a result geometry list.</div></div><div class=CToolTip id="tt95"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt96"><div class=CClass>A result list for featureCollections</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt87"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.register = function(</td><td class=PParameter nowrap>aFunction,</td></tr><tr><td></td><td class=PParameter nowrap>scope</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>A function that needs to be executed, when the event occurs, has to be registered via this function.</div></div><div class=CToolTip id="tt88"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.reload = function ()</td></tr></table></blockquote>Reloads the window.</div></div><div class=CToolTip id="tt89"><div class=CClass>A button that reloads the whole window.</div></div><div class=CToolTip id="tt90"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.remove = function ()</td></tr></table></blockquote>Remove the marker from the map.</div></div><div class=CToolTip id="tt91"><div class=CClass>Repaints a map. </div></div><div class=CToolTip id="tt92"><div class=CClass>An AJAX request (it expects a reply from the server)</div></div><div class=CToolTip id="tt93"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Ajax.Request = function (</td><td class=PParameter nowrap>options</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt94"><div class=CProperty>counts the number of requests that have been made</div></div><div class=CToolTip id="tt95"><div class=CClass>Adds a resizable plugin to the module in target, for example mapframe1</div></div><div class=CToolTip id="tt96"><div class=CClass>This modul dynamically resizes the mapframe in relation to the browsersize. </div></div><div class=CToolTip id="tt97"><div class=CClass>A feature collection of a result geometry list.</div></div><div class=CToolTip id="tt98"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>var ResultGeometryListModel = function ()</td></tr></table></blockquote></div></div><div class=CToolTip id="tt99"><div class=CClass>A result list for featureCollections</div></div><!--END_ND_TOOLTIPS-->
 </div><!--Index-->
Modified: trunk/mapbender/documents/api_js/index/General2.html
--- trunk/mapbender/documents/api_js/index/General2.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/index/General2.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,25 +11,25 @@
-<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar><a href="General.html#Symbols">$#!</a> &middot; 0-9 &middot; <a href="General.html#A">A</a> &middot; <a href="General.html#B">B</a> &middot; <a href="General.html#C">C</a> &middot; <a href="General.html#D">D</a> &middot; <a href="General.html#E">E</a> &middot; <a href="General.html#F">F</a> &middot; <a href="General.html#G">G</a> &middot; <a href="General.html#H">H</a> &middot; <a href="General.html#I">I</a> &middot; <a href="General.html#J">J</a> &middot; K &middot; <a href="General.html#L">L</a> &middot; <a href="General.html#M">M</a> &middot; <a href="General.html#N">N</a> &middot; <a href="General.html#O">O</a> &middot; <a href="General.html#P">P</a> &middot; Q &middot; <a href="General.html#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock" id=link99 onMouseOver="ShowTip(event, 'tt97', 'link99')" onMouseOut="HideTip('tt97')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_savewmc-js.html#savewmc" id=link100 onMouseOver="ShowTip(event, 'tt98', 'link100')" onMouseOut="HideTip('tt98')" class=ISymbol>savewmc</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_scalebar-js.html#scalebar" id=link101 onMouseOver="ShowTip(event, 'tt99', 'link101')" onMouseOut="HideTip('tt99')" class=ISymbol>scalebar</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>selArea</span><div class=ISubIndex><a href="../files/http/javascripts/mod_pan-js.html#selArea" id=link102 onMouseOver="ShowTip(event, 'tt100', 'link102')" onMouseOut="HideTip('tt100')" class=IFile>http/<wbr>javascripts/<wbr>mod_pan.js</a><a href="../files/http/javascripts/mod_selArea-js.html#selArea" id=link103 onMouseOver="ShowTip(event, 'tt100', 'link103')" onMouseOut="HideTip('tt100')" class=IFile>http/<wbr>javascripts/<wbr>mod_selArea.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_selectMapsize-js.html#selectMapsize" id=link104 onMouseOver="ShowTip(event, 'tt101', 'link104')" onMouseOut="HideTip('tt101')" class=ISymbol>selectMapsize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Request.send" id=link105 onMouseOver="ShowTip(event, 'tt102', 'link105')" onMouseOut="HideTip('tt102')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.set" id=link106 onMouseOver="ShowTip(event, 'tt103', 'link106')" onMouseOut="HideTip('tt103')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link107 onMouseOver="ShowTip(event, 'tt104', 'link107')" onMouseOut="HideTip('tt104')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link108 onMouseOver="ShowTip(event, 'tt105', 'link108')" onMouseOut="HideTip('tt105')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" id=link109 onMouseOver="ShowTip(event, 'tt106', 'link109')" onMouseOut="HideTip('tt106')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" id=link110 onMouseOver="ShowTip(event, 'tt107', 'link110')" onMouseOut="HideTip('tt107')" class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" id=link111 onMouseOver="ShowTip(event, 'tt108', 'link111')" onMouseOut="HideTip('tt108')" class=ISymbol>tabs_vertical</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" id=link112 onMouseOver="ShowTip(event, 'tt109', 'link112')" onMouseOut="HideTip('tt109')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" id=link113 onMouseOver="ShowTip(event, 'tt110', 'link113')" onMouseOut="HideTip('tt110')" class=ISymbol>twitter_signin</a></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IOnlySymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link114 onMouseOver="ShowTip(event, 'tt111', 'link114')" onMouseOut="HideTip('tt111')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Warning</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Warning" id=link115 onMouseOver="ShowTip(event, 'tt112', 'link115')" onMouseOut="HideTip('tt112')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Warning.Warning" id=link116 onMouseOver="ShowTip(event, 'tt113', 'link116')" onMouseOut="HideTip('tt113')" class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" id=link117 onMouseOver="ShowTip(event, 'tt114', 'link117')" onMouseOut="HideTip('tt114')" class=ISymbol>wmsTimeInterval</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" id=link118 onMouseOver="ShowTip(event, 'tt115', 'link118')" onMouseOut="HideTip('tt115')" class=ISymbol>wmsTimeSliderYear</a></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomFull-js.html#zoomFull" id=link119 onMouseOver="ShowTip(event, 'tt116', 'link119')" onMouseOut="HideTip('tt116')" class=ISymbol>zoomFull</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-js.html#ZoomIn1" id=link120 onMouseOver="ShowTip(event, 'tt117', 'link120')" onMouseOut="HideTip('tt117')" class=ISymbol>ZoomIn1</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomOut1-js.html#ZoomOut1" id=link121 onMouseOver="ShowTip(event, 'tt118', 'link121')" onMouseOut="HideTip('tt118')" class=ISymbol>ZoomOut1</a></td></tr></table>
+<div id=Index><div class=IPageTitle>Index</div><div class=INavigationBar><a href="General.html#Symbols">$#!</a> &middot; 0-9 &middot; <a href="General.html#A">A</a> &middot; <a href="General.html#B">B</a> &middot; <a href="General.html#C">C</a> &middot; <a href="General.html#D">D</a> &middot; <a href="General.html#E">E</a> &middot; <a href="General.html#F">F</a> &middot; <a href="General.html#G">G</a> &middot; <a href="General.html#H">H</a> &middot; <a href="General.html#I">I</a> &middot; <a href="General.html#J">J</a> &middot; K &middot; <a href="General.html#L">L</a> &middot; <a href="General.html#M">M</a> &middot; <a href="General.html#N">N</a> &middot; <a href="General.html#O">O</a> &middot; <a href="General.html#P">P</a> &middot; Q &middot; <a href="General.html#R">R</a> &middot; <a href="#S">S</a> &middot; <a href="#T">T</a> &middot; <a href="#U">U</a> &middot; V &middot; <a href="#W">W</a> &middot; X &middot; Y &middot; <a href="#Z">Z</a></div><table border=0 cellspacing=0 cellpadding=0><tr><td class=IHeading id=IFirstHeading><a name="S"></a>S</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock" id=link102 onMouseOver="ShowTip(event, 'tt100', 'link102')" onMouseOut="HideTip('tt100')" class=ISymbol>Sandclock</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_savewmc-js.html#savewmc" id=link103 onMouseOver="ShowTip(event, 'tt101', 'link103')" onMouseOut="HideTip('tt101')" class=ISymbol>savewmc</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_scalebar-js.html#scalebar" id=link104 onMouseOver="ShowTip(event, 'tt102', 'link104')" onMouseOut="HideTip('tt102')" class=ISymbol>scalebar</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>selArea</span><div class=ISubIndex><a href="../files/http/javascripts/mod_pan-js.html#selArea" id=link105 onMouseOver="ShowTip(event, 'tt103', 'link105')" onMouseOut="HideTip('tt103')" class=IFile>http/<wbr>javascripts/<wbr>mod_pan.js</a><a href="../files/http/javascripts/mod_selArea-js.html#selArea" id=link106 onMouseOver="ShowTip(event, 'tt103', 'link106')" onMouseOut="HideTip('tt103')" class=IFile>http/<wbr>javascripts/<wbr>mod_selArea.js</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_selectMapsize-js.html#selectMapsize" id=link107 onMouseOver="ShowTip(event, 'tt104', 'link107')" onMouseOut="HideTip('tt104')" class=ISymbol>selectMapsize</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/ajax-js.html#Request.send" id=link108 onMouseOver="ShowTip(event, 'tt105', 'link108')" onMouseOut="HideTip('tt105')" class=ISymbol>send</a>, <span class=IParent>Request</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.set" id=link109 onMouseOver="ShowTip(event, 'tt106', 'link109')" onMouseOut="HideTip('tt106')" class=ISymbol>set</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/map_obj-js.html#Map.setExtent" id=link110 onMouseOver="ShowTip(event, 'tt107', 'link110')" onMouseOut="HideTip('tt107')" class=ISymbol>setExtent</a>, <span class=IParent>Map</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.setFeatureProperty" id=link111 onMouseOver="ShowTip(event, 'tt108', 'link111')" onMouseOut="HideTip('tt108')" class=ISymbol>setFeatureProperty</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.show" id=link112 onMouseOver="ShowTip(event, 'tt109', 'link112')" onMouseOut="HideTip('tt109')" class=ISymbol>show</a>, <span class=IParent>Sandclock</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_print-js.html#printPDF.showResult" id=link113 onMouseOver="ShowTip(event, 'tt110', 'link113')" onMouseOut="HideTip('tt110')" class=ISymbol>showResult</a>, <span class=IParent>printPDF</span></td></tr><tr><td class=IHeading><a name="T"></a>T</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" id=link114 onMouseOver="ShowTip(event, 'tt111', 'link114')" onMouseOut="HideTip('tt111')" class=ISymbol>tabs_vertical</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" id=link115 onMouseOver="ShowTip(event, 'tt112', 'link115')" onMouseOut="HideTip('tt112')" class=ISymbol>toString</a>, <span class=IParent>Extent</span></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.trigger" id=link116 onMouseOver="ShowTip(event, 'tt113', 'link116')" onMouseOut="HideTip('tt113')" class=ISymbol>trigger</a>, <span class=IParent>Event</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" id=link117 onMouseOver="ShowTip(event, 'tt114', 'link117')" onMouseOut="HideTip('tt114')" class=ISymbol>twitter_signin</a></td></tr><tr><td class=IHeading><a name="U"></a>U</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/event-js.html#Event.unregister" id=link118 onMouseOver="ShowTip(event, 'tt115', 'link118')" onMouseOut="HideTip('tt115')" class=ISymbol>unregister</a>, <span class=IParent>Event</span></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" id=link119 onMouseOver="ShowTip(event, 'tt116', 'link119')" onMouseOut="HideTip('tt116')" class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></td></tr><tr><td class=IHeading><a name="W"></a>W</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><span class=ISymbol>Warning</span><div class=ISubIndex><a href="../files/lib/exception-js.html#Warning" id=link120 onMouseOver="ShowTip(event, 'tt117', 'link120')" onMouseOut="HideTip('tt117')" class=IParent>Global</a><a href="../files/lib/exception-js.html#Warning.Warning" id=link121 onMouseOver="ShowTip(event, 'tt118', 'link121')" onMouseOut="HideTip('tt118')" class=IParent>Warning</a></div></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeInterval-js.html#wmsTimeInterval" id=link122 onMouseOver="ShowTip(event, 'tt119', 'link122')" onMouseOut="HideTip('tt119')" class=ISymbol>wmsTimeInterval</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/plugins/mb_wmsTimeSliderYear-js.html#wmsTimeSliderYear" id=link123 onMouseOver="ShowTip(event, 'tt120', 'link123')" onMouseOut="HideTip('tt120')" class=ISymbol>wmsTimeSliderYear</a></td></tr><tr><td class=IHeading><a name="Z"></a>Z</td><td></td></tr><tr><td class=ISymbolPrefix id=IFirstSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomFull-js.html#zoomFull" id=link124 onMouseOver="ShowTip(event, 'tt121', 'link124')" onMouseOut="HideTip('tt121')" class=ISymbol>zoomFull</a></td></tr><tr><td class=ISymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomIn1-js.html#ZoomIn1" id=link125 onMouseOver="ShowTip(event, 'tt122', 'link125')" onMouseOut="HideTip('tt122')" class=ISymbol>ZoomIn1</a></td></tr><tr><td class=ISymbolPrefix id=ILastSymbolPrefix>&nbsp;</td><td class=IEntry><a href="../files/http/javascripts/mod_zoomOut1-js.html#ZoomOut1" id=link126 onMouseOver="ShowTip(event, 'tt123', 'link126')" onMouseOut="HideTip('tt123')" class=ISymbol>ZoomOut1</a></td></tr></table>
-<div class=CToolTip id="tt97"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt98"><div class=CClass>save workspace as WMC</div></div><div class=CToolTip id="tt99"><div class=CClass>Displays scalebar in the map. </div></div><div class=CToolTip id="tt100"><div class=CClass>Zoom by rectangle</div></div><div class=CToolTip id="tt101"><div class=CClass>Select the map size from a pre defined settings, like large or small</div></div><div class=CToolTip id="tt102"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt103"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt104"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt105"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><div class=CToolTip id="tt106"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt107"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt100"><div class=CClass>Displays an arbitrary sandclock image on a map</div></div><div class=CToolTip id="tt101"><div class=CClass>save workspace as WMC</div></div><div class=CToolTip id="tt102"><div class=CClass>Displays scalebar in the map. </div></div><div class=CToolTip id="tt103"><div class=CClass>Zoom by rectangle</div></div><div class=CToolTip id="tt104"><div class=CClass>Select the map size from a pre defined settings, like large or small</div></div><div class=CToolTip id="tt105"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>this.send = function ()</td></tr></table></blockquote>Sends the request to the server side</div></div><div class=CToolTip id="tt106"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.set = function (</td><td class=PParameter nowrap>min,</td></tr><tr><td></td><td class=PParameter nowrap>max</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Allows to set the center (one param) or the extent (two params)</div></div><div class=CToolTip id="tt107"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setExtent = function(</td><td class=PParameter nowrap>minx,</td></tr><tr><td></td><td class=PParameter nowrap>miny,</td></tr><tr><td></td><td class=PParameter nowrap>maxx,</td></tr><tr><td></td><td class=PParameter nowrap>maxy</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>set the extent of the wms</div></div><div class=CToolTip id="tt108"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.setFeatureProperty = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>pName,</td></tr><tr><td></td><td class=PParameter nowrap>pValue</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Set a property of a feature in the geometry array</div></div><div class=CToolTip id="tt109"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.show = function (</td><td class=PParameter nowrap>nodeId,</td></tr><tr><td></td><td class=PParameter nowrap>arg</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Displays the sandclock</div></div><div class=CToolTip id="tt110"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>var showResult = function (</td><td class=PParameter nowrap>res,</td></tr><tr><td></td><td class=PParameter nowrap>text</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>load the generated PDF from the returned URL as an attachment, that triggers a download popup or is displayed in PDF plugin.</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt108"><div class=CClass>An accordion decorator, replaces the deprecated element &ldquo;tabs&rdquo;</div></div><div class=CToolTip id="tt109"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><div class=CToolTip id="tt110"><div class=CClass>Authenticate with Twitter</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt111"><div class=CClass>An accordion decorator, replaces the deprecated element &ldquo;tabs&rdquo;</div></div><div class=CToolTip id="tt112"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td>Mapbender.Extent.prototype.toString = function ()</td></tr></table></blockquote>Returns a comma-separated list of all four coordinates</div></div><div class=CToolTip id="tt113"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.trigger = function(</td><td class=PParameter nowrap>properties,</td></tr><tr><td></td><td class=PParameter nowrap>booleanOperator</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>This function triggers the event.</div></div><div class=CToolTip id="tt114"><div class=CClass>Authenticate with Twitter</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt111"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt115"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.unregister = function(</td><td class=PParameter nowrap>aFunction</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Exclude a previously registered function from the event permanently</div></div><div class=CToolTip id="tt116"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>this.updateFeature = function (</td><td class=PParameter nowrap>index,</td></tr><tr><td></td><td class=PParameter nowrap>geoJson</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote>Replace a feature in the geometry array</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt112"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt113"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt114"><div class=CClass>Find an interval with two datepickers and attach it to getMap requests of WMS in your application</div></div><div class=CToolTip id="tt115"><div class=CClass>sets the TIME parameter for all activated WMS (years only)</div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt117"><div class=CClass>Logs an warning in the log file, in a console window or as an alert</div></div><div class=CToolTip id="tt118"><div class=CFunction><blockquote><table border=0 cellspacing=0 cellpadding=0 class=Prototype><tr><td><table border=0 cellspacing=0 cellpadding=0><tr><td class=PBeforeParameters nowrap>Mapbender.Warning = function (</td><td class=PParameter nowrap>message</td><td class=PAfterParameters nowrap>)</td></tr></table></td></tr></table></blockquote></div></div><div class=CToolTip id="tt119"><div class=CClass>Find an interval with two datepickers and attach it to getMap requests of WMS in your application</div></div><div class=CToolTip id="tt120"><div class=CClass>sets the TIME parameter for all activated WMS (years only)</div></div><!--END_ND_TOOLTIPS-->
-<div class=CToolTip id="tt116"><div class=CClass>Click button to zoom to the full extent of the BoundingBox.</div></div><div class=CToolTip id="tt117"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt118"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><!--END_ND_TOOLTIPS-->
+<div class=CToolTip id="tt121"><div class=CClass>Click button to zoom to the full extent of the BoundingBox.</div></div><div class=CToolTip id="tt122"><div class=CClass>Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). </div></div><div class=CToolTip id="tt123"><div class=CClass>Click button, which doubles the real world bounding box of the visible map section, halfes the scale (doubles the scale number). </div></div><!--END_ND_TOOLTIPS-->
 </div><!--Index-->
Modified: trunk/mapbender/documents/api_js/javascript/searchdata.js
--- trunk/mapbender/documents/api_js/javascript/searchdata.js	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/javascript/searchdata.js	2010-02-25 10:19:40 UTC (rev 5653)
@@ -40,7 +40,7 @@
       "F": false,
       "G": true,
       "H": true,
-      "I": false,
+      "I": true,
       "J": false,
       "K": false,
       "L": true,
Modified: trunk/mapbender/documents/api_js/search/FunctionsE.html
--- trunk/mapbender/documents/api_js/search/FunctionsE.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/FunctionsE.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=ISymbol>Exception</a>, <span class=IParent>Exception</span></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=ISymbol>Extent</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event.Mapbender.Event" target=_parent class=ISymbol>Event</a>, <span class=IParent>Event.<wbr>Mapbender</span></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=ISymbol>Exception</a>, <span class=IParent>Exception</span></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=ISymbol>Extent</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
 document.getElementById("Loading").style.display="none";
 document.getElementById("NoMatches").style.display="none";
 var searchResults = new SearchResults("searchResults", "HTML");
Added: trunk/mapbender/documents/api_js/search/FunctionsI.html
--- trunk/mapbender/documents/api_js/search/FunctionsI.html	                        (rev 0)
+++ trunk/mapbender/documents/api_js/search/FunctionsI.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -0,0 +1,20 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class="PopupSearchResultsPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
+if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
+<!--  Generated by Natural Docs, version 1.4 -->
+<!--  http://www.naturaldocs.org  -->
+<!-- saved from url=(0026)http://www.naturaldocs.org -->
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_isRegistered><div class=IEntry><a href="../files/lib/event-js.html#Event.isRegistered" target=_parent class=ISymbol>isRegistered</a>, <span class=IParent>Event</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+document.getElementById("Loading").style.display="none";
+document.getElementById("NoMatches").style.display="none";
+var searchResults = new SearchResults("searchResults", "HTML");
+searchResults.Search();
+--></script></div><script language=JavaScript><!--
+if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
\ No newline at end of file
Property changes on: trunk/mapbender/documents/api_js/search/FunctionsI.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Modified: trunk/mapbender/documents/api_js/search/FunctionsR.html
--- trunk/mapbender/documents/api_js/search/FunctionsR.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/FunctionsR.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_register><div class=IEntry><a href="../files/lib/event-js.html#Event.register" target=_parent class=ISymbol>register</a>, <span class=IParent>Event</span></div></div><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Marker</span></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=ISymbol>ResultGeometryListModel</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsT.html
--- trunk/mapbender/documents/api_js/search/FunctionsT.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/FunctionsT.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_trigger><div class=IEntry><a href="../files/lib/event-js.html#Event.trigger" target=_parent class=ISymbol>trigger</a>, <span class=IParent>Event</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/FunctionsU.html
--- trunk/mapbender/documents/api_js/search/FunctionsU.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/FunctionsU.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_unregister><div class=IEntry><a href="../files/lib/event-js.html#Event.unregister" target=_parent class=ISymbol>unregister</a>, <span class=IParent>Event</span></div></div><div class=SRResult id=SR_updateFeature><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.updateFeature" target=_parent class=ISymbol>updateFeature</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralE.html
--- trunk/mapbender/documents/api_js/search/GeneralE.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/GeneralE.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="../files/lib/event-js.html#Event" target=_parent class=ISymbol>Event</a></div></div><div class=SRResult id=SR_events><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Exception')" class=ISymbol>Exception</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=IParent>Exception</a></div></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Extent')" class=ISymbol>Extent</a><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" target=_parent class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=IParent>Extent</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_Event><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Event')" class=ISymbol>Event</a><div class=ISubIndex><a href="../files/lib/event-js.html#Event" target=_parent class=IParent>Global</a><a href="../files/lib/event-js.html#Event.Mapbender.Event" target=_parent class=IParent>Event.<wbr>Mapbender</a></div></div></div><div class=SRResult id=SR_events><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.events" target=_parent class=ISymbol>events</a>, <span class=IParent>ResultGeometryListModel</span></div></div><div class=SRResult id=SR_Exception><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Exception')" class=ISymbol>Exception</a><div class=ISubIndex><a href="../files/lib/exception-js.html#Exception" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Exception" target=_parent class=IParent>Exception</a></div></div></div><div class=SRResult id=SR_Extent><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Extent')" class=ISymbol>Extent</a><div class=ISubIndex><a href="../files/lib/extent-js.html#Extent" target=_parent class=IParent>Global</a><a href="../files/lib/extent-js.html#Extent.Extent" target=_parent class=IParent>Extent</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralF.html
--- trunk/mapbender/documents/api_js/search/GeneralF.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/GeneralF.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_firebug_undlite><div class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" target=_parent class=ISymbol>firebug_lite</a></div></div><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions" target=_parent class=IParent>Global</a><a href="../files/lib/exception-js.html#Exception.Functions" target=_parent class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions" target=_parent class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" target=_parent class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions" target=_parent class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Marker.Functions" target=_parent class=IParent>Marker</a><a href="../files/lib/exception-js.html#Notice.Functions" target=_parent class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions" target=_parent class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions" target=_parent class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions" target=_parent class=IParent>printPDF</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions" target=_parent class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions" target=_parent class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions" target=_parent class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions" target=_parent class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_Functions_spcand_spcProperties><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" target=_parent class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_firebug_undlite><div class=IEntry><a href="../files/http/javascripts/mod_firebug_lite-js.html#firebug_lite" target=_parent class=ISymbol>firebug_lite</a></div></div><div class=SRResult id=SR_Functions><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Functions')" class=ISymbol>Functions</a><div class=ISubIndex><a href="../files/lib/resultGeometryListController-js.html#Functions" target=_parent class=IParent>Global</a><a href="../files/lib/event-js.html#Event.Functions" target=_parent class=IParent>Event</a><a href="../files/lib/exception-js.html#Exception.Functions" target=_parent class=IParent>Exception</a><a href="../files/lib/extent-js.html#Extent.Functions" target=_parent class=IParent>Extent</a><a href="../files/http/javascripts/map_obj-js.html#Map.Functions" target=_parent class=IParent>Map</a><a href="../files/lib/basic-js.html#mapbender.Functions" target=_parent class=IParent>mapbender</a><a href="../files/lib/marker-js.html#Marker.Functions" target=_parent class=IParent>Marker</a><a href="../files/lib/exception-js.html#Notice.Functions" target=_parent class=IParent>Notice</a><a href="../files/lib/ajax-js.html#Notification.Functions" target=_parent class=IParent>Notification</a><a href="../files/lib/point-js.html#Point.Functions" target=_parent class=IParent>Point</a><a href="../files/http/plugins/mb_print-js.html#printPDF.Functions" target=_parent class=IParent>printPDF</a><a href="../files/http/javascripts/mod_reload-js.html#Reload.Functions" target=_parent class=IParent>Reload</a><a href="../files/lib/ajax-js.html#Request.Functions" target=_parent class=IParent>Request</a><a href="../files/http/javascripts/mod_ResultList-js.html#resultList.Functions" target=_parent class=IParent>resultList</a><a href="../files/http/javascripts/mod_sandclock-js.html#Sandclock.Functions" target=_parent class=IParent>Sandclock</a><a href="../files/lib/exception-js.html#Warning.Functions" target=_parent class=IParent>Warning</a></div></div></div><div class=SRResult id=SR_Functions_spcand_spcProperties><div class=IEntry><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.Functions_and_Properties" target=_parent class=ISymbol>Functions and Properties</a>, <span class=IParent>ResultGeometryListModel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralI.html
--- trunk/mapbender/documents/api_js/search/GeneralI.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/GeneralI.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_i18n><div class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" target=_parent class=ISymbol>i18n</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_i18n><div class=IEntry><a href="../files/http/plugins/mb_i18n-js.html#i18n" target=_parent class=ISymbol>i18n</a></div></div><div class=SRResult id=SR_isRegistered><div class=IEntry><a href="../files/lib/event-js.html#Event.isRegistered" target=_parent class=ISymbol>isRegistered</a>, <span class=IParent>Event</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralR.html
--- trunk/mapbender/documents/api_js/search/GeneralR.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/GeneralR.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR2_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Marker</span></div></div><div class=SRResult id=SR_repaint><div class=IEntry><a href="javascript:searchResults.Toggle('SR_repaint')" class=ISymbol>repaint</a><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Request" target=_parent class=IParent>Global</a><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div><div class=SRResult id=SR_resize><div class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" target=_parent class=ISymbol>resize</a></div></div><div class=SRResult id=SR_ResizeMapsize><div class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" target=_parent class=ISymbol>ResizeMapsize</a></div></div><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="javascript:searchResults.Toggle('SR_ResultGeometryListModel')" class=ISymbol>ResultGeometryListModel</a><div class=ISubIndex><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_resultList><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" target=_parent class=ISymbol>resultList</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_register><div class=IEntry><a href="../files/lib/event-js.html#Event.register" target=_parent class=ISymbol>register</a>, <span class=IParent>Event</span></div></div><div class=SRResult id=SR_reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload.reload" target=_parent class=ISymbol>reload</a>, <span class=IParent>Reload</span></div></div><div class=SRResult id=SR2_Reload><div class=IEntry><a href="../files/http/javascripts/mod_reload-js.html#Reload" target=_parent class=ISymbol>Reload</a></div></div><div class=SRResult id=SR_remove><div class=IEntry><a href="../files/lib/marker-js.html#Marker.remove" target=_parent class=ISymbol>remove</a>, <span class=IParent>Marker</span></div></div><div class=SRResult id=SR_repaint><div class=IEntry><a href="javascript:searchResults.Toggle('SR_repaint')" class=ISymbol>repaint</a><div class=ISubIndex><a href="../files/http/javascripts/mod_repaint-js.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.js</a><a href="../files/http/javascripts/mod_repaint-php.html#repaint" target=_parent class=IFile>http/<wbr>javascripts/<wbr>mod_repaint.php</a></div></div></div><div class=SRResult id=SR_Request><div class=IEntry><a href="javascript:searchResults.Toggle('SR_Request')" class=ISymbol>Request</a><div class=ISubIndex><a href="../files/lib/ajax-js.html#Request" target=_parent class=IParent>Global</a><a href="../files/lib/ajax-js.html#Notification.Mapbender.Ajax.Request" target=_parent class=IParent>Notification.<wbr>Mapbender.Ajax</a><a href="../files/lib/ajax-js.html#Request.Mapbender.Ajax.Request" target=_parent class=IParent>Request.<wbr>Mapbender.Ajax</a></div></div></div><div class=SRResult id=SR_requestCount><div class=IEntry><a href="../files/lib/ajax-js.html#Ajax.requestCount" target=_parent class=ISymbol>requestCount</a>, <span class=IParent>Ajax</span></div></div><div class=SRResult id=SR_resize><div class=IEntry><a href="../files/http/plugins/mb_resize-js.html#resize" target=_parent class=ISymbol>resize</a></div></div><div class=SRResult id=SR_ResizeMapsize><div class=IEntry><a href="../files/http/javascripts/mod_resize_mapsize-js.html#ResizeMapsize" target=_parent class=ISymbol>ResizeMapsize</a></div></div><div class=SRResult id=SR_resultGeometryListController_perjs><div class=IEntry><a href="../files/lib/resultGeometryListController-js.html#resultGeometryListController.js" target=_parent class=ISymbol>resultGeometryListController.js</a></div></div><div class=SRResult id=SR_ResultGeometryListModel><div class=IEntry><a href="javascript:searchResults.Toggle('SR_ResultGeometryListModel')" class=ISymbol>ResultGeometryListModel</a><div class=ISubIndex><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel" target=_parent class=IParent>Global</a><a href="../files/lib/resultGeometryListModel-js.html#ResultGeometryListModel.ResultGeometryListModel" target=_parent class=IParent>ResultGeometryListModel</a></div></div></div><div class=SRResult id=SR_resultList><div class=IEntry><a href="../files/http/javascripts/mod_ResultList-js.html#resultList" target=_parent class=ISymbol>resultList</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralT.html
--- trunk/mapbender/documents/api_js/search/GeneralT.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/GeneralT.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_tabs_undvertical><div class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" target=_parent class=ISymbol>tabs_vertical</a></div></div><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_twitter_undsignin><div class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" target=_parent class=ISymbol>twitter_signin</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
+<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_tabs_undvertical><div class=IEntry><a href="../files/http/plugins/mb_tabs_vertical-js.html#tabs_vertical" target=_parent class=ISymbol>tabs_vertical</a></div></div><div class=SRResult id=SR_toString><div class=IEntry><a href="../files/lib/extent-js.html#Extent.toString" target=_parent class=ISymbol>toString</a>, <span class=IParent>Extent</span></div></div><div class=SRResult id=SR_trigger><div class=IEntry><a href="../files/lib/event-js.html#Event.trigger" target=_parent class=ISymbol>trigger</a>, <span class=IParent>Event</span></div></div><div class=SRResult id=SR_twitter_undsignin><div class=IEntry><a href="../files/http/plugins/mb_twitter_signin-js.html#twitter_signin" target=_parent class=ISymbol>twitter_signin</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/search/GeneralU.html
--- trunk/mapbender/documents/api_js/search/GeneralU.html	2010-02-25 10:17:57 UTC (rev 5652)
+++ trunk/mapbender/documents/api_js/search/GeneralU.html	2010-02-25 10:19:40 UTC (rev 5653)
@@ -11,7 +11,7 @@
More information about the Mapbender_commits mailing list
