[Mapbender-commits] r5331 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 14 08:57:12 EST 2010
Author: christoph
Date: 2010-01-14 08:57:11 -0500 (Thu, 14 Jan 2010)
New Revision: 5331
   trunk/mapbender/http/javascripts/map_obj.js
   trunk/mapbender/http/javascripts/mod_repaint.js
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2010-01-14 13:09:58 UTC (rev 5330)
+++ trunk/mapbender/http/javascripts/map_obj.js	2010-01-14 13:57:11 UTC (rev 5331)
@@ -23,6 +23,7 @@
     var mapMsgObj;
+	var extentHasChanged = false;
     eventLocalize.register(function(){
         localizeMap();
@@ -34,7 +35,7 @@
     var localizeMap = function(){
         $.post("../php/mod_map_messages.php", function(obj, status){
-            mapMsgObj = eval('(' + obj + ')');
+            mapMsgObj = $.parseJSON(obj);
@@ -62,14 +63,15 @@
             this.oldExtent = new Extent(this.extent);
 	        // pixel coordinates of new extent in old extent
-	        if (arguments.length === 1) {
-				var oldpixll = this.convertRealToPixel(minx.min);
-				var oldpixur = this.convertRealToPixel(minx.max);
+	        var oldpixll, oldpixur;
+			if (arguments.length === 1) {
+				oldpixll = this.convertRealToPixel(minx.min);
+				oldpixur = this.convertRealToPixel(minx.max);
 				this.oldExtentPix = new Extent(oldpixll.x, oldpixll.y, oldpixur.x, oldpixur.y);
 			else if (arguments.length === 4) {
-				var oldpixll = this.convertRealToPixel(new Point(parseFloat(minx), parseFloat(miny)));
-				var oldpixur = this.convertRealToPixel(new Point(parseFloat(maxx), parseFloat(maxy)));
+				oldpixll = this.convertRealToPixel(new Point(parseFloat(minx), parseFloat(miny)));
+				oldpixur = this.convertRealToPixel(new Point(parseFloat(maxx), parseFloat(maxy)));
@@ -90,6 +92,7 @@
                 this.extent.set(new Point(arguments[0], arguments[1]), new Point(arguments[2], arguments[3]));
+		extentHasChanged = true;
@@ -1150,7 +1153,7 @@
 		// show new map
-		if (doAnimation) {
+		if (doAnimation && extentHasChanged) {
 			var previousRequest = $("#" + that.elementName + "_request_" + (index-1));
 			var wasPanned = parseInt(previousRequest.css("top"), 10) !== 0 ||
 				parseInt(previousRequest.css("left"), 10) !== 0;
@@ -1317,6 +1320,7 @@
 		this.history.forward(false);
+		extentHasChanged = false;
     var getLayerHtmlCode = function(ii, extent, width, height, top, left, requestCnt){
Modified: trunk/mapbender/http/javascripts/mod_repaint.js
--- trunk/mapbender/http/javascripts/mod_repaint.js	2010-01-14 13:09:58 UTC (rev 5330)
+++ trunk/mapbender/http/javascripts/mod_repaint.js	2010-01-14 13:57:11 UTC (rev 5331)
@@ -36,7 +36,7 @@
 	if (!Mapbender.modules[options.target]) {
 		return;
-	Mapbender.modules[options.target].zoom(true, 0.999);
+	Mapbender.modules[options.target].setMapRequest();
 }).mouseover(function () {
 	if (options.src) {
 		this.src = options.src.replace(/_off/, "_over");
More information about the Mapbender_commits mailing list
