[Mapbender-commits] r5350 - in trunk/mapbender: http/javascripts http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 19 08:30:30 EST 2010
Author: christoph
Date: 2010-01-19 08:30:29 -0500 (Tue, 19 Jan 2010)
New Revision: 5350
Added:
   trunk/mapbender/http/plugins/mb_map.js
Removed:
   trunk/mapbender/http/javascripts/mapnf.php
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
Deleted: trunk/mapbender/http/javascripts/mapnf.php
--- trunk/mapbender/http/javascripts/mapnf.php	2010-01-19 12:22:05 UTC (rev 5349)
+++ trunk/mapbender/http/javascripts/mapnf.php	2010-01-19 13:30:29 UTC (rev 5350)
@@ -1,54 +0,0 @@
-<?php
-# $Id:$
-# http://www.mapbender.org/Mapbender_without_iframes
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-var $this = $(this);
-eventInitMap.register(function () {
-	$this.data("isMap", true);
-	$this.html('<div id="'+options.id+'_maps" name="maps" style ="width: 0px; height: 0px; z-index:2;"></div>');
-	$this.mapbender(new Mapbender.Map (
-		options.id,
-		options.width,
-		options.height,
-		null
-	mb_mapObj.push(Mapbender.modules[options.id]);
-	var mapObject = Mapbender.modules[options.id];
-	mapObject.skipWmsIfSrsNotSupported =
-		options.skipWmsIfSrsNotSupported === 1 ? true : false;
-	// set restricted extent
-	try {
-		if (restrictedExtent !== '') {
-			mapObject.setRestrictedExtent(restrictedExtent);
-	catch (e) {
-		new Mb_notice("Restricted extent not set via element variable.");
Added: trunk/mapbender/http/plugins/mb_map.js
--- trunk/mapbender/http/plugins/mb_map.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_map.js	2010-01-19 13:30:29 UTC (rev 5350)
@@ -0,0 +1,80 @@
+ * Package: mapframe1
+ * Description:
+ * The main map in Mapbender
+ * Files:
+ *  - http/plugins/mb_map.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','mapframe1',
+ * > 1,1,'The main map in Mapbender','','div','','',220,105,625,400,2,
+ * > 'overflow:hidden;background-color:#ffffff','','div',
+ * > '../plugins/mb_map.js',
+ * > '../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php',
+ * > '','','http://www.mapbender.org/index.php/Mapframe');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<appId>', 'mapframe1',
+ * > 'skipWmsIfSrsNotSupported', '0',
+ * > 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility',
+ * > 'var');
+ * Help:
+ * http://www.mapbender.org/Mapframe
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters:
+ * skipWmsIfSrsNotSupported      - if set to 1, it skips the WMS request
+ * 									if the current SRS is not supported by
+ * 									the WMS; if set to 0, the WMS is always
+ * 									queried.
+ * 									Default is 0, because of backwards
+ * 									compatibility
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $this = $(this);
+Mapbender.events.initMaps.register(function () {
+	$this.data("isMap", true);
+	$this.html('<div id="' + options.id + '_maps" name="maps" ' +
+		'style="width: 0px; height: 0px; z-index:2;"></div>');
+	$this.mapbender(new Mapbender.Map (
+		options.id,
+		options.width,
+		options.height,
+		null
+	// for backwards compatibility
+	mb_mapObj.push(Mapbender.modules[options.id]);
+	var mapObject = Mapbender.modules[options.id];
+	// set restricted extent
+	mapObject.skipWmsIfSrsNotSupported =
+		options.skipWmsIfSrsNotSupported === 1 ? true : false;
+	if (typeof options.restrictedExtent !== "undefined") {
+		mapObject.setRestrictedExtent(restrictedExtent);
+	else {
+		new Mapbender.Notice("Restricted extent not set via element variable.");
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-19 12:22:05 UTC (rev 5349)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-19 13:30:29 UTC (rev 5350)
@@ -1091,3 +1091,6 @@
 INSERT INTO cat_op_conf VALUES (2, 'get', 'http://geomatics.nlr.nl/excat/csw', 'getrecordbyid');
 INSERT INTO cat_op_conf VALUES (2, 'post', 'http://geomatics.nlr.nl/excat/csw', 'getrecordbyid');
 INSERT INTO gui_cat VALUES ('gui1', 2);
+-- mapframe1 is now a jQuery plugin
+UPDATE gui_element SET e_js_file = '../plugins/mb_map.js' WHERE e_id = 'mapframe1';
\ No newline at end of file
More information about the Mapbender_commits mailing list
