[Mapbender-commits] r5377 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 20 10:51:47 EST 2010
Author: christoph
Date: 2010-01-20 10:51:46 -0500 (Wed, 20 Jan 2010)
New Revision: 5377
Added:
   trunk/mapbender/lib/printbox.js
Added: trunk/mapbender/lib/printbox.js
--- trunk/mapbender/lib/printbox.js	                        (rev 0)
+++ trunk/mapbender/lib/printbox.js	2010-01-20 15:51:46 UTC (rev 5377)
@@ -0,0 +1,702 @@
+Mapbender.PrintBox = function (options) {
+	if (!options) {
+		options = {};
+	var target = options.target || "mapframe1";
+	var map = getMapObjByName(target);
+//	var map = Mapbender.modules[target];
+	var map_el = map.getDomElement();
+	// Default is portrait, A4, unit seems to be cm
+	var printWidth = options.printWidth || 21;
+	var printHeight = options.printHeight || 29.7;
+	// initialised in setScale()
+	var boxWidth, boxHeight;
+	var scale = options.scale || 100000;
+	// behaviour
+	var afterChangeAngle = options.afterChangeAngle || function (obj) {};
+	var afterChangeSize = options.afterChangeSize || function (obj) {};
+	// styles
+	var opacity = options.boxOpacity || 0.6;
+	var boxColour = options.boxColour || "#9999FF";
+	var frameColour = options.frameColour || "#000000";
+	var pointColour = options.pointColour || "#DD0000";
+	var circleColour = options.circleColour || "#DD0000";
+	var circleWidth = options.circleWidth || 4;
+	// attributes
+	this.id = "printbox";
+	var angle = 0;
+	var totalAngle = 0;
+	// the four points of the box as pixel coordinates (incl rotation),
+	// with (0,0) as center. This is important for angle calculations.
+	var pointArray = [];
+	// The pointArray is moved by the center vector.
+	// default: place box in the center of the map
+	var center = options.center || new Point(map.width/2,map.height/2);
+	// the center in real world coordinates
+	var centerMap = null;
+	// the four points of the box as pixel coordinates (NO ROTATION)
+	var startPointPixArray = [];
+	// the four points of the box as real world coordinates (NO ROTATION)
+	var startPointMapArray = [];
+	var that = this;
+	// if the box is smaller than this, the circle will not be drawn
+	var MIN_BOX_WIDTH_OR_HEIGHT = 10;
+	// if the box is larger than this, the box will not be filled
+	var MAX_BOX_WIDTH_OR_HEIGHT = 800;
+	this.toString = function () {
+		var str = "";
+		str += "Center: " + getCenter() + "\n";
+		str += "Radius: " + radius + "\n";
+		str += "StartRadius: " + startRadius + "\n";
+		str += "Pixelpos: " + String(pointArray) + "\n";
+		str += "StartPixelpos: " + String(startPointPixArray) + "\n";
+		str += "Mappos: " + String(startPointMapArray) + "\n";
+		return str;
+	var initBehaviour = function () {
+		initMoveBehaviour();
+		initResizeBehaviour();
+		initRotateBehaviour();
+	var initRotateBehaviour = function () {
+		$circleCanvas.css("z-index", "110").mousedown(function (e) {
+			circleCanvas.clear();
+			var newCenter = getCenter();
+			var mouseMoveStart = map.getMousePos(e);
+			var vectorA = pointArray[0].minus(newCenter);
+			var currentPos = map.getMousePos(e);
+			var vectorCurrent = currentPos.minus(newCenter);
+			angle = Math.ceil(getAngle(vectorA, vectorCurrent));
+			$(document).mousemove(function (e) {
+				var currentAngle = Math.ceil(getAngle(vectorA, vectorCurrent));
+				var diffAngle = currentAngle - angle;
+				if (Math.abs(diffAngle) >= 1) {
+					angle = currentAngle;
+					totalAngle = ((totalAngle + diffAngle) +360 )% 360;
+					that.rotate(totalAngle);
+				return false;
+			}).mouseup(function (e) {
+				angle = 0;
+				$(document).unbind("mousemove");
+				$(document).unbind("mouseup");
+				afterChangeAngle({
+					angle: totalAngle,
+					coordinates: that.getStartCoordinates()
+				that.paintBox();
+				return false;
+			return false;
+		}).css("cursor", "move");
+	var initMoveBehaviour = function () {
+		$boxCanvas.mousedown(function (e) {
+			var containerStart = new Point(
+				parseInt($container.css("left"), 10),
+				parseInt($container.css("top"), 10)
+			var diff;
+				diff = (map.getMousePos(e)).minus(mouseMoveStart);
+				$container.css({
+					"top": (containerStart.y + diff.y) + "px",
+					"left": (containerStart.x + diff.x) + "px"
+				return false;
+				recalculateMapPositions();
+				that.paintBox();
+				return false;
+			return false;
+	var initResizeBehaviour = function () {
+		$pointCanvas.css("z-index", "120").mousedown(function (e) {
+			var vectorA = getCenter();
+			resizeRatio = 1;
+			mouseMoveStart = map.getMousePos(e);
+				var newRadius = vectorA.dist(map.getMousePos(e));
+				var resizeRatio = newRadius / radius;
+				if (resizeRatio < 0.98 || resizeRatio > 1.02) {
+					for (var i = 0; i < pointArray.length; i++) {
+						pointArray[i].x *= resizeRatio;
+						pointArray[i].y *= resizeRatio;
+						startPointPixArray[i].x *= resizeRatio;
+						startPointPixArray[i].y *= resizeRatio;
+					radius *= resizeRatio;
+					that.paintPoints();
+				return false;
+			$(document).mouseup(function (e) {
+				recalculatePixPositions();
+				afterChangeSize({
+					scale: that.getScale(),
+				that.paintBox();
+				return false;
+			return false;
+	var setCenter = function (inputCenter) {
+		center = inputCenter.minus(
+			new Point(
+	var getCenter = function () {
+		var c = center.plus(
+			new Point(
+		return c;
+	 * Calculates the angle (-180 < angle <= 180) between two vectors.
+	 * @param {Point} a
+	 * @param {Point} b
+	var getAngle = function (a, b) {
+		var undirectedAngle = 180 * Math.acos(
+				(a.x * b.x + a.y * b.y)
+					Math.sqrt(
+						a.x * a.x
+					 	a.y * a.y
+					Math.sqrt(
+						b.x * b.x
+						b.y * b.y
+			) / Math.PI;
+		if ((a.x*b.y - a.y*b.x) > 0) {
+			return -1 * undirectedAngle;
+		return undirectedAngle;
+	 * To be replaced by the map objects native getMousePosition
+	 * @param {Event} e
+	var getMousePos = function (e) {
+		if ($.msie) {
+			return new Point(event.clientX, event.clientY);
+		return new Point(e.pageX, e.pageY);
+	var recalculateMapPositions = function () {
+			startPointMapArray[i] = convertPixelToMap(startPointPixArray[i].plus(getCenter()));
+		centerMap = convertPixelToMap(getCenter());
+	var recalculatePixPositions = function () {
+		setCenter(convertMapToPixel(centerMap));
+		for (var i = 0; i < startPointMapArray.length; i++) {
+			pointArray[i] = convertMapToPixel(startPointMapArray[i]).minus(getCenter());
+			startPointPixArray[i] = convertMapToPixel(startPointMapArray[i]).minus(getCenter());
+		radius = pointArray[0].dist(new Point(0,0));
+		startRadius = radius;
+		boxWidth = pointArray[2].x - pointArray[0].x;
+		boxHeight = pointArray[0].y - pointArray[2].y;
+	var initPoints = function () {
+		var w = parseInt((boxWidth/2), 10);
+		var h = parseInt((boxHeight/2), 10);
+		pointArray[0] = new Point(-w,  h);
+		pointArray[1] = new Point( w,  h);
+		pointArray[2] = new Point( w, -h);
+		pointArray[3] = new Point(-w, -h);
+		startPointPixArray[0] = (new Point(-w,  h));
+		startPointPixArray[1] = (new Point( w,  h));
+		startPointPixArray[2] = (new Point( w, -h));
+		startPointPixArray[3] = (new Point(-w, -h));
+		scale = that.getScale();
+	var switchBoxDimensions = function () {
+		setBoxDimensions(boxHeight, boxWidth);
+		afterChangeSize({
+	this.setPortrait = function () {
+		this.setAngle(0);
+		if (boxWidth > boxHeight) {
+			switchBoxDimensions();
+	this.setLandscape = function () {
+		this.setAngle(0);
+		if (boxWidth < boxHeight) {
+	this.setPrintWidthAndHeight = function (width, height) {
+		var currentScale = this.getScale();
+		printWidth = width;
+		printHeight = height;
+		this.setScale(currentScale);
+	var convertMapToPixel = function (aPoint) {
+		var pArray = makeRealWorld2mapPos(map.elementName, aPoint.x, aPoint.y);
+		return new Point(pArray[0], pArray[1]);
+	var convertPixelToMap = function (aPoint) {
+		var pArray = makeClickPos2RealWorldPos(map.elementName, aPoint.x, aPoint.y);
+	 * Sets the box width and box height (calculated in setScale)
+	 * @param {Integer} inputWidth
+	 * @param {Integer} inputHeight
+	var setBoxDimensions = function (inputWidth, inputHeight) {
+		boxWidth = inputWidth;
+		boxHeight = inputHeight;
+		initPoints();
+		afterChangeSize({
+		that.paintBox();
+	 * Returns an array of two points, the lower left and upper right of the initial box
+	this.getStartCoordinates = function () {
+		var a = startPointMapArray[0];
+		var b = startPointMapArray[2];
+		if (!a || !b) {
+			return null;
+		var returnString =  a.x + "," + a.y + "," + b.x + "," + b.y;
+		return returnString;
+	 * Returns the current scale of the print box
+	this.getScale = function () {
+		var coords = this.getStartCoordinates();
+		var coordsArray = coords.split(",");
+		var ext = mapObj.getExtentInfos();
+		var extMinX = ext.minx;
+		var extMaxX = ext.maxx;
+		var x = (ext.minx + ext.maxx)/2;
+		var y = (ext.miny + ext.maxy)/2;
+		var scale1 = (x - coordsArray[0]) * (mb_resolution * 100 *2) / mapObj.width;
+		var scale2 = (coordsArray[2] - x) * (mb_resolution * 100 *2) / mapObj.width;
+		scale = Math.round(scale1/2 + scale2/2);
+		return scale;
+		xtentx =  coordsArray[2] - coordsArray[0];
+		scale = parseInt(Math.ceil(xtentx / (printWidth / 100)), 10);
+		return scale;
+	 * Repaints the Box with the current scale. Can be called from outside,
+	 * for example after zoom in.
+	this.repaint = function () {
+		this.rotate(totalAngle);
+		this.paintBox();
+	 * Sets the current scale, and repaints the box
+	 * @param {Integer} inputScale
+	this.setScale = function (inputScale) {
+		if (typeof(inputScale) == "number") {
+			var arrayBBox = mapObj.extent.split(",");
+			x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
+			y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
+			var minx = parseFloat(x) - (mapObj.width / (mb_resolution * 100 *2) * inputScale);
+			var miny = parseFloat(y) -  (mapObj.height / (mb_resolution * 100 *2) * inputScale);
+			var maxx = parseFloat(x) + (mapObj.width / (mb_resolution * 100 *2) * inputScale);
+			var maxy = parseFloat(y) +  (mapObj.height / (mb_resolution * 100 *2) * inputScale);
+			var newMinPos = makeRealWorld2mapPos(mapObj.frameName, minx, miny);
+			var newMaxPos = makeRealWorld2mapPos(mapObj.frameName, maxx, maxy);
+			var newBoxWidth = newMaxPos[0] - newMinPos[0];
+			var newBoxHeight = newBoxWidth * (printHeight / printWidth);
+			var mapWidthInM = printWidth / 100;
+			var realWidthInM = inputScale * mapWidthInM;
+			var mapHeightInM = printHeight / 100;
+			var realHeightInM = inputScale * mapHeightInM;
+			if (coords !== null) {
+				var oldMin = new Point(parseFloat(coordsArray[0]), parseFloat(coordsArray[1]));
+				var oldMax = new Point(parseFloat(coordsArray[2]), parseFloat(coordsArray[3]));
+				centerMap = (oldMin.times(0.5)).plus(oldMax.times(0.5));
+			else {
+			var newMin = new Point(centerMap.x - 0.5 * realWidthInM, centerMap.y - 0.5 * realHeightInM);
+			var newMax = new Point(centerMap.x + 0.5 * realWidthInM, centerMap.y + 0.5 * realHeightInM);
+			startPointMapArray[0] = new Point(newMin.x, newMin.y);
+			startPointMapArray[1] = new Point(newMax.x, newMin.y);
+			startPointMapArray[2] = new Point(newMax.x, newMax.y);
+			startPointMapArray[3] = new Point(newMin.x, newMax.y);
+			this.getStartCoordinates();
+			var newMinPos = convertMapToPixel(newMin);
+			var newMaxPos = convertMapToPixel(newMax);
+			boxWidth = newMaxPos.x - newMinPos.x;
+			boxHeight = newMinPos.y - newMaxPos.y;
+			var w = parseInt(0.5 * boxWidth, 10);
+			var h = parseInt(0.5 * boxHeight, 10);
+			afterChangeSize({
+			that.paintBox();
+			return true;
+		return false;
+	 * Sets the angle of the box to a specific angle.
+	 * @param {Integer} angle
+	this.setAngle = function (angle) {
+		if (typeof(angle) == "number" && angle >= -360) {
+			totalAngle = (360 + angle) % 360;
+			this.paintBox();
+			return true;
+		return false;
+	// VIEW
+	 * Rotates the box by a given degree (0 <= degree < 360),
+	 * and paints the corner points.
+	 * @param {Integer} degree
+	this.rotate = function (degree) {
+		var rotationAngle = (Math.PI * parseFloat(degree))/180;
+		var resizeRatio = radius / startRadius;
+			var p = (convertMapToPixel(startPointMapArray[i])).minus(getCenter());
+			var newx = p.x * Math.cos(rotationAngle) + p.y * Math.sin(rotationAngle);
+			var newy = p.x * -Math.sin(rotationAngle) + p.y * Math.cos(rotationAngle);
+			pointArray[i] = (new Point(newx, newy)).times(resizeRatio);
+			angle: degree,
+			coordinates: this.getStartCoordinates()
+		this.paintPoints();
+	 * Paints the four corner points of the print box.
+	this.paintPoints = function () {
+		switchActiveCanvas();
+		var c = center;
+			activeCanvas.fillEllipse(
+				pointArray[i].x + c.x - 4,
+				pointArray[i].y + c.y - 4,
+				8,
+				8
+		activeCanvas.paint();
+		passiveCanvas.clear();
+	var boxTooBig = function () {
+		if (boxWidth > MAX_BOX_WIDTH_OR_HEIGHT || boxHeight > MAX_BOX_WIDTH_OR_HEIGHT) {
+			return true;
+		return false;
+	var boxTooSmall = function () {
+		if (boxWidth < MIN_BOX_WIDTH_OR_HEIGHT || boxHeight < MIN_BOX_WIDTH_OR_HEIGHT) {
+			return true;
+		return false;
+	 * Paints the box itself. Plus the circle.
+	this.paintBox = function () {
+		var r = Math.round(0.75 * radius);
+		var c = center;
+		if (!boxTooSmall() && !boxTooBig()) {
+			circleCanvas.drawEllipse(c.x-r, c.y-r, 2*r, 2*r);
+		else {
+			new Mb_warning("The print box is too small or too big. The rotate circle is not shown.");
+		circleCanvas.paint();
+		boxCanvas.clear();
+		if (!boxTooBig()) {
+			boxCanvas.fillPolygon([
+				pointArray[0].x + c.x,
+				pointArray[1].x + c.x,
+				pointArray[2].x + c.x,
+				pointArray[3].x + c.x
+				pointArray[0].y + c.y,
+				pointArray[1].y + c.y,
+				pointArray[2].y + c.y,
+				pointArray[3].y + c.y
+		else {
+			new Mb_warning("The print box is too big. The box is not filled.");
+		// frame
+		boxCanvas.setColor(frameColour);
+			var indexA = i % 4;
+			var a = pointArray[indexA].plus(center);
+			var indexB = (i + 1) % 4;
+			var b = pointArray[indexB].plus(center);
+			boxCanvas.drawLine(a.x, a.y, b.x, b.y);
+		boxCanvas.setColor(boxColour);
+		boxCanvas.paint();
+	 * Clears all canvases, to be performed onunload.
+	this.destroy = function () {
+		activeCanvas.clear();
+		$("#" + this.id).remove();
+	var switchActiveCanvas = function () {
+		if (canvasNr == 1) {
+			canvasNr = 2;
+			activeCanvas = jg[2];
+			passiveCanvas = jg[1];
+		else {
+			canvasNr = 1;
+			activeCanvas = jg[1];
+			passiveCanvas = jg[2];
+	var $container = $("<div id='" + this.id + "' style='position:relative;top:0px;left:0px;" +
+		"'></div>");
+	var $superContainer = $("<div id='container_" + this.id + "' style='position:absolute;z-index:1000;'></div>");
+	$superContainer.append($container);
+	//$("#"+map.elementName).append($superContainer);
+	$(map_el).append($superContainer);
+	var canvasName = [
+		this.id + "_canvas_box",
+		this.id + "_canvas_points1",
+		this.id + "_canvas_points2",
+		this.id + "_canvas_circle"
+	var jg = [];
+	var canvasNr = 1;
+	for (var i = 0; i < canvasName.length; i++) {
+		$container.append(
+			$("<div id='" + canvasName[i] + "'></div>")
+		jg[i] = new jsGraphics(canvasName[i]);
+	$circleCanvas = $("#" + canvasName[3]);
+	$pointCanvas = $("#" + canvasName[1] +  ", #" + canvasName[2]);
+	$boxCanvas = $("#" + canvasName[0]);
+	$boxCanvas.css({
+		"opacity" : opacity,
+		"filter" : "alpha(opacity=" + (opacity * 100) + ")"
+	var boxCanvas = jg[0];
+	var activeCanvas = jg[1];
+	activeCanvas.setColor(pointColour);
+	var passiveCanvas = jg[2];
+	passiveCanvas.setColor(pointColour);
+	var circleCanvas = jg[3];
+	circleCanvas.setColor(circleColour);
+	circleCanvas.setStroke(circleWidth);
+	var mouseMoveStart = [];
+	var radius = 0;
+	var startRadius = 0;
+	// "constructor" functions
+	initBehaviour();
+	this.setScale(scale);
+	mb_registerPanSubElement($superContainer.get(0).id);
\ No newline at end of file
More information about the Mapbender_commits mailing list
