[Mapbender-commits] r5409 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon Jan 25 04:08:05 EST 2010
Author: christoph
Date: 2010-01-25 04:08:04 -0500 (Mon, 25 Jan 2010)
New Revision: 5409
trunk/mapbender/http/plugins/jq_ui_effects.php
Modified: trunk/mapbender/http/plugins/jq_ui_effects.php
--- trunk/mapbender/http/plugins/jq_ui_effects.php 2010-01-25 09:07:45 UTC (rev 5408)
+++ trunk/mapbender/http/plugins/jq_ui_effects.php 2010-01-25 09:08:04 UTC (rev 5409)
@@ -9,21 +9,69 @@
* - http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.*
* SQL:
- * > <SQL for element>
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<appId>','jq_ui_effect',
+ * > 1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','',
+ * > 'jq_ui_effects.php',
+ * > '../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js',
- * > <SQL for element var>
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'blind',
+ * > '0', '1 = effect active' ,'php_var');
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'bounce',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'clip',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'drop',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'explode',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'fold',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'highlight',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'pulsate',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'scale',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'shake',
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'slide',
+ * >'0', '1 = effect active' ,'php_var');
+ * > var_value, context, var_type) VALUES('<appId>', 'jq_ui_effect', 'transfer',
+ * > '1', '1 = effect active' ,'php_var');
* Help:
* http://www.mapbender.org/<wiki site name>
* Maintainer:
- * http://www.mapbender.org/User:<user>
+ * http://www.mapbender.org/User:Christoph_Baudson
- * Parameters:
- * <normal element var name> - <type and description>
- * <optional element var name> - *[optional]* <type and description>
- * <deprecated element var name> - *[deprecated]* <type and description>
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
* This program is dual licensed under the GNU General Public License
@@ -84,4 +132,4 @@
include $uiPath . "min.effects.transfer.js";
\ No newline at end of file
More information about the Mapbender_commits
