[Mapbender-commits] r5412 - branches/2.6/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jan 25 04:33:56 EST 2010
Author: christoph
Date: 2010-01-25 04:33:56 -0500 (Mon, 25 Jan 2010)
New Revision: 5412
   branches/2.6/http/html/mod_treefolderPlain.php
Modified: branches/2.6/http/html/mod_treefolderPlain.php
--- branches/2.6/http/html/mod_treefolderPlain.php	2010-01-25 09:33:12 UTC (rev 5411)
+++ branches/2.6/http/html/mod_treefolderPlain.php	2010-01-25 09:33:56 UTC (rev 5412)
@@ -36,6 +36,7 @@
 msgObj.tooltipRemoveWms = '<?php echo addslashes(_mb("Removes the selected WMS"));?>';
 msgObj.tooltipMoveSelectionUp = '<?php echo addslashes(_mb("Moves the selection up"));?>';
 msgObj.tooltipMoveSelectionDown = '<?php echo addslashes(_mb("Moves the selection down"));?>';
+msgObj.tooltipMetadata = '<?php echo addslashes(_mb("Show metadata"));?>';
 var jst_container = "document.getElementById('treeContainer')";
 var jst_image_folder = imagedir;
@@ -254,7 +255,7 @@
 				for(var iii=1; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
 					if(! mb_mapObj[i].wms[ii].objLayer[iii].has_childs){
 						path = arrNodes[0][0]+"|wms_"+ mb_mapObj[i].wms[ii].wms_id+"|"+ mb_mapObj[i].wms[ii].objLayer[iii].layer_id;
-						checkNode(path, 0,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible=='1', false);
+						checkNode(path, 0,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible==='1'||mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible===1, false);
 						if(ficheckbox == 'true')
 							checkNode(path, 1,  mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer=='1', false);
@@ -332,7 +333,7 @@
 	if( mb_mapObj[ind].wms[wms].mapURL == false ||  mb_mapObj[ind].getDomElement().ownerDocument.getElementById(map).complete){
 		if(state[wms]!=-1){
 			for(var i=1;i< mb_mapObj[ind].wms[wms].objLayer.length;i++){
-				if( mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1){
+				if(mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible===1||mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==="1"){
 					state[wms]=1;
 					if(showstatus=='true')
 						setNodeImage(img);
@@ -374,12 +375,12 @@
-function handleSelectedLayer(mapObj,wms_id,layername,type,status){
+function local_handleSelectedLayer(mapObj,wms_id,layername,type,status){
 	if(lock_update||lock_check)return;
 	var ind =  getMapObjIndexByName(mapObj);
 	for(var i=0; i< mb_mapObj[ind].wms.length; i++){
 		if( mb_mapObj[ind].wms[i].wms_id == wms_id){
-			 mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
+			mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
 			break;
@@ -503,7 +504,7 @@
 	var visibleWMS=0;
 	for(var i=0;i< mb_mapObj[j].wms.length;i++)
-		if( mb_mapObj[j].wms[i].gui_wms_visible=='1'|| mb_mapObj[j].wms[i].gui_wms_visible==1)
+		if( mb_mapObj[j].wms[i].gui_wms_visible==='1'|| mb_mapObj[j].wms[i].gui_wms_visible===1)
 			visibleWMS++;
 	if(visibleWMS<=1){
 		alert ("<?php echo addslashes(_mb('Last WMS can not be removed.'));?>");
@@ -526,6 +527,10 @@
 	if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
 		setTimeout('setNodeImage("'+path+'", "error_folder.png");', 100);
+	else{
+		setTimeout('setNodeImage("'+path+'", "closed_folder.png");', 100);
 	if(reset_lock)
 		lock_update=false;
@@ -544,8 +549,12 @@
 	lock_check=true;
 	checkChildren(path, 0, bChk);
 	if(ficheckbox)checkChildren(path, 1, bChk);
-	if(bChk==false && showstatus=='true')
+	if(bChk==false && showstatus=='true'){
+	else{
 	if(reset_lock)
 		 mb_restateLayers(mod_treeGDE_map,wms_id);
@@ -581,12 +590,14 @@
 		for(var i=0; i< mb_mapObj.length; i++){
 			if( mb_mapObj[i].elementName == mod_treeGDE_map){
 				for(var ii=0; ii< mb_mapObj[i].wms.length; ii++){
-					if( mb_mapObj[i].wms[ii].gui_wms_visible == '1' ||  mb_mapObj[i].wms[ii].gui_wms_visible == 1){
+					if( mb_mapObj[i].wms[ii].gui_wms_visible === '1' ||  mb_mapObj[i].wms[ii].gui_wms_visible === 1){
 						for(var iii=0; iii< mb_mapObj[i].wms[ii].objLayer.length; iii++){
 							var temp =  mb_mapObj[i].wms[ii].objLayer[iii];
 							if( mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
-								if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
+								if(temp.gui_layer_selectable !== '1' && temp.gui_layer_queryable !== '1'
+								&& temp.gui_layer_selectable !== 1 && temp.gui_layer_queryable !== 1) {
 									continue;
 								parentNode = arrNodes[0][0];
 								if(eval("categories.wms_"+ mb_mapObj[i].wms[ii].wms_id) !== undefined)
@@ -611,7 +622,7 @@
 								c_menu+="]";
 								controls=null;
 								if(switchwms=='true')controls='<INPUT type="checkbox" title="' + msgObj.tooltipHandleWms + '"  onclick="handleSelectedWMS(\''+parentNode+'|wms_'+ mb_mapObj[i].wms[ii].wms_id+'\');" />';
-								if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
+								if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');'+'"><img alt="'+msgObj.tooltipMetadata+'" title="'+msgObj.tooltipMetadata+'" src="'+imagedir+'/info.png" /></a>';
 								addNode(parentNode,["wms_"+ mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
 								parentObj = parentNode+"|wms_"+ mb_mapObj[i].wms[ii].wms_id;
@@ -628,7 +639,8 @@
 									parentLayer = "|" +  mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
-								if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
+								if(temp.gui_layer_selectable === '1' || temp.gui_layer_selectable === 1
+									|| temp.gui_layer_queryable === '1' || temp.gui_layer_queryable === 1){
 									var c_menu="[";
 									if(reverse=="true"){
 										if(menu.indexOf("layer_down")!=-1 && iii!= mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
@@ -649,26 +661,27 @@
 									controls.push('<input type="checkbox"  title="' + msgObj.tooltipLayerVisible + '" ');
 									if(temp.layer_name=="")
 										controls.push('style="display:none;" ');
-									if(temp.gui_layer_visible=='1')
+									if(temp.gui_layer_visible==='1' ||temp.gui_layer_visible===1){
 										controls.push('checked ');
-									if(temp.gui_layer_selectable!='1')
+									if(temp.gui_layer_selectable!=='1' && temp.gui_layer_selectable!==1)
 										controls.push('disabled ');
-									controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
+									controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
 									if(ficheckbox == 'false')
-										controls.push("handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+										controls.push("local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
 									controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);");
 									controls.push("updateParent('"+parentObj+parentLayer+"');\" />");
 									if(ficheckbox == 'true'){
 										controls.push('<input type="checkbox" title="' + msgObj.tooltipLayerQuerylayer + '" ');
 										if(temp.gui_layer_querylayer=='1')
-										if(temp.gui_layer_queryable!='1')
+										if(temp.gui_layer_queryable !== '1' && temp.gui_layer_queryable !== 1)
-										controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+										controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
 										controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
 									if(wmsbuttons == 'true'&&metadatalink == 'true'){
-										controls.push('<a href="javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');"><img src="'+imagedir+'/info.png" /></a>');
+										controls.push('<a href="javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');"><img alt="'+msgObj.tooltipMetadata+'" title="'+msgObj.tooltipMetadata+'" src="'+imagedir+'/info.png" /></a>');
 									addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),temp.layer_title,eval(c_menu),controls.join(""),[i,ii,iii]]],false,false,reverse=="true");
@@ -688,7 +701,7 @@
More information about the Mapbender_commits mailing list
