[Mapbender-commits] r5433 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 26 06:20:54 EST 2010
Author: christoph
Date: 2010-01-26 06:20:52 -0500 (Tue, 26 Jan 2010)
New Revision: 5433
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-26 10:59:42 UTC (rev 5432)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-26 11:20:52 UTC (rev 5433)
@@ -1107,3 +1107,17 @@
 DELETE FROM gui_element_vars WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame';
+-- set UI classes for treeGDE
+UPDATE gui_element SET e_more_styles = 'visibility:hidden;overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
+WHERE e_id = 'treeGDE' AND fkey_gui_id IN
+(SELECT fkey_gui_id FROM gui_element AS a, gui_element AS b WHERE a.e_id = 'tabs' AND b.e_id = 'treeGDE' AND a.fkey_gui_id = b.fkey_gui_id);
+-- remove expanding treeGDE in gui1
+UPDATE gui_element SET e_more_styles = 'overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
+WHERE e_id = 'treeGDE' AND fkey_gui_id IN ('gui1');
+-- add jQuery UI theme to all applications that have a body
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui.gui_id,'body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css'
+FROM gui, gui_element WHERE gui.gui_id = gui_element.fkey_gui_id AND gui_element.e_id = 'body';
More information about the Mapbender_commits mailing list
