[Mapbender-commits] r5457 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 29 07:46:04 EST 2010
Author: christoph
Date: 2010-01-29 07:46:01 -0500 (Fri, 29 Jan 2010)
New Revision: 5457
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
new container jQuery UI toolbox
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-29 11:47:05 UTC (rev 5456)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-29 12:46:01 UTC (rev 5457)
@@ -1121,3 +1121,57 @@
 SELECT gui.gui_id,'body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css'
 FROM gui, gui_element WHERE gui.gui_id = gui_element.fkey_gui_id AND gui_element.e_id = 'body';
+-- add resultList to gui
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url)
+VALUES('gui','resultList',2,1,'','Result List','div','','',NULL ,NULL
+,NULL ,NULL ,NULL
+,'','','div','mod_ResultList.js','../../lib/resultGeometryListController.js,
+../../lib/resultGeometryListModel.js','mapframe1','','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
+-- add new container toolbox_jquery
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('toolbox_jquery','toolbox_jquery','All jQuery related elements in Mapbender',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','body',1,1,'body (obligatory)','','body','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_datatables',1,1,'jQuery plugin datatables, use like this
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_jgrowl',1,1,'A growl like widget to display messages','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_jgrowl.js','../extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js','','','http://stanlemon.net/projects/jgrowl.html');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui',1,1,'jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.core.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_accordion',2,1,'accordion from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js','','jq_ui','http://docs.jquery.com/UI/Accordion');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_dialog.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.dialog.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_logo',2,1,'Logo','jQuery UI Logo','img','../img/jquery_ui_logo.png','',35,15,NULL ,NULL ,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.resizable.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_slider',5,1,'slider from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.slider.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.tabs.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_ui_themeroller',1,1,'A button that opens the ThemeRoller from a remote site','Themeroller','a','','class=''ui-state-default ui-corner-all''
+href="javascript:(function(){if%20(!/Firefox/.test(navigator.userAgent)){alert(navigator.userAgent);%20return%20false;%20};%20if(window.jquitr){%20jquitr.addThemeRoller();%20}%20else{%20jquitr%20=%20{};%20jquitr.s%20=%20document.createElement(''script'');%20jquitr.s.src%20=%20''http://jqueryui.com/themeroller/developertool/developertool.js.php'';%20document.getElementsByTagName(''head'')[0].appendChild(jquitr.s);}%20})();"',320,15,NULL ,NULL ,NULL ,'text-decoration:none;padding:0.4em 1em 0.4em 20px','Custom theme','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('toolbox_jquery','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'body', 'jq_ui_effects_transfer', '.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ', '', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'body', 'jq_ui_theme', '../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css', 'UI Theme from Themeroller', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'blind', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'bounce', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'clip', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'drop', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'explode', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'fold', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'highlight', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'pulsate', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'scale', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'transfer', '1', '1 = effect active', 'php_var');
\ No newline at end of file
More information about the Mapbender_commits mailing list
