[Mapbender-commits] r5719 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Mar 3 01:19:14 EST 2010
Author: armin11
Date: 2010-03-03 01:19:14 -0500 (Wed, 03 Mar 2010)
New Revision: 5719
trunk/mapbender/http/php/mod_deleteWMS.php
show detailed info about wms in delete modul
Modified: trunk/mapbender/http/php/mod_deleteWMS.php
--- trunk/mapbender/http/php/mod_deleteWMS.php 2010-03-02 15:30:59 UTC (rev 5718)
+++ trunk/mapbender/http/php/mod_deleteWMS.php 2010-03-03 06:19:14 UTC (rev 5719)
@@ -241,7 +241,14 @@
if($wmsList)
+ $sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_pos=0";
+ $v = array($wmsList);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ $row = db_fetch_array($res);
+ echo "view wms metadata: <a id='metadatalink' href='mod_layerMetadata.php?id=".$row["layer_id"]."' onclick='window.open(this.href,\"Metadaten\",\"width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes\"); return false' target='_blank'><span id='metadatatext'>WMS ID: ".$wmsList."</span></a><br><br>";
echo "<p class = 'guiList'>";
// Show GUIs using chosen WMS
$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1";
More information about the Mapbender_commits
