[Mapbender-commits] r5740 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Tue Mar 9 11:25:53 EST 2010
Author: verenadiewald
Date: 2010-03-09 11:25:52 -0500 (Tue, 09 Mar 2010)
New Revision: 5740
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
removed duplicate entry of element var jq_ui_theme for body element
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-03-09 16:21:26 UTC (rev 5739)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-03-09 16:25:52 UTC (rev 5740)
@@ -1110,11 +1110,6 @@
UPDATE gui_element SET e_more_styles = 'overflow:auto', e_attributes = 'class="ui-widget ui-widget-content"'
WHERE e_id = 'treeGDE' AND fkey_gui_id IN ('gui1');
--- add jQuery UI theme to all applications that have a body
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
-SELECT gui.gui_id,'body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css'
-FROM gui, gui_element WHERE gui.gui_id = gui_element.fkey_gui_id AND gui_element.e_id = 'body';
-- add resultList to gui
INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
More information about the Mapbender_commits
