[Mapbender-commits] r5795 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Tue Mar 16 16:50:31 EDT 2010
Author: armin11
Date: 2010-03-16 16:50:30 -0400 (Tue, 16 Mar 2010)
New Revision: 5795
trunk/mapbender/http/classes/class_metadata_new.php
trunk/mapbender/http/php/mod_callMetadata.php
small changes in the new search module - push the search classes in the filter file so that the client knows which resource types are searched
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php 2010-03-16 17:53:13 UTC (rev 5794)
+++ trunk/mapbender/http/classes/class_metadata_new.php 2010-03-16 20:50:30 UTC (rev 5795)
@@ -177,7 +177,7 @@
$this->generateWFSMetadata($this->wfsDoc);
if (isset($this->searchResources) & strtolower($this->searchResources) === "wms") {
- $this->searchView = 'search_wms_view';
+ $this->searchView = 'wms_search_table_test';
$this->orderBy = " ORDER BY load_count DESC";
$this->resourceClasses = array(0,1,2);
$this->generateWMSMetadata($this->wmsDoc);
@@ -468,6 +468,12 @@
else {
$this->wmsJSON->wms->srv[$j]->layer[0]->loadable = 1;
+ if ($subLayers[$rootIndex]['layer_pos'] == '0'){
+ $this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = true;
+ else {
+ $this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = false;
//give info for inspire categories - not relevant for other services or instances of mapbender TODO: comment it if the mapbender installation is not used to generate inspire output
if ($subLayers[$rootIndex]['md_inspire_cats'] == ''){
$this->wmsJSON->wms->srv[$j]->layer[0]->inspire = 0;
@@ -519,7 +525,7 @@
$this->wmsJSON = $this->json->encode($this->wmsJSON);
if ($this->resultTarget == 'file') {
if($wmsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
- fwrite($wmsFileHandle,$this->wfsJSON);
+ fwrite($wmsFileHandle,$this->wmsJSON);
fclose($wmsFileHandle);
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php 2010-03-16 17:53:13 UTC (rev 5794)
+++ trunk/mapbender/http/php/mod_callMetadata.php 2010-03-16 20:50:30 UTC (rev 5795)
@@ -38,8 +38,8 @@
$languageCode = "de";
$outputFormat = 'json';
#$searchResources = "wms,wfs,wmc,georss";
-$searchResources = "wms";
-$searchPages = "1,1,1,1";
+#$searchResources = "wms";
+$searchPages = "1";
$resultTarget = "debug";
$searchEPSG = "EPSG:31466";
$classJSON = new Mapbender_JSON;
@@ -248,14 +248,7 @@
$searchPages = $testMatch;
$testMatch = NULL;
-$searchPages = $_REQUEST["searchPages"];
+#$searchPages = $_REQUEST["searchPages"];
#$searchPages = split(',',$searchPages);
@@ -282,14 +275,9 @@
#$searchPages = array(1,1,1,1);
//TODO: if class is called directly
- #$registratingDepartments = explode(",",$registratingDepartments);
- #$isoCategories = explode(",",$isoCategories);
- #$inspireThemes = explode(",",$inspireThemes);
- #$searchBbox = explode(",",$searchBbox);
- $searchResources = explode(",",$searchResources);
- $searchPages = explode(",",$searchPages);
//read the whole query string:
$searchURL = $_SERVER['QUERY_STRING'];
if ($resultTarget == 'debug') {
@@ -298,8 +286,25 @@
+if ($resultTarget == 'file') {
+ if (!isset($searchResources) OR ($searchResources == "")) {
+ $searchResources = "wms,wfs";
+ $searchPages = "1,1";
+if ($resultTarget == 'web' or $resultTarget == 'debug') {
+ $searchResources = "wms";
+ $searchPages = "1";
+//convert the respources and the pagenumbers into arrays
+$searchResources = explode(",",$searchResources);
+$searchPages = explode(",",$searchPages);
//Generate search filter file. This file holds the defined search filter to allow the user to see how he searched
//The user should become the possibility to drop the search filters by clicking in some buttons
//list of options to display:
@@ -430,6 +435,10 @@
//define where to become the information from - this is relavant for the information which must be pulled out of the database
$classificationElements = array();
$classificationElements[0]['name'] = 'searchText';
$classificationElements[1]['name'] = 'registratingDepartments';
$classificationElements[2]['name'] = 'isoCategories';
@@ -457,8 +466,14 @@
$classificationElements[6]['list'] = false;
$classificationElements[7]['list'] = false;
+//Defining of the different result categories
+ $resourceCategories = array();
+ #$resourceCategories[0]['wms'] = 'WMS';
+ #$resourceCategories[1]['wfs'] = 'WFS';
+ #$resourceCategories[2]['wmc'] = 'WMC';
+ #$resourceCategories[3]['georss'] = 'GeoRSS';
switch($languageCode){
case 'de':
$classificationElements[0]['name2show'] = 'Suchbegriff(e):';
@@ -469,6 +484,11 @@
$classificationElements[5]['name2show'] = 'Räumliche Einschränkung:';
$classificationElements[6]['name2show'] = 'Registrierung/Aktualisierung von:';
$classificationElements[7]['name2show'] = 'Registrierung/Aktualisierung bis:';
+ $resourceCategories['wms'] = 'Darstellungsdienste';
+ $resourceCategories['wfs'] = 'Such- und Downloaddienste';
+ $resourceCategories['wmc'] = 'Kartenzusammenstellungen';
+ $resourceCategories['georss'] = 'Geokodierte Newsfeeds';
break;
case 'en':
@@ -481,6 +501,11 @@
$classificationElements[6]['name2show'] = 'Registration/Update from:';
$classificationElements[7]['name2show'] = 'Registration/Update till:';
+ $resourceCategories['wms'] = 'Viewingservices';
+ $resourceCategories['wfs'] = 'Search- and Downloadservices';
+ $resourceCategories['wmc'] = 'Combined Maps';
+ $resourceCategories['georss'] = 'Geocodet Newsfeeds';
break;
case 'fr':
@@ -492,6 +517,11 @@
break;
default:
@@ -503,11 +533,21 @@
$queryJSON = new stdClass;
$queryJSON->searchFilter = (object) array();
+#$queryJSON->searchFilter->classes = (object) array();
+for($i=0; $i<count($searchResources);$i++){
+//fill in the different search classes into the filter - the client can generate the headers out of this information
+ $queryJSON->searchFilter->classes[$i]->title = $resourceCategories[$searchResources[$i]];
+ $queryJSON->searchFilter->classes[$i]->name = $searchResources[$i];
//generate search filter file - if more categories are defined give
#echo "<br> number of filter elements: ".count($classificationElements)."<br>";
for($i=0; $i < count($classificationElements); $i++){
@@ -630,6 +670,8 @@
//call class_metadata - in case of file for all requested resources, in case of web only for one resource - cause there are different result files
$str = "nohup php5 /data/mapbender/http/php/mod_metadataWrite.php ";
More information about the Mapbender_commits
