[Mapbender-commits] r5801 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Wed Mar 17 06:53:54 EDT 2010
Author: verenadiewald
Date: 2010-03-17 06:53:53 -0400 (Wed, 17 Mar 2010)
New Revision: 5801
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
element var meetingPoint_export_url for element meetingPoint
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-03-17 10:47:12 UTC (rev 5800)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-03-17 10:53:53 UTC (rev 5801)
@@ -1566,3 +1566,24 @@
gui_element.fkey_gui_id
NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'featureInfo1' AND var_name = 'featureInfoPopupPosition');
+-- add element var meetingPoint_export_url to element meetingPoint
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui_element.fkey_gui_id,
+'meetingPoint', 'meetingPoint_export_url', '', 'set the export url for your meeting point (has to be a URL pointing to ..mapbender/frames/login.php)' ,'var'
+from gui_element
+WHERE
+gui_element.e_id = 'meetingPoint' AND
+gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'meetingPoint' AND var_name = 'meetingPoint_export_url');
More information about the Mapbender_commits
