[Mapbender-commits] r5821 -
branches/2.6/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Mar 19 13:34:57 EDT 2010
Author: marc
Date: 2010-03-19 13:34:56 -0400 (Fri, 19 Mar 2010)
New Revision: 5821
branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
set white background-color to treeGDE in gui2
Modified: branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
--- branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql 2010-03-19 16:08:43 UTC (rev 5820)
+++ branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql 2010-03-19 17:34:56 UTC (rev 5821)
@@ -345,11 +345,13 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var'
FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id NOT IN
-(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
--- http://trac.osgeo.org/mapbender/ticket/590 toggle Module and measure
-UPDATE gui_element set e_attributes ='onmouseover = "mb_regButton(''init_mod_measure'')"' where e_id='measure';
---Delete filter:Chroma styles from gui2
-UPDATE gui_element SET e_more_styles='' WHERE fkey_gui_id='gui2' AND e_more_styles ilike 'filter:Chroma%';
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
+-- http://trac.osgeo.org/mapbender/ticket/590 toggle Module and measure
+UPDATE gui_element set e_attributes ='onmouseover = "mb_regButton(''init_mod_measure'')"' where e_id='measure';
+--Delete filter:Chroma styles from gui2
+UPDATE gui_element SET e_more_styles='' WHERE fkey_gui_id='gui2' AND e_more_styles ilike 'filter:Chroma%';
+-- set white background-color to treeGDE in gui2
+UPDATE gui_element SET e_more_styles='visibility:visible;overflow:scroll;background-color:#ffffff;' WHERE fkey_gui_id='gui2' and e_id='treeGDE';
\ No newline at end of file
More information about the Mapbender_commits
