[Mapbender-commits] r6097 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 7 08:31:04 EDT 2010
Author: verenadiewald
Date: 2010-05-07 08:31:03 -0400 (Fri, 07 May 2010)
New Revision: 6097
   trunk/mapbender/resources/db/metadataGui.sql
new gui element mb_md_showOriginal
Modified: trunk/mapbender/resources/db/metadataGui.sql
--- trunk/mapbender/resources/db/metadataGui.sql	2010-05-07 12:20:45 UTC (rev 6096)
+++ trunk/mapbender/resources/db/metadataGui.sql	2010-05-07 12:31:03 UTC (rev 6097)
@@ -29,6 +29,7 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview_save',2,1,'','','img','../img/button_gray/wmc_save_off.png','',NULL ,NULL ,NULL ,NULL ,NULL ,'display: none;','','','../plugins/mb_metadata_saveLayerPreview.js','','mapframe1','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_tree',2,1,'Select a layer from a layer tree','Select a layer from a layer tree','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerTree.js','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'display:none;','','div','../plugins/mb_metadata_showOriginal.js','','','jq_ui_dialog','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_submit',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<input type=''button'' value=''Preview metadata''><input type=''button'' value=''Save metadata''>','div','','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_select,mb_md_edit,mb_md_layer','jq_ui_tabs','');
@@ -220,6 +221,19 @@
 ] ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_showOriginal', 'inputs', '[
+        "method": "init",
+        "title": "initialize",
+        "linkedTo": [
+                "id": "mb_md_edit",
+                "event": "showOriginalMetadata",
+                "attr": "data"
+]', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'center', 'mb_tabs_horizontal', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'south', 'mb_md_submit', '', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_tabs_horizontal', 'inputs', '[
More information about the Mapbender_commits mailing list
