[Mapbender-commits] r6101 - in branches/3_dev: core http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun May 9 07:32:14 EDT 2010
Author: christoph
Date: 2010-05-09 07:32:13 -0400 (Sun, 09 May 2010)
New Revision: 6101
Added:
   branches/3_dev/core/elementVarsJsObject.php
   branches/3_dev/http/javascripts/map.php
element vars from db to js
Added: branches/3_dev/core/elementVarsJsObject.php
--- branches/3_dev/core/elementVarsJsObject.php	                        (rev 0)
+++ branches/3_dev/core/elementVarsJsObject.php	2010-05-09 11:32:13 UTC (rev 6101)
@@ -0,0 +1,86 @@
+<?php
+# $Id: dyn_js.php 3850 2009-04-03 09:02:12Z christoph $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_wfs.php,v 1.15 2006/03/09 13:55:46 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once dirname(__FILE__) . "/lib/class_Log_Exception.php";
+if (isset($gui_id)) {
+	$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2 and var_type='var'";
+	$v = array($e_id, $gui_id);
+	$t = array('s', 's');
+   	$res = db_prep_query($sql, $v, $t);
+	$arrays = array();
+	$varArray = array();
+	while ($row = db_fetch_array($res)) {
+		if (mb_strpos($row["var_name"], "[")) {
+			// backwards compatibility for var names like name[0], name[1] etc
+			$arrayname = mb_substr($row["var_name"], 0, mb_strpos($row["var_name"], "["));
+			if (!in_array($arrayname, $arrays)) {
+				$arrays[]= $arrayname;
+				$varArray[]= $arrayname  . ": []";
+			else {
+				for ($i = 0; $i < count($varArray); $i++) {
+					if (mb_substr($varArray[$i], 0, mb_strlen($arrayname) + 1) === $arrayname . ":") {
+						if (is_numeric(stripslashes($row["var_value"]) ||
+							strpos(stripslashes($row["var_value"]), "[") === 0 ||
+							strpos(stripslashes($row["var_value"]), "{") === 0)) {
+							$varArray[$i] = substr_replace(
+								$varArray[$i],
+								$row["var_name"].": ".stripslashes($row["var_value"]) . "]",
+								-1);
+						else {
+								$varArray[$i],
+								$row["var_name"].": '".stripslashes($row["var_value"]) . "']",
+								-1);
+		if (is_numeric(stripslashes($row["var_value"]))) {
+			$varArray[]= $row["var_name"].": ".stripslashes($row["var_value"]);
+		elseif (strpos(stripslashes($row["var_value"]), "[") === 0 ||
+				strpos(stripslashes($row["var_value"]), "{") === 0) {
+		else {
+			$varArray[]= $row["var_name"].": '" .
+				str_replace(
+					array('"',"'", "\r", "\n", "\0"),
+					array('\"','\\\'','\r', '\n', '\0'),
+					stripslashes($row["var_value"])
+	echo "$.extend(options, {";
+	echo implode(",\n", $varArray);
+	echo "});";
+else {
+	$e = new mb_exception("Application ID not set while retrieving element vars of module " . $e_id);
\ No newline at end of file
Modified: branches/3_dev/http/javascripts/map.php
--- branches/3_dev/http/javascripts/map.php	2010-05-07 15:47:54 UTC (rev 6100)
+++ branches/3_dev/http/javascripts/map.php	2010-05-09 11:32:13 UTC (rev 6101)
@@ -168,7 +168,7 @@
 			echo "var options = Mapbender.modules." . $e_id . ";\n";
 			// extend the options variable by JS element vars
-			include "../include/dyn_js_object.php";
+			include "../../core/elementVarsJsObject.php";
 			echo "\n$.fn.$e_id = function (options) {\n" .
 				"\treturn this.each(function () {\n\n";
More information about the Mapbender_commits mailing list
