[Mapbender-commits] r6108 -
branches/3_dev/http/extensions/jquery.layout.all-1.2.0
svn_mapbender at osgeo.org
Sun May 9 09:28:08 EDT 2010
Author: christoph
Date: 2010-05-09 09:28:08 -0400 (Sun, 09 May 2010)
New Revision: 6108
Added:
branches/3_dev/http/extensions/jquery.layout.all-1.2.0/changelog.txt
branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.js
branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.js
branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.min.js
Added: branches/3_dev/http/extensions/jquery.layout.all-1.2.0/changelog.txt
--- branches/3_dev/http/extensions/jquery.layout.all-1.2.0/changelog.txt (rev 0)
+++ branches/3_dev/http/extensions/jquery.layout.all-1.2.0/changelog.txt 2010-05-09 13:28:08 UTC (rev 6108)
@@ -0,0 +1,60 @@
+1.2.0
+* ADDED maskIframesOnResize option: true=ALL -OR- a selector string
+* ADDED options to set different animations on open and close
+* ADDED new callback events, ie: onshow, onhide
+* ADDED start/end callbacks, eg: onopen_start, onopen_end, etc.
+* ADDED ability to cancel events using callbacks, eg: onopen_start
+* CHANGED Layout.config.fxDefaults to Layout.effects (internal use)
+* FIXED missing semi-colon so minified version works in IE
+1.1.3
+* FIXED typo in cursor-hotkeys code
+* ADDED scrollToBookmarkOnLoad options - enables use of URL hash:
+ o www.site.com/page.html#myBookmark
+ o AFTER layout is created, attempts to scroll to bookmark
+ o default = true - otherwise bookmarks are non-functional
+1.1.2
+* UPDATED paneSelector rules to handle FORMS and pane-nesting
+ o automatically looks for panes inside 'first form' in container
+ o if using an ID as paneSelector, pane can be 'deeply nested'
+* ADDED auto-CSS for 'containers' other than BODY
+ o overflow: hidden - ensures no scrollbars on container
+ o position: relative - IF NOT: fixed, absolute or relative
+ o height: 100% - IF NOT specified or is 'auto'
+* ADDED noAnimation param to open() and close() - not used internally
+1.1.1
+* CHANGED toggler element from a SPAN to a DIV
+* CHANGED auto-generated custom-buttons classes for better consistency
+ o [buttonClass]-[pane]-[buttonType] ==> [buttonClass]-[buttonType]-[pane]
+ o ui-layout-button-west-open ==> ui-layout-button-open-west
+ o ui-layout-button-west-pin-up ==> ui-layout-button-pin-west-up
+* CHANGED default for hideTogglerOnSlide to false
+* CHANGED internal 'cDims' hash to alias for state.container
+* CHANGED internal aliases: s = state[pane] and o = options[pane]
+* UPDATED toggler-text to auto-show correct spans (content-open/closed)
+* FIXED toggler-text - now centers text span correctly
+* FIXED bug affecting IE6 when layout has no north or south pane
+* ADDED new layout property 'state' - eg: myLayout.state.west.size
+* REMOVED layout.containerDimensions property - USE: layout.state.container
+* CHANGED data returned to callbacks - added pane-state as 3rd param
+1.1.0
+* RENAMED raisePaneZindexOnHover ==> showOverflowOnHover
+* REMOVED "overflow: auto" from base-styles. Overflow must now be set by
+ CSS - unless applyDefaultStyles==true. No longer need "!important" to
+ set pane overflow in your stylesheet.
+* CHANGED minSize default from 50 to 0 (still auto-limited to 'css size')
+* FIXED bug in allowOverflow - now works with 'custom paneClass'
+* EXPOSED two CSS utility methods
+ o myLayout.cssWidth( elem )
+ o myLayout.cssHeight( elem )
+* NEW auto-resize for ALL layouts on windows.resize
+* UPDATED auto-resizing of panes after a container-resize
+* NEW flow-code to prevent simultaneous pane animations
+* NEW options to add text inside toggler-buttons
+* NEW options for hotkeys - standard (cursors) and user-defined
+1.0
+* Initial release
\ No newline at end of file
Added: branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.js
--- branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.js (rev 0)
+++ branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.js 2010-05-09 13:28:08 UTC (rev 6108)
@@ -0,0 +1,3549 @@
+(function(){
+ * jQuery 1.2.6 - New Wave Javascript
+ * Copyright (c) 2008 John Resig (jquery.com)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * $Date: 2008-05-24 14:22:17 -0400 (Sat, 24 May 2008) $
+ * $Rev: 5685 $
+// Map over jQuery in case of overwrite
+var _jQuery = window.jQuery,
+// Map over the $ in case of overwrite
+ _$ = window.$;
+var jQuery = window.jQuery = window.$ = function( selector, context ) {
+ // The jQuery object is actually just the init constructor 'enhanced'
+ return new jQuery.fn.init( selector, context );
+// A simple way to check for HTML strings or ID strings
+// (both of which we optimize for)
+var quickExpr = /^[^<]*(<(.|\s)+>)[^>]*$|^#(\w+)$/,
+// Is it a simple selector
+ isSimple = /^.[^:#\[\.]*$/,
+// Will speed up references to undefined, and allows munging its name.
+ undefined;
+jQuery.fn = jQuery.prototype = {
+ init: function( selector, context ) {
+ // Make sure that a selection was provided
+ selector = selector || document;
+ // Handle $(DOMElement)
+ if ( selector.nodeType ) {
+ this[0] = selector;
+ this.length = 1;
+ return this;
+ // Handle HTML strings
+ if ( typeof selector == "string" ) {
+ // Are we dealing with HTML string or an ID?
+ var match = quickExpr.exec( selector );
+ // Verify a match, and that no context was specified for #id
+ if ( match && (match[1] || !context) ) {
+ // HANDLE: $(html) -> $(array)
+ if ( match[1] )
+ selector = jQuery.clean( [ match[1] ], context );
+ // HANDLE: $("#id")
+ else {
+ var elem = document.getElementById( match[3] );
+ // Make sure an element was located
+ if ( elem ){
+ // Handle the case where IE and Opera return items
+ // by name instead of ID
+ if ( elem.id != match[3] )
+ return jQuery().find( selector );
+ // Otherwise, we inject the element directly into the jQuery object
+ return jQuery( elem );
+ selector = [];
+ // HANDLE: $(expr, [context])
+ // (which is just equivalent to: $(content).find(expr)
+ } else
+ return jQuery( context ).find( selector );
+ // HANDLE: $(function)
+ // Shortcut for document ready
+ } else if ( jQuery.isFunction( selector ) )
+ return jQuery( document )[ jQuery.fn.ready ? "ready" : "load" ]( selector );
+ return this.setArray(jQuery.makeArray(selector));
+ // The current version of jQuery being used
+ jquery: "1.2.6",
+ // The number of elements contained in the matched element set
+ size: function() {
+ return this.length;
+ length: 0,
+ // Get the Nth element in the matched element set OR
+ // Get the whole matched element set as a clean array
+ get: function( num ) {
+ return num == undefined ?
+ // Return a 'clean' array
+ jQuery.makeArray( this ) :
+ // Return just the object
+ this[ num ];
+ // Take an array of elements and push it onto the stack
+ // (returning the new matched element set)
+ pushStack: function( elems ) {
+ // Build a new jQuery matched element set
+ var ret = jQuery( elems );
+ // Add the old object onto the stack (as a reference)
+ ret.prevObject = this;
+ // Return the newly-formed element set
+ return ret;
+ // Force the current matched set of elements to become
+ // the specified array of elements (destroying the stack in the process)
+ // You should use pushStack() in order to do this, but maintain the stack
+ setArray: function( elems ) {
+ // Resetting the length to 0, then using the native Array push
+ // is a super-fast way to populate an object with array-like properties
+ this.length = 0;
+ Array.prototype.push.apply( this, elems );
+ return this;
+ // Execute a callback for every element in the matched set.
+ // (You can seed the arguments with an array of args, but this is
+ // only used internally.)
+ each: function( callback, args ) {
+ return jQuery.each( this, callback, args );
+ // Determine the position of an element within
+ // the matched set of elements
+ index: function( elem ) {
+ var ret = -1;
+ // Locate the position of the desired element
+ return jQuery.inArray(
+ // If it receives a jQuery object, the first element is used
+ elem && elem.jquery ? elem[0] : elem
+ , this );
+ attr: function( name, value, type ) {
+ var options = name;
+ // Look for the case where we're accessing a style value
+ if ( name.constructor == String )
+ if ( value === undefined )
+ return this[0] && jQuery[ type || "attr" ]( this[0], name );
+ else {
+ options = {};
+ options[ name ] = value;
+ // Check to see if we're setting style values
+ return this.each(function(i){
+ // Set all the styles
+ for ( name in options )
+ jQuery.attr(
+ type ?
+ this.style :
+ this,
+ name, jQuery.prop( this, options[ name ], type, i, name )
+ css: function( key, value ) {
+ // ignore negative width and height values
+ if ( (key == 'width' || key == 'height') && parseFloat(value) < 0 )
+ value = undefined;
+ return this.attr( key, value, "curCSS" );
+ text: function( text ) {
+ if ( typeof text != "object" && text != null )
+ return this.empty().append( (this[0] && this[0].ownerDocument || document).createTextNode( text ) );
+ var ret = "";
+ jQuery.each( text || this, function(){
+ jQuery.each( this.childNodes, function(){
+ if ( this.nodeType != 8 )
+ ret += this.nodeType != 1 ?
+ this.nodeValue :
+ jQuery.fn.text( [ this ] );
+ return ret;
+ wrapAll: function( html ) {
+ if ( this[0] )
+ // The elements to wrap the target around
+ jQuery( html, this[0].ownerDocument )
+ .clone()
+ .insertBefore( this[0] )
+ .map(function(){
+ var elem = this;
+ while ( elem.firstChild )
+ elem = elem.firstChild;
+ return elem;
+ .append(this);
+ return this;
+ wrapInner: function( html ) {
+ return this.each(function(){
+ jQuery( this ).contents().wrapAll( html );
+ wrap: function( html ) {
+ jQuery( this ).wrapAll( html );
+ append: function() {
+ return this.domManip(arguments, true, false, function(elem){
+ if (this.nodeType == 1)
+ this.appendChild( elem );
+ prepend: function() {
+ return this.domManip(arguments, true, true, function(elem){
+ this.insertBefore( elem, this.firstChild );
+ before: function() {
+ return this.domManip(arguments, false, false, function(elem){
+ this.parentNode.insertBefore( elem, this );
+ after: function() {
+ return this.domManip(arguments, false, true, function(elem){
+ this.parentNode.insertBefore( elem, this.nextSibling );
+ end: function() {
+ return this.prevObject || jQuery( [] );
+ find: function( selector ) {
+ var elems = jQuery.map(this, function(elem){
+ return jQuery.find( selector, elem );
+ return this.pushStack( /[^+>] [^+>]/.test( selector ) || selector.indexOf("..") > -1 ?
+ jQuery.unique( elems ) :
+ elems );
+ clone: function( events ) {
+ // Do the clone
+ var ret = this.map(function(){
+ if ( jQuery.browser.msie && !jQuery.isXMLDoc(this) ) {
+ // IE copies events bound via attachEvent when
+ // using cloneNode. Calling detachEvent on the
+ // clone will also remove the events from the orignal
+ // In order to get around this, we use innerHTML.
+ // Unfortunately, this means some modifications to
+ // attributes in IE that are actually only stored
+ // as properties will not be copied (such as the
+ // the name attribute on an input).
+ var clone = this.cloneNode(true),
+ container = document.createElement("div");
+ container.appendChild(clone);
+ return jQuery.clean([container.innerHTML])[0];
+ } else
+ return this.cloneNode(true);
+ // Need to set the expando to null on the cloned set if it exists
+ // removeData doesn't work here, IE removes it from the original as well
+ // this is primarily for IE but the data expando shouldn't be copied over in any browser
+ var clone = ret.find("*").andSelf().each(function(){
+ if ( this[ expando ] != undefined )
+ this[ expando ] = null;
+ // Copy the events from the original to the clone
+ if ( events === true )
+ this.find("*").andSelf().each(function(i){
+ if (this.nodeType == 3)
+ return;
+ var events = jQuery.data( this, "events" );
+ for ( var type in events )
+ for ( var handler in events[ type ] )
+ jQuery.event.add( clone[ i ], type, events[ type ][ handler ], events[ type ][ handler ].data );
+ // Return the cloned set
+ return ret;
+ filter: function( selector ) {
+ jQuery.isFunction( selector ) &&
+ jQuery.grep(this, function(elem, i){
+ return selector.call( elem, i );
+ jQuery.multiFilter( selector, this ) );
+ not: function( selector ) {
+ if ( selector.constructor == String )
+ // test special case where just one selector is passed in
+ if ( isSimple.test( selector ) )
+ return this.pushStack( jQuery.multiFilter( selector, this, true ) );
+ else
+ selector = jQuery.multiFilter( selector, this );
+ var isArrayLike = selector.length && selector[selector.length - 1] !== undefined && !selector.nodeType;
+ return this.filter(function() {
+ return isArrayLike ? jQuery.inArray( this, selector ) < 0 : this != selector;
+ add: function( selector ) {
+ return this.pushStack( jQuery.unique( jQuery.merge(
+ this.get(),
+ typeof selector == 'string' ?
+ jQuery( selector ) :
+ jQuery.makeArray( selector )
+ is: function( selector ) {
+ return !!selector && jQuery.multiFilter( selector, this ).length > 0;
+ hasClass: function( selector ) {
+ return this.is( "." + selector );
+ val: function( value ) {
+ if ( value == undefined ) {
+ if ( this.length ) {
+ var elem = this[0];
+ // We need to handle select boxes special
+ if ( jQuery.nodeName( elem, "select" ) ) {
+ var index = elem.selectedIndex,
+ values = [],
+ options = elem.options,
+ one = elem.type == "select-one";
+ // Nothing was selected
+ if ( index < 0 )
+ return null;
+ // Loop through all the selected options
+ for ( var i = one ? index : 0, max = one ? index + 1 : options.length; i < max; i++ ) {
+ var option = options[ i ];
+ if ( option.selected ) {
+ // Get the specifc value for the option
+ value = jQuery.browser.msie && !option.attributes.value.specified ? option.text : option.value;
+ // We don't need an array for one selects
+ if ( one )
+ return value;
+ // Multi-Selects return an array
+ values.push( value );
+ return values;
+ // Everything else, we just grab the value
+ } else
+ return (this[0].value || "").replace(/\r/g, "");
+ return undefined;
+ if( value.constructor == Number )
+ value += '';
+ if ( this.nodeType != 1 )
+ return;
+ if ( value.constructor == Array && /radio|checkbox/.test( this.type ) )
+ this.checked = (jQuery.inArray(this.value, value) >= 0 ||
+ jQuery.inArray(this.name, value) >= 0);
+ else if ( jQuery.nodeName( this, "select" ) ) {
+ var values = jQuery.makeArray(value);
+ jQuery( "option", this ).each(function(){
+ this.selected = (jQuery.inArray( this.value, values ) >= 0 ||
+ jQuery.inArray( this.text, values ) >= 0);
+ if ( !values.length )
+ this.selectedIndex = -1;
+ } else
+ this.value = value;
+ html: function( value ) {
+ return value == undefined ?
+ (this[0] ?
+ this[0].innerHTML :
+ null) :
+ this.empty().append( value );
+ replaceWith: function( value ) {
+ return this.after( value ).remove();
+ eq: function( i ) {
+ return this.slice( i, i + 1 );
+ slice: function() {
+ return this.pushStack( Array.prototype.slice.apply( this, arguments ) );
+ map: function( callback ) {
+ return this.pushStack( jQuery.map(this, function(elem, i){
+ return callback.call( elem, i, elem );
+ andSelf: function() {
+ return this.add( this.prevObject );
+ data: function( key, value ){
+ var parts = key.split(".");
+ parts[1] = parts[1] ? "." + parts[1] : "";
+ if ( value === undefined ) {
+ var data = this.triggerHandler("getData" + parts[1] + "!", [parts[0]]);
+ if ( data === undefined && this.length )
+ data = jQuery.data( this[0], key );
+ return data === undefined && parts[1] ?
+ this.data( parts[0] ) :
+ data;
+ } else
+ return this.trigger("setData" + parts[1] + "!", [parts[0], value]).each(function(){
+ jQuery.data( this, key, value );
+ removeData: function( key ){
+ jQuery.removeData( this, key );
+ domManip: function( args, table, reverse, callback ) {
+ var clone = this.length > 1, elems;
+ if ( !elems ) {
+ elems = jQuery.clean( args, this.ownerDocument );
+ if ( reverse )
+ elems.reverse();
+ var obj = this;
+ if ( table && jQuery.nodeName( this, "table" ) && jQuery.nodeName( elems[0], "tr" ) )
+ obj = this.getElementsByTagName("tbody")[0] || this.appendChild( this.ownerDocument.createElement("tbody") );
+ var scripts = jQuery( [] );
+ jQuery.each(elems, function(){
+ var elem = clone ?
+ jQuery( this ).clone( true )[0] :
+ this;
+ // execute all scripts after the elements have been injected
+ if ( jQuery.nodeName( elem, "script" ) )
+ scripts = scripts.add( elem );
+ else {
+ // Remove any inner scripts for later evaluation
+ if ( elem.nodeType == 1 )
+ scripts = scripts.add( jQuery( "script", elem ).remove() );
+ // Inject the elements into the document
+ callback.call( obj, elem );
+ scripts.each( evalScript );
+// Give the init function the jQuery prototype for later instantiation
+jQuery.fn.init.prototype = jQuery.fn;
+function evalScript( i, elem ) {
+ if ( elem.src )
+ jQuery.ajax({
+ url: elem.src,
+ async: false,
+ dataType: "script"
+ else
+ jQuery.globalEval( elem.text || elem.textContent || elem.innerHTML || "" );
+ if ( elem.parentNode )
+ elem.parentNode.removeChild( elem );
+function now(){
+ return +new Date;
+jQuery.extend = jQuery.fn.extend = function() {
+ // copy reference to target object
+ var target = arguments[0] || {}, i = 1, length = arguments.length, deep = false, options;
+ // Handle a deep copy situation
+ if ( target.constructor == Boolean ) {
+ deep = target;
+ target = arguments[1] || {};
+ // skip the boolean and the target
+ i = 2;
+ // Handle case when target is a string or something (possible in deep copy)
+ if ( typeof target != "object" && typeof target != "function" )
+ target = {};
+ // extend jQuery itself if only one argument is passed
+ if ( length == i ) {
+ target = this;
+ --i;
+ for ( ; i < length; i++ )
+ // Only deal with non-null/undefined values
+ if ( (options = arguments[ i ]) != null )
+ // Extend the base object
+ for ( var name in options ) {
+ var src = target[ name ], copy = options[ name ];
+ // Prevent never-ending loop
+ if ( target === copy )
+ continue;
+ // Recurse if we're merging object values
+ if ( deep && copy && typeof copy == "object" && !copy.nodeType )
+ target[ name ] = jQuery.extend( deep,
+ // Never move original objects, clone them
+ src || ( copy.length != null ? [ ] : { } )
+ , copy );
+ // Don't bring in undefined values
+ else if ( copy !== undefined )
+ target[ name ] = copy;
+ // Return the modified object
+ return target;
+var expando = "jQuery" + now(), uuid = 0, windowData = {},
+ // exclude the following css properties to add px
+ exclude = /z-?index|font-?weight|opacity|zoom|line-?height/i,
+ // cache defaultView
+ defaultView = document.defaultView || {};
+jQuery.extend({
+ noConflict: function( deep ) {
+ window.$ = _$;
+ if ( deep )
+ window.jQuery = _jQuery;
+ return jQuery;
+ // See test/unit/core.js for details concerning this function.
+ isFunction: function( fn ) {
+ return !!fn && typeof fn != "string" && !fn.nodeName &&
+ fn.constructor != Array && /^[\s[]?function/.test( fn + "" );
+ // check if an element is in a (or is an) XML document
+ isXMLDoc: function( elem ) {
+ return elem.documentElement && !elem.body ||
+ elem.tagName && elem.ownerDocument && !elem.ownerDocument.body;
+ // Evalulates a script in a global context
+ globalEval: function( data ) {
+ data = jQuery.trim( data );
+ if ( data ) {
+ // Inspired by code by Andrea Giammarchi
+ // http://webreflection.blogspot.com/2007/08/global-scope-evaluation-and-dom.html
+ var head = document.getElementsByTagName("head")[0] || document.documentElement,
+ script = document.createElement("script");
+ script.type = "text/javascript";
+ if ( jQuery.browser.msie )
+ script.text = data;
+ else
+ script.appendChild( document.createTextNode( data ) );
+ // Use insertBefore instead of appendChild to circumvent an IE6 bug.
+ // This arises when a base node is used (#2709).
+ head.insertBefore( script, head.firstChild );
+ head.removeChild( script );
+ nodeName: function( elem, name ) {
+ return elem.nodeName && elem.nodeName.toUpperCase() == name.toUpperCase();
+ cache: {},
+ data: function( elem, name, data ) {
+ elem = elem == window ?
+ windowData :
+ elem;
+ var id = elem[ expando ];
+ // Compute a unique ID for the element
+ if ( !id )
+ id = elem[ expando ] = ++uuid;
+ // Only generate the data cache if we're
+ // trying to access or manipulate it
+ if ( name && !jQuery.cache[ id ] )
+ jQuery.cache[ id ] = {};
+ // Prevent overriding the named cache with undefined values
+ if ( data !== undefined )
+ jQuery.cache[ id ][ name ] = data;
+ // Return the named cache data, or the ID for the element
+ return name ?
+ jQuery.cache[ id ][ name ] :
+ id;
+ removeData: function( elem, name ) {
+ windowData :
+ elem;
+ // If we want to remove a specific section of the element's data
+ if ( name ) {
+ if ( jQuery.cache[ id ] ) {
+ // Remove the section of cache data
+ delete jQuery.cache[ id ][ name ];
+ // If we've removed all the data, remove the element's cache
+ name = "";
+ for ( name in jQuery.cache[ id ] )
+ break;
+ if ( !name )
+ jQuery.removeData( elem );
+ // Otherwise, we want to remove all of the element's data
+ } else {
+ // Clean up the element expando
+ try {
+ delete elem[ expando ];
+ } catch(e){
+ // IE has trouble directly removing the expando
+ // but it's ok with using removeAttribute
+ if ( elem.removeAttribute )
+ elem.removeAttribute( expando );
+ // Completely remove the data cache
+ delete jQuery.cache[ id ];
+ // args is for internal usage only
+ each: function( object, callback, args ) {
+ var name, i = 0, length = object.length;
+ if ( args ) {
+ if ( length == undefined ) {
+ for ( name in object )
+ if ( callback.apply( object[ name ], args ) === false )
+ break;
+ } else
+ for ( ; i < length; )
+ if ( callback.apply( object[ i++ ], args ) === false )
+ break;
+ // A special, fast, case for the most common use of each
+ } else {
+ if ( callback.call( object[ name ], name, object[ name ] ) === false )
+ break;
+ } else
+ for ( var value = object[0];
+ i < length && callback.call( value, i, value ) !== false; value = object[++i] ){}
+ return object;
+ prop: function( elem, value, type, i, name ) {
+ // Handle executable functions
+ if ( jQuery.isFunction( value ) )
+ value = value.call( elem, i );
+ // Handle passing in a number to a CSS property
+ return value && value.constructor == Number && type == "curCSS" && !exclude.test( name ) ?
+ value + "px" :
+ value;
+ className: {
+ // internal only, use addClass("class")
+ add: function( elem, classNames ) {
+ jQuery.each((classNames || "").split(/\s+/), function(i, className){
+ if ( elem.nodeType == 1 && !jQuery.className.has( elem.className, className ) )
+ elem.className += (elem.className ? " " : "") + className;
+ // internal only, use removeClass("class")
+ remove: function( elem, classNames ) {
+ if (elem.nodeType == 1)
+ elem.className = classNames != undefined ?
+ jQuery.grep(elem.className.split(/\s+/), function(className){
+ return !jQuery.className.has( classNames, className );
+ }).join(" ") :
+ // internal only, use hasClass("class")
+ has: function( elem, className ) {
+ return jQuery.inArray( className, (elem.className || elem).toString().split(/\s+/) ) > -1;
+ // A method for quickly swapping in/out CSS properties to get correct calculations
+ swap: function( elem, options, callback ) {
+ var old = {};
+ // Remember the old values, and insert the new ones
+ old[ name ] = elem.style[ name ];
+ elem.style[ name ] = options[ name ];
+ callback.call( elem );
+ // Revert the old values
+ elem.style[ name ] = old[ name ];
+ css: function( elem, name, force ) {
+ if ( name == "width" || name == "height" ) {
+ var val, props = { position: "absolute", visibility: "hidden", display:"block" }, which = name == "width" ? [ "Left", "Right" ] : [ "Top", "Bottom" ];
+ function getWH() {
+ val = name == "width" ? elem.offsetWidth : elem.offsetHeight;
+ var padding = 0, border = 0;
+ jQuery.each( which, function() {
+ padding += parseFloat(jQuery.curCSS( elem, "padding" + this, true)) || 0;
+ border += parseFloat(jQuery.curCSS( elem, "border" + this + "Width", true)) || 0;
+ val -= Math.round(padding + border);
+ if ( jQuery(elem).is(":visible") )
+ getWH();
+ else
+ jQuery.swap( elem, props, getWH );
+ return Math.max(0, val);
+ return jQuery.curCSS( elem, name, force );
+ curCSS: function( elem, name, force ) {
+ var ret, style = elem.style;
+ // A helper method for determining if an element's values are broken
+ function color( elem ) {
+ if ( !jQuery.browser.safari )
+ return false;
+ // defaultView is cached
+ var ret = defaultView.getComputedStyle( elem, null );
+ return !ret || ret.getPropertyValue("color") == "";
+ // We need to handle opacity special in IE
+ if ( name == "opacity" && jQuery.browser.msie ) {
+ ret = jQuery.attr( style, "opacity" );
+ return ret == "" ?
+ "1" :
+ ret;
+ // Opera sometimes will give the wrong display answer, this fixes it, see #2037
+ if ( jQuery.browser.opera && name == "display" ) {
+ var save = style.outline;
+ style.outline = "0 solid black";
+ style.outline = save;
+ // Make sure we're using the right name for getting the float value
+ if ( name.match( /float/i ) )
+ name = styleFloat;
+ if ( !force && style && style[ name ] )
+ ret = style[ name ];
+ else if ( defaultView.getComputedStyle ) {
+ // Only "float" is needed here
+ name = "float";
+ name = name.replace( /([A-Z])/g, "-$1" ).toLowerCase();
+ var computedStyle = defaultView.getComputedStyle( elem, null );
+ if ( computedStyle && !color( elem ) )
+ ret = computedStyle.getPropertyValue( name );
+ // If the element isn't reporting its values properly in Safari
+ // then some display: none elements are involved
+ else {
+ var swap = [], stack = [], a = elem, i = 0;
+ // Locate all of the parent display: none elements
+ for ( ; a && color(a); a = a.parentNode )
+ stack.unshift(a);
+ // Go through and make them visible, but in reverse
+ // (It would be better if we knew the exact display type that they had)
+ for ( ; i < stack.length; i++ )
+ if ( color( stack[ i ] ) ) {
+ swap[ i ] = stack[ i ].style.display;
+ stack[ i ].style.display = "block";
+ // Since we flip the display style, we have to handle that
+ // one special, otherwise get the value
+ ret = name == "display" && swap[ stack.length - 1 ] != null ?
+ "none" :
+ ( computedStyle && computedStyle.getPropertyValue( name ) ) || "";
+ // Finally, revert the display styles back
+ for ( i = 0; i < swap.length; i++ )
+ if ( swap[ i ] != null )
+ stack[ i ].style.display = swap[ i ];
+ // We should always get a number back from opacity
+ if ( name == "opacity" && ret == "" )
+ ret = "1";
+ } else if ( elem.currentStyle ) {
+ var camelCase = name.replace(/\-(\w)/g, function(all, letter){
+ return letter.toUpperCase();
+ ret = elem.currentStyle[ name ] || elem.currentStyle[ camelCase ];
+ // From the awesome hack by Dean Edwards
+ // http://erik.eae.net/archives/2007/07/27/18.54.15/#comment-102291
+ // If we're not dealing with a regular pixel number
+ // but a number that has a weird ending, we need to convert it to pixels
+ if ( !/^\d+(px)?$/i.test( ret ) && /^\d/.test( ret ) ) {
+ // Remember the original values
+ var left = style.left, rsLeft = elem.runtimeStyle.left;
+ // Put in the new values to get a computed value out
+ elem.runtimeStyle.left = elem.currentStyle.left;
+ style.left = ret || 0;
+ ret = style.pixelLeft + "px";
+ // Revert the changed values
+ style.left = left;
+ elem.runtimeStyle.left = rsLeft;
+ return ret;
+ clean: function( elems, context ) {
+ var ret = [];
+ context = context || document;
+ // !context.createElement fails in IE with an error but returns typeof 'object'
+ if (typeof context.createElement == 'undefined')
+ context = context.ownerDocument || context[0] && context[0].ownerDocument || document;
+ jQuery.each(elems, function(i, elem){
+ if ( !elem )
+ return;
+ if ( elem.constructor == Number )
+ elem += '';
+ // Convert html string into DOM nodes
+ if ( typeof elem == "string" ) {
+ // Fix "XHTML"-style tags in all browsers
+ elem = elem.replace(/(<(\w+)[^>]*?)\/>/g, function(all, front, tag){
+ return tag.match(/^(abbr|br|col|img|input|link|meta|param|hr|area|embed)$/i) ?
+ all :
+ front + "></" + tag + ">";
+ // Trim whitespace, otherwise indexOf won't work as expected
+ var tags = jQuery.trim( elem ).toLowerCase(), div = context.createElement("div");
+ var wrap =
+ // option or optgroup
+ !tags.indexOf("<opt") &&
+ [ 1, "<select multiple='multiple'>", "</select>" ] ||
+ !tags.indexOf("<leg") &&
+ [ 1, "<fieldset>", "</fieldset>" ] ||
+ tags.match(/^<(thead|tbody|tfoot|colg|cap)/) &&
+ [ 1, "<table>", "</table>" ] ||
+ !tags.indexOf("<tr") &&
+ [ 2, "<table><tbody>", "</tbody></table>" ] ||
+ // <thead> matched above
+ (!tags.indexOf("<td") || !tags.indexOf("<th")) &&
+ [ 3, "<table><tbody><tr>", "</tr></tbody></table>" ] ||
+ !tags.indexOf("<col") &&
+ [ 2, "<table><tbody></tbody><colgroup>", "</colgroup></table>" ] ||
+ // IE can't serialize <link> and <script> tags normally
+ jQuery.browser.msie &&
+ [ 1, "div<div>", "</div>" ] ||
+ [ 0, "", "" ];
+ // Go to html and back, then peel off extra wrappers
+ div.innerHTML = wrap[1] + elem + wrap[2];
+ // Move to the right depth
+ while ( wrap[0]-- )
+ div = div.lastChild;
+ // Remove IE's autoinserted <tbody> from table fragments
+ if ( jQuery.browser.msie ) {
+ // String was a <table>, *may* have spurious <tbody>
+ var tbody = !tags.indexOf("<table") && tags.indexOf("<tbody") < 0 ?
+ div.firstChild && div.firstChild.childNodes :
+ // String was a bare <thead> or <tfoot>
+ wrap[1] == "<table>" && tags.indexOf("<tbody") < 0 ?
+ div.childNodes :
+ for ( var j = tbody.length - 1; j >= 0 ; --j )
+ if ( jQuery.nodeName( tbody[ j ], "tbody" ) && !tbody[ j ].childNodes.length )
+ tbody[ j ].parentNode.removeChild( tbody[ j ] );
+ // IE completely kills leading whitespace when innerHTML is used
+ if ( /^\s/.test( elem ) )
+ div.insertBefore( context.createTextNode( elem.match(/^\s*/)[0] ), div.firstChild );
+ elem = jQuery.makeArray( div.childNodes );
+ if ( elem.length === 0 && (!jQuery.nodeName( elem, "form" ) && !jQuery.nodeName( elem, "select" )) )
+ return;
+ if ( elem[0] == undefined || jQuery.nodeName( elem, "form" ) || elem.options )
+ ret.push( elem );
+ else
+ ret = jQuery.merge( ret, elem );
+ return ret;
+ attr: function( elem, name, value ) {
+ // don't set attributes on text and comment nodes
+ if (!elem || elem.nodeType == 3 || elem.nodeType == 8)
+ return undefined;
+ var notxml = !jQuery.isXMLDoc( elem ),
+ // Whether we are setting (or getting)
+ set = value !== undefined,
+ msie = jQuery.browser.msie;
+ // Try to normalize/fix the name
+ name = notxml && jQuery.props[ name ] || name;
+ // Only do all the following if this is a node (faster for style)
+ // IE elem.getAttribute passes even for style
+ if ( elem.tagName ) {
+ // These attributes require special treatment
+ var special = /href|src|style/.test( name );
+ // Safari mis-reports the default selected property of a hidden option
+ // Accessing the parent's selectedIndex property fixes it
+ if ( name == "selected" && jQuery.browser.safari )
+ elem.parentNode.selectedIndex;
+ // If applicable, access the attribute via the DOM 0 way
+ if ( name in elem && notxml && !special ) {
+ if ( set ){
+ // We can't allow the type property to be changed (since it causes problems in IE)
+ if ( name == "type" && jQuery.nodeName( elem, "input" ) && elem.parentNode )
+ throw "type property can't be changed";
+ elem[ name ] = value;
+ // browsers index elements by id/name on forms, give priority to attributes.
+ if( jQuery.nodeName( elem, "form" ) && elem.getAttributeNode(name) )
+ return elem.getAttributeNode( name ).nodeValue;
+ return elem[ name ];
+ if ( msie && notxml && name == "style" )
+ return jQuery.attr( elem.style, "cssText", value );
+ if ( set )
+ // convert the value to a string (all browsers do this but IE) see #1070
+ elem.setAttribute( name, "" + value );
+ var attr = msie && notxml && special
+ // Some attributes require a special call on IE
+ ? elem.getAttribute( name, 2 )
+ : elem.getAttribute( name );
+ // Non-existent attributes return null, we normalize to undefined
+ return attr === null ? undefined : attr;
+ // elem is actually elem.style ... set the style
+ // IE uses filters for opacity
+ if ( msie && name == "opacity" ) {
+ if ( set ) {
+ // IE has trouble with opacity if it does not have layout
+ // Force it by setting the zoom level
+ elem.zoom = 1;
+ // Set the alpha filter to set the opacity
+ elem.filter = (elem.filter || "").replace( /alpha\([^)]*\)/, "" ) +
+ (parseInt( value ) + '' == "NaN" ? "" : "alpha(opacity=" + value * 100 + ")");
+ return elem.filter && elem.filter.indexOf("opacity=") >= 0 ?
+ (parseFloat( elem.filter.match(/opacity=([^)]*)/)[1] ) / 100) + '':
+ name = name.replace(/-([a-z])/ig, function(all, letter){
+ if ( set )
+ trim: function( text ) {
+ return (text || "").replace( /^\s+|\s+$/g, "" );
+ makeArray: function( array ) {
+ var ret = [];
+ if( array != null ){
+ var i = array.length;
+ //the window, strings and functions also have 'length'
+ if( i == null || array.split || array.setInterval || array.call )
+ ret[0] = array;
+ else
+ while( i )
+ ret[--i] = array[i];
+ return ret;
+ inArray: function( elem, array ) {
+ for ( var i = 0, length = array.length; i < length; i++ )
+ // Use === because on IE, window == document
+ if ( array[ i ] === elem )
+ return i;
+ return -1;
+ merge: function( first, second ) {
+ // We have to loop this way because IE & Opera overwrite the length
+ // expando of getElementsByTagName
+ var i = 0, elem, pos = first.length;
+ // Also, we need to make sure that the correct elements are being returned
+ // (IE returns comment nodes in a '*' query)
+ while ( elem = second[ i++ ] )
+ if ( elem.nodeType != 8 )
+ first[ pos++ ] = elem;
+ } else
+ return first;
+ unique: function( array ) {
+ var ret = [], done = {};
+ try {
+ for ( var i = 0, length = array.length; i < length; i++ ) {
+ var id = jQuery.data( array[ i ] );
+ if ( !done[ id ] ) {
+ done[ id ] = true;
+ ret.push( array[ i ] );
+ } catch( e ) {
+ ret = array;
+ return ret;
+ grep: function( elems, callback, inv ) {
+ var ret = [];
+ // Go through the array, only saving the items
+ // that pass the validator function
+ for ( var i = 0, length = elems.length; i < length; i++ )
+ if ( !inv != !callback( elems[ i ], i ) )
+ ret.push( elems[ i ] );
+ return ret;
+ map: function( elems, callback ) {
+ var ret = [];
+ // Go through the array, translating each of the items to their
+ // new value (or values).
+ for ( var i = 0, length = elems.length; i < length; i++ ) {
+ var value = callback( elems[ i ], i );
+ if ( value != null )
+ ret[ ret.length ] = value;
+ return ret.concat.apply( [], ret );
+var userAgent = navigator.userAgent.toLowerCase();
+// Figure out what browser is being used
+jQuery.browser = {
+ version: (userAgent.match( /.+(?:rv|it|ra|ie)[\/: ]([\d.]+)/ ) || [])[1],
+ safari: /webkit/.test( userAgent ),
+ opera: /opera/.test( userAgent ),
+ msie: /msie/.test( userAgent ) && !/opera/.test( userAgent ),
+ mozilla: /mozilla/.test( userAgent ) && !/(compatible|webkit)/.test( userAgent )
+var styleFloat = jQuery.browser.msie ?
+ "styleFloat" :
+ "cssFloat";
+jQuery.extend({
+ // Check to see if the W3C box model is being used
+ boxModel: !jQuery.browser.msie || document.compatMode == "CSS1Compat",
+ props: {
+ "for": "htmlFor",
+ "class": "className",
+ "float": styleFloat,
+ cssFloat: styleFloat,
+ styleFloat: styleFloat,
+ readonly: "readOnly",
+ maxlength: "maxLength",
+ cellspacing: "cellSpacing"
+jQuery.each({
+ parent: function(elem){return elem.parentNode;},
+ parents: function(elem){return jQuery.dir(elem,"parentNode");},
+ next: function(elem){return jQuery.nth(elem,2,"nextSibling");},
+ prev: function(elem){return jQuery.nth(elem,2,"previousSibling");},
+ nextAll: function(elem){return jQuery.dir(elem,"nextSibling");},
+ prevAll: function(elem){return jQuery.dir(elem,"previousSibling");},
+ siblings: function(elem){return jQuery.sibling(elem.parentNode.firstChild,elem);},
+ children: function(elem){return jQuery.sibling(elem.firstChild);},
+ contents: function(elem){return jQuery.nodeName(elem,"iframe")?elem.contentDocument||elem.contentWindow.document:jQuery.makeArray(elem.childNodes);}
+}, function(name, fn){
+ jQuery.fn[ name ] = function( selector ) {
+ var ret = jQuery.map( this, fn );
+ if ( selector && typeof selector == "string" )
+ ret = jQuery.multiFilter( selector, ret );
+ return this.pushStack( jQuery.unique( ret ) );
+jQuery.each({
+ appendTo: "append",
+ prependTo: "prepend",
+ insertBefore: "before",
+ insertAfter: "after",
+ replaceAll: "replaceWith"
+}, function(name, original){
+ jQuery.fn[ name ] = function() {
+ var args = arguments;
+ for ( var i = 0, length = args.length; i < length; i++ )
+ jQuery( args[ i ] )[ original ]( this );
+jQuery.each({
+ removeAttr: function( name ) {
+ jQuery.attr( this, name, "" );
+ this.removeAttribute( name );
+ addClass: function( classNames ) {
+ jQuery.className.add( this, classNames );
+ removeClass: function( classNames ) {
+ jQuery.className.remove( this, classNames );
+ toggleClass: function( classNames ) {
+ jQuery.className[ jQuery.className.has( this, classNames ) ? "remove" : "add" ]( this, classNames );
+ remove: function( selector ) {
+ if ( !selector || jQuery.filter( selector, [ this ] ).r.length ) {
+ // Prevent memory leaks
+ jQuery( "*", this ).add(this).each(function(){
+ jQuery.event.remove(this);
+ jQuery.removeData(this);
+ if (this.parentNode)
+ this.parentNode.removeChild( this );
+ empty: function() {
+ // Remove element nodes and prevent memory leaks
+ jQuery( ">*", this ).remove();
+ // Remove any remaining nodes
+ while ( this.firstChild )
+ this.removeChild( this.firstChild );
+ jQuery.fn[ name ] = function(){
+ return this.each( fn, arguments );
+jQuery.each([ "Height", "Width" ], function(i, name){
+ var type = name.toLowerCase();
+ jQuery.fn[ type ] = function( size ) {
+ // Get window width or height
+ return this[0] == window ?
+ // Opera reports document.body.client[Width/Height] properly in both quirks and standards
+ jQuery.browser.opera && document.body[ "client" + name ] ||
+ // Safari reports inner[Width/Height] just fine (Mozilla and Opera include scroll bar widths)
+ jQuery.browser.safari && window[ "inner" + name ] ||
+ // Everyone else use document.documentElement or document.body depending on Quirks vs Standards mode
+ document.compatMode == "CSS1Compat" && document.documentElement[ "client" + name ] || document.body[ "client" + name ] :
+ // Get document width or height
+ this[0] == document ?
+ // Either scroll[Width/Height] or offset[Width/Height], whichever is greater
+ Math.max(
+ Math.max(document.body["scroll" + name], document.documentElement["scroll" + name]),
+ Math.max(document.body["offset" + name], document.documentElement["offset" + name])
+ // Get or set width or height on the element
+ size == undefined ?
+ // Get width or height on the element
+ (this.length ? jQuery.css( this[0], type ) : null) :
+ // Set the width or height on the element (default to pixels if value is unitless)
+ this.css( type, size.constructor == String ? size : size + "px" );
+// Helper function used by the dimensions and offset modules
+function num(elem, prop) {
+ return elem[0] && parseInt( jQuery.curCSS(elem[0], prop, true), 10 ) || 0;
+}var chars = jQuery.browser.safari && parseInt(jQuery.browser.version) < 417 ?
+ "(?:[\\w*_-]|\\\\.)" :
+ "(?:[\\w\u0128-\uFFFF*_-]|\\\\.)",
+ quickChild = new RegExp("^>\\s*(" + chars + "+)"),
+ quickID = new RegExp("^(" + chars + "+)(#)(" + chars + "+)"),
+ quickClass = new RegExp("^([#.]?)(" + chars + "*)");
+jQuery.extend({
+ expr: {
+ "": function(a,i,m){return m[2]=="*"||jQuery.nodeName(a,m[2]);},
+ "#": function(a,i,m){return a.getAttribute("id")==m[2];},
+ // Position Checks
+ lt: function(a,i,m){return i<m[3]-0;},
+ gt: function(a,i,m){return i>m[3]-0;},
+ nth: function(a,i,m){return m[3]-0==i;},
+ eq: function(a,i,m){return m[3]-0==i;},
+ first: function(a,i){return i==0;},
+ last: function(a,i,m,r){return i==r.length-1;},
+ even: function(a,i){return i%2==0;},
+ odd: function(a,i){return i%2;},
+ // Child Checks
+ "first-child": function(a){return a.parentNode.getElementsByTagName("*")[0]==a;},
+ "last-child": function(a){return jQuery.nth(a.parentNode.lastChild,1,"previousSibling")==a;},
+ "only-child": function(a){return !jQuery.nth(a.parentNode.lastChild,2,"previousSibling");},
+ // Parent Checks
+ parent: function(a){return a.firstChild;},
+ empty: function(a){return !a.firstChild;},
+ // Text Check
+ contains: function(a,i,m){return (a.textContent||a.innerText||jQuery(a).text()||"").indexOf(m[3])>=0;},
+ // Visibility
+ visible: function(a){return "hidden"!=a.type&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden";},
+ hidden: function(a){return "hidden"==a.type||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden";},
+ // Form attributes
+ enabled: function(a){return !a.disabled;},
+ disabled: function(a){return a.disabled;},
+ checked: function(a){return a.checked;},
+ selected: function(a){return a.selected||jQuery.attr(a,"selected");},
+ // Form elements
+ text: function(a){return "text"==a.type;},
+ radio: function(a){return "radio"==a.type;},
+ checkbox: function(a){return "checkbox"==a.type;},
+ file: function(a){return "file"==a.type;},
+ password: function(a){return "password"==a.type;},
+ submit: function(a){return "submit"==a.type;},
+ image: function(a){return "image"==a.type;},
+ reset: function(a){return "reset"==a.type;},
+ button: function(a){return "button"==a.type||jQuery.nodeName(a,"button");},
+ input: function(a){return /input|select|textarea|button/i.test(a.nodeName);},
+ // :has()
+ has: function(a,i,m){return jQuery.find(m[3],a).length;},
+ // :header
+ header: function(a){return /h\d/i.test(a.nodeName);},
+ // :animated
+ animated: function(a){return jQuery.grep(jQuery.timers,function(fn){return a==fn.elem;}).length;}
+ // The regular expressions that power the parsing engine
+ parse: [
+ // Match: [@value='test'], [@foo]
+ /^(\[) *@?([\w-]+) *([!*$^~=]*) *('?"?)(.*?)\4 *\]/,
+ // Match: :contains('foo')
+ /^(:)([\w-]+)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/,
+ // Match: :even, :last-child, #id, .class
+ new RegExp("^([:.#]*)(" + chars + "+)")
+ multiFilter: function( expr, elems, not ) {
+ var old, cur = [];
+ while ( expr && expr != old ) {
+ old = expr;
+ var f = jQuery.filter( expr, elems, not );
+ expr = f.t.replace(/^\s*,\s*/, "" );
+ cur = not ? elems = f.r : jQuery.merge( cur, f.r );
+ return cur;
+ find: function( t, context ) {
+ // Quickly handle non-string expressions
+ if ( typeof t != "string" )
+ return [ t ];
+ // check to make sure context is a DOM element or a document
+ if ( context && context.nodeType != 1 && context.nodeType != 9)
+ return [ ];
+ // Set the correct context (if none is provided)
+ // Initialize the search
+ var ret = [context], done = [], last, nodeName;
+ // Continue while a selector expression exists, and while
+ // we're no longer looping upon ourselves
+ while ( t && last != t ) {
+ var r = [];
+ last = t;
+ t = jQuery.trim(t);
+ var foundToken = false,
+ // An attempt at speeding up child selectors that
+ // point to a specific element tag
+ re = quickChild,
+ m = re.exec(t);
+ if ( m ) {
+ nodeName = m[1].toUpperCase();
+ // Perform our own iteration and filter
+ for ( var i = 0; ret[i]; i++ )
+ for ( var c = ret[i].firstChild; c; c = c.nextSibling )
+ if ( c.nodeType == 1 && (nodeName == "*" || c.nodeName.toUpperCase() == nodeName) )
+ r.push( c );
+ ret = r;
+ t = t.replace( re, "" );
+ if ( t.indexOf(" ") == 0 ) continue;
+ foundToken = true;
+ } else {
+ re = /^([>+~])\s*(\w*)/i;
+ if ( (m = re.exec(t)) != null ) {
+ r = [];
+ var merge = {};
+ nodeName = m[2].toUpperCase();
+ m = m[1];
+ for ( var j = 0, rl = ret.length; j < rl; j++ ) {
+ var n = m == "~" || m == "+" ? ret[j].nextSibling : ret[j].firstChild;
+ for ( ; n; n = n.nextSibling )
+ if ( n.nodeType == 1 ) {
+ var id = jQuery.data(n);
+ if ( m == "~" && merge[id] ) break;
+ if (!nodeName || n.nodeName.toUpperCase() == nodeName ) {
+ if ( m == "~" ) merge[id] = true;
+ r.push( n );
+ if ( m == "+" ) break;
+ ret = r;
+ // And remove the token
+ t = jQuery.trim( t.replace( re, "" ) );
+ // See if there's still an expression, and that we haven't already
+ // matched a token
+ if ( t && !foundToken ) {
+ // Handle multiple expressions
+ if ( !t.indexOf(",") ) {
+ // Clean the result set
+ if ( context == ret[0] ) ret.shift();
+ // Merge the result sets
+ done = jQuery.merge( done, ret );
+ // Reset the context
+ r = ret = [context];
+ // Touch up the selector string
+ t = " " + t.substr(1,t.length);
+ } else {
+ // Optimize for the case nodeName#idName
+ var re2 = quickID;
+ var m = re2.exec(t);
+ // Re-organize the results, so that they're consistent
+ if ( m ) {
+ m = [ 0, m[2], m[3], m[1] ];
+ } else {
+ // Otherwise, do a traditional filter check for
+ // ID, class, and element selectors
+ re2 = quickClass;
+ m = re2.exec(t);
+ m[2] = m[2].replace(/\\/g, "");
+ var elem = ret[ret.length-1];
+ // Try to do a global search by ID, where we can
+ if ( m[1] == "#" && elem && elem.getElementById && !jQuery.isXMLDoc(elem) ) {
+ // Optimization for HTML document case
+ var oid = elem.getElementById(m[2]);
+ // Do a quick check for the existence of the actual ID attribute
+ // to avoid selecting by the name attribute in IE
+ // also check to insure id is a string to avoid selecting an element with the name of 'id' inside a form
+ if ( (jQuery.browser.msie||jQuery.browser.opera) && oid && typeof oid.id == "string" && oid.id != m[2] )
+ oid = jQuery('[@id="'+m[2]+'"]', elem)[0];
+ // Do a quick check for node name (where applicable) so
+ // that div#foo searches will be really fast
+ ret = r = oid && (!m[3] || jQuery.nodeName(oid, m[3])) ? [oid] : [];
+ } else {
+ // We need to find all descendant elements
+ for ( var i = 0; ret[i]; i++ ) {
+ // Grab the tag name being searched for
+ var tag = m[1] == "#" && m[3] ? m[3] : m[1] != "" || m[0] == "" ? "*" : m[2];
+ // Handle IE7 being really dumb about <object>s
+ if ( tag == "*" && ret[i].nodeName.toLowerCase() == "object" )
+ tag = "param";
+ r = jQuery.merge( r, ret[i].getElementsByTagName( tag ));
+ // It's faster to filter by class and be done with it
+ if ( m[1] == "." )
+ r = jQuery.classFilter( r, m[2] );
+ // Same with ID filtering
+ if ( m[1] == "#" ) {
+ var tmp = [];
+ // Try to find the element with the ID
+ for ( var i = 0; r[i]; i++ )
+ if ( r[i].getAttribute("id") == m[2] ) {
+ tmp = [ r[i] ];
+ break;
+ r = tmp;
+ ret = r;
+ t = t.replace( re2, "" );
+ // If a selector string still exists
+ if ( t ) {
+ // Attempt to filter it
+ var val = jQuery.filter(t,r);
+ ret = r = val.r;
+ t = jQuery.trim(val.t);
+ // An error occurred with the selector;
+ // just return an empty set instead
+ if ( t )
+ ret = [];
+ // Remove the root context
+ if ( ret && context == ret[0] )
+ ret.shift();
+ // And combine the results
+ return done;
+ classFilter: function(r,m,not){
+ m = " " + m + " ";
+ var tmp = [];
+ for ( var i = 0; r[i]; i++ ) {
+ var pass = (" " + r[i].className + " ").indexOf( m ) >= 0;
+ if ( !not && pass || not && !pass )
+ tmp.push( r[i] );
+ return tmp;
+ filter: function(t,r,not) {
+ var last;
+ // Look for common filter expressions
+ while ( t && t != last ) {
+ last = t;
+ var p = jQuery.parse, m;
+ for ( var i = 0; p[i]; i++ ) {
+ m = p[i].exec( t );
+ if ( m ) {
+ // Remove what we just matched
+ t = t.substring( m[0].length );
+ break;
+ if ( !m )
+ break;
+ // :not() is a special case that can be optimized by
+ // keeping it out of the expression list
+ if ( m[1] == ":" && m[2] == "not" )
+ // optimize if only one selector found (most common case)
+ r = isSimple.test( m[3] ) ?
+ jQuery.filter(m[3], r, true).r :
+ jQuery( r ).not( m[3] );
+ // We can get a big speed boost by filtering by class here
+ else if ( m[1] == "." )
+ r = jQuery.classFilter(r, m[2], not);
+ else if ( m[1] == "[" ) {
+ var tmp = [], type = m[3];
+ for ( var i = 0, rl = r.length; i < rl; i++ ) {
+ var a = r[i], z = a[ jQuery.props[m[2]] || m[2] ];
+ if ( z == null || /href|src|selected/.test(m[2]) )
+ z = jQuery.attr(a,m[2]) || '';
+ if ( (type == "" && !!z ||
+ type == "=" && z == m[5] ||
+ type == "!=" && z != m[5] ||
+ type == "^=" && z && !z.indexOf(m[5]) ||
+ type == "$=" && z.substr(z.length - m[5].length) == m[5] ||
+ (type == "*=" || type == "~=") && z.indexOf(m[5]) >= 0) ^ not )
+ tmp.push( a );
+ r = tmp;
+ // We can get a speed boost by handling nth-child here
+ } else if ( m[1] == ":" && m[2] == "nth-child" ) {
+ var merge = {}, tmp = [],
+ // parse equations like 'even', 'odd', '5', '2n', '3n+2', '4n-1', '-n+6'
+ test = /(-?)(\d*)n((?:\+|-)?\d*)/.exec(
+ m[3] == "even" && "2n" || m[3] == "odd" && "2n+1" ||
+ !/\D/.test(m[3]) && "0n+" + m[3] || m[3]),
+ // calculate the numbers (first)n+(last) including if they are negative
+ first = (test[1] + (test[2] || 1)) - 0, last = test[3] - 0;
+ // loop through all the elements left in the jQuery object
+ var node = r[i], parentNode = node.parentNode, id = jQuery.data(parentNode);
+ if ( !merge[id] ) {
+ var c = 1;
+ for ( var n = parentNode.firstChild; n; n = n.nextSibling )
+ n.nodeIndex = c++;
+ merge[id] = true;
+ var add = false;
+ if ( first == 0 ) {
+ if ( node.nodeIndex == last )
+ add = true;
+ } else if ( (node.nodeIndex - last) % first == 0 && (node.nodeIndex - last) / first >= 0 )
+ add = true;
+ if ( add ^ not )
+ tmp.push( node );
+ r = tmp;
+ // Otherwise, find the expression to execute
+ } else {
+ var fn = jQuery.expr[ m[1] ];
+ if ( typeof fn == "object" )
+ fn = fn[ m[2] ];
+ if ( typeof fn == "string" )
+ fn = eval("false||function(a,i){return " + fn + ";}");
+ // Execute it against the current filter
+ r = jQuery.grep( r, function(elem, i){
+ return fn(elem, i, m, r);
+ }, not );
+ // Return an array of filtered elements (r)
+ // and the modified expression string (t)
+ return { r: r, t: t };
+ dir: function( elem, dir ){
+ var matched = [],
+ cur = elem[dir];
+ while ( cur && cur != document ) {
+ if ( cur.nodeType == 1 )
+ matched.push( cur );
+ cur = cur[dir];
+ return matched;
+ nth: function(cur,result,dir,elem){
+ result = result || 1;
+ var num = 0;
+ for ( ; cur; cur = cur[dir] )
+ if ( cur.nodeType == 1 && ++num == result )
+ break;
+ return cur;
+ sibling: function( n, elem ) {
+ var r = [];
+ for ( ; n; n = n.nextSibling ) {
+ if ( n.nodeType == 1 && n != elem )
+ r.push( n );
+ return r;
+ * A number of helper functions used for managing events.
+ * Many of the ideas behind this code orignated from
+ * Dean Edwards' addEvent library.
+jQuery.event = {
+ // Bind an event to an element
+ // Original by Dean Edwards
+ add: function(elem, types, handler, data) {
+ if ( elem.nodeType == 3 || elem.nodeType == 8 )
+ return;
+ // For whatever reason, IE has trouble passing the window object
+ // around, causing it to be cloned in the process
+ if ( jQuery.browser.msie && elem.setInterval )
+ elem = window;
+ // Make sure that the function being executed has a unique ID
+ if ( !handler.guid )
+ handler.guid = this.guid++;
+ // if data is passed, bind to handler
+ if( data != undefined ) {
+ // Create temporary function pointer to original handler
+ var fn = handler;
+ // Create unique handler function, wrapped around original handler
+ handler = this.proxy( fn, function() {
+ // Pass arguments and context to original handler
+ return fn.apply(this, arguments);
+ // Store data in unique handler
+ handler.data = data;
+ // Init the element's event structure
+ var events = jQuery.data(elem, "events") || jQuery.data(elem, "events", {}),
+ handle = jQuery.data(elem, "handle") || jQuery.data(elem, "handle", function(){
+ // Handle the second event of a trigger and when
+ // an event is called after a page has unloaded
+ if ( typeof jQuery != "undefined" && !jQuery.event.triggered )
+ return jQuery.event.handle.apply(arguments.callee.elem, arguments);
+ // Add elem as a property of the handle function
+ // This is to prevent a memory leak with non-native
+ // event in IE.
+ handle.elem = elem;
+ // Handle multiple events separated by a space
+ // jQuery(...).bind("mouseover mouseout", fn);
+ jQuery.each(types.split(/\s+/), function(index, type) {
+ // Namespaced event handlers
+ var parts = type.split(".");
+ type = parts[0];
+ handler.type = parts[1];
+ // Get the current list of functions bound to this event
+ var handlers = events[type];
+ // Init the event handler queue
+ if (!handlers) {
+ handlers = events[type] = {};
+ // Check for a special event handler
+ // Only use addEventListener/attachEvent if the special
+ // events handler returns false
+ if ( !jQuery.event.special[type] || jQuery.event.special[type].setup.call(elem) === false ) {
+ // Bind the global event handler to the element
+ if (elem.addEventListener)
+ elem.addEventListener(type, handle, false);
+ else if (elem.attachEvent)
+ elem.attachEvent("on" + type, handle);
+ // Add the function to the element's handler list
+ handlers[handler.guid] = handler;
+ // Keep track of which events have been used, for global triggering
+ jQuery.event.global[type] = true;
+ // Nullify elem to prevent memory leaks in IE
+ elem = null;
+ guid: 1,
+ global: {},
+ // Detach an event or set of events from an element
+ remove: function(elem, types, handler) {
+ // don't do events on text and comment nodes
+ return;
+ var events = jQuery.data(elem, "events"), ret, index;
+ if ( events ) {
+ // Unbind all events for the element
+ if ( types == undefined || (typeof types == "string" && types.charAt(0) == ".") )
+ this.remove( elem, type + (types || "") );
+ else {
+ // types is actually an event object here
+ if ( types.type ) {
+ handler = types.handler;
+ types = types.type;
+ // Handle multiple events seperated by a space
+ // jQuery(...).unbind("mouseover mouseout", fn);
+ jQuery.each(types.split(/\s+/), function(index, type){
+ type = parts[0];
+ if ( events[type] ) {
+ // remove the given handler for the given type
+ if ( handler )
+ delete events[type][handler.guid];
+ // remove all handlers for the given type
+ else
+ for ( handler in events[type] )
+ // Handle the removal of namespaced events
+ if ( !parts[1] || events[type][handler].type == parts[1] )
+ delete events[type][handler];
+ // remove generic event handler if no more handlers exist
+ for ( ret in events[type] ) break;
+ if ( !ret ) {
+ if ( !jQuery.event.special[type] || jQuery.event.special[type].teardown.call(elem) === false ) {
+ if (elem.removeEventListener)
+ elem.removeEventListener(type, jQuery.data(elem, "handle"), false);
+ else if (elem.detachEvent)
+ elem.detachEvent("on" + type, jQuery.data(elem, "handle"));
+ ret = null;
+ delete events[type];
+ // Remove the expando if it's no longer used
+ for ( ret in events ) break;
+ if ( !ret ) {
+ var handle = jQuery.data( elem, "handle" );
+ if ( handle ) handle.elem = null;
+ jQuery.removeData( elem, "events" );
+ jQuery.removeData( elem, "handle" );
+ trigger: function(type, data, elem, donative, extra) {
+ // Clone the incoming data, if any
+ data = jQuery.makeArray(data);
+ if ( type.indexOf("!") >= 0 ) {
+ type = type.slice(0, -1);
+ var exclusive = true;
+ // Handle a global trigger
+ if ( !elem ) {
+ // Only trigger if we've ever bound an event for it
+ if ( this.global[type] )
+ jQuery("*").add([window, document]).trigger(type, data);
+ // Handle triggering a single element
+ } else {
+ return undefined;
+ var val, ret, fn = jQuery.isFunction( elem[ type ] || null ),
+ // Check to see if we need to provide a fake event, or not
+ event = !data[0] || !data[0].preventDefault;
+ // Pass along a fake event
+ if ( event ) {
+ data.unshift({
+ type: type,
+ target: elem,
+ preventDefault: function(){},
+ stopPropagation: function(){},
+ timeStamp: now()
+ data[0][expando] = true; // no need to fix fake event
+ // Enforce the right trigger type
+ data[0].type = type;
+ if ( exclusive )
+ data[0].exclusive = true;
+ // Trigger the event, it is assumed that "handle" is a function
+ var handle = jQuery.data(elem, "handle");
+ if ( handle )
+ val = handle.apply( elem, data );
+ // Handle triggering native .onfoo handlers (and on links since we don't call .click() for links)
+ if ( (!fn || (jQuery.nodeName(elem, 'a') && type == "click")) && elem["on"+type] && elem["on"+type].apply( elem, data ) === false )
+ val = false;
+ // Extra functions don't get the custom event object
+ if ( event )
+ data.shift();
+ // Handle triggering of extra function
+ if ( extra && jQuery.isFunction( extra ) ) {
+ // call the extra function and tack the current return value on the end for possible inspection
+ ret = extra.apply( elem, val == null ? data : data.concat( val ) );
+ // if anything is returned, give it precedence and have it overwrite the previous value
+ if (ret !== undefined)
+ val = ret;
+ // Trigger the native events (except for clicks on links)
+ if ( fn && donative !== false && val !== false && !(jQuery.nodeName(elem, 'a') && type == "click") ) {
+ this.triggered = true;
+ try {
+ elem[ type ]();
+ // prevent IE from throwing an error for some hidden elements
+ } catch (e) {}
+ this.triggered = false;
+ return val;
+ handle: function(event) {
+ // returned undefined or false
+ var val, ret, namespace, all, handlers;
+ event = arguments[0] = jQuery.event.fix( event || window.event );
+ namespace = event.type.split(".");
+ event.type = namespace[0];
+ namespace = namespace[1];
+ // Cache this now, all = true means, any handler
+ all = !namespace && !event.exclusive;
+ handlers = ( jQuery.data(this, "events") || {} )[event.type];
+ for ( var j in handlers ) {
+ var handler = handlers[j];
+ // Filter the functions by class
+ if ( all || handler.type == namespace ) {
+ // Pass in a reference to the handler function itself
+ // So that we can later remove it
+ event.handler = handler;
+ event.data = handler.data;
+ ret = handler.apply( this, arguments );
+ if ( val !== false )
+ val = ret;
+ if ( ret === false ) {
+ event.preventDefault();
+ event.stopPropagation();
+ return val;
+ fix: function(event) {
+ if ( event[expando] == true )
+ return event;
+ // store a copy of the original event object
+ // and "clone" to set read-only properties
+ var originalEvent = event;
+ event = { originalEvent: originalEvent };
+ var props = "altKey attrChange attrName bubbles button cancelable charCode clientX clientY ctrlKey currentTarget data detail eventPhase fromElement handler keyCode metaKey newValue originalTarget pageX pageY prevValue relatedNode relatedTarget screenX screenY shiftKey srcElement target timeStamp toElement type view wheelDelta which".split(" ");
+ for ( var i=props.length; i; i-- )
+ event[ props[i] ] = originalEvent[ props[i] ];
+ // Mark it as fixed
+ event[expando] = true;
+ // add preventDefault and stopPropagation since
+ // they will not work on the clone
+ event.preventDefault = function() {
+ // if preventDefault exists run it on the original event
+ if (originalEvent.preventDefault)
+ originalEvent.preventDefault();
+ // otherwise set the returnValue property of the original event to false (IE)
+ originalEvent.returnValue = false;
+ event.stopPropagation = function() {
+ // if stopPropagation exists run it on the original event
+ if (originalEvent.stopPropagation)
+ originalEvent.stopPropagation();
+ // otherwise set the cancelBubble property of the original event to true (IE)
+ originalEvent.cancelBubble = true;
+ // Fix timeStamp
+ event.timeStamp = event.timeStamp || now();
+ // Fix target property, if necessary
+ if ( !event.target )
+ event.target = event.srcElement || document; // Fixes #1925 where srcElement might not be defined either
+ // check if target is a textnode (safari)
+ if ( event.target.nodeType == 3 )
+ event.target = event.target.parentNode;
+ // Add relatedTarget, if necessary
+ if ( !event.relatedTarget && event.fromElement )
+ event.relatedTarget = event.fromElement == event.target ? event.toElement : event.fromElement;
+ // Calculate pageX/Y if missing and clientX/Y available
+ if ( event.pageX == null && event.clientX != null ) {
+ var doc = document.documentElement, body = document.body;
+ event.pageX = event.clientX + (doc && doc.scrollLeft || body && body.scrollLeft || 0) - (doc.clientLeft || 0);
+ event.pageY = event.clientY + (doc && doc.scrollTop || body && body.scrollTop || 0) - (doc.clientTop || 0);
+ // Add which for key events
+ if ( !event.which && ((event.charCode || event.charCode === 0) ? event.charCode : event.keyCode) )
+ event.which = event.charCode || event.keyCode;
+ // Add metaKey to non-Mac browsers (use ctrl for PC's and Meta for Macs)
+ if ( !event.metaKey && event.ctrlKey )
+ event.metaKey = event.ctrlKey;
+ // Add which for click: 1 == left; 2 == middle; 3 == right
+ // Note: button is not normalized, so don't use it
+ if ( !event.which && event.button )
+ event.which = (event.button & 1 ? 1 : ( event.button & 2 ? 3 : ( event.button & 4 ? 2 : 0 ) ));
+ return event;
+ proxy: function( fn, proxy ){
+ // Set the guid of unique handler to the same of original handler, so it can be removed
+ proxy.guid = fn.guid = fn.guid || proxy.guid || this.guid++;
+ // So proxy can be declared as an argument
+ return proxy;
+ special: {
+ ready: {
+ setup: function() {
+ // Make sure the ready event is setup
+ bindReady();
+ return;
+ teardown: function() { return; }
+ mouseenter: {
+ if ( jQuery.browser.msie ) return false;
+ jQuery(this).bind("mouseover", jQuery.event.special.mouseenter.handler);
+ return true;
+ jQuery(this).unbind("mouseover", jQuery.event.special.mouseenter.handler);
+ return true;
+ handler: function(event) {
+ // If we actually just moused on to a sub-element, ignore it
+ if ( withinElement(event, this) ) return true;
+ // Execute the right handlers by setting the event type to mouseenter
+ event.type = "mouseenter";
+ return jQuery.event.handle.apply(this, arguments);
+ mouseleave: {
+ jQuery(this).bind("mouseout", jQuery.event.special.mouseleave.handler);
+ return true;
+ jQuery(this).unbind("mouseout", jQuery.event.special.mouseleave.handler);
+ return true;
+ // Execute the right handlers by setting the event type to mouseleave
+ event.type = "mouseleave";
+jQuery.fn.extend({
+ bind: function( type, data, fn ) {
+ return type == "unload" ? this.one(type, data, fn) : this.each(function(){
+ jQuery.event.add( this, type, fn || data, fn && data );
+ one: function( type, data, fn ) {
+ var one = jQuery.event.proxy( fn || data, function(event) {
+ jQuery(this).unbind(event, one);
+ return (fn || data).apply( this, arguments );
+ jQuery.event.add( this, type, one, fn && data);
+ unbind: function( type, fn ) {
+ jQuery.event.remove( this, type, fn );
+ trigger: function( type, data, fn ) {
+ jQuery.event.trigger( type, data, this, true, fn );
+ triggerHandler: function( type, data, fn ) {
+ return this[0] && jQuery.event.trigger( type, data, this[0], false, fn );
+ toggle: function( fn ) {
+ // Save reference to arguments for access in closure
+ var args = arguments, i = 1;
+ // link all the functions, so any of them can unbind this click handler
+ while( i < args.length )
+ jQuery.event.proxy( fn, args[i++] );
+ return this.click( jQuery.event.proxy( fn, function(event) {
+ // Figure out which function to execute
+ this.lastToggle = ( this.lastToggle || 0 ) % i;
+ // Make sure that clicks stop
+ // and execute the function
+ return args[ this.lastToggle++ ].apply( this, arguments ) || false;
+ hover: function(fnOver, fnOut) {
+ return this.bind('mouseenter', fnOver).bind('mouseleave', fnOut);
+ ready: function(fn) {
+ // Attach the listeners
+ bindReady();
+ // If the DOM is already ready
+ if ( jQuery.isReady )
+ // Execute the function immediately
+ fn.call( document, jQuery );
+ // Otherwise, remember the function for later
+ else
+ // Add the function to the wait list
+ jQuery.readyList.push( function() { return fn.call(this, jQuery); } );
+ return this;
+jQuery.extend({
+ isReady: false,
+ readyList: [],
+ // Handle when the DOM is ready
+ ready: function() {
+ // Make sure that the DOM is not already loaded
+ if ( !jQuery.isReady ) {
+ // Remember that the DOM is ready
+ jQuery.isReady = true;
+ // If there are functions bound, to execute
+ if ( jQuery.readyList ) {
+ // Execute all of them
+ jQuery.each( jQuery.readyList, function(){
+ this.call( document );
+ // Reset the list of functions
+ jQuery.readyList = null;
+ // Trigger any bound ready events
+ jQuery(document).triggerHandler("ready");
+var readyBound = false;
+function bindReady(){
+ if ( readyBound ) return;
+ readyBound = true;
+ // Mozilla, Opera (see further below for it) and webkit nightlies currently support this event
+ if ( document.addEventListener && !jQuery.browser.opera)
+ // Use the handy event callback
+ document.addEventListener( "DOMContentLoaded", jQuery.ready, false );
+ // If IE is used and is not in a frame
+ // Continually check to see if the document is ready
+ if ( jQuery.browser.msie && window == top ) (function(){
+ if (jQuery.isReady) return;
+ try {
+ // If IE is used, use the trick by Diego Perini
+ // http://javascript.nwbox.com/IEContentLoaded/
+ document.documentElement.doScroll("left");
+ } catch( error ) {
+ setTimeout( arguments.callee, 0 );
+ return;
+ // and execute any waiting functions
+ jQuery.ready();
+ if ( jQuery.browser.opera )
+ document.addEventListener( "DOMContentLoaded", function () {
+ for (var i = 0; i < document.styleSheets.length; i++)
+ if (document.styleSheets[i].disabled) {
+ return;
+ jQuery.ready();
+ }, false);
+ if ( jQuery.browser.safari ) {
+ var numStyles;
+ (function(){
+ if ( document.readyState != "loaded" && document.readyState != "complete" ) {
+ return;
+ if ( numStyles === undefined )
+ numStyles = jQuery("style, link[rel=stylesheet]").length;
+ if ( document.styleSheets.length != numStyles ) {
+ return;
+ jQuery.ready();
+ // A fallback to window.onload, that will always work
+ jQuery.event.add( window, "load", jQuery.ready );
+jQuery.each( ("blur,focus,load,resize,scroll,unload,click,dblclick," +
+ "mousedown,mouseup,mousemove,mouseover,mouseout,change,select," +
+ "submit,keydown,keypress,keyup,error").split(","), function(i, name){
+ // Handle event binding
+ jQuery.fn[name] = function(fn){
+ return fn ? this.bind(name, fn) : this.trigger(name);
+// Checks if an event happened on an element within another element
+// Used in jQuery.event.special.mouseenter and mouseleave handlers
+var withinElement = function(event, elem) {
+ // Check if mouse(over|out) are still within the same parent element
+ var parent = event.relatedTarget;
+ // Traverse up the tree
+ while ( parent && parent != elem ) try { parent = parent.parentNode; } catch(error) { parent = elem; }
+ // Return true if we actually just moused on to a sub-element
+ return parent == elem;
+// Prevent memory leaks in IE
+// And prevent errors on refresh with events like mouseover in other browsers
+// Window isn't included so as not to unbind existing unload events
+jQuery(window).bind("unload", function() {
+ jQuery("*").add(document).unbind();
+jQuery.fn.extend({
+ // Keep a copy of the old load
+ _load: jQuery.fn.load,
+ load: function( url, params, callback ) {
+ if ( typeof url != 'string' )
+ return this._load( url );
+ var off = url.indexOf(" ");
+ if ( off >= 0 ) {
+ var selector = url.slice(off, url.length);
+ url = url.slice(0, off);
+ callback = callback || function(){};
+ // Default to a GET request
+ var type = "GET";
+ // If the second parameter was provided
+ if ( params )
+ // If it's a function
+ if ( jQuery.isFunction( params ) ) {
+ // We assume that it's the callback
+ callback = params;
+ params = null;
+ // Otherwise, build a param string
+ } else {
+ params = jQuery.param( params );
+ type = "POST";
+ var self = this;
+ // Request the remote document
+ jQuery.ajax({
+ url: url,
+ type: type,
+ dataType: "html",
+ data: params,
+ complete: function(res, status){
+ // If successful, inject the HTML into all the matched elements
+ if ( status == "success" || status == "notmodified" )
+ // See if a selector was specified
+ self.html( selector ?
+ // Create a dummy div to hold the results
+ jQuery("<div/>")
+ // inject the contents of the document in, removing the scripts
+ // to avoid any 'Permission Denied' errors in IE
+ .append(res.responseText.replace(/<script(.|\s)*?\/script>/g, ""))
+ // Locate the specified elements
+ .find(selector) :
+ // If not, just inject the full result
+ res.responseText );
+ self.each( callback, [res.responseText, status, res] );
+ return this;
+ serialize: function() {
+ return jQuery.param(this.serializeArray());
+ serializeArray: function() {
+ return this.map(function(){
+ return jQuery.nodeName(this, "form") ?
+ jQuery.makeArray(this.elements) : this;
+ .filter(function(){
+ return this.name && !this.disabled &&
+ (this.checked || /select|textarea/i.test(this.nodeName) ||
+ /text|hidden|password/i.test(this.type));
+ .map(function(i, elem){
+ var val = jQuery(this).val();
+ return val == null ? null :
+ val.constructor == Array ?
+ jQuery.map( val, function(val, i){
+ return {name: elem.name, value: val};
+ {name: elem.name, value: val};
+ }).get();
+// Attach a bunch of functions for handling common AJAX events
+jQuery.each( "ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","), function(i,o){
+ jQuery.fn[o] = function(f){
+ return this.bind(o, f);
+var jsc = now();
+jQuery.extend({
+ get: function( url, data, callback, type ) {
+ // shift arguments if data argument was ommited
+ if ( jQuery.isFunction( data ) ) {
+ callback = data;
+ data = null;
+ return jQuery.ajax({
+ type: "GET",
+ url: url,
+ data: data,
+ success: callback,
+ dataType: type
+ getScript: function( url, callback ) {
+ return jQuery.get(url, null, callback, "script");
+ getJSON: function( url, data, callback ) {
+ return jQuery.get(url, data, callback, "json");
+ post: function( url, data, callback, type ) {
+ callback = data;
+ data = {};
+ type: "POST",
+ url: url,
+ data: data,
+ dataType: type
+ ajaxSetup: function( settings ) {
+ jQuery.extend( jQuery.ajaxSettings, settings );
+ ajaxSettings: {
+ url: location.href,
+ global: true,
+ type: "GET",
+ timeout: 0,
+ contentType: "application/x-www-form-urlencoded",
+ processData: true,
+ async: true,
+ data: null,
+ username: null,
+ password: null,
+ accepts: {
+ xml: "application/xml, text/xml",
+ html: "text/html",
+ script: "text/javascript, application/javascript",
+ json: "application/json, text/javascript",
+ text: "text/plain",
+ _default: "*/*"
+ // Last-Modified header cache for next request
+ lastModified: {},
+ ajax: function( s ) {
+ // Extend the settings, but re-extend 's' so that it can be
+ // checked again later (in the test suite, specifically)
+ s = jQuery.extend(true, s, jQuery.extend(true, {}, jQuery.ajaxSettings, s));
+ var jsonp, jsre = /=\?(&|$)/g, status, data,
+ type = s.type.toUpperCase();
+ // convert data if not already a string
+ if ( s.data && s.processData && typeof s.data != "string" )
+ s.data = jQuery.param(s.data);
+ // Handle JSONP Parameter Callbacks
+ if ( s.dataType == "jsonp" ) {
+ if ( type == "GET" ) {
+ if ( !s.url.match(jsre) )
+ s.url += (s.url.match(/\?/) ? "&" : "?") + (s.jsonp || "callback") + "=?";
+ } else if ( !s.data || !s.data.match(jsre) )
+ s.data = (s.data ? s.data + "&" : "") + (s.jsonp || "callback") + "=?";
+ s.dataType = "json";
+ // Build temporary JSONP function
+ if ( s.dataType == "json" && (s.data && s.data.match(jsre) || s.url.match(jsre)) ) {
+ jsonp = "jsonp" + jsc++;
+ // Replace the =? sequence both in the query string and the data
+ if ( s.data )
+ s.data = (s.data + "").replace(jsre, "=" + jsonp + "$1");
+ s.url = s.url.replace(jsre, "=" + jsonp + "$1");
+ // We need to make sure
+ // that a JSONP style response is executed properly
+ s.dataType = "script";
+ // Handle JSONP-style loading
+ window[ jsonp ] = function(tmp){
+ data = tmp;
+ success();
+ complete();
+ // Garbage collect
+ window[ jsonp ] = undefined;
+ try{ delete window[ jsonp ]; } catch(e){}
+ if ( head )
+ if ( s.dataType == "script" && s.cache == null )
+ s.cache = false;
+ if ( s.cache === false && type == "GET" ) {
+ var ts = now();
+ // try replacing _= if it is there
+ var ret = s.url.replace(/(\?|&)_=.*?(&|$)/, "$1_=" + ts + "$2");
+ // if nothing was replaced, add timestamp to the end
+ s.url = ret + ((ret == s.url) ? (s.url.match(/\?/) ? "&" : "?") + "_=" + ts : "");
+ // If data is available, append data to url for get requests
+ if ( s.data && type == "GET" ) {
+ s.url += (s.url.match(/\?/) ? "&" : "?") + s.data;
+ // IE likes to send both get and post data, prevent this
+ s.data = null;
+ // Watch for a new set of requests
+ if ( s.global && ! jQuery.active++ )
+ jQuery.event.trigger( "ajaxStart" );
+ // Matches an absolute URL, and saves the domain
+ var remote = /^(?:\w+:)?\/\/([^\/?#]+)/;
+ // If we're requesting a remote document
+ // and trying to load JSON or Script with a GET
+ if ( s.dataType == "script" && type == "GET"
+ && remote.test(s.url) && remote.exec(s.url)[1] != location.host ){
+ var head = document.getElementsByTagName("head")[0];
+ var script = document.createElement("script");
+ script.src = s.url;
+ if (s.scriptCharset)
+ script.charset = s.scriptCharset;
+ // Handle Script loading
+ if ( !jsonp ) {
+ var done = false;
+ // Attach handlers for all browsers
+ script.onload = script.onreadystatechange = function(){
+ if ( !done && (!this.readyState ||
+ this.readyState == "loaded" || this.readyState == "complete") ) {
+ done = true;
+ success();
+ complete();
+ head.appendChild(script);
+ // We handle everything using the script element injection
+ return undefined;
+ var requestDone = false;
+ // Create the request object; Microsoft failed to properly
+ // implement the XMLHttpRequest in IE7, so we use the ActiveXObject when it is available
+ var xhr = window.ActiveXObject ? new ActiveXObject("Microsoft.XMLHTTP") : new XMLHttpRequest();
+ // Open the socket
+ // Passing null username, generates a login popup on Opera (#2865)
+ if( s.username )
+ xhr.open(type, s.url, s.async, s.username, s.password);
+ else
+ xhr.open(type, s.url, s.async);
+ // Need an extra try/catch for cross domain requests in Firefox 3
+ try {
+ // Set the correct header, if data is being sent
+ if ( s.data )
+ xhr.setRequestHeader("Content-Type", s.contentType);
+ // Set the If-Modified-Since header, if ifModified mode.
+ if ( s.ifModified )
+ xhr.setRequestHeader("If-Modified-Since",
+ jQuery.lastModified[s.url] || "Thu, 01 Jan 1970 00:00:00 GMT" );
+ // Set header so the called script knows that it's an XMLHttpRequest
+ xhr.setRequestHeader("X-Requested-With", "XMLHttpRequest");
+ // Set the Accepts header for the server, depending on the dataType
+ xhr.setRequestHeader("Accept", s.dataType && s.accepts[ s.dataType ] ?
+ s.accepts[ s.dataType ] + ", */*" :
+ s.accepts._default );
+ } catch(e){}
+ // Allow custom headers/mimetypes
+ if ( s.beforeSend && s.beforeSend(xhr, s) === false ) {
+ // cleanup active request counter
+ s.global && jQuery.active--;
+ // close opended socket
+ xhr.abort();
+ return false;
+ if ( s.global )
+ jQuery.event.trigger("ajaxSend", [xhr, s]);
+ // Wait for a response to come back
+ var onreadystatechange = function(isTimeout){
+ // The transfer is complete and the data is available, or the request timed out
+ if ( !requestDone && xhr && (xhr.readyState == 4 || isTimeout == "timeout") ) {
+ requestDone = true;
+ // clear poll interval
+ if (ival) {
+ clearInterval(ival);
+ ival = null;
+ status = isTimeout == "timeout" && "timeout" ||
+ !jQuery.httpSuccess( xhr ) && "error" ||
+ s.ifModified && jQuery.httpNotModified( xhr, s.url ) && "notmodified" ||
+ "success";
+ if ( status == "success" ) {
+ // Watch for, and catch, XML document parse errors
+ try {
+ // process the data (runs the xml through httpData regardless of callback)
+ data = jQuery.httpData( xhr, s.dataType, s.dataFilter );
+ } catch(e) {
+ status = "parsererror";
+ // Make sure that the request was successful or notmodified
+ // Cache Last-Modified header, if ifModified mode.
+ var modRes;
+ try {
+ modRes = xhr.getResponseHeader("Last-Modified");
+ } catch(e) {} // swallow exception thrown by FF if header is not available
+ if ( s.ifModified && modRes )
+ jQuery.lastModified[s.url] = modRes;
+ // JSONP handles its own success callback
+ if ( !jsonp )
+ success();
+ } else
+ jQuery.handleError(s, xhr, status);
+ // Fire the complete handlers
+ complete();
+ // Stop memory leaks
+ if ( s.async )
+ xhr = null;
+ if ( s.async ) {
+ // don't attach the handler to the request, just poll it instead
+ var ival = setInterval(onreadystatechange, 13);
+ // Timeout checker
+ if ( s.timeout > 0 )
+ setTimeout(function(){
+ // Check to see if the request is still happening
+ if ( xhr ) {
+ // Cancel the request
+ xhr.abort();
+ if( !requestDone )
+ onreadystatechange( "timeout" );
+ }, s.timeout);
+ // Send the data
+ try {
+ xhr.send(s.data);
+ } catch(e) {
+ jQuery.handleError(s, xhr, null, e);
+ // firefox 1.5 doesn't fire statechange for sync requests
+ if ( !s.async )
+ onreadystatechange();
+ function success(){
+ // If a local callback was specified, fire it and pass it the data
+ if ( s.success )
+ s.success( data, status );
+ // Fire the global callback
+ if ( s.global )
+ jQuery.event.trigger( "ajaxSuccess", [xhr, s] );
+ function complete(){
+ // Process result
+ if ( s.complete )
+ s.complete(xhr, status);
+ // The request was completed
+ if ( s.global )
+ jQuery.event.trigger( "ajaxComplete", [xhr, s] );
+ // Handle the global AJAX counter
+ if ( s.global && ! --jQuery.active )
+ jQuery.event.trigger( "ajaxStop" );
+ // return XMLHttpRequest to allow aborting the request etc.
+ return xhr;
+ handleError: function( s, xhr, status, e ) {
+ if ( s.error ) s.error( xhr, status, e );
+ if ( s.global )
+ jQuery.event.trigger( "ajaxError", [xhr, s, e] );
+ // Counter for holding the number of active queries
+ active: 0,
+ // Determines if an XMLHttpRequest was successful or not
+ httpSuccess: function( xhr ) {
+ try {
+ // IE error sometimes returns 1223 when it should be 204 so treat it as success, see #1450
+ return !xhr.status && location.protocol == "file:" ||
+ ( xhr.status >= 200 && xhr.status < 300 ) || xhr.status == 304 || xhr.status == 1223 ||
+ jQuery.browser.safari && xhr.status == undefined;
+ } catch(e){}
+ return false;
+ // Determines if an XMLHttpRequest returns NotModified
+ httpNotModified: function( xhr, url ) {
+ try {
+ var xhrRes = xhr.getResponseHeader("Last-Modified");
+ // Firefox always returns 200. check Last-Modified date
+ return xhr.status == 304 || xhrRes == jQuery.lastModified[url] ||
+ } catch(e){}
+ return false;
+ httpData: function( xhr, type, filter ) {
+ var ct = xhr.getResponseHeader("content-type"),
+ xml = type == "xml" || !type && ct && ct.indexOf("xml") >= 0,
+ data = xml ? xhr.responseXML : xhr.responseText;
+ if ( xml && data.documentElement.tagName == "parsererror" )
+ throw "parsererror";
+ // Allow a pre-filtering function to sanitize the response
+ if( filter )
+ data = filter( data, type );
+ // If the type is "script", eval it in global context
+ if ( type == "script" )
+ jQuery.globalEval( data );
+ // Get the JavaScript object, if JSON is used.
+ if ( type == "json" )
+ data = eval("(" + data + ")");
+ return data;
+ // Serialize an array of form elements or a set of
+ // key/values into a query string
+ param: function( a ) {
+ var s = [];
+ // If an array was passed in, assume that it is an array
+ // of form elements
+ if ( a.constructor == Array || a.jquery )
+ // Serialize the form elements
+ jQuery.each( a, function(){
+ s.push( encodeURIComponent(this.name) + "=" + encodeURIComponent( this.value ) );
+ // Otherwise, assume that it's an object of key/value pairs
+ else
+ // Serialize the key/values
+ for ( var j in a )
+ // If the value is an array then the key names need to be repeated
+ if ( a[j] && a[j].constructor == Array )
+ jQuery.each( a[j], function(){
+ s.push( encodeURIComponent(j) + "=" + encodeURIComponent( this ) );
+ else
+ s.push( encodeURIComponent(j) + "=" + encodeURIComponent( jQuery.isFunction(a[j]) ? a[j]() : a[j] ) );
+ // Return the resulting serialization
+ return s.join("&").replace(/%20/g, "+");
+jQuery.fn.extend({
+ show: function(speed,callback){
+ return speed ?
+ this.animate({
+ height: "show", width: "show", opacity: "show"
+ }, speed, callback) :
+ this.filter(":hidden").each(function(){
+ this.style.display = this.oldblock || "";
+ if ( jQuery.css(this,"display") == "none" ) {
+ var elem = jQuery("<" + this.tagName + " />").appendTo("body");
+ this.style.display = elem.css("display");
+ // handle an edge condition where css is - div { display:none; } or similar
+ if (this.style.display == "none")
+ this.style.display = "block";
+ elem.remove();
+ }).end();
+ hide: function(speed,callback){
+ return speed ?
+ this.animate({
+ height: "hide", width: "hide", opacity: "hide"
+ this.filter(":visible").each(function(){
+ this.oldblock = this.oldblock || jQuery.css(this,"display");
+ this.style.display = "none";
+ }).end();
+ // Save the old toggle function
+ _toggle: jQuery.fn.toggle,
+ toggle: function( fn, fn2 ){
+ return jQuery.isFunction(fn) && jQuery.isFunction(fn2) ?
+ this._toggle.apply( this, arguments ) :
+ fn ?
+ this.animate({
+ height: "toggle", width: "toggle", opacity: "toggle"
+ }, fn, fn2) :
+ this.each(function(){
+ jQuery(this)[ jQuery(this).is(":hidden") ? "show" : "hide" ]();
+ slideDown: function(speed,callback){
+ return this.animate({height: "show"}, speed, callback);
+ slideUp: function(speed,callback){
+ return this.animate({height: "hide"}, speed, callback);
+ slideToggle: function(speed, callback){
+ return this.animate({height: "toggle"}, speed, callback);
+ fadeIn: function(speed, callback){
+ return this.animate({opacity: "show"}, speed, callback);
+ fadeOut: function(speed, callback){
+ return this.animate({opacity: "hide"}, speed, callback);
+ fadeTo: function(speed,to,callback){
+ return this.animate({opacity: to}, speed, callback);
+ animate: function( prop, speed, easing, callback ) {
+ var optall = jQuery.speed(speed, easing, callback);
+ return this[ optall.queue === false ? "each" : "queue" ](function(){
+ if ( this.nodeType != 1)
+ return false;
+ var opt = jQuery.extend({}, optall), p,
+ hidden = jQuery(this).is(":hidden"), self = this;
+ for ( p in prop ) {
+ if ( prop[p] == "hide" && hidden || prop[p] == "show" && !hidden )
+ return opt.complete.call(this);
+ if ( p == "height" || p == "width" ) {
+ // Store display property
+ opt.display = jQuery.css(this, "display");
+ // Make sure that nothing sneaks out
+ opt.overflow = this.style.overflow;
+ if ( opt.overflow != null )
+ this.style.overflow = "hidden";
+ opt.curAnim = jQuery.extend({}, prop);
+ jQuery.each( prop, function(name, val){
+ var e = new jQuery.fx( self, opt, name );
+ if ( /toggle|show|hide/.test(val) )
+ e[ val == "toggle" ? hidden ? "show" : "hide" : val ]( prop );
+ else {
+ var parts = val.toString().match(/^([+-]=)?([\d+-.]+)(.*)$/),
+ start = e.cur(true) || 0;
+ if ( parts ) {
+ var end = parseFloat(parts[2]),
+ unit = parts[3] || "px";
+ // We need to compute starting value
+ if ( unit != "px" ) {
+ self.style[ name ] = (end || 1) + unit;
+ start = ((end || 1) / e.cur(true)) * start;
+ self.style[ name ] = start + unit;
+ // If a +=/-= token was provided, we're doing a relative animation
+ if ( parts[1] )
+ end = ((parts[1] == "-=" ? -1 : 1) * end) + start;
+ e.custom( start, end, unit );
+ } else
+ e.custom( start, val, "" );
+ // For JS strict compliance
+ return true;
+ queue: function(type, fn){
+ if ( jQuery.isFunction(type) || ( type && type.constructor == Array )) {
+ fn = type;
+ type = "fx";
+ if ( !type || (typeof type == "string" && !fn) )
+ return queue( this[0], type );
+ return this.each(function(){
+ if ( fn.constructor == Array )
+ queue(this, type, fn);
+ else {
+ queue(this, type).push( fn );
+ if ( queue(this, type).length == 1 )
+ fn.call(this);
+ stop: function(clearQueue, gotoEnd){
+ var timers = jQuery.timers;
+ if (clearQueue)
+ this.queue([]);
+ // go in reverse order so anything added to the queue during the loop is ignored
+ for ( var i = timers.length - 1; i >= 0; i-- )
+ if ( timers[i].elem == this ) {
+ if (gotoEnd)
+ // force the next step to be the last
+ timers[i](true);
+ timers.splice(i, 1);
+ // start the next in the queue if the last step wasn't forced
+ if (!gotoEnd)
+ this.dequeue();
+ return this;
+var queue = function( elem, type, array ) {
+ if ( elem ){
+ type = type || "fx";
+ var q = jQuery.data( elem, type + "queue" );
+ if ( !q || array )
+ q = jQuery.data( elem, type + "queue", jQuery.makeArray(array) );
+ return q;
+jQuery.fn.dequeue = function(type){
+ var q = queue(this, type);
+ q.shift();
+ if ( q.length )
+ q[0].call( this );
+jQuery.extend({
+ speed: function(speed, easing, fn) {
+ var opt = speed && speed.constructor == Object ? speed : {
+ complete: fn || !fn && easing ||
+ jQuery.isFunction( speed ) && speed,
+ duration: speed,
+ easing: fn && easing || easing && easing.constructor != Function && easing
+ opt.duration = (opt.duration && opt.duration.constructor == Number ?
+ opt.duration :
+ jQuery.fx.speeds[opt.duration]) || jQuery.fx.speeds.def;
+ // Queueing
+ opt.old = opt.complete;
+ opt.complete = function(){
+ if ( opt.queue !== false )
+ jQuery(this).dequeue();
+ if ( jQuery.isFunction( opt.old ) )
+ opt.old.call( this );
+ return opt;
+ easing: {
+ linear: function( p, n, firstNum, diff ) {
+ return firstNum + diff * p;
+ swing: function( p, n, firstNum, diff ) {
+ return ((-Math.cos(p*Math.PI)/2) + 0.5) * diff + firstNum;
+ timers: [],
+ timerId: null,
+ fx: function( elem, options, prop ){
+ this.options = options;
+ this.elem = elem;
+ this.prop = prop;
+ if ( !options.orig )
+ options.orig = {};
+jQuery.fx.prototype = {
+ // Simple function for setting a style value
+ update: function(){
+ if ( this.options.step )
+ this.options.step.call( this.elem, this.now, this );
+ (jQuery.fx.step[this.prop] || jQuery.fx.step._default)( this );
+ // Set display property to block for height/width animations
+ if ( this.prop == "height" || this.prop == "width" )
+ this.elem.style.display = "block";
+ // Get the current size
+ cur: function(force){
+ if ( this.elem[this.prop] != null && this.elem.style[this.prop] == null )
+ return this.elem[ this.prop ];
+ var r = parseFloat(jQuery.css(this.elem, this.prop, force));
+ return r && r > -10000 ? r : parseFloat(jQuery.curCSS(this.elem, this.prop)) || 0;
+ // Start an animation from one number to another
+ custom: function(from, to, unit){
+ this.startTime = now();
+ this.start = from;
+ this.end = to;
+ this.unit = unit || this.unit || "px";
+ this.now = this.start;
+ this.pos = this.state = 0;
+ this.update();
+ var self = this;
+ function t(gotoEnd){
+ return self.step(gotoEnd);
+ t.elem = this.elem;
+ jQuery.timers.push(t);
+ if ( jQuery.timerId == null ) {
+ jQuery.timerId = setInterval(function(){
+ for ( var i = 0; i < timers.length; i++ )
+ if ( !timers[i]() )
+ timers.splice(i--, 1);
+ if ( !timers.length ) {
+ clearInterval( jQuery.timerId );
+ jQuery.timerId = null;
+ }, 13);
+ // Simple 'show' function
+ show: function(){
+ // Remember where we started, so that we can go back to it later
+ this.options.orig[this.prop] = jQuery.attr( this.elem.style, this.prop );
+ this.options.show = true;
+ // Begin the animation
+ this.custom(0, this.cur());
+ // Make sure that we start at a small width/height to avoid any
+ // flash of content
+ if ( this.prop == "width" || this.prop == "height" )
+ this.elem.style[this.prop] = "1px";
+ // Start by showing the element
+ jQuery(this.elem).show();
+ // Simple 'hide' function
+ hide: function(){
+ this.options.hide = true;
+ this.custom(this.cur(), 0);
+ // Each step of an animation
+ step: function(gotoEnd){
+ var t = now();
+ if ( gotoEnd || t > this.options.duration + this.startTime ) {
+ this.now = this.end;
+ this.pos = this.state = 1;
+ this.update();
+ this.options.curAnim[ this.prop ] = true;
+ var done = true;
+ for ( var i in this.options.curAnim )
+ if ( this.options.curAnim[i] !== true )
+ done = false;
+ if ( done ) {
+ if ( this.options.display != null ) {
+ // Reset the overflow
+ this.elem.style.overflow = this.options.overflow;
+ // Reset the display
+ this.elem.style.display = this.options.display;
+ if ( jQuery.css(this.elem, "display") == "none" )
+ // Hide the element if the "hide" operation was done
+ if ( this.options.hide )
+ this.elem.style.display = "none";
+ // Reset the properties, if the item has been hidden or shown
+ if ( this.options.hide || this.options.show )
+ for ( var p in this.options.curAnim )
+ jQuery.attr(this.elem.style, p, this.options.orig[p]);
+ if ( done )
+ // Execute the complete function
+ this.options.complete.call( this.elem );
+ return false;
+ } else {
+ var n = t - this.startTime;
+ this.state = n / this.options.duration;
+ // Perform the easing function, defaults to swing
+ this.pos = jQuery.easing[this.options.easing || (jQuery.easing.swing ? "swing" : "linear")](this.state, n, 0, 1, this.options.duration);
+ this.now = this.start + ((this.end - this.start) * this.pos);
+ // Perform the next step of the animation
+ this.update();
+ return true;
+jQuery.extend( jQuery.fx, {
+ speeds:{
+ slow: 600,
+ fast: 200,
+ // Default speed
+ def: 400
+ step: {
+ scrollLeft: function(fx){
+ fx.elem.scrollLeft = fx.now;
+ scrollTop: function(fx){
+ fx.elem.scrollTop = fx.now;
+ opacity: function(fx){
+ jQuery.attr(fx.elem.style, "opacity", fx.now);
+ _default: function(fx){
+ fx.elem.style[ fx.prop ] = fx.now + fx.unit;
+// The Offset Method
+// Originally By Brandon Aaron, part of the Dimension Plugin
+// http://jquery.com/plugins/project/dimensions
+jQuery.fn.offset = function() {
+ var left = 0, top = 0, elem = this[0], results;
+ if ( elem ) with ( jQuery.browser ) {
+ var parent = elem.parentNode,
+ offsetChild = elem,
+ offsetParent = elem.offsetParent,
+ doc = elem.ownerDocument,
+ safari2 = safari && parseInt(version) < 522 && !/adobeair/i.test(userAgent),
+ css = jQuery.curCSS,
+ fixed = css(elem, "position") == "fixed";
+ // Use getBoundingClientRect if available
+ if ( elem.getBoundingClientRect ) {
+ var box = elem.getBoundingClientRect();
+ // Add the document scroll offsets
+ add(box.left + Math.max(doc.documentElement.scrollLeft, doc.body.scrollLeft),
+ box.top + Math.max(doc.documentElement.scrollTop, doc.body.scrollTop));
+ // IE adds the HTML element's border, by default it is medium which is 2px
+ // IE 6 and 7 quirks mode the border width is overwritable by the following css html { border: 0; }
+ // IE 7 standards mode, the border is always 2px
+ // This border/offset is typically represented by the clientLeft and clientTop properties
+ // However, in IE6 and 7 quirks mode the clientLeft and clientTop properties are not updated when overwriting it via CSS
+ // Therefore this method will be off by 2px in IE while in quirksmode
+ add( -doc.documentElement.clientLeft, -doc.documentElement.clientTop );
+ // Otherwise loop through the offsetParents and parentNodes
+ } else {
+ // Initial element offsets
+ add( elem.offsetLeft, elem.offsetTop );
+ // Get parent offsets
+ while ( offsetParent ) {
+ // Add offsetParent offsets
+ add( offsetParent.offsetLeft, offsetParent.offsetTop );
+ // Mozilla and Safari > 2 does not include the border on offset parents
+ // However Mozilla adds the border for table or table cells
+ if ( mozilla && !/^t(able|d|h)$/i.test(offsetParent.tagName) || safari && !safari2 )
+ border( offsetParent );
+ // Add the document scroll offsets if position is fixed on any offsetParent
+ if ( !fixed && css(offsetParent, "position") == "fixed" )
+ fixed = true;
+ // Set offsetChild to previous offsetParent unless it is the body element
+ offsetChild = /^body$/i.test(offsetParent.tagName) ? offsetChild : offsetParent;
+ // Get next offsetParent
+ offsetParent = offsetParent.offsetParent;
+ // Get parent scroll offsets
+ while ( parent && parent.tagName && !/^body|html$/i.test(parent.tagName) ) {
+ // Remove parent scroll UNLESS that parent is inline or a table to work around Opera inline/table scrollLeft/Top bug
+ if ( !/^inline|table.*$/i.test(css(parent, "display")) )
+ // Subtract parent scroll offsets
+ add( -parent.scrollLeft, -parent.scrollTop );
+ // Mozilla does not add the border for a parent that has overflow != visible
+ if ( mozilla && css(parent, "overflow") != "visible" )
+ border( parent );
+ // Get next parent
+ parent = parent.parentNode;
+ // Safari <= 2 doubles body offsets with a fixed position element/offsetParent or absolutely positioned offsetChild
+ // Mozilla doubles body offsets with a non-absolutely positioned offsetChild
+ if ( (safari2 && (fixed || css(offsetChild, "position") == "absolute")) ||
+ (mozilla && css(offsetChild, "position") != "absolute") )
+ add( -doc.body.offsetLeft, -doc.body.offsetTop );
+ if ( fixed )
+ add(Math.max(doc.documentElement.scrollLeft, doc.body.scrollLeft),
+ // Return an object with top and left properties
+ results = { top: top, left: left };
+ function border(elem) {
+ add( jQuery.curCSS(elem, "borderLeftWidth", true), jQuery.curCSS(elem, "borderTopWidth", true) );
+ function add(l, t) {
+ left += parseInt(l, 10) || 0;
+ top += parseInt(t, 10) || 0;
+ return results;
+jQuery.fn.extend({
+ position: function() {
+ var left = 0, top = 0, results;
+ if ( this[0] ) {
+ // Get *real* offsetParent
+ var offsetParent = this.offsetParent(),
+ // Get correct offsets
+ offset = this.offset(),
+ parentOffset = /^body|html$/i.test(offsetParent[0].tagName) ? { top: 0, left: 0 } : offsetParent.offset();
+ // Subtract element margins
+ // note: when an element has margin: auto the offsetLeft and marginLeft
+ // are the same in Safari causing offset.left to incorrectly be 0
+ offset.top -= num( this, 'marginTop' );
+ offset.left -= num( this, 'marginLeft' );
+ // Add offsetParent borders
+ parentOffset.top += num( offsetParent, 'borderTopWidth' );
+ parentOffset.left += num( offsetParent, 'borderLeftWidth' );
+ // Subtract the two offsets
+ results = {
+ top: offset.top - parentOffset.top,
+ left: offset.left - parentOffset.left
+ return results;
+ offsetParent: function() {
+ var offsetParent = this[0].offsetParent;
+ while ( offsetParent && (!/^body|html$/i.test(offsetParent.tagName) && jQuery.css(offsetParent, 'position') == 'static') )
+ return jQuery(offsetParent);
+// Create scrollLeft and scrollTop methods
+jQuery.each( ['Left', 'Top'], function(i, name) {
+ var method = 'scroll' + name;
+ jQuery.fn[ method ] = function(val) {
+ if (!this[0]) return;
+ return val != undefined ?
+ // Set the scroll offset
+ this.each(function() {
+ this == window || this == document ?
+ window.scrollTo(
+ !i ? val : jQuery(window).scrollLeft(),
+ i ? val : jQuery(window).scrollTop()
+ this[ method ] = val;
+ // Return the scroll offset
+ this[0] == window || this[0] == document ?
+ self[ i ? 'pageYOffset' : 'pageXOffset' ] ||
+ jQuery.boxModel && document.documentElement[ method ] ||
+ document.body[ method ] :
+ this[0][ method ];
+// Create innerHeight, innerWidth, outerHeight and outerWidth methods
+ var tl = i ? "Left" : "Top", // top or left
+ br = i ? "Right" : "Bottom"; // bottom or right
+ // innerHeight and innerWidth
+ jQuery.fn["inner" + name] = function(){
+ return this[ name.toLowerCase() ]() +
+ num(this, "padding" + tl) +
+ num(this, "padding" + br);
+ // outerHeight and outerWidth
+ jQuery.fn["outer" + name] = function(margin) {
+ return this["inner" + name]() +
+ num(this, "border" + tl + "Width") +
+ num(this, "border" + br + "Width") +
+ (margin ?
+ num(this, "margin" + tl) + num(this, "margin" + br) : 0);
Added: branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.js
--- branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.js (rev 0)
+++ branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.js 2010-05-09 13:28:08 UTC (rev 6108)
@@ -0,0 +1,2507 @@
+ * jquery.layout 1.2.0
+ * Copyright (c) 2008
+ * Fabrizio Balliano (http://www.fabrizioballiano.net)
+ * Kevin Dalman (http://allpro.net)
+ * Dual licensed under the GPL (http://www.gnu.org/licenses/gpl.html)
+ * and MIT (http://www.opensource.org/licenses/mit-license.php) licenses.
+ * $Date: 2008-12-27 02:17:22 +0100 (sab, 27 dic 2008) $
+ * $Rev: 203 $
+ * NOTE: For best code readability, view this with a fixed-space font and tabs equal to 4-chars
+(function($) {
+$.fn.layout = function (opts) {
+ * WIDGET CONFIG & OPTIONS
+ // DEFAULTS for options
+ var
+ prefix = "ui-layout-" // prefix for ALL selectors and classNames
+ , defaults = { // misc default values
+ paneClass: prefix+"pane" // ui-layout-pane
+ , resizerClass: prefix+"resizer" // ui-layout-resizer
+ , togglerClass: prefix+"toggler" // ui-layout-toggler
+ , togglerInnerClass: prefix+"" // ui-layout-open / ui-layout-closed
+ , buttonClass: prefix+"button" // ui-layout-button
+ , contentSelector: "."+prefix+"content"// ui-layout-content
+ , contentIgnoreSelector: "."+prefix+"ignore" // ui-layout-mask
+ // DEFAULT PANEL OPTIONS - CHANGE IF DESIRED
+ var options = {
+ name: "" // FUTURE REFERENCE - not used right now
+ , scrollToBookmarkOnLoad: true // after creating a layout, scroll to bookmark in URL (.../page.htm#myBookmark)
+ , defaults: { // default options for 'all panes' - will be overridden by 'per-pane settings'
+ applyDefaultStyles: false // apply basic styles directly to resizers & buttons? If not, then stylesheet must handle it
+ , closable: true // pane can open & close
+ , resizable: true // when open, pane can be resized
+ , slidable: true // when closed, pane can 'slide' open over other panes - closes on mouse-out
+ //, paneSelector: [ ] // MUST be pane-specific!
+ , contentSelector: defaults.contentSelector // INNER div/element to auto-size so only it scrolls, not the entire pane!
+ , contentIgnoreSelector: defaults.contentIgnoreSelector // elem(s) to 'ignore' when measuring 'content'
+ , paneClass: defaults.paneClass // border-Pane - default: 'ui-layout-pane'
+ , resizerClass: defaults.resizerClass // Resizer Bar - default: 'ui-layout-resizer'
+ , togglerClass: defaults.togglerClass // Toggler Button - default: 'ui-layout-toggler'
+ , buttonClass: defaults.buttonClass // CUSTOM Buttons - default: 'ui-layout-button-toggle/-open/-close/-pin'
+ , resizerDragOpacity: 1 // option for ui.draggable
+ //, resizerCursor: "" // MUST be pane-specific - cursor when over resizer-bar
+ , maskIframesOnResize: true // true = all iframes OR = iframe-selector(s) - adds masking-div during resizing/dragging
+ //, size: 100 // inital size of pane - defaults are set 'per pane'
+ , minSize: 0 // when manually resizing a pane
+ , maxSize: 0 // ditto, 0 = no limit
+ , spacing_open: 6 // space between pane and adjacent panes - when pane is 'open'
+ , spacing_closed: 6 // ditto - when pane is 'closed'
+ , togglerLength_open: 50 // Length = WIDTH of toggler button on north/south edges - HEIGHT on east/west edges
+ , togglerLength_closed: 50 // 100% OR -1 means 'full height/width of resizer bar' - 0 means 'hidden'
+ , togglerAlign_open: "center" // top/left, bottom/right, center, OR...
+ , togglerAlign_closed: "center" // 1 => nn = offset from top/left, -1 => -nn == offset from bottom/right
+ , togglerTip_open: "Close" // Toggler tool-tip (title)
+ , togglerTip_closed: "Open" // ditto
+ , resizerTip: "Resize" // Resizer tool-tip (title)
+ , sliderTip: "Slide Open" // resizer-bar triggers 'sliding' when pane is closed
+ , sliderCursor: "pointer" // cursor when resizer-bar will trigger 'sliding'
+ , slideTrigger_open: "click" // click, dblclick, mouseover
+ , slideTrigger_close: "mouseout" // click, mouseout
+ , hideTogglerOnSlide: false // when pane is slid-open, should the toggler show?
+ , togglerContent_open: "" // text or HTML to put INSIDE the toggler
+ , togglerContent_closed: "" // ditto
+ , showOverflowOnHover: false // will bind allowOverflow() utility to pane.onMouseOver
+ , enableCursorHotkey: true // enabled 'cursor' hotkeys
+ //, customHotkey: "" // MUST be pane-specific - EITHER a charCode OR a character
+ , customHotkeyModifier: "SHIFT" // either 'SHIFT', 'CTRL' or 'CTRL+SHIFT' - NOT 'ALT'
+ // NOTE: fxSss_open & fxSss_close options (eg: fxName_open) are auto-generated if not passed
+ , fxName: "slide" // ('none' or blank), slide, drop, scale
+ , fxSpeed: null // slow, normal, fast, 200, nnn - if passed, will OVERRIDE fxSettings.duration
+ , fxSettings: {} // can be passed, eg: { easing: "easeOutBounce", duration: 1500 }
+ , initClosed: false // true = init pane as 'closed'
+ , initHidden: false // true = init pane as 'hidden' - no resizer or spacing
+ /* callback options do not have to be set - listed here for reference only
+ , onshow_start: "" // CALLBACK when pane STARTS to Show - BEFORE onopen/onhide_start
+ , onshow_end: "" // CALLBACK when pane ENDS being Shown - AFTER onopen/onhide_end
+ , onhide_start: "" // CALLBACK when pane STARTS to Close - BEFORE onclose_start
+ , onhide_end: "" // CALLBACK when pane ENDS being Closed - AFTER onclose_end
+ , onopen_start: "" // CALLBACK when pane STARTS to Open
+ , onopen_end: "" // CALLBACK when pane ENDS being Opened
+ , onclose_start: "" // CALLBACK when pane STARTS to Close
+ , onclose_end: "" // CALLBACK when pane ENDS being Closed
+ , onresize_start: "" // CALLBACK when pane STARTS to be ***MANUALLY*** Resized
+ , onresize_end: "" // CALLBACK when pane ENDS being Resized ***FOR ANY REASON***
+ , north: {
+ paneSelector: "."+prefix+"north" // default = .ui-layout-north
+ , size: "auto"
+ , resizerCursor: "n-resize"
+ , south: {
+ paneSelector: "."+prefix+"south" // default = .ui-layout-south
+ , size: "auto"
+ , resizerCursor: "s-resize"
+ , east: {
+ paneSelector: "."+prefix+"east" // default = .ui-layout-east
+ , size: 200
+ , resizerCursor: "e-resize"
+ , west: {
+ paneSelector: "."+prefix+"west" // default = .ui-layout-west
+ , size: 200
+ , resizerCursor: "w-resize"
+ , center: {
+ paneSelector: "."+prefix+"center" // default = .ui-layout-center
+ var effects = { // LIST *PREDEFINED EFFECTS* HERE, even if effect has no settings
+ slide: {
+ all: { duration: "fast" } // eg: duration: 1000, easing: "easeOutBounce"
+ , north: { direction: "up" }
+ , south: { direction: "down" }
+ , east: { direction: "right"}
+ , west: { direction: "left" }
+ , drop: {
+ all: { duration: "slow" } // eg: duration: 1000, easing: "easeOutQuint"
+ , scale: {
+ // STATIC, INTERNAL CONFIG - DO NOT CHANGE THIS!
+ var config = {
+ allPanes: "north,south,east,west,center"
+ , borderPanes: "north,south,east,west"
+ , zIndex: { // set z-index values here
+ resizer_normal: 1 // normal z-index for resizer-bars
+ , pane_normal: 2 // normal z-index for panes
+ , mask: 4 // overlay div used to mask pane(s) during resizing
+ , sliding: 100 // applied to both the pane and its resizer when a pane is 'slid open'
+ , resizing: 10000 // applied to the CLONED resizer-bar when being 'dragged'
+ , animation: 10000 // applied to the pane when being animated - not applied to the resizer
+ , resizers: {
+ cssReq: {
+ position: "absolute"
+ , padding: 0
+ , margin: 0
+ , fontSize: "1px"
+ , textAlign: "left" // to counter-act "center" alignment!
+ , overflow: "hidden" // keep toggler button from overflowing
+ , zIndex: 1
+ , cssDef: { // DEFAULT CSS - applied if: options.PANE.applyDefaultStyles=true
+ background: "#DDD"
+ , border: "none"
+ , togglers: {
+ cssReq: {
+ , display: "block"
+ , padding: 0
+ , margin: 0
+ , textAlign: "center"
+ , fontSize: "1px"
+ , cursor: "pointer"
+ , zIndex: 1
+ background: "#AAA"
+ , content: {
+ cssReq: {
+ overflow: "auto"
+ , cssDef: {}
+ , defaults: { // defaults for ALL panes - overridden by 'per-pane settings' below
+ cssReq: {
+ , margin: 0
+ , zIndex: 2
+ , cssDef: {
+ padding: "10px"
+ , background: "#FFF"
+ , border: "1px solid #BBB"
+ , overflow: "auto"
+ , north: {
+ edge: "top"
+ , sizeType: "height"
+ , dir: "horz"
+ , cssReq: {
+ top: 0
+ , bottom: "auto"
+ , left: 0
+ , right: 0
+ , width: "auto"
+ // height: DYNAMIC
+ , south: {
+ edge: "bottom"
+ , dir: "horz"
+ , cssReq: {
+ top: "auto"
+ , bottom: 0
+ , left: 0
+ , right: 0
+ , width: "auto"
+ , east: {
+ edge: "right"
+ , sizeType: "width"
+ , dir: "vert"
+ , cssReq: {
+ left: "auto"
+ , right: 0
+ , top: "auto" // DYNAMIC
+ , bottom: "auto" // DYNAMIC
+ , height: "auto"
+ // width: DYNAMIC
+ , west: {
+ edge: "left"
+ , dir: "vert"
+ , cssReq: {
+ left: 0
+ , right: "auto"
+ , height: "auto"
+ // width: DYNAMIC
+ , center: {
+ dir: "center"
+ , cssReq: {
+ left: "auto" // DYNAMIC
+ , right: "auto" // DYNAMIC
+ , height: "auto"
+ , width: "auto"
+ // DYNAMIC DATA
+ var state = {
+ // generate random 'ID#' to identify layout - used to create global namespace for timers
+ id: Math.floor(Math.random() * 10000)
+ , container: {}
+ , north: {}
+ , south: {}
+ , east: {}
+ , west: {}
+ , center: {}
+ var
+ altEdge = {
+ top: "bottom"
+ , bottom: "top"
+ , left: "right"
+ , right: "left"
+ , altSide = {
+ north: "south"
+ , south: "north"
+ , east: "west"
+ , west: "east"
+ * INTERNAL HELPER FUNCTIONS
+ * isStr
+ * Returns true if passed param is EITHER a simple string OR a 'string object' - otherwise returns false
+ var isStr = function (o) {
+ if (typeof o == "string")
+ return true;
+ else if (typeof o == "object") {
+ try {
+ var match = o.constructor.toString().match(/string/i);
+ return (match !== null);
+ } catch (e) {}
+ return false;
+ * str
+ * Returns a simple string if the passed param is EITHER a simple string OR a 'string object',
+ * else returns the original object
+ var str = function (o) {
+ if (typeof o == "string" || isStr(o)) return $.trim(o); // trim converts 'String object' to a simple string
+ else return o;
+ * min / max
+ * Alias for Math.min/.max to simplify coding
+ var min = function (x,y) { return Math.min(x,y); };
+ var max = function (x,y) { return Math.max(x,y); };
+ * transformData
+ * Processes the options passed in and transforms them into the format used by layout()
+ * Missing keys are added, and converts the data if passed in 'flat-format' (no sub-keys)
+ * In flat-format, pane-specific-settings are prefixed like: north__optName (2-underscores)
+ * To update effects, options MUST use nested-keys format, with an effects key
+ * @callers initOptions()
+ * @params JSON d Data/options passed by user - may be a single level or nested levels
+ * @returns JSON Creates a data struture that perfectly matches 'options', ready to be imported
+ var transformData = function (d) {
+ var json = { defaults:{fxSettings:{}}, north:{fxSettings:{}}, south:{fxSettings:{}}, east:{fxSettings:{}}, west:{fxSettings:{}}, center:{fxSettings:{}} };
+ d = d || {};
+ if (d.effects || d.defaults || d.north || d.south || d.west || d.east || d.center)
+ json = $.extend( json, d ); // already in json format - add to base keys
+ else
+ // convert 'flat' to 'nest-keys' format - also handles 'empty' user-options
+ $.each( d, function (key,val) {
+ a = key.split("__");
+ json[ a[1] ? a[0] : "defaults" ][ a[1] ? a[1] : a[0] ] = val;
+ return json;
+ * setFlowCallback
+ * Set an INTERNAL callback to avoid simultaneous animation
+ * Runs only if needed and only if all callbacks are not 'already set'!
+ * @param String action Either 'open' or 'close'
+ * @pane String pane A valid border-pane name, eg 'west'
+ * @pane Boolean param Extra param for callback (optional)
+ var setFlowCallback = function (action, pane, param) {
+ var
+ cb = action +","+ pane +","+ (param ? 1 : 0)
+ , cP, cbPane
+ $.each(c.borderPanes.split(","), function (i,p) {
+ if (c[p].isMoving) {
+ bindCallback(p); // TRY to bind a callback
+ return false; // BREAK
+ function bindCallback (p, test) {
+ cP = c[p];
+ if (!cP.doCallback) {
+ cP.doCallback = true;
+ cP.callback = cb;
+ else { // try to 'chain' this callback
+ cpPane = cP.callback.split(",")[1]; // 2nd param is 'pane'
+ if (cpPane != p && cpPane != pane) // callback target NOT 'itself' and NOT 'this pane'
+ bindCallback (cpPane, true); // RECURSE
+ * execFlowCallback
+ * RUN the INTERNAL callback for this pane - if one exists
+ var execFlowCallback = function (pane) {
+ var cP = c[pane];
+ // RESET flow-control flaGs
+ c.isLayoutBusy = false;
+ delete cP.isMoving;
+ if (!cP.doCallback || !cP.callback) return;
+ cP.doCallback = false; // RESET logic flag
+ // EXECUTE the callback
+ var
+ cb = cP.callback.split(",")
+ , param = (cb[2] > 0 ? true : false)
+ if (cb[0] == "open")
+ open( cb[1], param );
+ else if (cb[0] == "close")
+ close( cb[1], param );
+ if (!cP.doCallback) cP.callback = null; // RESET - unless callback above enabled it again!
+ * execUserCallback
+ * Executes a Callback function after a trigger event, like resize, open or close
+ * @param String pane This is passed only so we can pass the 'pane object' to the callback
+ * @param String v_fn Accepts a function name, OR a comma-delimited array: [0]=function name, [1]=argument
+ var execUserCallback = function (pane, v_fn) {
+ if (!v_fn) return;
+ var fn;
+ try {
+ if (typeof v_fn == "function")
+ fn = v_fn;
+ else if (typeof v_fn != "string")
+ return;
+ else if (v_fn.indexOf(",") > 0) {
+ // function name cannot contain a comma, so must be a function name AND a 'name' parameter
+ var
+ args = v_fn.split(",")
+ , fn = eval(args[0])
+ if (typeof fn=="function" && args.length > 1)
+ return fn(args[1]); // pass the argument parsed from 'list'
+ else // just the name of an external function?
+ fn = eval(v_fn);
+ if (typeof fn=="function")
+ // pass data: pane-name, pane-element, pane-state, pane-options, and layout-name
+ return fn( pane, $Ps[pane], $.extend({},state[pane]), $.extend({},options[pane]), options.name );
+ catch (ex) {}
+ * cssNum
+ * Returns the 'current CSS value' for an element - returns 0 if property does not exist
+ * @callers Called by many methods
+ * @param jQuery $Elem Must pass a jQuery object - first element is processed
+ * @param String property The name of the CSS property, eg: top, width, etc.
+ * @returns Variant Usually is used to get an integer value for position (top, left) or size (height, width)
+ var cssNum = function ($E, prop) {
+ var
+ val = 0
+ , hidden = false
+ , visibility = ""
+ if (!$.browser.msie) { // IE CAN read dimensions of 'hidden' elements - FF CANNOT
+ if ($.curCSS($E[0], "display", true) == "none") {
+ hidden = true;
+ visibility = $.curCSS($E[0], "visibility", true); // SAVE current setting
+ $E.css({ display: "block", visibility: "hidden" }); // show element 'invisibly' so we can measure it
+ val = parseInt($.curCSS($E[0], prop, true), 10) || 0;
+ if (hidden) { // WAS hidden, so put back the way it was
+ $E.css({ display: "none" });
+ if (visibility && visibility != "hidden")
+ $E.css({ visibility: visibility }); // reset 'visibility'
+ return val;
+ * cssW / cssH / cssSize
+ * Contains logic to check boxModel & browser, and return the correct width/height for the current browser/doctype
+ * @callers initPanes(), sizeMidPanes(), initHandles(), sizeHandles()
+ * @param Variant elem Can accept a 'pane' (east, west, etc) OR a DOM object OR a jQuery object
+ * @param Integer outerWidth/outerHeight (optional) Can pass a width, allowing calculations BEFORE element is resized
+ * @returns Integer Returns the innerHeight of the elem by subtracting padding and borders
+ * @TODO May need to add additional logic to handle more browser/doctype variations?
+ var cssW = function (e, outerWidth) {
+ var $E;
+ if (isStr(e)) {
+ e = str(e);
+ $E = $Ps[e];
+ else
+ $E = $(e);
+ // a 'calculated' outerHeight can be passed so borders and/or padding are removed if needed
+ if (outerWidth <= 0)
+ return 0;
+ else if (!(outerWidth>0))
+ outerWidth = isStr(e) ? getPaneSize(e) : $E.outerWidth();
+ if (!$.boxModel)
+ return outerWidth;
+ else // strip border and padding size from outerWidth to get CSS Width
+ return outerWidth
+ - cssNum($E, "paddingLeft")
+ - cssNum($E, "paddingRight")
+ - ($.curCSS($E[0], "borderLeftStyle", true) == "none" ? 0 : cssNum($E, "borderLeftWidth"))
+ - ($.curCSS($E[0], "borderRightStyle", true) == "none" ? 0 : cssNum($E, "borderRightWidth"))
+ var cssH = function (e, outerHeight) {
+ var $E;
+ if (isStr(e)) {
+ e = str(e);
+ $E = $Ps[e];
+ else
+ $E = $(e);
+ if (outerHeight <= 0)
+ return 0;
+ else if (!(outerHeight>0))
+ outerHeight = (isStr(e)) ? getPaneSize(e) : $E.outerHeight();
+ if (!$.boxModel)
+ return outerHeight;
+ else // strip border and padding size from outerHeight to get CSS Height
+ - cssNum($E, "paddingTop")
+ - cssNum($E, "paddingBottom")
+ - ($.curCSS($E[0], "borderTopStyle", true) == "none" ? 0 : cssNum($E, "borderTopWidth"))
+ - ($.curCSS($E[0], "borderBottomStyle", true) == "none" ? 0 : cssNum($E, "borderBottomWidth"))
+ var cssSize = function (pane, outerSize) {
+ if (c[pane].dir=="horz") // pane = north or south
+ return cssH(pane, outerSize);
+ else // pane = east or west
+ return cssW(pane, outerSize);
+ * getPaneSize
+ * Calculates the current 'size' (width or height) of a border-pane - optionally with 'pane spacing' added
+ * @returns Integer Returns EITHER Width for east/west panes OR Height for north/south panes - adjusted for boxModel & browser
+ var getPaneSize = function (pane, inclSpace) {
+ var
+ $P = $Ps[pane]
+ , o = options[pane]
+ , s = state[pane]
+ , oSp = (inclSpace ? o.spacing_open : 0)
+ , cSp = (inclSpace ? o.spacing_closed : 0)
+ if (!$P || s.isHidden)
+ return 0;
+ else if (s.isClosed || (s.isSliding && inclSpace))
+ return cSp;
+ else if (c[pane].dir == "horz")
+ return $P.outerHeight() + oSp;
+ else // dir == "vert"
+ return $P.outerWidth() + oSp;
+ var setPaneMinMaxSizes = function (pane) {
+ var
+ d = cDims
+ , edge = c[pane].edge
+ , dir = c[pane].dir
+ , s = state[pane]
+ , $P = $Ps[pane]
+ , $altPane = $Ps[ altSide[pane] ]
+ , paneSpacing = o.spacing_open
+ , altPaneSpacing = options[ altSide[pane] ].spacing_open
+ , altPaneSize = (!$altPane ? 0 : (dir=="horz" ? $altPane.outerHeight() : $altPane.outerWidth()))
+ , containerSize = (dir=="horz" ? d.innerHeight : d.innerWidth)
+ // limitSize prevents this pane from 'overlapping' opposite pane - even if opposite pane is currently closed
+ , limitSize = containerSize - paneSpacing - altPaneSize - altPaneSpacing
+ , minSize = s.minSize || 0
+ , maxSize = Math.min(s.maxSize || 9999, limitSize)
+ , minPos, maxPos // used to set resizing limits
+ switch (pane) {
+ case "north": minPos = d.offsetTop + minSize;
+ maxPos = d.offsetTop + maxSize;
+ break;
+ case "west": minPos = d.offsetLeft + minSize;
+ maxPos = d.offsetLeft + maxSize;
+ break;
+ case "south": minPos = d.offsetTop + d.innerHeight - maxSize;
+ maxPos = d.offsetTop + d.innerHeight - minSize;
+ break;
+ case "east": minPos = d.offsetLeft + d.innerWidth - maxSize;
+ maxPos = d.offsetLeft + d.innerWidth - minSize;
+ break;
+ // save data to pane-state
+ $.extend(s, { minSize: minSize, maxSize: maxSize, minPosition: minPos, maxPosition: maxPos });
+ * getPaneDims
+ * Returns data for setting the size/position of center pane. Date is also used to set Height for east/west panes
+ * @returns JSON Returns a hash of all dimensions: top, bottom, left, right, (outer) width and (outer) height
+ var getPaneDims = function () {
+ var d = {
+ top: getPaneSize("north", true) // true = include 'spacing' value for p
+ , bottom: getPaneSize("south", true)
+ , left: getPaneSize("west", true)
+ , right: getPaneSize("east", true)
+ , width: 0
+ , height: 0
+ with (d) {
+ width = cDims.innerWidth - left - right;
+ height = cDims.innerHeight - bottom - top;
+ // now add the 'container border/padding' to get final positions - relative to the container
+ top += cDims.top;
+ bottom += cDims.bottom;
+ left += cDims.left;
+ right += cDims.right;
+ return d;
+ * getElemDims
+ * Returns data for setting size of an element (container or a pane).
+ * @callers create(), onWindowResize() for container, plus others for pane
+ * @returns JSON Returns a hash of all dimensions: top, bottom, left, right, outerWidth, innerHeight, etc
+ var getElemDims = function ($E) {
+ var
+ d = {} // dimensions hash
+ , e, b, p // edge, border, padding
+ $.each("Left,Right,Top,Bottom".split(","), function () {
+ e = str(this);
+ b = d["border" +e] = cssNum($E, "border"+e+"Width");
+ p = d["padding"+e] = cssNum($E, "padding"+e);
+ d["offset" +e] = b + p; // total offset of content from outer edge
+ // if BOX MODEL, then 'position' = PADDING (ignore borderWidth)
+ if ($E == $Container)
+ d[e.toLowerCase()] = ($.boxModel ? p : 0);
+ d.innerWidth = d.outerWidth = $E.outerWidth();
+ d.innerHeight = d.outerHeight = $E.outerHeight();
+ if ($.boxModel) {
+ d.innerWidth -= (d.offsetLeft + d.offsetRight);
+ d.innerHeight -= (d.offsetTop + d.offsetBottom);
+ return d;
+ var setTimer = function (pane, action, fn, ms) {
+ var
+ Layout = window.layout = window.layout || {}
+ , Timers = Layout.timers = Layout.timers || {}
+ , name = "layout_"+ state.id +"_"+ pane +"_"+ action // UNIQUE NAME for every layout-pane-action
+ if (Timers[name]) return; // timer already set!
+ else Timers[name] = setTimeout(fn, ms);
+ var clearTimer = function (pane, action) {
+ var
+ if (Timers[name]) {
+ clearTimeout( Timers[name] );
+ delete Timers[name];
+ return true;
+ else
+ return false;
+ * INITIALIZATION METHODS
+ * create
+ * Initialize the layout - called automatically whenever an instance of layout is created
+ * @callers NEVER explicity called
+ * @returns An object pointer to the instance created
+ var create = function () {
+ // initialize config/options
+ initOptions();
+ // initialize all objects
+ initContainer(); // set CSS as needed and init state.container dimensions
+ initPanes(); // size & position all panes
+ initHandles(); // create and position all resize bars & togglers buttons
+ initResizable(); // activate resizing on all panes where resizable=true
+ sizeContent("all"); // AFTER panes & handles have been initialized, size 'content' divs
+ if (options.scrollToBookmarkOnLoad)
+ with (self.location) if (hash) replace( hash ); // scrollTo Bookmark
+ // bind hotkey function - keyDown - if required
+ initHotkeys();
+ // bind resizeAll() for 'this layout instance' to window.resize event
+ $(window).resize(function () {
+ var timerID = "timerLayout_"+state.id;
+ if (window[timerID]) clearTimeout(window[timerID]);
+ window[timerID] = null;
+ if (true || $.browser.msie) // use a delay for IE because the resize event fires repeatly
+ window[timerID] = setTimeout(resizeAll, 100);
+ else // most other browsers have a built-in delay before firing the resize event
+ resizeAll(); // resize all layout elements NOW!
+ * initContainer
+ * Validate and initialize container CSS and events
+ var initContainer = function () {
+ try { // format html/body if this is a full page layout
+ if ($Container[0].tagName == "BODY") {
+ $("html").css({
+ height: "100%"
+ $("body").css({
+ position: "relative"
+ , height: "100%"
+ , margin: 0
+ , padding: 0 // TODO: test whether body-padding could be handled?
+ , border: "none" // a body-border creates problems because it cannot be measured!
+ else { // set required CSS - overflow and position
+ var
+ CSS = { overflow: "hidden" } // make sure container will not 'scroll'
+ , p = $Container.css("position")
+ , h = $Container.css("height")
+ // if this is a NESTED layout, then outer-pane ALREADY has position and height
+ if (!$Container.hasClass("ui-layout-pane")) {
+ if (!p || "fixed,absolute,relative".indexOf(p) < 0)
+ CSS.position = "relative"; // container MUST have a 'position'
+ if (!h || h=="auto")
+ CSS.height = "100%"; // container MUST have a 'height'
+ $Container.css( CSS );
+ } catch (ex) {}
+ // get layout-container dimensions (updated when necessary)
+ cDims = state.container = getElemDims( $Container ); // update data-pointer too
+ * initHotkeys
+ * Bind layout hotkeys - if options enabled
+ var initHotkeys = function () {
+ // bind keyDown to capture hotkeys, if option enabled for ANY pane
+ $.each(c.borderPanes.split(","), function (i,pane) {
+ var o = options[pane];
+ if (o.enableCursorHotkey || o.customHotkey) {
+ $(document).keydown( keyDown ); // only need to bind this ONCE
+ return false; // BREAK - binding was done
+ * initOptions
+ * Build final CONFIG and OPTIONS data
+ var initOptions = function () {
+ // simplify logic by making sure passed 'opts' var has basic keys
+ opts = transformData( opts );
+ // update default effects, if case user passed key
+ if (opts.effects) {
+ $.extend( effects, opts.effects );
+ delete opts.effects;
+ // see if any 'global options' were specified
+ $.each("name,scrollToBookmarkOnLoad".split(","), function (idx,key) {
+ if (opts[key] !== undefined)
+ options[key] = opts[key];
+ else if (opts.defaults[key] !== undefined) {
+ options[key] = opts.defaults[key];
+ delete opts.defaults[key];
+ // remove any 'defaults' that MUST be set 'per-pane'
+ $.each("paneSelector,resizerCursor,customHotkey".split(","),
+ function (idx,key) { delete opts.defaults[key]; } // is OK if key does not exist
+ // now update options.defaults
+ $.extend( options.defaults, opts.defaults );
+ // make sure required sub-keys exist
+ //if (typeof options.defaults.fxSettings != "object") options.defaults.fxSettings = {};
+ // merge all config & options for the 'center' pane
+ c.center = $.extend( true, {}, c.defaults, c.center );
+ $.extend( options.center, opts.center );
+ // Most 'default options' do not apply to 'center', so add only those that DO
+ var o_Center = $.extend( true, {}, options.defaults, opts.defaults, options.center ); // TEMP data
+ $.each("paneClass,contentSelector,contentIgnoreSelector,applyDefaultStyles,showOverflowOnHover".split(","),
+ function (idx,key) { options.center[key] = o_Center[key]; }
+ var defs = options.defaults;
+ // create a COMPLETE set of options for EACH border-pane
+ $.each(c.borderPanes.split(","), function(i,pane) {
+ // apply 'pane-defaults' to CONFIG.PANE
+ c[pane] = $.extend( true, {}, c.defaults, c[pane] );
+ // apply 'pane-defaults' + user-options to OPTIONS.PANE
+ o = options[pane] = $.extend( true, {}, options.defaults, options[pane], opts.defaults, opts[pane] );
+ // make sure we have base-classes
+ if (!o.paneClass) o.paneClass = defaults.paneClass;
+ if (!o.resizerClass) o.resizerClass = defaults.resizerClass;
+ if (!o.togglerClass) o.togglerClass = defaults.togglerClass;
+ // create FINAL fx options for each pane, ie: options.PANE.fxName/fxSpeed/fxSettings[_open|_close]
+ $.each(["_open","_close",""], function (i,n) {
+ var
+ sName = "fxName"+n
+ , sSpeed = "fxSpeed"+n
+ , sSettings = "fxSettings"+n
+ // recalculate fxName according to specificity rules
+ o[sName] =
+ opts[pane][sName] // opts.west.fxName_open
+ || opts[pane].fxName // opts.west.fxName
+ || opts.defaults[sName] // opts.defaults.fxName_open
+ || opts.defaults.fxName // opts.defaults.fxName
+ || o[sName] // options.west.fxName_open
+ || o.fxName // options.west.fxName
+ || defs[sName] // options.defaults.fxName_open
+ || defs.fxName // options.defaults.fxName
+ || "none"
+ // validate fxName to be sure is a valid effect
+ var fxName = o[sName];
+ if (fxName == "none" || !$.effects || !$.effects[fxName] || (!effects[fxName] && !o[sSettings] && !o.fxSettings))
+ fxName = o[sName] = "none"; // effect not loaded, OR undefined FX AND fxSettings not passed
+ // set vars for effects subkeys to simplify logic
+ var
+ fx = effects[fxName] || {} // effects.slide
+ , fx_all = fx.all || {} // effects.slide.all
+ , fx_pane = fx[pane] || {} // effects.slide.west
+ // RECREATE the fxSettings[_open|_close] keys using specificity rules
+ o[sSettings] = $.extend(
+ , fx_all // effects.slide.all
+ , fx_pane // effects.slide.west
+ , defs.fxSettings || {} // options.defaults.fxSettings
+ , defs[sSettings] || {} // options.defaults.fxSettings_open
+ , o.fxSettings // options.west.fxSettings
+ , o[sSettings] // options.west.fxSettings_open
+ , opts.defaults.fxSettings // opts.defaults.fxSettings
+ , opts.defaults[sSettings] || {} // opts.defaults.fxSettings_open
+ , opts[pane].fxSettings // opts.west.fxSettings
+ , opts[pane][sSettings] || {} // opts.west.fxSettings_open
+ // recalculate fxSpeed according to specificity rules
+ o[sSpeed] =
+ opts[pane][sSpeed] // opts.west.fxSpeed_open
+ || opts[pane].fxSpeed // opts.west.fxSpeed (pane-default)
+ || opts.defaults[sSpeed] // opts.defaults.fxSpeed_open
+ || opts.defaults.fxSpeed // opts.defaults.fxSpeed
+ || o[sSpeed] // options.west.fxSpeed_open
+ || o[sSettings].duration // options.west.fxSettings_open.duration
+ || o.fxSpeed // options.west.fxSpeed
+ || o.fxSettings.duration // options.west.fxSettings.duration
+ || defs.fxSpeed // options.defaults.fxSpeed
+ || defs.fxSettings.duration// options.defaults.fxSettings.duration
+ || fx_pane.duration // effects.slide.west.duration
+ || fx_all.duration // effects.slide.all.duration
+ || "normal" // DEFAULT
+ // DEBUG: if (pane=="east") debugData( $.extend({}, {speed: o[sSpeed], fxSettings_duration: o[sSettings].duration}, o[sSettings]), pane+"."+sName+" = "+fxName );
+ * initPanes
+ * Initialize module objects, styling, size and position for all panes
+ var initPanes = function () {
+ // NOTE: do north & south FIRST so we can measure their height - do center LAST
+ $.each(c.allPanes.split(","), function() {
+ var
+ pane = str(this)
+ , s = state[pane]
+ , fx = s.fx
+ // if o.size is not > 0, then we will use MEASURE the pane and use that as it's 'size'
+ , size = o.size=="auto" || isNaN(o.size) ? 0 : o.size
+ , minSize = o.minSize || 1
+ , maxSize = o.maxSize || 9999
+ , spacing = o.spacing_open || 0
+ , sel = o.paneSelector
+ , isIE6 = ($.browser.msie && $.browser.version < 7)
+ , CSS = {}
+ , $P, $C
+ $Cs[pane] = false; // init
+ if (sel.substr(0,1)==="#") // ID selector
+ // NOTE: elements selected 'by ID' DO NOT have to be 'children'
+ $P = $Ps[pane] = $Container.find(sel+":first");
+ else { // class or other selector
+ $P = $Ps[pane] = $Container.children(sel+":first");
+ // look for the pane nested inside a 'form' element
+ if (!$P.length) $P = $Ps[pane] = $Container.children("form:first").children(sel+":first");
+ if (!$P.length) {
+ $Ps[pane] = false; // logic
+ return true; // SKIP to next
+ // add basic classes & attributes
+ $P
+ .attr("pane", pane) // add pane-identifier
+ .addClass( o.paneClass +" "+ o.paneClass+"-"+pane ) // default = "ui-layout-pane ui-layout-pane-west" - may be a dupe of 'paneSelector'
+ // init pane-logic vars, etc.
+ if (pane != "center") {
+ s.isClosed = false; // true = pane is closed
+ s.isSliding = false; // true = pane is currently open by 'sliding' over adjacent panes
+ s.isResizing= false; // true = pane is in process of being resized
+ s.isHidden = false; // true = pane is hidden - no spacing, resizer or toggler is visible!
+ s.noRoom = false; // true = pane 'automatically' hidden due to insufficient room - will unhide automatically
+ // create special keys for internal use
+ c[pane].pins = []; // used to track and sync 'pin-buttons' for border-panes
+ CSS = $.extend({ visibility: "visible", display: "block" }, c.defaults.cssReq, c[pane].cssReq );
+ if (o.applyDefaultStyles) $.extend( CSS, c.defaults.cssDef, c[pane].cssDef ); // cosmetic defaults
+ $P.css(CSS); // add base-css BEFORE 'measuring' to calc size & position
+ CSS = {}; // reset var
+ // set css-position to account for container borders & padding
+ switch (pane) {
+ case "north": CSS.top = cDims.top;
+ CSS.left = cDims.left;
+ CSS.right = cDims.right;
+ break;
+ case "south": CSS.bottom = cDims.bottom;
+ break;
+ case "west": CSS.left = cDims.left; // top, bottom & height set by sizeMidPanes()
+ break;
+ case "east": CSS.right = cDims.right; // ditto
+ break;
+ case "center": // top, left, width & height set by sizeMidPanes()
+ if (dir == "horz") { // north or south pane
+ if (size === 0 || size == "auto") {
+ $P.css({ height: "auto" });
+ size = $P.outerHeight();
+ size = max(size, minSize);
+ size = min(size, maxSize);
+ size = min(size, cDims.innerHeight - spacing);
+ CSS.height = max(1, cssH(pane, size));
+ s.size = size; // update state
+ // make sure minSize is sufficient to avoid errors
+ s.maxSize = maxSize; // init value
+ s.minSize = max(minSize, size - CSS.height + 1); // = pane.outerHeight when css.height = 1px
+ // handle IE6
+ //if (isIE6) CSS.width = cssW($P, cDims.innerWidth);
+ $P.css(CSS); // apply size & position
+ else if (dir == "vert") { // east or west pane
+ $P.css({ width: "auto", float: "left" }); // float = FORCE pane to auto-size
+ size = $P.outerWidth();
+ $P.css({ float: "none" }); // RESET
+ size = min(size, cDims.innerWidth - spacing);
+ CSS.width = max(1, cssW(pane, size));
+ s.minSize = max(minSize, size - CSS.width + 1); // = pane.outerWidth when css.width = 1px
+ $P.css(CSS); // apply size - top, bottom & height set by sizeMidPanes
+ sizeMidPanes(pane, null, true); // true = onInit
+ else if (pane == "center") {
+ $P.css(CSS); // top, left, width & height set by sizeMidPanes...
+ sizeMidPanes("center", null, true); // true = onInit
+ // close or hide the pane if specified in settings
+ if (o.initClosed && o.closable) {
+ $P.hide().addClass("closed");
+ s.isClosed = true;
+ else if (o.initHidden || o.initClosed) {
+ hide(pane, true); // will be completely invisible - no resizer or spacing
+ s.isHidden = true;
+ else
+ $P.addClass("open");
+ // check option for auto-handling of pop-ups & drop-downs
+ if (o.showOverflowOnHover)
+ $P.hover( allowOverflow, resetOverflow );
+ * see if this pane has a 'content element' that we need to auto-size
+ if (o.contentSelector) {
+ $C = $Cs[pane] = $P.children(o.contentSelector+":first"); // match 1-element only
+ if (!$C.length) {
+ $C.css( c.content.cssReq );
+ if (o.applyDefaultStyles) $C.css( c.content.cssDef ); // cosmetic defaults
+ // NO PANE-SCROLLING when there is a content-div
+ $P.css({ overflow: "hidden" });
+ * initHandles
+ * Initialize module objects, styling, size and position for all resize bars and toggler buttons
+ var initHandles = function () {
+ // create toggler DIVs for each pane, and set object pointers for them, eg: $R.north = north toggler DIV
+ $.each(c.borderPanes.split(","), function() {
+ var
+ pane = str(this)
+ , s = state[pane]
+ , rClass = o.resizerClass
+ , tClass = o.togglerClass
+ , $P = $Ps[pane]
+ $Rs[pane] = false; // INIT
+ $Ts[pane] = false;
+ if (!$P || (!o.closable && !o.resizable)) return; // pane does not exist - skip
+ var
+ edge = c[pane].edge
+ , isOpen = $P.is(":visible")
+ , spacing = (isOpen ? o.spacing_open : o.spacing_closed)
+ , _pane = "-"+ pane // used for classNames
+ , _state = (isOpen ? "-open" : "-closed") // used for classNames
+ , $R, $T
+ // INIT RESIZER BAR
+ $R = $Rs[pane] = $("<span></span>");
+ if (isOpen && o.resizable)
+ ; // this is handled by initResizable
+ else if (!isOpen && o.slidable)
+ $R.attr("title", o.sliderTip).css("cursor", o.sliderCursor);
+ $R
+ // if paneSelector is an ID, then create a matching ID for the resizer, eg: "#paneLeft" => "paneLeft-resizer"
+ .attr("id", (o.paneSelector.substr(0,1)=="#" ? o.paneSelector.substr(1) + "-resizer" : ""))
+ .attr("resizer", pane) // so we can read this from the resizer
+ .css(c.resizers.cssReq) // add base/required styles
+ // POSITION of resizer bar - allow for container border & padding
+ .css(edge, cDims[edge] + getPaneSize(pane))
+ // ADD CLASSNAMES - eg: class="resizer resizer-west resizer-open"
+ .addClass( rClass +" "+ rClass+_pane +" "+ rClass+_state +" "+ rClass+_pane+_state )
+ .appendTo($Container) // append DIV to container
+ // ADD VISUAL STYLES
+ $R.css(c.resizers.cssDef);
+ if (o.closable) {
+ // INIT COLLAPSER BUTTON
+ $T = $Ts[pane] = $("<div></div>");
+ $T
+ // if paneSelector is an ID, then create a matching ID for the resizer, eg: "#paneLeft" => "paneLeft-toggler"
+ .attr("id", (o.paneSelector.substr(0,1)=="#" ? o.paneSelector.substr(1) + "-toggler" : ""))
+ .css(c.togglers.cssReq) // add base/required styles
+ .attr("title", (isOpen ? o.togglerTip_open : o.togglerTip_closed))
+ .click(function(evt){ toggle(pane); evt.stopPropagation(); })
+ .mouseover(function(evt){ evt.stopPropagation(); }) // prevent resizer event
+ // ADD CLASSNAMES - eg: class="toggler toggler-west toggler-west-open"
+ .addClass( tClass +" "+ tClass+_pane +" "+ tClass+_state +" "+ tClass+_pane+_state )
+ .appendTo($R) // append SPAN to resizer DIV
+ // ADD INNER-SPANS TO TOGGLER
+ if (o.togglerContent_open) // ui-layout-open
+ $("<span>"+ o.togglerContent_open +"</span>")
+ .addClass("content content-open")
+ .css("display", s.isClosed ? "none" : "block")
+ .appendTo( $T )
+ if (o.togglerContent_closed) // ui-layout-closed
+ $("<span>"+ o.togglerContent_closed +"</span>")
+ .addClass("content content-closed")
+ .css("display", s.isClosed ? "block" : "none")
+ .appendTo( $T )
+ // ADD BASIC VISUAL STYLES
+ $T.css(c.togglers.cssDef);
+ if (!isOpen) bindStartSlidingEvent(pane, true); // will enable if state.PANE.isSliding = true
+ // SET ALL HANDLE SIZES & LENGTHS
+ sizeHandles("all", true); // true = onInit
+ * initResizable
+ * Add resize-bars to all panes that specify it in options
+ * @dependancies $.fn.resizable - will abort if not found
+ var initResizable = function () {
+ var
+ draggingAvailable = (typeof $.fn.draggable == "function")
+ , minPosition, maxPosition, edge // set in start()
+ var
+ pane = str(this)
+ , s = state[pane]
+ if (!draggingAvailable || !$Ps[pane] || !o.resizable) {
+ o.resizable = false;
+ return true; // skip to next
+ var
+ rClass = o.resizerClass
+ // 'drag' classes are applied to the ORIGINAL resizer-bar while dragging is in process
+ , dragClass = rClass+"-drag" // resizer-drag
+ , dragPaneClass = rClass+"-"+pane+"-drag" // resizer-north-drag
+ // 'dragging' class is applied to the CLONED resizer-bar while it is being dragged
+ , draggingClass = rClass+"-dragging" // resizer-dragging
+ , draggingPaneClass = rClass+"-"+pane+"-dragging" // resizer-north-dragging
+ , draggingClassSet = false // logic var
+ , $P = $Ps[pane]
+ , $R = $Rs[pane]
+ if (!s.isClosed)
+ $R
+ .attr("title", o.resizerTip)
+ .css("cursor", o.resizerCursor) // n-resize, s-resize, etc
+ $R.draggable({
+ containment: $Container[0] // limit resizing to layout container
+ , axis: (c[pane].dir=="horz" ? "y" : "x") // limit resizing to horz or vert axis
+ , delay: 200
+ , distance: 1
+ // basic format for helper - style it using class: .ui-draggable-dragging
+ , helper: "clone"
+ , opacity: o.resizerDragOpacity
+ //, iframeFix: o.draggableIframeFix // TODO: consider using when bug is fixed
+ , zIndex: c.zIndex.resizing
+ , start: function (e, ui) {
+ // onresize_start callback - will CANCEL hide if returns false
+ // TODO: CONFIRM that dragging can be cancelled like this???
+ if (false === execUserCallback(pane, o.onresize_start)) return false;
+ s.isResizing = true; // prevent pane from closing while resizing
+ clearTimer(pane, "closeSlider"); // just in case already triggered
+ $R.addClass( dragClass +" "+ dragPaneClass ); // add drag classes
+ draggingClassSet = false; // reset logic var - see drag()
+ // SET RESIZING LIMITS - used in drag()
+ var resizerWidth = (pane=="east" || pane=="south" ? o.spacing_open : 0);
+ setPaneMinMaxSizes(pane); // update pane-state
+ s.minPosition -= resizerWidth;
+ s.maxPosition -= resizerWidth;
+ edge = (c[pane].dir=="horz" ? "top" : "left");
+ // MASK PANES WITH IFRAMES OR OTHER TROUBLESOME ELEMENTS
+ $(o.maskIframesOnResize === true ? "iframe" : o.maskIframesOnResize).each(function() {
+ $('<div class="ui-layout-mask"/>')
+ .css({
+ background: "#fff"
+ , opacity: "0.001"
+ , zIndex: 9
+ , position: "absolute"
+ , width: this.offsetWidth+"px"
+ , height: this.offsetHeight+"px"
+ .css($(this).offset()) // top & left
+ .appendTo(this.parentNode) // put div INSIDE pane to avoid zIndex issues
+ , drag: function (e, ui) {
+ if (!draggingClassSet) { // can only add classes after clone has been added to the DOM
+ $(".ui-draggable-dragging")
+ .addClass( draggingClass +" "+ draggingPaneClass ) // add dragging classes
+ .children().css("visibility","hidden") // hide toggler inside dragged resizer-bar
+ draggingClassSet = true;
+ // draggable bug!? RE-SET zIndex to prevent E/W resize-bar showing through N/S pane!
+ if (s.isSliding) $Ps[pane].css("zIndex", c.zIndex.sliding);
+ // CONTAIN RESIZER-BAR TO RESIZING LIMITS
+ if (ui.position[edge] < s.minPosition) ui.position[edge] = s.minPosition;
+ else if (ui.position[edge] > s.maxPosition) ui.position[edge] = s.maxPosition;
+ , stop: function (e, ui) {
+ var
+ dragPos = ui.position
+ , resizerPos
+ , newSize
+ $R.removeClass( dragClass +" "+ dragPaneClass ); // remove drag classes
+ switch (pane) {
+ case "north": resizerPos = dragPos.top; break;
+ case "west": resizerPos = dragPos.left; break;
+ case "south": resizerPos = cDims.outerHeight - dragPos.top - $R.outerHeight(); break;
+ case "east": resizerPos = cDims.outerWidth - dragPos.left - $R.outerWidth(); break;
+ // remove container margin from resizer position to get the pane size
+ newSize = resizerPos - cDims[ c[pane].edge ];
+ sizePane(pane, newSize);
+ // UN-MASK PANES MASKED IN drag.start
+ $("div.ui-layout-mask").remove(); // Remove iframe masks
+ s.isResizing = false;
+ * ACTION METHODS
+ * hide / show
+ * Completely 'hides' a pane, including its spacing - as if it does not exist
+ * The pane is not actually 'removed' from the source, so can use 'show' to un-hide it
+ * @param String pane The pane being hidden, ie: north, south, east, or west
+ var hide = function (pane, onInit) {
+ var
+ o = options[pane]
+ , s = state[pane]
+ , $P = $Ps[pane]
+ , $R = $Rs[pane]
+ if (!$P || s.isHidden) return; // pane does not exist OR is already hidden
+ // onhide_start callback - will CANCEL hide if returns false
+ if (false === execUserCallback(pane, o.onhide_start)) return;
+ s.isSliding = false; // just in case
+ // now hide the elements
+ if ($R) $R.hide(); // hide resizer-bar
+ if (onInit || s.isClosed) {
+ s.isClosed = true; // to trigger open-animation on show()
+ $P.hide(); // no animation when loading page
+ sizeMidPanes(c[pane].dir == "horz" ? "all" : "center");
+ execUserCallback(pane, o.onhide_end || o.onhide);
+ else {
+ s.isHiding = true; // used by onclose
+ close(pane, false); // adjust all panes to fit
+ //s.isHidden = true; - will be set by close - if not cancelled
+ var show = function (pane, openPane) {
+ var
+ o = options[pane]
+ , s = state[pane]
+ , $P = $Ps[pane]
+ , $R = $Rs[pane]
+ if (!$P || !s.isHidden) return; // pane does not exist OR is not hidden
+ if (false === execUserCallback(pane, o.onshow_start)) return;
+ s.isShowing = true; // used by onopen/onclose
+ //s.isHidden = false; - will be set by open/close - if not cancelled
+ // now show the elements
+ if ($R && o.spacing_open > 0) $R.show();
+ if (openPane === false)
+ close(pane, true); // true = force
+ else
+ open(pane); // adjust all panes to fit
+ * toggle
+ * Toggles a pane open/closed by calling either open or close
+ * @param String pane The pane being toggled, ie: north, south, east, or west
+ var toggle = function (pane) {
+ var s = state[pane];
+ if (s.isHidden)
+ show(pane); // will call 'open' after unhiding it
+ else if (s.isClosed)
+ open(pane);
+ else
+ close(pane);
+ * close
+ * Close the specified pane (animation optional), and resize all other panes as needed
+ * @param String pane The pane being closed, ie: north, south, east, or west
+ var close = function (pane, force, noAnimation) {
+ var
+ $P = $Ps[pane]
+ , $R = $Rs[pane]
+ , $T = $Ts[pane]
+ , s = state[pane]
+ , doFX = !noAnimation && !s.isClosed && (o.fxName_close != "none")
+ , _open = "-open"
+ , _sliding= "-sliding"
+ , _closed = "-closed"
+ // transfer logic vars to temp vars
+ , isShowing = s.isShowing
+ , isHiding = s.isHiding
+ // now clear the logic vars
+ delete s.isShowing;
+ delete s.isHiding;
+ if (!$P || (!o.resizable && !o.closable)) return; // invalid request
+ else if (!force && s.isClosed && !isShowing) return; // already closed
+ if (c.isLayoutBusy) { // layout is 'busy' - probably with an animation
+ setFlowCallback("close", pane, force); // set a callback for this action, if possible
+ return; // ABORT
+ // onclose_start callback - will CANCEL hide if returns false
+ // SKIP if just 'showing' a hidden pane as 'closed'
+ if (!isShowing && false === execUserCallback(pane, o.onclose_start)) return;
+ // SET flow-control flags
+ c[pane].isMoving = true;
+ c.isLayoutBusy = true;
+ // update isHidden BEFORE sizing panes
+ if (isHiding) s.isHidden = true;
+ else if (isShowing) s.isHidden = false;
+ // sync any 'pin buttons'
+ syncPinBtns(pane, false);
+ // resize panes adjacent to this one
+ if (!s.isSliding) sizeMidPanes(c[pane].dir == "horz" ? "all" : "center");
+ // if this pane has a resizer bar, move it now
+ if ($R) {
+ $R
+ .css(edge, cDims[edge]) // move the resizer bar
+ .removeClass( rClass+_open +" "+ rClass+_pane+_open )
+ .removeClass( rClass+_sliding +" "+ rClass+_pane+_sliding )
+ .addClass( rClass+_closed +" "+ rClass+_pane+_closed )
+ // DISABLE 'resizing' when closed - do this BEFORE bindStartSlidingEvent
+ if (o.resizable)
+ $R
+ .draggable("disable")
+ .css("cursor", "default")
+ .attr("title","")
+ // if pane has a toggler button, adjust that too
+ if ($T) {
+ $T
+ .removeClass( tClass+_open +" "+ tClass+_pane+_open )
+ .addClass( tClass+_closed +" "+ tClass+_pane+_closed )
+ .attr("title", o.togglerTip_closed) // may be blank
+ sizeHandles(); // resize 'length' and position togglers for adjacent panes
+ // ANIMATE 'CLOSE' - if no animation, then was ALREADY shown above
+ if (doFX) {
+ lockPaneForFX(pane, true); // need to set left/top so animation will work
+ $P.hide( o.fxName_close, o.fxSettings_close, o.fxSpeed_close, function () {
+ lockPaneForFX(pane, false); // undo
+ if (!s.isClosed) return; // pane was opened before animation finished!
+ close_2();
+ else {
+ $P.hide(); // just hide pane NOW
+ close_2();
+ // SUBROUTINE
+ function close_2 () {
+ bindStartSlidingEvent(pane, true); // will enable if state.PANE.isSliding = true
+ // onclose callback - UNLESS just 'showing' a hidden pane as 'closed'
+ if (!isShowing) execUserCallback(pane, o.onclose_end || o.onclose);
+ // onhide OR onshow callback
+ if (isShowing) execUserCallback(pane, o.onshow_end || o.onshow);
+ if (isHiding) execUserCallback(pane, o.onhide_end || o.onhide);
+ // internal flow-control callback
+ execFlowCallback(pane);
+ * open
+ * Open the specified pane (animation optional), and resize all other panes as needed
+ * @param String pane The pane being opened, ie: north, south, east, or west
+ var open = function (pane, slide, noAnimation) {
+ var
+ $P = $Ps[pane]
+ , $R = $Rs[pane]
+ , $T = $Ts[pane]
+ , s = state[pane]
+ , doFX = !noAnimation && s.isClosed && (o.fxName_open != "none")
+ , _open = "-open"
+ // transfer logic var to temp var
+ else if (!s.isClosed && !s.isSliding) return; // already open
+ // pane can ALSO be unhidden by just calling show(), so handle this scenario
+ if (s.isHidden && !isShowing) {
+ show(pane, true);
+ return;
+ setFlowCallback("open", pane, slide); // set a callback for this action, if possible
+ return; // ABORT
+ // onopen_start callback - will CANCEL hide if returns false
+ if (false === execUserCallback(pane, o.onopen_start)) return;
+ // 'PIN PANE' - stop sliding
+ if (s.isSliding && !slide) // !slide = 'open pane normally' - NOT sliding
+ bindStopSlidingEvents(pane, false); // will set isSliding=false
+ if (isShowing) s.isHidden = false;
+ // Container size may have changed - shrink the pane if now 'too big'
+ if (s.size > s.maxSize) // pane is too big! resize it before opening
+ $P.css( c[pane].sizeType, max(1, cssSize(pane, s.maxSize)) );
+ bindStartSlidingEvent(pane, false); // remove trigger event from resizer-bar
+ if (doFX) { // ANIMATE
+ $P.show( o.fxName_open, o.fxSettings_open, o.fxSpeed_open, function() {
+ if (s.isClosed) return; // pane was closed before animation finished!
+ open_2(); // continue
+ else {// no animation
+ $P.show(); // just show pane and...
+ // SUBROUTINE
+ function open_2 () {
+ // NOTE: if isSliding, then other panes are NOT 'resized'
+ if (!s.isSliding) // resize all panes adjacent to this one
+ sizeMidPanes(c[pane].dir=="vert" ? "center" : "all");
+ // if this pane has a toggler, move it now
+ if ($R) {
+ $R
+ .css(edge, cDims[edge] + getPaneSize(pane)) // move the toggler
+ .removeClass( rClass+_closed +" "+ rClass+_pane+_closed )
+ .addClass( rClass+_open +" "+ rClass+_pane+_open )
+ .addClass( !s.isSliding ? "" : rClass+_sliding +" "+ rClass+_pane+_sliding )
+ if (o.resizable)
+ $R
+ .draggable("enable")
+ else
+ $R.css("cursor", "default"); // n-resize, s-resize, etc
+ // if pane also has a toggler button, adjust that too
+ if ($T) {
+ $T
+ .removeClass( tClass+_closed +" "+ tClass+_pane+_closed )
+ .addClass( tClass+_open +" "+ tClass+_pane+_open )
+ .attr("title", o.togglerTip_open) // may be blank
+ sizeHandles("all"); // resize resizer & toggler sizes for all panes
+ // resize content every time pane opens - to be sure
+ sizeContent(pane);
+ syncPinBtns(pane, !s.isSliding);
+ // onopen callback
+ execUserCallback(pane, o.onopen_end || o.onopen);
+ // onshow callback
+ * lockPaneForFX
+ * Must set left/top on East/South panes so animation will work properly
+ * @param String pane The pane to lock, 'east' or 'south' - any other is ignored!
+ * @param Boolean doLock true = set left/top, false = remove
+ var lockPaneForFX = function (pane, doLock) {
+ var $P = $Ps[pane];
+ if (doLock) {
+ $P.css({ zIndex: c.zIndex.animation }); // overlay all elements during animation
+ if (pane=="south")
+ $P.css({ top: cDims.top + cDims.innerHeight - $P.outerHeight() });
+ else if (pane=="east")
+ $P.css({ left: cDims.left + cDims.innerWidth - $P.outerWidth() });
+ else {
+ if (!state[pane].isSliding) $P.css({ zIndex: c.zIndex.pane_normal });
+ $P.css({ top: "auto" });
+ $P.css({ left: "auto" });
+ * bindStartSlidingEvent
+ * Toggle sliding functionality of a specific pane on/off by adding removing 'slide open' trigger
+ * @callers open(), close()
+ * @param String pane The pane to enable/disable, 'north', 'south', etc.
+ * @param Boolean enable Enable or Disable sliding?
+ var bindStartSlidingEvent = function (pane, enable) {
+ var
+ o = options[pane]
+ , $R = $Rs[pane]
+ , trigger = o.slideTrigger_open
+ if (!$R || !o.slidable) return;
+ // make sure we have a valid event
+ if (trigger != "click" && trigger != "dblclick" && trigger != "mouseover") trigger = "click";
+ $R
+ // add or remove trigger event
+ [enable ? "bind" : "unbind"](trigger, slideOpen)
+ // set the appropriate cursor & title/tip
+ .css("cursor", (enable ? o.sliderCursor: "default"))
+ .attr("title", (enable ? o.sliderTip : ""))
+ * bindStopSlidingEvents
+ * Add or remove 'mouseout' events to 'slide close' when pane is 'sliding' open or closed
+ * Also increases zIndex when pane is sliding open
+ * See bindStartSlidingEvent for code to control 'slide open'
+ * @callers slideOpen(), slideClosed()
+ * @param String pane The pane to process, 'north', 'south', etc.
+ * @param Boolean isOpen Is pane open or closed?
+ var bindStopSlidingEvents = function (pane, enable) {
+ var
+ o = options[pane]
+ , s = state[pane]
+ , trigger = o.slideTrigger_close
+ , action = (enable ? "bind" : "unbind") // can't make 'unbind' work! - see disabled code below
+ , $P = $Ps[pane]
+ , $R = $Rs[pane]
+ s.isSliding = enable; // logic
+ // raise z-index when sliding
+ $P.css({ zIndex: (enable ? c.zIndex.sliding : c.zIndex.pane_normal) });
+ $R.css({ zIndex: (enable ? c.zIndex.sliding : c.zIndex.resizer_normal) });
+ if (trigger != "click" && trigger != "mouseout") trigger = "mouseout";
+ // when trigger is 'mouseout', must cancel timer when mouse moves between 'pane' and 'resizer'
+ if (enable) { // BIND trigger events
+ $P.bind(trigger, slideClosed );
+ $R.bind(trigger, slideClosed );
+ if (trigger = "mouseout") {
+ $P.bind("mouseover", cancelMouseOut );
+ $R.bind("mouseover", cancelMouseOut );
+ else { // UNBIND trigger events
+ // TODO: why does unbind of a 'single function' not work reliably?
+ //$P[action](trigger, slideClosed );
+ $P.unbind(trigger);
+ $R.unbind(trigger);
+ //$P[action]("mouseover", cancelMouseOut );
+ $P.unbind("mouseover");
+ $R.unbind("mouseover");
+ // SUBROUTINE for mouseout timer clearing
+ function cancelMouseOut (evt) {
+ evt.stopPropagation();
+ var slideOpen = function () {
+ var pane = $(this).attr("resizer"); // attr added by initHandles
+ if (state[pane].isClosed) { // skip if already open!
+ bindStopSlidingEvents(pane, true); // pane is opening, so BIND trigger events to close it
+ open(pane, true); // true = slide - ie, called from here!
+ var slideClosed = function () {
+ var
+ $E = $(this)
+ , pane = $E.attr("pane") || $E.attr("resizer")
+ , s = state[pane]
+ if (s.isClosed || s.isResizing)
+ return; // skip if already closed OR in process of resizing
+ else if (o.slideTrigger_close == "click")
+ close_NOW(); // close immediately onClick
+ else // trigger = mouseout - use a delay
+ setTimer(pane, "closeSlider", close_NOW, 300); // .3 sec delay
+ // SUBROUTINE for timed close
+ function close_NOW () {
+ bindStopSlidingEvents(pane, false); // pane is being closed, so UNBIND trigger events
+ if (!s.isClosed) close(pane); // skip if already closed!
+ * sizePane
+ * @callers initResizable.stop()
+ * @param String pane The pane being resized - usually west or east, but potentially north or south
+ * @param Integer newSize The new size for this pane - will be validated
+ var sizePane = function (pane, size) {
+ // TODO: accept "auto" as size, and size-to-fit pane content
+ var
+ , s = state[pane]
+ , $P = $Ps[pane]
+ , $R = $Rs[pane]
+ // calculate 'current' min/max sizes
+ // compare/update calculated min/max to user-options
+ s.minSize = max(s.minSize, o.minSize);
+ if (o.maxSize > 0) s.maxSize = min(s.maxSize, o.maxSize);
+ // validate passed size
+ size = max(size, s.minSize);
+ size = min(size, s.maxSize);
+ // move the resizer bar and resize the pane
+ $R.css( edge, size + cDims[edge] );
+ $P.css( c[pane].sizeType, max(1, cssSize(pane, size)) );
+ // resize all the adjacent panes, and adjust their toggler buttons
+ if (!s.isSliding) sizeMidPanes(dir=="horz" ? "all" : "center");
+ sizeHandles();
+ execUserCallback(pane, o.onresize_end || o.onresize);
+ * sizeMidPanes
+ * @callers create(), open(), close(), onWindowResize()
+ var sizeMidPanes = function (panes, overrideDims, onInit) {
+ if (!panes || panes == "all") panes = "east,west,center";
+ var d = getPaneDims();
+ if (overrideDims) $.extend( d, overrideDims );
+ $.each(panes.split(","), function() {
+ if (!$Ps[this]) return; // NO PANE - skip
+ var
+ pane = str(this)
+ , s = state[pane]
+ , $P = $Ps[pane]
+ , $R = $Rs[pane]
+ , hasRoom = true
+ , CSS = {}
+ if (pane == "center") {
+ d = getPaneDims(); // REFRESH Dims because may have just 'unhidden' East or West pane after a 'resize'
+ CSS = $.extend( {}, d ); // COPY ALL of the paneDims
+ CSS.width = max(1, cssW(pane, CSS.width));
+ CSS.height = max(1, cssH(pane, CSS.height));
+ hasRoom = (CSS.width > 1 && CSS.height > 1);
+ * Extra CSS for IE6 or IE7 in Quirks-mode - add 'width' to NORTH/SOUTH panes
+ * Normally these panes have only 'left' & 'right' positions so pane auto-sizes
+ if ($.browser.msie && (!$.boxModel || $.browser.version < 7)) {
+ if ($Ps.north) $Ps.north.css({ width: cssW($Ps.north, cDims.innerWidth) });
+ if ($Ps.south) $Ps.south.css({ width: cssW($Ps.south, cDims.innerWidth) });
+ else { // for east and west, set only the height
+ CSS.top = d.top;
+ CSS.bottom = d.bottom;
+ CSS.height = max(1, cssH(pane, d.height));
+ hasRoom = (CSS.height > 1);
+ if (hasRoom) {
+ $P.css(CSS);
+ if (s.noRoom) {
+ s.noRoom = false;
+ if (s.isHidden) return;
+ else show(pane, !s.isClosed);
+ /* OLD CODE - keep until sure line above works right!
+ if (!s.isClosed) $P.show(); // in case was previously hidden due to NOT hasRoom
+ if ($R) $R.show();
+ if (!onInit) {
+ else if (!s.noRoom) { // no room for pane, so just hide it (if not already)
+ s.noRoom = true; // update state
+ if (onInit) { // skip onhide callback and other logic onLoad
+ $P.hide();
+ else hide(pane);
+ var sizeContent = function (panes) {
+ if (!panes || panes == "all") panes = c.allPanes;
+ if (!$Cs[this]) return; // NO CONTENT - skip
+ var
+ pane = str(this)
+ , ignore = options[pane].contentIgnoreSelector
+ , $P = $Ps[pane]
+ , $C = $Cs[pane]
+ , e_C = $C[0] // DOM element
+ , height = cssH($P); // init to pane.innerHeight
+ $P.children().each(function() {
+ if (this == e_C) return; // Content elem - skip
+ var $E = $(this);
+ if (!ignore || !$E.is(ignore))
+ height -= $E.outerHeight();
+ if (height > 0)
+ height = cssH($C, height);
+ if (height < 1)
+ $C.hide(); // no room for content!
+ else
+ $C.css({ height: height }).show();
+ * sizeHandles
+ * Called every time a pane is opened, closed, or resized to slide the togglers to 'center' and adjust their length if necessary
+ * @callers initHandles(), open(), close(), resizeAll()
+ var sizeHandles = function (panes, onInit) {
+ if (!panes || panes == "all") panes = c.borderPanes;
+ var
+ pane = str(this)
+ , s = state[pane]
+ , $P = $Ps[pane]
+ , $R = $Rs[pane]
+ , $T = $Ts[pane]
+ if (!$P || !$R || (!o.resizable && !o.closable)) return; // skip
+ var
+ dir = c[pane].dir
+ , _state = (s.isClosed ? "_closed" : "_open")
+ , spacing = o["spacing"+ _state]
+ , togAlign = o["togglerAlign"+ _state]
+ , togLen = o["togglerLength"+ _state]
+ , paneLen
+ , offset
+ , CSS = {}
+ if (spacing == 0) {
+ $R.hide();
+ return;
+ else if (!s.noRoom && !s.isHidden) // skip if resizer was hidden for any reason
+ $R.show(); // in case was previously hidden
+ // Resizer Bar is ALWAYS same width/height of pane it is attached to
+ if (dir == "horz") { // north/south
+ paneLen = $P.outerWidth();
+ $R.css({
+ width: max(1, cssW($R, paneLen)) // account for borders & padding
+ , height: max(1, cssH($R, spacing)) // ditto
+ , left: cssNum($P, "left")
+ else { // east/west
+ paneLen = $P.outerHeight();
+ $R.css({
+ height: max(1, cssH($R, paneLen)) // account for borders & padding
+ , width: max(1, cssW($R, spacing)) // ditto
+ , top: cDims.top + getPaneSize("north", true)
+ //, top: cssNum($Ps["center"], "top")
+ if ($T) {
+ if (togLen == 0 || (s.isSliding && o.hideTogglerOnSlide)) {
+ $T.hide(); // always HIDE the toggler when 'sliding'
+ return;
+ else
+ $T.show(); // in case was previously hidden
+ if (!(togLen > 0) || togLen == "100%" || togLen > paneLen) {
+ togLen = paneLen;
+ offset = 0;
+ else { // calculate 'offset' based on options.PANE.togglerAlign_open/closed
+ if (typeof togAlign == "string") {
+ switch (togAlign) {
+ case "top":
+ case "left": offset = 0;
+ break;
+ case "bottom":
+ case "right": offset = paneLen - togLen;
+ break;
+ case "middle":
+ case "center":
+ default: offset = Math.floor((paneLen - togLen) / 2); // 'default' catches typos
+ else { // togAlign = number
+ var x = parseInt(togAlign); //
+ if (togAlign >= 0) offset = x;
+ else offset = paneLen - togLen + x; // NOTE: x is negative!
+ var
+ $TC_o = (o.togglerContent_open ? $T.children(".content-open") : false)
+ , $TC_c = (o.togglerContent_closed ? $T.children(".content-closed") : false)
+ , $TC = (s.isClosed ? $TC_c : $TC_o)
+ if ($TC_o) $TC_o.css("display", s.isClosed ? "none" : "block");
+ if ($TC_c) $TC_c.css("display", s.isClosed ? "block" : "none");
+ var width = cssW($T, togLen);
+ $T.css({
+ width: max(0, width) // account for borders & padding
+ , height: max(1, cssH($T, spacing)) // ditto
+ , left: offset // TODO: VERIFY that toggler positions correctly for ALL values
+ if ($TC) // CENTER the toggler content SPAN
+ $TC.css("marginLeft", Math.floor((width-$TC.outerWidth())/2)); // could be negative
+ var height = cssH($T, togLen);
+ $T.css({
+ height: max(0, height) // account for borders & padding
+ , width: max(1, cssW($T, spacing)) // ditto
+ , top: offset // POSITION the toggler
+ $TC.css("marginTop", Math.floor((height-$TC.outerHeight())/2)); // could be negative
+ // DONE measuring and sizing this resizer/toggler, so can be 'hidden' now
+ if (onInit && o.initHidden) {
+ $R.hide();
+ if ($T) $T.hide();
+ * resizeAll
+ * @callers window.onresize(), callbacks or custom code
+ var resizeAll = function () {
+ var
+ oldW = cDims.innerWidth
+ , oldH = cDims.innerHeight
+ cDims = state.container = getElemDims($Container); // UPDATE container dimensions
+ var
+ checkH = (cDims.innerHeight < oldH)
+ , checkW = (cDims.innerWidth < oldW)
+ , s, dir
+ if (checkH || checkW)
+ // NOTE special order for sizing: S-N-E-W
+ $.each(["south","north","east","west"], function(i,pane) {
+ s = state[pane];
+ dir = c[pane].dir;
+ if (!s.isClosed && ((checkH && dir=="horz") || (checkW && dir=="vert"))) {
+ // shrink pane if 'too big' to fit
+ sizePane(pane, s.maxSize);
+ sizeMidPanes("all");
+ sizeHandles("all"); // reposition the toggler elements
+ * keyDown
+ * Capture keys when enableCursorHotkey - toggle pane if hotkey pressed
+ * @callers document.keydown()
+ function keyDown (evt) {
+ if (!evt) return true;
+ var code = evt.keyCode;
+ if (code < 33) return true; // ignore special keys: ENTER, TAB, etc
+ var
+ PANE = {
+ 38: "north" // Up Cursor
+ , 40: "south" // Down Cursor
+ , 37: "west" // Left Cursor
+ , 39: "east" // Right Cursor
+ , isCursorKey = (code >= 37 && code <= 40)
+ , ALT = evt.altKey // no worky!
+ , SHIFT = evt.shiftKey
+ , CTRL = evt.ctrlKey
+ , pane = false
+ , s, o, k, m, el
+ if (!CTRL && !SHIFT)
+ return true; // no modifier key - abort
+ else if (isCursorKey && options[PANE[code]].enableCursorHotkey) // valid cursor-hotkey
+ pane = PANE[code];
+ else // check to see if this matches a custom-hotkey
+ $.each(c.borderPanes.split(","), function(i,p) { // loop each pane to check its hotkey
+ o = options[p];
+ k = o.customHotkey;
+ m = o.customHotkeyModifier; // if missing or invalid, treated as "CTRL+SHIFT"
+ if ((SHIFT && m=="SHIFT") || (CTRL && m=="CTRL") || (CTRL && SHIFT)) { // Modifier matches
+ if (k && code == (isNaN(k) || k <= 9 ? k.toUpperCase().charCodeAt(0) : k)) { // Key matches
+ pane = p;
+ if (!pane) return true; // no hotkey - abort
+ // validate pane
+ o = options[pane]; // get pane options
+ s = state[pane]; // get pane options
+ if (!o.enableCursorHotkey || s.isHidden || !$Ps[pane]) return true;
+ // see if user is in a 'form field' because may be 'selecting text'!
+ el = evt.target || evt.srcElement;
+ if (el && SHIFT && isCursorKey && (el.tagName=="TEXTAREA" || (el.tagName=="INPUT" && (code==37 || code==39))))
+ return true; // allow text-selection
+ // SYNTAX NOTES
+ // use "returnValue=false" to abort keystroke but NOT abort function - can run another command afterwards
+ // use "return false" to abort keystroke AND abort function
+ toggle(pane);
+ evt.returnValue = false; // CANCEL key
+ return false;
+ * UTILITY METHODS
+ * called externally only
+ function allowOverflow (elem) {
+ if (this && this.tagName) elem = this; // BOUND to element
+ var $P;
+ if (typeof elem=="string")
+ $P = $Ps[elem];
+ else {
+ if ($(elem).attr("pane")) $P = $(elem);
+ else $P = $(elem).parents("div[pane]:first");
+ if (!$P.length) return; // INVALID
+ var
+ pane = $P.attr("pane")
+ , s = state[pane]
+ // if pane is already raised, then reset it before doing it again!
+ // this would happen if allowOverflow is attached to BOTH the pane and an element
+ if (s.cssSaved)
+ resetOverflow(pane); // reset previous CSS before continuing
+ // if pane is raised by sliding or resizing, or it's closed, then abort
+ if (s.isSliding || s.isResizing || s.isClosed) {
+ s.cssSaved = false;
+ return;
+ var
+ newCSS = { zIndex: (c.zIndex.pane_normal + 1) }
+ , curCSS = {}
+ , of = $P.css("overflow")
+ , ofX = $P.css("overflowX")
+ , ofY = $P.css("overflowY")
+ // determine which, if any, overflow settings need to be changed
+ if (of != "visible") {
+ curCSS.overflow = of;
+ newCSS.overflow = "visible";
+ if (ofX && ofX != "visible" && ofX != "auto") {
+ curCSS.overflowX = ofX;
+ newCSS.overflowX = "visible";
+ if (ofY && ofY != "visible" && ofY != "auto") {
+ curCSS.overflowY = ofX;
+ newCSS.overflowY = "visible";
+ // save the current overflow settings - even if blank!
+ s.cssSaved = curCSS;
+ // apply new CSS to raise zIndex and, if necessary, make overflow 'visible'
+ $P.css( newCSS );
+ // make sure the zIndex of all other panes is normal
+ $.each(c.allPanes.split(","), function(i, p) {
+ if (p != pane) resetOverflow(p);
+ function resetOverflow (elem) {
+ var $P;
+ $P = $Ps[elem];
+ else {
+ if ($(elem).hasClass("ui-layout-pane")) $P = $(elem);
+ var
+ , s = state[pane]
+ , CSS = s.cssSaved || {}
+ // reset the zIndex
+ if (!s.isSliding && !s.isResizing)
+ $P.css("zIndex", c.zIndex.pane_normal);
+ // reset Overflow - if necessary
+ $P.css( CSS );
+ // clear var
+ * getBtn
+ * Helper function to validate params received by addButton utilities
+ * @param String selector jQuery selector for button, eg: ".ui-layout-north .toggle-button"
+ * @param String pane Name of the pane the button is for: 'north', 'south', etc.
+ * @returns If both params valid, the element matching 'selector' in a jQuery wrapper - otherwise 'false'
+ function getBtn(selector, pane, action) {
+ var
+ $E = $(selector)
+ , err = "Error Adding Button \n\nInvalid "
+ if (!$E.length) // element not found
+ alert(err+"selector: "+ selector);
+ else if (c.borderPanes.indexOf(pane) == -1) // invalid 'pane' sepecified
+ alert(err+"pane: "+ pane);
+ else { // VALID
+ var btn = options[pane].buttonClass +"-"+ action;
+ $E.addClass( btn +" "+ btn +"-"+ pane );
+ return $E;
+ return false; // INVALID
+ * addToggleBtn
+ * Add a custom Toggler button for a pane
+ function addToggleBtn (selector, pane) {
+ var $E = getBtn(selector, pane, "toggle");
+ if ($E)
+ $E
+ .attr("title", state[pane].isClosed ? "Open" : "Close")
+ .click(function (evt) {
+ toggle(pane);
+ * addOpenBtn
+ * Add a custom Open button for a pane
+ * @param String selector jQuery selector for button, eg: ".ui-layout-north .open-button"
+ function addOpenBtn (selector, pane) {
+ var $E = getBtn(selector, pane, "open");
+ if ($E)
+ $E
+ .attr("title", "Open")
+ open(pane);
+ * addCloseBtn
+ * Add a custom Close button for a pane
+ * @param String selector jQuery selector for button, eg: ".ui-layout-north .close-button"
+ function addCloseBtn (selector, pane) {
+ var $E = getBtn(selector, pane, "close");
+ if ($E)
+ $E
+ .attr("title", "Close")
+ close(pane);
+ * addPinBtn
+ * Add a custom Pin button for a pane
+ * Four classes are added to the element, based on the paneClass for the associated pane...
+ * Assuming the default paneClass and the pin is 'up', these classes are added for a west-pane pin:
+ * - ui-layout-pane-pin
+ * - ui-layout-pane-west-pin
+ * - ui-layout-pane-pin-up
+ * - ui-layout-pane-west-pin-up
+ * @param String selector jQuery selector for button, eg: ".ui-layout-north .ui-layout-pin"
+ * @param String pane Name of the pane the pin is for: 'north', 'south', etc.
+ function addPinBtn (selector, pane) {
+ var $E = getBtn(selector, pane, "pin");
+ if ($E) {
+ $E.click(function (evt) {
+ setPinState($(this), pane, (s.isSliding || s.isClosed));
+ if (s.isSliding || s.isClosed) open( pane ); // change from sliding to open
+ else close( pane ); // slide-closed
+ // add up/down pin attributes and classes
+ setPinState ($E, pane, (!s.isClosed && !s.isSliding));
+ // add this pin to the pane data so we can 'sync it' automatically
+ // PANE.pins key is an array so we can store multiple pins for each pane
+ c[pane].pins.push( selector ); // just save the selector string
+ * syncPinBtns
+ * INTERNAL function to sync 'pin buttons' when pane is opened or closed
+ * Unpinned means the pane is 'sliding' - ie, over-top of the adjacent panes
+ * @params pane These are the params returned to callbacks by layout()
+ * @params doPin True means set the pin 'down', False means 'up'
+ function syncPinBtns (pane, doPin) {
+ $.each(c[pane].pins, function (i, selector) {
+ setPinState($(selector), pane, doPin);
+ * setPinState
+ * Change the class of the pin button to make it look 'up' or 'down'
+ * @callers addPinBtn(), syncPinBtns()
+ * @param Element $Pin The pin-span element in a jQuery wrapper
+ * @param Boolean doPin True = set the pin 'down', False = set it 'up'
+ * @param String pinClass The root classname for pins - will add '-up' or '-down' suffix
+ function setPinState ($Pin, pane, doPin) {
+ var updown = $Pin.attr("pin");
+ if (updown && doPin == (updown=="down")) return; // already in correct state
+ var
+ root = options[pane].buttonClass
+ , class1 = root +"-pin"
+ , class2 = class1 +"-"+ pane
+ , UP1 = class1 + "-up"
+ , UP2 = class2 + "-up"
+ , DN1 = class1 + "-down"
+ , DN2 = class2 + "-down"
+ $Pin
+ .attr("pin", doPin ? "down" : "up") // logic
+ .attr("title", doPin ? "Un-Pin" : "Pin")
+ .removeClass( doPin ? UP1 : DN1 )
+ .removeClass( doPin ? UP2 : DN2 )
+ .addClass( doPin ? DN1 : UP1 )
+ .addClass( doPin ? DN2 : UP2 )
+ * CREATE/RETURN BORDER-LAYOUT
+ // init global vars
+ var
+ $Container = $(this).css({ overflow: "hidden" }) // Container elem
+ , $Ps = {} // Panes x4 - set in initPanes()
+ , $Cs = {} // Content x4 - set in initPanes()
+ , $Rs = {} // Resizers x4 - set in initHandles()
+ , $Ts = {} // Togglers x4 - set in initHandles()
+ // object aliases
+ , c = config // alias for config hash
+ , cDims = state.container // alias for easy access to 'container dimensions'
+ // create the border layout NOW
+ create();
+ // return object pointers to expose data & option Properties, and primary action Methods
+ return {
+ options: options // property - options hash
+ , state: state // property - dimensions hash
+ , panes: $Ps // property - object pointers for ALL panes: panes.north, panes.center
+ , toggle: toggle // method - pass a 'pane' ("north", "west", etc)
+ , open: open // method - ditto
+ , close: close // method - ditto
+ , hide: hide // method - ditto
+ , show: show // method - ditto
+ , resizeContent: sizeContent // method - ditto
+ , sizePane: sizePane // method - pass a 'pane' AND a 'size' in pixels
+ , resizeAll: resizeAll // method - no parameters
+ , addToggleBtn: addToggleBtn // utility - pass element selector and 'pane'
+ , addOpenBtn: addOpenBtn // utility - ditto
+ , addCloseBtn: addCloseBtn // utility - ditto
+ , addPinBtn: addPinBtn // utility - ditto
+ , allowOverflow: allowOverflow // utility - pass calling element
+ , resetOverflow: resetOverflow // utility - ditto
+ , cssWidth: cssW
+ , cssHeight: cssH
+})( jQuery );
\ No newline at end of file
Added: branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.min.js
--- branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.min.js (rev 0)
+++ branches/3_dev/http/extensions/jquery.layout.all-1.2.0/jquery.layout.min.js 2010-05-09 13:28:08 UTC (rev 6108)
@@ -0,0 +1,80 @@
+ * jquery.layout 1.2.0
+ * Copyright (c) 2008
+ * Fabrizio Balliano (http://www.fabrizioballiano.net)
+ * Kevin Dalman (http://allpro.net)
+ * Dual licensed under the GPL (http://www.gnu.org/licenses/gpl.html)
+ * and MIT (http://www.opensource.org/licenses/mit-license.php) licenses.
+ * $Date: 2008-12-27 02:17:22 +0100 (sab, 27 dic 2008) $
+ * $Rev: 203 $
+ * NOTE: For best code readability, view this with a fixed-space font and tabs equal to 4-chars
+(function($){$.fn.layout=function(opts){var
+prefix="ui-layout-",defaults={paneClass:prefix+"pane",resizerClass:prefix+"resizer",togglerClass:prefix+"toggler",togglerInnerClass:prefix+"",buttonClass:prefix+"button",contentSelector:"."+prefix+"content",contentIgnoreSelector:"."+prefix+"ignore"};var options={name:"",scrollToBookmarkOnLoad:true,defaults:{applyDefaultStyles:false,closable:true,resizable:true,slidable:true,contentSelector:defaults.contentSelector,contentIgnoreSelector:defaults.contentIgnoreSelector,paneClass:defaults.paneClass,resizerClass:defaults.resizerClass,togglerClass:defaults.togglerClass,buttonClass:defaults.buttonClass,resizerDragOpacity:1,maskIframesOnResize:true,minSize:0,maxSize:0,spacing_open:6,spacing_closed:6,togglerLength_open:50,togglerLength_closed:50,togglerAlign_open:"center",togglerAlign_closed:"center",togglerTip_open:"Close",togglerTip_closed:"Open",resizerTip:"Resize",sliderTip:"Slide Open",sliderCursor:"pointer",slideTrigger_open:"click",slideTrigger_close:"mouseout",hideTogglerOnSlide:false,togglerContent_open:"",togglerContent_closed:"",showOverflowOnHover:false,enableCursorHotkey:true,customHotkeyModifier:"SHIFT",fxName:"slide",fxSpeed:null,fxSettings:{},initClosed:false,initHidden:false},north:{paneSelector:"."+prefix+"north",size:"auto",resizerCursor:"n-resize"},south:{paneSelector:"."+prefix+"south",size:"auto",resizerCursor:"s-resize"},east:{paneSelector:"."+prefix+"east",size:200,resizerCursor:"e-resize"},west:{paneSelector:"."+prefix+"west",size:200,resizerCursor:"w-resize"},center:{paneSelector:"."+prefix+"center"}};var effects={slide:{all:{duration:"fast"},north:{direction:"up"},south:{direction:"down"},east:{direction:"right"},west:{direction:"left"}},drop:{all:{duration:"slow"},north:{direction:"up"},south:{direction:"down"},east:{direction:"right"},west:{direction:"left"}},scale:{all:{duration:"fast"}}};var config={allPanes:"north,south,east,west,center",borderPanes:"north,south,east,west",zIndex:{resizer_normal:1,pane_normal:2,mask:4,sliding:100,resizing:10000,animation:10000},resizers:{cssReq:{position:"absolute",padding:0,margin:0,fontSize:"1px",textAlign:"left",overflow:"hidden",zIndex:1},cssDef:{background:"#DDD",border:"none"}},togglers:{cssReq:{position:"absolute",display:"block",padding:0,margin:0,overflow:"hidden",textAlign:"center",fontSize:"1px",cursor:"pointer",zIndex:1},cssDef:{background:"#AAA"}},content:{cssReq:{overflow:"auto"},cssDef:{}},defaults:{cssReq:{position:"absolute",margin:0,zIndex:2},cssDef:{padding:"10px",background:"#FFF",border:"1px solid #BBB",overflow:"auto"}},north:{edge:"top",sizeType:"height",dir:"horz",cssReq:{top:0,bottom:"auto",left:0,right:0,width:"auto"}},south:{edge:"bottom",sizeType:"height",dir:"horz",cssReq:{top:"auto",bottom:0,left:0,right:0,width:"auto"}},east:{edge:"right",sizeType:"width",dir:"vert",cssReq:{left:"auto",right:0,top:"auto",bottom:"auto",height:"auto"}},west:{edge:"left",sizeType:"width",dir:"vert",cssReq:{left:0,right:"auto",top:"auto",bottom:"auto",height:"auto"}},center:{dir:"center",cssReq:{left:"auto",right:"auto",top:"auto",bottom:"auto",height:"auto",width:"auto"}}};var state={id:Math.floor(Math.random()*10000),container:{},north:{},south:{},east:{},west:{},center:{}};var
+altEdge={top:"bottom",bottom:"top",left:"right",right:"left"},altSide={north:"south",south:"north",east:"west",west:"east"};var isStr=function(o){if(typeof o=="string")return true;else if(typeof o=="object"){try{var match=o.constructor.toString().match(/string/i);return(match!==null);}catch(e){}}return false;};var str=function(o){if(typeof o=="string"||isStr(o))return $.trim(o);else return o;};var min=function(x,y){return Math.min(x,y);};var max=function(x,y){return Math.max(x,y);};var transformData=function(d){var json={defaults:{fxSettings:{}},north:{fxSettings:{}},south:{fxSettings:{}},east:{fxSettings:{}},west:{fxSettings:{}},center:{fxSettings:{}}};d=d||{};if(d.effects||d.defaults||d.north||d.south||d.west||d.east||d.center)json=$.extend(json,d);else
+$.each(d,function(key,val){a=key.split("__");json[a[1]?a[0]:"defaults"][a[1]?a[1]:a[0]]=val;});return json;};var setFlowCallback=function(action,pane,param){var
+cb=action+","+pane+","+(param?1:0),cP,cbPane;$.each(c.borderPanes.split(","),function(i,p){if(c[p].isMoving){bindCallback(p);return false;}});function bindCallback(p,test){cP=c[p];if(!cP.doCallback){cP.doCallback=true;cP.callback=cb;}else{cpPane=cP.callback.split(",")[1];if(cpPane!=p&&cpPane!=pane)bindCallback(cpPane,true);}}};var execFlowCallback=function(pane){var cP=c[pane];c.isLayoutBusy=false;delete cP.isMoving;if(!cP.doCallback||!cP.callback)return;cP.doCallback=false;var
+cb=cP.callback.split(","),param=(cb[2]>0?true:false);if(cb[0]=="open")open(cb[1],param);else if(cb[0]=="close")close(cb[1],param);if(!cP.doCallback)cP.callback=null;};var execUserCallback=function(pane,v_fn){if(!v_fn)return;var fn;try{if(typeof v_fn=="function")fn=v_fn;else if(typeof v_fn!="string")return;else if(v_fn.indexOf(",")>0){var
+args=v_fn.split(","),fn=eval(args[0]);if(typeof fn=="function"&&args.length>1)return fn(args[1]);}else
+fn=eval(v_fn);if(typeof fn=="function")return fn(pane,$Ps[pane],$.extend({},state[pane]),$.extend({},options[pane]),options.name);}catch(ex){}};var cssNum=function($E,prop){var
+val=0,hidden=false,visibility="";if(!$.browser.msie){if($.curCSS($E[0],"display",true)=="none"){hidden=true;visibility=$.curCSS($E[0],"visibility",true);$E.css({display:"block",visibility:"hidden"});}}val=parseInt($.curCSS($E[0],prop,true),10)||0;if(hidden){$E.css({display:"none"});if(visibility&&visibility!="hidden")$E.css({visibility:visibility});}return val;};var cssW=function(e,outerWidth){var $E;if(isStr(e)){e=str(e);$E=$Ps[e];}else
+$E=$(e);if(outerWidth<=0)return 0;else if(!(outerWidth>0))outerWidth=isStr(e)?getPaneSize(e):$E.outerWidth();if(!$.boxModel)return outerWidth;else
+return outerWidth
+-cssNum($E,"paddingLeft")-cssNum($E,"paddingRight")-($.curCSS($E[0],"borderLeftStyle",true)=="none"?0:cssNum($E,"borderLeftWidth"))-($.curCSS($E[0],"borderRightStyle",true)=="none"?0:cssNum($E,"borderRightWidth"));};var cssH=function(e,outerHeight){var $E;if(isStr(e)){e=str(e);$E=$Ps[e];}else
+$E=$(e);if(outerHeight<=0)return 0;else if(!(outerHeight>0))outerHeight=(isStr(e))?getPaneSize(e):$E.outerHeight();if(!$.boxModel)return outerHeight;else
+return outerHeight
+-cssNum($E,"paddingTop")-cssNum($E,"paddingBottom")-($.curCSS($E[0],"borderTopStyle",true)=="none"?0:cssNum($E,"borderTopWidth"))-($.curCSS($E[0],"borderBottomStyle",true)=="none"?0:cssNum($E,"borderBottomWidth"));};var cssSize=function(pane,outerSize){if(c[pane].dir=="horz")return cssH(pane,outerSize);else
+return cssW(pane,outerSize);};var getPaneSize=function(pane,inclSpace){var
+$P=$Ps[pane],o=options[pane],s=state[pane],oSp=(inclSpace?o.spacing_open:0),cSp=(inclSpace?o.spacing_closed:0);if(!$P||s.isHidden)return 0;else if(s.isClosed||(s.isSliding&&inclSpace))return cSp;else if(c[pane].dir=="horz")return $P.outerHeight()+oSp;else
+return $P.outerWidth()+oSp;};var setPaneMinMaxSizes=function(pane){var
+d=cDims,edge=c[pane].edge,dir=c[pane].dir,o=options[pane],s=state[pane],$P=$Ps[pane],$altPane=$Ps[altSide[pane]],paneSpacing=o.spacing_open,altPaneSpacing=options[altSide[pane]].spacing_open,altPaneSize=(!$altPane?0:(dir=="horz"?$altPane.outerHeight():$altPane.outerWidth())),containerSize=(dir=="horz"?d.innerHeight:d.innerWidth),limitSize=containerSize-paneSpacing-altPaneSize-altPaneSpacing,minSize=s.minSize||0,maxSize=Math.min(s.maxSize||9999,limitSize),minPos,maxPos;switch(pane){case"north":minPos=d.offsetTop+minSize;maxPos=d.offsetTop+maxSize;break;case"west":minPos=d.offsetLeft+minSize;maxPos=d.offsetLeft+maxSize;break;case"south":minPos=d.offsetTop+d.innerHeight-maxSize;maxPos=d.offsetTop+d.innerHeight-minSize;break;case"east":minPos=d.offsetLeft+d.innerWidth-maxSize;maxPos=d.offsetLeft+d.innerWidth-minSize;break;}$.extend(s,{minSize:minSize,maxSize:maxSize,minPosition:minPos,maxPosition:maxPos});};var getPaneDims=function(){var d={top:getPaneSize("north",true),bottom:getPaneSize("south",true),left:getPaneSize("west",true),right:getPaneSize("east",true),width:0,height:0};with(d){width=cDims.innerWidth-left-right;height=cDims.innerHeight-bottom-top;top+=cDims.top;bottom+=cDims.bottom;left+=cDims.left;right+=cDims.right;}return d;};var getElemDims=function($E){var
+d={},e,b,p;$.each("Left,Right,Top,Bottom".split(","),function(){e=str(this);b=d["border"+e]=cssNum($E,"border"+e+"Width");p=d["padding"+e]=cssNum($E,"padding"+e);d["offset"+e]=b+p;if($E==$Container)d[e.toLowerCase()]=($.boxModel?p:0);});d.innerWidth=d.outerWidth=$E.outerWidth();d.innerHeight=d.outerHeight=$E.outerHeight();if($.boxModel){d.innerWidth-=(d.offsetLeft+d.offsetRight);d.innerHeight-=(d.offsetTop+d.offsetBottom);}return d;};var setTimer=function(pane,action,fn,ms){var
+Layout=window.layout=window.layout||{},Timers=Layout.timers=Layout.timers||{},name="layout_"+state.id+"_"+pane+"_"+action;if(Timers[name])return;else Timers[name]=setTimeout(fn,ms);};var clearTimer=function(pane,action){var
+Layout=window.layout=window.layout||{},Timers=Layout.timers=Layout.timers||{},name="layout_"+state.id+"_"+pane+"_"+action;if(Timers[name]){clearTimeout(Timers[name]);delete Timers[name];return true;}else
+return false;};var create=function(){initOptions();initContainer();initPanes();initHandles();initResizable();sizeContent("all");if(options.scrollToBookmarkOnLoad)with(self.location)if(hash)replace(hash);initHotkeys();$(window).resize(function(){var timerID="timerLayout_"+state.id;if(window[timerID])clearTimeout(window[timerID]);window[timerID]=null;if(true||$.browser.msie)window[timerID]=setTimeout(resizeAll,100);else
+resizeAll();});};var initContainer=function(){try{if($Container[0].tagName=="BODY"){$("html").css({height:"100%",overflow:"hidden"});$("body").css({position:"relative",height:"100%",overflow:"hidden",margin:0,padding:0,border:"none"});}else{var
+CSS={overflow:"hidden"},p=$Container.css("position"),h=$Container.css("height");if(!$Container.hasClass("ui-layout-pane")){if(!p||"fixed,absolute,relative".indexOf(p)<0)CSS.position="relative";if(!h||h=="auto")CSS.height="100%";}$Container.css(CSS);}}catch(ex){}cDims=state.container=getElemDims($Container);};var initHotkeys=function(){$.each(c.borderPanes.split(","),function(i,pane){var o=options[pane];if(o.enableCursorHotkey||o.customHotkey){$(document).keydown(keyDown);return false;}});};var initOptions=function(){opts=transformData(opts);if(opts.effects){$.extend(effects,opts.effects);delete opts.effects;}$.each("name,scrollToBookmarkOnLoad".split(","),function(idx,key){if(opts[key]!==undefined)options[key]=opts[key];else if(opts.defaults[key]!==undefined){options[key]=opts.defaults[key];delete opts.defaults[key];}});$.each("paneSelector,resizerCursor,customHotkey".split(","),function(idx,key){delete opts.defaults[key];});$.extend(options.defaults,opts.defaults);c.center=$.extend(true,{},c.defaults,c.center);$.extend(options.center,opts.center);var o_Center=$.extend(true,{},options.defaults,opts.defaults,options.center);$.each("paneClass,contentSelector,contentIgnoreSelector,applyDefaultStyles,showOverflowOnHover".split(","),function(idx,key){options.center[key]=o_Center[key];});var defs=options.defaults;$.each(c.borderPanes.split(","),function(i,pane){c[pane]=$.extend(true,{},c.defaults,c[pane]);o=options[pane]=$.extend(true,{},options.defaults,options[pane],opts.defaults,opts[pane]);if(!o.paneClass)o.paneClass=defaults.paneClass;if(!o.resizerClass)o.resizerClass=defaults.resizerClass;if(!o.togglerClass)o.togglerClass=defaults.togglerClass;$.each(["_open","_close",""],function(i,n){var
+sName="fxName"+n,sSpeed="fxSpeed"+n,sSettings="fxSettings"+n;o[sName]=opts[pane][sName]||opts[pane].fxName||opts.defaults[sName]||opts.defaults.fxName||o[sName]||o.fxName||defs[sName]||defs.fxName||"none";var fxName=o[sName];if(fxName=="none"||!$.effects||!$.effects[fxName]||(!effects[fxName]&&!o[sSettings]&&!o.fxSettings))fxName=o[sName]="none";var
+fx=effects[fxName]||{},fx_all=fx.all||{},fx_pane=fx[pane]||{};o[sSettings]=$.extend({},fx_all,fx_pane,defs.fxSettings||{},defs[sSettings]||{},o.fxSettings,o[sSettings],opts.defaults.fxSettings,opts.defaults[sSettings]||{},opts[pane].fxSettings,opts[pane][sSettings]||{});o[sSpeed]=opts[pane][sSpeed]||opts[pane].fxSpeed||opts.defaults[sSpeed]||opts.defaults.fxSpeed||o[sSpeed]||o[sSettings].duration||o.fxSpeed||o.fxSettings.duration||defs.fxSpeed||defs.fxSettings.duration||fx_pane.duration||fx_all.duration||"normal";});});};var initPanes=function(){$.each(c.allPanes.split(","),function(){var
+pane=str(this),o=options[pane],s=state[pane],fx=s.fx,dir=c[pane].dir,size=o.size=="auto"||isNaN(o.size)?0:o.size,minSize=o.minSize||1,maxSize=o.maxSize||9999,spacing=o.spacing_open||0,sel=o.paneSelector,isIE6=($.browser.msie&&$.browser.version<7),CSS={},$P,$C;$Cs[pane]=false;if(sel.substr(0,1)==="#")$P=$Ps[pane]=$Container.find(sel+":first");else{$P=$Ps[pane]=$Container.children(sel+":first");if(!$P.length)$P=$Ps[pane]=$Container.children("form:first").children(sel+":first");}if(!$P.length){$Ps[pane]=false;return true;}$P.attr("pane",pane).addClass(o.paneClass+" "+o.paneClass+"-"+pane);if(pane!="center"){s.isClosed=false;s.isSliding=false;s.isResizing=false;s.isHidden=false;s.noRoom=false;c[pane].pins=[];}CSS=$.extend({visibility:"visible",display:"block"},c.defaults.cssReq,c[pane].cssReq);if(o.applyDefaultStyles)$.extend(CSS,c.defaults.cssDef,c[pane].cssDef);$P.css(CSS);CSS={};switch(pane){case"north":CSS.top=cDims.top;CSS.left=cDims.left;CSS.right=cDims.right;break;case"south":CSS.bottom=cDims.bottom;CSS.left=cDims.left;CSS.right=cDims.right;break;case"west":CSS.left=cDims.left;break;case"east":CSS.right=cDims.right;break;case"center":}if(dir=="horz"){if(size===0||size=="auto"){$P.css({height:"auto"});size=$P.outerHeight();}size=max(size,minSize);size=min(size,maxSize);size=min(size,cDims.innerHeight-spacing);CSS.height=max(1,cssH(pane,size));s.size=size;s.maxSize=maxSize;s.minSize=max(minSize,size-CSS.height+1);$P.css(CSS);}else if(dir=="vert"){if(size===0||size=="auto"){$P.css({width:"auto",float:"left"});size=$P.outerWidth();$P.css({float:"none"});}size=max(size,minSize);size=min(size,maxSize);size=min(size,cDims.innerWidth-spacing);CSS.width=max(1,cssW(pane,size));s.size=size;s.maxSize=maxSize;s.minSize=max(minSize,size-CSS.width+1);$P.css(CSS);sizeMidPanes(pane,null,true);}else if(pane=="center"){$P.css(CSS);sizeMidPanes("center",null,true);}if(o.initClosed&&o.closable){$P.hide().addClass("closed");s.isClosed=true;}else if(o.initHidden||o.initClosed){hide(pane,true);s.isHidden=true;}else
+$P.addClass("open");if(o.showOverflowOnHover)$P.hover(allowOverflow,resetOverflow);if(o.contentSelector){$C=$Cs[pane]=$P.children(o.contentSelector+":first");if(!$C.length){$Cs[pane]=false;return true;}$C.css(c.content.cssReq);if(o.applyDefaultStyles)$C.css(c.content.cssDef);$P.css({overflow:"hidden"});}});};var initHandles=function(){$.each(c.borderPanes.split(","),function(){var
+pane=str(this),o=options[pane],s=state[pane],rClass=o.resizerClass,tClass=o.togglerClass,$P=$Ps[pane];$Rs[pane]=false;$Ts[pane]=false;if(!$P||(!o.closable&&!o.resizable))return;var
+edge=c[pane].edge,isOpen=$P.is(":visible"),spacing=(isOpen?o.spacing_open:o.spacing_closed),_pane="-"+pane,_state=(isOpen?"-open":"-closed"),$R,$T;$R=$Rs[pane]=$("<span></span>");if(isOpen&&o.resizable);else if(!isOpen&&o.slidable)$R.attr("title",o.sliderTip).css("cursor",o.sliderCursor);$R.attr("id",(o.paneSelector.substr(0,1)=="#"?o.paneSelector.substr(1)+"-resizer":"")).attr("resizer",pane).css(c.resizers.cssReq).css(edge,cDims[edge]+getPaneSize(pane)).addClass(rClass+" "+rClass+_pane+" "+rClass+_state+" "+rClass+_pane+_state).appendTo($Container);if(o.applyDefaultStyles)$R.css(c.resizers.cssDef);if(o.closable){$T=$Ts[pane]=$("<div></div>");$T.attr("id",(o.paneSelector.substr(0,1)=="#"?o.paneSelector.substr(1)+"-toggler":"")).css(c.togglers.cssReq).attr("title",(isOpen?o.togglerTip_open:o.togglerTip_closed)).click(function(evt){toggle(pane);evt.stopPropagation();}).mouseover(function(evt){evt.stopPropagation();}).addClass(tClass+" "+tClass+_pane+" "+tClass+_state+" "+tClass+_pane+_state).appendTo($R);if(o.togglerContent_open)$("<span>"+o.togglerContent_open+"</span>").addClass("content content-open").css("display",s.isClosed?"none":"block").appendTo($T);if(o.togglerContent_closed)$("<span>"+o.togglerContent_closed+"</span>").addClass("content content-closed").css("display",s.isClosed?"block":"none").appendTo($T);if(o.applyDefaultStyles)$T.css(c.togglers.cssDef);if(!isOpen)bindStartSlidingEvent(pane,true);}});sizeHandles("all",true);};var initResizable=function(){var
+draggingAvailable=(typeof $.fn.draggable=="function"),minPosition,maxPosition,edge;$.each(c.borderPanes.split(","),function(){var
+pane=str(this),o=options[pane],s=state[pane];if(!draggingAvailable||!$Ps[pane]||!o.resizable){o.resizable=false;return true;}var
+rClass=o.resizerClass,dragClass=rClass+"-drag",dragPaneClass=rClass+"-"+pane+"-drag",draggingClass=rClass+"-dragging",draggingPaneClass=rClass+"-"+pane+"-dragging",draggingClassSet=false,$P=$Ps[pane],$R=$Rs[pane];if(!s.isClosed)$R.attr("title",o.resizerTip).css("cursor",o.resizerCursor);$R.draggable({containment:$Container[0],axis:(c[pane].dir=="horz"?"y":"x"),delay:200,distance:1,helper:"clone",opacity:o.resizerDragOpacity,zIndex:c.zIndex.resizing,start:function(e,ui){if(false===execUserCallback(pane,o.onresize_start))return false;s.isResizing=true;clearTimer(pane,"closeSlider");$R.addClass(dragClass+" "+dragPaneClass);draggingClassSet=false;var resizerWidth=(pane=="east"||pane=="south"?o.spacing_open:0);setPaneMinMaxSizes(pane);s.minPosition-=resizerWidth;s.maxPosition-=resizerWidth;edge=(c[pane].dir=="horz"?"top":"left");$(o.maskIframesOnResize===true?"iframe":o.maskIframesOnResize).each(function(){$('<div class="ui-layout-mask"/>').css({background:"#fff",opacity:"0.001",zIndex:9,position:"absolute",width:this.offsetWidth+"px",height:this.offsetHeight+"px"}).css($(this).offset()).appendTo(this.parentNode);});},drag:function(e,ui){if(!draggingClassSet){$(".ui-draggable-dragging").addClass(draggingClass+" "+draggingPaneClass).children().css("visibility","hidden");draggingClassSet=true;if(s.isSliding)$Ps[pane].css("zIndex",c.zIndex.sliding);}if(ui.position[edge]<s.minPosition)ui.position[edge]=s.minPosition;else if(ui.position[edge]>s.maxPosition)ui.position[edge]=s.maxPosition;},stop:function(e,ui){var
+dragPos=ui.position,resizerPos,newSize;$R.removeClass(dragClass+" "+dragPaneClass);switch(pane){case"north":resizerPos=dragPos.top;break;case"west":resizerPos=dragPos.left;break;case"south":resizerPos=cDims.outerHeight-dragPos.top-$R.outerHeight();break;case"east":resizerPos=cDims.outerWidth-dragPos.left-$R.outerWidth();break;}newSize=resizerPos-cDims[c[pane].edge];sizePane(pane,newSize);$("div.ui-layout-mask").remove();s.isResizing=false;}});});};var hide=function(pane,onInit){var
+o=options[pane],s=state[pane],$P=$Ps[pane],$R=$Rs[pane];if(!$P||s.isHidden)return;if(false===execUserCallback(pane,o.onhide_start))return;s.isSliding=false;if($R)$R.hide();if(onInit||s.isClosed){s.isClosed=true;s.isHidden=true;$P.hide();sizeMidPanes(c[pane].dir=="horz"?"all":"center");execUserCallback(pane,o.onhide_end||o.onhide);}else{s.isHiding=true;close(pane,false);}};var show=function(pane,openPane){var
+o=options[pane],s=state[pane],$P=$Ps[pane],$R=$Rs[pane];if(!$P||!s.isHidden)return;if(false===execUserCallback(pane,o.onshow_start))return;s.isSliding=false;s.isShowing=true;if($R&&o.spacing_open>0)$R.show();if(openPane===false)close(pane,true);else
+open(pane);};var toggle=function(pane){var s=state[pane];if(s.isHidden)show(pane);else if(s.isClosed)open(pane);else
+close(pane);};var close=function(pane,force,noAnimation){var
+$P=$Ps[pane],$R=$Rs[pane],$T=$Ts[pane],o=options[pane],s=state[pane],doFX=!noAnimation&&!s.isClosed&&(o.fxName_close!="none"),edge=c[pane].edge,rClass=o.resizerClass,tClass=o.togglerClass,_pane="-"+pane,_open="-open",_sliding="-sliding",_closed="-closed",isShowing=s.isShowing,isHiding=s.isHiding;delete s.isShowing;delete s.isHiding;if(!$P||(!o.resizable&&!o.closable))return;else if(!force&&s.isClosed&&!isShowing)return;if(c.isLayoutBusy){setFlowCallback("close",pane,force);return;}if(!isShowing&&false===execUserCallback(pane,o.onclose_start))return;c[pane].isMoving=true;c.isLayoutBusy=true;s.isClosed=true;if(isHiding)s.isHidden=true;else if(isShowing)s.isHidden=false;syncPinBtns(pane,false);if(!s.isSliding)sizeMidPanes(c[pane].dir=="horz"?"all":"center");if($R){$R.css(edge,cDims[edge]).removeClass(rClass+_open+" "+rClass+_pane+_open).removeClass(rClass+_sliding+" "+rClass+_pane+_sliding).addClass(rClass+_closed+" "+rClass+_pane+_closed);if(o.resizable)$R.draggable("disable").css("cursor","default").attr("title","");if($T){$T.removeClass(tClass+_open+" "+tClass+_pane+_open).addClass(tClass+_closed+" "+tClass+_pane+_closed).attr("title",o.togglerTip_closed);}sizeHandles();}if(doFX){lockPaneForFX(pane,true);$P.hide(o.fxName_close,o.fxSettings_close,o.fxSpeed_close,function(){lockPaneForFX(pane,false);if(!s.isClosed)return;close_2();});}else{$P.hide();close_2();}function close_2(){bindStartSlidingEvent(pane,true);if(!isShowing)execUserCallback(pane,o.onclose_end||o.onclose);if(isShowing)execUserCallback(pane,o.onshow_end||o.onshow);if(isHiding)execUserCallback(pane,o.onhide_end||o.onhide);execFlowCallback(pane);}};var open=function(pane,slide,noAnimation){var
+$P=$Ps[pane],$R=$Rs[pane],$T=$Ts[pane],o=options[pane],s=state[pane],doFX=!noAnimation&&s.isClosed&&(o.fxName_open!="none"),edge=c[pane].edge,rClass=o.resizerClass,tClass=o.togglerClass,_pane="-"+pane,_open="-open",_closed="-closed",_sliding="-sliding",isShowing=s.isShowing;delete s.isShowing;if(!$P||(!o.resizable&&!o.closable))return;else if(!s.isClosed&&!s.isSliding)return;if(s.isHidden&&!isShowing){show(pane,true);return;}if(c.isLayoutBusy){setFlowCallback("open",pane,slide);return;}if(false===execUserCallback(pane,o.onopen_start))return;c[pane].isMoving=true;c.isLayoutBusy=true;if(s.isSliding&&!slide)bindStopSlidingEvents(pane,false);s.isClosed=false;if(isShowing)s.isHidden=false;setPaneMinMaxSizes(pane);if(s.size>s.maxSize)$P.css(c[pane].sizeType,max(1,cssSize(pane,s.maxSize)));bindStartSlidingEvent(pane,false);if(doFX){lockPaneForFX(pane,true);$P.show(o.fxName_open,o.fxSettings_open,o.fxSpeed_open,function(){lockPaneForFX(pane,false);if(s.isClosed)return;open_2();});}else{$P.show();open_2();}function open_2(){if(!s.isSliding)sizeMidPanes(c[pane].dir=="vert"?"center":"all");if($R){$R.css(edge,cDims[edge]+getPaneSize(pane)).removeClass(rClass+_closed+" "+rClass+_pane+_closed).addClass(rClass+_open+" "+rClass+_pane+_open).addClass(!s.isSliding?"":rClass+_sliding+" "+rClass+_pane+_sliding);if(o.resizable)$R.draggable("enable").css("cursor",o.resizerCursor).attr("title",o.resizerTip);else
+$R.css("cursor","default");if($T){$T.removeClass(tClass+_closed+" "+tClass+_pane+_closed).addClass(tClass+_open+" "+tClass+_pane+_open).attr("title",o.togglerTip_open);}sizeHandles("all");}sizeContent(pane);syncPinBtns(pane,!s.isSliding);execUserCallback(pane,o.onopen_end||o.onopen);if(isShowing)execUserCallback(pane,o.onshow_end||o.onshow);execFlowCallback(pane);}};var lockPaneForFX=function(pane,doLock){var $P=$Ps[pane];if(doLock){$P.css({zIndex:c.zIndex.animation});if(pane=="south")$P.css({top:cDims.top+cDims.innerHeight-$P.outerHeight()});else if(pane=="east")$P.css({left:cDims.left+cDims.innerWidth-$P.outerWidth()});}else{if(!state[pane].isSliding)$P.css({zIndex:c.zIndex.pane_normal});if(pane=="south")$P.css({top:"auto"});else if(pane=="east")$P.css({left:"auto"});}};var bindStartSlidingEvent=function(pane,enable){var
+o=options[pane],$R=$Rs[pane],trigger=o.slideTrigger_open;if(!$R||!o.slidable)return;if(trigger!="click"&&trigger!="dblclick"&&trigger!="mouseover")trigger="click";$R
+[enable?"bind":"unbind"](trigger,slideOpen).css("cursor",(enable?o.sliderCursor:"default")).attr("title",(enable?o.sliderTip:""));};var bindStopSlidingEvents=function(pane,enable){var
+o=options[pane],s=state[pane],trigger=o.slideTrigger_close,action=(enable?"bind":"unbind"),$P=$Ps[pane],$R=$Rs[pane];s.isSliding=enable;clearTimer(pane,"closeSlider");$P.css({zIndex:(enable?c.zIndex.sliding:c.zIndex.pane_normal)});$R.css({zIndex:(enable?c.zIndex.sliding:c.zIndex.resizer_normal)});if(trigger!="click"&&trigger!="mouseout")trigger="mouseout";if(enable){$P.bind(trigger,slideClosed);$R.bind(trigger,slideClosed);if(trigger="mouseout"){$P.bind("mouseover",cancelMouseOut);$R.bind("mouseover",cancelMouseOut);}}else{$P.unbind(trigger);$R.unbind(trigger);if(trigger="mouseout"){$P.unbind("mouseover");$R.unbind("mouseover");clearTimer(pane,"closeSlider");}}function cancelMouseOut(evt){clearTimer(pane,"closeSlider");evt.stopPropagation();}};var slideOpen=function(){var pane=$(this).attr("resizer");if(state[pane].isClosed){bindStopSlidingEvents(pane,true);open(pane,true);}};var slideClosed=function(){var
+$E=$(this),pane=$E.attr("pane")||$E.attr("resizer"),o=options[pane],s=state[pane];if(s.isClosed||s.isResizing)return;else if(o.slideTrigger_close=="click")close_NOW();else
+setTimer(pane,"closeSlider",close_NOW,300);function close_NOW(){bindStopSlidingEvents(pane,false);if(!s.isClosed)close(pane);}};var sizePane=function(pane,size){var
+edge=c[pane].edge,dir=c[pane].dir,o=options[pane],s=state[pane],$P=$Ps[pane],$R=$Rs[pane];setPaneMinMaxSizes(pane);s.minSize=max(s.minSize,o.minSize);if(o.maxSize>0)s.maxSize=min(s.maxSize,o.maxSize);size=max(size,s.minSize);size=min(size,s.maxSize);s.size=size;$R.css(edge,size+cDims[edge]);$P.css(c[pane].sizeType,max(1,cssSize(pane,size)));if(!s.isSliding)sizeMidPanes(dir=="horz"?"all":"center");sizeHandles();sizeContent(pane);execUserCallback(pane,o.onresize_end||o.onresize);};var sizeMidPanes=function(panes,overrideDims,onInit){if(!panes||panes=="all")panes="east,west,center";var d=getPaneDims();if(overrideDims)$.extend(d,overrideDims);$.each(panes.split(","),function(){if(!$Ps[this])return;var
+pane=str(this),o=options[pane],s=state[pane],$P=$Ps[pane],$R=$Rs[pane],hasRoom=true,CSS={};if(pane=="center"){d=getPaneDims();CSS=$.extend({},d);CSS.width=max(1,cssW(pane,CSS.width));CSS.height=max(1,cssH(pane,CSS.height));hasRoom=(CSS.width>1&&CSS.height>1);if($.browser.msie&&(!$.boxModel||$.browser.version<7)){if($Ps.north)$Ps.north.css({width:cssW($Ps.north,cDims.innerWidth)});if($Ps.south)$Ps.south.css({width:cssW($Ps.south,cDims.innerWidth)});}}else{CSS.top=d.top;CSS.bottom=d.bottom;CSS.height=max(1,cssH(pane,d.height));hasRoom=(CSS.height>1);}if(hasRoom){$P.css(CSS);if(s.noRoom){s.noRoom=false;if(s.isHidden)return;else show(pane,!s.isClosed);}if(!onInit){sizeContent(pane);execUserCallback(pane,o.onresize_end||o.onresize);}}else if(!s.noRoom){s.noRoom=true;if(s.isHidden)return;if(onInit){$P.hide();if($R)$R.hide();}else hide(pane);}});};var sizeContent=function(panes){if(!panes||panes=="all")panes=c.allPanes;$.each(panes.split(","),function(){if(!$Cs[this])return;var
+pane=str(this),ignore=options[pane].contentIgnoreSelector,$P=$Ps[pane],$C=$Cs[pane],e_C=$C[0],height=cssH($P);;$P.children().each(function(){if(this==e_C)return;var $E=$(this);if(!ignore||!$E.is(ignore))height-=$E.outerHeight();});if(height>0)height=cssH($C,height);if(height<1)$C.hide();else
+$C.css({height:height}).show();});};var sizeHandles=function(panes,onInit){if(!panes||panes=="all")panes=c.borderPanes;$.each(panes.split(","),function(){var
+pane=str(this),o=options[pane],s=state[pane],$P=$Ps[pane],$R=$Rs[pane],$T=$Ts[pane];if(!$P||!$R||(!o.resizable&&!o.closable))return;var
+dir=c[pane].dir,_state=(s.isClosed?"_closed":"_open"),spacing=o["spacing"+_state],togAlign=o["togglerAlign"+_state],togLen=o["togglerLength"+_state],paneLen,offset,CSS={};if(spacing==0){$R.hide();return;}else if(!s.noRoom&&!s.isHidden)$R.show();if(dir=="horz"){paneLen=$P.outerWidth();$R.css({width:max(1,cssW($R,paneLen)),height:max(1,cssH($R,spacing)),left:cssNum($P,"left")});}else{paneLen=$P.outerHeight();$R.css({height:max(1,cssH($R,paneLen)),width:max(1,cssW($R,spacing)),top:cDims.top+getPaneSize("north",true)});}if($T){if(togLen==0||(s.isSliding&&o.hideTogglerOnSlide)){$T.hide();return;}else
+$T.show();if(!(togLen>0)||togLen=="100%"||togLen>paneLen){togLen=paneLen;offset=0;}else{if(typeof togAlign=="string"){switch(togAlign){case"top":case"left":offset=0;break;case"bottom":case"right":offset=paneLen-togLen;break;case"middle":case"center":default:offset=Math.floor((paneLen-togLen)/2);}}else{var x=parseInt(togAlign);if(togAlign>=0)offset=x;else offset=paneLen-togLen+x;}}var
+$TC_o=(o.togglerContent_open?$T.children(".content-open"):false),$TC_c=(o.togglerContent_closed?$T.children(".content-closed"):false),$TC=(s.isClosed?$TC_c:$TC_o);if($TC_o)$TC_o.css("display",s.isClosed?"none":"block");if($TC_c)$TC_c.css("display",s.isClosed?"block":"none");if(dir=="horz"){var width=cssW($T,togLen);$T.css({width:max(0,width),height:max(1,cssH($T,spacing)),left:offset});if($TC)$TC.css("marginLeft",Math.floor((width-$TC.outerWidth())/2));}else{var height=cssH($T,togLen);$T.css({height:max(0,height),width:max(1,cssW($T,spacing)),top:offset});if($TC)$TC.css("marginTop",Math.floor((height-$TC.outerHeight())/2));}}if(onInit&&o.initHidden){$R.hide();if($T)$T.hide();}});};var resizeAll=function(){var
+oldW=cDims.innerWidth,oldH=cDims.innerHeight;cDims=state.container=getElemDims($Container);var
+checkH=(cDims.innerHeight<oldH),checkW=(cDims.innerWidth<oldW),s,dir;if(checkH||checkW)$.each(["south","north","east","west"],function(i,pane){s=state[pane];dir=c[pane].dir;if(!s.isClosed&&((checkH&&dir=="horz")||(checkW&&dir=="vert"))){setPaneMinMaxSizes(pane);if(s.size>s.maxSize)sizePane(pane,s.maxSize);}});sizeMidPanes("all");sizeHandles("all");};function keyDown(evt){if(!evt)return true;var code=evt.keyCode;if(code<33)return true;var
+PANE={38:"north",40:"south",37:"west",39:"east"},isCursorKey=(code>=37&&code<=40),ALT=evt.altKey,SHIFT=evt.shiftKey,CTRL=evt.ctrlKey,pane=false,s,o,k,m,el;if(!CTRL&&!SHIFT)return true;else if(isCursorKey&&options[PANE[code]].enableCursorHotkey)pane=PANE[code];else
+$.each(c.borderPanes.split(","),function(i,p){o=options[p];k=o.customHotkey;m=o.customHotkeyModifier;if((SHIFT&&m=="SHIFT")||(CTRL&&m=="CTRL")||(CTRL&&SHIFT)){if(k&&code==(isNaN(k)||k<=9?k.toUpperCase().charCodeAt(0):k)){pane=p;return false;}}});if(!pane)return true;o=options[pane];s=state[pane];if(!o.enableCursorHotkey||s.isHidden||!$Ps[pane])return true;el=evt.target||evt.srcElement;if(el&&SHIFT&&isCursorKey&&(el.tagName=="TEXTAREA"||(el.tagName=="INPUT"&&(code==37||code==39))))return true;toggle(pane);evt.stopPropagation();evt.returnValue=false;return false;};function allowOverflow(elem){if(this&&this.tagName)elem=this;var $P;if(typeof elem=="string")$P=$Ps[elem];else{if($(elem).attr("pane"))$P=$(elem);else $P=$(elem).parents("div[pane]:first");}if(!$P.length)return;var
+pane=$P.attr("pane"),s=state[pane];if(s.cssSaved)resetOverflow(pane);if(s.isSliding||s.isResizing||s.isClosed){s.cssSaved=false;return;}var
+newCSS={zIndex:(c.zIndex.pane_normal+1)},curCSS={},of=$P.css("overflow"),ofX=$P.css("overflowX"),ofY=$P.css("overflowY");if(of!="visible"){curCSS.overflow=of;newCSS.overflow="visible";}if(ofX&&ofX!="visible"&&ofX!="auto"){curCSS.overflowX=ofX;newCSS.overflowX="visible";}if(ofY&&ofY!="visible"&&ofY!="auto"){curCSS.overflowY=ofX;newCSS.overflowY="visible";}s.cssSaved=curCSS;$P.css(newCSS);$.each(c.allPanes.split(","),function(i,p){if(p!=pane)resetOverflow(p);});};function resetOverflow(elem){if(this&&this.tagName)elem=this;var $P;if(typeof elem=="string")$P=$Ps[elem];else{if($(elem).hasClass("ui-layout-pane"))$P=$(elem);else $P=$(elem).parents("div[pane]:first");}if(!$P.length)return;var
+pane=$P.attr("pane"),s=state[pane],CSS=s.cssSaved||{};if(!s.isSliding&&!s.isResizing)$P.css("zIndex",c.zIndex.pane_normal);$P.css(CSS);s.cssSaved=false;};function getBtn(selector,pane,action){var
+$E=$(selector),err="Error Adding Button \n\nInvalid ";if(!$E.length)alert(err+"selector: "+selector);else if(c.borderPanes.indexOf(pane)==-1)alert(err+"pane: "+pane);else{var btn=options[pane].buttonClass+"-"+action;$E.addClass(btn+" "+btn+"-"+pane);return $E;}return false;};function addToggleBtn(selector,pane){var $E=getBtn(selector,pane,"toggle");if($E)$E.attr("title",state[pane].isClosed?"Open":"Close").click(function(evt){toggle(pane);evt.stopPropagation();});};function addOpenBtn(selector,pane){var $E=getBtn(selector,pane,"open");if($E)$E.attr("title","Open").click(function(evt){open(pane);evt.stopPropagation();});};function addCloseBtn(selector,pane){var $E=getBtn(selector,pane,"close");if($E)$E.attr("title","Close").click(function(evt){close(pane);evt.stopPropagation();});};function addPinBtn(selector,pane){var $E=getBtn(selector,pane,"pin");if($E){var s=state[pane];$E.click(function(evt){setPinState($(this),pane,(s.isSliding||s.isClosed));if(s.isSliding||s.isClosed)open(pane);else close(pane);evt.stopPropagation();});setPinState($E,pane,(!s.isClosed&&!s.isSliding));c[pane].pins.push(selector);}};function syncPinBtns(pane,doPin){$.each(c[pane].pins,function(i,selector){setPinState($(selector),pane,doPin);});};function setPinState($Pin,pane,doPin){var updown=$Pin.attr("pin");if(updown&&doPin==(updown=="down"))return;var
+root=options[pane].buttonClass,class1=root+"-pin",class2=class1+"-"+pane,UP1=class1+"-up",UP2=class2+"-up",DN1=class1+"-down",DN2=class2+"-down";$Pin.attr("pin",doPin?"down":"up").attr("title",doPin?"Un-Pin":"Pin").removeClass(doPin?UP1:DN1).removeClass(doPin?UP2:DN2).addClass(doPin?DN1:UP1).addClass(doPin?DN2:UP2);};var
+$Container=$(this).css({overflow:"hidden"}),$Ps={},$Cs={},$Rs={},$Ts={},c=config,cDims=state.container;create();return{options:options,state:state,panes:$Ps,toggle:toggle,open:open,close:close,hide:hide,show:show,resizeContent:sizeContent,sizePane:sizePane,resizeAll:resizeAll,addToggleBtn:addToggleBtn,addOpenBtn:addOpenBtn,addCloseBtn:addCloseBtn,addPinBtn:addPinBtn,allowOverflow:allowOverflow,resetOverflow:resetOverflow,cssWidth:cssW,cssHeight:cssH};}})(jQuery);
More information about the Mapbender_commits
