[Mapbender-commits] r6125 - branches/3_dev/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun May 9 12:49:37 EDT 2010
Author: astrid_emde
Date: 2010-05-09 12:49:36 -0400 (Sun, 09 May 2010)
New Revision: 6125
Added:
   branches/3_dev/http/plugins/mod_box1.js
   branches/3_dev/http/plugins/mod_pan.js
   branches/3_dev/http/plugins/mod_selArea.js
   branches/3_dev/http/plugins/mod_zoomIn1.js
   branches/3_dev/http/plugins/mod_zoomOut1.js
navigation modules
Added: branches/3_dev/http/plugins/mod_box1.js
--- branches/3_dev/http/plugins/mod_box1.js	                        (rev 0)
+++ branches/3_dev/http/plugins/mod_box1.js	2010-05-09 16:49:36 UTC (rev 6125)
@@ -0,0 +1,231 @@
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+Mapbender.Box = function (options) {
+	var map = (typeof options.target !== "undefined") ?
+		getMapObjByName(options.target) : null;
+	var color = (typeof options.color !== "undefined") ?
+		options.color : "#ff0000";
+	var isActive = false;
+	var top = 0;
+	var topSuffix = "_l_top";
+	var topNode;
+	var left = 0;
+	var leftSuffix = "_l_left";
+	var leftNode;
+	var bottom = 0;
+	var bottomSuffix = "_l_bottom";
+	var bottomNode;
+	var right = 0;
+	var rightSuffix = "_l_right";
+	var rightNode;
+	var startPos = null;
+	var stopPos = null;
+	var exists = false;
+	var that = this;
+	this.start = function (e) {
+		if (!map) {
+			return;
+		$(map.getDomElement()).mousemove(function (e) {
+			that.run(e);
+			return false;
+		isActive = true;
+		var click = map.getMousePosition(e);
+		startPos = new Point(click.x, click.y);
+		stopPos = new Point(click.x, click.y);
+		top = click.y;
+		left = click.y;
+		bottom = click.y;
+		right = click.x;
+	this.run = function (e) {
+		var pos = map.getMousePosition(e);
+		if (pos !== null) {
+			stopPos = pos;
+			var width = map.width;
+			var height = map.height;
+			if (startPos.x > stopPos.x) {
+				right = startPos.x;
+				left = stopPos.x;
+			else {
+				left = startPos.x;
+				right = stopPos.x;
+			if (startPos.y > stopPos.y) {
+				bottom = startPos.y;
+				top = stopPos.y;
+			else {
+				top = startPos.y;
+				bottom = stopPos.y;
+			if (!startPos.equals(stopPos)) {
+				this.draw();
+		return true;
+	this.stop = function (e, callback) {
+		$(map.getDomElement()).unbind("mousemove");
+		hideElement(topNode);
+		hideElement(leftNode);
+		hideElement(rightNode);
+		hideElement(bottomNode);
+		if (isActive) {
+			isActive = false;
+			if (typeof callback === "function") {
+				return callback(getExtent());
+			return getExtent();
+		isActive = false;
+	var arrangeBox = function (node, left, top, right, bottom) {
+		var el = node.style;
+		el.height = Math.abs(bottom - top);
+		el.width = Math.abs(right - left);
+		el.top = top + "px";
+		el.left = left + "px";
+	var displayElement = function (node) {
+		node.style.visibility = "visible";
+	var hideElement = function (node) {
+		node.style.visibility = "hidden";
+	var domElementsExist = function () {
+		if (!map) {
+			return;
+		return map.getDomElement(
+			).ownerDocument.getElementById(
+			map.elementName + topSuffix
+			) !== null;
+	var createDomElements = function () {
+		if (!map) {
+			return;
+		var map_el = map.getDomElement();
+		topNode = map_el.ownerDocument.createElement("div");
+		topNode.style.position = "absolute";
+		topNode.style.top = "0px";
+		topNode.style.left = "0px";
+		topNode.style.width = "0px";
+		topNode.style.height = "0px";
+		topNode.style.overflow = "hidden";
+//		topNode.style.zIndex = parseInt(map_el.style.zIndex, 10) + 1;
+		topNode.style.zIndex = 100;
+		topNode.style.visibility = "visible";
+		topNode.style.cursor = "crosshair";
+		topNode.style.backgroundColor = color;
+		leftNode = topNode.cloneNode(false);
+		rightNode = topNode.cloneNode(false);
+		bottomNode = topNode.cloneNode(false);
+		topNode.id = map.elementName + topSuffix;
+		leftNode.id = map.elementName + leftSuffix;
+		rightNode.id = map.elementName + rightSuffix;
+		bottomNode.id = map.elementName + bottomSuffix;
+		map_el.appendChild(topNode);
+		map_el.appendChild(leftNode);
+		map_el.appendChild(rightNode);
+		map_el.appendChild(bottomNode);
+		exists = true;
+	this.draw = function (extent) {
+		if (!map) {
+			return;
+		if (typeof extent === "object"
+			&& extent.constructor === Mapbender.Extent) {
+			left = extent.min.x;
+			right = extent.max.x;
+			bottom = extent.min.y;
+			top = extent.max.y;
+		arrangeBox(topNode, left, top, right, top + 2);
+		arrangeBox(leftNode, left, top, left + 2, bottom);
+		arrangeBox(rightNode, right - 2, top, right, bottom);
+		arrangeBox(bottomNode, left, bottom - 2, right, bottom);
+		displayElement(topNode);
+		displayElement(leftNode);
+		displayElement(rightNode);
+		displayElement(bottomNode);
+	var getExtent = function () {
+		if (!map) {
+			return null;
+		var x1 = startPos.x;
+		var x2 = stopPos.x;
+		var y1 = startPos.y;
+		var y2 = stopPos.y;
+		var minx = x2;
+		var maxx = x1;
+		if(x1 < x2){
+			minx = x1;
+			maxx = x2;
+		var miny = y1;
+		var maxy = y2;
+		if(y1 < y2){
+			miny = y2;
+			maxy = y1;
+		// area or clickpoint ?
+		var posMin = map.convertPixelToReal(new Point(minx,miny));
+		if((maxx - minx) > 3 && (miny - maxy) > 3){
+			var posMax = map.convertPixelToReal(new Point(maxx,maxy));
+			return new Mapbender.Extent(posMin, posMax);
+		return posMin;
+	if (!domElementsExist()) {
+		createDomElements();
+	else {
+		topNode = document.getElementById(map.elementName + topSuffix);
+		leftNode = document.getElementById(map.elementName + leftSuffix);
+		rightNode = document.getElementById(map.elementName + rightSuffix);
+		bottomNode = document.getElementById(map.elementName + bottomSuffix);
Added: branches/3_dev/http/plugins/mod_pan.js
--- branches/3_dev/http/plugins/mod_pan.js	                        (rev 0)
+++ branches/3_dev/http/plugins/mod_pan.js	2010-05-09 16:49:36 UTC (rev 6125)
@@ -0,0 +1,98 @@
+ * Package: selArea
+ * Description:
+ * Zoom by rectangle
+ * Files:
+ *  - http/javascripts/mod_selArea.js
+ * SQL:
+ * > <SQL for element>
+ * > <SQL for element var>
+ * Help:
+ * http://www.mapbender.org/SelArea1
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+var that = this;
+Mapbender.events.init.register(function () {
+	var mb_panActive = false;
+	var startPos, stopPos;
+	var map = Mapbender.modules[options.target];
+	var button = new Mapbender.Button({
+		domElement: that,
+		over: options.src.replace(/_off/, "_over"),
+		on: options.src.replace(/_off/, "_on"),
+		off: options.src,
+		name: options.id,
+		go: function () {
+			if (!map) {
+				new Mb_exception(options.id + ": " +
+					options.target + " is not a map!");
+				return;
+				.css("cursor", "move")
+				.mousedown(function (e) {
+				mb_panActive = true;
+				startPos = map.getMousePosition(e);
+				stopPos = new Mapbender.Point(startPos);
+				return false;
+			}).mousemove(function (e) {
+				if (!mb_panActive) {
+					return false;
+				stopPos = map.getMousePosition(e);
+				var dif = stopPos.minus(startPos);
+				map.moveMap(dif.x, dif.y);
+				if (!$.browser.msie){
+					return true;
+				return false;
+			}).mouseup(function (e) {
+					return false;
+				if (!map) {
+					return false;
+				mb_panActive = false;
+				var widthHeight = new Mapbender.Point(
+					map.getWidth(),
+					map.getHeight()
+				var center = widthHeight.times(0.5).minus(dif);
+				var realCenter = map.convertPixelToReal(center);
+				map.moveMap();
+				map.zoom(false, 1.0, realCenter);
+				return false;
+		stop: function () {
+			if (!map) {
+				return false;
+				.css("cursor", "default")
+				.unbind("mousedown")
+				.unbind("mouseup")
+				.unbind("mousemove");
Added: branches/3_dev/http/plugins/mod_selArea.js
--- branches/3_dev/http/plugins/mod_selArea.js	                        (rev 0)
+++ branches/3_dev/http/plugins/mod_selArea.js	2010-05-09 16:49:36 UTC (rev 6125)
@@ -0,0 +1,85 @@
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * License:
+var that = this;
+	var box;
+		domElement: that,
+		off: options.src,
+		name: options.id,
+		go: function () {
+			if (!map) {
+				return;
+			box = new Mapbender.Box({
+				target: options.target
+			$(map.getDomElement()).css(
+				"cursor", "crosshair"
+			).mousedown(function (e) {
+				box.start(e);
+				return false;
+				box.stop(e, function (extent) {
+					if (typeof extent === "undefined") {
+						return false;
+					if (extent.constructor === Mapbender.Extent) {
+						var xt = map.calculateExtent(extent);
+						map.setMapRequest();
+					else if (extent.constructor === Mapbender.Point) {
+						map.setCenter(extent);
+				return false;
+			if (!map) {
+				return;
+			box = null;
\ No newline at end of file
Added: branches/3_dev/http/plugins/mod_zoomIn1.js
--- branches/3_dev/http/plugins/mod_zoomIn1.js	                        (rev 0)
+++ branches/3_dev/http/plugins/mod_zoomIn1.js	2010-05-09 16:49:36 UTC (rev 6125)
@@ -0,0 +1,44 @@
+ * Package: ZoomIn1
+ * Description:
+ * Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). Image size is not affected.
+ * Files:
+ *  - http/javascripts/mod_zoomIn1.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
+ * > e_comment, e_title, e_element, e_src, e_attributes, e_left,
+ * > e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+ * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+ * > VALUES('gui', 'zoomIn1', 2, 1, 'zoomIn button','Zoom in',
+ * > 'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
+ * > '','','','mod_zoomIn1.js','','mapframe1','',
+ * > 'http://www.mapbender.org/index.php/ZoomIn');
+ * Maintainer:
+ * License:
+$(this).click(function () {
+	if (!options.target
+		|| !Mapbender.modules[options.target]
+		|| typeof Mapbender.modules[options.target].zoom !== "function") {
+		return;
+	Mapbender.modules[options.target].zoom(true, 2.0);
+}).mouseover(function () {
+	if (options.src) {
+		this.src = options.src.replace(/_off/, "_over");
+}).mouseout(function () {
+		this.src = options.src;
Added: branches/3_dev/http/plugins/mod_zoomOut1.js
--- branches/3_dev/http/plugins/mod_zoomOut1.js	                        (rev 0)
+++ branches/3_dev/http/plugins/mod_zoomOut1.js	2010-05-09 16:49:36 UTC (rev 6125)
@@ -0,0 +1,48 @@
+ * Package: ZoomOut1
+ * Description:
+ * Click button, which doubles the real world bounding box of the visible
+ * map section, halfes the scale (doubles the scale number). Image size
+ * is not affected.
+ * Files:
+ *  - http/javascripts/mod_zoomOut1.js
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','zoomOut1',
+ * > 2,1,'zoomOut button','Zoom out','img',
+ * > '../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','',
+ * > 'mod_zoomOut1.js','','mapframe1','',
+ * > 'http://www.mapbender.org/index.php/ZoomOut');
+ * Help:
+ * http://www.mapbender.org/ZoomOut
+ * Maintainer:
+ * License:
+		|| !Mapbender.modules[options.target]) {
+		return;
+	Mapbender.modules[options.target].zoom(false, 2.0);
More information about the Mapbender_commits mailing list
