[Mapbender-commits] r6150 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 10 09:25:41 EDT 2010
Author: christoph
Date: 2010-05-10 09:25:39 -0400 (Mon, 10 May 2010)
New Revision: 6150
   trunk/mapbender/http/plugins/mb_metadata_edit.js
   trunk/mapbender/http/plugins/mb_metadata_edit.php
   trunk/mapbender/http/plugins/mb_metadata_layer.js
   trunk/mapbender/http/plugins/mb_metadata_server.php
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_edit.js	2010-05-10 12:32:29 UTC (rev 6149)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.js	2010-05-10 13:25:39 UTC (rev 6150)
@@ -35,7 +35,9 @@
 	this.serialize = function (callback) {
 		var data = $metadataForm.easyform("serialize");
 		if ($.isFunction(callback)) {
-			callback(data);
+			callback({
+				wms: data
 		return data;
Modified: trunk/mapbender/http/plugins/mb_metadata_edit.php
--- trunk/mapbender/http/plugins/mb_metadata_edit.php	2010-05-10 12:32:29 UTC (rev 6149)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.php	2010-05-10 13:25:39 UTC (rev 6150)
@@ -34,9 +34,24 @@
 		<input name="accessconstraints" id="accessconstraints"/>
     	<img class="metadata_img" src="../img/misc/inspire_eu_klein.png"></img>
 	</p>
+<?php
+	$sql = "SELECT termsofuse_id, name FROM termsofuse";
+	$res = db_query($sql);
+	$termsofuse = array();
+	while ($row = db_fetch_assoc($res)) {
+		$termsofuse[$row["termsofuse_id"]] = $row["name"];
 	<p>
-		<label for="">WMS Predefined Licence (Registry):</label>
-    	<input name="" id""/>
+		<label for="wms_termsofuse">WMS Predefined Licence (Registry):</label>
+    	<select name="wms_termsofuse" id="wms_termsofuse">
+			<option>...</option>
+<?php
+	foreach ($termsofuse as $key => $value) {
+		echo "<option value='" . $key . "'>" . htmlentities($value, ENT_QUOTES, CHARSET) . "</option>";
+		</select>
     	<img class="metadata_img" src="../img/questionmark.png"></img>
 	</p>
 	<p>
@@ -90,12 +105,12 @@
 	</p>
 	<p>
 	  	<label for="wms_timestamp_create">Date of first registration (Registry):</label>
-      	<input name="wms_timestamp_create" id="wms_timestamp_create"/>
+      	<input disabled="disabled" name="wms_timestamp_create" id="wms_timestamp_create"/>
 	</p>
 	<p>
 	  	<label for="wms_timestamp">Date of last revision (Registry):</label>
-      	<td><input name="wms_timestamp" id="wms_timestamp"/>
+      	<td><input disabled="disabled" name="wms_timestamp" id="wms_timestamp"/>
 	</p>
 </fieldset>
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-05-10 12:32:29 UTC (rev 6149)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-05-10 13:25:39 UTC (rev 6150)
@@ -35,7 +35,9 @@
-			callback(data);
+			callback({
+				layer: data
 		return data;
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2010-05-10 12:32:29 UTC (rev 6149)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2010-05-10 13:25:39 UTC (rev 6150)
@@ -121,6 +121,20 @@
 		$resultObj["wms_keywords"] = implode(", ", $keywords);
+		$termsofuseSql = <<<SQL
+SELECT fkey_termsofuse_id FROM wms_termsofuse WHERE fkey_wms_id = $wmsId
+SQL;
+		$termsofuseRes = db_query($termsofuseSql);
+		if ($termsofuseRes) {
+			$termsofuseRow = db_fetch_assoc($termsofuseRes);
+			$resultObj["wms_termsofuse"] = $termsofuseRow["fkey_termsofuse_id"];
+		else {
+			$resultObj["wms_termsofuse"] = null;
 		$ajaxResponse->setResult($resultObj);
 		$ajaxResponse->setSuccess(true);
More information about the Mapbender_commits mailing list
