[Mapbender-commits] r6170 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 11 08:43:04 EDT 2010
Author: christoph
Date: 2010-05-11 08:43:02 -0400 (Tue, 11 May 2010)
New Revision: 6170
   trunk/mapbender/http/plugins/mb_metadata_layer.js
   trunk/mapbender/http/plugins/mb_metadata_layer.php
   trunk/mapbender/http/plugins/mb_metadata_server.php
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-05-11 11:33:43 UTC (rev 6169)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js	2010-05-11 12:43:02 UTC (rev 6170)
@@ -20,11 +20,12 @@
 var $metadataLayer = $(this);
-var $metadataForm = $("<form>No WMS selected.</form>").appendTo($metadataLayer);
+var $metadataForm = $("<form>No layer selected.</form>").appendTo($metadataLayer);
 var MetadataLayerApi = function (o) {
 	var that = this;
 	var validator;
+	var formReady = false;
 	this.valid = function () {
 		if (validator && validator.numberOfInvalids() > 0) {
@@ -48,21 +49,6 @@
 		submit: new Mapbender.Event()
-	var initialized = function (obj) {
-		for (var id in obj.categories) {
-			var cat = obj.categories[id];
-			var $select = $metadataForm.find("#" + id);
-			for (var j = 0; j < cat.length; j++) {
-				$select.append("<option value='" + cat[j][0] + "'>" + cat[j][1] + "</option>");
-		that.events.initialized.trigger({
-			wmsId: obj.wmsId
-		that.events.initialized.done = true;
 	this.fillForm = function (obj) {
 		// layer data
 		$metadataForm.easyform("reset");
@@ -117,38 +103,34 @@
-	this.init = function (obj) {
-		if (!that.events.initialized.done) {
+	this.init = function (wmsId) {
+		var formData = arguments.length >= 2 ? arguments[1] : undefined;
+		if (!formReady) {
 			$metadataForm.load("../plugins/mb_metadata_layer.php", function () {
 				validator = $metadataForm.validate();
-				var req = new Mapbender.Ajax.Request({
-					url: "../plugins/mb_metadata_server.php",
-					method: "getCategories",
-					parameters: {
-						"id": obj
-					callback: function(o, r, m) {
-						if (!r) {
-							return;
-						initialized($.extend({
-							wmsId: obj
-						}, o));
+				that.events.initialized.trigger({
+					wmsId: wmsId
-				req.send();
+				formReady = true;
+				// select layer in tree if set
+				// fill layer form if set
 			return;
-			wmsId: obj
+			wmsId: wmsId
 	Mapbender.events.localize.register(function () {
 		that.valid();
+		var formData = $metadataForm.easyform("serialize");
+		formReady = false;
+		that.init(wmsId, formData);
 	Mapbender.events.init.register(function () {
 		that.valid();
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.php
--- trunk/mapbender/http/plugins/mb_metadata_layer.php	2010-05-11 11:33:43 UTC (rev 6169)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.php	2010-05-11 12:43:02 UTC (rev 6170)
@@ -1,8 +1,6 @@
 <?php
 	require_once dirname(__FILE__) . "/../../core/globalSettings.php";
-	$firephp->log($_SESSION);
 	function displayCategories ($sql) {
 		if (Mapbender::session()->get("mb_lang") === "de") {
 			$sql = str_replace("category_code_en", "category_code_de", $sql);
@@ -82,7 +80,7 @@
 		</p>
 	</fieldset>
 </div>
-<div id="map">
+<div id="preview">
 	<fieldset class="">
 		<legend>Preview</legend>
 		<div id="map"></div>
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2010-05-11 11:33:43 UTC (rev 6169)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2010-05-11 12:43:02 UTC (rev 6170)
@@ -139,37 +139,7 @@
 		$ajaxResponse->setSuccess(true);
 		break;
-	case "getCategories":
-		$resultObj = array(
-			"categories" => array(
-				"fkey_md_topic_category_id" => array(),
-				"fkey_inspire_category_id" => array(),
-				"fkey_custom_category_id" => array()
-		$sql = "SELECT md_topic_category_id, md_topic_category_code_en FROM md_topic_category";
-		$res = db_query($sql);
-		while ($row = db_fetch_row($res)) {
-			$resultObj["categories"]["fkey_md_topic_category_id"][]= $row;
-		$sql = "SELECT inspire_category_id, inspire_category_code_en FROM inspire_category";
-			$resultObj["categories"]["fkey_inspire_category_id"][]= $row;
-		$sql = "SELECT custom_category_id, custom_category_code_en FROM custom_category";
-			$resultObj["categories"]["fkey_custom_category_id"][]= $row;
-		$ajaxResponse->setResult($resultObj);
-		$ajaxResponse->setSuccess(true);
-		break;
 	case "getLayerMetadata" :
 		$layerId = $ajaxResponse->getParameter("id");
 		getLayer($layerId);
More information about the Mapbender_commits mailing list
