[Mapbender-commits] r6212 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 19 09:01:06 EDT 2010
Author: verenadiewald
Date: 2010-05-19 09:01:01 -0400 (Wed, 19 May 2010)
New Revision: 6212
   trunk/mapbender/http/php/mod_wmc_publish.php
some changes for xml and openlayers preview
Modified: trunk/mapbender/http/php/mod_wmc_publish.php
--- trunk/mapbender/http/php/mod_wmc_publish.php	2010-05-18 14:02:07 UTC (rev 6211)
+++ trunk/mapbender/http/php/mod_wmc_publish.php	2010-05-19 13:01:01 UTC (rev 6212)
@@ -8,6 +8,7 @@
 		<title>Untitled Document</title>
 		<link rel="stylesheet" type="text/css" href="../extensions/dataTables-1.5/media/css/demo_table_jui.css">
 		<link rel="stylesheet" type="text/css" href="../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css">
+		<link rel="stylesheet" type="text/css" href="../css/popup.css">
 		<script type='text/javascript'>
 			var loadFromSession = false;
 <?php
@@ -26,9 +27,15 @@
 echo "var global_mb_log_level = '".LOG_LEVEL."';";
 echo "var global_log_levels = '".LOG_LEVEL_LIST."';";
+echo "Mapbender.sessionId = '".session_id()."';\n";
+echo "var mb_nr = Mapbender.sessionId;\n";
+echo "Mapbender.sessionName = '".session_name()."';\n";
+echo "var mb_session_name = Mapbender.sessionName;\n";
 	require_once(dirname(__FILE__) . "/../../lib/exception.js");
 	require_once(dirname(__FILE__) . "/../../lib/ajax.js");
 	require_once(dirname(__FILE__) . "/../../lib/basic.js");
+	require_once(dirname(__FILE__) . "/../javascripts/popup.js");
 	header('Content-type: text/html');
 	$(function () {
More information about the Mapbender_commits mailing list
