[Mapbender-commits] r6993 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 1 09:21:29 EDT 2010
Author: christoph
Date: 2010-10-01 13:21:29 +0000 (Fri, 01 Oct 2010)
New Revision: 6993
   trunk/mapbender/http/classes/class_wmc.php
added function removeWms
formatting
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2010-10-01 13:19:53 UTC (rev 6992)
+++ trunk/mapbender/http/classes/class_wmc.php	2010-10-01 13:21:29 UTC (rev 6993)
@@ -30,41 +30,41 @@
  * Implementation of a Web Map Context Document, WMC 1.1.0
  * Use cases:
  * Instantiation (1) create a WMC object from a WMC XML document
  * 		$myWmc = new wmc();
  * 		$myWmc->createFromXml($xml);
  *    If you want to create a WMC object from a WMC in the database
  *    	$xml = wmc::getDocument($wmcId);
  * Instantiation (2) create a WMC from the client side
  * 		$myWmc->createFromJs($mapObject, $generalTitle, $extensionData);
  * 	  	(creates a WMC from the JS data and then creates an object from that WMC)
  * Output (1) (do Instantiation first) Load a WMC into client
  * 		This will return an array of JS statements
  * 		$myWmc->toJavaScript();
  * Output (2) (do Instantiation first) Merge with another WMC, then load
  * 		$myWmc->merge($anotherWmcXml);
 class wmc {
-	 * Representing the main map in a map application
-	 * @var Map
+ * Representing the main map in a map application
+ * @var Map
 	var $mainMap;
@@ -83,17 +83,17 @@
 	 * @var String
 	var $xml;
 	// constants
 	var $saveWmcAsFile = false;
 	var $extensionNamespace = "mapbender";
 	var $extensionNamespaceUrl = "http://www.mapbender.org/context";
 	// set in constructor
 	var $wmc_id;
 	var $userId;
-    var $timestamp;
-    var $public;
+	var $timestamp;
+	var $public;
 	// set during parsing
 	var $wmc_version;
@@ -124,21 +124,21 @@
 	var $wmc_descriptionurl_format;
 	var $wmc_descriptionurl_type;
-	var $inspireCats;
+	var $inspireCats;
 	public function __construct () {
 		$this->userId = Mapbender::session()->get("mb_user_id");
 		$this->wmc_id = time();
 		$this->timestamp = time();
 	// INSTANTIATION
 	 * Parses the XML string and instantiates the WMC object.
 	 * @param $xml String
 	public function createFromXml ($xml) {
@@ -147,37 +147,34 @@
 	 * Loads a WMC from the database.
 	 * @param integer $wmc_id the ID of the WMC document in the database table "mb_user_wmc"
-	function createFromDb($wmcId){
+	function createFromDb($wmcId) {
 		$doc = wmc::getDocument($wmcId);
 		if ($doc === false) {
 			return false;
 		$this->createObjFromWMC_xml($doc);
-        $sql = "SELECT wmc_timestamp, wmc_title, wmc_public " .
+		$sql = "SELECT wmc_timestamp, wmc_title, wmc_public " .
 			"FROM mb_user_wmc WHERE wmc_id = $1 AND (fkey_user_id = $2 OR wmc_public = 1)";
-        $v = array($wmcId, Mapbender::session()->get("mb_user_id"));
-        $t = array("s", "i");
-        $res = db_prep_query($sql,$v,$t);
-        if(db_error()) { return false; }
-        if($row = db_fetch_row($res)) {
-          $this->wmc_id = $wmcId;
-          $this->timestamp = $row[0];
-          $this->title = $row[1];
-          $this->public = $row[2];
-		else {
-			return false;
+		$v = array($wmcId, Mapbender::session()->get("mb_user_id"));
+		$t = array("s", "i");
+		$res = db_prep_query($sql,$v,$t);
+		if(db_error()) { return false; }
+		if($row = db_fetch_row($res)) {
+			$this->wmc_id = $wmcId;
+			$this->timestamp = $row[0];
+			$this->title = $row[1];
+			$this->public = $row[2];
+			return true;
-		return true;
+		return false;
 	public function createFromApplication ($appId) {
-		// get the map objects "overview" and "mapframe1"
+	// get the map objects "overview" and "mapframe1"
 		$this->mainMap = map::selectMainMapByApplication($appId);
 		$this->overviewMap = map::selectOverviewMapByApplication($appId);
 		$this->createXml();
@@ -186,30 +183,30 @@
 	 * Creates a WMC object from a JS map object {@see map_obj.js}
 	 * @param object $mapObject a map object
 	 * @param integer $user_id the ID of the current user
 	 * @param string $generalTitle the desired title of the WMC
-	 * @param object $extensionData data exclusive to Mapbender, which will be
+	 * @param object $extensionData data exclusive to Mapbender, which will be
 	 * 								mapped into the extension part of the WMC
 	public function createFromJs($mapObject, $generalTitle,$extensionData, $id=null) {
 		if (count($mapObject) > 2) {
 			$e = new mb_exception("Save WMC only works for two concurrent map frames (overview plus main) at the moment.");
-		// set extension data
+		// set extension data
 		$this->generalExtensionArray = $extensionData;
 		if ($id) {
-			//set id
+		//set id
 			$this->wmc_id = $id;
 		// set title
 		$this->wmc_title = $generalTitle;
 		// create the map objects
 		for ($i = 0; $i < count($mapObject); $i++) {
 			$currentMap = new Map();
@@ -223,14 +220,14 @@
 		// create XML
 		$this->createXml();
 		$this->saveAsFile();
 		return true;
 	// DATABASE FUNCTIONS
@@ -239,8 +236,8 @@
 		$sql .= "WHERE wmc_public = 1 GROUP BY wmc_id";
 		$res_wmc = db_query($sql);
-  		$wmcArray = array();
-		while($row = db_fetch_array($res_wmc)){
+		$wmcArray = array();
+		while($row = db_fetch_array($res_wmc)) {
 			array_push($wmcArray, $row["wmc_id"]);
 		return $wmcArray;
@@ -248,12 +245,12 @@
 	public function getAccessibleWmcs ($user) {
-		// get WMC ids
+		// get WMC ids
 		$wmcOwnerArray = $user->getWmcByOwner();
 		$publicWmcIdArray = $this->getPublicWmcIds();
 		return array_keys( array_flip(array_merge($wmcOwnerArray, $publicWmcIdArray)));
@@ -261,47 +258,47 @@
 	public function selectByUser ($user) {
-		// get WMC ids
+		// get WMC ids
 		$publicWmcIdArray = self::getPublicWmcIds();
 		$wmcIdArray = array_keys( array_flip(array_merge($wmcOwnerArray, $publicWmcIdArray)));
 		// get WMC data
 		$v = array();
 		$t = array();
 		$wmcIdList = "";
 		for ($i = 0; $i < count($wmcIdArray); $i++) {
-			if ($i > 0) {
+			if ($i > 0) {
 				$wmcIdList .= ",";
 			$wmcIdList .= "$".($i+1);
 			array_push($v, $wmcIdArray[$i]);
 			array_push($t, 's');
 		if ($wmcIdList !== "") {
 			$sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp, wmc_timestamp_create, wmc_public, abstract FROM mb_user_wmc ";
 			$sql .= "WHERE wmc_id IN (" . $wmcIdList . ") ";
 			$sql .=	"ORDER BY wmc_timestamp DESC";
 			$res = db_prep_query($sql, $v, $t);
-			while($row = db_fetch_assoc($res)){
+			while($row = db_fetch_assoc($res)) {
 				$currentResult = array();
 				$currentResult["id"] = $row["wmc_id"];
 				$currentResult["abstract"] = $row["abstract"];
 				$currentResult["title"] = administration::convertIncomingString($row["wmc_title"]);
-				$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
-				$currentResult["timestamp_create"] = date("M d Y H:i:s", $row["wmc_timestamp_create"]);
+				$currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
+				$currentResult["timestamp_create"] = date("M d Y H:i:s", $row["wmc_timestamp_create"]);
 				$currentResult["isPublic"] = $row["wmc_public"] == 1? true: false;
 				$currentResult["disabled"] = ((
-					in_array($currentResult["id"], $publicWmcIdArray) &&
+					in_array($currentResult["id"], $publicWmcIdArray) &&
 					!in_array($currentResult["id"], $wmcOwnerArray)) || $user->isPublic()) ?
 					true : false;
 				// get categories
 				$currentResult["categories"] = $this->getCategoriesById($currentResult["id"], $user);
 				$currentResult["keywords"] = $this->getKeywordsById($currentResult["id"], $user);
@@ -316,10 +313,10 @@
 		if (!in_array($id, $wmcArray)) {
 			return array();
 		$keywordArray = array();
-		$sql = "SELECT DISTINCT k.keyword FROM keyword AS k, wmc_keyword AS w " .
+		$sql = "SELECT DISTINCT k.keyword FROM keyword AS k, wmc_keyword AS w " .
 			"WHERE w.fkey_keyword_id = k.keyword_id AND w.fkey_wmc_id = $1";
 		$v = array($id);
 		$t = array("s");
@@ -335,12 +332,12 @@
 			return array();
-		$sql = "SELECT DISTINCT t.md_topic_category_id FROM " .
-			"md_topic_category AS t, wmc_md_topic_category AS w " .
-			"WHERE w.fkey_md_topic_category_id = t.md_topic_category_id " .
+		$sql = "SELECT DISTINCT t.md_topic_category_id FROM " .
+			"md_topic_category AS t, wmc_md_topic_category AS w " .
+			"WHERE w.fkey_md_topic_category_id = t.md_topic_category_id " .
 			"AND w.fkey_wmc_id = $1";
 		$v = array($id);
 		$t = array("s");
@@ -351,10 +348,10 @@
 		return $keywordArray;
-    private function compareWms ($a, $b) {
+	private function compareWms ($a, $b) {
 		if ($a["id"] === $b["id"]) return 0;
-        return -1;
+		return -1;
 	public function getAllWms () {
 		$wmsArray = $this->mainMap->getWmsArray();
 		$resultObj = array();
@@ -364,56 +361,56 @@
 				continue;
 			$resultObj[]= array(
-				"title" => $wmsArray[$i]->wms_title,
+				"title" => $wmsArray[$i]->wms_title,
 				"id" => is_null($wmsArray[$i]->wms_id) ? null : intval($wmsArray[$i]->wms_id),
 				"index" => $i
 			$usedIds[]= $wmsArray[$i]->wms_id;
-		return $resultObj;
+		return $resultObj;
 	public function getWmsWithoutId () {
-		$wmsArray = $this->getAllWms();
+		$wmsArray = $this->getAllWms();
 		for ($i = 0; $i < count($wmsArray); $i++) {
 			if (is_numeric($wmsArray[$i]["id"])) {
 				continue;
-				"title" => $wmsArray[$i]["title"],
+				"title" => $wmsArray[$i]["title"],
 				"id" => $wmsArray[$i]["id"],
 				"index" => $i
 	public function getWmsWithId () {
 		return array_values(array_udiff(
-			$this->getAllWms(),
+			$this->getAllWms(),
 			$this->getWmsWithoutId(),
 			array("wmc", "compareWms")
 	public function getValidWms () {
 		$inv = $this->getInvalidWms();
 		$withId = $this->getWmsWithId();
-			$withId,
+			$withId,
 			$inv,
 	public function getInvalidWms () {
 		$wmsArray = $this->getWmsWithId();
 			$sql = "SELECT COUNT(wms_id) FROM wms WHERE wms_id = $1";
 			$v = array($wmsArray[$i]["id"]);
 			$t = array('i');
@@ -421,17 +418,17 @@
 			$layerRow = db_fetch_row($res);
 			if (intval($layerRow[0]) === 0) {
 					"id" => intval($wmsArray[$i]["id"]),
 					"index" => $wmsArray[$i]["index"]
 		return $resultObj;
 	public function getWmsWithPermission ($user) {
-		$wmsArray = $this->getValidWms();
+		$wmsArray = $this->getValidWms();
@@ -439,39 +436,39 @@
 			if ($user->isWmsAccessible($currentWmsId)) {
 					"id" => intval($currentWmsId),
 	public function getWmsWithoutPermission ($user) {
-			$this->getValidWms(),
-			$this->getWmsWithPermission($user),
-			array("wmc", "compareWms")
+		$this->getValidWms(),
+		$this->getWmsWithPermission($user),
+		array("wmc", "compareWms")
 	public function getAvailableWms ($user) {
-			$this->getUnavailableWms(),
+		$this->getUnavailableWms(),
 	public function getUnavailableWms ($user) {
 		$wmsArray = $this->getWmsWithPermission($user);
 			$currentWmsId = $wmsArray[$i]["id"];
-			$sql = "SELECT last_status FROM mb_wms_availability WHERE fkey_wms_id = $1";
+			$sql = "SELECT last_status FROM mb_wms_availability WHERE fkey_wms_id = $1";
 			$v = array($currentWmsId);
 			$t = array("i");
@@ -479,59 +476,59 @@
 			$status = intval($statusRow[0]);
 			if (isset($status) && $status < 0) {
 					"id" => $currentWmsId,
 	public function updateUrlsFromDb () {
 		$query_mbWMSId = "/wmc:ViewContext/wmc:LayerList/wmc:Layer/wmc:Extension/mapbender:wms_id";
 		try {
 			$WMCDoc = DOMDocument::loadXML($this->toXml());
 		catch (Exception $E) {
 			new mb_exception("WMC XML is broken.");
 		$xpath = new DOMXPath($WMCDoc);
 		$xpath->registerNamespace("wmc","http://www.opengis.net/context");
 		$xpath->registerNamespace("mapbender","http://www.mapbender.org/context");
 		$xpath->registerNamespace("xlink","http://www.w3.org/1999/xlink");
 		$WMSIdList = $xpath->query($query_mbWMSId);
 		foreach($WMSIdList as $WMSId) {
 			$id =  $WMSId->nodeValue;
-			$sql = "SELECT wms_timestamp,wms_getmap,wms_getlegendurl " .
-				"FROM wms WHERE wms_id = $1 AND " .
+			$sql = "SELECT wms_timestamp,wms_getmap,wms_getlegendurl " .
+				"FROM wms WHERE wms_id = $1 AND " .
 				"wms_owsproxy <> NULL AND wms_owsproxy <> ''";
 			$v = array($id);
 			$t = array("t");
 			if (db_error()) {
-				true;
+				true;
 			} //FIMXE: PROPER ERROR MESSAGE
 			if($row = db_fetch_array($res)) {
 				$wms_timestamp = $row["wms_timestamp"];
 				if ($this->timestamp < $wms_timestamp) {
 				// wmc is fresh, life is good
-				else{
+				else {
 					$MapResources = $xpath->query("../../wmc:Server/wmc:OnlineResource",$WMSId);
 					foreach($MapResources as $MapResource) {
 						$MapResource->setAttribute("xlink:href",$row["wms_getmap"]);
 					$LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
 					foreach ($LegendResources as $LegendResource) {
 						$base = $row["wms_getlegendurl"];
 						$origurl = explode('&', $LegendResource->getAttribute("xlink:href"),2);
-						$url = $base . $origurl[1];
+						$url = $base . $origurl[1];
 						$LegendResource->setAttribute("xlink:href",$url);
@@ -544,16 +541,16 @@
 	 * Stores this WMC in the database. The WMC has to be instantiated first, see above.
 	 * @return mixed[] an assoc array with attributes "success" (boolean) and "message" (String).
 	public function insert ($overwrite) {
 		$result = array();
 		if ($this->userId && $this->xml && $this->wmc_title) {
 			try {
 				$user = new user($this->userId);
 				$errMsg = "Error while saving WMC document " . $this->wmc_title . "': Invalud UserId";
 				$result["success"] = false;
@@ -561,19 +558,19 @@
 				$e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
 				return $result;
 			$overwrite  = ($user->isPublic())? false: $overwrite;
 			//put keywords into Document
 			try {
 			$NewDoc = new DOMDocument();
@@ -583,48 +580,48 @@
 			$query_general = "/wmc:ViewContext/wmc:General";
 			$DocKeywordLists = $xpath->query($query_KeywordList);
 			// we just use a single <general> element
 			$NewKeywordList = new DOMElement('KeywordList','','http://opengis.net/context');
 			$NewDoc->appendChild($NewKeywordList);
-	 		foreach($this->keyword as $keyword){
+			foreach($this->keyword as $keyword) {
 				$Keyword = new DOMElement('Keyword',$keyword, 'http://opengis.net/context');
 				$NewKeywordList->appendChild($Keyword);
-			$generalList = $xpath->query($query_general);
+			$generalList = $xpath->query($query_general);
 			$general = $generalList->item(0);
-			if($DocKeywordLists->item(0)){
+			if($DocKeywordLists->item(0)) {
 				$general->replaceChild($NewKeywordList,$DocKeywordList->item(0));
-			}else{
+			}else {
 				$tmpNode = $WMCDoc->importNode($NewKeywordList,true);
 				$general->appendChild($tmpNode);
 			$this->xml  = $WMCDoc->saveXML();
 			db_begin();
 			if($overwrite) {
-	            $findsql = "SELECT fkey_user_id,wmc_title,wmc_timestamp, wmc_id FROM mb_user_wmc WHERE fkey_user_id = $1 AND wmc_id = $2 ORDER BY wmc_timestamp DESC LIMIT 1;";
-	            $v = array($this->userId, $this->wmc_id);
-	            $t = array("i","i");
-	            $res = db_prep_query($findsql,$v,$t);
+				$findsql = "SELECT fkey_user_id,wmc_title,wmc_timestamp, wmc_id FROM mb_user_wmc WHERE fkey_user_id = $1 AND wmc_id = $2 ORDER BY wmc_timestamp DESC LIMIT 1;";
+				$v = array($this->userId, $this->wmc_id);
+				$t = array("i","i");
+				$res = db_prep_query($findsql,$v,$t);
 				if (db_error()) {
 					$errMsg = "Error while saving WMC document '" . $this->wmc_title . "': " . db_error();
 					$result["message"] = $errMsg;
-	                return $result;
+					return $result;
 					$sql = "UPDATE mb_user_wmc SET wmc = $1, wmc_timestamp = $2, abstract = $3, srs = $4, minx = $5, miny = $6,".
 						" maxx = $7, maxy = $8, wmc_title = $9 WHERE fkey_user_id = $10 AND wmc_id=$11 AND wmc_timestamp = $12;";
 					$v = array($this->xml, time(), $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->minx,
-						 $this->wmc_extent->maxx, $this->wmc_extent->maxy ,administration::convertOutgoingString($this->wmc_title), $this->userId, $this->wmc_id,$row[2]);
+						$this->wmc_extent->maxx, $this->wmc_extent->maxy ,administration::convertOutgoingString($this->wmc_title), $this->userId, $this->wmc_id,$row[2]);
 					$t = array("s", "s","s","s","i","i","i","i", "s", "i", "i","s");
 					// need the database Id
 					$wmc_DB_ID = $row[3];
@@ -632,18 +629,18 @@
 					$delv = array($wmc_DB_ID);
 					$delt = array("s");
 					db_prep_query($delsql, $delv,$delt);
 					$delkwsql = "DELETE FROM wmc_keyword WHERE fkey_wmc_id = $1;";
 					$delkwv = array($wmc_DB_ID);
 					$delkwt = array("s");
 					db_prep_query($delkwsql, $delkwv,$delkwt);
-				else{
-					$sql = "INSERT INTO mb_user_wmc (" .
-						"wmc_id, fkey_user_id, wmc, wmc_title, wmc_public, wmc_timestamp, wmc_timestamp_create, " .
+				else {
+					$sql = "INSERT INTO mb_user_wmc (" .
+						"wmc_id, fkey_user_id, wmc, wmc_title, wmc_public, wmc_timestamp, wmc_timestamp_create, " .
 						"abstract, srs, minx, miny, maxx, maxy ".
 						") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13);";
 					$v = array($this->wmc_id, $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $user->isPublic()?1:0,time(),time(),
@@ -651,75 +648,74 @@
 					$t = array("s", "i", "s", "s", "i", "s","s", "s","s","i","i","i", "i");
-			else{
+			else {
 				$v = array($this->wmc_id, $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $user->isPublic()?1:0, time(),time(),
-						$this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx,  $this->wmc_extent->miny, $this->wmc_extent->maxx, $this->wmc_extent->maxy);
+					$this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx,  $this->wmc_extent->miny, $this->wmc_extent->maxx, $this->wmc_extent->maxy);
-			  $res = db_prep_query($sql, $v, $t);
-			  if (db_error()) {
-				  $errMsg = "Error while saving WMC document '" . $this->wmc_title . "': " . db_error();
-				  $result["success"] = false;
-				  $result["message"] = $errMsg;
-				  $e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
-			  else {
-				// because the wmc id is created each time a wmc is instantiated $this->wmc_id has nothing to do with the database wmc_id
-				// this is some duct tape to fix it :-(
-				// see also above where wmc_DB_ID is defined if we need to update
+			$res = db_prep_query($sql, $v, $t);
+			if (db_error()) {
+				$errMsg = "Error while saving WMC document '" . $this->wmc_title . "': " . db_error();
+				$result["success"] = false;
+				$result["message"] = $errMsg;
+				$e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
+			else {
+			// because the wmc id is created each time a wmc is instantiated $this->wmc_id has nothing to do with the database wmc_id
+			// this is some duct tape to fix it :-(
+			// see also above where wmc_DB_ID is defined if we need to update
 				if(!isset($wmc_DB_ID)) { $wmc_DB_ID = $this->wmc_id; }
 				// update keywords
-					// if a keyword does not yet exist, create it
-			  		$keywordExistsSql = "SELECT keyword FROM keyword WHERE keyword = $1";
-				 	$keywordCreateSql = "INSERT INTO keyword (keyword) VALUES($1);";
-				 	$v = array($keyword);
-				 	$t = array("s");
-				 	$res =  db_prep_query($keywordExistsSql,$v,$t);
-				 	if(db_num_rows($res) == 0){
+				// if a keyword does not yet exist, create it
+					$keywordExistsSql = "SELECT keyword FROM keyword WHERE keyword = $1";
+					$keywordCreateSql = "INSERT INTO keyword (keyword) VALUES($1);";
+					$v = array($keyword);
+					$t = array("s");
+					$res =  db_prep_query($keywordExistsSql,$v,$t);
+					if(db_num_rows($res) == 0) {
 						$res = db_prep_query($keywordCreateSql,$v,$t);
-				 		if($a = db_error()){
+						if($a = db_error()) {
 					$keywordsql = "INSERT INTO wmc_keyword (fkey_keyword_id,fkey_wmc_id) SELECT keyword.keyword_id,$1 FROM keyword WHERE keyword = $2 AND NOT EXISTS (SELECT fkey_wmc_id FROM wmc_keyword	WHERE fkey_wmc_id = $3 );";
 					$v = array($wmc_DB_ID, $keyword,$wmc_DB_ID);
 					$t = array("s","s","s");
 					$res = db_prep_query($keywordsql, $v, $t);
 				// update categories
 				$this->inspireCats = $this->inspireCats? $this->inspireCats: array();
-				foreach($this->inspireCats as $catId)
+				foreach($this->inspireCats as $catId) {
 					$catSql = "INSERT INTO wmc_md_topic_category (fkey_wmc_id, fkey_md_topic_category_id) VALUES ($1,$2)";
 					$v = array($wmc_DB_ID, $catId);
 					$t = array("s","s");
 					$res = db_prep_query($catSql, $v, $t);
-				  $result["success"] = true;
-				  $msg = "WMC document '" . $this->wmc_title . "' has been saved.";
-				  $result["message"] = $msg;
-				  $e = new mb_notice("mod_insertWMCIntoDB: WMC  '" . $this->wmc_title . "' saved successfully.");
+				$result["success"] = true;
+				$msg = "WMC document '" . $this->wmc_title . "' has been saved.";
+				$result["message"] = $msg;
+				$e = new mb_notice("mod_insertWMCIntoDB: WMC  '" . $this->wmc_title . "' saved successfully.");
 		else {
@@ -727,25 +723,24 @@
 			$e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg .")");
-        db_commit();
+		db_commit();
 		return $result;
     * overwrites an exact version of a wmc in the database
-    public function update_existing($xml,$id)
-      $sql = "UPDATE mb_user_wmc SET wmc = $1 WHERE wmc_id = $2";
-      $v = array($xml,$id);
-      $t = array("s","i");
-      if(db_error()) { $e = new mb_exception("There was an error saving an updated WMC"); }
+	public function update_existing($xml,$id) {
+		$sql = "UPDATE mb_user_wmc SET wmc = $1 WHERE wmc_id = $2";
+		$v = array($xml,$id);
+		$t = array("s","i");
+		if(db_error()) { $e = new mb_exception("There was an error saving an updated WMC"); }
-	 * deletes a {@link http://www.mapbender.org/index.php/WMC WMC}
+	 * deletes a {@link http://www.mapbender.org/index.php/WMC WMC}
 	 * entry specified by wmc_id and user_id
 	 * @param	integer		the user_id
@@ -757,17 +752,16 @@
 			$userId = Mapbender::session()->get("mb_user_id");
-        try {
-          $user = new user($userId);
-        } catch (Exception $E) {
-          return $false;
-        if($user->isPublic())
-            return $false;
+		try {
+			$user = new user($userId);
+		} catch (Exception $E) {
+			return $false;
+		if($user->isPublic()) {
+			return $false;
 		$sql = "DELETE FROM mb_user_wmc ";
 		$sql .= "WHERE fkey_user_id = $1 AND wmc_id = $2";
 		$v = array($userId, $wmcId);
@@ -785,7 +779,7 @@
 	 * @param $id String the WMC id
 	public static function getDocument ($id) {
-		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 AND " .
+		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 AND " .
 			"(fkey_user_id = $2 OR wmc_public = 1)";
 		$v = array($id, Mapbender::session()->get("mb_user_id"));
 		$t = array('s', 'i');
@@ -803,7 +797,7 @@
 	public static function getDocumentByTitle ($title) {
-		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_title = $1 AND " .
+		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_title = $1 AND " .
 		$v = array($title, Mapbender::session()->get("mb_user_id"));
@@ -819,27 +813,26 @@
     * sets the WMC's public flag
     * @param $public boolean wether access should be public
-    public function setPublic($public)
-	  $currentUser = new User(Mapbender::session()->get("mb_user_id"));
-	  if ($currentUser->isPublic()) {
+	public function setPublic($public) {
+		$currentUser = new User(Mapbender::session()->get("mb_user_id"));
+		if ($currentUser->isPublic()) {
 			return false;
-      $wmcId = $this->wmc_Id;
-      $public = $public ? 1 :0;
-      $sql = "UPDATE mb_user_wmc SET wmc_public = $1 WHERE wmc_id = $2 AND fkey_user_id = $3;";
-      $v = array($public,$wmcId, $currentUser->id);
-      $t = array("i","s","i");
-      if(db_error()){
-        return false;
-      return true;
+		$wmcId = $this->wmc_Id;
+		$public = $public ? 1 :0;
+		$sql = "UPDATE mb_user_wmc SET wmc_public = $1 WHERE wmc_id = $2 AND fkey_user_id = $3;";
+		$v = array($public,$wmcId, $currentUser->id);
+		$t = array("i","s","i");
+		if(db_error()) {
+			return false;
+		return true;
 	// GETTER FUNCTIONS
 	 * @return string the title of the WMC.
@@ -850,16 +843,16 @@
 	private function getLayerWithoutIdArray () {
 		$layerWithoutWmsIdArray = array();
 		$layerWithoutLayerIdArray = array();
 		// check if WMS IDs exist
-			$currentWms = $wmsArray[$i];
+			$currentWms = $wmsArray[$i];
 			if (!is_numeric($currentWms[$currentId])) {
 				array_push($layerWithoutWmsIdArray, $currentId);
 		// check if layer IDs exist
 		for ($i = 0; $i < count($layerIdArray); $i++) {
 			$currentId = $layerIdArray[$i];
@@ -875,7 +868,7 @@
 	// OUTPUT FUNCTIONS
 	 * Wrapper function, returns XML at the moment
 	 * @return String
@@ -886,18 +879,18 @@
 	 * Returns the XML document if available
 	 * @return String The XML document; if unavailable, null is returned.
 	public function toXml () {
-//		if (!$this->xml) {
-			$this->createXml();
+	//		if (!$this->xml) {
+		$this->createXml();
 		return $this->xml;
 	private function incrementLoadCount ($wms) {
-		// counts how often a layer has been loaded
+	// counts how often a layer has been loaded
 		$monitor = new Layer_load_count();
 		foreach ($wms->objLayer as $l) {
 			$monitor->increment($l->layer_uid);
@@ -910,17 +903,17 @@
 		$wmcJsArray = array();
 			$wmcJsArray[] = $currentWms->createJsObjFromWMS_();
 			$this->incrementLoadCount($currentWms);
 		return $wmcJsArray;
 	public function featuretypeConfToJavaScript() {
 		$wfsConfIds = $this->generalExtensionArray['WFSCONFIDSTRING'];
 		$featuretypeConfs = array();
-		$featuretypeConfArray = is_string($wfsConfIds) ?
+		$featuretypeConfArray = is_string($wfsConfIds) ?
 			explode(",", $wfsConfIds) : array();
 		for ($i = 0; $i < count($featuretypeConfArray); $i++) {
 			$featuretypeConf = WfsConfiguration::createFromDb($featuretypeConfArray[$i]);
@@ -930,9 +923,32 @@
 		$featuretypeConfObj = $featuretypeConfObj->encode($featuretypeConfs);
 		return $featuretypeConfObj;
+	public function removeWms ($wmsIndexArray) {
+		$wmsArray = $this->mainMap->getWmsArray();
+		// remove WMS from overview map
+		if (!is_null($this->overviewMap)) {
+			$ovIndices = array();
+			$ovWmsArray = $this->overviewMap->getWmsArray();
+			for ($i = 0; $i < count($ovWmsArray); $i++) {
+				for ($j = 0; $j < count($wmsArray); $j++) {
+					if ($ovWmsArray[$i]->equals($wmsArray[$j]) && in_array($j, $skipWmsArray)) {
+						$ovIndices[]= $i;
+						break;
+			$this->overviewMap->removeWms($ovIndices);
+		// remove WMS from main map
+		$this->mainMap->removeWms($wmsIndexArray);
 	 * Returns an array of JavaScript statements
 	 * @return String[]
 	public function toJavaScript () {
@@ -947,13 +963,13 @@
 		// will contain the JS code to create the maps
 		// representing the state stored in this WMC
 		// set general extension data
 		if (count($this->generalExtensionArray) > 0) {
 			$json = new Mapbender_JSON();
-			array_push($wmcJsArray, "restoredWmcExtensionData = " . $json->encode($this->generalExtensionArray) . ";");
+			array_push($wmcJsArray, "restoredWmcExtensionData = " . $json->encode($this->generalExtensionArray) . ";");
 		// reset WMS data
 		array_push($wmcJsArray, "wms = [];");
 		array_push($wmcJsArray, "wms_layer_count = 0;");
@@ -971,8 +987,8 @@
 					if ($ovWmsArray[$i]->equals($wmsArray[$j]) && !in_array($j, $skipWmsArray)) {
-						$overviewWmsIndex = $j;
-						$wmsIndexOverview = $i;
+						$overviewWmsIndex = $j;
+						$wmsIndexOverview = $i;
 						break;
@@ -987,25 +1003,25 @@
 			array_push($wmcJsArray, $wmsArray[$i]->createJsObjFromWMS_());
 			$this->incrementLoadCount($wmsArray[$i]);
 		// delete existing map objects...
-//		array_push($wmcJsArray, "mb_mapObj = [];");
+		//		array_push($wmcJsArray, "mb_mapObj = [];");
 		// .. and add the overview map (if exists) and set map request
 		if ($this->overviewMap !== null) {
 			$wmcJsArray = array_merge(
-				$wmcJsArray,
+				$wmcJsArray,
 				$this->overviewMap->toJavaScript(
-					"{wms:wms,wmsIndexOverview:" . $overviewWmsIndex . "}"
+				"{wms:wms,wmsIndexOverview:" . $overviewWmsIndex . "}"
 		// .. and add main map ..
-			$wmcJsArray,
+			$wmcJsArray,
 			$this->mainMap->toJavaScript(
-				"{wms:wms,wmsIndexOverview:null}"
+			"{wms:wms,wmsIndexOverview:null}"
@@ -1013,38 +1029,38 @@
 			for ($i = 0; $i < count($ovWmsArray[$wmsIndexOverview]->objLayer); $i++) {
 				$visStr = "Mapbender.modules['".$this->overviewMap->getFrameName().
-//					"'].wms[" .$wmsIndexOverview . "].handleLayer(" .
-// The above doesn't work.
-// But there is only one WMS in the overview anyway! The index 0 is hard wired for now.
-					"'].wms[0].handleLayer(" .
-					"'" . $ovWmsArray[$wmsIndexOverview]->objLayer[$i]->layer_name . "', " .
-					"'visible', " .
+					//					"'].wms[" .$wmsIndexOverview . "].handleLayer(" .
+					// The above doesn't work.
+					// But there is only one WMS in the overview anyway! The index 0 is hard wired for now.
+					"'].wms[0].handleLayer(" .
+					"'" . $ovWmsArray[$wmsIndexOverview]->objLayer[$i]->layer_name . "', " .
+					"'visible', " .
 					($ovWmsArray[$wmsIndexOverview]->objLayer[$i]->gui_layer_visible ? 1 : 0) . ");";
 				array_push($wmcJsArray, $visStr);
 			array_push($wmcJsArray, "Mapbender.modules['".$this->overviewMap->getFrameName().
-					"'].restateLayers(" . $ovWmsArray[$wmsIndexOverview]->wms_id . ");");
+				"'].restateLayers(" . $ovWmsArray[$wmsIndexOverview]->wms_id . ");");
 		// .. request the map
 		array_push($wmcJsArray, "Mapbender.modules['".$this->mainMap->getFrameName().
-					"'].setMapRequest();");
+			"'].setMapRequest();");
 		array_push($wmcJsArray, "eventAfterLoadWMS.trigger();");
 		return $wmcJsArray;
 	// manipulation
 	 * Merges this WMC with another WMC.
 	 * The settings of the other WMC overwrite the settings of this WMC.
 	 * @return void
 	 * @param $xml2 Object
@@ -1060,7 +1076,7 @@
 	 * Appends the layers of another WMC to this WMC.
 	 * @return void
@@ -1070,24 +1086,24 @@
 		$this->mainMap->append($someWmc->mainMap);
 		if (isset($this->overviewMap) && isset($someWmc->overviewMap)) {
-			// There is only one WMS in the overview map; merge, not append
+		// There is only one WMS in the overview map; merge, not append
 			$this->overviewMap->merge($someWmc->overviewMap);
 	 * Adds a WMS to this WMC
-	 * @return
+	 * @return
 	public function appendWmsArray ($wmsArray) {
 		return $this->mainMap->appendWmsArray($wmsArray);
 	 * Merges a WMS into this WMC
-	 * @return
+	 * @return
 	public function mergeWmsArray ($wmsArray) {
 		if (func_num_args() > 1) {
@@ -1097,20 +1113,20 @@
 		return $this->mainMap->mergeWmsArray($wmsArray);
-// private functions
+	// private functions
 	 * Loads a WMC from an actual WMC XML document.
 	 * Uses WMS class.
 	 * @param string $data the data from the XML file
-	protected function createObjFromWMC_xml($data){
-		// store xml
+	protected function createObjFromWMC_xml($data) {
+	// store xml
 		$this->xml = $data;
 		$values = administration::parseXml($data);
 		if (!$values) {
 			throw new Exception("WMC document could not be parsed.");
@@ -1129,7 +1145,7 @@
 		$this->mainMap = new Map();
 		$this->overviewMap = null;
 		$this->generalExtensionArray = array();
 		$layerlistArray = array();
 		$layerlistArray["main"] = array();
 		$layerlistArray["overview"] = array();
@@ -1140,7 +1156,7 @@
 			$type = $element[type];
 			$attributes = $element[attributes];
 			$value = mb_utf8_decode(html_entity_decode($element[value]));
 			if ($tag == "VIEWCONTEXT" && $type == "open") {
 				$this->wmc_id = $attributes["id"];
 				$this->wmc_version = $attributes["version"];
@@ -1215,7 +1231,7 @@
 						if ($tag == "STATEORPROVINCE") {
 							$this->wmc_contactstateorprovince = $value;
-						if ($tag == "POSTCODE"){
+						if ($tag == "POSTCODE") {
 							$this->wmc_contactpostcode = $value;
 						if ($tag == "COUNTRY") {
@@ -1227,10 +1243,10 @@
 				if ($tag == "LOGOURL" && $type == "open") {
-						$logourl = true;
-						$this->wmc_logourl_width = $attributes["width"];
-						$this->wmc_logourl_height = $attributes["height"];
-						$this->wmc_logourl_format = $attributes["format"];
+					$logourl = true;
+					$this->wmc_logourl_width = $attributes["width"];
+					$this->wmc_logourl_height = $attributes["height"];
+					$this->wmc_logourl_format = $attributes["format"];
 				if ($logourl) {
 					if ($tag == "LOGOURL" && $type == "close") {
@@ -1242,11 +1258,11 @@
 				if ($tag == "DESCRIPTIONURL" && $type == "open") {
-						$descriptionurl = true;
-						$this->wmc_descriptionurl_format = $attributes["format"];
+					$descriptionurl = true;
+					$this->wmc_descriptionurl_format = $attributes["format"];
 				if ($descriptionurl) {
-					if ($tag == "DESCRIPTIONURL" && $type == "close"){
+					if ($tag == "DESCRIPTIONURL" && $type == "close") {
 						$descriptionurl = false;
 					if ($tag == "ONLINERESOURCE") {
@@ -1284,11 +1300,11 @@
 								$firstValue = $this->generalExtensionArray[$tag];
 								$this->generalExtensionArray[$tag] = array();
 								array_push($this->generalExtensionArray[$tag], $firstValue);
 							array_push($this->generalExtensionArray[$tag], $value);
 						else {
-							$this->generalExtensionArray[$tag] = $value;
+							$this->generalExtensionArray[$tag] = $value;
@@ -1296,22 +1312,22 @@
 					$generalExtension = true;
 				if ($tag == "GENERAL" && $type == "close") {
-		   			$general = false;
+					$general = false;
 			if ($layerlist) {
 				if ($tag == "LAYERLIST" && $type == "close") {
-				   $layerlist = false;
+					$layerlist = false;
 				if ($tag == "LAYER" && $type == "open") {
-					// The associative array currentLayer holds all
-					// data of the currently processed layer.
-					// The data will be set in the classes' WMS
-					// object when the layer tag is closed.
+				// The associative array currentLayer holds all
+				// data of the currently processed layer.
+				// The data will be set in the classes' WMS
+				// object when the layer tag is closed.
 					$currentLayer = array();
 					$currentLayer["queryable"] = $attributes["queryable"];
 					if ($attributes["hidden"] == "1") {
 						$currentLayer["visible"] = 0;
@@ -1326,47 +1342,47 @@
 				if ($layer) {
 					if ($tag == "LAYER" && $type == "close") {
-						// After a layer tag is closed,
-						// we have all necessary information to CREATE
-						// a layer object and append it to the WMS object
+					// After a layer tag is closed,
+					// we have all necessary information to CREATE
+					// a layer object and append it to the WMS object
 						if (isset($currentLayer["extension"]["OVERVIEWHIDDEN"])) {
-							array_push($layerlistArray["overview"], $currentLayer);
+							array_push($layerlistArray["overview"], $currentLayer);
 						$modifiedLayer = $currentLayer;
 						unset($modifiedLayer["extension"]["OVERVIEWHIDDEN"]);
-						array_push($layerlistArray["main"], $modifiedLayer);
-				 		$layer = false;
+						array_push($layerlistArray["main"], $modifiedLayer);
+						$layer = false;
 					if ($formatlist) {
 						if ($tag == "FORMAT") {
-						 	array_push($currentLayer["format"], array("current" => $attributes["current"], "name" => $value));
+							array_push($currentLayer["format"], array("current" => $attributes["current"], "name" => $value));
 							if ($attributes["current"] == "1") {
 								$currentLayer["formatIndex"] = count($currentLayer["format"]) - 1;
-						 if ($tag == "FORMATLIST" && $type == "close") {
-							 $formatlist = false;
-					 elseif ($metadataurl) {
+						if ($tag == "FORMATLIST" && $type == "close") {
+							$formatlist = false;
+					elseif ($metadataurl) {
 							$currentLayer["metadataurl"] = $attributes["xlink:href"];
 						if ($tag == "METADATAURL" && $type == "close") {
 							$metadataurl = false;
-					 elseif ($dataurl) {
+					elseif ($dataurl) {
-						 	$currentLayer["dataurl"] = $attributes["xlink:href"];
+							$currentLayer["dataurl"] = $attributes["xlink:href"];
-						 if ($tag == "DATAURL" && $type == "close") {
+						if ($tag == "DATAURL" && $type == "close") {
 							$dataurl = false;
-					 elseif ($stylelist) {
+					elseif ($stylelist) {
 						if ($style) {
 							$index = count($currentLayer["style"]) - 1;
 							if ($tag == "STYLE" && $type == "close") {
@@ -1388,7 +1404,7 @@
 							else {
-								if ($tag == "NAME"){
+								if ($tag == "NAME") {
 									$currentLayer["style"][$index]["name"] = $value ? $value : "default";
 								if ($tag == "TITLE") {
@@ -1399,15 +1415,15 @@
 										$legendurl = false;
-									 	$currentLayer["style"][$index]["legendurl_type"] = $attributes["xlink:type"];
-									 	$currentLayer["style"][$index]["legendurl"] = $attributes["xlink:href"];
+										$currentLayer["style"][$index]["legendurl_type"] = $attributes["xlink:type"];
+										$currentLayer["style"][$index]["legendurl"] = $attributes["xlink:href"];
 								if ($tag == "LEGENDURL" && $type == "open") {
-								 	$legendurl = true;
-								 	$currentLayer["style"][$index]["legendurl_width"] = $attributes["width"];
-								 	$currentLayer["style"][$index]["legendurl_height"] = $attributes["height"];
-								 	$currentLayer["style"][$index]["legendurl_format"] = $attributes["format"];
+									$legendurl = true;
+									$currentLayer["style"][$index]["legendurl_width"] = $attributes["width"];
+									$currentLayer["style"][$index]["legendurl_height"] = $attributes["height"];
+									$currentLayer["style"][$index]["legendurl_format"] = $attributes["format"];
@@ -1424,48 +1440,48 @@
 					else {
 						if ($tag == "SERVER" && $type == "open") {
-							 $server = true;
-							 $currentLayer["service"] = $attributes["service"];
-							 $currentLayer["version"] = $attributes["version"];
-							 $currentLayer["wms_title"] = $attributes["title"];
+							$server = true;
+							$currentLayer["service"] = $attributes["service"];
+							$currentLayer["version"] = $attributes["version"];
+							$currentLayer["wms_title"] = $attributes["title"];
 						if ($server) {
 							if ($tag == "SERVER" && $type == "close") {
-						 		$server = false;
+								$server = false;
-						 		$currentLayer["url"] = $attributes["xlink:href"];
+								$currentLayer["url"] = $attributes["xlink:href"];
-					 		$currentLayer["name"] = $value;
+							$currentLayer["name"] = $value;
-					 		$currentLayer["title"] = $value;
+							$currentLayer["title"] = $value;
 						if ($tag == "ABSTRACT") {
-					 		$currentLayer["abstract"] = $value;
+							$currentLayer["abstract"] = $value;
 						if ($tag == "SRS") {
-							$currentLayer["epsg"] = explode(" ", $value);
+							$currentLayer["epsg"] = explode(" ", $value);
 						if ($tag == "EXTENSION" && $type == "close") {
 							$extension = false;
-						if ($extension == true){
-//							if ($value !== "") {
-								if (isset($currentLayer["extension"][$tag])) {
-									if (!is_array($currentLayer["extension"][$tag])) {
-										$firstValue = $currentLayer["extension"][$tag];
-										$currentLayer["extension"][$tag] = array();
-										array_push($currentLayer["extension"][$tag], $firstValue);
-									array_push($currentLayer["extension"][$tag], $value);
+						if ($extension == true) {
+						//							if ($value !== "") {
+							if (isset($currentLayer["extension"][$tag])) {
+								if (!is_array($currentLayer["extension"][$tag])) {
+									$firstValue = $currentLayer["extension"][$tag];
+									$currentLayer["extension"][$tag] = array();
+									array_push($currentLayer["extension"][$tag], $firstValue);
-								else {
-									$currentLayer["extension"][$tag] = $value;
+								array_push($currentLayer["extension"][$tag], $value);
+							else {
+								$currentLayer["extension"][$tag] = $value;
 						if ($tag == "EXTENSION" && $type == "open") {
 							$currentLayer["extension"] = array();
@@ -1487,9 +1503,9 @@
 		// set WMS data
 		$layerlistCompleteArray = array_merge($layerlistArray["main"], $layerlistArray["overview"]);
 		for ($i = 0; $i < count($layerlistCompleteArray); $i++) {
@@ -1505,17 +1521,17 @@
 	 * Saves the current WMC in the log folder.
 	 * @return string the filename of the WMC document.
 	private function saveAsFile() {
 		if ($this->saveWmcAsFile) {
 			$filename = "wmc_" . date("Y_m_d_H_i_s") . ".xml";
 			$logfile = "../tmp/" . $filename;
-			if($h = fopen($logfile,"a")){
+			if($h = fopen($logfile,"a")) {
 				$content = $this->xml;
-				if(!fwrite($h,$content)){
+				if(!fwrite($h,$content)) {
 					$e = new mb_exception("class_wmc.php: failed to write wmc.");
 					return false;
@@ -1526,11 +1542,11 @@
 		return null;
 	 * Called during WMC parsing; sets the data of a single layer.
-	 * @return
+	 * @return
 	 * @param $currentLayer Array an associative array with layer data
 	private function setLayerData ($currentLayer) {
@@ -1558,30 +1574,30 @@
 		// find last WMS with the same online resource
 		for ($i = count($wmsArray) - 1; $i >= 0; $i--) {
-			if (isset($currentLayer["url"]) &&
+			if (isset($currentLayer["url"]) &&
 				$currentLayer["url"] == $wmsArray[$i]->wms_getmap) {
-					$wmsIndex = $i;
-					break;
+				$wmsIndex = $i;
+				break;
 		// Even if this WMS has been found before it could still
-		// be a duplicate! We would have to create a new WMS and
+		// be a duplicate! We would have to create a new WMS and
 		// not append this layer to that WMS.
 		// For the overview layer we never add a new wms.
 		// check if this layer is an overview layer. If yes, skip this layer.
 		if ($wmsIndex !== null && !$currentMapIsOverview) {
-			// check if this WMS has a layer equal to the current layer.
-			// If yes, this is a new WMS. If not, append this layer
-			// to the existing WMS.
+		// check if this WMS has a layer equal to the current layer.
+		// If yes, this is a new WMS. If not, append this layer
+		// to the existing WMS.
 			$matchingWmsLayerArray = $this->wmsArray[$wmsIndex]->objLayer;
 			for ($i = 0; $i < count($matchingWmsLayerArray); $i++) {
 				if ($matchingWmsLayerArray[$i]->layer_name == $currentLayer["name"]) {
-					// by re-setting the index to null, a new WMS will be
-					// added below.
+				// by re-setting the index to null, a new WMS will be
+				// added below.
 					$wmsIndex = null;
 					break;
@@ -1602,7 +1618,7 @@
 			$wms->wms_abstract = $currentLayer["abstract"];
 			$wms->wms_getmap = $currentLayer["url"];
 			$wms->wms_getfeatureinfo = $currentLayer["url"]; // TODO : Add correct data
 			$styleIndex = $currentLayer["styleIndex"];
 			$wms->wms_getlegendurl = $currentLayer["style"][$styleIndex]["legendurl"];
@@ -1623,8 +1639,8 @@
 			// set data formats
 			for ($i = 0; $i < count($currentLayer["format"]); $i++) {
-				array_push($wms->data_type, "map");
-				array_push($wms->data_format, $currentLayer["format"][$i]["name"]);
+				array_push($wms->data_type, "map");
+				array_push($wms->data_format, $currentLayer["format"][$i]["name"]);
 			// add WMS
@@ -1640,14 +1656,14 @@
 		$currentMap->setWmsArray($wmsArray);
 		return true;
 	 * Called during WMC parsing; sets the maps within a WMC.
-	 * @return
+	 * @return
 	private function setMapData () {
-		if ($this->generalExtensionArray["OV_WIDTH"] &&
+		if ($this->generalExtensionArray["OV_WIDTH"] &&
 			$this->generalExtensionArray["OV_HEIGHT"] &&
 			$this->generalExtensionArray["OV_FRAMENAME"] &&
 			$this->generalExtensionArray["OV_MINX"] &&
@@ -1655,31 +1671,31 @@
 			$this->generalExtensionArray["OV_MAXX"] &&
 			$this->generalExtensionArray["OV_MAXY"] &&
 			$this->generalExtensionArray["OV_SRS"]) {
 			$this->overviewMap = new Map();
 			$this->overviewMap->setWidth(
 				// this should not be an array, but sometimes it is.
 				// I can't find the reason at the moment, consider
 				// this a workaround
 				is_array($this->generalExtensionArray["OV_WIDTH"]) ?
-					$this->generalExtensionArray["OV_WIDTH"][0] :
+				$this->generalExtensionArray["OV_WIDTH"][0] :
 			$this->overviewMap->setHeight(
-				is_array($this->generalExtensionArray["OV_HEIGHT"]) ?
-					$this->generalExtensionArray["OV_HEIGHT"][0] :
+				is_array($this->generalExtensionArray["OV_HEIGHT"]) ?
+				$this->generalExtensionArray["OV_HEIGHT"][0] :
 			$this->overviewMap->setFrameName(
 				is_array($this->generalExtensionArray["OV_FRAMENAME"]) ?
-					$this->generalExtensionArray["OV_FRAMENAME"][0] :
+				$this->generalExtensionArray["OV_FRAMENAME"][0] :
 			$this->overviewMap->setIsOverview(true);
@@ -1693,10 +1709,10 @@
 			$bbox = new Mapbender_bbox($this->generalExtensionArray["OV_MINX"], $this->generalExtensionArray["OV_MINY"], $this->generalExtensionArray["OV_MAXX"], $this->generalExtensionArray["OV_MAXY"], $this->generalExtensionArray["OV_SRS"]);
 			$this->overviewMap->setExtent($bbox);
-		if ($this->generalExtensionArray["EPSG"] &&
-			$this->generalExtensionArray["MINX"] &&
-			$this->generalExtensionArray["MINY"] &&
-			$this->generalExtensionArray["MAXX"] &&
+		if ($this->generalExtensionArray["EPSG"] &&
+			$this->generalExtensionArray["MINX"] &&
+			$this->generalExtensionArray["MINY"] &&
+			$this->generalExtensionArray["MAXX"] &&
 			$this->generalExtensionArray["MAXY"]) {
 			$mainEpsgArray = array();
@@ -1721,13 +1737,13 @@
 			for ($i=0; $i < count($mainEpsgArray); $i++) {
 				$box = new Mapbender_bbox(
-					floatval($mainMinXArray[$i]), floatval($mainMinYArray[$i]),
+					floatval($mainMinXArray[$i]), floatval($mainMinYArray[$i]),
 					floatval($mainMaxXArray[$i]), floatval($mainMaxYArray[$i]),
 					$mainEpsgArray[$i]
 				$this->mainMap->addZoomFullExtent($box);
 		if ($this->generalExtensionArray["MAIN_FRAMENAME"]) {
 			$this->mainMap->setFrameName(
@@ -1735,8 +1751,8 @@
 				is_array($this->generalExtensionArray["MAIN_FRAMENAME"]) ?
-					$this->generalExtensionArray["MAIN_FRAMENAME"][0] :
+				$this->generalExtensionArray["MAIN_FRAMENAME"][0] :
 		else {
@@ -1747,7 +1763,7 @@
 	 * Creates a WMC document (XML) from the current object
 	 * @return String XML
 	private function createXml() {
More information about the Mapbender_commits mailing list
