[Mapbender-commits] r6996 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 1 09:37:05 EDT 2010
Author: armin11
Date: 2010-10-01 13:37:05 +0000 (Fri, 01 Oct 2010)
New Revision: 6996
   trunk/mapbender/http/php/mod_showMetadata.php
bugfixing
Modified: trunk/mapbender/http/php/mod_showMetadata.php
--- trunk/mapbender/http/php/mod_showMetadata.php	2010-10-01 13:29:34 UTC (rev 6995)
+++ trunk/mapbender/http/php/mod_showMetadata.php	2010-10-01 13:37:05 UTC (rev 6996)
@@ -26,7 +26,7 @@
 //id: integer
 //outputFormat: html, xml, georss,
 //languageCode: de, en, fr
-$layout = 'accordion';
+$layout = 'tabs';
 //Parse REQUEST Parameters
 if (isset($_REQUEST["resource"]) & $_REQUEST["resource"] != "") {
 	//validate to csv integer list
@@ -199,9 +199,11 @@
 		$translation['originalCapabilities'] = 'Original Capabilities';
 		$translation['kml'] = 'KML';
 		$translation['inspireMetadata'] = 'INSPIRE Service Metadata';
+		$translation['showInspireMetadata'] = 'Metadatendatei';
 		$translation['securedCapabilities'] = 'Secured Capabilities URL';
-		$translation['capabilities'] = 'Link to OWS capabilities document';
-		$translation['inspireMetadataValidation'] = 'Validate against INSPIRE Geoportal';
+		$translation['capabilities'] = 'Link zum Capabilities Dokument';
+		$translation['inspireMetadataValidation'] = 'Validation against INSPIRE Geoportal';
+		$translation['showInspireMetadataValidation'] = 'Start Validation';
 		$translation['statusOK'] = 'stable';
 		$translation['statusChanged'] = 'Description changed - update necessary';
 		$translation['statusProblem'] = 'Problem at last control';
@@ -250,18 +252,17 @@
 		$translation['contactTelephone'] = 'Telephon';
 //Array with infos about the different elements which are shown in the tabs
 //Check if an id and a resource was given
@@ -464,7 +465,7 @@
 	$html .= '<link type="text/css" href="../css/metadataNew.css" rel="Stylesheet" />';
 if ($layout == 'tabs') {
-	$html .= '<link type="text/css" href="../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.4.custom.css" rel="Stylesheet" />';
+	$html .= '<link type="text/css" href="../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.5.custom.css" rel="Stylesheet" />';
 	$html .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-1.4.2.min.js"></script>';
 	$html .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-ui-1.8.1.custom.min.js"></script>';
More information about the Mapbender_commits mailing list
