[Mapbender-commits] r7071 - trunk/mapbender/test/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Oct 28 07:55:22 EDT 2010
Author: christoph
Date: 2010-10-28 04:55:22 -0700 (Thu, 28 Oct 2010)
New Revision: 7071
Added:
   trunk/mapbender/test/http/classes/Gml3FactoryTst.php
renamed file because it breaks the build (will be fixed later)
Copied: trunk/mapbender/test/http/classes/Gml3FactoryTst.php (from rev 7060, trunk/mapbender/test/http/classes/Gml3FactoryTest.php)
--- trunk/mapbender/test/http/classes/Gml3FactoryTst.php	                        (rev 0)
+++ trunk/mapbender/test/http/classes/Gml3FactoryTst.php	2010-10-28 11:55:22 UTC (rev 7071)
@@ -0,0 +1,128 @@
+<?php
+require_once 'PHPUnit/Framework.php';
+require_once dirname(__FILE__) . "/../../../http/classes/class_gml_3_factory.php";
+class Gml3FactoryTest extends PHPUnit_Framework_TestCase {
+	protected $gml3Factory;
+	protected $geoJsonPolygonDonut;
+	public function setUp () {
+		$this->geoJsonPolygonDonut = dirname(__FILE__) . "/../../data/polygonDonut.json";
+		$this->gml3PolygonDonut = dirname(__FILE__) . "/../../data/polygonDonut.gml3.xml";
+                $this->geoJsonLine = dirname(__FILE__) . "/../../data/line.json";
+		$this->gml3Line = dirname(__FILE__) . "/../../data/line.gml3.xml";
+                $this->geoJsonPoint = dirname(__FILE__) . "/../../data/point.json";
+		$this->gml3Point = dirname(__FILE__) . "/../../data/point.gml3.xml";
+                $this->geoJsonPolygon = dirname(__FILE__) . "/../../data/polygon.json";
+		$this->gml3Polygon = dirname(__FILE__) . "/../../data/polygon.gml3.xml";
+                $this->geoJsonMultiPolygon = dirname(__FILE__) . "/../../data/multipolygon.json";
+		$this->gml3MultiPolygon = dirname(__FILE__) . "/../../data/multipolygon.gml3.xml";
+                $this->geoJsonMultiLine = dirname(__FILE__) . "/../../data/multiline.json";
+		$this->gml3MultiLine = dirname(__FILE__) . "/../../data/multiline.gml3.xml";
+                $this->geoJsonMultiPoint = dirname(__FILE__) . "/../../data/multipoint.json";
+		$this->gml3MultiPoint = dirname(__FILE__) . "/../../data/multipoint.gml3.xml";
+                $this->gml3PolygonDonutNoWhiteSpace = dirname(__FILE__) . "/../../data/polygonDonutNoWhiteSpace.gml3.xml";
+		$this->gml3Factory = new Gml_3_Factory();
+	public function testRemoveWhiteSpace () {
+		$gml3 = file_get_contents($this->gml3PolygonDonut);
+		$expectedGml3 = file_get_contents($this->gml3PolygonDonutNoWhiteSpace);
+		$this->assertEquals(
+			$expectedGml3,
+			$this->gml3Factory->removeWhiteSpace($gml3)
+	public function testGeoJsonToGml3PolygonDonut() {
+		$geoJson = file_get_contents($this->geoJsonPolygonDonut);
+		$expectedGml3 = file_get_contents($this->gml3PolygonDonut);
+		$gmlObj = $this->gml3Factory->createFromGeoJson($geoJson);
+			$this->gml3Factory->removeWhiteSpace($expectedGml3),
+			$gmlObj->toGml()
+        public function testGeoJsonToGml3Line() {
+		$geoJson = file_get_contents($this->geoJsonLine);
+		$expectedGml3 = file_get_contents($this->gml3Line);
+			$gmlObj->toGml()
+        public function testGeoJsonToGml3Point() {
+		$geoJson = file_get_contents($this->geoJsonPoint);
+		$expectedGml3 = file_get_contents($this->gml3Point);
+			$gmlObj->toGml()
+        public function testGeoJsonToGml3Polygon() {
+		$geoJson = file_get_contents($this->geoJsonPolygon);
+		$expectedGml3 = file_get_contents($this->gml3Polygon);
+			$gmlObj->toGml()
+        public function testGeoJsonToGml3MultiPolygon() {
+		$geoJson = file_get_contents($this->geoJsonMultiPolygon);
+		$expectedGml3 = file_get_contents($this->gml3MultiPolygon);
+			$gmlObj->toGml()
+        public function testGeoJsonToGml3MultiPoint() {
+		$geoJson = file_get_contents($this->geoJsonMultiPoint);
+		$expectedGml3 = file_get_contents($this->gml3MultiPoint);
+			$gmlObj->toGml()
+        public function testGeoJsonToGml3MultiLine() {
+		$geoJson = file_get_contents($this->geoJsonMultiLine);
+		$expectedGml3 = file_get_contents($this->gml3MultiLine);
+			$gmlObj->toGml()
\ No newline at end of file
More information about the Mapbender_commits mailing list
