[Mapbender-commits] r6871 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Sep 2 04:44:28 EDT 2010
Author: christoph
Date: 2010-09-02 08:44:28 +0000 (Thu, 02 Sep 2010)
New Revision: 6871
Added:
   trunk/mapbender/http/plugins/mb_sql.js
   trunk/mapbender/http/plugins/mb_sql_server.php
http://trac.osgeo.org/mapbender/ticket/702
Added: trunk/mapbender/http/plugins/mb_sql.js
--- trunk/mapbender/http/plugins/mb_sql.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_sql.js	2010-09-02 08:44:28 UTC (rev 6871)
@@ -0,0 +1,51 @@
+ * Package: sql
+ * Description:
+ * Exports the current application as SQL
+ * Files:
+ *  - http/plugins/mb_sql.js
+ *  - http/plugins/mb_sql_server.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('test_sql','sql',1,1,'','Export to SQL','a','','href=''#''',900,20,NULL ,NULL ,NULL ,'','Export to SQL','a','../plugins/mb_sql.js','','','jq_ui_dialog','');
+ * Help:
+ * http://www.mapbender.org/<wiki site name>
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $sql = $(this);
+var SqlApi = function (o) {
+	$sql.bind("click", function () {
+		var req = new Mapbender.Ajax.Request({
+			url: "../plugins/mb_sql_server.php",
+			method: "sql",
+			parameters: {
+				applicationId: Mapbender.application
+			callback: function (obj, result, message) {
+				if (!result) {
+					alert(message);
+					return;
+				$("<textarea />").attr({
+					"title": "SQL of application '" + Mapbender.application + "'"
+				}).text(obj.sql).dialog();
+		req.send();
+$sql.mapbender(new SqlApi(options));
Added: trunk/mapbender/http/plugins/mb_sql_server.php
--- trunk/mapbender/http/plugins/mb_sql_server.php	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_sql_server.php	2010-09-02 08:44:28 UTC (rev 6871)
@@ -0,0 +1,41 @@
+<?php
+# License:
+# Copyright (c) 2009, Open Source Geospatial Foundation
+# This program is dual licensed under the GNU General Public License
+# and Simplified BSD license.
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once dirname(__FILE__) . "/../php/mb_validateSession.php";
+require_once dirname(__FILE__) . "/../classes/class_gui.php";
+require_once dirname(__FILE__) . "/../classes/class_user.php";
+$ajaxResponse = new AjaxResponse($_POST);
+switch ($ajaxResponse->getMethod()) {
+	case "sql" :
+		$application = new gui($ajaxResponse->getParameter("applicationId"));
+		$user = new User();
+		$apps = $user->getApplicationsByPermission();
+		if (in_array($application->id, $apps)) {
+			$sql = $application->toSql();
+			$resultObj = array(
+				"sql" => $sql
+			$ajaxResponse->setResult($resultObj);
+			$ajaxResponse->setSuccess(true);
+			break;
+		$ajaxResponse->setSuccess(false);
+		$ajaxResponse->setMessage(_mb("You are not allowed to access this application."));
+		break;
+	default:
+		$ajaxResponse->setMessage(_mb("An unknown error occured."));
+		break;
+$ajaxResponse->send();
\ No newline at end of file
More information about the Mapbender_commits mailing list
