[Mapbender-commits] r6875 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Thu Sep 2 11:45:31 EDT 2010
Author: christoph
Date: 2010-09-02 15:45:31 +0000 (Thu, 02 Sep 2010)
New Revision: 6875
trunk/mapbender/http/javascripts/mod_legend.php
added intval to parse top and left
Modified: trunk/mapbender/http/javascripts/mod_legend.php
--- trunk/mapbender/http/javascripts/mod_legend.php 2010-09-02 09:01:06 UTC (rev 6874)
+++ trunk/mapbender/http/javascripts/mod_legend.php 2010-09-02 15:45:31 UTC (rev 6875)
@@ -53,8 +53,8 @@
$res2 = db_prep_query($sql2, $v, $t);
echo "<script type='text/javascript'>\n";
echo "var mod_legend_target = '".$e_target."';\n";
-echo "var mod_legend_target_left = ".db_result($res2,0,"e_left").";\n";
-echo "var mod_legend_target_top = ".db_result($res2,0,"e_top").";\n";
+echo "var mod_legend_target_left = ".intval(db_result($res2,0,"e_left")).";\n";
+echo "var mod_legend_target_top = ".intval(db_result($res2,0,"e_top")).";\n";
//echo "var mod_legend_target_width = ".db_result($res2,0,"e_width").";\n";
//echo "var mod_legend_target_height = ".db_result($res2,0,"e_height").";\n";
echo "</script>\n";
@@ -69,39 +69,6 @@
var checkbox_on_off = typeof checkbox_on_off === "undefined" ? 'false' : checkbox_on_off;
var stickylegend = typeof stickylegend === "undefined" ? "false" : stickylegend;
-// Todo: return-value may change in the next version....
-parent.eventAfterMapRequest.register(function (obj) {
- mod_legend_pos(obj.map.elementName)
-function mod_legend_init(){
- var obj = parent.document.getElementById("legend");
-// obj.style.top = mod_legend_target_top + mod_legend_offsetTop;
-// obj.style.left = mod_legend_target_left + mod_legend_target_width + mod_legend_offsetLeft;
- var checkobj = document.getElementById("checkboxstyle");
- if (checkbox_on_off == 'false'){
- checkobj.style.display = "none";
- checkobj.style.width = 0;
- checkobj.style.height = 0;
- if (parent.Mapbender.events.init.done) {
- mod_legend_pos(mod_legend_target);
- else {
- parent.Mapbender.events.init.register(function () {
-function mod_legend_repaint(obj){
- if(checkobj.style.display == "block"){
function mod_legend_pos(frameName){
if(frameName == mod_legend_target){
var ind = parent.getMapObjIndexByName(mod_legend_target);
@@ -172,6 +139,39 @@
+// Todo: return-value may change in the next version....
+parent.eventAfterMapRequest.register(function (obj) {
+// mod_legend_pos(obj.map.elementName)
+function mod_legend_init(){
+ var obj = parent.document.getElementById("legend");
+// obj.style.top = mod_legend_target_top + mod_legend_offsetTop;
+// obj.style.left = mod_legend_target_left + mod_legend_target_width + mod_legend_offsetLeft;
+ var checkobj = document.getElementById("checkboxstyle");
+ if (checkbox_on_off == 'false'){
+ checkobj.style.display = "none";
+ checkobj.style.width = 0;
+ checkobj.style.height = 0;
+ if (parent.Mapbender.events.init.done) {
+ mod_legend_pos(mod_legend_target);
+ else {
+ parent.Mapbender.events.init.register(function () {
+function mod_legend_repaint(obj){
+ if(checkobj.style.display == "block"){
</script>
More information about the Mapbender_commits
