[Mapbender-commits] r6877 - trunk/mapbender/http/extensions/jquery.layout.all-1.2.0
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Sep 2 11:46:36 EDT 2010
Author: christoph
Date: 2010-09-02 15:46:36 +0000 (Thu, 02 Sep 2010)
New Revision: 6877
Added:
   trunk/mapbender/http/extensions/jquery.layout.all-1.2.0/jquery.layout.css
default css
Added: trunk/mapbender/http/extensions/jquery.layout.all-1.2.0/jquery.layout.css
--- trunk/mapbender/http/extensions/jquery.layout.all-1.2.0/jquery.layout.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.layout.all-1.2.0/jquery.layout.css	2010-09-02 15:46:36 UTC (rev 6877)
@@ -0,0 +1,119 @@
+ * Default Layout Theme
+ * Created for jquery.layout
+ * Copyright (c) 2010
+ *   Fabrizio Balliano (http://www.fabrizioballiano.net)
+ *   Kevin Dalman (http://allpro.net)
+ * Dual licensed under the GPL (http://www.gnu.org/licenses/gpl.html)
+ * and MIT (http://www.opensource.org/licenses/mit-license.php) licenses.
+ * Last Updated: 2010-02-10
+ * NOTE: For best code readability, view this with a fixed-space font and tabs equal to 4-chars
+ *	PANES & CONTENT-DIVs
+.ui-layout-pane { /* all 'panes' */
+	background:	#FFF;
+	border:		1px solid #BBB;
+	/* DO NOT add scrolling (or padding) to 'panes' that have a content-div,
+	   otherwise you may get double-scrollbars - on the pane AND on the content-div
+	padding:	5px;
+	overflow:	hidden;
+	/* (scrolling) content-div inside pane allows for fixed header(s) and/or footer(s) */
+	.ui-layout-content {
+		padding:	10px;
+		position:	relative; /* contain floated or positioned elements */
+		overflow:	auto; /* add scrolling to content-div */
+ *	RESIZER-BARS
+.ui-layout-resizer	{ /* all 'resizer-bars' */
+	background:		#DDD;
+	border-width:	0;
+	.ui-layout-resizer-drag {		/* REAL resizer while resize in progress */
+	.ui-layout-resizer-hover	{	/* affects both open and closed states */
+	/* NOTE: It looks best when 'hover' and 'dragging' are set to the same color,
+		otherwise color shifts while dragging when bar can't keep up with mouse */
+	.ui-layout-resizer-open-hover ,	/* hover-color to 'resize' */
+	.ui-layout-resizer-dragging {	/* resizer beging 'dragging' */
+		background: #C4E1A4;
+	.ui-layout-resizer-dragging {	/* CLONED resizer being dragged */
+		border-left:  1px solid #BBB;
+		border-right: 1px solid #BBB;
+	/* NOTE: Add a 'dragging-limit' color to provide visual feedback when resizer hits min/max size limits */
+	.ui-layout-resizer-dragging-limit {	/* CLONED resizer at min or max size-limit */
+		background: #E1A4A4; /* red */
+	.ui-layout-resizer-closed-hover	{ /* hover-color to 'slide open' */
+		background: #EBD5AA;
+	.ui-layout-resizer-sliding {	/* resizer when pane is 'slid open' */
+		opacity: .10; /* show only a slight shadow */
+		filter:  alpha(opacity=10);
+		.ui-layout-resizer-sliding-hover {	/* sliding resizer - hover */
+			opacity: 1.00; /* on-hover, show the resizer-bar normally */
+			filter:  alpha(opacity=100);
+		/* sliding resizer - add 'outside-border' to resizer on-hover
+		 * this sample illustrates how to target specific panes and states */
+		.ui-layout-resizer-north-sliding-hover	{ border-bottom-width:	1px; }
+		.ui-layout-resizer-south-sliding-hover	{ border-top-width:		1px; }
+		.ui-layout-resizer-west-sliding-hover	{ border-right-width:	1px; }
+		.ui-layout-resizer-east-sliding-hover	{ border-left-width:	1px; }
+ *	TOGGLER-BUTTONS
+.ui-layout-toggler {
+	border: 1px solid #BBB; /* match pane-border */
+	background-color: #BBB;
+	.ui-layout-resizer-hover .ui-layout-toggler {
+		opacity: .60;
+		filter:  alpha(opacity=60);
+	.ui-layout-resizer-hover .ui-layout-toggler-hover { /* need specificity */
+		background-color: #FC6;
+		opacity: 1.00;
+	.ui-layout-toggler-north ,
+	.ui-layout-toggler-south {
+		border-width: 0 1px; /* left/right borders */
+	.ui-layout-toggler-west ,
+	.ui-layout-toggler-east {
+		border-width: 1px 0; /* top/bottom borders */
+	/* hide the toggler-button when the pane is 'slid open' */
+	.ui-layout-resizer-sliding  ui-layout-toggler {
+		display: none;
+	 *	style the text we put INSIDE the togglers
+	.ui-layout-toggler .content {
+		color:			#666;
+		font-size:		12px;
+		font-weight:	bold;
+		width:			100%;
+		padding-bottom:	0.35ex; /* to 'vertically center' text inside text-span */
More information about the Mapbender_commits mailing list
