[Mapbender-commits] r6894 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Sep 3 10:54:54 EDT 2010
Author: christoph
Date: 2010-09-03 14:54:54 +0000 (Fri, 03 Sep 2010)
New Revision: 6894
trunk/mapbender/http/javascripts/map.php
trim and check if target exists before adding to options.$targets
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php 2010-09-03 14:54:24 UTC (rev 6893)
+++ trunk/mapbender/http/javascripts/map.php 2010-09-03 14:54:54 UTC (rev 6894)
@@ -199,7 +199,7 @@
echo "Mapbender.modules." . $e_id . " = " . $elementAttributes . ";\n";
echo "var t = Mapbender.modules." . $e_id . ".target;";
- echo "var sel = [];for (var k in t) {sel.push($('#' + t[k]).get(0))}\n";
+ echo "var sel = [];for (var k in t) {t[k] = $.trim(t[k]);if($('#' + t[k]).size() > 0) {sel.push($('#' + t[k]).get(0))}}\n";
echo "Mapbender.modules." . $e_id . ".\$target = sel.length > 0 ? \$(sel) : $([]);\n";
echo "$('#" . $e_id . "').data('api', Mapbender.modules." . $e_id . ");";
More information about the Mapbender_commits
